[fdo-commits] r714 - in branches/3.2.x/Fdo/Unmanaged/Inc: Common/Io Fdo/Commands
svn_fdo at osgeo.org svn_fdo at osgeo.org
Thu Feb 1 20:15:57 EST 2007
Author: gregboone
Date: 2007-02-01 20:15:57 -0500 (Thu, 01 Feb 2007)
New Revision: 714
   branches/3.2.x/Fdo/Unmanaged/Inc/Common/Io/Stream.h
   branches/3.2.x/Fdo/Unmanaged/Inc/Fdo/Commands/CommandType.h
893057: DOC: FDO API Documentation Updates
Modified: branches/3.2.x/Fdo/Unmanaged/Inc/Common/Io/Stream.h
--- branches/3.2.x/Fdo/Unmanaged/Inc/Common/Io/Stream.h	2007-02-02 01:12:57 UTC (rev 713)
+++ branches/3.2.x/Fdo/Unmanaged/Inc/Common/Io/Stream.h	2007-02-02 01:15:57 UTC (rev 714)
@@ -108,7 +108,7 @@
     /// skips over part of the stream.
     /// \param offset
-    /// The number of bytes to skip. if position then
+    /// The number of bytes to skip. if positive then
     /// the current position is moved forward. If negative, the position is
     /// moved backward. The position will remain between the start and end
     /// of the stream. The position is set to the end of the stream if the
Modified: branches/3.2.x/Fdo/Unmanaged/Inc/Fdo/Commands/CommandType.h
--- branches/3.2.x/Fdo/Unmanaged/Inc/Fdo/Commands/CommandType.h	2007-02-02 01:12:57 UTC (rev 713)
+++ branches/3.2.x/Fdo/Unmanaged/Inc/Fdo/Commands/CommandType.h	2007-02-02 01:15:57 UTC (rev 714)
@@ -140,7 +140,7 @@
 /// <param name="(See Description note)">
 /// \note
 /// The following parameters are not supported in this release.
-/// They are provided here for informational use only. Autodesk
+/// They are provided here for informational use only. OSGeo
 /// reserves the right to change the software related to the content herein.
 /// </param>
 /// <param name="FdoCommandType_NetworkShortestPath">
More information about the fdo-commits mailing list
