svn commit: r15 - trunk/www/docs/SHP
gregboone at osgeo.org
Tue May 16 16:42:26 EDT 2006
Author: gregboone
Date: 2006-05-16 20:42:26+0000
New Revision: 15
Added:
trunk/www/docs/SHP/_fdo_shp_class_collection_8h-source.html (contents, props changed)
trunk/www/docs/SHP/_fdo_shp_class_collection_8h.html (contents, props changed)
trunk/www/docs/SHP/_fdo_shp_class_collection_8h__dep__incl.map (contents, props changed)
trunk/www/docs/SHP/_fdo_shp_class_collection_8h__dep__incl.md5 (contents, props changed)
trunk/www/docs/SHP/_fdo_shp_class_collection_8h__dep__incl.png (contents, props changed)
trunk/www/docs/SHP/_fdo_shp_class_collection_8h__incl.map (contents, props changed)
trunk/www/docs/SHP/_fdo_shp_class_collection_8h__incl.md5 (contents, props changed)
trunk/www/docs/SHP/_fdo_shp_class_collection_8h__incl.png (contents, props changed)
trunk/www/docs/SHP/_fdo_shp_class_collection_8h_e68feb280094416a66eb2e7f7ad86837.html (contents, props changed)
trunk/www/docs/SHP/_fdo_shp_class_definition_8h-source.html (contents, props changed)
trunk/www/docs/SHP/_fdo_shp_class_definition_8h.html (contents, props changed)
trunk/www/docs/SHP/_fdo_shp_class_definition_8h__dep__incl.map (contents, props changed)
trunk/www/docs/SHP/_fdo_shp_class_definition_8h__dep__incl.md5 (contents, props changed)
trunk/www/docs/SHP/_fdo_shp_class_definition_8h__dep__incl.png (contents, props changed)
trunk/www/docs/SHP/_fdo_shp_class_definition_8h__incl.map (contents, props changed)
trunk/www/docs/SHP/_fdo_shp_class_definition_8h__incl.md5 (contents, props changed)
trunk/www/docs/SHP/_fdo_shp_class_definition_8h__incl.png (contents, props changed)
trunk/www/docs/SHP/_fdo_shp_class_definition_8h_e6c80e15cb30580f4a33f0b0bf25875a.html (contents, props changed)
trunk/www/docs/SHP/_fdo_shp_column_definition_8h-source.html (contents, props changed)
trunk/www/docs/SHP/_fdo_shp_column_definition_8h.html (contents, props changed)
trunk/www/docs/SHP/_fdo_shp_column_definition_8h__dep__incl.map (contents, props changed)
trunk/www/docs/SHP/_fdo_shp_column_definition_8h__dep__incl.md5 (contents, props changed)
trunk/www/docs/SHP/_fdo_shp_column_definition_8h__dep__incl.png (contents, props changed)
trunk/www/docs/SHP/_fdo_shp_column_definition_8h_f44b3b0db4b0df599032ed54748aff07.html (contents, props changed)
trunk/www/docs/SHP/_fdo_shp_physical_schema_mapping_8h-source.html (contents, props changed)
trunk/www/docs/SHP/_fdo_shp_physical_schema_mapping_8h.html (contents, props changed)
trunk/www/docs/SHP/_fdo_shp_physical_schema_mapping_8h_01dee688aae19647cd329e59b751a1c9.html (contents, props changed)
trunk/www/docs/SHP/_fdo_shp_physical_schema_mapping_8h__incl.map (contents, props changed)
trunk/www/docs/SHP/_fdo_shp_physical_schema_mapping_8h__incl.md5 (contents, props changed)
trunk/www/docs/SHP/_fdo_shp_physical_schema_mapping_8h__incl.png (contents, props changed)
trunk/www/docs/SHP/_fdo_shp_property_definition_8h-source.html (contents, props changed)
trunk/www/docs/SHP/_fdo_shp_property_definition_8h.html (contents, props changed)
trunk/www/docs/SHP/_fdo_shp_property_definition_8h__dep__incl.map (contents, props changed)
trunk/www/docs/SHP/_fdo_shp_property_definition_8h__dep__incl.md5 (contents, props changed)
trunk/www/docs/SHP/_fdo_shp_property_definition_8h__dep__incl.png (contents, props changed)
trunk/www/docs/SHP/_fdo_shp_property_definition_8h__incl.map (contents, props changed)
trunk/www/docs/SHP/_fdo_shp_property_definition_8h__incl.md5 (contents, props changed)
trunk/www/docs/SHP/_fdo_shp_property_definition_8h__incl.png (contents, props changed)
trunk/www/docs/SHP/_fdo_shp_property_definition_8h_a8352482cc4887e6db2714402dbe3d57.html (contents, props changed)
trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h-source.html (contents, props changed)
trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h.html (contents, props changed)
trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h__dep__incl.map (contents, props changed)
trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h__dep__incl.md5 (contents, props changed)
trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h__dep__incl.png (contents, props changed)
trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h__incl.map (contents, props changed)
trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h__incl.md5 (contents, props changed)
trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h__incl.png (contents, props changed)
trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h_c523fa2a650dbc38df6576e0a1e8cbb6.html (contents, props changed)
trunk/www/docs/SHP/annotated.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_class_collection-members.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_class_collection.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_class_collection_2075c326880b1d10e848791f5c781ef2.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_class_collection_3f8d21ceb843d89dd1501c5345e959ce.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_class_collection_7ca47202e723ee690e94240c2dbaa22b.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_class_collection_c5568ebf824873a81cae138f1f72c0a7.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_class_collection_d49972d5035851fc525d319fdd0ac0de.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_class_collection_e71697e929d4ac5b62f7fc9fcdfcec8f.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_class_definition-members.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_class_definition.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_class_definition_03246baa324656d80807273c8669082f.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_class_definition_03bd17ccb7d6f1f3509b49309073d154.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_class_definition_1e811303f7da9de17189d3b91b40df17.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_class_definition_231e0376b3239b584382401389a74991.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_class_definition_2de74cf4ba695c3a27f84d924fae13d1.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_class_definition_3212ae28553647cef5b24eea5be5d182.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_class_definition_58b334144a66fdd59ca905faa384cedc.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_class_definition_5ff553ac0195587c9753b2fe95d42a61.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_class_definition_73405bd93a5068e2c0125076ef82b0ae.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_class_definition_74352faa22702f58a3ed79591635dffb.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_class_definition_a4318e266ade8f0561246fe5385a488c.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_class_definition_c4fd98e86e1b061f3314ee5eb6664030.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_class_definition_d27f1b55c70e4ff58df6df488f8abf9b.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_class_definition_f7f39af97bbd5e5644196196f322f02c.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_column_definition-members.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_column_definition.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_column_definition_343c8b7cbb45e9ad7aefbd97f7879ec3.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_column_definition_58f92ba87a369a97428c7d937d569c72.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_column_definition_64d163015f3c021b5dc5fbe6105ff89a.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_column_definition_71f1cbc25bd5085cd546450015067b08.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_column_definition_90d84295b5cbbda30ca5e3d66a895cff.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_column_definition_d8671acab0db72d517012189859cdafe.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_column_definition_eca75a56d812c8a7bd40dbc5bb303adc.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_column_definition_fff19eb49dc45425fdb3ef7e1a8cc34f.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_physical_schema_mapping-members.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_physical_schema_mapping.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_physical_schema_mapping_29a8cbc220b2489ec8894212e55e6a63.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_physical_schema_mapping_323760df2b4697a81b70b1a4d494b401.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_physical_schema_mapping_39b1326a353fa925aca33e51952f2e97.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_physical_schema_mapping_414ac55477c612f4cc898cb949f7c349.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_physical_schema_mapping_4f696de2a2bcba8d7f83892e3a3f2bbe.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_physical_schema_mapping_57b8da135b87b7df5b0400cc07536f44.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_physical_schema_mapping_8ff550c78afad1e00544a0393a17fa7c.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_physical_schema_mapping_a09f3b41a60fa1d6adf257252bbe5670.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_physical_schema_mapping_aa23c8e7b0c5f94a2c5fe96d62bb96b0.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_physical_schema_mapping_bc4cb63ab21fc31035d25cc8852a3046.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_physical_schema_mapping_d89ecf4a8c025d05c75aa9412a37284f.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_physical_schema_mapping_e34e818940d63ab41db19c2e73a107d1.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_property_definition-members.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_property_definition.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_0b52161945add0910480f452d9ac2bc0.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_28f724d715783bd56d4ee112b182d6d6.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_31b64b4fe2e08635300ddac43e8cca96.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_3247a059e0eb2c1f60c516e81739058e.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_4be129d8f231d3c80f4b5d8f67d55b3d.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_7ea7dfeeb0bf291c7a8049415300c66f.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_7eededaf3297b36ddd9445f6fcf67a01.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_944e21212809bf59f3c838980f77bcde.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_b2e5583363bffe8483b92ca1dae3a6c7.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_c41a3a6e4a1d09b8f9174dce7c6f6b25.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_collection-members.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_collection.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_collection_1c61c73f46f6077d623451c5b73c66cd.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_collection_6e8f77facd3026d3207b96bfd7e558e0.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_collection_9dcd52a0dfe26c64474d8b0688437ab2.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_collection_bd6b681557f031ced9d12cb5905ce3e8.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_collection_c242cc50d3484173bd53f93d49b748cd.html (contents, props changed)
trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_collection_d3eed0522918ece73f92aa1340718aeb.html (contents, props changed)
trunk/www/docs/SHP/classes.html (contents, props changed)
trunk/www/docs/SHP/custom.css (contents, props changed)
trunk/www/docs/SHP/define__pages_8h-source.html (contents, props changed)
trunk/www/docs/SHP/define__pages_8h.html (contents, props changed)
trunk/www/docs/SHP/doxygen.png (contents, props changed)
trunk/www/docs/SHP/files.html (contents, props changed)
trunk/www/docs/SHP/ftv2blank.png (contents, props changed)
trunk/www/docs/SHP/ftv2doc.png (contents, props changed)
trunk/www/docs/SHP/ftv2folderclosed.png (contents, props changed)
trunk/www/docs/SHP/ftv2folderopen.png (contents, props changed)
trunk/www/docs/SHP/ftv2lastnode.png (contents, props changed)
trunk/www/docs/SHP/ftv2link.png (contents, props changed)
trunk/www/docs/SHP/ftv2mlastnode.png (contents, props changed)
trunk/www/docs/SHP/ftv2mnode.png (contents, props changed)
trunk/www/docs/SHP/ftv2node.png (contents, props changed)
trunk/www/docs/SHP/ftv2plastnode.png (contents, props changed)
trunk/www/docs/SHP/ftv2pnode.png (contents, props changed)
trunk/www/docs/SHP/ftv2vertline.png (contents, props changed)
trunk/www/docs/SHP/functions.html (contents, props changed)
trunk/www/docs/SHP/functions_func.html (contents, props changed)
trunk/www/docs/SHP/globals.html (contents, props changed)
trunk/www/docs/SHP/globals_type.html (contents, props changed)
trunk/www/docs/SHP/graph_legend.dot (contents, props changed)
trunk/www/docs/SHP/graph_legend.html (contents, props changed)
trunk/www/docs/SHP/graph_legend.png (contents, props changed)
trunk/www/docs/SHP/hierarchy.html (contents, props changed)
trunk/www/docs/SHP/index.hhc (contents, props changed)
trunk/www/docs/SHP/index.hhk (contents, props changed)
trunk/www/docs/SHP/index.hhp (contents, props changed)
trunk/www/docs/SHP/index.html (contents, props changed)
trunk/www/docs/SHP/inherit__graph__0.map (contents, props changed)
trunk/www/docs/SHP/inherit__graph__0.md5 (contents, props changed)
trunk/www/docs/SHP/inherit__graph__0.png (contents, props changed)
trunk/www/docs/SHP/inherit__graph__1.map (contents, props changed)
trunk/www/docs/SHP/inherit__graph__1.md5 (contents, props changed)
trunk/www/docs/SHP/inherit__graph__1.png (contents, props changed)
trunk/www/docs/SHP/inherit__graph__2.map (contents, props changed)
trunk/www/docs/SHP/inherit__graph__2.md5 (contents, props changed)
trunk/www/docs/SHP/inherit__graph__2.png (contents, props changed)
trunk/www/docs/SHP/inherit__graph__3.map (contents, props changed)
trunk/www/docs/SHP/inherit__graph__3.md5 (contents, props changed)
trunk/www/docs/SHP/inherit__graph__3.png (contents, props changed)
trunk/www/docs/SHP/inherit__graph__4.map (contents, props changed)
trunk/www/docs/SHP/inherit__graph__4.md5 (contents, props changed)
trunk/www/docs/SHP/inherit__graph__4.png (contents, props changed)
trunk/www/docs/SHP/inherit__graph__5.map (contents, props changed)
trunk/www/docs/SHP/inherit__graph__5.md5 (contents, props changed)
trunk/www/docs/SHP/inherit__graph__5.png (contents, props changed)
trunk/www/docs/SHP/inherits.html (contents, props changed)
trunk/www/docs/SHP/main.html (contents, props changed)
trunk/www/docs/SHP/tab_b.gif (contents, props changed)
trunk/www/docs/SHP/tab_l.gif (contents, props changed)
trunk/www/docs/SHP/tab_r.gif (contents, props changed)
trunk/www/docs/SHP/tabs.css (contents, props changed)
trunk/www/docs/SHP/tree.html (contents, props changed)
FDO2
Added: trunk/www/docs/SHP/_fdo_shp_class_collection_8h-source.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_class_collection_8h-source.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_class_collection_8h-source.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,82 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
+<html>
+ <head>
+ <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
+ <title>OSGeo FDO Provider for SHP API Reference</title>
+ <link href="custom.css" rel="stylesheet" type="text/css">
+ <link href="tabs.css" rel="stylesheet" type="text/css">
+ </head>
+ <body bgcolor="#FFFFFF">
+ <table width="100%" border="0">
+ <tr>
+ <td><b>API Reference<b></td>
+ <td align="right"><b>OSGeo FDO Provider for SHP<b></td>
+ </tr>
+ </table>
+<!-- End of: header.html -->
+<!-- Generated by Doxygen 1.4.6-NO -->
+<div class="tabs">
+ <ul>
+ <li><a href="main.html"><span>Main Page</span></a></li>
+ <li><a href="classes.html"><span>Classes</span></a></li>
+ <li id="current"><a href="files.html"><span>Files</span></a></li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li><a href="files.html"><span>File List</span></a></li>
+ <li><a href="globals.html"><span>File Members</span></a></li>
+ </ul></div>
+<h1>FdoShpClassCollection.h</h1><a href="_fdo_shp_class_collection_8h.html">Go to the documentation of this file.</a><div class="fragment"><pre class="fragment"><a name="l00001"></a>00001 <span class="comment">/*</span>
+<a name="l00002"></a>00002 <span class="comment"> * Copyright (C) 2004-2006 Autodesk, Inc.</span>
+<a name="l00003"></a>00003 <span class="comment">* </span>
+<a name="l00004"></a>00004 <span class="comment">* This library is free software; you can redistribute it and/or</span>
+<a name="l00005"></a>00005 <span class="comment">* modify it under the terms of version 2.1 of the GNU Lesser</span>
+<a name="l00006"></a>00006 <span class="comment">* General Public License as published by the Free Software Foundation.</span>
+<a name="l00007"></a>00007 <span class="comment">* </span>
+<a name="l00008"></a>00008 <span class="comment">* This library is distributed in the hope that it will be useful,</span>
+<a name="l00009"></a>00009 <span class="comment">* but WITHOUT ANY WARRANTY; without even the implied warranty of</span>
+<a name="l00010"></a>00010 <span class="comment">* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU</span>
+<a name="l00011"></a>00011 <span class="comment">* Lesser General Public License for more details.</span>
+<a name="l00012"></a>00012 <span class="comment">* </span>
+<a name="l00013"></a>00013 <span class="comment">* You should have received a copy of the GNU Lesser General Public</span>
+<a name="l00014"></a>00014 <span class="comment">* License along with this library; if not, write to the Free Software</span>
+<a name="l00015"></a>00015 <span class="comment">* Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA</span>
+<a name="l00016"></a>00016 <span class="comment"> */</span>
+<a name="l00017"></a>00017 <span class="preprocessor">#ifndef FDOSHPCLASSCOLLECTION_H</span>
+<a name="l00018"></a>00018 <span class="preprocessor"></span><span class="preprocessor">#define FDOSHPCLASSCOLLECTION_H</span>
+<a name="l00019"></a>00019 <span class="preprocessor"></span>
+<a name="l00020"></a>00020 <span class="preprocessor">#ifdef _WIN32</span>
+<a name="l00021"></a>00021 <span class="preprocessor"></span><span class="preprocessor">#pragma once</span>
+<a name="l00022"></a>00022 <span class="preprocessor"></span><span class="preprocessor">#endif //_WIN32</span>
+<a name="l00023"></a>00023 <span class="preprocessor"></span>
+<a name="l00024"></a>00024 <span class="preprocessor">#include <<a class="code" href="_fdo_shp_class_definition_8h.html">SHP/Override/FdoShpClassDefinition.h</a>></span>
+<a name="l00025"></a>00025
+<a name="l00026"></a><a class="code" href="class_fdo_shp_ov_class_collection.html">00026</a> <span class="keyword">class </span><a class="code" href="class_fdo_shp_ov_class_collection.html">FdoShpOvClassCollection</a> : <span class="keyword">public</span> FdoPhysicalElementMappingCollection<FdoShpOvClassDefinition>
+<a name="l00027"></a>00027 {
+<a name="l00028"></a>00028 <span class="keyword">public</span>:
+<a name="l00029"></a>00029 FDOSHP_API <span class="keyword">static</span> <a class="code" href="class_fdo_shp_ov_class_collection.html">FdoShpOvClassCollection</a>* <a class="code" href="class_fdo_shp_ov_class_collection_e71697e929d4ac5b62f7fc9fcdfcec8f.html#e71697e929d4ac5b62f7fc9fcdfcec8f">Create</a>();
+<a name="l00030"></a>00030 FDOSHP_API <span class="keyword">static</span> <a class="code" href="class_fdo_shp_ov_class_collection.html">FdoShpOvClassCollection</a>* <a class="code" href="class_fdo_shp_ov_class_collection_e71697e929d4ac5b62f7fc9fcdfcec8f.html#e71697e929d4ac5b62f7fc9fcdfcec8f">Create</a>(FdoPhysicalElementMapping *parent);
+<a name="l00031"></a>00031
+<a name="l00032"></a>00032 <span class="keyword">protected</span>:
+<a name="l00033"></a>00033 <a class="code" href="class_fdo_shp_ov_class_collection_2075c326880b1d10e848791f5c781ef2.html#2075c326880b1d10e848791f5c781ef2">FdoShpOvClassCollection</a>();
+<a name="l00034"></a>00034 <a class="code" href="class_fdo_shp_ov_class_collection_2075c326880b1d10e848791f5c781ef2.html#2075c326880b1d10e848791f5c781ef2">FdoShpOvClassCollection</a>(FdoPhysicalElementMapping *parent);
+<a name="l00035"></a>00035 <span class="keyword">virtual</span> <a class="code" href="class_fdo_shp_ov_class_collection_d49972d5035851fc525d319fdd0ac0de.html#d49972d5035851fc525d319fdd0ac0de">~FdoShpOvClassCollection</a>(<span class="keywordtype">void</span>);
+<a name="l00036"></a>00036 <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_shp_ov_class_collection_c5568ebf824873a81cae138f1f72c0a7.html#c5568ebf824873a81cae138f1f72c0a7">Dispose</a>();
+<a name="l00037"></a>00037 };
+<a name="l00038"></a>00038
+<a name="l00039"></a><a class="code" href="_fdo_shp_class_collection_8h_e68feb280094416a66eb2e7f7ad86837.html#e68feb280094416a66eb2e7f7ad86837">00039</a> <span class="keyword">typedef</span> FdoPtr<FdoShpOvClassCollection> <a class="code" href="_fdo_shp_class_collection_8h_e68feb280094416a66eb2e7f7ad86837.html#e68feb280094416a66eb2e7f7ad86837">FdoShpOvClassCollectionP</a>;
+<a name="l00040"></a>00040
+<a name="l00041"></a>00041 <span class="preprocessor">#endif // FDOSHPCLASSCOLLECTION_H</span>
+<a name="l00042"></a>00042 <span class="preprocessor"></span>
+<a name="l00043"></a>00043
+</pre></div><!-- footer.html -->
+ <hr>
+ <tr>
+ <td align="right"><font size="-2"><a href="mailto:isd.docs at autodesk.com&subject=FDO%20Provider%20for%20SHP%20API%20documentation">Comments?</a></font></td>
+ <!-- The logo can go in another cell, when we get one -->
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/_fdo_shp_class_collection_8h.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_class_collection_8h.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_class_collection_8h.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,66 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>FdoShpClassCollection.h File Reference</h1>
+<p>
+<code>#include <<a class="el" href="_fdo_shp_class_definition_8h-source.html">SHP/Override/FdoShpClassDefinition.h</a>></code><br>
+<p>
+Include dependency graph for FdoShpClassCollection.h:<p><center><img src="_fdo_shp_class_collection_8h__incl.png" border="0" usemap="#FdoShpClassCollection.h_map" alt=""></center>
+<map name="FdoShpClassCollection.h_map">
+<area href="_fdo_shp_class_definition_8h.html" shape="rect" coords="230,7,486,33" alt="">
+<area href="_fdo_shp_property_definition_collection_8h.html" shape="rect" coords="535,7,868,33" alt="">
+</map>
+<p>
+This graph shows which files directly or indirectly include this file:<p><center><img src="_fdo_shp_class_collection_8h__dep__incl.png" border="0" usemap="#FdoShpClassCollection.hdep_map" alt=""></center>
+<map name="FdoShpClassCollection.hdep_map">
+<area href="_fdo_shp_physical_schema_mapping_8h.html" shape="rect" coords="230,7,459,33" alt="">
+</map>
+<p>
+<a href="_fdo_shp_class_collection_8h-source.html">Go to the source code of this file.</a><table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td colspan="2"><br><h2>Classes</h2></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">class </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_ov_class_collection.html">FdoShpOvClassCollection</a></td></tr>
+<tr><td colspan="2"><br><h2>Typedefs</h2></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">typedef FdoPtr< <a class="el" href="class_fdo_shp_ov_class_collection.html">FdoShpOvClassCollection</a> > </td><td class="memItemRight" valign="bottom"><a class="el" href="_fdo_shp_class_collection_8h_e68feb280094416a66eb2e7f7ad86837.html#e68feb280094416a66eb2e7f7ad86837">FdoShpOvClassCollectionP</a></td></tr>
+</table>
+<!-- footer.html -->
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/_fdo_shp_class_collection_8h__dep__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_class_collection_8h__dep__incl.map?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_class_collection_8h__dep__incl.map 2006-05-16 20:42:26+0000
@@ -0,0 +1,2 @@
+base referer
+rect $_fdo_shp_physical_schema_mapping_8h.html 230,7 459,33
Added: trunk/www/docs/SHP/_fdo_shp_class_collection_8h__dep__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_class_collection_8h__dep__incl.md5?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_class_collection_8h__dep__incl.md5 2006-05-16 20:42:26+0000
@@ -0,0 +1 @@
+6a76a1b41f79138518e324e66b191332
\ No newline at end of file
Added: trunk/www/docs/SHP/_fdo_shp_class_collection_8h__dep__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_class_collection_8h__dep__incl.png?view=auto&rev=15
Binary file. No diff available.
Added: trunk/www/docs/SHP/_fdo_shp_class_collection_8h__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_class_collection_8h__incl.map?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_class_collection_8h__incl.map 2006-05-16 20:42:26+0000
@@ -0,0 +1,3 @@
+base referer
+rect $_fdo_shp_class_definition_8h.html 230,7 486,33
+rect $_fdo_shp_property_definition_collection_8h.html 535,7 868,33
Added: trunk/www/docs/SHP/_fdo_shp_class_collection_8h__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_class_collection_8h__incl.md5?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_class_collection_8h__incl.md5 2006-05-16 20:42:26+0000
@@ -0,0 +1 @@
+2a1e34e98d63c4a5a84f851a1742653a
Added: trunk/www/docs/SHP/_fdo_shp_class_collection_8h__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_class_collection_8h__incl.png?view=auto&rev=15
Added: trunk/www/docs/SHP/_fdo_shp_class_collection_8h_e68feb280094416a66eb2e7f7ad86837.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_class_collection_8h_e68feb280094416a66eb2e7f7ad86837.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_class_collection_8h_e68feb280094416a66eb2e7f7ad86837.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,74 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li><a href="files.html"><span>Files</span></a></li>
+ </ul></div>
+<div class="nav">
+<a class="el" href="_fdo_shp_class_collection_8h.html">FdoShpClassCollection.h</a></div>
+<table cellspacing="0" cellpadding="0" border="0">
+ <tr>
+ <td valign="top">
+ <div class="navtab">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="_fdo_shp_class_collection_8h_e68feb280094416a66eb2e7f7ad86837.html#e68feb280094416a66eb2e7f7ad86837">FdoShpOvClassCollectionP</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="e68feb280094416a66eb2e7f7ad86837"></a><!-- doxytag: member="FdoShpClassCollection.h::FdoShpOvClassCollectionP" ref="e68feb280094416a66eb2e7f7ad86837" args="" --><p>
+<table class="mdTable" cellpadding="2" cellspacing="0">
+ <tr>
+ <td class="mdRow">
+ <table cellpadding="0" cellspacing="0" border="0">
+ <tr>
+ <td class="md" nowrap valign="top">typedef FdoPtr<<a class="el" href="class_fdo_shp_ov_class_collection.html">FdoShpOvClassCollection</a>> <a class="el" href="_fdo_shp_class_collection_8h_e68feb280094416a66eb2e7f7ad86837.html#e68feb280094416a66eb2e7f7ad86837">FdoShpOvClassCollectionP</a> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+<table cellspacing="5" cellpadding="0" border="0">
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+<p>
+Definition at line <a class="el" href="_fdo_shp_class_collection_8h-source.html#l00039">39</a> of file <a class="el" href="_fdo_shp_class_collection_8h-source.html">FdoShpClassCollection.h</a>. </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/_fdo_shp_class_definition_8h-source.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_class_definition_8h-source.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_class_definition_8h-source.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,103 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>FdoShpClassDefinition.h</h1><a href="_fdo_shp_class_definition_8h.html">Go to the documentation of this file.</a><div class="fragment"><pre class="fragment"><a name="l00001"></a>00001 <span class="comment">/*</span>
+<a name="l00017"></a>00017 <span class="preprocessor">#ifndef FDOSHPCLASSDEFINITION_H</span>
+<a name="l00018"></a>00018 <span class="preprocessor"></span><span class="preprocessor">#define FDOSHPCLASSDEFINITION_H</span>
+<a name="l00024"></a>00024 <span class="preprocessor">#include <<a class="code" href="_fdo_shp_property_definition_collection_8h.html">SHP/Override/FdoShpPropertyDefinitionCollection.h</a>></span>
+<a name="l00026"></a><a class="code" href="class_fdo_shp_ov_class_definition.html">00026</a> <span class="keyword">class </span><a class="code" href="class_fdo_shp_ov_class_definition.html">FdoShpOvClassDefinition</a> : <span class="keyword">public</span> FdoPhysicalClassMapping
+<a name="l00028"></a>00028 <span class="keyword">typedef</span> FdoPhysicalClassMapping BaseType;
+<a name="l00030"></a>00030 <span class="keyword">public</span>:
+<a name="l00031"></a>00031 FDOSHP_API <span class="keyword">static</span> <a class="code" href="class_fdo_shp_ov_class_definition.html">FdoShpOvClassDefinition</a>* <a class="code" href="class_fdo_shp_ov_class_definition_74352faa22702f58a3ed79591635dffb.html#74352faa22702f58a3ed79591635dffb">Create</a>();
+<a name="l00033"></a>00033 <span class="keyword">public</span>:
+<a name="l00034"></a>00034 FDOSHP_API <a class="code" href="class_fdo_shp_ov_property_definition_collection.html">FdoShpOvPropertyDefinitionCollection</a>* <a class="code" href="class_fdo_shp_ov_class_definition_c4fd98e86e1b061f3314ee5eb6664030.html#c4fd98e86e1b061f3314ee5eb6664030">GetProperties</a>() <span class="keyword">const</span>;
+<a name="l00036"></a>00036 FDOSHP_API FdoString* <a class="code" href="class_fdo_shp_ov_class_definition_f7f39af97bbd5e5644196196f322f02c.html#f7f39af97bbd5e5644196196f322f02c">GetShapeFile</a>() <span class="keyword">const</span>;
+<a name="l00037"></a>00037 FDOSHP_API <span class="keywordtype">void</span> <a class="code" href="class_fdo_shp_ov_class_definition_231e0376b3239b584382401389a74991.html#231e0376b3239b584382401389a74991">SetShapeFile</a>(FdoString * location);
+<a name="l00038"></a><a class="code" href="class_fdo_shp_ov_class_definition_1e811303f7da9de17189d3b91b40df17.html#1e811303f7da9de17189d3b91b40df17">00038</a> <span class="keywordtype">bool</span> <a class="code" href="class_fdo_shp_ov_class_definition_1e811303f7da9de17189d3b91b40df17.html#1e811303f7da9de17189d3b91b40df17">IsPathUpdated</a>(){ <span class="keywordflow">return</span> m_pathUpdated; }
+<a name="l00039"></a><a class="code" href="class_fdo_shp_ov_class_definition_58b334144a66fdd59ca905faa384cedc.html#58b334144a66fdd59ca905faa384cedc">00039</a> <span class="keywordtype">void</span> <a class="code" href="class_fdo_shp_ov_class_definition_58b334144a66fdd59ca905faa384cedc.html#58b334144a66fdd59ca905faa384cedc">SetPathUpdated</a>(<span class="keywordtype">bool</span> lPathUpdated = <span class="keyword">true</span>){ m_pathUpdated = lPathUpdated; }
+<a name="l00041"></a>00041 FDOSHP_API <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_shp_ov_class_definition_03246baa324656d80807273c8669082f.html#03246baa324656d80807273c8669082f">InitFromXml</a>(FdoXmlSaxContext* pContext, FdoXmlAttributeCollection* attrs);
+<a name="l00042"></a>00042 FDOSHP_API <span class="keyword">virtual</span> FdoXmlSaxHandler* <a class="code" href="class_fdo_shp_ov_class_definition_73405bd93a5068e2c0125076ef82b0ae.html#73405bd93a5068e2c0125076ef82b0ae">XmlStartElement</a>(FdoXmlSaxContext* context,FdoString* uri, FdoString* name, FdoString* qname, FdoXmlAttributeCollection* atts);
+<a name="l00043"></a>00043 FDOSHP_API <span class="keyword">virtual</span> FdoBoolean <a class="code" href="class_fdo_shp_ov_class_definition_d27f1b55c70e4ff58df6df488f8abf9b.html#d27f1b55c70e4ff58df6df488f8abf9b">XmlEndElement</a>(FdoXmlSaxContext* context, FdoString* uri, FdoString* name, FdoString* qname);
+<a name="l00044"></a>00044 FDOSHP_API <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_shp_ov_class_definition_a4318e266ade8f0561246fe5385a488c.html#a4318e266ade8f0561246fe5385a488c">_writeXml</a>(FdoXmlWriter* xmlWriter, <span class="keyword">const</span> FdoXmlFlags* flags);
+<a name="l00045"></a>00045 <span class="comment"></span>
+<a name="l00046"></a>00046 <span class="comment"> /// Helper method to find a property mapping by its column name:</span>
+<a name="l00047"></a>00047 <span class="comment"></span> FDOSHP_API <a class="code" href="class_fdo_shp_ov_property_definition.html">FdoShpOvPropertyDefinition</a>* <a class="code" href="class_fdo_shp_ov_class_definition_03bd17ccb7d6f1f3509b49309073d154.html#03bd17ccb7d6f1f3509b49309073d154">FindByColumnName</a>(FdoString* columnName);
+<a name="l00048"></a>00048
+<a name="l00049"></a>00049 <span class="keyword">protected</span>:
+<a name="l00050"></a>00050 <a class="code" href="class_fdo_shp_ov_class_definition_5ff553ac0195587c9753b2fe95d42a61.html#5ff553ac0195587c9753b2fe95d42a61">FdoShpOvClassDefinition</a>(<span class="keywordtype">void</span>);
+<a name="l00051"></a>00051 <span class="keyword">virtual</span> <a class="code" href="class_fdo_shp_ov_class_definition_2de74cf4ba695c3a27f84d924fae13d1.html#2de74cf4ba695c3a27f84d924fae13d1">~FdoShpOvClassDefinition</a>(<span class="keywordtype">void</span>);
+<a name="l00052"></a>00052 <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_shp_ov_class_definition_3212ae28553647cef5b24eea5be5d182.html#3212ae28553647cef5b24eea5be5d182">Dispose</a>(<span class="keywordtype">void</span>);
+<a name="l00053"></a>00053
+<a name="l00054"></a>00054 <span class="keyword">private</span>:
+<a name="l00055"></a>00055 <span class="keywordtype">bool</span> m_pathUpdated;
+<a name="l00056"></a>00056 FdoStringP m_ShapeFileLocation;
+<a name="l00057"></a>00057 <a class="code" href="_fdo_shp_property_definition_collection_8h_c523fa2a650dbc38df6576e0a1e8cbb6.html#c523fa2a650dbc38df6576e0a1e8cbb6">FdoShpOvPropertyDefinitionCollectionP</a> m_Properties;
+<a name="l00058"></a>00058 };
+<a name="l00059"></a>00059
+<a name="l00060"></a><a class="code" href="_fdo_shp_class_definition_8h_e6c80e15cb30580f4a33f0b0bf25875a.html#e6c80e15cb30580f4a33f0b0bf25875a">00060</a> <span class="keyword">typedef</span> FdoPtr<FdoShpOvClassDefinition> <a class="code" href="_fdo_shp_class_definition_8h_e6c80e15cb30580f4a33f0b0bf25875a.html#e6c80e15cb30580f4a33f0b0bf25875a">FdoShpOvClassDefinitionP</a>;
+<a name="l00061"></a>00061
+<a name="l00062"></a>00062 <span class="preprocessor">#endif // FDOSHPCLASSDEFINITION_H</span>
+<a name="l00063"></a>00063 <span class="preprocessor"></span>
+<a name="l00064"></a>00064
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/_fdo_shp_class_definition_8h.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_class_definition_8h.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_class_definition_8h.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,67 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>FdoShpClassDefinition.h File Reference</h1>
+<p>
+<code>#include <<a class="el" href="_fdo_shp_property_definition_collection_8h-source.html">SHP/Override/FdoShpPropertyDefinitionCollection.h</a>></code><br>
+<p>
+Include dependency graph for FdoShpClassDefinition.h:<p><center><img src="_fdo_shp_class_definition_8h__incl.png" border="0" usemap="#FdoShpClassDefinition.h_map" alt=""></center>
+<map name="FdoShpClassDefinition.h_map">
+<area href="_fdo_shp_property_definition_collection_8h.html" shape="rect" coords="225,7,559,33" alt="">
+<area href="_fdo_shp_property_definition_8h.html" shape="rect" coords="607,7,881,33" alt="">
+</map>
+<p>
+This graph shows which files directly or indirectly include this file:<p><center><img src="_fdo_shp_class_definition_8h__dep__incl.png" border="0" usemap="#FdoShpClassDefinition.hdep_map" alt=""></center>
+<map name="FdoShpClassDefinition.hdep_map">
+<area href="_fdo_shp_class_collection_8h.html" shape="rect" coords="227,7,397,33" alt="">
+<area href="_fdo_shp_physical_schema_mapping_8h.html" shape="rect" coords="448,7,677,33" alt="">
+</map>
+<p>
+<a href="_fdo_shp_class_definition_8h-source.html">Go to the source code of this file.</a><table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">class </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_ov_class_definition.html">FdoShpOvClassDefinition</a></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">typedef FdoPtr< <a class="el" href="class_fdo_shp_ov_class_definition.html">FdoShpOvClassDefinition</a> > </td><td class="memItemRight" valign="bottom"><a class="el" href="_fdo_shp_class_definition_8h_e6c80e15cb30580f4a33f0b0bf25875a.html#e6c80e15cb30580f4a33f0b0bf25875a">FdoShpOvClassDefinitionP</a></td></tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/_fdo_shp_class_definition_8h__dep__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_class_definition_8h__dep__incl.map?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_class_definition_8h__dep__incl.map 2006-05-16 20:42:26+0000
@@ -0,0 +1,3 @@
+base referer
+rect $_fdo_shp_class_collection_8h.html 227,7 397,33
+rect $_fdo_shp_physical_schema_mapping_8h.html 448,7 677,33
Added: trunk/www/docs/SHP/_fdo_shp_class_definition_8h__dep__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_class_definition_8h__dep__incl.md5?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_class_definition_8h__dep__incl.md5 2006-05-16 20:42:26+0000
@@ -0,0 +1 @@
+af4a285b1b0a1daec9f21667cf86f9a5
Added: trunk/www/docs/SHP/_fdo_shp_class_definition_8h__dep__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_class_definition_8h__dep__incl.png?view=auto&rev=15
Added: trunk/www/docs/SHP/_fdo_shp_class_definition_8h__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_class_definition_8h__incl.map?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_class_definition_8h__incl.map 2006-05-16 20:42:26+0000
@@ -0,0 +1,3 @@
+base referer
+rect $_fdo_shp_property_definition_collection_8h.html 225,7 559,33
+rect $_fdo_shp_property_definition_8h.html 607,7 881,33
Added: trunk/www/docs/SHP/_fdo_shp_class_definition_8h__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_class_definition_8h__incl.md5?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_class_definition_8h__incl.md5 2006-05-16 20:42:26+0000
@@ -0,0 +1 @@
+5df00440e1d72e665804a91fb8fdf42f
Added: trunk/www/docs/SHP/_fdo_shp_class_definition_8h__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_class_definition_8h__incl.png?view=auto&rev=15
Added: trunk/www/docs/SHP/_fdo_shp_class_definition_8h_e6c80e15cb30580f4a33f0b0bf25875a.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_class_definition_8h_e6c80e15cb30580f4a33f0b0bf25875a.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_class_definition_8h_e6c80e15cb30580f4a33f0b0bf25875a.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,74 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+<a class="el" href="_fdo_shp_class_definition_8h.html">FdoShpClassDefinition.h</a></div>
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="_fdo_shp_class_definition_8h_e6c80e15cb30580f4a33f0b0bf25875a.html#e6c80e15cb30580f4a33f0b0bf25875a">FdoShpOvClassDefinitionP</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="e6c80e15cb30580f4a33f0b0bf25875a"></a><!-- doxytag: member="FdoShpClassDefinition.h::FdoShpOvClassDefinitionP" ref="e6c80e15cb30580f4a33f0b0bf25875a" args="" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">typedef FdoPtr<<a class="el" href="class_fdo_shp_ov_class_definition.html">FdoShpOvClassDefinition</a>> <a class="el" href="_fdo_shp_class_definition_8h_e6c80e15cb30580f4a33f0b0bf25875a.html#e6c80e15cb30580f4a33f0b0bf25875a">FdoShpOvClassDefinitionP</a> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+<p>
+Definition at line <a class="el" href="_fdo_shp_class_definition_8h-source.html#l00060">60</a> of file <a class="el" href="_fdo_shp_class_definition_8h-source.html">FdoShpClassDefinition.h</a>. </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/_fdo_shp_column_definition_8h-source.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_column_definition_8h-source.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_column_definition_8h-source.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,86 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>FdoShpColumnDefinition.h</h1><a href="_fdo_shp_column_definition_8h.html">Go to the documentation of this file.</a><div class="fragment"><pre class="fragment"><a name="l00001"></a>00001 <span class="comment">/*</span>
+<a name="l00017"></a>00017 <span class="preprocessor">#ifndef FDOSHPCOLUMNDEFINITION_H</span>
+<a name="l00018"></a>00018 <span class="preprocessor"></span><span class="preprocessor">#define FDOSHPCOLUMNDEFINITION_H</span>
+<a name="l00024"></a><a class="code" href="class_fdo_shp_ov_column_definition.html">00024</a> <span class="keyword">class </span><a class="code" href="class_fdo_shp_ov_column_definition.html">FdoShpOvColumnDefinition</a> : <span class="keyword">public</span> FdoPhysicalElementMapping
+<a name="l00025"></a>00025 {
+<a name="l00026"></a>00026 <span class="keyword">typedef</span> FdoPhysicalElementMapping BaseType;
+<a name="l00029"></a>00029 FDOSHP_API <span class="keyword">static</span> <a class="code" href="class_fdo_shp_ov_column_definition.html">FdoShpOvColumnDefinition</a>* <a class="code" href="class_fdo_shp_ov_column_definition_71f1cbc25bd5085cd546450015067b08.html#71f1cbc25bd5085cd546450015067b08">Create</a>();
+<a name="l00031"></a>00031 <span class="keyword">public</span>:
+<a name="l00032"></a>00032 FDOSHP_API <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_shp_ov_column_definition_d8671acab0db72d517012189859cdafe.html#d8671acab0db72d517012189859cdafe">InitFromXml</a>(FdoXmlSaxContext* pContext, FdoXmlAttributeCollection* attrs);
+<a name="l00033"></a>00033 FDOSHP_API <span class="keyword">virtual</span> FdoXmlSaxHandler* <a class="code" href="class_fdo_shp_ov_column_definition_64d163015f3c021b5dc5fbe6105ff89a.html#64d163015f3c021b5dc5fbe6105ff89a">XmlStartElement</a>(FdoXmlSaxContext* context,FdoString* uri, FdoString* name, FdoString* qname, FdoXmlAttributeCollection* atts);
+<a name="l00034"></a>00034 FDOSHP_API <span class="keyword">virtual</span> FdoBoolean <a class="code" href="class_fdo_shp_ov_column_definition_fff19eb49dc45425fdb3ef7e1a8cc34f.html#fff19eb49dc45425fdb3ef7e1a8cc34f">XmlEndElement</a>(FdoXmlSaxContext* context, FdoString* uri, FdoString* name, FdoString* qname);
+<a name="l00035"></a>00035 FDOSHP_API <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_shp_ov_column_definition_58f92ba87a369a97428c7d937d569c72.html#58f92ba87a369a97428c7d937d569c72">_writeXml</a>(FdoXmlWriter* xmlWriter, <span class="keyword">const</span> FdoXmlFlags* flags);
+<a name="l00037"></a>00037 <span class="keyword">protected</span>:
+<a name="l00038"></a>00038 <a class="code" href="class_fdo_shp_ov_column_definition_90d84295b5cbbda30ca5e3d66a895cff.html#90d84295b5cbbda30ca5e3d66a895cff">FdoShpOvColumnDefinition</a>(<span class="keywordtype">void</span>);
+<a name="l00039"></a>00039 <span class="keyword">virtual</span> <a class="code" href="class_fdo_shp_ov_column_definition_343c8b7cbb45e9ad7aefbd97f7879ec3.html#343c8b7cbb45e9ad7aefbd97f7879ec3">~FdoShpOvColumnDefinition</a>(<span class="keywordtype">void</span>);
+<a name="l00040"></a>00040 <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_shp_ov_column_definition_eca75a56d812c8a7bd40dbc5bb303adc.html#eca75a56d812c8a7bd40dbc5bb303adc">Dispose</a>(<span class="keywordtype">void</span>);
+<a name="l00041"></a>00041 };
+<a name="l00043"></a><a class="code" href="_fdo_shp_column_definition_8h_f44b3b0db4b0df599032ed54748aff07.html#f44b3b0db4b0df599032ed54748aff07">00043</a> <span class="keyword">typedef</span> FdoPtr<FdoShpOvColumnDefinition> <a class="code" href="_fdo_shp_column_definition_8h_f44b3b0db4b0df599032ed54748aff07.html#f44b3b0db4b0df599032ed54748aff07">FdoShpOvColumnDefinitionP</a>;
+<a name="l00045"></a>00045 <span class="preprocessor">#endif // FDOSHPCOLUMNDEFINITION_H</span>
+<a name="l00046"></a>00046 <span class="preprocessor"></span>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/_fdo_shp_column_definition_8h.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_column_definition_8h.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_column_definition_8h.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,60 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>FdoShpColumnDefinition.h File Reference</h1>
+<p>
+<p>
+This graph shows which files directly or indirectly include this file:<p><center><img src="_fdo_shp_column_definition_8h__dep__incl.png" border="0" usemap="#FdoShpColumnDefinition.hdep_map" alt=""></center>
+<map name="FdoShpColumnDefinition.hdep_map">
+<area href="_fdo_shp_property_definition_8h.html" shape="rect" coords="239,7,426,33" alt="">
+<area href="_fdo_shp_property_definition_collection_8h.html" shape="rect" coords="475,7,720,33" alt="">
+<area href="_fdo_shp_class_definition_8h.html" shape="rect" coords="771,7,939,33" alt="">
+</map>
+<p>
+<a href="_fdo_shp_column_definition_8h-source.html">Go to the source code of this file.</a><table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">class </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_ov_column_definition.html">FdoShpOvColumnDefinition</a></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">typedef FdoPtr< <a class="el" href="class_fdo_shp_ov_column_definition.html">FdoShpOvColumnDefinition</a> > </td><td class="memItemRight" valign="bottom"><a class="el" href="_fdo_shp_column_definition_8h_f44b3b0db4b0df599032ed54748aff07.html#f44b3b0db4b0df599032ed54748aff07">FdoShpOvColumnDefinitionP</a></td></tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/_fdo_shp_column_definition_8h__dep__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_column_definition_8h__dep__incl.map?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_column_definition_8h__dep__incl.map 2006-05-16 20:42:26+0000
@@ -0,0 +1,4 @@
+base referer
+rect $_fdo_shp_property_definition_8h.html 239,7 426,33
+rect $_fdo_shp_property_definition_collection_8h.html 475,7 720,33
+rect $_fdo_shp_class_definition_8h.html 771,7 939,33
Added: trunk/www/docs/SHP/_fdo_shp_column_definition_8h__dep__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_column_definition_8h__dep__incl.md5?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_column_definition_8h__dep__incl.md5 2006-05-16 20:42:26+0000
@@ -0,0 +1 @@
+16125c21a449ab1bddc840e8909d43ad
Added: trunk/www/docs/SHP/_fdo_shp_column_definition_8h__dep__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_column_definition_8h__dep__incl.png?view=auto&rev=15
Added: trunk/www/docs/SHP/_fdo_shp_column_definition_8h_f44b3b0db4b0df599032ed54748aff07.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_column_definition_8h_f44b3b0db4b0df599032ed54748aff07.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_column_definition_8h_f44b3b0db4b0df599032ed54748aff07.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,74 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+<a class="el" href="_fdo_shp_column_definition_8h.html">FdoShpColumnDefinition.h</a></div>
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="_fdo_shp_column_definition_8h_f44b3b0db4b0df599032ed54748aff07.html#f44b3b0db4b0df599032ed54748aff07">FdoShpOvColumnDefinitionP</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="f44b3b0db4b0df599032ed54748aff07"></a><!-- doxytag: member="FdoShpColumnDefinition.h::FdoShpOvColumnDefinitionP" ref="f44b3b0db4b0df599032ed54748aff07" args="" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">typedef FdoPtr<<a class="el" href="class_fdo_shp_ov_column_definition.html">FdoShpOvColumnDefinition</a>> <a class="el" href="_fdo_shp_column_definition_8h_f44b3b0db4b0df599032ed54748aff07.html#f44b3b0db4b0df599032ed54748aff07">FdoShpOvColumnDefinitionP</a> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+<p>
+Definition at line <a class="el" href="_fdo_shp_column_definition_8h-source.html#l00043">43</a> of file <a class="el" href="_fdo_shp_column_definition_8h-source.html">FdoShpColumnDefinition.h</a>. </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/_fdo_shp_physical_schema_mapping_8h-source.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_physical_schema_mapping_8h-source.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_physical_schema_mapping_8h-source.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,99 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>FdoShpPhysicalSchemaMapping.h</h1><a href="_fdo_shp_physical_schema_mapping_8h.html">Go to the documentation of this file.</a><div class="fragment"><pre class="fragment"><a name="l00001"></a>00001 <span class="comment">/*</span>
+<a name="l00017"></a>00017 <span class="preprocessor">#ifndef FDOSHPPHYSICALSCHEMAMAPPING_H</span>
+<a name="l00018"></a>00018 <span class="preprocessor"></span><span class="preprocessor">#define FDOSHPPHYSICALSCHEMAMAPPING_H</span>
+<a name="l00024"></a>00024 <span class="preprocessor">#include <<a class="code" href="_fdo_shp_class_collection_8h.html">SHP/Override/FdoShpClassCollection.h</a>></span>
+<a name="l00026"></a><a class="code" href="class_fdo_shp_ov_physical_schema_mapping.html">00026</a> <span class="keyword">class </span><a class="code" href="class_fdo_shp_ov_physical_schema_mapping.html">FdoShpOvPhysicalSchemaMapping</a> : <span class="keyword">public</span> FdoPhysicalSchemaMapping
+<a name="l00028"></a>00028 <span class="keyword">typedef</span> FdoPhysicalSchemaMapping BaseType;
+<a name="l00031"></a>00031 FDOSHP_API <span class="keyword">static</span> <a class="code" href="class_fdo_shp_ov_physical_schema_mapping.html">FdoShpOvPhysicalSchemaMapping</a>* <a class="code" href="class_fdo_shp_ov_physical_schema_mapping_29a8cbc220b2489ec8894212e55e6a63.html#29a8cbc220b2489ec8894212e55e6a63">Create</a>();
+<a name="l00033"></a>00033 FDOSHP_API <span class="keyword">virtual</span> FdoString* <a class="code" href="class_fdo_shp_ov_physical_schema_mapping_e34e818940d63ab41db19c2e73a107d1.html#e34e818940d63ab41db19c2e73a107d1">GetProvider</a>();
+<a name="l00034"></a>00034 FDOSHP_API <a class="code" href="class_fdo_shp_ov_class_collection.html">FdoShpOvClassCollection</a>* <a class="code" href="class_fdo_shp_ov_physical_schema_mapping_4f696de2a2bcba8d7f83892e3a3f2bbe.html#4f696de2a2bcba8d7f83892e3a3f2bbe">GetClasses</a>() <span class="keyword">const</span>;
+<a name="l00036"></a>00036 FDOSHP_API <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_shp_ov_physical_schema_mapping_323760df2b4697a81b70b1a4d494b401.html#323760df2b4697a81b70b1a4d494b401">InitFromXml</a>(FdoXmlSaxContext* pContext, FdoXmlAttributeCollection* attrs);
+<a name="l00037"></a>00037 FDOSHP_API <span class="keyword">virtual</span> FdoXmlSaxHandler* <a class="code" href="class_fdo_shp_ov_physical_schema_mapping_a09f3b41a60fa1d6adf257252bbe5670.html#a09f3b41a60fa1d6adf257252bbe5670">XmlStartElement</a>(FdoXmlSaxContext* context,FdoString* uri, FdoString* name, FdoString* qname, FdoXmlAttributeCollection* atts);
+<a name="l00038"></a>00038 FDOSHP_API <span class="keyword">virtual</span> FdoBoolean <a class="code" href="class_fdo_shp_ov_physical_schema_mapping_39b1326a353fa925aca33e51952f2e97.html#39b1326a353fa925aca33e51952f2e97">XmlEndElement</a>(FdoXmlSaxContext* context, FdoString* uri, FdoString* name, FdoString* qname);
+<a name="l00039"></a>00039 FDOSHP_API <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_shp_ov_physical_schema_mapping_414ac55477c612f4cc898cb949f7c349.html#414ac55477c612f4cc898cb949f7c349">_writeXml</a>(FdoXmlWriter* xmlWriter, <span class="keyword">const</span> FdoXmlFlags* flags);
+<a name="l00040"></a>00040 <span class="comment"></span>
+<a name="l00041"></a>00041 <span class="comment"> /// Helper method to find a class mapping that maps to a given shapefile:</span>
+<a name="l00042"></a>00042 <span class="comment"></span> FDOSHP_API <a class="code" href="class_fdo_shp_ov_class_definition.html">FdoShpOvClassDefinition</a>* <a class="code" href="class_fdo_shp_ov_physical_schema_mapping_bc4cb63ab21fc31035d25cc8852a3046.html#bc4cb63ab21fc31035d25cc8852a3046">FindByShapefile</a>(FdoString *shapefilePath);
+<a name="l00043"></a>00043 <span class="comment"></span>
+<a name="l00044"></a>00044 <span class="comment"> /// Helper method to find a class mapping that maps to a given classname:</span>
+<a name="l00045"></a>00045 <span class="comment"></span> FDOSHP_API <a class="code" href="class_fdo_shp_ov_class_definition.html">FdoShpOvClassDefinition</a>* <a class="code" href="class_fdo_shp_ov_physical_schema_mapping_d89ecf4a8c025d05c75aa9412a37284f.html#d89ecf4a8c025d05c75aa9412a37284f">FindByClassName</a>(FdoString *class_name);
+<a name="l00047"></a>00047 <span class="keyword">protected</span>:
+<a name="l00048"></a>00048 <a class="code" href="class_fdo_shp_ov_physical_schema_mapping_57b8da135b87b7df5b0400cc07536f44.html#57b8da135b87b7df5b0400cc07536f44">FdoShpOvPhysicalSchemaMapping</a>(<span class="keywordtype">void</span>);
+<a name="l00049"></a>00049 <span class="keyword">virtual</span> <a class="code" href="class_fdo_shp_ov_physical_schema_mapping_aa23c8e7b0c5f94a2c5fe96d62bb96b0.html#aa23c8e7b0c5f94a2c5fe96d62bb96b0">~FdoShpOvPhysicalSchemaMapping</a>(<span class="keywordtype">void</span>);
+<a name="l00050"></a>00050 <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_shp_ov_physical_schema_mapping_8ff550c78afad1e00544a0393a17fa7c.html#8ff550c78afad1e00544a0393a17fa7c">Dispose</a>(<span class="keywordtype">void</span>);
+<a name="l00052"></a>00052 <span class="keyword">private</span>:
+<a name="l00053"></a>00053 <a class="code" href="_fdo_shp_class_collection_8h_e68feb280094416a66eb2e7f7ad86837.html#e68feb280094416a66eb2e7f7ad86837">FdoShpOvClassCollectionP</a> m_Classes;
+<a name="l00054"></a>00054 };
+<a name="l00056"></a><a class="code" href="_fdo_shp_physical_schema_mapping_8h_01dee688aae19647cd329e59b751a1c9.html#01dee688aae19647cd329e59b751a1c9">00056</a> <span class="keyword">typedef</span> FdoPtr<FdoShpOvPhysicalSchemaMapping> <a class="code" href="_fdo_shp_physical_schema_mapping_8h_01dee688aae19647cd329e59b751a1c9.html#01dee688aae19647cd329e59b751a1c9">FdoShpOvPhysicalSchemaMappingP</a>;
+<a name="l00058"></a>00058 <span class="preprocessor">#endif // FDOSHPPHYSICALSCHEMAMAPPING_H</span>
+<a name="l00059"></a>00059 <span class="preprocessor"></span>
+<a name="l00060"></a>00060
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/_fdo_shp_physical_schema_mapping_8h.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_physical_schema_mapping_8h.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_physical_schema_mapping_8h.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,60 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>FdoShpPhysicalSchemaMapping.h File Reference</h1>
+<p>
+<code>#include <<a class="el" href="_fdo_shp_class_collection_8h-source.html">SHP/Override/FdoShpClassCollection.h</a>></code><br>
+<p>
+Include dependency graph for FdoShpPhysicalSchemaMapping.h:<p><center><img src="_fdo_shp_physical_schema_mapping_8h__incl.png" border="0" usemap="#FdoShpPhysicalSchemaMapping.h_map" alt=""></center>
+<map name="FdoShpPhysicalSchemaMapping.h_map">
+<area href="_fdo_shp_class_collection_8h.html" shape="rect" coords="288,7,547,33" alt="">
+<area href="_fdo_shp_class_definition_8h.html" shape="rect" coords="597,7,853,33" alt="">
+</map>
+<p>
+<a href="_fdo_shp_physical_schema_mapping_8h-source.html">Go to the source code of this file.</a><table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">class </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_ov_physical_schema_mapping.html">FdoShpOvPhysicalSchemaMapping</a></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">typedef FdoPtr< <a class="el" href="class_fdo_shp_ov_physical_schema_mapping.html">FdoShpOvPhysicalSchemaMapping</a> > </td><td class="memItemRight" valign="bottom"><a class="el" href="_fdo_shp_physical_schema_mapping_8h_01dee688aae19647cd329e59b751a1c9.html#01dee688aae19647cd329e59b751a1c9">FdoShpOvPhysicalSchemaMappingP</a></td></tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/_fdo_shp_physical_schema_mapping_8h_01dee688aae19647cd329e59b751a1c9.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_physical_schema_mapping_8h_01dee688aae19647cd329e59b751a1c9.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_physical_schema_mapping_8h_01dee688aae19647cd329e59b751a1c9.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,74 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+<a class="el" href="_fdo_shp_physical_schema_mapping_8h.html">FdoShpPhysicalSchemaMapping.h</a></div>
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="_fdo_shp_physical_schema_mapping_8h_01dee688aae19647cd329e59b751a1c9.html#01dee688aae19647cd329e59b751a1c9">FdoShpOvPhysicalSchemaMappingP</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="01dee688aae19647cd329e59b751a1c9"></a><!-- doxytag: member="FdoShpPhysicalSchemaMapping.h::FdoShpOvPhysicalSchemaMappingP" ref="01dee688aae19647cd329e59b751a1c9" args="" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">typedef FdoPtr<<a class="el" href="class_fdo_shp_ov_physical_schema_mapping.html">FdoShpOvPhysicalSchemaMapping</a>> <a class="el" href="_fdo_shp_physical_schema_mapping_8h_01dee688aae19647cd329e59b751a1c9.html#01dee688aae19647cd329e59b751a1c9">FdoShpOvPhysicalSchemaMappingP</a> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+<p>
+Definition at line <a class="el" href="_fdo_shp_physical_schema_mapping_8h-source.html#l00056">56</a> of file <a class="el" href="_fdo_shp_physical_schema_mapping_8h-source.html">FdoShpPhysicalSchemaMapping.h</a>. </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/_fdo_shp_physical_schema_mapping_8h__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_physical_schema_mapping_8h__incl.map?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_physical_schema_mapping_8h__incl.map 2006-05-16 20:42:26+0000
@@ -0,0 +1,3 @@
+base referer
+rect $_fdo_shp_class_collection_8h.html 288,7 547,33
+rect $_fdo_shp_class_definition_8h.html 597,7 853,33
Added: trunk/www/docs/SHP/_fdo_shp_physical_schema_mapping_8h__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_physical_schema_mapping_8h__incl.md5?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_physical_schema_mapping_8h__incl.md5 2006-05-16 20:42:26+0000
@@ -0,0 +1 @@
+adf87891b30861cbd85658ac4dab61f9
Added: trunk/www/docs/SHP/_fdo_shp_physical_schema_mapping_8h__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_physical_schema_mapping_8h__incl.png?view=auto&rev=15
Added: trunk/www/docs/SHP/_fdo_shp_property_definition_8h-source.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_property_definition_8h-source.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_property_definition_8h-source.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,94 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>FdoShpPropertyDefinition.h</h1><a href="_fdo_shp_property_definition_8h.html">Go to the documentation of this file.</a><div class="fragment"><pre class="fragment"><a name="l00001"></a>00001 <span class="comment">/*</span>
+<a name="l00017"></a>00017 <span class="preprocessor">#ifndef FDOSHPPROPERTYDEFINITION_H</span>
+<a name="l00018"></a>00018 <span class="preprocessor"></span><span class="preprocessor">#define FDOSHPPROPERTYDEFINITION_H</span>
+<a name="l00024"></a>00024 <span class="preprocessor">#include <<a class="code" href="_fdo_shp_column_definition_8h.html">SHP/Override/FdoShpColumnDefinition.h</a>></span>
+<a name="l00026"></a><a class="code" href="class_fdo_shp_ov_property_definition.html">00026</a> <span class="keyword">class </span><a class="code" href="class_fdo_shp_ov_property_definition.html">FdoShpOvPropertyDefinition</a> : <span class="keyword">public</span> FdoPhysicalPropertyMapping
+<a name="l00028"></a>00028 <span class="keyword">typedef</span> FdoPhysicalElementMapping BaseType;
+<a name="l00031"></a>00031 FDOSHP_API <span class="keyword">static</span> <a class="code" href="class_fdo_shp_ov_property_definition.html">FdoShpOvPropertyDefinition</a>* <a class="code" href="class_fdo_shp_ov_property_definition_7ea7dfeeb0bf291c7a8049415300c66f.html#7ea7dfeeb0bf291c7a8049415300c66f">Create</a>();
+<a name="l00034"></a>00034 FDOSHP_API <a class="code" href="class_fdo_shp_ov_column_definition.html">FdoShpOvColumnDefinition</a>* <a class="code" href="class_fdo_shp_ov_property_definition_4be129d8f231d3c80f4b5d8f67d55b3d.html#4be129d8f231d3c80f4b5d8f67d55b3d">GetColumn</a>() <span class="keyword">const</span>;
+<a name="l00035"></a>00035 FDOSHP_API <span class="keywordtype">void</span> <a class="code" href="class_fdo_shp_ov_property_definition_b2e5583363bffe8483b92ca1dae3a6c7.html#b2e5583363bffe8483b92ca1dae3a6c7">SetColumn</a>(<a class="code" href="class_fdo_shp_ov_column_definition.html">FdoShpOvColumnDefinition</a> * definition);
+<a name="l00037"></a>00037 FDOSHP_API <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_shp_ov_property_definition_c41a3a6e4a1d09b8f9174dce7c6f6b25.html#c41a3a6e4a1d09b8f9174dce7c6f6b25">InitFromXml</a>(FdoXmlSaxContext* pContext, FdoXmlAttributeCollection* attrs);
+<a name="l00038"></a>00038 FDOSHP_API <span class="keyword">virtual</span> FdoXmlSaxHandler* <a class="code" href="class_fdo_shp_ov_property_definition_31b64b4fe2e08635300ddac43e8cca96.html#31b64b4fe2e08635300ddac43e8cca96">XmlStartElement</a>(FdoXmlSaxContext* context,FdoString* uri, FdoString* name, FdoString* qname, FdoXmlAttributeCollection* atts);
+<a name="l00039"></a>00039 FDOSHP_API <span class="keyword">virtual</span> FdoBoolean <a class="code" href="class_fdo_shp_ov_property_definition_3247a059e0eb2c1f60c516e81739058e.html#3247a059e0eb2c1f60c516e81739058e">XmlEndElement</a>(FdoXmlSaxContext* context, FdoString* uri, FdoString* name, FdoString* qname);
+<a name="l00040"></a>00040 FDOSHP_API <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_shp_ov_property_definition_7eededaf3297b36ddd9445f6fcf67a01.html#7eededaf3297b36ddd9445f6fcf67a01">_writeXml</a>( FdoXmlWriter* xmlWriter, <span class="keyword">const</span> FdoXmlFlags* flags );
+<a name="l00042"></a>00042 <span class="keyword">protected</span>:
+<a name="l00043"></a>00043 <a class="code" href="class_fdo_shp_ov_property_definition_28f724d715783bd56d4ee112b182d6d6.html#28f724d715783bd56d4ee112b182d6d6">FdoShpOvPropertyDefinition</a>(<span class="keywordtype">void</span>);
+<a name="l00044"></a>00044 <span class="keyword">virtual</span> <a class="code" href="class_fdo_shp_ov_property_definition_0b52161945add0910480f452d9ac2bc0.html#0b52161945add0910480f452d9ac2bc0">~FdoShpOvPropertyDefinition</a>(<span class="keywordtype">void</span>);
+<a name="l00045"></a>00045 <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_shp_ov_property_definition_944e21212809bf59f3c838980f77bcde.html#944e21212809bf59f3c838980f77bcde">Dispose</a>(<span class="keywordtype">void</span>);
+<a name="l00047"></a>00047 <span class="keyword">private</span>:
+<a name="l00048"></a>00048 <a class="code" href="_fdo_shp_column_definition_8h_f44b3b0db4b0df599032ed54748aff07.html#f44b3b0db4b0df599032ed54748aff07">FdoShpOvColumnDefinitionP</a> m_ColumnDefinition;
+<a name="l00049"></a>00049 };
+<a name="l00051"></a><a class="code" href="_fdo_shp_property_definition_8h_a8352482cc4887e6db2714402dbe3d57.html#a8352482cc4887e6db2714402dbe3d57">00051</a> <span class="keyword">typedef</span> FdoPtr<FdoShpOvPropertyDefinition> <a class="code" href="_fdo_shp_property_definition_8h_a8352482cc4887e6db2714402dbe3d57.html#a8352482cc4887e6db2714402dbe3d57">FdoShpOvPropertyDefinitionP</a>;
+<a name="l00053"></a>00053 <span class="preprocessor">#endif // FDOSHPPROPERTYDEFINITION_H</span>
+<a name="l00054"></a>00054 <span class="preprocessor"></span>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/_fdo_shp_property_definition_8h.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_property_definition_8h.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_property_definition_8h.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,67 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>FdoShpPropertyDefinition.h File Reference</h1>
+<p>
+<code>#include <<a class="el" href="_fdo_shp_column_definition_8h-source.html">SHP/Override/FdoShpColumnDefinition.h</a>></code><br>
+<p>
+Include dependency graph for FdoShpPropertyDefinition.h:<p><center><img src="_fdo_shp_property_definition_8h__incl.png" border="0" usemap="#FdoShpPropertyDefinition.h_map" alt=""></center>
+<map name="FdoShpPropertyDefinition.h_map">
+<area href="_fdo_shp_column_definition_8h.html" shape="rect" coords="243,7,512,33" alt="">
+</map>
+<p>
+This graph shows which files directly or indirectly include this file:<p><center><img src="_fdo_shp_property_definition_8h__dep__incl.png" border="0" usemap="#FdoShpPropertyDefinition.hdep_map" alt=""></center>
+<map name="FdoShpPropertyDefinition.hdep_map">
+<area href="_fdo_shp_property_definition_collection_8h.html" shape="rect" coords="243,7,488,33" alt="">
+<area href="_fdo_shp_class_definition_8h.html" shape="rect" coords="539,7,707,33" alt="">
+<area href="_fdo_shp_class_collection_8h.html" shape="rect" coords="757,7,928,33" alt="">
+</map>
+<p>
+<a href="_fdo_shp_property_definition_8h-source.html">Go to the source code of this file.</a><table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">class </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_ov_property_definition.html">FdoShpOvPropertyDefinition</a></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">typedef FdoPtr< <a class="el" href="class_fdo_shp_ov_property_definition.html">FdoShpOvPropertyDefinition</a> > </td><td class="memItemRight" valign="bottom"><a class="el" href="_fdo_shp_property_definition_8h_a8352482cc4887e6db2714402dbe3d57.html#a8352482cc4887e6db2714402dbe3d57">FdoShpOvPropertyDefinitionP</a></td></tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/_fdo_shp_property_definition_8h__dep__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_property_definition_8h__dep__incl.map?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_property_definition_8h__dep__incl.map 2006-05-16 20:42:26+0000
@@ -0,0 +1,4 @@
+base referer
+rect $_fdo_shp_property_definition_collection_8h.html 243,7 488,33
+rect $_fdo_shp_class_definition_8h.html 539,7 707,33
+rect $_fdo_shp_class_collection_8h.html 757,7 928,33
Added: trunk/www/docs/SHP/_fdo_shp_property_definition_8h__dep__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_property_definition_8h__dep__incl.md5?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_property_definition_8h__dep__incl.md5 2006-05-16 20:42:26+0000
@@ -0,0 +1 @@
+ebcf332c05fe4118e582c07ae4e57895
Added: trunk/www/docs/SHP/_fdo_shp_property_definition_8h__dep__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_property_definition_8h__dep__incl.png?view=auto&rev=15
Added: trunk/www/docs/SHP/_fdo_shp_property_definition_8h__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_property_definition_8h__incl.map?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_property_definition_8h__incl.map 2006-05-16 20:42:26+0000
@@ -0,0 +1,2 @@
+base referer
+rect $_fdo_shp_column_definition_8h.html 243,7 512,33
Added: trunk/www/docs/SHP/_fdo_shp_property_definition_8h__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_property_definition_8h__incl.md5?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_property_definition_8h__incl.md5 2006-05-16 20:42:26+0000
@@ -0,0 +1 @@
+011c5decfede2d714cac6e35fbc9bc10
Added: trunk/www/docs/SHP/_fdo_shp_property_definition_8h__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_property_definition_8h__incl.png?view=auto&rev=15
Added: trunk/www/docs/SHP/_fdo_shp_property_definition_8h_a8352482cc4887e6db2714402dbe3d57.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_property_definition_8h_a8352482cc4887e6db2714402dbe3d57.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_property_definition_8h_a8352482cc4887e6db2714402dbe3d57.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,74 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+<a class="el" href="_fdo_shp_property_definition_8h.html">FdoShpPropertyDefinition.h</a></div>
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="_fdo_shp_property_definition_8h_a8352482cc4887e6db2714402dbe3d57.html#a8352482cc4887e6db2714402dbe3d57">FdoShpOvPropertyDefinitionP</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="a8352482cc4887e6db2714402dbe3d57"></a><!-- doxytag: member="FdoShpPropertyDefinition.h::FdoShpOvPropertyDefinitionP" ref="a8352482cc4887e6db2714402dbe3d57" args="" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">typedef FdoPtr<<a class="el" href="class_fdo_shp_ov_property_definition.html">FdoShpOvPropertyDefinition</a>> <a class="el" href="_fdo_shp_property_definition_8h_a8352482cc4887e6db2714402dbe3d57.html#a8352482cc4887e6db2714402dbe3d57">FdoShpOvPropertyDefinitionP</a> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+<p>
+Definition at line <a class="el" href="_fdo_shp_property_definition_8h-source.html#l00051">51</a> of file <a class="el" href="_fdo_shp_property_definition_8h-source.html">FdoShpPropertyDefinition.h</a>. </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h-source.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h-source.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h-source.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,83 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>FdoShpPropertyDefinitionCollection.h</h1><a href="_fdo_shp_property_definition_collection_8h.html">Go to the documentation of this file.</a><div class="fragment"><pre class="fragment"><a name="l00001"></a>00001 <span class="comment">/*</span>
+<a name="l00017"></a>00017 <span class="preprocessor">#ifndef FDOSHPPROPERTYDEFINITIONCOLLECTION_H</span>
+<a name="l00018"></a>00018 <span class="preprocessor"></span><span class="preprocessor">#define FDOSHPPROPERTYDEFINITIONCOLLECTION_H</span>
+<a name="l00024"></a>00024 <span class="preprocessor">#include <<a class="code" href="_fdo_shp_property_definition_8h.html">SHP/Override/FdoShpPropertyDefinition.h</a>></span>
+<a name="l00026"></a><a class="code" href="class_fdo_shp_ov_property_definition_collection.html">00026</a> <span class="keyword">class </span><a class="code" href="class_fdo_shp_ov_property_definition_collection.html">FdoShpOvPropertyDefinitionCollection</a> : <span class="keyword">public</span> FdoPhysicalElementMappingCollection<FdoShpOvPropertyDefinition>
+<a name="l00029"></a>00029 FDOSHP_API <span class="keyword">static</span> <a class="code" href="class_fdo_shp_ov_property_definition_collection.html">FdoShpOvPropertyDefinitionCollection</a>* <a class="code" href="class_fdo_shp_ov_property_definition_collection_bd6b681557f031ced9d12cb5905ce3e8.html#bd6b681557f031ced9d12cb5905ce3e8">Create</a>();
+<a name="l00030"></a>00030 FDOSHP_API <span class="keyword">static</span> <a class="code" href="class_fdo_shp_ov_property_definition_collection.html">FdoShpOvPropertyDefinitionCollection</a>* <a class="code" href="class_fdo_shp_ov_property_definition_collection_bd6b681557f031ced9d12cb5905ce3e8.html#bd6b681557f031ced9d12cb5905ce3e8">Create</a>(FdoPhysicalElementMapping *parent);
+<a name="l00033"></a>00033 <a class="code" href="class_fdo_shp_ov_property_definition_collection_9dcd52a0dfe26c64474d8b0688437ab2.html#9dcd52a0dfe26c64474d8b0688437ab2">FdoShpOvPropertyDefinitionCollection</a>();
+<a name="l00034"></a>00034 <a class="code" href="class_fdo_shp_ov_property_definition_collection_9dcd52a0dfe26c64474d8b0688437ab2.html#9dcd52a0dfe26c64474d8b0688437ab2">FdoShpOvPropertyDefinitionCollection</a>(FdoPhysicalElementMapping *parent);
+<a name="l00035"></a>00035 <span class="keyword">virtual</span> <a class="code" href="class_fdo_shp_ov_property_definition_collection_d3eed0522918ece73f92aa1340718aeb.html#d3eed0522918ece73f92aa1340718aeb">~FdoShpOvPropertyDefinitionCollection</a>(<span class="keywordtype">void</span>);
+<a name="l00036"></a>00036 <span class="keyword">virtual</span> <span class="keywordtype">void</span> <a class="code" href="class_fdo_shp_ov_property_definition_collection_1c61c73f46f6077d623451c5b73c66cd.html#1c61c73f46f6077d623451c5b73c66cd">Dispose</a>();
+<a name="l00039"></a><a class="code" href="_fdo_shp_property_definition_collection_8h_c523fa2a650dbc38df6576e0a1e8cbb6.html#c523fa2a650dbc38df6576e0a1e8cbb6">00039</a> <span class="keyword">typedef</span> FdoPtr<FdoShpOvPropertyDefinitionCollection> <a class="code" href="_fdo_shp_property_definition_collection_8h_c523fa2a650dbc38df6576e0a1e8cbb6.html#c523fa2a650dbc38df6576e0a1e8cbb6">FdoShpOvPropertyDefinitionCollectionP</a>;
+<a name="l00042"></a>00042 <span class="preprocessor">#endif // FDOSHPPROPERTYDEFINITIONCOLLECTION_H</span>
+<a name="l00043"></a>00043 <span class="preprocessor"></span>
+ <hr>
+ <table width="100%" border="0">
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,68 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
+<html>
+ <head>
+ <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
+ <title>OSGeo FDO Provider for SHP API Reference</title>
+ <link href="custom.css" rel="stylesheet" type="text/css">
+ <link href="tabs.css" rel="stylesheet" type="text/css">
+ </head>
+ <body bgcolor="#FFFFFF">
+ <tr>
+ <td><b>API Reference<b></td>
+ <td align="right"><b>OSGeo FDO Provider for SHP<b></td>
+ </tr>
+ </table>
+<!-- End of: header.html -->
+<!-- Generated by Doxygen 1.4.6-NO -->
+<div class="tabs">
+ <ul>
+ <li><a href="main.html"><span>Main Page</span></a></li>
+ <li><a href="classes.html"><span>Classes</span></a></li>
+ <li id="current"><a href="files.html"><span>Files</span></a></li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li><a href="files.html"><span>File List</span></a></li>
+ <li><a href="globals.html"><span>File Members</span></a></li>
+ </ul></div>
+<h1>FdoShpPropertyDefinitionCollection.h File Reference</h1>
+<p>
+<code>#include <<a class="el" href="_fdo_shp_property_definition_8h-source.html">SHP/Override/FdoShpPropertyDefinition.h</a>></code><br>
+<p>
+Include dependency graph for FdoShpPropertyDefinitionCollection.h:<p><center><img src="_fdo_shp_property_definition_collection_8h__incl.png" border="0" usemap="#FdoShpPropertyDefinitionCollection.h_map" alt=""></center>
+<map name="FdoShpPropertyDefinitionCollection.h_map">
+<area href="_fdo_shp_property_definition_8h.html" shape="rect" coords="303,7,577,33" alt="">
+<area href="_fdo_shp_column_definition_8h.html" shape="rect" coords="627,7,896,33" alt="">
+</map>
+<p>
+This graph shows which files directly or indirectly include this file:<p><center><img src="_fdo_shp_property_definition_collection_8h__dep__incl.png" border="0" usemap="#FdoShpPropertyDefinitionCollection.hdep_map" alt=""></center>
+<map name="FdoShpPropertyDefinitionCollection.hdep_map">
+<area href="_fdo_shp_class_definition_8h.html" shape="rect" coords="304,7,472,33" alt="">
+<area href="_fdo_shp_class_collection_8h.html" shape="rect" coords="523,7,693,33" alt="">
+<area href="_fdo_shp_physical_schema_mapping_8h.html" shape="rect" coords="744,7,973,33" alt="">
+</map>
+<p>
+<a href="_fdo_shp_property_definition_collection_8h-source.html">Go to the source code of this file.</a><table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">class </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_ov_property_definition_collection.html">FdoShpOvPropertyDefinitionCollection</a></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">typedef FdoPtr< <a class="el" href="class_fdo_shp_ov_property_definition_collection.html">FdoShpOvPropertyDefinitionCollection</a> > </td><td class="memItemRight" valign="bottom"><a class="el" href="_fdo_shp_property_definition_collection_8h_c523fa2a650dbc38df6576e0a1e8cbb6.html#c523fa2a650dbc38df6576e0a1e8cbb6">FdoShpOvPropertyDefinitionCollectionP</a></td></tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h__dep__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h__dep__incl.map?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h__dep__incl.map 2006-05-16 20:42:26+0000
@@ -0,0 +1,4 @@
+base referer
+rect $_fdo_shp_class_definition_8h.html 304,7 472,33
+rect $_fdo_shp_class_collection_8h.html 523,7 693,33
+rect $_fdo_shp_physical_schema_mapping_8h.html 744,7 973,33
Added: trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h__dep__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h__dep__incl.md5?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h__dep__incl.md5 2006-05-16 20:42:26+0000
@@ -0,0 +1 @@
+a671c1831a66264d3e8f98f4c2ecfb91
Added: trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h__dep__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h__dep__incl.png?view=auto&rev=15
Added: trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h__incl.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h__incl.map?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h__incl.map 2006-05-16 20:42:26+0000
@@ -0,0 +1,3 @@
+base referer
+rect $_fdo_shp_property_definition_8h.html 303,7 577,33
+rect $_fdo_shp_column_definition_8h.html 627,7 896,33
Added: trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h__incl.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h__incl.md5?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h__incl.md5 2006-05-16 20:42:26+0000
@@ -0,0 +1 @@
+fed427885475a5ae74cd4fb8027d9c05
Added: trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h__incl.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h__incl.png?view=auto&rev=15
Added: trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h_c523fa2a650dbc38df6576e0a1e8cbb6.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h_c523fa2a650dbc38df6576e0a1e8cbb6.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/_fdo_shp_property_definition_collection_8h_c523fa2a650dbc38df6576e0a1e8cbb6.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,74 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+<a class="el" href="_fdo_shp_property_definition_collection_8h.html">FdoShpPropertyDefinitionCollection.h</a></div>
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="_fdo_shp_property_definition_collection_8h_c523fa2a650dbc38df6576e0a1e8cbb6.html#c523fa2a650dbc38df6576e0a1e8cbb6">FdoShpOvPropertyDefinitionCollectionP</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="c523fa2a650dbc38df6576e0a1e8cbb6"></a><!-- doxytag: member="FdoShpPropertyDefinitionCollection.h::FdoShpOvPropertyDefinitionCollectionP" ref="c523fa2a650dbc38df6576e0a1e8cbb6" args="" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">typedef FdoPtr<<a class="el" href="class_fdo_shp_ov_property_definition_collection.html">FdoShpOvPropertyDefinitionCollection</a>> <a class="el" href="_fdo_shp_property_definition_collection_8h_c523fa2a650dbc38df6576e0a1e8cbb6.html#c523fa2a650dbc38df6576e0a1e8cbb6">FdoShpOvPropertyDefinitionCollectionP</a> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+<p>
+Definition at line <a class="el" href="_fdo_shp_property_definition_collection_8h-source.html#l00039">39</a> of file <a class="el" href="_fdo_shp_property_definition_collection_8h-source.html">FdoShpPropertyDefinitionCollection.h</a>. </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+<!-- footer.html -->
+ <hr>
+ <tr>
+ <td align="right"><font size="-2"><a href="mailto:isd.docs at autodesk.com&subject=FDO%20Provider%20for%20SHP%20API%20documentation">Comments?</a></font></td>
+ <!-- The logo can go in another cell, when we get one -->
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/annotated.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/annotated.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/annotated.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,49 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li id="current"><a href="classes.html"><span>Classes</span></a></li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li><a href="classes.html"><span>Alphabetical List</span></a></li>
+ <li id="current"><a href="annotated.html"><span>Class List</span></a></li>
+ <li><a href="hierarchy.html"><span>Class Hierarchy</span></a></li>
+ <li><a href="functions.html"><span>Class Members</span></a></li>
+ </ul></div>
+<h1>FDO Provider for SHP Class List</h1>Here are the classes, structs, unions and interfaces with brief descriptions:<table>
+ <tr><td class="indexkey"><a class="el" href="class_fdo_shp_ov_class_collection.html">FdoShpOvClassCollection</a></td><td class="indexvalue"></td></tr>
+ <tr><td class="indexkey"><a class="el" href="class_fdo_shp_ov_class_definition.html">FdoShpOvClassDefinition</a></td><td class="indexvalue"></td></tr>
+ <tr><td class="indexkey"><a class="el" href="class_fdo_shp_ov_column_definition.html">FdoShpOvColumnDefinition</a></td><td class="indexvalue"></td></tr>
+ <tr><td class="indexkey"><a class="el" href="class_fdo_shp_ov_physical_schema_mapping.html">FdoShpOvPhysicalSchemaMapping</a></td><td class="indexvalue"></td></tr>
+ <tr><td class="indexkey"><a class="el" href="class_fdo_shp_ov_property_definition.html">FdoShpOvPropertyDefinition</a></td><td class="indexvalue"></td></tr>
+ <tr><td class="indexkey"><a class="el" href="class_fdo_shp_ov_property_definition_collection.html">FdoShpOvPropertyDefinitionCollection</a></td><td class="indexvalue"></td></tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_class_collection-members.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_class_collection-members.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_class_collection-members.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,48 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li><a href="files.html"><span>Files</span></a></li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li><a href="annotated.html"><span>Class List</span></a></li>
+ </ul></div>
+<h1>FdoShpOvClassCollection Member List</h1>This is the complete list of members for <a class="el" href="class_fdo_shp_ov_class_collection.html">FdoShpOvClassCollection</a>, including all inherited members.<p><table>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_ov_class_collection_e71697e929d4ac5b62f7fc9fcdfcec8f.html#e71697e929d4ac5b62f7fc9fcdfcec8f">Create</a>()</td><td><a class="el" href="class_fdo_shp_ov_class_collection.html">FdoShpOvClassCollection</a></td><td><code> [static]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_ov_class_collection_3f8d21ceb843d89dd1501c5345e959ce.html#3f8d21ceb843d89dd1501c5345e959ce">Create</a>(FdoPhysicalElementMapping *parent)</td><td><a class="el" href="class_fdo_shp_ov_class_collection.html">FdoShpOvClassCollection</a></td><td><code> [static]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_ov_class_collection_c5568ebf824873a81cae138f1f72c0a7.html#c5568ebf824873a81cae138f1f72c0a7">Dispose</a>()</td><td><a class="el" href="class_fdo_shp_ov_class_collection.html">FdoShpOvClassCollection</a></td><td><code> [protected, virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_ov_class_collection_2075c326880b1d10e848791f5c781ef2.html#2075c326880b1d10e848791f5c781ef2">FdoShpOvClassCollection</a>()</td><td><a class="el" href="class_fdo_shp_ov_class_collection.html">FdoShpOvClassCollection</a></td><td><code> [protected]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_ov_class_collection_7ca47202e723ee690e94240c2dbaa22b.html#7ca47202e723ee690e94240c2dbaa22b">FdoShpOvClassCollection</a>(FdoPhysicalElementMapping *parent)</td><td><a class="el" href="class_fdo_shp_ov_class_collection.html">FdoShpOvClassCollection</a></td><td><code> [protected]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_ov_class_collection_d49972d5035851fc525d319fdd0ac0de.html#d49972d5035851fc525d319fdd0ac0de">~FdoShpOvClassCollection</a>(void)</td><td><a class="el" href="class_fdo_shp_ov_class_collection.html">FdoShpOvClassCollection</a></td><td><code> [protected, virtual]</code></td></tr>
+</table><!-- footer.html -->
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_class_collection.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_class_collection.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_class_collection.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,67 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>FdoShpOvClassCollection Class Reference</h1><!-- doxytag: class="FdoShpOvClassCollection" --><code>#include <<a class="el" href="_fdo_shp_class_collection_8h-source.html">FdoShpClassCollection.h</a>></code>
+<p>
+<a href="class_fdo_shp_ov_class_collection-members.html">List of all members.</a><hr><a name="_details"></a><h2>Detailed Description</h2>
+<p>
+<p>
+Definition at line <a class="el" href="_fdo_shp_class_collection_8h-source.html#l00026">26</a> of file <a class="el" href="_fdo_shp_class_collection_8h-source.html">FdoShpClassCollection.h</a>.<table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td colspan="2"><br><h2>Static Public Member Functions</h2></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">static FDOSHP_API <a class="el" href="class_fdo_shp_ov_class_collection.html">FdoShpOvClassCollection</a> * </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_ov_class_collection_3f8d21ceb843d89dd1501c5345e959ce.html#3f8d21ceb843d89dd1501c5345e959ce">Create</a> (FdoPhysicalElementMapping *parent)</td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">static FDOSHP_API <a class="el" href="class_fdo_shp_ov_class_collection.html">FdoShpOvClassCollection</a> * </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_ov_class_collection_e71697e929d4ac5b62f7fc9fcdfcec8f.html#e71697e929d4ac5b62f7fc9fcdfcec8f">Create</a> ()</td></tr>
+<tr><td colspan="2"><br><h2>Protected Member Functions</h2></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual void </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_ov_class_collection_c5568ebf824873a81cae138f1f72c0a7.html#c5568ebf824873a81cae138f1f72c0a7">Dispose</a> ()</td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top"> </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_ov_class_collection_7ca47202e723ee690e94240c2dbaa22b.html#7ca47202e723ee690e94240c2dbaa22b">FdoShpOvClassCollection</a> (FdoPhysicalElementMapping *parent)</td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top"> </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_ov_class_collection_2075c326880b1d10e848791f5c781ef2.html#2075c326880b1d10e848791f5c781ef2">FdoShpOvClassCollection</a> ()</td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_ov_class_collection_d49972d5035851fc525d319fdd0ac0de.html#d49972d5035851fc525d319fdd0ac0de">~FdoShpOvClassCollection</a> (void)</td></tr>
+</table>
+<hr>The documentation for this class was generated from the following file:<ul>
+<li><a class="el" href="_fdo_shp_class_collection_8h-source.html">FdoShpClassCollection.h</a></ul>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_class_collection_2075c326880b1d10e848791f5c781ef2.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_class_collection_2075c326880b1d10e848791f5c781ef2.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_class_collection_2075c326880b1d10e848791f5c781ef2.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,81 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+<a class="el" href="class_fdo_shp_ov_class_collection.html">FdoShpOvClassCollection</a></div>
+<table cellspacing="0" cellpadding="0" border="0">
+ <tr>
+ <td valign="top">
+ <div class="navtab">
+ <table>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_ov_class_collection_e71697e929d4ac5b62f7fc9fcdfcec8f.html#e71697e929d4ac5b62f7fc9fcdfcec8f">Create</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_ov_class_collection_3f8d21ceb843d89dd1501c5345e959ce.html#3f8d21ceb843d89dd1501c5345e959ce">Create</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_ov_class_collection_c5568ebf824873a81cae138f1f72c0a7.html#c5568ebf824873a81cae138f1f72c0a7">Dispose</a></td></tr>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_ov_class_collection_2075c326880b1d10e848791f5c781ef2.html#2075c326880b1d10e848791f5c781ef2">FdoShpOvClassCollection</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_ov_class_collection_7ca47202e723ee690e94240c2dbaa22b.html#7ca47202e723ee690e94240c2dbaa22b">FdoShpOvClassCollection</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_ov_class_collection_d49972d5035851fc525d319fdd0ac0de.html#d49972d5035851fc525d319fdd0ac0de">~FdoShpOvClassCollection</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="2075c326880b1d10e848791f5c781ef2"></a><!-- doxytag: member="FdoShpOvClassCollection::FdoShpOvClassCollection" ref="2075c326880b1d10e848791f5c781ef2" args="()" --><p>
+<table class="mdTable" cellpadding="2" cellspacing="0">
+ <tr>
+ <td class="mdRow">
+ <table cellpadding="0" cellspacing="0" border="0">
+ <tr>
+ <td class="md" nowrap valign="top">FdoShpOvClassCollection::FdoShpOvClassCollection </td>
+ <td class="md" valign="top">( </td>
+ <td class="mdname1" valign="top" nowrap> </td>
+ <td class="md" valign="top"> ) </td>
+ <td class="md" nowrap><code> [protected]</code></td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+<table cellspacing="5" cellpadding="0" border="0">
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_class_collection_3f8d21ceb843d89dd1501c5345e959ce.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_class_collection_3f8d21ceb843d89dd1501c5345e959ce.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_class_collection_3f8d21ceb843d89dd1501c5345e959ce.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,82 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_ov_class_collection_3f8d21ceb843d89dd1501c5345e959ce.html#3f8d21ceb843d89dd1501c5345e959ce">Create</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_ov_class_collection_2075c326880b1d10e848791f5c781ef2.html#2075c326880b1d10e848791f5c781ef2">FdoShpOvClassCollection</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="3f8d21ceb843d89dd1501c5345e959ce"></a><!-- doxytag: member="FdoShpOvClassCollection::Create" ref="3f8d21ceb843d89dd1501c5345e959ce" args="(FdoPhysicalElementMapping *parent)" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">static FDOSHP_API <a class="el" href="class_fdo_shp_ov_class_collection.html">FdoShpOvClassCollection</a>* FdoShpOvClassCollection::Create </td>
+ <td class="md" nowrap valign="top">FdoPhysicalElementMapping * </td>
+ <td class="mdname1" valign="top" nowrap> <em>parent</em> </td>
+ <td class="md" nowrap><code> [static]</code></td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_class_collection_7ca47202e723ee690e94240c2dbaa22b.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_class_collection_7ca47202e723ee690e94240c2dbaa22b.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_class_collection_7ca47202e723ee690e94240c2dbaa22b.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,82 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_ov_class_collection_7ca47202e723ee690e94240c2dbaa22b.html#7ca47202e723ee690e94240c2dbaa22b">FdoShpOvClassCollection</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="7ca47202e723ee690e94240c2dbaa22b"></a><!-- doxytag: member="FdoShpOvClassCollection::FdoShpOvClassCollection" ref="7ca47202e723ee690e94240c2dbaa22b" args="(FdoPhysicalElementMapping *parent)" --><p>
+ <tr>
+ <tr>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_class_collection_c5568ebf824873a81cae138f1f72c0a7.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_class_collection_c5568ebf824873a81cae138f1f72c0a7.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_class_collection_c5568ebf824873a81cae138f1f72c0a7.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,81 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_ov_class_collection_c5568ebf824873a81cae138f1f72c0a7.html#c5568ebf824873a81cae138f1f72c0a7">Dispose</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="c5568ebf824873a81cae138f1f72c0a7"></a><!-- doxytag: member="FdoShpOvClassCollection::Dispose" ref="c5568ebf824873a81cae138f1f72c0a7" args="()" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual void FdoShpOvClassCollection::Dispose </td>
+ <td class="md" nowrap><code> [protected, virtual]</code></td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_class_collection_d49972d5035851fc525d319fdd0ac0de.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_class_collection_d49972d5035851fc525d319fdd0ac0de.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_class_collection_d49972d5035851fc525d319fdd0ac0de.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,82 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_ov_class_collection_d49972d5035851fc525d319fdd0ac0de.html#d49972d5035851fc525d319fdd0ac0de">~FdoShpOvClassCollection</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="d49972d5035851fc525d319fdd0ac0de"></a><!-- doxytag: member="FdoShpOvClassCollection::~FdoShpOvClassCollection" ref="d49972d5035851fc525d319fdd0ac0de" args="(void)" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual FdoShpOvClassCollection::~FdoShpOvClassCollection </td>
+ <td class="md" nowrap valign="top">void </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_class_collection_e71697e929d4ac5b62f7fc9fcdfcec8f.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_class_collection_e71697e929d4ac5b62f7fc9fcdfcec8f.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_class_collection_e71697e929d4ac5b62f7fc9fcdfcec8f.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,81 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_ov_class_collection_e71697e929d4ac5b62f7fc9fcdfcec8f.html#e71697e929d4ac5b62f7fc9fcdfcec8f">Create</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="e71697e929d4ac5b62f7fc9fcdfcec8f"></a><!-- doxytag: member="FdoShpOvClassCollection::Create" ref="e71697e929d4ac5b62f7fc9fcdfcec8f" args="()" --><p>
+ <tr>
+ <tr>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_class_definition-members.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_class_definition-members.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_class_definition-members.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,56 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>FdoShpOvClassDefinition Member List</h1>This is the complete list of members for <a class="el" href="class_fdo_shp_ov_class_definition.html">FdoShpOvClassDefinition</a>, including all inherited members.<p><table>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_ov_class_definition_a4318e266ade8f0561246fe5385a488c.html#a4318e266ade8f0561246fe5385a488c">_writeXml</a>(FdoXmlWriter *xmlWriter, const FdoXmlFlags *flags)</td><td><a class="el" href="class_fdo_shp_ov_class_definition.html">FdoShpOvClassDefinition</a></td><td><code> [virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_ov_class_definition_74352faa22702f58a3ed79591635dffb.html#74352faa22702f58a3ed79591635dffb">Create</a>()</td><td><a class="el" href="class_fdo_shp_ov_class_definition.html">FdoShpOvClassDefinition</a></td><td><code> [static]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_ov_class_definition_3212ae28553647cef5b24eea5be5d182.html#3212ae28553647cef5b24eea5be5d182">Dispose</a>(void)</td><td><a class="el" href="class_fdo_shp_ov_class_definition.html">FdoShpOvClassDefinition</a></td><td><code> [protected, virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_ov_class_definition_5ff553ac0195587c9753b2fe95d42a61.html#5ff553ac0195587c9753b2fe95d42a61">FdoShpOvClassDefinition</a>(void)</td><td><a class="el" href="class_fdo_shp_ov_class_definition.html">FdoShpOvClassDefinition</a></td><td><code> [protected]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_ov_class_definition_03bd17ccb7d6f1f3509b49309073d154.html#03bd17ccb7d6f1f3509b49309073d154">FindByColumnName</a>(FdoString *columnName)</td><td><a class="el" href="class_fdo_shp_ov_class_definition.html">FdoShpOvClassDefinition</a></td><td></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_ov_class_definition_c4fd98e86e1b061f3314ee5eb6664030.html#c4fd98e86e1b061f3314ee5eb6664030">GetProperties</a>() const </td><td><a class="el" href="class_fdo_shp_ov_class_definition.html">FdoShpOvClassDefinition</a></td><td></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_ov_class_definition_f7f39af97bbd5e5644196196f322f02c.html#f7f39af97bbd5e5644196196f322f02c">GetShapeFile</a>() const </td><td><a class="el" href="class_fdo_shp_ov_class_definition.html">FdoShpOvClassDefinition</a></td><td></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_ov_class_definition_03246baa324656d80807273c8669082f.html#03246baa324656d80807273c8669082f">InitFromXml</a>(FdoXmlSaxContext *pContext, FdoXmlAttributeCollection *attrs)</td><td><a class="el" href="class_fdo_shp_ov_class_definition.html">FdoShpOvClassDefinition</a></td><td><code> [virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_ov_class_definition_1e811303f7da9de17189d3b91b40df17.html#1e811303f7da9de17189d3b91b40df17">IsPathUpdated</a>()</td><td><a class="el" href="class_fdo_shp_ov_class_definition.html">FdoShpOvClassDefinition</a></td><td><code> [inline]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_ov_class_definition_58b334144a66fdd59ca905faa384cedc.html#58b334144a66fdd59ca905faa384cedc">SetPathUpdated</a>(bool lPathUpdated=true)</td><td><a class="el" href="class_fdo_shp_ov_class_definition.html">FdoShpOvClassDefinition</a></td><td><code> [inline]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_ov_class_definition_231e0376b3239b584382401389a74991.html#231e0376b3239b584382401389a74991">SetShapeFile</a>(FdoString *location)</td><td><a class="el" href="class_fdo_shp_ov_class_definition.html">FdoShpOvClassDefinition</a></td><td></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_ov_class_definition_d27f1b55c70e4ff58df6df488f8abf9b.html#d27f1b55c70e4ff58df6df488f8abf9b">XmlEndElement</a>(FdoXmlSaxContext *context, FdoString *uri, FdoString *name, FdoString *qname)</td><td><a class="el" href="class_fdo_shp_ov_class_definition.html">FdoShpOvClassDefinition</a></td><td><code> [virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_ov_class_definition_73405bd93a5068e2c0125076ef82b0ae.html#73405bd93a5068e2c0125076ef82b0ae">XmlStartElement</a>(FdoXmlSaxContext *context, FdoString *uri, FdoString *name, FdoString *qname, FdoXmlAttributeCollection *atts)</td><td><a class="el" href="class_fdo_shp_ov_class_definition.html">FdoShpOvClassDefinition</a></td><td><code> [virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_ov_class_definition_2de74cf4ba695c3a27f84d924fae13d1.html#2de74cf4ba695c3a27f84d924fae13d1">~FdoShpOvClassDefinition</a>(void)</td><td><a class="el" href="class_fdo_shp_ov_class_definition.html">FdoShpOvClassDefinition</a></td><td><code> [protected, virtual]</code></td></tr>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_class_definition.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_class_definition.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_class_definition.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,85 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>FdoShpOvClassDefinition Class Reference</h1><!-- doxytag: class="FdoShpOvClassDefinition" --><code>#include <<a class="el" href="_fdo_shp_class_definition_8h-source.html">FdoShpClassDefinition.h</a>></code>
+<p>
+<a href="class_fdo_shp_ov_class_definition-members.html">List of all members.</a><hr><a name="_details"></a><h2>Detailed Description</h2>
+<p>
+<p>
+Definition at line <a class="el" href="_fdo_shp_class_definition_8h-source.html#l00026">26</a> of file <a class="el" href="_fdo_shp_class_definition_8h-source.html">FdoShpClassDefinition.h</a>.<table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td colspan="2"><br><h2>Public Member Functions</h2></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDOSHP_API void </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_ov_class_definition_a4318e266ade8f0561246fe5385a488c.html#a4318e266ade8f0561246fe5385a488c">_writeXml</a> (FdoXmlWriter *xmlWriter, const FdoXmlFlags *flags)</td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">FDOSHP_API <a class="el" href="class_fdo_shp_ov_property_definition.html">FdoShpOvPropertyDefinition</a> * </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_ov_class_definition_03bd17ccb7d6f1f3509b49309073d154.html#03bd17ccb7d6f1f3509b49309073d154">FindByColumnName</a> (FdoString *columnName)</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Helper method to find a property mapping by its column name:. <a href="#03bd17ccb7d6f1f3509b49309073d154"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">FDOSHP_API <a class="el" href="class_fdo_shp_ov_property_definition_collection.html">FdoShpOvPropertyDefinitionCollection</a> * </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_ov_class_definition_c4fd98e86e1b061f3314ee5eb6664030.html#c4fd98e86e1b061f3314ee5eb6664030">GetProperties</a> () const </td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">FDOSHP_API FdoString * </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_ov_class_definition_f7f39af97bbd5e5644196196f322f02c.html#f7f39af97bbd5e5644196196f322f02c">GetShapeFile</a> () const </td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDOSHP_API void </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_ov_class_definition_03246baa324656d80807273c8669082f.html#03246baa324656d80807273c8669082f">InitFromXml</a> (FdoXmlSaxContext *pContext, FdoXmlAttributeCollection *attrs)</td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">bool </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_ov_class_definition_1e811303f7da9de17189d3b91b40df17.html#1e811303f7da9de17189d3b91b40df17">IsPathUpdated</a> ()</td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">void </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_ov_class_definition_58b334144a66fdd59ca905faa384cedc.html#58b334144a66fdd59ca905faa384cedc">SetPathUpdated</a> (bool lPathUpdated=true)</td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">FDOSHP_API void </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_ov_class_definition_231e0376b3239b584382401389a74991.html#231e0376b3239b584382401389a74991">SetShapeFile</a> (FdoString *location)</td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDOSHP_API FdoBoolean </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_ov_class_definition_d27f1b55c70e4ff58df6df488f8abf9b.html#d27f1b55c70e4ff58df6df488f8abf9b">XmlEndElement</a> (FdoXmlSaxContext *context, FdoString *uri, FdoString *name, FdoString *qname)</td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDOSHP_API FdoXmlSaxHandler * </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_ov_class_definition_73405bd93a5068e2c0125076ef82b0ae.html#73405bd93a5068e2c0125076ef82b0ae">XmlStartElement</a> (FdoXmlSaxContext *context, FdoString *uri, FdoString *name, FdoString *qname, FdoXmlAttributeCollection *atts)</td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">static FDOSHP_API <a class="el" href="class_fdo_shp_ov_class_definition.html">FdoShpOvClassDefinition</a> * </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_ov_class_definition_74352faa22702f58a3ed79591635dffb.html#74352faa22702f58a3ed79591635dffb">Create</a> ()</td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual void </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_ov_class_definition_3212ae28553647cef5b24eea5be5d182.html#3212ae28553647cef5b24eea5be5d182">Dispose</a> (void)</td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top"> </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_ov_class_definition_5ff553ac0195587c9753b2fe95d42a61.html#5ff553ac0195587c9753b2fe95d42a61">FdoShpOvClassDefinition</a> (void)</td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_ov_class_definition_2de74cf4ba695c3a27f84d924fae13d1.html#2de74cf4ba695c3a27f84d924fae13d1">~FdoShpOvClassDefinition</a> (void)</td></tr>
+</table>
+<li><a class="el" href="_fdo_shp_class_definition_8h-source.html">FdoShpClassDefinition.h</a></ul>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_class_definition_03246baa324656d80807273c8669082f.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_class_definition_03246baa324656d80807273c8669082f.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_class_definition_03246baa324656d80807273c8669082f.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,99 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+<a class="el" href="class_fdo_shp_ov_class_definition.html">FdoShpOvClassDefinition</a></div>
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_ov_class_definition_a4318e266ade8f0561246fe5385a488c.html#a4318e266ade8f0561246fe5385a488c">_writeXml</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_ov_class_definition_74352faa22702f58a3ed79591635dffb.html#74352faa22702f58a3ed79591635dffb">Create</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_ov_class_definition_3212ae28553647cef5b24eea5be5d182.html#3212ae28553647cef5b24eea5be5d182">Dispose</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_ov_class_definition_5ff553ac0195587c9753b2fe95d42a61.html#5ff553ac0195587c9753b2fe95d42a61">FdoShpOvClassDefinition</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_ov_class_definition_03bd17ccb7d6f1f3509b49309073d154.html#03bd17ccb7d6f1f3509b49309073d154">FindByColumnName</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_ov_class_definition_c4fd98e86e1b061f3314ee5eb6664030.html#c4fd98e86e1b061f3314ee5eb6664030">GetProperties</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_ov_class_definition_f7f39af97bbd5e5644196196f322f02c.html#f7f39af97bbd5e5644196196f322f02c">GetShapeFile</a></td></tr>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_ov_class_definition_03246baa324656d80807273c8669082f.html#03246baa324656d80807273c8669082f">InitFromXml</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_ov_class_definition_1e811303f7da9de17189d3b91b40df17.html#1e811303f7da9de17189d3b91b40df17">IsPathUpdated</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_ov_class_definition_58b334144a66fdd59ca905faa384cedc.html#58b334144a66fdd59ca905faa384cedc">SetPathUpdated</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_ov_class_definition_231e0376b3239b584382401389a74991.html#231e0376b3239b584382401389a74991">SetShapeFile</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_ov_class_definition_d27f1b55c70e4ff58df6df488f8abf9b.html#d27f1b55c70e4ff58df6df488f8abf9b">XmlEndElement</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_ov_class_definition_73405bd93a5068e2c0125076ef82b0ae.html#73405bd93a5068e2c0125076ef82b0ae">XmlStartElement</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_ov_class_definition_2de74cf4ba695c3a27f84d924fae13d1.html#2de74cf4ba695c3a27f84d924fae13d1">~FdoShpOvClassDefinition</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="03246baa324656d80807273c8669082f"></a><!-- doxytag: member="FdoShpOvClassDefinition::InitFromXml" ref="03246baa324656d80807273c8669082f" args="(FdoXmlSaxContext *pContext, FdoXmlAttributeCollection *attrs)" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual FDOSHP_API void FdoShpOvClassDefinition::InitFromXml </td>
+ <td class="md" nowrap valign="top">FdoXmlSaxContext * </td>
+ <td class="mdname" nowrap> <em>pContext</em>, </td>
+ </tr>
+ <tr>
+ <td class="md" nowrap align="right"></td>
+ <td class="md"></td>
+ <td class="md" nowrap>FdoXmlAttributeCollection * </td>
+ <td class="mdname" nowrap> <em>attrs</em></td>
+ </tr>
+ <tr>
+ <td class="md">) </td>
+ <td class="md" colspan="2"><code> [virtual]</code></td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_class_definition_03bd17ccb7d6f1f3509b49309073d154.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_class_definition_03bd17ccb7d6f1f3509b49309073d154.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_class_definition_03bd17ccb7d6f1f3509b49309073d154.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,92 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_ov_class_definition_03bd17ccb7d6f1f3509b49309073d154.html#03bd17ccb7d6f1f3509b49309073d154">FindByColumnName</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_ov_class_definition_03246baa324656d80807273c8669082f.html#03246baa324656d80807273c8669082f">InitFromXml</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="03bd17ccb7d6f1f3509b49309073d154"></a><!-- doxytag: member="FdoShpOvClassDefinition::FindByColumnName" ref="03bd17ccb7d6f1f3509b49309073d154" args="(FdoString *columnName)" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">FDOSHP_API <a class="el" href="class_fdo_shp_ov_property_definition.html">FdoShpOvPropertyDefinition</a>* FdoShpOvClassDefinition::FindByColumnName </td>
+ <td class="md" nowrap valign="top">FdoString * </td>
+ <td class="mdname1" valign="top" nowrap> <em>columnName</em> </td>
+ <td class="md" nowrap></td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Helper method to find a property mapping by its column name:.
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_class_definition_1e811303f7da9de17189d3b91b40df17.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_class_definition_1e811303f7da9de17189d3b91b40df17.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_class_definition_1e811303f7da9de17189d3b91b40df17.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,91 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_ov_class_definition_1e811303f7da9de17189d3b91b40df17.html#1e811303f7da9de17189d3b91b40df17">IsPathUpdated</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="1e811303f7da9de17189d3b91b40df17"></a><!-- doxytag: member="FdoShpOvClassDefinition::IsPathUpdated" ref="1e811303f7da9de17189d3b91b40df17" args="()" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">bool FdoShpOvClassDefinition::IsPathUpdated </td>
+ <td class="md" nowrap><code> [inline]</code></td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+<p>
+Definition at line <a class="el" href="_fdo_shp_class_definition_8h-source.html#l00038">38</a> of file <a class="el" href="_fdo_shp_class_definition_8h-source.html">FdoShpClassDefinition.h</a>. </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_class_definition_231e0376b3239b584382401389a74991.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_class_definition_231e0376b3239b584382401389a74991.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_class_definition_231e0376b3239b584382401389a74991.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,90 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_ov_class_definition_231e0376b3239b584382401389a74991.html#231e0376b3239b584382401389a74991">SetShapeFile</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="231e0376b3239b584382401389a74991"></a><!-- doxytag: member="FdoShpOvClassDefinition::SetShapeFile" ref="231e0376b3239b584382401389a74991" args="(FdoString *location)" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">FDOSHP_API void FdoShpOvClassDefinition::SetShapeFile </td>
+ <td class="mdname1" valign="top" nowrap> <em>location</em> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_class_definition_2de74cf4ba695c3a27f84d924fae13d1.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_class_definition_2de74cf4ba695c3a27f84d924fae13d1.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_class_definition_2de74cf4ba695c3a27f84d924fae13d1.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,90 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_ov_class_definition_2de74cf4ba695c3a27f84d924fae13d1.html#2de74cf4ba695c3a27f84d924fae13d1">~FdoShpOvClassDefinition</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="2de74cf4ba695c3a27f84d924fae13d1"></a><!-- doxytag: member="FdoShpOvClassDefinition::~FdoShpOvClassDefinition" ref="2de74cf4ba695c3a27f84d924fae13d1" args="(void)" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual FdoShpOvClassDefinition::~FdoShpOvClassDefinition </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_class_definition_3212ae28553647cef5b24eea5be5d182.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_class_definition_3212ae28553647cef5b24eea5be5d182.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_class_definition_3212ae28553647cef5b24eea5be5d182.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,90 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_ov_class_definition_3212ae28553647cef5b24eea5be5d182.html#3212ae28553647cef5b24eea5be5d182">Dispose</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="3212ae28553647cef5b24eea5be5d182"></a><!-- doxytag: member="FdoShpOvClassDefinition::Dispose" ref="3212ae28553647cef5b24eea5be5d182" args="(void)" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual void FdoShpOvClassDefinition::Dispose </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_class_definition_58b334144a66fdd59ca905faa384cedc.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_class_definition_58b334144a66fdd59ca905faa384cedc.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_class_definition_58b334144a66fdd59ca905faa384cedc.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,92 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_ov_class_definition_58b334144a66fdd59ca905faa384cedc.html#58b334144a66fdd59ca905faa384cedc">SetPathUpdated</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="58b334144a66fdd59ca905faa384cedc"></a><!-- doxytag: member="FdoShpOvClassDefinition::SetPathUpdated" ref="58b334144a66fdd59ca905faa384cedc" args="(bool lPathUpdated=true)" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">void FdoShpOvClassDefinition::SetPathUpdated </td>
+ <td class="md" nowrap valign="top">bool </td>
+ <td class="mdname1" valign="top" nowrap> <em>lPathUpdated</em> = <code>true</code> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+<p>
+Definition at line <a class="el" href="_fdo_shp_class_definition_8h-source.html#l00039">39</a> of file <a class="el" href="_fdo_shp_class_definition_8h-source.html">FdoShpClassDefinition.h</a>. </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_class_definition_5ff553ac0195587c9753b2fe95d42a61.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_class_definition_5ff553ac0195587c9753b2fe95d42a61.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_class_definition_5ff553ac0195587c9753b2fe95d42a61.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,90 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_ov_class_definition_5ff553ac0195587c9753b2fe95d42a61.html#5ff553ac0195587c9753b2fe95d42a61">FdoShpOvClassDefinition</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="5ff553ac0195587c9753b2fe95d42a61"></a><!-- doxytag: member="FdoShpOvClassDefinition::FdoShpOvClassDefinition" ref="5ff553ac0195587c9753b2fe95d42a61" args="(void)" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">FdoShpOvClassDefinition::FdoShpOvClassDefinition </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_class_definition_73405bd93a5068e2c0125076ef82b0ae.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_class_definition_73405bd93a5068e2c0125076ef82b0ae.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_class_definition_73405bd93a5068e2c0125076ef82b0ae.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,117 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_ov_class_definition_73405bd93a5068e2c0125076ef82b0ae.html#73405bd93a5068e2c0125076ef82b0ae">XmlStartElement</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="73405bd93a5068e2c0125076ef82b0ae"></a><!-- doxytag: member="FdoShpOvClassDefinition::XmlStartElement" ref="73405bd93a5068e2c0125076ef82b0ae" args="(FdoXmlSaxContext *context, FdoString *uri, FdoString *name, FdoString *qname, FdoXmlAttributeCollection *atts)" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual FDOSHP_API FdoXmlSaxHandler* FdoShpOvClassDefinition::XmlStartElement </td>
+ <td class="mdname" nowrap> <em>context</em>, </td>
+ </tr>
+ <tr>
+ <td class="md" nowrap>FdoString * </td>
+ <td class="mdname" nowrap> <em>uri</em>, </td>
+ </tr>
+ <tr>
+ <td class="mdname" nowrap> <em>name</em>, </td>
+ </tr>
+ <tr>
+ <td class="mdname" nowrap> <em>qname</em>, </td>
+ </tr>
+ <tr>
+ <td class="mdname" nowrap> <em>atts</em></td>
+ </tr>
+ <tr>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_class_definition_74352faa22702f58a3ed79591635dffb.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_class_definition_74352faa22702f58a3ed79591635dffb.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_class_definition_74352faa22702f58a3ed79591635dffb.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,89 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_ov_class_definition_74352faa22702f58a3ed79591635dffb.html#74352faa22702f58a3ed79591635dffb">Create</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="74352faa22702f58a3ed79591635dffb"></a><!-- doxytag: member="FdoShpOvClassDefinition::Create" ref="74352faa22702f58a3ed79591635dffb" args="()" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">static FDOSHP_API <a class="el" href="class_fdo_shp_ov_class_definition.html">FdoShpOvClassDefinition</a>* FdoShpOvClassDefinition::Create </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_class_definition_a4318e266ade8f0561246fe5385a488c.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_class_definition_a4318e266ade8f0561246fe5385a488c.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_class_definition_a4318e266ade8f0561246fe5385a488c.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,99 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_ov_class_definition_a4318e266ade8f0561246fe5385a488c.html#a4318e266ade8f0561246fe5385a488c">_writeXml</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="a4318e266ade8f0561246fe5385a488c"></a><!-- doxytag: member="FdoShpOvClassDefinition::_writeXml" ref="a4318e266ade8f0561246fe5385a488c" args="(FdoXmlWriter *xmlWriter, const FdoXmlFlags *flags)" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual FDOSHP_API void FdoShpOvClassDefinition::_writeXml </td>
+ <td class="md" nowrap valign="top">FdoXmlWriter * </td>
+ <td class="mdname" nowrap> <em>xmlWriter</em>, </td>
+ </tr>
+ <tr>
+ <td class="md" nowrap>const FdoXmlFlags * </td>
+ <td class="mdname" nowrap> <em>flags</em></td>
+ </tr>
+ <tr>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_class_definition_c4fd98e86e1b061f3314ee5eb6664030.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_class_definition_c4fd98e86e1b061f3314ee5eb6664030.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_class_definition_c4fd98e86e1b061f3314ee5eb6664030.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,89 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_ov_class_definition_c4fd98e86e1b061f3314ee5eb6664030.html#c4fd98e86e1b061f3314ee5eb6664030">GetProperties</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="c4fd98e86e1b061f3314ee5eb6664030"></a><!-- doxytag: member="FdoShpOvClassDefinition::GetProperties" ref="c4fd98e86e1b061f3314ee5eb6664030" args="() const " --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">FDOSHP_API <a class="el" href="class_fdo_shp_ov_property_definition_collection.html">FdoShpOvPropertyDefinitionCollection</a>* FdoShpOvClassDefinition::GetProperties </td>
+ <td class="md" nowrap> const</td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_class_definition_d27f1b55c70e4ff58df6df488f8abf9b.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_class_definition_d27f1b55c70e4ff58df6df488f8abf9b.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_class_definition_d27f1b55c70e4ff58df6df488f8abf9b.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,111 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_ov_class_definition_d27f1b55c70e4ff58df6df488f8abf9b.html#d27f1b55c70e4ff58df6df488f8abf9b">XmlEndElement</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="d27f1b55c70e4ff58df6df488f8abf9b"></a><!-- doxytag: member="FdoShpOvClassDefinition::XmlEndElement" ref="d27f1b55c70e4ff58df6df488f8abf9b" args="(FdoXmlSaxContext *context, FdoString *uri, FdoString *name, FdoString *qname)" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual FDOSHP_API FdoBoolean FdoShpOvClassDefinition::XmlEndElement </td>
+ </tr>
+ <tr>
+ </tr>
+ <tr>
+ </tr>
+ <tr>
+ <td class="mdname" nowrap> <em>qname</em></td>
+ </tr>
+ <tr>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_class_definition_f7f39af97bbd5e5644196196f322f02c.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_class_definition_f7f39af97bbd5e5644196196f322f02c.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_class_definition_f7f39af97bbd5e5644196196f322f02c.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,89 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_ov_class_definition_f7f39af97bbd5e5644196196f322f02c.html#f7f39af97bbd5e5644196196f322f02c">GetShapeFile</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="f7f39af97bbd5e5644196196f322f02c"></a><!-- doxytag: member="FdoShpOvClassDefinition::GetShapeFile" ref="f7f39af97bbd5e5644196196f322f02c" args="() const " --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">FDOSHP_API FdoString* FdoShpOvClassDefinition::GetShapeFile </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <table width="100%" border="0">
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_column_definition-members.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_column_definition-members.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_column_definition-members.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,50 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
+<html>
+ <head>
+ <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
+ <title>OSGeo FDO Provider for SHP API Reference</title>
+ <link href="custom.css" rel="stylesheet" type="text/css">
+ <link href="tabs.css" rel="stylesheet" type="text/css">
+ </head>
+ <body bgcolor="#FFFFFF">
+ <tr>
+ <td><b>API Reference<b></td>
+ <td align="right"><b>OSGeo FDO Provider for SHP<b></td>
+ </tr>
+ </table>
+<!-- End of: header.html -->
+<!-- Generated by Doxygen 1.4.6-NO -->
+<div class="tabs">
+ <ul>
+ <li><a href="main.html"><span>Main Page</span></a></li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>FdoShpOvColumnDefinition Member List</h1>This is the complete list of members for <a class="el" href="class_fdo_shp_ov_column_definition.html">FdoShpOvColumnDefinition</a>, including all inherited members.<p><table>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_ov_column_definition_58f92ba87a369a97428c7d937d569c72.html#58f92ba87a369a97428c7d937d569c72">_writeXml</a>(FdoXmlWriter *xmlWriter, const FdoXmlFlags *flags)</td><td><a class="el" href="class_fdo_shp_ov_column_definition.html">FdoShpOvColumnDefinition</a></td><td><code> [virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_ov_column_definition_71f1cbc25bd5085cd546450015067b08.html#71f1cbc25bd5085cd546450015067b08">Create</a>()</td><td><a class="el" href="class_fdo_shp_ov_column_definition.html">FdoShpOvColumnDefinition</a></td><td><code> [static]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_ov_column_definition_eca75a56d812c8a7bd40dbc5bb303adc.html#eca75a56d812c8a7bd40dbc5bb303adc">Dispose</a>(void)</td><td><a class="el" href="class_fdo_shp_ov_column_definition.html">FdoShpOvColumnDefinition</a></td><td><code> [protected, virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_ov_column_definition_90d84295b5cbbda30ca5e3d66a895cff.html#90d84295b5cbbda30ca5e3d66a895cff">FdoShpOvColumnDefinition</a>(void)</td><td><a class="el" href="class_fdo_shp_ov_column_definition.html">FdoShpOvColumnDefinition</a></td><td><code> [protected]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_ov_column_definition_d8671acab0db72d517012189859cdafe.html#d8671acab0db72d517012189859cdafe">InitFromXml</a>(FdoXmlSaxContext *pContext, FdoXmlAttributeCollection *attrs)</td><td><a class="el" href="class_fdo_shp_ov_column_definition.html">FdoShpOvColumnDefinition</a></td><td><code> [virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_ov_column_definition_fff19eb49dc45425fdb3ef7e1a8cc34f.html#fff19eb49dc45425fdb3ef7e1a8cc34f">XmlEndElement</a>(FdoXmlSaxContext *context, FdoString *uri, FdoString *name, FdoString *qname)</td><td><a class="el" href="class_fdo_shp_ov_column_definition.html">FdoShpOvColumnDefinition</a></td><td><code> [virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_ov_column_definition_64d163015f3c021b5dc5fbe6105ff89a.html#64d163015f3c021b5dc5fbe6105ff89a">XmlStartElement</a>(FdoXmlSaxContext *context, FdoString *uri, FdoString *name, FdoString *qname, FdoXmlAttributeCollection *atts)</td><td><a class="el" href="class_fdo_shp_ov_column_definition.html">FdoShpOvColumnDefinition</a></td><td><code> [virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_ov_column_definition_343c8b7cbb45e9ad7aefbd97f7879ec3.html#343c8b7cbb45e9ad7aefbd97f7879ec3">~FdoShpOvColumnDefinition</a>(void)</td><td><a class="el" href="class_fdo_shp_ov_column_definition.html">FdoShpOvColumnDefinition</a></td><td><code> [protected, virtual]</code></td></tr>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_column_definition.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_column_definition.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_column_definition.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,72 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>FdoShpOvColumnDefinition Class Reference</h1><!-- doxytag: class="FdoShpOvColumnDefinition" --><code>#include <<a class="el" href="_fdo_shp_column_definition_8h-source.html">FdoShpColumnDefinition.h</a>></code>
+<p>
+<a href="class_fdo_shp_ov_column_definition-members.html">List of all members.</a><hr><a name="_details"></a><h2>Detailed Description</h2>
+<p>
+<p>
+Definition at line <a class="el" href="_fdo_shp_column_definition_8h-source.html#l00024">24</a> of file <a class="el" href="_fdo_shp_column_definition_8h-source.html">FdoShpColumnDefinition.h</a>.<table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDOSHP_API void </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_ov_column_definition_58f92ba87a369a97428c7d937d569c72.html#58f92ba87a369a97428c7d937d569c72">_writeXml</a> (FdoXmlWriter *xmlWriter, const FdoXmlFlags *flags)</td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDOSHP_API void </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_ov_column_definition_d8671acab0db72d517012189859cdafe.html#d8671acab0db72d517012189859cdafe">InitFromXml</a> (FdoXmlSaxContext *pContext, FdoXmlAttributeCollection *attrs)</td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDOSHP_API FdoBoolean </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_ov_column_definition_fff19eb49dc45425fdb3ef7e1a8cc34f.html#fff19eb49dc45425fdb3ef7e1a8cc34f">XmlEndElement</a> (FdoXmlSaxContext *context, FdoString *uri, FdoString *name, FdoString *qname)</td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDOSHP_API FdoXmlSaxHandler * </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_ov_column_definition_64d163015f3c021b5dc5fbe6105ff89a.html#64d163015f3c021b5dc5fbe6105ff89a">XmlStartElement</a> (FdoXmlSaxContext *context, FdoString *uri, FdoString *name, FdoString *qname, FdoXmlAttributeCollection *atts)</td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">static FDOSHP_API <a class="el" href="class_fdo_shp_ov_column_definition.html">FdoShpOvColumnDefinition</a> * </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_ov_column_definition_71f1cbc25bd5085cd546450015067b08.html#71f1cbc25bd5085cd546450015067b08">Create</a> ()</td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual void </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_ov_column_definition_eca75a56d812c8a7bd40dbc5bb303adc.html#eca75a56d812c8a7bd40dbc5bb303adc">Dispose</a> (void)</td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top"> </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_ov_column_definition_90d84295b5cbbda30ca5e3d66a895cff.html#90d84295b5cbbda30ca5e3d66a895cff">FdoShpOvColumnDefinition</a> (void)</td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_ov_column_definition_343c8b7cbb45e9ad7aefbd97f7879ec3.html#343c8b7cbb45e9ad7aefbd97f7879ec3">~FdoShpOvColumnDefinition</a> (void)</td></tr>
+</table>
+<li><a class="el" href="_fdo_shp_column_definition_8h-source.html">FdoShpColumnDefinition.h</a></ul>
+<!-- footer.html -->
+ <hr>
+ <tr>
+ <td align="right"><font size="-2"><a href="mailto:isd.docs at autodesk.com&subject=FDO%20Provider%20for%20SHP%20API%20documentation">Comments?</a></font></td>
+ <!-- The logo can go in another cell, when we get one -->
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_column_definition_343c8b7cbb45e9ad7aefbd97f7879ec3.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_column_definition_343c8b7cbb45e9ad7aefbd97f7879ec3.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_column_definition_343c8b7cbb45e9ad7aefbd97f7879ec3.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,84 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li><a href="classes.html"><span>Classes</span></a></li>
+ </ul></div>
+<div class="nav">
+<a class="el" href="class_fdo_shp_ov_column_definition.html">FdoShpOvColumnDefinition</a></div>
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_ov_column_definition_58f92ba87a369a97428c7d937d569c72.html#58f92ba87a369a97428c7d937d569c72">_writeXml</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_ov_column_definition_71f1cbc25bd5085cd546450015067b08.html#71f1cbc25bd5085cd546450015067b08">Create</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_ov_column_definition_eca75a56d812c8a7bd40dbc5bb303adc.html#eca75a56d812c8a7bd40dbc5bb303adc">Dispose</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_ov_column_definition_90d84295b5cbbda30ca5e3d66a895cff.html#90d84295b5cbbda30ca5e3d66a895cff">FdoShpOvColumnDefinition</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_ov_column_definition_d8671acab0db72d517012189859cdafe.html#d8671acab0db72d517012189859cdafe">InitFromXml</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_ov_column_definition_fff19eb49dc45425fdb3ef7e1a8cc34f.html#fff19eb49dc45425fdb3ef7e1a8cc34f">XmlEndElement</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_ov_column_definition_64d163015f3c021b5dc5fbe6105ff89a.html#64d163015f3c021b5dc5fbe6105ff89a">XmlStartElement</a></td></tr>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_ov_column_definition_343c8b7cbb45e9ad7aefbd97f7879ec3.html#343c8b7cbb45e9ad7aefbd97f7879ec3">~FdoShpOvColumnDefinition</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="343c8b7cbb45e9ad7aefbd97f7879ec3"></a><!-- doxytag: member="FdoShpOvColumnDefinition::~FdoShpOvColumnDefinition" ref="343c8b7cbb45e9ad7aefbd97f7879ec3" args="(void)" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual FdoShpOvColumnDefinition::~FdoShpOvColumnDefinition </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_column_definition_58f92ba87a369a97428c7d937d569c72.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_column_definition_58f92ba87a369a97428c7d937d569c72.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_column_definition_58f92ba87a369a97428c7d937d569c72.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,93 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li><a href="files.html"><span>Files</span></a></li>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_ov_column_definition_58f92ba87a369a97428c7d937d569c72.html#58f92ba87a369a97428c7d937d569c72">_writeXml</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_ov_column_definition_343c8b7cbb45e9ad7aefbd97f7879ec3.html#343c8b7cbb45e9ad7aefbd97f7879ec3">~FdoShpOvColumnDefinition</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="58f92ba87a369a97428c7d937d569c72"></a><!-- doxytag: member="FdoShpOvColumnDefinition::_writeXml" ref="58f92ba87a369a97428c7d937d569c72" args="(FdoXmlWriter *xmlWriter, const FdoXmlFlags *flags)" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual FDOSHP_API void FdoShpOvColumnDefinition::_writeXml </td>
+ </tr>
+ <tr>
+ </tr>
+ <tr>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_column_definition_64d163015f3c021b5dc5fbe6105ff89a.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_column_definition_64d163015f3c021b5dc5fbe6105ff89a.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_column_definition_64d163015f3c021b5dc5fbe6105ff89a.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,111 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_ov_column_definition_64d163015f3c021b5dc5fbe6105ff89a.html#64d163015f3c021b5dc5fbe6105ff89a">XmlStartElement</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="64d163015f3c021b5dc5fbe6105ff89a"></a><!-- doxytag: member="FdoShpOvColumnDefinition::XmlStartElement" ref="64d163015f3c021b5dc5fbe6105ff89a" args="(FdoXmlSaxContext *context, FdoString *uri, FdoString *name, FdoString *qname, FdoXmlAttributeCollection *atts)" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual FDOSHP_API FdoXmlSaxHandler* FdoShpOvColumnDefinition::XmlStartElement </td>
+ </tr>
+ <tr>
+ </tr>
+ <tr>
+ </tr>
+ <tr>
+ </tr>
+ <tr>
+ </tr>
+ <tr>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_column_definition_71f1cbc25bd5085cd546450015067b08.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_column_definition_71f1cbc25bd5085cd546450015067b08.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_column_definition_71f1cbc25bd5085cd546450015067b08.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,83 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_ov_column_definition_71f1cbc25bd5085cd546450015067b08.html#71f1cbc25bd5085cd546450015067b08">Create</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="71f1cbc25bd5085cd546450015067b08"></a><!-- doxytag: member="FdoShpOvColumnDefinition::Create" ref="71f1cbc25bd5085cd546450015067b08" args="()" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">static FDOSHP_API <a class="el" href="class_fdo_shp_ov_column_definition.html">FdoShpOvColumnDefinition</a>* FdoShpOvColumnDefinition::Create </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_column_definition_90d84295b5cbbda30ca5e3d66a895cff.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_column_definition_90d84295b5cbbda30ca5e3d66a895cff.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_column_definition_90d84295b5cbbda30ca5e3d66a895cff.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,84 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_ov_column_definition_90d84295b5cbbda30ca5e3d66a895cff.html#90d84295b5cbbda30ca5e3d66a895cff">FdoShpOvColumnDefinition</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="90d84295b5cbbda30ca5e3d66a895cff"></a><!-- doxytag: member="FdoShpOvColumnDefinition::FdoShpOvColumnDefinition" ref="90d84295b5cbbda30ca5e3d66a895cff" args="(void)" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">FdoShpOvColumnDefinition::FdoShpOvColumnDefinition </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_column_definition_d8671acab0db72d517012189859cdafe.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_column_definition_d8671acab0db72d517012189859cdafe.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_column_definition_d8671acab0db72d517012189859cdafe.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,93 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+<table cellspacing="0" cellpadding="0" border="0">
+ <tr>
+ <td valign="top">
+ <div class="navtab">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_ov_column_definition_d8671acab0db72d517012189859cdafe.html#d8671acab0db72d517012189859cdafe">InitFromXml</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="d8671acab0db72d517012189859cdafe"></a><!-- doxytag: member="FdoShpOvColumnDefinition::InitFromXml" ref="d8671acab0db72d517012189859cdafe" args="(FdoXmlSaxContext *pContext, FdoXmlAttributeCollection *attrs)" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual FDOSHP_API void FdoShpOvColumnDefinition::InitFromXml </td>
+ </tr>
+ <tr>
+ </tr>
+ <tr>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_column_definition_eca75a56d812c8a7bd40dbc5bb303adc.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_column_definition_eca75a56d812c8a7bd40dbc5bb303adc.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_column_definition_eca75a56d812c8a7bd40dbc5bb303adc.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,84 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_ov_column_definition_eca75a56d812c8a7bd40dbc5bb303adc.html#eca75a56d812c8a7bd40dbc5bb303adc">Dispose</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="eca75a56d812c8a7bd40dbc5bb303adc"></a><!-- doxytag: member="FdoShpOvColumnDefinition::Dispose" ref="eca75a56d812c8a7bd40dbc5bb303adc" args="(void)" --><p>
+<table class="mdTable" cellpadding="2" cellspacing="0">
+ <tr>
+ <td class="mdRow">
+ <table cellpadding="0" cellspacing="0" border="0">
+ <tr>
+ <td class="md" nowrap valign="top">virtual void FdoShpOvColumnDefinition::Dispose </td>
+ <td class="md" valign="top">( </td>
+ <td class="mdname1" valign="top" nowrap> </td>
+ <td class="md" valign="top"> ) </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+<table cellspacing="5" cellpadding="0" border="0">
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_column_definition_fff19eb49dc45425fdb3ef7e1a8cc34f.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_column_definition_fff19eb49dc45425fdb3ef7e1a8cc34f.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_column_definition_fff19eb49dc45425fdb3ef7e1a8cc34f.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,105 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_ov_column_definition_fff19eb49dc45425fdb3ef7e1a8cc34f.html#fff19eb49dc45425fdb3ef7e1a8cc34f">XmlEndElement</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="fff19eb49dc45425fdb3ef7e1a8cc34f"></a><!-- doxytag: member="FdoShpOvColumnDefinition::XmlEndElement" ref="fff19eb49dc45425fdb3ef7e1a8cc34f" args="(FdoXmlSaxContext *context, FdoString *uri, FdoString *name, FdoString *qname)" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual FDOSHP_API FdoBoolean FdoShpOvColumnDefinition::XmlEndElement </td>
+ </tr>
+ <tr>
+ </tr>
+ <tr>
+ </tr>
+ <tr>
+ </tr>
+ <tr>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_physical_schema_mapping-members.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_physical_schema_mapping-members.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_physical_schema_mapping-members.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,54 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li id="current"><a href="classes.html"><span>Classes</span></a></li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li><a href="classes.html"><span>Alphabetical List</span></a></li>
+ <li><a href="annotated.html"><span>Class List</span></a></li>
+ <li><a href="hierarchy.html"><span>Class Hierarchy</span></a></li>
+ <li><a href="functions.html"><span>Class Members</span></a></li>
+ </ul></div>
+<h1>FdoShpOvPhysicalSchemaMapping Member List</h1>This is the complete list of members for <a class="el" href="class_fdo_shp_ov_physical_schema_mapping.html">FdoShpOvPhysicalSchemaMapping</a>, including all inherited members.<p><table>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_ov_physical_schema_mapping_414ac55477c612f4cc898cb949f7c349.html#414ac55477c612f4cc898cb949f7c349">_writeXml</a>(FdoXmlWriter *xmlWriter, const FdoXmlFlags *flags)</td><td><a class="el" href="class_fdo_shp_ov_physical_schema_mapping.html">FdoShpOvPhysicalSchemaMapping</a></td><td><code> [virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_ov_physical_schema_mapping_29a8cbc220b2489ec8894212e55e6a63.html#29a8cbc220b2489ec8894212e55e6a63">Create</a>()</td><td><a class="el" href="class_fdo_shp_ov_physical_schema_mapping.html">FdoShpOvPhysicalSchemaMapping</a></td><td><code> [static]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_ov_physical_schema_mapping_8ff550c78afad1e00544a0393a17fa7c.html#8ff550c78afad1e00544a0393a17fa7c">Dispose</a>(void)</td><td><a class="el" href="class_fdo_shp_ov_physical_schema_mapping.html">FdoShpOvPhysicalSchemaMapping</a></td><td><code> [protected, virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_ov_physical_schema_mapping_57b8da135b87b7df5b0400cc07536f44.html#57b8da135b87b7df5b0400cc07536f44">FdoShpOvPhysicalSchemaMapping</a>(void)</td><td><a class="el" href="class_fdo_shp_ov_physical_schema_mapping.html">FdoShpOvPhysicalSchemaMapping</a></td><td><code> [protected]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_ov_physical_schema_mapping_d89ecf4a8c025d05c75aa9412a37284f.html#d89ecf4a8c025d05c75aa9412a37284f">FindByClassName</a>(FdoString *class_name)</td><td><a class="el" href="class_fdo_shp_ov_physical_schema_mapping.html">FdoShpOvPhysicalSchemaMapping</a></td><td></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_ov_physical_schema_mapping_bc4cb63ab21fc31035d25cc8852a3046.html#bc4cb63ab21fc31035d25cc8852a3046">FindByShapefile</a>(FdoString *shapefilePath)</td><td><a class="el" href="class_fdo_shp_ov_physical_schema_mapping.html">FdoShpOvPhysicalSchemaMapping</a></td><td></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_ov_physical_schema_mapping_4f696de2a2bcba8d7f83892e3a3f2bbe.html#4f696de2a2bcba8d7f83892e3a3f2bbe">GetClasses</a>() const </td><td><a class="el" href="class_fdo_shp_ov_physical_schema_mapping.html">FdoShpOvPhysicalSchemaMapping</a></td><td></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_ov_physical_schema_mapping_e34e818940d63ab41db19c2e73a107d1.html#e34e818940d63ab41db19c2e73a107d1">GetProvider</a>()</td><td><a class="el" href="class_fdo_shp_ov_physical_schema_mapping.html">FdoShpOvPhysicalSchemaMapping</a></td><td><code> [virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_ov_physical_schema_mapping_323760df2b4697a81b70b1a4d494b401.html#323760df2b4697a81b70b1a4d494b401">InitFromXml</a>(FdoXmlSaxContext *pContext, FdoXmlAttributeCollection *attrs)</td><td><a class="el" href="class_fdo_shp_ov_physical_schema_mapping.html">FdoShpOvPhysicalSchemaMapping</a></td><td><code> [virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_ov_physical_schema_mapping_39b1326a353fa925aca33e51952f2e97.html#39b1326a353fa925aca33e51952f2e97">XmlEndElement</a>(FdoXmlSaxContext *context, FdoString *uri, FdoString *name, FdoString *qname)</td><td><a class="el" href="class_fdo_shp_ov_physical_schema_mapping.html">FdoShpOvPhysicalSchemaMapping</a></td><td><code> [virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_ov_physical_schema_mapping_a09f3b41a60fa1d6adf257252bbe5670.html#a09f3b41a60fa1d6adf257252bbe5670">XmlStartElement</a>(FdoXmlSaxContext *context, FdoString *uri, FdoString *name, FdoString *qname, FdoXmlAttributeCollection *atts)</td><td><a class="el" href="class_fdo_shp_ov_physical_schema_mapping.html">FdoShpOvPhysicalSchemaMapping</a></td><td><code> [virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_ov_physical_schema_mapping_aa23c8e7b0c5f94a2c5fe96d62bb96b0.html#aa23c8e7b0c5f94a2c5fe96d62bb96b0">~FdoShpOvPhysicalSchemaMapping</a>(void)</td><td><a class="el" href="class_fdo_shp_ov_physical_schema_mapping.html">FdoShpOvPhysicalSchemaMapping</a></td><td><code> [protected, virtual]</code></td></tr>
+</table><!-- footer.html -->
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_physical_schema_mapping.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_physical_schema_mapping.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_physical_schema_mapping.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,82 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>FdoShpOvPhysicalSchemaMapping Class Reference</h1><!-- doxytag: class="FdoShpOvPhysicalSchemaMapping" --><code>#include <<a class="el" href="_fdo_shp_physical_schema_mapping_8h-source.html">FdoShpPhysicalSchemaMapping.h</a>></code>
+<p>
+<a href="class_fdo_shp_ov_physical_schema_mapping-members.html">List of all members.</a><hr><a name="_details"></a><h2>Detailed Description</h2>
+<p>
+<p>
+Definition at line <a class="el" href="_fdo_shp_physical_schema_mapping_8h-source.html#l00026">26</a> of file <a class="el" href="_fdo_shp_physical_schema_mapping_8h-source.html">FdoShpPhysicalSchemaMapping.h</a>.<table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDOSHP_API void </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_ov_physical_schema_mapping_414ac55477c612f4cc898cb949f7c349.html#414ac55477c612f4cc898cb949f7c349">_writeXml</a> (FdoXmlWriter *xmlWriter, const FdoXmlFlags *flags)</td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">FDOSHP_API <a class="el" href="class_fdo_shp_ov_class_definition.html">FdoShpOvClassDefinition</a> * </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_ov_physical_schema_mapping_d89ecf4a8c025d05c75aa9412a37284f.html#d89ecf4a8c025d05c75aa9412a37284f">FindByClassName</a> (FdoString *class_name)</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Helper method to find a class mapping that maps to a given classname:. <a href="#d89ecf4a8c025d05c75aa9412a37284f"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">FDOSHP_API <a class="el" href="class_fdo_shp_ov_class_definition.html">FdoShpOvClassDefinition</a> * </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_ov_physical_schema_mapping_bc4cb63ab21fc31035d25cc8852a3046.html#bc4cb63ab21fc31035d25cc8852a3046">FindByShapefile</a> (FdoString *shapefilePath)</td></tr>
+<tr><td class="mdescLeft"> </td><td class="mdescRight">Helper method to find a class mapping that maps to a given shapefile:. <a href="#bc4cb63ab21fc31035d25cc8852a3046"></a><br></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">FDOSHP_API <a class="el" href="class_fdo_shp_ov_class_collection.html">FdoShpOvClassCollection</a> * </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_ov_physical_schema_mapping_4f696de2a2bcba8d7f83892e3a3f2bbe.html#4f696de2a2bcba8d7f83892e3a3f2bbe">GetClasses</a> () const </td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDOSHP_API FdoString * </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_ov_physical_schema_mapping_e34e818940d63ab41db19c2e73a107d1.html#e34e818940d63ab41db19c2e73a107d1">GetProvider</a> ()</td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDOSHP_API void </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_ov_physical_schema_mapping_323760df2b4697a81b70b1a4d494b401.html#323760df2b4697a81b70b1a4d494b401">InitFromXml</a> (FdoXmlSaxContext *pContext, FdoXmlAttributeCollection *attrs)</td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDOSHP_API FdoBoolean </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_ov_physical_schema_mapping_39b1326a353fa925aca33e51952f2e97.html#39b1326a353fa925aca33e51952f2e97">XmlEndElement</a> (FdoXmlSaxContext *context, FdoString *uri, FdoString *name, FdoString *qname)</td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDOSHP_API FdoXmlSaxHandler * </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_ov_physical_schema_mapping_a09f3b41a60fa1d6adf257252bbe5670.html#a09f3b41a60fa1d6adf257252bbe5670">XmlStartElement</a> (FdoXmlSaxContext *context, FdoString *uri, FdoString *name, FdoString *qname, FdoXmlAttributeCollection *atts)</td></tr>
+<tr><td colspan="2"><br><h2>Static Public Member Functions</h2></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">static FDOSHP_API <a class="el" href="class_fdo_shp_ov_physical_schema_mapping.html">FdoShpOvPhysicalSchemaMapping</a> * </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_ov_physical_schema_mapping_29a8cbc220b2489ec8894212e55e6a63.html#29a8cbc220b2489ec8894212e55e6a63">Create</a> ()</td></tr>
+<tr><td colspan="2"><br><h2>Protected Member Functions</h2></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual void </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_ov_physical_schema_mapping_8ff550c78afad1e00544a0393a17fa7c.html#8ff550c78afad1e00544a0393a17fa7c">Dispose</a> (void)</td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top"> </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_ov_physical_schema_mapping_57b8da135b87b7df5b0400cc07536f44.html#57b8da135b87b7df5b0400cc07536f44">FdoShpOvPhysicalSchemaMapping</a> (void)</td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_ov_physical_schema_mapping_aa23c8e7b0c5f94a2c5fe96d62bb96b0.html#aa23c8e7b0c5f94a2c5fe96d62bb96b0">~FdoShpOvPhysicalSchemaMapping</a> (void)</td></tr>
+</table>
+<hr>The documentation for this class was generated from the following file:<ul>
+<li><a class="el" href="_fdo_shp_physical_schema_mapping_8h-source.html">FdoShpPhysicalSchemaMapping.h</a></ul>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_physical_schema_mapping_29a8cbc220b2489ec8894212e55e6a63.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_physical_schema_mapping_29a8cbc220b2489ec8894212e55e6a63.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_physical_schema_mapping_29a8cbc220b2489ec8894212e55e6a63.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,87 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+<a class="el" href="class_fdo_shp_ov_physical_schema_mapping.html">FdoShpOvPhysicalSchemaMapping</a></div>
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_ov_physical_schema_mapping_414ac55477c612f4cc898cb949f7c349.html#414ac55477c612f4cc898cb949f7c349">_writeXml</a></td></tr>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_ov_physical_schema_mapping_29a8cbc220b2489ec8894212e55e6a63.html#29a8cbc220b2489ec8894212e55e6a63">Create</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_ov_physical_schema_mapping_8ff550c78afad1e00544a0393a17fa7c.html#8ff550c78afad1e00544a0393a17fa7c">Dispose</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_ov_physical_schema_mapping_57b8da135b87b7df5b0400cc07536f44.html#57b8da135b87b7df5b0400cc07536f44">FdoShpOvPhysicalSchemaMapping</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_ov_physical_schema_mapping_d89ecf4a8c025d05c75aa9412a37284f.html#d89ecf4a8c025d05c75aa9412a37284f">FindByClassName</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_ov_physical_schema_mapping_bc4cb63ab21fc31035d25cc8852a3046.html#bc4cb63ab21fc31035d25cc8852a3046">FindByShapefile</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_ov_physical_schema_mapping_4f696de2a2bcba8d7f83892e3a3f2bbe.html#4f696de2a2bcba8d7f83892e3a3f2bbe">GetClasses</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_ov_physical_schema_mapping_e34e818940d63ab41db19c2e73a107d1.html#e34e818940d63ab41db19c2e73a107d1">GetProvider</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_ov_physical_schema_mapping_323760df2b4697a81b70b1a4d494b401.html#323760df2b4697a81b70b1a4d494b401">InitFromXml</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_ov_physical_schema_mapping_39b1326a353fa925aca33e51952f2e97.html#39b1326a353fa925aca33e51952f2e97">XmlEndElement</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_ov_physical_schema_mapping_a09f3b41a60fa1d6adf257252bbe5670.html#a09f3b41a60fa1d6adf257252bbe5670">XmlStartElement</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_ov_physical_schema_mapping_aa23c8e7b0c5f94a2c5fe96d62bb96b0.html#aa23c8e7b0c5f94a2c5fe96d62bb96b0">~FdoShpOvPhysicalSchemaMapping</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="29a8cbc220b2489ec8894212e55e6a63"></a><!-- doxytag: member="FdoShpOvPhysicalSchemaMapping::Create" ref="29a8cbc220b2489ec8894212e55e6a63" args="()" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">static FDOSHP_API <a class="el" href="class_fdo_shp_ov_physical_schema_mapping.html">FdoShpOvPhysicalSchemaMapping</a>* FdoShpOvPhysicalSchemaMapping::Create </td>
+ <td class="md" nowrap><code> [static]</code></td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_physical_schema_mapping_323760df2b4697a81b70b1a4d494b401.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_physical_schema_mapping_323760df2b4697a81b70b1a4d494b401.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_physical_schema_mapping_323760df2b4697a81b70b1a4d494b401.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,97 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_ov_physical_schema_mapping_29a8cbc220b2489ec8894212e55e6a63.html#29a8cbc220b2489ec8894212e55e6a63">Create</a></td></tr>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_ov_physical_schema_mapping_323760df2b4697a81b70b1a4d494b401.html#323760df2b4697a81b70b1a4d494b401">InitFromXml</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="323760df2b4697a81b70b1a4d494b401"></a><!-- doxytag: member="FdoShpOvPhysicalSchemaMapping::InitFromXml" ref="323760df2b4697a81b70b1a4d494b401" args="(FdoXmlSaxContext *pContext, FdoXmlAttributeCollection *attrs)" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual FDOSHP_API void FdoShpOvPhysicalSchemaMapping::InitFromXml </td>
+ </tr>
+ <tr>
+ </tr>
+ <tr>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_physical_schema_mapping_39b1326a353fa925aca33e51952f2e97.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_physical_schema_mapping_39b1326a353fa925aca33e51952f2e97.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_physical_schema_mapping_39b1326a353fa925aca33e51952f2e97.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,109 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_ov_physical_schema_mapping_39b1326a353fa925aca33e51952f2e97.html#39b1326a353fa925aca33e51952f2e97">XmlEndElement</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="39b1326a353fa925aca33e51952f2e97"></a><!-- doxytag: member="FdoShpOvPhysicalSchemaMapping::XmlEndElement" ref="39b1326a353fa925aca33e51952f2e97" args="(FdoXmlSaxContext *context, FdoString *uri, FdoString *name, FdoString *qname)" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual FDOSHP_API FdoBoolean FdoShpOvPhysicalSchemaMapping::XmlEndElement </td>
+ </tr>
+ <tr>
+ </tr>
+ <tr>
+ </tr>
+ <tr>
+ </tr>
+ <tr>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_physical_schema_mapping_414ac55477c612f4cc898cb949f7c349.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_physical_schema_mapping_414ac55477c612f4cc898cb949f7c349.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_physical_schema_mapping_414ac55477c612f4cc898cb949f7c349.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,97 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_ov_physical_schema_mapping_414ac55477c612f4cc898cb949f7c349.html#414ac55477c612f4cc898cb949f7c349">_writeXml</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="414ac55477c612f4cc898cb949f7c349"></a><!-- doxytag: member="FdoShpOvPhysicalSchemaMapping::_writeXml" ref="414ac55477c612f4cc898cb949f7c349" args="(FdoXmlWriter *xmlWriter, const FdoXmlFlags *flags)" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual FDOSHP_API void FdoShpOvPhysicalSchemaMapping::_writeXml </td>
+ </tr>
+ <tr>
+ <td class="md" nowrap align="right"></td>
+ <td class="md"></td>
+ </tr>
+ <tr>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_physical_schema_mapping_4f696de2a2bcba8d7f83892e3a3f2bbe.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_physical_schema_mapping_4f696de2a2bcba8d7f83892e3a3f2bbe.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_physical_schema_mapping_4f696de2a2bcba8d7f83892e3a3f2bbe.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,87 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_ov_physical_schema_mapping_4f696de2a2bcba8d7f83892e3a3f2bbe.html#4f696de2a2bcba8d7f83892e3a3f2bbe">GetClasses</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="4f696de2a2bcba8d7f83892e3a3f2bbe"></a><!-- doxytag: member="FdoShpOvPhysicalSchemaMapping::GetClasses" ref="4f696de2a2bcba8d7f83892e3a3f2bbe" args="() const " --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">FDOSHP_API <a class="el" href="class_fdo_shp_ov_class_collection.html">FdoShpOvClassCollection</a>* FdoShpOvPhysicalSchemaMapping::GetClasses </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_physical_schema_mapping_57b8da135b87b7df5b0400cc07536f44.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_physical_schema_mapping_57b8da135b87b7df5b0400cc07536f44.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_physical_schema_mapping_57b8da135b87b7df5b0400cc07536f44.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,88 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_ov_physical_schema_mapping_57b8da135b87b7df5b0400cc07536f44.html#57b8da135b87b7df5b0400cc07536f44">FdoShpOvPhysicalSchemaMapping</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="57b8da135b87b7df5b0400cc07536f44"></a><!-- doxytag: member="FdoShpOvPhysicalSchemaMapping::FdoShpOvPhysicalSchemaMapping" ref="57b8da135b87b7df5b0400cc07536f44" args="(void)" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">FdoShpOvPhysicalSchemaMapping::FdoShpOvPhysicalSchemaMapping </td>
+ <td class="md" nowrap valign="top">void </td>
+ <td class="md" nowrap><code> [protected]</code></td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_physical_schema_mapping_8ff550c78afad1e00544a0393a17fa7c.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_physical_schema_mapping_8ff550c78afad1e00544a0393a17fa7c.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_physical_schema_mapping_8ff550c78afad1e00544a0393a17fa7c.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,88 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_ov_physical_schema_mapping_8ff550c78afad1e00544a0393a17fa7c.html#8ff550c78afad1e00544a0393a17fa7c">Dispose</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="8ff550c78afad1e00544a0393a17fa7c"></a><!-- doxytag: member="FdoShpOvPhysicalSchemaMapping::Dispose" ref="8ff550c78afad1e00544a0393a17fa7c" args="(void)" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual void FdoShpOvPhysicalSchemaMapping::Dispose </td>
+ <td class="md" nowrap><code> [protected, virtual]</code></td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_physical_schema_mapping_a09f3b41a60fa1d6adf257252bbe5670.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_physical_schema_mapping_a09f3b41a60fa1d6adf257252bbe5670.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_physical_schema_mapping_a09f3b41a60fa1d6adf257252bbe5670.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,115 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_ov_physical_schema_mapping_a09f3b41a60fa1d6adf257252bbe5670.html#a09f3b41a60fa1d6adf257252bbe5670">XmlStartElement</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="a09f3b41a60fa1d6adf257252bbe5670"></a><!-- doxytag: member="FdoShpOvPhysicalSchemaMapping::XmlStartElement" ref="a09f3b41a60fa1d6adf257252bbe5670" args="(FdoXmlSaxContext *context, FdoString *uri, FdoString *name, FdoString *qname, FdoXmlAttributeCollection *atts)" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual FDOSHP_API FdoXmlSaxHandler* FdoShpOvPhysicalSchemaMapping::XmlStartElement </td>
+ <td class="md" nowrap valign="top">FdoXmlSaxContext * </td>
+ </tr>
+ <tr>
+ </tr>
+ <tr>
+ </tr>
+ <tr>
+ </tr>
+ <tr>
+ <td class="md" nowrap>FdoXmlAttributeCollection * </td>
+ </tr>
+ <tr>
+ <td class="md">) </td>
+ <td class="md" colspan="2"><code> [virtual]</code></td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_physical_schema_mapping_aa23c8e7b0c5f94a2c5fe96d62bb96b0.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_physical_schema_mapping_aa23c8e7b0c5f94a2c5fe96d62bb96b0.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_physical_schema_mapping_aa23c8e7b0c5f94a2c5fe96d62bb96b0.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,88 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_ov_physical_schema_mapping_aa23c8e7b0c5f94a2c5fe96d62bb96b0.html#aa23c8e7b0c5f94a2c5fe96d62bb96b0">~FdoShpOvPhysicalSchemaMapping</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="aa23c8e7b0c5f94a2c5fe96d62bb96b0"></a><!-- doxytag: member="FdoShpOvPhysicalSchemaMapping::~FdoShpOvPhysicalSchemaMapping" ref="aa23c8e7b0c5f94a2c5fe96d62bb96b0" args="(void)" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual FdoShpOvPhysicalSchemaMapping::~FdoShpOvPhysicalSchemaMapping </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_physical_schema_mapping_bc4cb63ab21fc31035d25cc8852a3046.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_physical_schema_mapping_bc4cb63ab21fc31035d25cc8852a3046.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_physical_schema_mapping_bc4cb63ab21fc31035d25cc8852a3046.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,90 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_ov_physical_schema_mapping_bc4cb63ab21fc31035d25cc8852a3046.html#bc4cb63ab21fc31035d25cc8852a3046">FindByShapefile</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="bc4cb63ab21fc31035d25cc8852a3046"></a><!-- doxytag: member="FdoShpOvPhysicalSchemaMapping::FindByShapefile" ref="bc4cb63ab21fc31035d25cc8852a3046" args="(FdoString *shapefilePath)" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">FDOSHP_API <a class="el" href="class_fdo_shp_ov_class_definition.html">FdoShpOvClassDefinition</a>* FdoShpOvPhysicalSchemaMapping::FindByShapefile </td>
+ <td class="md" nowrap valign="top">FdoString * </td>
+ <td class="mdname1" valign="top" nowrap> <em>shapefilePath</em> </td>
+ <td class="md" nowrap></td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Helper method to find a class mapping that maps to a given shapefile:.
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_physical_schema_mapping_d89ecf4a8c025d05c75aa9412a37284f.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_physical_schema_mapping_d89ecf4a8c025d05c75aa9412a37284f.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_physical_schema_mapping_d89ecf4a8c025d05c75aa9412a37284f.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,90 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_ov_physical_schema_mapping_d89ecf4a8c025d05c75aa9412a37284f.html#d89ecf4a8c025d05c75aa9412a37284f">FindByClassName</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="d89ecf4a8c025d05c75aa9412a37284f"></a><!-- doxytag: member="FdoShpOvPhysicalSchemaMapping::FindByClassName" ref="d89ecf4a8c025d05c75aa9412a37284f" args="(FdoString *class_name)" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">FDOSHP_API <a class="el" href="class_fdo_shp_ov_class_definition.html">FdoShpOvClassDefinition</a>* FdoShpOvPhysicalSchemaMapping::FindByClassName </td>
+ <td class="mdname1" valign="top" nowrap> <em>class_name</em> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+Helper method to find a class mapping that maps to a given classname:.
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_physical_schema_mapping_e34e818940d63ab41db19c2e73a107d1.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_physical_schema_mapping_e34e818940d63ab41db19c2e73a107d1.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_physical_schema_mapping_e34e818940d63ab41db19c2e73a107d1.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,87 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_ov_physical_schema_mapping_e34e818940d63ab41db19c2e73a107d1.html#e34e818940d63ab41db19c2e73a107d1">GetProvider</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="e34e818940d63ab41db19c2e73a107d1"></a><!-- doxytag: member="FdoShpOvPhysicalSchemaMapping::GetProvider" ref="e34e818940d63ab41db19c2e73a107d1" args="()" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual FDOSHP_API FdoString* FdoShpOvPhysicalSchemaMapping::GetProvider </td>
+ <td class="md" nowrap><code> [virtual]</code></td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_property_definition-members.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_property_definition-members.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_property_definition-members.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,52 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>FdoShpOvPropertyDefinition Member List</h1>This is the complete list of members for <a class="el" href="class_fdo_shp_ov_property_definition.html">FdoShpOvPropertyDefinition</a>, including all inherited members.<p><table>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_ov_property_definition_7eededaf3297b36ddd9445f6fcf67a01.html#7eededaf3297b36ddd9445f6fcf67a01">_writeXml</a>(FdoXmlWriter *xmlWriter, const FdoXmlFlags *flags)</td><td><a class="el" href="class_fdo_shp_ov_property_definition.html">FdoShpOvPropertyDefinition</a></td><td><code> [virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_ov_property_definition_7ea7dfeeb0bf291c7a8049415300c66f.html#7ea7dfeeb0bf291c7a8049415300c66f">Create</a>()</td><td><a class="el" href="class_fdo_shp_ov_property_definition.html">FdoShpOvPropertyDefinition</a></td><td><code> [static]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_ov_property_definition_944e21212809bf59f3c838980f77bcde.html#944e21212809bf59f3c838980f77bcde">Dispose</a>(void)</td><td><a class="el" href="class_fdo_shp_ov_property_definition.html">FdoShpOvPropertyDefinition</a></td><td><code> [protected, virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_ov_property_definition_28f724d715783bd56d4ee112b182d6d6.html#28f724d715783bd56d4ee112b182d6d6">FdoShpOvPropertyDefinition</a>(void)</td><td><a class="el" href="class_fdo_shp_ov_property_definition.html">FdoShpOvPropertyDefinition</a></td><td><code> [protected]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_ov_property_definition_4be129d8f231d3c80f4b5d8f67d55b3d.html#4be129d8f231d3c80f4b5d8f67d55b3d">GetColumn</a>() const </td><td><a class="el" href="class_fdo_shp_ov_property_definition.html">FdoShpOvPropertyDefinition</a></td><td></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_ov_property_definition_c41a3a6e4a1d09b8f9174dce7c6f6b25.html#c41a3a6e4a1d09b8f9174dce7c6f6b25">InitFromXml</a>(FdoXmlSaxContext *pContext, FdoXmlAttributeCollection *attrs)</td><td><a class="el" href="class_fdo_shp_ov_property_definition.html">FdoShpOvPropertyDefinition</a></td><td><code> [virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_ov_property_definition_b2e5583363bffe8483b92ca1dae3a6c7.html#b2e5583363bffe8483b92ca1dae3a6c7">SetColumn</a>(FdoShpOvColumnDefinition *definition)</td><td><a class="el" href="class_fdo_shp_ov_property_definition.html">FdoShpOvPropertyDefinition</a></td><td></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_ov_property_definition_3247a059e0eb2c1f60c516e81739058e.html#3247a059e0eb2c1f60c516e81739058e">XmlEndElement</a>(FdoXmlSaxContext *context, FdoString *uri, FdoString *name, FdoString *qname)</td><td><a class="el" href="class_fdo_shp_ov_property_definition.html">FdoShpOvPropertyDefinition</a></td><td><code> [virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_ov_property_definition_31b64b4fe2e08635300ddac43e8cca96.html#31b64b4fe2e08635300ddac43e8cca96">XmlStartElement</a>(FdoXmlSaxContext *context, FdoString *uri, FdoString *name, FdoString *qname, FdoXmlAttributeCollection *atts)</td><td><a class="el" href="class_fdo_shp_ov_property_definition.html">FdoShpOvPropertyDefinition</a></td><td><code> [virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_ov_property_definition_0b52161945add0910480f452d9ac2bc0.html#0b52161945add0910480f452d9ac2bc0">~FdoShpOvPropertyDefinition</a>(void)</td><td><a class="el" href="class_fdo_shp_ov_property_definition.html">FdoShpOvPropertyDefinition</a></td><td><code> [protected, virtual]</code></td></tr>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_property_definition.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_property_definition.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_property_definition.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,76 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>FdoShpOvPropertyDefinition Class Reference</h1><!-- doxytag: class="FdoShpOvPropertyDefinition" --><code>#include <<a class="el" href="_fdo_shp_property_definition_8h-source.html">FdoShpPropertyDefinition.h</a>></code>
+<p>
+<a href="class_fdo_shp_ov_property_definition-members.html">List of all members.</a><hr><a name="_details"></a><h2>Detailed Description</h2>
+<p>
+<p>
+Definition at line <a class="el" href="_fdo_shp_property_definition_8h-source.html#l00026">26</a> of file <a class="el" href="_fdo_shp_property_definition_8h-source.html">FdoShpPropertyDefinition.h</a>.<table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td colspan="2"><br><h2>Public Member Functions</h2></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDOSHP_API void </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_ov_property_definition_7eededaf3297b36ddd9445f6fcf67a01.html#7eededaf3297b36ddd9445f6fcf67a01">_writeXml</a> (FdoXmlWriter *xmlWriter, const FdoXmlFlags *flags)</td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">FDOSHP_API <a class="el" href="class_fdo_shp_ov_column_definition.html">FdoShpOvColumnDefinition</a> * </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_ov_property_definition_4be129d8f231d3c80f4b5d8f67d55b3d.html#4be129d8f231d3c80f4b5d8f67d55b3d">GetColumn</a> () const </td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDOSHP_API void </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_ov_property_definition_c41a3a6e4a1d09b8f9174dce7c6f6b25.html#c41a3a6e4a1d09b8f9174dce7c6f6b25">InitFromXml</a> (FdoXmlSaxContext *pContext, FdoXmlAttributeCollection *attrs)</td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">FDOSHP_API void </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_ov_property_definition_b2e5583363bffe8483b92ca1dae3a6c7.html#b2e5583363bffe8483b92ca1dae3a6c7">SetColumn</a> (<a class="el" href="class_fdo_shp_ov_column_definition.html">FdoShpOvColumnDefinition</a> *definition)</td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDOSHP_API FdoBoolean </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_ov_property_definition_3247a059e0eb2c1f60c516e81739058e.html#3247a059e0eb2c1f60c516e81739058e">XmlEndElement</a> (FdoXmlSaxContext *context, FdoString *uri, FdoString *name, FdoString *qname)</td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual FDOSHP_API FdoXmlSaxHandler * </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_ov_property_definition_31b64b4fe2e08635300ddac43e8cca96.html#31b64b4fe2e08635300ddac43e8cca96">XmlStartElement</a> (FdoXmlSaxContext *context, FdoString *uri, FdoString *name, FdoString *qname, FdoXmlAttributeCollection *atts)</td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">static FDOSHP_API <a class="el" href="class_fdo_shp_ov_property_definition.html">FdoShpOvPropertyDefinition</a> * </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_ov_property_definition_7ea7dfeeb0bf291c7a8049415300c66f.html#7ea7dfeeb0bf291c7a8049415300c66f">Create</a> ()</td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual void </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_ov_property_definition_944e21212809bf59f3c838980f77bcde.html#944e21212809bf59f3c838980f77bcde">Dispose</a> (void)</td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top"> </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_ov_property_definition_28f724d715783bd56d4ee112b182d6d6.html#28f724d715783bd56d4ee112b182d6d6">FdoShpOvPropertyDefinition</a> (void)</td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_ov_property_definition_0b52161945add0910480f452d9ac2bc0.html#0b52161945add0910480f452d9ac2bc0">~FdoShpOvPropertyDefinition</a> (void)</td></tr>
+</table>
+<li><a class="el" href="_fdo_shp_property_definition_8h-source.html">FdoShpPropertyDefinition.h</a></ul>
+ <hr>
+ <table width="100%" border="0">
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_0b52161945add0910480f452d9ac2bc0.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_0b52161945add0910480f452d9ac2bc0.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_0b52161945add0910480f452d9ac2bc0.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,86 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
+<html>
+ <head>
+ <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
+ <title>OSGeo FDO Provider for SHP API Reference</title>
+ <link href="custom.css" rel="stylesheet" type="text/css">
+ <link href="tabs.css" rel="stylesheet" type="text/css">
+ </head>
+ <body bgcolor="#FFFFFF">
+ <tr>
+ <td><b>API Reference<b></td>
+ <td align="right"><b>OSGeo FDO Provider for SHP<b></td>
+ </tr>
+ </table>
+<!-- End of: header.html -->
+<!-- Generated by Doxygen 1.4.6-NO -->
+<div class="tabs">
+ <ul>
+ <li><a href="main.html"><span>Main Page</span></a></li>
+ </ul></div>
+<div class="nav">
+<a class="el" href="class_fdo_shp_ov_property_definition.html">FdoShpOvPropertyDefinition</a></div>
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_ov_property_definition_7eededaf3297b36ddd9445f6fcf67a01.html#7eededaf3297b36ddd9445f6fcf67a01">_writeXml</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_ov_property_definition_7ea7dfeeb0bf291c7a8049415300c66f.html#7ea7dfeeb0bf291c7a8049415300c66f">Create</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_ov_property_definition_944e21212809bf59f3c838980f77bcde.html#944e21212809bf59f3c838980f77bcde">Dispose</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_ov_property_definition_28f724d715783bd56d4ee112b182d6d6.html#28f724d715783bd56d4ee112b182d6d6">FdoShpOvPropertyDefinition</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_ov_property_definition_4be129d8f231d3c80f4b5d8f67d55b3d.html#4be129d8f231d3c80f4b5d8f67d55b3d">GetColumn</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_ov_property_definition_c41a3a6e4a1d09b8f9174dce7c6f6b25.html#c41a3a6e4a1d09b8f9174dce7c6f6b25">InitFromXml</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_ov_property_definition_b2e5583363bffe8483b92ca1dae3a6c7.html#b2e5583363bffe8483b92ca1dae3a6c7">SetColumn</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_ov_property_definition_3247a059e0eb2c1f60c516e81739058e.html#3247a059e0eb2c1f60c516e81739058e">XmlEndElement</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_ov_property_definition_31b64b4fe2e08635300ddac43e8cca96.html#31b64b4fe2e08635300ddac43e8cca96">XmlStartElement</a></td></tr>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_ov_property_definition_0b52161945add0910480f452d9ac2bc0.html#0b52161945add0910480f452d9ac2bc0">~FdoShpOvPropertyDefinition</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="0b52161945add0910480f452d9ac2bc0"></a><!-- doxytag: member="FdoShpOvPropertyDefinition::~FdoShpOvPropertyDefinition" ref="0b52161945add0910480f452d9ac2bc0" args="(void)" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual FdoShpOvPropertyDefinition::~FdoShpOvPropertyDefinition </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_28f724d715783bd56d4ee112b182d6d6.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_28f724d715783bd56d4ee112b182d6d6.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_28f724d715783bd56d4ee112b182d6d6.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,86 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_ov_property_definition_28f724d715783bd56d4ee112b182d6d6.html#28f724d715783bd56d4ee112b182d6d6">FdoShpOvPropertyDefinition</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_ov_property_definition_0b52161945add0910480f452d9ac2bc0.html#0b52161945add0910480f452d9ac2bc0">~FdoShpOvPropertyDefinition</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="28f724d715783bd56d4ee112b182d6d6"></a><!-- doxytag: member="FdoShpOvPropertyDefinition::FdoShpOvPropertyDefinition" ref="28f724d715783bd56d4ee112b182d6d6" args="(void)" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">FdoShpOvPropertyDefinition::FdoShpOvPropertyDefinition </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_31b64b4fe2e08635300ddac43e8cca96.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_31b64b4fe2e08635300ddac43e8cca96.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_31b64b4fe2e08635300ddac43e8cca96.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,113 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_ov_property_definition_31b64b4fe2e08635300ddac43e8cca96.html#31b64b4fe2e08635300ddac43e8cca96">XmlStartElement</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="31b64b4fe2e08635300ddac43e8cca96"></a><!-- doxytag: member="FdoShpOvPropertyDefinition::XmlStartElement" ref="31b64b4fe2e08635300ddac43e8cca96" args="(FdoXmlSaxContext *context, FdoString *uri, FdoString *name, FdoString *qname, FdoXmlAttributeCollection *atts)" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual FDOSHP_API FdoXmlSaxHandler* FdoShpOvPropertyDefinition::XmlStartElement </td>
+ <td class="mdname" nowrap> <em>context</em>, </td>
+ </tr>
+ <tr>
+ <td class="md" nowrap>FdoString * </td>
+ <td class="mdname" nowrap> <em>uri</em>, </td>
+ </tr>
+ <tr>
+ <td class="mdname" nowrap> <em>name</em>, </td>
+ </tr>
+ <tr>
+ <td class="mdname" nowrap> <em>qname</em>, </td>
+ </tr>
+ <tr>
+ <td class="mdname" nowrap> <em>atts</em></td>
+ </tr>
+ <tr>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+<!-- footer.html -->
+ <hr>
+ <tr>
+ <td align="right"><font size="-2"><a href="mailto:isd.docs at autodesk.com&subject=FDO%20Provider%20for%20SHP%20API%20documentation">Comments?</a></font></td>
+ <!-- The logo can go in another cell, when we get one -->
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_3247a059e0eb2c1f60c516e81739058e.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_3247a059e0eb2c1f60c516e81739058e.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_3247a059e0eb2c1f60c516e81739058e.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,107 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li><a href="classes.html"><span>Classes</span></a></li>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_ov_property_definition_3247a059e0eb2c1f60c516e81739058e.html#3247a059e0eb2c1f60c516e81739058e">XmlEndElement</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="3247a059e0eb2c1f60c516e81739058e"></a><!-- doxytag: member="FdoShpOvPropertyDefinition::XmlEndElement" ref="3247a059e0eb2c1f60c516e81739058e" args="(FdoXmlSaxContext *context, FdoString *uri, FdoString *name, FdoString *qname)" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual FDOSHP_API FdoBoolean FdoShpOvPropertyDefinition::XmlEndElement </td>
+ </tr>
+ <tr>
+ </tr>
+ <tr>
+ </tr>
+ <tr>
+ <td class="mdname" nowrap> <em>qname</em></td>
+ </tr>
+ <tr>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_4be129d8f231d3c80f4b5d8f67d55b3d.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_4be129d8f231d3c80f4b5d8f67d55b3d.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_4be129d8f231d3c80f4b5d8f67d55b3d.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,85 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_ov_property_definition_4be129d8f231d3c80f4b5d8f67d55b3d.html#4be129d8f231d3c80f4b5d8f67d55b3d">GetColumn</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="4be129d8f231d3c80f4b5d8f67d55b3d"></a><!-- doxytag: member="FdoShpOvPropertyDefinition::GetColumn" ref="4be129d8f231d3c80f4b5d8f67d55b3d" args="() const " --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">FDOSHP_API <a class="el" href="class_fdo_shp_ov_column_definition.html">FdoShpOvColumnDefinition</a>* FdoShpOvPropertyDefinition::GetColumn </td>
+ <td class="md" nowrap> const</td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_7ea7dfeeb0bf291c7a8049415300c66f.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_7ea7dfeeb0bf291c7a8049415300c66f.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_7ea7dfeeb0bf291c7a8049415300c66f.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,85 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li><a href="files.html"><span>Files</span></a></li>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_ov_property_definition_7ea7dfeeb0bf291c7a8049415300c66f.html#7ea7dfeeb0bf291c7a8049415300c66f">Create</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="7ea7dfeeb0bf291c7a8049415300c66f"></a><!-- doxytag: member="FdoShpOvPropertyDefinition::Create" ref="7ea7dfeeb0bf291c7a8049415300c66f" args="()" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">static FDOSHP_API <a class="el" href="class_fdo_shp_ov_property_definition.html">FdoShpOvPropertyDefinition</a>* FdoShpOvPropertyDefinition::Create </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_7eededaf3297b36ddd9445f6fcf67a01.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_7eededaf3297b36ddd9445f6fcf67a01.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_7eededaf3297b36ddd9445f6fcf67a01.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,95 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_ov_property_definition_7eededaf3297b36ddd9445f6fcf67a01.html#7eededaf3297b36ddd9445f6fcf67a01">_writeXml</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="7eededaf3297b36ddd9445f6fcf67a01"></a><!-- doxytag: member="FdoShpOvPropertyDefinition::_writeXml" ref="7eededaf3297b36ddd9445f6fcf67a01" args="(FdoXmlWriter *xmlWriter, const FdoXmlFlags *flags)" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual FDOSHP_API void FdoShpOvPropertyDefinition::_writeXml </td>
+ <td class="md" nowrap valign="top">FdoXmlWriter * </td>
+ <td class="mdname" nowrap> <em>xmlWriter</em>, </td>
+ </tr>
+ <tr>
+ <td class="md" nowrap>const FdoXmlFlags * </td>
+ <td class="mdname" nowrap> <em>flags</em></td>
+ </tr>
+ <tr>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_944e21212809bf59f3c838980f77bcde.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_944e21212809bf59f3c838980f77bcde.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_944e21212809bf59f3c838980f77bcde.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,86 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_ov_property_definition_944e21212809bf59f3c838980f77bcde.html#944e21212809bf59f3c838980f77bcde">Dispose</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="944e21212809bf59f3c838980f77bcde"></a><!-- doxytag: member="FdoShpOvPropertyDefinition::Dispose" ref="944e21212809bf59f3c838980f77bcde" args="(void)" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual void FdoShpOvPropertyDefinition::Dispose </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_b2e5583363bffe8483b92ca1dae3a6c7.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_b2e5583363bffe8483b92ca1dae3a6c7.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_b2e5583363bffe8483b92ca1dae3a6c7.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,86 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_ov_property_definition_b2e5583363bffe8483b92ca1dae3a6c7.html#b2e5583363bffe8483b92ca1dae3a6c7">SetColumn</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="b2e5583363bffe8483b92ca1dae3a6c7"></a><!-- doxytag: member="FdoShpOvPropertyDefinition::SetColumn" ref="b2e5583363bffe8483b92ca1dae3a6c7" args="(FdoShpOvColumnDefinition *definition)" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">FDOSHP_API void FdoShpOvPropertyDefinition::SetColumn </td>
+ <td class="md" nowrap valign="top"><a class="el" href="class_fdo_shp_ov_column_definition.html">FdoShpOvColumnDefinition</a> * </td>
+ <td class="mdname1" valign="top" nowrap> <em>definition</em> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_c41a3a6e4a1d09b8f9174dce7c6f6b25.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_c41a3a6e4a1d09b8f9174dce7c6f6b25.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_c41a3a6e4a1d09b8f9174dce7c6f6b25.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,95 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+<table cellspacing="0" cellpadding="0" border="0">
+ <tr>
+ <td valign="top">
+ <div class="navtab">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_ov_property_definition_c41a3a6e4a1d09b8f9174dce7c6f6b25.html#c41a3a6e4a1d09b8f9174dce7c6f6b25">InitFromXml</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="c41a3a6e4a1d09b8f9174dce7c6f6b25"></a><!-- doxytag: member="FdoShpOvPropertyDefinition::InitFromXml" ref="c41a3a6e4a1d09b8f9174dce7c6f6b25" args="(FdoXmlSaxContext *pContext, FdoXmlAttributeCollection *attrs)" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual FDOSHP_API void FdoShpOvPropertyDefinition::InitFromXml </td>
+ <td class="mdname" nowrap> <em>pContext</em>, </td>
+ </tr>
+ <tr>
+ <td class="mdname" nowrap> <em>attrs</em></td>
+ </tr>
+ <tr>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_collection-members.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_collection-members.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_collection-members.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,48 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>FdoShpOvPropertyDefinitionCollection Member List</h1>This is the complete list of members for <a class="el" href="class_fdo_shp_ov_property_definition_collection.html">FdoShpOvPropertyDefinitionCollection</a>, including all inherited members.<p><table>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_ov_property_definition_collection_bd6b681557f031ced9d12cb5905ce3e8.html#bd6b681557f031ced9d12cb5905ce3e8">Create</a>()</td><td><a class="el" href="class_fdo_shp_ov_property_definition_collection.html">FdoShpOvPropertyDefinitionCollection</a></td><td><code> [static]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_ov_property_definition_collection_c242cc50d3484173bd53f93d49b748cd.html#c242cc50d3484173bd53f93d49b748cd">Create</a>(FdoPhysicalElementMapping *parent)</td><td><a class="el" href="class_fdo_shp_ov_property_definition_collection.html">FdoShpOvPropertyDefinitionCollection</a></td><td><code> [static]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_ov_property_definition_collection_1c61c73f46f6077d623451c5b73c66cd.html#1c61c73f46f6077d623451c5b73c66cd">Dispose</a>()</td><td><a class="el" href="class_fdo_shp_ov_property_definition_collection.html">FdoShpOvPropertyDefinitionCollection</a></td><td><code> [protected, virtual]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_ov_property_definition_collection_9dcd52a0dfe26c64474d8b0688437ab2.html#9dcd52a0dfe26c64474d8b0688437ab2">FdoShpOvPropertyDefinitionCollection</a>()</td><td><a class="el" href="class_fdo_shp_ov_property_definition_collection.html">FdoShpOvPropertyDefinitionCollection</a></td><td><code> [protected]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_ov_property_definition_collection_6e8f77facd3026d3207b96bfd7e558e0.html#6e8f77facd3026d3207b96bfd7e558e0">FdoShpOvPropertyDefinitionCollection</a>(FdoPhysicalElementMapping *parent)</td><td><a class="el" href="class_fdo_shp_ov_property_definition_collection.html">FdoShpOvPropertyDefinitionCollection</a></td><td><code> [protected]</code></td></tr>
+ <tr class="memlist"><td><a class="el" href="class_fdo_shp_ov_property_definition_collection_d3eed0522918ece73f92aa1340718aeb.html#d3eed0522918ece73f92aa1340718aeb">~FdoShpOvPropertyDefinitionCollection</a>(void)</td><td><a class="el" href="class_fdo_shp_ov_property_definition_collection.html">FdoShpOvPropertyDefinitionCollection</a></td><td><code> [protected, virtual]</code></td></tr>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_collection.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_collection.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_collection.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,67 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li id="current"><a href="classes.html"><span>Classes</span></a></li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li><a href="classes.html"><span>Alphabetical List</span></a></li>
+ <li><a href="annotated.html"><span>Class List</span></a></li>
+ <li><a href="hierarchy.html"><span>Class Hierarchy</span></a></li>
+ <li><a href="functions.html"><span>Class Members</span></a></li>
+ </ul></div>
+<h1>FdoShpOvPropertyDefinitionCollection Class Reference</h1><!-- doxytag: class="FdoShpOvPropertyDefinitionCollection" --><code>#include <<a class="el" href="_fdo_shp_property_definition_collection_8h-source.html">FdoShpPropertyDefinitionCollection.h</a>></code>
+<p>
+<a href="class_fdo_shp_ov_property_definition_collection-members.html">List of all members.</a><hr><a name="_details"></a><h2>Detailed Description</h2>
+<p>
+<p>
+Definition at line <a class="el" href="_fdo_shp_property_definition_collection_8h-source.html#l00026">26</a> of file <a class="el" href="_fdo_shp_property_definition_collection_8h-source.html">FdoShpPropertyDefinitionCollection.h</a>.<table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">static FDOSHP_API <a class="el" href="class_fdo_shp_ov_property_definition_collection.html">FdoShpOvPropertyDefinitionCollection</a> * </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_ov_property_definition_collection_c242cc50d3484173bd53f93d49b748cd.html#c242cc50d3484173bd53f93d49b748cd">Create</a> (FdoPhysicalElementMapping *parent)</td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">static FDOSHP_API <a class="el" href="class_fdo_shp_ov_property_definition_collection.html">FdoShpOvPropertyDefinitionCollection</a> * </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_ov_property_definition_collection_bd6b681557f031ced9d12cb5905ce3e8.html#bd6b681557f031ced9d12cb5905ce3e8">Create</a> ()</td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual void </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_ov_property_definition_collection_1c61c73f46f6077d623451c5b73c66cd.html#1c61c73f46f6077d623451c5b73c66cd">Dispose</a> ()</td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top"> </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_ov_property_definition_collection_6e8f77facd3026d3207b96bfd7e558e0.html#6e8f77facd3026d3207b96bfd7e558e0">FdoShpOvPropertyDefinitionCollection</a> (FdoPhysicalElementMapping *parent)</td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top"> </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_ov_property_definition_collection_9dcd52a0dfe26c64474d8b0688437ab2.html#9dcd52a0dfe26c64474d8b0688437ab2">FdoShpOvPropertyDefinitionCollection</a> ()</td></tr>
+<tr><td class="memItemLeft" nowrap align="right" valign="top">virtual </td><td class="memItemRight" valign="bottom"><a class="el" href="class_fdo_shp_ov_property_definition_collection_d3eed0522918ece73f92aa1340718aeb.html#d3eed0522918ece73f92aa1340718aeb">~FdoShpOvPropertyDefinitionCollection</a> (void)</td></tr>
+</table>
+<li><a class="el" href="_fdo_shp_property_definition_collection_8h-source.html">FdoShpPropertyDefinitionCollection.h</a></ul>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_collection_1c61c73f46f6077d623451c5b73c66cd.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_collection_1c61c73f46f6077d623451c5b73c66cd.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_collection_1c61c73f46f6077d623451c5b73c66cd.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,81 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+<a class="el" href="class_fdo_shp_ov_property_definition_collection.html">FdoShpOvPropertyDefinitionCollection</a></div>
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_ov_property_definition_collection_bd6b681557f031ced9d12cb5905ce3e8.html#bd6b681557f031ced9d12cb5905ce3e8">Create</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_ov_property_definition_collection_c242cc50d3484173bd53f93d49b748cd.html#c242cc50d3484173bd53f93d49b748cd">Create</a></td></tr>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_ov_property_definition_collection_1c61c73f46f6077d623451c5b73c66cd.html#1c61c73f46f6077d623451c5b73c66cd">Dispose</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_ov_property_definition_collection_9dcd52a0dfe26c64474d8b0688437ab2.html#9dcd52a0dfe26c64474d8b0688437ab2">FdoShpOvPropertyDefinitionCollection</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_ov_property_definition_collection_6e8f77facd3026d3207b96bfd7e558e0.html#6e8f77facd3026d3207b96bfd7e558e0">FdoShpOvPropertyDefinitionCollection</a></td></tr>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_ov_property_definition_collection_d3eed0522918ece73f92aa1340718aeb.html#d3eed0522918ece73f92aa1340718aeb">~FdoShpOvPropertyDefinitionCollection</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="1c61c73f46f6077d623451c5b73c66cd"></a><!-- doxytag: member="FdoShpOvPropertyDefinitionCollection::Dispose" ref="1c61c73f46f6077d623451c5b73c66cd" args="()" --><p>
+<table class="mdTable" cellpadding="2" cellspacing="0">
+ <tr>
+ <td class="mdRow">
+ <table cellpadding="0" cellspacing="0" border="0">
+ <tr>
+ <td class="md" nowrap valign="top">virtual void FdoShpOvPropertyDefinitionCollection::Dispose </td>
+ <td class="md" valign="top">( </td>
+ <td class="mdname1" valign="top" nowrap> </td>
+ <td class="md" valign="top"> ) </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+<table cellspacing="5" cellpadding="0" border="0">
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_collection_6e8f77facd3026d3207b96bfd7e558e0.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_collection_6e8f77facd3026d3207b96bfd7e558e0.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_collection_6e8f77facd3026d3207b96bfd7e558e0.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,82 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindex" href="class_fdo_shp_ov_property_definition_collection_1c61c73f46f6077d623451c5b73c66cd.html#1c61c73f46f6077d623451c5b73c66cd">Dispose</a></td></tr>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_ov_property_definition_collection_6e8f77facd3026d3207b96bfd7e558e0.html#6e8f77facd3026d3207b96bfd7e558e0">FdoShpOvPropertyDefinitionCollection</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="6e8f77facd3026d3207b96bfd7e558e0"></a><!-- doxytag: member="FdoShpOvPropertyDefinitionCollection::FdoShpOvPropertyDefinitionCollection" ref="6e8f77facd3026d3207b96bfd7e558e0" args="(FdoPhysicalElementMapping *parent)" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">FdoShpOvPropertyDefinitionCollection::FdoShpOvPropertyDefinitionCollection </td>
+ <td class="md" nowrap valign="top">FdoPhysicalElementMapping * </td>
+ <td class="mdname1" valign="top" nowrap> <em>parent</em> </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_collection_9dcd52a0dfe26c64474d8b0688437ab2.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_collection_9dcd52a0dfe26c64474d8b0688437ab2.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_collection_9dcd52a0dfe26c64474d8b0688437ab2.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,81 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_ov_property_definition_collection_9dcd52a0dfe26c64474d8b0688437ab2.html#9dcd52a0dfe26c64474d8b0688437ab2">FdoShpOvPropertyDefinitionCollection</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="9dcd52a0dfe26c64474d8b0688437ab2"></a><!-- doxytag: member="FdoShpOvPropertyDefinitionCollection::FdoShpOvPropertyDefinitionCollection" ref="9dcd52a0dfe26c64474d8b0688437ab2" args="()" --><p>
+ <tr>
+ <tr>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_collection_bd6b681557f031ced9d12cb5905ce3e8.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_collection_bd6b681557f031ced9d12cb5905ce3e8.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_collection_bd6b681557f031ced9d12cb5905ce3e8.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,81 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_ov_property_definition_collection_bd6b681557f031ced9d12cb5905ce3e8.html#bd6b681557f031ced9d12cb5905ce3e8">Create</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="bd6b681557f031ced9d12cb5905ce3e8"></a><!-- doxytag: member="FdoShpOvPropertyDefinitionCollection::Create" ref="bd6b681557f031ced9d12cb5905ce3e8" args="()" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">static FDOSHP_API <a class="el" href="class_fdo_shp_ov_property_definition_collection.html">FdoShpOvPropertyDefinitionCollection</a>* FdoShpOvPropertyDefinitionCollection::Create </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_collection_c242cc50d3484173bd53f93d49b748cd.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_collection_c242cc50d3484173bd53f93d49b748cd.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_collection_c242cc50d3484173bd53f93d49b748cd.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,82 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_ov_property_definition_collection_c242cc50d3484173bd53f93d49b748cd.html#c242cc50d3484173bd53f93d49b748cd">Create</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="c242cc50d3484173bd53f93d49b748cd"></a><!-- doxytag: member="FdoShpOvPropertyDefinitionCollection::Create" ref="c242cc50d3484173bd53f93d49b748cd" args="(FdoPhysicalElementMapping *parent)" --><p>
+ <tr>
+ <tr>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_collection_d3eed0522918ece73f92aa1340718aeb.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_collection_d3eed0522918ece73f92aa1340718aeb.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/class_fdo_shp_ov_property_definition_collection_d3eed0522918ece73f92aa1340718aeb.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,82 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="nav">
+ <tr>
+ <td valign="top">
+ <table>
+ <tr><td class="navtab"><a class="qindexHL" href="class_fdo_shp_ov_property_definition_collection_d3eed0522918ece73f92aa1340718aeb.html#d3eed0522918ece73f92aa1340718aeb">~FdoShpOvPropertyDefinitionCollection</a></td></tr>
+ </table>
+ </div>
+ </td>
+ <td valign="top">
+<a class="anchor" name="d3eed0522918ece73f92aa1340718aeb"></a><!-- doxytag: member="FdoShpOvPropertyDefinitionCollection::~FdoShpOvPropertyDefinitionCollection" ref="d3eed0522918ece73f92aa1340718aeb" args="(void)" --><p>
+ <tr>
+ <tr>
+ <td class="md" nowrap valign="top">virtual FdoShpOvPropertyDefinitionCollection::~FdoShpOvPropertyDefinitionCollection </td>
+ </tr>
+ </table>
+ </td>
+ </tr>
+</table>
+ <tr>
+ <td>
+ </td>
+ <td>
+<p>
+ </td>
+ </tr>
+</table>
+ </td>
+ </tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/classes.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/classes.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/classes.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,45 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li id="current"><a href="classes.html"><span>Alphabetical List</span></a></li>
+ </ul></div>
+<h1>FDO Provider for SHP Class Index</h1><p><div class="qindex"><a class="qindex" href="#letter_F">F</a></div><p>
+<table align="center" width="95%" border="0" cellspacing="0" cellpadding="0">
+<tr><td><a name="letter_F"></a><table border="0" cellspacing="0" cellpadding="0"><tr><td><div class="ah"> F </div></td></tr></table>
+</td><td><a class="el" href="class_fdo_shp_ov_class_definition.html">FdoShpOvClassDefinition</a> </td><td><a class="el" href="class_fdo_shp_ov_physical_schema_mapping.html">FdoShpOvPhysicalSchemaMapping</a> </td><td><a class="el" href="class_fdo_shp_ov_property_definition.html">FdoShpOvPropertyDefinition</a> </td><td><a class="el" href="class_fdo_shp_ov_property_definition_collection.html">FdoShpOvPropertyDefinitionCollection</a> </td></tr><tr><td><a class="el" href="class_fdo_shp_ov_class_collection.html">FdoShpOvClassCollection</a> </td><td><a class="el" href="class_fdo_shp_ov_column_definition.html">FdoShpOvColumnDefinition</a> </td></tr></table><p><div class="qindex"><a class="qindex" href="#letter_F">F</a></div><p>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/custom.css
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/custom.css?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/custom.css 2006-05-16 20:42:26+0000
@@ -0,0 +1,96 @@
+ at import url(doxygen.css);
+div.Syntax{
+ background-color:#FFFFD9;
+div.Example{
+ background-color:#E9E9E9;
+/* table cells on the main page (index.html) */
+div.mainpage td {
+ background-color: #FFFFCC;
+ border-right-color: #FF6633;
+ border-bottom-color: #FF6633;
+ border-left-color: #FFCC33;
+ border-top-color: #FFCC33;
+ text-align: center;
+/*** Used in external topics ***/
+p.indent_1 {
+ padding-left: 0.25in;
+p.indent_2 {
+ padding-left: 0.5in;
+p.indent_3 {
+ padding-left: 0.75in;
+table.RuledTable {
+ border-collapse: collapse;
+ table-layout: auto;
+ width: auto;
+ cellpadding: none;
+ cellspacing: none;
+table.RuledTable th {
+ background-color: #CCCCCC;
+ border-left-style: solid;
+ border-left-width: thin;
+ border-left-color: #000000;
+ border-right-style: solid;
+ border-right-width: thin;
+ border-right-color: #000000;
+ border-bottom-style: solid;
+ border-bottom-width: thin;
+ border-bottom-color: #000000;
+ border-top-style: solid;
+ border-top-width: thin;
+ border-top-color: #000000;
+ padding: 6px;
+ width: auto;
+table.RuledTable td {
+ padding-left: 6px;
+ padding-right: 6px;
+ padding-top: 4px;
+ padding-top: 4px;
+ width: auto;
+td.shaded{
+ background-color:#CCCCCC;
+/* Used in Geometry_FgfText.h */
+p.row_1 {
+ font-family: "Courier New", Courier, monospace;
+pre.row_2 {
+ background-color: #E7FFCE;
Added: trunk/www/docs/SHP/define__pages_8h-source.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/define__pages_8h-source.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/define__pages_8h-source.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,85 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li id="current"><a href="files.html"><span>Files</span></a></li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li><a href="files.html"><span>File List</span></a></li>
+ <li><a href="globals.html"><span>File Members</span></a></li>
+ </ul></div>
+<h1>define_pages.h</h1><a href="define__pages_8h.html">Go to the documentation of this file.</a><div class="fragment"><pre class="fragment"><a name="l00001"></a>00001 <span class="comment">/*! \mainpage Introduction</span>
+<a name="l00002"></a>00002 <span class="comment"><div class="mainpage"></span>
+<a name="l00003"></a>00003 <span class="comment"><!-- This is the index.html page that the user first sees. --></span>
+<a name="l00004"></a>00004 <span class="comment"></span>
+<a name="l00005"></a>00005 <span class="comment"><p>The Feature Data Objects (FDO) API provides access to data in a </span>
+<a name="l00006"></a>00006 <span class="comment">data store. A provider is a specific implementation of the FDO API </span>
+<a name="l00007"></a>00007 <span class="comment">that provides access to data in a particular data store. The FDO </span>
+<a name="l00008"></a>00008 <span class="comment">Provider for SHP provides FDO with access to a SHP-based data store.</span>
+<a name="l00009"></a>00009 <span class="comment"></p></span>
+<a name="l00010"></a>00010 <span class="comment"><p>The FDO Provider for SHP uses a standalone file format that</span>
+<a name="l00011"></a>00011 <span class="comment">supports GIS data. The FDO Provider for SHP (Shape) has the </span>
+<a name="l00012"></a>00012 <span class="comment">following characteristics: </span>
+<a name="l00013"></a>00013 <span class="comment"></p></span>
+<a name="l00014"></a>00014 <span class="comment"><ul></span>
+<a name="l00015"></a>00015 <span class="comment"> <li> Read-only access is provided to pre-existing</span>
+<a name="l00016"></a>00016 <span class="comment"> spatial and attribute data from an Environmental Systems</span>
+<a name="l00017"></a>00017 <span class="comment"> Research Institute (ESRI) Shape file (SHP).</span>
+<a name="l00018"></a>00018 <span class="comment"> <li> The FDO Provider for SHP can run in a multi-platform environment,</span>
+<a name="l00019"></a>00019 <span class="comment"> including Windows and Linux.</span>
+<a name="l00020"></a>00020 <span class="comment"> <li> A Shape file consists of three separate files: SHP (shape</span>
+<a name="l00021"></a>00021 <span class="comment"> geometry), SHX (shape index), and DBF (shape attributes in</span>
+<a name="l00022"></a>00022 <span class="comment"> dBASE format).</span>
+<a name="l00023"></a>00023 <span class="comment"> <li> The FDO Provider for SHP accesses the information in each of the </span>
+<a name="l00024"></a>00024 <span class="comment"> three separate files, and treats each SHP, and its associated DBF file, </span>
+<a name="l00025"></a>00025 <span class="comment"> as a feature class with a single geometry property, and optionally, </span>
+<a name="l00026"></a>00026 <span class="comment"> with data attribute properties.</span>
+<a name="l00027"></a>00027 <span class="comment"> <li> Schema configuration of the data store is provided to the</span>
+<a name="l00028"></a>00028 <span class="comment"> FDO Provider for SHP through an XML file containing the</span>
+<a name="l00029"></a>00029 <span class="comment"> Geographic Markup Language (GML) definition of the schema</span>
+<a name="l00030"></a>00030 <span class="comment"> that maps SHP and DBF data in the data store to feature</span>
+<a name="l00031"></a>00031 <span class="comment"> classes and property mappings in the FDO data model.</span>
+<a name="l00032"></a>00032 <span class="comment"> <li> Although it does not support concurrency control (locking), the SHP </span>
+<a name="l00033"></a>00033 <span class="comment"> file format is a valid alternative to RDBMS.</span>
+<a name="l00034"></a>00034 <span class="comment"></ul></span>
+<a name="l00035"></a>00035 <span class="comment"><p></span>
+<a name="l00036"></a>00036 <span class="comment">For more information, see <i>The Essential FDO</i> (FET_TheEssentialFDO.pdf) </span>
+<a name="l00037"></a>00037 <span class="comment">and the <i>FDO Developer's Guide</i> (FDG_FDODevGuide.pdf).</span>
+<a name="l00038"></a>00038 <span class="comment"></p></span>
+<a name="l00039"></a>00039 <span class="comment"></span>
+<a name="l00040"></a>00040 <span class="comment"><br></span>
+<a name="l00041"></a>00041 <span class="comment"></div></span>
+<a name="l00042"></a>00042 <span class="comment">*/</span>
+<a name="l00043"></a>00043
+<a name="l00044"></a>00044
+<a name="l00045"></a>00045
+<a name="l00046"></a>00046
+</pre></div><!-- footer.html -->
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/define__pages_8h.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/define__pages_8h.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/define__pages_8h.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,46 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<h1>define_pages.h File Reference</h1>
+<p>
+<p>
+<a href="define__pages_8h-source.html">Go to the source code of this file.</a><table border="0" cellpadding="0" cellspacing="0">
+<tr><td></td></tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/doxygen.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/doxygen.png?view=auto&rev=15
Binary file. No diff available.
Added: trunk/www/docs/SHP/files.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/files.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/files.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,48 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li id="current"><a href="files.html"><span>File List</span></a></li>
+ </ul></div>
+<h1>FDO Provider for SHP File List</h1>Here is a list of all files with brief descriptions:<table>
+ <tr><td class="indexkey"><a class="el" href="define__pages_8h.html">define_pages.h</a> <a href="define__pages_8h-source.html">[code]</a></td><td class="indexvalue"></td></tr>
+ <tr><td class="indexkey"><a class="el" href="_fdo_shp_class_collection_8h.html">FdoShpClassCollection.h</a> <a href="_fdo_shp_class_collection_8h-source.html">[code]</a></td><td class="indexvalue"></td></tr>
+ <tr><td class="indexkey"><a class="el" href="_fdo_shp_class_definition_8h.html">FdoShpClassDefinition.h</a> <a href="_fdo_shp_class_definition_8h-source.html">[code]</a></td><td class="indexvalue"></td></tr>
+ <tr><td class="indexkey"><a class="el" href="_fdo_shp_column_definition_8h.html">FdoShpColumnDefinition.h</a> <a href="_fdo_shp_column_definition_8h-source.html">[code]</a></td><td class="indexvalue"></td></tr>
+ <tr><td class="indexkey"><a class="el" href="_fdo_shp_physical_schema_mapping_8h.html">FdoShpPhysicalSchemaMapping.h</a> <a href="_fdo_shp_physical_schema_mapping_8h-source.html">[code]</a></td><td class="indexvalue"></td></tr>
+ <tr><td class="indexkey"><a class="el" href="_fdo_shp_property_definition_8h.html">FdoShpPropertyDefinition.h</a> <a href="_fdo_shp_property_definition_8h-source.html">[code]</a></td><td class="indexvalue"></td></tr>
+ <tr><td class="indexkey"><a class="el" href="_fdo_shp_property_definition_collection_8h.html">FdoShpPropertyDefinitionCollection.h</a> <a href="_fdo_shp_property_definition_collection_8h-source.html">[code]</a></td><td class="indexvalue"></td></tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/ftv2blank.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/ftv2blank.png?view=auto&rev=15
Added: trunk/www/docs/SHP/ftv2doc.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/ftv2doc.png?view=auto&rev=15
Added: trunk/www/docs/SHP/ftv2folderclosed.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/ftv2folderclosed.png?view=auto&rev=15
Added: trunk/www/docs/SHP/ftv2folderopen.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/ftv2folderopen.png?view=auto&rev=15
Added: trunk/www/docs/SHP/ftv2lastnode.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/ftv2lastnode.png?view=auto&rev=15
Added: trunk/www/docs/SHP/ftv2link.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/ftv2link.png?view=auto&rev=15
Added: trunk/www/docs/SHP/ftv2mlastnode.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/ftv2mlastnode.png?view=auto&rev=15
Added: trunk/www/docs/SHP/ftv2mnode.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/ftv2mnode.png?view=auto&rev=15
Added: trunk/www/docs/SHP/ftv2node.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/ftv2node.png?view=auto&rev=15
Added: trunk/www/docs/SHP/ftv2plastnode.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/ftv2plastnode.png?view=auto&rev=15
Added: trunk/www/docs/SHP/ftv2pnode.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/ftv2pnode.png?view=auto&rev=15
Added: trunk/www/docs/SHP/ftv2vertline.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/ftv2vertline.png?view=auto&rev=15
Added: trunk/www/docs/SHP/functions.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/functions.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/functions.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,81 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li id="current"><a href="functions.html"><span>Class Members</span></a></li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li id="current"><a href="functions.html"><span>All</span></a></li>
+ <li><a href="functions_func.html"><span>Functions</span></a></li>
+ </ul>
+</div>
+Here is a list of all class members with links to the classes they belong to:
+<p>
+<ul>
+<li>_writeXml()
+: <a class="el" href="class_fdo_shp_ov_property_definition_7eededaf3297b36ddd9445f6fcf67a01.html#7eededaf3297b36ddd9445f6fcf67a01">FdoShpOvPropertyDefinition</a>, <a class="el" href="class_fdo_shp_ov_physical_schema_mapping_414ac55477c612f4cc898cb949f7c349.html#414ac55477c612f4cc898cb949f7c349">FdoShpOvPhysicalSchemaMapping</a>, <a class="el" href="class_fdo_shp_ov_column_definition_58f92ba87a369a97428c7d937d569c72.html#58f92ba87a369a97428c7d937d569c72">FdoShpOvColumnDefinition</a>, <a class="el" href="class_fdo_shp_ov_class_definition_a4318e266ade8f0561246fe5385a488c.html#a4318e266ade8f0561246fe5385a488c">FdoShpOvClassDefinition</a><li>Create()
+: <a class="el" href="class_fdo_shp_ov_property_definition_collection_c242cc50d3484173bd53f93d49b748cd.html#c242cc50d3484173bd53f93d49b748cd">FdoShpOvPropertyDefinitionCollection</a>, <a class="el" href="class_fdo_shp_ov_property_definition_7ea7dfeeb0bf291c7a8049415300c66f.html#7ea7dfeeb0bf291c7a8049415300c66f">FdoShpOvPropertyDefinition</a>, <a class="el" href="class_fdo_shp_ov_physical_schema_mapping_29a8cbc220b2489ec8894212e55e6a63.html#29a8cbc220b2489ec8894212e55e6a63">FdoShpOvPhysicalSchemaMapping</a>, <a class="el" href="class_fdo_shp_ov_column_definition_71f1cbc25bd5085cd546450015067b08.html#71f1cbc25bd5085cd546450015067b08">FdoShpOvColumnDefinition</a>, <a class="el" href="class_fdo_shp_ov_class_definition_74352faa22702f58a3ed79591635dffb.html#74352faa22702f58a3ed79591635dffb">FdoShpOvClassDefinition</a>, <a class="el" href="class_fdo_shp_ov_class_collection_3f8d21ceb843d89dd1501c5345e959ce.html#3f8d21ceb843d89dd1501c5345e959ce">FdoShpOvClassCollection</a><li>Dispose()
+: <a class="el" href="class_fdo_shp_ov_property_definition_collection_1c61c73f46f6077d623451c5b73c66cd.html#1c61c73f46f6077d623451c5b73c66cd">FdoShpOvPropertyDefinitionCollection</a>, <a class="el" href="class_fdo_shp_ov_property_definition_944e21212809bf59f3c838980f77bcde.html#944e21212809bf59f3c838980f77bcde">FdoShpOvPropertyDefinition</a>, <a class="el" href="class_fdo_shp_ov_physical_schema_mapping_8ff550c78afad1e00544a0393a17fa7c.html#8ff550c78afad1e00544a0393a17fa7c">FdoShpOvPhysicalSchemaMapping</a>, <a class="el" href="class_fdo_shp_ov_column_definition_eca75a56d812c8a7bd40dbc5bb303adc.html#eca75a56d812c8a7bd40dbc5bb303adc">FdoShpOvColumnDefinition</a>, <a class="el" href="class_fdo_shp_ov_class_definition_3212ae28553647cef5b24eea5be5d182.html#3212ae28553647cef5b24eea5be5d182">FdoShpOvClassDefinition</a>, <a class="el" href="class_fdo_shp_ov_class_collection_c5568ebf824873a81cae138f1f72c0a7.html#c5568ebf824873a81cae138f1f72c0a7">FdoShpOvClassCollection</a><li>FdoShpOvClassCollection()
+: <a class="el" href="class_fdo_shp_ov_class_collection_7ca47202e723ee690e94240c2dbaa22b.html#7ca47202e723ee690e94240c2dbaa22b">FdoShpOvClassCollection</a><li>FdoShpOvClassDefinition()
+: <a class="el" href="class_fdo_shp_ov_class_definition_5ff553ac0195587c9753b2fe95d42a61.html#5ff553ac0195587c9753b2fe95d42a61">FdoShpOvClassDefinition</a><li>FdoShpOvColumnDefinition()
+: <a class="el" href="class_fdo_shp_ov_column_definition_90d84295b5cbbda30ca5e3d66a895cff.html#90d84295b5cbbda30ca5e3d66a895cff">FdoShpOvColumnDefinition</a><li>FdoShpOvPhysicalSchemaMapping()
+: <a class="el" href="class_fdo_shp_ov_physical_schema_mapping_57b8da135b87b7df5b0400cc07536f44.html#57b8da135b87b7df5b0400cc07536f44">FdoShpOvPhysicalSchemaMapping</a><li>FdoShpOvPropertyDefinition()
+: <a class="el" href="class_fdo_shp_ov_property_definition_28f724d715783bd56d4ee112b182d6d6.html#28f724d715783bd56d4ee112b182d6d6">FdoShpOvPropertyDefinition</a><li>FdoShpOvPropertyDefinitionCollection()
+: <a class="el" href="class_fdo_shp_ov_property_definition_collection_6e8f77facd3026d3207b96bfd7e558e0.html#6e8f77facd3026d3207b96bfd7e558e0">FdoShpOvPropertyDefinitionCollection</a><li>FindByClassName()
+: <a class="el" href="class_fdo_shp_ov_physical_schema_mapping_d89ecf4a8c025d05c75aa9412a37284f.html#d89ecf4a8c025d05c75aa9412a37284f">FdoShpOvPhysicalSchemaMapping</a><li>FindByColumnName()
+: <a class="el" href="class_fdo_shp_ov_class_definition_03bd17ccb7d6f1f3509b49309073d154.html#03bd17ccb7d6f1f3509b49309073d154">FdoShpOvClassDefinition</a><li>FindByShapefile()
+: <a class="el" href="class_fdo_shp_ov_physical_schema_mapping_bc4cb63ab21fc31035d25cc8852a3046.html#bc4cb63ab21fc31035d25cc8852a3046">FdoShpOvPhysicalSchemaMapping</a><li>GetClasses()
+: <a class="el" href="class_fdo_shp_ov_physical_schema_mapping_4f696de2a2bcba8d7f83892e3a3f2bbe.html#4f696de2a2bcba8d7f83892e3a3f2bbe">FdoShpOvPhysicalSchemaMapping</a><li>GetColumn()
+: <a class="el" href="class_fdo_shp_ov_property_definition_4be129d8f231d3c80f4b5d8f67d55b3d.html#4be129d8f231d3c80f4b5d8f67d55b3d">FdoShpOvPropertyDefinition</a><li>GetProperties()
+: <a class="el" href="class_fdo_shp_ov_class_definition_c4fd98e86e1b061f3314ee5eb6664030.html#c4fd98e86e1b061f3314ee5eb6664030">FdoShpOvClassDefinition</a><li>GetProvider()
+: <a class="el" href="class_fdo_shp_ov_physical_schema_mapping_e34e818940d63ab41db19c2e73a107d1.html#e34e818940d63ab41db19c2e73a107d1">FdoShpOvPhysicalSchemaMapping</a><li>GetShapeFile()
+: <a class="el" href="class_fdo_shp_ov_class_definition_f7f39af97bbd5e5644196196f322f02c.html#f7f39af97bbd5e5644196196f322f02c">FdoShpOvClassDefinition</a><li>InitFromXml()
+: <a class="el" href="class_fdo_shp_ov_property_definition_c41a3a6e4a1d09b8f9174dce7c6f6b25.html#c41a3a6e4a1d09b8f9174dce7c6f6b25">FdoShpOvPropertyDefinition</a>, <a class="el" href="class_fdo_shp_ov_physical_schema_mapping_323760df2b4697a81b70b1a4d494b401.html#323760df2b4697a81b70b1a4d494b401">FdoShpOvPhysicalSchemaMapping</a>, <a class="el" href="class_fdo_shp_ov_column_definition_d8671acab0db72d517012189859cdafe.html#d8671acab0db72d517012189859cdafe">FdoShpOvColumnDefinition</a>, <a class="el" href="class_fdo_shp_ov_class_definition_03246baa324656d80807273c8669082f.html#03246baa324656d80807273c8669082f">FdoShpOvClassDefinition</a><li>IsPathUpdated()
+: <a class="el" href="class_fdo_shp_ov_class_definition_1e811303f7da9de17189d3b91b40df17.html#1e811303f7da9de17189d3b91b40df17">FdoShpOvClassDefinition</a><li>SetColumn()
+: <a class="el" href="class_fdo_shp_ov_property_definition_b2e5583363bffe8483b92ca1dae3a6c7.html#b2e5583363bffe8483b92ca1dae3a6c7">FdoShpOvPropertyDefinition</a><li>SetPathUpdated()
+: <a class="el" href="class_fdo_shp_ov_class_definition_58b334144a66fdd59ca905faa384cedc.html#58b334144a66fdd59ca905faa384cedc">FdoShpOvClassDefinition</a><li>SetShapeFile()
+: <a class="el" href="class_fdo_shp_ov_class_definition_231e0376b3239b584382401389a74991.html#231e0376b3239b584382401389a74991">FdoShpOvClassDefinition</a><li>XmlEndElement()
+: <a class="el" href="class_fdo_shp_ov_property_definition_3247a059e0eb2c1f60c516e81739058e.html#3247a059e0eb2c1f60c516e81739058e">FdoShpOvPropertyDefinition</a>, <a class="el" href="class_fdo_shp_ov_physical_schema_mapping_39b1326a353fa925aca33e51952f2e97.html#39b1326a353fa925aca33e51952f2e97">FdoShpOvPhysicalSchemaMapping</a>, <a class="el" href="class_fdo_shp_ov_column_definition_fff19eb49dc45425fdb3ef7e1a8cc34f.html#fff19eb49dc45425fdb3ef7e1a8cc34f">FdoShpOvColumnDefinition</a>, <a class="el" href="class_fdo_shp_ov_class_definition_d27f1b55c70e4ff58df6df488f8abf9b.html#d27f1b55c70e4ff58df6df488f8abf9b">FdoShpOvClassDefinition</a><li>XmlStartElement()
+: <a class="el" href="class_fdo_shp_ov_property_definition_31b64b4fe2e08635300ddac43e8cca96.html#31b64b4fe2e08635300ddac43e8cca96">FdoShpOvPropertyDefinition</a>, <a class="el" href="class_fdo_shp_ov_physical_schema_mapping_a09f3b41a60fa1d6adf257252bbe5670.html#a09f3b41a60fa1d6adf257252bbe5670">FdoShpOvPhysicalSchemaMapping</a>, <a class="el" href="class_fdo_shp_ov_column_definition_64d163015f3c021b5dc5fbe6105ff89a.html#64d163015f3c021b5dc5fbe6105ff89a">FdoShpOvColumnDefinition</a>, <a class="el" href="class_fdo_shp_ov_class_definition_73405bd93a5068e2c0125076ef82b0ae.html#73405bd93a5068e2c0125076ef82b0ae">FdoShpOvClassDefinition</a><li>~FdoShpOvClassCollection()
+: <a class="el" href="class_fdo_shp_ov_class_collection_d49972d5035851fc525d319fdd0ac0de.html#d49972d5035851fc525d319fdd0ac0de">FdoShpOvClassCollection</a><li>~FdoShpOvClassDefinition()
+: <a class="el" href="class_fdo_shp_ov_class_definition_2de74cf4ba695c3a27f84d924fae13d1.html#2de74cf4ba695c3a27f84d924fae13d1">FdoShpOvClassDefinition</a><li>~FdoShpOvColumnDefinition()
+: <a class="el" href="class_fdo_shp_ov_column_definition_343c8b7cbb45e9ad7aefbd97f7879ec3.html#343c8b7cbb45e9ad7aefbd97f7879ec3">FdoShpOvColumnDefinition</a><li>~FdoShpOvPhysicalSchemaMapping()
+: <a class="el" href="class_fdo_shp_ov_physical_schema_mapping_aa23c8e7b0c5f94a2c5fe96d62bb96b0.html#aa23c8e7b0c5f94a2c5fe96d62bb96b0">FdoShpOvPhysicalSchemaMapping</a><li>~FdoShpOvPropertyDefinition()
+: <a class="el" href="class_fdo_shp_ov_property_definition_0b52161945add0910480f452d9ac2bc0.html#0b52161945add0910480f452d9ac2bc0">FdoShpOvPropertyDefinition</a><li>~FdoShpOvPropertyDefinitionCollection()
+: <a class="el" href="class_fdo_shp_ov_property_definition_collection_d3eed0522918ece73f92aa1340718aeb.html#d3eed0522918ece73f92aa1340718aeb">FdoShpOvPropertyDefinitionCollection</a></ul>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/functions_func.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/functions_func.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/functions_func.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,81 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li><a href="functions.html"><span>All</span></a></li>
+ <li id="current"><a href="functions_func.html"><span>Functions</span></a></li>
+ </ul>
+</div>
+<p>
+<ul>
+<li>_writeXml()
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/globals.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/globals.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/globals.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,55 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li id="current"><a href="globals.html"><span>File Members</span></a></li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li id="current"><a href="globals.html"><span>All</span></a></li>
+ <li><a href="globals_type.html"><span>Typedefs</span></a></li>
+ </ul>
+</div>
+Here is a list of all file members with links to the files they belong to:
+<p>
+<ul>
+<li>FdoShpOvClassCollectionP
+: <a class="el" href="_fdo_shp_class_collection_8h_e68feb280094416a66eb2e7f7ad86837.html#e68feb280094416a66eb2e7f7ad86837">FdoShpClassCollection.h</a><li>FdoShpOvClassDefinitionP
+: <a class="el" href="_fdo_shp_class_definition_8h_e6c80e15cb30580f4a33f0b0bf25875a.html#e6c80e15cb30580f4a33f0b0bf25875a">FdoShpClassDefinition.h</a><li>FdoShpOvColumnDefinitionP
+: <a class="el" href="_fdo_shp_column_definition_8h_f44b3b0db4b0df599032ed54748aff07.html#f44b3b0db4b0df599032ed54748aff07">FdoShpColumnDefinition.h</a><li>FdoShpOvPhysicalSchemaMappingP
+: <a class="el" href="_fdo_shp_physical_schema_mapping_8h_01dee688aae19647cd329e59b751a1c9.html#01dee688aae19647cd329e59b751a1c9">FdoShpPhysicalSchemaMapping.h</a><li>FdoShpOvPropertyDefinitionCollectionP
+: <a class="el" href="_fdo_shp_property_definition_collection_8h_c523fa2a650dbc38df6576e0a1e8cbb6.html#c523fa2a650dbc38df6576e0a1e8cbb6">FdoShpPropertyDefinitionCollection.h</a><li>FdoShpOvPropertyDefinitionP
+: <a class="el" href="_fdo_shp_property_definition_8h_a8352482cc4887e6db2714402dbe3d57.html#a8352482cc4887e6db2714402dbe3d57">FdoShpPropertyDefinition.h</a></ul>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/globals_type.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/globals_type.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/globals_type.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,55 @@
+<html>
+ <head>
+ </head>
+ <table width="100%" border="0">
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li><a href="globals.html"><span>All</span></a></li>
+ <li id="current"><a href="globals_type.html"><span>Typedefs</span></a></li>
+ </ul>
+</div>
+<p>
+<ul>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/graph_legend.dot
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/graph_legend.dot?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/graph_legend.dot 2006-05-16 20:42:26+0000
@@ -0,0 +1,22 @@
+digraph G
+ edge [fontname="Helvetica",fontsize=10,labelfontname="Helvetica",labelfontsize=10];
+ node [fontname="Helvetica",fontsize=10,shape=record];
+ Node9 [shape="box",label="Inherited",fontsize=10,height=0.2,width=0.4,fontname="Helvetica",color="black",style="filled" fontcolor="white"];
+ Node10 -> Node9 [dir=back,color="midnightblue",fontsize=10,style="solid",fontname="Helvetica"];
+ Node10 [shape="box",label="PublicBase",fontsize=10,height=0.2,width=0.4,fontname="Helvetica",color="black",URL="$classPublicBase.html"];
+ Node11 -> Node10 [dir=back,color="midnightblue",fontsize=10,style="solid",fontname="Helvetica"];
+ Node11 [shape="box",label="Truncated",fontsize=10,height=0.2,width=0.4,fontname="Helvetica",color="red",URL="$classTruncated.html"];
+ Node13 -> Node9 [dir=back,color="darkgreen",fontsize=10,style="solid",fontname="Helvetica"];
+ Node13 [shape="box",label="ProtectedBase",fontsize=10,height=0.2,width=0.4,fontname="Helvetica",color="black",URL="$classProtectedBase.html"];
+ Node14 -> Node9 [dir=back,color="firebrick4",fontsize=10,style="solid",fontname="Helvetica"];
+ Node14 [shape="box",label="PrivateBase",fontsize=10,height=0.2,width=0.4,fontname="Helvetica",color="black",URL="$classPrivateBase.html"];
+ Node15 -> Node9 [dir=back,color="midnightblue",fontsize=10,style="solid",fontname="Helvetica"];
+ Node15 [shape="box",label="Undocumented",fontsize=10,height=0.2,width=0.4,fontname="Helvetica",color="grey75"];
+ Node16 -> Node9 [dir=back,color="midnightblue",fontsize=10,style="solid",fontname="Helvetica"];
+ Node16 [shape="box",label="Templ< int >",fontsize=10,height=0.2,width=0.4,fontname="Helvetica",color="black",URL="$classTempl.html"];
+ Node17 -> Node16 [dir=back,color="orange",fontsize=10,style="dashed",label="< int >",fontname="Helvetica"];
+ Node17 [shape="box",label="Templ< T >",fontsize=10,height=0.2,width=0.4,fontname="Helvetica",color="black",URL="$classTempl.html"];
+ Node18 -> Node9 [dir=back,color="darkorchid3",fontsize=10,style="dashed",label="m_usedClass",fontname="Helvetica"];
+ Node18 [shape="box",label="Used",fontsize=10,height=0.2,width=0.4,fontname="Helvetica",color="black",URL="$classUsed.html"];
Added: trunk/www/docs/SHP/graph_legend.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/graph_legend.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/graph_legend.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,96 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
+<html>
+ <head>
+ <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
+ <title>OSGeo FDO Provider for SHP API Reference</title>
+ <link href="custom.css" rel="stylesheet" type="text/css">
+ <link href="tabs.css" rel="stylesheet" type="text/css">
+ </head>
+ <body bgcolor="#FFFFFF">
+ <tr>
+ <td><b>API Reference<b></td>
+ <td align="right"><b>OSGeo FDO Provider for SHP<b></td>
+ </tr>
+ </table>
+<!-- End of: header.html -->
+<!-- Generated by Doxygen 1.4.6-NO -->
+<div class="tabs">
+ <ul>
+ <li><a href="main.html"><span>Main Page</span></a></li>
+ </ul></div>
+<h1>Graph Legend</h1>This page explains how to interpret the graphs that are generated by doxygen.<p>
+Consider the following example: <div class="fragment"><pre class="fragment"><span class="comment">/*! Invisible class because of truncation */</span>
+<span class="keyword">class </span>Invisible { };
+<span class="comment"></span>
+<span class="comment">/*! Truncated class, inheritance relation is hidden */</span>
+<span class="keyword">class </span>Truncated : <span class="keyword">public</span> Invisible { };
+<span class="comment">/* Class not documented with doxygen comments */</span>
+<span class="keyword">class </span>Undocumented { };
+<span class="comment">/*! Class that is inherited using public inheritance */</span>
+<span class="keyword">class </span>PublicBase : <span class="keyword">public</span> Truncated { };
+<span class="comment">/*! A template class */</span>
+<span class="keyword">template</span><<span class="keyword">class</span> T> <span class="keyword">class </span>Templ { };
+<span class="comment">/*! Class that is inherited using protected inheritance */</span>
+<span class="keyword">class </span>ProtectedBase { };
+<span class="comment">/*! Class that is inherited using private inheritance */</span>
+<span class="keyword">class </span>PrivateBase { };
+<span class="comment">/*! Class that is used by the Inherited class */</span>
+<span class="keyword">class </span>Used { };
+<span class="comment">/*! Super class that inherits a number of other classes */</span>
+<span class="keyword">class </span>Inherited : <span class="keyword">public</span> PublicBase,
+ <span class="keyword">protected</span> ProtectedBase,
+ <span class="keyword">private</span> PrivateBase,
+ <span class="keyword">public</span> Undocumented
+ <span class="keyword">public</span> Templ<int>
+ <span class="keyword">private</span>:
+ Used *m_usedClass;
+</pre></div> If the <code>MAX_DOT_GRAPH_HEIGHT</code> tag in the configuration file is set to 240 this will result in the following graph:<p>
+<center><div align="center">
+<img src="graph_legend.png" alt="graph_legend.png">
+</div>
+</center> <p>
+The boxes in the above graph have the following meaning: <ul>
+<li>
+A filled black box represents the struct or class for which the graph is generated. </li>
+<li>
+A box with a black border denotes a documented struct or class. </li>
+<li>
+A box with a grey border denotes an undocumented struct or class. </li>
+<li>
+A box with a red border denotes a documented struct or class forwhich not all inheritance/containment relations are shown. A graph is truncated if it does not fit within the specified boundaries. </li>
+</ul>
+The arrows have the following meaning: <ul>
+<li>
+A dark blue arrow is used to visualize a public inheritance relation between two classes. </li>
+<li>
+A dark green arrow is used for protected inheritance. </li>
+<li>
+A dark red arrow is used for private inheritance. </li>
+<li>
+A purple dashed arrow is used if a class is contained or used by another class. The arrow is labeled with the variable(s) through which the pointed class or struct is accessible. </li>
+<li>
+A yellow dashed arrow denotes a relation between a template instance and the template class it was instantiated from. The arrow is labeled with the template parameters of the instance. </li>
+</ul>
+<!-- footer.html -->
+ <hr>
+ <tr>
+ <td align="right"><font size="-2"><a href="mailto:isd.docs at autodesk.com&subject=FDO%20Provider%20for%20SHP%20API%20documentation">Comments?</a></font></td>
+ <!-- The logo can go in another cell, when we get one -->
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/graph_legend.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/graph_legend.png?view=auto&rev=15
Added: trunk/www/docs/SHP/hierarchy.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/hierarchy.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/hierarchy.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,51 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li id="current"><a href="hierarchy.html"><span>Class Hierarchy</span></a></li>
+ </ul></div>
+<h1>FDO Provider for SHP Class Hierarchy</h1><a href="inherits.html">Go to the graphical class hierarchy</a>
+<p>
+This inheritance list is sorted roughly, but not completely, alphabetically:<ul>
+<li><a class="el" href="class_fdo_shp_ov_class_collection.html">FdoShpOvClassCollection</a>
+<li><a class="el" href="class_fdo_shp_ov_class_definition.html">FdoShpOvClassDefinition</a>
+<li><a class="el" href="class_fdo_shp_ov_column_definition.html">FdoShpOvColumnDefinition</a>
+<li><a class="el" href="class_fdo_shp_ov_physical_schema_mapping.html">FdoShpOvPhysicalSchemaMapping</a>
+<li><a class="el" href="class_fdo_shp_ov_property_definition.html">FdoShpOvPropertyDefinition</a>
+<li><a class="el" href="class_fdo_shp_ov_property_definition_collection.html">FdoShpOvPropertyDefinitionCollection</a>
+</ul>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/index.hhc
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/index.hhc?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/index.hhc 2006-05-16 20:42:26+0000
@@ -0,0 +1,39 @@
+<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML//EN">
+<HTML><HEAD></HEAD><BODY>
+<OBJECT type="text/site properties">
+<param name="FrameName" value="right">
+</OBJECT>
+<UL>
+<LI><OBJECT type="text/sitemap"><param name="Name" value="Introduction"><param name="Local" value="main.html"><param name="ImageNumber" value="11"></OBJECT>
+<LI><OBJECT type="text/sitemap"><param name="Name" value="File List"><param name="ImageNumber" value="1"></OBJECT>
+ <UL>
+ <LI><OBJECT type="text/sitemap"><param name="Name" value="define_pages.h"><param name="Local" value="define__pages_8h.html"><param name="ImageNumber" value="11"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Name" value="FdoShpClassCollection.h"><param name="Local" value="_fdo_shp_class_collection_8h.html"><param name="ImageNumber" value="11"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Name" value="FdoShpClassDefinition.h"><param name="Local" value="_fdo_shp_class_definition_8h.html"><param name="ImageNumber" value="11"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Name" value="FdoShpColumnDefinition.h"><param name="Local" value="_fdo_shp_column_definition_8h.html"><param name="ImageNumber" value="11"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Name" value="FdoShpPhysicalSchemaMapping.h"><param name="Local" value="_fdo_shp_physical_schema_mapping_8h.html"><param name="ImageNumber" value="11"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Name" value="FdoShpPropertyDefinition.h"><param name="Local" value="_fdo_shp_property_definition_8h.html"><param name="ImageNumber" value="11"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Name" value="FdoShpPropertyDefinitionCollection.h"><param name="Local" value="_fdo_shp_property_definition_collection_8h.html"><param name="ImageNumber" value="11"></OBJECT>
+ </UL>
+<LI><OBJECT type="text/sitemap"><param name="Name" value="Class List"><param name="ImageNumber" value="1"></OBJECT>
+ <UL>
+ <LI><OBJECT type="text/sitemap"><param name="Name" value="FdoShpOvClassCollection"><param name="Local" value="class_fdo_shp_ov_class_collection.html"><param name="ImageNumber" value="11"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Name" value="FdoShpOvClassDefinition"><param name="Local" value="class_fdo_shp_ov_class_definition.html"><param name="ImageNumber" value="11"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Name" value="FdoShpOvColumnDefinition"><param name="Local" value="class_fdo_shp_ov_column_definition.html"><param name="ImageNumber" value="11"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Name" value="FdoShpOvPhysicalSchemaMapping"><param name="Local" value="class_fdo_shp_ov_physical_schema_mapping.html"><param name="ImageNumber" value="11"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Name" value="FdoShpOvPropertyDefinition"><param name="Local" value="class_fdo_shp_ov_property_definition.html"><param name="ImageNumber" value="11"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Name" value="FdoShpOvPropertyDefinitionCollection"><param name="Local" value="class_fdo_shp_ov_property_definition_collection.html"><param name="ImageNumber" value="11"></OBJECT>
+ </UL>
+<LI><OBJECT type="text/sitemap"><param name="Name" value="Class Hierarchy"><param name="ImageNumber" value="1"></OBJECT>
+ <UL>
+ </UL>
+<LI><OBJECT type="text/sitemap"><param name="Name" value="Class Members"><param name="Local" value="functions.html"><param name="ImageNumber" value="11"></OBJECT>
+<LI><OBJECT type="text/sitemap"><param name="Name" value="File Members"><param name="Local" value="globals.html"><param name="ImageNumber" value="11"></OBJECT>
+<LI><OBJECT type="text/sitemap"><param name="Name" value="Graphical Class Hierarchy"><param name="Local" value="inherits.html"><param name="ImageNumber" value="11"></OBJECT>
+</UL>
Added: trunk/www/docs/SHP/index.hhk
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/index.hhk?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/index.hhk 2006-05-16 20:42:26+0000
@@ -0,0 +1,153 @@
+</OBJECT>
+<UL>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_class_definition_a4318e266ade8f0561246fe5385a488c.html#a4318e266ade8f0561246fe5385a488c"><param name="Name" value="_writeXml"></OBJECT>
+ <UL>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_class_definition_a4318e266ade8f0561246fe5385a488c.html#a4318e266ade8f0561246fe5385a488c"><param name="Name" value="FdoShpOvClassDefinition"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_column_definition_58f92ba87a369a97428c7d937d569c72.html#58f92ba87a369a97428c7d937d569c72"><param name="Name" value="FdoShpOvColumnDefinition"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_physical_schema_mapping_414ac55477c612f4cc898cb949f7c349.html#414ac55477c612f4cc898cb949f7c349"><param name="Name" value="FdoShpOvPhysicalSchemaMapping"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_property_definition_7eededaf3297b36ddd9445f6fcf67a01.html#7eededaf3297b36ddd9445f6fcf67a01"><param name="Name" value="FdoShpOvPropertyDefinition"></OBJECT>
+ </UL>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_class_collection_3f8d21ceb843d89dd1501c5345e959ce.html#3f8d21ceb843d89dd1501c5345e959ce"><param name="Name" value="Create"></OBJECT>
+ <UL>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_class_collection_3f8d21ceb843d89dd1501c5345e959ce.html#3f8d21ceb843d89dd1501c5345e959ce"><param name="Name" value="FdoShpOvClassCollection"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_class_definition_74352faa22702f58a3ed79591635dffb.html#74352faa22702f58a3ed79591635dffb"><param name="Name" value="FdoShpOvClassDefinition"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_column_definition_71f1cbc25bd5085cd546450015067b08.html#71f1cbc25bd5085cd546450015067b08"><param name="Name" value="FdoShpOvColumnDefinition"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_physical_schema_mapping_29a8cbc220b2489ec8894212e55e6a63.html#29a8cbc220b2489ec8894212e55e6a63"><param name="Name" value="FdoShpOvPhysicalSchemaMapping"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_property_definition_7ea7dfeeb0bf291c7a8049415300c66f.html#7ea7dfeeb0bf291c7a8049415300c66f"><param name="Name" value="FdoShpOvPropertyDefinition"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_property_definition_collection_c242cc50d3484173bd53f93d49b748cd.html#c242cc50d3484173bd53f93d49b748cd"><param name="Name" value="FdoShpOvPropertyDefinitionCollection"></OBJECT>
+ </UL>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_class_collection_c5568ebf824873a81cae138f1f72c0a7.html#c5568ebf824873a81cae138f1f72c0a7"><param name="Name" value="Dispose"></OBJECT>
+ <UL>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_class_collection_c5568ebf824873a81cae138f1f72c0a7.html#c5568ebf824873a81cae138f1f72c0a7"><param name="Name" value="FdoShpOvClassCollection"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_class_definition_3212ae28553647cef5b24eea5be5d182.html#3212ae28553647cef5b24eea5be5d182"><param name="Name" value="FdoShpOvClassDefinition"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_column_definition_eca75a56d812c8a7bd40dbc5bb303adc.html#eca75a56d812c8a7bd40dbc5bb303adc"><param name="Name" value="FdoShpOvColumnDefinition"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_physical_schema_mapping_8ff550c78afad1e00544a0393a17fa7c.html#8ff550c78afad1e00544a0393a17fa7c"><param name="Name" value="FdoShpOvPhysicalSchemaMapping"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_property_definition_944e21212809bf59f3c838980f77bcde.html#944e21212809bf59f3c838980f77bcde"><param name="Name" value="FdoShpOvPropertyDefinition"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_property_definition_collection_1c61c73f46f6077d623451c5b73c66cd.html#1c61c73f46f6077d623451c5b73c66cd"><param name="Name" value="FdoShpOvPropertyDefinitionCollection"></OBJECT>
+ </UL>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="_fdo_shp_class_collection_8h.html"><param name="Name" value="FdoShpClassCollection.h"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="_fdo_shp_class_definition_8h.html"><param name="Name" value="FdoShpClassDefinition.h"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="_fdo_shp_column_definition_8h.html"><param name="Name" value="FdoShpColumnDefinition.h"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_class_collection.html"><param name="Name" value="FdoShpOvClassCollection"></OBJECT>
+ <UL>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_class_collection.html#3f8d21ceb843d89dd1501c5345e959ce"><param name="Name" value="Create"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_class_collection.html#c5568ebf824873a81cae138f1f72c0a7"><param name="Name" value="Dispose"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_class_collection.html#2075c326880b1d10e848791f5c781ef2"><param name="Name" value="FdoShpOvClassCollection"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_class_collection.html#d49972d5035851fc525d319fdd0ac0de"><param name="Name" value="~FdoShpOvClassCollection"></OBJECT>
+ </UL>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="_fdo_shp_class_collection_8h_e68feb280094416a66eb2e7f7ad86837.html#e68feb280094416a66eb2e7f7ad86837"><param name="Name" value="FdoShpOvClassCollectionP"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_class_definition.html"><param name="Name" value="FdoShpOvClassDefinition"></OBJECT>
+ <UL>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_class_definition.html#a4318e266ade8f0561246fe5385a488c"><param name="Name" value="_writeXml"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_class_definition.html#74352faa22702f58a3ed79591635dffb"><param name="Name" value="Create"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_class_definition.html#3212ae28553647cef5b24eea5be5d182"><param name="Name" value="Dispose"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_class_definition.html#5ff553ac0195587c9753b2fe95d42a61"><param name="Name" value="FdoShpOvClassDefinition"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_class_definition.html#03bd17ccb7d6f1f3509b49309073d154"><param name="Name" value="FindByColumnName"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_class_definition.html#c4fd98e86e1b061f3314ee5eb6664030"><param name="Name" value="GetProperties"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_class_definition.html#f7f39af97bbd5e5644196196f322f02c"><param name="Name" value="GetShapeFile"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_class_definition.html#03246baa324656d80807273c8669082f"><param name="Name" value="InitFromXml"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_class_definition.html#1e811303f7da9de17189d3b91b40df17"><param name="Name" value="IsPathUpdated"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_class_definition.html#58b334144a66fdd59ca905faa384cedc"><param name="Name" value="SetPathUpdated"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_class_definition.html#231e0376b3239b584382401389a74991"><param name="Name" value="SetShapeFile"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_class_definition.html#d27f1b55c70e4ff58df6df488f8abf9b"><param name="Name" value="XmlEndElement"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_class_definition.html#73405bd93a5068e2c0125076ef82b0ae"><param name="Name" value="XmlStartElement"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_class_definition.html#2de74cf4ba695c3a27f84d924fae13d1"><param name="Name" value="~FdoShpOvClassDefinition"></OBJECT>
+ </UL>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="_fdo_shp_class_definition_8h_e6c80e15cb30580f4a33f0b0bf25875a.html#e6c80e15cb30580f4a33f0b0bf25875a"><param name="Name" value="FdoShpOvClassDefinitionP"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_column_definition.html"><param name="Name" value="FdoShpOvColumnDefinition"></OBJECT>
+ <UL>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_column_definition.html#58f92ba87a369a97428c7d937d569c72"><param name="Name" value="_writeXml"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_column_definition.html#71f1cbc25bd5085cd546450015067b08"><param name="Name" value="Create"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_column_definition.html#eca75a56d812c8a7bd40dbc5bb303adc"><param name="Name" value="Dispose"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_column_definition.html#90d84295b5cbbda30ca5e3d66a895cff"><param name="Name" value="FdoShpOvColumnDefinition"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_column_definition.html#d8671acab0db72d517012189859cdafe"><param name="Name" value="InitFromXml"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_column_definition.html#fff19eb49dc45425fdb3ef7e1a8cc34f"><param name="Name" value="XmlEndElement"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_column_definition.html#64d163015f3c021b5dc5fbe6105ff89a"><param name="Name" value="XmlStartElement"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_column_definition.html#343c8b7cbb45e9ad7aefbd97f7879ec3"><param name="Name" value="~FdoShpOvColumnDefinition"></OBJECT>
+ </UL>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="_fdo_shp_column_definition_8h_f44b3b0db4b0df599032ed54748aff07.html#f44b3b0db4b0df599032ed54748aff07"><param name="Name" value="FdoShpOvColumnDefinitionP"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_physical_schema_mapping.html"><param name="Name" value="FdoShpOvPhysicalSchemaMapping"></OBJECT>
+ <UL>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_physical_schema_mapping.html#414ac55477c612f4cc898cb949f7c349"><param name="Name" value="_writeXml"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_physical_schema_mapping.html#29a8cbc220b2489ec8894212e55e6a63"><param name="Name" value="Create"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_physical_schema_mapping.html#8ff550c78afad1e00544a0393a17fa7c"><param name="Name" value="Dispose"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_physical_schema_mapping.html#57b8da135b87b7df5b0400cc07536f44"><param name="Name" value="FdoShpOvPhysicalSchemaMapping"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_physical_schema_mapping.html#d89ecf4a8c025d05c75aa9412a37284f"><param name="Name" value="FindByClassName"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_physical_schema_mapping.html#bc4cb63ab21fc31035d25cc8852a3046"><param name="Name" value="FindByShapefile"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_physical_schema_mapping.html#4f696de2a2bcba8d7f83892e3a3f2bbe"><param name="Name" value="GetClasses"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_physical_schema_mapping.html#e34e818940d63ab41db19c2e73a107d1"><param name="Name" value="GetProvider"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_physical_schema_mapping.html#323760df2b4697a81b70b1a4d494b401"><param name="Name" value="InitFromXml"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_physical_schema_mapping.html#39b1326a353fa925aca33e51952f2e97"><param name="Name" value="XmlEndElement"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_physical_schema_mapping.html#a09f3b41a60fa1d6adf257252bbe5670"><param name="Name" value="XmlStartElement"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_physical_schema_mapping.html#aa23c8e7b0c5f94a2c5fe96d62bb96b0"><param name="Name" value="~FdoShpOvPhysicalSchemaMapping"></OBJECT>
+ </UL>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="_fdo_shp_physical_schema_mapping_8h_01dee688aae19647cd329e59b751a1c9.html#01dee688aae19647cd329e59b751a1c9"><param name="Name" value="FdoShpOvPhysicalSchemaMappingP"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_property_definition.html"><param name="Name" value="FdoShpOvPropertyDefinition"></OBJECT>
+ <UL>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_property_definition.html#7eededaf3297b36ddd9445f6fcf67a01"><param name="Name" value="_writeXml"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_property_definition.html#7ea7dfeeb0bf291c7a8049415300c66f"><param name="Name" value="Create"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_property_definition.html#944e21212809bf59f3c838980f77bcde"><param name="Name" value="Dispose"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_property_definition.html#28f724d715783bd56d4ee112b182d6d6"><param name="Name" value="FdoShpOvPropertyDefinition"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_property_definition.html#4be129d8f231d3c80f4b5d8f67d55b3d"><param name="Name" value="GetColumn"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_property_definition.html#c41a3a6e4a1d09b8f9174dce7c6f6b25"><param name="Name" value="InitFromXml"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_property_definition.html#b2e5583363bffe8483b92ca1dae3a6c7"><param name="Name" value="SetColumn"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_property_definition.html#3247a059e0eb2c1f60c516e81739058e"><param name="Name" value="XmlEndElement"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_property_definition.html#31b64b4fe2e08635300ddac43e8cca96"><param name="Name" value="XmlStartElement"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_property_definition.html#0b52161945add0910480f452d9ac2bc0"><param name="Name" value="~FdoShpOvPropertyDefinition"></OBJECT>
+ </UL>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_property_definition_collection.html"><param name="Name" value="FdoShpOvPropertyDefinitionCollection"></OBJECT>
+ <UL>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_property_definition_collection.html#c242cc50d3484173bd53f93d49b748cd"><param name="Name" value="Create"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_property_definition_collection.html#1c61c73f46f6077d623451c5b73c66cd"><param name="Name" value="Dispose"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_property_definition_collection.html#9dcd52a0dfe26c64474d8b0688437ab2"><param name="Name" value="FdoShpOvPropertyDefinitionCollection"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_property_definition_collection.html#d3eed0522918ece73f92aa1340718aeb"><param name="Name" value="~FdoShpOvPropertyDefinitionCollection"></OBJECT>
+ </UL>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="_fdo_shp_property_definition_collection_8h_c523fa2a650dbc38df6576e0a1e8cbb6.html#c523fa2a650dbc38df6576e0a1e8cbb6"><param name="Name" value="FdoShpOvPropertyDefinitionCollectionP"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="_fdo_shp_property_definition_8h_a8352482cc4887e6db2714402dbe3d57.html#a8352482cc4887e6db2714402dbe3d57"><param name="Name" value="FdoShpOvPropertyDefinitionP"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="_fdo_shp_physical_schema_mapping_8h.html"><param name="Name" value="FdoShpPhysicalSchemaMapping.h"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="_fdo_shp_property_definition_8h.html"><param name="Name" value="FdoShpPropertyDefinition.h"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="_fdo_shp_property_definition_collection_8h.html"><param name="Name" value="FdoShpPropertyDefinitionCollection.h"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_physical_schema_mapping_d89ecf4a8c025d05c75aa9412a37284f.html#d89ecf4a8c025d05c75aa9412a37284f"><param name="Name" value="FindByClassName"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_class_definition_03bd17ccb7d6f1f3509b49309073d154.html#03bd17ccb7d6f1f3509b49309073d154"><param name="Name" value="FindByColumnName"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_physical_schema_mapping_bc4cb63ab21fc31035d25cc8852a3046.html#bc4cb63ab21fc31035d25cc8852a3046"><param name="Name" value="FindByShapefile"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_physical_schema_mapping_4f696de2a2bcba8d7f83892e3a3f2bbe.html#4f696de2a2bcba8d7f83892e3a3f2bbe"><param name="Name" value="GetClasses"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_property_definition_4be129d8f231d3c80f4b5d8f67d55b3d.html#4be129d8f231d3c80f4b5d8f67d55b3d"><param name="Name" value="GetColumn"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_class_definition_c4fd98e86e1b061f3314ee5eb6664030.html#c4fd98e86e1b061f3314ee5eb6664030"><param name="Name" value="GetProperties"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_physical_schema_mapping_e34e818940d63ab41db19c2e73a107d1.html#e34e818940d63ab41db19c2e73a107d1"><param name="Name" value="GetProvider"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_class_definition_f7f39af97bbd5e5644196196f322f02c.html#f7f39af97bbd5e5644196196f322f02c"><param name="Name" value="GetShapeFile"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_class_definition_03246baa324656d80807273c8669082f.html#03246baa324656d80807273c8669082f"><param name="Name" value="InitFromXml"></OBJECT>
+ <UL>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_class_definition_03246baa324656d80807273c8669082f.html#03246baa324656d80807273c8669082f"><param name="Name" value="FdoShpOvClassDefinition"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_column_definition_d8671acab0db72d517012189859cdafe.html#d8671acab0db72d517012189859cdafe"><param name="Name" value="FdoShpOvColumnDefinition"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_physical_schema_mapping_323760df2b4697a81b70b1a4d494b401.html#323760df2b4697a81b70b1a4d494b401"><param name="Name" value="FdoShpOvPhysicalSchemaMapping"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_property_definition_c41a3a6e4a1d09b8f9174dce7c6f6b25.html#c41a3a6e4a1d09b8f9174dce7c6f6b25"><param name="Name" value="FdoShpOvPropertyDefinition"></OBJECT>
+ </UL>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_class_definition_1e811303f7da9de17189d3b91b40df17.html#1e811303f7da9de17189d3b91b40df17"><param name="Name" value="IsPathUpdated"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_property_definition_b2e5583363bffe8483b92ca1dae3a6c7.html#b2e5583363bffe8483b92ca1dae3a6c7"><param name="Name" value="SetColumn"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_class_definition_58b334144a66fdd59ca905faa384cedc.html#58b334144a66fdd59ca905faa384cedc"><param name="Name" value="SetPathUpdated"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_class_definition_231e0376b3239b584382401389a74991.html#231e0376b3239b584382401389a74991"><param name="Name" value="SetShapeFile"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_class_definition_d27f1b55c70e4ff58df6df488f8abf9b.html#d27f1b55c70e4ff58df6df488f8abf9b"><param name="Name" value="XmlEndElement"></OBJECT>
+ <UL>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_class_definition_d27f1b55c70e4ff58df6df488f8abf9b.html#d27f1b55c70e4ff58df6df488f8abf9b"><param name="Name" value="FdoShpOvClassDefinition"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_column_definition_fff19eb49dc45425fdb3ef7e1a8cc34f.html#fff19eb49dc45425fdb3ef7e1a8cc34f"><param name="Name" value="FdoShpOvColumnDefinition"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_physical_schema_mapping_39b1326a353fa925aca33e51952f2e97.html#39b1326a353fa925aca33e51952f2e97"><param name="Name" value="FdoShpOvPhysicalSchemaMapping"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_property_definition_3247a059e0eb2c1f60c516e81739058e.html#3247a059e0eb2c1f60c516e81739058e"><param name="Name" value="FdoShpOvPropertyDefinition"></OBJECT>
+ </UL>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_class_definition_73405bd93a5068e2c0125076ef82b0ae.html#73405bd93a5068e2c0125076ef82b0ae"><param name="Name" value="XmlStartElement"></OBJECT>
+ <UL>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_class_definition_73405bd93a5068e2c0125076ef82b0ae.html#73405bd93a5068e2c0125076ef82b0ae"><param name="Name" value="FdoShpOvClassDefinition"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_column_definition_64d163015f3c021b5dc5fbe6105ff89a.html#64d163015f3c021b5dc5fbe6105ff89a"><param name="Name" value="FdoShpOvColumnDefinition"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_physical_schema_mapping_a09f3b41a60fa1d6adf257252bbe5670.html#a09f3b41a60fa1d6adf257252bbe5670"><param name="Name" value="FdoShpOvPhysicalSchemaMapping"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_property_definition_31b64b4fe2e08635300ddac43e8cca96.html#31b64b4fe2e08635300ddac43e8cca96"><param name="Name" value="FdoShpOvPropertyDefinition"></OBJECT>
+ </UL>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_class_collection_d49972d5035851fc525d319fdd0ac0de.html#d49972d5035851fc525d319fdd0ac0de"><param name="Name" value="~FdoShpOvClassCollection"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_class_definition_2de74cf4ba695c3a27f84d924fae13d1.html#2de74cf4ba695c3a27f84d924fae13d1"><param name="Name" value="~FdoShpOvClassDefinition"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_column_definition_343c8b7cbb45e9ad7aefbd97f7879ec3.html#343c8b7cbb45e9ad7aefbd97f7879ec3"><param name="Name" value="~FdoShpOvColumnDefinition"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_physical_schema_mapping_aa23c8e7b0c5f94a2c5fe96d62bb96b0.html#aa23c8e7b0c5f94a2c5fe96d62bb96b0"><param name="Name" value="~FdoShpOvPhysicalSchemaMapping"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_property_definition_0b52161945add0910480f452d9ac2bc0.html#0b52161945add0910480f452d9ac2bc0"><param name="Name" value="~FdoShpOvPropertyDefinition"></OBJECT>
+ <LI><OBJECT type="text/sitemap"><param name="Local" value="class_fdo_shp_ov_property_definition_collection_d3eed0522918ece73f92aa1340718aeb.html#d3eed0522918ece73f92aa1340718aeb"><param name="Name" value="~FdoShpOvPropertyDefinitionCollection"></OBJECT>
+</UL>
Added: trunk/www/docs/SHP/index.hhp
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/index.hhp?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/index.hhp 2006-05-16 20:42:26+0000
@@ -0,0 +1,119 @@
+[OPTIONS]
+Compiled file=../../../SHP_Provider_API.chm
+Compatibility=1.1
+Full-text search=Yes
+Contents file=index.hhc
+Default Window=main
+Default topic=main.html
+Index file=index.hhk
+Language=0x409 English (United States)
+Binary TOC=YES
+Title=FDO Provider for SHP
+[WINDOWS]
+main="FDO Provider for SHP","index.hhc","index.hhk","main.html","main.html",,,,,0x23520,,0x387e,,,,,,,,0
+[FILES]
+main.html
+files.html
+define__pages_8h-source.html
+_fdo_shp_class_collection_8h-source.html
+_fdo_shp_class_definition_8h-source.html
+_fdo_shp_column_definition_8h-source.html
+_fdo_shp_physical_schema_mapping_8h-source.html
+_fdo_shp_property_definition_8h-source.html
+_fdo_shp_property_definition_collection_8h-source.html
+define__pages_8h.html
+_fdo_shp_class_collection_8h.html
+_fdo_shp_class_collection_8h_e68feb280094416a66eb2e7f7ad86837.html
+_fdo_shp_class_definition_8h.html
+_fdo_shp_class_definition_8h_e6c80e15cb30580f4a33f0b0bf25875a.html
+_fdo_shp_column_definition_8h.html
+_fdo_shp_column_definition_8h_f44b3b0db4b0df599032ed54748aff07.html
+_fdo_shp_physical_schema_mapping_8h.html
+_fdo_shp_physical_schema_mapping_8h_01dee688aae19647cd329e59b751a1c9.html
+_fdo_shp_property_definition_8h.html
+_fdo_shp_property_definition_8h_a8352482cc4887e6db2714402dbe3d57.html
+_fdo_shp_property_definition_collection_8h.html
+_fdo_shp_property_definition_collection_8h_c523fa2a650dbc38df6576e0a1e8cbb6.html
+annotated.html
+classes.html
+hierarchy.html
+functions.html
+functions_func.html
+class_fdo_shp_ov_class_collection.html
+class_fdo_shp_ov_class_collection_2075c326880b1d10e848791f5c781ef2.html
+class_fdo_shp_ov_class_collection_7ca47202e723ee690e94240c2dbaa22b.html
+class_fdo_shp_ov_class_collection_d49972d5035851fc525d319fdd0ac0de.html
+class_fdo_shp_ov_class_collection_3f8d21ceb843d89dd1501c5345e959ce.html
+class_fdo_shp_ov_class_collection_e71697e929d4ac5b62f7fc9fcdfcec8f.html
+class_fdo_shp_ov_class_collection_c5568ebf824873a81cae138f1f72c0a7.html
+class_fdo_shp_ov_class_collection-members.html
+class_fdo_shp_ov_class_definition.html
+class_fdo_shp_ov_class_definition_5ff553ac0195587c9753b2fe95d42a61.html
+class_fdo_shp_ov_class_definition_2de74cf4ba695c3a27f84d924fae13d1.html
+class_fdo_shp_ov_class_definition_a4318e266ade8f0561246fe5385a488c.html
+class_fdo_shp_ov_class_definition_74352faa22702f58a3ed79591635dffb.html
+class_fdo_shp_ov_class_definition_3212ae28553647cef5b24eea5be5d182.html
+class_fdo_shp_ov_class_definition_03bd17ccb7d6f1f3509b49309073d154.html
+class_fdo_shp_ov_class_definition_c4fd98e86e1b061f3314ee5eb6664030.html
+class_fdo_shp_ov_class_definition_f7f39af97bbd5e5644196196f322f02c.html
+class_fdo_shp_ov_class_definition_03246baa324656d80807273c8669082f.html
+class_fdo_shp_ov_class_definition_1e811303f7da9de17189d3b91b40df17.html
+class_fdo_shp_ov_class_definition_58b334144a66fdd59ca905faa384cedc.html
+class_fdo_shp_ov_class_definition_231e0376b3239b584382401389a74991.html
+class_fdo_shp_ov_class_definition_d27f1b55c70e4ff58df6df488f8abf9b.html
+class_fdo_shp_ov_class_definition_73405bd93a5068e2c0125076ef82b0ae.html
+class_fdo_shp_ov_class_definition-members.html
+class_fdo_shp_ov_column_definition.html
+class_fdo_shp_ov_column_definition_90d84295b5cbbda30ca5e3d66a895cff.html
+class_fdo_shp_ov_column_definition_343c8b7cbb45e9ad7aefbd97f7879ec3.html
+class_fdo_shp_ov_column_definition_58f92ba87a369a97428c7d937d569c72.html
+class_fdo_shp_ov_column_definition_71f1cbc25bd5085cd546450015067b08.html
+class_fdo_shp_ov_column_definition_eca75a56d812c8a7bd40dbc5bb303adc.html
+class_fdo_shp_ov_column_definition_d8671acab0db72d517012189859cdafe.html
+class_fdo_shp_ov_column_definition_fff19eb49dc45425fdb3ef7e1a8cc34f.html
+class_fdo_shp_ov_column_definition_64d163015f3c021b5dc5fbe6105ff89a.html
+class_fdo_shp_ov_column_definition-members.html
+class_fdo_shp_ov_physical_schema_mapping.html
+class_fdo_shp_ov_physical_schema_mapping_57b8da135b87b7df5b0400cc07536f44.html
+class_fdo_shp_ov_physical_schema_mapping_aa23c8e7b0c5f94a2c5fe96d62bb96b0.html
+class_fdo_shp_ov_physical_schema_mapping_414ac55477c612f4cc898cb949f7c349.html
+class_fdo_shp_ov_physical_schema_mapping_29a8cbc220b2489ec8894212e55e6a63.html
+class_fdo_shp_ov_physical_schema_mapping_8ff550c78afad1e00544a0393a17fa7c.html
+class_fdo_shp_ov_physical_schema_mapping_d89ecf4a8c025d05c75aa9412a37284f.html
+class_fdo_shp_ov_physical_schema_mapping_bc4cb63ab21fc31035d25cc8852a3046.html
+class_fdo_shp_ov_physical_schema_mapping_4f696de2a2bcba8d7f83892e3a3f2bbe.html
+class_fdo_shp_ov_physical_schema_mapping_e34e818940d63ab41db19c2e73a107d1.html
+class_fdo_shp_ov_physical_schema_mapping_323760df2b4697a81b70b1a4d494b401.html
+class_fdo_shp_ov_physical_schema_mapping_39b1326a353fa925aca33e51952f2e97.html
+class_fdo_shp_ov_physical_schema_mapping_a09f3b41a60fa1d6adf257252bbe5670.html
+class_fdo_shp_ov_physical_schema_mapping-members.html
+class_fdo_shp_ov_property_definition.html
+class_fdo_shp_ov_property_definition_28f724d715783bd56d4ee112b182d6d6.html
+class_fdo_shp_ov_property_definition_0b52161945add0910480f452d9ac2bc0.html
+class_fdo_shp_ov_property_definition_7eededaf3297b36ddd9445f6fcf67a01.html
+class_fdo_shp_ov_property_definition_7ea7dfeeb0bf291c7a8049415300c66f.html
+class_fdo_shp_ov_property_definition_944e21212809bf59f3c838980f77bcde.html
+class_fdo_shp_ov_property_definition_4be129d8f231d3c80f4b5d8f67d55b3d.html
+class_fdo_shp_ov_property_definition_c41a3a6e4a1d09b8f9174dce7c6f6b25.html
+class_fdo_shp_ov_property_definition_b2e5583363bffe8483b92ca1dae3a6c7.html
+class_fdo_shp_ov_property_definition_3247a059e0eb2c1f60c516e81739058e.html
+class_fdo_shp_ov_property_definition_31b64b4fe2e08635300ddac43e8cca96.html
+class_fdo_shp_ov_property_definition-members.html
+class_fdo_shp_ov_property_definition_collection.html
+class_fdo_shp_ov_property_definition_collection_9dcd52a0dfe26c64474d8b0688437ab2.html
+class_fdo_shp_ov_property_definition_collection_6e8f77facd3026d3207b96bfd7e558e0.html
+class_fdo_shp_ov_property_definition_collection_d3eed0522918ece73f92aa1340718aeb.html
+class_fdo_shp_ov_property_definition_collection_c242cc50d3484173bd53f93d49b748cd.html
+class_fdo_shp_ov_property_definition_collection_bd6b681557f031ced9d12cb5905ce3e8.html
+class_fdo_shp_ov_property_definition_collection_1c61c73f46f6077d623451c5b73c66cd.html
+class_fdo_shp_ov_property_definition_collection-members.html
+globals.html
+globals_type.html
+graph_legend.html
+inherits.html
+tabs.css
Added: trunk/www/docs/SHP/index.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/index.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/index.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,8 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
+<html><head><meta http-equiv="Content-Type" content="text/html;charset=iso-8859-1">
+<title>FDO Provider for SHP</title></head>
+<frameset cols="250,*">
+ <frame src="tree.html" name="treefrm">
+ <frame src="main.html" name="basefrm">
+</frameset>
+</html>
Added: trunk/www/docs/SHP/inherit__graph__0.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/inherit__graph__0.map?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/inherit__graph__0.map 2006-05-16 20:42:26+0000
@@ -0,0 +1,2 @@
+base referer
+rect $class_fdo_shp_ov_class_collection.html 7,7 185,33
Added: trunk/www/docs/SHP/inherit__graph__0.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/inherit__graph__0.md5?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/inherit__graph__0.md5 2006-05-16 20:42:26+0000
@@ -0,0 +1 @@
+c343c8d5d05f2569d2e9d2579d72fd7e
\ No newline at end of file
Added: trunk/www/docs/SHP/inherit__graph__0.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/inherit__graph__0.png?view=auto&rev=15
Binary file. No diff available.
Added: trunk/www/docs/SHP/inherit__graph__1.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/inherit__graph__1.map?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/inherit__graph__1.map 2006-05-16 20:42:26+0000
@@ -0,0 +1,2 @@
+base referer
+rect $class_fdo_shp_ov_class_definition.html 7,7 183,33
Added: trunk/www/docs/SHP/inherit__graph__1.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/inherit__graph__1.md5?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/inherit__graph__1.md5 2006-05-16 20:42:26+0000
@@ -0,0 +1 @@
+78a0a5682d093ee021af70b590d924b2
Added: trunk/www/docs/SHP/inherit__graph__1.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/inherit__graph__1.png?view=auto&rev=15
Added: trunk/www/docs/SHP/inherit__graph__2.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/inherit__graph__2.map?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/inherit__graph__2.map 2006-05-16 20:42:26+0000
@@ -0,0 +1,2 @@
+base referer
+rect $class_fdo_shp_ov_column_definition.html 7,7 196,33
Added: trunk/www/docs/SHP/inherit__graph__2.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/inherit__graph__2.md5?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/inherit__graph__2.md5 2006-05-16 20:42:26+0000
@@ -0,0 +1 @@
+2adf93e4c05f2da18fc95367fd211711
Added: trunk/www/docs/SHP/inherit__graph__2.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/inherit__graph__2.png?view=auto&rev=15
Added: trunk/www/docs/SHP/inherit__graph__3.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/inherit__graph__3.map?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/inherit__graph__3.map 2006-05-16 20:42:26+0000
@@ -0,0 +1,2 @@
+base referer
+rect $class_fdo_shp_ov_physical_schema_mapping.html 7,7 244,33
Added: trunk/www/docs/SHP/inherit__graph__3.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/inherit__graph__3.md5?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/inherit__graph__3.md5 2006-05-16 20:42:26+0000
@@ -0,0 +1 @@
+5409e59a79c7b5a79a1616fc07ea04ec
Added: trunk/www/docs/SHP/inherit__graph__3.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/inherit__graph__3.png?view=auto&rev=15
Added: trunk/www/docs/SHP/inherit__graph__4.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/inherit__graph__4.map?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/inherit__graph__4.map 2006-05-16 20:42:26+0000
@@ -0,0 +1,2 @@
+base referer
+rect $class_fdo_shp_ov_property_definition.html 7,7 201,33
Added: trunk/www/docs/SHP/inherit__graph__4.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/inherit__graph__4.md5?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/inherit__graph__4.md5 2006-05-16 20:42:26+0000
@@ -0,0 +1 @@
+c50650e9b7a480e1c4f162024863b2ef
Added: trunk/www/docs/SHP/inherit__graph__4.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/inherit__graph__4.png?view=auto&rev=15
Added: trunk/www/docs/SHP/inherit__graph__5.map
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/inherit__graph__5.map?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/inherit__graph__5.map 2006-05-16 20:42:26+0000
@@ -0,0 +1,2 @@
+base referer
+rect $class_fdo_shp_ov_property_definition_collection.html 7,7 260,33
Added: trunk/www/docs/SHP/inherit__graph__5.md5
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/inherit__graph__5.md5?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/inherit__graph__5.md5 2006-05-16 20:42:26+0000
@@ -0,0 +1 @@
+cc6140421809fdcb7bbe5b7ac5ed463b
Added: trunk/www/docs/SHP/inherit__graph__5.png
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/inherit__graph__5.png?view=auto&rev=15
Added: trunk/www/docs/SHP/inherits.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/inherits.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/inherits.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,69 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li id="current"><a href="classes.html"><span>Classes</span></a></li>
+ <li><a href="files.html"><span>Files</span></a></li>
+ </ul></div>
+<div class="tabs">
+ <ul>
+ <li><a href="classes.html"><span>Alphabetical List</span></a></li>
+ <li><a href="annotated.html"><span>Class List</span></a></li>
+ <li><a href="functions.html"><span>Class Members</span></a></li>
+ </ul></div>
+<h1>FDO Provider for SHP Graphical Class Hierarchy</h1><a href="hierarchy.html">Go to the textual class hierarchy</a>
+<p>
+<table border="0" cellspacing="10" cellpadding="0">
+<tr><td><img src="inherit__graph__0.png" border="0" alt="" usemap="#_fdo_shp_ov_class_collection_map">
+<map name="_fdo_shp_ov_class_collection_map">
+<area href="class_fdo_shp_ov_class_collection.html" shape="rect" coords="7,7,185,33" alt="">
+</map></td></tr>
+<tr><td><img src="inherit__graph__1.png" border="0" alt="" usemap="#_fdo_shp_ov_class_definition_map">
+<map name="_fdo_shp_ov_class_definition_map">
+<area href="class_fdo_shp_ov_class_definition.html" shape="rect" coords="7,7,183,33" alt="">
+</map></td></tr>
+<tr><td><img src="inherit__graph__2.png" border="0" alt="" usemap="#_fdo_shp_ov_column_definition_map">
+<map name="_fdo_shp_ov_column_definition_map">
+<area href="class_fdo_shp_ov_column_definition.html" shape="rect" coords="7,7,196,33" alt="">
+</map></td></tr>
+<tr><td><img src="inherit__graph__3.png" border="0" alt="" usemap="#_fdo_shp_ov_physical_schema_mapping_map">
+<map name="_fdo_shp_ov_physical_schema_mapping_map">
+<area href="class_fdo_shp_ov_physical_schema_mapping.html" shape="rect" coords="7,7,244,33" alt="">
+</map></td></tr>
+<tr><td><img src="inherit__graph__4.png" border="0" alt="" usemap="#_fdo_shp_ov_property_definition_map">
+<map name="_fdo_shp_ov_property_definition_map">
+<area href="class_fdo_shp_ov_property_definition.html" shape="rect" coords="7,7,201,33" alt="">
+</map></td></tr>
+<tr><td><img src="inherit__graph__5.png" border="0" alt="" usemap="#_fdo_shp_ov_property_definition_collection_map">
+<map name="_fdo_shp_ov_property_definition_collection_map">
+<area href="class_fdo_shp_ov_property_definition_collection.html" shape="rect" coords="7,7,260,33" alt="">
+</map></td></tr>
+</table>
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/main.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/main.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/main.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,56 @@
+<html>
+ <head>
+ </head>
+ <tr>
+ </tr>
+ </table>
+<div class="tabs">
+ <ul>
+ <li id="current"><a href="main.html"><span>Main Page</span></a></li>
+ <li><a href="classes.html"><span>Classes</span></a></li>
+ </ul></div>
+<h1>Introduction</h1>
+<p>
+<div class="mainpage"></div><p>
+<div class="mainpage">The Feature Data Objects (FDO) API provides access to data in a data store. A provider is a specific implementation of the FDO API that provides access to data in a particular data store. The FDO Provider for SHP provides FDO with access to a SHP-based data store. </div><p>
+<div class="mainpage">The FDO Provider for SHP uses a standalone file format that supports GIS data. The FDO Provider for SHP (Shape) has the following characteristics: <ul>
+<li>
+Read-only access is provided to pre-existing spatial and attribute data from an Environmental Systems Research Institute (ESRI) Shape file (SHP). </li>
+<li>
+The FDO Provider for SHP can run in a multi-platform environment, including Windows and Linux. </li>
+<li>
+A Shape file consists of three separate files: SHP (shape geometry), SHX (shape index), and DBF (shape attributes in dBASE format). </li>
+<li>
+The FDO Provider for SHP accesses the information in each of the three separate files, and treats each SHP, and its associated DBF file, as a feature class with a single geometry property, and optionally, with data attribute properties. </li>
+<li>
+Schema configuration of the data store is provided to the FDO Provider for SHP through an XML file containing the Geographic Markup Language (GML) definition of the schema that maps SHP and DBF data in the data store to feature classes and property mappings in the FDO data model. </li>
+<li>
+Although it does not support concurrency control (locking), the SHP file format is a valid alternative to RDBMS. </li>
+</ul>
+</div><p>
+<div class="mainpage"> For more information, see <em>The Essential FDO</em> (FET_TheEssentialFDO.pdf) and the <em>FDO Developer's Guide</em> (FDG_FDODevGuide.pdf). </div><p>
+<div class="mainpage"><br>
+ </div> <!-- footer.html -->
+ <hr>
+ <tr>
+ </tr>
+ </table>
+ </body>
+</html>
Added: trunk/www/docs/SHP/tab_b.gif
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/tab_b.gif?view=auto&rev=15
Added: trunk/www/docs/SHP/tab_l.gif
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/tab_l.gif?view=auto&rev=15
Added: trunk/www/docs/SHP/tab_r.gif
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/tab_r.gif?view=auto&rev=15
Added: trunk/www/docs/SHP/tabs.css
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/tabs.css?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/tabs.css 2006-05-16 20:42:26+0000
@@ -0,0 +1,102 @@
+/* tabs styles, based on http://www.alistapart.com/articles/slidingdoors */
+DIV.tabs
+ float : left;
+ width : 100%;
+ background : url("tab_b.gif") repeat-x bottom;
+ margin-bottom : 4px;
+DIV.tabs UL
+ margin : 0px;
+ padding-left : 10px;
+ list-style : none;
+DIV.tabs LI, DIV.tabs FORM
+ display : inline;
+ margin : 0px;
+ padding : 0px;
+DIV.tabs FORM
+ float : right;
+DIV.tabs A
+ float : left;
+ background : url("tab_r.gif") no-repeat right top;
+ border-bottom : 1px solid #84B0C7;
+ font-size : x-small;
+ font-weight : bold;
+ text-decoration : none;
+DIV.tabs A:hover
+ background-position: 100% -150px;
+DIV.tabs A:link, DIV.tabs A:visited,
+DIV.tabs A:active, DIV.tabs A:hover
+ color: #1A419D;
+DIV.tabs SPAN
+ float : left;
+ display : block;
+ background : url("tab_l.gif") no-repeat left top;
+ padding : 5px 9px;
+ white-space : nowrap;
+DIV.tabs INPUT
+ float : right;
+ display : inline;
+ font-size : 1em;
+DIV.tabs TD
+/* Commented Backslash Hack hides rule from IE5-Mac \*/
+DIV.tabs SPAN {float : none;}
+/* End IE5-Mac hack */
+DIV.tabs A:hover SPAN
+ background-position: 0% -150px;
+DIV.tabs LI#current A
+ border-width : 0px;
+DIV.tabs LI#current SPAN
+ padding-bottom : 6px;
+DIV.nav
+ background : none;
+ border : none;
Added: trunk/www/docs/SHP/tree.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/docs/SHP/tree.html?view=auto&rev=15
--- (empty file)
+++ trunk/www/docs/SHP/tree.html 2006-05-16 20:42:26+0000
@@ -0,0 +1,110 @@
+<html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en">
+ <head>
+ <meta http-equiv="Content-Type" content="text/xhtml;charset=iso-8859-1" />
+ <meta http-equiv="Content-Style-Type" content="text/css" />
+ <meta http-equiv="Content-Language" content="en" />
+ <link rel="stylesheet" href="custom.css">
+ <title>TreeView</title>
+ <style type="text/css">
+ .directory { font-size: 10pt; font-weight: bold; }
+ .directory h3 { margin: 0px; margin-top: 1em; font-size: 11pt; }
+ .directory p { margin: 0px; white-space: nowrap; }
+ .directory div { display: none; margin: 0px; }
+ .directory img { vertical-align: middle; }
+ </style>
+ <script type="text/javascript">
+ <!-- // Hide script from old browsers
+ function toggleFolder(id, imageNode)
+ var folder = document.getElementById(id);
+ var l = imageNode.src.length;
+ if (imageNode.src.substring(l-20,l)=="ftv2folderclosed.png" ||
+ imageNode.src.substring(l-18,l)=="ftv2folderopen.png")
+ imageNode = imageNode.previousSibling;
+ l = imageNode.src.length;
+ if (folder == null)
+ else if (folder.style.display == "block")
+ if (imageNode != null)
+ imageNode.nextSibling.src = "ftv2folderclosed.png";
+ if (imageNode.src.substring(l-13,l) == "ftv2mnode.png")
+ imageNode.src = "ftv2pnode.png";
+ else if (imageNode.src.substring(l-17,l) == "ftv2mlastnode.png")
+ imageNode.src = "ftv2plastnode.png";
+ folder.style.display = "none";
+ else
+ imageNode.nextSibling.src = "ftv2folderopen.png";
+ if (imageNode.src.substring(l-13,l) == "ftv2pnode.png")
+ imageNode.src = "ftv2mnode.png";
+ else if (imageNode.src.substring(l-17,l) == "ftv2plastnode.png")
+ imageNode.src = "ftv2mlastnode.png";
+ folder.style.display = "block";
+ // End script hiding -->
+ </script>
+ </head>
+ <body>
+ <div class="directory">
+ <h3>FDO Provider for SHP</h3>
+ <div style="display: block;">
+ <p><img src="ftv2node.png" alt="o" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="main.html" target="basefrm">Introduction</a></p>
+ <p><img src="ftv2pnode.png" alt="o" width=16 height=22 onclick="toggleFolder('folder1', this)"/><img src="ftv2folderclosed.png" alt="+" width=24 height=22 onclick="toggleFolder('folder1', this)"/><a class="el" href="files.html" target="basefrm">File List</a></p>
+ <div id="folder1">
+ <p><img src="ftv2vertline.png" alt="|" width=16 height=22 /><img src="ftv2node.png" alt="o" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="define__pages_8h.html" target="basefrm">define_pages.h</a></p>
+ <p><img src="ftv2vertline.png" alt="|" width=16 height=22 /><img src="ftv2node.png" alt="o" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="_fdo_shp_class_collection_8h.html" target="basefrm">FdoShpClassCollection.h</a></p>
+ <p><img src="ftv2vertline.png" alt="|" width=16 height=22 /><img src="ftv2node.png" alt="o" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="_fdo_shp_class_definition_8h.html" target="basefrm">FdoShpClassDefinition.h</a></p>
+ <p><img src="ftv2vertline.png" alt="|" width=16 height=22 /><img src="ftv2node.png" alt="o" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="_fdo_shp_column_definition_8h.html" target="basefrm">FdoShpColumnDefinition.h</a></p>
+ <p><img src="ftv2vertline.png" alt="|" width=16 height=22 /><img src="ftv2node.png" alt="o" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="_fdo_shp_physical_schema_mapping_8h.html" target="basefrm">FdoShpPhysicalSchemaMapping.h</a></p>
+ <p><img src="ftv2vertline.png" alt="|" width=16 height=22 /><img src="ftv2node.png" alt="o" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="_fdo_shp_property_definition_8h.html" target="basefrm">FdoShpPropertyDefinition.h</a></p>
+ <p><img src="ftv2vertline.png" alt="|" width=16 height=22 /><img src="ftv2lastnode.png" alt="\" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="_fdo_shp_property_definition_collection_8h.html" target="basefrm">FdoShpPropertyDefinitionCollection.h</a></p>
+ </div>
+ <p><img src="ftv2pnode.png" alt="o" width=16 height=22 onclick="toggleFolder('folder2', this)"/><img src="ftv2folderclosed.png" alt="+" width=24 height=22 onclick="toggleFolder('folder2', this)"/><a class="el" href="annotated.html" target="basefrm">Class List</a></p>
+ <div id="folder2">
+ <p><img src="ftv2vertline.png" alt="|" width=16 height=22 /><img src="ftv2node.png" alt="o" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="class_fdo_shp_ov_class_collection.html" target="basefrm">FdoShpOvClassCollection</a></p>
+ <p><img src="ftv2vertline.png" alt="|" width=16 height=22 /><img src="ftv2node.png" alt="o" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="class_fdo_shp_ov_class_definition.html" target="basefrm">FdoShpOvClassDefinition</a></p>
+ <p><img src="ftv2vertline.png" alt="|" width=16 height=22 /><img src="ftv2node.png" alt="o" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="class_fdo_shp_ov_column_definition.html" target="basefrm">FdoShpOvColumnDefinition</a></p>
+ <p><img src="ftv2vertline.png" alt="|" width=16 height=22 /><img src="ftv2node.png" alt="o" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="class_fdo_shp_ov_physical_schema_mapping.html" target="basefrm">FdoShpOvPhysicalSchemaMapping</a></p>
+ <p><img src="ftv2vertline.png" alt="|" width=16 height=22 /><img src="ftv2node.png" alt="o" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="class_fdo_shp_ov_property_definition.html" target="basefrm">FdoShpOvPropertyDefinition</a></p>
+ <p><img src="ftv2vertline.png" alt="|" width=16 height=22 /><img src="ftv2lastnode.png" alt="\" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="class_fdo_shp_ov_property_definition_collection.html" target="basefrm">FdoShpOvPropertyDefinitionCollection</a></p>
+ </div>
+ <p><img src="ftv2pnode.png" alt="o" width=16 height=22 onclick="toggleFolder('folder3', this)"/><img src="ftv2folderclosed.png" alt="+" width=24 height=22 onclick="toggleFolder('folder3', this)"/><a class="el" href="hierarchy.html" target="basefrm">Class Hierarchy</a></p>
+ <div id="folder3">
+ </div>
+ <p><img src="ftv2node.png" alt="o" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="functions.html" target="basefrm">Class Members</a></p>
+ <p><img src="ftv2node.png" alt="o" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="globals.html" target="basefrm">File Members</a></p>
+ <p><img src="ftv2lastnode.png" alt="\" width=16 height=22 /><img src="ftv2doc.png" alt="*" width=24 height=22 /><a class="el" href="inherits.html" target="basefrm">Graphical Class Hierarchy</a></p>
+ </div>
+ </div>
+ </body>
+</html>
More information about the Fdo-commits
