[fdo-commits] r729 - in branches/3.2.x/Utilities/Common: Inc Src
svn_fdo at osgeo.org
Wed Feb 7 14:58:06 EST 2007
Author: danstoica
Date: 2007-02-07 14:58:06 -0500 (Wed, 07 Feb 2007)
New Revision: 729
branches/3.2.x/Utilities/Common/Inc/FdoCommonFilterExecutor.h
branches/3.2.x/Utilities/Common/Src/FdoCommonFilterExecutor.cpp
Misspelled property name in query causes crash
Modified: branches/3.2.x/Utilities/Common/Inc/FdoCommonFilterExecutor.h
--- branches/3.2.x/Utilities/Common/Inc/FdoCommonFilterExecutor.h 2007-02-07 16:05:01 UTC (rev 728)
+++ branches/3.2.x/Utilities/Common/Inc/FdoCommonFilterExecutor.h 2007-02-07 19:58:06 UTC (rev 729)
@@ -72,6 +72,14 @@
static FdoCommonFilterExecutor* Create (FdoIReader* featureReader, FdoIdentifierCollection* compIdents);
/// \brief
+ /// Validate the properties mentioned in the filter against class properties and identifiers.
+ /// \return
+ /// Throws "The identifier 'IdName' was not recognized" exception.
+ static void ValidateFilter( FdoClassDefinition *cls, FdoFilter *filter, FdoIdentifierCollection *selIds = NULL );
+ /// \brief
/// Increase the reference count.
/// \return
Modified: branches/3.2.x/Utilities/Common/Src/FdoCommonFilterExecutor.cpp
--- branches/3.2.x/Utilities/Common/Src/FdoCommonFilterExecutor.cpp 2007-02-07 16:05:01 UTC (rev 728)
+++ branches/3.2.x/Utilities/Common/Src/FdoCommonFilterExecutor.cpp 2007-02-07 19:58:06 UTC (rev 729)
@@ -3797,3 +3797,160 @@
+void FdoCommonFilterExecutor::ValidateFilter( FdoClassDefinition *cls, FdoFilter *filter, FdoIdentifierCollection *selIds )
+ class FdoCommonFilterValidator : public virtual FdoIExpressionProcessor, public virtual FdoIFilterProcessor
+ private:
+ FdoClassDefinition* m_class;
+ FdoIdentifierCollection *m_selectedIds;
+ protected:
+ void HandleExpr( FdoExpression *exp )
+ exp->Process( this );
+ void HandleFilter( FdoFilter *filter )
+ filter->Process( this );
+ public:
+ FdoCommonFilterValidator( FdoClassDefinition *cls, FdoIdentifierCollection *selIds )
+ m_class = cls;
+ m_selectedIds = selIds;
+ virtual void Dispose() { delete this; }
+ /// <summary>Increase the reference count.</summary>
+ /// <returns>Returns the new reference count (value for debugging use only).</returns>
+ FdoInt32 AddRef()
+ // NOTE: due to multiple inheritance, there is an ambiguity in which AddRef() method to call.
+ // Calling BOTH AddRef() methods leads to instances of this class being prematurely released.
+ return FdoIFilterProcessor::AddRef();
+ /// <summary>Decrease the reference count.</summary>
+ FdoInt32 Release ()
+ // NOTE: due to multiple inheritance, there is an ambiguity in which Release() method to call.
+ // Calling BOTH Release() methods leads to instances of this class being prematurely released.
+ return FdoIFilterProcessor::Release();
+ virtual void ProcessBinaryExpression(FdoBinaryExpression& expr)
+ HandleExpr( FdoPtr<FdoExpression>(expr.GetLeftExpression()) );
+ HandleExpr( FdoPtr<FdoExpression>(expr.GetRightExpression()) );
+// Supress warnings C4100: 'expr' : unreferenced formal parameter
+#pragma warning( disable : 4100 )
+ virtual void ProcessBooleanValue(FdoBooleanValue& expr) { }
+ virtual void ProcessByteValue(FdoByteValue& expr){ }
+ virtual void ProcessDateTimeValue(FdoDateTimeValue& expr){ }
+ virtual void ProcessDoubleValue(FdoDoubleValue& expr){ }
+ virtual void ProcessDecimalValue(FdoDecimalValue& expr){ }
+ virtual void ProcessInt16Value(FdoInt16Value& expr){ }
+ virtual void ProcessInt32Value(FdoInt32Value& expr){ }
+ virtual void ProcessInt64Value(FdoInt64Value& expr){ }
+ virtual void ProcessSingleValue(FdoSingleValue& expr){ }
+ virtual void ProcessStringValue(FdoStringValue& expr){ }
+ virtual void ProcessBLOBValue(FdoBLOBValue& expr){ }
+ virtual void ProcessCLOBValue(FdoCLOBValue& expr){ }
+ virtual void ProcessFunction(FdoFunction& expr)
+ FdoPtr<FdoExpressionCollection>col = expr.GetArguments();
+ for(int i=0; i<col->GetCount(); i++)
+ HandleExpr( FdoPtr<FdoExpression>(col->GetItem( i ) ) );
+ virtual void ProcessGeometryValue(FdoGeometryValue& expr){ }
+ virtual void ProcessParameter(FdoParameter& expr){ }
+ virtual void ProcessUnaryExpression(FdoUnaryExpression& expr)
+ HandleExpr( FdoPtr<FdoExpression>(expr.GetExpression()) );
+ virtual void ProcessBinaryLogicalOperator(FdoBinaryLogicalOperator& filter)
+ HandleFilter( FdoPtr<FdoFilter>(filter.GetLeftOperand()) );
+ HandleFilter( FdoPtr<FdoFilter>(filter.GetRightOperand()) );
+ virtual void ProcessComparisonCondition(FdoComparisonCondition& filter)
+ HandleExpr( FdoPtr<FdoExpression>(filter.GetLeftExpression()) );
+ HandleExpr( FdoPtr<FdoExpression>(filter.GetRightExpression()) );
+ virtual void ProcessDistanceCondition(FdoDistanceCondition& filter){ }
+ virtual void ProcessInCondition(FdoInCondition& filter)
+ ProcessIdentifier( *(FdoPtr<FdoIdentifier>(filter.GetPropertyName())) );
+ virtual void ProcessNullCondition(FdoNullCondition& filter)
+ virtual void ProcessSpatialCondition(FdoSpatialCondition& filter){ }
+ virtual void ProcessUnaryLogicalOperator(FdoUnaryLogicalOperator& filter)
+ HandleFilter( FdoPtr<FdoFilter>(filter.GetOperand()) );
+ virtual void ProcessIdentifier(FdoIdentifier& expr)
+ // This is used to validate the property names referenced in the filter.
+ FdoPtr<FdoPropertyDefinitionCollection> props = m_class->GetProperties();
+ FdoPtr<FdoReadOnlyPropertyDefinitionCollection> baseProps = m_class->GetBaseProperties();
+ FdoPtr<FdoPropertyDefinition> prop;
+ int length;
+ // If any of the identifiers is a decorated name of the form <obj proper>.<property>, then this is
+ // an association or object proeperty; assume it exist for now.
+ if( expr.GetScope( length ) && length > 0 )
+ return;
+ // Check properties
+ prop = props->FindItem( expr.GetName() );
+ bool found = ( prop != NULL );
+ if( !found )
+ // Check base properties
+ try
+ prop = baseProps->GetItem( expr.GetName() );
+ found = true;
+ catch(FdoException *exp )
+ exp->Release();
+ // Check computed identifiers
+ if( !found && m_selectedIds )
+ FdoPtr<FdoIdentifier> id = m_selectedIds->FindItem( expr.GetName() );
+ found = ( id != NULL );
+ if ( !found )
+ throw FdoException::Create(FdoException::NLSGetMessage(FDO_NLSID(FDO_81_IDENTIFIER_NOT_FOUND), expr.GetName()));
+ virtual void ProcessComputedIdentifier(FdoComputedIdentifier& expr)
+ FdoCommonFilterValidator validator(cls, selIds);
+ filter->Process( &validator );
More information about the fdo-commits
