[fdo-commits] r738 - branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Raster
svn_fdo at osgeo.org svn_fdo at osgeo.org
Wed Feb 7 16:45:51 EST 2007
Author: gregboone
Date: 2007-02-07 16:45:51 -0500 (Wed, 07 Feb 2007)
New Revision: 738
   branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Raster/mgDataValueCollection.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Raster/mgIRaster.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Raster/mgIRasterImp.h
   branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Raster/mgRasterDataModel.h
893057: DOC: FDO Managed API Documentation Updates
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Raster/mgDataValueCollection.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Raster/mgDataValueCollection.h	2007-02-07 21:44:59 UTC (rev 737)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Raster/mgDataValueCollection.h	2007-02-07 21:45:51 UTC (rev 738)
@@ -235,10 +235,11 @@
     /// \param array
     /// Output the one-dimensional Array that is the destination of the elements copied from this collection.
     /// \param startAt
     /// Input an integer that represents the index in array at which copying begins.
-	System::Void CopyTo(DataValue* array[],System::Int32 size);
+	System::Void CopyTo(DataValue* array[],System::Int32 startAt);
     /// \brief
     /// Gets the item in the collection at the specified index.
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Raster/mgIRaster.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Raster/mgIRaster.h	2007-02-07 21:44:59 UTC (rev 737)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Raster/mgIRaster.h	2007-02-07 21:45:51 UTC (rev 738)
@@ -56,35 +56,35 @@
 	System::Void SetNull ();
     /// \brief
-    ///  Gets the number of bands/channels contained in the raster image.
+    /// Gets the number of bands/channels contained in the raster image.
     /// \return
-    ///  Returns the numbers of bands/channels contained in the raster image.
+    /// Returns the numbers of bands/channels contained in the raster image.
 	__property System::Int32 get_NumberOfBands();
     /// \brief
-    ///  Sets the number of bands/channels contained in the raster image.
+    /// Sets the number of bands/channels contained in the raster image.
     /// \return
-    ///  Returns nothing.
+    /// Returns nothing.
 	__property System::Void set_NumberOfBands (System::Int32 value);
     /// \brief
-    ///  Gets the currently active band/channel.
+    /// Gets the currently active band/channel.
     /// \remarks
     /// IRaster Bounds, DataModel, ImageSize, AuxilliaryProperties and Stream
     /// accessors all conform to the current band.
     /// \return
-    ///  Returns the current active band/channel.
+    /// Returns the current active band/channel.
 	__property System::Int32 get_CurrentBand ();
     /// \brief
-    ///  Sets the currently active band/channel.
+    /// Sets the currently active band/channel.
     /// \remarks
     /// Setting the current band will mean that the Bounds, DataModel, ImageSize,
@@ -92,20 +92,29 @@
     /// will all switch to the specified band.
     /// \return
 	__property System::Void set_CurrentBand (System::Int32 value);
-    /// Get the minimum bounding box around the image.
-    /// The bounds are transformed to the active spatial context.
+    /// \brief
+    /// Get the minimum bounding box around the curent band of the image.
+    /// \return
+    /// Returns the bounds of the raster image
 	__property System::Byte get_Bounds () [];
+    /// \brief
     /// Set the minimum bounding box around the image.
     /// For georeferenced images, the coordinate system is specified by the
     /// spatial context in force when the object is created.  The act of
     /// setting this property georeferences the image.  In order to provide
     /// for non-georeferenced images, this property is Nullable (doesn't
     /// need to be set).
+    /// \param bounds
+    /// The new bounds of the raster image.
 	__property System::Void set_Bounds (System::Byte bounds[]);
     /// \brief
@@ -120,6 +129,8 @@
     /// Sets the data model used by this raster property.
     /// Allowed values are only those data models that are acceptable to the
     /// SupportsDataModel capability.
+    /// \remarks
     /// This attribute specifies the colour/palette model, bits per pixel,
     /// tiling and interleaving. For example, if the bits per pixel of the
     /// data model is 8 and it is set to 24, a conversion would be performed
@@ -128,7 +139,7 @@
     /// transformed and saved.  The next time this image is retrieved
     /// by the client the bits per pixel value would indicate 24.
-    /// \param datamodel
+    /// \param dataModel
     /// The datamodel to be used.
 	__property System::Void set_DataModel (NAMESPACE_OSGEO_FDO_RASTER::RasterDataModel* dataModel);
@@ -206,17 +217,17 @@
 	NAMESPACE_OSGEO_FDO_RASTER::IRasterPropertyDictionary* GetAuxiliaryProperties();
     /// \brief
-    ///  Gets the pixel value that represents a NULL value in the available raster stream.
+    /// Gets the pixel value that represents a NULL value in the available raster stream.
     /// \remarks
-    ///  The Null Pixel Value is Data Model dependent. The value of the Null pixel
+    /// The Null Pixel Value is Data Model dependent. The value of the Null pixel
     /// will change depending on which data model is set. If the client application changes
     /// the Data Model using SetDataModel(RasterDataModel* datamodel) a subsequent
     /// call to GetNullPixelValue will need to be made in order to determine the valid Null
     /// value for the current data model.
     /// \return
-    ///  Returns the DataType value that can be used to identify the Null value.
+    /// Returns the DataType value that can be used to identify the Null value.
 	__property NAMESPACE_OSGEO_FDO_EXPRESSION::DataValue* get_NullPixelValue ();
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Raster/mgIRasterImp.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Raster/mgIRasterImp.h	2007-02-07 21:44:59 UTC (rev 737)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Raster/mgIRasterImp.h	2007-02-07 21:45:51 UTC (rev 738)
@@ -49,56 +49,65 @@
     /// \brief
     /// \return
     /// \brief
     /// \return
     /// \brief
     /// \remarks
     /// \return
     /// \brief
     /// \remarks
-    ///  Setting the current band will mean that the Bounds, DataModel, ImageSize,
+    /// Setting the current band will mean that the Bounds, DataModel, ImageSize,
     /// AuxilliaryProperties and Stream accessors of IRaster
     /// \return
+    /// \brief
+    /// \return
+    /// \brief
+    /// \param bounds
     /// \brief
@@ -113,6 +122,8 @@
+    /// \remarks
@@ -122,7 +133,7 @@
-    /// The dataModel to be used.
+    /// The datamodel to be used.
@@ -199,17 +210,17 @@
     /// \brief
     /// \remarks
     /// \return
Modified: branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Raster/mgRasterDataModel.h
--- branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Raster/mgRasterDataModel.h	2007-02-07 21:44:59 UTC (rev 737)
+++ branches/3.2.x/Fdo/Managed/Src/OSGeo/FDO/Raster/mgRasterDataModel.h	2007-02-07 21:45:51 UTC (rev 738)
@@ -72,7 +72,7 @@
     /// \brief
     /// Set the number of bits per pixel.
-    /// \param bpp
+    /// \param bitsPerPixel
     /// The number of bits per pixel desired.
     /// Values of 1, 4, 8, 16, 24, 32, 48 and 64 bits per channel may
     /// be supported. Others values (i.e. indivisible by the number of channels)
@@ -143,7 +143,7 @@
     /// \brief
     /// Sets the data type.
-    /// \param value
+    /// \param dataType
     /// Specifies the data type the raster data is to be returned in.
 	__property System::Void set_DataType (NAMESPACE_OSGEO_FDO_RASTER::RasterDataType dataType);
More information about the fdo-commits mailing list
