[fdo-commits] r702 - branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry
svn_fdo at osgeo.org
Thu Feb 1 19:09:08 EST 2007
Author: gregboone
Date: 2007-02-01 19:09:07 -0500 (Thu, 01 Feb 2007)
New Revision: 702
branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgICurvePolygon.h
branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgICurvePolygonImp.h
branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgICurveSegmentAbstract.h
branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgICurveSegmentAbstractImp.h
branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgICurveString.h
branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgICurveStringImp.h
branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgIDirectPosition.h
branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgIDirectPositionImp.h
branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgIGeometry.h
branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgIGeometryImp.h
branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgILineString.h
branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgILineStringImp.h
branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgILinearRing.h
branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgILinearRingImp.h
branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgIPoint.h
branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgIPointImp.h
branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgIPolygon.h
branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgIPolygonImp.h
branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgIRing.h
branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgIRingImp.h
893057: DOC: FDO Managed API Documentation Updates
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgICurvePolygon.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgICurvePolygon.h 2007-02-02 00:07:02 UTC (rev 701)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgICurvePolygon.h 2007-02-02 00:09:07 UTC (rev 702)
@@ -16,11 +16,12 @@
#pragma once
#include "mgISurfaceAbstract.h"
+class FdoCurvePolygonCollection;
BEGIN_NAMESPACE_OSGEO_GEOMETRY
public __gc __interface IRing;
END_NAMESPACE_OSGEO_GEOMETRY
@@ -62,6 +63,270 @@
__property NAMESPACE_OSGEO_GEOMETRY::IRing *get_InteriorRing(System::Int32 index);
+/// \brief
+/// The CurvePolygonCollection class is a collection of CurvePolygon objects.
+[System::Reflection::DefaultMemberAttribute("RealTypeItem")]
+public __gc __sealed class CurvePolygonCollection
+ : public NAMESPACE_OSGEO_RUNTIME::Disposable, public System::Collections::IList
+public:
+ /// \brief
+ /// Constructs a CurvePolygonCollection managed object based on an unmanaged instance of the object
+ /// \param unmanaged
+ /// Input A Pointer to the unmanaged object.
+ /// \param autoDelete
+ /// Input Indicates if the constructed object should be automatically deleted
+ /// once it no longer referenced.
+ CurvePolygonCollection(System::IntPtr unmanaged, System::Boolean autoDelete);
+public private:
+ FdoCurvePolygonCollection *GetImpObj();
+/// \cond DOXYGEN-IGNORE
+protected:
+ __sealed System::Void ReleaseUnmanagedObject();
+private:
+ /// \brief
+ /// A Nested class defined to provide enumeration of Dictionary elements
+ /// Enumerators can be used to read the data in the collection,
+ /// but they cannot be used to modify the underlying collection.
+ /// An enumerator remains valid as long as the collection remains unchanged.
+ /// If changes are made to the collection, such as adding, modifying, or deleting
+ /// elements, the enumerator is irrecoverably invalidated and the next call to
+ /// MoveNext or Reset throws an InvalidOperationException. If the collection is
+ /// modified between MoveNext and Current, Current returns the element that it is
+ /// set to, even if the enumerator is already invalidated.
+ /// The enumerator does not have exclusive access to the collection; therefore,
+ /// enumerating through a collection is intrinsically not a thread-safe procedure.
+ /// Even when a collection is synchronized, other threads can still modify the
+ /// collection, which causes the enumerator to throw an exception. To guarantee
+ /// thread safety during enumeration, you can either lock the collection during
+ /// the entire enumeration or catch the exceptions resulting from changes made
+ /// by other threads.
+ __gc class Enumerator : public System::Collections::IEnumerator
+ CurvePolygonCollection *m_pCol;
+ System::Int32 m_nIdx;
+ public:
+ /// \brief
+ /// Constructs a new Collection Enumerator
+ /// \param col
+ /// Input The collection to enumerate.
+ Enumerator(CurvePolygonCollection *col)
+ : m_pCol(col), m_nIdx(-1)
+ /// \brief
+ /// Retrieves the current object at the enumerator location
+ /// \return
+ /// Retuns the current object referenced by the enumerator
+ __property System::Object *get_Current();
+ /// \brief
+ /// Initially, the enumerator is positioned before the first object in the collection.
+ /// At this position, calling the Current property throws an exception.
+ /// Therefore, you must call the MoveNext method to advance the enumerator
+ /// to the first element of the collection before reading the value of Current.
+ /// If MoveNext passes the end of the collection, the enumerator is positioned
+ /// after the last element in the collection and MoveNext returns false.
+ /// When the enumerator is at this position, subsequent calls to MoveNext also return false.
+ /// If the last call to MoveNext returned false, calling Current throws an exception.
+ /// To set Current to the first element of the collection again, you can call Reset
+ /// followed by MoveNext.
+ /// \return
+ /// Retuns true if the Enumerator is able to move to a valid element
+ /// otherwise false.
+ System::Boolean MoveNext();
+ /// \brief
+ /// Initially, the enumerator is positioned before the first element in the collection.
+ /// The Reset method brings the enumerator back to this position.
+ System::Void Reset();
+/// \endcond
+public:
+ /// \brief
+ /// Creates an instance of CurveSegmentCollection with no contained elements.
+ /// \return
+ /// Returns an empty collection
+ CurvePolygonCollection();
+private:
+ // System::Collections::ICollection interface properties
+ __property System::Object* System::Collections::ICollection::get_SyncRoot();
+ __property System::Boolean System::Collections::ICollection::get_IsSynchronized();
+ // System::Collections::ICollection interface methods
+ System::Void System::Collections::ICollection::CopyTo(System::Array* array,System::Int32 index);
+ // System::Collections::IList interface properties
+ __property System::Boolean System::Collections::IList::get_IsFixedSize();
+ __property System::Boolean System::Collections::IList::get_IsReadOnly();
+ __property Object* System::Collections::IList::get_Item(System::Int32 index);
+ __property System::Void System::Collections::IList::set_Item(System::Int32 index, Object* value);
+ // System::Collections::IList interface methods
+ System::Int32 System::Collections::IList::Add(Object* value);
+ System::Boolean System::Collections::IList::Contains(Object* value);
+ System::Int32 System::Collections::IList::IndexOf(Object* value);
+ System::Void System::Collections::IList::Insert(System::Int32 index, Object* value);
+ System::Void System::Collections::IList::Remove(Object* value);
+public:
+ /// \brief
+ /// Gets the count of items in collection.
+ /// \return
+ /// Returns the number of items in the collection.
+ __property System::Int32 get_Count(System::Void);
+ /// \brief
+ /// Gets an enumerator that can iterate through a collection.
+ /// \return
+ /// Returns an enumerator on the dictionary.
+ __sealed System::Collections::IEnumerator* GetEnumerator(System::Void);
+ /// \brief
+ /// Removes the index-th ICurvePolygon from this collection.
+ /// \param index
+ /// Input index of the element to remove.
+ System::Void RemoveAt(System::Int32 index);
+ /// \brief
+ /// Removes all elements from the collection.
+ System::Void Clear();
+public:
+ /// \brief
+ /// Adds a ICurvePolygon object into the collection.
+ /// \param value
+ /// Input the ICurvePolygon object to add.
+ /// \return
+ /// The position into which the new element was inserted.
+ System::Int32 Add(NAMESPACE_OSGEO_GEOMETRY::ICurvePolygon* value);
+ /// \brief
+ /// Determines the index of a specific ICurvePolygon object.
+ /// \param value
+ /// Input the ICurvePolygon object to locate in the collection.
+ /// \return
+ /// The index of value if found in the collection; otherwise, -1.
+ System::Int32 IndexOf(NAMESPACE_OSGEO_GEOMETRY::ICurvePolygon* value);
+ /// \brief
+ /// Inserts an ICurvePolygon object to the collection at the specified position.
+ /// \param index
+ /// Input the zero-based index at which value should be inserted.
+ /// \param value
+ /// Input the ICurvePolygon object to insert.
+ System::Void Insert(System::Int32 index, NAMESPACE_OSGEO_GEOMETRY::ICurvePolygon* value);
+ /// \brief
+ /// Removes the first occurrence of a specific ICurvePolygon object.
+ /// \param value
+ /// Input the ICurvePolygon object to remove from the collection.
+ System::Void Remove(NAMESPACE_OSGEO_GEOMETRY::ICurvePolygon* value);
+ /// \brief
+ /// Determines whether the collection contains a specific ICurvePolygon object.
+ /// \param value
+ /// Input The ICurvePolygon object to locate in the collection.
+ /// \return
+ /// True if the value is found in the collection; otherwise, false.
+ System::Boolean Contains(NAMESPACE_OSGEO_GEOMETRY::ICurvePolygon* value);
+ /// \brief
+ /// Copies the elements of the collection to an array.
+ /// \param array
+ /// Output the one-dimensional Array that is the destination of the elements copied from this collection.
+ /// \param startAt
+ /// Input an integer that represents the index in array at which copying begins.
+ System::Void CopyTo(NAMESPACE_OSGEO_GEOMETRY::ICurvePolygon* array[],System::Int32 startAt);
+ /// \brief
+ /// Gets an ICurvePolygon in the collection.
+ /// \param index
+ /// Input index of the ICurvePolygon to retrieve.
+ __property NAMESPACE_OSGEO_GEOMETRY::ICurvePolygon *get_RealTypeItem(System::Int32 index);
+ /// \brief
+ /// Sets the value of the ICurvePolygon at the specified index
+ /// \param index
+ /// Input index of the ICurvePolygon to set.
+ /// \param value
+ /// Input the value of the ICurvePolygon
+ __property System::Void set_RealTypeItem(System::Int32 index, NAMESPACE_OSGEO_GEOMETRY::ICurvePolygon *value);
+ /// \brief
+ /// \param index
+ /// \return
+ /// Returns the ICurvePolygon at the specified index
+ __property NAMESPACE_OSGEO_GEOMETRY::ICurvePolygon *get_Item(System::Int32 index);
+ /// \brief
+ /// \param index
+ /// \param value
+ __property System::Void set_Item(System::Int32 index, NAMESPACE_OSGEO_GEOMETRY::ICurvePolygon *value);
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgICurvePolygonImp.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgICurvePolygonImp.h 2007-02-02 00:07:02 UTC (rev 701)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgICurvePolygonImp.h 2007-02-02 00:09:07 UTC (rev 702)
@@ -16,13 +16,13 @@
#pragma once
#include "mgISurfaceAbstractImp.h"
#include "mgICurvePolygon.h"
class FdoICurvePolygon;
-class FdoCurvePolygonCollection;
@@ -81,240 +81,6 @@
-/// \brief
-/// The CurvePolygonCollection class is a collection of CurvePolygon objects.
-[System::Reflection::DefaultMemberAttribute("RealTypeItem")]
-public __gc __sealed class CurvePolygonCollection
- : public NAMESPACE_OSGEO_RUNTIME::Disposable, public System::Collections::IList
-public:
- /// \brief
- /// Constructs a CurvePolygonCollection managed object based on an unmanaged instance of the object
- /// \param unmanaged
- /// Input A Pointer to the unmanaged object.
- /// \param autoDelete
- /// Input Indicates if the constructed object should be automatically deleted
- /// once it no longer referenced.
- CurvePolygonCollection(System::IntPtr unmanaged, System::Boolean autoDelete);
-public private:
- FdoCurvePolygonCollection *GetImpObj();
-/// \cond DOXYGEN-IGNORE
-protected:
- __sealed System::Void ReleaseUnmanagedObject();
-private:
- /// \brief
- /// nested class defined to provide Enumerator.
- __gc class Enumerator : public System::Collections::IEnumerator
- CurvePolygonCollection *m_pCol;
- System::Int32 m_nIdx;
- public:
- /// \brief
- /// Constructs a new Collection Enumerator
- /// \param col
- /// Input The collection to enumerate.
- Enumerator(CurvePolygonCollection *col)
- : m_pCol(col), m_nIdx(-1)
- /// \brief
- /// Retrieves the current object at the enumerator location
- /// \return
- /// Retuns the current object referenced by the enumerator
- __property System::Object *get_Current();
- /// \brief
- /// Initially, the enumerator is positioned before the first object in the collection.
- /// At this position, calling the Current property throws an exception.
- /// Therefore, you must call the MoveNext method to advance the enumerator
- /// to the first element of the collection before reading the value of Current.
- /// If MoveNext passes the end of the collection, the enumerator is positioned
- /// after the last element in the collection and MoveNext returns false.
- /// When the enumerator is at this position, subsequent calls to MoveNext also return false.
- /// If the last call to MoveNext returned false, calling Current throws an exception.
- /// To set Current to the first element of the collection again, you can call Reset
- /// followed by MoveNext.
- /// \return
- /// Retuns true if the Enumerator is able to move to a valid element
- /// otherwise false.
- System::Boolean MoveNext();
- /// \brief
- /// Initially, the enumerator is positioned before the first element in the collection.
- /// The Reset method brings the enumerator back to this position.
- System::Void Reset();
-/// \endcond
-public:
- /// \brief
- /// Creates an instance of CurveSegmentCollection with no contained elements.
- /// \return
- /// Returns an empty collection
- CurvePolygonCollection();
-private:
- // System::Collections::ICollection
- System::Void System::Collections::ICollection::CopyTo(System::Array* array,System::Int32 index);
- __property System::Object* System::Collections::ICollection::get_SyncRoot(System::Void);
- __property System::Boolean System::Collections::ICollection::get_IsSynchronized(System::Void);
- // System::Collections::IList
- __property System::Boolean System::Collections::IList::get_IsFixedSize(System::Void);
- __property System::Boolean System::Collections::IList::get_IsReadOnly(System::Void);
- System::Int32 System::Collections::IList::Add(Object* value);
- System::Boolean System::Collections::IList::Contains(Object* value);
- System::Int32 System::Collections::IList::IndexOf(Object* value);
- System::Void System::Collections::IList::Insert(System::Int32 index, Object* value);
- System::Void System::Collections::IList::Remove(Object* value);
- __property Object* System::Collections::IList::get_Item(System::Int32 index);
- __property System::Void System::Collections::IList::set_Item(System::Int32 index, Object* value);
-public:
- /// \brief
- /// Gets the count of items in collection.
- __property System::Int32 get_Count(System::Void);
- /// \brief
- /// Gets an enumerator that can iterate through a collection.
- __sealed System::Collections::IEnumerator* GetEnumerator(System::Void);
- /// \brief
- /// Removes the index-th ICurvePolygon from this collection.
- /// \param index
- /// Input index of the element to remove.
- System::Void RemoveAt(System::Int32 index);
- /// \brief
- /// Removes all elements from the collection.
- System::Void Clear();
-public:
- /// \brief
- /// Adds a ICurvePolygon object into the collection.
- /// \param value
- /// Input the ICurvePolygon object to add.
- /// \return
- /// The position into which the new element was inserted.
- System::Int32 Add(NAMESPACE_OSGEO_GEOMETRY::ICurvePolygon* value);
- /// \brief
- /// Determines the index of a specific ICurvePolygon object.
- /// \param value
- /// Input the ICurvePolygon object to locate in the collection.
- /// \return
- /// The index of value if found in the collection; otherwise, -1.
- System::Int32 IndexOf(NAMESPACE_OSGEO_GEOMETRY::ICurvePolygon* value);
- /// \brief
- /// Inserts an ICurvePolygon object to the collection at the specified position.
- /// \param index
- /// Input the zero-based index at which value should be inserted.
- /// \param value
- /// Input the ICurvePolygon object to insert.
- System::Void Insert(System::Int32 index, NAMESPACE_OSGEO_GEOMETRY::ICurvePolygon* value);
- /// \brief
- /// Removes the first occurrence of a specific ICurvePolygon object.
- /// \param value
- /// Input the ICurvePolygon object to remove from the collection.
- System::Void Remove(NAMESPACE_OSGEO_GEOMETRY::ICurvePolygon* value);
- /// \brief
- /// Determines whether the collection contains a specific ICurvePolygon object.
- /// \param value
- /// Input The ICurvePolygon object to locate in the collection.
- /// \return
- /// True if the value is found in the collection; otherwise, false.
- System::Boolean Contains(NAMESPACE_OSGEO_GEOMETRY::ICurvePolygon* value);
- /// \brief
- /// Copies the elements of the collection to an array.
- /// \param array
- /// Output the one-dimensional Array that is the destination of the elements copied from this collection.
- /// \param startAt
- /// Input an integer that represents the index in array at which copying begins.
- System::Void CopyTo(NAMESPACE_OSGEO_GEOMETRY::ICurvePolygon* array[],System::Int32 startAt);
- /// \brief
- /// Gets an ICurvePolygon in the collection.
- /// \param index
- /// Input index of the ICurvePolygon to retrieve.
- __property NAMESPACE_OSGEO_GEOMETRY::ICurvePolygon *get_RealTypeItem(System::Int32 index);
- /// \brief
- /// Sets the value of the ICurvePolygon at the specified index
- /// \param index
- /// Input index of the ICurvePolygon to set.
- /// \param value
- /// Input the value of the ICurvePolygon
- __property System::Void set_RealTypeItem(System::Int32 index, NAMESPACE_OSGEO_GEOMETRY::ICurvePolygon *value);
- /// \brief
- /// \param index
- /// \return
- /// Returns the ICurvePolygon at the specified index
- __property NAMESPACE_OSGEO_GEOMETRY::ICurvePolygon *get_Item(System::Int32 index);
- /// \brief
- /// \param index
- /// \param value
- __property System::Void set_Item(System::Int32 index, NAMESPACE_OSGEO_GEOMETRY::ICurvePolygon *value);
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgICurveSegmentAbstract.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgICurveSegmentAbstract.h 2007-02-02 00:07:02 UTC (rev 701)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgICurveSegmentAbstract.h 2007-02-02 00:09:07 UTC (rev 702)
@@ -19,6 +19,8 @@
#pragma once
+class FdoCurveSegmentCollection;
public __gc __interface IEnvelope;
@@ -97,6 +99,268 @@
__property System::Int32 get_Dimensionality();
+/// \brief
+/// The CurveSegmentCollection class represents a collection of CurveSegment objects.
+public __gc __sealed class CurveSegmentCollection
+public:
+ /// \brief
+ /// Constructs a CurveSegmentCollection managed object based on an unmanaged instance of the object
+ CurveSegmentCollection(System::IntPtr unmanaged, System::Boolean autoDelete);
+public private:
+ FdoCurveSegmentCollection *GetImpObj();
+protected:
+private:
+ /// \brief
+ CurveSegmentCollection *m_pCol;
+ public:
+ /// \brief
+ /// \param col
+ Enumerator(CurveSegmentCollection *col)
+ /// \brief
+ /// \return
+ /// \brief
+ /// \return
+ /// \brief
+/// \endcond
+public:
+ /// \brief
+ /// \return
+ CurveSegmentCollection();
+private:
+public:
+ /// \brief
+ /// \return
+ /// \brief
+ /// \return
+ /// \brief
+ /// Removes the index-th ICurveSegmentAbstract from this collection.
+ /// \param index
+ /// \brief
+public:
+ /// \brief
+ /// Adds a ICurveSegmentAbstract object into the collection.
+ /// \param value
+ /// Input the ICurveSegmentAbstract object to add.
+ /// \return
+ System::Int32 Add(NAMESPACE_OSGEO_GEOMETRY::ICurveSegmentAbstract* value);
+ /// \brief
+ /// Determines the index of a specific ICurveSegmentAbstract object.
+ /// \param value
+ /// Input the ICurveSegmentAbstract object to locate in the collection.
+ /// \return
+ System::Int32 IndexOf(NAMESPACE_OSGEO_GEOMETRY::ICurveSegmentAbstract* value);
+ /// \brief
+ /// Inserts an ICurveSegmentAbstract object to the collection at the specified position.
+ /// \param index
+ /// \param value
+ /// Input the ICurveSegmentAbstract object to insert.
+ System::Void Insert(System::Int32 index, NAMESPACE_OSGEO_GEOMETRY::ICurveSegmentAbstract* value);
+ /// \brief
+ /// Removes the first occurrence of a specific ICurveSegmentAbstract object.
+ /// \param value
+ /// Input the ICurveSegmentAbstract object to remove from the collection.
+ System::Void Remove(NAMESPACE_OSGEO_GEOMETRY::ICurveSegmentAbstract* value);
+ /// \brief
+ /// Determines whether the collection contains a specific ICurveSegmentAbstract object.
+ /// \param value
+ /// Input The ICurveSegmentAbstract object to locate in the collection.
+ /// \return
+ System::Boolean Contains(NAMESPACE_OSGEO_GEOMETRY::ICurveSegmentAbstract* value);
+ /// \brief
+ /// \param array
+ System::Void CopyTo(NAMESPACE_OSGEO_GEOMETRY::ICurveSegmentAbstract* array[],System::Int32 startAt);
+ /// \brief
+ /// Gets an ICurveSegmentAbstract in the collection.
+ /// \param index
+ /// Input index of the ICurveSegmentAbstract to retrieve
+ __property NAMESPACE_OSGEO_GEOMETRY::ICurveSegmentAbstract *get_RealTypeItem(System::Int32 index);
+ /// \brief
+ /// Sets the value of the ICurveSegmentAbstract object at the specified index
+ /// \param index
+ /// Input index of the ICurveSegmentAbstract object to set.
+ /// \param value
+ /// Input the value of the ICurveSegmentAbstract object
+ __property System::Void set_RealTypeItem(System::Int32 index, NAMESPACE_OSGEO_GEOMETRY::ICurveSegmentAbstract *value);
+ /// \brief
+ /// Gets an ICurveSegmentAbstract object in the collection.
+ /// \param index
+ /// Input index of the ICurveSegmentAbstract object to retrieve.
+ /// \return
+ /// Returns the ICurveSegmentAbstract object at the specified index.
+ __property NAMESPACE_OSGEO_GEOMETRY::ICurveSegmentAbstract *get_Item(System::Int32 index);
+ /// \brief
+ /// \param index
+ /// \param value
+ /// Input the value of the ICurveSegmentAbstract object.
+ __property System::Void set_Item(System::Int32 index, NAMESPACE_OSGEO_GEOMETRY::ICurveSegmentAbstract *value);
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgICurveSegmentAbstractImp.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgICurveSegmentAbstractImp.h 2007-02-02 00:07:02 UTC (rev 701)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgICurveSegmentAbstractImp.h 2007-02-02 00:09:07 UTC (rev 702)
@@ -22,7 +22,6 @@
#include "mgICurveSegmentAbstract.h"
class FdoICurveSegmentAbstract;
-class FdoCurveSegmentCollection;
@@ -123,237 +122,6 @@
FdoICurveSegmentAbstract *GetImpObj();
-public __gc __sealed class CurveSegmentCollection
-public:
- /// \brief
- /// Constructs a CurveSegmentCollection managed object based on an unmanaged instance of the object
- CurveSegmentCollection(System::IntPtr unmanaged, System::Boolean autoDelete);
-public private:
- FdoCurveSegmentCollection *GetImpObj();
-protected:
-private:
- /// \brief
- CurveSegmentCollection *m_pCol;
- public:
- /// \brief
- /// \param col
- Enumerator(CurveSegmentCollection *col)
- /// \brief
- /// \return
- /// \brief
- /// \return
- /// \brief
-/// \endcond
-public:
- /// \brief
- /// \return
- CurveSegmentCollection();
-private:
-public:
- /// \brief
- /// \brief
- /// \brief
- /// Removes the index-th ICurveSegmentAbstract from this collection.
- /// \param index
- /// \brief
-public:
- /// \brief
- /// Adds a ICurveSegmentAbstract object into the collection.
- /// \param value
- /// Input the ICurveSegmentAbstract object to add.
- /// \return
- System::Int32 Add(NAMESPACE_OSGEO_GEOMETRY::ICurveSegmentAbstract* value);
- /// \brief
- /// Determines the index of a specific ICurveSegmentAbstract object.
- /// \param value
- /// Input the ICurveSegmentAbstract object to locate in the collection.
- /// \return
- System::Int32 IndexOf(NAMESPACE_OSGEO_GEOMETRY::ICurveSegmentAbstract* value);
- /// \brief
- /// Inserts an ICurveSegmentAbstract object to the collection at the specified position.
- /// \param index
- /// \param value
- /// Input the ICurveSegmentAbstract object to insert.
- System::Void Insert(System::Int32 index, NAMESPACE_OSGEO_GEOMETRY::ICurveSegmentAbstract* value);
- /// \brief
- /// Removes the first occurrence of a specific ICurveSegmentAbstract object.
- /// \param value
- /// Input the ICurveSegmentAbstract object to remove from the collection.
- System::Void Remove(NAMESPACE_OSGEO_GEOMETRY::ICurveSegmentAbstract* value);
- /// \brief
- /// Determines whether the collection contains a specific ICurveSegmentAbstract object.
- /// \param value
- /// Input The ICurveSegmentAbstract object to locate in the collection.
- /// \return
- System::Boolean Contains(NAMESPACE_OSGEO_GEOMETRY::ICurveSegmentAbstract* value);
- /// \brief
- /// \param array
- System::Void CopyTo(NAMESPACE_OSGEO_GEOMETRY::ICurveSegmentAbstract* array[],System::Int32 startAt);
- /// \brief
- /// Gets an ICurveSegmentAbstract in the collection.
- /// \param index
- /// Input index of the ICurveSegmentAbstract to retrieve
- __property NAMESPACE_OSGEO_GEOMETRY::ICurveSegmentAbstract *get_RealTypeItem(System::Int32 index);
- /// \brief
- /// Sets the value of the object at the specified index
- /// \param index
- /// Input index of the object to set.
- /// \param value
- /// Input the value of the object
- __property System::Void set_RealTypeItem(System::Int32 index, NAMESPACE_OSGEO_GEOMETRY::ICurveSegmentAbstract *value);
- /// \brief
- /// Gets am object in the collection.
- /// \param index
- /// Input index of the object to retrieve.
- /// \return
- /// Returns the object at the specified index.
- __property NAMESPACE_OSGEO_GEOMETRY::ICurveSegmentAbstract *get_Item(System::Int32 index);
- /// \brief
- /// \param index
- /// \param value
- /// Input the value of the object.
- __property System::Void set_Item(System::Int32 index, NAMESPACE_OSGEO_GEOMETRY::ICurveSegmentAbstract *value);
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgICurveString.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgICurveString.h 2007-02-02 00:07:02 UTC (rev 701)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgICurveString.h 2007-02-02 00:09:07 UTC (rev 702)
@@ -18,8 +18,11 @@
#pragma once
#include "mgICurveAbstract.h"
+class FdoCurveStringCollection;
public __gc __interface ICurveSegmentAbstract;
public __gc class CurveSegmentCollection;
@@ -60,6 +63,269 @@
__property NAMESPACE_OSGEO_GEOMETRY::CurveSegmentCollection *get_CurveSegments();
+/// \brief
+/// The CurveStringCollection class is a collection of CurvePolygon objects.
+public __gc __sealed class CurveStringCollection
+public:
+ /// \brief
+ /// Constructs a CurveStringCollection managed object based on an unmanaged instance of the object
+ CurveStringCollection(System::IntPtr unmanaged, System::Boolean autoDelete);
+public private:
+ FdoCurveStringCollection *GetImpObj();
+protected:
+private:
+ /// \brief
+ CurveStringCollection *m_pCol;
+ public:
+ /// \brief
+ /// \param col
+ Enumerator(CurveStringCollection *col)
+ /// \brief
+ /// \return
+ /// \brief
+ /// \return
+ /// \brief
+/// \endcond
+public:
+ /// \brief
+ /// \return
+ CurveStringCollection();
+private:
+public:
+ /// \brief
+ /// \return
+ /// \brief
+ /// \return
+ /// \brief
+ /// Removes the index-th ICurveString from this collection.
+ /// \param index
+ /// \brief
+public:
+ /// \brief
+ /// Adds a ICurveString object into the collection.
+ /// \param value
+ /// Input the ICurveString object to add.
+ /// \return
+ System::Int32 Add(NAMESPACE_OSGEO_GEOMETRY::ICurveString* value);
+ /// \brief
+ /// Determines the index of a specific ICurveString object.
+ /// \param value
+ /// Input the ICurveString object to locate in the collection.
+ /// \return
+ System::Int32 IndexOf(NAMESPACE_OSGEO_GEOMETRY::ICurveString* value);
+ /// \brief
+ /// Inserts an ICurveString object to the collection at the specified position.
+ /// \param index
+ /// \param value
+ /// Input the ICurveString object to insert.
+ System::Void Insert(System::Int32 index, NAMESPACE_OSGEO_GEOMETRY::ICurveString* value);
+ /// \brief
+ /// Removes the first occurrence of a specific ICurveString object.
+ /// \param value
+ /// Input the ICurveString object to remove from the collection.
+ System::Void Remove(NAMESPACE_OSGEO_GEOMETRY::ICurveString* value);
+ /// \brief
+ /// Determines whether the collection contains a specific ICurveString object.
+ /// \param value
+ /// Input The ICurveString object to locate in the collection.
+ /// \return
+ System::Boolean Contains(NAMESPACE_OSGEO_GEOMETRY::ICurveString* value);
+ /// \brief
+ /// \param array
+ System::Void CopyTo(NAMESPACE_OSGEO_GEOMETRY::ICurveString* array[],System::Int32 startAt);
+ /// \brief
+ /// Gets an ICurveString in the collection.
+ /// \param index
+ /// Input index of the ICurveString to retrieve.
+ __property NAMESPACE_OSGEO_GEOMETRY::ICurveString *get_RealTypeItem(System::Int32 index);
+ /// \brief
+ /// Sets the value of the ICurveString at the specified index
+ /// \param index
+ /// Input index of the ICurveString to set.
+ /// \param value
+ /// Input the value of the ICurveString
+ __property System::Void set_RealTypeItem(System::Int32 index, NAMESPACE_OSGEO_GEOMETRY::ICurveString *value);
+ /// \brief
+ /// \param index
+ /// \return
+ /// Returns the ICurveString at the specified index
+ __property NAMESPACE_OSGEO_GEOMETRY::ICurveString *get_Item(System::Int32 index);
+ /// \brief
+ /// \param index
+ /// \param value
+ __property System::Void set_Item(System::Int32 index, NAMESPACE_OSGEO_GEOMETRY::ICurveString *value);
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgICurveStringImp.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgICurveStringImp.h 2007-02-02 00:07:02 UTC (rev 701)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgICurveStringImp.h 2007-02-02 00:09:07 UTC (rev 702)
@@ -22,7 +22,7 @@
#include "mgICurveAbstractImp.h"
class FdoICurveString;
-class FdoCurveStringCollection;
@@ -81,240 +81,6 @@
-/// \brief
-/// The CurveStringCollection class is a collection of CurvePolygon objects.
-public __gc __sealed class CurveStringCollection
-public:
- /// \brief
- /// Constructs a CurveStringCollection managed object based on an unmanaged instance of the object
- CurveStringCollection(System::IntPtr unmanaged, System::Boolean autoDelete);
-public private:
- FdoCurveStringCollection *GetImpObj();
-protected:
-private:
- /// \brief
- /// A Nested class defined to provide Enumerator.
- CurveStringCollection *m_pCol;
- public:
- /// \brief
- /// \param col
- Enumerator(CurveStringCollection *col)
- /// \brief
- /// \return
- /// \brief
- /// \return
- /// \brief
-/// \endcond
-public:
- /// \brief
- /// \return
- CurveStringCollection();
-private:
-public:
- /// \brief
- /// \brief
- /// \brief
- /// Removes the index-th ICurveString from this collection.
- /// \param index
- /// \brief
-public:
- /// \brief
- /// Adds a ICurveString object into the collection.
- /// \param value
- /// Input the ICurveString object to add.
- /// \return
- System::Int32 Add(NAMESPACE_OSGEO_GEOMETRY::ICurveString* value);
- /// \brief
- /// Determines the index of a specific ICurveString object.
- /// \param value
- /// Input the ICurveString object to locate in the collection.
- /// \return
- System::Int32 IndexOf(NAMESPACE_OSGEO_GEOMETRY::ICurveString* value);
- /// \brief
- /// Inserts an ICurveString object to the collection at the specified position.
- /// \param index
- /// \param value
- /// Input the ICurveString object to insert.
- System::Void Insert(System::Int32 index, NAMESPACE_OSGEO_GEOMETRY::ICurveString* value);
- /// \brief
- /// Removes the first occurrence of a specific ICurveString object.
- /// \param value
- /// Input the ICurveString object to remove from the collection.
- System::Void Remove(NAMESPACE_OSGEO_GEOMETRY::ICurveString* value);
- /// \brief
- /// Determines whether the collection contains a specific ICurveString object.
- /// \param value
- /// Input The ICurveString object to locate in the collection.
- /// \return
- System::Boolean Contains(NAMESPACE_OSGEO_GEOMETRY::ICurveString* value);
- /// \brief
- /// \param array
- System::Void CopyTo(NAMESPACE_OSGEO_GEOMETRY::ICurveString* array[],System::Int32 startAt);
- /// \brief
- /// Gets an ICurveString in the collection.
- /// \param index
- /// Input index of the ICurveString to retrieve.
- __property NAMESPACE_OSGEO_GEOMETRY::ICurveString *get_RealTypeItem(System::Int32 index);
- /// \brief
- /// Sets the value of the ICurveString at the specified index
- /// \param index
- /// Input index of the ICurveString to set.
- /// \param value
- /// Input the value of the ICurveString
- __property System::Void set_RealTypeItem(System::Int32 index, NAMESPACE_OSGEO_GEOMETRY::ICurveString *value);
- /// \brief
- /// \param index
- /// \return
- /// Returns the ICurveString at the specified index
- __property NAMESPACE_OSGEO_GEOMETRY::ICurveString *get_Item(System::Int32 index);
- /// \brief
- /// \param index
- /// \param value
- __property System::Void set_Item(System::Int32 index, NAMESPACE_OSGEO_GEOMETRY::ICurveString *value);
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgIDirectPosition.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgIDirectPosition.h 2007-02-02 00:07:02 UTC (rev 701)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgIDirectPosition.h 2007-02-02 00:09:07 UTC (rev 702)
@@ -16,9 +16,10 @@
#pragma once
+class FdoDirectPositionCollection;
/// \brief
@@ -76,6 +77,270 @@
+/// \brief
+/// The DirectPositionCollection class is a collection of DirectPosition objects.
+public __gc __sealed class DirectPositionCollection
+public:
+ /// \brief
+ /// Constructs a DirectPositionCollection managed object based on an unmanaged instance of the object
+ DirectPositionCollection(System::IntPtr unmanaged, System::Boolean autoDelete);
+public private:
+ FdoDirectPositionCollection *GetImpObj();
+protected:
+private:
+ /// \brief
+ DirectPositionCollection *m_pCol;
+ public:
+ /// \brief
+ /// \param col
+ Enumerator(DirectPositionCollection *col)
+ /// \brief
+ /// \return
+ /// \brief
+ /// \return
+ /// \brief
+public:
+ /// \brief
+ /// Creates an instance of DirectPositionCollection with no contained elements.
+ /// \return
+ DirectPositionCollection();
+private:
+public:
+ /// \brief
+ /// \return
+ /// \brief
+ /// \return
+ /// \brief
+ /// Removes the index-th IDirectPosition from this collection.
+ /// \param index
+ /// \brief
+public:
+ /// \brief
+ /// Adds a IDirectPosition object into the collection.
+ /// \param value
+ /// Input the IDirectPosition object to add.
+ /// \return
+ System::Int32 Add(NAMESPACE_OSGEO_GEOMETRY::IDirectPosition* value);
+ /// \brief
+ /// Determines the index of a specific IDirectPosition object.
+ /// \param value
+ /// Input the IDirectPosition object to locate in the collection.
+ /// \return
+ System::Int32 IndexOf(NAMESPACE_OSGEO_GEOMETRY::IDirectPosition* value);
+ /// \brief
+ /// Inserts an IDirectPosition object to the collection at the specified position.
+ /// \param index
+ /// \param value
+ /// Input the IDirectPosition object to insert.
+ System::Void Insert(System::Int32 index, NAMESPACE_OSGEO_GEOMETRY::IDirectPosition* value);
+ /// \brief
+ /// Removes the first occurrence of a specific IDirectPosition object.
+ /// \param value
+ /// Input the IDirectPosition object to remove from the collection.
+ System::Void Remove(NAMESPACE_OSGEO_GEOMETRY::IDirectPosition* value);
+ /// \brief
+ /// Determines whether the collection contains a specific IDirectPosition object.
+ /// \param value
+ /// Input The IDirectPosition object to locate in the collection.
+ /// \return
+ System::Boolean Contains(NAMESPACE_OSGEO_GEOMETRY::IDirectPosition* value);
+ /// \brief
+ /// \param array
+ System::Void CopyTo(NAMESPACE_OSGEO_GEOMETRY::IDirectPosition* array[],System::Int32 startAt);
+ /// \brief
+ /// Gets an IDirectPosition in the collection.
+ /// \param index
+ /// Input index of the IDirectPosition to retrieve.
+ __property NAMESPACE_OSGEO_GEOMETRY::IDirectPosition *get_RealTypeItem(System::Int32 index);
+ /// \brief
+ /// Sets the value of the IDirectPosition at the specified index
+ /// \param index
+ /// Input index of the IDirectPosition to set.
+ /// \param value
+ /// Input the value of the IDirectPosition
+ __property System::Void set_RealTypeItem(System::Int32 index, NAMESPACE_OSGEO_GEOMETRY::IDirectPosition *value);
+ /// \brief
+ /// \param index
+ /// \return
+ /// Returns the IDirectPosition at the specified index
+ __property NAMESPACE_OSGEO_GEOMETRY::IDirectPosition *get_Item(System::Int32 index);
+ /// \brief
+ /// \param index
+ /// \param value
+ __property System::Void set_Item(System::Int32 index, NAMESPACE_OSGEO_GEOMETRY::IDirectPosition *value);
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgIDirectPositionImp.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgIDirectPositionImp.h 2007-02-02 00:07:02 UTC (rev 701)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgIDirectPositionImp.h 2007-02-02 00:09:07 UTC (rev 702)
@@ -22,7 +22,6 @@
#include "mgIDirectPosition.h"
class FdoIDirectPosition;
-class FdoDirectPositionCollection;
@@ -103,240 +102,6 @@
FdoIDirectPosition *GetImpObj();
-/// \brief
-/// The DirectPositionCollection class is a collection of DirectPosition objects.
-public __gc __sealed class DirectPositionCollection
-public:
- /// \brief
- /// Constructs a DirectPositionCollection managed object based on an unmanaged instance of the object
- DirectPositionCollection(System::IntPtr unmanaged, System::Boolean autoDelete);
-public private:
- FdoDirectPositionCollection *GetImpObj();
-protected:
-private:
- /// \brief
- DirectPositionCollection *m_pCol;
- public:
- /// \brief
- /// \param col
- Enumerator(DirectPositionCollection *col)
- /// \brief
- /// \return
- /// \brief
- /// \return
- /// \brief
-public:
- /// \brief
- /// Creates an instance of DirectPositionCollection with no contained elements.
- /// \return
- DirectPositionCollection();
-private:
-public:
- /// \brief
- /// \brief
- /// \brief
- /// Removes the index-th IDirectPosition from this collection.
- /// \param index
- /// \brief
-public:
- /// \brief
- /// Adds a IDirectPosition object into the collection.
- /// \param value
- /// Input the IDirectPosition object to add.
- /// \return
- System::Int32 Add(NAMESPACE_OSGEO_GEOMETRY::IDirectPosition* value);
- /// \brief
- /// Determines the index of a specific IDirectPosition object.
- /// \param value
- /// Input the IDirectPosition object to locate in the collection.
- /// \return
- System::Int32 IndexOf(NAMESPACE_OSGEO_GEOMETRY::IDirectPosition* value);
- /// \brief
- /// Inserts an IDirectPosition object to the collection at the specified position.
- /// \param index
- /// \param value
- /// Input the IDirectPosition object to insert.
- System::Void Insert(System::Int32 index, NAMESPACE_OSGEO_GEOMETRY::IDirectPosition* value);
- /// \brief
- /// Removes the first occurrence of a specific IDirectPosition object.
- /// \param value
- /// Input the IDirectPosition object to remove from the collection.
- System::Void Remove(NAMESPACE_OSGEO_GEOMETRY::IDirectPosition* value);
- /// \brief
- /// Determines whether the collection contains a specific IDirectPosition object.
- /// \param value
- /// Input The IDirectPosition object to locate in the collection.
- /// \return
- System::Boolean Contains(NAMESPACE_OSGEO_GEOMETRY::IDirectPosition* value);
- /// \brief
- /// \param array
- System::Void CopyTo(NAMESPACE_OSGEO_GEOMETRY::IDirectPosition* array[],System::Int32 startAt);
- /// \brief
- /// Gets an IDirectPosition in the collection.
- /// \param index
- /// Input index of the IDirectPosition to retrieve.
- __property NAMESPACE_OSGEO_GEOMETRY::IDirectPosition *get_RealTypeItem(System::Int32 index);
- /// \brief
- /// Sets the value of the IDirectPosition at the specified index
- /// \param index
- /// Input index of the IDirectPosition to set.
- /// \param value
- /// Input the value of the IDirectPosition
- __property System::Void set_RealTypeItem(System::Int32 index, NAMESPACE_OSGEO_GEOMETRY::IDirectPosition *value);
- /// \brief
- /// \param index
- /// \return
- /// Returns the IDirectPosition at the specified index
- __property NAMESPACE_OSGEO_GEOMETRY::IDirectPosition *get_Item(System::Int32 index);
- /// \brief
- /// \param index
- /// \param value
- __property System::Void set_Item(System::Int32 index, NAMESPACE_OSGEO_GEOMETRY::IDirectPosition *value);
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgIGeometry.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgIGeometry.h 2007-02-02 00:07:02 UTC (rev 701)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgIGeometry.h 2007-02-02 00:09:07 UTC (rev 702)
@@ -19,6 +19,8 @@
#pragma once
+class FdoGeometryCollection;
@@ -78,6 +80,268 @@
__property System::String* get_Text();
+/// \brief
+/// The GeometryCollection class is a collection of Geometry objects.
+public __gc __sealed class GeometryCollection
+public:
+ /// \brief
+ /// Constructs a GeometryCollection managed object based on an unmanaged instance of the object
+ GeometryCollection(System::IntPtr unmanaged, System::Boolean autoDelete);
+public private:
+ FdoGeometryCollection *GetImpObj();
+protected:
+private:
+ /// \brief
+ GeometryCollection *m_pCol;
+ public:
+ /// \brief
+ /// \param col
+ Enumerator(GeometryCollection *col)
+ /// \brief
+ /// \return
+ /// \brief
+ /// \return
+ /// \brief
+/// \endcond
+public:
+ /// \brief
+ /// Creates an instance of GeometryCollection with no contained elements.
+ /// \return
+ GeometryCollection();
+private:
+public:
+ /// \brief
+ /// \return
+ /// \brief
+ /// \return
+ /// \brief
+ /// Removes the index-th IGeometry from this collection.
+ /// \param index
+ /// \brief
+public:
+ /// \brief
+ /// Adds a IGeometry object into the collection.
+ /// \param value
+ /// Input the IGeometry object to add.
+ /// \return
+ System::Int32 Add(NAMESPACE_OSGEO_GEOMETRY::IGeometry* value);
+ /// \brief
+ /// Determines the index of a specific IGeometry object.
+ /// \param value
+ /// Input the IGeometry object to locate in the collection.
+ /// \return
+ System::Int32 IndexOf(NAMESPACE_OSGEO_GEOMETRY::IGeometry* value);
+ /// \brief
+ /// Inserts an IGeometry object to the collection at the specified position.
+ /// \param index
+ /// \param value
+ /// Input the IGeometry object to insert.
+ System::Void Insert(System::Int32 index, NAMESPACE_OSGEO_GEOMETRY::IGeometry* value);
+ /// \brief
+ /// Removes the first occurrence of a specific IGeometry object.
+ /// \param value
+ /// Input the IGeometry object to remove from the collection.
+ System::Void Remove(NAMESPACE_OSGEO_GEOMETRY::IGeometry* value);
+ /// \brief
+ /// Determines whether the collection contains a specific IGeometry object.
+ /// \param value
+ /// Input The IGeometry object to locate in the collection.
+ /// \return
+ System::Boolean Contains(NAMESPACE_OSGEO_GEOMETRY::IGeometry* value);
+ /// \brief
+ /// \param array
+ System::Void CopyTo(NAMESPACE_OSGEO_GEOMETRY::IGeometry* array[],System::Int32 startAt);
+ /// \brief
+ /// Gets an IGeometry object in the collection.
+ /// \param index
+ /// Input index of the IGeometry object to retrieve.
+ __property NAMESPACE_OSGEO_GEOMETRY::IGeometry *get_RealTypeItem(System::Int32 index);
+ /// \brief
+ /// Sets the value of the IGeometry object at the specified index
+ /// \param index
+ /// Input index of the IGeometry object to set.
+ /// \param value
+ /// Input the value of the IGeometry
+ __property System::Void set_RealTypeItem(System::Int32 index, NAMESPACE_OSGEO_GEOMETRY::IGeometry *value);
+ /// \brief
+ /// \param index
+ /// \return
+ /// Returns the IGeometry object at the specified index
+ __property NAMESPACE_OSGEO_GEOMETRY::IGeometry *get_Item(System::Int32 index);
+ /// \brief
+ /// \param index
+ /// \param value
+ /// Input the value of the IGeometry object
+ __property System::Void set_Item(System::Int32 index, NAMESPACE_OSGEO_GEOMETRY::IGeometry *value);
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgIGeometryImp.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgIGeometryImp.h 2007-02-02 00:07:02 UTC (rev 701)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgIGeometryImp.h 2007-02-02 00:09:07 UTC (rev 702)
@@ -22,7 +22,6 @@
#include "mgIGeometry.h"
class FdoIGeometry;
-class FdoGeometryCollection;
@@ -106,240 +105,6 @@
FdoIGeometry *GetImpObj();
-/// \brief
-/// The GeometryCollection class is a collection of Geometry objects.
-public __gc __sealed class GeometryCollection
-public:
- /// \brief
- /// Constructs a GeometryCollection managed object based on an unmanaged instance of the object
- GeometryCollection(System::IntPtr unmanaged, System::Boolean autoDelete);
-public private:
- FdoGeometryCollection *GetImpObj();
-protected:
-private:
- /// \brief
- GeometryCollection *m_pCol;
- public:
- /// \brief
- /// \param col
- Enumerator(GeometryCollection *col)
- /// \brief
- /// \return
- /// \brief
- /// \return
- /// \brief
-/// \endcond
-public:
- /// \brief
- /// Creates an instance of GeometryCollection with no contained elements.
- /// \return
- GeometryCollection();
-private:
-public:
- /// \brief
- /// \brief
- /// \brief
- /// Removes the index-th IGeometry from this collection.
- /// \param index
- /// \brief
-public:
- /// \brief
- /// Adds a IGeometry object into the collection.
- /// \param value
- /// Input the IGeometry object to add.
- /// \return
- System::Int32 Add(NAMESPACE_OSGEO_GEOMETRY::IGeometry* value);
- /// \brief
- /// Determines the index of a specific IGeometry object.
- /// \param value
- /// Input the IGeometry object to locate in the collection.
- /// \return
- System::Int32 IndexOf(NAMESPACE_OSGEO_GEOMETRY::IGeometry* value);
- /// \brief
- /// Inserts an IGeometry object to the collection at the specified position.
- /// \param index
- /// \param value
- /// Input the IGeometry object to insert.
- System::Void Insert(System::Int32 index, NAMESPACE_OSGEO_GEOMETRY::IGeometry* value);
- /// \brief
- /// Removes the first occurrence of a specific IGeometry object.
- /// \param value
- /// Input the IGeometry object to remove from the collection.
- System::Void Remove(NAMESPACE_OSGEO_GEOMETRY::IGeometry* value);
- /// \brief
- /// Determines whether the collection contains a specific IGeometry object.
- /// \param value
- /// Input The IGeometry object to locate in the collection.
- /// \return
- System::Boolean Contains(NAMESPACE_OSGEO_GEOMETRY::IGeometry* value);
- /// \brief
- /// \param array
- System::Void CopyTo(NAMESPACE_OSGEO_GEOMETRY::IGeometry* array[],System::Int32 startAt);
- /// \brief
- /// Gets an IGeometry object in the collection.
- /// \param index
- /// Input index of the IGeometry object to retrieve.
- __property NAMESPACE_OSGEO_GEOMETRY::IGeometry *get_RealTypeItem(System::Int32 index);
- /// \brief
- /// Sets the value of the IGeometry object at the specified index
- /// \param index
- /// Input index of the IGeometry object to set.
- /// \param value
- /// Input the value of the IGeometry
- __property System::Void set_RealTypeItem(System::Int32 index, NAMESPACE_OSGEO_GEOMETRY::IGeometry *value);
- /// \brief
- /// \param index
- /// \return
- /// Returns the IGeometry object at the specified index
- __property NAMESPACE_OSGEO_GEOMETRY::IGeometry *get_Item(System::Int32 index);
- /// \brief
- /// \param index
- /// \param value
- /// Input the value of the IGeometry object
- __property System::Void set_Item(System::Int32 index, NAMESPACE_OSGEO_GEOMETRY::IGeometry *value);
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgILineString.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgILineString.h 2007-02-02 00:07:02 UTC (rev 701)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgILineString.h 2007-02-02 00:09:07 UTC (rev 702)
@@ -18,8 +18,11 @@
#pragma once
+class FdoLineStringCollection;
public __gc __interface IDirectPosition;
public __gc class DirectPositionCollection;
@@ -92,6 +95,268 @@
__property NAMESPACE_OSGEO_GEOMETRY::DirectPositionCollection *get_Positions();
+/// \brief
+/// The LineStringCollection class is a collection of LineString objects.
+public __gc __sealed class LineStringCollection
+public:
+ /// \brief
+ /// Constructs a managed object based on an unmanaged instance of the object
+ /// Input Indicates if the constructed element should be automatically deleted
+ LineStringCollection(System::IntPtr unmanaged, System::Boolean autoDelete);
+public private:
+ FdoLineStringCollection *GetImpObj();
+protected:
+private:
+ /// \brief
+ LineStringCollection *m_pCol;
+ public:
+ /// \brief
+ /// \param col
+ Enumerator(LineStringCollection *col)
+ /// \brief
+ /// \return
+ /// \brief
+ /// \return
+ /// \brief
+/// \endcond
+public:
+ /// \brief
+ /// Creates an instance of LineStringCollection with no contained elements.
+ /// \return
+ LineStringCollection();
+private:
+public:
+ /// \brief
+ /// \return
+ /// \brief
+ /// \return
+ /// \brief
+ /// Removes the index-th ILineString from this collection.
+ /// \param index
+ /// \brief
+public:
+ /// \brief
+ /// Adds a ILineString object into the collection.
+ /// \param value
+ /// Input the ILineString object to add.
+ /// \return
+ System::Int32 Add(NAMESPACE_OSGEO_GEOMETRY::ILineString* value);
+ /// \brief
+ /// Determines the index of a specific ILineString object.
+ /// \param value
+ /// Input the ILineString object to locate in the collection.
+ /// \return
+ System::Int32 IndexOf(NAMESPACE_OSGEO_GEOMETRY::ILineString* value);
+ /// \brief
+ /// Inserts an ILineString object to the collection at the specified position.
+ /// \param index
+ /// \param value
+ /// Input the ILineString object to insert.
+ System::Void Insert(System::Int32 index, NAMESPACE_OSGEO_GEOMETRY::ILineString* value);
+ /// \brief
+ /// Removes the first occurrence of a specific ILineString object.
+ /// \param value
+ /// Input the ILineString object to remove from the collection.
+ System::Void Remove(NAMESPACE_OSGEO_GEOMETRY::ILineString* value);
+ /// \brief
+ /// Determines whether the collection contains a specific ILineString object.
+ /// \param value
+ /// Input The ILineString object to locate in the collection.
+ /// \return
+ System::Boolean Contains(NAMESPACE_OSGEO_GEOMETRY::ILineString* value);
+ /// \brief
+ /// \param array
+ System::Void CopyTo(NAMESPACE_OSGEO_GEOMETRY::ILineString* array[],System::Int32 startAt);
+ /// \brief
+ /// Gets an ILineString object in the collection.
+ /// \param index
+ /// Input index of the ILineString object to retrieve.
+ __property NAMESPACE_OSGEO_GEOMETRY::ILineString *get_RealTypeItem(System::Int32 index);
+ /// \brief
+ /// Sets the value of the ILineString object at the specified index
+ /// \param index
+ /// Input index of the ILineString object to set.
+ /// \param value
+ /// Input the value of the ILineString
+ __property System::Void set_RealTypeItem(System::Int32 index, NAMESPACE_OSGEO_GEOMETRY::ILineString *value);
+ /// \brief
+ /// \param index
+ /// \return
+ /// Returns the ILineString object at the specified index
+ __property NAMESPACE_OSGEO_GEOMETRY::ILineString *get_Item(System::Int32 index);
+ /// \brief
+ /// \param index
+ /// \param value
+ /// Input the value of the ILineString object
+ __property System::Void set_Item(System::Int32 index, NAMESPACE_OSGEO_GEOMETRY::ILineString *value);
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgILineStringImp.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgILineStringImp.h 2007-02-02 00:07:02 UTC (rev 701)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgILineStringImp.h 2007-02-02 00:09:07 UTC (rev 702)
@@ -22,7 +22,7 @@
class FdoILineString;
-class FdoLineStringCollection;
@@ -112,240 +112,6 @@
-/// \brief
-/// The LineStringCollection class is a collection of LineString objects.
-public __gc __sealed class LineStringCollection
-public:
- /// \brief
- /// Constructs a managed object based on an unmanaged instance of the object
- /// Input Indicates if the constructed element should be automatically deleted
- LineStringCollection(System::IntPtr unmanaged, System::Boolean autoDelete);
-public private:
- FdoLineStringCollection *GetImpObj();
-protected:
-private:
- /// \brief
- LineStringCollection *m_pCol;
- public:
- /// \brief
- /// \param col
- Enumerator(LineStringCollection *col)
- /// \brief
- /// \return
- /// \brief
- /// \return
- /// \brief
-/// \endcond
-public:
- /// \brief
- /// Creates an instance of LineStringCollection with no contained elements.
- /// \return
- LineStringCollection();
-private:
-public:
- /// \brief
- /// \brief
- /// \brief
- /// Removes the index-th ILineString from this collection.
- /// \param index
- /// \brief
-public:
- /// \brief
- /// Adds a ILineString object into the collection.
- /// \param value
- /// Input the ILineString object to add.
- /// \return
- System::Int32 Add(NAMESPACE_OSGEO_GEOMETRY::ILineString* value);
- /// \brief
- /// Determines the index of a specific ILineString object.
- /// \param value
- /// Input the ILineString object to locate in the collection.
- /// \return
- System::Int32 IndexOf(NAMESPACE_OSGEO_GEOMETRY::ILineString* value);
- /// \brief
- /// Inserts an ILineString object to the collection at the specified position.
- /// \param index
- /// \param value
- /// Input the ILineString object to insert.
- System::Void Insert(System::Int32 index, NAMESPACE_OSGEO_GEOMETRY::ILineString* value);
- /// \brief
- /// Removes the first occurrence of a specific ILineString object.
- /// \param value
- /// Input the ILineString object to remove from the collection.
- System::Void Remove(NAMESPACE_OSGEO_GEOMETRY::ILineString* value);
- /// \brief
- /// Determines whether the collection contains a specific ILineString object.
- /// \param value
- /// Input The ILineString object to locate in the collection.
- /// \return
- System::Boolean Contains(NAMESPACE_OSGEO_GEOMETRY::ILineString* value);
- /// \brief
- /// \param array
- System::Void CopyTo(NAMESPACE_OSGEO_GEOMETRY::ILineString* array[],System::Int32 startAt);
- /// \brief
- /// Gets an ILineString object in the collection.
- /// \param index
- /// Input index of the ILineString object to retrieve.
- __property NAMESPACE_OSGEO_GEOMETRY::ILineString *get_RealTypeItem(System::Int32 index);
- /// \brief
- /// Sets the value of the ILineString object at the specified index
- /// \param index
- /// Input index of the ILineString object to set.
- /// \param value
- /// Input the value of the ILineString
- __property System::Void set_RealTypeItem(System::Int32 index, NAMESPACE_OSGEO_GEOMETRY::ILineString *value);
- /// \brief
- /// \param index
- /// \return
- /// Returns the ILineString object at the specified index
- __property NAMESPACE_OSGEO_GEOMETRY::ILineString *get_Item(System::Int32 index);
- /// \brief
- /// \param index
- /// \param value
- /// Input the value of the ILineString object
- __property System::Void set_Item(System::Int32 index, NAMESPACE_OSGEO_GEOMETRY::ILineString *value);
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgILinearRing.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgILinearRing.h 2007-02-02 00:07:02 UTC (rev 701)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgILinearRing.h 2007-02-02 00:09:07 UTC (rev 702)
@@ -21,6 +21,8 @@
#include "mgIRingAbstract.h"
+class FdoLinearRingCollection;
@@ -93,6 +95,268 @@
+/// \brief
+/// The LinearRingCollection class is a collection of ILinearRing objects.
+public __gc __sealed class LinearRingCollection
+public:
+ /// \brief
+ LinearRingCollection(System::IntPtr unmanaged, System::Boolean autoDelete);
+public private:
+ FdoLinearRingCollection *GetImpObj();
+protected:
+private:
+ /// \brief
+ LinearRingCollection *m_pCol;
+ public:
+ /// \brief
+ /// \param col
+ Enumerator(LinearRingCollection *col)
+ /// \brief
+ /// \return
+ /// \brief
+ /// \return
+ /// \brief
+/// \endcond
+public:
+ /// \brief
+ /// Creates an instance of LinearRingCollection with no contained elements.
+ /// \return
+ LinearRingCollection();
+private:
+public:
+ /// \brief
+ /// \return
+ /// \brief
+ /// \return
+ /// \brief
+ /// Removes the index-th ILinearRing from this collection.
+ /// \param index
+ /// \brief
+public:
+ /// \brief
+ /// Adds a ILinearRing object into the collection.
+ /// \param value
+ /// Input the ILinearRing object to add.
+ /// \return
+ System::Int32 Add(NAMESPACE_OSGEO_GEOMETRY::ILinearRing* value);
+ /// \brief
+ /// Determines the index of a specific ILinearRing object.
+ /// \param value
+ /// Input the ILinearRing object to locate in the collection.
+ /// \return
+ System::Int32 IndexOf(NAMESPACE_OSGEO_GEOMETRY::ILinearRing* value);
+ /// \brief
+ /// Inserts an ILinearRing object to the collection at the specified position.
+ /// \param index
+ /// \param value
+ /// Input the ILinearRing object to insert.
+ System::Void Insert(System::Int32 index, NAMESPACE_OSGEO_GEOMETRY::ILinearRing* value);
+ /// \brief
+ /// Removes the first occurrence of a specific ILinearRing object.
+ /// \param value
+ /// Input the ILinearRing object to remove from the collection.
+ System::Void Remove(NAMESPACE_OSGEO_GEOMETRY::ILinearRing* value);
+ /// \brief
+ /// Determines whether the collection contains a specific ILinearRing object.
+ /// \param value
+ /// Input The ILinearRing object to locate in the collection.
+ /// \return
+ System::Boolean Contains(NAMESPACE_OSGEO_GEOMETRY::ILinearRing* value);
+ /// \brief
+ /// \param array
+ System::Void CopyTo(NAMESPACE_OSGEO_GEOMETRY::ILinearRing* array[],System::Int32 startAt);
+ /// \brief
+ /// Gets an ILinearRing object in the collection.
+ /// \param index
+ /// Input index of the ILinearRing object to retrieve.
+ __property NAMESPACE_OSGEO_GEOMETRY::ILinearRing *get_RealTypeItem(System::Int32 index);
+ /// \brief
+ /// Sets the value of the ILinearRing object at the specified index
+ /// \param index
+ /// Input index of the ILinearRing object to set.
+ /// \param value
+ /// Input the value of the ILinearRing
+ __property System::Void set_RealTypeItem(System::Int32 index, NAMESPACE_OSGEO_GEOMETRY::ILinearRing *value);
+ /// \brief
+ /// \param index
+ /// \return
+ /// Returns the ILinearRing object at the specified index
+ __property NAMESPACE_OSGEO_GEOMETRY::ILinearRing *get_Item(System::Int32 index);
+ /// \brief
+ /// \param index
+ /// \param value
+ /// Input the value of the ILinearRing object
+ __property System::Void set_Item(System::Int32 index, NAMESPACE_OSGEO_GEOMETRY::ILinearRing *value);
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgILinearRingImp.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgILinearRingImp.h 2007-02-02 00:07:02 UTC (rev 701)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgILinearRingImp.h 2007-02-02 00:09:07 UTC (rev 702)
@@ -22,7 +22,7 @@
#include "mgILinearRing.h"
class FdoILinearRing;
-class FdoLinearRingCollection;
-/// \brief
-/// The LinearRingCollection class is a collection of ILinearRing objects.
-public __gc __sealed class LinearRingCollection
-public:
- /// \brief
- LinearRingCollection(System::IntPtr unmanaged, System::Boolean autoDelete);
-public private:
- FdoLinearRingCollection *GetImpObj();
-protected:
-private:
- /// \brief
- LinearRingCollection *m_pCol;
- public:
- /// \brief
- /// \param col
- Enumerator(LinearRingCollection *col)
- /// \brief
- /// \return
- /// \brief
- /// \return
- /// \brief
-/// \endcond
-public:
- /// \brief
- /// Creates an instance of LinearRingCollection with no contained elements.
- /// \return
- LinearRingCollection();
-private:
-public:
- /// \brief
- /// \brief
- /// \brief
- /// Removes the index-th ILinearRing from this collection.
- /// \param index
- /// \brief
-public:
- /// \brief
- /// Adds a ILinearRing object into the collection.
- /// \param value
- /// Input the ILinearRing object to add.
- /// \return
- System::Int32 Add(NAMESPACE_OSGEO_GEOMETRY::ILinearRing* value);
- /// \brief
- /// Determines the index of a specific ILinearRing object.
- /// \param value
- /// Input the ILinearRing object to locate in the collection.
- /// \return
- System::Int32 IndexOf(NAMESPACE_OSGEO_GEOMETRY::ILinearRing* value);
- /// \brief
- /// Inserts an ILinearRing object to the collection at the specified position.
- /// \param index
- /// \param value
- /// Input the ILinearRing object to insert.
- System::Void Insert(System::Int32 index, NAMESPACE_OSGEO_GEOMETRY::ILinearRing* value);
- /// \brief
- /// Removes the first occurrence of a specific ILinearRing object.
- /// \param value
- /// Input the ILinearRing object to remove from the collection.
- System::Void Remove(NAMESPACE_OSGEO_GEOMETRY::ILinearRing* value);
- /// \brief
- /// Determines whether the collection contains a specific ILinearRing object.
- /// \param value
- /// Input The ILinearRing object to locate in the collection.
- /// \return
- System::Boolean Contains(NAMESPACE_OSGEO_GEOMETRY::ILinearRing* value);
- /// \brief
- /// \param array
- System::Void CopyTo(NAMESPACE_OSGEO_GEOMETRY::ILinearRing* array[],System::Int32 startAt);
- /// \brief
- /// Gets an ILinearRing object in the collection.
- /// \param index
- /// Input index of the ILinearRing object to retrieve.
- __property NAMESPACE_OSGEO_GEOMETRY::ILinearRing *get_RealTypeItem(System::Int32 index);
- /// \brief
- /// Sets the value of the ILinearRing object at the specified index
- /// \param index
- /// Input index of the ILinearRing object to set.
- /// \param value
- /// Input the value of the ILinearRing
- __property System::Void set_RealTypeItem(System::Int32 index, NAMESPACE_OSGEO_GEOMETRY::ILinearRing *value);
- /// \brief
- /// \param index
- /// \return
- /// Returns the ILinearRing object at the specified index
- __property NAMESPACE_OSGEO_GEOMETRY::ILinearRing *get_Item(System::Int32 index);
- /// \brief
- /// \param index
- /// \param value
- /// Input the value of the ILinearRing object
- __property System::Void set_Item(System::Int32 index, NAMESPACE_OSGEO_GEOMETRY::ILinearRing *value);
END_NAMESPACE_OSGEO_GEOMETRY
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgIPoint.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgIPoint.h 2007-02-02 00:07:02 UTC (rev 701)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgIPoint.h 2007-02-02 00:09:07 UTC (rev 702)
@@ -20,6 +20,8 @@
+class FdoPointCollection;
BEGIN_NAMESPACE_OSGEO_GEOMETRY
@@ -67,6 +69,262 @@
System::Int32 &dimensionality) = 0;
+/// \brief
+/// The PointCollection class is a collection of Point objects.
+[System::Reflection::DefaultMemberAttribute("RealTypeItem")]
+public __gc __sealed class PointCollection
+ : public NAMESPACE_OSGEO_RUNTIME::Disposable, public System::Collections::IList
+public:
+ /// \brief
+ /// \param unmanaged
+ /// Input A Pointer to the unmanaged object.
+ /// \param autoDelete
+ /// once it no longer referenced.
+ PointCollection(System::IntPtr unmanaged, System::Boolean autoDelete);
+public private:
+ FdoPointCollection *GetImpObj();
+/// \cond DOXYGEN-IGNORE
+protected:
+ __sealed System::Void ReleaseUnmanagedObject();
+private:
+ /// \brief
+ /// A Nested class defined to provide enumeration of Dictionary elements
+ /// Enumerators can be used to read the data in the collection,
+ /// but they cannot be used to modify the underlying collection.
+ /// An enumerator remains valid as long as the collection remains unchanged.
+ /// If changes are made to the collection, such as adding, modifying, or deleting
+ /// elements, the enumerator is irrecoverably invalidated and the next call to
+ /// MoveNext or Reset throws an InvalidOperationException. If the collection is
+ /// modified between MoveNext and Current, Current returns the element that it is
+ /// set to, even if the enumerator is already invalidated.
+ /// The enumerator does not have exclusive access to the collection; therefore,
+ /// enumerating through a collection is intrinsically not a thread-safe procedure.
+ /// Even when a collection is synchronized, other threads can still modify the
+ /// collection, which causes the enumerator to throw an exception. To guarantee
+ /// thread safety during enumeration, you can either lock the collection during
+ /// the entire enumeration or catch the exceptions resulting from changes made
+ /// by other threads.
+ __gc class Enumerator : public System::Collections::IEnumerator
+ PointCollection *m_pCol;
+ System::Int32 m_nIdx;
+ public:
+ /// \brief
+ /// Constructs a new Collection Enumerator
+ /// \param col
+ /// Input The collection to enumerate.
+ Enumerator(PointCollection *col)
+ : m_pCol(col), m_nIdx(-1)
+ /// \brief
+ /// Retrieves the current object at the enumerator location
+ /// \return
+ /// Retuns the current object referenced by the enumerator
+ __property System::Object *get_Current();
+ /// \brief
+ /// At this position, calling the Current property throws an exception.
+ /// Therefore, you must call the MoveNext method to advance the enumerator
+ /// to the first element of the collection before reading the value of Current.
+ /// If MoveNext passes the end of the collection, the enumerator is positioned
+ /// after the last element in the collection and MoveNext returns false.
+ /// When the enumerator is at this position, subsequent calls to MoveNext also return false.
+ /// If the last call to MoveNext returned false, calling Current throws an exception.
+ /// To set Current to the first element of the collection again, you can call Reset
+ /// followed by MoveNext.
+ /// \return
+ /// Retuns true if the Enumerator is able to move to a valid element
+ /// otherwise false.
+ System::Boolean MoveNext();
+ /// \brief
+ /// Initially, the enumerator is positioned before the first element in the collection.
+ /// The Reset method brings the enumerator back to this position.
+ System::Void Reset();
+/// \endcond
+public:
+ /// \brief
+ /// Creates an instance of PointCollection with no contained elements.
+ /// \return
+ /// Returns an empty collection
+ PointCollection();
+private:
+ // System::Collections::ICollection interface properties
+ __property System::Object* System::Collections::ICollection::get_SyncRoot();
+ __property System::Boolean System::Collections::ICollection::get_IsSynchronized();
+ // System::Collections::ICollection interface methods
+ System::Void System::Collections::ICollection::CopyTo(System::Array* array,System::Int32 index);
+ // System::Collections::IList interface properties
+ __property System::Boolean System::Collections::IList::get_IsFixedSize();
+ __property System::Boolean System::Collections::IList::get_IsReadOnly();
+ __property Object* System::Collections::IList::get_Item(System::Int32 index);
+ __property System::Void System::Collections::IList::set_Item(System::Int32 index, Object* value);
+ // System::Collections::IList interface methods
+ System::Int32 System::Collections::IList::Add(Object* value);
+ System::Boolean System::Collections::IList::Contains(Object* value);
+ System::Int32 System::Collections::IList::IndexOf(Object* value);
+ System::Void System::Collections::IList::Insert(System::Int32 index, Object* value);
+ System::Void System::Collections::IList::Remove(Object* value);
+public:
+ /// \brief
+ /// Gets the count of items in collection.
+ /// \return
+ /// Returns the number of items in the collection.
+ __property System::Int32 get_Count(System::Void);
+ /// \brief
+ /// Gets an enumerator that can iterate through a collection.
+ /// \return
+ /// Returns an enumerator on the dictionary.
+ __sealed System::Collections::IEnumerator* GetEnumerator(System::Void);
+ /// \brief
+ /// Removes the index-th IPoint from this collection.
+ /// \param index
+ /// Input index of the element to remove.
+ System::Void RemoveAt(System::Int32 index);
+ /// \brief
+ /// Removes all elements from the collection.
+ System::Void Clear();
+public:
+ /// \brief
+ /// Adds a IPoint object into the collection.
+ /// \param value
+ /// Input the IPoint object to add.
+ /// \return
+ /// The position into which the new element was inserted.
+ System::Int32 Add(NAMESPACE_OSGEO_GEOMETRY::IPoint* value);
+ /// \brief
+ /// Determines the index of a specific IPoint object.
+ /// \param value
+ /// Input the IPoint object to locate in the collection.
+ /// \return
+ /// The index of value if found in the collection; otherwise, -1.
+ System::Int32 IndexOf(NAMESPACE_OSGEO_GEOMETRY::IPoint* value);
+ /// \brief
+ /// Inserts an IPoint object to the collection at the specified position.
+ /// \param index
+ /// Input the zero-based index at which value should be inserted.
+ /// \param value
+ /// Input the IPoint object to insert.
+ System::Void Insert(System::Int32 index, NAMESPACE_OSGEO_GEOMETRY::IPoint* value);
+ /// \brief
+ /// Removes the first occurrence of a specific IPoint object.
+ /// \param value
+ /// Input the IPoint object to remove from the collection.
+ System::Void Remove(NAMESPACE_OSGEO_GEOMETRY::IPoint* value);
+ /// \brief
+ /// Determines whether the collection contains a specific IPoint object.
+ /// \param value
+ /// Input The IPoint object to locate in the collection.
+ /// \return
+ /// True if the value is found in the collection; otherwise, false.
+ System::Boolean Contains(NAMESPACE_OSGEO_GEOMETRY::IPoint* value);
+ /// \brief
+ /// Copies the elements of the collection to an array.
+ /// \param array
+ /// Output the one-dimensional Array that is the destination of the elements copied from this collection.
+ /// \param startAt
+ /// Input an integer that represents the index in array at which copying begins.
+ System::Void CopyTo(NAMESPACE_OSGEO_GEOMETRY::IPoint* array[],System::Int32 startAt);
+ /// \brief
+ /// Gets an IPoint object in the collection.
+ /// \param index
+ /// Input index of the IPoint object to retrieve.
+ __property NAMESPACE_OSGEO_GEOMETRY::IPoint *get_RealTypeItem(System::Int32 index);
+ /// \brief
+ /// Sets the value of the IPoint object at the specified index
+ /// \param index
+ /// Input index of the IPoint object to set.
+ /// \param value
+ /// Input the value of the IPoint
+ __property System::Void set_RealTypeItem(System::Int32 index, NAMESPACE_OSGEO_GEOMETRY::IPoint *value);
+ /// \brief
+ /// \param index
+ /// \return
+ /// Returns the IPoint object at the specified index
+ __property NAMESPACE_OSGEO_GEOMETRY::IPoint *get_Item(System::Int32 index);
+ /// \brief
+ /// \param index
+ /// \param value
+ /// Input the value of the IPoint object
+ __property System::Void set_Item(System::Int32 index, NAMESPACE_OSGEO_GEOMETRY::IPoint *value);
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgIPointImp.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgIPointImp.h 2007-02-02 00:07:02 UTC (rev 701)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgIPointImp.h 2007-02-02 00:09:07 UTC (rev 702)
@@ -17,11 +17,12 @@
#pragma once
#include "mgIGeometryImp.h"
#include "mgIPoint.h"
class FdoIPoint;
-class FdoPointCollection;
@@ -86,205 +87,6 @@
System::Int32 &dimensionality);
-/// \brief
-/// The PointCollection class is a collection of Point objects.
-[System::Reflection::DefaultMemberAttribute("RealTypeItem")]
-public __gc __sealed class PointCollection
- : public NAMESPACE_OSGEO_RUNTIME::Disposable, public System::Collections::IList
-public:
- /// \brief
- /// \param unmanaged
- /// Input A Pointer to the unmanaged object.
- /// \param autoDelete
- /// once it no longer referenced.
- PointCollection(System::IntPtr unmanaged, System::Boolean autoDelete);
-public private:
- FdoPointCollection *GetImpObj();
-protected:
-private:
- /// \brief
- PointCollection *m_pCol;
- public:
- /// \brief
- /// \param col
- Enumerator(PointCollection *col)
- /// \brief
- /// \return
- /// \brief
- /// \return
- /// \brief
-/// \endcond
-public:
- /// \brief
- /// Creates an instance of PointCollection with no contained elements.
- /// \return
- PointCollection();
-private:
-public:
- /// \brief
- /// \brief
- /// \brief
- /// Removes the index-th IPoint from this collection.
- /// \param index
- /// \brief
-public:
- /// \brief
- /// Adds a IPoint object into the collection.
- /// \param value
- /// Input the IPoint object to add.
- /// \return
- System::Int32 Add(NAMESPACE_OSGEO_GEOMETRY::IPoint* value);
- /// \brief
- /// Determines the index of a specific IPoint object.
- /// \param value
- /// Input the IPoint object to locate in the collection.
- /// \return
- System::Int32 IndexOf(NAMESPACE_OSGEO_GEOMETRY::IPoint* value);
- /// \brief
- /// Inserts an IPoint object to the collection at the specified position.
- /// \param index
- /// \param value
- /// Input the IPoint object to insert.
- System::Void Insert(System::Int32 index, NAMESPACE_OSGEO_GEOMETRY::IPoint* value);
- /// \brief
- /// Removes the first occurrence of a specific IPoint object.
- /// \param value
- /// Input the IPoint object to remove from the collection.
- System::Void Remove(NAMESPACE_OSGEO_GEOMETRY::IPoint* value);
- /// \brief
- /// Determines whether the collection contains a specific IPoint object.
- /// \param value
- /// Input The IPoint object to locate in the collection.
- /// \return
- System::Boolean Contains(NAMESPACE_OSGEO_GEOMETRY::IPoint* value);
- /// \brief
- /// \param array
- System::Void CopyTo(NAMESPACE_OSGEO_GEOMETRY::IPoint* array[],System::Int32 startAt);
- /// \brief
- /// Gets or sets an IPoint in the collection.
- /// \param index
- /// Input index of the IPoint to retrieve or set (System::Int32).
- __property NAMESPACE_OSGEO_GEOMETRY::IPoint *get_RealTypeItem(System::Int32 index);
- __property System::Void set_RealTypeItem(System::Int32 index, NAMESPACE_OSGEO_GEOMETRY::IPoint *value);
- __property NAMESPACE_OSGEO_GEOMETRY::IPoint *get_Item(System::Int32 index);
- __property System::Void set_Item(System::Int32 index, NAMESPACE_OSGEO_GEOMETRY::IPoint *value);
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgIPolygon.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgIPolygon.h 2007-02-02 00:07:02 UTC (rev 701)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgIPolygon.h 2007-02-02 00:09:07 UTC (rev 702)
@@ -20,6 +20,8 @@
#include "mgISurfaceAbstract.h"
+class FdoPolygonCollection;
public __gc __interface ILinearRing;
@@ -63,6 +65,262 @@
+/// \brief
+/// The PolygonCollection class is a collection of IPolygon objects.
+public __gc __sealed class PolygonCollection
+public:
+ /// \brief
+ PolygonCollection(System::IntPtr unmanaged, System::Boolean autoDelete);
+public private:
+ FdoPolygonCollection *GetImpObj();
+protected:
+private:
+ /// \brief
+ PolygonCollection *m_pCol;
+ public:
+ /// \brief
+ /// \param col
+ Enumerator(PolygonCollection *col)
+ /// \brief
+ /// \return
+ /// \brief
+ /// \return
+ /// \brief
+/// \endcond
+public:
+ /// \brief
+ /// Creates an instance of PolygonCollection with no contained elements.
+ /// \return
+ PolygonCollection();
+private:
+public:
+ /// \brief
+ /// \return
+ /// \brief
+ /// \return
+ /// \brief
+ /// Removes the index-th IPolygon from this collection.
+ /// \param index
+ /// \brief
+public:
+ /// \brief
+ /// Adds a IPolygon object into the collection.
+ /// \param value
+ /// Input the IPolygon object to add.
+ /// \return
+ System::Int32 Add(NAMESPACE_OSGEO_GEOMETRY::IPolygon* value);
+ /// \brief
+ /// Determines the index of a specific IPolygon object.
+ /// \param value
+ /// Input the IPolygon object to locate in the collection.
+ /// \return
+ System::Int32 IndexOf(NAMESPACE_OSGEO_GEOMETRY::IPolygon* value);
+ /// \brief
+ /// Inserts an IPolygon object to the collection at the specified position.
+ /// \param index
+ /// \param value
+ /// Input the IPolygon object to insert.
+ System::Void Insert(System::Int32 index, NAMESPACE_OSGEO_GEOMETRY::IPolygon* value);
+ /// \brief
+ /// Removes the first occurrence of a specific IPolygon object.
+ /// \param value
+ /// Input the IPolygon object to remove from the collection.
+ System::Void Remove(NAMESPACE_OSGEO_GEOMETRY::IPolygon* value);
+ /// \brief
+ /// Determines whether the collection contains a specific IPolygon object.
+ /// \param value
+ /// Input The IPolygon object to locate in the collection.
+ /// \return
+ System::Boolean Contains(NAMESPACE_OSGEO_GEOMETRY::IPolygon* value);
+ /// \brief
+ /// \param array
+ System::Void CopyTo(NAMESPACE_OSGEO_GEOMETRY::IPolygon* array[],System::Int32 startAt);
+ /// \brief
+ /// Gets an IPolygon object in the collection.
+ /// \param index
+ /// Input index of the IPolygon object to retrieve.
+ __property NAMESPACE_OSGEO_GEOMETRY::IPolygon *get_RealTypeItem(System::Int32 index);
+ /// \brief
+ /// Sets the value of the IPolygon object at the specified index
+ /// \param index
+ /// Input index of the IPolygon object to set.
+ /// \param value
+ /// Input the value of the IPolygon
+ __property System::Void set_RealTypeItem(System::Int32 index, NAMESPACE_OSGEO_GEOMETRY::IPolygon *value);
+ /// \brief
+ /// \param index
+ /// \return
+ /// Returns the IPolygon object at the specified index
+ __property NAMESPACE_OSGEO_GEOMETRY::IPolygon *get_Item(System::Int32 index);
+ /// \brief
+ /// \param index
+ /// \param value
+ /// Input the value of the IPolygon object
+ __property System::Void set_Item(System::Int32 index, NAMESPACE_OSGEO_GEOMETRY::IPolygon *value);
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgIPolygonImp.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgIPolygonImp.h 2007-02-02 00:07:02 UTC (rev 701)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgIPolygonImp.h 2007-02-02 00:09:07 UTC (rev 702)
@@ -21,7 +21,7 @@
#include "mgIPolygon.h"
class FdoIPolygon;
-class FdoPolygonCollection;
@@ -82,205 +82,6 @@
-/// \brief
-/// The PolygonCollection class is a collection of Polygon objects.
-public __gc __sealed class PolygonCollection
-public:
- /// \brief
- PolygonCollection(System::IntPtr unmanaged, System::Boolean autoDelete);
-public private:
- FdoPolygonCollection *GetImpObj();
-/// \cond DOXYGEN-IGNORE
-protected:
- __sealed System::Void ReleaseUnmanagedObject();
-private:
- /// \brief
- /// nested class defined to provide Enumerator.
- __gc class Enumerator : public System::Collections::IEnumerator
- PolygonCollection *m_pCol;
- System::Int32 m_nIdx;
- public:
- /// \brief
- /// Constructs a new Collection Enumerator
- /// \param col
- /// Input The collection to enumerate.
- Enumerator(PolygonCollection *col)
- : m_pCol(col), m_nIdx(-1)
- /// \brief
- /// Retrieves the current object at the enumerator location
- /// \return
- /// Retuns the current object referenced by the enumerator
- __property System::Object *get_Current();
- /// \brief
- /// Initially, the enumerator is positioned before the first element in the collection.
- /// At this position, calling the Current property throws an exception.
- /// Therefore, you must call the MoveNext method to advance the enumerator
- /// to the first element of the collection before reading the value of Current.
- /// If MoveNext passes the end of the collection, the enumerator is positioned
- /// after the last element in the collection and MoveNext returns false.
- /// When the enumerator is at this position, subsequent calls to MoveNext also return false.
- /// If the last call to MoveNext returned false, calling Current throws an exception.
- /// To set Current to the first element of the collection again, you can call Reset
- /// followed by MoveNext.
- /// \return
- /// Retuns true if the Enumerator is able to move to a valid element
- /// otherwise false.
- System::Boolean MoveNext();
- /// \brief
- /// The Reset method brings the enumerator back to this position.
- System::Void Reset();
-/// \endcond
-public:
- /// \brief
- /// Creates an instance of PolygonCollection with no contained elements.
- /// \return
- /// Returns an empty collection
- PolygonCollection();
-private:
- // System::Collections::ICollection
- System::Void System::Collections::ICollection::CopyTo(System::Array* array,System::Int32 index);
- __property System::Object* System::Collections::ICollection::get_SyncRoot(System::Void);
- __property System::Boolean System::Collections::ICollection::get_IsSynchronized(System::Void);
- // System::Collections::IList
- __property System::Boolean System::Collections::IList::get_IsFixedSize(System::Void);
- __property System::Boolean System::Collections::IList::get_IsReadOnly(System::Void);
- System::Int32 System::Collections::IList::Add(Object* value);
- System::Boolean System::Collections::IList::Contains(Object* value);
- System::Int32 System::Collections::IList::IndexOf(Object* value);
- System::Void System::Collections::IList::Insert(System::Int32 index, Object* value);
- System::Void System::Collections::IList::Remove(Object* value);
- __property Object* System::Collections::IList::get_Item(System::Int32 index);
- __property System::Void System::Collections::IList::set_Item(System::Int32 index, Object* value);
-public:
- /// \brief
- /// Gets the count of items in collection.
- __property System::Int32 get_Count(System::Void);
- /// \brief
- /// Gets an enumerator that can iterate through a collection.
- __sealed System::Collections::IEnumerator* GetEnumerator(System::Void);
- /// \brief
- /// Removes the index-th IPolygon from this collection.
- /// \param index
- /// Input index of the element to remove.
- System::Void RemoveAt(System::Int32 index);
- /// \brief
- /// Removes all elements from the collection.
- System::Void Clear();
-public:
- /// \brief
- /// Adds a IPolygon object into the collection.
- /// \param value
- /// Input the IPolygon object to add.
- /// \return
- /// The position into which the new element was inserted.
- System::Int32 Add(NAMESPACE_OSGEO_GEOMETRY::IPolygon* value);
- /// \brief
- /// Determines the index of a specific IPolygon object.
- /// \param value
- /// Input the IPolygon object to locate in the collection.
- /// \return
- /// The index of value if found in the collection; otherwise, -1.
- System::Int32 IndexOf(NAMESPACE_OSGEO_GEOMETRY::IPolygon* value);
- /// \brief
- /// Inserts an IPolygon object to the collection at the specified position.
- /// \param index
- /// Input the zero-based index at which value should be inserted.
- /// \param value
- /// Input the IPolygon object to insert.
- System::Void Insert(System::Int32 index, NAMESPACE_OSGEO_GEOMETRY::IPolygon* value);
- /// \brief
- /// Removes the first occurrence of a specific IPolygon object.
- /// \param value
- /// Input the IPolygon object to remove from the collection.
- System::Void Remove(NAMESPACE_OSGEO_GEOMETRY::IPolygon* value);
- /// \brief
- /// Determines whether the collection contains a specific IPolygon object.
- /// \param value
- /// Input The IPolygon object to locate in the collection.
- /// \return
- /// True if the value is found in the collection; otherwise, false.
- System::Boolean Contains(NAMESPACE_OSGEO_GEOMETRY::IPolygon* value);
- /// \brief
- /// Copies the elements of the collection to an array.
- /// \param array
- /// Output the one-dimensional Array that is the destination of the elements copied from this collection.
- /// \param startAt
- /// Input an integer that represents the index in array at which copying begins.
- System::Void CopyTo(NAMESPACE_OSGEO_GEOMETRY::IPolygon* array[],System::Int32 startAt);
- /// \brief
- /// Gets or sets an IPolygon in the collection.
- /// \param index
- /// Input index of the IPolygon to retrieve or set (System::Int32).
- __property NAMESPACE_OSGEO_GEOMETRY::IPolygon *get_RealTypeItem(System::Int32 index);
- __property System::Void set_RealTypeItem(System::Int32 index, NAMESPACE_OSGEO_GEOMETRY::IPolygon *value);
- __property NAMESPACE_OSGEO_GEOMETRY::IPolygon *get_Item(System::Int32 index);
- __property System::Void set_Item(System::Int32 index, NAMESPACE_OSGEO_GEOMETRY::IPolygon *value);
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgIRing.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgIRing.h 2007-02-02 00:07:02 UTC (rev 701)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgIRing.h 2007-02-02 00:09:07 UTC (rev 702)
@@ -19,9 +19,10 @@
#pragma once
+class FdoRingCollection;
@@ -63,6 +64,262 @@
+/// \brief
+/// The RingCollection class is a collection of IRing objects.
+public __gc __sealed class RingCollection
+public:
+ /// \brief
+ RingCollection(System::IntPtr unmanaged, System::Boolean autoDelete);
+public private:
+ FdoRingCollection *GetImpObj();
+protected:
+private:
+ /// \brief
+ RingCollection *m_pCol;
+ public:
+ /// \brief
+ /// \param col
+ Enumerator(RingCollection *col)
+ /// \brief
+ /// \return
+ /// \brief
+ /// \return
+ /// \brief
+/// \endcond
+public:
+ /// \brief
+ /// Creates an instance of RingCollection with no contained elements.
+ /// \return
+ RingCollection();
+private:
+public:
+ /// \brief
+ /// \return
+ /// \brief
+ /// \return
+ /// \brief
+ /// Removes the index-th IRing from this collection.
+ /// \param index
+ /// \brief
+public:
+ /// \brief
+ /// Adds a IRing object into the collection.
+ /// \param value
+ /// Input the IRing object to add.
+ /// \return
+ System::Int32 Add(NAMESPACE_OSGEO_GEOMETRY::IRing* value);
+ /// \brief
+ /// Determines the index of a specific IRing object.
+ /// \param value
+ /// Input the IRing object to locate in the collection.
+ /// \return
+ System::Int32 IndexOf(NAMESPACE_OSGEO_GEOMETRY::IRing* value);
+ /// \brief
+ /// Inserts an IRing object to the collection at the specified position.
+ /// \param index
+ /// \param value
+ /// Input the IRing object to insert.
+ System::Void Insert(System::Int32 index, NAMESPACE_OSGEO_GEOMETRY::IRing* value);
+ /// \brief
+ /// Removes the first occurrence of a specific IRing object.
+ /// \param value
+ /// Input the IRing object to remove from the collection.
+ System::Void Remove(NAMESPACE_OSGEO_GEOMETRY::IRing* value);
+ /// \brief
+ /// Determines whether the collection contains a specific IRing object.
+ /// \param value
+ /// Input The IRing object to locate in the collection.
+ /// \return
+ System::Boolean Contains(NAMESPACE_OSGEO_GEOMETRY::IRing* value);
+ /// \brief
+ /// \param array
+ System::Void CopyTo(NAMESPACE_OSGEO_GEOMETRY::IRing* array[],System::Int32 startAt);
+ /// \brief
+ /// \param index
+ __property NAMESPACE_OSGEO_GEOMETRY::IRing *get_RealTypeItem(System::Int32 index);
+ /// \brief
+ /// \param index
+ /// \param value
+ __property System::Void set_RealTypeItem(System::Int32 index, NAMESPACE_OSGEO_GEOMETRY::IRing *value);
+ /// \brief
+ /// \param index
+ /// \return
+ __property NAMESPACE_OSGEO_GEOMETRY::IRing *get_Item(System::Int32 index);
+ /// \brief
+ /// \param index
+ /// \param value
+ __property System::Void set_Item(System::Int32 index, NAMESPACE_OSGEO_GEOMETRY::IRing *value);
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgIRingImp.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgIRingImp.h 2007-02-02 00:07:02 UTC (rev 701)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/Geometry/mgIRingImp.h 2007-02-02 00:09:07 UTC (rev 702)
@@ -18,11 +18,12 @@
#pragma once
#include "mgIRingAbstractImp.h"
#include "mgIRing.h"
class FdoIRing;
-class FdoRingCollection;
public __gc __interface ICurveSegmentAbstract;
public __gc class CurveSegmentCollection;
@@ -81,205 +82,6 @@
__property NAMESPACE_OSGEO_GEOMETRY::CurveSegmentCollection *get_CurveSegments();
-/// \brief
-/// The RingCollection class is a collection of Ring objects.
-public __gc __sealed class RingCollection
-public:
- /// \brief
- RingCollection(System::IntPtr unmanaged, System::Boolean autoDelete);
-public private:
- FdoRingCollection *GetImpObj();
-protected:
-private:
- /// \brief
- RingCollection *m_pCol;
- public:
- /// \brief
- /// \param col
- Enumerator(RingCollection *col)
- /// \brief
- /// \return
- /// \brief
- /// \return
- /// \brief
-/// \endcond
-public:
- /// \brief
- /// Creates an instance of RingCollection with no contained elements.
- /// \return
- RingCollection();
-private:
-public:
- /// \brief
- /// \brief
- /// \brief
- /// Removes the index-th IRing from this collection.
- /// \param index
- /// \brief
-public:
- /// \brief
- /// Adds a IRing object into the collection.
- /// \param value
- /// Input the IRing object to add.
- /// \return
- System::Int32 Add(NAMESPACE_OSGEO_GEOMETRY::IRing* value);
- /// \brief
- /// Determines the index of a specific IRing object.
- /// \param value
- /// Input the IRing object to locate in the collection.
- /// \return
- System::Int32 IndexOf(NAMESPACE_OSGEO_GEOMETRY::IRing* value);
- /// \brief
- /// Inserts an IRing object to the collection at the specified position.
- /// \param index
- /// \param value
- /// Input the IRing object to insert.
- System::Void Insert(System::Int32 index, NAMESPACE_OSGEO_GEOMETRY::IRing* value);
- /// \brief
- /// Removes the first occurrence of a specific IRing object.
- /// \param value
- /// Input the IRing object to remove from the collection.
- System::Void Remove(NAMESPACE_OSGEO_GEOMETRY::IRing* value);
- /// \brief
- /// Determines whether the collection contains a specific IRing object.
- /// \param value
- /// Input The IRing object to locate in the collection.
- /// \return
- System::Boolean Contains(NAMESPACE_OSGEO_GEOMETRY::IRing* value);
- /// \brief
- /// \param array
- System::Void CopyTo(NAMESPACE_OSGEO_GEOMETRY::IRing* array[],System::Int32 startAt);
- /// \brief
- /// Gets or sets an IRing in the collection.
- /// \param index
- /// Input index of the IRing to retrieve or set (System::Int32).
- __property NAMESPACE_OSGEO_GEOMETRY::IRing *get_RealTypeItem(System::Int32 index);
- __property System::Void set_RealTypeItem(System::Int32 index, NAMESPACE_OSGEO_GEOMETRY::IRing *value);
- __property NAMESPACE_OSGEO_GEOMETRY::IRing *get_Item(System::Int32 index);
- __property System::Void set_Item(System::Int32 index, NAMESPACE_OSGEO_GEOMETRY::IRing *value);
More information about the fdo-commits
