svn commit: r47 - trunk/www/docs/SDF
gregboone at osgeo.org
Wed Jul 26 12:15:20 EDT 2006
Author: gregboone
Date: 2006-07-26 16:15:19+0000
New Revision: 47
Added:
trunk/www/docs/SDF/_i_extended_select_8h-source.html (contents, props changed)
trunk/www/docs/SDF/_i_extended_select_8h.html (contents, props changed)
trunk/www/docs/SDF/_i_extended_select_8h__incl.map (contents, props changed)
trunk/www/docs/SDF/_i_extended_select_8h__incl.md5 (contents, props changed)
trunk/www/docs/SDF/_i_extended_select_8h__incl.png (contents, props changed)
trunk/www/docs/SDF/_i_scrollable_feature_reader_8h-source.html (contents, props changed)
trunk/www/docs/SDF/_i_scrollable_feature_reader_8h.html (contents, props changed)
trunk/www/docs/SDF/_i_scrollable_feature_reader_8h__dep__incl.map (contents, props changed)
trunk/www/docs/SDF/_i_scrollable_feature_reader_8h__dep__incl.md5 (contents, props changed)
trunk/www/docs/SDF/_i_scrollable_feature_reader_8h__dep__incl.png (contents, props changed)
trunk/www/docs/SDF/_i_scrollable_feature_reader_8h__incl.map (contents, props changed)
trunk/www/docs/SDF/_i_scrollable_feature_reader_8h__incl.md5 (contents, props changed)
trunk/www/docs/SDF/_i_scrollable_feature_reader_8h__incl.png (contents, props changed)
trunk/www/docs/SDF/_sdf_compare_handler_8h-source.html (contents, props changed)
trunk/www/docs/SDF/_sdf_compare_handler_8h.html (contents, props changed)
trunk/www/docs/SDF/_sdf_compare_handler_8h_9bfa9402971b67602a99fd99449c5d76.html (contents, props changed)
trunk/www/docs/SDF/_sdf_compare_handler_8h__dep__incl.map (contents, props changed)
trunk/www/docs/SDF/_sdf_compare_handler_8h__dep__incl.md5 (contents, props changed)
trunk/www/docs/SDF/_sdf_compare_handler_8h__dep__incl.png (contents, props changed)
trunk/www/docs/SDF/class_sdf_compare_handler-members.html (contents, props changed)
trunk/www/docs/SDF/class_sdf_compare_handler.html (contents, props changed)
trunk/www/docs/SDF/class_sdf_compare_handler_25efcd708f7d73df47e3f592a4dc9df2.html (contents, props changed)
trunk/www/docs/SDF/class_sdf_compare_handler_3a1cda4006166f838c9c90dbbd16daf5.html (contents, props changed)
trunk/www/docs/SDF/class_sdf_compare_handler_3ade9dcf05112bb16590f695c022a474.html (contents, props changed)
trunk/www/docs/SDF/class_sdf_compare_handler_4b9fe2c6a37153efe808fbe7b9cfac39.html (contents, props changed)
trunk/www/docs/SDF/class_sdf_compare_handler_5da8124ec6d48c42207912cb1004168c.html (contents, props changed)
trunk/www/docs/SDF/class_sdf_compare_handler_c1e1a5c47894aa43ada963c4cb84b980.html (contents, props changed)
trunk/www/docs/SDF/class_sdf_compare_handler_d3a014c324bcbb6e2eccbf17ee9b43f3.html (contents, props changed)
trunk/www/docs/SDF/class_sdf_compare_handler_dd5c70a33541eb9eabc2d19021a768fd.html (contents, props changed)
trunk/www/docs/SDF/class_sdf_compare_handler_e99c60fe9321858c35f204003e06954c.html (contents, props changed)
trunk/www/docs/SDF/class_sdf_compare_handler_fb5771764ec97dd9888a0d243d01886b.html (contents, props changed)
trunk/www/docs/SDF/class_sdf_compare_handler_fba0af521a5201a71547bce66c36f583.html (contents, props changed)
trunk/www/docs/SDF/class_sdf_i_extended_select-members.html (contents, props changed)
trunk/www/docs/SDF/class_sdf_i_extended_select.html (contents, props changed)
trunk/www/docs/SDF/class_sdf_i_extended_select_56fb99cd7bef0a7528cf1dd408d32e16.html (contents, props changed)
trunk/www/docs/SDF/class_sdf_i_extended_select_69a9441cd4ada6b204a5b3ccfde49eab.html (contents, props changed)
trunk/www/docs/SDF/class_sdf_i_extended_select_7094d0597a2dec8f759b553af3c5aebd.html (contents, props changed)
trunk/www/docs/SDF/class_sdf_i_extended_select_8921a5db2a527690f4d5592daa014be8.html (contents, props changed)
trunk/www/docs/SDF/class_sdf_i_extended_select_a9e4db2cb4a126bfd03259073ef74719.html (contents, props changed)
trunk/www/docs/SDF/class_sdf_i_extended_select_d10d84246bb47e87adb334fd6d5e8836.html (contents, props changed)
trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader-members.html (contents, props changed)
trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader.html (contents, props changed)
trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader_0c8bd83991d3de13ea3914e50eea68cd.html (contents, props changed)
trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader_1f018e50f3f7fb295d1c0968bc66aad3.html (contents, props changed)
trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader_31612208adc6a6e34023b40ccbbe9ee9.html (contents, props changed)
trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader_3e1b34ea5d045715c41d232c261f9f37.html (contents, props changed)
trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader_5b3f6fe4b58576aef1f2b3e47bd32392.html (contents, props changed)
trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader_8de8b2476b8dc5051c7f17f734b4693c.html (contents, props changed)
trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader_d692f60e023be7168ac6cf22d781cacd.html (contents, props changed)
trunk/www/docs/SDF/inherit__graph__1.map (contents, props changed)
trunk/www/docs/SDF/inherit__graph__1.md5 (contents, props changed)
trunk/www/docs/SDF/inherit__graph__1.png (contents, props changed)
trunk/www/docs/SDF/inherit__graph__2.map (contents, props changed)
trunk/www/docs/SDF/inherit__graph__2.md5 (contents, props changed)
trunk/www/docs/SDF/inherit__graph__2.png (contents, props changed)
trunk/www/docs/SDF/inherit__graph__3.map (contents, props changed)
trunk/www/docs/SDF/inherit__graph__3.md5 (contents, props changed)
trunk/www/docs/SDF/inherit__graph__3.png (contents, props changed)
trunk/www/docs/SDF/_i_create_s_d_f_file_8h-source.html
trunk/www/docs/SDF/_i_create_s_d_f_file_8h.html
trunk/www/docs/SDF/_i_create_s_d_f_file_8h__incl.md5
trunk/www/docs/SDF/_i_create_s_d_f_file_8h__incl.png
trunk/www/docs/SDF/_sdf_command_type_8h-source.html
trunk/www/docs/SDF/_sdf_command_type_8h.html
trunk/www/docs/SDF/_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html
trunk/www/docs/SDF/_sdf_command_type_8h_86597e57635d4329ec6b9d0a67f969d7.html
trunk/www/docs/SDF/annotated.html
trunk/www/docs/SDF/classes.html
trunk/www/docs/SDF/files.html
trunk/www/docs/SDF/functions.html
trunk/www/docs/SDF/functions_func.html
trunk/www/docs/SDF/globals.html
trunk/www/docs/SDF/globals_defs.html
trunk/www/docs/SDF/globals_eval.html
trunk/www/docs/SDF/hierarchy.html
trunk/www/docs/SDF/index.hhc
trunk/www/docs/SDF/index.hhk
trunk/www/docs/SDF/index.hhp
trunk/www/docs/SDF/inherits.html
trunk/www/docs/SDF/tree.html
FDO2
Modified: trunk/www/docs/SDF/_i_create_s_d_f_file_8h-source.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_i_create_s_d_f_file_8h-source.html?view=diff&rev=47&p1=trunk/www/docs/SDF/_i_create_s_d_f_file_8h-source.html&p2=trunk/www/docs/SDF/_i_create_s_d_f_file_8h-source.html&r1=46&r2=47
--- trunk/www/docs/SDF/_i_create_s_d_f_file_8h-source.html (original)
+++ trunk/www/docs/SDF/_i_create_s_d_f_file_8h-source.html 2006-07-26 16:15:19+0000
@@ -45,7 +45,7 @@
<a name="l00016"></a>00016 <span class="preprocessor">#ifndef ICREATESDFFILE_H</span>
<a name="l00017"></a>00017 <span class="preprocessor"></span><span class="preprocessor">#define ICREATESDFFILE_H</span>
<a name="l00018"></a>00018 <span class="preprocessor"></span>
-<a name="l00019"></a>00019 <span class="preprocessor">#include "Std.h"</span>
+<a name="l00019"></a>00019 <span class="preprocessor">#include "FdoStd.h"</span>
<a name="l00020"></a>00020 <span class="preprocessor">#include "Fdo/Commands/ICommand.h"</span>
<a name="l00021"></a>00021
<a name="l00022"></a>00022 <span class="comment"></span>
Modified: trunk/www/docs/SDF/_i_create_s_d_f_file_8h.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_i_create_s_d_f_file_8h.html?view=diff&rev=47&p1=trunk/www/docs/SDF/_i_create_s_d_f_file_8h.html&p2=trunk/www/docs/SDF/_i_create_s_d_f_file_8h.html&r1=46&r2=47
--- trunk/www/docs/SDF/_i_create_s_d_f_file_8h.html (original)
+++ trunk/www/docs/SDF/_i_create_s_d_f_file_8h.html 2006-07-26 16:15:19+0000
@@ -29,7 +29,7 @@
</ul></div>
<h1>ICreateSDFFile.h File Reference</h1>
<p>
-<code>#include "Std.h"</code><br>
+<code>#include "FdoStd.h"</code><br>
<code>#include "Fdo/Commands/ICommand.h"</code><br>
<p>
Modified: trunk/www/docs/SDF/_i_create_s_d_f_file_8h__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_i_create_s_d_f_file_8h__incl.md5?view=diff&rev=47&p1=trunk/www/docs/SDF/_i_create_s_d_f_file_8h__incl.md5&p2=trunk/www/docs/SDF/_i_create_s_d_f_file_8h__incl.md5&r1=46&r2=47
--- trunk/www/docs/SDF/_i_create_s_d_f_file_8h__incl.md5 (original)
+++ trunk/www/docs/SDF/_i_create_s_d_f_file_8h__incl.md5 2006-07-26 16:15:19+0000
@@ -1 +1 @@
-b7f2c016a3d343e487215e39332e9d4a
\ No newline at end of file
+396f6285ab173e6a8c4be76a13e034da
Modified: trunk/www/docs/SDF/_i_create_s_d_f_file_8h__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_i_create_s_d_f_file_8h__incl.png?view=diff&rev=47&p1=trunk/www/docs/SDF/_i_create_s_d_f_file_8h__incl.png&p2=trunk/www/docs/SDF/_i_create_s_d_f_file_8h__incl.png&r1=46&r2=47
Binary files. No diff available.
Added: trunk/www/docs/SDF/_i_extended_select_8h-source.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_i_extended_select_8h-source.html?view=auto&rev=47
--- (empty file)
+++ trunk/www/docs/SDF/_i_extended_select_8h-source.html 2006-07-26 16:15:19+0000
@@ -0,0 +1,114 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
+<html>
+ <head>
+ <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
+ <title>OSGeo FDO Provider for SDF API Reference</title>
+ <link href="custom.css" rel="stylesheet" type="text/css">
+ <link href="tabs.css" rel="stylesheet" type="text/css">
+ </head>
+ <body bgcolor="#FFFFFF">
+ <table width="100%" border="0">
+ <tr>
+ <td><b>API Reference<b></td>
+ <td align="right"><b>OSGeo FDO Provider for SDF<b></td>
+ </tr>
+ </table>
+<!-- End of: header.html -->
+<!-- Generated by Doxygen 1.4.6-NO -->
+<div class="tabs">
+ <ul>
+ <li><a href="main.html"><span>Main Page</span></a></li>
+ <li><a href="classes.html"><span>Classes</span></a></li>
+ <li id="current"><a href="files.html"><span>Files</span></a></li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li><a href="files.html"><span>File List</span></a></li>
+ <li><a href="globals.html"><span>File Members</span></a></li>
+ </ul></div>
+<h1>IExtendedSelect.h</h1><a href="_i_extended_select_8h.html">Go to the documentation of this file.</a><div class="fragment"><pre class="fragment"><a name="l00001"></a>00001 <span class="comment">// </span>
+<a name="l00002"></a>00002 <span class="comment">// Copyright (C) 2004-2006 Autodesk, Inc.</span>
+<a name="l00003"></a>00003 <span class="comment">// </span>
+<a name="l00004"></a>00004 <span class="comment">// This library is free software; you can redistribute it and/or</span>
+<a name="l00005"></a>00005 <span class="comment">// modify it under the terms of version 2.1 of the GNU Lesser</span>
+<a name="l00006"></a>00006 <span class="comment">// General Public License as published by the Free Software Foundation.</span>
+<a name="l00007"></a>00007 <span class="comment">// </span>
+<a name="l00008"></a>00008 <span class="comment">// This library is distributed in the hope that it will be useful,</span>
+<a name="l00009"></a>00009 <span class="comment">// but WITHOUT ANY WARRANTY; without even the implied warranty of</span>
+<a name="l00010"></a>00010 <span class="comment">// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU</span>
+<a name="l00011"></a>00011 <span class="comment">// Lesser General Public License for more details.</span>
+<a name="l00012"></a>00012 <span class="comment">// </span>
+<a name="l00013"></a>00013 <span class="comment">// You should have received a copy of the GNU Lesser General Public</span>
+<a name="l00014"></a>00014 <span class="comment">// License along with this library; if not, write to the Free Software</span>
+<a name="l00015"></a>00015 <span class="comment">// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA</span>
+<a name="l00016"></a>00016
+<a name="l00017"></a>00017 <span class="preprocessor">#ifndef _SdfIExtendedSelect_H_</span>
+<a name="l00018"></a>00018 <span class="preprocessor"></span><span class="preprocessor">#define _SdfIExtendedSelect_H_</span>
+<a name="l00019"></a>00019 <span class="preprocessor"></span>
+<a name="l00020"></a>00020 <span class="preprocessor">#include "FdoStd.h"</span>
+<a name="l00021"></a>00021 <span class="preprocessor">#include "Fdo.h"</span>
+<a name="l00022"></a>00022 <span class="preprocessor">#include "<a class="code" href="_i_scrollable_feature_reader_8h.html">SDF/IScrollableFeatureReader.h</a>"</span>
+<a name="l00023"></a>00023 <span class="preprocessor">#include "<a class="code" href="_sdf_compare_handler_8h.html">SDF/SdfCompareHandler.h</a>"</span>
+<a name="l00024"></a>00024
+<a name="l00025"></a><a class="code" href="class_sdf_i_extended_select.html">00025</a> <span class="keyword">class </span><a class="code" href="class_sdf_i_extended_select.html">SdfIExtendedSelect</a> : <span class="keyword">public</span> FdoISelect
+<a name="l00026"></a>00026 {
+<a name="l00027"></a>00027
+<a name="l00028"></a>00028 <span class="keyword">public</span>:
+<a name="l00029"></a>00029 <span class="comment">// Expose the FdoISelect hidden functions</span>
+<a name="l00030"></a>00030 <span class="keyword">using</span> FdoISelect::GetOrderingOption;
+<a name="l00031"></a>00031 <span class="keyword">using</span> FdoISelect::SetOrderingOption;
+<a name="l00032"></a>00032 <span class="comment"></span>
+<a name="l00033"></a>00033 <span class="comment"> /// <summary>Set the ordering option of the selection. This is only used if the ordering collection is not empty.</summary></span>
+<a name="l00034"></a>00034 <span class="comment"> /// <param name="propertyName">Is the property name for which the ordering should be applied. This property should be in the ordering collection.</param> </span>
+<a name="l00035"></a>00035 <span class="comment"> /// <param name="option">Is the ordering option and should be set to one of FdoOrderingOption_Ascending or FdoOrderingOption_Descending.</span>
+<a name="l00036"></a>00036 <span class="comment"> /// FdoOrderingOption_Ascending is the default value.</param> </span>
+<a name="l00037"></a>00037 <span class="comment"> /// <returns>Returns nothing</returns> </span>
+<a name="l00038"></a>00038 <span class="comment"></span> <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_sdf_i_extended_select_8921a5db2a527690f4d5592daa014be8.html#8921a5db2a527690f4d5592daa014be8">SetOrderingOption</a>( FdoString* propertyName, FdoOrderingOption option ) = 0;
+<a name="l00039"></a>00039 <span class="comment"></span>
+<a name="l00040"></a>00040 <span class="comment"> /// <summary>Gets the ordering option for a given property.</summary></span>
+<a name="l00041"></a>00041 <span class="comment"> /// <param name="propertyName">Is the property name for which the ordering should be applied. This property should be in the ordering collection.</param> </span>
+<a name="l00042"></a>00042 <span class="comment"> /// <returns>Returns the ordering option.</returns> </span>
+<a name="l00043"></a>00043 <span class="comment"></span> <span class="keyword">virtual</span> FdoOrderingOption <a class="code" href="class_sdf_i_extended_select_a9e4db2cb4a126bfd03259073ef74719.html#a9e4db2cb4a126bfd03259073ef74719">GetOrderingOption</a>( FdoString* propertyName ) = 0;
+<a name="l00044"></a>00044 <span class="comment"></span>
+<a name="l00045"></a>00045 <span class="comment"> /// <summary>This method clears the internal list of property/ordering option list and re-sets the ordering option for all </span>
+<a name="l00046"></a>00046 <span class="comment"> /// the ordering properties to the default FdoOrderingOption_Ascending or to the ordering option specified by the </span>
+<a name="l00047"></a>00047 <span class="comment"> /// FdoIBaseSelect interface.</summary></span>
+<a name="l00048"></a>00048 <span class="comment"> /// <returns>Returns nothing.</returns> </span>
+<a name="l00049"></a>00049 <span class="comment"></span> <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_sdf_i_extended_select_56fb99cd7bef0a7528cf1dd408d32e16.html#56fb99cd7bef0a7528cf1dd408d32e16">ClearOrderingOptions</a>( ) = 0;
+<a name="l00050"></a>00050 <span class="comment"></span>
+<a name="l00051"></a>00051 <span class="comment"> /// <summary>Set the compare handler. This method is used to override the default sdf compare handler.</summary></span>
+<a name="l00052"></a>00052 <span class="comment"> /// <param name="handler">The compare handle that should be derived from the SdfCompareHandler class.</param> </span>
+<a name="l00053"></a>00053 <span class="comment"> /// <returns>Returns nothing</returns> </span>
+<a name="l00054"></a>00054 <span class="comment"></span> <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_sdf_i_extended_select_69a9441cd4ada6b204a5b3ccfde49eab.html#69a9441cd4ada6b204a5b3ccfde49eab">SetCompareHandler</a>( <a class="code" href="class_sdf_compare_handler.html">SdfCompareHandler</a>* handler ) = 0;
+<a name="l00055"></a>00055 <span class="comment"></span>
+<a name="l00056"></a>00056 <span class="comment"> /// <summary> Executes the select command and returns a SdfIScrollableFeatureReader. </span>
+<a name="l00057"></a>00057 <span class="comment"> /// If ordering is enabled, then the returned reader is sorted according to </span>
+<a name="l00058"></a>00058 <span class="comment"> /// the ordering collection. This method perform sorting in memory and allocates an integer value for each row.</summary></span>
+<a name="l00059"></a>00059 <span class="comment"> /// <returns>Returns a SdfIScrollableFeatureReader object</returns> </span>
+<a name="l00060"></a>00060 <span class="comment"></span> <span class="keyword">virtual</span> <a class="code" href="class_sdf_i_scrollable_feature_reader.html">SdfIScrollableFeatureReader</a>* <a class="code" href="class_sdf_i_extended_select_7094d0597a2dec8f759b553af3c5aebd.html#7094d0597a2dec8f759b553af3c5aebd">ExecuteScrollable</a>() = 0;
+<a name="l00061"></a>00061 <span class="comment"></span>
+<a name="l00062"></a>00062 <span class="comment"> /// <summary> Executes the select command and returns a SdfIScrollableFeatureReader. This method creates a temporary SDF file </span>
+<a name="l00063"></a>00063 <span class="comment"> /// that contains the selected properties. If ordering is enabled, then the created temporary SDF file is sorted according to </span>
+<a name="l00064"></a>00064 <span class="comment"> /// the ordering collection. In this case the sorting is file based where the SQLite BTree is used. </span>
+<a name="l00065"></a>00065 <span class="comment"></span> <span class="comment">// The extendedProps and extendedDefaults can be used to extend the class definition of the selected data. </span><span class="comment"></span>
+<a name="l00066"></a>00066 <span class="comment"> /// Both collections have to be in-sync otherwise an exception will be thrown.</summary></span>
+<a name="l00067"></a>00067 <span class="comment"> /// <param name="sdfCacheFile">File path and name used to store the result of the query.</param> </span>
+<a name="l00068"></a>00068 <span class="comment"> /// <param name="extendedProps">A collection of data property definition that extends the class definition defined by the selected properties.</param> </span>
+<a name="l00069"></a>00069 <span class="comment"> /// <param name="extendedDefaults">A collection of property values used as defaults for extended properties defined by extendedProps parameter.</param> </span>
+<a name="l00070"></a>00070 <span class="comment"> /// <returns>Returns a SdfIScrollableFeatureReader object</returns> </span>
+<a name="l00071"></a>00071 <span class="comment"></span> <span class="keyword">virtual</span> <a class="code" href="class_sdf_i_scrollable_feature_reader.html">SdfIScrollableFeatureReader</a>* <a class="code" href="class_sdf_i_extended_select_7094d0597a2dec8f759b553af3c5aebd.html#7094d0597a2dec8f759b553af3c5aebd">ExecuteScrollable</a>( <span class="keyword">const</span> <span class="keywordtype">wchar_t</span>* sdfCacheFile, FdoDataPropertyDefinitionCollection* extendedProps, FdoPropertyValueCollection* extendedDefaults ) = 0;
+<a name="l00072"></a>00072 };
+<a name="l00073"></a>00073
+<a name="l00074"></a>00074 <span class="preprocessor">#endif</span>
+<a name="l00075"></a>00075 <span class="preprocessor"></span>
+</pre></div><!-- footer.html -->
+ <hr>
+ <tr>
+ <td align="right"><font size="-2"><a href="mailto:isd.docs at autodesk.com&subject=FDO%20Provider%20for%20SDF%20API%20documentation">Comments?</a></font></td>
+ <!-- The logo can go in another cell, when we get one -->
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/_i_extended_select_8h.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_i_extended_select_8h.html?view=auto&rev=47
--- (empty file)
+++ trunk/www/docs/SDF/_i_extended_select_8h.html 2006-07-26 16:15:19+0000
@@ -0,0 +1,60 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>IExtendedSelect.h File Reference</h1>
+<p>
+<code>#include "Fdo.h"</code><br>
+<code>#include "<a class="el" href="_i_scrollable_feature_reader_8h-source.html">SDF/IScrollableFeatureReader.h</a>"</code><br>
+<code>#include "<a class="el" href="_sdf_compare_handler_8h-source.html">SDF/SdfCompareHandler.h</a>"</code><br>
+<p>
+Include dependency graph for IExtendedSelect.h:<p><center><img src="_i_extended_select_8h__incl.png" border="0" usemap="#IExtendedSelect.h_map" alt=""></center>
+<map name="IExtendedSelect.h_map">
+<area href="_i_scrollable_feature_reader_8h.html" shape="rect" coords="185,108,401,135" alt="">
+<area href="_sdf_compare_handler_8h.html" shape="rect" coords="201,159,385,185" alt="">
+</map>
+<p>
+<a href="_i_extended_select_8h-source.html">Go to the source code of this file.</a><table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td colspan="2"><br><h2>Classes</h2></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">class </td><td class="memItemRight" valign="bottom"><a class="el" href="class_sdf_i_extended_select.html">SdfIExtendedSelect</a></td></tr>
+</table>
+<!-- footer.html -->
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/_i_extended_select_8h__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_i_extended_select_8h__incl.map?view=auto&rev=47
--- (empty file)
+++ trunk/www/docs/SDF/_i_extended_select_8h__incl.map 2006-07-26 16:15:19+0000
@@ -0,0 +1,3 @@
+base referer
+rect $_i_scrollable_feature_reader_8h.html 185,108 401,135
+rect $_sdf_compare_handler_8h.html 201,159 385,185
Added: trunk/www/docs/SDF/_i_extended_select_8h__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_i_extended_select_8h__incl.md5?view=auto&rev=47
--- (empty file)
+++ trunk/www/docs/SDF/_i_extended_select_8h__incl.md5 2006-07-26 16:15:19+0000
@@ -0,0 +1 @@
+e497b3cfbcd8e6b6c662c1468534efbd
Added: trunk/www/docs/SDF/_i_extended_select_8h__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_i_extended_select_8h__incl.png?view=auto&rev=47
Binary file. No diff available.
Added: trunk/www/docs/SDF/_i_scrollable_feature_reader_8h-source.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_i_scrollable_feature_reader_8h-source.html?view=auto&rev=47
--- (empty file)
+++ trunk/www/docs/SDF/_i_scrollable_feature_reader_8h-source.html 2006-07-26 16:15:19+0000
@@ -0,0 +1,106 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>IScrollableFeatureReader.h</h1><a href="_i_scrollable_feature_reader_8h.html">Go to the documentation of this file.</a><div class="fragment"><pre class="fragment"><a name="l00001"></a>00001 <span class="comment">// </span>
+<a name="l00015"></a>00015 <span class="comment">// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 US</span>
+<a name="l00017"></a>00017 <span class="preprocessor">#ifndef _SdfIScrollableFeatureReader_</span>
+<a name="l00018"></a>00018 <span class="preprocessor"></span><span class="preprocessor">#define _SdfIScrollableFeatureReader_</span>
+<a name="l00020"></a>00020 <span class="preprocessor">#include "Fdo.h"</span>
+<a name="l00022"></a><a class="code" href="class_sdf_i_scrollable_feature_reader.html">00022</a> <span class="keyword">class </span><a class="code" href="class_sdf_i_scrollable_feature_reader.html">SdfIScrollableFeatureReader</a> : <span class="keyword">public</span> FdoIFeatureReader
+<a name="l00023"></a>00023 {
+<a name="l00024"></a>00024 <span class="keyword">public</span>:
+<a name="l00025"></a>00025 <span class="comment"></span>
+<a name="l00026"></a>00026 <span class="comment"> /// <summary>Returns the number of records of the query result.</summary></span>
+<a name="l00027"></a>00027 <span class="comment"> /// <returns>Returns number of records.</returns> </span>
+<a name="l00028"></a>00028 <span class="comment"></span> <span class="keyword">virtual</span> <span class="keywordtype">int</span> <a class="code" href="class_sdf_i_scrollable_feature_reader_0c8bd83991d3de13ea3914e50eea68cd.html#0c8bd83991d3de13ea3914e50eea68cd">Count</a>() = 0;
+<a name="l00029"></a>00029 <span class="comment"></span>
+<a name="l00030"></a>00030 <span class="comment"> /// <summary>Position the reader at the first record of the query result. This method returns false if the query result is empty.</summary></span>
+<a name="l00031"></a>00031 <span class="comment"> /// <returns>Returns true if a record is found or false if the result is empty.</returns></span>
+<a name="l00032"></a>00032 <span class="comment"></span> <span class="keyword">virtual</span> <span class="keywordtype">bool</span> <a class="code" href="class_sdf_i_scrollable_feature_reader_5b3f6fe4b58576aef1f2b3e47bd32392.html#5b3f6fe4b58576aef1f2b3e47bd32392">ReadFirst</a>() = 0;
+<a name="l00033"></a>00033 <span class="comment"></span>
+<a name="l00034"></a>00034 <span class="comment"> /// <summary>Position the reader at the last record of the query result. This method returns false if the query result is empty.</summary></span>
+<a name="l00035"></a>00035 <span class="comment"> /// <returns>Returns true if a record is found or false if the result is empty.</returns></span>
+<a name="l00036"></a>00036 <span class="comment"></span> <span class="keyword">virtual</span> <span class="keywordtype">bool</span> <a class="code" href="class_sdf_i_scrollable_feature_reader_31612208adc6a6e34023b40ccbbe9ee9.html#31612208adc6a6e34023b40ccbbe9ee9">ReadLast</a>() = 0;
+<a name="l00037"></a>00037 <span class="comment"></span>
+<a name="l00038"></a>00038 <span class="comment"> /// <summary>Advances the reader to the previous item and returns true if there is</span>
+<a name="l00039"></a>00039 <span class="comment"> /// another object to read or false if reading is complete. The default</span>
+<a name="l00040"></a>00040 <span class="comment"> /// position of the reader is prior to the first item. Therefore you</span>
+<a name="l00041"></a>00041 <span class="comment"> /// must call ReadFirst or ReadLast to begin accessing any data.</summary></span>
+<a name="l00042"></a>00042 <span class="comment"> /// <returns>Returns true if a record is found or false otherwise.</returns></span>
+<a name="l00043"></a>00043 <span class="comment"></span> <span class="keyword">virtual</span> <span class="keywordtype">bool</span> <a class="code" href="class_sdf_i_scrollable_feature_reader_8de8b2476b8dc5051c7f17f734b4693c.html#8de8b2476b8dc5051c7f17f734b4693c">ReadPrevious</a>() = 0;
+<a name="l00045"></a>00045 <span class="comment"> /// <summary>provide the ad-hoc access to the query result. It positions the position of the reader at a given record </span>
+<a name="l00046"></a>00046 <span class="comment"> /// defined by the key. If the record is not found, then the reader position is unset and false value is returned. </span>
+<a name="l00047"></a>00047 <span class="comment"> /// Once the readers position becames unset, the caller needs to call ReadFirst, ReadLast or ReadAt to re-position </span>
+<a name="l00048"></a>00048 <span class="comment"> /// the reader at a valid location.</returns></span>
+<a name="l00049"></a>00049 <span class="comment"> /// <param name="key">The key that identifies a record.</param> </span>
+<a name="l00050"></a>00050 <span class="comment"> /// <returns>Returns true if a record is found or false otherwise.</returns></span>
+<a name="l00051"></a>00051 <span class="comment"></span> <span class="keyword">virtual</span> <span class="keywordtype">bool</span> <a class="code" href="class_sdf_i_scrollable_feature_reader_3e1b34ea5d045715c41d232c261f9f37.html#3e1b34ea5d045715c41d232c261f9f37">ReadAt</a>(FdoPropertyValueCollection* key) = 0;
+<a name="l00052"></a>00052 <span class="comment"></span>
+<a name="l00053"></a>00053 <span class="comment"> /// <summary>Provides an ad-hoc access to the query result. The recordindex is the one-based nth item in the query result. </span>
+<a name="l00054"></a>00054 <span class="comment"> /// If successful, this method will position the reader at the feature identified by the recordindex.</summary></span>
+<a name="l00055"></a>00055 <span class="comment"> /// <param name="recordindex">The index of the row.</param> </span>
+<a name="l00056"></a>00056 <span class="comment"> /// <returns>Returns true if a record is found or false otherwise.</returns></span>
+<a name="l00057"></a>00057 <span class="comment"></span> <span class="keyword">virtual</span> <span class="keywordtype">bool</span> <a class="code" href="class_sdf_i_scrollable_feature_reader_1f018e50f3f7fb295d1c0968bc66aad3.html#1f018e50f3f7fb295d1c0968bc66aad3">ReadAtIndex</a>( <span class="keywordtype">unsigned</span> <span class="keywordtype">int</span> recordindex ) = 0;
+<a name="l00058"></a>00058 <span class="comment"></span>
+<a name="l00059"></a>00059 <span class="comment"> /// <summary>Given a key of a feature, IndexOf will return the one based index or the record number of the feature within </span>
+<a name="l00060"></a>00060 <span class="comment"> /// the returned query result. If the record is not found, then zero is retuned. This is the mirror function of the GetAtIndex function. This method does not affect the reader position. </span>
+<a name="l00061"></a>00061 <span class="comment"> /// GetAtIndex need to be called to move the reader to the returned index.</summary></span>
+<a name="l00062"></a>00062 <span class="comment"> /// <param name="key">The key that identifies a record.</param> </span>
+<a name="l00063"></a>00063 <span class="comment"> /// <returns>Returns true if a record is found or false otherwise.</returns></span>
+<a name="l00064"></a>00064 <span class="comment"></span> <span class="keyword">virtual</span> <span class="keywordtype">unsigned</span> <span class="keywordtype">int</span> <a class="code" href="class_sdf_i_scrollable_feature_reader_d692f60e023be7168ac6cf22d781cacd.html#d692f60e023be7168ac6cf22d781cacd">IndexOf</a>(FdoPropertyValueCollection* key) = 0;
+<a name="l00065"></a>00065 };
+<a name="l00067"></a>00067 <span class="preprocessor">#endif</span>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/_i_scrollable_feature_reader_8h.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_i_scrollable_feature_reader_8h.html?view=auto&rev=47
--- (empty file)
+++ trunk/www/docs/SDF/_i_scrollable_feature_reader_8h.html 2006-07-26 16:15:19+0000
@@ -0,0 +1,59 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>IScrollableFeatureReader.h File Reference</h1>
+<p>
+<p>
+Include dependency graph for IScrollableFeatureReader.h:<p><center><img src="_i_scrollable_feature_reader_8h__incl.png" border="0" usemap="#IScrollableFeatureReader.h_map" alt=""></center>
+<p>
+This graph shows which files directly or indirectly include this file:<p><center><img src="_i_scrollable_feature_reader_8h__dep__incl.png" border="0" usemap="#IScrollableFeatureReader.hdep_map" alt=""></center>
+<map name="IScrollableFeatureReader.hdep_map">
+<area href="_i_extended_select_8h.html" shape="rect" coords="242,7,372,33" alt="">
+</map>
+<p>
+<a href="_i_scrollable_feature_reader_8h-source.html">Go to the source code of this file.</a><table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">class </td><td class="memItemRight" valign="bottom"><a class="el" href="class_sdf_i_scrollable_feature_reader.html">SdfIScrollableFeatureReader</a></td></tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/_i_scrollable_feature_reader_8h__dep__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_i_scrollable_feature_reader_8h__dep__incl.map?view=auto&rev=47
--- (empty file)
+++ trunk/www/docs/SDF/_i_scrollable_feature_reader_8h__dep__incl.map 2006-07-26 16:15:19+0000
@@ -0,0 +1,2 @@
+base referer
+rect $_i_extended_select_8h.html 242,7 372,33
Added: trunk/www/docs/SDF/_i_scrollable_feature_reader_8h__dep__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_i_scrollable_feature_reader_8h__dep__incl.md5?view=auto&rev=47
--- (empty file)
+++ trunk/www/docs/SDF/_i_scrollable_feature_reader_8h__dep__incl.md5 2006-07-26 16:15:19+0000
@@ -0,0 +1 @@
+09d081cefef47d35b9772a8b7e1a2c57
Added: trunk/www/docs/SDF/_i_scrollable_feature_reader_8h__dep__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_i_scrollable_feature_reader_8h__dep__incl.png?view=auto&rev=47
Added: trunk/www/docs/SDF/_i_scrollable_feature_reader_8h__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_i_scrollable_feature_reader_8h__incl.map?view=auto&rev=47
--- (empty file)
+++ trunk/www/docs/SDF/_i_scrollable_feature_reader_8h__incl.map 2006-07-26 16:15:19+0000
@@ -0,0 +1 @@
+base referer
Added: trunk/www/docs/SDF/_i_scrollable_feature_reader_8h__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_i_scrollable_feature_reader_8h__incl.md5?view=auto&rev=47
--- (empty file)
+++ trunk/www/docs/SDF/_i_scrollable_feature_reader_8h__incl.md5 2006-07-26 16:15:19+0000
@@ -0,0 +1 @@
+13adf1a9d41e67b2987a1af622a5ee47
Added: trunk/www/docs/SDF/_i_scrollable_feature_reader_8h__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_i_scrollable_feature_reader_8h__incl.png?view=auto&rev=47
Modified: trunk/www/docs/SDF/_sdf_command_type_8h-source.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_sdf_command_type_8h-source.html?view=diff&rev=47&p1=trunk/www/docs/SDF/_sdf_command_type_8h-source.html&p2=trunk/www/docs/SDF/_sdf_command_type_8h-source.html&r1=46&r2=47
--- trunk/www/docs/SDF/_sdf_command_type_8h-source.html (original)
+++ trunk/www/docs/SDF/_sdf_command_type_8h-source.html 2006-07-26 16:15:19+0000
@@ -62,16 +62,17 @@
<a name="l00034"></a>00034 <span class="comment"> /// Represents the CreateSDFFile command.</span>
<a name="l00035"></a>00035 <span class="comment"></span> <a class="code" href="_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html#4ac92492e0d58aeace1b0c0f96cefea348c2e525ef9f5e6ae1db0962a09cff37">SdfCommandType_CreateSDFFile</a> = FdoCommandType_FirstProviderCommand + <a class="code" href="_sdf_command_type_8h_86597e57635d4329ec6b9d0a67f969d7.html#86597e57635d4329ec6b9d0a67f969d7">SDF_FIRST_PROVIDER_COMMAND</a>,
-<a name="l00036"></a>00036 };
-<a name="l00037"></a>00037
+<a name="l00036"></a>00036 <a class="code" href="_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html#4ac92492e0d58aeace1b0c0f96cefea3cff985287cc5191960dc4a2258697243">SdfCommandType_ExtendedSelect</a>
+<a name="l00037"></a>00037 };
-<a name="l00043"></a>00043 <span class="preprocessor">#endif</span>
-<a name="l00044"></a>00044 <span class="preprocessor"></span>
-<a name="l00045"></a>00045
+<a name="l00044"></a>00044 <span class="preprocessor">#endif</span>
+<a name="l00045"></a>00045 <span class="preprocessor"></span>
<hr>
Modified: trunk/www/docs/SDF/_sdf_command_type_8h.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_sdf_command_type_8h.html?view=diff&rev=47&p1=trunk/www/docs/SDF/_sdf_command_type_8h.html&p2=trunk/www/docs/SDF/_sdf_command_type_8h.html&r1=46&r2=47
--- trunk/www/docs/SDF/_sdf_command_type_8h.html (original)
+++ trunk/www/docs/SDF/_sdf_command_type_8h.html 2006-07-26 16:15:19+0000
@@ -41,7 +41,8 @@
<tr><td class="memItemLeft" nowrap align="right" valign="top">#define </td><td class="memItemRight" valign="bottom"><a class="el" href="_sdf_command_type_8h_86597e57635d4329ec6b9d0a67f969d7.html#86597e57635d4329ec6b9d0a67f969d7">SDF_FIRST_PROVIDER_COMMAND</a> 911</td></tr>
<tr><td colspan="2"><br><h2>Enumerations</h2></td></tr>
-<tr><td class="memItemLeft" nowrap align="right" valign="top">enum </td><td class="memItemRight" valign="bottom"><a class="el" href="_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html#4ac92492e0d58aeace1b0c0f96cefea3">SdfCommandType</a> { <a class="el" href="_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html#4ac92492e0d58aeace1b0c0f96cefea348c2e525ef9f5e6ae1db0962a09cff37">SdfCommandType_CreateSDFFile</a> = FdoCommandType_FirstProviderCommand + 911
+<tr><td class="memItemLeft" nowrap align="right" valign="top">enum </td><td class="memItemRight" valign="bottom"><a class="el" href="_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html#4ac92492e0d58aeace1b0c0f96cefea3">SdfCommandType</a> { <a class="el" href="_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html#4ac92492e0d58aeace1b0c0f96cefea348c2e525ef9f5e6ae1db0962a09cff37">SdfCommandType_CreateSDFFile</a> = FdoCommandType_FirstProviderCommand + 911,
+<a class="el" href="_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html#4ac92492e0d58aeace1b0c0f96cefea3cff985287cc5191960dc4a2258697243">SdfCommandType_ExtendedSelect</a>
}</td></tr>
<tr><td class="mdescLeft"> </td><td class="mdescRight">The SdfCommandType enumeration defines the list of SDF+ commands. <dl compact><dt><b>Parameters:</b></dt><dd>
Modified: trunk/www/docs/SDF/_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html?view=diff&rev=47&p1=trunk/www/docs/SDF/_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html&p2=trunk/www/docs/SDF/_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html&r1=46&r2=47
--- trunk/www/docs/SDF/_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html (original)
+++ trunk/www/docs/SDF/_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html 2006-07-26 16:15:19+0000
@@ -32,6 +32,7 @@
<tr><td class="navtab"><a class="qindex" href="_sdf_command_type_8h_86597e57635d4329ec6b9d0a67f969d7.html#86597e57635d4329ec6b9d0a67f969d7">SDF_FIRST_PROVIDER_COMMAND</a></td></tr>
<tr><td class="navtab"><a class="qindexHL" href="_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html#4ac92492e0d58aeace1b0c0f96cefea3">SdfCommandType</a></td></tr>
<tr><td class="navtab"><a class="qindex" href="_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html#4ac92492e0d58aeace1b0c0f96cefea348c2e525ef9f5e6ae1db0962a09cff37">SdfCommandType_CreateSDFFile</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html#4ac92492e0d58aeace1b0c0f96cefea3cff985287cc5191960dc4a2258697243">SdfCommandType_ExtendedSelect</a></td></tr>
</table>
</div>
</td>
@@ -67,6 +68,8 @@
<table border="0" cellspacing="2" cellpadding="0">
<tr><td valign="top"><em><a class="anchor" name="4ac92492e0d58aeace1b0c0f96cefea348c2e525ef9f5e6ae1db0962a09cff37"></a><!-- doxytag: member="SdfCommandType_CreateSDFFile" ref="4ac92492e0d58aeace1b0c0f96cefea348c2e525ef9f5e6ae1db0962a09cff37" args="" -->SdfCommandType_CreateSDFFile</em> </td><td>
Represents the CreateSDFFile command. </td></tr>
+<tr><td valign="top"><em><a class="anchor" name="4ac92492e0d58aeace1b0c0f96cefea3cff985287cc5191960dc4a2258697243"></a><!-- doxytag: member="SdfCommandType_ExtendedSelect" ref="4ac92492e0d58aeace1b0c0f96cefea3cff985287cc5191960dc4a2258697243" args="" -->SdfCommandType_ExtendedSelect</em> </td><td>
+</td></tr>
</table>
</dl>
Modified: trunk/www/docs/SDF/_sdf_command_type_8h_86597e57635d4329ec6b9d0a67f969d7.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_sdf_command_type_8h_86597e57635d4329ec6b9d0a67f969d7.html?view=diff&rev=47&p1=trunk/www/docs/SDF/_sdf_command_type_8h_86597e57635d4329ec6b9d0a67f969d7.html&p2=trunk/www/docs/SDF/_sdf_command_type_8h_86597e57635d4329ec6b9d0a67f969d7.html&r1=46&r2=47
--- trunk/www/docs/SDF/_sdf_command_type_8h_86597e57635d4329ec6b9d0a67f969d7.html (original)
+++ trunk/www/docs/SDF/_sdf_command_type_8h_86597e57635d4329ec6b9d0a67f969d7.html 2006-07-26 16:15:19+0000
@@ -32,6 +32,7 @@
<tr><td class="navtab"><a class="qindexHL" href="_sdf_command_type_8h_86597e57635d4329ec6b9d0a67f969d7.html#86597e57635d4329ec6b9d0a67f969d7">SDF_FIRST_PROVIDER_COMMAND</a></td></tr>
<tr><td class="navtab"><a class="qindex" href="_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html#4ac92492e0d58aeace1b0c0f96cefea3">SdfCommandType</a></td></tr>
</table>
</div>
</td>
Added: trunk/www/docs/SDF/_sdf_compare_handler_8h-source.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_sdf_compare_handler_8h-source.html?view=auto&rev=47
--- (empty file)
+++ trunk/www/docs/SDF/_sdf_compare_handler_8h-source.html 2006-07-26 16:15:19+0000
@@ -0,0 +1,145 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>SdfCompareHandler.h</h1><a href="_sdf_compare_handler_8h.html">Go to the documentation of this file.</a><div class="fragment"><pre class="fragment"><a name="l00001"></a>00001 <span class="comment">// </span>
+<a name="l00016"></a>00016 <span class="preprocessor">#ifndef SDFCOMPAREHANDLER_H</span>
+<a name="l00017"></a>00017 <span class="preprocessor"></span><span class="preprocessor">#define SDFCOMPAREHANDLER_H</span>
+<a name="l00019"></a>00019 <span class="preprocessor">#ifdef _WIN32</span>
+<a name="l00020"></a>00020 <span class="preprocessor"></span><span class="preprocessor"> #ifdef SDF_EXPORTS</span>
+<a name="l00021"></a>00021 <span class="preprocessor"></span><span class="preprocessor"> #define SDF_API __declspec(dllexport)</span>
+<a name="l00022"></a>00022 <span class="preprocessor"></span><span class="preprocessor"> #else</span>
+<a name="l00023"></a>00023 <span class="preprocessor"></span><span class="preprocessor"> #define SDF_API __declspec(dllimport)</span>
+<a name="l00024"></a>00024 <span class="preprocessor"></span><span class="preprocessor"> #endif</span>
+<a name="l00025"></a>00025 <span class="preprocessor"></span><span class="preprocessor">#else </span>
+<a name="l00026"></a><a class="code" href="_sdf_compare_handler_8h_9bfa9402971b67602a99fd99449c5d76.html#9bfa9402971b67602a99fd99449c5d76">00026</a> <span class="preprocessor"></span><span class="preprocessor">#define SDF_API</span>
+<a name="l00027"></a>00027 <span class="preprocessor"></span><span class="preprocessor">#endif</span>
+<a name="l00028"></a>00028 <span class="preprocessor"></span>
+<a name="l00029"></a><a class="code" href="class_sdf_compare_handler.html">00029</a> <span class="keyword">class </span><a class="code" href="class_sdf_compare_handler.html">SdfCompareHandler</a>: <span class="keyword">public</span> FdoIDisposable
+<a name="l00030"></a>00030 {
+<a name="l00031"></a>00031 <span class="keyword">private</span>:
+<a name="l00032"></a>00032 <a class="code" href="_sdf_compare_handler_8h_9bfa9402971b67602a99fd99449c5d76.html#9bfa9402971b67602a99fd99449c5d76">SDF_API</a> <a class="code" href="class_sdf_compare_handler.html">SdfCompareHandler</a>();
+<a name="l00034"></a>00034 <span class="keyword">protected</span>:
+<a name="l00035"></a>00035 <a class="code" href="_sdf_compare_handler_8h_9bfa9402971b67602a99fd99449c5d76.html#9bfa9402971b67602a99fd99449c5d76">SDF_API</a> <span class="keyword">virtual</span> <a class="code" href="class_sdf_compare_handler_c1e1a5c47894aa43ada963c4cb84b980.html#c1e1a5c47894aa43ada963c4cb84b980">~SdfCompareHandler</a>();
+<a name="l00037"></a>00037 <span class="comment">// dispose this object</span>
+<a name="l00038"></a><a class="code" href="class_sdf_compare_handler_d3a014c324bcbb6e2eccbf17ee9b43f3.html#d3a014c324bcbb6e2eccbf17ee9b43f3">00038</a> <a class="code" href="_sdf_compare_handler_8h_9bfa9402971b67602a99fd99449c5d76.html#9bfa9402971b67602a99fd99449c5d76">SDF_API</a> <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_sdf_compare_handler_d3a014c324bcbb6e2eccbf17ee9b43f3.html#d3a014c324bcbb6e2eccbf17ee9b43f3">Dispose</a>() { <span class="keyword">delete</span> <span class="keyword">this</span>; }
+<a name="l00040"></a>00040 <span class="keyword">public</span>:<span class="comment"></span>
+<a name="l00041"></a>00041 <span class="comment"> /// <summary>The factory function that can be used to create new instance of this class.</summary></span>
+<a name="l00042"></a>00042 <span class="comment"> /// <returns>Returns a new instance of theSdfCompareHandler class.</returns> </span>
+<a name="l00043"></a>00043 <span class="comment"></span> <a class="code" href="_sdf_compare_handler_8h_9bfa9402971b67602a99fd99449c5d76.html#9bfa9402971b67602a99fd99449c5d76">SDF_API</a> <span class="keyword">static</span> <a class="code" href="class_sdf_compare_handler.html">SdfCompareHandler</a>* <a class="code" href="class_sdf_compare_handler_dd5c70a33541eb9eabc2d19021a768fd.html#dd5c70a33541eb9eabc2d19021a768fd">Create</a>();
+<a name="l00045"></a>00045 <span class="comment"> /// <summary>Compares double values.</summary></span>
+<a name="l00046"></a>00046 <span class="comment"> /// <param name="name">Is the property name.</param> </span>
+<a name="l00047"></a>00047 <span class="comment"> /// <param name="val1">Is the value of the first object.</param> </span>
+<a name="l00048"></a>00048 <span class="comment"> /// <param name="val1">Is the value of the second object.</param> </span>
+<a name="l00049"></a>00049 <span class="comment"> /// <returns>Returns a positive value if val1 is greater than val2, negative if val1 is smaller than val2 or zero if both val1 and val2 are equal.</returns> </span>
+<a name="l00050"></a>00050 <span class="comment"></span> <a class="code" href="_sdf_compare_handler_8h_9bfa9402971b67602a99fd99449c5d76.html#9bfa9402971b67602a99fd99449c5d76">SDF_API</a> <span class="keyword">virtual</span> <span class="keywordtype">int</span> <a class="code" href="class_sdf_compare_handler_4b9fe2c6a37153efe808fbe7b9cfac39.html#4b9fe2c6a37153efe808fbe7b9cfac39">Compare</a>( <span class="keyword">const</span> <span class="keywordtype">wchar_t</span>* name, <span class="keywordtype">double</span> val1, <span class="keywordtype">double</span> val2 );
+<a name="l00052"></a>00052 <span class="comment"> /// <summary>Compares float values.</summary></span>
+<a name="l00053"></a>00053 <span class="comment"> /// <param name="name">Is the property name.</param> </span>
+<a name="l00054"></a>00054 <span class="comment"> /// <param name="val1">Is the value of the first object.</param> </span>
+<a name="l00055"></a>00055 <span class="comment"> /// <param name="val1">Is the value of the second object.</param> </span>
+<a name="l00056"></a>00056 <span class="comment"> /// <returns>Returns a positive value if val1 is greater than val2, negative if val1 is smaller than val2 or zero if both val1 and val2 are equal.</returns> </span>
+<a name="l00057"></a>00057 <span class="comment"></span> <a class="code" href="_sdf_compare_handler_8h_9bfa9402971b67602a99fd99449c5d76.html#9bfa9402971b67602a99fd99449c5d76">SDF_API</a> <span class="keyword">virtual</span> <span class="keywordtype">int</span> <a class="code" href="class_sdf_compare_handler_4b9fe2c6a37153efe808fbe7b9cfac39.html#4b9fe2c6a37153efe808fbe7b9cfac39">Compare</a>( <span class="keyword">const</span> <span class="keywordtype">wchar_t</span>* name, <span class="keywordtype">float</span> val1, <span class="keywordtype">float</span> val2 );
+<a name="l00059"></a>00059 <span class="comment"> /// <summary>Compares int64 values.</summary></span>
+<a name="l00060"></a>00060 <span class="comment"> /// <param name="name">Is the property name.</param> </span>
+<a name="l00061"></a>00061 <span class="comment"> /// <param name="val1">Is the value of the first object.</param> </span>
+<a name="l00062"></a>00062 <span class="comment"> /// <param name="val1">Is the value of the second object.</param> </span>
+<a name="l00063"></a>00063 <span class="comment"> /// <returns>Returns a positive value if val1 is greater than val2, negative if val1 is smaller than val2 or zero if both val1 and val2 are equal.</returns> </span>
+<a name="l00064"></a>00064 <span class="comment"></span> <a class="code" href="_sdf_compare_handler_8h_9bfa9402971b67602a99fd99449c5d76.html#9bfa9402971b67602a99fd99449c5d76">SDF_API</a> <span class="keyword">virtual</span> <span class="keywordtype">int</span> <a class="code" href="class_sdf_compare_handler_4b9fe2c6a37153efe808fbe7b9cfac39.html#4b9fe2c6a37153efe808fbe7b9cfac39">Compare</a>( <span class="keyword">const</span> <span class="keywordtype">wchar_t</span>* name, FdoInt64 val1, FdoInt64 val2 );
+<a name="l00066"></a>00066 <span class="comment"> /// <summary>Compares int32 values.</summary></span>
+<a name="l00067"></a>00067 <span class="comment"> /// <param name="name">Is the property name.</param> </span>
+<a name="l00068"></a>00068 <span class="comment"> /// <param name="val1">Is the value of the first object.</param> </span>
+<a name="l00069"></a>00069 <span class="comment"> /// <param name="val1">Is the value of the second object.</param> </span>
+<a name="l00070"></a>00070 <span class="comment"> /// <returns>Returns a positive value if val1 is greater than val2, negative if val1 is smaller than val2 or zero if both val1 and val2 are equal.</returns> </span>
+<a name="l00071"></a>00071 <span class="comment"></span> <a class="code" href="_sdf_compare_handler_8h_9bfa9402971b67602a99fd99449c5d76.html#9bfa9402971b67602a99fd99449c5d76">SDF_API</a> <span class="keyword">virtual</span> <span class="keywordtype">int</span> <a class="code" href="class_sdf_compare_handler_4b9fe2c6a37153efe808fbe7b9cfac39.html#4b9fe2c6a37153efe808fbe7b9cfac39">Compare</a>( <span class="keyword">const</span> <span class="keywordtype">wchar_t</span>* name, FdoInt32 val1, FdoInt32 val2 );
+<a name="l00072"></a>00072 <span class="comment"></span>
+<a name="l00073"></a>00073 <span class="comment"> /// <summary>Compares int16 values.</summary></span>
+<a name="l00074"></a>00074 <span class="comment"> /// <param name="name">Is the property name.</param> </span>
+<a name="l00075"></a>00075 <span class="comment"> /// <param name="val1">Is the value of the first object.</param> </span>
+<a name="l00076"></a>00076 <span class="comment"> /// <param name="val1">Is the value of the second object.</param> </span>
+<a name="l00077"></a>00077 <span class="comment"> /// <returns>Returns a positive value if val1 is greater than val2, negative if val1 is smaller than val2 or zero if both val1 and val2 are equal.</returns> </span>
+<a name="l00078"></a>00078 <span class="comment"></span> <a class="code" href="_sdf_compare_handler_8h_9bfa9402971b67602a99fd99449c5d76.html#9bfa9402971b67602a99fd99449c5d76">SDF_API</a> <span class="keyword">virtual</span> <span class="keywordtype">int</span> <a class="code" href="class_sdf_compare_handler_4b9fe2c6a37153efe808fbe7b9cfac39.html#4b9fe2c6a37153efe808fbe7b9cfac39">Compare</a>( <span class="keyword">const</span> <span class="keywordtype">wchar_t</span>* name, FdoInt16 val1, FdoInt16 val2 );
+<a name="l00079"></a>00079 <span class="comment"></span>
+<a name="l00080"></a>00080 <span class="comment"> /// <summary>Compares string values.</summary></span>
+<a name="l00081"></a>00081 <span class="comment"> /// <param name="name">Is the property name.</param> </span>
+<a name="l00082"></a>00082 <span class="comment"> /// <param name="val1">Is the value of the first object.</param> </span>
+<a name="l00083"></a>00083 <span class="comment"> /// <param name="val1">Is the value of the second object.</param> </span>
+<a name="l00084"></a>00084 <span class="comment"> /// <returns>Returns a positive value if val1 is greater than val2, negative if val1 is smaller than val2 or zero if both val1 and val2 are equal.</returns> </span>
+<a name="l00085"></a>00085 <span class="comment"></span> <a class="code" href="_sdf_compare_handler_8h_9bfa9402971b67602a99fd99449c5d76.html#9bfa9402971b67602a99fd99449c5d76">SDF_API</a> <span class="keyword">virtual</span> <span class="keywordtype">int</span> <a class="code" href="class_sdf_compare_handler_4b9fe2c6a37153efe808fbe7b9cfac39.html#4b9fe2c6a37153efe808fbe7b9cfac39">Compare</a>( <span class="keyword">const</span> <span class="keywordtype">wchar_t</span>* name, <span class="keyword">const</span> <span class="keywordtype">wchar_t</span>* val1, <span class="keyword">const</span> <span class="keywordtype">wchar_t</span>* val2 );
+<a name="l00086"></a>00086 <span class="comment"></span>
+<a name="l00087"></a>00087 <span class="comment"> /// <summary>Compares date time values.</summary></span>
+<a name="l00088"></a>00088 <span class="comment"> /// <param name="name">Is the property name.</param> </span>
+<a name="l00089"></a>00089 <span class="comment"> /// <param name="val1">Is the value of the first object.</param> </span>
+<a name="l00090"></a>00090 <span class="comment"> /// <param name="val1">Is the value of the second object.</param> </span>
+<a name="l00091"></a>00091 <span class="comment"> /// <returns>Returns a positive value if val1 is greater than val2, negative if val1 is smaller than val2 or zero if both val1 and val2 are equal.</returns> </span>
+<a name="l00092"></a>00092 <span class="comment"></span> <a class="code" href="_sdf_compare_handler_8h_9bfa9402971b67602a99fd99449c5d76.html#9bfa9402971b67602a99fd99449c5d76">SDF_API</a> <span class="keyword">virtual</span> <span class="keywordtype">int</span> <a class="code" href="class_sdf_compare_handler_4b9fe2c6a37153efe808fbe7b9cfac39.html#4b9fe2c6a37153efe808fbe7b9cfac39">Compare</a>( <span class="keyword">const</span> <span class="keywordtype">wchar_t</span>* name, FdoDateTime val1, FdoDateTime val2 );
+<a name="l00093"></a>00093 <span class="comment"></span>
+<a name="l00094"></a>00094 <span class="comment"> /// <summary>Compares unsigned char values.</summary></span>
+<a name="l00095"></a>00095 <span class="comment"> /// <param name="name">Is the property name.</param> </span>
+<a name="l00096"></a>00096 <span class="comment"> /// <param name="val1">Is the value of the first object.</param> </span>
+<a name="l00097"></a>00097 <span class="comment"> /// <param name="val1">Is the value of the second object.</param> </span>
+<a name="l00098"></a>00098 <span class="comment"> /// <returns>Returns a positive value if val1 is greater than val2, negative if val1 is smaller than val2 or zero if both val1 and val2 are equal.</returns> </span>
+<a name="l00099"></a>00099 <span class="comment"></span> <a class="code" href="_sdf_compare_handler_8h_9bfa9402971b67602a99fd99449c5d76.html#9bfa9402971b67602a99fd99449c5d76">SDF_API</a> <span class="keyword">virtual</span> <span class="keywordtype">int</span> <a class="code" href="class_sdf_compare_handler_4b9fe2c6a37153efe808fbe7b9cfac39.html#4b9fe2c6a37153efe808fbe7b9cfac39">Compare</a>( <span class="keyword">const</span> <span class="keywordtype">wchar_t</span>* name, <span class="keywordtype">unsigned</span> <span class="keywordtype">char</span> val1, <span class="keywordtype">unsigned</span> <span class="keywordtype">char</span> val2 );
+<a name="l00100"></a>00100
+<a name="l00101"></a>00101 };
+<a name="l00102"></a>00102
+<a name="l00103"></a>00103
+<a name="l00104"></a>00104 <span class="preprocessor">#endif</span>
+<a name="l00105"></a>00105 <span class="preprocessor"></span>
+<a name="l00106"></a>00106
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/_sdf_compare_handler_8h.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_sdf_compare_handler_8h.html?view=auto&rev=47
--- (empty file)
+++ trunk/www/docs/SDF/_sdf_compare_handler_8h.html 2006-07-26 16:15:19+0000
@@ -0,0 +1,58 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>SdfCompareHandler.h File Reference</h1>
+<p>
+<p>
+This graph shows which files directly or indirectly include this file:<p><center><img src="_sdf_compare_handler_8h__dep__incl.png" border="0" usemap="#SdfCompareHandler.hdep_map" alt=""></center>
+<map name="SdfCompareHandler.hdep_map">
+<area href="_i_extended_select_8h.html" shape="rect" coords="210,7,340,33" alt="">
+</map>
+<p>
+<a href="_sdf_compare_handler_8h-source.html">Go to the source code of this file.</a><table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">class </td><td class="memItemRight" valign="bottom"><a class="el" href="class_sdf_compare_handler.html">SdfCompareHandler</a></td></tr>
+<tr><td colspan="2"><br><h2>Defines</h2></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">#define </td><td class="memItemRight" valign="bottom"><a class="el" href="_sdf_compare_handler_8h_9bfa9402971b67602a99fd99449c5d76.html#9bfa9402971b67602a99fd99449c5d76">SDF_API</a></td></tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/_sdf_compare_handler_8h_9bfa9402971b67602a99fd99449c5d76.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_sdf_compare_handler_8h_9bfa9402971b67602a99fd99449c5d76.html?view=auto&rev=47
--- (empty file)
+++ trunk/www/docs/SDF/_sdf_compare_handler_8h_9bfa9402971b67602a99fd99449c5d76.html 2006-07-26 16:15:19+0000
@@ -0,0 +1,74 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li><a href="files.html"><span>Files</span></a></li>
+ </ul></div>
+<div class="nav">
+<a class="el" href="_sdf_compare_handler_8h.html">SdfCompareHandler.h</a></div>
+<table cellspacing="0" cellpadding="0" border="0">
+ <tr>
+ <td valign="top">
+ <div class="navtab">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="_sdf_compare_handler_8h_9bfa9402971b67602a99fd99449c5d76.html#9bfa9402971b67602a99fd99449c5d76">SDF_API</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="9bfa9402971b67602a99fd99449c5d76"></a><!-- doxytag: member="SdfCompareHandler.h::SDF_API" ref="9bfa9402971b67602a99fd99449c5d76" args="" --><p>
+<table class="mdTable" cellpadding="2" cellspacing="0">
+ <tr>
+ <td class="mdRow">
+ <table cellpadding="0" cellspacing="0" border="0">
+ <tr>
+ <td class="md" nowrap valign="top">#define SDF_API </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+<table cellspacing="5" cellpadding="0" border="0">
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+<p>
+Definition at line <a class="el" href="_sdf_compare_handler_8h-source.html#l00026">26</a> of file <a class="el" href="_sdf_compare_handler_8h-source.html">SdfCompareHandler.h</a>. </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/_sdf_compare_handler_8h__dep__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_sdf_compare_handler_8h__dep__incl.map?view=auto&rev=47
--- (empty file)
+++ trunk/www/docs/SDF/_sdf_compare_handler_8h__dep__incl.map 2006-07-26 16:15:19+0000
@@ -0,0 +1,2 @@
+base referer
+rect $_i_extended_select_8h.html 210,7 340,33
Added: trunk/www/docs/SDF/_sdf_compare_handler_8h__dep__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_sdf_compare_handler_8h__dep__incl.md5?view=auto&rev=47
--- (empty file)
+++ trunk/www/docs/SDF/_sdf_compare_handler_8h__dep__incl.md5 2006-07-26 16:15:19+0000
@@ -0,0 +1 @@
+ef90ed725a4944434236319bd0c74f1b
Added: trunk/www/docs/SDF/_sdf_compare_handler_8h__dep__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_sdf_compare_handler_8h__dep__incl.png?view=auto&rev=47
Modified: trunk/www/docs/SDF/annotated.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/annotated.html?view=diff&rev=47&p1=trunk/www/docs/SDF/annotated.html&p2=trunk/www/docs/SDF/annotated.html&r1=46&r2=47
--- trunk/www/docs/SDF/annotated.html (original)
+++ trunk/www/docs/SDF/annotated.html 2006-07-26 16:15:19+0000
@@ -31,6 +31,9 @@
</ul></div>
<h1>FDO Provider for SDF Class List</h1>Here are the classes, structs, unions and interfaces with brief descriptions:<table>
<tr><td class="indexkey"><a class="el" href="class_fdo_i_create_s_d_f_file.html">FdoICreateSDFFile</a></td><td class="indexvalue">This command creates a new SDF+ file with a specified location and file name and a given spatial coordinate system </td></tr>
+ <tr><td class="indexkey"><a class="el" href="class_sdf_compare_handler.html">SdfCompareHandler</a></td><td class="indexvalue"></td></tr>
+ <tr><td class="indexkey"><a class="el" href="class_sdf_i_extended_select.html">SdfIExtendedSelect</a></td><td class="indexvalue"></td></tr>
+ <tr><td class="indexkey"><a class="el" href="class_sdf_i_scrollable_feature_reader.html">SdfIScrollableFeatureReader</a></td><td class="indexvalue"></td></tr>
</table>
<hr>
Added: trunk/www/docs/SDF/class_sdf_compare_handler-members.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_sdf_compare_handler-members.html?view=auto&rev=47
--- (empty file)
+++ trunk/www/docs/SDF/class_sdf_compare_handler-members.html 2006-07-26 16:15:19+0000
@@ -0,0 +1,53 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li id="current"><a href="classes.html"><span>Classes</span></a></li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li><a href="classes.html"><span>Alphabetical List</span></a></li>
+ <li><a href="annotated.html"><span>Class List</span></a></li>
+ <li><a href="hierarchy.html"><span>Class Hierarchy</span></a></li>
+ <li><a href="functions.html"><span>Class Members</span></a></li>
+ </ul></div>
+<h1>SdfCompareHandler Member List</h1>This is the complete list of members for <a class="el" href="class_sdf_compare_handler.html">SdfCompareHandler</a>, including all inherited members.<p><table>
+ <tr class="memlist"><td><a class="el" href="class_sdf_compare_handler_4b9fe2c6a37153efe808fbe7b9cfac39.html#4b9fe2c6a37153efe808fbe7b9cfac39">Compare</a>(const wchar_t *name, double val1, double val2)</td><td><a class="el" href="class_sdf_compare_handler.html">SdfCompareHandler</a></td><td><code> [virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_sdf_compare_handler_e99c60fe9321858c35f204003e06954c.html#e99c60fe9321858c35f204003e06954c">Compare</a>(const wchar_t *name, float val1, float val2)</td><td><a class="el" href="class_sdf_compare_handler.html">SdfCompareHandler</a></td><td><code> [virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_sdf_compare_handler_fba0af521a5201a71547bce66c36f583.html#fba0af521a5201a71547bce66c36f583">Compare</a>(const wchar_t *name, FdoInt64 val1, FdoInt64 val2)</td><td><a class="el" href="class_sdf_compare_handler.html">SdfCompareHandler</a></td><td><code> [virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_sdf_compare_handler_3a1cda4006166f838c9c90dbbd16daf5.html#3a1cda4006166f838c9c90dbbd16daf5">Compare</a>(const wchar_t *name, FdoInt32 val1, FdoInt32 val2)</td><td><a class="el" href="class_sdf_compare_handler.html">SdfCompareHandler</a></td><td><code> [virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_sdf_compare_handler_25efcd708f7d73df47e3f592a4dc9df2.html#25efcd708f7d73df47e3f592a4dc9df2">Compare</a>(const wchar_t *name, FdoInt16 val1, FdoInt16 val2)</td><td><a class="el" href="class_sdf_compare_handler.html">SdfCompareHandler</a></td><td><code> [virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_sdf_compare_handler_3ade9dcf05112bb16590f695c022a474.html#3ade9dcf05112bb16590f695c022a474">Compare</a>(const wchar_t *name, const wchar_t *val1, const wchar_t *val2)</td><td><a class="el" href="class_sdf_compare_handler.html">SdfCompareHandler</a></td><td><code> [virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_sdf_compare_handler_5da8124ec6d48c42207912cb1004168c.html#5da8124ec6d48c42207912cb1004168c">Compare</a>(const wchar_t *name, FdoDateTime val1, FdoDateTime val2)</td><td><a class="el" href="class_sdf_compare_handler.html">SdfCompareHandler</a></td><td><code> [virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_sdf_compare_handler_fb5771764ec97dd9888a0d243d01886b.html#fb5771764ec97dd9888a0d243d01886b">Compare</a>(const wchar_t *name, unsigned char val1, unsigned char val2)</td><td><a class="el" href="class_sdf_compare_handler.html">SdfCompareHandler</a></td><td><code> [virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_sdf_compare_handler_dd5c70a33541eb9eabc2d19021a768fd.html#dd5c70a33541eb9eabc2d19021a768fd">Create</a>()</td><td><a class="el" href="class_sdf_compare_handler.html">SdfCompareHandler</a></td><td><code> [static]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_sdf_compare_handler_d3a014c324bcbb6e2eccbf17ee9b43f3.html#d3a014c324bcbb6e2eccbf17ee9b43f3">Dispose</a>()</td><td><a class="el" href="class_sdf_compare_handler.html">SdfCompareHandler</a></td><td><code> [inline, protected, virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_sdf_compare_handler_c1e1a5c47894aa43ada963c4cb84b980.html#c1e1a5c47894aa43ada963c4cb84b980">~SdfCompareHandler</a>()</td><td><a class="el" href="class_sdf_compare_handler.html">SdfCompareHandler</a></td><td><code> [protected, virtual]</code></td></tr>
+</table><!-- footer.html -->
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_sdf_compare_handler.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_sdf_compare_handler.html?view=auto&rev=47
--- (empty file)
+++ trunk/www/docs/SDF/class_sdf_compare_handler.html 2006-07-26 16:15:19+0000
@@ -0,0 +1,87 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>SdfCompareHandler Class Reference</h1><!-- doxytag: class="SdfCompareHandler" --><code>#include <<a class="el" href="_sdf_compare_handler_8h-source.html">SdfCompareHandler.h</a>></code>
+<p>
+<a href="class_sdf_compare_handler-members.html">List of all members.</a><hr><a name="_details"></a><h2>Detailed Description</h2>
+<p>
+<p>
+Definition at line <a class="el" href="_sdf_compare_handler_8h-source.html#l00029">29</a> of file <a class="el" href="_sdf_compare_handler_8h-source.html">SdfCompareHandler.h</a>.<table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td colspan="2"><br><h2>Public Member Functions</h2></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual int </td><td class="memItemRight" valign="bottom"><a class="el" href="class_sdf_compare_handler_fb5771764ec97dd9888a0d243d01886b.html#fb5771764ec97dd9888a0d243d01886b">Compare</a> (const wchar_t *name, unsigned char val1, unsigned char val2)</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Compares unsigned char values. <a href="#fb5771764ec97dd9888a0d243d01886b"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual int </td><td class="memItemRight" valign="bottom"><a class="el" href="class_sdf_compare_handler_5da8124ec6d48c42207912cb1004168c.html#5da8124ec6d48c42207912cb1004168c">Compare</a> (const wchar_t *name, FdoDateTime val1, FdoDateTime val2)</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Compares date time values. <a href="#5da8124ec6d48c42207912cb1004168c"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual int </td><td class="memItemRight" valign="bottom"><a class="el" href="class_sdf_compare_handler_3ade9dcf05112bb16590f695c022a474.html#3ade9dcf05112bb16590f695c022a474">Compare</a> (const wchar_t *name, const wchar_t *val1, const wchar_t *val2)</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Compares string values. <a href="#3ade9dcf05112bb16590f695c022a474"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual int </td><td class="memItemRight" valign="bottom"><a class="el" href="class_sdf_compare_handler_25efcd708f7d73df47e3f592a4dc9df2.html#25efcd708f7d73df47e3f592a4dc9df2">Compare</a> (const wchar_t *name, FdoInt16 val1, FdoInt16 val2)</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Compares int16 values. <a href="#25efcd708f7d73df47e3f592a4dc9df2"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual int </td><td class="memItemRight" valign="bottom"><a class="el" href="class_sdf_compare_handler_3a1cda4006166f838c9c90dbbd16daf5.html#3a1cda4006166f838c9c90dbbd16daf5">Compare</a> (const wchar_t *name, FdoInt32 val1, FdoInt32 val2)</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Compares int32 values. <a href="#3a1cda4006166f838c9c90dbbd16daf5"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual int </td><td class="memItemRight" valign="bottom"><a class="el" href="class_sdf_compare_handler_fba0af521a5201a71547bce66c36f583.html#fba0af521a5201a71547bce66c36f583">Compare</a> (const wchar_t *name, FdoInt64 val1, FdoInt64 val2)</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Compares int64 values. <a href="#fba0af521a5201a71547bce66c36f583"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual int </td><td class="memItemRight" valign="bottom"><a class="el" href="class_sdf_compare_handler_e99c60fe9321858c35f204003e06954c.html#e99c60fe9321858c35f204003e06954c">Compare</a> (const wchar_t *name, float val1, float val2)</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Compares float values. <a href="#e99c60fe9321858c35f204003e06954c"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual int </td><td class="memItemRight" valign="bottom"><a class="el" href="class_sdf_compare_handler_4b9fe2c6a37153efe808fbe7b9cfac39.html#4b9fe2c6a37153efe808fbe7b9cfac39">Compare</a> (const wchar_t *name, double val1, double val2)</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Compares double values. <a href="#4b9fe2c6a37153efe808fbe7b9cfac39"></a><br></td></tr>
+<tr><td colspan="2"><br><h2>Static Public Member Functions</h2></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">static <a class="el" href="class_sdf_compare_handler.html">SdfCompareHandler</a> * </td><td class="memItemRight" valign="bottom"><a class="el" href="class_sdf_compare_handler_dd5c70a33541eb9eabc2d19021a768fd.html#dd5c70a33541eb9eabc2d19021a768fd">Create</a> ()</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">The factory function that can be used to create new instance of this class. <a href="#dd5c70a33541eb9eabc2d19021a768fd"></a><br></td></tr>
+<tr><td colspan="2"><br><h2>Protected Member Functions</h2></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual void </td><td class="memItemRight" valign="bottom"><a class="el" href="class_sdf_compare_handler_d3a014c324bcbb6e2eccbf17ee9b43f3.html#d3a014c324bcbb6e2eccbf17ee9b43f3">Dispose</a> ()</td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual </td><td class="memItemRight" valign="bottom"><a class="el" href="class_sdf_compare_handler_c1e1a5c47894aa43ada963c4cb84b980.html#c1e1a5c47894aa43ada963c4cb84b980">~SdfCompareHandler</a> ()</td></tr>
+</table>
+<hr>The documentation for this class was generated from the following file:<ul>
+<li><a class="el" href="_sdf_compare_handler_8h-source.html">SdfCompareHandler.h</a></ul>
+ <hr>
+ <table width="100%" border="0">
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_sdf_compare_handler_25efcd708f7d73df47e3f592a4dc9df2.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_sdf_compare_handler_25efcd708f7d73df47e3f592a4dc9df2.html?view=auto&rev=47
--- (empty file)
+++ trunk/www/docs/SDF/class_sdf_compare_handler_25efcd708f7d73df47e3f592a4dc9df2.html 2006-07-26 16:15:19+0000
@@ -0,0 +1,112 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
+<html>
+ <head>
+ <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
+ <title>OSGeo FDO Provider for SDF API Reference</title>
+ <link href="custom.css" rel="stylesheet" type="text/css">
+ <link href="tabs.css" rel="stylesheet" type="text/css">
+ </head>
+ <body bgcolor="#FFFFFF">
+ <tr>
+ <td><b>API Reference<b></td>
+ <td align="right"><b>OSGeo FDO Provider for SDF<b></td>
+ </tr>
+ </table>
+<!-- End of: header.html -->
+<!-- Generated by Doxygen 1.4.6-NO -->
+<div class="tabs">
+ <ul>
+ <li><a href="main.html"><span>Main Page</span></a></li>
+ <li><a href="classes.html"><span>Classes</span></a></li>
+ </ul></div>
+<div class="nav">
+<a class="el" href="class_sdf_compare_handler.html">SdfCompareHandler</a></div>
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindex" href="class_sdf_compare_handler_4b9fe2c6a37153efe808fbe7b9cfac39.html#4b9fe2c6a37153efe808fbe7b9cfac39">Compare</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_sdf_compare_handler_e99c60fe9321858c35f204003e06954c.html#e99c60fe9321858c35f204003e06954c">Compare</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_sdf_compare_handler_fba0af521a5201a71547bce66c36f583.html#fba0af521a5201a71547bce66c36f583">Compare</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_sdf_compare_handler_3a1cda4006166f838c9c90dbbd16daf5.html#3a1cda4006166f838c9c90dbbd16daf5">Compare</a></td></tr>
+ <tr><td class="navtab"><a class="qindexHL" href="class_sdf_compare_handler_25efcd708f7d73df47e3f592a4dc9df2.html#25efcd708f7d73df47e3f592a4dc9df2">Compare</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_sdf_compare_handler_3ade9dcf05112bb16590f695c022a474.html#3ade9dcf05112bb16590f695c022a474">Compare</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_sdf_compare_handler_5da8124ec6d48c42207912cb1004168c.html#5da8124ec6d48c42207912cb1004168c">Compare</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_sdf_compare_handler_fb5771764ec97dd9888a0d243d01886b.html#fb5771764ec97dd9888a0d243d01886b">Compare</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_sdf_compare_handler_dd5c70a33541eb9eabc2d19021a768fd.html#dd5c70a33541eb9eabc2d19021a768fd">Create</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_sdf_compare_handler_d3a014c324bcbb6e2eccbf17ee9b43f3.html#d3a014c324bcbb6e2eccbf17ee9b43f3">Dispose</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_sdf_compare_handler_c1e1a5c47894aa43ada963c4cb84b980.html#c1e1a5c47894aa43ada963c4cb84b980">~SdfCompareHandler</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="25efcd708f7d73df47e3f592a4dc9df2"></a><!-- doxytag: member="SdfCompareHandler::Compare" ref="25efcd708f7d73df47e3f592a4dc9df2" args="(const wchar_t *name, FdoInt16 val1, FdoInt16 val2)" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual int SdfCompareHandler::Compare </td>
+ <td class="md" valign="top">( </td>
+ <td class="md" nowrap valign="top">const wchar_t * </td>
+ <td class="mdname" nowrap> <em>name</em>, </td>
+ </tr>
+ <tr>
+ <td class="md" nowrap align="right"></td>
+ <td class="md"></td>
+ <td class="md" nowrap>FdoInt16 </td>
+ <td class="mdname" nowrap> <em>val1</em>, </td>
+ </tr>
+ <tr>
+ <td class="mdname" nowrap> <em>val2</em></td>
+ </tr>
+ <tr>
+ <td class="md">) </td>
+ <td class="md" colspan="2"><code> [virtual]</code></td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Compares int16 values.
+<p>
+<dl compact><dt><b>Parameters:</b></dt><dd>
+ <table border="0" cellspacing="2" cellpadding="0">
+ <tr><td valign="top"></td><td valign="top"><em>name</em> </td><td>Is the property name.</td></tr>
+ <tr><td valign="top"></td><td valign="top"><em>val1</em> </td><td>Is the value of the first object.</td></tr>
+ <tr><td valign="top"></td><td valign="top"><em>val1</em> </td><td>Is the value of the second object.</td></tr>
+ </table>
+</dl>
+<dl compact><dt><b>Returns:</b></dt><dd>Returns a positive value if val1 is greater than val2, negative if val1 is smaller than val2 or zero if both val1 and val2 are equal.</dd></dl>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_sdf_compare_handler_3a1cda4006166f838c9c90dbbd16daf5.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_sdf_compare_handler_3a1cda4006166f838c9c90dbbd16daf5.html?view=auto&rev=47
--- (empty file)
+++ trunk/www/docs/SDF/class_sdf_compare_handler_3a1cda4006166f838c9c90dbbd16daf5.html 2006-07-26 16:15:19+0000
@@ -0,0 +1,112 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_sdf_compare_handler_3a1cda4006166f838c9c90dbbd16daf5.html#3a1cda4006166f838c9c90dbbd16daf5">Compare</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_sdf_compare_handler_25efcd708f7d73df47e3f592a4dc9df2.html#25efcd708f7d73df47e3f592a4dc9df2">Compare</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="3a1cda4006166f838c9c90dbbd16daf5"></a><!-- doxytag: member="SdfCompareHandler::Compare" ref="3a1cda4006166f838c9c90dbbd16daf5" args="(const wchar_t *name, FdoInt32 val1, FdoInt32 val2)" --><p>
+ <tr>
+ <tr>
+ </tr>
+ <tr>
+ <td class="md" nowrap>FdoInt32 </td>
+ </tr>
+ <tr>
+ </tr>
+ <tr>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Compares int32 values.
+<p>
+ </table>
+</dl>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_sdf_compare_handler_3ade9dcf05112bb16590f695c022a474.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_sdf_compare_handler_3ade9dcf05112bb16590f695c022a474.html?view=auto&rev=47
--- (empty file)
+++ trunk/www/docs/SDF/class_sdf_compare_handler_3ade9dcf05112bb16590f695c022a474.html 2006-07-26 16:15:19+0000
@@ -0,0 +1,112 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_sdf_compare_handler_3ade9dcf05112bb16590f695c022a474.html#3ade9dcf05112bb16590f695c022a474">Compare</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="3ade9dcf05112bb16590f695c022a474"></a><!-- doxytag: member="SdfCompareHandler::Compare" ref="3ade9dcf05112bb16590f695c022a474" args="(const wchar_t *name, const wchar_t *val1, const wchar_t *val2)" --><p>
+ <tr>
+ <tr>
+ </tr>
+ <tr>
+ <td class="md" nowrap>const wchar_t * </td>
+ </tr>
+ <tr>
+ </tr>
+ <tr>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Compares string values.
+<p>
+ </table>
+</dl>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_sdf_compare_handler_4b9fe2c6a37153efe808fbe7b9cfac39.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_sdf_compare_handler_4b9fe2c6a37153efe808fbe7b9cfac39.html?view=auto&rev=47
--- (empty file)
+++ trunk/www/docs/SDF/class_sdf_compare_handler_4b9fe2c6a37153efe808fbe7b9cfac39.html 2006-07-26 16:15:19+0000
@@ -0,0 +1,112 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_sdf_compare_handler_4b9fe2c6a37153efe808fbe7b9cfac39.html#4b9fe2c6a37153efe808fbe7b9cfac39">Compare</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="4b9fe2c6a37153efe808fbe7b9cfac39"></a><!-- doxytag: member="SdfCompareHandler::Compare" ref="4b9fe2c6a37153efe808fbe7b9cfac39" args="(const wchar_t *name, double val1, double val2)" --><p>
+ <tr>
+ <tr>
+ </tr>
+ <tr>
+ <td class="md" nowrap>double </td>
+ </tr>
+ <tr>
+ </tr>
+ <tr>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Compares double values.
+<p>
+ </table>
+</dl>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ <td align="right"><font size="-2"><a href="mailto:isd.docs at autodesk.com&subject=FDO%20Provider%20for%20SDF%20API%20documentation">Comments?</a></font></td>
+ <!-- The logo can go in another cell, when we get one -->
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_sdf_compare_handler_5da8124ec6d48c42207912cb1004168c.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_sdf_compare_handler_5da8124ec6d48c42207912cb1004168c.html?view=auto&rev=47
--- (empty file)
+++ trunk/www/docs/SDF/class_sdf_compare_handler_5da8124ec6d48c42207912cb1004168c.html 2006-07-26 16:15:19+0000
@@ -0,0 +1,112 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_sdf_compare_handler_5da8124ec6d48c42207912cb1004168c.html#5da8124ec6d48c42207912cb1004168c">Compare</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="5da8124ec6d48c42207912cb1004168c"></a><!-- doxytag: member="SdfCompareHandler::Compare" ref="5da8124ec6d48c42207912cb1004168c" args="(const wchar_t *name, FdoDateTime val1, FdoDateTime val2)" --><p>
+ <tr>
+ <tr>
+ </tr>
+ <tr>
+ <td class="md" nowrap>FdoDateTime </td>
+ </tr>
+ <tr>
+ </tr>
+ <tr>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Compares date time values.
+<p>
+ </table>
+</dl>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+<!-- footer.html -->
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_sdf_compare_handler_c1e1a5c47894aa43ada963c4cb84b980.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_sdf_compare_handler_c1e1a5c47894aa43ada963c4cb84b980.html?view=auto&rev=47
--- (empty file)
+++ trunk/www/docs/SDF/class_sdf_compare_handler_c1e1a5c47894aa43ada963c4cb84b980.html 2006-07-26 16:15:19+0000
@@ -0,0 +1,86 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_sdf_compare_handler_c1e1a5c47894aa43ada963c4cb84b980.html#c1e1a5c47894aa43ada963c4cb84b980">~SdfCompareHandler</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="c1e1a5c47894aa43ada963c4cb84b980"></a><!-- doxytag: member="SdfCompareHandler::~SdfCompareHandler" ref="c1e1a5c47894aa43ada963c4cb84b980" args="()" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual SdfCompareHandler::~SdfCompareHandler </td>
+ <td class="mdname1" valign="top" nowrap> </td>
+ <td class="md" valign="top"> ) </td>
+ <td class="md" nowrap><code> [protected, virtual]</code></td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_sdf_compare_handler_d3a014c324bcbb6e2eccbf17ee9b43f3.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_sdf_compare_handler_d3a014c324bcbb6e2eccbf17ee9b43f3.html?view=auto&rev=47
--- (empty file)
+++ trunk/www/docs/SDF/class_sdf_compare_handler_d3a014c324bcbb6e2eccbf17ee9b43f3.html 2006-07-26 16:15:19+0000
@@ -0,0 +1,88 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_sdf_compare_handler_d3a014c324bcbb6e2eccbf17ee9b43f3.html#d3a014c324bcbb6e2eccbf17ee9b43f3">Dispose</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="d3a014c324bcbb6e2eccbf17ee9b43f3"></a><!-- doxytag: member="SdfCompareHandler::Dispose" ref="d3a014c324bcbb6e2eccbf17ee9b43f3" args="()" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual void SdfCompareHandler::Dispose </td>
+ <td class="md" nowrap><code> [inline, protected, virtual]</code></td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+<p>
+Definition at line <a class="el" href="_sdf_compare_handler_8h-source.html#l00038">38</a> of file <a class="el" href="_sdf_compare_handler_8h-source.html">SdfCompareHandler.h</a>. </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_sdf_compare_handler_dd5c70a33541eb9eabc2d19021a768fd.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_sdf_compare_handler_dd5c70a33541eb9eabc2d19021a768fd.html?view=auto&rev=47
--- (empty file)
+++ trunk/www/docs/SDF/class_sdf_compare_handler_dd5c70a33541eb9eabc2d19021a768fd.html 2006-07-26 16:15:19+0000
@@ -0,0 +1,89 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_sdf_compare_handler_dd5c70a33541eb9eabc2d19021a768fd.html#dd5c70a33541eb9eabc2d19021a768fd">Create</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="dd5c70a33541eb9eabc2d19021a768fd"></a><!-- doxytag: member="SdfCompareHandler::Create" ref="dd5c70a33541eb9eabc2d19021a768fd" args="()" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">static <a class="el" href="class_sdf_compare_handler.html">SdfCompareHandler</a>* SdfCompareHandler::Create </td>
+ <td class="md" nowrap><code> [static]</code></td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+The factory function that can be used to create new instance of this class.
+<p>
+<dl compact><dt><b>Returns:</b></dt><dd>Returns a new instance of theSdfCompareHandler class.</dd></dl>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_sdf_compare_handler_e99c60fe9321858c35f204003e06954c.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_sdf_compare_handler_e99c60fe9321858c35f204003e06954c.html?view=auto&rev=47
--- (empty file)
+++ trunk/www/docs/SDF/class_sdf_compare_handler_e99c60fe9321858c35f204003e06954c.html 2006-07-26 16:15:19+0000
@@ -0,0 +1,112 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_sdf_compare_handler_e99c60fe9321858c35f204003e06954c.html#e99c60fe9321858c35f204003e06954c">Compare</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="e99c60fe9321858c35f204003e06954c"></a><!-- doxytag: member="SdfCompareHandler::Compare" ref="e99c60fe9321858c35f204003e06954c" args="(const wchar_t *name, float val1, float val2)" --><p>
+ <tr>
+ <tr>
+ </tr>
+ <tr>
+ <td class="md" nowrap>float </td>
+ </tr>
+ <tr>
+ </tr>
+ <tr>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Compares float values.
+<p>
+ </table>
+</dl>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_sdf_compare_handler_fb5771764ec97dd9888a0d243d01886b.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_sdf_compare_handler_fb5771764ec97dd9888a0d243d01886b.html?view=auto&rev=47
--- (empty file)
+++ trunk/www/docs/SDF/class_sdf_compare_handler_fb5771764ec97dd9888a0d243d01886b.html 2006-07-26 16:15:19+0000
@@ -0,0 +1,112 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_sdf_compare_handler_fb5771764ec97dd9888a0d243d01886b.html#fb5771764ec97dd9888a0d243d01886b">Compare</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="fb5771764ec97dd9888a0d243d01886b"></a><!-- doxytag: member="SdfCompareHandler::Compare" ref="fb5771764ec97dd9888a0d243d01886b" args="(const wchar_t *name, unsigned char val1, unsigned char val2)" --><p>
+ <tr>
+ <tr>
+ </tr>
+ <tr>
+ <td class="md" nowrap>unsigned char </td>
+ </tr>
+ <tr>
+ </tr>
+ <tr>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Compares unsigned char values.
+<p>
+ </table>
+</dl>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_sdf_compare_handler_fba0af521a5201a71547bce66c36f583.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_sdf_compare_handler_fba0af521a5201a71547bce66c36f583.html?view=auto&rev=47
--- (empty file)
+++ trunk/www/docs/SDF/class_sdf_compare_handler_fba0af521a5201a71547bce66c36f583.html 2006-07-26 16:15:19+0000
@@ -0,0 +1,112 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_sdf_compare_handler_fba0af521a5201a71547bce66c36f583.html#fba0af521a5201a71547bce66c36f583">Compare</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="fba0af521a5201a71547bce66c36f583"></a><!-- doxytag: member="SdfCompareHandler::Compare" ref="fba0af521a5201a71547bce66c36f583" args="(const wchar_t *name, FdoInt64 val1, FdoInt64 val2)" --><p>
+ <tr>
+ <tr>
+ </tr>
+ <tr>
+ <td class="md" nowrap>FdoInt64 </td>
+ </tr>
+ <tr>
+ </tr>
+ <tr>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Compares int64 values.
+<p>
+ </table>
+</dl>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_sdf_i_extended_select-members.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_sdf_i_extended_select-members.html?view=auto&rev=47
--- (empty file)
+++ trunk/www/docs/SDF/class_sdf_i_extended_select-members.html 2006-07-26 16:15:19+0000
@@ -0,0 +1,48 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>SdfIExtendedSelect Member List</h1>This is the complete list of members for <a class="el" href="class_sdf_i_extended_select.html">SdfIExtendedSelect</a>, including all inherited members.<p><table>
+ <tr class="memlist"><td><a class="el" href="class_sdf_i_extended_select_56fb99cd7bef0a7528cf1dd408d32e16.html#56fb99cd7bef0a7528cf1dd408d32e16">ClearOrderingOptions</a>()=0</td><td><a class="el" href="class_sdf_i_extended_select.html">SdfIExtendedSelect</a></td><td><code> [pure virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_sdf_i_extended_select_7094d0597a2dec8f759b553af3c5aebd.html#7094d0597a2dec8f759b553af3c5aebd">ExecuteScrollable</a>()=0</td><td><a class="el" href="class_sdf_i_extended_select.html">SdfIExtendedSelect</a></td><td><code> [pure virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_sdf_i_extended_select_d10d84246bb47e87adb334fd6d5e8836.html#d10d84246bb47e87adb334fd6d5e8836">ExecuteScrollable</a>(const wchar_t *sdfCacheFile, FdoDataPropertyDefinitionCollection *extendedProps, FdoPropertyValueCollection *extendedDefaults)=0</td><td><a class="el" href="class_sdf_i_extended_select.html">SdfIExtendedSelect</a></td><td><code> [pure virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_sdf_i_extended_select_a9e4db2cb4a126bfd03259073ef74719.html#a9e4db2cb4a126bfd03259073ef74719">GetOrderingOption</a>(FdoString *propertyName)=0</td><td><a class="el" href="class_sdf_i_extended_select.html">SdfIExtendedSelect</a></td><td><code> [pure virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_sdf_i_extended_select_69a9441cd4ada6b204a5b3ccfde49eab.html#69a9441cd4ada6b204a5b3ccfde49eab">SetCompareHandler</a>(SdfCompareHandler *handler)=0</td><td><a class="el" href="class_sdf_i_extended_select.html">SdfIExtendedSelect</a></td><td><code> [pure virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_sdf_i_extended_select_8921a5db2a527690f4d5592daa014be8.html#8921a5db2a527690f4d5592daa014be8">SetOrderingOption</a>(FdoString *propertyName, FdoOrderingOption option)=0</td><td><a class="el" href="class_sdf_i_extended_select.html">SdfIExtendedSelect</a></td><td><code> [pure virtual]</code></td></tr>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_sdf_i_extended_select.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_sdf_i_extended_select.html?view=auto&rev=47
--- (empty file)
+++ trunk/www/docs/SDF/class_sdf_i_extended_select.html 2006-07-26 16:15:19+0000
@@ -0,0 +1,72 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>SdfIExtendedSelect Class Reference</h1><!-- doxytag: class="SdfIExtendedSelect" --><code>#include <<a class="el" href="_i_extended_select_8h-source.html">IExtendedSelect.h</a>></code>
+<p>
+<a href="class_sdf_i_extended_select-members.html">List of all members.</a><hr><a name="_details"></a><h2>Detailed Description</h2>
+<p>
+<p>
+Definition at line <a class="el" href="_i_extended_select_8h-source.html#l00025">25</a> of file <a class="el" href="_i_extended_select_8h-source.html">IExtendedSelect.h</a>.<table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual void </td><td class="memItemRight" valign="bottom"><a class="el" href="class_sdf_i_extended_select_56fb99cd7bef0a7528cf1dd408d32e16.html#56fb99cd7bef0a7528cf1dd408d32e16">ClearOrderingOptions</a> ()=0</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">This method clears the internal list of property/ordering option list and re-sets the ordering option for all the ordering properties to the default FdoOrderingOption_Ascending or to the ordering option specified by the FdoIBaseSelect interface. <a href="#56fb99cd7bef0a7528cf1dd408d32e16"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual <a class="el" href="class_sdf_i_scrollable_feature_reader.html">SdfIScrollableFeatureReader</a> * </td><td class="memItemRight" valign="bottom"><a class="el" href="class_sdf_i_extended_select_d10d84246bb47e87adb334fd6d5e8836.html#d10d84246bb47e87adb334fd6d5e8836">ExecuteScrollable</a> (const wchar_t *sdfCacheFile, FdoDataPropertyDefinitionCollection *extendedProps, FdoPropertyValueCollection *extendedDefaults)=0</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Executes the select command and returns a <a class="el" href="class_sdf_i_scrollable_feature_reader.html">SdfIScrollableFeatureReader</a>. This method creates a temporary SDF file that contains the selected properties. If ordering is enabled, then the created temporary SDF file is sorted according to the ordering collection. In this case the sorting is file based where the SQLite BTree is used. <a href="#d10d84246bb47e87adb334fd6d5e8836"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual <a class="el" href="class_sdf_i_scrollable_feature_reader.html">SdfIScrollableFeatureReader</a> * </td><td class="memItemRight" valign="bottom"><a class="el" href="class_sdf_i_extended_select_7094d0597a2dec8f759b553af3c5aebd.html#7094d0597a2dec8f759b553af3c5aebd">ExecuteScrollable</a> ()=0</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Executes the select command and returns a <a class="el" href="class_sdf_i_scrollable_feature_reader.html">SdfIScrollableFeatureReader</a>. If ordering is enabled, then the returned reader is sorted according to the ordering collection. This method perform sorting in memory and allocates an integer value for each row. <a href="#7094d0597a2dec8f759b553af3c5aebd"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FdoOrderingOption </td><td class="memItemRight" valign="bottom"><a class="el" href="class_sdf_i_extended_select_a9e4db2cb4a126bfd03259073ef74719.html#a9e4db2cb4a126bfd03259073ef74719">GetOrderingOption</a> (FdoString *propertyName)=0</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Gets the ordering option for a given property. <a href="#a9e4db2cb4a126bfd03259073ef74719"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual void </td><td class="memItemRight" valign="bottom"><a class="el" href="class_sdf_i_extended_select_69a9441cd4ada6b204a5b3ccfde49eab.html#69a9441cd4ada6b204a5b3ccfde49eab">SetCompareHandler</a> (<a class="el" href="class_sdf_compare_handler.html">SdfCompareHandler</a> *handler)=0</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Set the compare handler. This method is used to override the default sdf compare handler. <a href="#69a9441cd4ada6b204a5b3ccfde49eab"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual void </td><td class="memItemRight" valign="bottom"><a class="el" href="class_sdf_i_extended_select_8921a5db2a527690f4d5592daa014be8.html#8921a5db2a527690f4d5592daa014be8">SetOrderingOption</a> (FdoString *propertyName, FdoOrderingOption option)=0</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Set the ordering option of the selection. This is only used if the ordering collection is not empty. <a href="#8921a5db2a527690f4d5592daa014be8"></a><br></td></tr>
+</table>
+<li><a class="el" href="_i_extended_select_8h-source.html">IExtendedSelect.h</a></ul>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_sdf_i_extended_select_56fb99cd7bef0a7528cf1dd408d32e16.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_sdf_i_extended_select_56fb99cd7bef0a7528cf1dd408d32e16.html?view=auto&rev=47
--- (empty file)
+++ trunk/www/docs/SDF/class_sdf_i_extended_select_56fb99cd7bef0a7528cf1dd408d32e16.html 2006-07-26 16:15:19+0000
@@ -0,0 +1,84 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+<a class="el" href="class_sdf_i_extended_select.html">SdfIExtendedSelect</a></div>
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_sdf_i_extended_select_56fb99cd7bef0a7528cf1dd408d32e16.html#56fb99cd7bef0a7528cf1dd408d32e16">ClearOrderingOptions</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_sdf_i_extended_select_7094d0597a2dec8f759b553af3c5aebd.html#7094d0597a2dec8f759b553af3c5aebd">ExecuteScrollable</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_sdf_i_extended_select_d10d84246bb47e87adb334fd6d5e8836.html#d10d84246bb47e87adb334fd6d5e8836">ExecuteScrollable</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_sdf_i_extended_select_a9e4db2cb4a126bfd03259073ef74719.html#a9e4db2cb4a126bfd03259073ef74719">GetOrderingOption</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_sdf_i_extended_select_69a9441cd4ada6b204a5b3ccfde49eab.html#69a9441cd4ada6b204a5b3ccfde49eab">SetCompareHandler</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_sdf_i_extended_select_8921a5db2a527690f4d5592daa014be8.html#8921a5db2a527690f4d5592daa014be8">SetOrderingOption</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="56fb99cd7bef0a7528cf1dd408d32e16"></a><!-- doxytag: member="SdfIExtendedSelect::ClearOrderingOptions" ref="56fb99cd7bef0a7528cf1dd408d32e16" args="()=0" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual void SdfIExtendedSelect::ClearOrderingOptions </td>
+ <td class="md" nowrap><code> [pure virtual]</code></td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+This method clears the internal list of property/ordering option list and re-sets the ordering option for all the ordering properties to the default FdoOrderingOption_Ascending or to the ordering option specified by the FdoIBaseSelect interface.
+<p>
+<dl compact><dt><b>Returns:</b></dt><dd>Returns nothing.</dd></dl>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_sdf_i_extended_select_69a9441cd4ada6b204a5b3ccfde49eab.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_sdf_i_extended_select_69a9441cd4ada6b204a5b3ccfde49eab.html?view=auto&rev=47
--- (empty file)
+++ trunk/www/docs/SDF/class_sdf_i_extended_select_69a9441cd4ada6b204a5b3ccfde49eab.html 2006-07-26 16:15:19+0000
@@ -0,0 +1,90 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindex" href="class_sdf_i_extended_select_56fb99cd7bef0a7528cf1dd408d32e16.html#56fb99cd7bef0a7528cf1dd408d32e16">ClearOrderingOptions</a></td></tr>
+ <tr><td class="navtab"><a class="qindexHL" href="class_sdf_i_extended_select_69a9441cd4ada6b204a5b3ccfde49eab.html#69a9441cd4ada6b204a5b3ccfde49eab">SetCompareHandler</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="69a9441cd4ada6b204a5b3ccfde49eab"></a><!-- doxytag: member="SdfIExtendedSelect::SetCompareHandler" ref="69a9441cd4ada6b204a5b3ccfde49eab" args="(SdfCompareHandler *handler)=0" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual void SdfIExtendedSelect::SetCompareHandler </td>
+ <td class="md" nowrap valign="top"><a class="el" href="class_sdf_compare_handler.html">SdfCompareHandler</a> * </td>
+ <td class="mdname1" valign="top" nowrap> <em>handler</em> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Set the compare handler. This method is used to override the default sdf compare handler.
+<p>
+ <tr><td valign="top"></td><td valign="top"><em>handler</em> </td><td>The compare handle that should be derived from the <a class="el" href="class_sdf_compare_handler.html">SdfCompareHandler</a> class.</td></tr>
+ </table>
+</dl>
+<dl compact><dt><b>Returns:</b></dt><dd>Returns nothing</dd></dl>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_sdf_i_extended_select_7094d0597a2dec8f759b553af3c5aebd.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_sdf_i_extended_select_7094d0597a2dec8f759b553af3c5aebd.html?view=auto&rev=47
--- (empty file)
+++ trunk/www/docs/SDF/class_sdf_i_extended_select_7094d0597a2dec8f759b553af3c5aebd.html 2006-07-26 16:15:19+0000
@@ -0,0 +1,84 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_sdf_i_extended_select_7094d0597a2dec8f759b553af3c5aebd.html#7094d0597a2dec8f759b553af3c5aebd">ExecuteScrollable</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="7094d0597a2dec8f759b553af3c5aebd"></a><!-- doxytag: member="SdfIExtendedSelect::ExecuteScrollable" ref="7094d0597a2dec8f759b553af3c5aebd" args="()=0" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual <a class="el" href="class_sdf_i_scrollable_feature_reader.html">SdfIScrollableFeatureReader</a>* SdfIExtendedSelect::ExecuteScrollable </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Executes the select command and returns a <a class="el" href="class_sdf_i_scrollable_feature_reader.html">SdfIScrollableFeatureReader</a>. If ordering is enabled, then the returned reader is sorted according to the ordering collection. This method perform sorting in memory and allocates an integer value for each row.
+<p>
+<dl compact><dt><b>Returns:</b></dt><dd>Returns a <a class="el" href="class_sdf_i_scrollable_feature_reader.html">SdfIScrollableFeatureReader</a> object</dd></dl>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_sdf_i_extended_select_8921a5db2a527690f4d5592daa014be8.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_sdf_i_extended_select_8921a5db2a527690f4d5592daa014be8.html?view=auto&rev=47
--- (empty file)
+++ trunk/www/docs/SDF/class_sdf_i_extended_select_8921a5db2a527690f4d5592daa014be8.html 2006-07-26 16:15:19+0000
@@ -0,0 +1,100 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_sdf_i_extended_select_8921a5db2a527690f4d5592daa014be8.html#8921a5db2a527690f4d5592daa014be8">SetOrderingOption</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="8921a5db2a527690f4d5592daa014be8"></a><!-- doxytag: member="SdfIExtendedSelect::SetOrderingOption" ref="8921a5db2a527690f4d5592daa014be8" args="(FdoString *propertyName, FdoOrderingOption option)=0" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual void SdfIExtendedSelect::SetOrderingOption </td>
+ <td class="md" nowrap valign="top">FdoString * </td>
+ <td class="mdname" nowrap> <em>propertyName</em>, </td>
+ </tr>
+ <tr>
+ <td class="md" nowrap>FdoOrderingOption </td>
+ <td class="mdname" nowrap> <em>option</em></td>
+ </tr>
+ <tr>
+ <td class="md" colspan="2"><code> [pure virtual]</code></td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Set the ordering option of the selection. This is only used if the ordering collection is not empty.
+<p>
+ <tr><td valign="top"></td><td valign="top"><em>propertyName</em> </td><td>Is the property name for which the ordering should be applied. This property should be in the ordering collection.</td></tr>
+ <tr><td valign="top"></td><td valign="top"><em>option</em> </td><td>Is the ordering option and should be set to one of FdoOrderingOption_Ascending or FdoOrderingOption_Descending. FdoOrderingOption_Ascending is the default value.</td></tr>
+ </table>
+</dl>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_sdf_i_extended_select_a9e4db2cb4a126bfd03259073ef74719.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_sdf_i_extended_select_a9e4db2cb4a126bfd03259073ef74719.html?view=auto&rev=47
--- (empty file)
+++ trunk/www/docs/SDF/class_sdf_i_extended_select_a9e4db2cb4a126bfd03259073ef74719.html 2006-07-26 16:15:19+0000
@@ -0,0 +1,90 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_sdf_i_extended_select_a9e4db2cb4a126bfd03259073ef74719.html#a9e4db2cb4a126bfd03259073ef74719">GetOrderingOption</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="a9e4db2cb4a126bfd03259073ef74719"></a><!-- doxytag: member="SdfIExtendedSelect::GetOrderingOption" ref="a9e4db2cb4a126bfd03259073ef74719" args="(FdoString *propertyName)=0" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual FdoOrderingOption SdfIExtendedSelect::GetOrderingOption </td>
+ <td class="mdname1" valign="top" nowrap> <em>propertyName</em> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Gets the ordering option for a given property.
+<p>
+ </table>
+</dl>
+<dl compact><dt><b>Returns:</b></dt><dd>Returns the ordering option.</dd></dl>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_sdf_i_extended_select_d10d84246bb47e87adb334fd6d5e8836.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_sdf_i_extended_select_d10d84246bb47e87adb334fd6d5e8836.html?view=auto&rev=47
--- (empty file)
+++ trunk/www/docs/SDF/class_sdf_i_extended_select_d10d84246bb47e87adb334fd6d5e8836.html 2006-07-26 16:15:19+0000
@@ -0,0 +1,107 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_sdf_i_extended_select_d10d84246bb47e87adb334fd6d5e8836.html#d10d84246bb47e87adb334fd6d5e8836">ExecuteScrollable</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="d10d84246bb47e87adb334fd6d5e8836"></a><!-- doxytag: member="SdfIExtendedSelect::ExecuteScrollable" ref="d10d84246bb47e87adb334fd6d5e8836" args="(const wchar_t *sdfCacheFile, FdoDataPropertyDefinitionCollection *extendedProps, FdoPropertyValueCollection *extendedDefaults)=0" --><p>
+ <tr>
+ <tr>
+ <td class="mdname" nowrap> <em>sdfCacheFile</em>, </td>
+ </tr>
+ <tr>
+ <td class="md" nowrap>FdoDataPropertyDefinitionCollection * </td>
+ <td class="mdname" nowrap> <em>extendedProps</em>, </td>
+ </tr>
+ <tr>
+ <td class="md" nowrap>FdoPropertyValueCollection * </td>
+ <td class="mdname" nowrap> <em>extendedDefaults</em></td>
+ </tr>
+ <tr>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Executes the select command and returns a <a class="el" href="class_sdf_i_scrollable_feature_reader.html">SdfIScrollableFeatureReader</a>. This method creates a temporary SDF file that contains the selected properties. If ordering is enabled, then the created temporary SDF file is sorted according to the ordering collection. In this case the sorting is file based where the SQLite BTree is used.
+<p>
+Both collections have to be in-sync otherwise an exception will be thrown. <dl compact><dt><b>Parameters:</b></dt><dd>
+ <tr><td valign="top"></td><td valign="top"><em>sdfCacheFile</em> </td><td>File path and name used to store the result of the query.</td></tr>
+ <tr><td valign="top"></td><td valign="top"><em>extendedProps</em> </td><td>A collection of data property definition that extends the class definition defined by the selected properties.</td></tr>
+ <tr><td valign="top"></td><td valign="top"><em>extendedDefaults</em> </td><td>A collection of property values used as defaults for extended properties defined by extendedProps parameter.</td></tr>
+ </table>
+</dl>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader-members.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader-members.html?view=auto&rev=47
--- (empty file)
+++ trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader-members.html 2006-07-26 16:15:19+0000
@@ -0,0 +1,49 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>SdfIScrollableFeatureReader Member List</h1>This is the complete list of members for <a class="el" href="class_sdf_i_scrollable_feature_reader.html">SdfIScrollableFeatureReader</a>, including all inherited members.<p><table>
+ <tr class="memlist"><td><a class="el" href="class_sdf_i_scrollable_feature_reader_0c8bd83991d3de13ea3914e50eea68cd.html#0c8bd83991d3de13ea3914e50eea68cd">Count</a>()=0</td><td><a class="el" href="class_sdf_i_scrollable_feature_reader.html">SdfIScrollableFeatureReader</a></td><td><code> [pure virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_sdf_i_scrollable_feature_reader_d692f60e023be7168ac6cf22d781cacd.html#d692f60e023be7168ac6cf22d781cacd">IndexOf</a>(FdoPropertyValueCollection *key)=0</td><td><a class="el" href="class_sdf_i_scrollable_feature_reader.html">SdfIScrollableFeatureReader</a></td><td><code> [pure virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_sdf_i_scrollable_feature_reader_3e1b34ea5d045715c41d232c261f9f37.html#3e1b34ea5d045715c41d232c261f9f37">ReadAt</a>(FdoPropertyValueCollection *key)=0</td><td><a class="el" href="class_sdf_i_scrollable_feature_reader.html">SdfIScrollableFeatureReader</a></td><td><code> [pure virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_sdf_i_scrollable_feature_reader_1f018e50f3f7fb295d1c0968bc66aad3.html#1f018e50f3f7fb295d1c0968bc66aad3">ReadAtIndex</a>(unsigned int recordindex)=0</td><td><a class="el" href="class_sdf_i_scrollable_feature_reader.html">SdfIScrollableFeatureReader</a></td><td><code> [pure virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_sdf_i_scrollable_feature_reader_5b3f6fe4b58576aef1f2b3e47bd32392.html#5b3f6fe4b58576aef1f2b3e47bd32392">ReadFirst</a>()=0</td><td><a class="el" href="class_sdf_i_scrollable_feature_reader.html">SdfIScrollableFeatureReader</a></td><td><code> [pure virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_sdf_i_scrollable_feature_reader_31612208adc6a6e34023b40ccbbe9ee9.html#31612208adc6a6e34023b40ccbbe9ee9">ReadLast</a>()=0</td><td><a class="el" href="class_sdf_i_scrollable_feature_reader.html">SdfIScrollableFeatureReader</a></td><td><code> [pure virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_sdf_i_scrollable_feature_reader_8de8b2476b8dc5051c7f17f734b4693c.html#8de8b2476b8dc5051c7f17f734b4693c">ReadPrevious</a>()=0</td><td><a class="el" href="class_sdf_i_scrollable_feature_reader.html">SdfIScrollableFeatureReader</a></td><td><code> [pure virtual]</code></td></tr>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader.html?view=auto&rev=47
--- (empty file)
+++ trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader.html 2006-07-26 16:15:19+0000
@@ -0,0 +1,82 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>SdfIScrollableFeatureReader Class Reference</h1><!-- doxytag: class="SdfIScrollableFeatureReader" --><code>#include <<a class="el" href="_i_scrollable_feature_reader_8h-source.html">IScrollableFeatureReader.h</a>></code>
+<p>
+<a href="class_sdf_i_scrollable_feature_reader-members.html">List of all members.</a><hr><a name="_details"></a><h2>Detailed Description</h2>
+<p>
+<p>
+Definition at line <a class="el" href="_i_scrollable_feature_reader_8h-source.html#l00022">22</a> of file <a class="el" href="_i_scrollable_feature_reader_8h-source.html">IScrollableFeatureReader.h</a>.<table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual int </td><td class="memItemRight" valign="bottom"><a class="el" href="class_sdf_i_scrollable_feature_reader_0c8bd83991d3de13ea3914e50eea68cd.html#0c8bd83991d3de13ea3914e50eea68cd">Count</a> ()=0</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Returns the number of records of the query result. <a href="#0c8bd83991d3de13ea3914e50eea68cd"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual unsigned int </td><td class="memItemRight" valign="bottom"><a class="el" href="class_sdf_i_scrollable_feature_reader_d692f60e023be7168ac6cf22d781cacd.html#d692f60e023be7168ac6cf22d781cacd">IndexOf</a> (FdoPropertyValueCollection *key)=0</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Given a key of a feature, IndexOf will return the one based index or the record number of the feature within the returned query result. If the record is not found, then zero is retuned. This is the mirror function of the GetAtIndex function. This method does not affect the reader position. GetAtIndex need to be called to move the reader to the returned index. <a href="#d692f60e023be7168ac6cf22d781cacd"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual bool </td><td class="memItemRight" valign="bottom"><a class="el" href="class_sdf_i_scrollable_feature_reader_3e1b34ea5d045715c41d232c261f9f37.html#3e1b34ea5d045715c41d232c261f9f37">ReadAt</a> (FdoPropertyValueCollection *key)=0</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">provide the ad-hoc access to the query result. It positions the position of the reader at a given record defined by the key. If the record is not found, then the reader position is unset and false value is returned. Once the readers position becames unset, the caller needs to call ReadFirst, ReadLast or ReadAt to re-position the reader at a valid location.<p>
+ <tr><td valign="top"></td><td valign="top"><em>key</em> </td><td>The key that identifies a record.</td></tr>
+ </table>
+</dl>
+<dl compact><dt><b>Returns:</b></dt><dd>Returns true if a record is found or false otherwise.</dd></dl>
+ <a href="#3e1b34ea5d045715c41d232c261f9f37"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual bool </td><td class="memItemRight" valign="bottom"><a class="el" href="class_sdf_i_scrollable_feature_reader_1f018e50f3f7fb295d1c0968bc66aad3.html#1f018e50f3f7fb295d1c0968bc66aad3">ReadAtIndex</a> (unsigned int recordindex)=0</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Provides an ad-hoc access to the query result. The recordindex is the one-based nth item in the query result. If successful, this method will position the reader at the feature identified by the recordindex. <a href="#1f018e50f3f7fb295d1c0968bc66aad3"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual bool </td><td class="memItemRight" valign="bottom"><a class="el" href="class_sdf_i_scrollable_feature_reader_5b3f6fe4b58576aef1f2b3e47bd32392.html#5b3f6fe4b58576aef1f2b3e47bd32392">ReadFirst</a> ()=0</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Position the reader at the first record of the query result. This method returns false if the query result is empty. <a href="#5b3f6fe4b58576aef1f2b3e47bd32392"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual bool </td><td class="memItemRight" valign="bottom"><a class="el" href="class_sdf_i_scrollable_feature_reader_31612208adc6a6e34023b40ccbbe9ee9.html#31612208adc6a6e34023b40ccbbe9ee9">ReadLast</a> ()=0</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Position the reader at the last record of the query result. This method returns false if the query result is empty. <a href="#31612208adc6a6e34023b40ccbbe9ee9"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual bool </td><td class="memItemRight" valign="bottom"><a class="el" href="class_sdf_i_scrollable_feature_reader_8de8b2476b8dc5051c7f17f734b4693c.html#8de8b2476b8dc5051c7f17f734b4693c">ReadPrevious</a> ()=0</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Advances the reader to the previous item and returns true if there is another object to read or false if reading is complete. The default position of the reader is prior to the first item. Therefore you must call ReadFirst or ReadLast to begin accessing any data. <a href="#8de8b2476b8dc5051c7f17f734b4693c"></a><br></td></tr>
+</table>
+<li><a class="el" href="_i_scrollable_feature_reader_8h-source.html">IScrollableFeatureReader.h</a></ul>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader_0c8bd83991d3de13ea3914e50eea68cd.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader_0c8bd83991d3de13ea3914e50eea68cd.html?view=auto&rev=47
--- (empty file)
+++ trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader_0c8bd83991d3de13ea3914e50eea68cd.html 2006-07-26 16:15:19+0000
@@ -0,0 +1,85 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li><a href="files.html"><span>Files</span></a></li>
+ </ul></div>
+<div class="nav">
+<a class="el" href="class_sdf_i_scrollable_feature_reader.html">SdfIScrollableFeatureReader</a></div>
+<table cellspacing="0" cellpadding="0" border="0">
+ <tr>
+ <td valign="top">
+ <div class="navtab">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_sdf_i_scrollable_feature_reader_0c8bd83991d3de13ea3914e50eea68cd.html#0c8bd83991d3de13ea3914e50eea68cd">Count</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_sdf_i_scrollable_feature_reader_d692f60e023be7168ac6cf22d781cacd.html#d692f60e023be7168ac6cf22d781cacd">IndexOf</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_sdf_i_scrollable_feature_reader_3e1b34ea5d045715c41d232c261f9f37.html#3e1b34ea5d045715c41d232c261f9f37">ReadAt</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_sdf_i_scrollable_feature_reader_1f018e50f3f7fb295d1c0968bc66aad3.html#1f018e50f3f7fb295d1c0968bc66aad3">ReadAtIndex</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_sdf_i_scrollable_feature_reader_5b3f6fe4b58576aef1f2b3e47bd32392.html#5b3f6fe4b58576aef1f2b3e47bd32392">ReadFirst</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_sdf_i_scrollable_feature_reader_31612208adc6a6e34023b40ccbbe9ee9.html#31612208adc6a6e34023b40ccbbe9ee9">ReadLast</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_sdf_i_scrollable_feature_reader_8de8b2476b8dc5051c7f17f734b4693c.html#8de8b2476b8dc5051c7f17f734b4693c">ReadPrevious</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="0c8bd83991d3de13ea3914e50eea68cd"></a><!-- doxytag: member="SdfIScrollableFeatureReader::Count" ref="0c8bd83991d3de13ea3914e50eea68cd" args="()=0" --><p>
+<table class="mdTable" cellpadding="2" cellspacing="0">
+ <tr>
+ <td class="mdRow">
+ <table cellpadding="0" cellspacing="0" border="0">
+ <tr>
+ <td class="md" nowrap valign="top">virtual int SdfIScrollableFeatureReader::Count </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+<table cellspacing="5" cellpadding="0" border="0">
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Returns the number of records of the query result.
+<p>
+<dl compact><dt><b>Returns:</b></dt><dd>Returns number of records.</dd></dl>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader_1f018e50f3f7fb295d1c0968bc66aad3.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader_1f018e50f3f7fb295d1c0968bc66aad3.html?view=auto&rev=47
--- (empty file)
+++ trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader_1f018e50f3f7fb295d1c0968bc66aad3.html 2006-07-26 16:15:19+0000
@@ -0,0 +1,91 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindex" href="class_sdf_i_scrollable_feature_reader_0c8bd83991d3de13ea3914e50eea68cd.html#0c8bd83991d3de13ea3914e50eea68cd">Count</a></td></tr>
+ <tr><td class="navtab"><a class="qindexHL" href="class_sdf_i_scrollable_feature_reader_1f018e50f3f7fb295d1c0968bc66aad3.html#1f018e50f3f7fb295d1c0968bc66aad3">ReadAtIndex</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="1f018e50f3f7fb295d1c0968bc66aad3"></a><!-- doxytag: member="SdfIScrollableFeatureReader::ReadAtIndex" ref="1f018e50f3f7fb295d1c0968bc66aad3" args="(unsigned int recordindex)=0" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual bool SdfIScrollableFeatureReader::ReadAtIndex </td>
+ <td class="md" nowrap valign="top">unsigned int </td>
+ <td class="mdname1" valign="top" nowrap> <em>recordindex</em> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Provides an ad-hoc access to the query result. The recordindex is the one-based nth item in the query result. If successful, this method will position the reader at the feature identified by the recordindex.
+<p>
+ <tr><td valign="top"></td><td valign="top"><em>recordindex</em> </td><td>The index of the row.</td></tr>
+ </table>
+</dl>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader_31612208adc6a6e34023b40ccbbe9ee9.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader_31612208adc6a6e34023b40ccbbe9ee9.html?view=auto&rev=47
--- (empty file)
+++ trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader_31612208adc6a6e34023b40ccbbe9ee9.html 2006-07-26 16:15:19+0000
@@ -0,0 +1,85 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_sdf_i_scrollable_feature_reader_31612208adc6a6e34023b40ccbbe9ee9.html#31612208adc6a6e34023b40ccbbe9ee9">ReadLast</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="31612208adc6a6e34023b40ccbbe9ee9"></a><!-- doxytag: member="SdfIScrollableFeatureReader::ReadLast" ref="31612208adc6a6e34023b40ccbbe9ee9" args="()=0" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual bool SdfIScrollableFeatureReader::ReadLast </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Position the reader at the last record of the query result. This method returns false if the query result is empty.
+<p>
+<dl compact><dt><b>Returns:</b></dt><dd>Returns true if a record is found or false if the result is empty.</dd></dl>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader_3e1b34ea5d045715c41d232c261f9f37.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader_3e1b34ea5d045715c41d232c261f9f37.html?view=auto&rev=47
--- (empty file)
+++ trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader_3e1b34ea5d045715c41d232c261f9f37.html 2006-07-26 16:15:19+0000
@@ -0,0 +1,92 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_sdf_i_scrollable_feature_reader_3e1b34ea5d045715c41d232c261f9f37.html#3e1b34ea5d045715c41d232c261f9f37">ReadAt</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="3e1b34ea5d045715c41d232c261f9f37"></a><!-- doxytag: member="SdfIScrollableFeatureReader::ReadAt" ref="3e1b34ea5d045715c41d232c261f9f37" args="(FdoPropertyValueCollection *key)=0" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual bool SdfIScrollableFeatureReader::ReadAt </td>
+ <td class="md" nowrap valign="top">FdoPropertyValueCollection * </td>
+ <td class="mdname1" valign="top" nowrap> <em>key</em> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+provide the ad-hoc access to the query result. It positions the position of the reader at a given record defined by the key. If the record is not found, then the reader position is unset and false value is returned. Once the readers position becames unset, the caller needs to call ReadFirst, ReadLast or ReadAt to re-position the reader at a valid location.<p>
+ </table>
+</dl>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader_5b3f6fe4b58576aef1f2b3e47bd32392.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader_5b3f6fe4b58576aef1f2b3e47bd32392.html?view=auto&rev=47
--- (empty file)
+++ trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader_5b3f6fe4b58576aef1f2b3e47bd32392.html 2006-07-26 16:15:19+0000
@@ -0,0 +1,85 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_sdf_i_scrollable_feature_reader_5b3f6fe4b58576aef1f2b3e47bd32392.html#5b3f6fe4b58576aef1f2b3e47bd32392">ReadFirst</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="5b3f6fe4b58576aef1f2b3e47bd32392"></a><!-- doxytag: member="SdfIScrollableFeatureReader::ReadFirst" ref="5b3f6fe4b58576aef1f2b3e47bd32392" args="()=0" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual bool SdfIScrollableFeatureReader::ReadFirst </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Position the reader at the first record of the query result. This method returns false if the query result is empty.
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader_8de8b2476b8dc5051c7f17f734b4693c.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader_8de8b2476b8dc5051c7f17f734b4693c.html?view=auto&rev=47
--- (empty file)
+++ trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader_8de8b2476b8dc5051c7f17f734b4693c.html 2006-07-26 16:15:19+0000
@@ -0,0 +1,85 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_sdf_i_scrollable_feature_reader_8de8b2476b8dc5051c7f17f734b4693c.html#8de8b2476b8dc5051c7f17f734b4693c">ReadPrevious</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="8de8b2476b8dc5051c7f17f734b4693c"></a><!-- doxytag: member="SdfIScrollableFeatureReader::ReadPrevious" ref="8de8b2476b8dc5051c7f17f734b4693c" args="()=0" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual bool SdfIScrollableFeatureReader::ReadPrevious </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Advances the reader to the previous item and returns true if there is another object to read or false if reading is complete. The default position of the reader is prior to the first item. Therefore you must call ReadFirst or ReadLast to begin accessing any data.
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader_d692f60e023be7168ac6cf22d781cacd.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader_d692f60e023be7168ac6cf22d781cacd.html?view=auto&rev=47
--- (empty file)
+++ trunk/www/docs/SDF/class_sdf_i_scrollable_feature_reader_d692f60e023be7168ac6cf22d781cacd.html 2006-07-26 16:15:19+0000
@@ -0,0 +1,91 @@
+<html>
+ <head>
+ </head>
+ <table width="100%" border="0">
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_sdf_i_scrollable_feature_reader_d692f60e023be7168ac6cf22d781cacd.html#d692f60e023be7168ac6cf22d781cacd">IndexOf</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="d692f60e023be7168ac6cf22d781cacd"></a><!-- doxytag: member="SdfIScrollableFeatureReader::IndexOf" ref="d692f60e023be7168ac6cf22d781cacd" args="(FdoPropertyValueCollection *key)=0" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual unsigned int SdfIScrollableFeatureReader::IndexOf </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Given a key of a feature, IndexOf will return the one based index or the record number of the feature within the returned query result. If the record is not found, then zero is retuned. This is the mirror function of the GetAtIndex function. This method does not affect the reader position. GetAtIndex need to be called to move the reader to the returned index.
+<p>
+ </table>
+</dl>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Modified: trunk/www/docs/SDF/classes.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/classes.html?view=diff&rev=47&p1=trunk/www/docs/SDF/classes.html&p2=trunk/www/docs/SDF/classes.html&r1=46&r2=47
--- trunk/www/docs/SDF/classes.html (original)
+++ trunk/www/docs/SDF/classes.html 2006-07-26 16:15:19+0000
@@ -29,10 +29,11 @@
<li><a href="hierarchy.html"><span>Class Hierarchy</span></a></li>
<li><a href="functions.html"><span>Class Members</span></a></li>
</ul></div>
-<h1>FDO Provider for SDF Class Index</h1><p><div class="qindex"><a class="qindex" href="#letter_F">F</a></div><p>
+<h1>FDO Provider for SDF Class Index</h1><p><div class="qindex"><a class="qindex" href="#letter_F">F</a> | <a class="qindex" href="#letter_S">S</a></div><p>
<table align="center" width="95%" border="0" cellspacing="0" cellpadding="0">
<tr><td><a name="letter_F"></a><table border="0" cellspacing="0" cellpadding="0"><tr><td><div class="ah"> F </div></td></tr></table>
-</td><td><a class="el" href="class_fdo_i_create_s_d_f_file.html">FdoICreateSDFFile</a> </td></tr></table><p><div class="qindex"><a class="qindex" href="#letter_F">F</a></div><p>
+</td><td><a name="letter_S"></a><table border="0" cellspacing="0" cellpadding="0"><tr><td><div class="ah"> S </div></td></tr></table>
+</td><td><a class="el" href="class_sdf_compare_handler.html">SdfCompareHandler</a> </td><td><a class="el" href="class_sdf_i_extended_select.html">SdfIExtendedSelect</a> </td><td><a class="el" href="class_sdf_i_scrollable_feature_reader.html">SdfIScrollableFeatureReader</a> </td></tr><tr><td><a class="el" href="class_fdo_i_create_s_d_f_file.html">FdoICreateSDFFile</a> </td></tr></table><p><div class="qindex"><a class="qindex" href="#letter_F">F</a> | <a class="qindex" href="#letter_S">S</a></div><p>
<hr>
Modified: trunk/www/docs/SDF/files.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/files.html?view=diff&rev=47&p1=trunk/www/docs/SDF/files.html&p2=trunk/www/docs/SDF/files.html&r1=46&r2=47
--- trunk/www/docs/SDF/files.html (original)
+++ trunk/www/docs/SDF/files.html 2006-07-26 16:15:19+0000
@@ -30,7 +30,10 @@
<h1>FDO Provider for SDF File List</h1>Here is a list of all files with brief descriptions:<table>
<tr><td class="indexkey"><a class="el" href="define__pages_8h.html">define_pages.h</a> <a href="define__pages_8h-source.html">[code]</a></td><td class="indexvalue"></td></tr>
<tr><td class="indexkey"><a class="el" href="_i_create_s_d_f_file_8h.html">ICreateSDFFile.h</a> <a href="_i_create_s_d_f_file_8h-source.html">[code]</a></td><td class="indexvalue"></td></tr>
+ <tr><td class="indexkey"><a class="el" href="_i_extended_select_8h.html">IExtendedSelect.h</a> <a href="_i_extended_select_8h-source.html">[code]</a></td><td class="indexvalue"></td></tr>
+ <tr><td class="indexkey"><a class="el" href="_i_scrollable_feature_reader_8h.html">IScrollableFeatureReader.h</a> <a href="_i_scrollable_feature_reader_8h-source.html">[code]</a></td><td class="indexvalue"></td></tr>
<tr><td class="indexkey"><a class="el" href="_sdf_command_type_8h.html">SdfCommandType.h</a> <a href="_sdf_command_type_8h-source.html">[code]</a></td><td class="indexvalue"></td></tr>
+ <tr><td class="indexkey"><a class="el" href="_sdf_compare_handler_8h.html">SdfCompareHandler.h</a> <a href="_sdf_compare_handler_8h-source.html">[code]</a></td><td class="indexvalue"></td></tr>
</table>
<hr>
Modified: trunk/www/docs/SDF/functions.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/functions.html?view=diff&rev=47&p1=trunk/www/docs/SDF/functions.html&p2=trunk/www/docs/SDF/functions.html&r1=46&r2=47
--- trunk/www/docs/SDF/functions.html (original)
+++ trunk/www/docs/SDF/functions.html 2006-07-26 16:15:19+0000
@@ -38,20 +38,36 @@
Here is a list of all class members with links to the classes they belong to:
<p>
<ul>
-<li>Execute()
-: <a class="el" href="class_fdo_i_create_s_d_f_file_05550ca7007c3e389b7029c41baa1587.html#05550ca7007c3e389b7029c41baa1587">FdoICreateSDFFile</a><li>GetCoordinateSystemWKT()
+<li>ClearOrderingOptions()
+: <a class="el" href="class_sdf_i_extended_select_56fb99cd7bef0a7528cf1dd408d32e16.html#56fb99cd7bef0a7528cf1dd408d32e16">SdfIExtendedSelect</a><li>Compare()
+: <a class="el" href="class_sdf_compare_handler_fb5771764ec97dd9888a0d243d01886b.html#fb5771764ec97dd9888a0d243d01886b">SdfCompareHandler</a><li>Count()
+: <a class="el" href="class_sdf_i_scrollable_feature_reader_0c8bd83991d3de13ea3914e50eea68cd.html#0c8bd83991d3de13ea3914e50eea68cd">SdfIScrollableFeatureReader</a><li>Create()
+: <a class="el" href="class_sdf_compare_handler_dd5c70a33541eb9eabc2d19021a768fd.html#dd5c70a33541eb9eabc2d19021a768fd">SdfCompareHandler</a><li>Dispose()
+: <a class="el" href="class_sdf_compare_handler_d3a014c324bcbb6e2eccbf17ee9b43f3.html#d3a014c324bcbb6e2eccbf17ee9b43f3">SdfCompareHandler</a><li>Execute()
+: <a class="el" href="class_fdo_i_create_s_d_f_file_05550ca7007c3e389b7029c41baa1587.html#05550ca7007c3e389b7029c41baa1587">FdoICreateSDFFile</a><li>ExecuteScrollable()
+: <a class="el" href="class_sdf_i_extended_select_d10d84246bb47e87adb334fd6d5e8836.html#d10d84246bb47e87adb334fd6d5e8836">SdfIExtendedSelect</a><li>GetCoordinateSystemWKT()
: <a class="el" href="class_fdo_i_create_s_d_f_file_0b8020c31deb9acc05311fd11f260c7d.html#0b8020c31deb9acc05311fd11f260c7d">FdoICreateSDFFile</a><li>GetFileName()
-: <a class="el" href="class_fdo_i_create_s_d_f_file_0bde059736005f052076c6735c8b2453.html#0bde059736005f052076c6735c8b2453">FdoICreateSDFFile</a><li>GetSpatialContextDescription()
+: <a class="el" href="class_fdo_i_create_s_d_f_file_0bde059736005f052076c6735c8b2453.html#0bde059736005f052076c6735c8b2453">FdoICreateSDFFile</a><li>GetOrderingOption()
+: <a class="el" href="class_sdf_i_extended_select_a9e4db2cb4a126bfd03259073ef74719.html#a9e4db2cb4a126bfd03259073ef74719">SdfIExtendedSelect</a><li>GetSpatialContextDescription()
: <a class="el" href="class_fdo_i_create_s_d_f_file_4d74d6f8e45e76d8c8606953ae4cb307.html#4d74d6f8e45e76d8c8606953ae4cb307">FdoICreateSDFFile</a><li>GetSpatialContextName()
: <a class="el" href="class_fdo_i_create_s_d_f_file_647ff5d7f47cf47422c32645074cce8d.html#647ff5d7f47cf47422c32645074cce8d">FdoICreateSDFFile</a><li>GetXYTolerance()
: <a class="el" href="class_fdo_i_create_s_d_f_file_4a2bb60374b5db4f9dca173de2845803.html#4a2bb60374b5db4f9dca173de2845803">FdoICreateSDFFile</a><li>GetZTolerance()
-: <a class="el" href="class_fdo_i_create_s_d_f_file_8b2fc8bbd39311d609c316fac75d765b.html#8b2fc8bbd39311d609c316fac75d765b">FdoICreateSDFFile</a><li>SetCoordinateSystemWKT()
+: <a class="el" href="class_fdo_i_create_s_d_f_file_8b2fc8bbd39311d609c316fac75d765b.html#8b2fc8bbd39311d609c316fac75d765b">FdoICreateSDFFile</a><li>IndexOf()
+: <a class="el" href="class_sdf_i_scrollable_feature_reader_d692f60e023be7168ac6cf22d781cacd.html#d692f60e023be7168ac6cf22d781cacd">SdfIScrollableFeatureReader</a><li>ReadAt()
+: <a class="el" href="class_sdf_i_scrollable_feature_reader_3e1b34ea5d045715c41d232c261f9f37.html#3e1b34ea5d045715c41d232c261f9f37">SdfIScrollableFeatureReader</a><li>ReadAtIndex()
+: <a class="el" href="class_sdf_i_scrollable_feature_reader_1f018e50f3f7fb295d1c0968bc66aad3.html#1f018e50f3f7fb295d1c0968bc66aad3">SdfIScrollableFeatureReader</a><li>ReadFirst()
+: <a class="el" href="class_sdf_i_scrollable_feature_reader_5b3f6fe4b58576aef1f2b3e47bd32392.html#5b3f6fe4b58576aef1f2b3e47bd32392">SdfIScrollableFeatureReader</a><li>ReadLast()
+: <a class="el" href="class_sdf_i_scrollable_feature_reader_31612208adc6a6e34023b40ccbbe9ee9.html#31612208adc6a6e34023b40ccbbe9ee9">SdfIScrollableFeatureReader</a><li>ReadPrevious()
+: <a class="el" href="class_sdf_i_scrollable_feature_reader_8de8b2476b8dc5051c7f17f734b4693c.html#8de8b2476b8dc5051c7f17f734b4693c">SdfIScrollableFeatureReader</a><li>SetCompareHandler()
+: <a class="el" href="class_sdf_i_extended_select_69a9441cd4ada6b204a5b3ccfde49eab.html#69a9441cd4ada6b204a5b3ccfde49eab">SdfIExtendedSelect</a><li>SetCoordinateSystemWKT()
: <a class="el" href="class_fdo_i_create_s_d_f_file_8bb4c31009cf0ab76fc094eadcf4ca91.html#8bb4c31009cf0ab76fc094eadcf4ca91">FdoICreateSDFFile</a><li>SetFileName()
-: <a class="el" href="class_fdo_i_create_s_d_f_file_e92b777da3c498180dd72fe4629ee788.html#e92b777da3c498180dd72fe4629ee788">FdoICreateSDFFile</a><li>SetSpatialContextDescription()
+: <a class="el" href="class_fdo_i_create_s_d_f_file_e92b777da3c498180dd72fe4629ee788.html#e92b777da3c498180dd72fe4629ee788">FdoICreateSDFFile</a><li>SetOrderingOption()
+: <a class="el" href="class_sdf_i_extended_select_8921a5db2a527690f4d5592daa014be8.html#8921a5db2a527690f4d5592daa014be8">SdfIExtendedSelect</a><li>SetSpatialContextDescription()
: <a class="el" href="class_fdo_i_create_s_d_f_file_86b4ac8510f46ad6629e42023f184cee.html#86b4ac8510f46ad6629e42023f184cee">FdoICreateSDFFile</a><li>SetSpatialContextName()
: <a class="el" href="class_fdo_i_create_s_d_f_file_bda73a210df146335a62e933ebe19948.html#bda73a210df146335a62e933ebe19948">FdoICreateSDFFile</a><li>SetXYTolerance()
: <a class="el" href="class_fdo_i_create_s_d_f_file_b3e528dda87b952a83786b2d01343524.html#b3e528dda87b952a83786b2d01343524">FdoICreateSDFFile</a><li>SetZTolerance()
-: <a class="el" href="class_fdo_i_create_s_d_f_file_2937b06fdf37207301200042b40e8d71.html#2937b06fdf37207301200042b40e8d71">FdoICreateSDFFile</a></ul>
+: <a class="el" href="class_fdo_i_create_s_d_f_file_2937b06fdf37207301200042b40e8d71.html#2937b06fdf37207301200042b40e8d71">FdoICreateSDFFile</a><li>~SdfCompareHandler()
+: <a class="el" href="class_sdf_compare_handler_c1e1a5c47894aa43ada963c4cb84b980.html#c1e1a5c47894aa43ada963c4cb84b980">SdfCompareHandler</a></ul>
<!-- footer.html -->
<hr>
Modified: trunk/www/docs/SDF/functions_func.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/functions_func.html?view=diff&rev=47&p1=trunk/www/docs/SDF/functions_func.html&p2=trunk/www/docs/SDF/functions_func.html&r1=46&r2=47
--- trunk/www/docs/SDF/functions_func.html (original)
+++ trunk/www/docs/SDF/functions_func.html 2006-07-26 16:15:19+0000
@@ -38,20 +38,36 @@
<p>
<ul>
-<li>Execute()
<hr>
Modified: trunk/www/docs/SDF/globals.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/globals.html?view=diff&rev=47&p1=trunk/www/docs/SDF/globals.html&p2=trunk/www/docs/SDF/globals.html&r1=46&r2=47
--- trunk/www/docs/SDF/globals.html (original)
+++ trunk/www/docs/SDF/globals.html 2006-07-26 16:15:19+0000
@@ -38,10 +38,12 @@
Here is a list of all file members with links to the files they belong to:
<p>
<ul>
-<li>SDF_FIRST_PROVIDER_COMMAND
+<li>SDF_API
+: <a class="el" href="_sdf_compare_handler_8h_9bfa9402971b67602a99fd99449c5d76.html#9bfa9402971b67602a99fd99449c5d76">SdfCompareHandler.h</a><li>SDF_FIRST_PROVIDER_COMMAND
: <a class="el" href="_sdf_command_type_8h_86597e57635d4329ec6b9d0a67f969d7.html#86597e57635d4329ec6b9d0a67f969d7">SdfCommandType.h</a><li>SdfCommandType
: <a class="el" href="_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html#4ac92492e0d58aeace1b0c0f96cefea3">SdfCommandType.h</a><li>SdfCommandType_CreateSDFFile
-: <a class="el" href="_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html#4ac92492e0d58aeace1b0c0f96cefea348c2e525ef9f5e6ae1db0962a09cff37">SdfCommandType.h</a></ul>
+: <a class="el" href="_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html#4ac92492e0d58aeace1b0c0f96cefea348c2e525ef9f5e6ae1db0962a09cff37">SdfCommandType.h</a><li>SdfCommandType_ExtendedSelect
+: <a class="el" href="_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html#4ac92492e0d58aeace1b0c0f96cefea3cff985287cc5191960dc4a2258697243">SdfCommandType.h</a></ul>
<hr>
Modified: trunk/www/docs/SDF/globals_defs.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/globals_defs.html?view=diff&rev=47&p1=trunk/www/docs/SDF/globals_defs.html&p2=trunk/www/docs/SDF/globals_defs.html&r1=46&r2=47
--- trunk/www/docs/SDF/globals_defs.html (original)
+++ trunk/www/docs/SDF/globals_defs.html 2006-07-26 16:15:19+0000
@@ -38,7 +38,8 @@
<p>
<ul>
+<li>SDF_API
: <a class="el" href="_sdf_command_type_8h_86597e57635d4329ec6b9d0a67f969d7.html#86597e57635d4329ec6b9d0a67f969d7">SdfCommandType.h</a></ul>
<hr>
Modified: trunk/www/docs/SDF/globals_eval.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/globals_eval.html?view=diff&rev=47&p1=trunk/www/docs/SDF/globals_eval.html&p2=trunk/www/docs/SDF/globals_eval.html&r1=46&r2=47
--- trunk/www/docs/SDF/globals_eval.html (original)
+++ trunk/www/docs/SDF/globals_eval.html 2006-07-26 16:15:19+0000
@@ -39,7 +39,8 @@
<p>
<ul>
<hr>
Modified: trunk/www/docs/SDF/hierarchy.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/hierarchy.html?view=diff&rev=47&p1=trunk/www/docs/SDF/hierarchy.html&p2=trunk/www/docs/SDF/hierarchy.html&r1=46&r2=47
--- trunk/www/docs/SDF/hierarchy.html (original)
+++ trunk/www/docs/SDF/hierarchy.html 2006-07-26 16:15:19+0000
@@ -33,6 +33,9 @@
<p>
This inheritance list is sorted roughly, but not completely, alphabetically:<ul>
<li><a class="el" href="class_fdo_i_create_s_d_f_file.html">FdoICreateSDFFile</a>
+<li><a class="el" href="class_sdf_compare_handler.html">SdfCompareHandler</a>
+<li><a class="el" href="class_sdf_i_extended_select.html">SdfIExtendedSelect</a>
+<li><a class="el" href="class_sdf_i_scrollable_feature_reader.html">SdfIScrollableFeatureReader</a>
</ul>
<hr>
Modified: trunk/www/docs/SDF/index.hhc
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/index.hhc?view=diff&rev=47&p1=trunk/www/docs/SDF/index.hhc&p2=trunk/www/docs/SDF/index.hhc&r1=46&r2=47
--- trunk/www/docs/SDF/index.hhc (original)
+++ trunk/www/docs/SDF/index.hhc 2006-07-26 16:15:19+0000
@@ -9,15 +9,24 @@
<UL>
<LI><OBJECT type="text/sitemap"><param name="Name" value="define_pages.h"><param name="Local" value="define__pages_8h.html"><param name="ImageNumber" value="11"></OBJECT>
<LI><OBJECT type="text/sitemap"><param name="Name" value="ICreateSDFFile.h"><param name="Local" value="_i_create_s_d_f_file_8h.html"><param name="ImageNumber" value="11"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Name" value="IExtendedSelect.h"><param name="Local" value="_i_extended_select_8h.html"><param name="ImageNumber" value="11"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Name" value="IScrollableFeatureReader.h"><param name="Local" value="_i_scrollable_feature_reader_8h.html"><param name="ImageNumber" value="11"></OBJECT>
<LI><OBJECT type="text/sitemap"><param name="Name" value="SdfCommandType.h"><param name="Local" value="_sdf_command_type_8h.html"><param name="ImageNumber" value="11"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Name" value="SdfCompareHandler.h"><param name="Local" value="_sdf_compare_handler_8h.html"><param name="ImageNumber" value="11"></OBJECT>
</UL>
<LI><OBJECT type="text/sitemap"><param name="Name" value="Class List"><param name="ImageNumber" value="1"></OBJECT>
<UL>
<LI><OBJECT type="text/sitemap"><param name="Name" value="FdoICreateSDFFile"><param name="Local" value="class_fdo_i_create_s_d_f_file.html"><param name="ImageNumber" value="11"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Name" value="SdfCompareHandler"><param name="Local" value="class_sdf_compare_handler.html"><param name="ImageNumber" value="11"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Name" value="SdfIExtendedSelect"><param name="Local" value="class_sdf_i_extended_select.html"><param name="ImageNumber" value="11"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Name" value="SdfIScrollableFeatureReader"><param name="Local" value="class_sdf_i_scrollable_feature_reader.html"><param name="ImageNumber" value="11"></OBJECT>
</UL>
<LI><OBJECT type="text/sitemap"><param name="Name" value="Class Hierarchy"><param name="ImageNumber" value="1"></OBJECT>
<UL>
</UL>
<LI><OBJECT type="text/sitemap"><param name="Name" value="Class Members"><param name="Local" value="functions.html"><param name="ImageNumber" value="11"></OBJECT>
<LI><OBJECT type="text/sitemap"><param name="Name" value="File Members"><param name="Local" value="globals.html"><param name="ImageNumber" value="11"></OBJECT>
Modified: trunk/www/docs/SDF/index.hhk
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/index.hhk?view=diff&rev=47&p1=trunk/www/docs/SDF/index.hhk&p2=trunk/www/docs/SDF/index.hhk&r1=46&r2=47
--- trunk/www/docs/SDF/index.hhk (original)
+++ trunk/www/docs/SDF/index.hhk 2006-07-26 16:15:19+0000
@@ -4,7 +4,13 @@
<param name="FrameName" value="right">
</OBJECT>
<UL>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_i_extended_select_56fb99cd7bef0a7528cf1dd408d32e16.html#56fb99cd7bef0a7528cf1dd408d32e16"><param name="Name" value="ClearOrderingOptions"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_compare_handler_fb5771764ec97dd9888a0d243d01886b.html#fb5771764ec97dd9888a0d243d01886b"><param name="Name" value="Compare"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_i_scrollable_feature_reader_0c8bd83991d3de13ea3914e50eea68cd.html#0c8bd83991d3de13ea3914e50eea68cd"><param name="Name" value="Count"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_compare_handler_dd5c70a33541eb9eabc2d19021a768fd.html#dd5c70a33541eb9eabc2d19021a768fd"><param name="Name" value="Create"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_compare_handler_d3a014c324bcbb6e2eccbf17ee9b43f3.html#d3a014c324bcbb6e2eccbf17ee9b43f3"><param name="Name" value="Dispose"></OBJECT>
<LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file_05550ca7007c3e389b7029c41baa1587.html#05550ca7007c3e389b7029c41baa1587"><param name="Name" value="Execute"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_i_extended_select_d10d84246bb47e87adb334fd6d5e8836.html#d10d84246bb47e87adb334fd6d5e8836"><param name="Name" value="ExecuteScrollable"></OBJECT>
<LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file.html"><param name="Name" value="FdoICreateSDFFile"></OBJECT>
<UL>
<LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file.html#05550ca7007c3e389b7029c41baa1587"><param name="Name" value="Execute"></OBJECT>
@@ -23,23 +29,62 @@
</UL>
<LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file_0b8020c31deb9acc05311fd11f260c7d.html#0b8020c31deb9acc05311fd11f260c7d"><param name="Name" value="GetCoordinateSystemWKT"></OBJECT>
<LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file_0bde059736005f052076c6735c8b2453.html#0bde059736005f052076c6735c8b2453"><param name="Name" value="GetFileName"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_i_extended_select_a9e4db2cb4a126bfd03259073ef74719.html#a9e4db2cb4a126bfd03259073ef74719"><param name="Name" value="GetOrderingOption"></OBJECT>
<LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file_4d74d6f8e45e76d8c8606953ae4cb307.html#4d74d6f8e45e76d8c8606953ae4cb307"><param name="Name" value="GetSpatialContextDescription"></OBJECT>
<LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file_647ff5d7f47cf47422c32645074cce8d.html#647ff5d7f47cf47422c32645074cce8d"><param name="Name" value="GetSpatialContextName"></OBJECT>
<LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file_4a2bb60374b5db4f9dca173de2845803.html#4a2bb60374b5db4f9dca173de2845803"><param name="Name" value="GetXYTolerance"></OBJECT>
<LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file_8b2fc8bbd39311d609c316fac75d765b.html#8b2fc8bbd39311d609c316fac75d765b"><param name="Name" value="GetZTolerance"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_i_scrollable_feature_reader_d692f60e023be7168ac6cf22d781cacd.html#d692f60e023be7168ac6cf22d781cacd"><param name="Name" value="IndexOf"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_i_scrollable_feature_reader_3e1b34ea5d045715c41d232c261f9f37.html#3e1b34ea5d045715c41d232c261f9f37"><param name="Name" value="ReadAt"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_i_scrollable_feature_reader_1f018e50f3f7fb295d1c0968bc66aad3.html#1f018e50f3f7fb295d1c0968bc66aad3"><param name="Name" value="ReadAtIndex"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_i_scrollable_feature_reader_5b3f6fe4b58576aef1f2b3e47bd32392.html#5b3f6fe4b58576aef1f2b3e47bd32392"><param name="Name" value="ReadFirst"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_i_scrollable_feature_reader_31612208adc6a6e34023b40ccbbe9ee9.html#31612208adc6a6e34023b40ccbbe9ee9"><param name="Name" value="ReadLast"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_i_scrollable_feature_reader_8de8b2476b8dc5051c7f17f734b4693c.html#8de8b2476b8dc5051c7f17f734b4693c"><param name="Name" value="ReadPrevious"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="_sdf_compare_handler_8h_9bfa9402971b67602a99fd99449c5d76.html#9bfa9402971b67602a99fd99449c5d76"><param name="Name" value="SDF_API"></OBJECT>
<LI><OBJECT type="text/sitemap"><param name="Local" value="_sdf_command_type_8h_86597e57635d4329ec6b9d0a67f969d7.html#86597e57635d4329ec6b9d0a67f969d7"><param name="Name" value="SDF_FIRST_PROVIDER_COMMAND"></OBJECT>
<LI><OBJECT type="text/sitemap"><param name="Local" value="_sdf_command_type_8h.html"><param name="Name" value="SdfCommandType.h"></OBJECT>
<UL>
<LI><OBJECT type="text/sitemap"><param name="Local" value="_sdf_command_type_8h.html#86597e57635d4329ec6b9d0a67f969d7"><param name="Name" value="SDF_FIRST_PROVIDER_COMMAND"></OBJECT>
<LI><OBJECT type="text/sitemap"><param name="Local" value="_sdf_command_type_8h.html#4ac92492e0d58aeace1b0c0f96cefea3"><param name="Name" value="SdfCommandType"></OBJECT>
<LI><OBJECT type="text/sitemap"><param name="Local" value="_sdf_command_type_8h.html#4ac92492e0d58aeace1b0c0f96cefea348c2e525ef9f5e6ae1db0962a09cff37"><param name="Name" value="SdfCommandType_CreateSDFFile"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="_sdf_command_type_8h.html#4ac92492e0d58aeace1b0c0f96cefea3cff985287cc5191960dc4a2258697243"><param name="Name" value="SdfCommandType_ExtendedSelect"></OBJECT>
</UL>
<LI><OBJECT type="text/sitemap"><param name="Local" value="_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html#4ac92492e0d58aeace1b0c0f96cefea3"><param name="Name" value="SdfCommandType"></OBJECT>
<LI><OBJECT type="text/sitemap"><param name="Local" value="_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html#4ac92492e0d58aeace1b0c0f96cefea348c2e525ef9f5e6ae1db0962a09cff37"><param name="Name" value="SdfCommandType_CreateSDFFile"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html#4ac92492e0d58aeace1b0c0f96cefea3cff985287cc5191960dc4a2258697243"><param name="Name" value="SdfCommandType_ExtendedSelect"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="_sdf_compare_handler_8h.html"><param name="Name" value="SdfCompareHandler.h"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_compare_handler.html"><param name="Name" value="SdfCompareHandler"></OBJECT>
+ <UL>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_compare_handler.html#fb5771764ec97dd9888a0d243d01886b"><param name="Name" value="Compare"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_compare_handler.html#dd5c70a33541eb9eabc2d19021a768fd"><param name="Name" value="Create"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_compare_handler.html#d3a014c324bcbb6e2eccbf17ee9b43f3"><param name="Name" value="Dispose"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_compare_handler.html#c1e1a5c47894aa43ada963c4cb84b980"><param name="Name" value="~SdfCompareHandler"></OBJECT>
+ </UL>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_i_extended_select.html"><param name="Name" value="SdfIExtendedSelect"></OBJECT>
+ <UL>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_i_extended_select.html#56fb99cd7bef0a7528cf1dd408d32e16"><param name="Name" value="ClearOrderingOptions"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_i_extended_select.html#d10d84246bb47e87adb334fd6d5e8836"><param name="Name" value="ExecuteScrollable"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_i_extended_select.html#a9e4db2cb4a126bfd03259073ef74719"><param name="Name" value="GetOrderingOption"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_i_extended_select.html#69a9441cd4ada6b204a5b3ccfde49eab"><param name="Name" value="SetCompareHandler"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_i_extended_select.html#8921a5db2a527690f4d5592daa014be8"><param name="Name" value="SetOrderingOption"></OBJECT>
+ </UL>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_i_scrollable_feature_reader.html"><param name="Name" value="SdfIScrollableFeatureReader"></OBJECT>
+ <UL>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_i_scrollable_feature_reader.html#0c8bd83991d3de13ea3914e50eea68cd"><param name="Name" value="Count"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_i_scrollable_feature_reader.html#d692f60e023be7168ac6cf22d781cacd"><param name="Name" value="IndexOf"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_i_scrollable_feature_reader.html#3e1b34ea5d045715c41d232c261f9f37"><param name="Name" value="ReadAt"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_i_scrollable_feature_reader.html#1f018e50f3f7fb295d1c0968bc66aad3"><param name="Name" value="ReadAtIndex"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_i_scrollable_feature_reader.html#5b3f6fe4b58576aef1f2b3e47bd32392"><param name="Name" value="ReadFirst"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_i_scrollable_feature_reader.html#31612208adc6a6e34023b40ccbbe9ee9"><param name="Name" value="ReadLast"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_i_scrollable_feature_reader.html#8de8b2476b8dc5051c7f17f734b4693c"><param name="Name" value="ReadPrevious"></OBJECT>
+ </UL>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_i_extended_select_69a9441cd4ada6b204a5b3ccfde49eab.html#69a9441cd4ada6b204a5b3ccfde49eab"><param name="Name" value="SetCompareHandler"></OBJECT>
<LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file_8bb4c31009cf0ab76fc094eadcf4ca91.html#8bb4c31009cf0ab76fc094eadcf4ca91"><param name="Name" value="SetCoordinateSystemWKT"></OBJECT>
<LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file_e92b777da3c498180dd72fe4629ee788.html#e92b777da3c498180dd72fe4629ee788"><param name="Name" value="SetFileName"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_i_extended_select_8921a5db2a527690f4d5592daa014be8.html#8921a5db2a527690f4d5592daa014be8"><param name="Name" value="SetOrderingOption"></OBJECT>
<LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file_86b4ac8510f46ad6629e42023f184cee.html#86b4ac8510f46ad6629e42023f184cee"><param name="Name" value="SetSpatialContextDescription"></OBJECT>
<LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file_bda73a210df146335a62e933ebe19948.html#bda73a210df146335a62e933ebe19948"><param name="Name" value="SetSpatialContextName"></OBJECT>
<LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file_b3e528dda87b952a83786b2d01343524.html#b3e528dda87b952a83786b2d01343524"><param name="Name" value="SetXYTolerance"></OBJECT>
<LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file_2937b06fdf37207301200042b40e8d71.html#2937b06fdf37207301200042b40e8d71"><param name="Name" value="SetZTolerance"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_sdf_compare_handler_c1e1a5c47894aa43ada963c4cb84b980.html#c1e1a5c47894aa43ada963c4cb84b980"><param name="Name" value="~SdfCompareHandler"></OBJECT>
</UL>
Modified: trunk/www/docs/SDF/index.hhp
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/index.hhp?view=diff&rev=47&p1=trunk/www/docs/SDF/index.hhp&p2=trunk/www/docs/SDF/index.hhp&r1=46&r2=47
--- trunk/www/docs/SDF/index.hhp (original)
+++ trunk/www/docs/SDF/index.hhp 2006-07-26 16:15:19+0000
@@ -1,5 +1,5 @@
[OPTIONS]
-Compiled file=../../../SDF_Provider_API.chm
+Compiled file=../../SDF_Provider_API.chm
Compatibility=1.1
Full-text search=Yes
Contents file=index.hhc
@@ -18,12 +18,19 @@
files.html
+_i_extended_select_8h-source.html
+_i_scrollable_feature_reader_8h-source.html
+_sdf_compare_handler_8h-source.html
+_i_extended_select_8h.html
+_i_scrollable_feature_reader_8h.html
+_sdf_compare_handler_8h.html
+_sdf_compare_handler_8h_9bfa9402971b67602a99fd99449c5d76.html
annotated.html
classes.html
hierarchy.html
@@ -44,6 +51,36 @@
class_fdo_i_create_s_d_f_file-members.html
+class_sdf_compare_handler.html
+class_sdf_compare_handler_c1e1a5c47894aa43ada963c4cb84b980.html
+class_sdf_compare_handler_fb5771764ec97dd9888a0d243d01886b.html
+class_sdf_compare_handler_5da8124ec6d48c42207912cb1004168c.html
+class_sdf_compare_handler_3ade9dcf05112bb16590f695c022a474.html
+class_sdf_compare_handler_25efcd708f7d73df47e3f592a4dc9df2.html
+class_sdf_compare_handler_3a1cda4006166f838c9c90dbbd16daf5.html
+class_sdf_compare_handler_fba0af521a5201a71547bce66c36f583.html
+class_sdf_compare_handler_e99c60fe9321858c35f204003e06954c.html
+class_sdf_compare_handler_4b9fe2c6a37153efe808fbe7b9cfac39.html
+class_sdf_compare_handler_dd5c70a33541eb9eabc2d19021a768fd.html
+class_sdf_compare_handler_d3a014c324bcbb6e2eccbf17ee9b43f3.html
+class_sdf_compare_handler-members.html
+class_sdf_i_extended_select.html
+class_sdf_i_extended_select_56fb99cd7bef0a7528cf1dd408d32e16.html
+class_sdf_i_extended_select_d10d84246bb47e87adb334fd6d5e8836.html
+class_sdf_i_extended_select_7094d0597a2dec8f759b553af3c5aebd.html
+class_sdf_i_extended_select_a9e4db2cb4a126bfd03259073ef74719.html
+class_sdf_i_extended_select_69a9441cd4ada6b204a5b3ccfde49eab.html
+class_sdf_i_extended_select_8921a5db2a527690f4d5592daa014be8.html
+class_sdf_i_extended_select-members.html
+class_sdf_i_scrollable_feature_reader.html
+class_sdf_i_scrollable_feature_reader_0c8bd83991d3de13ea3914e50eea68cd.html
+class_sdf_i_scrollable_feature_reader_d692f60e023be7168ac6cf22d781cacd.html
+class_sdf_i_scrollable_feature_reader_3e1b34ea5d045715c41d232c261f9f37.html
+class_sdf_i_scrollable_feature_reader_1f018e50f3f7fb295d1c0968bc66aad3.html
+class_sdf_i_scrollable_feature_reader_5b3f6fe4b58576aef1f2b3e47bd32392.html
+class_sdf_i_scrollable_feature_reader_31612208adc6a6e34023b40ccbbe9ee9.html
+class_sdf_i_scrollable_feature_reader_8de8b2476b8dc5051c7f17f734b4693c.html
+class_sdf_i_scrollable_feature_reader-members.html
globals.html
globals_enum.html
globals_eval.html
Added: trunk/www/docs/SDF/inherit__graph__1.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/inherit__graph__1.map?view=auto&rev=47
--- (empty file)
+++ trunk/www/docs/SDF/inherit__graph__1.map 2006-07-26 16:15:19+0000
@@ -0,0 +1,2 @@
+base referer
+rect $class_sdf_compare_handler.html 7,7 151,33
Added: trunk/www/docs/SDF/inherit__graph__1.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/inherit__graph__1.md5?view=auto&rev=47
--- (empty file)
+++ trunk/www/docs/SDF/inherit__graph__1.md5 2006-07-26 16:15:19+0000
@@ -0,0 +1 @@
+029bf9cda700dadbc0efdb3ba9e5d079
\ No newline at end of file
Added: trunk/www/docs/SDF/inherit__graph__1.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/inherit__graph__1.png?view=auto&rev=47
Binary file. No diff available.
Added: trunk/www/docs/SDF/inherit__graph__2.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/inherit__graph__2.map?view=auto&rev=47
--- (empty file)
+++ trunk/www/docs/SDF/inherit__graph__2.map 2006-07-26 16:15:19+0000
@@ -0,0 +1,2 @@
+base referer
+rect $class_sdf_i_extended_select.html 8,7 147,33
Added: trunk/www/docs/SDF/inherit__graph__2.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/inherit__graph__2.md5?view=auto&rev=47
--- (empty file)
+++ trunk/www/docs/SDF/inherit__graph__2.md5 2006-07-26 16:15:19+0000
@@ -0,0 +1 @@
+d88ffb3ec8f32a714182eadf656f907a
Added: trunk/www/docs/SDF/inherit__graph__2.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/inherit__graph__2.png?view=auto&rev=47
Added: trunk/www/docs/SDF/inherit__graph__3.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/inherit__graph__3.map?view=auto&rev=47
--- (empty file)
+++ trunk/www/docs/SDF/inherit__graph__3.map 2006-07-26 16:15:19+0000
@@ -0,0 +1,2 @@
+base referer
+rect $class_sdf_i_scrollable_feature_reader.html 7,7 201,33
Added: trunk/www/docs/SDF/inherit__graph__3.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/inherit__graph__3.md5?view=auto&rev=47
--- (empty file)
+++ trunk/www/docs/SDF/inherit__graph__3.md5 2006-07-26 16:15:19+0000
@@ -0,0 +1 @@
+bddb4d26caf3c87c319b7b7a29a8903d
Added: trunk/www/docs/SDF/inherit__graph__3.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/inherit__graph__3.png?view=auto&rev=47
Modified: trunk/www/docs/SDF/inherits.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/inherits.html?view=diff&rev=47&p1=trunk/www/docs/SDF/inherits.html&p2=trunk/www/docs/SDF/inherits.html&r1=46&r2=47
--- trunk/www/docs/SDF/inherits.html (original)
+++ trunk/www/docs/SDF/inherits.html 2006-07-26 16:15:19+0000
@@ -36,6 +36,18 @@
<map name="_fdo_i_create_s_d_f_file_map">
<area href="class_fdo_i_create_s_d_f_file.html" shape="rect" coords="7,7,145,33" alt="">
</map></td></tr>
+<tr><td><img src="inherit__graph__1.png" border="0" alt="" usemap="#_sdf_compare_handler_map">
+<map name="_sdf_compare_handler_map">
+<area href="class_sdf_compare_handler.html" shape="rect" coords="7,7,151,33" alt="">
+</map></td></tr>
+<tr><td><img src="inherit__graph__2.png" border="0" alt="" usemap="#_sdf_i_extended_select_map">
+<map name="_sdf_i_extended_select_map">
+<area href="class_sdf_i_extended_select.html" shape="rect" coords="8,7,147,33" alt="">
+</map></td></tr>
+<tr><td><img src="inherit__graph__3.png" border="0" alt="" usemap="#_sdf_i_scrollable_feature_reader_map">
+<map name="_sdf_i_scrollable_feature_reader_map">
+<area href="class_sdf_i_scrollable_feature_reader.html" shape="rect" coords="7,7,201,33" alt="">
+</map></td></tr>
</table>
<hr>
Modified: trunk/www/docs/SDF/tree.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/tree.html?view=diff&rev=47&p1=trunk/www/docs/SDF/tree.html&p2=trunk/www/docs/SDF/tree.html&r1=46&r2=47
--- trunk/www/docs/SDF/tree.html (original)
+++ trunk/www/docs/SDF/tree.html 2006-07-26 16:15:19+0000
@@ -77,15 +77,24 @@
<div id="folder1">
<p><img src="ftv2vertline.png" alt="|" width=16 height=22 /><img src="ftv2node.png" alt="o" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="define__pages_8h.html" target="basefrm">define_pages.h</a></p>
<p><img src="ftv2vertline.png" alt="|" width=16 height=22 /><img src="ftv2node.png" alt="o" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="_i_create_s_d_f_file_8h.html" target="basefrm">ICreateSDFFile.h</a></p>
- <p><img src="ftv2vertline.png" alt="|" width=16 height=22 /><img src="ftv2lastnode.png" alt="\" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="_sdf_command_type_8h.html" target="basefrm">SdfCommandType.h</a></p>
+ <p><img src="ftv2vertline.png" alt="|" width=16 height=22 /><img src="ftv2node.png" alt="o" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="_i_extended_select_8h.html" target="basefrm">IExtendedSelect.h</a></p>
+ <p><img src="ftv2vertline.png" alt="|" width=16 height=22 /><img src="ftv2node.png" alt="o" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="_i_scrollable_feature_reader_8h.html" target="basefrm">IScrollableFeatureReader.h</a></p>
+ <p><img src="ftv2vertline.png" alt="|" width=16 height=22 /><img src="ftv2node.png" alt="o" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="_sdf_command_type_8h.html" target="basefrm">SdfCommandType.h</a></p>
+ <p><img src="ftv2vertline.png" alt="|" width=16 height=22 /><img src="ftv2lastnode.png" alt="\" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="_sdf_compare_handler_8h.html" target="basefrm">SdfCompareHandler.h</a></p>
</div>
<p><img src="ftv2pnode.png" alt="o" width=16 height=22 onclick="toggleFolder('folder2', this)"/><img src="ftv2folderclosed.png" alt="+" width=24 height=22 onclick="toggleFolder('folder2', this)"/><a class="el" href="annotated.html" target="basefrm">Class List</a></p>
<div id="folder2">
- <p><img src="ftv2vertline.png" alt="|" width=16 height=22 /><img src="ftv2lastnode.png" alt="\" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="class_fdo_i_create_s_d_f_file.html" target="basefrm">FdoICreateSDFFile</a></p>
+ <p><img src="ftv2vertline.png" alt="|" width=16 height=22 /><img src="ftv2node.png" alt="o" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="class_fdo_i_create_s_d_f_file.html" target="basefrm">FdoICreateSDFFile</a></p>
+ <p><img src="ftv2vertline.png" alt="|" width=16 height=22 /><img src="ftv2node.png" alt="o" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="class_sdf_compare_handler.html" target="basefrm">SdfCompareHandler</a></p>
+ <p><img src="ftv2vertline.png" alt="|" width=16 height=22 /><img src="ftv2node.png" alt="o" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="class_sdf_i_extended_select.html" target="basefrm">SdfIExtendedSelect</a></p>
+ <p><img src="ftv2vertline.png" alt="|" width=16 height=22 /><img src="ftv2lastnode.png" alt="\" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="class_sdf_i_scrollable_feature_reader.html" target="basefrm">SdfIScrollableFeatureReader</a></p>
</div>
<p><img src="ftv2pnode.png" alt="o" width=16 height=22 onclick="toggleFolder('folder3', this)"/><img src="ftv2folderclosed.png" alt="+" width=24 height=22 onclick="toggleFolder('folder3', this)"/><a class="el" href="hierarchy.html" target="basefrm">Class Hierarchy</a></p>
<div id="folder3">
</div>
<p><img src="ftv2node.png" alt="o" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="functions.html" target="basefrm">Class Members</a></p>
<p><img src="ftv2node.png" alt="o" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="globals.html" target="basefrm">File Members</a></p>
More information about the Fdo-commits
