[fdo-commits] r723 - branches/3.2.x/Fdo/Unmanaged/Inc/Geometry/Fgf
svn_fdo at osgeo.org
Wed Feb 7 02:16:59 EST 2007
Author: gavincramer
Date: 2007-02-07 02:16:59 -0500 (Wed, 07 Feb 2007)
New Revision: 723
branches/3.2.x/Fdo/Unmanaged/Inc/Geometry/Fgf/Factory.h
Fix Geometry pool sharing objects between threads
Modified: branches/3.2.x/Fdo/Unmanaged/Inc/Geometry/Fgf/Factory.h
--- branches/3.2.x/Fdo/Unmanaged/Inc/Geometry/Fgf/Factory.h 2007-02-07 00:45:53 UTC (rev 722)
+++ branches/3.2.x/Fdo/Unmanaged/Inc/Geometry/Fgf/Factory.h 2007-02-07 07:16:59 UTC (rev 723)
@@ -49,6 +49,9 @@
/// The object returned may maintain internal pools
/// of other objects in this package, for performance.
/// Pools will be small, tuned to transient object use.
+ /// Objects returned by this factory are safe to pass
+ /// to other threads (i.e. they won't try to interact
+ /// with the originating thread).
/// \return
/// Returns a FdoFgfGeometryFactory object
@@ -61,7 +64,8 @@
/// \remarks
/// This class is its own factory.
/// This method will return a new, private instance, with any internal
- /// object pools tuned to the input parameters.
+ /// object pools tuned to the input parameters. NOTE: objects created
+ /// by this factory should NOT be passed between threads.
/// \param numGeometries
/// Input Minimum number of geometries to pool.
@@ -544,6 +548,16 @@
FDO_GEOM_API ~FdoFgfGeometryFactory();
+/// \cond DOXYGEN-IGNORE
+ /// Constructor for a private instance.
+ FdoFgfGeometryFactory(
+ FdoInt32 numGeometries,
+ FdoInt32 numPositions,
+ FdoInt32 numEnvelopes,
+ FdoInt32 numCurveSegments,
+ FdoInt32 numRings);
+/// \endcond
#endif
More information about the fdo-commits
