[fdo-commits] r751 - branches/3.2.x
    svn_fdo at osgeo.org
    Fri Feb  9 01:01:16 EST 2007
Author: gregboone
Date: 2007-02-09 01:01:14 -0500 (Fri, 09 Feb 2007)
New Revision: 751
   branches/3.2.x/providers.xml
Update FDO 3.2.2 build scripts
Modified: branches/3.2.x/providers.xml
--- branches/3.2.x/providers.xml	2007-02-09 05:55:36 UTC (rev 750)
+++ branches/3.2.x/providers.xml	2007-02-09 06:01:14 UTC (rev 751)
@@ -5,8 +5,8 @@
     <DisplayName>OSGeo FDO Provider for SDF</DisplayName>
     <Description>Read/write access to Autodesk's spatial database format, a file-based personal geodatabase that supports multiple features/attributes, spatial indexing, and file-locking.</Description>
     <IsManaged>False</IsManaged>
-    <Version>3.2.0.0</Version>
-    <FeatureDataObjectsVersion>3.2.0.0</FeatureDataObjectsVersion>
+    <Version>3.2.1.0</Version>
+    <FeatureDataObjectsVersion>3.2.1.0</FeatureDataObjectsVersion>
     <LibraryPath>/usr/local/fdo-3.2.0/lib/libSDFProvider.so</LibraryPath>
   </FeatureProvider>
   <FeatureProvider>
@@ -14,8 +14,8 @@
     <DisplayName>OSGeo FDO Provider for SHP</DisplayName>
     <Description>Read/write access to spatial and attribute data in an ESRI SHP file.</Description>
     <LibraryPath>/usr/local/fdo-3.2.0/lib/libSHPProvider.so</LibraryPath>
   </FeatureProvider>
   <FeatureProvider>
@@ -23,8 +23,8 @@
     <DisplayName>OSGeo FDO Provider for ArcSDE</DisplayName>
     <Description>Read/write access to an ESRI ArcSDE-based data store, using Oracle and SQL Server.</Description>
     <LibraryPath>/usr/local/fdo-3.2.0/lib/libArcSDEProvider.so</LibraryPath>
   </FeatureProvider>
   <FeatureProvider>
@@ -32,8 +32,8 @@
     <DisplayName>OSGeo FDO Provider for WFS</DisplayName>
     <Description>Read access to OGC WFS-based data store.</Description>
     <LibraryPath>/usr/local/fdo-3.2.0/lib/libWFSProvider.so</LibraryPath>
   </FeatureProvider>
   <FeatureProvider>
@@ -41,8 +41,8 @@
     <DisplayName>OSGeo FDO Provider for WMS</DisplayName>
     <Description>Read access to OGC WMS-based data store.</Description>
     <LibraryPath>/usr/local/fdo-3.2.0/lib/libWMSProvider.so</LibraryPath>
   </FeatureProvider>
   <FeatureProvider>
@@ -50,8 +50,8 @@
     <DisplayName>OSGeo FDO Provider for ODBC</DisplayName>
     <Description>FDO Provider for ODBC</Description>
     <LibraryPath>/usr/local/fdo-3.2.0/lib/libFdoODBC.so</LibraryPath>
   </FeatureProvider>
   <FeatureProvider>
@@ -59,8 +59,8 @@
     <DisplayName>OSGeo FDO Provider for MySQL</DisplayName>
     <Description>FDO Provider for MySql</Description>
     <LibraryPath>/usr/local/fdo-3.2.0/lib/libFdoMySQL.so</LibraryPath>
   </FeatureProvider>
   <FeatureProvider>
@@ -68,8 +68,8 @@
     <DisplayName>OSGeo FDO Provider for GDAL</DisplayName>
     <Description>FDO Provider for GDAL</Description>
     <LibraryPath>/usr/local/fdo-3.2.0/lib/libGRFPProvider.so</LibraryPath>
   </FeatureProvider>
 </FeatureProviderRegistry>
More information about the fdo-commits
