svn commit: r11 - trunk/www/docs/SDF
gregboone at osgeo.org gregboone at osgeo.org
Tue May 16 16:14:06 EDT 2006
Author: gregboone
Date: 2006-05-16 20:14:06+0000
New Revision: 11
Added:
   trunk/www/docs/SDF/_i_create_s_d_f_file_8h-source.html   (contents, props changed)
   trunk/www/docs/SDF/_i_create_s_d_f_file_8h.html   (contents, props changed)
   trunk/www/docs/SDF/_i_create_s_d_f_file_8h__incl.map   (contents, props changed)
   trunk/www/docs/SDF/_i_create_s_d_f_file_8h__incl.md5   (contents, props changed)
   trunk/www/docs/SDF/_i_create_s_d_f_file_8h__incl.png   (contents, props changed)
   trunk/www/docs/SDF/annotated.html   (contents, props changed)
   trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file-members.html   (contents, props changed)
   trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file.html   (contents, props changed)
   trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_05550ca7007c3e389b7029c41baa1587.html   (contents, props changed)
   trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_0b8020c31deb9acc05311fd11f260c7d.html   (contents, props changed)
   trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_0bde059736005f052076c6735c8b2453.html   (contents, props changed)
   trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_2937b06fdf37207301200042b40e8d71.html   (contents, props changed)
   trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_4a2bb60374b5db4f9dca173de2845803.html   (contents, props changed)
   trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_4d74d6f8e45e76d8c8606953ae4cb307.html   (contents, props changed)
   trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_647ff5d7f47cf47422c32645074cce8d.html   (contents, props changed)
   trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_86b4ac8510f46ad6629e42023f184cee.html   (contents, props changed)
   trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_8b2fc8bbd39311d609c316fac75d765b.html   (contents, props changed)
   trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_8bb4c31009cf0ab76fc094eadcf4ca91.html   (contents, props changed)
   trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_b3e528dda87b952a83786b2d01343524.html   (contents, props changed)
   trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_bda73a210df146335a62e933ebe19948.html   (contents, props changed)
   trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_e92b777da3c498180dd72fe4629ee788.html   (contents, props changed)
   trunk/www/docs/SDF/classes.html   (contents, props changed)
   trunk/www/docs/SDF/custom.css   (contents, props changed)
   trunk/www/docs/SDF/define__pages_8h-source.html   (contents, props changed)
   trunk/www/docs/SDF/define__pages_8h.html   (contents, props changed)
   trunk/www/docs/SDF/doxygen.png   (contents, props changed)
FDO2
Added: trunk/www/docs/SDF/_i_create_s_d_f_file_8h-source.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_i_create_s_d_f_file_8h-source.html?view=auto&rev=11
--- (empty file)
+++ trunk/www/docs/SDF/_i_create_s_d_f_file_8h-source.html	2006-05-16 20:14:06+0000
@@ -0,0 +1,222 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN"	"http://www.w3.org/TR/html4/loose.dtd">
+<html>
+	<head>
+		<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
+		<title>OSGeo FDO Provider for SDF API Reference</title>
+		<link href="custom.css" rel="stylesheet" type="text/css">
+		<link href="tabs.css" rel="stylesheet" type="text/css">
+	</head>
+	<body bgcolor="#FFFFFF">
+		<table width="100%"  border="0">
+			<tr>
+				<td><b>API Reference<b></td>
+				<td align="right"><b>OSGeo FDO Provider for SDF<b></td>
+			</tr>
+		</table>
+<!-- End of: header.html -->
+<!-- Generated by Doxygen 1.4.6-NO -->
+<div class="tabs">
+  <ul>
+    <li><a href="main.html"><span>Main&nbsp;Page</span></a></li>
+    <li><a href="classes.html"><span>Classes</span></a></li>
+    <li id="current"><a href="files.html"><span>Files</span></a></li>
+  </ul></div>
+<div class="tabs">
+  <ul>
+    <li><a href="files.html"><span>File&nbsp;List</span></a></li>
+    <li><a href="globals.html"><span>File&nbsp;Members</span></a></li>
+  </ul></div>
+<h1>ICreateSDFFile.h</h1><a href="_i_create_s_d_f_file_8h.html">Go to the documentation of this file.</a><div class="fragment"><pre class="fragment"><a name="l00001"></a>00001 <span class="comment">// </span>
+<a name="l00002"></a>00002 <span class="comment">//  Copyright (C) 2004-2006  Autodesk, Inc.</span>
+<a name="l00003"></a>00003 <span class="comment">//  </span>
+<a name="l00004"></a>00004 <span class="comment">//  This library is free software; you can redistribute it and/or</span>
+<a name="l00005"></a>00005 <span class="comment">//  modify it under the terms of version 2.1 of the GNU Lesser</span>
+<a name="l00006"></a>00006 <span class="comment">//  General Public License as published by the Free Software Foundation.</span>
+<a name="l00007"></a>00007 <span class="comment">//  </span>
+<a name="l00008"></a>00008 <span class="comment">//  This library is distributed in the hope that it will be useful,</span>
+<a name="l00009"></a>00009 <span class="comment">//  but WITHOUT ANY WARRANTY; without even the implied warranty of</span>
+<a name="l00010"></a>00010 <span class="comment">//  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU</span>
+<a name="l00011"></a>00011 <span class="comment">//  Lesser General Public License for more details.</span>
+<a name="l00012"></a>00012 <span class="comment">//  </span>
+<a name="l00013"></a>00013 <span class="comment">//  You should have received a copy of the GNU Lesser General Public</span>
+<a name="l00014"></a>00014 <span class="comment">//  License along with this library; if not, write to the Free Software</span>
+<a name="l00015"></a>00015 <span class="comment">//  Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA</span>
+<a name="l00016"></a>00016 <span class="preprocessor">#ifndef ICREATESDFFILE_H</span>
+<a name="l00017"></a>00017 <span class="preprocessor"></span><span class="preprocessor">#define ICREATESDFFILE_H</span>
+<a name="l00018"></a>00018 <span class="preprocessor"></span>
+<a name="l00019"></a>00019 <span class="preprocessor">#include "Std.h"</span>
+<a name="l00020"></a>00020 <span class="preprocessor">#include "Fdo/Commands/ICommand.h"</span>
+<a name="l00021"></a>00021
+<a name="l00022"></a>00022 <span class="comment"></span>
+<a name="l00023"></a>00023 <span class="comment">/// \brief</span>
+<a name="l00024"></a>00024 <span class="comment">/// This command creates a new SDF+ file with a specified location</span>
+<a name="l00025"></a>00025 <span class="comment">/// and file name and a given spatial coordinate system.</span>
+<a name="l00026"></a><a class="code" href="class_fdo_i_create_s_d_f_file.html">00026</a> <span class="comment"></span><span class="keyword">class </span><a class="code" href="class_fdo_i_create_s_d_f_file.html">FdoICreateSDFFile</a> : <span class="keyword">public</span> FdoICommand
+<a name="l00027"></a>00027 {
+<a name="l00028"></a>00028 <span class="keyword">public</span>:
+<a name="l00029"></a>00029 <span class="comment"></span>
+<a name="l00030"></a>00030 <span class="comment">    /// \brief</span>
+<a name="l00031"></a>00031 <span class="comment">    /// Sets the name of the SDF+ file being created.</span>
+<a name="l00032"></a>00032 <span class="comment">    /// The name must be a fully qualified absolute path.</span>
+<a name="l00033"></a>00033 <span class="comment">    /// </span>
+<a name="l00034"></a>00034 <span class="comment">    /// \param name </span>
+<a name="l00035"></a>00035 <span class="comment">    /// The fully qualified SDF+ file name.</span>
+<a name="l00036"></a>00036 <span class="comment">    /// </span>
+<a name="l00037"></a>00037 <span class="comment">    /// \return</span>
+<a name="l00038"></a>00038 <span class="comment">    /// Returns nothing.</span>
+<a name="l00039"></a>00039 <span class="comment">    /// </span>
+<a name="l00040"></a>00040 <span class="comment"></span>    FDO_API <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_i_create_s_d_f_file_e92b777da3c498180dd72fe4629ee788.html#e92b777da3c498180dd72fe4629ee788">SetFileName</a>(FdoString* name) = 0;
+<a name="l00041"></a>00041 <span class="comment"></span>
+<a name="l00042"></a>00042 <span class="comment">    /// \brief</span>
+<a name="l00043"></a>00043 <span class="comment">    /// Gets the name of the SDF+ file being created.</span>
+<a name="l00044"></a>00044 <span class="comment">    /// The name is a fully qualified absolute path.</span>
+<a name="l00045"></a>00045 <span class="comment">    /// </span>
+<a name="l00046"></a>00046 <span class="comment">    /// \return</span>
+<a name="l00047"></a>00047 <span class="comment">    /// Returns the name of the SDF+ file.</span>
+<a name="l00048"></a>00048 <span class="comment">    /// </span>
+<a name="l00049"></a>00049 <span class="comment"></span>    FDO_API <span class="keyword">virtual</span> FdoString* <a class="code" href="class_fdo_i_create_s_d_f_file_0bde059736005f052076c6735c8b2453.html#0bde059736005f052076c6735c8b2453">GetFileName</a>() = 0;
+<a name="l00050"></a>00050 <span class="comment"></span>
+<a name="l00051"></a>00051 <span class="comment">    /// \brief</span>
+<a name="l00052"></a>00052 <span class="comment">    /// Sets the name of the spatial context as a string.</span>
+<a name="l00053"></a>00053 <span class="comment">    /// </span>
+<a name="l00054"></a>00054 <span class="comment">    /// \param name </span>
+<a name="l00055"></a>00055 <span class="comment">    /// Input the name of the spatial context.</span>
+<a name="l00056"></a>00056 <span class="comment">    /// </span>
+<a name="l00057"></a>00057 <span class="comment">    /// \return</span>
+<a name="l00058"></a>00058 <span class="comment">    /// Returns nothing.</span>
+<a name="l00059"></a>00059 <span class="comment">    /// </span>
+<a name="l00060"></a>00060 <span class="comment"></span>    FDO_API <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_i_create_s_d_f_file_bda73a210df146335a62e933ebe19948.html#bda73a210df146335a62e933ebe19948">SetSpatialContextName</a>(FdoString* name) = 0;
+<a name="l00061"></a>00061 <span class="comment"></span>
+<a name="l00062"></a>00062 <span class="comment">    /// \brief</span>
+<a name="l00063"></a>00063 <span class="comment">    /// Gets the name of the coordinate system of the spatial context.</span>
+<a name="l00064"></a>00064 <span class="comment">    /// If the result is a null or empty string, the coordinate system is</span>
+<a name="l00065"></a>00065 <span class="comment">    /// unknown to the spatial context.</span>
+<a name="l00066"></a>00066 <span class="comment">    /// </span>
+<a name="l00067"></a>00067 <span class="comment">    /// \return</span>
+<a name="l00068"></a>00068 <span class="comment">    /// Returns the coordinate system name of the spatial context.</span>
+<a name="l00069"></a>00069 <span class="comment">    /// </span>
+<a name="l00070"></a>00070 <span class="comment"></span>    FDO_API <span class="keyword">virtual</span> FdoString* <a class="code" href="class_fdo_i_create_s_d_f_file_647ff5d7f47cf47422c32645074cce8d.html#647ff5d7f47cf47422c32645074cce8d">GetSpatialContextName</a>() = 0;
+<a name="l00071"></a>00071 <span class="comment"></span>
+<a name="l00072"></a>00072 <span class="comment">    /// \brief</span>
+<a name="l00073"></a>00073 <span class="comment">    /// Sets the description of the spatial context as a string.</span>
+<a name="l00074"></a>00074 <span class="comment">    /// </span>
+<a name="l00075"></a>00075 <span class="comment">    /// \param description </span>
+<a name="l00076"></a>00076 <span class="comment">    /// Input the description of the spatial context.</span>
+<a name="l00077"></a>00077 <span class="comment">    /// </span>
+<a name="l00078"></a>00078 <span class="comment">    /// \return</span>
+<a name="l00079"></a>00079 <span class="comment">    /// Returns nothing.</span>
+<a name="l00080"></a>00080 <span class="comment">    /// </span>
+<a name="l00081"></a>00081 <span class="comment"></span>    FDO_API <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_i_create_s_d_f_file_86b4ac8510f46ad6629e42023f184cee.html#86b4ac8510f46ad6629e42023f184cee">SetSpatialContextDescription</a>(FdoString* description) = 0;
+<a name="l00082"></a>00082 <span class="comment"></span>
+<a name="l00083"></a>00083 <span class="comment">    /// \brief</span>
+<a name="l00084"></a>00084 <span class="comment">    /// Gets the description of the spatial context.</span>
+<a name="l00085"></a>00085 <span class="comment">    /// </span>
+<a name="l00086"></a>00086 <span class="comment">    /// \return</span>
+<a name="l00087"></a>00087 <span class="comment">    /// Returns the description of the spatial context.</span>
+<a name="l00088"></a>00088 <span class="comment">    /// </span>
+<a name="l00089"></a>00089 <span class="comment"></span>    FDO_API <span class="keyword">virtual</span> FdoString* <a class="code" href="class_fdo_i_create_s_d_f_file_4d74d6f8e45e76d8c8606953ae4cb307.html#4d74d6f8e45e76d8c8606953ae4cb307">GetSpatialContextDescription</a>() = 0;
+<a name="l00090"></a>00090 <span class="comment"></span>
+<a name="l00091"></a>00091 <span class="comment">    /// \brief</span>
+<a name="l00092"></a>00092 <span class="comment">    /// Sets the coordinate system of the context to create as a string in</span>
+<a name="l00093"></a>00093 <span class="comment">    /// OpenGIS SRS WKT format.</span>
+<a name="l00094"></a>00094 <span class="comment">    /// </span>
+<a name="l00095"></a>00095 <span class="comment">    /// \param wkt </span>
+<a name="l00096"></a>00096 <span class="comment">    /// Input the coordinate system.</span>
+<a name="l00097"></a>00097 <span class="comment">    /// </span>
+<a name="l00098"></a>00098 <span class="comment">    /// \return</span>
+<a name="l00099"></a>00099 <span class="comment">    /// Returns nothing.</span>
+<a name="l00100"></a>00100 <span class="comment">    /// </span>
+<a name="l00101"></a>00101 <span class="comment"></span>    FDO_API <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_i_create_s_d_f_file_8bb4c31009cf0ab76fc094eadcf4ca91.html#8bb4c31009cf0ab76fc094eadcf4ca91">SetCoordinateSystemWKT</a>(FdoString* wkt) = 0;
+<a name="l00102"></a>00102 <span class="comment"></span>
+<a name="l00103"></a>00103 <span class="comment">    /// \brief</span>
+<a name="l00104"></a>00104 <span class="comment">    /// Gets the name of the coordinate system in OpenGIS SRS WKT format of the spatial context.</span>
+<a name="l00105"></a>00105 <span class="comment">    /// If the result is an empty string, the coordinate system WKT description is</span>
+<a name="l00106"></a>00106 <span class="comment">    /// not available.</span>
+<a name="l00107"></a>00107 <span class="comment">    /// </span>
+<a name="l00108"></a>00108 <span class="comment">    /// \return</span>
+<a name="l00109"></a>00109 <span class="comment">    /// Returns the coordinate system description in WKT format of the spatial context.</span>
+<a name="l00110"></a>00110 <span class="comment">    /// </span>
+<a name="l00111"></a>00111 <span class="comment"></span>    FDO_API <span class="keyword">virtual</span> FdoString* <a class="code" href="class_fdo_i_create_s_d_f_file_0b8020c31deb9acc05311fd11f260c7d.html#0b8020c31deb9acc05311fd11f260c7d">GetCoordinateSystemWKT</a>() = 0;
+<a name="l00112"></a>00112 <span class="comment"></span>
+<a name="l00113"></a>00113 <span class="comment">    /// \brief</span>
+<a name="l00114"></a>00114 <span class="comment">    /// Sets the tolerance value to use for X/Y ordinates. Tolerances are used</span>
+<a name="l00115"></a>00115 <span class="comment">    /// in some geometric tests, mostly for equality between coordinates. This</span>
+<a name="l00116"></a>00116 <span class="comment">    /// occurs frequently in spatial queries, especially with "on boundary" or "just</span>
+<a name="l00117"></a>00117 <span class="comment">    /// touching" conditions. It is also an objective amount that can be used</span>
+<a name="l00118"></a>00118 <span class="comment">    /// when formulating step distances for parametric curve interpolation.</span>
+<a name="l00119"></a>00119 <span class="comment">    /// </span>
+<a name="l00120"></a>00120 <span class="comment">    /// \param tolerance </span>
+<a name="l00121"></a>00121 <span class="comment">    /// Input the tolerance.</span>
+<a name="l00122"></a>00122 <span class="comment">    /// </span>
+<a name="l00123"></a>00123 <span class="comment">    /// \return</span>
+<a name="l00124"></a>00124 <span class="comment">    /// Returns nothing.</span>
+<a name="l00125"></a>00125 <span class="comment">    /// </span>
+<a name="l00126"></a>00126 <span class="comment"></span>    FDO_API <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_i_create_s_d_f_file_b3e528dda87b952a83786b2d01343524.html#b3e528dda87b952a83786b2d01343524">SetXYTolerance</a>(<span class="keywordtype">double</span> tolerance) = 0;
+<a name="l00127"></a>00127 <span class="comment"></span>
+<a name="l00128"></a>00128 <span class="comment">    /// \brief</span>
+<a name="l00129"></a>00129 <span class="comment">    /// Gets the tolerance value for X/Y ordinates of the spatial context.</span>
+<a name="l00130"></a>00130 <span class="comment">    /// Tolerances are used in some geometric tests,</span>
+<a name="l00131"></a>00131 <span class="comment">    /// mostly for equality between coordinates. This occurs frequently in spatial</span>
+<a name="l00132"></a>00132 <span class="comment">    /// queries, especially with "on boundary" or "just touching" conditions.</span>
+<a name="l00133"></a>00133 <span class="comment">    /// It is also an objective amount that can be used when formulating step</span>
+<a name="l00134"></a>00134 <span class="comment">    /// distances for parametric curve interpolation.</span>
+<a name="l00135"></a>00135 <span class="comment">    /// </span>
+<a name="l00136"></a>00136 <span class="comment">    /// \return</span>
+<a name="l00137"></a>00137 <span class="comment">    /// Returns the tolerance.</span>
+<a name="l00138"></a>00138 <span class="comment">    /// </span>
+<a name="l00139"></a>00139 <span class="comment"></span>    FDO_API <span class="keyword">virtual</span> <span class="keywordtype">double</span> <a class="code" href="class_fdo_i_create_s_d_f_file_4a2bb60374b5db4f9dca173de2845803.html#4a2bb60374b5db4f9dca173de2845803">GetXYTolerance</a>() = 0;
+<a name="l00140"></a>00140     <span class="comment"></span>
+<a name="l00141"></a>00141 <span class="comment">    /// \brief</span>
+<a name="l00142"></a>00142 <span class="comment">    /// Sets the tolerance value to use for Z ordinates. Tolerances are used in</span>
+<a name="l00143"></a>00143 <span class="comment">    /// some geometric tests, mostly for equality between coordinates. This</span>
+<a name="l00144"></a>00144 <span class="comment">    /// occurs frequently in spatial queries, especially with "on boundary" or "just</span>
+<a name="l00145"></a>00145 <span class="comment">    /// touching" conditions. It is also an objective amount that can be used</span>
+<a name="l00146"></a>00146 <span class="comment">    /// when formulating step distances for parametric curve interpolation.</span>
+<a name="l00147"></a>00147 <span class="comment">    /// </span>
+<a name="l00148"></a>00148 <span class="comment">    /// \param tolerance </span>
+<a name="l00149"></a>00149 <span class="comment">    /// Input the tolerance.</span>
+<a name="l00150"></a>00150 <span class="comment">    /// </span>
+<a name="l00151"></a>00151 <span class="comment">    /// \return</span>
+<a name="l00152"></a>00152 <span class="comment">    /// Returns nothing.</span>
+<a name="l00153"></a>00153 <span class="comment">    /// </span>
+<a name="l00154"></a>00154 <span class="comment"></span>    FDO_API <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_i_create_s_d_f_file_2937b06fdf37207301200042b40e8d71.html#2937b06fdf37207301200042b40e8d71">SetZTolerance</a>(<span class="keywordtype">double</span> tolerance) = 0;
+<a name="l00155"></a>00155 <span class="comment"></span>
+<a name="l00156"></a>00156 <span class="comment">    /// \brief</span>
+<a name="l00157"></a>00157 <span class="comment">    /// Gets the tolerance value for Z ordinates of the spatial context.</span>
+<a name="l00158"></a>00158 <span class="comment">    /// Tolerances are used in some geometric tests,</span>
+<a name="l00159"></a>00159 <span class="comment">    /// mostly for equality between coordinates. This occurs a frequently in spatial</span>
+<a name="l00160"></a>00160 <span class="comment">    /// queries, especially with "on boundary" or "just touching" conditions.</span>
+<a name="l00161"></a>00161 <span class="comment">    /// It is also an objective amount that can be used when formulating step</span>
+<a name="l00162"></a>00162 <span class="comment">    /// distances for parametric curve interpolation.</span>
+<a name="l00163"></a>00163 <span class="comment">    /// </span>
+<a name="l00164"></a>00164 <span class="comment">    /// \return</span>
+<a name="l00165"></a>00165 <span class="comment">    /// Returns the tolerance.</span>
+<a name="l00166"></a>00166 <span class="comment">    /// </span>
+<a name="l00167"></a>00167 <span class="comment"></span>    FDO_API <span class="keyword">virtual</span> <span class="keywordtype">double</span> <a class="code" href="class_fdo_i_create_s_d_f_file_8b2fc8bbd39311d609c316fac75d765b.html#8b2fc8bbd39311d609c316fac75d765b">GetZTolerance</a>() = 0;
+<a name="l00168"></a>00168 <span class="comment"></span>
+<a name="l00169"></a>00169 <span class="comment">    /// \brief</span>
+<a name="l00170"></a>00170 <span class="comment">    /// Executes the command. An exception is thrown if the file fails to be </span>
+<a name="l00171"></a>00171 <span class="comment">    /// created.</span>
+<a name="l00172"></a>00172 <span class="comment">    /// </span>
+<a name="l00173"></a>00173 <span class="comment">    /// \return</span>
+<a name="l00174"></a>00174 <span class="comment">    /// Returns nothing.</span>
+<a name="l00175"></a>00175 <span class="comment">    /// </span>
+<a name="l00176"></a>00176 <span class="comment"></span>    FDO_API <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_i_create_s_d_f_file_05550ca7007c3e389b7029c41baa1587.html#05550ca7007c3e389b7029c41baa1587">Execute</a>() = 0;
+<a name="l00177"></a>00177
+<a name="l00178"></a>00178 };
+<a name="l00179"></a>00179
+<a name="l00180"></a>00180
+<a name="l00181"></a>00181 <span class="preprocessor">#endif</span>
+<a name="l00182"></a>00182 <span class="preprocessor"></span>
+<a name="l00183"></a>00183
+</pre></div><!-- footer.html -->
+		<hr>
+			<tr>
+				<td align="right"><font size="-2"><a href="mailto:isd.docs at autodesk.com&subject=FDO%20Provider%20for%20SDF%20API%20documentation">Comments?</a></font></td>
+				<!-- The logo can go in another cell, when we get one -->
+			</tr>
+		</table>
+	</body>
+</html>
Added: trunk/www/docs/SDF/_i_create_s_d_f_file_8h.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_i_create_s_d_f_file_8h.html?view=auto&rev=11
--- (empty file)
+++ trunk/www/docs/SDF/_i_create_s_d_f_file_8h.html	2006-05-16 20:14:06+0000
@@ -0,0 +1,55 @@
+<html>
+	<head>
+	</head>
+			<tr>
+			</tr>
+		</table>
+<div class="tabs">
+  <ul>
+  </ul></div>
+<div class="tabs">
+  <ul>
+  </ul></div>
+<h1>ICreateSDFFile.h File Reference</h1>
+<p>
+<code>#include &quot;Std.h&quot;</code><br>
+<code>#include &quot;Fdo/Commands/ICommand.h&quot;</code><br>
+<p>
+Include dependency graph for ICreateSDFFile.h:<p><center><img src="_i_create_s_d_f_file_8h__incl.png" border="0" usemap="#ICreateSDFFile.h_map" alt=""></center>
+<p>
+<a href="_i_create_s_d_f_file_8h-source.html">Go to the source code of this file.</a><table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td colspan="2"><br><h2>Classes</h2></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">class &nbsp;</td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_i_create_s_d_f_file.html">FdoICreateSDFFile</a></td></tr>
+<tr><td class="mdescLeft">&nbsp;</td><td class="mdescRight">This command creates a new SDF+ file with a specified location and file name and a given spatial coordinate system.  <a href="class_fdo_i_create_s_d_f_file.html#_details">More...</a><br></td></tr>
+</table>
+<!-- footer.html -->
+		<hr>
+			<tr>
+			</tr>
+		</table>
+	</body>
+</html>
Added: trunk/www/docs/SDF/_i_create_s_d_f_file_8h__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_i_create_s_d_f_file_8h__incl.map?view=auto&rev=11
--- (empty file)
+++ trunk/www/docs/SDF/_i_create_s_d_f_file_8h__incl.map	2006-05-16 20:14:06+0000
@@ -0,0 +1 @@
+base referer
Added: trunk/www/docs/SDF/_i_create_s_d_f_file_8h__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_i_create_s_d_f_file_8h__incl.md5?view=auto&rev=11
--- (empty file)
+++ trunk/www/docs/SDF/_i_create_s_d_f_file_8h__incl.md5	2006-05-16 20:14:06+0000
@@ -0,0 +1 @@
+b7f2c016a3d343e487215e39332e9d4a
\ No newline at end of file
Added: trunk/www/docs/SDF/_i_create_s_d_f_file_8h__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/_i_create_s_d_f_file_8h__incl.png?view=auto&rev=11
Binary file. No diff available.
Added: trunk/www/docs/SDF/annotated.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/annotated.html?view=auto&rev=11
--- (empty file)
+++ trunk/www/docs/SDF/annotated.html	2006-05-16 20:14:06+0000
@@ -0,0 +1,44 @@
+<html>
+	<head>
+	</head>
+			<tr>
+			</tr>
+		</table>
+<div class="tabs">
+  <ul>
+    <li id="current"><a href="classes.html"><span>Classes</span></a></li>
+    <li><a href="files.html"><span>Files</span></a></li>
+  </ul></div>
+<div class="tabs">
+  <ul>
+    <li><a href="classes.html"><span>Alphabetical&nbsp;List</span></a></li>
+    <li id="current"><a href="annotated.html"><span>Class&nbsp;List</span></a></li>
+    <li><a href="hierarchy.html"><span>Class&nbsp;Hierarchy</span></a></li>
+    <li><a href="functions.html"><span>Class&nbsp;Members</span></a></li>
+  </ul></div>
+<h1>FDO Provider for SDF Class List</h1>Here are the classes, structs, unions and interfaces with brief descriptions:<table>
+  <tr><td class="indexkey"><a class="el" href="class_fdo_i_create_s_d_f_file.html">FdoICreateSDFFile</a></td><td class="indexvalue">This command creates a new SDF+ file with a specified location and file name and a given spatial coordinate system </td></tr>
+</table>
+		<hr>
+			<tr>
+			</tr>
+		</table>
+	</body>
+</html>
Added: trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file-members.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file-members.html?view=auto&rev=11
--- (empty file)
+++ trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file-members.html	2006-05-16 20:14:06+0000
@@ -0,0 +1,55 @@
+<html>
+	<head>
+	</head>
+			<tr>
+			</tr>
+		</table>
+<div class="tabs">
+  <ul>
+  </ul></div>
+<div class="tabs">
+  <ul>
+    <li><a href="annotated.html"><span>Class&nbsp;List</span></a></li>
+  </ul></div>
+<h1>FdoICreateSDFFile Member List</h1>This is the complete list of members for <a class="el" href="class_fdo_i_create_s_d_f_file.html">FdoICreateSDFFile</a>, including all inherited members.<p><table>
+  <tr class="memlist"><td><a class="el" href="class_fdo_i_create_s_d_f_file_05550ca7007c3e389b7029c41baa1587.html#05550ca7007c3e389b7029c41baa1587">Execute</a>()=0</td><td><a class="el" href="class_fdo_i_create_s_d_f_file.html">FdoICreateSDFFile</a></td><td><code> [pure virtual]</code></td></tr>
+  <tr class="memlist"><td><a class="el" href="class_fdo_i_create_s_d_f_file_0b8020c31deb9acc05311fd11f260c7d.html#0b8020c31deb9acc05311fd11f260c7d">GetCoordinateSystemWKT</a>()=0</td><td><a class="el" href="class_fdo_i_create_s_d_f_file.html">FdoICreateSDFFile</a></td><td><code> [pure virtual]</code></td></tr>
+  <tr class="memlist"><td><a class="el" href="class_fdo_i_create_s_d_f_file_0bde059736005f052076c6735c8b2453.html#0bde059736005f052076c6735c8b2453">GetFileName</a>()=0</td><td><a class="el" href="class_fdo_i_create_s_d_f_file.html">FdoICreateSDFFile</a></td><td><code> [pure virtual]</code></td></tr>
+  <tr class="memlist"><td><a class="el" href="class_fdo_i_create_s_d_f_file_4d74d6f8e45e76d8c8606953ae4cb307.html#4d74d6f8e45e76d8c8606953ae4cb307">GetSpatialContextDescription</a>()=0</td><td><a class="el" href="class_fdo_i_create_s_d_f_file.html">FdoICreateSDFFile</a></td><td><code> [pure virtual]</code></td></tr>
+  <tr class="memlist"><td><a class="el" href="class_fdo_i_create_s_d_f_file_647ff5d7f47cf47422c32645074cce8d.html#647ff5d7f47cf47422c32645074cce8d">GetSpatialContextName</a>()=0</td><td><a class="el" href="class_fdo_i_create_s_d_f_file.html">FdoICreateSDFFile</a></td><td><code> [pure virtual]</code></td></tr>
+  <tr class="memlist"><td><a class="el" href="class_fdo_i_create_s_d_f_file_4a2bb60374b5db4f9dca173de2845803.html#4a2bb60374b5db4f9dca173de2845803">GetXYTolerance</a>()=0</td><td><a class="el" href="class_fdo_i_create_s_d_f_file.html">FdoICreateSDFFile</a></td><td><code> [pure virtual]</code></td></tr>
+  <tr class="memlist"><td><a class="el" href="class_fdo_i_create_s_d_f_file_8b2fc8bbd39311d609c316fac75d765b.html#8b2fc8bbd39311d609c316fac75d765b">GetZTolerance</a>()=0</td><td><a class="el" href="class_fdo_i_create_s_d_f_file.html">FdoICreateSDFFile</a></td><td><code> [pure virtual]</code></td></tr>
+  <tr class="memlist"><td><a class="el" href="class_fdo_i_create_s_d_f_file_8bb4c31009cf0ab76fc094eadcf4ca91.html#8bb4c31009cf0ab76fc094eadcf4ca91">SetCoordinateSystemWKT</a>(FdoString *wkt)=0</td><td><a class="el" href="class_fdo_i_create_s_d_f_file.html">FdoICreateSDFFile</a></td><td><code> [pure virtual]</code></td></tr>
+  <tr class="memlist"><td><a class="el" href="class_fdo_i_create_s_d_f_file_e92b777da3c498180dd72fe4629ee788.html#e92b777da3c498180dd72fe4629ee788">SetFileName</a>(FdoString *name)=0</td><td><a class="el" href="class_fdo_i_create_s_d_f_file.html">FdoICreateSDFFile</a></td><td><code> [pure virtual]</code></td></tr>
+  <tr class="memlist"><td><a class="el" href="class_fdo_i_create_s_d_f_file_86b4ac8510f46ad6629e42023f184cee.html#86b4ac8510f46ad6629e42023f184cee">SetSpatialContextDescription</a>(FdoString *description)=0</td><td><a class="el" href="class_fdo_i_create_s_d_f_file.html">FdoICreateSDFFile</a></td><td><code> [pure virtual]</code></td></tr>
+  <tr class="memlist"><td><a class="el" href="class_fdo_i_create_s_d_f_file_bda73a210df146335a62e933ebe19948.html#bda73a210df146335a62e933ebe19948">SetSpatialContextName</a>(FdoString *name)=0</td><td><a class="el" href="class_fdo_i_create_s_d_f_file.html">FdoICreateSDFFile</a></td><td><code> [pure virtual]</code></td></tr>
+  <tr class="memlist"><td><a class="el" href="class_fdo_i_create_s_d_f_file_b3e528dda87b952a83786b2d01343524.html#b3e528dda87b952a83786b2d01343524">SetXYTolerance</a>(double tolerance)=0</td><td><a class="el" href="class_fdo_i_create_s_d_f_file.html">FdoICreateSDFFile</a></td><td><code> [pure virtual]</code></td></tr>
+  <tr class="memlist"><td><a class="el" href="class_fdo_i_create_s_d_f_file_2937b06fdf37207301200042b40e8d71.html#2937b06fdf37207301200042b40e8d71">SetZTolerance</a>(double tolerance)=0</td><td><a class="el" href="class_fdo_i_create_s_d_f_file.html">FdoICreateSDFFile</a></td><td><code> [pure virtual]</code></td></tr>
+</table><!-- footer.html -->
+		<hr>
+			<tr>
+			</tr>
+		</table>
+	</body>
+</html>
Added: trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file.html?view=auto&rev=11
--- (empty file)
+++ trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file.html	2006-05-16 20:14:06+0000
@@ -0,0 +1,93 @@
+<html>
+	<head>
+	</head>
+			<tr>
+			</tr>
+		</table>
+<div class="tabs">
+  <ul>
+  </ul></div>
+<div class="tabs">
+  <ul>
+  </ul></div>
+<h1>FdoICreateSDFFile Class Reference</h1><!-- doxytag: class="FdoICreateSDFFile" --><code>#include &lt;<a class="el" href="_i_create_s_d_f_file_8h-source.html">ICreateSDFFile.h</a>&gt;</code>
+<p>
+<a href="class_fdo_i_create_s_d_f_file-members.html">List of all members.</a><hr><a name="_details"></a><h2>Detailed Description</h2>
+This command creates a new SDF+ file with a specified location and file name and a given spatial coordinate system.
+<p>
+<p>
+Definition at line <a class="el" href="_i_create_s_d_f_file_8h-source.html#l00026">26</a> of file <a class="el" href="_i_create_s_d_f_file_8h-source.html">ICreateSDFFile.h</a>.<table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td colspan="2"><br><h2>Public Member Functions</h2></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDO_API void&nbsp;</td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_i_create_s_d_f_file_05550ca7007c3e389b7029c41baa1587.html#05550ca7007c3e389b7029c41baa1587">Execute</a> ()=0</td></tr>
+<tr><td class="mdescLeft">&nbsp;</td><td class="mdescRight">Executes the command. An exception is thrown if the file fails to be created.  <a href="#05550ca7007c3e389b7029c41baa1587"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDO_API FdoString *&nbsp;</td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_i_create_s_d_f_file_0b8020c31deb9acc05311fd11f260c7d.html#0b8020c31deb9acc05311fd11f260c7d">GetCoordinateSystemWKT</a> ()=0</td></tr>
+<tr><td class="mdescLeft">&nbsp;</td><td class="mdescRight">Gets the name of the coordinate system in OpenGIS SRS WKT format of the spatial context. If the result is an empty string, the coordinate system WKT description is not available.  <a href="#0b8020c31deb9acc05311fd11f260c7d"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDO_API FdoString *&nbsp;</td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_i_create_s_d_f_file_0bde059736005f052076c6735c8b2453.html#0bde059736005f052076c6735c8b2453">GetFileName</a> ()=0</td></tr>
+<tr><td class="mdescLeft">&nbsp;</td><td class="mdescRight">Gets the name of the SDF+ file being created. The name is a fully qualified absolute path.  <a href="#0bde059736005f052076c6735c8b2453"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDO_API FdoString *&nbsp;</td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_i_create_s_d_f_file_4d74d6f8e45e76d8c8606953ae4cb307.html#4d74d6f8e45e76d8c8606953ae4cb307">GetSpatialContextDescription</a> ()=0</td></tr>
+<tr><td class="mdescLeft">&nbsp;</td><td class="mdescRight">Gets the description of the spatial context.  <a href="#4d74d6f8e45e76d8c8606953ae4cb307"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDO_API FdoString *&nbsp;</td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_i_create_s_d_f_file_647ff5d7f47cf47422c32645074cce8d.html#647ff5d7f47cf47422c32645074cce8d">GetSpatialContextName</a> ()=0</td></tr>
+<tr><td class="mdescLeft">&nbsp;</td><td class="mdescRight">Gets the name of the coordinate system of the spatial context. If the result is a null or empty string, the coordinate system is unknown to the spatial context.  <a href="#647ff5d7f47cf47422c32645074cce8d"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDO_API double&nbsp;</td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_i_create_s_d_f_file_4a2bb60374b5db4f9dca173de2845803.html#4a2bb60374b5db4f9dca173de2845803">GetXYTolerance</a> ()=0</td></tr>
+<tr><td class="mdescLeft">&nbsp;</td><td class="mdescRight">Gets the tolerance value for X/Y ordinates of the spatial context. Tolerances are used in some geometric tests, mostly for equality between coordinates. This occurs frequently in spatial queries, especially with "on boundary" or "just touching" conditions. It is also an objective amount that can be used when formulating step distances for parametric curve interpolation.  <a href="#4a2bb60374b5db4f9dca173de2845803"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDO_API double&nbsp;</td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_i_create_s_d_f_file_8b2fc8bbd39311d609c316fac75d765b.html#8b2fc8bbd39311d609c316fac75d765b">GetZTolerance</a> ()=0</td></tr>
+<tr><td class="mdescLeft">&nbsp;</td><td class="mdescRight">Gets the tolerance value for Z ordinates of the spatial context. Tolerances are used in some geometric tests, mostly for equality between coordinates. This occurs a frequently in spatial queries, especially with "on boundary" or "just touching" conditions. It is also an objective amount that can be used when formulating step distances for parametric curve interpolation.  <a href="#8b2fc8bbd39311d609c316fac75d765b"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDO_API void&nbsp;</td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_i_create_s_d_f_file_8bb4c31009cf0ab76fc094eadcf4ca91.html#8bb4c31009cf0ab76fc094eadcf4ca91">SetCoordinateSystemWKT</a> (FdoString *wkt)=0</td></tr>
+<tr><td class="mdescLeft">&nbsp;</td><td class="mdescRight">Sets the coordinate system of the context to create as a string in OpenGIS SRS WKT format.  <a href="#8bb4c31009cf0ab76fc094eadcf4ca91"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDO_API void&nbsp;</td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_i_create_s_d_f_file_e92b777da3c498180dd72fe4629ee788.html#e92b777da3c498180dd72fe4629ee788">SetFileName</a> (FdoString *name)=0</td></tr>
+<tr><td class="mdescLeft">&nbsp;</td><td class="mdescRight">Sets the name of the SDF+ file being created. The name must be a fully qualified absolute path.  <a href="#e92b777da3c498180dd72fe4629ee788"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDO_API void&nbsp;</td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_i_create_s_d_f_file_86b4ac8510f46ad6629e42023f184cee.html#86b4ac8510f46ad6629e42023f184cee">SetSpatialContextDescription</a> (FdoString *description)=0</td></tr>
+<tr><td class="mdescLeft">&nbsp;</td><td class="mdescRight">Sets the description of the spatial context as a string.  <a href="#86b4ac8510f46ad6629e42023f184cee"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDO_API void&nbsp;</td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_i_create_s_d_f_file_bda73a210df146335a62e933ebe19948.html#bda73a210df146335a62e933ebe19948">SetSpatialContextName</a> (FdoString *name)=0</td></tr>
+<tr><td class="mdescLeft">&nbsp;</td><td class="mdescRight">Sets the name of the spatial context as a string.  <a href="#bda73a210df146335a62e933ebe19948"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDO_API void&nbsp;</td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_i_create_s_d_f_file_b3e528dda87b952a83786b2d01343524.html#b3e528dda87b952a83786b2d01343524">SetXYTolerance</a> (double tolerance)=0</td></tr>
+<tr><td class="mdescLeft">&nbsp;</td><td class="mdescRight">Sets the tolerance value to use for X/Y ordinates. Tolerances are used in some geometric tests, mostly for equality between coordinates. This occurs frequently in spatial queries, especially with "on boundary" or "just touching" conditions. It is also an objective amount that can be used when formulating step distances for parametric curve interpolation.  <a href="#b3e528dda87b952a83786b2d01343524"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDO_API void&nbsp;</td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_i_create_s_d_f_file_2937b06fdf37207301200042b40e8d71.html#2937b06fdf37207301200042b40e8d71">SetZTolerance</a> (double tolerance)=0</td></tr>
+<tr><td class="mdescLeft">&nbsp;</td><td class="mdescRight">Sets the tolerance value to use for Z ordinates. Tolerances are used in some geometric tests, mostly for equality between coordinates. This occurs frequently in spatial queries, especially with "on boundary" or "just touching" conditions. It is also an objective amount that can be used when formulating step distances for parametric curve interpolation.  <a href="#2937b06fdf37207301200042b40e8d71"></a><br></td></tr>
+</table>
+<hr>The documentation for this class was generated from the following file:<ul>
+<li><a class="el" href="_i_create_s_d_f_file_8h-source.html">ICreateSDFFile.h</a></ul>
+		<hr>
+			<tr>
+			</tr>
+		</table>
+	</body>
+</html>
Added: trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_05550ca7007c3e389b7029c41baa1587.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_05550ca7007c3e389b7029c41baa1587.html?view=auto&rev=11
--- (empty file)
+++ trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_05550ca7007c3e389b7029c41baa1587.html	2006-05-16 20:14:06+0000
@@ -0,0 +1,91 @@
+<html>
+	<head>
+	</head>
+			<tr>
+			</tr>
+		</table>
+<div class="tabs">
+  <ul>
+  </ul></div>
+<div class="nav">
+<a class="el" href="class_fdo_i_create_s_d_f_file.html">FdoICreateSDFFile</a></div>
+<table cellspacing="0" cellpadding="0" border="0">
+  <tr>
+   <td valign="top">
+      <div class="navtab">
+        <table>
+          <tr><td class="navtab"><a class="qindexHL" href="class_fdo_i_create_s_d_f_file_05550ca7007c3e389b7029c41baa1587.html#05550ca7007c3e389b7029c41baa1587">Execute</a></td></tr>
+          <tr><td class="navtab"><a class="qindex" href="class_fdo_i_create_s_d_f_file_0b8020c31deb9acc05311fd11f260c7d.html#0b8020c31deb9acc05311fd11f260c7d">GetCoordinateSystemWKT</a></td></tr>
+          <tr><td class="navtab"><a class="qindex" href="class_fdo_i_create_s_d_f_file_0bde059736005f052076c6735c8b2453.html#0bde059736005f052076c6735c8b2453">GetFileName</a></td></tr>
+          <tr><td class="navtab"><a class="qindex" href="class_fdo_i_create_s_d_f_file_4d74d6f8e45e76d8c8606953ae4cb307.html#4d74d6f8e45e76d8c8606953ae4cb307">GetSpatialContextDescription</a></td></tr>
+          <tr><td class="navtab"><a class="qindex" href="class_fdo_i_create_s_d_f_file_647ff5d7f47cf47422c32645074cce8d.html#647ff5d7f47cf47422c32645074cce8d">GetSpatialContextName</a></td></tr>
+          <tr><td class="navtab"><a class="qindex" href="class_fdo_i_create_s_d_f_file_4a2bb60374b5db4f9dca173de2845803.html#4a2bb60374b5db4f9dca173de2845803">GetXYTolerance</a></td></tr>
+          <tr><td class="navtab"><a class="qindex" href="class_fdo_i_create_s_d_f_file_8b2fc8bbd39311d609c316fac75d765b.html#8b2fc8bbd39311d609c316fac75d765b">GetZTolerance</a></td></tr>
+          <tr><td class="navtab"><a class="qindex" href="class_fdo_i_create_s_d_f_file_8bb4c31009cf0ab76fc094eadcf4ca91.html#8bb4c31009cf0ab76fc094eadcf4ca91">SetCoordinateSystemWKT</a></td></tr>
+          <tr><td class="navtab"><a class="qindex" href="class_fdo_i_create_s_d_f_file_e92b777da3c498180dd72fe4629ee788.html#e92b777da3c498180dd72fe4629ee788">SetFileName</a></td></tr>
+          <tr><td class="navtab"><a class="qindex" href="class_fdo_i_create_s_d_f_file_86b4ac8510f46ad6629e42023f184cee.html#86b4ac8510f46ad6629e42023f184cee">SetSpatialContextDescription</a></td></tr>
+          <tr><td class="navtab"><a class="qindex" href="class_fdo_i_create_s_d_f_file_bda73a210df146335a62e933ebe19948.html#bda73a210df146335a62e933ebe19948">SetSpatialContextName</a></td></tr>
+          <tr><td class="navtab"><a class="qindex" href="class_fdo_i_create_s_d_f_file_b3e528dda87b952a83786b2d01343524.html#b3e528dda87b952a83786b2d01343524">SetXYTolerance</a></td></tr>
+          <tr><td class="navtab"><a class="qindex" href="class_fdo_i_create_s_d_f_file_2937b06fdf37207301200042b40e8d71.html#2937b06fdf37207301200042b40e8d71">SetZTolerance</a></td></tr>
+        </table>
+      </div>
+   </td>
+   <td valign="top">
+<a class="anchor" name="05550ca7007c3e389b7029c41baa1587"></a><!-- doxytag: member="FdoICreateSDFFile::Execute" ref="05550ca7007c3e389b7029c41baa1587" args="()=0" --><p>
+<table class="mdTable" cellpadding="2" cellspacing="0">
+  <tr>
+    <td class="mdRow">
+      <table cellpadding="0" cellspacing="0" border="0">
+        <tr>
+          <td class="md" nowrap valign="top">virtual FDO_API void FdoICreateSDFFile::Execute           </td>
+          <td class="md" valign="top">(&nbsp;</td>
+          <td class="mdname1" valign="top" nowrap>          </td>
+          <td class="md" valign="top">&nbsp;)&nbsp;</td>
+          <td class="md" nowrap><code> [pure virtual]</code></td>
+        </tr>
+      </table>
+    </td>
+  </tr>
+</table>
+<table cellspacing="5" cellpadding="0" border="0">
+  <tr>
+    <td>
+      &nbsp;
+    </td>
+    <td>
+<p>
+Executes the command. An exception is thrown if the file fails to be created.
+<p>
+<dl compact><dt><b>Returns:</b></dt><dd>Returns nothing. </dd></dl>
+    </td>
+  </tr>
+</table>
+    </td>
+  </tr>
+</table>
+		<hr>
+			<tr>
+			</tr>
+		</table>
+	</body>
+</html>
Added: trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_0b8020c31deb9acc05311fd11f260c7d.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_0b8020c31deb9acc05311fd11f260c7d.html?view=auto&rev=11
--- (empty file)
+++ trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_0b8020c31deb9acc05311fd11f260c7d.html	2006-05-16 20:14:06+0000
@@ -0,0 +1,91 @@
+<html>
+	<head>
+	</head>
+			<tr>
+			</tr>
+		</table>
+<div class="tabs">
+  <ul>
+  </ul></div>
+<div class="nav">
+  <tr>
+   <td valign="top">
+        <table>
+          <tr><td class="navtab"><a class="qindex" href="class_fdo_i_create_s_d_f_file_05550ca7007c3e389b7029c41baa1587.html#05550ca7007c3e389b7029c41baa1587">Execute</a></td></tr>
+          <tr><td class="navtab"><a class="qindexHL" href="class_fdo_i_create_s_d_f_file_0b8020c31deb9acc05311fd11f260c7d.html#0b8020c31deb9acc05311fd11f260c7d">GetCoordinateSystemWKT</a></td></tr>
+        </table>
+      </div>
+   </td>
+   <td valign="top">
+<a class="anchor" name="0b8020c31deb9acc05311fd11f260c7d"></a><!-- doxytag: member="FdoICreateSDFFile::GetCoordinateSystemWKT" ref="0b8020c31deb9acc05311fd11f260c7d" args="()=0" --><p>
+  <tr>
+        <tr>
+          <td class="md" nowrap valign="top">virtual FDO_API FdoString* FdoICreateSDFFile::GetCoordinateSystemWKT           </td>
+        </tr>
+      </table>
+    </td>
+  </tr>
+</table>
+  <tr>
+    <td>
+      &nbsp;
+    </td>
+    <td>
+<p>
+Gets the name of the coordinate system in OpenGIS SRS WKT format of the spatial context. If the result is an empty string, the coordinate system WKT description is not available.
+<p>
+<dl compact><dt><b>Returns:</b></dt><dd>Returns the coordinate system description in WKT format of the spatial context. </dd></dl>
+    </td>
+  </tr>
+</table>
+    </td>
+  </tr>
+</table>
+		<hr>
+			<tr>
+			</tr>
+		</table>
+	</body>
+</html>
Added: trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_0bde059736005f052076c6735c8b2453.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_0bde059736005f052076c6735c8b2453.html?view=auto&rev=11
--- (empty file)
+++ trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_0bde059736005f052076c6735c8b2453.html	2006-05-16 20:14:06+0000
@@ -0,0 +1,91 @@
+<html>
+	<head>
+	</head>
+			<tr>
+			</tr>
+		</table>
+<div class="tabs">
+  <ul>
+  </ul></div>
+<div class="nav">
+  <tr>
+   <td valign="top">
+        <table>
+          <tr><td class="navtab"><a class="qindexHL" href="class_fdo_i_create_s_d_f_file_0bde059736005f052076c6735c8b2453.html#0bde059736005f052076c6735c8b2453">GetFileName</a></td></tr>
+        </table>
+      </div>
+   </td>
+   <td valign="top">
+<a class="anchor" name="0bde059736005f052076c6735c8b2453"></a><!-- doxytag: member="FdoICreateSDFFile::GetFileName" ref="0bde059736005f052076c6735c8b2453" args="()=0" --><p>
+  <tr>
+        <tr>
+          <td class="md" nowrap valign="top">virtual FDO_API FdoString* FdoICreateSDFFile::GetFileName           </td>
+        </tr>
+      </table>
+    </td>
+  </tr>
+</table>
+  <tr>
+    <td>
+      &nbsp;
+    </td>
+    <td>
+<p>
+Gets the name of the SDF+ file being created. The name is a fully qualified absolute path.
+<p>
+<dl compact><dt><b>Returns:</b></dt><dd>Returns the name of the SDF+ file. </dd></dl>
+    </td>
+  </tr>
+</table>
+    </td>
+  </tr>
+</table>
+		<hr>
+			<tr>
+			</tr>
+		</table>
+	</body>
+</html>
Added: trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_2937b06fdf37207301200042b40e8d71.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_2937b06fdf37207301200042b40e8d71.html?view=auto&rev=11
--- (empty file)
+++ trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_2937b06fdf37207301200042b40e8d71.html	2006-05-16 20:14:06+0000
@@ -0,0 +1,97 @@
+<html>
+	<head>
+	</head>
+			<tr>
+			</tr>
+		</table>
+<div class="tabs">
+  <ul>
+  </ul></div>
+<div class="nav">
+  <tr>
+   <td valign="top">
+        <table>
+          <tr><td class="navtab"><a class="qindexHL" href="class_fdo_i_create_s_d_f_file_2937b06fdf37207301200042b40e8d71.html#2937b06fdf37207301200042b40e8d71">SetZTolerance</a></td></tr>
+        </table>
+      </div>
+   </td>
+   <td valign="top">
+<a class="anchor" name="2937b06fdf37207301200042b40e8d71"></a><!-- doxytag: member="FdoICreateSDFFile::SetZTolerance" ref="2937b06fdf37207301200042b40e8d71" args="(double tolerance)=0" --><p>
+  <tr>
+        <tr>
+          <td class="md" nowrap valign="top">virtual FDO_API void FdoICreateSDFFile::SetZTolerance           </td>
+          <td class="md" nowrap valign="top">double&nbsp;</td>
+          <td class="mdname1" valign="top" nowrap> <em>tolerance</em>          </td>
+        </tr>
+      </table>
+    </td>
+  </tr>
+</table>
+  <tr>
+    <td>
+      &nbsp;
+    </td>
+    <td>
+<p>
+Sets the tolerance value to use for Z ordinates. Tolerances are used in some geometric tests, mostly for equality between coordinates. This occurs frequently in spatial queries, especially with "on boundary" or "just touching" conditions. It is also an objective amount that can be used when formulating step distances for parametric curve interpolation.
+<p>
+<dl compact><dt><b>Parameters:</b></dt><dd>
+  <table border="0" cellspacing="2" cellpadding="0">
+    <tr><td valign="top"></td><td valign="top"><em>tolerance</em>&nbsp;</td><td>Input the tolerance.</td></tr>
+  </table>
+</dl>
+    </td>
+  </tr>
+</table>
+    </td>
+  </tr>
+</table>
+		<hr>
+			<tr>
+			</tr>
+		</table>
+	</body>
+</html>
Added: trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_4a2bb60374b5db4f9dca173de2845803.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_4a2bb60374b5db4f9dca173de2845803.html?view=auto&rev=11
--- (empty file)
+++ trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_4a2bb60374b5db4f9dca173de2845803.html	2006-05-16 20:14:06+0000
@@ -0,0 +1,91 @@
+<html>
+	<head>
+	</head>
+			<tr>
+			</tr>
+		</table>
+<div class="tabs">
+  <ul>
+  </ul></div>
+<div class="nav">
+  <tr>
+   <td valign="top">
+        <table>
+          <tr><td class="navtab"><a class="qindexHL" href="class_fdo_i_create_s_d_f_file_4a2bb60374b5db4f9dca173de2845803.html#4a2bb60374b5db4f9dca173de2845803">GetXYTolerance</a></td></tr>
+        </table>
+      </div>
+   </td>
+   <td valign="top">
+<a class="anchor" name="4a2bb60374b5db4f9dca173de2845803"></a><!-- doxytag: member="FdoICreateSDFFile::GetXYTolerance" ref="4a2bb60374b5db4f9dca173de2845803" args="()=0" --><p>
+  <tr>
+        <tr>
+          <td class="md" nowrap valign="top">virtual FDO_API double FdoICreateSDFFile::GetXYTolerance           </td>
+        </tr>
+      </table>
+    </td>
+  </tr>
+</table>
+  <tr>
+    <td>
+      &nbsp;
+    </td>
+    <td>
+<p>
+Gets the tolerance value for X/Y ordinates of the spatial context. Tolerances are used in some geometric tests, mostly for equality between coordinates. This occurs frequently in spatial queries, especially with "on boundary" or "just touching" conditions. It is also an objective amount that can be used when formulating step distances for parametric curve interpolation.
+<p>
+<dl compact><dt><b>Returns:</b></dt><dd>Returns the tolerance. </dd></dl>
+    </td>
+  </tr>
+</table>
+    </td>
+  </tr>
+</table>
+		<hr>
+			<tr>
+			</tr>
+		</table>
+	</body>
+</html>
Added: trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_4d74d6f8e45e76d8c8606953ae4cb307.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_4d74d6f8e45e76d8c8606953ae4cb307.html?view=auto&rev=11
--- (empty file)
+++ trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_4d74d6f8e45e76d8c8606953ae4cb307.html	2006-05-16 20:14:06+0000
@@ -0,0 +1,91 @@
+<html>
+	<head>
+	</head>
+			<tr>
+			</tr>
+		</table>
+<div class="tabs">
+  <ul>
+  </ul></div>
+<div class="nav">
+  <tr>
+   <td valign="top">
+        <table>
+          <tr><td class="navtab"><a class="qindexHL" href="class_fdo_i_create_s_d_f_file_4d74d6f8e45e76d8c8606953ae4cb307.html#4d74d6f8e45e76d8c8606953ae4cb307">GetSpatialContextDescription</a></td></tr>
+        </table>
+      </div>
+   </td>
+   <td valign="top">
+<a class="anchor" name="4d74d6f8e45e76d8c8606953ae4cb307"></a><!-- doxytag: member="FdoICreateSDFFile::GetSpatialContextDescription" ref="4d74d6f8e45e76d8c8606953ae4cb307" args="()=0" --><p>
+  <tr>
+        <tr>
+          <td class="md" nowrap valign="top">virtual FDO_API FdoString* FdoICreateSDFFile::GetSpatialContextDescription           </td>
+        </tr>
+      </table>
+    </td>
+  </tr>
+</table>
+  <tr>
+    <td>
+      &nbsp;
+    </td>
+    <td>
+<p>
+Gets the description of the spatial context.
+<p>
+<dl compact><dt><b>Returns:</b></dt><dd>Returns the description of the spatial context. </dd></dl>
+    </td>
+  </tr>
+</table>
+    </td>
+  </tr>
+</table>
+		<hr>
+			<tr>
+			</tr>
+		</table>
+	</body>
+</html>
Added: trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_647ff5d7f47cf47422c32645074cce8d.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_647ff5d7f47cf47422c32645074cce8d.html?view=auto&rev=11
--- (empty file)
+++ trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_647ff5d7f47cf47422c32645074cce8d.html	2006-05-16 20:14:06+0000
@@ -0,0 +1,91 @@
+<html>
+	<head>
+	</head>
+			<tr>
+			</tr>
+		</table>
+<div class="tabs">
+  <ul>
+  </ul></div>
+<div class="nav">
+  <tr>
+   <td valign="top">
+        <table>
+          <tr><td class="navtab"><a class="qindexHL" href="class_fdo_i_create_s_d_f_file_647ff5d7f47cf47422c32645074cce8d.html#647ff5d7f47cf47422c32645074cce8d">GetSpatialContextName</a></td></tr>
+        </table>
+      </div>
+   </td>
+   <td valign="top">
+<a class="anchor" name="647ff5d7f47cf47422c32645074cce8d"></a><!-- doxytag: member="FdoICreateSDFFile::GetSpatialContextName" ref="647ff5d7f47cf47422c32645074cce8d" args="()=0" --><p>
+  <tr>
+        <tr>
+          <td class="md" nowrap valign="top">virtual FDO_API FdoString* FdoICreateSDFFile::GetSpatialContextName           </td>
+        </tr>
+      </table>
+    </td>
+  </tr>
+</table>
+  <tr>
+    <td>
+      &nbsp;
+    </td>
+    <td>
+<p>
+Gets the name of the coordinate system of the spatial context. If the result is a null or empty string, the coordinate system is unknown to the spatial context.
+<p>
+<dl compact><dt><b>Returns:</b></dt><dd>Returns the coordinate system name of the spatial context. </dd></dl>
+    </td>
+  </tr>
+</table>
+    </td>
+  </tr>
+</table>
+		<hr>
+			<tr>
+			</tr>
+		</table>
+	</body>
+</html>
Added: trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_86b4ac8510f46ad6629e42023f184cee.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_86b4ac8510f46ad6629e42023f184cee.html?view=auto&rev=11
--- (empty file)
+++ trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_86b4ac8510f46ad6629e42023f184cee.html	2006-05-16 20:14:06+0000
@@ -0,0 +1,97 @@
+<html>
+	<head>
+	</head>
+			<tr>
+			</tr>
+		</table>
+<div class="tabs">
+  <ul>
+  </ul></div>
+<div class="nav">
+  <tr>
+   <td valign="top">
+        <table>
+          <tr><td class="navtab"><a class="qindexHL" href="class_fdo_i_create_s_d_f_file_86b4ac8510f46ad6629e42023f184cee.html#86b4ac8510f46ad6629e42023f184cee">SetSpatialContextDescription</a></td></tr>
+        </table>
+      </div>
+   </td>
+   <td valign="top">
+<a class="anchor" name="86b4ac8510f46ad6629e42023f184cee"></a><!-- doxytag: member="FdoICreateSDFFile::SetSpatialContextDescription" ref="86b4ac8510f46ad6629e42023f184cee" args="(FdoString *description)=0" --><p>
+  <tr>
+        <tr>
+          <td class="md" nowrap valign="top">virtual FDO_API void FdoICreateSDFFile::SetSpatialContextDescription           </td>
+          <td class="md" nowrap valign="top">FdoString *&nbsp;</td>
+          <td class="mdname1" valign="top" nowrap> <em>description</em>          </td>
+        </tr>
+      </table>
+    </td>
+  </tr>
+</table>
+  <tr>
+    <td>
+      &nbsp;
+    </td>
+    <td>
+<p>
+Sets the description of the spatial context as a string.
+<p>
+    <tr><td valign="top"></td><td valign="top"><em>description</em>&nbsp;</td><td>Input the description of the spatial context.</td></tr>
+  </table>
+</dl>
+    </td>
+  </tr>
+</table>
+    </td>
+  </tr>
+</table>
+		<hr>
+			<tr>
+			</tr>
+		</table>
+	</body>
+</html>
Added: trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_8b2fc8bbd39311d609c316fac75d765b.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_8b2fc8bbd39311d609c316fac75d765b.html?view=auto&rev=11
--- (empty file)
+++ trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_8b2fc8bbd39311d609c316fac75d765b.html	2006-05-16 20:14:06+0000
@@ -0,0 +1,91 @@
+<html>
+	<head>
+	</head>
+			<tr>
+			</tr>
+		</table>
+<div class="tabs">
+  <ul>
+  </ul></div>
+<div class="nav">
+  <tr>
+   <td valign="top">
+        <table>
+          <tr><td class="navtab"><a class="qindexHL" href="class_fdo_i_create_s_d_f_file_8b2fc8bbd39311d609c316fac75d765b.html#8b2fc8bbd39311d609c316fac75d765b">GetZTolerance</a></td></tr>
+        </table>
+      </div>
+   </td>
+   <td valign="top">
+<a class="anchor" name="8b2fc8bbd39311d609c316fac75d765b"></a><!-- doxytag: member="FdoICreateSDFFile::GetZTolerance" ref="8b2fc8bbd39311d609c316fac75d765b" args="()=0" --><p>
+  <tr>
+        <tr>
+          <td class="md" nowrap valign="top">virtual FDO_API double FdoICreateSDFFile::GetZTolerance           </td>
+        </tr>
+      </table>
+    </td>
+  </tr>
+</table>
+  <tr>
+    <td>
+      &nbsp;
+    </td>
+    <td>
+<p>
+Gets the tolerance value for Z ordinates of the spatial context. Tolerances are used in some geometric tests, mostly for equality between coordinates. This occurs a frequently in spatial queries, especially with "on boundary" or "just touching" conditions. It is also an objective amount that can be used when formulating step distances for parametric curve interpolation.
+<p>
+    </td>
+  </tr>
+</table>
+    </td>
+  </tr>
+</table>
+		<hr>
+			<tr>
+			</tr>
+		</table>
+	</body>
+</html>
Added: trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_8bb4c31009cf0ab76fc094eadcf4ca91.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_8bb4c31009cf0ab76fc094eadcf4ca91.html?view=auto&rev=11
--- (empty file)
+++ trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_8bb4c31009cf0ab76fc094eadcf4ca91.html	2006-05-16 20:14:06+0000
@@ -0,0 +1,97 @@
+<html>
+	<head>
+	</head>
+			<tr>
+			</tr>
+		</table>
+<div class="tabs">
+  <ul>
+  </ul></div>
+<div class="nav">
+  <tr>
+   <td valign="top">
+        <table>
+          <tr><td class="navtab"><a class="qindexHL" href="class_fdo_i_create_s_d_f_file_8bb4c31009cf0ab76fc094eadcf4ca91.html#8bb4c31009cf0ab76fc094eadcf4ca91">SetCoordinateSystemWKT</a></td></tr>
+        </table>
+      </div>
+   </td>
+   <td valign="top">
+<a class="anchor" name="8bb4c31009cf0ab76fc094eadcf4ca91"></a><!-- doxytag: member="FdoICreateSDFFile::SetCoordinateSystemWKT" ref="8bb4c31009cf0ab76fc094eadcf4ca91" args="(FdoString *wkt)=0" --><p>
+  <tr>
+        <tr>
+          <td class="md" nowrap valign="top">virtual FDO_API void FdoICreateSDFFile::SetCoordinateSystemWKT           </td>
+          <td class="mdname1" valign="top" nowrap> <em>wkt</em>          </td>
+        </tr>
+      </table>
+    </td>
+  </tr>
+</table>
+  <tr>
+    <td>
+      &nbsp;
+    </td>
+    <td>
+<p>
+Sets the coordinate system of the context to create as a string in OpenGIS SRS WKT format.
+<p>
+    <tr><td valign="top"></td><td valign="top"><em>wkt</em>&nbsp;</td><td>Input the coordinate system.</td></tr>
+  </table>
+</dl>
+    </td>
+  </tr>
+</table>
+    </td>
+  </tr>
+</table>
+		<hr>
+			<tr>
+			</tr>
+		</table>
+	</body>
+</html>
Added: trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_b3e528dda87b952a83786b2d01343524.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_b3e528dda87b952a83786b2d01343524.html?view=auto&rev=11
--- (empty file)
+++ trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_b3e528dda87b952a83786b2d01343524.html	2006-05-16 20:14:06+0000
@@ -0,0 +1,97 @@
+<html>
+	<head>
+	</head>
+			<tr>
+			</tr>
+		</table>
+<div class="tabs">
+  <ul>
+  </ul></div>
+<div class="nav">
+  <tr>
+   <td valign="top">
+        <table>
+          <tr><td class="navtab"><a class="qindexHL" href="class_fdo_i_create_s_d_f_file_b3e528dda87b952a83786b2d01343524.html#b3e528dda87b952a83786b2d01343524">SetXYTolerance</a></td></tr>
+        </table>
+      </div>
+   </td>
+   <td valign="top">
+<a class="anchor" name="b3e528dda87b952a83786b2d01343524"></a><!-- doxytag: member="FdoICreateSDFFile::SetXYTolerance" ref="b3e528dda87b952a83786b2d01343524" args="(double tolerance)=0" --><p>
+  <tr>
+        <tr>
+          <td class="md" nowrap valign="top">virtual FDO_API void FdoICreateSDFFile::SetXYTolerance           </td>
+        </tr>
+      </table>
+    </td>
+  </tr>
+</table>
+  <tr>
+    <td>
+      &nbsp;
+    </td>
+    <td>
+<p>
+Sets the tolerance value to use for X/Y ordinates. Tolerances are used in some geometric tests, mostly for equality between coordinates. This occurs frequently in spatial queries, especially with "on boundary" or "just touching" conditions. It is also an objective amount that can be used when formulating step distances for parametric curve interpolation.
+<p>
+  </table>
+</dl>
+    </td>
+  </tr>
+</table>
+    </td>
+  </tr>
+</table>
+		<hr>
+			<tr>
+			</tr>
+		</table>
+	</body>
+</html>
Added: trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_bda73a210df146335a62e933ebe19948.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_bda73a210df146335a62e933ebe19948.html?view=auto&rev=11
--- (empty file)
+++ trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_bda73a210df146335a62e933ebe19948.html	2006-05-16 20:14:06+0000
@@ -0,0 +1,97 @@
+<html>
+	<head>
+	</head>
+			<tr>
+			</tr>
+		</table>
+<div class="tabs">
+  <ul>
+  </ul></div>
+<div class="nav">
+  <tr>
+   <td valign="top">
+        <table>
+          <tr><td class="navtab"><a class="qindexHL" href="class_fdo_i_create_s_d_f_file_bda73a210df146335a62e933ebe19948.html#bda73a210df146335a62e933ebe19948">SetSpatialContextName</a></td></tr>
+        </table>
+      </div>
+   </td>
+   <td valign="top">
+<a class="anchor" name="bda73a210df146335a62e933ebe19948"></a><!-- doxytag: member="FdoICreateSDFFile::SetSpatialContextName" ref="bda73a210df146335a62e933ebe19948" args="(FdoString *name)=0" --><p>
+  <tr>
+        <tr>
+          <td class="md" nowrap valign="top">virtual FDO_API void FdoICreateSDFFile::SetSpatialContextName           </td>
+          <td class="mdname1" valign="top" nowrap> <em>name</em>          </td>
+        </tr>
+      </table>
+    </td>
+  </tr>
+</table>
+  <tr>
+    <td>
+      &nbsp;
+    </td>
+    <td>
+<p>
+Sets the name of the spatial context as a string.
+<p>
+    <tr><td valign="top"></td><td valign="top"><em>name</em>&nbsp;</td><td>Input the name of the spatial context.</td></tr>
+  </table>
+</dl>
+    </td>
+  </tr>
+</table>
+    </td>
+  </tr>
+</table>
+		<hr>
+			<tr>
+			</tr>
+		</table>
+	</body>
+</html>
Added: trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_e92b777da3c498180dd72fe4629ee788.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_e92b777da3c498180dd72fe4629ee788.html?view=auto&rev=11
--- (empty file)
+++ trunk/www/docs/SDF/class_fdo_i_create_s_d_f_file_e92b777da3c498180dd72fe4629ee788.html	2006-05-16 20:14:06+0000
@@ -0,0 +1,97 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN"	"http://www.w3.org/TR/html4/loose.dtd">
+<html>
+	<head>
+		<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
+		<title>OSGeo FDO Provider for SDF API Reference</title>
+		<link href="custom.css" rel="stylesheet" type="text/css">
+		<link href="tabs.css" rel="stylesheet" type="text/css">
+	</head>
+	<body bgcolor="#FFFFFF">
+		<table width="100%"  border="0">
+			<tr>
+				<td><b>API Reference<b></td>
+				<td align="right"><b>OSGeo FDO Provider for SDF<b></td>
+			</tr>
+		</table>
+<!-- End of: header.html -->
+<!-- Generated by Doxygen 1.4.6-NO -->
+<div class="tabs">
+  <ul>
+    <li><a href="main.html"><span>Main&nbsp;Page</span></a></li>
+    <li><a href="classes.html"><span>Classes</span></a></li>
+  </ul></div>
+<div class="nav">
+  <tr>
+   <td valign="top">
+        <table>
+          <tr><td class="navtab"><a class="qindexHL" href="class_fdo_i_create_s_d_f_file_e92b777da3c498180dd72fe4629ee788.html#e92b777da3c498180dd72fe4629ee788">SetFileName</a></td></tr>
+        </table>
+      </div>
+   </td>
+   <td valign="top">
+<a class="anchor" name="e92b777da3c498180dd72fe4629ee788"></a><!-- doxytag: member="FdoICreateSDFFile::SetFileName" ref="e92b777da3c498180dd72fe4629ee788" args="(FdoString *name)=0" --><p>
+  <tr>
+        <tr>
+          <td class="md" nowrap valign="top">virtual FDO_API void FdoICreateSDFFile::SetFileName           </td>
+        </tr>
+      </table>
+    </td>
+  </tr>
+</table>
+  <tr>
+    <td>
+      &nbsp;
+    </td>
+    <td>
+<p>
+Sets the name of the SDF+ file being created. The name must be a fully qualified absolute path.
+<p>
+    <tr><td valign="top"></td><td valign="top"><em>name</em>&nbsp;</td><td>The fully qualified SDF+ file name.</td></tr>
+  </table>
+</dl>
+    </td>
+  </tr>
+</table>
+    </td>
+  </tr>
+</table>
+		<hr>
+			<tr>
+			</tr>
+		</table>
+	</body>
+</html>
Added: trunk/www/docs/SDF/classes.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/classes.html?view=auto&rev=11
--- (empty file)
+++ trunk/www/docs/SDF/classes.html	2006-05-16 20:14:06+0000
@@ -0,0 +1,45 @@
+<html>
+	<head>
+	</head>
+			<tr>
+			</tr>
+		</table>
+<div class="tabs">
+  <ul>
+  </ul></div>
+<div class="tabs">
+  <ul>
+    <li id="current"><a href="classes.html"><span>Alphabetical&nbsp;List</span></a></li>
+  </ul></div>
+<h1>FDO Provider for SDF Class Index</h1><p><div class="qindex"><a class="qindex" href="#letter_F">F</a></div><p>
+<table align="center" width="95%" border="0" cellspacing="0" cellpadding="0">
+<tr><td><a name="letter_F"></a><table border="0" cellspacing="0" cellpadding="0"><tr><td><div class="ah">&nbsp;&nbsp;F&nbsp;&nbsp;</div></td></tr></table>
+</td><td><a class="el" href="class_fdo_i_create_s_d_f_file.html">FdoICreateSDFFile</a>&nbsp;&nbsp;&nbsp;</td></tr></table><p><div class="qindex"><a class="qindex" href="#letter_F">F</a></div><p>
+		<hr>
+			<tr>
+			</tr>
+		</table>
+	</body>
+</html>
Added: trunk/www/docs/SDF/custom.css
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/custom.css?view=auto&rev=11
--- (empty file)
+++ trunk/www/docs/SDF/custom.css	2006-05-16 20:14:06+0000
@@ -0,0 +1,96 @@
+ at import url(doxygen.css);
+div.Syntax{
+	background-color:#FFFFD9;
+div.Example{
+	background-color:#E9E9E9;
+/*  table cells on the main page (index.html) */
+div.mainpage td {
+	background-color: #FFFFCC;
+	border-right-color: #FF6633;
+	border-bottom-color: #FF6633;
+	border-left-color: #FFCC33;
+	border-top-color: #FFCC33;
+	text-align: center;
+/*** Used in external topics ***/
+p.indent_1 {
+	padding-left: 0.25in;
+p.indent_2 {
+	padding-left: 0.5in;
+p.indent_3 {
+	padding-left: 0.75in;
+table.RuledTable {
+	border-collapse: collapse;
+	table-layout: auto;
+	width: auto;
+	cellpadding: none;
+	cellspacing: none;
+table.RuledTable th {
+	background-color: #CCCCCC;
+	border-left-style: solid;
+	border-left-width: thin;
+	border-left-color: #000000;
+	border-right-style: solid;
+	border-right-width: thin;
+	border-right-color: #000000;
+	border-bottom-style: solid;
+	border-bottom-width: thin;
+	border-bottom-color: #000000;
+	border-top-style: solid;
+	border-top-width: thin;
+	border-top-color: #000000;
+	padding: 6px;
+	width: auto;
+table.RuledTable td {
+	padding-left: 6px;
+	padding-right: 6px;
+	padding-top: 4px;
+	padding-top: 4px;
+	width: auto;
+td.shaded{
+	background-color:#CCCCCC;
+/* Used in Geometry_FgfText.h */
+p.row_1 {
+	font-family: "Courier New", Courier, monospace;
+pre.row_2 {
+	background-color: #E7FFCE;
Added: trunk/www/docs/SDF/define__pages_8h-source.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/define__pages_8h-source.html?view=auto&rev=11
--- (empty file)
+++ trunk/www/docs/SDF/define__pages_8h-source.html	2006-05-16 20:14:06+0000
@@ -0,0 +1,77 @@
+<html>
+	<head>
+	</head>
+			<tr>
+			</tr>
+		</table>
+<div class="tabs">
+  <ul>
+    <li id="current"><a href="files.html"><span>Files</span></a></li>
+  </ul></div>
+<div class="tabs">
+  <ul>
+    <li><a href="files.html"><span>File&nbsp;List</span></a></li>
+    <li><a href="globals.html"><span>File&nbsp;Members</span></a></li>
+  </ul></div>
+<h1>define_pages.h</h1><a href="define__pages_8h.html">Go to the documentation of this file.</a><div class="fragment"><pre class="fragment"><a name="l00001"></a>00001 <span class="comment">/*! \mainpage Introduction</span>
+<a name="l00002"></a>00002 <span class="comment">&lt;div class="mainpage"&gt;</span>
+<a name="l00003"></a>00003 <span class="comment">&lt;!-- This is the index.html page that the user first sees. --&gt;</span>
+<a name="l00004"></a>00004 <span class="comment"></span>
+<a name="l00005"></a>00005 <span class="comment">&lt;p&gt;The Feature Data Objects (FDO) API provides access to data in a </span>
+<a name="l00006"></a>00006 <span class="comment">data store. A provider is a specific implementation of the FDO API </span>
+<a name="l00007"></a>00007 <span class="comment">that provides access to data in a particular data store. The FDO </span>
+<a name="l00008"></a>00008 <span class="comment">Provider for SDF provides FDO with access to an SDF-based data store.</span>
+<a name="l00009"></a>00009 <span class="comment"></span>
+<a name="l00010"></a>00010 <span class="comment">&lt;p&gt;The FDO Provider for SDF uses Autodesk's spatial database </span>
+<a name="l00011"></a>00011 <span class="comment">format, which is a file-based personal geodatabase that supports </span>
+<a name="l00012"></a>00012 <span class="comment">multiple features/attributes, spatial indexing, </span>
+<a name="l00013"></a>00013 <span class="comment">interoperability, file-locking, and high performance for </span>
+<a name="l00014"></a>00014 <span class="comment">large data sets.</span>
+<a name="l00015"></a>00015 <span class="comment">&lt;/p&gt;</span>
+<a name="l00016"></a>00016 <span class="comment">&lt;p&gt;The SDF file format has the following characteristics:</span>
+<a name="l00017"></a>00017 <span class="comment">&lt;/p&gt;</span>
+<a name="l00018"></a>00018 <span class="comment"></span>
+<a name="l00019"></a>00019 <span class="comment">&lt;ul&gt;</span>
+<a name="l00020"></a>00020 <span class="comment">  &lt;li&gt; SDF files can be read on different platforms.</span>
+<a name="l00021"></a>00021 <span class="comment">  &lt;li&gt; The SDF file format has its own spatial indexing.</span>
+<a name="l00022"></a>00022 <span class="comment">  &lt;li&gt; SDF files can store geometric and non-geometric data with minimum </span>
+<a name="l00023"></a>00023 <span class="comment">overhead</span>
+<a name="l00024"></a>00024 <span class="comment">  &lt;li&gt;Although it does not support concurrency control (locking), </span>
+<a name="l00025"></a>00025 <span class="comment">   the SDF file format is a valid alternative to RDBMS.</span>
+<a name="l00026"></a>00026 <span class="comment">&lt;/ul&gt;</span>
+<a name="l00027"></a>00027 <span class="comment">&lt;p&gt;</span>
+<a name="l00028"></a>00028 <span class="comment">For more information, see &lt;i&gt;The Essential FDO&lt;/i&gt; (FET_TheEssentialFDO.pdf) </span>
+<a name="l00029"></a>00029 <span class="comment">and the &lt;i&gt;FDO Developer's Guide&lt;/i&gt; (FDG_FDODevGuide.pdf).</span>
+<a name="l00030"></a>00030 <span class="comment">&lt;/p&gt;</span>
+<a name="l00031"></a>00031 <span class="comment"></span>
+<a name="l00032"></a>00032 <span class="comment">&lt;br&gt;</span>
+<a name="l00033"></a>00033 <span class="comment">&lt;/div&gt;</span>
+<a name="l00034"></a>00034 <span class="comment">*/</span>
+<a name="l00035"></a>00035
+<a name="l00036"></a>00036
+<a name="l00037"></a>00037
+<a name="l00038"></a>00038
+		<hr>
+			<tr>
+			</tr>
+		</table>
+	</body>
+</html>
Added: trunk/www/docs/SDF/define__pages_8h.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/define__pages_8h.html?view=auto&rev=11
--- (empty file)
+++ trunk/www/docs/SDF/define__pages_8h.html	2006-05-16 20:14:06+0000
@@ -0,0 +1,46 @@
+<html>
+	<head>
+	</head>
+			<tr>
+			</tr>
+		</table>
+<div class="tabs">
+  <ul>
+  </ul></div>
+<div class="tabs">
+  <ul>
+  </ul></div>
+<h1>define_pages.h File Reference</h1>
+<p>
+<p>
+<a href="define__pages_8h-source.html">Go to the source code of this file.</a><table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+</table>
+		<hr>
+			<tr>
+			</tr>
+		</table>
+	</body>
+</html>
Added: trunk/www/docs/SDF/doxygen.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SDF/doxygen.png?view=auto&rev=11
More information about the Fdo-commits mailing list
