svn commit: r4 - trunk/www/docs: SDF SHP
robertbray at osgeo.org
Mon Mar 6 16:40:51 EST 2006
Author: robertbray
Date: 2006-03-06 21:40:50+0000
New Revision: 4
Added:
trunk/www/docs/SDF/
trunk/www/docs/SDF/_i_create_s_d_f_file_8h-source.html
trunk/www/docs/SDF/_i_create_s_d_f_file_8h.html
trunk/www/docs/SDF/_i_create_s_d_f_file_8h__incl.map
trunk/www/docs/SDF/_i_create_s_d_f_file_8h__incl.md5
trunk/www/docs/SDF/_i_create_s_d_f_file_8h__incl.png (contents, props changed)
trunk/www/docs/SDF/_sdf_command_type_8h-source.html
trunk/www/docs/SDF/_sdf_command_type_8h.html
trunk/www/docs/SDF/_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html
trunk/www/docs/SDF/_sdf_command_type_8h_86597e57635d4329ec6b9d0a67f969d7.html
trunk/www/docs/SDF/_sdf_command_type_8h__incl.map
trunk/www/docs/SDF/_sdf_command_type_8h__incl.md5
trunk/www/docs/SDF/_sdf_command_type_8h__incl.png (contents, props changed)
trunk/www/docs/SDF/annotated.html
trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file-members.html
trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file.html
trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_05550ca7007c3e389b7029c41baa1587.html
trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_2937b06fdf37207301200042b40e8d71.html
trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_31d3dc34da21f6049581211a14b27d37.html
trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_4a2bb60374b5db4f9dca173de2845803.html
trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_65ffde001f9b3d4932c4163a8e8e2134.html
trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_7f8850475beb73c192be00a4960628a1.html
trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_8b2fc8bbd39311d609c316fac75d765b.html
trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_9920ab315df81464390397ee73bcfab4.html
trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_a98dd232eefdc6835623c5deec259123.html
trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_ad37e0d64c5a74e57765a108447332bb.html
trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_b3e528dda87b952a83786b2d01343524.html
trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_e37b34b21d62e779c004fb5229a83d37.html
trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_eb8a85d56333894242c2ad05ede1a830.html
trunk/www/docs/SDF/classes.html
trunk/www/docs/SDF/custom.css
trunk/www/docs/SDF/define__pages_8h-source.html
trunk/www/docs/SDF/define__pages_8h.html
trunk/www/docs/SDF/doxygen.png (contents, props changed)
trunk/www/docs/SDF/files.html
trunk/www/docs/SDF/ftv2blank.png (contents, props changed)
trunk/www/docs/SDF/ftv2doc.png (contents, props changed)
trunk/www/docs/SDF/ftv2folderclosed.png (contents, props changed)
trunk/www/docs/SDF/ftv2folderopen.png (contents, props changed)
trunk/www/docs/SDF/ftv2lastnode.png (contents, props changed)
trunk/www/docs/SDF/ftv2link.png (contents, props changed)
trunk/www/docs/SDF/ftv2mlastnode.png (contents, props changed)
trunk/www/docs/SDF/ftv2mnode.png (contents, props changed)
trunk/www/docs/SDF/ftv2node.png (contents, props changed)
trunk/www/docs/SDF/ftv2plastnode.png (contents, props changed)
trunk/www/docs/SDF/ftv2pnode.png (contents, props changed)
trunk/www/docs/SDF/ftv2vertline.png (contents, props changed)
trunk/www/docs/SDF/functions.html
trunk/www/docs/SDF/functions_func.html
trunk/www/docs/SDF/globals.html
trunk/www/docs/SDF/globals_defs.html
trunk/www/docs/SDF/globals_enum.html
trunk/www/docs/SDF/globals_eval.html
trunk/www/docs/SDF/graph_legend.dot
trunk/www/docs/SDF/graph_legend.html
trunk/www/docs/SDF/graph_legend.png (contents, props changed)
trunk/www/docs/SDF/hierarchy.html
trunk/www/docs/SDF/index.hhc
trunk/www/docs/SDF/index.hhk
trunk/www/docs/SDF/index.hhp
trunk/www/docs/SDF/index.html
trunk/www/docs/SDF/inherit__graph__0.map
trunk/www/docs/SDF/inherit__graph__0.md5
trunk/www/docs/SDF/inherit__graph__0.png (contents, props changed)
trunk/www/docs/SDF/inherits.html
trunk/www/docs/SDF/main.html
trunk/www/docs/SDF/tab_b.gif (contents, props changed)
trunk/www/docs/SDF/tab_l.gif (contents, props changed)
trunk/www/docs/SDF/tab_r.gif (contents, props changed)
trunk/www/docs/SDF/tabs.css
trunk/www/docs/SDF/tree.html
trunk/www/docs/SHP/
trunk/www/docs/SHP/_fdo_shp_class_collection_8h-source.html
trunk/www/docs/SHP/_fdo_shp_class_collection_8h.html
trunk/www/docs/SHP/_fdo_shp_class_collection_8h_14b881fe200a848b2f39736eec0557f3.html
trunk/www/docs/SHP/_fdo_shp_class_collection_8h__dep__incl.map
trunk/www/docs/SHP/_fdo_shp_class_collection_8h__dep__incl.md5
trunk/www/docs/SHP/_fdo_shp_class_collection_8h__dep__incl.png (contents, props changed)
trunk/www/docs/SHP/_fdo_shp_class_collection_8h__incl.map
trunk/www/docs/SHP/_fdo_shp_class_collection_8h__incl.md5
trunk/www/docs/SHP/_fdo_shp_class_collection_8h__incl.png (contents, props changed)
trunk/www/docs/SHP/_fdo_shp_class_definition_8h-source.html
trunk/www/docs/SHP/_fdo_shp_class_definition_8h.html
trunk/www/docs/SHP/_fdo_shp_class_definition_8h_4e85e161f3a61d5a480c8d71c3bfd4ff.html
trunk/www/docs/SHP/_fdo_shp_class_definition_8h__dep__incl.map
trunk/www/docs/SHP/_fdo_shp_class_definition_8h__dep__incl.md5
trunk/www/docs/SHP/_fdo_shp_class_definition_8h__dep__incl.png (contents, props changed)
trunk/www/docs/SHP/_fdo_shp_class_definition_8h__incl.map
trunk/www/docs/SHP/_fdo_shp_class_definition_8h__incl.md5
trunk/www/docs/SHP/_fdo_shp_class_definition_8h__incl.png (contents, props changed)
trunk/www/docs/SHP/_fdo_shp_column_definition_8h-source.html
trunk/www/docs/SHP/_fdo_shp_column_definition_8h.html
trunk/www/docs/SHP/_fdo_shp_column_definition_8h_8542aa83f9163bd323db446eb4e1035d.html
trunk/www/docs/SHP/_fdo_shp_column_definition_8h__dep__incl.map
trunk/www/docs/SHP/_fdo_shp_column_definition_8h__dep__incl.md5
trunk/www/docs/SHP/_fdo_shp_column_definition_8h__dep__incl.png (contents, props changed)
trunk/www/docs/SHP/_fdo_shp_physical_schema_mapping_8h-source.html
trunk/www/docs/SHP/_fdo_shp_physical_schema_mapping_8h.html
trunk/www/docs/SHP/_fdo_shp_physical_schema_mapping_8h__incl.map
trunk/www/docs/SHP/_fdo_shp_physical_schema_mapping_8h__incl.md5
trunk/www/docs/SHP/_fdo_shp_physical_schema_mapping_8h__incl.png (contents, props changed)
trunk/www/docs/SHP/_fdo_shp_physical_schema_mapping_8h_a6ba1b4d1f4f7db9e0005451ac2cb3f5.html
trunk/www/docs/SHP/_fdo_shp_property_definition_8h-source.html
trunk/www/docs/SHP/_fdo_shp_property_definition_8h.html
trunk/www/docs/SHP/_fdo_shp_property_definition_8h__dep__incl.map
trunk/www/docs/SHP/_fdo_shp_property_definition_8h__dep__incl.md5
trunk/www/docs/SHP/_fdo_shp_property_definition_8h__dep__incl.png (contents, props changed)
trunk/www/docs/SHP/_fdo_shp_property_definition_8h__incl.map
trunk/www/docs/SHP/_fdo_shp_property_definition_8h__incl.md5
trunk/www/docs/SHP/_fdo_shp_property_definition_8h__incl.png (contents, props changed)
trunk/www/docs/SHP/_fdo_shp_property_definition_8h_d0b59a42138824423a735f567bc1a47c.html
trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h-source.html
trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h.html
trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h_7d1d57dbcd029bc5b5d15fd32f2e165e.html
trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h__dep__incl.map
trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h__dep__incl.md5
trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h__dep__incl.png (contents, props changed)
trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h__incl.map
trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h__incl.md5
trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h__incl.png (contents, props changed)
trunk/www/docs/SHP/annotated.html
trunk/www/docs/SHP/class_fdo_shp_class_collection-members.html
trunk/www/docs/SHP/class_fdo_shp_class_collection.html
trunk/www/docs/SHP/class_fdo_shp_class_collection_523f8784b5a62bfd9a00ffb621bac528.html
trunk/www/docs/SHP/class_fdo_shp_class_collection_8ac302ce67fca3f9558ff5c647cfcff9.html
trunk/www/docs/SHP/class_fdo_shp_class_definition-members.html
trunk/www/docs/SHP/class_fdo_shp_class_definition.html
trunk/www/docs/SHP/class_fdo_shp_class_definition_1eb8e1be10f1d92361eacbbdc50a0677.html
trunk/www/docs/SHP/class_fdo_shp_class_definition_2e617c437f74fe496aac753fb7666146.html
trunk/www/docs/SHP/class_fdo_shp_class_definition_3d19e7886b05e4cfa5fb5371890ab97f.html
trunk/www/docs/SHP/class_fdo_shp_class_definition_4603016faf3795e4c4544f71e0fb4152.html
trunk/www/docs/SHP/class_fdo_shp_class_definition_95b2357abf02d1278ac66f01921db44b.html
trunk/www/docs/SHP/class_fdo_shp_class_definition_96936568a01aa49e3ef3fbb154fa5ad5.html
trunk/www/docs/SHP/class_fdo_shp_class_definition_b9340be1c7d393ddedcf670de2149d76.html
trunk/www/docs/SHP/class_fdo_shp_class_definition_bdc54fa302f857e4acc9a0c3660dd245.html
trunk/www/docs/SHP/class_fdo_shp_class_definition_c3f943759f93d8173aacc9ce12c8feee.html
trunk/www/docs/SHP/class_fdo_shp_class_definition_cb66f23743bb45b0e3faaa2bfafeaad8.html
trunk/www/docs/SHP/class_fdo_shp_class_definition_daed9b86862ad2148b72edadbbcf479e.html
trunk/www/docs/SHP/class_fdo_shp_column_definition-members.html
trunk/www/docs/SHP/class_fdo_shp_column_definition.html
trunk/www/docs/SHP/class_fdo_shp_column_definition_4ba0b1a32d4f0126a9a5079eab9fe025.html
trunk/www/docs/SHP/class_fdo_shp_column_definition_600ecd1991fa387cc926316543de81e8.html
trunk/www/docs/SHP/class_fdo_shp_column_definition_955c02380b27a475d2f00ad14568a2ae.html
trunk/www/docs/SHP/class_fdo_shp_column_definition_c9d77b68d5f4a385142690b92d0e7ef9.html
trunk/www/docs/SHP/class_fdo_shp_column_definition_d5669958dfaeb362578fde7cac156561.html
trunk/www/docs/SHP/class_fdo_shp_physical_schema_mapping-members.html
trunk/www/docs/SHP/class_fdo_shp_physical_schema_mapping.html
trunk/www/docs/SHP/class_fdo_shp_physical_schema_mapping_36448c6a7557f454b949b605a6c80129.html
trunk/www/docs/SHP/class_fdo_shp_physical_schema_mapping_45d51d0f0311ff85ed516136e2ce16f6.html
trunk/www/docs/SHP/class_fdo_shp_physical_schema_mapping_48e086264cd4780a442f8ecb841faea8.html
trunk/www/docs/SHP/class_fdo_shp_physical_schema_mapping_4d944a128be1ad6406974f8375f12f69.html
trunk/www/docs/SHP/class_fdo_shp_physical_schema_mapping_7c0b1de21670db480e4463bcecfce94b.html
trunk/www/docs/SHP/class_fdo_shp_physical_schema_mapping_852853e469120e86223be6db80bccb20.html
trunk/www/docs/SHP/class_fdo_shp_physical_schema_mapping_af942717804976ecf3233c259650fb48.html
trunk/www/docs/SHP/class_fdo_shp_physical_schema_mapping_bb73c56d22638012ed655b6a276e75db.html
trunk/www/docs/SHP/class_fdo_shp_physical_schema_mapping_cc639fa3a2ae6823d20042cc95f06dae.html
trunk/www/docs/SHP/class_fdo_shp_property_definition-members.html
trunk/www/docs/SHP/class_fdo_shp_property_definition.html
trunk/www/docs/SHP/class_fdo_shp_property_definition_20d2033a8034eaed4bfef6d0e3eabaab.html
trunk/www/docs/SHP/class_fdo_shp_property_definition_2961dfcc8cb657ce57689f56c9764fec.html
trunk/www/docs/SHP/class_fdo_shp_property_definition_3530f2250ead9a4f2589dfcf013b23b4.html
trunk/www/docs/SHP/class_fdo_shp_property_definition_9f411822896503e8e305bcd5baa501c3.html
trunk/www/docs/SHP/class_fdo_shp_property_definition_a603b74205bc257c10b7bc068f516292.html
trunk/www/docs/SHP/class_fdo_shp_property_definition_ca026498f207e7542714e2094301f456.html
trunk/www/docs/SHP/class_fdo_shp_property_definition_collection-members.html
trunk/www/docs/SHP/class_fdo_shp_property_definition_collection.html
trunk/www/docs/SHP/class_fdo_shp_property_definition_collection_6b3823628fb7e5e0833d9110c5128d07.html
trunk/www/docs/SHP/class_fdo_shp_property_definition_collection_f78776eddbd77318ae7278ed70d2eb29.html
trunk/www/docs/SHP/class_fdo_shp_property_definition_e2292de181258077b5faa7c1a62c80eb.html
trunk/www/docs/SHP/classes.html
trunk/www/docs/SHP/custom.css
trunk/www/docs/SHP/define__pages_8h-source.html
trunk/www/docs/SHP/define__pages_8h.html
trunk/www/docs/SHP/doxygen.png (contents, props changed)
trunk/www/docs/SHP/files.html
trunk/www/docs/SHP/ftv2blank.png (contents, props changed)
trunk/www/docs/SHP/ftv2doc.png (contents, props changed)
trunk/www/docs/SHP/ftv2folderclosed.png (contents, props changed)
trunk/www/docs/SHP/ftv2folderopen.png (contents, props changed)
trunk/www/docs/SHP/ftv2lastnode.png (contents, props changed)
trunk/www/docs/SHP/ftv2link.png (contents, props changed)
trunk/www/docs/SHP/ftv2mlastnode.png (contents, props changed)
trunk/www/docs/SHP/ftv2mnode.png (contents, props changed)
trunk/www/docs/SHP/ftv2node.png (contents, props changed)
trunk/www/docs/SHP/ftv2plastnode.png (contents, props changed)
trunk/www/docs/SHP/ftv2pnode.png (contents, props changed)
trunk/www/docs/SHP/ftv2vertline.png (contents, props changed)
trunk/www/docs/SHP/functions.html
trunk/www/docs/SHP/functions_func.html
trunk/www/docs/SHP/globals.html
trunk/www/docs/SHP/globals_type.html
trunk/www/docs/SHP/graph_legend.dot
trunk/www/docs/SHP/graph_legend.html
trunk/www/docs/SHP/graph_legend.png (contents, props changed)
trunk/www/docs/SHP/hierarchy.html
trunk/www/docs/SHP/index.hhc
trunk/www/docs/SHP/index.hhk
trunk/www/docs/SHP/index.hhp
trunk/www/docs/SHP/index.html
trunk/www/docs/SHP/inherit__graph__0.map
trunk/www/docs/SHP/inherit__graph__0.md5
trunk/www/docs/SHP/inherit__graph__0.png (contents, props changed)
trunk/www/docs/SHP/inherit__graph__1.map
trunk/www/docs/SHP/inherit__graph__1.md5
trunk/www/docs/SHP/inherit__graph__1.png (contents, props changed)
trunk/www/docs/SHP/inherit__graph__2.map
trunk/www/docs/SHP/inherit__graph__2.md5
trunk/www/docs/SHP/inherit__graph__2.png (contents, props changed)
trunk/www/docs/SHP/inherit__graph__3.map
trunk/www/docs/SHP/inherit__graph__3.md5
trunk/www/docs/SHP/inherit__graph__3.png (contents, props changed)
trunk/www/docs/SHP/inherit__graph__4.map
trunk/www/docs/SHP/inherit__graph__4.md5
trunk/www/docs/SHP/inherit__graph__4.png (contents, props changed)
trunk/www/docs/SHP/inherit__graph__5.map
trunk/www/docs/SHP/inherit__graph__5.md5
trunk/www/docs/SHP/inherit__graph__5.png (contents, props changed)
trunk/www/docs/SHP/inherits.html
trunk/www/docs/SHP/installdox
trunk/www/docs/SHP/main.html
trunk/www/docs/SHP/search.idx (contents, props changed)
trunk/www/docs/SHP/search.php
trunk/www/docs/SHP/tab_b.gif (contents, props changed)
trunk/www/docs/SHP/tab_l.gif (contents, props changed)
trunk/www/docs/SHP/tab_r.gif (contents, props changed)
trunk/www/docs/SHP/tabs.css
trunk/www/docs/SHP/tree.html
Added: trunk/www/docs/SDF/_i_create_s_d_f_file_8h-source.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_i_create_s_d_f_file_8h-source.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SDF/_i_create_s_d_f_file_8h-source.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,222 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
+<html>
+ <head>
+ <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
+ <title>OSGeo FDO Provider for SDF API Reference</title>
+ <link href="custom.css" rel="stylesheet" type="text/css">
+ <link href="tabs.css" rel="stylesheet" type="text/css">
+ </head>
+ <body bgcolor="#FFFFFF">
+ <table width="100%" border="0">
+ <tr>
+ <td><b>API Reference<b></td>
+ <td align="right"><b>OSGeo FDO Provider for SDF<b></td>
+ </tr>
+ </table>
+<!-- End of: header.html -->
+<!-- Generated by Doxygen 1.4.6-NO -->
+<div class="tabs">
+ <ul>
+ <li><a href="main.html"><span>Main Page</span></a></li>
+ <li><a href="classes.html"><span>Classes</span></a></li>
+ <li id="current"><a href="files.html"><span>Files</span></a></li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li><a href="files.html"><span>File List</span></a></li>
+ <li><a href="globals.html"><span>File Members</span></a></li>
+ </ul></div>
+<h1>ICreateSDFFile.h</h1><a href="_i_create_s_d_f_file_8h.html">Go to the documentation of this file.</a><div class="fragment"><pre class="fragment"><a name="l00001"></a>00001 <span class="comment">// </span>
+<a name="l00002"></a>00002 <span class="comment">// Copyright (C) 2004-2006 Autodesk, Inc.</span>
+<a name="l00003"></a>00003 <span class="comment">// </span>
+<a name="l00004"></a>00004 <span class="comment">// This library is free software; you can redistribute it and/or</span>
+<a name="l00005"></a>00005 <span class="comment">// modify it under the terms of version 2.1 of the GNU Lesser</span>
+<a name="l00006"></a>00006 <span class="comment">// General Public License as published by the Free Software Foundation.</span>
+<a name="l00007"></a>00007 <span class="comment">// </span>
+<a name="l00008"></a>00008 <span class="comment">// This library is distributed in the hope that it will be useful,</span>
+<a name="l00009"></a>00009 <span class="comment">// but WITHOUT ANY WARRANTY; without even the implied warranty of</span>
+<a name="l00010"></a>00010 <span class="comment">// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU</span>
+<a name="l00011"></a>00011 <span class="comment">// Lesser General Public License for more details.</span>
+<a name="l00012"></a>00012 <span class="comment">// </span>
+<a name="l00013"></a>00013 <span class="comment">// You should have received a copy of the GNU Lesser General Public</span>
+<a name="l00014"></a>00014 <span class="comment">// License along with this library; if not, write to the Free Software</span>
+<a name="l00015"></a>00015 <span class="comment">// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA</span>
+<a name="l00016"></a>00016 <span class="preprocessor">#ifndef ICREATESDFFILE_H</span>
+<a name="l00017"></a>00017 <span class="preprocessor"></span><span class="preprocessor">#define ICREATESDFFILE_H</span>
+<a name="l00018"></a>00018 <span class="preprocessor"></span>
+<a name="l00019"></a>00019 <span class="preprocessor">#include "FdoStd.h"</span>
+<a name="l00020"></a>00020 <span class="preprocessor">#include "fdo/Commands/ICommand.h"</span>
+<a name="l00021"></a>00021
+<a name="l00022"></a>00022 <span class="comment"></span>
+<a name="l00023"></a>00023 <span class="comment">/// \brief</span>
+<a name="l00024"></a>00024 <span class="comment">/// This command creates a new SDF+ file with a specified location</span>
+<a name="l00025"></a>00025 <span class="comment">/// and file name and a given spatial coordinate system.</span>
+<a name="l00026"></a><a class="code" href="class_fdo_i_create_s_d_f_file.html">00026</a> <span class="comment"></span><span class="keyword">class </span><a class="code" href="class_fdo_i_create_s_d_f_file.html">FdoICreateSDFFile</a> : <span class="keyword">public</span> FdoICommand
+<a name="l00027"></a>00027 {
+<a name="l00028"></a>00028 <span class="keyword">public</span>:
+<a name="l00029"></a>00029 <span class="comment"></span>
+<a name="l00030"></a>00030 <span class="comment"> /// \brief</span>
+<a name="l00031"></a>00031 <span class="comment"> /// Sets the name of the SDF+ file being created.</span>
+<a name="l00032"></a>00032 <span class="comment"> /// The name must be a fully qualified absolute path.</span>
+<a name="l00033"></a>00033 <span class="comment"> /// </span>
+<a name="l00034"></a>00034 <span class="comment"> /// \param name </span>
+<a name="l00035"></a>00035 <span class="comment"> /// The fully qualified SDF+ file name.</span>
+<a name="l00036"></a>00036 <span class="comment"> /// </span>
+<a name="l00037"></a>00037 <span class="comment"> /// \return</span>
+<a name="l00038"></a>00038 <span class="comment"> /// Returns nothing.</span>
+<a name="l00039"></a>00039 <span class="comment"> /// </span>
+<a name="l00040"></a>00040 <span class="comment"></span> FDO_API <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_i_create_s_d_f_file_e37b34b21d62e779c004fb5229a83d37.html#e37b34b21d62e779c004fb5229a83d37">SetFileName</a>(GisString* name) = 0;
+<a name="l00041"></a>00041 <span class="comment"></span>
+<a name="l00042"></a>00042 <span class="comment"> /// \brief</span>
+<a name="l00043"></a>00043 <span class="comment"> /// Gets the name of the SDF+ file being created.</span>
+<a name="l00044"></a>00044 <span class="comment"> /// The name is a fully qualified absolute path.</span>
+<a name="l00045"></a>00045 <span class="comment"> /// </span>
+<a name="l00046"></a>00046 <span class="comment"> /// \return</span>
+<a name="l00047"></a>00047 <span class="comment"> /// Returns the name of the SDF+ file.</span>
+<a name="l00048"></a>00048 <span class="comment"> /// </span>
+<a name="l00049"></a>00049 <span class="comment"></span> FDO_API <span class="keyword">virtual</span> GisString* <a class="code" href="class_fdo_i_create_s_d_f_file_eb8a85d56333894242c2ad05ede1a830.html#eb8a85d56333894242c2ad05ede1a830">GetFileName</a>() = 0;
+<a name="l00050"></a>00050 <span class="comment"></span>
+<a name="l00051"></a>00051 <span class="comment"> /// \brief</span>
+<a name="l00052"></a>00052 <span class="comment"> /// Sets the name of the spatial context as a string.</span>
+<a name="l00053"></a>00053 <span class="comment"> /// </span>
+<a name="l00054"></a>00054 <span class="comment"> /// \param name </span>
+<a name="l00055"></a>00055 <span class="comment"> /// Input the name of the spatial context.</span>
+<a name="l00056"></a>00056 <span class="comment"> /// </span>
+<a name="l00057"></a>00057 <span class="comment"> /// \return</span>
+<a name="l00058"></a>00058 <span class="comment"> /// Returns nothing.</span>
+<a name="l00059"></a>00059 <span class="comment"> /// </span>
+<a name="l00060"></a>00060 <span class="comment"></span> FDO_API <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_i_create_s_d_f_file_ad37e0d64c5a74e57765a108447332bb.html#ad37e0d64c5a74e57765a108447332bb">SetSpatialContextName</a>(GisString* name) = 0;
+<a name="l00061"></a>00061 <span class="comment"></span>
+<a name="l00062"></a>00062 <span class="comment"> /// \brief</span>
+<a name="l00063"></a>00063 <span class="comment"> /// Gets the name of the coordinate system of the spatial context.</span>
+<a name="l00064"></a>00064 <span class="comment"> /// If the result is a null or empty string, the coordinate system is</span>
+<a name="l00065"></a>00065 <span class="comment"> /// unknown to the spatial context.</span>
+<a name="l00066"></a>00066 <span class="comment"> /// </span>
+<a name="l00067"></a>00067 <span class="comment"> /// \return</span>
+<a name="l00068"></a>00068 <span class="comment"> /// Returns the coordinate system name of the spatial context.</span>
+<a name="l00069"></a>00069 <span class="comment"> /// </span>
+<a name="l00070"></a>00070 <span class="comment"></span> FDO_API <span class="keyword">virtual</span> GisString* <a class="code" href="class_fdo_i_create_s_d_f_file_65ffde001f9b3d4932c4163a8e8e2134.html#65ffde001f9b3d4932c4163a8e8e2134">GetSpatialContextName</a>() = 0;
+<a name="l00071"></a>00071 <span class="comment"></span>
+<a name="l00072"></a>00072 <span class="comment"> /// \brief</span>
+<a name="l00073"></a>00073 <span class="comment"> /// Sets the description of the spatial context as a string.</span>
+<a name="l00074"></a>00074 <span class="comment"> /// </span>
+<a name="l00075"></a>00075 <span class="comment"> /// \param description </span>
+<a name="l00076"></a>00076 <span class="comment"> /// Input the description of the spatial context.</span>
+<a name="l00077"></a>00077 <span class="comment"> /// </span>
+<a name="l00078"></a>00078 <span class="comment"> /// \return</span>
+<a name="l00079"></a>00079 <span class="comment"> /// Returns nothing.</span>
+<a name="l00080"></a>00080 <span class="comment"> /// </span>
+<a name="l00081"></a>00081 <span class="comment"></span> FDO_API <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_i_create_s_d_f_file_9920ab315df81464390397ee73bcfab4.html#9920ab315df81464390397ee73bcfab4">SetSpatialContextDescription</a>(GisString* description) = 0;
+<a name="l00082"></a>00082 <span class="comment"></span>
+<a name="l00083"></a>00083 <span class="comment"> /// \brief</span>
+<a name="l00084"></a>00084 <span class="comment"> /// Gets the description of the spatial context.</span>
+<a name="l00085"></a>00085 <span class="comment"> /// </span>
+<a name="l00086"></a>00086 <span class="comment"> /// \return</span>
+<a name="l00087"></a>00087 <span class="comment"> /// Returns the description of the spatial context.</span>
+<a name="l00088"></a>00088 <span class="comment"> /// </span>
+<a name="l00089"></a>00089 <span class="comment"></span> FDO_API <span class="keyword">virtual</span> GisString* <a class="code" href="class_fdo_i_create_s_d_f_file_7f8850475beb73c192be00a4960628a1.html#7f8850475beb73c192be00a4960628a1">GetSpatialContextDescription</a>() = 0;
+<a name="l00090"></a>00090 <span class="comment"></span>
+<a name="l00091"></a>00091 <span class="comment"> /// \brief</span>
+<a name="l00092"></a>00092 <span class="comment"> /// Sets the coordinate system of the context to create as a string in</span>
+<a name="l00093"></a>00093 <span class="comment"> /// OpenGIS SRS WKT format.</span>
+<a name="l00094"></a>00094 <span class="comment"> /// </span>
+<a name="l00095"></a>00095 <span class="comment"> /// \param wkt </span>
+<a name="l00096"></a>00096 <span class="comment"> /// Input the coordinate system.</span>
+<a name="l00097"></a>00097 <span class="comment"> /// </span>
+<a name="l00098"></a>00098 <span class="comment"> /// \return</span>
+<a name="l00099"></a>00099 <span class="comment"> /// Returns nothing.</span>
+<a name="l00100"></a>00100 <span class="comment"> /// </span>
+<a name="l00101"></a>00101 <span class="comment"></span> FDO_API <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_i_create_s_d_f_file_a98dd232eefdc6835623c5deec259123.html#a98dd232eefdc6835623c5deec259123">SetCoordinateSystemWKT</a>(GisString* wkt) = 0;
+<a name="l00102"></a>00102 <span class="comment"></span>
+<a name="l00103"></a>00103 <span class="comment"> /// \brief</span>
+<a name="l00104"></a>00104 <span class="comment"> /// Gets the name of the coordinate system in OpenGIS SRS WKT format of the spatial context.</span>
+<a name="l00105"></a>00105 <span class="comment"> /// If the result is an empty string, the coordinate system WKT description is</span>
+<a name="l00106"></a>00106 <span class="comment"> /// not available.</span>
+<a name="l00107"></a>00107 <span class="comment"> /// </span>
+<a name="l00108"></a>00108 <span class="comment"> /// \return</span>
+<a name="l00109"></a>00109 <span class="comment"> /// Returns the coordinate system description in WKT format of the spatial context.</span>
+<a name="l00110"></a>00110 <span class="comment"> /// </span>
+<a name="l00111"></a>00111 <span class="comment"></span> FDO_API <span class="keyword">virtual</span> GisString* <a class="code" href="class_fdo_i_create_s_d_f_file_31d3dc34da21f6049581211a14b27d37.html#31d3dc34da21f6049581211a14b27d37">GetCoordinateSystemWKT</a>() = 0;
+<a name="l00112"></a>00112 <span class="comment"></span>
+<a name="l00113"></a>00113 <span class="comment"> /// \brief</span>
+<a name="l00114"></a>00114 <span class="comment"> /// Sets the tolerance value to use for X/Y ordinates. Tolerances are used</span>
+<a name="l00115"></a>00115 <span class="comment"> /// in some geometric tests, mostly for equality between coordinates. This</span>
+<a name="l00116"></a>00116 <span class="comment"> /// occurs frequently in spatial queries, especially with "on boundary" or "just</span>
+<a name="l00117"></a>00117 <span class="comment"> /// touching" conditions. It is also an objective amount that can be used</span>
+<a name="l00118"></a>00118 <span class="comment"> /// when formulating step distances for parametric curve interpolation.</span>
+<a name="l00119"></a>00119 <span class="comment"> /// </span>
+<a name="l00120"></a>00120 <span class="comment"> /// \param tolerance </span>
+<a name="l00121"></a>00121 <span class="comment"> /// Input the tolerance.</span>
+<a name="l00122"></a>00122 <span class="comment"> /// </span>
+<a name="l00123"></a>00123 <span class="comment"> /// \return</span>
+<a name="l00124"></a>00124 <span class="comment"> /// Returns nothing.</span>
+<a name="l00125"></a>00125 <span class="comment"> /// </span>
+<a name="l00126"></a>00126 <span class="comment"></span> FDO_API <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_i_create_s_d_f_file_b3e528dda87b952a83786b2d01343524.html#b3e528dda87b952a83786b2d01343524">SetXYTolerance</a>(<span class="keywordtype">double</span> tolerance) = 0;
+<a name="l00127"></a>00127 <span class="comment"></span>
+<a name="l00128"></a>00128 <span class="comment"> /// \brief</span>
+<a name="l00129"></a>00129 <span class="comment"> /// Gets the tolerance value for X/Y ordinates of the spatial context.</span>
+<a name="l00130"></a>00130 <span class="comment"> /// Tolerances are used in some geometric tests,</span>
+<a name="l00131"></a>00131 <span class="comment"> /// mostly for equality between coordinates. This occurs frequently in spatial</span>
+<a name="l00132"></a>00132 <span class="comment"> /// queries, especially with "on boundary" or "just touching" conditions.</span>
+<a name="l00133"></a>00133 <span class="comment"> /// It is also an objective amount that can be used when formulating step</span>
+<a name="l00134"></a>00134 <span class="comment"> /// distances for parametric curve interpolation.</span>
+<a name="l00135"></a>00135 <span class="comment"> /// </span>
+<a name="l00136"></a>00136 <span class="comment"> /// \return</span>
+<a name="l00137"></a>00137 <span class="comment"> /// Returns the tolerance.</span>
+<a name="l00138"></a>00138 <span class="comment"> /// </span>
+<a name="l00139"></a>00139 <span class="comment"></span> FDO_API <span class="keyword">virtual</span> <span class="keywordtype">double</span> <a class="code" href="class_fdo_i_create_s_d_f_file_4a2bb60374b5db4f9dca173de2845803.html#4a2bb60374b5db4f9dca173de2845803">GetXYTolerance</a>() = 0;
+<a name="l00140"></a>00140 <span class="comment"></span>
+<a name="l00141"></a>00141 <span class="comment"> /// \brief</span>
+<a name="l00142"></a>00142 <span class="comment"> /// Sets the tolerance value to use for Z ordinates. Tolerances are used in</span>
+<a name="l00143"></a>00143 <span class="comment"> /// some geometric tests, mostly for equality between coordinates. This</span>
+<a name="l00144"></a>00144 <span class="comment"> /// occurs frequently in spatial queries, especially with "on boundary" or "just</span>
+<a name="l00145"></a>00145 <span class="comment"> /// touching" conditions. It is also an objective amount that can be used</span>
+<a name="l00146"></a>00146 <span class="comment"> /// when formulating step distances for parametric curve interpolation.</span>
+<a name="l00147"></a>00147 <span class="comment"> /// </span>
+<a name="l00148"></a>00148 <span class="comment"> /// \param tolerance </span>
+<a name="l00149"></a>00149 <span class="comment"> /// Input the tolerance.</span>
+<a name="l00150"></a>00150 <span class="comment"> /// </span>
+<a name="l00151"></a>00151 <span class="comment"> /// \return</span>
+<a name="l00152"></a>00152 <span class="comment"> /// Returns nothing.</span>
+<a name="l00153"></a>00153 <span class="comment"> /// </span>
+<a name="l00154"></a>00154 <span class="comment"></span> FDO_API <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_i_create_s_d_f_file_2937b06fdf37207301200042b40e8d71.html#2937b06fdf37207301200042b40e8d71">SetZTolerance</a>(<span class="keywordtype">double</span> tolerance) = 0;
+<a name="l00155"></a>00155 <span class="comment"></span>
+<a name="l00156"></a>00156 <span class="comment"> /// \brief</span>
+<a name="l00157"></a>00157 <span class="comment"> /// Gets the tolerance value for Z ordinates of the spatial context.</span>
+<a name="l00158"></a>00158 <span class="comment"> /// Tolerances are used in some geometric tests,</span>
+<a name="l00159"></a>00159 <span class="comment"> /// mostly for equality between coordinates. This occurs a frequently in spatial</span>
+<a name="l00160"></a>00160 <span class="comment"> /// queries, especially with "on boundary" or "just touching" conditions.</span>
+<a name="l00161"></a>00161 <span class="comment"> /// It is also an objective amount that can be used when formulating step</span>
+<a name="l00162"></a>00162 <span class="comment"> /// distances for parametric curve interpolation.</span>
+<a name="l00163"></a>00163 <span class="comment"> /// </span>
+<a name="l00164"></a>00164 <span class="comment"> /// \return</span>
+<a name="l00165"></a>00165 <span class="comment"> /// Returns the tolerance.</span>
+<a name="l00166"></a>00166 <span class="comment"> /// </span>
+<a name="l00167"></a>00167 <span class="comment"></span> FDO_API <span class="keyword">virtual</span> <span class="keywordtype">double</span> <a class="code" href="class_fdo_i_create_s_d_f_file_8b2fc8bbd39311d609c316fac75d765b.html#8b2fc8bbd39311d609c316fac75d765b">GetZTolerance</a>() = 0;
+<a name="l00168"></a>00168 <span class="comment"></span>
+<a name="l00169"></a>00169 <span class="comment"> /// \brief</span>
+<a name="l00170"></a>00170 <span class="comment"> /// Executes the command. An exception is thrown if the file fails to be </span>
+<a name="l00171"></a>00171 <span class="comment"> /// created.</span>
+<a name="l00172"></a>00172 <span class="comment"> /// </span>
+<a name="l00173"></a>00173 <span class="comment"> /// \return</span>
+<a name="l00174"></a>00174 <span class="comment"> /// Returns nothing.</span>
+<a name="l00175"></a>00175 <span class="comment"> /// </span>
+<a name="l00176"></a>00176 <span class="comment"></span> FDO_API <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_i_create_s_d_f_file_05550ca7007c3e389b7029c41baa1587.html#05550ca7007c3e389b7029c41baa1587">Execute</a>() = 0;
+<a name="l00177"></a>00177
+<a name="l00178"></a>00178 };
+<a name="l00179"></a>00179
+<a name="l00180"></a>00180
+<a name="l00181"></a>00181 <span class="preprocessor">#endif</span>
+<a name="l00182"></a>00182 <span class="preprocessor"></span>
+<a name="l00183"></a>00183
+</pre></div><!-- footer.html -->
+ <hr>
+ <tr>
+ <td align="right"><font size="-2"><a href="mailto:isd.docs at autodesk.com&subject=FDO%20Provider%20for%20SDF%20API%20documentation">Comments?</a></font></td>
+ <!-- The logo can go in another cell, when we get one -->
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/_i_create_s_d_f_file_8h.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_i_create_s_d_f_file_8h.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SDF/_i_create_s_d_f_file_8h.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,55 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>ICreateSDFFile.h File Reference</h1>
+<p>
+<code>#include "FdoStd.h"</code><br>
+<code>#include "fdo/Commands/ICommand.h"</code><br>
+<p>
+Include dependency graph for ICreateSDFFile.h:<p><center><img src="_i_create_s_d_f_file_8h__incl.png" border="0" usemap="#ICreateSDFFile.h_map" alt=""></center>
+<p>
+<a href="_i_create_s_d_f_file_8h-source.html">Go to the source code of this file.</a><table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td colspan="2"><br><h2>Classes</h2></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">class </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_i_create_s_d_f_file.html">FdoICreateSDFFile</a></td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">This command creates a new SDF+ file with a specified location and file name and a given spatial coordinate system. <a href="class_fdo_i_create_s_d_f_file.html#_details">More...</a><br></td></tr>
+</table>
+<!-- footer.html -->
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/_i_create_s_d_f_file_8h__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_i_create_s_d_f_file_8h__incl.map?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SDF/_i_create_s_d_f_file_8h__incl.map 2006-03-06 21:40:50+0000
@@ -0,0 +1 @@
+base referer
Added: trunk/www/docs/SDF/_i_create_s_d_f_file_8h__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_i_create_s_d_f_file_8h__incl.md5?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SDF/_i_create_s_d_f_file_8h__incl.md5 2006-03-06 21:40:50+0000
@@ -0,0 +1 @@
+f191fa61c3858f54be247609c8de2a6a
\ No newline at end of file
Added: trunk/www/docs/SDF/_i_create_s_d_f_file_8h__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_i_create_s_d_f_file_8h__incl.png?view=auto&rev=4
Binary file. No diff available.
Added: trunk/www/docs/SDF/_sdf_command_type_8h-source.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_sdf_command_type_8h-source.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SDF/_sdf_command_type_8h-source.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,84 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>SdfCommandType.h</h1><a href="_sdf_command_type_8h.html">Go to the documentation of this file.</a><div class="fragment"><pre class="fragment"><a name="l00001"></a>00001 <span class="comment">// </span>
+<a name="l00016"></a>00016 <span class="preprocessor">#ifndef SDFCOMMANDTYPE_H</span>
+<a name="l00017"></a>00017 <span class="preprocessor"></span><span class="preprocessor">#define SDFCOMMANDTYPE_H</span>
+<a name="l00019"></a>00019 <span class="preprocessor">#include "fdo/Commands/CommandType.h"</span>
+<a name="l00021"></a>00021 <span class="comment">// This number is defined so our custom command would not clash with other</span>
+<a name="l00022"></a>00022 <span class="comment">// custom provider commands.</span>
+<a name="l00023"></a><a class="code" href="_sdf_command_type_8h_86597e57635d4329ec6b9d0a67f969d7.html#86597e57635d4329ec6b9d0a67f969d7">00023</a> <span class="preprocessor">#define SDF_FIRST_PROVIDER_COMMAND 911</span>
+<a name="l00024"></a>00024 <span class="preprocessor"></span>
+<a name="l00025"></a>00025 <span class="comment"></span>
+<a name="l00026"></a>00026 <span class="comment">/// \brief</span>
+<a name="l00027"></a>00027 <span class="comment">/// The SdfCommandType enumeration defines the list of SDF+ commands.</span>
+<a name="l00028"></a>00028 <span class="comment">/// <param name="SdfCommandType_CreateSDFFile"></span>
+<a name="l00029"></a>00029 <span class="comment">/// Represents the CreateSDFFile command.</span>
+<a name="l00030"></a>00030 <span class="comment">/// </param></span>
+<a name="l00031"></a>00031 <span class="comment"></span>
+<a name="l00032"></a><a class="code" href="_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html#4ac92492e0d58aeace1b0c0f96cefea3">00032</a> <span class="keyword">enum</span> <a class="code" href="_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html#4ac92492e0d58aeace1b0c0f96cefea3">SdfCommandType</a>{
+<a name="l00033"></a>00033 <span class="comment"></span>
+<a name="l00034"></a>00034 <span class="comment"> /// Represents the CreateSDFFile command.</span>
+<a name="l00035"></a>00035 <span class="comment"></span> <a class="code" href="_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html#4ac92492e0d58aeace1b0c0f96cefea348c2e525ef9f5e6ae1db0962a09cff37">SdfCommandType_CreateSDFFile</a> = FdoCommandType_FirstProviderCommand + <a class="code" href="_sdf_command_type_8h_86597e57635d4329ec6b9d0a67f969d7.html#86597e57635d4329ec6b9d0a67f969d7">SDF_FIRST_PROVIDER_COMMAND</a>,
+<a name="l00036"></a>00036 };
+<a name="l00043"></a>00043 <span class="preprocessor">#endif</span>
+<a name="l00044"></a>00044 <span class="preprocessor"></span>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/_sdf_command_type_8h.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_sdf_command_type_8h.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SDF/_sdf_command_type_8h.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,63 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>SdfCommandType.h File Reference</h1>
+<p>
+<code>#include "fdo/Commands/CommandType.h"</code><br>
+<p>
+Include dependency graph for SdfCommandType.h:<p><center><img src="_sdf_command_type_8h__incl.png" border="0" usemap="#SdfCommandType.h_map" alt=""></center>
+<p>
+<a href="_sdf_command_type_8h-source.html">Go to the source code of this file.</a><table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td colspan="2"><br><h2>Defines</h2></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">#define </td><td class="memItemRight" valign="bottom"><a class="el" href="_sdf_command_type_8h_86597e57635d4329ec6b9d0a67f969d7.html#86597e57635d4329ec6b9d0a67f969d7">SDF_FIRST_PROVIDER_COMMAND</a> 911</td></tr>
+<tr><td colspan="2"><br><h2>Enumerations</h2></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">enum </td><td class="memItemRight" valign="bottom"><a class="el" href="_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html#4ac92492e0d58aeace1b0c0f96cefea3">SdfCommandType</a> { <a class="el" href="_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html#4ac92492e0d58aeace1b0c0f96cefea348c2e525ef9f5e6ae1db0962a09cff37">SdfCommandType_CreateSDFFile</a> = FdoCommandType_FirstProviderCommand + 911
+ }</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">The SdfCommandType enumeration defines the list of SDF+ commands. <dl compact><dt><b>Parameters:</b></dt><dd>
+ <table border="0" cellspacing="2" cellpadding="0">
+ <tr><td valign="top"></td><td valign="top"><em>SdfCommandType_CreateSDFFile</em> </td><td>Represents the CreateSDFFile command. </td></tr>
+ </table>
+</dl>
+. <a href="_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html#4ac92492e0d58aeace1b0c0f96cefea3">More...</a><br></td></tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SDF/_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,89 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li><a href="files.html"><span>Files</span></a></li>
+ </ul></div>
+<div class="nav">
+<a class="el" href="_sdf_command_type_8h.html">SdfCommandType.h</a></div>
+<table cellspacing="0" cellpadding="0" border="0">
+ <tr>
+ <td valign="top">
+ <div class="navtab">
+ <table>
+ <tr><td class="navtab"><a class="qindex" href="_sdf_command_type_8h_86597e57635d4329ec6b9d0a67f969d7.html#86597e57635d4329ec6b9d0a67f969d7">SDF_FIRST_PROVIDER_COMMAND</a></td></tr>
+ <tr><td class="navtab"><a class="qindexHL" href="_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html#4ac92492e0d58aeace1b0c0f96cefea3">SdfCommandType</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html#4ac92492e0d58aeace1b0c0f96cefea348c2e525ef9f5e6ae1db0962a09cff37">SdfCommandType_CreateSDFFile</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="4ac92492e0d58aeace1b0c0f96cefea3"></a><!-- doxytag: member="SdfCommandType.h::SdfCommandType" ref="4ac92492e0d58aeace1b0c0f96cefea3" args="" --><p>
+<table class="mdTable" cellpadding="2" cellspacing="0">
+ <tr>
+ <td class="mdRow">
+ <table cellpadding="0" cellspacing="0" border="0">
+ <tr>
+ <td class="md" nowrap valign="top">enum <a class="el" href="_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html#4ac92492e0d58aeace1b0c0f96cefea3">SdfCommandType</a> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+<table cellspacing="5" cellpadding="0" border="0">
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+The SdfCommandType enumeration defines the list of SDF+ commands. <dl compact><dt><b>Parameters:</b></dt><dd>
+ </table>
+</dl>
+<p>
+<dl compact><dt><b>Enumerator: </b></dt><dd>
+<table border="0" cellspacing="2" cellpadding="0">
+<tr><td valign="top"><em><a class="anchor" name="4ac92492e0d58aeace1b0c0f96cefea348c2e525ef9f5e6ae1db0962a09cff37"></a><!-- doxytag: member="SdfCommandType_CreateSDFFile" ref="4ac92492e0d58aeace1b0c0f96cefea348c2e525ef9f5e6ae1db0962a09cff37" args="" -->SdfCommandType_CreateSDFFile</em> </td><td>
+Represents the CreateSDFFile command. </td></tr>
+</table>
+</dl>
+<p>
+Definition at line <a class="el" href="_sdf_command_type_8h-source.html#l00032">32</a> of file <a class="el" href="_sdf_command_type_8h-source.html">SdfCommandType.h</a>. </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/_sdf_command_type_8h_86597e57635d4329ec6b9d0a67f969d7.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_sdf_command_type_8h_86597e57635d4329ec6b9d0a67f969d7.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SDF/_sdf_command_type_8h_86597e57635d4329ec6b9d0a67f969d7.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,76 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="_sdf_command_type_8h_86597e57635d4329ec6b9d0a67f969d7.html#86597e57635d4329ec6b9d0a67f969d7">SDF_FIRST_PROVIDER_COMMAND</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html#4ac92492e0d58aeace1b0c0f96cefea3">SdfCommandType</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="86597e57635d4329ec6b9d0a67f969d7"></a><!-- doxytag: member="SdfCommandType.h::SDF_FIRST_PROVIDER_COMMAND" ref="86597e57635d4329ec6b9d0a67f969d7" args="" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">#define SDF_FIRST_PROVIDER_COMMAND 911 </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+<p>
+Definition at line <a class="el" href="_sdf_command_type_8h-source.html#l00023">23</a> of file <a class="el" href="_sdf_command_type_8h-source.html">SdfCommandType.h</a>. </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/_sdf_command_type_8h__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_sdf_command_type_8h__incl.map?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SDF/_sdf_command_type_8h__incl.map 2006-03-06 21:40:50+0000
@@ -0,0 +1 @@
+base referer
Added: trunk/www/docs/SDF/_sdf_command_type_8h__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_sdf_command_type_8h__incl.md5?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SDF/_sdf_command_type_8h__incl.md5 2006-03-06 21:40:50+0000
@@ -0,0 +1 @@
+f61ae7d6b94e1e0db293627ee7704b96
Added: trunk/www/docs/SDF/_sdf_command_type_8h__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_sdf_command_type_8h__incl.png?view=auto&rev=4
Added: trunk/www/docs/SDF/annotated.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/annotated.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SDF/annotated.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,44 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li id="current"><a href="classes.html"><span>Classes</span></a></li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li><a href="classes.html"><span>Alphabetical List</span></a></li>
+ <li id="current"><a href="annotated.html"><span>Class List</span></a></li>
+ <li><a href="hierarchy.html"><span>Class Hierarchy</span></a></li>
+ <li><a href="functions.html"><span>Class Members</span></a></li>
+ </ul></div>
+<h1>FDO Provider for SDF Class List</h1>Here are the classes, structs, unions and interfaces with brief descriptions:<table>
+ <tr><td class="indexkey"><a class="el" href="class_fdo_i_create_s_d_f_file.html">FdoICreateSDFFile</a></td><td class="indexvalue">This command creates a new SDF+ file with a specified location and file name and a given spatial coordinate system </td></tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file-members.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file-members.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file-members.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,55 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li><a href="annotated.html"><span>Class List</span></a></li>
+ </ul></div>
+<h1>FdoICreateSDFFile Member List</h1>This is the complete list of members for <a class="el" href="class_fdo_i_create_s_d_f_file.html">FdoICreateSDFFile</a>, including all inherited members.<p><table>
+ <tr class="memlist"><td><a class="el" href="class_fdo_i_create_s_d_f_file_05550ca7007c3e389b7029c41baa1587.html#05550ca7007c3e389b7029c41baa1587">Execute</a>()=0</td><td><a class="el" href="class_fdo_i_create_s_d_f_file.html">FdoICreateSDFFile</a></td><td><code> [pure virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_i_create_s_d_f_file_31d3dc34da21f6049581211a14b27d37.html#31d3dc34da21f6049581211a14b27d37">GetCoordinateSystemWKT</a>()=0</td><td><a class="el" href="class_fdo_i_create_s_d_f_file.html">FdoICreateSDFFile</a></td><td><code> [pure virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_i_create_s_d_f_file_eb8a85d56333894242c2ad05ede1a830.html#eb8a85d56333894242c2ad05ede1a830">GetFileName</a>()=0</td><td><a class="el" href="class_fdo_i_create_s_d_f_file.html">FdoICreateSDFFile</a></td><td><code> [pure virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_i_create_s_d_f_file_7f8850475beb73c192be00a4960628a1.html#7f8850475beb73c192be00a4960628a1">GetSpatialContextDescription</a>()=0</td><td><a class="el" href="class_fdo_i_create_s_d_f_file.html">FdoICreateSDFFile</a></td><td><code> [pure virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_i_create_s_d_f_file_65ffde001f9b3d4932c4163a8e8e2134.html#65ffde001f9b3d4932c4163a8e8e2134">GetSpatialContextName</a>()=0</td><td><a class="el" href="class_fdo_i_create_s_d_f_file.html">FdoICreateSDFFile</a></td><td><code> [pure virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_i_create_s_d_f_file_4a2bb60374b5db4f9dca173de2845803.html#4a2bb60374b5db4f9dca173de2845803">GetXYTolerance</a>()=0</td><td><a class="el" href="class_fdo_i_create_s_d_f_file.html">FdoICreateSDFFile</a></td><td><code> [pure virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_i_create_s_d_f_file_8b2fc8bbd39311d609c316fac75d765b.html#8b2fc8bbd39311d609c316fac75d765b">GetZTolerance</a>()=0</td><td><a class="el" href="class_fdo_i_create_s_d_f_file.html">FdoICreateSDFFile</a></td><td><code> [pure virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_i_create_s_d_f_file_a98dd232eefdc6835623c5deec259123.html#a98dd232eefdc6835623c5deec259123">SetCoordinateSystemWKT</a>(GisString *wkt)=0</td><td><a class="el" href="class_fdo_i_create_s_d_f_file.html">FdoICreateSDFFile</a></td><td><code> [pure virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_i_create_s_d_f_file_e37b34b21d62e779c004fb5229a83d37.html#e37b34b21d62e779c004fb5229a83d37">SetFileName</a>(GisString *name)=0</td><td><a class="el" href="class_fdo_i_create_s_d_f_file.html">FdoICreateSDFFile</a></td><td><code> [pure virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_i_create_s_d_f_file_9920ab315df81464390397ee73bcfab4.html#9920ab315df81464390397ee73bcfab4">SetSpatialContextDescription</a>(GisString *description)=0</td><td><a class="el" href="class_fdo_i_create_s_d_f_file.html">FdoICreateSDFFile</a></td><td><code> [pure virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_i_create_s_d_f_file_ad37e0d64c5a74e57765a108447332bb.html#ad37e0d64c5a74e57765a108447332bb">SetSpatialContextName</a>(GisString *name)=0</td><td><a class="el" href="class_fdo_i_create_s_d_f_file.html">FdoICreateSDFFile</a></td><td><code> [pure virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_i_create_s_d_f_file_b3e528dda87b952a83786b2d01343524.html#b3e528dda87b952a83786b2d01343524">SetXYTolerance</a>(double tolerance)=0</td><td><a class="el" href="class_fdo_i_create_s_d_f_file.html">FdoICreateSDFFile</a></td><td><code> [pure virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_i_create_s_d_f_file_2937b06fdf37207301200042b40e8d71.html#2937b06fdf37207301200042b40e8d71">SetZTolerance</a>(double tolerance)=0</td><td><a class="el" href="class_fdo_i_create_s_d_f_file.html">FdoICreateSDFFile</a></td><td><code> [pure virtual]</code></td></tr>
+</table><!-- footer.html -->
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,93 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>FdoICreateSDFFile Class Reference</h1><!-- doxytag: class="FdoICreateSDFFile" --><code>#include <<a class="el" href="_i_create_s_d_f_file_8h-source.html">ICreateSDFFile.h</a>></code>
+<p>
+<a href="class_fdo_i_create_s_d_f_file-members.html">List of all members.</a><hr><a name="_details"></a><h2>Detailed Description</h2>
+This command creates a new SDF+ file with a specified location and file name and a given spatial coordinate system.
+<p>
+<p>
+Definition at line <a class="el" href="_i_create_s_d_f_file_8h-source.html#l00026">26</a> of file <a class="el" href="_i_create_s_d_f_file_8h-source.html">ICreateSDFFile.h</a>.<table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td colspan="2"><br><h2>Public Member Functions</h2></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDO_API void </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_i_create_s_d_f_file_05550ca7007c3e389b7029c41baa1587.html#05550ca7007c3e389b7029c41baa1587">Execute</a> ()=0</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Executes the command. An exception is thrown if the file fails to be created. <a href="#05550ca7007c3e389b7029c41baa1587"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDO_API GisString * </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_i_create_s_d_f_file_31d3dc34da21f6049581211a14b27d37.html#31d3dc34da21f6049581211a14b27d37">GetCoordinateSystemWKT</a> ()=0</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Gets the name of the coordinate system in OpenGIS SRS WKT format of the spatial context. If the result is an empty string, the coordinate system WKT description is not available. <a href="#31d3dc34da21f6049581211a14b27d37"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDO_API GisString * </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_i_create_s_d_f_file_eb8a85d56333894242c2ad05ede1a830.html#eb8a85d56333894242c2ad05ede1a830">GetFileName</a> ()=0</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Gets the name of the SDF+ file being created. The name is a fully qualified absolute path. <a href="#eb8a85d56333894242c2ad05ede1a830"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDO_API GisString * </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_i_create_s_d_f_file_7f8850475beb73c192be00a4960628a1.html#7f8850475beb73c192be00a4960628a1">GetSpatialContextDescription</a> ()=0</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Gets the description of the spatial context. <a href="#7f8850475beb73c192be00a4960628a1"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDO_API GisString * </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_i_create_s_d_f_file_65ffde001f9b3d4932c4163a8e8e2134.html#65ffde001f9b3d4932c4163a8e8e2134">GetSpatialContextName</a> ()=0</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Gets the name of the coordinate system of the spatial context. If the result is a null or empty string, the coordinate system is unknown to the spatial context. <a href="#65ffde001f9b3d4932c4163a8e8e2134"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDO_API double </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_i_create_s_d_f_file_4a2bb60374b5db4f9dca173de2845803.html#4a2bb60374b5db4f9dca173de2845803">GetXYTolerance</a> ()=0</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Gets the tolerance value for X/Y ordinates of the spatial context. Tolerances are used in some geometric tests, mostly for equality between coordinates. This occurs frequently in spatial queries, especially with "on boundary" or "just touching" conditions. It is also an objective amount that can be used when formulating step distances for parametric curve interpolation. <a href="#4a2bb60374b5db4f9dca173de2845803"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDO_API double </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_i_create_s_d_f_file_8b2fc8bbd39311d609c316fac75d765b.html#8b2fc8bbd39311d609c316fac75d765b">GetZTolerance</a> ()=0</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Gets the tolerance value for Z ordinates of the spatial context. Tolerances are used in some geometric tests, mostly for equality between coordinates. This occurs a frequently in spatial queries, especially with "on boundary" or "just touching" conditions. It is also an objective amount that can be used when formulating step distances for parametric curve interpolation. <a href="#8b2fc8bbd39311d609c316fac75d765b"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDO_API void </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_i_create_s_d_f_file_a98dd232eefdc6835623c5deec259123.html#a98dd232eefdc6835623c5deec259123">SetCoordinateSystemWKT</a> (GisString *wkt)=0</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Sets the coordinate system of the context to create as a string in OpenGIS SRS WKT format. <a href="#a98dd232eefdc6835623c5deec259123"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDO_API void </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_i_create_s_d_f_file_e37b34b21d62e779c004fb5229a83d37.html#e37b34b21d62e779c004fb5229a83d37">SetFileName</a> (GisString *name)=0</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Sets the name of the SDF+ file being created. The name must be a fully qualified absolute path. <a href="#e37b34b21d62e779c004fb5229a83d37"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDO_API void </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_i_create_s_d_f_file_9920ab315df81464390397ee73bcfab4.html#9920ab315df81464390397ee73bcfab4">SetSpatialContextDescription</a> (GisString *description)=0</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Sets the description of the spatial context as a string. <a href="#9920ab315df81464390397ee73bcfab4"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDO_API void </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_i_create_s_d_f_file_ad37e0d64c5a74e57765a108447332bb.html#ad37e0d64c5a74e57765a108447332bb">SetSpatialContextName</a> (GisString *name)=0</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Sets the name of the spatial context as a string. <a href="#ad37e0d64c5a74e57765a108447332bb"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDO_API void </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_i_create_s_d_f_file_b3e528dda87b952a83786b2d01343524.html#b3e528dda87b952a83786b2d01343524">SetXYTolerance</a> (double tolerance)=0</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Sets the tolerance value to use for X/Y ordinates. Tolerances are used in some geometric tests, mostly for equality between coordinates. This occurs frequently in spatial queries, especially with "on boundary" or "just touching" conditions. It is also an objective amount that can be used when formulating step distances for parametric curve interpolation. <a href="#b3e528dda87b952a83786b2d01343524"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDO_API void </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_i_create_s_d_f_file_2937b06fdf37207301200042b40e8d71.html#2937b06fdf37207301200042b40e8d71">SetZTolerance</a> (double tolerance)=0</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Sets the tolerance value to use for Z ordinates. Tolerances are used in some geometric tests, mostly for equality between coordinates. This occurs frequently in spatial queries, especially with "on boundary" or "just touching" conditions. It is also an objective amount that can be used when formulating step distances for parametric curve interpolation. <a href="#2937b06fdf37207301200042b40e8d71"></a><br></td></tr>
+</table>
+<hr>The documentation for this class was generated from the following file:<ul>
+<li><a class="el" href="_i_create_s_d_f_file_8h-source.html">ICreateSDFFile.h</a></ul>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_05550ca7007c3e389b7029c41baa1587.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_05550ca7007c3e389b7029c41baa1587.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_05550ca7007c3e389b7029c41baa1587.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,91 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+<a class="el" href="class_fdo_i_create_s_d_f_file.html">FdoICreateSDFFile</a></div>
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_i_create_s_d_f_file_05550ca7007c3e389b7029c41baa1587.html#05550ca7007c3e389b7029c41baa1587">Execute</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_i_create_s_d_f_file_31d3dc34da21f6049581211a14b27d37.html#31d3dc34da21f6049581211a14b27d37">GetCoordinateSystemWKT</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_i_create_s_d_f_file_eb8a85d56333894242c2ad05ede1a830.html#eb8a85d56333894242c2ad05ede1a830">GetFileName</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_i_create_s_d_f_file_7f8850475beb73c192be00a4960628a1.html#7f8850475beb73c192be00a4960628a1">GetSpatialContextDescription</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_i_create_s_d_f_file_65ffde001f9b3d4932c4163a8e8e2134.html#65ffde001f9b3d4932c4163a8e8e2134">GetSpatialContextName</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_i_create_s_d_f_file_4a2bb60374b5db4f9dca173de2845803.html#4a2bb60374b5db4f9dca173de2845803">GetXYTolerance</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_i_create_s_d_f_file_8b2fc8bbd39311d609c316fac75d765b.html#8b2fc8bbd39311d609c316fac75d765b">GetZTolerance</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_i_create_s_d_f_file_a98dd232eefdc6835623c5deec259123.html#a98dd232eefdc6835623c5deec259123">SetCoordinateSystemWKT</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_i_create_s_d_f_file_e37b34b21d62e779c004fb5229a83d37.html#e37b34b21d62e779c004fb5229a83d37">SetFileName</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_i_create_s_d_f_file_9920ab315df81464390397ee73bcfab4.html#9920ab315df81464390397ee73bcfab4">SetSpatialContextDescription</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_i_create_s_d_f_file_ad37e0d64c5a74e57765a108447332bb.html#ad37e0d64c5a74e57765a108447332bb">SetSpatialContextName</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_i_create_s_d_f_file_b3e528dda87b952a83786b2d01343524.html#b3e528dda87b952a83786b2d01343524">SetXYTolerance</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_i_create_s_d_f_file_2937b06fdf37207301200042b40e8d71.html#2937b06fdf37207301200042b40e8d71">SetZTolerance</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="05550ca7007c3e389b7029c41baa1587"></a><!-- doxytag: member="FdoICreateSDFFile::Execute" ref="05550ca7007c3e389b7029c41baa1587" args="()=0" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual FDO_API void FdoICreateSDFFile::Execute </td>
+ <td class="md" valign="top">( </td>
+ <td class="mdname1" valign="top" nowrap> </td>
+ <td class="md" valign="top"> ) </td>
+ <td class="md" nowrap><code> [pure virtual]</code></td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Executes the command. An exception is thrown if the file fails to be created.
+<p>
+<dl compact><dt><b>Returns:</b></dt><dd>Returns nothing. </dd></dl>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_2937b06fdf37207301200042b40e8d71.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_2937b06fdf37207301200042b40e8d71.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_2937b06fdf37207301200042b40e8d71.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,97 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_i_create_s_d_f_file_05550ca7007c3e389b7029c41baa1587.html#05550ca7007c3e389b7029c41baa1587">Execute</a></td></tr>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_i_create_s_d_f_file_2937b06fdf37207301200042b40e8d71.html#2937b06fdf37207301200042b40e8d71">SetZTolerance</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="2937b06fdf37207301200042b40e8d71"></a><!-- doxytag: member="FdoICreateSDFFile::SetZTolerance" ref="2937b06fdf37207301200042b40e8d71" args="(double tolerance)=0" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual FDO_API void FdoICreateSDFFile::SetZTolerance </td>
+ <td class="md" nowrap valign="top">double </td>
+ <td class="mdname1" valign="top" nowrap> <em>tolerance</em> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Sets the tolerance value to use for Z ordinates. Tolerances are used in some geometric tests, mostly for equality between coordinates. This occurs frequently in spatial queries, especially with "on boundary" or "just touching" conditions. It is also an objective amount that can be used when formulating step distances for parametric curve interpolation.
+<p>
+<dl compact><dt><b>Parameters:</b></dt><dd>
+ <tr><td valign="top"></td><td valign="top"><em>tolerance</em> </td><td>Input the tolerance.</td></tr>
+ </table>
+</dl>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_31d3dc34da21f6049581211a14b27d37.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_31d3dc34da21f6049581211a14b27d37.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_31d3dc34da21f6049581211a14b27d37.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,91 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_i_create_s_d_f_file_31d3dc34da21f6049581211a14b27d37.html#31d3dc34da21f6049581211a14b27d37">GetCoordinateSystemWKT</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="31d3dc34da21f6049581211a14b27d37"></a><!-- doxytag: member="FdoICreateSDFFile::GetCoordinateSystemWKT" ref="31d3dc34da21f6049581211a14b27d37" args="()=0" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual FDO_API GisString* FdoICreateSDFFile::GetCoordinateSystemWKT </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Gets the name of the coordinate system in OpenGIS SRS WKT format of the spatial context. If the result is an empty string, the coordinate system WKT description is not available.
+<p>
+<dl compact><dt><b>Returns:</b></dt><dd>Returns the coordinate system description in WKT format of the spatial context. </dd></dl>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_4a2bb60374b5db4f9dca173de2845803.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_4a2bb60374b5db4f9dca173de2845803.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_4a2bb60374b5db4f9dca173de2845803.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,91 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_i_create_s_d_f_file_4a2bb60374b5db4f9dca173de2845803.html#4a2bb60374b5db4f9dca173de2845803">GetXYTolerance</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="4a2bb60374b5db4f9dca173de2845803"></a><!-- doxytag: member="FdoICreateSDFFile::GetXYTolerance" ref="4a2bb60374b5db4f9dca173de2845803" args="()=0" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual FDO_API double FdoICreateSDFFile::GetXYTolerance </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Gets the tolerance value for X/Y ordinates of the spatial context. Tolerances are used in some geometric tests, mostly for equality between coordinates. This occurs frequently in spatial queries, especially with "on boundary" or "just touching" conditions. It is also an objective amount that can be used when formulating step distances for parametric curve interpolation.
+<p>
+<dl compact><dt><b>Returns:</b></dt><dd>Returns the tolerance. </dd></dl>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_65ffde001f9b3d4932c4163a8e8e2134.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_65ffde001f9b3d4932c4163a8e8e2134.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_65ffde001f9b3d4932c4163a8e8e2134.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,91 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_i_create_s_d_f_file_65ffde001f9b3d4932c4163a8e8e2134.html#65ffde001f9b3d4932c4163a8e8e2134">GetSpatialContextName</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="65ffde001f9b3d4932c4163a8e8e2134"></a><!-- doxytag: member="FdoICreateSDFFile::GetSpatialContextName" ref="65ffde001f9b3d4932c4163a8e8e2134" args="()=0" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual FDO_API GisString* FdoICreateSDFFile::GetSpatialContextName </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Gets the name of the coordinate system of the spatial context. If the result is a null or empty string, the coordinate system is unknown to the spatial context.
+<p>
+<dl compact><dt><b>Returns:</b></dt><dd>Returns the coordinate system name of the spatial context. </dd></dl>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_7f8850475beb73c192be00a4960628a1.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_7f8850475beb73c192be00a4960628a1.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_7f8850475beb73c192be00a4960628a1.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,91 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_i_create_s_d_f_file_7f8850475beb73c192be00a4960628a1.html#7f8850475beb73c192be00a4960628a1">GetSpatialContextDescription</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="7f8850475beb73c192be00a4960628a1"></a><!-- doxytag: member="FdoICreateSDFFile::GetSpatialContextDescription" ref="7f8850475beb73c192be00a4960628a1" args="()=0" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual FDO_API GisString* FdoICreateSDFFile::GetSpatialContextDescription </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Gets the description of the spatial context.
+<p>
+<dl compact><dt><b>Returns:</b></dt><dd>Returns the description of the spatial context. </dd></dl>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_8b2fc8bbd39311d609c316fac75d765b.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_8b2fc8bbd39311d609c316fac75d765b.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_8b2fc8bbd39311d609c316fac75d765b.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,91 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
+<html>
+ <head>
+ <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
+ <title>OSGeo FDO Provider for SDF API Reference</title>
+ <link href="custom.css" rel="stylesheet" type="text/css">
+ <link href="tabs.css" rel="stylesheet" type="text/css">
+ </head>
+ <body bgcolor="#FFFFFF">
+ <table width="100%" border="0">
+ <tr>
+ <td><b>API Reference<b></td>
+ <td align="right"><b>OSGeo FDO Provider for SDF<b></td>
+ </tr>
+ </table>
+<!-- End of: header.html -->
+<!-- Generated by Doxygen 1.4.6-NO -->
+<div class="tabs">
+ <ul>
+ <li><a href="main.html"><span>Main Page</span></a></li>
+ <li><a href="classes.html"><span>Classes</span></a></li>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_i_create_s_d_f_file_8b2fc8bbd39311d609c316fac75d765b.html#8b2fc8bbd39311d609c316fac75d765b">GetZTolerance</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="8b2fc8bbd39311d609c316fac75d765b"></a><!-- doxytag: member="FdoICreateSDFFile::GetZTolerance" ref="8b2fc8bbd39311d609c316fac75d765b" args="()=0" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual FDO_API double FdoICreateSDFFile::GetZTolerance </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Gets the tolerance value for Z ordinates of the spatial context. Tolerances are used in some geometric tests, mostly for equality between coordinates. This occurs a frequently in spatial queries, especially with "on boundary" or "just touching" conditions. It is also an objective amount that can be used when formulating step distances for parametric curve interpolation.
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_9920ab315df81464390397ee73bcfab4.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_9920ab315df81464390397ee73bcfab4.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_9920ab315df81464390397ee73bcfab4.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,97 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_i_create_s_d_f_file_9920ab315df81464390397ee73bcfab4.html#9920ab315df81464390397ee73bcfab4">SetSpatialContextDescription</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="9920ab315df81464390397ee73bcfab4"></a><!-- doxytag: member="FdoICreateSDFFile::SetSpatialContextDescription" ref="9920ab315df81464390397ee73bcfab4" args="(GisString *description)=0" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual FDO_API void FdoICreateSDFFile::SetSpatialContextDescription </td>
+ <td class="md" nowrap valign="top">GisString * </td>
+ <td class="mdname1" valign="top" nowrap> <em>description</em> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Sets the description of the spatial context as a string.
+<p>
+ <tr><td valign="top"></td><td valign="top"><em>description</em> </td><td>Input the description of the spatial context.</td></tr>
+ </table>
+</dl>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_a98dd232eefdc6835623c5deec259123.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_a98dd232eefdc6835623c5deec259123.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_a98dd232eefdc6835623c5deec259123.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,97 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_i_create_s_d_f_file_a98dd232eefdc6835623c5deec259123.html#a98dd232eefdc6835623c5deec259123">SetCoordinateSystemWKT</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="a98dd232eefdc6835623c5deec259123"></a><!-- doxytag: member="FdoICreateSDFFile::SetCoordinateSystemWKT" ref="a98dd232eefdc6835623c5deec259123" args="(GisString *wkt)=0" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual FDO_API void FdoICreateSDFFile::SetCoordinateSystemWKT </td>
+ <td class="mdname1" valign="top" nowrap> <em>wkt</em> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Sets the coordinate system of the context to create as a string in OpenGIS SRS WKT format.
+<p>
+ <tr><td valign="top"></td><td valign="top"><em>wkt</em> </td><td>Input the coordinate system.</td></tr>
+ </table>
+</dl>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_ad37e0d64c5a74e57765a108447332bb.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_ad37e0d64c5a74e57765a108447332bb.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_ad37e0d64c5a74e57765a108447332bb.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,97 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_i_create_s_d_f_file_ad37e0d64c5a74e57765a108447332bb.html#ad37e0d64c5a74e57765a108447332bb">SetSpatialContextName</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="ad37e0d64c5a74e57765a108447332bb"></a><!-- doxytag: member="FdoICreateSDFFile::SetSpatialContextName" ref="ad37e0d64c5a74e57765a108447332bb" args="(GisString *name)=0" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual FDO_API void FdoICreateSDFFile::SetSpatialContextName </td>
+ <td class="mdname1" valign="top" nowrap> <em>name</em> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Sets the name of the spatial context as a string.
+<p>
+ <tr><td valign="top"></td><td valign="top"><em>name</em> </td><td>Input the name of the spatial context.</td></tr>
+ </table>
+</dl>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_b3e528dda87b952a83786b2d01343524.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_b3e528dda87b952a83786b2d01343524.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_b3e528dda87b952a83786b2d01343524.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,97 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_i_create_s_d_f_file_b3e528dda87b952a83786b2d01343524.html#b3e528dda87b952a83786b2d01343524">SetXYTolerance</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="b3e528dda87b952a83786b2d01343524"></a><!-- doxytag: member="FdoICreateSDFFile::SetXYTolerance" ref="b3e528dda87b952a83786b2d01343524" args="(double tolerance)=0" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual FDO_API void FdoICreateSDFFile::SetXYTolerance </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Sets the tolerance value to use for X/Y ordinates. Tolerances are used in some geometric tests, mostly for equality between coordinates. This occurs frequently in spatial queries, especially with "on boundary" or "just touching" conditions. It is also an objective amount that can be used when formulating step distances for parametric curve interpolation.
+<p>
+ </table>
+</dl>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_e37b34b21d62e779c004fb5229a83d37.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_e37b34b21d62e779c004fb5229a83d37.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_e37b34b21d62e779c004fb5229a83d37.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,97 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_i_create_s_d_f_file_e37b34b21d62e779c004fb5229a83d37.html#e37b34b21d62e779c004fb5229a83d37">SetFileName</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="e37b34b21d62e779c004fb5229a83d37"></a><!-- doxytag: member="FdoICreateSDFFile::SetFileName" ref="e37b34b21d62e779c004fb5229a83d37" args="(GisString *name)=0" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual FDO_API void FdoICreateSDFFile::SetFileName </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Sets the name of the SDF+ file being created. The name must be a fully qualified absolute path.
+<p>
+ <tr><td valign="top"></td><td valign="top"><em>name</em> </td><td>The fully qualified SDF+ file name.</td></tr>
+ </table>
+</dl>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_eb8a85d56333894242c2ad05ede1a830.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_eb8a85d56333894242c2ad05ede1a830.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_eb8a85d56333894242c2ad05ede1a830.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,91 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_i_create_s_d_f_file_eb8a85d56333894242c2ad05ede1a830.html#eb8a85d56333894242c2ad05ede1a830">GetFileName</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="eb8a85d56333894242c2ad05ede1a830"></a><!-- doxytag: member="FdoICreateSDFFile::GetFileName" ref="eb8a85d56333894242c2ad05ede1a830" args="()=0" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual FDO_API GisString* FdoICreateSDFFile::GetFileName </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Gets the name of the SDF+ file being created. The name is a fully qualified absolute path.
+<p>
+<dl compact><dt><b>Returns:</b></dt><dd>Returns the name of the SDF+ file. </dd></dl>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/classes.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/classes.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SDF/classes.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,45 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li id="current"><a href="classes.html"><span>Alphabetical List</span></a></li>
+ </ul></div>
+<h1>FDO Provider for SDF Class Index</h1><p><div class="qindex"><a class="qindex" href="#letter_F">F</a></div><p>
+<table align="center" width="95%" border="0" cellspacing="0" cellpadding="0">
+<tr><td><a name="letter_F"></a><table border="0" cellspacing="0" cellpadding="0"><tr><td><div class="ah"> F </div></td></tr></table>
+</td><td><a class="el" href="class_fdo_i_create_s_d_f_file.html">FdoICreateSDFFile</a> </td></tr></table><p><div class="qindex"><a class="qindex" href="#letter_F">F</a></div><p>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/custom.css
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/custom.css?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SDF/custom.css 2006-03-06 21:40:50+0000
@@ -0,0 +1,96 @@
+ at import url(doxygen.css);
+div.Syntax{
+ background-color:#FFFFD9;
+div.Example{
+ background-color:#E9E9E9;
+/* table cells on the main page (index.html) */
+div.mainpage td {
+ background-color: #FFFFCC;
+ border-right-color: #FF6633;
+ border-bottom-color: #FF6633;
+ border-left-color: #FFCC33;
+ border-top-color: #FFCC33;
+ text-align: center;
+/*** Used in external topics ***/
+p.indent_1 {
+ padding-left: 0.25in;
+p.indent_2 {
+ padding-left: 0.5in;
+p.indent_3 {
+ padding-left: 0.75in;
+table.RuledTable {
+ border-collapse: collapse;
+ table-layout: auto;
+ width: auto;
+ cellpadding: none;
+ cellspacing: none;
+table.RuledTable th {
+ background-color: #CCCCCC;
+ border-left-style: solid;
+ border-left-width: thin;
+ border-left-color: #000000;
+ border-right-style: solid;
+ border-right-width: thin;
+ border-right-color: #000000;
+ border-bottom-style: solid;
+ border-bottom-width: thin;
+ border-bottom-color: #000000;
+ border-top-style: solid;
+ border-top-width: thin;
+ border-top-color: #000000;
+ padding: 6px;
+ width: auto;
+table.RuledTable td {
+ padding-left: 6px;
+ padding-right: 6px;
+ padding-top: 4px;
+ padding-top: 4px;
+ width: auto;
+td.shaded{
+ background-color:#CCCCCC;
+/* Used in Geometry_AgfText.h */
+p.row_1 {
+ font-family: "Courier New", Courier, monospace;
+pre.row_2 {
+ background-color: #E7FFCE;
Added: trunk/www/docs/SDF/define__pages_8h-source.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/define__pages_8h-source.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SDF/define__pages_8h-source.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,77 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li id="current"><a href="files.html"><span>Files</span></a></li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li><a href="files.html"><span>File List</span></a></li>
+ <li><a href="globals.html"><span>File Members</span></a></li>
+ </ul></div>
+<h1>define_pages.h</h1><a href="define__pages_8h.html">Go to the documentation of this file.</a><div class="fragment"><pre class="fragment"><a name="l00001"></a>00001 <span class="comment">/*! \mainpage Introduction</span>
+<a name="l00002"></a>00002 <span class="comment"><div class="mainpage"></span>
+<a name="l00003"></a>00003 <span class="comment"><!-- This is the index.html page that the user first sees. --></span>
+<a name="l00004"></a>00004 <span class="comment"></span>
+<a name="l00005"></a>00005 <span class="comment"><p>The Feature Data Objects (FDO) API provides access to data in a </span>
+<a name="l00006"></a>00006 <span class="comment">data store. A provider is a specific implementation of the FDO API </span>
+<a name="l00007"></a>00007 <span class="comment">that provides access to data in a particular data store. The FDO </span>
+<a name="l00008"></a>00008 <span class="comment">Provider for SDF provides FDO with access to an SDF-based data store.</span>
+<a name="l00009"></a>00009 <span class="comment"></span>
+<a name="l00010"></a>00010 <span class="comment"><p>The FDO Provider for SDF uses Autodesk's spatial database </span>
+<a name="l00011"></a>00011 <span class="comment">format, which is a file-based personal geodatabase that supports </span>
+<a name="l00012"></a>00012 <span class="comment">multiple features/attributes, spatial indexing, </span>
+<a name="l00013"></a>00013 <span class="comment">interoperability, file-locking, and high performance for </span>
+<a name="l00014"></a>00014 <span class="comment">large data sets.</span>
+<a name="l00015"></a>00015 <span class="comment"></p></span>
+<a name="l00016"></a>00016 <span class="comment"><p>The SDF file format has the following characteristics:</span>
+<a name="l00017"></a>00017 <span class="comment"></p></span>
+<a name="l00018"></a>00018 <span class="comment"></span>
+<a name="l00019"></a>00019 <span class="comment"><ul></span>
+<a name="l00020"></a>00020 <span class="comment"> <li> SDF files can be read on different platforms.</span>
+<a name="l00021"></a>00021 <span class="comment"> <li> The SDF file format has its own spatial indexing.</span>
+<a name="l00022"></a>00022 <span class="comment"> <li> SDF files can store geometric and non-geometric data with minimum </span>
+<a name="l00023"></a>00023 <span class="comment">overhead</span>
+<a name="l00024"></a>00024 <span class="comment"> <li>Although it does not support concurrency control (locking), </span>
+<a name="l00025"></a>00025 <span class="comment"> the SDF file format is a valid alternative to RDBMS.</span>
+<a name="l00026"></a>00026 <span class="comment"></ul></span>
+<a name="l00027"></a>00027 <span class="comment"><p></span>
+<a name="l00028"></a>00028 <span class="comment">For more information, see <i>The Essential FDO</i> (FET_TheEssentialFDO.pdf) </span>
+<a name="l00029"></a>00029 <span class="comment">and the <i>FDO Developer's Guide</i> (FDG_FDODevGuide.pdf).</span>
+<a name="l00030"></a>00030 <span class="comment"></p></span>
+<a name="l00032"></a>00032 <span class="comment"><br></span>
+<a name="l00033"></a>00033 <span class="comment"></div></span>
+<a name="l00034"></a>00034 <span class="comment">*/</span>
+<a name="l00037"></a>00037
+<a name="l00038"></a>00038
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/define__pages_8h.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/define__pages_8h.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SDF/define__pages_8h.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,46 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>define_pages.h File Reference</h1>
+<p>
+<p>
+<a href="define__pages_8h-source.html">Go to the source code of this file.</a><table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/doxygen.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/doxygen.png?view=auto&rev=4
Added: trunk/www/docs/SDF/files.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/files.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SDF/files.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,44 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li id="current"><a href="files.html"><span>File List</span></a></li>
+ </ul></div>
+<h1>FDO Provider for SDF File List</h1>Here is a list of all files with brief descriptions:<table>
+ <tr><td class="indexkey"><a class="el" href="define__pages_8h.html">define_pages.h</a> <a href="define__pages_8h-source.html">[code]</a></td><td class="indexvalue"></td></tr>
+ <tr><td class="indexkey"><a class="el" href="_i_create_s_d_f_file_8h.html">ICreateSDFFile.h</a> <a href="_i_create_s_d_f_file_8h-source.html">[code]</a></td><td class="indexvalue"></td></tr>
+ <tr><td class="indexkey"><a class="el" href="_sdf_command_type_8h.html">SdfCommandType.h</a> <a href="_sdf_command_type_8h-source.html">[code]</a></td><td class="indexvalue"></td></tr>
+</table>
+ <hr>
+ <tr>
+ <td align="right"><font size="-2"><a href="mailto:isd.docs at autodesk.com&subject=FDO%20Provider%20for%20SDF%20API%20documentation">Comments?</a></font></td>
+ <!-- The logo can go in another cell, when we get one -->
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/ftv2blank.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/ftv2blank.png?view=auto&rev=4
Added: trunk/www/docs/SDF/ftv2doc.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/ftv2doc.png?view=auto&rev=4
Added: trunk/www/docs/SDF/ftv2folderclosed.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/ftv2folderclosed.png?view=auto&rev=4
Added: trunk/www/docs/SDF/ftv2folderopen.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/ftv2folderopen.png?view=auto&rev=4
Added: trunk/www/docs/SDF/ftv2lastnode.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/ftv2lastnode.png?view=auto&rev=4
Added: trunk/www/docs/SDF/ftv2link.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/ftv2link.png?view=auto&rev=4
Added: trunk/www/docs/SDF/ftv2mlastnode.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/ftv2mlastnode.png?view=auto&rev=4
Added: trunk/www/docs/SDF/ftv2mnode.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/ftv2mnode.png?view=auto&rev=4
Added: trunk/www/docs/SDF/ftv2node.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/ftv2node.png?view=auto&rev=4
Added: trunk/www/docs/SDF/ftv2plastnode.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/ftv2plastnode.png?view=auto&rev=4
Added: trunk/www/docs/SDF/ftv2pnode.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/ftv2pnode.png?view=auto&rev=4
Added: trunk/www/docs/SDF/ftv2vertline.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/ftv2vertline.png?view=auto&rev=4
Added: trunk/www/docs/SDF/functions.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/functions.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SDF/functions.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,64 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li id="current"><a href="functions.html"><span>Class Members</span></a></li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li id="current"><a href="functions.html"><span>All</span></a></li>
+ <li><a href="functions_func.html"><span>Functions</span></a></li>
+ </ul>
+</div>
+Here is a list of all class members with links to the classes they belong to:
+<p>
+<ul>
+<li>Execute()
+: <a class="el" href="class_fdo_i_create_s_d_f_file_05550ca7007c3e389b7029c41baa1587.html#05550ca7007c3e389b7029c41baa1587">FdoICreateSDFFile</a><li>GetCoordinateSystemWKT()
+: <a class="el" href="class_fdo_i_create_s_d_f_file_31d3dc34da21f6049581211a14b27d37.html#31d3dc34da21f6049581211a14b27d37">FdoICreateSDFFile</a><li>GetFileName()
+: <a class="el" href="class_fdo_i_create_s_d_f_file_eb8a85d56333894242c2ad05ede1a830.html#eb8a85d56333894242c2ad05ede1a830">FdoICreateSDFFile</a><li>GetSpatialContextDescription()
+: <a class="el" href="class_fdo_i_create_s_d_f_file_7f8850475beb73c192be00a4960628a1.html#7f8850475beb73c192be00a4960628a1">FdoICreateSDFFile</a><li>GetSpatialContextName()
+: <a class="el" href="class_fdo_i_create_s_d_f_file_65ffde001f9b3d4932c4163a8e8e2134.html#65ffde001f9b3d4932c4163a8e8e2134">FdoICreateSDFFile</a><li>GetXYTolerance()
+: <a class="el" href="class_fdo_i_create_s_d_f_file_4a2bb60374b5db4f9dca173de2845803.html#4a2bb60374b5db4f9dca173de2845803">FdoICreateSDFFile</a><li>GetZTolerance()
+: <a class="el" href="class_fdo_i_create_s_d_f_file_8b2fc8bbd39311d609c316fac75d765b.html#8b2fc8bbd39311d609c316fac75d765b">FdoICreateSDFFile</a><li>SetCoordinateSystemWKT()
+: <a class="el" href="class_fdo_i_create_s_d_f_file_a98dd232eefdc6835623c5deec259123.html#a98dd232eefdc6835623c5deec259123">FdoICreateSDFFile</a><li>SetFileName()
+: <a class="el" href="class_fdo_i_create_s_d_f_file_e37b34b21d62e779c004fb5229a83d37.html#e37b34b21d62e779c004fb5229a83d37">FdoICreateSDFFile</a><li>SetSpatialContextDescription()
+: <a class="el" href="class_fdo_i_create_s_d_f_file_9920ab315df81464390397ee73bcfab4.html#9920ab315df81464390397ee73bcfab4">FdoICreateSDFFile</a><li>SetSpatialContextName()
+: <a class="el" href="class_fdo_i_create_s_d_f_file_ad37e0d64c5a74e57765a108447332bb.html#ad37e0d64c5a74e57765a108447332bb">FdoICreateSDFFile</a><li>SetXYTolerance()
+: <a class="el" href="class_fdo_i_create_s_d_f_file_b3e528dda87b952a83786b2d01343524.html#b3e528dda87b952a83786b2d01343524">FdoICreateSDFFile</a><li>SetZTolerance()
+: <a class="el" href="class_fdo_i_create_s_d_f_file_2937b06fdf37207301200042b40e8d71.html#2937b06fdf37207301200042b40e8d71">FdoICreateSDFFile</a></ul>
+<!-- footer.html -->
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/functions_func.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/functions_func.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SDF/functions_func.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,64 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li><a href="functions.html"><span>All</span></a></li>
+ <li id="current"><a href="functions_func.html"><span>Functions</span></a></li>
+ </ul>
+</div>
+<p>
+<ul>
+<li>Execute()
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/globals.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/globals.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SDF/globals.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,54 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li id="current"><a href="globals.html"><span>File Members</span></a></li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li id="current"><a href="globals.html"><span>All</span></a></li>
+ <li><a href="globals_enum.html"><span>Enumerations</span></a></li>
+ <li><a href="globals_eval.html"><span>Enumerator</span></a></li>
+ <li><a href="globals_defs.html"><span>Defines</span></a></li>
+ </ul>
+</div>
+Here is a list of all file members with links to the files they belong to:
+<p>
+<ul>
+<li>SDF_FIRST_PROVIDER_COMMAND
+: <a class="el" href="_sdf_command_type_8h_86597e57635d4329ec6b9d0a67f969d7.html#86597e57635d4329ec6b9d0a67f969d7">SdfCommandType.h</a><li>SdfCommandType
+: <a class="el" href="_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html#4ac92492e0d58aeace1b0c0f96cefea3">SdfCommandType.h</a><li>SdfCommandType_CreateSDFFile
+: <a class="el" href="_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html#4ac92492e0d58aeace1b0c0f96cefea348c2e525ef9f5e6ae1db0962a09cff37">SdfCommandType.h</a></ul>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/globals_defs.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/globals_defs.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SDF/globals_defs.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,52 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li><a href="globals.html"><span>All</span></a></li>
+ <li id="current"><a href="globals_defs.html"><span>Defines</span></a></li>
+ </ul>
+</div>
+<p>
+<ul>
+: <a class="el" href="_sdf_command_type_8h_86597e57635d4329ec6b9d0a67f969d7.html#86597e57635d4329ec6b9d0a67f969d7">SdfCommandType.h</a></ul>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/globals_enum.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/globals_enum.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SDF/globals_enum.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,52 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li id="current"><a href="globals_enum.html"><span>Enumerations</span></a></li>
+ </ul>
+</div>
+<p>
+<ul>
+<li>SdfCommandType
+: <a class="el" href="_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html#4ac92492e0d58aeace1b0c0f96cefea3">SdfCommandType.h</a></ul>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/globals_eval.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/globals_eval.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SDF/globals_eval.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,52 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li id="current"><a href="globals_eval.html"><span>Enumerator</span></a></li>
+ </ul>
+</div>
+<p>
+<ul>
+<li>SdfCommandType_CreateSDFFile
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/graph_legend.dot
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/graph_legend.dot?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SDF/graph_legend.dot 2006-03-06 21:40:50+0000
@@ -0,0 +1,22 @@
+digraph G
+ edge [fontname="Helvetica",fontsize=10,labelfontname="Helvetica",labelfontsize=10];
+ node [fontname="Helvetica",fontsize=10,shape=record];
+ Node9 [shape="box",label="Inherited",fontsize=10,height=0.2,width=0.4,fontname="Helvetica",color="black",style="filled" fontcolor="white"];
+ Node10 -> Node9 [dir=back,color="midnightblue",fontsize=10,style="solid",fontname="Helvetica"];
+ Node10 [shape="box",label="PublicBase",fontsize=10,height=0.2,width=0.4,fontname="Helvetica",color="black",URL="$classPublicBase.html"];
+ Node11 -> Node10 [dir=back,color="midnightblue",fontsize=10,style="solid",fontname="Helvetica"];
+ Node11 [shape="box",label="Truncated",fontsize=10,height=0.2,width=0.4,fontname="Helvetica",color="red",URL="$classTruncated.html"];
+ Node13 -> Node9 [dir=back,color="darkgreen",fontsize=10,style="solid",fontname="Helvetica"];
+ Node13 [shape="box",label="ProtectedBase",fontsize=10,height=0.2,width=0.4,fontname="Helvetica",color="black",URL="$classProtectedBase.html"];
+ Node14 -> Node9 [dir=back,color="firebrick4",fontsize=10,style="solid",fontname="Helvetica"];
+ Node14 [shape="box",label="PrivateBase",fontsize=10,height=0.2,width=0.4,fontname="Helvetica",color="black",URL="$classPrivateBase.html"];
+ Node15 -> Node9 [dir=back,color="midnightblue",fontsize=10,style="solid",fontname="Helvetica"];
+ Node15 [shape="box",label="Undocumented",fontsize=10,height=0.2,width=0.4,fontname="Helvetica",color="grey75"];
+ Node16 -> Node9 [dir=back,color="midnightblue",fontsize=10,style="solid",fontname="Helvetica"];
+ Node16 [shape="box",label="Templ< int >",fontsize=10,height=0.2,width=0.4,fontname="Helvetica",color="black",URL="$classTempl.html"];
+ Node17 -> Node16 [dir=back,color="orange",fontsize=10,style="dashed",label="< int >",fontname="Helvetica"];
+ Node17 [shape="box",label="Templ< T >",fontsize=10,height=0.2,width=0.4,fontname="Helvetica",color="black",URL="$classTempl.html"];
+ Node18 -> Node9 [dir=back,color="darkorchid3",fontsize=10,style="dashed",label="m_usedClass",fontname="Helvetica"];
+ Node18 [shape="box",label="Used",fontsize=10,height=0.2,width=0.4,fontname="Helvetica",color="black",URL="$classUsed.html"];
Added: trunk/www/docs/SDF/graph_legend.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/graph_legend.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SDF/graph_legend.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,96 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li><a href="files.html"><span>Files</span></a></li>
+ </ul></div>
+<h1>Graph Legend</h1>This page explains how to interpret the graphs that are generated by doxygen.<p>
+Consider the following example: <div class="fragment"><pre class="fragment"><span class="comment">/*! Invisible class because of truncation */</span>
+<span class="keyword">class </span>Invisible { };
+<span class="comment"></span>
+<span class="comment">/*! Truncated class, inheritance relation is hidden */</span>
+<span class="keyword">class </span>Truncated : <span class="keyword">public</span> Invisible { };
+<span class="comment">/* Class not documented with doxygen comments */</span>
+<span class="keyword">class </span>Undocumented { };
+<span class="comment">/*! Class that is inherited using public inheritance */</span>
+<span class="keyword">class </span>PublicBase : <span class="keyword">public</span> Truncated { };
+<span class="comment">/*! A template class */</span>
+<span class="keyword">template</span><<span class="keyword">class</span> T> <span class="keyword">class </span>Templ { };
+<span class="comment">/*! Class that is inherited using protected inheritance */</span>
+<span class="keyword">class </span>ProtectedBase { };
+<span class="comment">/*! Class that is inherited using private inheritance */</span>
+<span class="keyword">class </span>PrivateBase { };
+<span class="comment">/*! Class that is used by the Inherited class */</span>
+<span class="keyword">class </span>Used { };
+<span class="comment">/*! Super class that inherits a number of other classes */</span>
+<span class="keyword">class </span>Inherited : <span class="keyword">public</span> PublicBase,
+ <span class="keyword">protected</span> ProtectedBase,
+ <span class="keyword">private</span> PrivateBase,
+ <span class="keyword">public</span> Undocumented
+ <span class="keyword">public</span> Templ<int>
+ <span class="keyword">private</span>:
+ Used *m_usedClass;
+</pre></div> If the <code>MAX_DOT_GRAPH_HEIGHT</code> tag in the configuration file is set to 240 this will result in the following graph:<p>
+<center><div align="center">
+<img src="graph_legend.png" alt="graph_legend.png">
+</div>
+</center> <p>
+The boxes in the above graph have the following meaning: <ul>
+<li>
+A filled black box represents the struct or class for which the graph is generated. </li>
+<li>
+A box with a black border denotes a documented struct or class. </li>
+<li>
+A box with a grey border denotes an undocumented struct or class. </li>
+<li>
+A box with a red border denotes a documented struct or class forwhich not all inheritance/containment relations are shown. A graph is truncated if it does not fit within the specified boundaries. </li>
+</ul>
+The arrows have the following meaning: <ul>
+<li>
+A dark blue arrow is used to visualize a public inheritance relation between two classes. </li>
+<li>
+A dark green arrow is used for protected inheritance. </li>
+<li>
+A dark red arrow is used for private inheritance. </li>
+<li>
+A purple dashed arrow is used if a class is contained or used by another class. The arrow is labeled with the variable(s) through which the pointed class or struct is accessible. </li>
+<li>
+A yellow dashed arrow denotes a relation between a template instance and the template class it was instantiated from. The arrow is labeled with the template parameters of the instance. </li>
+</ul>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/graph_legend.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/graph_legend.png?view=auto&rev=4
Binary file. No diff available.
Added: trunk/www/docs/SDF/hierarchy.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/hierarchy.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SDF/hierarchy.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,46 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li id="current"><a href="classes.html"><span>Classes</span></a></li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li><a href="classes.html"><span>Alphabetical List</span></a></li>
+ <li><a href="annotated.html"><span>Class List</span></a></li>
+ <li id="current"><a href="hierarchy.html"><span>Class Hierarchy</span></a></li>
+ <li><a href="functions.html"><span>Class Members</span></a></li>
+ </ul></div>
+<h1>FDO Provider for SDF Class Hierarchy</h1><a href="inherits.html">Go to the graphical class hierarchy</a>
+<p>
+This inheritance list is sorted roughly, but not completely, alphabetically:<ul>
+<li><a class="el" href="class_fdo_i_create_s_d_f_file.html">FdoICreateSDFFile</a>
+</ul>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/index.hhc
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/index.hhc?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SDF/index.hhc 2006-03-06 21:40:50+0000
@@ -0,0 +1,25 @@
+<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML//EN">
+<HTML><HEAD></HEAD><BODY>
+<OBJECT type="text/site properties">
+<param name="FrameName" value="right">
+</OBJECT>
+<UL>
+<LI><OBJECT type="text/sitemap"><param name="Name" value="Introduction"><param name="Local" value="main.html"><param name="ImageNumber" value="11"></OBJECT>
+<LI><OBJECT type="text/sitemap"><param name="Name" value="File List"><param name="ImageNumber" value="1"></OBJECT>
+ <UL>
+ <LI><OBJECT type="text/sitemap"><param name="Name" value="define_pages.h"><param name="Local" value="define__pages_8h.html"><param name="ImageNumber" value="11"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Name" value="ICreateSDFFile.h"><param name="Local" value="_i_create_s_d_f_file_8h.html"><param name="ImageNumber" value="11"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Name" value="SdfCommandType.h"><param name="Local" value="_sdf_command_type_8h.html"><param name="ImageNumber" value="11"></OBJECT>
+ </UL>
+<LI><OBJECT type="text/sitemap"><param name="Name" value="Class List"><param name="ImageNumber" value="1"></OBJECT>
+ <UL>
+ <LI><OBJECT type="text/sitemap"><param name="Name" value="FdoICreateSDFFile"><param name="Local" value="class_fdo_i_create_s_d_f_file.html"><param name="ImageNumber" value="11"></OBJECT>
+ </UL>
+<LI><OBJECT type="text/sitemap"><param name="Name" value="Class Hierarchy"><param name="ImageNumber" value="1"></OBJECT>
+ <UL>
+ </UL>
+<LI><OBJECT type="text/sitemap"><param name="Name" value="Class Members"><param name="Local" value="functions.html"><param name="ImageNumber" value="11"></OBJECT>
+<LI><OBJECT type="text/sitemap"><param name="Name" value="File Members"><param name="Local" value="globals.html"><param name="ImageNumber" value="11"></OBJECT>
+<LI><OBJECT type="text/sitemap"><param name="Name" value="Graphical Class Hierarchy"><param name="Local" value="inherits.html"><param name="ImageNumber" value="11"></OBJECT>
+</UL>
Added: trunk/www/docs/SDF/index.hhk
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/index.hhk?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SDF/index.hhk 2006-03-06 21:40:50+0000
@@ -0,0 +1,45 @@
+</OBJECT>
+<UL>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file_05550ca7007c3e389b7029c41baa1587.html#05550ca7007c3e389b7029c41baa1587"><param name="Name" value="Execute"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file.html"><param name="Name" value="FdoICreateSDFFile"></OBJECT>
+ <UL>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file.html#05550ca7007c3e389b7029c41baa1587"><param name="Name" value="Execute"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file.html#31d3dc34da21f6049581211a14b27d37"><param name="Name" value="GetCoordinateSystemWKT"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file.html#eb8a85d56333894242c2ad05ede1a830"><param name="Name" value="GetFileName"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file.html#7f8850475beb73c192be00a4960628a1"><param name="Name" value="GetSpatialContextDescription"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file.html#65ffde001f9b3d4932c4163a8e8e2134"><param name="Name" value="GetSpatialContextName"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file.html#4a2bb60374b5db4f9dca173de2845803"><param name="Name" value="GetXYTolerance"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file.html#8b2fc8bbd39311d609c316fac75d765b"><param name="Name" value="GetZTolerance"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file.html#a98dd232eefdc6835623c5deec259123"><param name="Name" value="SetCoordinateSystemWKT"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file.html#e37b34b21d62e779c004fb5229a83d37"><param name="Name" value="SetFileName"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file.html#9920ab315df81464390397ee73bcfab4"><param name="Name" value="SetSpatialContextDescription"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file.html#ad37e0d64c5a74e57765a108447332bb"><param name="Name" value="SetSpatialContextName"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file.html#b3e528dda87b952a83786b2d01343524"><param name="Name" value="SetXYTolerance"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file.html#2937b06fdf37207301200042b40e8d71"><param name="Name" value="SetZTolerance"></OBJECT>
+ </UL>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file_31d3dc34da21f6049581211a14b27d37.html#31d3dc34da21f6049581211a14b27d37"><param name="Name" value="GetCoordinateSystemWKT"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file_eb8a85d56333894242c2ad05ede1a830.html#eb8a85d56333894242c2ad05ede1a830"><param name="Name" value="GetFileName"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file_7f8850475beb73c192be00a4960628a1.html#7f8850475beb73c192be00a4960628a1"><param name="Name" value="GetSpatialContextDescription"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file_65ffde001f9b3d4932c4163a8e8e2134.html#65ffde001f9b3d4932c4163a8e8e2134"><param name="Name" value="GetSpatialContextName"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file_4a2bb60374b5db4f9dca173de2845803.html#4a2bb60374b5db4f9dca173de2845803"><param name="Name" value="GetXYTolerance"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file_8b2fc8bbd39311d609c316fac75d765b.html#8b2fc8bbd39311d609c316fac75d765b"><param name="Name" value="GetZTolerance"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="_sdf_command_type_8h_86597e57635d4329ec6b9d0a67f969d7.html#86597e57635d4329ec6b9d0a67f969d7"><param name="Name" value="SDF_FIRST_PROVIDER_COMMAND"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="_sdf_command_type_8h.html"><param name="Name" value="SdfCommandType.h"></OBJECT>
+ <UL>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="_sdf_command_type_8h.html#86597e57635d4329ec6b9d0a67f969d7"><param name="Name" value="SDF_FIRST_PROVIDER_COMMAND"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="_sdf_command_type_8h.html#4ac92492e0d58aeace1b0c0f96cefea3"><param name="Name" value="SdfCommandType"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="_sdf_command_type_8h.html#4ac92492e0d58aeace1b0c0f96cefea348c2e525ef9f5e6ae1db0962a09cff37"><param name="Name" value="SdfCommandType_CreateSDFFile"></OBJECT>
+ </UL>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html#4ac92492e0d58aeace1b0c0f96cefea3"><param name="Name" value="SdfCommandType"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html#4ac92492e0d58aeace1b0c0f96cefea348c2e525ef9f5e6ae1db0962a09cff37"><param name="Name" value="SdfCommandType_CreateSDFFile"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file_a98dd232eefdc6835623c5deec259123.html#a98dd232eefdc6835623c5deec259123"><param name="Name" value="SetCoordinateSystemWKT"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file_e37b34b21d62e779c004fb5229a83d37.html#e37b34b21d62e779c004fb5229a83d37"><param name="Name" value="SetFileName"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file_9920ab315df81464390397ee73bcfab4.html#9920ab315df81464390397ee73bcfab4"><param name="Name" value="SetSpatialContextDescription"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file_ad37e0d64c5a74e57765a108447332bb.html#ad37e0d64c5a74e57765a108447332bb"><param name="Name" value="SetSpatialContextName"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file_b3e528dda87b952a83786b2d01343524.html#b3e528dda87b952a83786b2d01343524"><param name="Name" value="SetXYTolerance"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_i_create_s_d_f_file_2937b06fdf37207301200042b40e8d71.html#2937b06fdf37207301200042b40e8d71"><param name="Name" value="SetZTolerance"></OBJECT>
+</UL>
Added: trunk/www/docs/SDF/index.hhp
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/index.hhp?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SDF/index.hhp 2006-03-06 21:40:50+0000
@@ -0,0 +1,56 @@
+[OPTIONS]
+Compiled file=..\..\..\SDF_Provider_API.chm
+Compatibility=1.1
+Full-text search=Yes
+Contents file=index.hhc
+Default Window=main
+Default topic=main.html
+Index file=index.hhk
+Language=0x409 English (United States)
+Binary TOC=YES
+Title=FDO Provider for SDF
+[WINDOWS]
+main="FDO Provider for SDF","index.hhc","index.hhk","main.html","main.html",,,,,0x23520,,0x387e,,,,,,,,0
+[FILES]
+main.html
+files.html
+define__pages_8h-source.html
+_i_create_s_d_f_file_8h-source.html
+_sdf_command_type_8h-source.html
+define__pages_8h.html
+_i_create_s_d_f_file_8h.html
+_sdf_command_type_8h.html
+_sdf_command_type_8h_86597e57635d4329ec6b9d0a67f969d7.html
+_sdf_command_type_8h_4ac92492e0d58aeace1b0c0f96cefea3.html
+annotated.html
+classes.html
+hierarchy.html
+functions.html
+functions_func.html
+class_fdo_i_create_s_d_f_file.html
+class_fdo_i_create_s_d_f_file_05550ca7007c3e389b7029c41baa1587.html
+class_fdo_i_create_s_d_f_file_31d3dc34da21f6049581211a14b27d37.html
+class_fdo_i_create_s_d_f_file_eb8a85d56333894242c2ad05ede1a830.html
+class_fdo_i_create_s_d_f_file_7f8850475beb73c192be00a4960628a1.html
+class_fdo_i_create_s_d_f_file_65ffde001f9b3d4932c4163a8e8e2134.html
+class_fdo_i_create_s_d_f_file_4a2bb60374b5db4f9dca173de2845803.html
+class_fdo_i_create_s_d_f_file_8b2fc8bbd39311d609c316fac75d765b.html
+class_fdo_i_create_s_d_f_file_a98dd232eefdc6835623c5deec259123.html
+class_fdo_i_create_s_d_f_file_e37b34b21d62e779c004fb5229a83d37.html
+class_fdo_i_create_s_d_f_file_9920ab315df81464390397ee73bcfab4.html
+class_fdo_i_create_s_d_f_file_ad37e0d64c5a74e57765a108447332bb.html
+class_fdo_i_create_s_d_f_file_b3e528dda87b952a83786b2d01343524.html
+class_fdo_i_create_s_d_f_file_2937b06fdf37207301200042b40e8d71.html
+class_fdo_i_create_s_d_f_file-members.html
+globals.html
+globals_enum.html
+globals_eval.html
+globals_defs.html
+graph_legend.html
+inherits.html
+tabs.css
Added: trunk/www/docs/SDF/index.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/index.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SDF/index.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,8 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
+<html><head><meta http-equiv="Content-Type" content="text/html;charset=iso-8859-1">
+<title>FDO Provider for SDF</title></head>
+<frameset cols="250,*">
+ <frame src="tree.html" name="treefrm">
+ <frame src="main.html" name="basefrm">
+</frameset>
+</html>
Added: trunk/www/docs/SDF/inherit__graph__0.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/inherit__graph__0.map?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SDF/inherit__graph__0.map 2006-03-06 21:40:50+0000
@@ -0,0 +1,2 @@
+base referer
+rect $class_fdo_i_create_s_d_f_file.html 7,7 145,33
Added: trunk/www/docs/SDF/inherit__graph__0.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/inherit__graph__0.md5?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SDF/inherit__graph__0.md5 2006-03-06 21:40:50+0000
@@ -0,0 +1 @@
+b1661466bf076ac9f54d14627d06032d
\ No newline at end of file
Added: trunk/www/docs/SDF/inherit__graph__0.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/inherit__graph__0.png?view=auto&rev=4
Added: trunk/www/docs/SDF/inherits.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/inherits.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SDF/inherits.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,49 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>FDO Provider for SDF Graphical Class Hierarchy</h1><a href="hierarchy.html">Go to the textual class hierarchy</a>
+<p>
+<table border="0" cellspacing="10" cellpadding="0">
+<tr><td><img src="inherit__graph__0.png" border="0" alt="" usemap="#_fdo_i_create_s_d_f_file_map">
+<map name="_fdo_i_create_s_d_f_file_map">
+<area href="class_fdo_i_create_s_d_f_file.html" shape="rect" coords="7,7,145,33" alt="">
+</map></td></tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/main.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/main.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SDF/main.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,55 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li id="current"><a href="main.html"><span>Main Page</span></a></li>
+ </ul></div>
+<h1>Introduction</h1>
+<p>
+<div class="mainpage"></div><p>
+<div class="mainpage">The Feature Data Objects (FDO) API provides access to data in a data store. A provider is a specific implementation of the FDO API that provides access to data in a particular data store. The FDO Provider for SDF provides FDO with access to an SDF-based data store.</div><p>
+<div class="mainpage">The FDO Provider for SDF uses Autodesk's spatial database format, which is a file-based personal geodatabase that supports multiple features/attributes, spatial indexing, interoperability, file-locking, and high performance for large data sets. </div><p>
+<div class="mainpage">The SDF file format has the following characteristics: </div><p>
+<div class="mainpage"><ul>
+<li>
+SDF files can be read on different platforms. </li>
+<li>
+The SDF file format has its own spatial indexing. </li>
+<li>
+SDF files can store geometric and non-geometric data with minimum overhead </li>
+<li>
+Although it does not support concurrency control (locking), the SDF file format is a valid alternative to RDBMS. </li>
+</ul>
+</div><p>
+<div class="mainpage"> For more information, see <em>The Essential FDO</em> (FET_TheEssentialFDO.pdf) and the <em>FDO Developer's Guide</em> (FDG_FDODevGuide.pdf). </div><p>
+<div class="mainpage"><br>
+ </div> <!-- footer.html -->
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SDF/tab_b.gif
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/tab_b.gif?view=auto&rev=4
Added: trunk/www/docs/SDF/tab_l.gif
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/tab_l.gif?view=auto&rev=4
Added: trunk/www/docs/SDF/tab_r.gif
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/tab_r.gif?view=auto&rev=4
Added: trunk/www/docs/SDF/tabs.css
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/tabs.css?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SDF/tabs.css 2006-03-06 21:40:50+0000
@@ -0,0 +1,102 @@
+/* tabs styles, based on http://www.alistapart.com/articles/slidingdoors */
+DIV.tabs
+ float : left;
+ width : 100%;
+ background : url("tab_b.gif") repeat-x bottom;
+ margin-bottom : 4px;
+DIV.tabs UL
+ margin : 0px;
+ padding-left : 10px;
+ list-style : none;
+DIV.tabs LI, DIV.tabs FORM
+ display : inline;
+ margin : 0px;
+ padding : 0px;
+DIV.tabs FORM
+ float : right;
+DIV.tabs A
+ float : left;
+ background : url("tab_r.gif") no-repeat right top;
+ border-bottom : 1px solid #84B0C7;
+ font-size : x-small;
+ font-weight : bold;
+ text-decoration : none;
+DIV.tabs A:hover
+ background-position: 100% -150px;
+DIV.tabs A:link, DIV.tabs A:visited,
+DIV.tabs A:active, DIV.tabs A:hover
+ color: #1A419D;
+DIV.tabs SPAN
+ float : left;
+ display : block;
+ background : url("tab_l.gif") no-repeat left top;
+ padding : 5px 9px;
+ white-space : nowrap;
+DIV.tabs INPUT
+ float : right;
+ display : inline;
+ font-size : 1em;
+DIV.tabs TD
+/* Commented Backslash Hack hides rule from IE5-Mac \*/
+DIV.tabs SPAN {float : none;}
+/* End IE5-Mac hack */
+DIV.tabs A:hover SPAN
+ background-position: 0% -150px;
+DIV.tabs LI#current A
+ border-width : 0px;
+DIV.tabs LI#current SPAN
+ padding-bottom : 6px;
+DIV.nav
+ background : none;
+ border : none;
Added: trunk/www/docs/SDF/tree.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/tree.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SDF/tree.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,96 @@
+<html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en">
+ <head>
+ <meta http-equiv="Content-Type" content="text/xhtml;charset=iso-8859-1" />
+ <meta http-equiv="Content-Style-Type" content="text/css" />
+ <meta http-equiv="Content-Language" content="en" />
+ <link rel="stylesheet" href="custom.css">
+ <title>TreeView</title>
+ <style type="text/css">
+ .directory { font-size: 10pt; font-weight: bold; }
+ .directory h3 { margin: 0px; margin-top: 1em; font-size: 11pt; }
+ .directory p { margin: 0px; white-space: nowrap; }
+ .directory div { display: none; margin: 0px; }
+ .directory img { vertical-align: middle; }
+ </style>
+ <script type="text/javascript">
+ <!-- // Hide script from old browsers
+ function toggleFolder(id, imageNode)
+ var folder = document.getElementById(id);
+ var l = imageNode.src.length;
+ if (imageNode.src.substring(l-20,l)=="ftv2folderclosed.png" ||
+ imageNode.src.substring(l-18,l)=="ftv2folderopen.png")
+ imageNode = imageNode.previousSibling;
+ l = imageNode.src.length;
+ if (folder == null)
+ else if (folder.style.display == "block")
+ if (imageNode != null)
+ imageNode.nextSibling.src = "ftv2folderclosed.png";
+ if (imageNode.src.substring(l-13,l) == "ftv2mnode.png")
+ imageNode.src = "ftv2pnode.png";
+ else if (imageNode.src.substring(l-17,l) == "ftv2mlastnode.png")
+ imageNode.src = "ftv2plastnode.png";
+ folder.style.display = "none";
+ else
+ imageNode.nextSibling.src = "ftv2folderopen.png";
+ if (imageNode.src.substring(l-13,l) == "ftv2pnode.png")
+ imageNode.src = "ftv2mnode.png";
+ else if (imageNode.src.substring(l-17,l) == "ftv2plastnode.png")
+ imageNode.src = "ftv2mlastnode.png";
+ folder.style.display = "block";
+ // End script hiding -->
+ </script>
+ </head>
+ <body>
+ <div class="directory">
+ <h3>FDO Provider for SDF</h3>
+ <div style="display: block;">
+ <p><img src="ftv2node.png" alt="o" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="main.html" target="basefrm">Introduction</a></p>
+ <p><img src="ftv2pnode.png" alt="o" width=16 height=22 onclick="toggleFolder('folder1', this)"/><img src="ftv2folderclosed.png" alt="+" width=24 height=22 onclick="toggleFolder('folder1', this)"/><a class="el" href="files.html" target="basefrm">File List</a></p>
+ <div id="folder1">
+ <p><img src="ftv2vertline.png" alt="|" width=16 height=22 /><img src="ftv2node.png" alt="o" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="define__pages_8h.html" target="basefrm">define_pages.h</a></p>
+ <p><img src="ftv2vertline.png" alt="|" width=16 height=22 /><img src="ftv2node.png" alt="o" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="_i_create_s_d_f_file_8h.html" target="basefrm">ICreateSDFFile.h</a></p>
+ <p><img src="ftv2vertline.png" alt="|" width=16 height=22 /><img src="ftv2lastnode.png" alt="\" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="_sdf_command_type_8h.html" target="basefrm">SdfCommandType.h</a></p>
+ </div>
+ <p><img src="ftv2pnode.png" alt="o" width=16 height=22 onclick="toggleFolder('folder2', this)"/><img src="ftv2folderclosed.png" alt="+" width=24 height=22 onclick="toggleFolder('folder2', this)"/><a class="el" href="annotated.html" target="basefrm">Class List</a></p>
+ <div id="folder2">
+ <p><img src="ftv2vertline.png" alt="|" width=16 height=22 /><img src="ftv2lastnode.png" alt="\" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="class_fdo_i_create_s_d_f_file.html" target="basefrm">FdoICreateSDFFile</a></p>
+ </div>
+ <p><img src="ftv2pnode.png" alt="o" width=16 height=22 onclick="toggleFolder('folder3', this)"/><img src="ftv2folderclosed.png" alt="+" width=24 height=22 onclick="toggleFolder('folder3', this)"/><a class="el" href="hierarchy.html" target="basefrm">Class Hierarchy</a></p>
+ <div id="folder3">
+ </div>
+ <p><img src="ftv2node.png" alt="o" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="functions.html" target="basefrm">Class Members</a></p>
+ <p><img src="ftv2node.png" alt="o" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="globals.html" target="basefrm">File Members</a></p>
+ <p><img src="ftv2lastnode.png" alt="\" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="inherits.html" target="basefrm">Graphical Class Hierarchy</a></p>
+ </div>
+ </div>
+ </body>
+</html>
Added: trunk/www/docs/SHP/_fdo_shp_class_collection_8h-source.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_class_collection_8h-source.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_class_collection_8h-source.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,92 @@
+<html>
+ <head>
+ <title>OSGeo FDO Provider for SHP API Reference</title>
+ </head>
+ <tr>
+ <td align="right"><b>OSGeo FDO Provider for SHP<b></td>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li>
+ <form action="search.php" method="get">
+ <table cellspacing="0" cellpadding="0" border="0">
+ <tr>
+ <td><label> <u>S</u>earch for </label></td>
+ <td><input type="text" name="query" value="" size="20" accesskey="s"/></td>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>FdoShpClassCollection.h</h1><a href="_fdo_shp_class_collection_8h.html">Go to the documentation of this file.</a><div class="fragment"><pre class="fragment"><a name="l00001"></a>00001 <span class="comment">/*</span>
+<a name="l00002"></a>00002 <span class="comment"> * Copyright (C) 2004-2006 Autodesk, Inc.</span>
+<a name="l00003"></a>00003 <span class="comment">* </span>
+<a name="l00004"></a>00004 <span class="comment">* This library is free software; you can redistribute it and/or</span>
+<a name="l00005"></a>00005 <span class="comment">* modify it under the terms of version 2.1 of the GNU Lesser</span>
+<a name="l00006"></a>00006 <span class="comment">* General Public License as published by the Free Software Foundation.</span>
+<a name="l00007"></a>00007 <span class="comment">* </span>
+<a name="l00008"></a>00008 <span class="comment">* This library is distributed in the hope that it will be useful,</span>
+<a name="l00009"></a>00009 <span class="comment">* but WITHOUT ANY WARRANTY; without even the implied warranty of</span>
+<a name="l00010"></a>00010 <span class="comment">* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU</span>
+<a name="l00011"></a>00011 <span class="comment">* Lesser General Public License for more details.</span>
+<a name="l00012"></a>00012 <span class="comment">* </span>
+<a name="l00013"></a>00013 <span class="comment">* You should have received a copy of the GNU Lesser General Public</span>
+<a name="l00014"></a>00014 <span class="comment">* License along with this library; if not, write to the Free Software</span>
+<a name="l00015"></a>00015 <span class="comment">* Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA</span>
+<a name="l00016"></a>00016 <span class="comment"> */</span>
+<a name="l00017"></a>00017 <span class="preprocessor">#ifndef FDOSHPCLASSCOLLECTION_H</span>
+<a name="l00018"></a>00018 <span class="preprocessor"></span><span class="preprocessor">#define FDOSHPCLASSCOLLECTION_H</span>
+<a name="l00019"></a>00019 <span class="preprocessor"></span>
+<a name="l00020"></a>00020 <span class="preprocessor">#ifdef _WIN32</span>
+<a name="l00021"></a>00021 <span class="preprocessor"></span><span class="preprocessor">#pragma once</span>
+<a name="l00022"></a>00022 <span class="preprocessor"></span><span class="preprocessor">#endif //_WIN32</span>
+<a name="l00023"></a>00023 <span class="preprocessor"></span>
+<a name="l00024"></a>00024 <span class="preprocessor">#include <<a class="code" href="_fdo_shp_class_definition_8h.html">Shp/Override/FdoShpClassDefinition.h</a>></span>
+<a name="l00026"></a><a class="code" href="class_fdo_shp_class_collection.html">00026</a> <span class="keyword">class </span><a class="code" href="class_fdo_shp_class_collection.html">FdoShpClassCollection</a> : <span class="keyword">public</span> FdoPhysicalElementMappingCollection<FdoShpClassDefinition>
+<a name="l00027"></a>00027 {
+<a name="l00028"></a>00028 <span class="keyword">public</span>:
+<a name="l00029"></a>00029 FDOSHP_API <span class="keyword">static</span> <a class="code" href="class_fdo_shp_class_collection.html">FdoShpClassCollection</a>* <a class="code" href="class_fdo_shp_class_collection_8ac302ce67fca3f9558ff5c647cfcff9.html#8ac302ce67fca3f9558ff5c647cfcff9">Create</a>();
+<a name="l00030"></a>00030 FDOSHP_API <span class="keyword">static</span> <a class="code" href="class_fdo_shp_class_collection.html">FdoShpClassCollection</a>* <a class="code" href="class_fdo_shp_class_collection_8ac302ce67fca3f9558ff5c647cfcff9.html#8ac302ce67fca3f9558ff5c647cfcff9">Create</a>(FdoPhysicalElementMapping *parent);
+<a name="l00031"></a>00031
+<a name="l00032"></a>00032 <span class="keyword">protected</span>:
+<a name="l00033"></a>00033 <a class="code" href="class_fdo_shp_class_collection.html">FdoShpClassCollection</a>();
+<a name="l00034"></a>00034 <a class="code" href="class_fdo_shp_class_collection.html">FdoShpClassCollection</a>(FdoPhysicalElementMapping *parent);
+<a name="l00035"></a>00035 <span class="keyword">virtual</span> ~<a class="code" href="class_fdo_shp_class_collection.html">FdoShpClassCollection</a>(<span class="keywordtype">void</span>);
+<a name="l00036"></a>00036 <span class="keyword">virtual</span> <span class="keywordtype">void</span> Dispose();
+<a name="l00037"></a>00037 };
+<a name="l00039"></a><a class="code" href="_fdo_shp_class_collection_8h_14b881fe200a848b2f39736eec0557f3.html#14b881fe200a848b2f39736eec0557f3">00039</a> <span class="keyword">typedef</span> GisPtr<FdoShpClassCollection> <a class="code" href="_fdo_shp_class_collection_8h_14b881fe200a848b2f39736eec0557f3.html#14b881fe200a848b2f39736eec0557f3">FdoShpClassCollectionP</a>;
+<a name="l00040"></a>00040
+<a name="l00041"></a>00041 <span class="preprocessor">#endif // FDOSHPCLASSCOLLECTION_H</span>
+<a name="l00042"></a>00042 <span class="preprocessor"></span>
+<a name="l00043"></a>00043
+</pre></div><!-- footer.html -->
+ <hr>
+ <table width="100%" border="0">
+ <tr>
+ <td align="right"><font size="-2"><a href="mailto:isd.docs at autodesk.com&subject=FDO%20Provider%20for%20SHP%20API%20documentation">Comments?</a></font></td>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/_fdo_shp_class_collection_8h.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_class_collection_8h.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_class_collection_8h.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,76 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
+<html>
+ <head>
+ <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
+ <link href="custom.css" rel="stylesheet" type="text/css">
+ <link href="tabs.css" rel="stylesheet" type="text/css">
+ </head>
+ <body bgcolor="#FFFFFF">
+ <tr>
+ <td><b>API Reference<b></td>
+ </tr>
+ </table>
+<!-- End of: header.html -->
+<!-- Generated by Doxygen 1.4.6-NO -->
+<div class="tabs">
+ <ul>
+ <li><a href="main.html"><span>Main Page</span></a></li>
+ <li><a href="classes.html"><span>Classes</span></a></li>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>FdoShpClassCollection.h File Reference</h1>
+<p>
+<code>#include <<a class="el" href="_fdo_shp_class_definition_8h-source.html">Shp/Override/FdoShpClassDefinition.h</a>></code><br>
+<p>
+Include dependency graph for FdoShpClassCollection.h:<p><center><img src="_fdo_shp_class_collection_8h__incl.png" border="0" usemap="#FdoShpClassCollection.h_map" alt=""></center>
+<map name="FdoShpClassCollection.h_map">
+<area href="_fdo_shp_class_definition_8h.html" shape="rect" coords="228,7,482,33" alt="">
+<area href="_fdo_shp_property_definition_collection_8h.html" shape="rect" coords="530,7,860,33" alt="">
+</map>
+<p>
+This graph shows which files directly or indirectly include this file:<p><center><img src="_fdo_shp_class_collection_8h__dep__incl.png" border="0" usemap="#FdoShpClassCollection.hdep_map" alt=""></center>
+<map name="FdoShpClassCollection.hdep_map">
+<area href="_fdo_shp_physical_schema_mapping_8h.html" shape="rect" coords="230,7,459,33" alt="">
+</map>
+<p>
+<a href="_fdo_shp_class_collection_8h-source.html">Go to the source code of this file.</a><table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td colspan="2"><br><h2>Classes</h2></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">class </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_class_collection.html">FdoShpClassCollection</a></td></tr>
+<tr><td colspan="2"><br><h2>Typedefs</h2></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">typedef GisPtr< <a class="el" href="class_fdo_shp_class_collection.html">FdoShpClassCollection</a> > </td><td class="memItemRight" valign="bottom"><a class="el" href="_fdo_shp_class_collection_8h_14b881fe200a848b2f39736eec0557f3.html#14b881fe200a848b2f39736eec0557f3">FdoShpClassCollectionP</a></td></tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/_fdo_shp_class_collection_8h_14b881fe200a848b2f39736eec0557f3.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_class_collection_8h_14b881fe200a848b2f39736eec0557f3.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_class_collection_8h_14b881fe200a848b2f39736eec0557f3.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,84 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="nav">
+<a class="el" href="_fdo_shp_class_collection_8h.html">FdoShpClassCollection.h</a></div>
+<table cellspacing="0" cellpadding="0" border="0">
+ <tr>
+ <td valign="top">
+ <div class="navtab">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="_fdo_shp_class_collection_8h_14b881fe200a848b2f39736eec0557f3.html#14b881fe200a848b2f39736eec0557f3">FdoShpClassCollectionP</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="14b881fe200a848b2f39736eec0557f3"></a><!-- doxytag: member="FdoShpClassCollection.h::FdoShpClassCollectionP" ref="14b881fe200a848b2f39736eec0557f3" args="" --><p>
+<table class="mdTable" cellpadding="2" cellspacing="0">
+ <tr>
+ <td class="mdRow">
+ <table cellpadding="0" cellspacing="0" border="0">
+ <tr>
+ <td class="md" nowrap valign="top">typedef GisPtr<<a class="el" href="class_fdo_shp_class_collection.html">FdoShpClassCollection</a>> <a class="el" href="_fdo_shp_class_collection_8h_14b881fe200a848b2f39736eec0557f3.html#14b881fe200a848b2f39736eec0557f3">FdoShpClassCollectionP</a> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+<table cellspacing="5" cellpadding="0" border="0">
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+<p>
+Definition at line <a class="el" href="_fdo_shp_class_collection_8h-source.html#l00039">39</a> of file <a class="el" href="_fdo_shp_class_collection_8h-source.html">FdoShpClassCollection.h</a>. </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/_fdo_shp_class_collection_8h__dep__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_class_collection_8h__dep__incl.map?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_class_collection_8h__dep__incl.map 2006-03-06 21:40:50+0000
@@ -0,0 +1,2 @@
+base referer
+rect $_fdo_shp_physical_schema_mapping_8h.html 230,7 459,33
Added: trunk/www/docs/SHP/_fdo_shp_class_collection_8h__dep__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_class_collection_8h__dep__incl.md5?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_class_collection_8h__dep__incl.md5 2006-03-06 21:40:50+0000
@@ -0,0 +1 @@
+6a76a1b41f79138518e324e66b191332
Added: trunk/www/docs/SHP/_fdo_shp_class_collection_8h__dep__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_class_collection_8h__dep__incl.png?view=auto&rev=4
Added: trunk/www/docs/SHP/_fdo_shp_class_collection_8h__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_class_collection_8h__incl.map?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_class_collection_8h__incl.map 2006-03-06 21:40:50+0000
@@ -0,0 +1,3 @@
+base referer
+rect $_fdo_shp_class_definition_8h.html 228,7 482,33
+rect $_fdo_shp_property_definition_collection_8h.html 530,7 860,33
Added: trunk/www/docs/SHP/_fdo_shp_class_collection_8h__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_class_collection_8h__incl.md5?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_class_collection_8h__incl.md5 2006-03-06 21:40:50+0000
@@ -0,0 +1 @@
+d14330334be43a46cfa1850d9792feac
Added: trunk/www/docs/SHP/_fdo_shp_class_collection_8h__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_class_collection_8h__incl.png?view=auto&rev=4
Added: trunk/www/docs/SHP/_fdo_shp_class_definition_8h-source.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_class_definition_8h-source.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_class_definition_8h-source.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,113 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>FdoShpClassDefinition.h</h1><a href="_fdo_shp_class_definition_8h.html">Go to the documentation of this file.</a><div class="fragment"><pre class="fragment"><a name="l00001"></a>00001 <span class="comment">/*</span>
+<a name="l00017"></a>00017 <span class="preprocessor">#ifndef FDOSHPCLASSDEFINITION_H</span>
+<a name="l00018"></a>00018 <span class="preprocessor"></span><span class="preprocessor">#define FDOSHPCLASSDEFINITION_H</span>
+<a name="l00024"></a>00024 <span class="preprocessor">#include <<a class="code" href="_fdo_shp_property_definition_collection_8h.html">Shp/Override/FdoShpPropertyDefinitionCollection.h</a>></span>
+<a name="l00026"></a><a class="code" href="class_fdo_shp_class_definition.html">00026</a> <span class="keyword">class </span><a class="code" href="class_fdo_shp_class_definition.html">FdoShpClassDefinition</a> : <span class="keyword">public</span> FdoPhysicalClassMapping
+<a name="l00028"></a>00028 <span class="keyword">typedef</span> FdoPhysicalClassMapping BaseType;
+<a name="l00030"></a>00030 <span class="keyword">public</span>:
+<a name="l00031"></a>00031 FDOSHP_API <span class="keyword">static</span> <a class="code" href="class_fdo_shp_class_definition.html">FdoShpClassDefinition</a>* <a class="code" href="class_fdo_shp_class_definition_96936568a01aa49e3ef3fbb154fa5ad5.html#96936568a01aa49e3ef3fbb154fa5ad5">Create</a>();
+<a name="l00033"></a>00033 <span class="keyword">public</span>:
+<a name="l00034"></a>00034 FDOSHP_API <a class="code" href="class_fdo_shp_property_definition_collection.html">FdoShpPropertyDefinitionCollection</a>* <a class="code" href="class_fdo_shp_class_definition_bdc54fa302f857e4acc9a0c3660dd245.html#bdc54fa302f857e4acc9a0c3660dd245">GetProperties</a>() <span class="keyword">const</span>;
+<a name="l00036"></a>00036 FDOSHP_API GisString* <a class="code" href="class_fdo_shp_class_definition_4603016faf3795e4c4544f71e0fb4152.html#4603016faf3795e4c4544f71e0fb4152">GetShapeFile</a>() <span class="keyword">const</span>;
+<a name="l00037"></a>00037 FDOSHP_API <span class="keywordtype">void</span> <a class="code" href="class_fdo_shp_class_definition_2e617c437f74fe496aac753fb7666146.html#2e617c437f74fe496aac753fb7666146">SetShapeFile</a>(GisString * location);
+<a name="l00038"></a><a class="code" href="class_fdo_shp_class_definition_b9340be1c7d393ddedcf670de2149d76.html#b9340be1c7d393ddedcf670de2149d76">00038</a> <span class="keywordtype">bool</span> <a class="code" href="class_fdo_shp_class_definition_b9340be1c7d393ddedcf670de2149d76.html#b9340be1c7d393ddedcf670de2149d76">IsPathUpdated</a>(){ <span class="keywordflow">return</span> m_pathUpdated; }
+<a name="l00039"></a><a class="code" href="class_fdo_shp_class_definition_cb66f23743bb45b0e3faaa2bfafeaad8.html#cb66f23743bb45b0e3faaa2bfafeaad8">00039</a> <span class="keywordtype">void</span> <a class="code" href="class_fdo_shp_class_definition_cb66f23743bb45b0e3faaa2bfafeaad8.html#cb66f23743bb45b0e3faaa2bfafeaad8">SetPathUpdated</a>(<span class="keywordtype">bool</span> lPathUpdated = <span class="keyword">true</span>){ m_pathUpdated = lPathUpdated; }
+<a name="l00041"></a>00041 FDOSHP_API <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_shp_class_definition_daed9b86862ad2148b72edadbbcf479e.html#daed9b86862ad2148b72edadbbcf479e">InitFromXml</a>(GisXmlSaxContext* pContext, GisXmlAttributeCollection* attrs);
+<a name="l00042"></a>00042 FDOSHP_API <span class="keyword">virtual</span> GisXmlSaxHandler* <a class="code" href="class_fdo_shp_class_definition_95b2357abf02d1278ac66f01921db44b.html#95b2357abf02d1278ac66f01921db44b">XmlStartElement</a>(GisXmlSaxContext* context,GisString* uri, GisString* name, GisString* qname, GisXmlAttributeCollection* atts);
+<a name="l00043"></a>00043 FDOSHP_API <span class="keyword">virtual</span> GisBoolean <a class="code" href="class_fdo_shp_class_definition_1eb8e1be10f1d92361eacbbdc50a0677.html#1eb8e1be10f1d92361eacbbdc50a0677">XmlEndElement</a>(GisXmlSaxContext* context, GisString* uri, GisString* name, GisString* qname);
+<a name="l00044"></a>00044 FDOSHP_API <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_shp_class_definition_3d19e7886b05e4cfa5fb5371890ab97f.html#3d19e7886b05e4cfa5fb5371890ab97f">_writeXml</a>(GisXmlWriter* xmlWriter, <span class="keyword">const</span> FdoXmlFlags* flags);
+<a name="l00045"></a>00045 <span class="comment"></span>
+<a name="l00046"></a>00046 <span class="comment"> /// Helper method to find a property mapping by its column name:</span>
+<a name="l00047"></a>00047 <span class="comment"></span> FDOSHP_API <a class="code" href="class_fdo_shp_property_definition.html">FdoShpPropertyDefinition</a>* <a class="code" href="class_fdo_shp_class_definition_c3f943759f93d8173aacc9ce12c8feee.html#c3f943759f93d8173aacc9ce12c8feee">FindByColumnName</a>(GisString* columnName);
+<a name="l00048"></a>00048
+<a name="l00049"></a>00049 <span class="keyword">protected</span>:
+<a name="l00050"></a>00050 <a class="code" href="class_fdo_shp_class_definition.html">FdoShpClassDefinition</a>(<span class="keywordtype">void</span>);
+<a name="l00051"></a>00051 <span class="keyword">virtual</span> ~<a class="code" href="class_fdo_shp_class_definition.html">FdoShpClassDefinition</a>(<span class="keywordtype">void</span>);
+<a name="l00052"></a>00052 <span class="keyword">virtual</span> <span class="keywordtype">void</span> Dispose(<span class="keywordtype">void</span>);
+<a name="l00053"></a>00053
+<a name="l00054"></a>00054 <span class="keyword">private</span>:
+<a name="l00055"></a>00055 <span class="keywordtype">bool</span> m_pathUpdated;
+<a name="l00056"></a>00056 GisStringP m_ShapeFileLocation;
+<a name="l00057"></a>00057 <a class="code" href="_fdo_shp_property_definition_collection_8h_7d1d57dbcd029bc5b5d15fd32f2e165e.html#7d1d57dbcd029bc5b5d15fd32f2e165e">FdoShpPropertyDefinitionCollectionP</a> m_Properties;
+<a name="l00058"></a>00058 };
+<a name="l00059"></a>00059
+<a name="l00060"></a><a class="code" href="_fdo_shp_class_definition_8h_4e85e161f3a61d5a480c8d71c3bfd4ff.html#4e85e161f3a61d5a480c8d71c3bfd4ff">00060</a> <span class="keyword">typedef</span> GisPtr<FdoShpClassDefinition> <a class="code" href="_fdo_shp_class_definition_8h_4e85e161f3a61d5a480c8d71c3bfd4ff.html#4e85e161f3a61d5a480c8d71c3bfd4ff">FdoShpClassDefinitionP</a>;
+<a name="l00061"></a>00061
+<a name="l00062"></a>00062 <span class="preprocessor">#endif // FDOSHPCLASSDEFINITION_H</span>
+<a name="l00063"></a>00063 <span class="preprocessor"></span>
+<a name="l00064"></a>00064
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/_fdo_shp_class_definition_8h.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_class_definition_8h.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_class_definition_8h.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,77 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li id="current"><a href="files.html"><span>Files</span></a></li>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li><a href="files.html"><span>File List</span></a></li>
+ <li><a href="globals.html"><span>File Members</span></a></li>
+ </ul></div>
+<h1>FdoShpClassDefinition.h File Reference</h1>
+<p>
+<code>#include <<a class="el" href="_fdo_shp_property_definition_collection_8h-source.html">Shp/Override/FdoShpPropertyDefinitionCollection.h</a>></code><br>
+<p>
+Include dependency graph for FdoShpClassDefinition.h:<p><center><img src="_fdo_shp_class_definition_8h__incl.png" border="0" usemap="#FdoShpClassDefinition.h_map" alt=""></center>
+<map name="FdoShpClassDefinition.h_map">
+<area href="_fdo_shp_property_definition_collection_8h.html" shape="rect" coords="226,7,556,33" alt="">
+<area href="_fdo_shp_property_definition_8h.html" shape="rect" coords="606,7,875,33" alt="">
+</map>
+<p>
+This graph shows which files directly or indirectly include this file:<p><center><img src="_fdo_shp_class_definition_8h__dep__incl.png" border="0" usemap="#FdoShpClassDefinition.hdep_map" alt=""></center>
+<map name="FdoShpClassDefinition.hdep_map">
+<area href="_fdo_shp_class_collection_8h.html" shape="rect" coords="227,7,397,33" alt="">
+<area href="_fdo_shp_physical_schema_mapping_8h.html" shape="rect" coords="448,7,677,33" alt="">
+</map>
+<p>
+<a href="_fdo_shp_class_definition_8h-source.html">Go to the source code of this file.</a><table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">class </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_class_definition.html">FdoShpClassDefinition</a></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">typedef GisPtr< <a class="el" href="class_fdo_shp_class_definition.html">FdoShpClassDefinition</a> > </td><td class="memItemRight" valign="bottom"><a class="el" href="_fdo_shp_class_definition_8h_4e85e161f3a61d5a480c8d71c3bfd4ff.html#4e85e161f3a61d5a480c8d71c3bfd4ff">FdoShpClassDefinitionP</a></td></tr>
+</table>
+ <hr>
+ <tr>
+ <!-- The logo can go in another cell, when we get one -->
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/_fdo_shp_class_definition_8h_4e85e161f3a61d5a480c8d71c3bfd4ff.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_class_definition_8h_4e85e161f3a61d5a480c8d71c3bfd4ff.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_class_definition_8h_4e85e161f3a61d5a480c8d71c3bfd4ff.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,84 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="nav">
+<a class="el" href="_fdo_shp_class_definition_8h.html">FdoShpClassDefinition.h</a></div>
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="_fdo_shp_class_definition_8h_4e85e161f3a61d5a480c8d71c3bfd4ff.html#4e85e161f3a61d5a480c8d71c3bfd4ff">FdoShpClassDefinitionP</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="4e85e161f3a61d5a480c8d71c3bfd4ff"></a><!-- doxytag: member="FdoShpClassDefinition.h::FdoShpClassDefinitionP" ref="4e85e161f3a61d5a480c8d71c3bfd4ff" args="" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">typedef GisPtr<<a class="el" href="class_fdo_shp_class_definition.html">FdoShpClassDefinition</a>> <a class="el" href="_fdo_shp_class_definition_8h_4e85e161f3a61d5a480c8d71c3bfd4ff.html#4e85e161f3a61d5a480c8d71c3bfd4ff">FdoShpClassDefinitionP</a> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+<p>
+Definition at line <a class="el" href="_fdo_shp_class_definition_8h-source.html#l00060">60</a> of file <a class="el" href="_fdo_shp_class_definition_8h-source.html">FdoShpClassDefinition.h</a>. </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/_fdo_shp_class_definition_8h__dep__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_class_definition_8h__dep__incl.map?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_class_definition_8h__dep__incl.map 2006-03-06 21:40:50+0000
@@ -0,0 +1,3 @@
+base referer
+rect $_fdo_shp_class_collection_8h.html 227,7 397,33
+rect $_fdo_shp_physical_schema_mapping_8h.html 448,7 677,33
Added: trunk/www/docs/SHP/_fdo_shp_class_definition_8h__dep__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_class_definition_8h__dep__incl.md5?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_class_definition_8h__dep__incl.md5 2006-03-06 21:40:50+0000
@@ -0,0 +1 @@
+af4a285b1b0a1daec9f21667cf86f9a5
Added: trunk/www/docs/SHP/_fdo_shp_class_definition_8h__dep__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_class_definition_8h__dep__incl.png?view=auto&rev=4
Added: trunk/www/docs/SHP/_fdo_shp_class_definition_8h__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_class_definition_8h__incl.map?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_class_definition_8h__incl.map 2006-03-06 21:40:50+0000
@@ -0,0 +1,3 @@
+base referer
+rect $_fdo_shp_property_definition_collection_8h.html 226,7 556,33
+rect $_fdo_shp_property_definition_8h.html 606,7 875,33
Added: trunk/www/docs/SHP/_fdo_shp_class_definition_8h__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_class_definition_8h__incl.md5?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_class_definition_8h__incl.md5 2006-03-06 21:40:50+0000
@@ -0,0 +1 @@
+acd951e135bf72364cd9f2b675488569
Added: trunk/www/docs/SHP/_fdo_shp_class_definition_8h__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_class_definition_8h__incl.png?view=auto&rev=4
Added: trunk/www/docs/SHP/_fdo_shp_column_definition_8h-source.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_column_definition_8h-source.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_column_definition_8h-source.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,96 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>FdoShpColumnDefinition.h</h1><a href="_fdo_shp_column_definition_8h.html">Go to the documentation of this file.</a><div class="fragment"><pre class="fragment"><a name="l00001"></a>00001 <span class="comment">/*</span>
+<a name="l00017"></a>00017 <span class="preprocessor">#ifndef FDOSHPCOLUMNDEFINITION_H</span>
+<a name="l00018"></a>00018 <span class="preprocessor"></span><span class="preprocessor">#define FDOSHPCOLUMNDEFINITION_H</span>
+<a name="l00024"></a><a class="code" href="class_fdo_shp_column_definition.html">00024</a> <span class="keyword">class </span><a class="code" href="class_fdo_shp_column_definition.html">FdoShpColumnDefinition</a> : <span class="keyword">public</span> FdoPhysicalElementMapping
+<a name="l00025"></a>00025 {
+<a name="l00026"></a>00026 <span class="keyword">typedef</span> FdoPhysicalElementMapping BaseType;
+<a name="l00029"></a>00029 FDOSHP_API <span class="keyword">static</span> <a class="code" href="class_fdo_shp_column_definition.html">FdoShpColumnDefinition</a>* <a class="code" href="class_fdo_shp_column_definition_4ba0b1a32d4f0126a9a5079eab9fe025.html#4ba0b1a32d4f0126a9a5079eab9fe025">Create</a>();
+<a name="l00031"></a>00031 <span class="keyword">public</span>:
+<a name="l00032"></a>00032 FDOSHP_API <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_shp_column_definition_600ecd1991fa387cc926316543de81e8.html#600ecd1991fa387cc926316543de81e8">InitFromXml</a>(GisXmlSaxContext* pContext, GisXmlAttributeCollection* attrs);
+<a name="l00033"></a>00033 FDOSHP_API <span class="keyword">virtual</span> GisXmlSaxHandler* <a class="code" href="class_fdo_shp_column_definition_d5669958dfaeb362578fde7cac156561.html#d5669958dfaeb362578fde7cac156561">XmlStartElement</a>(GisXmlSaxContext* context,GisString* uri, GisString* name, GisString* qname, GisXmlAttributeCollection* atts);
+<a name="l00034"></a>00034 FDOSHP_API <span class="keyword">virtual</span> GisBoolean <a class="code" href="class_fdo_shp_column_definition_c9d77b68d5f4a385142690b92d0e7ef9.html#c9d77b68d5f4a385142690b92d0e7ef9">XmlEndElement</a>(GisXmlSaxContext* context, GisString* uri, GisString* name, GisString* qname);
+<a name="l00035"></a>00035 FDOSHP_API <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_shp_column_definition_955c02380b27a475d2f00ad14568a2ae.html#955c02380b27a475d2f00ad14568a2ae">_writeXml</a>(GisXmlWriter* xmlWriter, <span class="keyword">const</span> FdoXmlFlags* flags);
+<a name="l00037"></a>00037 <span class="keyword">protected</span>:
+<a name="l00038"></a>00038 <a class="code" href="class_fdo_shp_column_definition.html">FdoShpColumnDefinition</a>(<span class="keywordtype">void</span>);
+<a name="l00039"></a>00039 <span class="keyword">virtual</span> ~<a class="code" href="class_fdo_shp_column_definition.html">FdoShpColumnDefinition</a>(<span class="keywordtype">void</span>);
+<a name="l00040"></a>00040 <span class="keyword">virtual</span> <span class="keywordtype">void</span> Dispose(<span class="keywordtype">void</span>);
+<a name="l00041"></a>00041 };
+<a name="l00043"></a><a class="code" href="_fdo_shp_column_definition_8h_8542aa83f9163bd323db446eb4e1035d.html#8542aa83f9163bd323db446eb4e1035d">00043</a> <span class="keyword">typedef</span> GisPtr<FdoShpColumnDefinition> <a class="code" href="_fdo_shp_column_definition_8h_8542aa83f9163bd323db446eb4e1035d.html#8542aa83f9163bd323db446eb4e1035d">FdoShpColumnDefinitionP</a>;
+<a name="l00045"></a>00045 <span class="preprocessor">#endif // FDOSHPCOLUMNDEFINITION_H</span>
+<a name="l00046"></a>00046 <span class="preprocessor"></span>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/_fdo_shp_column_definition_8h.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_column_definition_8h.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_column_definition_8h.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,70 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>FdoShpColumnDefinition.h File Reference</h1>
+<p>
+<p>
+This graph shows which files directly or indirectly include this file:<p><center><img src="_fdo_shp_column_definition_8h__dep__incl.png" border="0" usemap="#FdoShpColumnDefinition.hdep_map" alt=""></center>
+<map name="FdoShpColumnDefinition.hdep_map">
+<area href="_fdo_shp_property_definition_8h.html" shape="rect" coords="239,7,426,33" alt="">
+<area href="_fdo_shp_property_definition_collection_8h.html" shape="rect" coords="475,7,720,33" alt="">
+<area href="_fdo_shp_class_definition_8h.html" shape="rect" coords="771,7,939,33" alt="">
+</map>
+<p>
+<a href="_fdo_shp_column_definition_8h-source.html">Go to the source code of this file.</a><table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">class </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_column_definition.html">FdoShpColumnDefinition</a></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">typedef GisPtr< <a class="el" href="class_fdo_shp_column_definition.html">FdoShpColumnDefinition</a> > </td><td class="memItemRight" valign="bottom"><a class="el" href="_fdo_shp_column_definition_8h_8542aa83f9163bd323db446eb4e1035d.html#8542aa83f9163bd323db446eb4e1035d">FdoShpColumnDefinitionP</a></td></tr>
+</table>
+<!-- footer.html -->
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/_fdo_shp_column_definition_8h_8542aa83f9163bd323db446eb4e1035d.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_column_definition_8h_8542aa83f9163bd323db446eb4e1035d.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_column_definition_8h_8542aa83f9163bd323db446eb4e1035d.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,84 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="nav">
+<a class="el" href="_fdo_shp_column_definition_8h.html">FdoShpColumnDefinition.h</a></div>
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="_fdo_shp_column_definition_8h_8542aa83f9163bd323db446eb4e1035d.html#8542aa83f9163bd323db446eb4e1035d">FdoShpColumnDefinitionP</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="8542aa83f9163bd323db446eb4e1035d"></a><!-- doxytag: member="FdoShpColumnDefinition.h::FdoShpColumnDefinitionP" ref="8542aa83f9163bd323db446eb4e1035d" args="" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">typedef GisPtr<<a class="el" href="class_fdo_shp_column_definition.html">FdoShpColumnDefinition</a>> <a class="el" href="_fdo_shp_column_definition_8h_8542aa83f9163bd323db446eb4e1035d.html#8542aa83f9163bd323db446eb4e1035d">FdoShpColumnDefinitionP</a> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+<p>
+Definition at line <a class="el" href="_fdo_shp_column_definition_8h-source.html#l00043">43</a> of file <a class="el" href="_fdo_shp_column_definition_8h-source.html">FdoShpColumnDefinition.h</a>. </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/_fdo_shp_column_definition_8h__dep__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_column_definition_8h__dep__incl.map?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_column_definition_8h__dep__incl.map 2006-03-06 21:40:50+0000
@@ -0,0 +1,4 @@
+base referer
+rect $_fdo_shp_property_definition_8h.html 239,7 426,33
+rect $_fdo_shp_property_definition_collection_8h.html 475,7 720,33
+rect $_fdo_shp_class_definition_8h.html 771,7 939,33
Added: trunk/www/docs/SHP/_fdo_shp_column_definition_8h__dep__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_column_definition_8h__dep__incl.md5?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_column_definition_8h__dep__incl.md5 2006-03-06 21:40:50+0000
@@ -0,0 +1 @@
+16125c21a449ab1bddc840e8909d43ad
Added: trunk/www/docs/SHP/_fdo_shp_column_definition_8h__dep__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_column_definition_8h__dep__incl.png?view=auto&rev=4
Added: trunk/www/docs/SHP/_fdo_shp_physical_schema_mapping_8h-source.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_physical_schema_mapping_8h-source.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_physical_schema_mapping_8h-source.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,109 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>FdoShpPhysicalSchemaMapping.h</h1><a href="_fdo_shp_physical_schema_mapping_8h.html">Go to the documentation of this file.</a><div class="fragment"><pre class="fragment"><a name="l00001"></a>00001 <span class="comment">/*</span>
+<a name="l00017"></a>00017 <span class="preprocessor">#ifndef FDOSHPPHYSICALSCHEMAMAPPING_H</span>
+<a name="l00018"></a>00018 <span class="preprocessor"></span><span class="preprocessor">#define FDOSHPPHYSICALSCHEMAMAPPING_H</span>
+<a name="l00024"></a>00024 <span class="preprocessor">#include <<a class="code" href="_fdo_shp_class_collection_8h.html">Shp/Override/FdoShpClassCollection.h</a>></span>
+<a name="l00026"></a><a class="code" href="class_fdo_shp_physical_schema_mapping.html">00026</a> <span class="keyword">class </span><a class="code" href="class_fdo_shp_physical_schema_mapping.html">FdoShpPhysicalSchemaMapping</a> : <span class="keyword">public</span> FdoPhysicalSchemaMapping
+<a name="l00028"></a>00028 <span class="keyword">typedef</span> FdoPhysicalSchemaMapping BaseType;
+<a name="l00031"></a>00031 FDOSHP_API <span class="keyword">static</span> <a class="code" href="class_fdo_shp_physical_schema_mapping.html">FdoShpPhysicalSchemaMapping</a>* <a class="code" href="class_fdo_shp_physical_schema_mapping_48e086264cd4780a442f8ecb841faea8.html#48e086264cd4780a442f8ecb841faea8">Create</a>();
+<a name="l00033"></a>00033 FDOSHP_API <span class="keyword">virtual</span> GisString* <a class="code" href="class_fdo_shp_physical_schema_mapping_45d51d0f0311ff85ed516136e2ce16f6.html#45d51d0f0311ff85ed516136e2ce16f6">GetProvider</a>();
+<a name="l00034"></a>00034 FDOSHP_API <a class="code" href="class_fdo_shp_class_collection.html">FdoShpClassCollection</a>* <a class="code" href="class_fdo_shp_physical_schema_mapping_4d944a128be1ad6406974f8375f12f69.html#4d944a128be1ad6406974f8375f12f69">GetClasses</a>() <span class="keyword">const</span>;
+<a name="l00036"></a>00036 FDOSHP_API <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_shp_physical_schema_mapping_852853e469120e86223be6db80bccb20.html#852853e469120e86223be6db80bccb20">InitFromXml</a>(GisXmlSaxContext* pContext, GisXmlAttributeCollection* attrs);
+<a name="l00037"></a>00037 FDOSHP_API <span class="keyword">virtual</span> GisXmlSaxHandler* <a class="code" href="class_fdo_shp_physical_schema_mapping_af942717804976ecf3233c259650fb48.html#af942717804976ecf3233c259650fb48">XmlStartElement</a>(GisXmlSaxContext* context,GisString* uri, GisString* name, GisString* qname, GisXmlAttributeCollection* atts);
+<a name="l00038"></a>00038 FDOSHP_API <span class="keyword">virtual</span> GisBoolean <a class="code" href="class_fdo_shp_physical_schema_mapping_7c0b1de21670db480e4463bcecfce94b.html#7c0b1de21670db480e4463bcecfce94b">XmlEndElement</a>(GisXmlSaxContext* context, GisString* uri, GisString* name, GisString* qname);
+<a name="l00039"></a>00039 FDOSHP_API <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_shp_physical_schema_mapping_36448c6a7557f454b949b605a6c80129.html#36448c6a7557f454b949b605a6c80129">_writeXml</a>(GisXmlWriter* xmlWriter, <span class="keyword">const</span> FdoXmlFlags* flags);
+<a name="l00040"></a>00040 <span class="comment"></span>
+<a name="l00041"></a>00041 <span class="comment"> /// Helper method to find a class mapping that maps to a given shapefile:</span>
+<a name="l00042"></a>00042 <span class="comment"></span> FDOSHP_API <a class="code" href="class_fdo_shp_class_definition.html">FdoShpClassDefinition</a>* <a class="code" href="class_fdo_shp_physical_schema_mapping_bb73c56d22638012ed655b6a276e75db.html#bb73c56d22638012ed655b6a276e75db">FindByShapefile</a>(GisString *shapefilePath);
+<a name="l00043"></a>00043 <span class="comment"></span>
+<a name="l00044"></a>00044 <span class="comment"> /// Helper method to find a class mapping that maps to a given classname:</span>
+<a name="l00045"></a>00045 <span class="comment"></span> FDOSHP_API <a class="code" href="class_fdo_shp_class_definition.html">FdoShpClassDefinition</a>* <a class="code" href="class_fdo_shp_physical_schema_mapping_cc639fa3a2ae6823d20042cc95f06dae.html#cc639fa3a2ae6823d20042cc95f06dae">FindByClassName</a>(GisString *class_name);
+<a name="l00047"></a>00047 <span class="keyword">protected</span>:
+<a name="l00048"></a>00048 <a class="code" href="class_fdo_shp_physical_schema_mapping.html">FdoShpPhysicalSchemaMapping</a>(<span class="keywordtype">void</span>);
+<a name="l00049"></a>00049 <span class="keyword">virtual</span> ~<a class="code" href="class_fdo_shp_physical_schema_mapping.html">FdoShpPhysicalSchemaMapping</a>(<span class="keywordtype">void</span>);
+<a name="l00050"></a>00050 <span class="keyword">virtual</span> <span class="keywordtype">void</span> Dispose(<span class="keywordtype">void</span>);
+<a name="l00052"></a>00052 <span class="keyword">private</span>:
+<a name="l00053"></a>00053 <a class="code" href="_fdo_shp_class_collection_8h_14b881fe200a848b2f39736eec0557f3.html#14b881fe200a848b2f39736eec0557f3">FdoShpClassCollectionP</a> m_Classes;
+<a name="l00054"></a>00054 };
+<a name="l00056"></a><a class="code" href="_fdo_shp_physical_schema_mapping_8h_a6ba1b4d1f4f7db9e0005451ac2cb3f5.html#a6ba1b4d1f4f7db9e0005451ac2cb3f5">00056</a> <span class="keyword">typedef</span> GisPtr<FdoShpPhysicalSchemaMapping> <a class="code" href="_fdo_shp_physical_schema_mapping_8h_a6ba1b4d1f4f7db9e0005451ac2cb3f5.html#a6ba1b4d1f4f7db9e0005451ac2cb3f5">FdoShpPhysicalSchemaMappingP</a>;
+<a name="l00058"></a>00058 <span class="preprocessor">#endif // FDOSHPPHYSICALSCHEMAMAPPING_H</span>
+<a name="l00059"></a>00059 <span class="preprocessor"></span>
+<a name="l00060"></a>00060
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/_fdo_shp_physical_schema_mapping_8h.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_physical_schema_mapping_8h.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_physical_schema_mapping_8h.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,70 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>FdoShpPhysicalSchemaMapping.h File Reference</h1>
+<p>
+<code>#include <<a class="el" href="_fdo_shp_class_collection_8h-source.html">Shp/Override/FdoShpClassCollection.h</a>></code><br>
+<p>
+Include dependency graph for FdoShpPhysicalSchemaMapping.h:<p><center><img src="_fdo_shp_physical_schema_mapping_8h__incl.png" border="0" usemap="#FdoShpPhysicalSchemaMapping.h_map" alt=""></center>
+<map name="FdoShpPhysicalSchemaMapping.h_map">
+<area href="_fdo_shp_class_collection_8h.html" shape="rect" coords="287,7,543,33" alt="">
+<area href="_fdo_shp_class_definition_8h.html" shape="rect" coords="591,7,844,33" alt="">
+</map>
+<p>
+<a href="_fdo_shp_physical_schema_mapping_8h-source.html">Go to the source code of this file.</a><table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">class </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_physical_schema_mapping.html">FdoShpPhysicalSchemaMapping</a></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">typedef GisPtr< <a class="el" href="class_fdo_shp_physical_schema_mapping.html">FdoShpPhysicalSchemaMapping</a> > </td><td class="memItemRight" valign="bottom"><a class="el" href="_fdo_shp_physical_schema_mapping_8h_a6ba1b4d1f4f7db9e0005451ac2cb3f5.html#a6ba1b4d1f4f7db9e0005451ac2cb3f5">FdoShpPhysicalSchemaMappingP</a></td></tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/_fdo_shp_physical_schema_mapping_8h__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_physical_schema_mapping_8h__incl.map?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_physical_schema_mapping_8h__incl.map 2006-03-06 21:40:50+0000
@@ -0,0 +1,3 @@
+base referer
+rect $_fdo_shp_class_collection_8h.html 287,7 543,33
+rect $_fdo_shp_class_definition_8h.html 591,7 844,33
Added: trunk/www/docs/SHP/_fdo_shp_physical_schema_mapping_8h__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_physical_schema_mapping_8h__incl.md5?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_physical_schema_mapping_8h__incl.md5 2006-03-06 21:40:50+0000
@@ -0,0 +1 @@
+974f83da7ca9885cdafce0b479ec5917
Added: trunk/www/docs/SHP/_fdo_shp_physical_schema_mapping_8h__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_physical_schema_mapping_8h__incl.png?view=auto&rev=4
Binary file. No diff available.
Added: trunk/www/docs/SHP/_fdo_shp_physical_schema_mapping_8h_a6ba1b4d1f4f7db9e0005451ac2cb3f5.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_physical_schema_mapping_8h_a6ba1b4d1f4f7db9e0005451ac2cb3f5.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_physical_schema_mapping_8h_a6ba1b4d1f4f7db9e0005451ac2cb3f5.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,84 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li><a href="files.html"><span>Files</span></a></li>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="nav">
+<a class="el" href="_fdo_shp_physical_schema_mapping_8h.html">FdoShpPhysicalSchemaMapping.h</a></div>
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="_fdo_shp_physical_schema_mapping_8h_a6ba1b4d1f4f7db9e0005451ac2cb3f5.html#a6ba1b4d1f4f7db9e0005451ac2cb3f5">FdoShpPhysicalSchemaMappingP</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="a6ba1b4d1f4f7db9e0005451ac2cb3f5"></a><!-- doxytag: member="FdoShpPhysicalSchemaMapping.h::FdoShpPhysicalSchemaMappingP" ref="a6ba1b4d1f4f7db9e0005451ac2cb3f5" args="" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">typedef GisPtr<<a class="el" href="class_fdo_shp_physical_schema_mapping.html">FdoShpPhysicalSchemaMapping</a>> <a class="el" href="_fdo_shp_physical_schema_mapping_8h_a6ba1b4d1f4f7db9e0005451ac2cb3f5.html#a6ba1b4d1f4f7db9e0005451ac2cb3f5">FdoShpPhysicalSchemaMappingP</a> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+<p>
+Definition at line <a class="el" href="_fdo_shp_physical_schema_mapping_8h-source.html#l00056">56</a> of file <a class="el" href="_fdo_shp_physical_schema_mapping_8h-source.html">FdoShpPhysicalSchemaMapping.h</a>. </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/_fdo_shp_property_definition_8h-source.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_property_definition_8h-source.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_property_definition_8h-source.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,104 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>FdoShpPropertyDefinition.h</h1><a href="_fdo_shp_property_definition_8h.html">Go to the documentation of this file.</a><div class="fragment"><pre class="fragment"><a name="l00001"></a>00001 <span class="comment">/*</span>
+<a name="l00017"></a>00017 <span class="preprocessor">#ifndef FDOSHPPROPERTYDEFINITION_H</span>
+<a name="l00018"></a>00018 <span class="preprocessor"></span><span class="preprocessor">#define FDOSHPPROPERTYDEFINITION_H</span>
+<a name="l00024"></a>00024 <span class="preprocessor">#include <<a class="code" href="_fdo_shp_column_definition_8h.html">Shp/Override/FdoShpColumnDefinition.h</a>></span>
+<a name="l00026"></a><a class="code" href="class_fdo_shp_property_definition.html">00026</a> <span class="keyword">class </span><a class="code" href="class_fdo_shp_property_definition.html">FdoShpPropertyDefinition</a> : <span class="keyword">public</span> FdoPhysicalPropertyMapping
+<a name="l00028"></a>00028 <span class="keyword">typedef</span> FdoPhysicalElementMapping BaseType;
+<a name="l00031"></a>00031 FDOSHP_API <span class="keyword">static</span> <a class="code" href="class_fdo_shp_property_definition.html">FdoShpPropertyDefinition</a>* <a class="code" href="class_fdo_shp_property_definition_a603b74205bc257c10b7bc068f516292.html#a603b74205bc257c10b7bc068f516292">Create</a>();
+<a name="l00034"></a>00034 FDOSHP_API <a class="code" href="class_fdo_shp_column_definition.html">FdoShpColumnDefinition</a>* <a class="code" href="class_fdo_shp_property_definition_20d2033a8034eaed4bfef6d0e3eabaab.html#20d2033a8034eaed4bfef6d0e3eabaab">GetColumn</a>() <span class="keyword">const</span>;
+<a name="l00035"></a>00035 FDOSHP_API <span class="keywordtype">void</span> <a class="code" href="class_fdo_shp_property_definition_9f411822896503e8e305bcd5baa501c3.html#9f411822896503e8e305bcd5baa501c3">SetColumn</a>(<a class="code" href="class_fdo_shp_column_definition.html">FdoShpColumnDefinition</a> * definition);
+<a name="l00037"></a>00037 FDOSHP_API <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_shp_property_definition_e2292de181258077b5faa7c1a62c80eb.html#e2292de181258077b5faa7c1a62c80eb">InitFromXml</a>(GisXmlSaxContext* pContext, GisXmlAttributeCollection* attrs);
+<a name="l00038"></a>00038 FDOSHP_API <span class="keyword">virtual</span> GisXmlSaxHandler* <a class="code" href="class_fdo_shp_property_definition_3530f2250ead9a4f2589dfcf013b23b4.html#3530f2250ead9a4f2589dfcf013b23b4">XmlStartElement</a>(GisXmlSaxContext* context,GisString* uri, GisString* name, GisString* qname, GisXmlAttributeCollection* atts);
+<a name="l00039"></a>00039 FDOSHP_API <span class="keyword">virtual</span> GisBoolean <a class="code" href="class_fdo_shp_property_definition_2961dfcc8cb657ce57689f56c9764fec.html#2961dfcc8cb657ce57689f56c9764fec">XmlEndElement</a>(GisXmlSaxContext* context, GisString* uri, GisString* name, GisString* qname);
+<a name="l00040"></a>00040 FDOSHP_API <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_shp_property_definition_ca026498f207e7542714e2094301f456.html#ca026498f207e7542714e2094301f456">_writeXml</a>( GisXmlWriter* xmlWriter, <span class="keyword">const</span> FdoXmlFlags* flags );
+<a name="l00042"></a>00042 <span class="keyword">protected</span>:
+<a name="l00043"></a>00043 <a class="code" href="class_fdo_shp_property_definition.html">FdoShpPropertyDefinition</a>(<span class="keywordtype">void</span>);
+<a name="l00044"></a>00044 <span class="keyword">virtual</span> ~<a class="code" href="class_fdo_shp_property_definition.html">FdoShpPropertyDefinition</a>(<span class="keywordtype">void</span>);
+<a name="l00045"></a>00045 <span class="keyword">virtual</span> <span class="keywordtype">void</span> Dispose(<span class="keywordtype">void</span>);
+<a name="l00047"></a>00047 <span class="keyword">private</span>:
+<a name="l00048"></a>00048 <a class="code" href="_fdo_shp_column_definition_8h_8542aa83f9163bd323db446eb4e1035d.html#8542aa83f9163bd323db446eb4e1035d">FdoShpColumnDefinitionP</a> m_ColumnDefinition;
+<a name="l00049"></a>00049 };
+<a name="l00051"></a><a class="code" href="_fdo_shp_property_definition_8h_d0b59a42138824423a735f567bc1a47c.html#d0b59a42138824423a735f567bc1a47c">00051</a> <span class="keyword">typedef</span> GisPtr<FdoShpPropertyDefinition> <a class="code" href="_fdo_shp_property_definition_8h_d0b59a42138824423a735f567bc1a47c.html#d0b59a42138824423a735f567bc1a47c">FdoShpPropertyDefinitionP</a>;
+<a name="l00053"></a>00053 <span class="preprocessor">#endif // FDOSHPPROPERTYDEFINITION_H</span>
+<a name="l00054"></a>00054 <span class="preprocessor"></span>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/_fdo_shp_property_definition_8h.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_property_definition_8h.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_property_definition_8h.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,77 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>FdoShpPropertyDefinition.h File Reference</h1>
+<p>
+<code>#include <<a class="el" href="_fdo_shp_column_definition_8h-source.html">Shp/Override/FdoShpColumnDefinition.h</a>></code><br>
+<p>
+Include dependency graph for FdoShpPropertyDefinition.h:<p><center><img src="_fdo_shp_property_definition_8h__incl.png" border="0" usemap="#FdoShpPropertyDefinition.h_map" alt=""></center>
+<map name="FdoShpPropertyDefinition.h_map">
+<area href="_fdo_shp_column_definition_8h.html" shape="rect" coords="242,7,508,33" alt="">
+</map>
+<p>
+This graph shows which files directly or indirectly include this file:<p><center><img src="_fdo_shp_property_definition_8h__dep__incl.png" border="0" usemap="#FdoShpPropertyDefinition.hdep_map" alt=""></center>
+<map name="FdoShpPropertyDefinition.hdep_map">
+<area href="_fdo_shp_property_definition_collection_8h.html" shape="rect" coords="243,7,488,33" alt="">
+<area href="_fdo_shp_class_definition_8h.html" shape="rect" coords="539,7,707,33" alt="">
+<area href="_fdo_shp_class_collection_8h.html" shape="rect" coords="757,7,928,33" alt="">
+</map>
+<p>
+<a href="_fdo_shp_property_definition_8h-source.html">Go to the source code of this file.</a><table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">class </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_property_definition.html">FdoShpPropertyDefinition</a></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">typedef GisPtr< <a class="el" href="class_fdo_shp_property_definition.html">FdoShpPropertyDefinition</a> > </td><td class="memItemRight" valign="bottom"><a class="el" href="_fdo_shp_property_definition_8h_d0b59a42138824423a735f567bc1a47c.html#d0b59a42138824423a735f567bc1a47c">FdoShpPropertyDefinitionP</a></td></tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/_fdo_shp_property_definition_8h__dep__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_property_definition_8h__dep__incl.map?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_property_definition_8h__dep__incl.map 2006-03-06 21:40:50+0000
@@ -0,0 +1,4 @@
+base referer
+rect $_fdo_shp_property_definition_collection_8h.html 243,7 488,33
+rect $_fdo_shp_class_definition_8h.html 539,7 707,33
+rect $_fdo_shp_class_collection_8h.html 757,7 928,33
Added: trunk/www/docs/SHP/_fdo_shp_property_definition_8h__dep__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_property_definition_8h__dep__incl.md5?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_property_definition_8h__dep__incl.md5 2006-03-06 21:40:50+0000
@@ -0,0 +1 @@
+ebcf332c05fe4118e582c07ae4e57895
\ No newline at end of file
Added: trunk/www/docs/SHP/_fdo_shp_property_definition_8h__dep__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_property_definition_8h__dep__incl.png?view=auto&rev=4
Added: trunk/www/docs/SHP/_fdo_shp_property_definition_8h__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_property_definition_8h__incl.map?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_property_definition_8h__incl.map 2006-03-06 21:40:50+0000
@@ -0,0 +1,2 @@
+base referer
+rect $_fdo_shp_column_definition_8h.html 242,7 508,33
Added: trunk/www/docs/SHP/_fdo_shp_property_definition_8h__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_property_definition_8h__incl.md5?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_property_definition_8h__incl.md5 2006-03-06 21:40:50+0000
@@ -0,0 +1 @@
+a7ccf90776ada5182191ef7db80b3bf9
Added: trunk/www/docs/SHP/_fdo_shp_property_definition_8h__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_property_definition_8h__incl.png?view=auto&rev=4
Added: trunk/www/docs/SHP/_fdo_shp_property_definition_8h_d0b59a42138824423a735f567bc1a47c.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_property_definition_8h_d0b59a42138824423a735f567bc1a47c.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_property_definition_8h_d0b59a42138824423a735f567bc1a47c.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,84 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="nav">
+<a class="el" href="_fdo_shp_property_definition_8h.html">FdoShpPropertyDefinition.h</a></div>
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="_fdo_shp_property_definition_8h_d0b59a42138824423a735f567bc1a47c.html#d0b59a42138824423a735f567bc1a47c">FdoShpPropertyDefinitionP</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="d0b59a42138824423a735f567bc1a47c"></a><!-- doxytag: member="FdoShpPropertyDefinition.h::FdoShpPropertyDefinitionP" ref="d0b59a42138824423a735f567bc1a47c" args="" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">typedef GisPtr<<a class="el" href="class_fdo_shp_property_definition.html">FdoShpPropertyDefinition</a>> <a class="el" href="_fdo_shp_property_definition_8h_d0b59a42138824423a735f567bc1a47c.html#d0b59a42138824423a735f567bc1a47c">FdoShpPropertyDefinitionP</a> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+<p>
+Definition at line <a class="el" href="_fdo_shp_property_definition_8h-source.html#l00051">51</a> of file <a class="el" href="_fdo_shp_property_definition_8h-source.html">FdoShpPropertyDefinition.h</a>. </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h-source.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h-source.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h-source.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,93 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>FdoShpPropertyDefinitionCollection.h</h1><a href="_fdo_shp_property_definition_collection_8h.html">Go to the documentation of this file.</a><div class="fragment"><pre class="fragment"><a name="l00001"></a>00001 <span class="comment">/*</span>
+<a name="l00017"></a>00017 <span class="preprocessor">#ifndef FDOSHPPROPERTYDEFINITIONCOLLECTION_H</span>
+<a name="l00018"></a>00018 <span class="preprocessor"></span><span class="preprocessor">#define FDOSHPPROPERTYDEFINITIONCOLLECTION_H</span>
+<a name="l00024"></a>00024 <span class="preprocessor">#include <<a class="code" href="_fdo_shp_property_definition_8h.html">Shp/Override/FdoShpPropertyDefinition.h</a>></span>
+<a name="l00026"></a><a class="code" href="class_fdo_shp_property_definition_collection.html">00026</a> <span class="keyword">class </span><a class="code" href="class_fdo_shp_property_definition_collection.html">FdoShpPropertyDefinitionCollection</a> : <span class="keyword">public</span> FdoPhysicalElementMappingCollection<FdoShpPropertyDefinition>
+<a name="l00029"></a>00029 FDOSHP_API <span class="keyword">static</span> <a class="code" href="class_fdo_shp_property_definition_collection.html">FdoShpPropertyDefinitionCollection</a>* <a class="code" href="class_fdo_shp_property_definition_collection_6b3823628fb7e5e0833d9110c5128d07.html#6b3823628fb7e5e0833d9110c5128d07">Create</a>();
+<a name="l00030"></a>00030 FDOSHP_API <span class="keyword">static</span> <a class="code" href="class_fdo_shp_property_definition_collection.html">FdoShpPropertyDefinitionCollection</a>* <a class="code" href="class_fdo_shp_property_definition_collection_6b3823628fb7e5e0833d9110c5128d07.html#6b3823628fb7e5e0833d9110c5128d07">Create</a>(FdoPhysicalElementMapping *parent);
+<a name="l00033"></a>00033 <a class="code" href="class_fdo_shp_property_definition_collection.html">FdoShpPropertyDefinitionCollection</a>();
+<a name="l00034"></a>00034 <a class="code" href="class_fdo_shp_property_definition_collection.html">FdoShpPropertyDefinitionCollection</a>(FdoPhysicalElementMapping *parent);
+<a name="l00035"></a>00035 <span class="keyword">virtual</span> ~<a class="code" href="class_fdo_shp_property_definition_collection.html">FdoShpPropertyDefinitionCollection</a>(<span class="keywordtype">void</span>);
+<a name="l00039"></a><a class="code" href="_fdo_shp_property_definition_collection_8h_7d1d57dbcd029bc5b5d15fd32f2e165e.html#7d1d57dbcd029bc5b5d15fd32f2e165e">00039</a> <span class="keyword">typedef</span> GisPtr<FdoShpPropertyDefinitionCollection> <a class="code" href="_fdo_shp_property_definition_collection_8h_7d1d57dbcd029bc5b5d15fd32f2e165e.html#7d1d57dbcd029bc5b5d15fd32f2e165e">FdoShpPropertyDefinitionCollectionP</a>;
+<a name="l00042"></a>00042 <span class="preprocessor">#endif // FDOSHPPROPERTYDEFINITIONCOLLECTION_H</span>
+<a name="l00043"></a>00043 <span class="preprocessor"></span>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,78 @@
+<html>
+ <head>
+ <title>OSGeo FDO Provider for SHP API Reference</title>
+ </head>
+ <tr>
+ <td align="right"><b>OSGeo FDO Provider for SHP<b></td>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li>
+ <form action="search.php" method="get">
+ <table cellspacing="0" cellpadding="0" border="0">
+ <tr>
+ <td><label> <u>S</u>earch for </label></td>
+ <td><input type="text" name="query" value="" size="20" accesskey="s"/></td>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>FdoShpPropertyDefinitionCollection.h File Reference</h1>
+<p>
+<code>#include <<a class="el" href="_fdo_shp_property_definition_8h-source.html">Shp/Override/FdoShpPropertyDefinition.h</a>></code><br>
+<p>
+Include dependency graph for FdoShpPropertyDefinitionCollection.h:<p><center><img src="_fdo_shp_property_definition_collection_8h__incl.png" border="0" usemap="#FdoShpPropertyDefinitionCollection.h_map" alt=""></center>
+<map name="FdoShpPropertyDefinitionCollection.h_map">
+<area href="_fdo_shp_property_definition_8h.html" shape="rect" coords="304,7,573,33" alt="">
+<area href="_fdo_shp_column_definition_8h.html" shape="rect" coords="623,7,889,33" alt="">
+</map>
+<p>
+This graph shows which files directly or indirectly include this file:<p><center><img src="_fdo_shp_property_definition_collection_8h__dep__incl.png" border="0" usemap="#FdoShpPropertyDefinitionCollection.hdep_map" alt=""></center>
+<map name="FdoShpPropertyDefinitionCollection.hdep_map">
+<area href="_fdo_shp_class_definition_8h.html" shape="rect" coords="304,7,472,33" alt="">
+<area href="_fdo_shp_class_collection_8h.html" shape="rect" coords="523,7,693,33" alt="">
+<area href="_fdo_shp_physical_schema_mapping_8h.html" shape="rect" coords="744,7,973,33" alt="">
+</map>
+<p>
+<a href="_fdo_shp_property_definition_collection_8h-source.html">Go to the source code of this file.</a><table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">class </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_property_definition_collection.html">FdoShpPropertyDefinitionCollection</a></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">typedef GisPtr< <a class="el" href="class_fdo_shp_property_definition_collection.html">FdoShpPropertyDefinitionCollection</a> > </td><td class="memItemRight" valign="bottom"><a class="el" href="_fdo_shp_property_definition_collection_8h_7d1d57dbcd029bc5b5d15fd32f2e165e.html#7d1d57dbcd029bc5b5d15fd32f2e165e">FdoShpPropertyDefinitionCollectionP</a></td></tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h_7d1d57dbcd029bc5b5d15fd32f2e165e.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h_7d1d57dbcd029bc5b5d15fd32f2e165e.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h_7d1d57dbcd029bc5b5d15fd32f2e165e.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,84 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="nav">
+<a class="el" href="_fdo_shp_property_definition_collection_8h.html">FdoShpPropertyDefinitionCollection.h</a></div>
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="_fdo_shp_property_definition_collection_8h_7d1d57dbcd029bc5b5d15fd32f2e165e.html#7d1d57dbcd029bc5b5d15fd32f2e165e">FdoShpPropertyDefinitionCollectionP</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="7d1d57dbcd029bc5b5d15fd32f2e165e"></a><!-- doxytag: member="FdoShpPropertyDefinitionCollection.h::FdoShpPropertyDefinitionCollectionP" ref="7d1d57dbcd029bc5b5d15fd32f2e165e" args="" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">typedef GisPtr<<a class="el" href="class_fdo_shp_property_definition_collection.html">FdoShpPropertyDefinitionCollection</a>> <a class="el" href="_fdo_shp_property_definition_collection_8h_7d1d57dbcd029bc5b5d15fd32f2e165e.html#7d1d57dbcd029bc5b5d15fd32f2e165e">FdoShpPropertyDefinitionCollectionP</a> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+<p>
+Definition at line <a class="el" href="_fdo_shp_property_definition_collection_8h-source.html#l00039">39</a> of file <a class="el" href="_fdo_shp_property_definition_collection_8h-source.html">FdoShpPropertyDefinitionCollection.h</a>. </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <table width="100%" border="0">
+ <tr>
+ <td align="right"><font size="-2"><a href="mailto:isd.docs at autodesk.com&subject=FDO%20Provider%20for%20SHP%20API%20documentation">Comments?</a></font></td>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h__dep__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h__dep__incl.map?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h__dep__incl.map 2006-03-06 21:40:50+0000
@@ -0,0 +1,4 @@
+base referer
+rect $_fdo_shp_class_definition_8h.html 304,7 472,33
+rect $_fdo_shp_class_collection_8h.html 523,7 693,33
+rect $_fdo_shp_physical_schema_mapping_8h.html 744,7 973,33
Added: trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h__dep__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h__dep__incl.md5?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h__dep__incl.md5 2006-03-06 21:40:50+0000
@@ -0,0 +1 @@
+a671c1831a66264d3e8f98f4c2ecfb91
Added: trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h__dep__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h__dep__incl.png?view=auto&rev=4
Added: trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h__incl.map?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h__incl.map 2006-03-06 21:40:50+0000
@@ -0,0 +1,3 @@
+base referer
+rect $_fdo_shp_property_definition_8h.html 304,7 573,33
+rect $_fdo_shp_column_definition_8h.html 623,7 889,33
Added: trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h__incl.md5?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h__incl.md5 2006-03-06 21:40:50+0000
@@ -0,0 +1 @@
+ffb4fa6bb92e9a4eafd8d276daf3a0bc
Added: trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h__incl.png?view=auto&rev=4
Added: trunk/www/docs/SHP/annotated.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/annotated.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/annotated.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,59 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
+<html>
+ <head>
+ <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
+ <link href="custom.css" rel="stylesheet" type="text/css">
+ <link href="tabs.css" rel="stylesheet" type="text/css">
+ </head>
+ <body bgcolor="#FFFFFF">
+ <tr>
+ <td><b>API Reference<b></td>
+ </tr>
+ </table>
+<!-- End of: header.html -->
+<!-- Generated by Doxygen 1.4.6-NO -->
+<div class="tabs">
+ <ul>
+ <li><a href="main.html"><span>Main Page</span></a></li>
+ <li id="current"><a href="classes.html"><span>Classes</span></a></li>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li><a href="classes.html"><span>Alphabetical List</span></a></li>
+ <li id="current"><a href="annotated.html"><span>Class List</span></a></li>
+ <li><a href="hierarchy.html"><span>Class Hierarchy</span></a></li>
+ <li><a href="functions.html"><span>Class Members</span></a></li>
+ </ul></div>
+<h1>FDO Provider for SHP Class List</h1>Here are the classes, structs, unions and interfaces with brief descriptions:<table>
+ <tr><td class="indexkey"><a class="el" href="class_fdo_shp_class_collection.html">FdoShpClassCollection</a></td><td class="indexvalue"></td></tr>
+ <tr><td class="indexkey"><a class="el" href="class_fdo_shp_class_definition.html">FdoShpClassDefinition</a></td><td class="indexvalue"></td></tr>
+ <tr><td class="indexkey"><a class="el" href="class_fdo_shp_column_definition.html">FdoShpColumnDefinition</a></td><td class="indexvalue"></td></tr>
+ <tr><td class="indexkey"><a class="el" href="class_fdo_shp_physical_schema_mapping.html">FdoShpPhysicalSchemaMapping</a></td><td class="indexvalue"></td></tr>
+ <tr><td class="indexkey"><a class="el" href="class_fdo_shp_property_definition.html">FdoShpPropertyDefinition</a></td><td class="indexvalue"></td></tr>
+ <tr><td class="indexkey"><a class="el" href="class_fdo_shp_property_definition_collection.html">FdoShpPropertyDefinitionCollection</a></td><td class="indexvalue"></td></tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_class_collection-members.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_class_collection-members.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_class_collection-members.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,54 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li><a href="annotated.html"><span>Class List</span></a></li>
+ </ul></div>
+<h1>FdoShpClassCollection Member List</h1>This is the complete list of members for <a class="el" href="class_fdo_shp_class_collection.html">FdoShpClassCollection</a>, including all inherited members.<p><table>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_class_collection_8ac302ce67fca3f9558ff5c647cfcff9.html#8ac302ce67fca3f9558ff5c647cfcff9">Create</a>()</td><td><a class="el" href="class_fdo_shp_class_collection.html">FdoShpClassCollection</a></td><td><code> [static]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_class_collection_523f8784b5a62bfd9a00ffb621bac528.html#523f8784b5a62bfd9a00ffb621bac528">Create</a>(FdoPhysicalElementMapping *parent)</td><td><a class="el" href="class_fdo_shp_class_collection.html">FdoShpClassCollection</a></td><td><code> [static]</code></td></tr>
+</table><!-- footer.html -->
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_class_collection.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_class_collection.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_class_collection.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,68 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>FdoShpClassCollection Class Reference</h1><!-- doxytag: class="FdoShpClassCollection" --><code>#include <<a class="el" href="_fdo_shp_class_collection_8h-source.html">FdoShpClassCollection.h</a>></code>
+<p>
+<a href="class_fdo_shp_class_collection-members.html">List of all members.</a><hr><a name="_details"></a><h2>Detailed Description</h2>
+<p>
+<p>
+Definition at line <a class="el" href="_fdo_shp_class_collection_8h-source.html#l00026">26</a> of file <a class="el" href="_fdo_shp_class_collection_8h-source.html">FdoShpClassCollection.h</a>.<table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td colspan="2"><br><h2>Static Public Member Functions</h2></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">static FDOSHP_API <a class="el" href="class_fdo_shp_class_collection.html">FdoShpClassCollection</a> * </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_class_collection_523f8784b5a62bfd9a00ffb621bac528.html#523f8784b5a62bfd9a00ffb621bac528">Create</a> (FdoPhysicalElementMapping *parent)</td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">static FDOSHP_API <a class="el" href="class_fdo_shp_class_collection.html">FdoShpClassCollection</a> * </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_class_collection_8ac302ce67fca3f9558ff5c647cfcff9.html#8ac302ce67fca3f9558ff5c647cfcff9">Create</a> ()</td></tr>
+</table>
+<hr>The documentation for this class was generated from the following file:<ul>
+<li><a class="el" href="_fdo_shp_class_collection_8h-source.html">FdoShpClassCollection.h</a></ul>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_class_collection_523f8784b5a62bfd9a00ffb621bac528.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_class_collection_523f8784b5a62bfd9a00ffb621bac528.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_class_collection_523f8784b5a62bfd9a00ffb621bac528.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,88 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li><a href="classes.html"><span>Classes</span></a></li>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="nav">
+<a class="el" href="class_fdo_shp_class_collection.html">FdoShpClassCollection</a></div>
+<table cellspacing="0" cellpadding="0" border="0">
+ <tr>
+ <td valign="top">
+ <div class="navtab">
+ <table>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_class_collection_8ac302ce67fca3f9558ff5c647cfcff9.html#8ac302ce67fca3f9558ff5c647cfcff9">Create</a></td></tr>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_class_collection_523f8784b5a62bfd9a00ffb621bac528.html#523f8784b5a62bfd9a00ffb621bac528">Create</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="523f8784b5a62bfd9a00ffb621bac528"></a><!-- doxytag: member="FdoShpClassCollection::Create" ref="523f8784b5a62bfd9a00ffb621bac528" args="(FdoPhysicalElementMapping *parent)" --><p>
+<table class="mdTable" cellpadding="2" cellspacing="0">
+ <tr>
+ <td class="mdRow">
+ <table cellpadding="0" cellspacing="0" border="0">
+ <tr>
+ <td class="md" nowrap valign="top">static FDOSHP_API <a class="el" href="class_fdo_shp_class_collection.html">FdoShpClassCollection</a>* FdoShpClassCollection::Create </td>
+ <td class="md" valign="top">( </td>
+ <td class="md" nowrap valign="top">FdoPhysicalElementMapping * </td>
+ <td class="mdname1" valign="top" nowrap> <em>parent</em> </td>
+ <td class="md" valign="top"> ) </td>
+ <td class="md" nowrap><code> [static]</code></td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+<table cellspacing="5" cellpadding="0" border="0">
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_class_collection_8ac302ce67fca3f9558ff5c647cfcff9.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_class_collection_8ac302ce67fca3f9558ff5c647cfcff9.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_class_collection_8ac302ce67fca3f9558ff5c647cfcff9.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,87 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_class_collection_8ac302ce67fca3f9558ff5c647cfcff9.html#8ac302ce67fca3f9558ff5c647cfcff9">Create</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_class_collection_523f8784b5a62bfd9a00ffb621bac528.html#523f8784b5a62bfd9a00ffb621bac528">Create</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="8ac302ce67fca3f9558ff5c647cfcff9"></a><!-- doxytag: member="FdoShpClassCollection::Create" ref="8ac302ce67fca3f9558ff5c647cfcff9" args="()" --><p>
+ <tr>
+ <tr>
+ <td class="mdname1" valign="top" nowrap> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_class_definition-members.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_class_definition-members.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_class_definition-members.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,63 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>FdoShpClassDefinition Member List</h1>This is the complete list of members for <a class="el" href="class_fdo_shp_class_definition.html">FdoShpClassDefinition</a>, including all inherited members.<p><table>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_class_definition_3d19e7886b05e4cfa5fb5371890ab97f.html#3d19e7886b05e4cfa5fb5371890ab97f">_writeXml</a>(GisXmlWriter *xmlWriter, const FdoXmlFlags *flags)</td><td><a class="el" href="class_fdo_shp_class_definition.html">FdoShpClassDefinition</a></td><td><code> [virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_class_definition_96936568a01aa49e3ef3fbb154fa5ad5.html#96936568a01aa49e3ef3fbb154fa5ad5">Create</a>()</td><td><a class="el" href="class_fdo_shp_class_definition.html">FdoShpClassDefinition</a></td><td><code> [static]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_class_definition_c3f943759f93d8173aacc9ce12c8feee.html#c3f943759f93d8173aacc9ce12c8feee">FindByColumnName</a>(GisString *columnName)</td><td><a class="el" href="class_fdo_shp_class_definition.html">FdoShpClassDefinition</a></td><td></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_class_definition_bdc54fa302f857e4acc9a0c3660dd245.html#bdc54fa302f857e4acc9a0c3660dd245">GetProperties</a>() const </td><td><a class="el" href="class_fdo_shp_class_definition.html">FdoShpClassDefinition</a></td><td></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_class_definition_4603016faf3795e4c4544f71e0fb4152.html#4603016faf3795e4c4544f71e0fb4152">GetShapeFile</a>() const </td><td><a class="el" href="class_fdo_shp_class_definition.html">FdoShpClassDefinition</a></td><td></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_class_definition_daed9b86862ad2148b72edadbbcf479e.html#daed9b86862ad2148b72edadbbcf479e">InitFromXml</a>(GisXmlSaxContext *pContext, GisXmlAttributeCollection *attrs)</td><td><a class="el" href="class_fdo_shp_class_definition.html">FdoShpClassDefinition</a></td><td><code> [virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_class_definition_b9340be1c7d393ddedcf670de2149d76.html#b9340be1c7d393ddedcf670de2149d76">IsPathUpdated</a>()</td><td><a class="el" href="class_fdo_shp_class_definition.html">FdoShpClassDefinition</a></td><td><code> [inline]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_class_definition_cb66f23743bb45b0e3faaa2bfafeaad8.html#cb66f23743bb45b0e3faaa2bfafeaad8">SetPathUpdated</a>(bool lPathUpdated=true)</td><td><a class="el" href="class_fdo_shp_class_definition.html">FdoShpClassDefinition</a></td><td><code> [inline]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_class_definition_2e617c437f74fe496aac753fb7666146.html#2e617c437f74fe496aac753fb7666146">SetShapeFile</a>(GisString *location)</td><td><a class="el" href="class_fdo_shp_class_definition.html">FdoShpClassDefinition</a></td><td></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_class_definition_1eb8e1be10f1d92361eacbbdc50a0677.html#1eb8e1be10f1d92361eacbbdc50a0677">XmlEndElement</a>(GisXmlSaxContext *context, GisString *uri, GisString *name, GisString *qname)</td><td><a class="el" href="class_fdo_shp_class_definition.html">FdoShpClassDefinition</a></td><td><code> [virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_class_definition_95b2357abf02d1278ac66f01921db44b.html#95b2357abf02d1278ac66f01921db44b">XmlStartElement</a>(GisXmlSaxContext *context, GisString *uri, GisString *name, GisString *qname, GisXmlAttributeCollection *atts)</td><td><a class="el" href="class_fdo_shp_class_definition.html">FdoShpClassDefinition</a></td><td><code> [virtual]</code></td></tr>
+ <hr>
+ <tr>
+ <!-- The logo can go in another cell, when we get one -->
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_class_definition.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_class_definition.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_class_definition.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,88 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>FdoShpClassDefinition Class Reference</h1><!-- doxytag: class="FdoShpClassDefinition" --><code>#include <<a class="el" href="_fdo_shp_class_definition_8h-source.html">FdoShpClassDefinition.h</a>></code>
+<p>
+<a href="class_fdo_shp_class_definition-members.html">List of all members.</a><hr><a name="_details"></a><h2>Detailed Description</h2>
+<p>
+<p>
+Definition at line <a class="el" href="_fdo_shp_class_definition_8h-source.html#l00026">26</a> of file <a class="el" href="_fdo_shp_class_definition_8h-source.html">FdoShpClassDefinition.h</a>.<table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td colspan="2"><br><h2>Public Member Functions</h2></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDOSHP_API void </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_class_definition_3d19e7886b05e4cfa5fb5371890ab97f.html#3d19e7886b05e4cfa5fb5371890ab97f">_writeXml</a> (GisXmlWriter *xmlWriter, const FdoXmlFlags *flags)</td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">FDOSHP_API <a class="el" href="class_fdo_shp_property_definition.html">FdoShpPropertyDefinition</a> * </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_class_definition_c3f943759f93d8173aacc9ce12c8feee.html#c3f943759f93d8173aacc9ce12c8feee">FindByColumnName</a> (GisString *columnName)</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Helper method to find a property mapping by its column name:. <a href="#c3f943759f93d8173aacc9ce12c8feee"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">FDOSHP_API <a class="el" href="class_fdo_shp_property_definition_collection.html">FdoShpPropertyDefinitionCollection</a> * </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_class_definition_bdc54fa302f857e4acc9a0c3660dd245.html#bdc54fa302f857e4acc9a0c3660dd245">GetProperties</a> () const </td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">FDOSHP_API GisString * </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_class_definition_4603016faf3795e4c4544f71e0fb4152.html#4603016faf3795e4c4544f71e0fb4152">GetShapeFile</a> () const </td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDOSHP_API void </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_class_definition_daed9b86862ad2148b72edadbbcf479e.html#daed9b86862ad2148b72edadbbcf479e">InitFromXml</a> (GisXmlSaxContext *pContext, GisXmlAttributeCollection *attrs)</td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">bool </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_class_definition_b9340be1c7d393ddedcf670de2149d76.html#b9340be1c7d393ddedcf670de2149d76">IsPathUpdated</a> ()</td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">void </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_class_definition_cb66f23743bb45b0e3faaa2bfafeaad8.html#cb66f23743bb45b0e3faaa2bfafeaad8">SetPathUpdated</a> (bool lPathUpdated=true)</td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">FDOSHP_API void </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_class_definition_2e617c437f74fe496aac753fb7666146.html#2e617c437f74fe496aac753fb7666146">SetShapeFile</a> (GisString *location)</td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDOSHP_API GisBoolean </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_class_definition_1eb8e1be10f1d92361eacbbdc50a0677.html#1eb8e1be10f1d92361eacbbdc50a0677">XmlEndElement</a> (GisXmlSaxContext *context, GisString *uri, GisString *name, GisString *qname)</td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDOSHP_API GisXmlSaxHandler * </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_class_definition_95b2357abf02d1278ac66f01921db44b.html#95b2357abf02d1278ac66f01921db44b">XmlStartElement</a> (GisXmlSaxContext *context, GisString *uri, GisString *name, GisString *qname, GisXmlAttributeCollection *atts)</td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">static FDOSHP_API <a class="el" href="class_fdo_shp_class_definition.html">FdoShpClassDefinition</a> * </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_class_definition_96936568a01aa49e3ef3fbb154fa5ad5.html#96936568a01aa49e3ef3fbb154fa5ad5">Create</a> ()</td></tr>
+</table>
+<li><a class="el" href="_fdo_shp_class_definition_8h-source.html">FdoShpClassDefinition.h</a></ul>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_class_definition_1eb8e1be10f1d92361eacbbdc50a0677.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_class_definition_1eb8e1be10f1d92361eacbbdc50a0677.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_class_definition_1eb8e1be10f1d92361eacbbdc50a0677.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,118 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="nav">
+<a class="el" href="class_fdo_shp_class_definition.html">FdoShpClassDefinition</a></div>
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_class_definition_3d19e7886b05e4cfa5fb5371890ab97f.html#3d19e7886b05e4cfa5fb5371890ab97f">_writeXml</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_class_definition_96936568a01aa49e3ef3fbb154fa5ad5.html#96936568a01aa49e3ef3fbb154fa5ad5">Create</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_class_definition_c3f943759f93d8173aacc9ce12c8feee.html#c3f943759f93d8173aacc9ce12c8feee">FindByColumnName</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_class_definition_bdc54fa302f857e4acc9a0c3660dd245.html#bdc54fa302f857e4acc9a0c3660dd245">GetProperties</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_class_definition_4603016faf3795e4c4544f71e0fb4152.html#4603016faf3795e4c4544f71e0fb4152">GetShapeFile</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_class_definition_daed9b86862ad2148b72edadbbcf479e.html#daed9b86862ad2148b72edadbbcf479e">InitFromXml</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_class_definition_b9340be1c7d393ddedcf670de2149d76.html#b9340be1c7d393ddedcf670de2149d76">IsPathUpdated</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_class_definition_cb66f23743bb45b0e3faaa2bfafeaad8.html#cb66f23743bb45b0e3faaa2bfafeaad8">SetPathUpdated</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_class_definition_2e617c437f74fe496aac753fb7666146.html#2e617c437f74fe496aac753fb7666146">SetShapeFile</a></td></tr>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_class_definition_1eb8e1be10f1d92361eacbbdc50a0677.html#1eb8e1be10f1d92361eacbbdc50a0677">XmlEndElement</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_class_definition_95b2357abf02d1278ac66f01921db44b.html#95b2357abf02d1278ac66f01921db44b">XmlStartElement</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="1eb8e1be10f1d92361eacbbdc50a0677"></a><!-- doxytag: member="FdoShpClassDefinition::XmlEndElement" ref="1eb8e1be10f1d92361eacbbdc50a0677" args="(GisXmlSaxContext *context, GisString *uri, GisString *name, GisString *qname)" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual FDOSHP_API GisBoolean FdoShpClassDefinition::XmlEndElement </td>
+ <td class="md" nowrap valign="top">GisXmlSaxContext * </td>
+ <td class="mdname" nowrap> <em>context</em>, </td>
+ </tr>
+ <tr>
+ <td class="md" nowrap align="right"></td>
+ <td class="md"></td>
+ <td class="md" nowrap>GisString * </td>
+ <td class="mdname" nowrap> <em>uri</em>, </td>
+ </tr>
+ <tr>
+ <td class="mdname" nowrap> <em>name</em>, </td>
+ </tr>
+ <tr>
+ <td class="mdname" nowrap> <em>qname</em></td>
+ </tr>
+ <tr>
+ <td class="md">) </td>
+ <td class="md" colspan="2"><code> [virtual]</code></td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_class_definition_2e617c437f74fe496aac753fb7666146.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_class_definition_2e617c437f74fe496aac753fb7666146.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_class_definition_2e617c437f74fe496aac753fb7666146.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,97 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_class_definition_2e617c437f74fe496aac753fb7666146.html#2e617c437f74fe496aac753fb7666146">SetShapeFile</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_class_definition_1eb8e1be10f1d92361eacbbdc50a0677.html#1eb8e1be10f1d92361eacbbdc50a0677">XmlEndElement</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="2e617c437f74fe496aac753fb7666146"></a><!-- doxytag: member="FdoShpClassDefinition::SetShapeFile" ref="2e617c437f74fe496aac753fb7666146" args="(GisString *location)" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">FDOSHP_API void FdoShpClassDefinition::SetShapeFile </td>
+ <td class="md" nowrap valign="top">GisString * </td>
+ <td class="mdname1" valign="top" nowrap> <em>location</em> </td>
+ <td class="md" nowrap></td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+<!-- footer.html -->
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_class_definition_3d19e7886b05e4cfa5fb5371890ab97f.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_class_definition_3d19e7886b05e4cfa5fb5371890ab97f.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_class_definition_3d19e7886b05e4cfa5fb5371890ab97f.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,106 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_class_definition_3d19e7886b05e4cfa5fb5371890ab97f.html#3d19e7886b05e4cfa5fb5371890ab97f">_writeXml</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="3d19e7886b05e4cfa5fb5371890ab97f"></a><!-- doxytag: member="FdoShpClassDefinition::_writeXml" ref="3d19e7886b05e4cfa5fb5371890ab97f" args="(GisXmlWriter *xmlWriter, const FdoXmlFlags *flags)" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual FDOSHP_API void FdoShpClassDefinition::_writeXml </td>
+ <td class="md" nowrap valign="top">GisXmlWriter * </td>
+ <td class="mdname" nowrap> <em>xmlWriter</em>, </td>
+ </tr>
+ <tr>
+ <td class="md" nowrap>const FdoXmlFlags * </td>
+ <td class="mdname" nowrap> <em>flags</em></td>
+ </tr>
+ <tr>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_class_definition_4603016faf3795e4c4544f71e0fb4152.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_class_definition_4603016faf3795e4c4544f71e0fb4152.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_class_definition_4603016faf3795e4c4544f71e0fb4152.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,96 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_class_definition_4603016faf3795e4c4544f71e0fb4152.html#4603016faf3795e4c4544f71e0fb4152">GetShapeFile</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="4603016faf3795e4c4544f71e0fb4152"></a><!-- doxytag: member="FdoShpClassDefinition::GetShapeFile" ref="4603016faf3795e4c4544f71e0fb4152" args="() const " --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">FDOSHP_API GisString* FdoShpClassDefinition::GetShapeFile </td>
+ <td class="md" nowrap> const</td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_class_definition_95b2357abf02d1278ac66f01921db44b.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_class_definition_95b2357abf02d1278ac66f01921db44b.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_class_definition_95b2357abf02d1278ac66f01921db44b.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,124 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_class_definition_95b2357abf02d1278ac66f01921db44b.html#95b2357abf02d1278ac66f01921db44b">XmlStartElement</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="95b2357abf02d1278ac66f01921db44b"></a><!-- doxytag: member="FdoShpClassDefinition::XmlStartElement" ref="95b2357abf02d1278ac66f01921db44b" args="(GisXmlSaxContext *context, GisString *uri, GisString *name, GisString *qname, GisXmlAttributeCollection *atts)" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual FDOSHP_API GisXmlSaxHandler* FdoShpClassDefinition::XmlStartElement </td>
+ </tr>
+ <tr>
+ </tr>
+ <tr>
+ </tr>
+ <tr>
+ <td class="mdname" nowrap> <em>qname</em>, </td>
+ </tr>
+ <tr>
+ <td class="md" nowrap>GisXmlAttributeCollection * </td>
+ <td class="mdname" nowrap> <em>atts</em></td>
+ </tr>
+ <tr>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_class_definition_96936568a01aa49e3ef3fbb154fa5ad5.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_class_definition_96936568a01aa49e3ef3fbb154fa5ad5.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_class_definition_96936568a01aa49e3ef3fbb154fa5ad5.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,96 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_class_definition_96936568a01aa49e3ef3fbb154fa5ad5.html#96936568a01aa49e3ef3fbb154fa5ad5">Create</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="96936568a01aa49e3ef3fbb154fa5ad5"></a><!-- doxytag: member="FdoShpClassDefinition::Create" ref="96936568a01aa49e3ef3fbb154fa5ad5" args="()" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">static FDOSHP_API <a class="el" href="class_fdo_shp_class_definition.html">FdoShpClassDefinition</a>* FdoShpClassDefinition::Create </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_class_definition_b9340be1c7d393ddedcf670de2149d76.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_class_definition_b9340be1c7d393ddedcf670de2149d76.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_class_definition_b9340be1c7d393ddedcf670de2149d76.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,98 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_class_definition_b9340be1c7d393ddedcf670de2149d76.html#b9340be1c7d393ddedcf670de2149d76">IsPathUpdated</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="b9340be1c7d393ddedcf670de2149d76"></a><!-- doxytag: member="FdoShpClassDefinition::IsPathUpdated" ref="b9340be1c7d393ddedcf670de2149d76" args="()" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">bool FdoShpClassDefinition::IsPathUpdated </td>
+ <td class="md" nowrap><code> [inline]</code></td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+<p>
+Definition at line <a class="el" href="_fdo_shp_class_definition_8h-source.html#l00038">38</a> of file <a class="el" href="_fdo_shp_class_definition_8h-source.html">FdoShpClassDefinition.h</a>. </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_class_definition_bdc54fa302f857e4acc9a0c3660dd245.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_class_definition_bdc54fa302f857e4acc9a0c3660dd245.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_class_definition_bdc54fa302f857e4acc9a0c3660dd245.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,96 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_class_definition_bdc54fa302f857e4acc9a0c3660dd245.html#bdc54fa302f857e4acc9a0c3660dd245">GetProperties</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="bdc54fa302f857e4acc9a0c3660dd245"></a><!-- doxytag: member="FdoShpClassDefinition::GetProperties" ref="bdc54fa302f857e4acc9a0c3660dd245" args="() const " --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">FDOSHP_API <a class="el" href="class_fdo_shp_property_definition_collection.html">FdoShpPropertyDefinitionCollection</a>* FdoShpClassDefinition::GetProperties </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_class_definition_c3f943759f93d8173aacc9ce12c8feee.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_class_definition_c3f943759f93d8173aacc9ce12c8feee.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_class_definition_c3f943759f93d8173aacc9ce12c8feee.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,99 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_class_definition_c3f943759f93d8173aacc9ce12c8feee.html#c3f943759f93d8173aacc9ce12c8feee">FindByColumnName</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="c3f943759f93d8173aacc9ce12c8feee"></a><!-- doxytag: member="FdoShpClassDefinition::FindByColumnName" ref="c3f943759f93d8173aacc9ce12c8feee" args="(GisString *columnName)" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">FDOSHP_API <a class="el" href="class_fdo_shp_property_definition.html">FdoShpPropertyDefinition</a>* FdoShpClassDefinition::FindByColumnName </td>
+ <td class="mdname1" valign="top" nowrap> <em>columnName</em> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Helper method to find a property mapping by its column name:.
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_class_definition_cb66f23743bb45b0e3faaa2bfafeaad8.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_class_definition_cb66f23743bb45b0e3faaa2bfafeaad8.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_class_definition_cb66f23743bb45b0e3faaa2bfafeaad8.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,99 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_class_definition_cb66f23743bb45b0e3faaa2bfafeaad8.html#cb66f23743bb45b0e3faaa2bfafeaad8">SetPathUpdated</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="cb66f23743bb45b0e3faaa2bfafeaad8"></a><!-- doxytag: member="FdoShpClassDefinition::SetPathUpdated" ref="cb66f23743bb45b0e3faaa2bfafeaad8" args="(bool lPathUpdated=true)" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">void FdoShpClassDefinition::SetPathUpdated </td>
+ <td class="md" nowrap valign="top">bool </td>
+ <td class="mdname1" valign="top" nowrap> <em>lPathUpdated</em> = <code>true</code> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+<p>
+Definition at line <a class="el" href="_fdo_shp_class_definition_8h-source.html#l00039">39</a> of file <a class="el" href="_fdo_shp_class_definition_8h-source.html">FdoShpClassDefinition.h</a>. </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_class_definition_daed9b86862ad2148b72edadbbcf479e.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_class_definition_daed9b86862ad2148b72edadbbcf479e.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_class_definition_daed9b86862ad2148b72edadbbcf479e.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,106 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li><a href="files.html"><span>Files</span></a></li>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_class_definition_daed9b86862ad2148b72edadbbcf479e.html#daed9b86862ad2148b72edadbbcf479e">InitFromXml</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="daed9b86862ad2148b72edadbbcf479e"></a><!-- doxytag: member="FdoShpClassDefinition::InitFromXml" ref="daed9b86862ad2148b72edadbbcf479e" args="(GisXmlSaxContext *pContext, GisXmlAttributeCollection *attrs)" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual FDOSHP_API void FdoShpClassDefinition::InitFromXml </td>
+ <td class="mdname" nowrap> <em>pContext</em>, </td>
+ </tr>
+ <tr>
+ <td class="mdname" nowrap> <em>attrs</em></td>
+ </tr>
+ <tr>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_column_definition-members.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_column_definition-members.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_column_definition-members.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,57 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>FdoShpColumnDefinition Member List</h1>This is the complete list of members for <a class="el" href="class_fdo_shp_column_definition.html">FdoShpColumnDefinition</a>, including all inherited members.<p><table>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_column_definition_955c02380b27a475d2f00ad14568a2ae.html#955c02380b27a475d2f00ad14568a2ae">_writeXml</a>(GisXmlWriter *xmlWriter, const FdoXmlFlags *flags)</td><td><a class="el" href="class_fdo_shp_column_definition.html">FdoShpColumnDefinition</a></td><td><code> [virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_column_definition_4ba0b1a32d4f0126a9a5079eab9fe025.html#4ba0b1a32d4f0126a9a5079eab9fe025">Create</a>()</td><td><a class="el" href="class_fdo_shp_column_definition.html">FdoShpColumnDefinition</a></td><td><code> [static]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_column_definition_600ecd1991fa387cc926316543de81e8.html#600ecd1991fa387cc926316543de81e8">InitFromXml</a>(GisXmlSaxContext *pContext, GisXmlAttributeCollection *attrs)</td><td><a class="el" href="class_fdo_shp_column_definition.html">FdoShpColumnDefinition</a></td><td><code> [virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_column_definition_c9d77b68d5f4a385142690b92d0e7ef9.html#c9d77b68d5f4a385142690b92d0e7ef9">XmlEndElement</a>(GisXmlSaxContext *context, GisString *uri, GisString *name, GisString *qname)</td><td><a class="el" href="class_fdo_shp_column_definition.html">FdoShpColumnDefinition</a></td><td><code> [virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_column_definition_d5669958dfaeb362578fde7cac156561.html#d5669958dfaeb362578fde7cac156561">XmlStartElement</a>(GisXmlSaxContext *context, GisString *uri, GisString *name, GisString *qname, GisXmlAttributeCollection *atts)</td><td><a class="el" href="class_fdo_shp_column_definition.html">FdoShpColumnDefinition</a></td><td><code> [virtual]</code></td></tr>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_column_definition.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_column_definition.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_column_definition.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,75 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>FdoShpColumnDefinition Class Reference</h1><!-- doxytag: class="FdoShpColumnDefinition" --><code>#include <<a class="el" href="_fdo_shp_column_definition_8h-source.html">FdoShpColumnDefinition.h</a>></code>
+<p>
+<a href="class_fdo_shp_column_definition-members.html">List of all members.</a><hr><a name="_details"></a><h2>Detailed Description</h2>
+<p>
+<p>
+Definition at line <a class="el" href="_fdo_shp_column_definition_8h-source.html#l00024">24</a> of file <a class="el" href="_fdo_shp_column_definition_8h-source.html">FdoShpColumnDefinition.h</a>.<table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDOSHP_API void </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_column_definition_955c02380b27a475d2f00ad14568a2ae.html#955c02380b27a475d2f00ad14568a2ae">_writeXml</a> (GisXmlWriter *xmlWriter, const FdoXmlFlags *flags)</td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDOSHP_API void </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_column_definition_600ecd1991fa387cc926316543de81e8.html#600ecd1991fa387cc926316543de81e8">InitFromXml</a> (GisXmlSaxContext *pContext, GisXmlAttributeCollection *attrs)</td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDOSHP_API GisBoolean </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_column_definition_c9d77b68d5f4a385142690b92d0e7ef9.html#c9d77b68d5f4a385142690b92d0e7ef9">XmlEndElement</a> (GisXmlSaxContext *context, GisString *uri, GisString *name, GisString *qname)</td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDOSHP_API GisXmlSaxHandler * </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_column_definition_d5669958dfaeb362578fde7cac156561.html#d5669958dfaeb362578fde7cac156561">XmlStartElement</a> (GisXmlSaxContext *context, GisString *uri, GisString *name, GisString *qname, GisXmlAttributeCollection *atts)</td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">static FDOSHP_API <a class="el" href="class_fdo_shp_column_definition.html">FdoShpColumnDefinition</a> * </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_column_definition_4ba0b1a32d4f0126a9a5079eab9fe025.html#4ba0b1a32d4f0126a9a5079eab9fe025">Create</a> ()</td></tr>
+</table>
+<li><a class="el" href="_fdo_shp_column_definition_8h-source.html">FdoShpColumnDefinition.h</a></ul>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_column_definition_4ba0b1a32d4f0126a9a5079eab9fe025.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_column_definition_4ba0b1a32d4f0126a9a5079eab9fe025.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_column_definition_4ba0b1a32d4f0126a9a5079eab9fe025.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,90 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="nav">
+<a class="el" href="class_fdo_shp_column_definition.html">FdoShpColumnDefinition</a></div>
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_column_definition_955c02380b27a475d2f00ad14568a2ae.html#955c02380b27a475d2f00ad14568a2ae">_writeXml</a></td></tr>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_column_definition_4ba0b1a32d4f0126a9a5079eab9fe025.html#4ba0b1a32d4f0126a9a5079eab9fe025">Create</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_column_definition_600ecd1991fa387cc926316543de81e8.html#600ecd1991fa387cc926316543de81e8">InitFromXml</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_column_definition_c9d77b68d5f4a385142690b92d0e7ef9.html#c9d77b68d5f4a385142690b92d0e7ef9">XmlEndElement</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_column_definition_d5669958dfaeb362578fde7cac156561.html#d5669958dfaeb362578fde7cac156561">XmlStartElement</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="4ba0b1a32d4f0126a9a5079eab9fe025"></a><!-- doxytag: member="FdoShpColumnDefinition::Create" ref="4ba0b1a32d4f0126a9a5079eab9fe025" args="()" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">static FDOSHP_API <a class="el" href="class_fdo_shp_column_definition.html">FdoShpColumnDefinition</a>* FdoShpColumnDefinition::Create </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_column_definition_600ecd1991fa387cc926316543de81e8.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_column_definition_600ecd1991fa387cc926316543de81e8.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_column_definition_600ecd1991fa387cc926316543de81e8.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,100 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_column_definition_4ba0b1a32d4f0126a9a5079eab9fe025.html#4ba0b1a32d4f0126a9a5079eab9fe025">Create</a></td></tr>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_column_definition_600ecd1991fa387cc926316543de81e8.html#600ecd1991fa387cc926316543de81e8">InitFromXml</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="600ecd1991fa387cc926316543de81e8"></a><!-- doxytag: member="FdoShpColumnDefinition::InitFromXml" ref="600ecd1991fa387cc926316543de81e8" args="(GisXmlSaxContext *pContext, GisXmlAttributeCollection *attrs)" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual FDOSHP_API void FdoShpColumnDefinition::InitFromXml </td>
+ </tr>
+ <tr>
+ </tr>
+ <tr>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_column_definition_955c02380b27a475d2f00ad14568a2ae.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_column_definition_955c02380b27a475d2f00ad14568a2ae.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_column_definition_955c02380b27a475d2f00ad14568a2ae.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,100 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_column_definition_955c02380b27a475d2f00ad14568a2ae.html#955c02380b27a475d2f00ad14568a2ae">_writeXml</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="955c02380b27a475d2f00ad14568a2ae"></a><!-- doxytag: member="FdoShpColumnDefinition::_writeXml" ref="955c02380b27a475d2f00ad14568a2ae" args="(GisXmlWriter *xmlWriter, const FdoXmlFlags *flags)" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual FDOSHP_API void FdoShpColumnDefinition::_writeXml </td>
+ </tr>
+ <tr>
+ </tr>
+ <tr>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_column_definition_c9d77b68d5f4a385142690b92d0e7ef9.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_column_definition_c9d77b68d5f4a385142690b92d0e7ef9.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_column_definition_c9d77b68d5f4a385142690b92d0e7ef9.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,112 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_column_definition_c9d77b68d5f4a385142690b92d0e7ef9.html#c9d77b68d5f4a385142690b92d0e7ef9">XmlEndElement</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="c9d77b68d5f4a385142690b92d0e7ef9"></a><!-- doxytag: member="FdoShpColumnDefinition::XmlEndElement" ref="c9d77b68d5f4a385142690b92d0e7ef9" args="(GisXmlSaxContext *context, GisString *uri, GisString *name, GisString *qname)" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual FDOSHP_API GisBoolean FdoShpColumnDefinition::XmlEndElement </td>
+ </tr>
+ <tr>
+ </tr>
+ <tr>
+ </tr>
+ <tr>
+ </tr>
+ <tr>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_column_definition_d5669958dfaeb362578fde7cac156561.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_column_definition_d5669958dfaeb362578fde7cac156561.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_column_definition_d5669958dfaeb362578fde7cac156561.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,118 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_column_definition_d5669958dfaeb362578fde7cac156561.html#d5669958dfaeb362578fde7cac156561">XmlStartElement</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="d5669958dfaeb362578fde7cac156561"></a><!-- doxytag: member="FdoShpColumnDefinition::XmlStartElement" ref="d5669958dfaeb362578fde7cac156561" args="(GisXmlSaxContext *context, GisString *uri, GisString *name, GisString *qname, GisXmlAttributeCollection *atts)" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual FDOSHP_API GisXmlSaxHandler* FdoShpColumnDefinition::XmlStartElement </td>
+ </tr>
+ <tr>
+ </tr>
+ <tr>
+ </tr>
+ <tr>
+ </tr>
+ <tr>
+ </tr>
+ <tr>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_physical_schema_mapping-members.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_physical_schema_mapping-members.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_physical_schema_mapping-members.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,61 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>FdoShpPhysicalSchemaMapping Member List</h1>This is the complete list of members for <a class="el" href="class_fdo_shp_physical_schema_mapping.html">FdoShpPhysicalSchemaMapping</a>, including all inherited members.<p><table>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_physical_schema_mapping_36448c6a7557f454b949b605a6c80129.html#36448c6a7557f454b949b605a6c80129">_writeXml</a>(GisXmlWriter *xmlWriter, const FdoXmlFlags *flags)</td><td><a class="el" href="class_fdo_shp_physical_schema_mapping.html">FdoShpPhysicalSchemaMapping</a></td><td><code> [virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_physical_schema_mapping_48e086264cd4780a442f8ecb841faea8.html#48e086264cd4780a442f8ecb841faea8">Create</a>()</td><td><a class="el" href="class_fdo_shp_physical_schema_mapping.html">FdoShpPhysicalSchemaMapping</a></td><td><code> [static]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_physical_schema_mapping_cc639fa3a2ae6823d20042cc95f06dae.html#cc639fa3a2ae6823d20042cc95f06dae">FindByClassName</a>(GisString *class_name)</td><td><a class="el" href="class_fdo_shp_physical_schema_mapping.html">FdoShpPhysicalSchemaMapping</a></td><td></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_physical_schema_mapping_bb73c56d22638012ed655b6a276e75db.html#bb73c56d22638012ed655b6a276e75db">FindByShapefile</a>(GisString *shapefilePath)</td><td><a class="el" href="class_fdo_shp_physical_schema_mapping.html">FdoShpPhysicalSchemaMapping</a></td><td></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_physical_schema_mapping_4d944a128be1ad6406974f8375f12f69.html#4d944a128be1ad6406974f8375f12f69">GetClasses</a>() const </td><td><a class="el" href="class_fdo_shp_physical_schema_mapping.html">FdoShpPhysicalSchemaMapping</a></td><td></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_physical_schema_mapping_45d51d0f0311ff85ed516136e2ce16f6.html#45d51d0f0311ff85ed516136e2ce16f6">GetProvider</a>()</td><td><a class="el" href="class_fdo_shp_physical_schema_mapping.html">FdoShpPhysicalSchemaMapping</a></td><td><code> [virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_physical_schema_mapping_852853e469120e86223be6db80bccb20.html#852853e469120e86223be6db80bccb20">InitFromXml</a>(GisXmlSaxContext *pContext, GisXmlAttributeCollection *attrs)</td><td><a class="el" href="class_fdo_shp_physical_schema_mapping.html">FdoShpPhysicalSchemaMapping</a></td><td><code> [virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_physical_schema_mapping_7c0b1de21670db480e4463bcecfce94b.html#7c0b1de21670db480e4463bcecfce94b">XmlEndElement</a>(GisXmlSaxContext *context, GisString *uri, GisString *name, GisString *qname)</td><td><a class="el" href="class_fdo_shp_physical_schema_mapping.html">FdoShpPhysicalSchemaMapping</a></td><td><code> [virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_physical_schema_mapping_af942717804976ecf3233c259650fb48.html#af942717804976ecf3233c259650fb48">XmlStartElement</a>(GisXmlSaxContext *context, GisString *uri, GisString *name, GisString *qname, GisXmlAttributeCollection *atts)</td><td><a class="el" href="class_fdo_shp_physical_schema_mapping.html">FdoShpPhysicalSchemaMapping</a></td><td><code> [virtual]</code></td></tr>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_physical_schema_mapping.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_physical_schema_mapping.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_physical_schema_mapping.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,85 @@
+<html>
+ <head>
+ <title>OSGeo FDO Provider for SHP API Reference</title>
+ </head>
+ <tr>
+ <td align="right"><b>OSGeo FDO Provider for SHP<b></td>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li>
+ <form action="search.php" method="get">
+ <table cellspacing="0" cellpadding="0" border="0">
+ <tr>
+ <td><label> <u>S</u>earch for </label></td>
+ <td><input type="text" name="query" value="" size="20" accesskey="s"/></td>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>FdoShpPhysicalSchemaMapping Class Reference</h1><!-- doxytag: class="FdoShpPhysicalSchemaMapping" --><code>#include <<a class="el" href="_fdo_shp_physical_schema_mapping_8h-source.html">FdoShpPhysicalSchemaMapping.h</a>></code>
+<p>
+<a href="class_fdo_shp_physical_schema_mapping-members.html">List of all members.</a><hr><a name="_details"></a><h2>Detailed Description</h2>
+<p>
+<p>
+Definition at line <a class="el" href="_fdo_shp_physical_schema_mapping_8h-source.html#l00026">26</a> of file <a class="el" href="_fdo_shp_physical_schema_mapping_8h-source.html">FdoShpPhysicalSchemaMapping.h</a>.<table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDOSHP_API void </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_physical_schema_mapping_36448c6a7557f454b949b605a6c80129.html#36448c6a7557f454b949b605a6c80129">_writeXml</a> (GisXmlWriter *xmlWriter, const FdoXmlFlags *flags)</td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">FDOSHP_API <a class="el" href="class_fdo_shp_class_definition.html">FdoShpClassDefinition</a> * </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_physical_schema_mapping_cc639fa3a2ae6823d20042cc95f06dae.html#cc639fa3a2ae6823d20042cc95f06dae">FindByClassName</a> (GisString *class_name)</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Helper method to find a class mapping that maps to a given classname:. <a href="#cc639fa3a2ae6823d20042cc95f06dae"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">FDOSHP_API <a class="el" href="class_fdo_shp_class_definition.html">FdoShpClassDefinition</a> * </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_physical_schema_mapping_bb73c56d22638012ed655b6a276e75db.html#bb73c56d22638012ed655b6a276e75db">FindByShapefile</a> (GisString *shapefilePath)</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Helper method to find a class mapping that maps to a given shapefile:. <a href="#bb73c56d22638012ed655b6a276e75db"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">FDOSHP_API <a class="el" href="class_fdo_shp_class_collection.html">FdoShpClassCollection</a> * </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_physical_schema_mapping_4d944a128be1ad6406974f8375f12f69.html#4d944a128be1ad6406974f8375f12f69">GetClasses</a> () const </td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDOSHP_API GisString * </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_physical_schema_mapping_45d51d0f0311ff85ed516136e2ce16f6.html#45d51d0f0311ff85ed516136e2ce16f6">GetProvider</a> ()</td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDOSHP_API void </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_physical_schema_mapping_852853e469120e86223be6db80bccb20.html#852853e469120e86223be6db80bccb20">InitFromXml</a> (GisXmlSaxContext *pContext, GisXmlAttributeCollection *attrs)</td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDOSHP_API GisBoolean </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_physical_schema_mapping_7c0b1de21670db480e4463bcecfce94b.html#7c0b1de21670db480e4463bcecfce94b">XmlEndElement</a> (GisXmlSaxContext *context, GisString *uri, GisString *name, GisString *qname)</td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDOSHP_API GisXmlSaxHandler * </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_physical_schema_mapping_af942717804976ecf3233c259650fb48.html#af942717804976ecf3233c259650fb48">XmlStartElement</a> (GisXmlSaxContext *context, GisString *uri, GisString *name, GisString *qname, GisXmlAttributeCollection *atts)</td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">static FDOSHP_API <a class="el" href="class_fdo_shp_physical_schema_mapping.html">FdoShpPhysicalSchemaMapping</a> * </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_physical_schema_mapping_48e086264cd4780a442f8ecb841faea8.html#48e086264cd4780a442f8ecb841faea8">Create</a> ()</td></tr>
+</table>
+<li><a class="el" href="_fdo_shp_physical_schema_mapping_8h-source.html">FdoShpPhysicalSchemaMapping.h</a></ul>
+ <hr>
+ <table width="100%" border="0">
+ <tr>
+ <td align="right"><font size="-2"><a href="mailto:isd.docs at autodesk.com&subject=FDO%20Provider%20for%20SHP%20API%20documentation">Comments?</a></font></td>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_physical_schema_mapping_36448c6a7557f454b949b605a6c80129.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_physical_schema_mapping_36448c6a7557f454b949b605a6c80129.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_physical_schema_mapping_36448c6a7557f454b949b605a6c80129.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,104 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
+<html>
+ <head>
+ <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
+ <link href="custom.css" rel="stylesheet" type="text/css">
+ <link href="tabs.css" rel="stylesheet" type="text/css">
+ </head>
+ <body bgcolor="#FFFFFF">
+ <tr>
+ <td><b>API Reference<b></td>
+ </tr>
+ </table>
+<!-- End of: header.html -->
+<!-- Generated by Doxygen 1.4.6-NO -->
+<div class="tabs">
+ <ul>
+ <li><a href="main.html"><span>Main Page</span></a></li>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="nav">
+<a class="el" href="class_fdo_shp_physical_schema_mapping.html">FdoShpPhysicalSchemaMapping</a></div>
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_physical_schema_mapping_36448c6a7557f454b949b605a6c80129.html#36448c6a7557f454b949b605a6c80129">_writeXml</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_physical_schema_mapping_48e086264cd4780a442f8ecb841faea8.html#48e086264cd4780a442f8ecb841faea8">Create</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_physical_schema_mapping_cc639fa3a2ae6823d20042cc95f06dae.html#cc639fa3a2ae6823d20042cc95f06dae">FindByClassName</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_physical_schema_mapping_bb73c56d22638012ed655b6a276e75db.html#bb73c56d22638012ed655b6a276e75db">FindByShapefile</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_physical_schema_mapping_4d944a128be1ad6406974f8375f12f69.html#4d944a128be1ad6406974f8375f12f69">GetClasses</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_physical_schema_mapping_45d51d0f0311ff85ed516136e2ce16f6.html#45d51d0f0311ff85ed516136e2ce16f6">GetProvider</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_physical_schema_mapping_852853e469120e86223be6db80bccb20.html#852853e469120e86223be6db80bccb20">InitFromXml</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_physical_schema_mapping_7c0b1de21670db480e4463bcecfce94b.html#7c0b1de21670db480e4463bcecfce94b">XmlEndElement</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_physical_schema_mapping_af942717804976ecf3233c259650fb48.html#af942717804976ecf3233c259650fb48">XmlStartElement</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="36448c6a7557f454b949b605a6c80129"></a><!-- doxytag: member="FdoShpPhysicalSchemaMapping::_writeXml" ref="36448c6a7557f454b949b605a6c80129" args="(GisXmlWriter *xmlWriter, const FdoXmlFlags *flags)" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual FDOSHP_API void FdoShpPhysicalSchemaMapping::_writeXml </td>
+ </tr>
+ <tr>
+ </tr>
+ <tr>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_physical_schema_mapping_45d51d0f0311ff85ed516136e2ce16f6.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_physical_schema_mapping_45d51d0f0311ff85ed516136e2ce16f6.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_physical_schema_mapping_45d51d0f0311ff85ed516136e2ce16f6.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,94 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_physical_schema_mapping_36448c6a7557f454b949b605a6c80129.html#36448c6a7557f454b949b605a6c80129">_writeXml</a></td></tr>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_physical_schema_mapping_45d51d0f0311ff85ed516136e2ce16f6.html#45d51d0f0311ff85ed516136e2ce16f6">GetProvider</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="45d51d0f0311ff85ed516136e2ce16f6"></a><!-- doxytag: member="FdoShpPhysicalSchemaMapping::GetProvider" ref="45d51d0f0311ff85ed516136e2ce16f6" args="()" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual FDOSHP_API GisString* FdoShpPhysicalSchemaMapping::GetProvider </td>
+ <td class="md" nowrap><code> [virtual]</code></td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_physical_schema_mapping_48e086264cd4780a442f8ecb841faea8.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_physical_schema_mapping_48e086264cd4780a442f8ecb841faea8.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_physical_schema_mapping_48e086264cd4780a442f8ecb841faea8.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,94 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li><a href="classes.html"><span>Classes</span></a></li>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="nav">
+<table cellspacing="0" cellpadding="0" border="0">
+ <tr>
+ <td valign="top">
+ <div class="navtab">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_physical_schema_mapping_48e086264cd4780a442f8ecb841faea8.html#48e086264cd4780a442f8ecb841faea8">Create</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="48e086264cd4780a442f8ecb841faea8"></a><!-- doxytag: member="FdoShpPhysicalSchemaMapping::Create" ref="48e086264cd4780a442f8ecb841faea8" args="()" --><p>
+<table class="mdTable" cellpadding="2" cellspacing="0">
+ <tr>
+ <td class="mdRow">
+ <table cellpadding="0" cellspacing="0" border="0">
+ <tr>
+ <td class="md" nowrap valign="top">static FDOSHP_API <a class="el" href="class_fdo_shp_physical_schema_mapping.html">FdoShpPhysicalSchemaMapping</a>* FdoShpPhysicalSchemaMapping::Create </td>
+ <td class="md" valign="top">( </td>
+ <td class="md" valign="top"> ) </td>
+ <td class="md" nowrap><code> [static]</code></td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+<table cellspacing="5" cellpadding="0" border="0">
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_physical_schema_mapping_4d944a128be1ad6406974f8375f12f69.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_physical_schema_mapping_4d944a128be1ad6406974f8375f12f69.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_physical_schema_mapping_4d944a128be1ad6406974f8375f12f69.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,94 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_physical_schema_mapping_4d944a128be1ad6406974f8375f12f69.html#4d944a128be1ad6406974f8375f12f69">GetClasses</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="4d944a128be1ad6406974f8375f12f69"></a><!-- doxytag: member="FdoShpPhysicalSchemaMapping::GetClasses" ref="4d944a128be1ad6406974f8375f12f69" args="() const " --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">FDOSHP_API <a class="el" href="class_fdo_shp_class_collection.html">FdoShpClassCollection</a>* FdoShpPhysicalSchemaMapping::GetClasses </td>
+ <td class="mdname1" valign="top" nowrap> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_physical_schema_mapping_7c0b1de21670db480e4463bcecfce94b.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_physical_schema_mapping_7c0b1de21670db480e4463bcecfce94b.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_physical_schema_mapping_7c0b1de21670db480e4463bcecfce94b.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,116 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_physical_schema_mapping_7c0b1de21670db480e4463bcecfce94b.html#7c0b1de21670db480e4463bcecfce94b">XmlEndElement</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="7c0b1de21670db480e4463bcecfce94b"></a><!-- doxytag: member="FdoShpPhysicalSchemaMapping::XmlEndElement" ref="7c0b1de21670db480e4463bcecfce94b" args="(GisXmlSaxContext *context, GisString *uri, GisString *name, GisString *qname)" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual FDOSHP_API GisBoolean FdoShpPhysicalSchemaMapping::XmlEndElement </td>
+ </tr>
+ <tr>
+ </tr>
+ <tr>
+ </tr>
+ <tr>
+ </tr>
+ <tr>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_physical_schema_mapping_852853e469120e86223be6db80bccb20.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_physical_schema_mapping_852853e469120e86223be6db80bccb20.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_physical_schema_mapping_852853e469120e86223be6db80bccb20.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,104 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_physical_schema_mapping_852853e469120e86223be6db80bccb20.html#852853e469120e86223be6db80bccb20">InitFromXml</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="852853e469120e86223be6db80bccb20"></a><!-- doxytag: member="FdoShpPhysicalSchemaMapping::InitFromXml" ref="852853e469120e86223be6db80bccb20" args="(GisXmlSaxContext *pContext, GisXmlAttributeCollection *attrs)" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual FDOSHP_API void FdoShpPhysicalSchemaMapping::InitFromXml </td>
+ </tr>
+ <tr>
+ </tr>
+ <tr>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_physical_schema_mapping_af942717804976ecf3233c259650fb48.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_physical_schema_mapping_af942717804976ecf3233c259650fb48.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_physical_schema_mapping_af942717804976ecf3233c259650fb48.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,122 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_physical_schema_mapping_af942717804976ecf3233c259650fb48.html#af942717804976ecf3233c259650fb48">XmlStartElement</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="af942717804976ecf3233c259650fb48"></a><!-- doxytag: member="FdoShpPhysicalSchemaMapping::XmlStartElement" ref="af942717804976ecf3233c259650fb48" args="(GisXmlSaxContext *context, GisString *uri, GisString *name, GisString *qname, GisXmlAttributeCollection *atts)" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual FDOSHP_API GisXmlSaxHandler* FdoShpPhysicalSchemaMapping::XmlStartElement </td>
+ </tr>
+ <tr>
+ </tr>
+ <tr>
+ </tr>
+ <tr>
+ </tr>
+ <tr>
+ </tr>
+ <tr>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ <!-- The logo can go in another cell, when we get one -->
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_physical_schema_mapping_bb73c56d22638012ed655b6a276e75db.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_physical_schema_mapping_bb73c56d22638012ed655b6a276e75db.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_physical_schema_mapping_bb73c56d22638012ed655b6a276e75db.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,97 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_physical_schema_mapping_bb73c56d22638012ed655b6a276e75db.html#bb73c56d22638012ed655b6a276e75db">FindByShapefile</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="bb73c56d22638012ed655b6a276e75db"></a><!-- doxytag: member="FdoShpPhysicalSchemaMapping::FindByShapefile" ref="bb73c56d22638012ed655b6a276e75db" args="(GisString *shapefilePath)" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">FDOSHP_API <a class="el" href="class_fdo_shp_class_definition.html">FdoShpClassDefinition</a>* FdoShpPhysicalSchemaMapping::FindByShapefile </td>
+ <td class="mdname1" valign="top" nowrap> <em>shapefilePath</em> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Helper method to find a class mapping that maps to a given shapefile:.
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_physical_schema_mapping_cc639fa3a2ae6823d20042cc95f06dae.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_physical_schema_mapping_cc639fa3a2ae6823d20042cc95f06dae.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_physical_schema_mapping_cc639fa3a2ae6823d20042cc95f06dae.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,97 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_physical_schema_mapping_cc639fa3a2ae6823d20042cc95f06dae.html#cc639fa3a2ae6823d20042cc95f06dae">FindByClassName</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="cc639fa3a2ae6823d20042cc95f06dae"></a><!-- doxytag: member="FdoShpPhysicalSchemaMapping::FindByClassName" ref="cc639fa3a2ae6823d20042cc95f06dae" args="(GisString *class_name)" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">FDOSHP_API <a class="el" href="class_fdo_shp_class_definition.html">FdoShpClassDefinition</a>* FdoShpPhysicalSchemaMapping::FindByClassName </td>
+ <td class="mdname1" valign="top" nowrap> <em>class_name</em> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Helper method to find a class mapping that maps to a given classname:.
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_property_definition-members.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_property_definition-members.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_property_definition-members.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,59 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li id="current"><a href="classes.html"><span>Classes</span></a></li>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li><a href="classes.html"><span>Alphabetical List</span></a></li>
+ <li><a href="annotated.html"><span>Class List</span></a></li>
+ <li><a href="hierarchy.html"><span>Class Hierarchy</span></a></li>
+ <li><a href="functions.html"><span>Class Members</span></a></li>
+ </ul></div>
+<h1>FdoShpPropertyDefinition Member List</h1>This is the complete list of members for <a class="el" href="class_fdo_shp_property_definition.html">FdoShpPropertyDefinition</a>, including all inherited members.<p><table>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_property_definition_ca026498f207e7542714e2094301f456.html#ca026498f207e7542714e2094301f456">_writeXml</a>(GisXmlWriter *xmlWriter, const FdoXmlFlags *flags)</td><td><a class="el" href="class_fdo_shp_property_definition.html">FdoShpPropertyDefinition</a></td><td><code> [virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_property_definition_a603b74205bc257c10b7bc068f516292.html#a603b74205bc257c10b7bc068f516292">Create</a>()</td><td><a class="el" href="class_fdo_shp_property_definition.html">FdoShpPropertyDefinition</a></td><td><code> [static]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_property_definition_20d2033a8034eaed4bfef6d0e3eabaab.html#20d2033a8034eaed4bfef6d0e3eabaab">GetColumn</a>() const </td><td><a class="el" href="class_fdo_shp_property_definition.html">FdoShpPropertyDefinition</a></td><td></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_property_definition_e2292de181258077b5faa7c1a62c80eb.html#e2292de181258077b5faa7c1a62c80eb">InitFromXml</a>(GisXmlSaxContext *pContext, GisXmlAttributeCollection *attrs)</td><td><a class="el" href="class_fdo_shp_property_definition.html">FdoShpPropertyDefinition</a></td><td><code> [virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_property_definition_9f411822896503e8e305bcd5baa501c3.html#9f411822896503e8e305bcd5baa501c3">SetColumn</a>(FdoShpColumnDefinition *definition)</td><td><a class="el" href="class_fdo_shp_property_definition.html">FdoShpPropertyDefinition</a></td><td></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_property_definition_2961dfcc8cb657ce57689f56c9764fec.html#2961dfcc8cb657ce57689f56c9764fec">XmlEndElement</a>(GisXmlSaxContext *context, GisString *uri, GisString *name, GisString *qname)</td><td><a class="el" href="class_fdo_shp_property_definition.html">FdoShpPropertyDefinition</a></td><td><code> [virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_property_definition_3530f2250ead9a4f2589dfcf013b23b4.html#3530f2250ead9a4f2589dfcf013b23b4">XmlStartElement</a>(GisXmlSaxContext *context, GisString *uri, GisString *name, GisString *qname, GisXmlAttributeCollection *atts)</td><td><a class="el" href="class_fdo_shp_property_definition.html">FdoShpPropertyDefinition</a></td><td><code> [virtual]</code></td></tr>
+</table><!-- footer.html -->
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_property_definition.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_property_definition.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_property_definition.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,79 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>FdoShpPropertyDefinition Class Reference</h1><!-- doxytag: class="FdoShpPropertyDefinition" --><code>#include <<a class="el" href="_fdo_shp_property_definition_8h-source.html">FdoShpPropertyDefinition.h</a>></code>
+<p>
+<a href="class_fdo_shp_property_definition-members.html">List of all members.</a><hr><a name="_details"></a><h2>Detailed Description</h2>
+<p>
+<p>
+Definition at line <a class="el" href="_fdo_shp_property_definition_8h-source.html#l00026">26</a> of file <a class="el" href="_fdo_shp_property_definition_8h-source.html">FdoShpPropertyDefinition.h</a>.<table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td colspan="2"><br><h2>Public Member Functions</h2></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDOSHP_API void </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_property_definition_ca026498f207e7542714e2094301f456.html#ca026498f207e7542714e2094301f456">_writeXml</a> (GisXmlWriter *xmlWriter, const FdoXmlFlags *flags)</td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">FDOSHP_API <a class="el" href="class_fdo_shp_column_definition.html">FdoShpColumnDefinition</a> * </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_property_definition_20d2033a8034eaed4bfef6d0e3eabaab.html#20d2033a8034eaed4bfef6d0e3eabaab">GetColumn</a> () const </td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDOSHP_API void </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_property_definition_e2292de181258077b5faa7c1a62c80eb.html#e2292de181258077b5faa7c1a62c80eb">InitFromXml</a> (GisXmlSaxContext *pContext, GisXmlAttributeCollection *attrs)</td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">FDOSHP_API void </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_property_definition_9f411822896503e8e305bcd5baa501c3.html#9f411822896503e8e305bcd5baa501c3">SetColumn</a> (<a class="el" href="class_fdo_shp_column_definition.html">FdoShpColumnDefinition</a> *definition)</td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDOSHP_API GisBoolean </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_property_definition_2961dfcc8cb657ce57689f56c9764fec.html#2961dfcc8cb657ce57689f56c9764fec">XmlEndElement</a> (GisXmlSaxContext *context, GisString *uri, GisString *name, GisString *qname)</td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDOSHP_API GisXmlSaxHandler * </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_property_definition_3530f2250ead9a4f2589dfcf013b23b4.html#3530f2250ead9a4f2589dfcf013b23b4">XmlStartElement</a> (GisXmlSaxContext *context, GisString *uri, GisString *name, GisString *qname, GisXmlAttributeCollection *atts)</td></tr>
+<tr><td colspan="2"><br><h2>Static Public Member Functions</h2></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">static FDOSHP_API <a class="el" href="class_fdo_shp_property_definition.html">FdoShpPropertyDefinition</a> * </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_property_definition_a603b74205bc257c10b7bc068f516292.html#a603b74205bc257c10b7bc068f516292">Create</a> ()</td></tr>
+</table>
+<hr>The documentation for this class was generated from the following file:<ul>
+<li><a class="el" href="_fdo_shp_property_definition_8h-source.html">FdoShpPropertyDefinition.h</a></ul>
+<!-- footer.html -->
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_property_definition_20d2033a8034eaed4bfef6d0e3eabaab.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_property_definition_20d2033a8034eaed4bfef6d0e3eabaab.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_property_definition_20d2033a8034eaed4bfef6d0e3eabaab.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,92 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="nav">
+<a class="el" href="class_fdo_shp_property_definition.html">FdoShpPropertyDefinition</a></div>
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_property_definition_ca026498f207e7542714e2094301f456.html#ca026498f207e7542714e2094301f456">_writeXml</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_property_definition_a603b74205bc257c10b7bc068f516292.html#a603b74205bc257c10b7bc068f516292">Create</a></td></tr>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_property_definition_20d2033a8034eaed4bfef6d0e3eabaab.html#20d2033a8034eaed4bfef6d0e3eabaab">GetColumn</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_property_definition_e2292de181258077b5faa7c1a62c80eb.html#e2292de181258077b5faa7c1a62c80eb">InitFromXml</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_property_definition_9f411822896503e8e305bcd5baa501c3.html#9f411822896503e8e305bcd5baa501c3">SetColumn</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_property_definition_2961dfcc8cb657ce57689f56c9764fec.html#2961dfcc8cb657ce57689f56c9764fec">XmlEndElement</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_property_definition_3530f2250ead9a4f2589dfcf013b23b4.html#3530f2250ead9a4f2589dfcf013b23b4">XmlStartElement</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="20d2033a8034eaed4bfef6d0e3eabaab"></a><!-- doxytag: member="FdoShpPropertyDefinition::GetColumn" ref="20d2033a8034eaed4bfef6d0e3eabaab" args="() const " --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">FDOSHP_API <a class="el" href="class_fdo_shp_column_definition.html">FdoShpColumnDefinition</a>* FdoShpPropertyDefinition::GetColumn </td>
+ <td class="md" nowrap> const</td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_property_definition_2961dfcc8cb657ce57689f56c9764fec.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_property_definition_2961dfcc8cb657ce57689f56c9764fec.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_property_definition_2961dfcc8cb657ce57689f56c9764fec.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,114 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_property_definition_20d2033a8034eaed4bfef6d0e3eabaab.html#20d2033a8034eaed4bfef6d0e3eabaab">GetColumn</a></td></tr>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_property_definition_2961dfcc8cb657ce57689f56c9764fec.html#2961dfcc8cb657ce57689f56c9764fec">XmlEndElement</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="2961dfcc8cb657ce57689f56c9764fec"></a><!-- doxytag: member="FdoShpPropertyDefinition::XmlEndElement" ref="2961dfcc8cb657ce57689f56c9764fec" args="(GisXmlSaxContext *context, GisString *uri, GisString *name, GisString *qname)" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual FDOSHP_API GisBoolean FdoShpPropertyDefinition::XmlEndElement </td>
+ <td class="md" nowrap valign="top">GisXmlSaxContext * </td>
+ <td class="mdname" nowrap> <em>context</em>, </td>
+ </tr>
+ <tr>
+ <td class="md" nowrap align="right"></td>
+ <td class="md"></td>
+ <td class="md" nowrap>GisString * </td>
+ <td class="mdname" nowrap> <em>uri</em>, </td>
+ </tr>
+ <tr>
+ <td class="mdname" nowrap> <em>name</em>, </td>
+ </tr>
+ <tr>
+ <td class="mdname" nowrap> <em>qname</em></td>
+ </tr>
+ <tr>
+ <td class="md">) </td>
+ <td class="md" colspan="2"><code> [virtual]</code></td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_property_definition_3530f2250ead9a4f2589dfcf013b23b4.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_property_definition_3530f2250ead9a4f2589dfcf013b23b4.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_property_definition_3530f2250ead9a4f2589dfcf013b23b4.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,120 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_property_definition_3530f2250ead9a4f2589dfcf013b23b4.html#3530f2250ead9a4f2589dfcf013b23b4">XmlStartElement</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="3530f2250ead9a4f2589dfcf013b23b4"></a><!-- doxytag: member="FdoShpPropertyDefinition::XmlStartElement" ref="3530f2250ead9a4f2589dfcf013b23b4" args="(GisXmlSaxContext *context, GisString *uri, GisString *name, GisString *qname, GisXmlAttributeCollection *atts)" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual FDOSHP_API GisXmlSaxHandler* FdoShpPropertyDefinition::XmlStartElement </td>
+ </tr>
+ <tr>
+ </tr>
+ <tr>
+ </tr>
+ <tr>
+ <td class="mdname" nowrap> <em>qname</em>, </td>
+ </tr>
+ <tr>
+ <td class="md" nowrap>GisXmlAttributeCollection * </td>
+ <td class="mdname" nowrap> <em>atts</em></td>
+ </tr>
+ <tr>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_property_definition_9f411822896503e8e305bcd5baa501c3.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_property_definition_9f411822896503e8e305bcd5baa501c3.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_property_definition_9f411822896503e8e305bcd5baa501c3.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,93 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_property_definition_9f411822896503e8e305bcd5baa501c3.html#9f411822896503e8e305bcd5baa501c3">SetColumn</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="9f411822896503e8e305bcd5baa501c3"></a><!-- doxytag: member="FdoShpPropertyDefinition::SetColumn" ref="9f411822896503e8e305bcd5baa501c3" args="(FdoShpColumnDefinition *definition)" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">FDOSHP_API void FdoShpPropertyDefinition::SetColumn </td>
+ <td class="md" nowrap valign="top"><a class="el" href="class_fdo_shp_column_definition.html">FdoShpColumnDefinition</a> * </td>
+ <td class="mdname1" valign="top" nowrap> <em>definition</em> </td>
+ <td class="md" nowrap></td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_property_definition_a603b74205bc257c10b7bc068f516292.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_property_definition_a603b74205bc257c10b7bc068f516292.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_property_definition_a603b74205bc257c10b7bc068f516292.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,92 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_property_definition_a603b74205bc257c10b7bc068f516292.html#a603b74205bc257c10b7bc068f516292">Create</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="a603b74205bc257c10b7bc068f516292"></a><!-- doxytag: member="FdoShpPropertyDefinition::Create" ref="a603b74205bc257c10b7bc068f516292" args="()" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">static FDOSHP_API <a class="el" href="class_fdo_shp_property_definition.html">FdoShpPropertyDefinition</a>* FdoShpPropertyDefinition::Create </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_property_definition_ca026498f207e7542714e2094301f456.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_property_definition_ca026498f207e7542714e2094301f456.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_property_definition_ca026498f207e7542714e2094301f456.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,102 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_property_definition_ca026498f207e7542714e2094301f456.html#ca026498f207e7542714e2094301f456">_writeXml</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="ca026498f207e7542714e2094301f456"></a><!-- doxytag: member="FdoShpPropertyDefinition::_writeXml" ref="ca026498f207e7542714e2094301f456" args="(GisXmlWriter *xmlWriter, const FdoXmlFlags *flags)" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual FDOSHP_API void FdoShpPropertyDefinition::_writeXml </td>
+ <td class="md" nowrap valign="top">GisXmlWriter * </td>
+ <td class="mdname" nowrap> <em>xmlWriter</em>, </td>
+ </tr>
+ <tr>
+ <td class="md" nowrap>const FdoXmlFlags * </td>
+ <td class="mdname" nowrap> <em>flags</em></td>
+ </tr>
+ <tr>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_property_definition_collection-members.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_property_definition_collection-members.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_property_definition_collection-members.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,54 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>FdoShpPropertyDefinitionCollection Member List</h1>This is the complete list of members for <a class="el" href="class_fdo_shp_property_definition_collection.html">FdoShpPropertyDefinitionCollection</a>, including all inherited members.<p><table>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_property_definition_collection_6b3823628fb7e5e0833d9110c5128d07.html#6b3823628fb7e5e0833d9110c5128d07">Create</a>()</td><td><a class="el" href="class_fdo_shp_property_definition_collection.html">FdoShpPropertyDefinitionCollection</a></td><td><code> [static]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_property_definition_collection_f78776eddbd77318ae7278ed70d2eb29.html#f78776eddbd77318ae7278ed70d2eb29">Create</a>(FdoPhysicalElementMapping *parent)</td><td><a class="el" href="class_fdo_shp_property_definition_collection.html">FdoShpPropertyDefinitionCollection</a></td><td><code> [static]</code></td></tr>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_property_definition_collection.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_property_definition_collection.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_property_definition_collection.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,68 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li><a href="files.html"><span>Files</span></a></li>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>FdoShpPropertyDefinitionCollection Class Reference</h1><!-- doxytag: class="FdoShpPropertyDefinitionCollection" --><code>#include <<a class="el" href="_fdo_shp_property_definition_collection_8h-source.html">FdoShpPropertyDefinitionCollection.h</a>></code>
+<p>
+<a href="class_fdo_shp_property_definition_collection-members.html">List of all members.</a><hr><a name="_details"></a><h2>Detailed Description</h2>
+<p>
+<p>
+Definition at line <a class="el" href="_fdo_shp_property_definition_collection_8h-source.html#l00026">26</a> of file <a class="el" href="_fdo_shp_property_definition_collection_8h-source.html">FdoShpPropertyDefinitionCollection.h</a>.<table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">static FDOSHP_API <a class="el" href="class_fdo_shp_property_definition_collection.html">FdoShpPropertyDefinitionCollection</a> * </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_property_definition_collection_f78776eddbd77318ae7278ed70d2eb29.html#f78776eddbd77318ae7278ed70d2eb29">Create</a> (FdoPhysicalElementMapping *parent)</td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">static FDOSHP_API <a class="el" href="class_fdo_shp_property_definition_collection.html">FdoShpPropertyDefinitionCollection</a> * </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_property_definition_collection_6b3823628fb7e5e0833d9110c5128d07.html#6b3823628fb7e5e0833d9110c5128d07">Create</a> ()</td></tr>
+</table>
+<li><a class="el" href="_fdo_shp_property_definition_collection_8h-source.html">FdoShpPropertyDefinitionCollection.h</a></ul>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_property_definition_collection_6b3823628fb7e5e0833d9110c5128d07.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_property_definition_collection_6b3823628fb7e5e0833d9110c5128d07.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_property_definition_collection_6b3823628fb7e5e0833d9110c5128d07.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,87 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="nav">
+<a class="el" href="class_fdo_shp_property_definition_collection.html">FdoShpPropertyDefinitionCollection</a></div>
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_property_definition_collection_6b3823628fb7e5e0833d9110c5128d07.html#6b3823628fb7e5e0833d9110c5128d07">Create</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_property_definition_collection_f78776eddbd77318ae7278ed70d2eb29.html#f78776eddbd77318ae7278ed70d2eb29">Create</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="6b3823628fb7e5e0833d9110c5128d07"></a><!-- doxytag: member="FdoShpPropertyDefinitionCollection::Create" ref="6b3823628fb7e5e0833d9110c5128d07" args="()" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">static FDOSHP_API <a class="el" href="class_fdo_shp_property_definition_collection.html">FdoShpPropertyDefinitionCollection</a>* FdoShpPropertyDefinitionCollection::Create </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_property_definition_collection_f78776eddbd77318ae7278ed70d2eb29.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_property_definition_collection_f78776eddbd77318ae7278ed70d2eb29.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_property_definition_collection_f78776eddbd77318ae7278ed70d2eb29.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,88 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_property_definition_collection_6b3823628fb7e5e0833d9110c5128d07.html#6b3823628fb7e5e0833d9110c5128d07">Create</a></td></tr>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_property_definition_collection_f78776eddbd77318ae7278ed70d2eb29.html#f78776eddbd77318ae7278ed70d2eb29">Create</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="f78776eddbd77318ae7278ed70d2eb29"></a><!-- doxytag: member="FdoShpPropertyDefinitionCollection::Create" ref="f78776eddbd77318ae7278ed70d2eb29" args="(FdoPhysicalElementMapping *parent)" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">FdoPhysicalElementMapping * </td>
+ <td class="mdname1" valign="top" nowrap> <em>parent</em> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_property_definition_e2292de181258077b5faa7c1a62c80eb.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_property_definition_e2292de181258077b5faa7c1a62c80eb.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_property_definition_e2292de181258077b5faa7c1a62c80eb.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,102 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_property_definition_e2292de181258077b5faa7c1a62c80eb.html#e2292de181258077b5faa7c1a62c80eb">InitFromXml</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="e2292de181258077b5faa7c1a62c80eb"></a><!-- doxytag: member="FdoShpPropertyDefinition::InitFromXml" ref="e2292de181258077b5faa7c1a62c80eb" args="(GisXmlSaxContext *pContext, GisXmlAttributeCollection *attrs)" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual FDOSHP_API void FdoShpPropertyDefinition::InitFromXml </td>
+ <td class="mdname" nowrap> <em>pContext</em>, </td>
+ </tr>
+ <tr>
+ <td class="mdname" nowrap> <em>attrs</em></td>
+ </tr>
+ <tr>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/classes.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/classes.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/classes.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,55 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li id="current"><a href="classes.html"><span>Alphabetical List</span></a></li>
+ </ul></div>
+<h1>FDO Provider for SHP Class Index</h1><p><div class="qindex"><a class="qindex" href="#letter_F">F</a></div><p>
+<table align="center" width="95%" border="0" cellspacing="0" cellpadding="0">
+<tr><td><a name="letter_F"></a><table border="0" cellspacing="0" cellpadding="0"><tr><td><div class="ah"> F </div></td></tr></table>
+</td><td><a class="el" href="class_fdo_shp_class_definition.html">FdoShpClassDefinition</a> </td><td><a class="el" href="class_fdo_shp_physical_schema_mapping.html">FdoShpPhysicalSchemaMapping</a> </td><td><a class="el" href="class_fdo_shp_property_definition.html">FdoShpPropertyDefinition</a> </td><td><a class="el" href="class_fdo_shp_property_definition_collection.html">FdoShpPropertyDefinitionCollection</a> </td></tr><tr><td><a class="el" href="class_fdo_shp_class_collection.html">FdoShpClassCollection</a> </td><td><a class="el" href="class_fdo_shp_column_definition.html">FdoShpColumnDefinition</a> </td></tr></table><p><div class="qindex"><a class="qindex" href="#letter_F">F</a></div><p>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/custom.css
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/custom.css?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/custom.css 2006-03-06 21:40:50+0000
@@ -0,0 +1,96 @@
+ at import url(doxygen.css);
+div.Syntax{
+ background-color:#FFFFD9;
+div.Example{
+ background-color:#E9E9E9;
+/* table cells on the main page (index.html) */
+div.mainpage td {
+ background-color: #FFFFCC;
+ border-right-color: #FF6633;
+ border-bottom-color: #FF6633;
+ border-left-color: #FFCC33;
+ border-top-color: #FFCC33;
+ text-align: center;
+/*** Used in external topics ***/
+p.indent_1 {
+ padding-left: 0.25in;
+p.indent_2 {
+ padding-left: 0.5in;
+p.indent_3 {
+ padding-left: 0.75in;
+table.RuledTable {
+ border-collapse: collapse;
+ table-layout: auto;
+ width: auto;
+ cellpadding: none;
+ cellspacing: none;
+table.RuledTable th {
+ background-color: #CCCCCC;
+ border-left-style: solid;
+ border-left-width: thin;
+ border-left-color: #000000;
+ border-right-style: solid;
+ border-right-width: thin;
+ border-right-color: #000000;
+ border-bottom-style: solid;
+ border-bottom-width: thin;
+ border-bottom-color: #000000;
+ border-top-style: solid;
+ border-top-width: thin;
+ border-top-color: #000000;
+ padding: 6px;
+ width: auto;
+table.RuledTable td {
+ padding-left: 6px;
+ padding-right: 6px;
+ padding-top: 4px;
+ padding-top: 4px;
+ width: auto;
+td.shaded{
+ background-color:#CCCCCC;
+/* Used in Geometry_AgfText.h */
+p.row_1 {
+ font-family: "Courier New", Courier, monospace;
+pre.row_2 {
+ background-color: #E7FFCE;
Added: trunk/www/docs/SHP/define__pages_8h-source.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/define__pages_8h-source.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/define__pages_8h-source.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,95 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li id="current"><a href="files.html"><span>Files</span></a></li>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li><a href="files.html"><span>File List</span></a></li>
+ <li><a href="globals.html"><span>File Members</span></a></li>
+ </ul></div>
+<h1>define_pages.h</h1><a href="define__pages_8h.html">Go to the documentation of this file.</a><div class="fragment"><pre class="fragment"><a name="l00001"></a>00001 <span class="comment">/*! \mainpage Introduction</span>
+<a name="l00002"></a>00002 <span class="comment"><div class="mainpage"></span>
+<a name="l00003"></a>00003 <span class="comment"><!-- This is the index.html page that the user first sees. --></span>
+<a name="l00004"></a>00004 <span class="comment"></span>
+<a name="l00005"></a>00005 <span class="comment"><p>The Feature Data Objects (FDO) API provides access to data in a </span>
+<a name="l00006"></a>00006 <span class="comment">data store. A provider is a specific implementation of the FDO API </span>
+<a name="l00007"></a>00007 <span class="comment">that provides access to data in a particular data store. The FDO </span>
+<a name="l00008"></a>00008 <span class="comment">Provider for SHP provides FDO with access to a SHP-based data store.</span>
+<a name="l00009"></a>00009 <span class="comment"></p></span>
+<a name="l00010"></a>00010 <span class="comment"><p>The FDO Provider for SHP uses a standalone file format that</span>
+<a name="l00011"></a>00011 <span class="comment">supports GIS data. The FDO Provider for SHP (Shape) has the </span>
+<a name="l00012"></a>00012 <span class="comment">following characteristics: </span>
+<a name="l00013"></a>00013 <span class="comment"></p></span>
+<a name="l00014"></a>00014 <span class="comment"><ul></span>
+<a name="l00015"></a>00015 <span class="comment"> <li> Read-only access is provided to pre-existing</span>
+<a name="l00016"></a>00016 <span class="comment"> spatial and attribute data from an Environmental Systems</span>
+<a name="l00017"></a>00017 <span class="comment"> Research Institute (ESRI) Shape file (SHP).</span>
+<a name="l00018"></a>00018 <span class="comment"> <li> The FDO Provider for SHP can run in a multi-platform environment,</span>
+<a name="l00019"></a>00019 <span class="comment"> including Windows and Linux.</span>
+<a name="l00020"></a>00020 <span class="comment"> <li> A Shape file consists of three separate files: SHP (shape</span>
+<a name="l00021"></a>00021 <span class="comment"> geometry), SHX (shape index), and DBF (shape attributes in</span>
+<a name="l00022"></a>00022 <span class="comment"> dBASE format).</span>
+<a name="l00023"></a>00023 <span class="comment"> <li> The FDO Provider for SHP accesses the information in each of the </span>
+<a name="l00024"></a>00024 <span class="comment"> three separate files, and treats each SHP, and its associated DBF file, </span>
+<a name="l00025"></a>00025 <span class="comment"> as a feature class with a single geometry property, and optionally, </span>
+<a name="l00026"></a>00026 <span class="comment"> with data attribute properties.</span>
+<a name="l00027"></a>00027 <span class="comment"> <li> Schema configuration of the data store is provided to the</span>
+<a name="l00028"></a>00028 <span class="comment"> FDO Provider for SHP through an XML file containing the</span>
+<a name="l00029"></a>00029 <span class="comment"> Geographic Markup Language (GML) definition of the schema</span>
+<a name="l00030"></a>00030 <span class="comment"> that maps SHP and DBF data in the data store to feature</span>
+<a name="l00031"></a>00031 <span class="comment"> classes and property mappings in the FDO data model.</span>
+<a name="l00032"></a>00032 <span class="comment"> <li> Although it does not support concurrency control (locking), the SHP </span>
+<a name="l00033"></a>00033 <span class="comment"> file format is a valid alternative to RDBMS.</span>
+<a name="l00034"></a>00034 <span class="comment"></ul></span>
+<a name="l00035"></a>00035 <span class="comment"><p></span>
+<a name="l00036"></a>00036 <span class="comment">For more information, see <i>The Essential FDO</i> (FET_TheEssentialFDO.pdf) </span>
+<a name="l00037"></a>00037 <span class="comment">and the <i>FDO Developer's Guide</i> (FDG_FDODevGuide.pdf).</span>
+<a name="l00038"></a>00038 <span class="comment"></p></span>
+<a name="l00039"></a>00039 <span class="comment"></span>
+<a name="l00040"></a>00040 <span class="comment"><br></span>
+<a name="l00041"></a>00041 <span class="comment"></div></span>
+<a name="l00042"></a>00042 <span class="comment">*/</span>
+<a name="l00043"></a>00043
+<a name="l00044"></a>00044
+<a name="l00045"></a>00045
+<a name="l00046"></a>00046
+</pre></div><!-- footer.html -->
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/define__pages_8h.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/define__pages_8h.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/define__pages_8h.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,56 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>define_pages.h File Reference</h1>
+<p>
+<p>
+<a href="define__pages_8h-source.html">Go to the source code of this file.</a><table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/doxygen.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/doxygen.png?view=auto&rev=4
Binary file. No diff available.
Added: trunk/www/docs/SHP/files.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/files.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/files.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,58 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li id="current"><a href="files.html"><span>File List</span></a></li>
+ </ul></div>
+<h1>FDO Provider for SHP File List</h1>Here is a list of all files with brief descriptions:<table>
+ <tr><td class="indexkey"><a class="el" href="define__pages_8h.html">define_pages.h</a> <a href="define__pages_8h-source.html">[code]</a></td><td class="indexvalue"></td></tr>
+ <tr><td class="indexkey"><a class="el" href="_fdo_shp_class_collection_8h.html">FdoShpClassCollection.h</a> <a href="_fdo_shp_class_collection_8h-source.html">[code]</a></td><td class="indexvalue"></td></tr>
+ <tr><td class="indexkey"><a class="el" href="_fdo_shp_class_definition_8h.html">FdoShpClassDefinition.h</a> <a href="_fdo_shp_class_definition_8h-source.html">[code]</a></td><td class="indexvalue"></td></tr>
+ <tr><td class="indexkey"><a class="el" href="_fdo_shp_column_definition_8h.html">FdoShpColumnDefinition.h</a> <a href="_fdo_shp_column_definition_8h-source.html">[code]</a></td><td class="indexvalue"></td></tr>
+ <tr><td class="indexkey"><a class="el" href="_fdo_shp_physical_schema_mapping_8h.html">FdoShpPhysicalSchemaMapping.h</a> <a href="_fdo_shp_physical_schema_mapping_8h-source.html">[code]</a></td><td class="indexvalue"></td></tr>
+ <tr><td class="indexkey"><a class="el" href="_fdo_shp_property_definition_8h.html">FdoShpPropertyDefinition.h</a> <a href="_fdo_shp_property_definition_8h-source.html">[code]</a></td><td class="indexvalue"></td></tr>
+ <tr><td class="indexkey"><a class="el" href="_fdo_shp_property_definition_collection_8h.html">FdoShpPropertyDefinitionCollection.h</a> <a href="_fdo_shp_property_definition_collection_8h-source.html">[code]</a></td><td class="indexvalue"></td></tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/ftv2blank.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/ftv2blank.png?view=auto&rev=4
Added: trunk/www/docs/SHP/ftv2doc.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/ftv2doc.png?view=auto&rev=4
Added: trunk/www/docs/SHP/ftv2folderclosed.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/ftv2folderclosed.png?view=auto&rev=4
Added: trunk/www/docs/SHP/ftv2folderopen.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/ftv2folderopen.png?view=auto&rev=4
Added: trunk/www/docs/SHP/ftv2lastnode.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/ftv2lastnode.png?view=auto&rev=4
Added: trunk/www/docs/SHP/ftv2link.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/ftv2link.png?view=auto&rev=4
Added: trunk/www/docs/SHP/ftv2mlastnode.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/ftv2mlastnode.png?view=auto&rev=4
Added: trunk/www/docs/SHP/ftv2mnode.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/ftv2mnode.png?view=auto&rev=4
Added: trunk/www/docs/SHP/ftv2node.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/ftv2node.png?view=auto&rev=4
Added: trunk/www/docs/SHP/ftv2plastnode.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/ftv2plastnode.png?view=auto&rev=4
Added: trunk/www/docs/SHP/ftv2pnode.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/ftv2pnode.png?view=auto&rev=4
Added: trunk/www/docs/SHP/ftv2vertline.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/ftv2vertline.png?view=auto&rev=4
Added: trunk/www/docs/SHP/functions.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/functions.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/functions.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,78 @@
+<html>
+ <head>
+ <title>OSGeo FDO Provider for SHP API Reference</title>
+ </head>
+ <tr>
+ <td align="right"><b>OSGeo FDO Provider for SHP<b></td>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li>
+ <form action="search.php" method="get">
+ <table cellspacing="0" cellpadding="0" border="0">
+ <tr>
+ <td><label> <u>S</u>earch for </label></td>
+ <td><input type="text" name="query" value="" size="20" accesskey="s"/></td>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li id="current"><a href="functions.html"><span>Class Members</span></a></li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li id="current"><a href="functions.html"><span>All</span></a></li>
+ <li><a href="functions_func.html"><span>Functions</span></a></li>
+ </ul>
+</div>
+Here is a list of all class members with links to the classes they belong to:
+<p>
+<ul>
+<li>_writeXml()
+: <a class="el" href="class_fdo_shp_property_definition_ca026498f207e7542714e2094301f456.html#ca026498f207e7542714e2094301f456">FdoShpPropertyDefinition</a>, <a class="el" href="class_fdo_shp_physical_schema_mapping_36448c6a7557f454b949b605a6c80129.html#36448c6a7557f454b949b605a6c80129">FdoShpPhysicalSchemaMapping</a>, <a class="el" href="class_fdo_shp_column_definition_955c02380b27a475d2f00ad14568a2ae.html#955c02380b27a475d2f00ad14568a2ae">FdoShpColumnDefinition</a>, <a class="el" href="class_fdo_shp_class_definition_3d19e7886b05e4cfa5fb5371890ab97f.html#3d19e7886b05e4cfa5fb5371890ab97f">FdoShpClassDefinition</a><li>Create()
+: <a class="el" href="class_fdo_shp_property_definition_collection_f78776eddbd77318ae7278ed70d2eb29.html#f78776eddbd77318ae7278ed70d2eb29">FdoShpPropertyDefinitionCollection</a>, <a class="el" href="class_fdo_shp_property_definition_a603b74205bc257c10b7bc068f516292.html#a603b74205bc257c10b7bc068f516292">FdoShpPropertyDefinition</a>, <a class="el" href="class_fdo_shp_physical_schema_mapping_48e086264cd4780a442f8ecb841faea8.html#48e086264cd4780a442f8ecb841faea8">FdoShpPhysicalSchemaMapping</a>, <a class="el" href="class_fdo_shp_column_definition_4ba0b1a32d4f0126a9a5079eab9fe025.html#4ba0b1a32d4f0126a9a5079eab9fe025">FdoShpColumnDefinition</a>, <a class="el" href="class_fdo_shp_class_definition_96936568a01aa49e3ef3fbb154fa5ad5.html#96936568a01aa49e3ef3fbb154fa5ad5">FdoShpClassDefinition</a>, <a class="el" href="class_fdo_shp_class_collection_523f8784b5a62bfd9a00ffb621bac528.html#523f8784b5a62bfd9a00ffb621bac528">FdoShpClassCollection</a><li>FindByClassName()
+: <a class="el" href="class_fdo_shp_physical_schema_mapping_cc639fa3a2ae6823d20042cc95f06dae.html#cc639fa3a2ae6823d20042cc95f06dae">FdoShpPhysicalSchemaMapping</a><li>FindByColumnName()
+: <a class="el" href="class_fdo_shp_class_definition_c3f943759f93d8173aacc9ce12c8feee.html#c3f943759f93d8173aacc9ce12c8feee">FdoShpClassDefinition</a><li>FindByShapefile()
+: <a class="el" href="class_fdo_shp_physical_schema_mapping_bb73c56d22638012ed655b6a276e75db.html#bb73c56d22638012ed655b6a276e75db">FdoShpPhysicalSchemaMapping</a><li>GetClasses()
+: <a class="el" href="class_fdo_shp_physical_schema_mapping_4d944a128be1ad6406974f8375f12f69.html#4d944a128be1ad6406974f8375f12f69">FdoShpPhysicalSchemaMapping</a><li>GetColumn()
+: <a class="el" href="class_fdo_shp_property_definition_20d2033a8034eaed4bfef6d0e3eabaab.html#20d2033a8034eaed4bfef6d0e3eabaab">FdoShpPropertyDefinition</a><li>GetProperties()
+: <a class="el" href="class_fdo_shp_class_definition_bdc54fa302f857e4acc9a0c3660dd245.html#bdc54fa302f857e4acc9a0c3660dd245">FdoShpClassDefinition</a><li>GetProvider()
+: <a class="el" href="class_fdo_shp_physical_schema_mapping_45d51d0f0311ff85ed516136e2ce16f6.html#45d51d0f0311ff85ed516136e2ce16f6">FdoShpPhysicalSchemaMapping</a><li>GetShapeFile()
+: <a class="el" href="class_fdo_shp_class_definition_4603016faf3795e4c4544f71e0fb4152.html#4603016faf3795e4c4544f71e0fb4152">FdoShpClassDefinition</a><li>InitFromXml()
+: <a class="el" href="class_fdo_shp_property_definition_e2292de181258077b5faa7c1a62c80eb.html#e2292de181258077b5faa7c1a62c80eb">FdoShpPropertyDefinition</a>, <a class="el" href="class_fdo_shp_physical_schema_mapping_852853e469120e86223be6db80bccb20.html#852853e469120e86223be6db80bccb20">FdoShpPhysicalSchemaMapping</a>, <a class="el" href="class_fdo_shp_column_definition_600ecd1991fa387cc926316543de81e8.html#600ecd1991fa387cc926316543de81e8">FdoShpColumnDefinition</a>, <a class="el" href="class_fdo_shp_class_definition_daed9b86862ad2148b72edadbbcf479e.html#daed9b86862ad2148b72edadbbcf479e">FdoShpClassDefinition</a><li>IsPathUpdated()
+: <a class="el" href="class_fdo_shp_class_definition_b9340be1c7d393ddedcf670de2149d76.html#b9340be1c7d393ddedcf670de2149d76">FdoShpClassDefinition</a><li>SetColumn()
+: <a class="el" href="class_fdo_shp_property_definition_9f411822896503e8e305bcd5baa501c3.html#9f411822896503e8e305bcd5baa501c3">FdoShpPropertyDefinition</a><li>SetPathUpdated()
+: <a class="el" href="class_fdo_shp_class_definition_cb66f23743bb45b0e3faaa2bfafeaad8.html#cb66f23743bb45b0e3faaa2bfafeaad8">FdoShpClassDefinition</a><li>SetShapeFile()
+: <a class="el" href="class_fdo_shp_class_definition_2e617c437f74fe496aac753fb7666146.html#2e617c437f74fe496aac753fb7666146">FdoShpClassDefinition</a><li>XmlEndElement()
+: <a class="el" href="class_fdo_shp_property_definition_2961dfcc8cb657ce57689f56c9764fec.html#2961dfcc8cb657ce57689f56c9764fec">FdoShpPropertyDefinition</a>, <a class="el" href="class_fdo_shp_physical_schema_mapping_7c0b1de21670db480e4463bcecfce94b.html#7c0b1de21670db480e4463bcecfce94b">FdoShpPhysicalSchemaMapping</a>, <a class="el" href="class_fdo_shp_column_definition_c9d77b68d5f4a385142690b92d0e7ef9.html#c9d77b68d5f4a385142690b92d0e7ef9">FdoShpColumnDefinition</a>, <a class="el" href="class_fdo_shp_class_definition_1eb8e1be10f1d92361eacbbdc50a0677.html#1eb8e1be10f1d92361eacbbdc50a0677">FdoShpClassDefinition</a><li>XmlStartElement()
+: <a class="el" href="class_fdo_shp_property_definition_3530f2250ead9a4f2589dfcf013b23b4.html#3530f2250ead9a4f2589dfcf013b23b4">FdoShpPropertyDefinition</a>, <a class="el" href="class_fdo_shp_physical_schema_mapping_af942717804976ecf3233c259650fb48.html#af942717804976ecf3233c259650fb48">FdoShpPhysicalSchemaMapping</a>, <a class="el" href="class_fdo_shp_column_definition_d5669958dfaeb362578fde7cac156561.html#d5669958dfaeb362578fde7cac156561">FdoShpColumnDefinition</a>, <a class="el" href="class_fdo_shp_class_definition_95b2357abf02d1278ac66f01921db44b.html#95b2357abf02d1278ac66f01921db44b">FdoShpClassDefinition</a></ul>
+ <hr>
+ <table width="100%" border="0">
+ <tr>
+ <td align="right"><font size="-2"><a href="mailto:isd.docs at autodesk.com&subject=FDO%20Provider%20for%20SHP%20API%20documentation">Comments?</a></font></td>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/functions_func.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/functions_func.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/functions_func.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,78 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
+<html>
+ <head>
+ <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
+ <link href="custom.css" rel="stylesheet" type="text/css">
+ <link href="tabs.css" rel="stylesheet" type="text/css">
+ </head>
+ <body bgcolor="#FFFFFF">
+ <tr>
+ <td><b>API Reference<b></td>
+ </tr>
+ </table>
+<!-- End of: header.html -->
+<!-- Generated by Doxygen 1.4.6-NO -->
+<div class="tabs">
+ <ul>
+ <li><a href="main.html"><span>Main Page</span></a></li>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li><a href="functions.html"><span>All</span></a></li>
+ <li id="current"><a href="functions_func.html"><span>Functions</span></a></li>
+ </ul>
+</div>
+<p>
+<ul>
+<li>_writeXml()
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/globals.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/globals.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/globals.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,65 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li id="current"><a href="globals.html"><span>File Members</span></a></li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li id="current"><a href="globals.html"><span>All</span></a></li>
+ <li><a href="globals_type.html"><span>Typedefs</span></a></li>
+ </ul>
+</div>
+Here is a list of all file members with links to the files they belong to:
+<p>
+<ul>
+<li>FdoShpClassCollectionP
+: <a class="el" href="_fdo_shp_class_collection_8h_14b881fe200a848b2f39736eec0557f3.html#14b881fe200a848b2f39736eec0557f3">FdoShpClassCollection.h</a><li>FdoShpClassDefinitionP
+: <a class="el" href="_fdo_shp_class_definition_8h_4e85e161f3a61d5a480c8d71c3bfd4ff.html#4e85e161f3a61d5a480c8d71c3bfd4ff">FdoShpClassDefinition.h</a><li>FdoShpColumnDefinitionP
+: <a class="el" href="_fdo_shp_column_definition_8h_8542aa83f9163bd323db446eb4e1035d.html#8542aa83f9163bd323db446eb4e1035d">FdoShpColumnDefinition.h</a><li>FdoShpPhysicalSchemaMappingP
+: <a class="el" href="_fdo_shp_physical_schema_mapping_8h_a6ba1b4d1f4f7db9e0005451ac2cb3f5.html#a6ba1b4d1f4f7db9e0005451ac2cb3f5">FdoShpPhysicalSchemaMapping.h</a><li>FdoShpPropertyDefinitionCollectionP
+: <a class="el" href="_fdo_shp_property_definition_collection_8h_7d1d57dbcd029bc5b5d15fd32f2e165e.html#7d1d57dbcd029bc5b5d15fd32f2e165e">FdoShpPropertyDefinitionCollection.h</a><li>FdoShpPropertyDefinitionP
+: <a class="el" href="_fdo_shp_property_definition_8h_d0b59a42138824423a735f567bc1a47c.html#d0b59a42138824423a735f567bc1a47c">FdoShpPropertyDefinition.h</a></ul>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/globals_type.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/globals_type.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/globals_type.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,65 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li><a href="classes.html"><span>Classes</span></a></li>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li><a href="globals.html"><span>All</span></a></li>
+ <li id="current"><a href="globals_type.html"><span>Typedefs</span></a></li>
+ </ul>
+</div>
+<p>
+<ul>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/graph_legend.dot
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/graph_legend.dot?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/graph_legend.dot 2006-03-06 21:40:50+0000
@@ -0,0 +1,22 @@
+digraph G
+ edge [fontname="Helvetica",fontsize=10,labelfontname="Helvetica",labelfontsize=10];
+ node [fontname="Helvetica",fontsize=10,shape=record];
+ Node9 [shape="box",label="Inherited",fontsize=10,height=0.2,width=0.4,fontname="Helvetica",color="black",style="filled" fontcolor="white"];
+ Node10 -> Node9 [dir=back,color="midnightblue",fontsize=10,style="solid",fontname="Helvetica"];
+ Node10 [shape="box",label="PublicBase",fontsize=10,height=0.2,width=0.4,fontname="Helvetica",color="black",URL="$classPublicBase.html"];
+ Node11 -> Node10 [dir=back,color="midnightblue",fontsize=10,style="solid",fontname="Helvetica"];
+ Node11 [shape="box",label="Truncated",fontsize=10,height=0.2,width=0.4,fontname="Helvetica",color="red",URL="$classTruncated.html"];
+ Node13 -> Node9 [dir=back,color="darkgreen",fontsize=10,style="solid",fontname="Helvetica"];
+ Node13 [shape="box",label="ProtectedBase",fontsize=10,height=0.2,width=0.4,fontname="Helvetica",color="black",URL="$classProtectedBase.html"];
+ Node14 -> Node9 [dir=back,color="firebrick4",fontsize=10,style="solid",fontname="Helvetica"];
+ Node14 [shape="box",label="PrivateBase",fontsize=10,height=0.2,width=0.4,fontname="Helvetica",color="black",URL="$classPrivateBase.html"];
+ Node15 -> Node9 [dir=back,color="midnightblue",fontsize=10,style="solid",fontname="Helvetica"];
+ Node15 [shape="box",label="Undocumented",fontsize=10,height=0.2,width=0.4,fontname="Helvetica",color="grey75"];
+ Node16 -> Node9 [dir=back,color="midnightblue",fontsize=10,style="solid",fontname="Helvetica"];
+ Node16 [shape="box",label="Templ< int >",fontsize=10,height=0.2,width=0.4,fontname="Helvetica",color="black",URL="$classTempl.html"];
+ Node17 -> Node16 [dir=back,color="orange",fontsize=10,style="dashed",label="< int >",fontname="Helvetica"];
+ Node17 [shape="box",label="Templ< T >",fontsize=10,height=0.2,width=0.4,fontname="Helvetica",color="black",URL="$classTempl.html"];
+ Node18 -> Node9 [dir=back,color="darkorchid3",fontsize=10,style="dashed",label="m_usedClass",fontname="Helvetica"];
+ Node18 [shape="box",label="Used",fontsize=10,height=0.2,width=0.4,fontname="Helvetica",color="black",URL="$classUsed.html"];
Added: trunk/www/docs/SHP/graph_legend.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/graph_legend.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/graph_legend.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,106 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<h1>Graph Legend</h1>This page explains how to interpret the graphs that are generated by doxygen.<p>
+Consider the following example: <div class="fragment"><pre class="fragment"><span class="comment">/*! Invisible class because of truncation */</span>
+<span class="keyword">class </span>Invisible { };
+<span class="comment"></span>
+<span class="comment">/*! Truncated class, inheritance relation is hidden */</span>
+<span class="keyword">class </span>Truncated : <span class="keyword">public</span> Invisible { };
+<span class="comment">/* Class not documented with doxygen comments */</span>
+<span class="keyword">class </span>Undocumented { };
+<span class="comment">/*! Class that is inherited using public inheritance */</span>
+<span class="keyword">class </span>PublicBase : <span class="keyword">public</span> Truncated { };
+<span class="comment">/*! A template class */</span>
+<span class="keyword">template</span><<span class="keyword">class</span> T> <span class="keyword">class </span>Templ { };
+<span class="comment">/*! Class that is inherited using protected inheritance */</span>
+<span class="keyword">class </span>ProtectedBase { };
+<span class="comment">/*! Class that is inherited using private inheritance */</span>
+<span class="keyword">class </span>PrivateBase { };
+<span class="comment">/*! Class that is used by the Inherited class */</span>
+<span class="keyword">class </span>Used { };
+<span class="comment">/*! Super class that inherits a number of other classes */</span>
+<span class="keyword">class </span>Inherited : <span class="keyword">public</span> PublicBase,
+ <span class="keyword">protected</span> ProtectedBase,
+ <span class="keyword">private</span> PrivateBase,
+ <span class="keyword">public</span> Undocumented
+ <span class="keyword">public</span> Templ<int>
+ <span class="keyword">private</span>:
+ Used *m_usedClass;
+</pre></div> If the <code>MAX_DOT_GRAPH_HEIGHT</code> tag in the configuration file is set to 240 this will result in the following graph:<p>
+<center><div align="center">
+<img src="graph_legend.png" alt="graph_legend.png">
+</div>
+</center> <p>
+The boxes in the above graph have the following meaning: <ul>
+<li>
+A filled black box represents the struct or class for which the graph is generated. </li>
+<li>
+A box with a black border denotes a documented struct or class. </li>
+<li>
+A box with a grey border denotes an undocumented struct or class. </li>
+<li>
+A box with a red border denotes a documented struct or class forwhich not all inheritance/containment relations are shown. A graph is truncated if it does not fit within the specified boundaries. </li>
+</ul>
+The arrows have the following meaning: <ul>
+<li>
+A dark blue arrow is used to visualize a public inheritance relation between two classes. </li>
+<li>
+A dark green arrow is used for protected inheritance. </li>
+<li>
+A dark red arrow is used for private inheritance. </li>
+<li>
+A purple dashed arrow is used if a class is contained or used by another class. The arrow is labeled with the variable(s) through which the pointed class or struct is accessible. </li>
+<li>
+A yellow dashed arrow denotes a relation between a template instance and the template class it was instantiated from. The arrow is labeled with the template parameters of the instance. </li>
+</ul>
+ <hr>
+ <tr>
+ <!-- The logo can go in another cell, when we get one -->
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/graph_legend.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/graph_legend.png?view=auto&rev=4
Added: trunk/www/docs/SHP/hierarchy.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/hierarchy.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/hierarchy.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,61 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li id="current"><a href="hierarchy.html"><span>Class Hierarchy</span></a></li>
+ </ul></div>
+<h1>FDO Provider for SHP Class Hierarchy</h1><a href="inherits.html">Go to the graphical class hierarchy</a>
+<p>
+This inheritance list is sorted roughly, but not completely, alphabetically:<ul>
+<li><a class="el" href="class_fdo_shp_class_collection.html">FdoShpClassCollection</a>
+<li><a class="el" href="class_fdo_shp_class_definition.html">FdoShpClassDefinition</a>
+<li><a class="el" href="class_fdo_shp_column_definition.html">FdoShpColumnDefinition</a>
+<li><a class="el" href="class_fdo_shp_physical_schema_mapping.html">FdoShpPhysicalSchemaMapping</a>
+<li><a class="el" href="class_fdo_shp_property_definition.html">FdoShpPropertyDefinition</a>
+<li><a class="el" href="class_fdo_shp_property_definition_collection.html">FdoShpPropertyDefinitionCollection</a>
+</ul>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/index.hhc
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/index.hhc?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/index.hhc 2006-03-06 21:40:50+0000
@@ -0,0 +1,39 @@
+<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML//EN">
+<HTML><HEAD></HEAD><BODY>
+<OBJECT type="text/site properties">
+<param name="FrameName" value="right">
+</OBJECT>
+<UL>
+<LI><OBJECT type="text/sitemap"><param name="Name" value="Introduction"><param name="Local" value="main.html"><param name="ImageNumber" value="11"></OBJECT>
+<LI><OBJECT type="text/sitemap"><param name="Name" value="File List"><param name="ImageNumber" value="1"></OBJECT>
+ <UL>
+ <LI><OBJECT type="text/sitemap"><param name="Name" value="define_pages.h"><param name="Local" value="define__pages_8h.html"><param name="ImageNumber" value="11"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Name" value="FdoShpClassCollection.h"><param name="Local" value="_fdo_shp_class_collection_8h.html"><param name="ImageNumber" value="11"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Name" value="FdoShpClassDefinition.h"><param name="Local" value="_fdo_shp_class_definition_8h.html"><param name="ImageNumber" value="11"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Name" value="FdoShpColumnDefinition.h"><param name="Local" value="_fdo_shp_column_definition_8h.html"><param name="ImageNumber" value="11"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Name" value="FdoShpPhysicalSchemaMapping.h"><param name="Local" value="_fdo_shp_physical_schema_mapping_8h.html"><param name="ImageNumber" value="11"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Name" value="FdoShpPropertyDefinition.h"><param name="Local" value="_fdo_shp_property_definition_8h.html"><param name="ImageNumber" value="11"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Name" value="FdoShpPropertyDefinitionCollection.h"><param name="Local" value="_fdo_shp_property_definition_collection_8h.html"><param name="ImageNumber" value="11"></OBJECT>
+ </UL>
+<LI><OBJECT type="text/sitemap"><param name="Name" value="Class List"><param name="ImageNumber" value="1"></OBJECT>
+ <UL>
+ <LI><OBJECT type="text/sitemap"><param name="Name" value="FdoShpClassCollection"><param name="Local" value="class_fdo_shp_class_collection.html"><param name="ImageNumber" value="11"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Name" value="FdoShpClassDefinition"><param name="Local" value="class_fdo_shp_class_definition.html"><param name="ImageNumber" value="11"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Name" value="FdoShpColumnDefinition"><param name="Local" value="class_fdo_shp_column_definition.html"><param name="ImageNumber" value="11"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Name" value="FdoShpPhysicalSchemaMapping"><param name="Local" value="class_fdo_shp_physical_schema_mapping.html"><param name="ImageNumber" value="11"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Name" value="FdoShpPropertyDefinition"><param name="Local" value="class_fdo_shp_property_definition.html"><param name="ImageNumber" value="11"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Name" value="FdoShpPropertyDefinitionCollection"><param name="Local" value="class_fdo_shp_property_definition_collection.html"><param name="ImageNumber" value="11"></OBJECT>
+ </UL>
+<LI><OBJECT type="text/sitemap"><param name="Name" value="Class Hierarchy"><param name="ImageNumber" value="1"></OBJECT>
+ <UL>
+ </UL>
+<LI><OBJECT type="text/sitemap"><param name="Name" value="Class Members"><param name="Local" value="functions.html"><param name="ImageNumber" value="11"></OBJECT>
+<LI><OBJECT type="text/sitemap"><param name="Name" value="File Members"><param name="Local" value="globals.html"><param name="ImageNumber" value="11"></OBJECT>
+<LI><OBJECT type="text/sitemap"><param name="Name" value="Graphical Class Hierarchy"><param name="Local" value="inherits.html"><param name="ImageNumber" value="11"></OBJECT>
+</UL>
Added: trunk/www/docs/SHP/index.hhk
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/index.hhk?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/index.hhk 2006-03-06 21:40:50+0000
@@ -0,0 +1,114 @@
+</OBJECT>
+<UL>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_class_definition_3d19e7886b05e4cfa5fb5371890ab97f.html#3d19e7886b05e4cfa5fb5371890ab97f"><param name="Name" value="_writeXml"></OBJECT>
+ <UL>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_class_definition_3d19e7886b05e4cfa5fb5371890ab97f.html#3d19e7886b05e4cfa5fb5371890ab97f"><param name="Name" value="FdoShpClassDefinition"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_column_definition_955c02380b27a475d2f00ad14568a2ae.html#955c02380b27a475d2f00ad14568a2ae"><param name="Name" value="FdoShpColumnDefinition"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_physical_schema_mapping_36448c6a7557f454b949b605a6c80129.html#36448c6a7557f454b949b605a6c80129"><param name="Name" value="FdoShpPhysicalSchemaMapping"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_property_definition_ca026498f207e7542714e2094301f456.html#ca026498f207e7542714e2094301f456"><param name="Name" value="FdoShpPropertyDefinition"></OBJECT>
+ </UL>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_class_collection_523f8784b5a62bfd9a00ffb621bac528.html#523f8784b5a62bfd9a00ffb621bac528"><param name="Name" value="Create"></OBJECT>
+ <UL>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_class_collection_523f8784b5a62bfd9a00ffb621bac528.html#523f8784b5a62bfd9a00ffb621bac528"><param name="Name" value="FdoShpClassCollection"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_class_definition_96936568a01aa49e3ef3fbb154fa5ad5.html#96936568a01aa49e3ef3fbb154fa5ad5"><param name="Name" value="FdoShpClassDefinition"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_column_definition_4ba0b1a32d4f0126a9a5079eab9fe025.html#4ba0b1a32d4f0126a9a5079eab9fe025"><param name="Name" value="FdoShpColumnDefinition"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_physical_schema_mapping_48e086264cd4780a442f8ecb841faea8.html#48e086264cd4780a442f8ecb841faea8"><param name="Name" value="FdoShpPhysicalSchemaMapping"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_property_definition_a603b74205bc257c10b7bc068f516292.html#a603b74205bc257c10b7bc068f516292"><param name="Name" value="FdoShpPropertyDefinition"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_property_definition_collection_f78776eddbd77318ae7278ed70d2eb29.html#f78776eddbd77318ae7278ed70d2eb29"><param name="Name" value="FdoShpPropertyDefinitionCollection"></OBJECT>
+ </UL>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="_fdo_shp_class_collection_8h.html"><param name="Name" value="FdoShpClassCollection.h"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_class_collection.html"><param name="Name" value="FdoShpClassCollection"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="_fdo_shp_class_collection_8h_14b881fe200a848b2f39736eec0557f3.html#14b881fe200a848b2f39736eec0557f3"><param name="Name" value="FdoShpClassCollectionP"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="_fdo_shp_class_definition_8h.html"><param name="Name" value="FdoShpClassDefinition.h"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_class_definition.html"><param name="Name" value="FdoShpClassDefinition"></OBJECT>
+ <UL>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_class_definition.html#3d19e7886b05e4cfa5fb5371890ab97f"><param name="Name" value="_writeXml"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_class_definition.html#96936568a01aa49e3ef3fbb154fa5ad5"><param name="Name" value="Create"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_class_definition.html#c3f943759f93d8173aacc9ce12c8feee"><param name="Name" value="FindByColumnName"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_class_definition.html#bdc54fa302f857e4acc9a0c3660dd245"><param name="Name" value="GetProperties"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_class_definition.html#4603016faf3795e4c4544f71e0fb4152"><param name="Name" value="GetShapeFile"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_class_definition.html#daed9b86862ad2148b72edadbbcf479e"><param name="Name" value="InitFromXml"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_class_definition.html#b9340be1c7d393ddedcf670de2149d76"><param name="Name" value="IsPathUpdated"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_class_definition.html#cb66f23743bb45b0e3faaa2bfafeaad8"><param name="Name" value="SetPathUpdated"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_class_definition.html#2e617c437f74fe496aac753fb7666146"><param name="Name" value="SetShapeFile"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_class_definition.html#1eb8e1be10f1d92361eacbbdc50a0677"><param name="Name" value="XmlEndElement"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_class_definition.html#95b2357abf02d1278ac66f01921db44b"><param name="Name" value="XmlStartElement"></OBJECT>
+ </UL>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="_fdo_shp_class_definition_8h_4e85e161f3a61d5a480c8d71c3bfd4ff.html#4e85e161f3a61d5a480c8d71c3bfd4ff"><param name="Name" value="FdoShpClassDefinitionP"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="_fdo_shp_column_definition_8h.html"><param name="Name" value="FdoShpColumnDefinition.h"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_column_definition.html"><param name="Name" value="FdoShpColumnDefinition"></OBJECT>
+ <UL>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_column_definition.html#955c02380b27a475d2f00ad14568a2ae"><param name="Name" value="_writeXml"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_column_definition.html#4ba0b1a32d4f0126a9a5079eab9fe025"><param name="Name" value="Create"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_column_definition.html#600ecd1991fa387cc926316543de81e8"><param name="Name" value="InitFromXml"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_column_definition.html#c9d77b68d5f4a385142690b92d0e7ef9"><param name="Name" value="XmlEndElement"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_column_definition.html#d5669958dfaeb362578fde7cac156561"><param name="Name" value="XmlStartElement"></OBJECT>
+ </UL>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="_fdo_shp_column_definition_8h_8542aa83f9163bd323db446eb4e1035d.html#8542aa83f9163bd323db446eb4e1035d"><param name="Name" value="FdoShpColumnDefinitionP"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="_fdo_shp_physical_schema_mapping_8h.html"><param name="Name" value="FdoShpPhysicalSchemaMapping.h"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_physical_schema_mapping.html"><param name="Name" value="FdoShpPhysicalSchemaMapping"></OBJECT>
+ <UL>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_physical_schema_mapping.html#36448c6a7557f454b949b605a6c80129"><param name="Name" value="_writeXml"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_physical_schema_mapping.html#48e086264cd4780a442f8ecb841faea8"><param name="Name" value="Create"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_physical_schema_mapping.html#cc639fa3a2ae6823d20042cc95f06dae"><param name="Name" value="FindByClassName"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_physical_schema_mapping.html#bb73c56d22638012ed655b6a276e75db"><param name="Name" value="FindByShapefile"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_physical_schema_mapping.html#4d944a128be1ad6406974f8375f12f69"><param name="Name" value="GetClasses"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_physical_schema_mapping.html#45d51d0f0311ff85ed516136e2ce16f6"><param name="Name" value="GetProvider"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_physical_schema_mapping.html#852853e469120e86223be6db80bccb20"><param name="Name" value="InitFromXml"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_physical_schema_mapping.html#7c0b1de21670db480e4463bcecfce94b"><param name="Name" value="XmlEndElement"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_physical_schema_mapping.html#af942717804976ecf3233c259650fb48"><param name="Name" value="XmlStartElement"></OBJECT>
+ </UL>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="_fdo_shp_physical_schema_mapping_8h_a6ba1b4d1f4f7db9e0005451ac2cb3f5.html#a6ba1b4d1f4f7db9e0005451ac2cb3f5"><param name="Name" value="FdoShpPhysicalSchemaMappingP"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="_fdo_shp_property_definition_8h.html"><param name="Name" value="FdoShpPropertyDefinition.h"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_property_definition.html"><param name="Name" value="FdoShpPropertyDefinition"></OBJECT>
+ <UL>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_property_definition.html#ca026498f207e7542714e2094301f456"><param name="Name" value="_writeXml"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_property_definition.html#a603b74205bc257c10b7bc068f516292"><param name="Name" value="Create"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_property_definition.html#20d2033a8034eaed4bfef6d0e3eabaab"><param name="Name" value="GetColumn"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_property_definition.html#e2292de181258077b5faa7c1a62c80eb"><param name="Name" value="InitFromXml"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_property_definition.html#9f411822896503e8e305bcd5baa501c3"><param name="Name" value="SetColumn"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_property_definition.html#2961dfcc8cb657ce57689f56c9764fec"><param name="Name" value="XmlEndElement"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_property_definition.html#3530f2250ead9a4f2589dfcf013b23b4"><param name="Name" value="XmlStartElement"></OBJECT>
+ </UL>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="_fdo_shp_property_definition_collection_8h.html"><param name="Name" value="FdoShpPropertyDefinitionCollection.h"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_property_definition_collection.html"><param name="Name" value="FdoShpPropertyDefinitionCollection"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="_fdo_shp_property_definition_collection_8h_7d1d57dbcd029bc5b5d15fd32f2e165e.html#7d1d57dbcd029bc5b5d15fd32f2e165e"><param name="Name" value="FdoShpPropertyDefinitionCollectionP"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="_fdo_shp_property_definition_8h_d0b59a42138824423a735f567bc1a47c.html#d0b59a42138824423a735f567bc1a47c"><param name="Name" value="FdoShpPropertyDefinitionP"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_physical_schema_mapping_cc639fa3a2ae6823d20042cc95f06dae.html#cc639fa3a2ae6823d20042cc95f06dae"><param name="Name" value="FindByClassName"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_class_definition_c3f943759f93d8173aacc9ce12c8feee.html#c3f943759f93d8173aacc9ce12c8feee"><param name="Name" value="FindByColumnName"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_physical_schema_mapping_bb73c56d22638012ed655b6a276e75db.html#bb73c56d22638012ed655b6a276e75db"><param name="Name" value="FindByShapefile"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_physical_schema_mapping_4d944a128be1ad6406974f8375f12f69.html#4d944a128be1ad6406974f8375f12f69"><param name="Name" value="GetClasses"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_property_definition_20d2033a8034eaed4bfef6d0e3eabaab.html#20d2033a8034eaed4bfef6d0e3eabaab"><param name="Name" value="GetColumn"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_class_definition_bdc54fa302f857e4acc9a0c3660dd245.html#bdc54fa302f857e4acc9a0c3660dd245"><param name="Name" value="GetProperties"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_physical_schema_mapping_45d51d0f0311ff85ed516136e2ce16f6.html#45d51d0f0311ff85ed516136e2ce16f6"><param name="Name" value="GetProvider"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_class_definition_4603016faf3795e4c4544f71e0fb4152.html#4603016faf3795e4c4544f71e0fb4152"><param name="Name" value="GetShapeFile"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_class_definition_daed9b86862ad2148b72edadbbcf479e.html#daed9b86862ad2148b72edadbbcf479e"><param name="Name" value="InitFromXml"></OBJECT>
+ <UL>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_class_definition_daed9b86862ad2148b72edadbbcf479e.html#daed9b86862ad2148b72edadbbcf479e"><param name="Name" value="FdoShpClassDefinition"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_column_definition_600ecd1991fa387cc926316543de81e8.html#600ecd1991fa387cc926316543de81e8"><param name="Name" value="FdoShpColumnDefinition"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_physical_schema_mapping_852853e469120e86223be6db80bccb20.html#852853e469120e86223be6db80bccb20"><param name="Name" value="FdoShpPhysicalSchemaMapping"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_property_definition_e2292de181258077b5faa7c1a62c80eb.html#e2292de181258077b5faa7c1a62c80eb"><param name="Name" value="FdoShpPropertyDefinition"></OBJECT>
+ </UL>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_class_definition_b9340be1c7d393ddedcf670de2149d76.html#b9340be1c7d393ddedcf670de2149d76"><param name="Name" value="IsPathUpdated"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_property_definition_9f411822896503e8e305bcd5baa501c3.html#9f411822896503e8e305bcd5baa501c3"><param name="Name" value="SetColumn"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_class_definition_cb66f23743bb45b0e3faaa2bfafeaad8.html#cb66f23743bb45b0e3faaa2bfafeaad8"><param name="Name" value="SetPathUpdated"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_class_definition_2e617c437f74fe496aac753fb7666146.html#2e617c437f74fe496aac753fb7666146"><param name="Name" value="SetShapeFile"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_class_definition_1eb8e1be10f1d92361eacbbdc50a0677.html#1eb8e1be10f1d92361eacbbdc50a0677"><param name="Name" value="XmlEndElement"></OBJECT>
+ <UL>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_class_definition_1eb8e1be10f1d92361eacbbdc50a0677.html#1eb8e1be10f1d92361eacbbdc50a0677"><param name="Name" value="FdoShpClassDefinition"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_column_definition_c9d77b68d5f4a385142690b92d0e7ef9.html#c9d77b68d5f4a385142690b92d0e7ef9"><param name="Name" value="FdoShpColumnDefinition"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_physical_schema_mapping_7c0b1de21670db480e4463bcecfce94b.html#7c0b1de21670db480e4463bcecfce94b"><param name="Name" value="FdoShpPhysicalSchemaMapping"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_property_definition_2961dfcc8cb657ce57689f56c9764fec.html#2961dfcc8cb657ce57689f56c9764fec"><param name="Name" value="FdoShpPropertyDefinition"></OBJECT>
+ </UL>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_class_definition_95b2357abf02d1278ac66f01921db44b.html#95b2357abf02d1278ac66f01921db44b"><param name="Name" value="XmlStartElement"></OBJECT>
+ <UL>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_class_definition_95b2357abf02d1278ac66f01921db44b.html#95b2357abf02d1278ac66f01921db44b"><param name="Name" value="FdoShpClassDefinition"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_column_definition_d5669958dfaeb362578fde7cac156561.html#d5669958dfaeb362578fde7cac156561"><param name="Name" value="FdoShpColumnDefinition"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_physical_schema_mapping_af942717804976ecf3233c259650fb48.html#af942717804976ecf3233c259650fb48"><param name="Name" value="FdoShpPhysicalSchemaMapping"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_property_definition_3530f2250ead9a4f2589dfcf013b23b4.html#3530f2250ead9a4f2589dfcf013b23b4"><param name="Name" value="FdoShpPropertyDefinition"></OBJECT>
+ </UL>
+</UL>
Added: trunk/www/docs/SHP/index.hhp
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/index.hhp?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/index.hhp 2006-03-06 21:40:50+0000
@@ -0,0 +1,99 @@
+[OPTIONS]
+Compiled file=..\..\..\SHP_Provider_API.chm
+Compatibility=1.1
+Full-text search=Yes
+Contents file=index.hhc
+Default Window=main
+Default topic=main.html
+Index file=index.hhk
+Language=0x409 English (United States)
+Binary TOC=YES
+Title=FDO Provider for SHP
+[WINDOWS]
+main="FDO Provider for SHP","index.hhc","index.hhk","main.html","main.html",,,,,0x23520,,0x387e,,,,,,,,0
+[FILES]
+main.html
+files.html
+define__pages_8h-source.html
+_fdo_shp_class_collection_8h-source.html
+_fdo_shp_class_definition_8h-source.html
+_fdo_shp_column_definition_8h-source.html
+_fdo_shp_physical_schema_mapping_8h-source.html
+_fdo_shp_property_definition_8h-source.html
+_fdo_shp_property_definition_collection_8h-source.html
+define__pages_8h.html
+_fdo_shp_class_collection_8h.html
+_fdo_shp_class_collection_8h_14b881fe200a848b2f39736eec0557f3.html
+_fdo_shp_class_definition_8h.html
+_fdo_shp_class_definition_8h_4e85e161f3a61d5a480c8d71c3bfd4ff.html
+_fdo_shp_column_definition_8h.html
+_fdo_shp_column_definition_8h_8542aa83f9163bd323db446eb4e1035d.html
+_fdo_shp_physical_schema_mapping_8h.html
+_fdo_shp_physical_schema_mapping_8h_a6ba1b4d1f4f7db9e0005451ac2cb3f5.html
+_fdo_shp_property_definition_8h.html
+_fdo_shp_property_definition_8h_d0b59a42138824423a735f567bc1a47c.html
+_fdo_shp_property_definition_collection_8h.html
+_fdo_shp_property_definition_collection_8h_7d1d57dbcd029bc5b5d15fd32f2e165e.html
+annotated.html
+classes.html
+hierarchy.html
+functions.html
+functions_func.html
+class_fdo_shp_class_collection.html
+class_fdo_shp_class_collection_523f8784b5a62bfd9a00ffb621bac528.html
+class_fdo_shp_class_collection_8ac302ce67fca3f9558ff5c647cfcff9.html
+class_fdo_shp_class_collection-members.html
+class_fdo_shp_class_definition.html
+class_fdo_shp_class_definition_3d19e7886b05e4cfa5fb5371890ab97f.html
+class_fdo_shp_class_definition_96936568a01aa49e3ef3fbb154fa5ad5.html
+class_fdo_shp_class_definition_c3f943759f93d8173aacc9ce12c8feee.html
+class_fdo_shp_class_definition_bdc54fa302f857e4acc9a0c3660dd245.html
+class_fdo_shp_class_definition_4603016faf3795e4c4544f71e0fb4152.html
+class_fdo_shp_class_definition_daed9b86862ad2148b72edadbbcf479e.html
+class_fdo_shp_class_definition_b9340be1c7d393ddedcf670de2149d76.html
+class_fdo_shp_class_definition_cb66f23743bb45b0e3faaa2bfafeaad8.html
+class_fdo_shp_class_definition_2e617c437f74fe496aac753fb7666146.html
+class_fdo_shp_class_definition_1eb8e1be10f1d92361eacbbdc50a0677.html
+class_fdo_shp_class_definition_95b2357abf02d1278ac66f01921db44b.html
+class_fdo_shp_class_definition-members.html
+class_fdo_shp_column_definition.html
+class_fdo_shp_column_definition_955c02380b27a475d2f00ad14568a2ae.html
+class_fdo_shp_column_definition_4ba0b1a32d4f0126a9a5079eab9fe025.html
+class_fdo_shp_column_definition_600ecd1991fa387cc926316543de81e8.html
+class_fdo_shp_column_definition_c9d77b68d5f4a385142690b92d0e7ef9.html
+class_fdo_shp_column_definition_d5669958dfaeb362578fde7cac156561.html
+class_fdo_shp_column_definition-members.html
+class_fdo_shp_physical_schema_mapping.html
+class_fdo_shp_physical_schema_mapping_36448c6a7557f454b949b605a6c80129.html
+class_fdo_shp_physical_schema_mapping_48e086264cd4780a442f8ecb841faea8.html
+class_fdo_shp_physical_schema_mapping_cc639fa3a2ae6823d20042cc95f06dae.html
+class_fdo_shp_physical_schema_mapping_bb73c56d22638012ed655b6a276e75db.html
+class_fdo_shp_physical_schema_mapping_4d944a128be1ad6406974f8375f12f69.html
+class_fdo_shp_physical_schema_mapping_45d51d0f0311ff85ed516136e2ce16f6.html
+class_fdo_shp_physical_schema_mapping_852853e469120e86223be6db80bccb20.html
+class_fdo_shp_physical_schema_mapping_7c0b1de21670db480e4463bcecfce94b.html
+class_fdo_shp_physical_schema_mapping_af942717804976ecf3233c259650fb48.html
+class_fdo_shp_physical_schema_mapping-members.html
+class_fdo_shp_property_definition.html
+class_fdo_shp_property_definition_ca026498f207e7542714e2094301f456.html
+class_fdo_shp_property_definition_a603b74205bc257c10b7bc068f516292.html
+class_fdo_shp_property_definition_20d2033a8034eaed4bfef6d0e3eabaab.html
+class_fdo_shp_property_definition_e2292de181258077b5faa7c1a62c80eb.html
+class_fdo_shp_property_definition_9f411822896503e8e305bcd5baa501c3.html
+class_fdo_shp_property_definition_2961dfcc8cb657ce57689f56c9764fec.html
+class_fdo_shp_property_definition_3530f2250ead9a4f2589dfcf013b23b4.html
+class_fdo_shp_property_definition-members.html
+class_fdo_shp_property_definition_collection.html
+class_fdo_shp_property_definition_collection_f78776eddbd77318ae7278ed70d2eb29.html
+class_fdo_shp_property_definition_collection_6b3823628fb7e5e0833d9110c5128d07.html
+class_fdo_shp_property_definition_collection-members.html
+globals.html
+globals_type.html
+graph_legend.html
+inherits.html
+tabs.css
Added: trunk/www/docs/SHP/index.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/index.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/index.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,8 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
+<html><head><meta http-equiv="Content-Type" content="text/html;charset=iso-8859-1">
+<title>FDO Provider for SHP</title></head>
+<frameset cols="250,*">
+ <frame src="tree.html" name="treefrm">
+ <frame src="main.html" name="basefrm">
+</frameset>
+</html>
Added: trunk/www/docs/SHP/inherit__graph__0.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/inherit__graph__0.map?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/inherit__graph__0.map 2006-03-06 21:40:50+0000
@@ -0,0 +1,2 @@
+base referer
+rect $class_fdo_shp_class_collection.html 8,7 168,33
Added: trunk/www/docs/SHP/inherit__graph__0.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/inherit__graph__0.md5?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/inherit__graph__0.md5 2006-03-06 21:40:50+0000
@@ -0,0 +1 @@
+5b6054492035cbbc58d1eebffcee7ff5
\ No newline at end of file
Added: trunk/www/docs/SHP/inherit__graph__0.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/inherit__graph__0.png?view=auto&rev=4
Added: trunk/www/docs/SHP/inherit__graph__1.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/inherit__graph__1.map?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/inherit__graph__1.map 2006-03-06 21:40:50+0000
@@ -0,0 +1,2 @@
+base referer
+rect $class_fdo_shp_class_definition.html 8,7 165,33
Added: trunk/www/docs/SHP/inherit__graph__1.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/inherit__graph__1.md5?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/inherit__graph__1.md5 2006-03-06 21:40:50+0000
@@ -0,0 +1 @@
+06f242aef8b84b53b586760f4e025176
Added: trunk/www/docs/SHP/inherit__graph__1.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/inherit__graph__1.png?view=auto&rev=4
Added: trunk/www/docs/SHP/inherit__graph__2.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/inherit__graph__2.map?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/inherit__graph__2.map 2006-03-06 21:40:50+0000
@@ -0,0 +1,2 @@
+base referer
+rect $class_fdo_shp_column_definition.html 8,7 179,33
Added: trunk/www/docs/SHP/inherit__graph__2.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/inherit__graph__2.md5?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/inherit__graph__2.md5 2006-03-06 21:40:50+0000
@@ -0,0 +1 @@
+7add7387f544563c4804170c155dbf61
Added: trunk/www/docs/SHP/inherit__graph__2.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/inherit__graph__2.png?view=auto&rev=4
Added: trunk/www/docs/SHP/inherit__graph__3.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/inherit__graph__3.map?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/inherit__graph__3.map 2006-03-06 21:40:50+0000
@@ -0,0 +1,2 @@
+base referer
+rect $class_fdo_shp_physical_schema_mapping.html 7,7 225,33
Added: trunk/www/docs/SHP/inherit__graph__3.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/inherit__graph__3.md5?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/inherit__graph__3.md5 2006-03-06 21:40:50+0000
@@ -0,0 +1 @@
+a2fd68cfa23e14d1921b16d09db5145b
Added: trunk/www/docs/SHP/inherit__graph__3.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/inherit__graph__3.png?view=auto&rev=4
Added: trunk/www/docs/SHP/inherit__graph__4.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/inherit__graph__4.map?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/inherit__graph__4.map 2006-03-06 21:40:50+0000
@@ -0,0 +1,2 @@
+base referer
+rect $class_fdo_shp_property_definition.html 7,7 183,33
Added: trunk/www/docs/SHP/inherit__graph__4.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/inherit__graph__4.md5?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/inherit__graph__4.md5 2006-03-06 21:40:50+0000
@@ -0,0 +1 @@
+3fb2c8292b476ac96b0ab75f325c0248
Added: trunk/www/docs/SHP/inherit__graph__4.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/inherit__graph__4.png?view=auto&rev=4
Added: trunk/www/docs/SHP/inherit__graph__5.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/inherit__graph__5.map?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/inherit__graph__5.map 2006-03-06 21:40:50+0000
@@ -0,0 +1,2 @@
+base referer
+rect $class_fdo_shp_property_definition_collection.html 7,7 241,33
Added: trunk/www/docs/SHP/inherit__graph__5.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/inherit__graph__5.md5?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/inherit__graph__5.md5 2006-03-06 21:40:50+0000
@@ -0,0 +1 @@
+04e6bbb419e6639f7d5f0f757cfb34a2
Added: trunk/www/docs/SHP/inherit__graph__5.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/inherit__graph__5.png?view=auto&rev=4
Added: trunk/www/docs/SHP/inherits.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/inherits.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/inherits.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,79 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li id="current"><a href="classes.html"><span>Classes</span></a></li>
+ <li><a href="files.html"><span>Files</span></a></li>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li><a href="classes.html"><span>Alphabetical List</span></a></li>
+ <li><a href="annotated.html"><span>Class List</span></a></li>
+ <li><a href="functions.html"><span>Class Members</span></a></li>
+ </ul></div>
+<h1>FDO Provider for SHP Graphical Class Hierarchy</h1><a href="hierarchy.html">Go to the textual class hierarchy</a>
+<p>
+<table border="0" cellspacing="10" cellpadding="0">
+<tr><td><img src="inherit__graph__0.png" border="0" alt="" usemap="#_fdo_shp_class_collection_map">
+<map name="_fdo_shp_class_collection_map">
+<area href="class_fdo_shp_class_collection.html" shape="rect" coords="8,7,168,33" alt="">
+</map></td></tr>
+<tr><td><img src="inherit__graph__1.png" border="0" alt="" usemap="#_fdo_shp_class_definition_map">
+<map name="_fdo_shp_class_definition_map">
+<area href="class_fdo_shp_class_definition.html" shape="rect" coords="8,7,165,33" alt="">
+</map></td></tr>
+<tr><td><img src="inherit__graph__2.png" border="0" alt="" usemap="#_fdo_shp_column_definition_map">
+<map name="_fdo_shp_column_definition_map">
+<area href="class_fdo_shp_column_definition.html" shape="rect" coords="8,7,179,33" alt="">
+</map></td></tr>
+<tr><td><img src="inherit__graph__3.png" border="0" alt="" usemap="#_fdo_shp_physical_schema_mapping_map">
+<map name="_fdo_shp_physical_schema_mapping_map">
+<area href="class_fdo_shp_physical_schema_mapping.html" shape="rect" coords="7,7,225,33" alt="">
+</map></td></tr>
+<tr><td><img src="inherit__graph__4.png" border="0" alt="" usemap="#_fdo_shp_property_definition_map">
+<map name="_fdo_shp_property_definition_map">
+<area href="class_fdo_shp_property_definition.html" shape="rect" coords="7,7,183,33" alt="">
+</map></td></tr>
+<tr><td><img src="inherit__graph__5.png" border="0" alt="" usemap="#_fdo_shp_property_definition_collection_map">
+<map name="_fdo_shp_property_definition_collection_map">
+<area href="class_fdo_shp_property_definition_collection.html" shape="rect" coords="7,7,241,33" alt="">
+</map></td></tr>
+</table>
+<!-- footer.html -->
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/installdox
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/installdox?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/installdox 2006-03-06 21:40:50+0000
@@ -0,0 +1,117 @@
+#!/usr/bin/perl
+%subst = ( );
+$quiet = 0;
+if (open(F,"search.cfg"))
+ $_=<F> ; s/[ \t\n]*$//g ; $subst{"_doc"} = $_;
+ $_=<F> ; s/[ \t\n]*$//g ; $subst{"_cgi"} = $_;
+while ( @ARGV ) {
+ $_ = shift @ARGV;
+ if ( s/^-// ) {
+ if ( /^l(.*)/ ) {
+ $v = ($1 eq "") ? shift @ARGV : $1;
+ ($v =~ /\/$/) || ($v .= "/");
+ $_ = $v;
+ if ( /(.+)\@(.+)/ ) {
+ if ( exists $subst{$1} ) {
+ $subst{$1} = $2;
+ } else {
+ print STDERR "Unknown tag file $1 given with option -l\n";
+ &usage();
+ } else {
+ print STDERR "Argument $_ is invalid for option -l\n";
+ &usage();
+ elsif ( /^q/ ) {
+ $quiet = 1;
+ elsif ( /^\?|^h/ ) {
+ &usage();
+ else {
+ print STDERR "Illegal option -$_\n";
+ &usage();
+ else {
+ push (@files, $_ );
+foreach $sub (keys %subst)
+ if ( $subst{$sub} eq "" )
+ print STDERR "No substitute given for tag file `$sub'\n";
+ &usage();
+ elsif ( ! $quiet && $sub ne "_doc" && $sub ne "_cgi" )
+ print "Substituting $subst{$sub} for each occurence of tag file $sub\n";
+if ( ! @files ) {
+ if (opendir(D,".")) {
+ foreach $file ( readdir(D) ) {
+ $match = ".html";
+ next if ( $file =~ /^\.\.?$/ );
+ ($file =~ /$match/) && (push @files, $file);
+ ($file =~ "tree.js") && (push @files, $file);
+ closedir(D);
+if ( ! @files ) {
+ print STDERR "Warning: No input files given and none found!\n";
+foreach $f (@files)
+ if ( ! $quiet ) {
+ print "Editing: $f...\n";
+ $oldf = $f;
+ $f .= ".bak";
+ unless (rename $oldf,$f) {
+ print STDERR "Error: cannot rename file $oldf\n";
+ exit 1;
+ if (open(F,"<$f")) {
+ unless (open(G,">$oldf")) {
+ print STDERR "Error: opening file $oldf for writing\n";
+ exit 1;
+ if ($oldf ne "tree.js") {
+ while (<F>) {
+ s/doxygen\=\"([^ \"\:\t\>\<]*)\:([^ \"\t\>\<]*)\" (href|src)=\"\2/doxygen\=\"$1:$subst{$1}\" \3=\"$subst{$1}/g;
+ print G "$_";
+ else {
+ while (<F>) {
+ s/\"([^ \"\:\t\>\<]*)\:([^ \"\t\>\<]*)\", \"\2/\"$1:$subst{$1}\" ,\"$subst{$1}/g;
+ print G "$_";
+ else {
+ print STDERR "Warning file $f does not exist\n";
+ unlink $f;
+sub usage {
+ print STDERR "Usage: installdox [options] [html-file [html-file ...]]\n";
+ print STDERR "Options:\n";
+ print STDERR " -l tagfile\@linkName tag file + URL or directory \n";
+ print STDERR " -q Quiet mode\n\n";
+ exit 1;
Added: trunk/www/docs/SHP/main.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/main.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/main.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,66 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li id="current"><a href="main.html"><span>Main Page</span></a></li>
+ <li>
+ <tr>
+ </tr>
+ </table>
+ </form>
+ </li>
+ </ul></div>
+<h1>Introduction</h1>
+<p>
+<div class="mainpage"></div><p>
+<div class="mainpage">The Feature Data Objects (FDO) API provides access to data in a data store. A provider is a specific implementation of the FDO API that provides access to data in a particular data store. The FDO Provider for SHP provides FDO with access to a SHP-based data store. </div><p>
+<div class="mainpage">The FDO Provider for SHP uses a standalone file format that supports GIS data. The FDO Provider for SHP (Shape) has the following characteristics: <ul>
+<li>
+Read-only access is provided to pre-existing spatial and attribute data from an Environmental Systems Research Institute (ESRI) Shape file (SHP). </li>
+<li>
+The FDO Provider for SHP can run in a multi-platform environment, including Windows and Linux. </li>
+<li>
+A Shape file consists of three separate files: SHP (shape geometry), SHX (shape index), and DBF (shape attributes in dBASE format). </li>
+<li>
+The FDO Provider for SHP accesses the information in each of the three separate files, and treats each SHP, and its associated DBF file, as a feature class with a single geometry property, and optionally, with data attribute properties. </li>
+<li>
+Schema configuration of the data store is provided to the FDO Provider for SHP through an XML file containing the Geographic Markup Language (GML) definition of the schema that maps SHP and DBF data in the data store to feature classes and property mappings in the FDO data model. </li>
+<li>
+Although it does not support concurrency control (locking), the SHP file format is a valid alternative to RDBMS. </li>
+</ul>
+</div><p>
+<div class="mainpage"> For more information, see <em>The Essential FDO</em> (FET_TheEssentialFDO.pdf) and the <em>FDO Developer's Guide</em> (FDG_FDODevGuide.pdf). </div><p>
+<div class="mainpage"><br>
+ </div> <!-- footer.html -->
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/search.idx
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/search.idx?view=auto&rev=4
Binary file. No diff available.
Added: trunk/www/docs/SHP/search.php
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/search.php?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/search.php 2006-03-06 21:40:50+0000
@@ -0,0 +1,397 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li>
+ <tr>
+<?php
+function search_results()
+ return "Search Results";
+function matches_text($num)
+ if ($num==0)
+ return "Sorry, no documents matching your query.";
+ else if ($num==1)
+ return "Found <b>1</b> document matching your query.";
+ else // $num>1
+ return "Found <b>$num</b> documents matching your query. Showing best matches first.";
+function report_matches()
+ return "Matches: ";
+function end_form($value)
+ echo " <td><input type=\"text\" name=\"query\" value=\"$value\" size=\"20\" accesskey=\"s\"/></td>\n </tr>\n </table>\n </form>\n </li>\n </ul>\n</div>\n";
+function readInt($file)
+ $b1 = ord(fgetc($file)); $b2 = ord(fgetc($file));
+ $b3 = ord(fgetc($file)); $b4 = ord(fgetc($file));
+ return ($b1<<24)|($b2<<16)|($b3<<8)|$b4;
+function readString($file)
+ $result="";
+ while (ord($c=fgetc($file))) $result.=$c;
+ return $result;
+function readHeader($file)
+ $header =fgetc($file); $header.=fgetc($file);
+ $header.=fgetc($file); $header.=fgetc($file);
+ return $header;
+function computeIndex($word)
+ // Fast string hashing
+ //$lword = strtolower($word);
+ //$l = strlen($lword);
+ //for ($i=0;$i<$l;$i++)
+ // $c = ord($lword{$i});
+ // $v = (($v & 0xfc00) ^ ($v << 6) ^ $c) & 0xffff;
+ //return $v;
+ // Simple hashing that allows for substring search
+ if (strlen($word)<2) return -1;
+ // high char of the index
+ $hi = ord($word{0});
+ if ($hi==0) return -1;
+ // low char of the index
+ $lo = ord($word{1});
+ if ($lo==0) return -1;
+ // return index
+ return $hi*256+$lo;
+function search($file,$word,&$statsList)
+ $index = computeIndex($word);
+ if ($index!=-1) // found a valid index
+ fseek($file,$index*4+4); // 4 bytes per entry, skip header
+ $index = readInt($file);
+ if ($index) // found words matching the hash key
+ $start=sizeof($statsList);
+ $count=$start;
+ fseek($file,$index);
+ $w = readString($file);
+ while ($w)
+ $statIdx = readInt($file);
+ if ($word==substr($w,0,strlen($word)))
+ { // found word that matches (as substring)
+ $statsList[$count++]=array(
+ "word"=>$word,
+ "match"=>$w,
+ "index"=>$statIdx,
+ "full"=>strlen($w)==strlen($word),
+ "docs"=>array()
+ $totalHi=0;
+ $totalFreqHi=0;
+ $totalFreqLo=0;
+ for ($count=$start;$count<sizeof($statsList);$count++)
+ $statInfo = &$statsList[$count];
+ $multiplier = 1;
+ // whole word matches have a double weight
+ if ($statInfo["full"]) $multiplier=2;
+ fseek($file,$statInfo["index"]);
+ $numDocs = readInt($file);
+ $docInfo = array();
+ // read docs info + occurrence frequency of the word
+ for ($i=0;$i<$numDocs;$i++)
+ $idx=readInt($file);
+ $freq=readInt($file);
+ $docInfo[$i]=array("idx" => $idx,
+ "freq" => $freq>>1,
+ "rank" => 0.0,
+ "hi" => $freq&1
+ if ($freq&1) // word occurs in high priority doc
+ $totalHi++;
+ $totalFreqHi+=$freq*$multiplier;
+ else // word occurs in low priority doc
+ $totalFreqLo+=$freq*$multiplier;
+ // read name and url info for the doc
+ fseek($file,$docInfo[$i]["idx"]);
+ $docInfo[$i]["name"]=readString($file);
+ $docInfo[$i]["url"]=readString($file);
+ $statInfo["docs"]=$docInfo;
+ $totalFreq=($totalHi+1)*$totalFreqLo + $totalFreqHi;
+ $multiplier = 1;
+ for ($i=0;$i<sizeof($statInfo["docs"]);$i++)
+ $docInfo = &$statInfo["docs"];
+ // compute frequency rank of the word in each doc
+ $freq=$docInfo[$i]["freq"];
+ if ($docInfo[$i]["hi"])
+ $statInfo["docs"][$i]["rank"]=
+ (float)($freq*$multiplier+$totalFreqLo)/$totalFreq;
+ else
+ (float)($freq*$multiplier)/$totalFreq;
+ return $statsList;
+function combine_results($results,&$docs)
+ foreach ($results as $wordInfo)
+ $docsList = &$wordInfo["docs"];
+ foreach ($docsList as $di)
+ $key=$di["url"];
+ $rank=$di["rank"];
+ if (in_array($key, array_keys($docs)))
+ $docs[$key]["rank"]+=$rank;
+ else
+ $docs[$key] = array("url"=>$key,
+ "name"=>$di["name"],
+ "rank"=>$rank
+ $docs[$key]["words"][] = array(
+ "word"=>$wordInfo["word"],
+ "match"=>$wordInfo["match"],
+ "freq"=>$di["freq"]
+ return $docs;
+function filter_results($docs,&$requiredWords,&$forbiddenWords)
+ $filteredDocs=array();
+ while (list ($key, $val) = each ($docs))
+ $words = &$docs[$key]["words"];
+ $copy=1; // copy entry by default
+ if (sizeof($requiredWords)>0)
+ foreach ($requiredWords as $reqWord)
+ $found=0;
+ foreach ($words as $wordInfo)
+ $found = $wordInfo["word"]==$reqWord;
+ if ($found) break;
+ if (!$found)
+ $copy=0; // document contains none of the required words
+ break;
+ if (sizeof($forbiddenWords)>0)
+ if (in_array($wordInfo["word"],$forbiddenWords))
+ $copy=0; // document contains a forbidden word
+ break;
+ if ($copy) $filteredDocs[$key]=$docs[$key];
+ return $filteredDocs;
+function compare_rank($a,$b)
+ if ($a["rank"] == $b["rank"])
+ return 0;
+ return ($a["rank"]>$b["rank"]) ? -1 : 1;
+function sort_results($docs,&$sorted)
+ $sorted = $docs;
+ usort($sorted,"compare_rank");
+ return $sorted;
+function report_results(&$docs)
+ echo "<table cellspacing=\"2\">\n";
+ echo " <tr>\n";
+ echo " <td colspan=\"2\"><h2>".search_results()."</h2></td>\n";
+ echo " </tr>\n";
+ $numDocs = sizeof($docs);
+ if ($numDocs==0)
+ echo " <tr>\n";
+ echo " <td colspan=\"2\">".matches_text(0)."</td>\n";
+ echo " </tr>\n";
+ else
+ echo " <tr>\n";
+ echo " <td colspan=\"2\">".matches_text($numDocs);
+ echo "\n";
+ echo " </td>\n";
+ echo " </tr>\n";
+ $num=1;
+ foreach ($docs as $doc)
+ echo " <tr>\n";
+ echo " <td align=\"right\">$num.</td>";
+ echo "<td><a class=\"el\" href=\"".$doc["url"]."\">".$doc["name"]."</a></td>\n";
+ echo " <tr>\n";
+ echo " <td></td><td class=\"tiny\">".report_matches()." ";
+ foreach ($doc["words"] as $wordInfo)
+ $word = $wordInfo["word"];
+ $matchRight = substr($wordInfo["match"],strlen($word));
+ echo "<b>$word</b>$matchRight(".$wordInfo["freq"].") ";
+ echo " </td>\n";
+ echo " </tr>\n";
+ $num++;
+ echo "</table>\n";
+function main()
+ if(strcmp('4.1.0', phpversion()) > 0)
+ die("Error: PHP version 4.1.0 or above required!");
+ if (!($file=fopen("search.idx","rb")))
+ die("Error: Search index file could NOT be opened!");
+ if (readHeader($file)!="DOXS")
+ die("Error: Header of index file is invalid!");
+ $query="";
+ if (array_key_exists("query", $_GET))
+ $query=$_GET["query"];
+ end_form($query);
+ echo " \n<div class=\"searchresults\">\n";
+ $results = array();
+ $requiredWords = array();
+ $forbiddenWords = array();
+ $foundWords = array();
+ $word=strtok($query," ");
+ while ($word) // for each word in the search query
+ if (($word{0}=='+')) { $word=substr($word,1); $requiredWords[]=$word; }
+ if (($word{0}=='-')) { $word=substr($word,1); $forbiddenWords[]=$word; }
+ if (!in_array($word,$foundWords))
+ $foundWords[]=$word;
+ search($file,strtolower($word),$results);
+ $word=strtok(" ");
+ $docs = array();
+ combine_results($results,$docs);
+ // filter out documents with forbidden word or that do not contain
+ // required words
+ $filteredDocs = filter_results($docs,$requiredWords,$forbiddenWords);
+ // sort the results based on rank
+ $sorted = array();
+ sort_results($filteredDocs,$sorted);
+ // report results to the user
+ report_results($sorted);
+ echo "</div>\n";
+ fclose($file);
+main();
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/tab_b.gif
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/tab_b.gif?view=auto&rev=4
Added: trunk/www/docs/SHP/tab_l.gif
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/tab_l.gif?view=auto&rev=4
Added: trunk/www/docs/SHP/tab_r.gif
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/tab_r.gif?view=auto&rev=4
Added: trunk/www/docs/SHP/tabs.css
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/tabs.css?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/tabs.css 2006-03-06 21:40:50+0000
@@ -0,0 +1,102 @@
+/* tabs styles, based on http://www.alistapart.com/articles/slidingdoors */
+DIV.tabs
+ float : left;
+ width : 100%;
+ background : url("tab_b.gif") repeat-x bottom;
+ margin-bottom : 4px;
+DIV.tabs UL
+ margin : 0px;
+ padding-left : 10px;
+ list-style : none;
+DIV.tabs LI, DIV.tabs FORM
+ display : inline;
+ margin : 0px;
+ padding : 0px;
+DIV.tabs FORM
+ float : right;
+DIV.tabs A
+ float : left;
+ background : url("tab_r.gif") no-repeat right top;
+ border-bottom : 1px solid #84B0C7;
+ font-size : x-small;
+ font-weight : bold;
+ text-decoration : none;
+DIV.tabs A:hover
+ background-position: 100% -150px;
+DIV.tabs A:link, DIV.tabs A:visited,
+DIV.tabs A:active, DIV.tabs A:hover
+ color: #1A419D;
+DIV.tabs SPAN
+ float : left;
+ display : block;
+ background : url("tab_l.gif") no-repeat left top;
+ padding : 5px 9px;
+ white-space : nowrap;
+DIV.tabs INPUT
+ float : right;
+ display : inline;
+ font-size : 1em;
+DIV.tabs TD
+/* Commented Backslash Hack hides rule from IE5-Mac \*/
+DIV.tabs SPAN {float : none;}
+/* End IE5-Mac hack */
+DIV.tabs A:hover SPAN
+ background-position: 0% -150px;
+DIV.tabs LI#current A
+ border-width : 0px;
+DIV.tabs LI#current SPAN
+ padding-bottom : 6px;
+DIV.nav
+ background : none;
+ border : none;
Added: trunk/www/docs/SHP/tree.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/tree.html?view=auto&rev=4
--- (empty file)
+++ trunk/www/docs/SHP/tree.html 2006-03-06 21:40:50+0000
@@ -0,0 +1,110 @@
+<html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en">
+ <head>
+ <meta http-equiv="Content-Type" content="text/xhtml;charset=iso-8859-1" />
+ <meta http-equiv="Content-Style-Type" content="text/css" />
+ <meta http-equiv="Content-Language" content="en" />
+ <link rel="stylesheet" href="custom.css">
+ <title>TreeView</title>
+ <style type="text/css">
+ .directory { font-size: 10pt; font-weight: bold; }
+ .directory h3 { margin: 0px; margin-top: 1em; font-size: 11pt; }
+ .directory p { margin: 0px; white-space: nowrap; }
+ .directory div { display: none; margin: 0px; }
+ .directory img { vertical-align: middle; }
+ </style>
+ <script type="text/javascript">
+ <!-- // Hide script from old browsers
+ function toggleFolder(id, imageNode)
+ var folder = document.getElementById(id);
+ var l = imageNode.src.length;
+ if (imageNode.src.substring(l-20,l)=="ftv2folderclosed.png" ||
+ imageNode.src.substring(l-18,l)=="ftv2folderopen.png")
+ imageNode = imageNode.previousSibling;
+ l = imageNode.src.length;
+ if (folder == null)
+ else if (folder.style.display == "block")
+ if (imageNode != null)
+ imageNode.nextSibling.src = "ftv2folderclosed.png";
+ if (imageNode.src.substring(l-13,l) == "ftv2mnode.png")
+ imageNode.src = "ftv2pnode.png";
+ else if (imageNode.src.substring(l-17,l) == "ftv2mlastnode.png")
+ imageNode.src = "ftv2plastnode.png";
+ folder.style.display = "none";
+ else
+ imageNode.nextSibling.src = "ftv2folderopen.png";
+ if (imageNode.src.substring(l-13,l) == "ftv2pnode.png")
+ imageNode.src = "ftv2mnode.png";
+ else if (imageNode.src.substring(l-17,l) == "ftv2plastnode.png")
+ imageNode.src = "ftv2mlastnode.png";
+ folder.style.display = "block";
+ // End script hiding -->
+ </script>
+ </head>
+ <body>
+ <div class="directory">
+ <h3>FDO Provider for SHP</h3>
+ <div style="display: block;">
+ <p><img src="ftv2node.png" alt="o" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="main.html" target="basefrm">Introduction</a></p>
+ <p><img src="ftv2pnode.png" alt="o" width=16 height=22 onclick="toggleFolder('folder1', this)"/><img src="ftv2folderclosed.png" alt="+" width=24 height=22 onclick="toggleFolder('folder1', this)"/><a class="el" href="files.html" target="basefrm">File List</a></p>
+ <div id="folder1">
+ <p><img src="ftv2vertline.png" alt="|" width=16 height=22 /><img src="ftv2node.png" alt="o" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="define__pages_8h.html" target="basefrm">define_pages.h</a></p>
+ <p><img src="ftv2vertline.png" alt="|" width=16 height=22 /><img src="ftv2node.png" alt="o" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="_fdo_shp_class_collection_8h.html" target="basefrm">FdoShpClassCollection.h</a></p>
+ <p><img src="ftv2vertline.png" alt="|" width=16 height=22 /><img src="ftv2node.png" alt="o" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="_fdo_shp_class_definition_8h.html" target="basefrm">FdoShpClassDefinition.h</a></p>
+ <p><img src="ftv2vertline.png" alt="|" width=16 height=22 /><img src="ftv2node.png" alt="o" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="_fdo_shp_column_definition_8h.html" target="basefrm">FdoShpColumnDefinition.h</a></p>
+ <p><img src="ftv2vertline.png" alt="|" width=16 height=22 /><img src="ftv2node.png" alt="o" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="_fdo_shp_physical_schema_mapping_8h.html" target="basefrm">FdoShpPhysicalSchemaMapping.h</a></p>
+ <p><img src="ftv2vertline.png" alt="|" width=16 height=22 /><img src="ftv2node.png" alt="o" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="_fdo_shp_property_definition_8h.html" target="basefrm">FdoShpPropertyDefinition.h</a></p>
+ <p><img src="ftv2vertline.png" alt="|" width=16 height=22 /><img src="ftv2lastnode.png" alt="\" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="_fdo_shp_property_definition_collection_8h.html" target="basefrm">FdoShpPropertyDefinitionCollection.h</a></p>
+ </div>
+ <p><img src="ftv2pnode.png" alt="o" width=16 height=22 onclick="toggleFolder('folder2', this)"/><img src="ftv2folderclosed.png" alt="+" width=24 height=22 onclick="toggleFolder('folder2', this)"/><a class="el" href="annotated.html" target="basefrm">Class List</a></p>
+ <div id="folder2">
+ <p><img src="ftv2vertline.png" alt="|" width=16 height=22 /><img src="ftv2node.png" alt="o" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="class_fdo_shp_class_collection.html" target="basefrm">FdoShpClassCollection</a></p>
+ <p><img src="ftv2vertline.png" alt="|" width=16 height=22 /><img src="ftv2node.png" alt="o" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="class_fdo_shp_class_definition.html" target="basefrm">FdoShpClassDefinition</a></p>
+ <p><img src="ftv2vertline.png" alt="|" width=16 height=22 /><img src="ftv2node.png" alt="o" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="class_fdo_shp_column_definition.html" target="basefrm">FdoShpColumnDefinition</a></p>
+ <p><img src="ftv2vertline.png" alt="|" width=16 height=22 /><img src="ftv2node.png" alt="o" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="class_fdo_shp_physical_schema_mapping.html" target="basefrm">FdoShpPhysicalSchemaMapping</a></p>
+ <p><img src="ftv2vertline.png" alt="|" width=16 height=22 /><img src="ftv2node.png" alt="o" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="class_fdo_shp_property_definition.html" target="basefrm">FdoShpPropertyDefinition</a></p>
+ <p><img src="ftv2vertline.png" alt="|" width=16 height=22 /><img src="ftv2lastnode.png" alt="\" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="class_fdo_shp_property_definition_collection.html" target="basefrm">FdoShpPropertyDefinitionCollection</a></p>
+ </div>
+ <p><img src="ftv2pnode.png" alt="o" width=16 height=22 onclick="toggleFolder('folder3', this)"/><img src="ftv2folderclosed.png" alt="+" width=24 height=22 onclick="toggleFolder('folder3', this)"/><a class="el" href="hierarchy.html" target="basefrm">Class Hierarchy</a></p>
+ <div id="folder3">
+ </div>
+ <p><img src="ftv2node.png" alt="o" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="functions.html" target="basefrm">Class Members</a></p>
+ <p><img src="ftv2node.png" alt="o" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="globals.html" target="basefrm">File Members</a></p>
+ <p><img src="ftv2lastnode.png" alt="\" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="inherits.html" target="basefrm">Graphical Class Hierarchy</a></p>
+ </div>
+ </div>
+ </body>
+</html>
More information about the Fdo-commits
