svn commit: r40 - trunk/www
gregboone at osgeo.org gregboone at osgeo.org
Fri Jul 21 21:25:03 EDT 2006
Author: gregboone
Date: 2006-07-22 01:25:03+0000
New Revision: 40
   trunk/www/documentation.html
   trunk/www/index.html
FDO2
Modified: trunk/www/documentation.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/documentation.html?view=diff&rev=40&p1=trunk/www/documentation.html&p2=trunk/www/documentation.html&r1=39&r2=40
--- trunk/www/documentation.html	(original)
+++ trunk/www/documentation.html	2006-07-22 01:25:03+0000
@@ -8,9 +8,9 @@
 <h1>Feature Data Objects  - Documentation</h1>
 <div class="h2">
 <h2>Getting Started </h2>
-<p><a href="docs/BuildFDOOpenSource.pdf" target="_blank">Building FDO Open Source</a>&nbsp;[PDF]</p>
-<p><a href="docs/OpenSourceBuild__README.html" target="_blank">OpenSourceBuild_README</a>&nbsp;</p>
-<p><a href="docs/FET_TheEssentialFDO.pdf" target="_blank">The Essential FDO</a>&nbsp;[PDF]</p>
+<p><a href="docs/OpenSourceBuild__README.html" target="_blank">OpenSourceBuild_README</a>&nbsp;[HTML]</p>
+<p><a href="nonav/docs/BuildFDOOpenSource/index.html" target="_blank">Building FDO Open Source</a>&nbsp;<a href="nonav/docs/BuildFDOOpenSource/index.html" target="_blank">[HTML]</a>&nbsp;<a href="docs/BuildFDOOpenSource.pdf" target="_blank">[PDF]</a>&nbsp;</p>
+<p><a href="nonav/docs/FET_TheEssentialFDO/index.html" target="_blank">The Essential FDO</a>&nbsp;<a href="nonav/docs/FET_TheEssentialFDO/index.html" target="_blank">[HTML]</a>&nbsp;<a href="docs/FET_TheEssentialFDO.pdf" target="_blank">[PDF]</a>&nbsp;</p>
 </div>
 <div class="h2">
 <h2>Developer Reference</h2>
Modified: trunk/www/index.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/index.html?view=diff&rev=40&p1=trunk/www/index.html&p2=trunk/www/index.html&r1=39&r2=40
--- trunk/www/index.html	(original)
+++ trunk/www/index.html	2006-07-22 01:25:03+0000
@@ -44,16 +44,6 @@
 			GIS (Geographic Information System) data.
 			</p>
 			<p>
-			FDO Geometry is based on the
-			<a href="http://portal.opengeospatial.org/files/?artifact_id=829">OpenGIS Simple Features Implementation Specification for SQL</a>
-			(version 1.1, document 99-049),
-			but is extended to include z and measure dimensions and circular arcs.
-			The FDO XML format for schema is based on the
-			<a href="http://portal.opengeospatial.org/files/?artifact_id=1034">Open GIS Consortium Geography Markup Language</a> (version 2.1.1, document 02-009).
-			The schema model is object-based using classes and properties and is
-			independent of any physical storage format.
-			</p>
-			<p>
 			FDO provides a model for extending
 			its interface to additional data source technologies.
 			The generic API is extensible, and it is possible to add
@@ -99,6 +89,23 @@
 				non-feature geometry properties, and optionally other types of properties.
 				</li>
 			</ul>
+			<p>
+			A geometry is represented using geometric constructs either defined as lists of one or more XY or XYZ
+                  points or defined parametrically, for example, as a circular arc. While geometry typically is two- or three-dimensional,
+                  it may also contain the measurement dimension (M) to provide the basis for dynamic segments. FDO Geometry is based
+                  on the <a href="http://portal.opengeospatial.org/files/?artifact_id=829">OpenGIS Simple Features Implementation Specification for SQL</a>
+                  (version 1.1, document 99-049), but is extended to include z and measure dimensions and circular arcs.
+			</p>
+			<p>
+			A schema is a logical description of the data types used to model real-world objects. A schema is not the actual
+                  data instances (that is, not a particular road or land parcel), rather it is metadata. A schema is a model of the types
+                  of data that would be found in a data store. FDO feature schemas can be written to an XML file. The FDO XML
+                  format for schema is based on the <a href="http://portal.opengeospatial.org/files/?artifact_id=1034">Open GIS Consortium Geography Markup Language </a>
+                  (version 2.1.1, document 02-009).  The schema model is object-based using classes and properties
+                  and is independent of any physical storage format.
+			</p>
         </div>
         <div class="h2">
More information about the Fdo-commits mailing list
