[fdo-commits] r704 - branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Xml
svn_fdo at osgeo.org svn_fdo at osgeo.org
Thu Feb 1 19:18:52 EST 2007
Author: gregboone
Date: 2007-02-01 19:18:51 -0500 (Thu, 01 Feb 2007)
New Revision: 704
   branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlClassMappingCollection.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlElementMappingCollection.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeatureFlags.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeatureHandler.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeaturePropertyReader.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeaturePropertyWriter.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeatureWriter.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFlags.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlNameCollectionHandler.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlSchemaMapping.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlSerializable.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlSpatialContextFlags.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlSpatialContextReader.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlSpatialContextWriter.h
893057: DOC: FDO Managed API Documentation Updates
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlClassMappingCollection.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlClassMappingCollection.h	2007-02-02 00:11:31 UTC (rev 703)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlClassMappingCollection.h	2007-02-02 00:18:51 UTC (rev 704)
@@ -32,9 +32,28 @@
 [System::Reflection::DefaultMemberAttribute("RealTypeItem")]
 public __sealed __gc class XmlClassMappingCollection : public NAMESPACE_OSGEO_RUNTIME::Disposable, public System::Collections::IList
+/// \cond DOXYGEN-IGNORE
 private:
     /// \brief
-    /// 		nested class defined to provide Enumerator.
+    /// A Nested class defined to provide enumeration of Dictionary elements
+    /// Enumerators can be used to read the data in the collection,
+    /// but they cannot be used to modify the underlying collection.
+    /// An enumerator remains valid as long as the collection remains unchanged.
+    /// If changes are made to the collection, such as adding, modifying, or deleting
+    /// elements, the enumerator is irrecoverably invalidated and the next call to
+    /// MoveNext or Reset throws an InvalidOperationException. If the collection is
+    /// modified between MoveNext and Current, Current returns the element that it is
+    /// set to, even if the enumerator is already invalidated.
+    /// The enumerator does not have exclusive access to the collection; therefore,
+    /// enumerating through a collection is intrinsically not a thread-safe procedure.
+    /// Even when a collection is synchronized, other threads can still modify the
+    /// collection, which causes the enumerator to throw an exception. To guarantee
+    /// thread safety during enumeration, you can either lock the collection during
+    /// the entire enumeration or catch the exceptions resulting from changes made
+    /// by other threads.
 	__gc class Enumerator : public System::Collections::IEnumerator
@@ -43,15 +62,47 @@
 		System::Int32 m_nIdx;
 	public:
+        /// \brief
+        /// Constructs a new Collection Enumerator
+        /// \param col
+        /// Input The collection to enumerate.
 		Enumerator(XmlClassMappingCollection* elements) : m_pCol(elements), m_nIdx(-1)
-		__property System::Object* get_Current();
+        /// \brief
+        /// Retrieves the current object at the enumerator location
+        /// \return
+        /// Retuns the current object referenced by the enumerator
+		__property System::Object *get_Current();
+        /// \brief
+        /// Initially, the enumerator is positioned before the first object in the collection.
+        /// At this position, calling the Current property throws an exception.
+        /// Therefore, you must call the MoveNext method to advance the enumerator
+        /// to the first element of the collection before reading the value of Current.
+        /// If MoveNext passes the end of the collection, the enumerator is positioned
+        /// after the last element in the collection and MoveNext returns false.
+        /// When the enumerator is at this position, subsequent calls to MoveNext also return false.
+        /// If the last call to MoveNext returned false, calling Current throws an exception.
+        /// To set Current to the first element of the collection again, you can call Reset
+        /// followed by MoveNext.
+        /// \return
+        /// Retuns true if the Enumerator is able to move to a valid element
+        /// otherwise false.
 		System::Boolean MoveNext();
+        /// \brief
+        /// Initially, the enumerator is positioned before the first element in the collection.
+        /// The Reset method brings the enumerator back to this position.
 		System::Void Reset();
@@ -64,57 +115,58 @@
 	inline FdoXmlClassMappingCollection* GetImpObj();
 private:
-    /// System::Collections::ICollection interfaces
-	System::Void System::Collections::ICollection::CopyTo(System::Array* array,System::Int32 index);
+    // System::Collections::ICollection interface properties
+    __property System::Object* System::Collections::ICollection::get_SyncRoot();
+    __property System::Boolean System::Collections::ICollection::get_IsSynchronized();
-	__property System::Object* System::Collections::ICollection::get_SyncRoot();
+    // System::Collections::ICollection interface methods
+    System::Void System::Collections::ICollection::CopyTo(System::Array* array,System::Int32 index);
-	__property System::Boolean System::Collections::ICollection::get_IsSynchronized();
+    // System::Collections::IList interface properties
+    __property System::Boolean System::Collections::IList::get_IsFixedSize();
+    __property System::Boolean System::Collections::IList::get_IsReadOnly();
+    __property Object* System::Collections::IList::get_Item(System::Int32 index);
+    __property System::Void  System::Collections::IList::set_Item(System::Int32 index, Object* value);
-    // System::Collections::IList interfaces
-	__property System::Boolean System::Collections::IList::get_IsFixedSize();
+    // System::Collections::IList interface methods
+    System::Int32 System::Collections::IList::Add(Object* value);
+    System::Boolean System::Collections::IList::Contains(Object* value);
+    System::Int32 System::Collections::IList::IndexOf(Object* value);
+    System::Void System::Collections::IList::Insert(System::Int32 index, Object* value);
+    System::Void System::Collections::IList::Remove(Object* value);
-	__property System::Boolean System::Collections::IList::get_IsReadOnly();
-	System::Int32 System::Collections::IList::Add(Object* value);
-	System::Boolean System::Collections::IList::Contains(Object* value);
-	System::Int32 System::Collections::IList::IndexOf(Object* value);
-	System::Void System::Collections::IList::Insert(System::Int32 index, Object* value);
-	System::Void System::Collections::IList::Remove(Object* value);
-	__property Object* System::Collections::IList::get_Item(System::Int32 index);
-	__property System::Void  System::Collections::IList::set_Item(System::Int32 index, Object* value);
 protected:
 	System::Void ReleaseUnmanagedObject();
+/// \endcond
 public:
     /// \brief
-    ///     Constructs a new empty string collection
+    /// Constructs a new empty string collection
     /// \return
-    ///     Returns StringCollection
+    /// Returns StringCollection
 	XmlClassMappingCollection(NAMESPACE_OSGEO_FDO_COMMANDS_SCHEMA::PhysicalElementMapping* parent);
     /// \brief
-    ///    Gets the count of items in collection.
+    /// Gets the count of items in collection.
+    /// \return
+    /// Returns the number of items in the collection.
 	__property System::Int32 get_Count(System::Void);
     /// \brief
-    ///    Gets an enumerator that can iterate through a collection.
+    /// Gets an enumerator that can iterate through a collection.
+    /// \return
+    /// Returns an enumerator on the dictionary.
 	__sealed System::Collections::IEnumerator* GetEnumerator(System::Void);
     /// \brief
-    ///     Removes the index-th NAMESPACE_OSGEO_FDO_XML::XmlClassMapping from this collection.
+    /// Removes the index-th NAMESPACE_OSGEO_FDO_XML::XmlClassMapping from this collection.
     /// \param index
     /// Input index of the element to remove.
@@ -122,34 +174,34 @@
 	System::Void RemoveAt(System::Int32 index);
     /// \brief
-    ///     Removes all elements from the collection.
+    /// Removes all elements from the collection.
 	System::Void  Clear();
     /// \brief
-    ///     Adds a NAMESPACE_OSGEO_FDO_XML::XmlClassMapping object into the collection.
+    /// Adds a NAMESPACE_OSGEO_FDO_XML::XmlClassMapping object into the collection.
     /// \param value
     /// Input the NAMESPACE_OSGEO_FDO_XML::XmlClassMapping object to add.
     /// \return
-    /// 		Returns the position into which the new element was inserted.
+    /// Returns the position into which the new element was inserted.
 	System::Int32 Add(NAMESPACE_OSGEO_FDO_XML::XmlClassMapping* value);
     /// \brief
-    ///     Determines the index of a specific NAMESPACE_OSGEO_FDO_XML::XmlClassMapping object.
+    /// Determines the index of a specific NAMESPACE_OSGEO_FDO_XML::XmlClassMapping object.
     /// \param value
     /// Input the NAMESPACE_OSGEO_FDO_XML::XmlClassMapping object to locate in the collection.
     /// \return
-    /// 		The index of value if found in the collection; otherwise, -1.
+    /// The index of value if found in the collection; otherwise, -1.
 	System::Int32 IndexOf(NAMESPACE_OSGEO_FDO_XML::XmlClassMapping* value);
     /// \brief
-    ///     Inserts a NAMESPACE_OSGEO_FDO_XML::XmlClassMapping object into the collection at the specified position.
+    /// Inserts a NAMESPACE_OSGEO_FDO_XML::XmlClassMapping object into the collection at the specified position.
     /// \param index
     /// Input the zero-based index at which value should be inserted.
@@ -159,7 +211,7 @@
 	System::Void Insert(System::Int32 index, NAMESPACE_OSGEO_FDO_XML::XmlClassMapping* value);
     /// \brief
-    ///     Removes the first occurrence of a specific NAMESPACE_OSGEO_FDO_XML::XmlClassMapping object.
+    /// Removes the first occurrence of a specific NAMESPACE_OSGEO_FDO_XML::XmlClassMapping object.
     /// \param value
     /// Input the NAMESPACE_OSGEO_FDO_XML::XmlClassMapping object to remove from the collection.
@@ -167,18 +219,18 @@
 	System::Void Remove(NAMESPACE_OSGEO_FDO_XML::XmlClassMapping* value);
     /// \brief
-    ///     Determines whether the collection contains a specific NAMESPACE_OSGEO_FDO_XML::XmlClassMapping object.
+    /// Determines whether the collection contains a specific NAMESPACE_OSGEO_FDO_XML::XmlClassMapping object.
     /// \param value
     /// Input The NAMESPACE_OSGEO_FDO_XML::XmlClassMapping object to search in the collection.
     /// \return
-    /// 		Returns true if the value is found in the collection; otherwise, false.
+    /// Returns true if the value is found in the collection; otherwise, false.
 	System::Boolean Contains(NAMESPACE_OSGEO_FDO_XML::XmlClassMapping* value);
     /// \brief
-    ///     Copies the elements of the collection to an array.
+    /// Copies the elements of the collection to an array.
     /// \param array
     /// Output the one-dimensional Array that is the destination of the elements copied from this collection.
@@ -187,19 +239,49 @@
 	System::Void CopyTo(NAMESPACE_OSGEO_FDO_XML::XmlClassMapping* array[],System::Int32 size);
     /// \brief
-    ///     Gets or sets a NAMESPACE_OSGEO_FDO_XML::XmlClassMapping in the collection.
+    /// Gets the item in the collection at the specified index.
     /// \param index
-    /// Input index of the NAMESPACE_OSGEO_FDO_XML::XmlClassMapping to retrieve or set (System::Int32).
+    /// The index of the item in the collection. The index is 0 based.
+    /// \return
+    /// Returns an instance of a the collected item.
+    /// Throws an instance of Exception if the index is out of range or an error occurs.
 	__property NAMESPACE_OSGEO_FDO_XML::XmlClassMapping* get_RealTypeItem(System::Int32 index);
+    /// \brief
+    /// Sets the value of the item at the specified index
+    /// \param index
+    /// Input index of the item to set.
+    /// \param value
+    /// Input the value of the item
 	__property System::Void  set_RealTypeItem(System::Int32 index, NAMESPACE_OSGEO_FDO_XML::XmlClassMapping* value);
+    /// \brief
+    /// Gets an item in the collection.
+    /// \param index
+    /// Input index of the item to retrieve.
+    /// \return
+    /// Returns the item at the specified index
 	__property NAMESPACE_OSGEO_FDO_XML::XmlClassMapping* get_Item(System::Int32 index);
+    /// \brief
+    /// \param index
+    /// \param value
 	__property System::Void  set_Item(System::Int32 index, NAMESPACE_OSGEO_FDO_XML::XmlClassMapping* value);
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlElementMappingCollection.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlElementMappingCollection.h	2007-02-02 00:11:31 UTC (rev 703)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlElementMappingCollection.h	2007-02-02 00:18:51 UTC (rev 704)
@@ -32,9 +32,28 @@
 public __sealed __gc class XmlElementMappingCollection : public NAMESPACE_OSGEO_RUNTIME::Disposable, public System::Collections::IList
 private:
     /// \brief
@@ -43,15 +62,47 @@
 	public:
+        /// \brief
+        /// \param col
 		Enumerator(XmlElementMappingCollection* elements) : m_pCol(elements), m_nIdx(-1)
+        /// \brief
+        /// \return
+        /// \brief
+        /// \return
+        /// \brief
 	inline FdoXmlElementMappingCollection* GetImpObj();
 private:
 protected:
+/// \endcond
 public:
     /// \brief
     /// \return
 	XmlElementMappingCollection(NAMESPACE_OSGEO_FDO_COMMANDS_SCHEMA::PhysicalElementMapping* parent);
     /// \brief
+    /// \return
     /// \brief
+    /// \return
     /// \brief
-    ///     Removes the index-th NAMESPACE_OSGEO_FDO_XML::XmlElementMapping from this collection.
+    /// Removes the index-th NAMESPACE_OSGEO_FDO_XML::XmlElementMapping from this collection.
     /// \param index
     /// \brief
     /// \brief
-    ///     Adds a NAMESPACE_OSGEO_FDO_XML::XmlElementMapping object into the collection.
+    /// Adds a NAMESPACE_OSGEO_FDO_XML::XmlElementMapping object into the collection.
     /// \param value
     /// Input the NAMESPACE_OSGEO_FDO_XML::XmlElementMapping object to add.
     /// \return
 	System::Int32 Add(NAMESPACE_OSGEO_FDO_XML::XmlElementMapping* value);
     /// \brief
-    ///     Determines the index of a specific NAMESPACE_OSGEO_FDO_XML::XmlElementMapping object.
+    /// Determines the index of a specific NAMESPACE_OSGEO_FDO_XML::XmlElementMapping object.
     /// \param value
     /// Input the NAMESPACE_OSGEO_FDO_XML::XmlElementMapping object to locate in the collection.
     /// \return
 	System::Int32 IndexOf(NAMESPACE_OSGEO_FDO_XML::XmlElementMapping* value);
     /// \brief
-    ///     Inserts a NAMESPACE_OSGEO_FDO_XML::XmlElementMapping object into the collection at the specified position.
+    /// Inserts a NAMESPACE_OSGEO_FDO_XML::XmlElementMapping object into the collection at the specified position.
     /// \param index
@@ -159,7 +211,7 @@
 	System::Void Insert(System::Int32 index, NAMESPACE_OSGEO_FDO_XML::XmlElementMapping* value);
     /// \brief
-    ///     Removes the first occurrence of a specific NAMESPACE_OSGEO_FDO_XML::XmlElementMapping object.
+    /// Removes the first occurrence of a specific NAMESPACE_OSGEO_FDO_XML::XmlElementMapping object.
     /// \param value
     /// Input the NAMESPACE_OSGEO_FDO_XML::XmlElementMapping object to remove from the collection.
 	System::Void Remove(NAMESPACE_OSGEO_FDO_XML::XmlElementMapping* value);
     /// \brief
-    ///     Determines whether the collection contains a specific NAMESPACE_OSGEO_FDO_XML::XmlElementMapping object.
+    /// Determines whether the collection contains a specific NAMESPACE_OSGEO_FDO_XML::XmlElementMapping object.
     /// \param value
     /// Input The NAMESPACE_OSGEO_FDO_XML::XmlElementMapping object to search in the collection.
     /// \return
 	System::Boolean Contains(NAMESPACE_OSGEO_FDO_XML::XmlElementMapping* value);
     /// \brief
     /// \param array
@@ -187,21 +239,60 @@
 	System::Void CopyTo(NAMESPACE_OSGEO_FDO_XML::XmlElementMapping* array[],System::Int32 size);
     /// \brief
-    ///     Gets or sets a NAMESPACE_OSGEO_FDO_XML::XmlElementMapping in the collection.
     /// \param index
-    /// Input index of the NAMESPACE_OSGEO_FDO_XML::XmlElementMapping to retrieve or set (System::Int32).
+    /// \return
 	__property NAMESPACE_OSGEO_FDO_XML::XmlElementMapping* get_RealTypeItem(System::Int32 index);
+    /// \brief
+    /// Gets the item in the collection by name.
+    /// \param index
+    /// The name of the item in the collection.
+    /// \return
 	__property NAMESPACE_OSGEO_FDO_XML::XmlElementMapping* get_RealTypeItem(System::String* index);
+    /// \brief
+    /// \param index
+    /// \param value
 	__property System::Void  set_RealTypeItem(System::Int32 index, NAMESPACE_OSGEO_FDO_XML::XmlElementMapping* value);
+    /// \brief
+    /// \param index
+    /// \return
 	__property NAMESPACE_OSGEO_FDO_XML::XmlElementMapping* get_Item(System::Int32 index);
+    /// \brief
+    /// \param index
+    /// \param value
 	__property System::Void  set_Item(System::Int32 index, NAMESPACE_OSGEO_FDO_XML::XmlElementMapping* value);
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeatureFlags.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeatureFlags.h	2007-02-02 00:11:31 UTC (rev 703)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeatureFlags.h	2007-02-02 00:18:51 UTC (rev 704)
@@ -33,23 +33,23 @@
 /// If Document A is read into FDO and then written to Document B then the Error Levels
 /// applied to the Document A read have the following meaning:
 /// <ul>
-///    <li>ErrorLevel_High: Document B will be structurally identical to Document A.
-///    Errors are issued if this cannot be guaranteed. Document B will have the
-///    exact same elements and attributes as Document A.
-///    <li>ErrorLevel_Normal: There is no information loss. Document B contains
-///    all of the information from Document A and Document B conforms to Schema A.
-///    However, Documents A and B might not look exactly alike; some Document A elements
-///    may have an equivalent but different structure in Document B.
-///    <li>ErrorLevel_Low: There can be information loss. Document B is a subset
-///    of Document A but still conforms to Schema A. Errors are issued if
-///    this cannot be guaranteed. Any Document A elements, not recognized by
-///    FDO, are discarded on read.
-///    <li>ErrorLevel_VeryLow: FDO does a best effort read of Document A and write of
-///    Document B. There is no guarantee that Document B will look anything like
-///    Document A or that Document B will conform to Schema A.
+/// <li>ErrorLevel_High: Document B will be structurally identical to Document A.
+/// Errors are issued if this cannot be guaranteed. Document B will have the
+/// exact same elements and attributes as Document A.
+/// <li>ErrorLevel_Normal: There is no information loss. Document B contains
+/// all of the information from Document A and Document B conforms to Schema A.
+/// However, Documents A and B might not look exactly alike; some Document A elements
+/// may have an equivalent but different structure in Document B.
+/// <li>ErrorLevel_Low: There can be information loss. Document B is a subset
+/// of Document A but still conforms to Schema A. Errors are issued if
+/// this cannot be guaranteed. Any Document A elements, not recognized by
+/// FDO, are discarded on read.
+/// <li>ErrorLevel_VeryLow: FDO does a best effort read of Document A and write of
+/// Document B. There is no guarantee that Document B will look anything like
+/// Document A or that Document B will conform to Schema A.
 /// </ul>
 /// The above assumes that FDO is not provided the GML form of Schema A when writing
 /// Document B. For example, supposed that FDO can write a Schema A conformant
 /// Document B only when supplied the GML version of Schema A. FDO will still generate
@@ -311,8 +311,10 @@
 	inline FdoXmlFeatureFlags* GetImpObj();
 protected:
     virtual System::Void ReleaseUnmanagedObject();
+/// \endcond
 END_NAMESPACE_OSGEO_FDO_XML
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeatureHandler.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeatureHandler.h	2007-02-02 00:11:31 UTC (rev 703)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeatureHandler.h	2007-02-02 00:18:51 UTC (rev 704)
@@ -437,14 +437,14 @@
     /// referenced by the current association property:
     /// <ul>
     /// 	<li> if the associated feature is specified by an xlink:href, then
-    ///       the href value is sent through a single FeatureProperty event.
-    ///       The property is named "gml/id".
+    ///   the href value is sent through a single FeatureProperty event.
+    ///   The property is named "gml/id".
     /// 	<li> if the associated feature is specified by its identity property
-    ///       values, then a FeatureProperty event is fired for each identity
-    ///       property value.
+    ///   values, then a FeatureProperty event is fired for each identity
+    ///   property value.
     /// 	<li> if the associated feature is inline (specified by a sub-element of
-    ///       current association property) then a set of FeatureStart,
-    ///       FeatureProperty, and FeatureEnd events are fired.
+    ///   current association property) then a set of FeatureStart,
+    ///   FeatureProperty, and FeatureEnd events are fired.
     /// </ul>
     /// \param featureContext
@@ -523,8 +523,10 @@
 	inline FdoXmlFeatureHandler* GetImpObj();
 protected:
+/// \endcond
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeaturePropertyReader.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeaturePropertyReader.h	2007-02-02 00:11:31 UTC (rev 703)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeaturePropertyReader.h	2007-02-02 00:18:51 UTC (rev 704)
@@ -51,7 +51,7 @@
     /// 	<li> GML FeatureCollection element
     /// 	<li> the element specified by flags->collectionUri and flags->collectionName
     /// 	<li> it has a corresponding class definition, in the given schemas, that
-    ///       derives from the GML AbstractFeatureCollectionType.
+    ///   derives from the GML AbstractFeatureCollectionType.
     /// </ul>
     /// \param reader
@@ -69,7 +69,6 @@
     /// Returns XmlFeaturePropertyReader
 	XmlFeaturePropertyReader(NAMESPACE_OSGEO_COMMON_XML::XmlReader* reader);
 	XmlFeaturePropertyReader(NAMESPACE_OSGEO_COMMON_XML::XmlReader* reader, NAMESPACE_OSGEO_FDO_XML::XmlFeatureFlags* flags);
     /// \brief
@@ -98,9 +97,9 @@
     /// in these schemas, is encountered then one of the following is done:
     /// <ul>
     /// 	<li> an exception is thrown when flags->errorLevel is Normal or higher. The
-    ///       exception reports all such features.
+    ///   exception reports all such features.
     /// 	<li> the feature is read according to a best default translation when the
-    ///       flags->errorLevel is below Normal.
+    ///   flags->errorLevel is below Normal.
     /// </ul>
     /// \param schemas
@@ -130,11 +129,8 @@
     /// Returns false if no feature(s) were read.
 	System::Boolean Parse();
 	System::Boolean Parse(NAMESPACE_OSGEO_FDO_XML::XmlFeatureHandler* featureHandler);
 	System::Boolean Parse(NAMESPACE_OSGEO_FDO_XML::XmlFeatureHandler* featureHandler, NAMESPACE_OSGEO_FDO_XML::XmlFeatureContext* featureContext);
 	System::Boolean Parse(NAMESPACE_OSGEO_FDO_XML::XmlFeatureHandler* featureHandler, NAMESPACE_OSGEO_FDO_XML::XmlFeatureContext* featureContext, System::Boolean incremental);
     /// \brief
@@ -153,8 +149,10 @@
 	inline FdoXmlFeaturePropertyReader* GetImpObj();
 protected:
+/// \endcond
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeaturePropertyWriter.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeaturePropertyWriter.h	2007-02-02 00:11:31 UTC (rev 703)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeaturePropertyWriter.h	2007-02-02 00:18:51 UTC (rev 704)
@@ -259,8 +259,10 @@
 	inline FdoXmlFeaturePropertyWriter* GetImpObj();
 protected:
+/// \endcond
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeatureWriter.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeatureWriter.h	2007-02-02 00:11:31 UTC (rev 703)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFeatureWriter.h	2007-02-02 00:18:51 UTC (rev 704)
@@ -41,11 +41,11 @@
 /// written in GML format. Each feature is written in 3 steps:
 /// <ol>
 /// 	<li> call SetClassDefintion() to define the feature's class name,
-///     schema name, and list of valid properties.
+/// schema name, and list of valid properties.
 /// 	<li> call SetProperty() for each feature property value to set.
 /// 	<li> call WriteFeature() to write the feature with the current
-///     property values. The feature's element name is derived from the
-///     class and schema name.
+/// property values. The feature's element name is derived from the
+/// class and schema name.
 /// </ol>
 /// WriteFeature() ensures that the properties are written in their proper order. This
 /// may have slight performance implications since this writer has to accumulate the
@@ -174,8 +174,10 @@
 	inline FdoXmlFeatureWriter* GetImpObj();
 protected:
-    System::Void ReleaseUnmanagedObject();
+	System::Void ReleaseUnmanagedObject();
+/// \endcond
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFlags.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFlags.h	2007-02-02 00:11:31 UTC (rev 703)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlFlags.h	2007-02-02 00:18:51 UTC (rev 704)
@@ -228,8 +228,10 @@
 	inline FdoXmlFlags* GetImpObj();
 protected:
+/// \endcond
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlNameCollectionHandler.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlNameCollectionHandler.h	2007-02-02 00:11:31 UTC (rev 703)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlNameCollectionHandler.h	2007-02-02 00:18:51 UTC (rev 704)
@@ -23,7 +23,7 @@
 BEGIN_NAMESPACE_OSGEO_FDO_XML
 /// \brief
-/// FdoXmlNameCollectionHandler is a class for serializing and
+/// XmlNameCollectionHandler is a class for serializing and
 /// deserializing fdo:NameCollectionType elements.
 public __gc class XmlNameCollectionHandler : public NAMESPACE_OSGEO_COMMON_XML::XmlSaxHandler
@@ -56,8 +56,10 @@
 	inline FdoXmlNameCollectionHandler* GetImpObj();
 protected:
+/// \endcond
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlSchemaMapping.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlSchemaMapping.h	2007-02-02 00:11:31 UTC (rev 703)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlSchemaMapping.h	2007-02-02 00:18:51 UTC (rev 704)
@@ -28,7 +28,7 @@
 public __gc class XmlClassMappingCollection;
 /// \brief
-/// FdoXmlSchemaMapping specifies overrides for translating a feature schema between
+/// XmlSchemaMapping specifies overrides for translating a feature schema between
 /// FDO and GML.
 public __gc class XmlSchemaMapping : public NAMESPACE_OSGEO_FDO_COMMANDS_SCHEMA::PhysicalSchemaMapping
@@ -65,15 +65,15 @@
     /// Gets the mappings between GML global elements and their types as Fdo Classes. These
     /// mappings are used in two circumstances:
     /// <ul>
-    ///     <li> when features are read from a GML Document, these mappings determine the Feature
-    ///     class of each feature, based on its element name. If the element name is not
-    ///     in these mappings then the class name defaults to the element name.
-    ///     <li> when the Feature Schema for these overrides is written to GML, a global element
-    ///     is created from each item in element mappings collection.
+    /// <li> when features are read from a GML Document, these mappings determine the Feature
+    /// class of each feature, based on its element name. If the element name is not
+    /// in these mappings then the class name defaults to the element name.
+    /// <li> when the Feature Schema for these overrides is written to GML, a global element
+    /// is created from each item in element mappings collection.
     /// </ul>
     /// \return
-    /// Returns FdoXmlElementMappingCollection*
+    /// Returns XmlElementMappingCollection
 	NAMESPACE_OSGEO_FDO_XML::XmlElementMappingCollection* GetElementMappings();
@@ -81,7 +81,7 @@
     /// Gets the mappings for FDO Classes.
     /// \return
-    /// Returns FdoXmlClassMappingCollection*
+    /// Returns XmlClassMappingCollection
 	NAMESPACE_OSGEO_FDO_XML::XmlClassMappingCollection* GetClassMappings();
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlSerializable.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlSerializable.h	2007-02-02 00:11:31 UTC (rev 703)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlSerializable.h	2007-02-02 00:18:51 UTC (rev 704)
@@ -26,9 +26,9 @@
 public __gc class XmlFlags;
 /// \brief
-/// FdoXmlSerializable provides the ability to serialize an FDO object
+/// XmlSerializable provides the ability to serialize an FDO object
 /// to an XML Document. Serialization support can be added to any class by basing
-/// it on FdoXmlSerializable and implementing the _writeXml callback.
+/// it on XmlSerializable and implementing the _writeXml callback.
 public __gc class XmlSerializable : public NAMESPACE_OSGEO_RUNTIME:: Disposable, public NAMESPACE_OSGEO_FDO_XML::IXmlSerializable
 public:
@@ -40,7 +40,7 @@
     /// Input the file name.
     /// \param flags
     /// Input controls the writing of the elements to the document.
-    /// If NULL then the default flags are used (see FdoXmlFlags::Create())
+    /// If NULL then the default flags are used (see XmlFlags::Create())
 	System::Void WriteXml(String* fileName);
@@ -56,7 +56,7 @@
     /// XML writer's current position will be just after this object.
     /// \param flags
     /// Input controls the writing of the elements to the writer.
 	System::Void WriteXml(NAMESPACE_OSGEO_COMMON_XML::XmlWriter* xmlWriter);
@@ -71,7 +71,7 @@
     /// text writer's current position will be just after this object.
     /// \param flags
 	System::Void WriteXml(NAMESPACE_OSGEO_COMMON_IO::IoTextWriter* textWriter);
@@ -86,7 +86,7 @@
     /// stream's current position will be just after this object.
     /// \param flags
     /// Input controls the writing of the elements to the stream.
 	System::Void WriteXml(NAMESPACE_OSGEO_COMMON_IO::IoStream* stream);
@@ -94,7 +94,7 @@
     /// \brief
     /// Gets the stylesheet for converting the XML document from
-    /// internal to external format. When classes derived from FdoXmlSerializable
+    /// internal to external format. When classes derived from XmlSerializable
     /// define an internal format, they must override this function to return a
     /// stylesheet that does the conversion.
@@ -108,8 +108,10 @@
 	inline FdoXmlSerializable* GetImpObj();
 protected:
+/// \endcond
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlSpatialContextFlags.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlSpatialContextFlags.h	2007-02-02 00:11:31 UTC (rev 703)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlSpatialContextFlags.h	2007-02-02 00:18:51 UTC (rev 704)
@@ -28,7 +28,7 @@
 public:
     /// \brief
-    /// The FdoXmlSpatialContextFlags::ConflictOption specifies how
+    /// XmlSpatialContextFlags::ConflictOption specifies how
     /// to handle Spatial Contexts that are already in the DataStore,
     ///  when Deserializing:
@@ -51,7 +51,7 @@
     /// \brief
-    /// Constructs an FdoXmlSpatialContextFlags object.
+    /// Constructs an XmlSpatialContextFlags object.
     /// \param location
     /// Base URL for generating well-known references to
@@ -64,7 +64,7 @@
     /// false: apply name adjustment only to elements with fdo:nameAdjust="true"
     /// \param conflictOption
     /// Input option for Deserializing Spatial Contexts.
-    /// Specified how Spatial Contexts, already in the FDO connection, are handled.
+    /// Specified how Spatial Contexts, already in  connection, are handled.
     /// \param includeDefault
     /// Input true: When Serializing Spatial Contexts, serialize
     /// all contexts including the default.
@@ -119,6 +119,16 @@
 	__property System::Boolean get_IncludeDefault();
+    /// \brief
+    /// Constructs a XmlSpatialContextFlags object based on an unmanaged instance of the object
+    /// \param unmanaged
+    /// Input A Pointer to the unmanaged object.
+    /// \param autoDelete
+    /// Input Indicates if the constructed object should be automatically deleted
+    /// once it no longer referenced.
 	XmlSpatialContextFlags(System::IntPtr unmanaged, System::Boolean autoDelete) : NAMESPACE_OSGEO_FDO_XML::XmlFlags(unmanaged, autoDelete)
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlSpatialContextReader.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlSpatialContextReader.h	2007-02-02 00:11:31 UTC (rev 703)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlSpatialContextReader.h	2007-02-02 00:18:51 UTC (rev 704)
@@ -27,10 +27,10 @@
 public __gc class XmlSpatialContextFlags;
 /// \brief
-/// FdoXmlSpatialContextReader reads Spatial Contexts from an XML
+/// XmlSpatialContextReader reads Spatial Contexts from an XML
 /// document. Unlike other XML Readers, the reading is done procedurally,
-/// rather than through events. FdoXmlSpatialContextReader implements
-/// FdoISpatialContextReader to provide the functions for retrieving the
+/// rather than through events. XmlSpatialContextReader implements
+/// ISpatialContextReader to provide the functions for retrieving the
 /// spatial contexts that were read.
 public __gc class XmlSpatialContextReader : public NAMESPACE_OSGEO_COMMON_XML::XmlSaxHandler, public NAMESPACE_OSGEO_FDO_COMMANDS_SPATIALCONTEXT::ISpatialContextReader
@@ -58,7 +58,7 @@
 	NAMESPACE_OSGEO_COMMON_XML::XmlReader* GetXmlReader();
-    /// FdoISpatialContextReader implementation
+    /// ISpatialContextReader implementation
     /// \brief
     /// Gets the name of the spatial context currently being read.
@@ -169,8 +169,10 @@
 	inline FdoXmlSpatialContextReader* GetImpObj();
 protected:
+/// \endcond
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlSpatialContextWriter.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlSpatialContextWriter.h	2007-02-02 00:11:31 UTC (rev 703)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Xml/mgXmlSpatialContextWriter.h	2007-02-02 00:18:51 UTC (rev 704)
@@ -26,7 +26,7 @@
 /// \brief
-/// FdoXmlSpatialContextWriter writes Spatial Contexts to an
+/// XmlSpatialContextWriter writes Spatial Contexts to an
 /// XML document. This is done by calling the various setter functions
 /// to set the spatial context attributes and then calling
 /// WriteSpatialContext() to write the spatial context using the current
@@ -46,7 +46,7 @@
     /// default flags are used.
     /// \return
-    /// Returns FdoXmlSpatialContextWriter
+    /// Returns XmlSpatialContextWriter
 	XmlSpatialContextWriter(NAMESPACE_OSGEO_COMMON_XML::XmlWriter* writer);
@@ -237,8 +237,10 @@
 	inline FdoXmlSpatialContextWriter* GetImpObj();
 protected:
+/// \endcond
More information about the fdo-commits mailing list
