svn commit: r67 - trunk/www/fdo32.html
gregboone at osgeo.org
Thu Oct 19 18:21:39 EDT 2006
Author: gregboone
Date: 2006-10-19 22:21:38+0000
New Revision: 67
FDO111: Update FDO Web Documentation
Modified: trunk/www/fdo32.html
Url: https://fdo.osgeo.org/source/browse/fdo/trunk/www/fdo32.html?view=diff&rev=67&p1=trunk/www/fdo32.html&p2=trunk/www/fdo32.html&r1=66&r2=67
--- trunk/www/fdo32.html (original)
+++ trunk/www/fdo32.html 2006-10-19 22:21:38+0000
@@ -9,208 +9,6 @@
<meta name=Originator content="Microsoft Word 11">
<link rel=File-List href="7EFFBFBD_files/filelist.xml">
<link rel=Edit-Time-Data href="7EFFBFBD_files/editdata.mso">
-<!--[if gte mso 9]><xml>
- <o:DocumentProperties>
- <o:Author>GB</o:Author>
- <o:Revision>1</o:Revision>
- <o:TotalTime>0</o:TotalTime>
- <o:Created>2006-10-19T21:58:00Z</o:Created>
- <o:Pages>1</o:Pages>
- <o:Words>2011</o:Words>
- <o:Characters>11465</o:Characters>
- <o:Company>Autodesk, Inc.</o:Company>
- <o:Lines>95</o:Lines>
- <o:Paragraphs>26</o:Paragraphs>
- <o:CharactersWithSpaces>13450</o:CharactersWithSpaces>
- <o:Version>11.6408</o:Version>
- </o:DocumentProperties>
-</xml><![endif]--><!--[if gte mso 9]><xml>
- <w:WordDocument>
- <w:View>Normal</w:View>
- <w:Zoom>0</w:Zoom>
- <w:SpellingState>Clean</w:SpellingState>
- <w:GrammarState>Clean</w:GrammarState>
- <w:DocumentKind>DocumentEmail</w:DocumentKind>
- <w:EnvelopeVis/>
- <w:PunctuationKerning/>
- <w:ValidateAgainstSchemas/>
- <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid>
- <w:IgnoreMixedContent>false</w:IgnoreMixedContent>
- <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText>
- <w:Compatibility>
- <w:BreakWrappedTables/>
- <w:SnapToGridInCell/>
- <w:WrapTextWithPunct/>
- <w:UseAsianBreakRules/>
- <w:DontGrowAutofit/>
- <w:UseFELayout/>
- </w:Compatibility>
- <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel>
- </w:WordDocument>
- <w:LatentStyles DefLockedState="false" LatentStyleCount="156">
- </w:LatentStyles>
-</xml><![endif]-->
-<style>
- /* Font Definitions */
- @font-face
- {font-family:"MS Mincho";
- panose-1:2 2 6 9 4 2 5 8 3 4;
- mso-font-alt:"\FF2D\FF33 \660E\671D";
- mso-font-charset:128;
- mso-generic-font-family:modern;
- mso-font-pitch:fixed;
- mso-font-signature:-1610612033 1757936891 16 0 131231 0;}
- at font-face
- {font-family:"\@MS Mincho";
- /* Style Definitions */
- p.MsoNormal, li.MsoNormal, div.MsoNormal
- {mso-style-parent:"";
- margin:0in;
- margin-bottom:.0001pt;
- mso-pagination:widow-orphan;
- font-size:12.0pt;
- font-family:"Times New Roman";
- mso-fareast-font-family:"MS Mincho";}
-h1
- {margin-top:12.0pt;
- margin-right:0in;
- margin-bottom:3.0pt;
- margin-left:0in;
- page-break-after:avoid;
- mso-outline-level:1;
- font-size:16.0pt;
- font-family:Arial;}
-h2
- margin-right:0in;
- margin-left:0in;
- mso-outline-level:2;
- font-size:14.0pt;
-h3
- margin-right:0in;
- margin-left:0in;
- mso-outline-level:3;
- font-size:12.0pt;
-a:link, span.MsoHyperlink
- {color:blue;
- text-decoration:underline;
- text-underline:single;}
-a:visited, span.MsoHyperlinkFollowed
- {color:purple;
-span.EmailStyle17
- {mso-style-type:personal-compose;
- mso-style-noshow:yes;
- mso-ansi-font-size:10.0pt;
- mso-bidi-font-size:10.0pt;
- mso-ascii-font-family:Arial;
- mso-hansi-font-family:Arial;
- mso-bidi-font-family:Arial;
- color:windowtext;}
-span.SpellE
- {mso-style-name:"";
- mso-spl-e:yes;}
-span.GramE
- mso-gram-e:yes;}
- at page Section1
- {size:8.5in 11.0in;
- margin:1.0in 1.25in 1.0in 1.25in;
- mso-header-margin:.5in;
- mso-footer-margin:.5in;
- mso-paper-source:0;}
-div.Section1
- {page:Section1;}
- /* List Definitions */
- @list l0
- {mso-list-id:1903252227;
- mso-list-type:hybrid;
- mso-list-template-ids:-699084292 67698689 67698691 67698693 67698689 67698691 67698693 67698689 67698691 67698693;}
- at list l0:level1
- {mso-level-number-format:bullet;
- mso-level-text:\F0B7;
- mso-level-tab-stop:.25in;
- mso-level-number-position:left;
- margin-left:.25in;
- text-indent:-.25in;
- font-family:Symbol;}
- at list l0:level2
- {mso-level-tab-stop:1.0in;
- text-indent:-.25in;}
- at list l0:level3
- {mso-level-tab-stop:1.5in;
- at list l0:level4
- {mso-level-tab-stop:2.0in;
- at list l0:level5
- {mso-level-tab-stop:2.5in;
- at list l0:level6
- {mso-level-tab-stop:3.0in;
- at list l0:level7
- {mso-level-tab-stop:3.5in;
- at list l0:level8
- {mso-level-tab-stop:4.0in;
- at list l0:level9
- {mso-level-tab-stop:4.5in;
-ol
- {margin-bottom:0in;}
-ul
-</style>
-<!--[if gte mso 10]>
-<style>
- table.MsoNormalTable
- {mso-style-name:"Table Normal";
- mso-tstyle-rowband-size:0;
- mso-tstyle-colband-size:0;
- mso-style-parent:"";
- mso-padding-alt:0in 5.4pt 0in 5.4pt;
- mso-para-margin:0in;
- mso-para-margin-bottom:.0001pt;
- font-size:10.0pt;
- mso-ansi-language:#0400;
- mso-fareast-language:#0400;
- mso-bidi-language:#0400;}
-</style>
-<![endif]-->
</head>
<body lang=EN-US link=blue vlink=purple style='tab-interval:.5in'>
@@ -220,12 +18,12 @@
<h1>FDO 3.0 vs. FDO 3.2<o:p></o:p></h1>
<p class=MsoNormal>The naming conventions used in version 3.2 of the FDO API <span
-class=GramE>have been modified</span> from those exposed in version 3.0 of the
-API. These modifications <span class=GramE>were undertaken</span> to move the
-naming conventions used in the API away from its Autodesk roots and position
+class=GramE>has been modified</span> from those used in version 3.0.
+These modifications <span class=GramE>were undertaken</span> to move the
+naming convention used in 3.0 away from its Autodesk roots and position
itself within the <span class=SpellE>OSGeo</span> framework. As a result of
implementing these changes, users will be required to modify their applications
-to use the new names of the FDO classes, enumerations<span class=GramE>,
+to use the names of the renamed FDO classes, enumerations<span class=GramE>,
header</span> files, libraries, etc.<o:p></o:p></p>
<p class=MsoNormal><o:p> </o:p></p>
@@ -2018,9 +1816,9 @@
<p class=MsoNormal><i><span style='font-size:10.0pt;font-family:Arial'><o:p> </o:p></span></i></p>
-<p class=MsoNormal><i><span style='font-size:10.0pt;font-family:Arial'>The
+<p class=MsoNormal><span style='font-size:10.0pt;font-family:Arial'>The
prefix of the FDO Geometry classes changed from <span class=SpellE><span
-class=GramE>Gis</span></span> to <span class=SpellE>Fdo</span><o:p></o:p></span></i></p>
+class=GramE>Gis</span></span> to <span class=SpellE>Fdo</span><o:p></o:p></span></p>
@@ -2556,9 +2354,9 @@
prefix of the FDO Spatial classes changed from <span class=SpellE><span
<p class=MsoNormal><span style='font-size:10.0pt;font-family:Arial'><o:p> </o:p></span></p>
@@ -2647,11 +2445,11 @@
<tr style='mso-yfti-irow:0;mso-yfti-firstrow:yes'>
<td width=295 valign=top style='width:221.4pt;border:solid black 1.5pt;
border-right:none;background:gray;padding:0in 5.4pt 0in 5.4pt'>
- <p class=MsoNormal><b><span style='color:white'>3.0 Factory Method Name<o:p></o:p></span></b></p>
+ <p class=MsoNormal><b><span style='color:white'>3.0 Factory Method Names<o:p></o:p></span></b></p>
</td>
border-left:none;background:gray;padding:0in 5.4pt 0in 5.4pt'>
- <p class=MsoNormal><b><span style='color:white'>3.2 Factory Method Name<o:p></o:p></span></b></p>
+ <p class=MsoNormal><b><span style='color:white'>3.2 Factory Method Names<o:p></o:p></span></b></p>
</td>
</tr>
<tr style='mso-yfti-irow:1'>
More information about the Fdo-commits
