[fdo-commits] r756 - branches/3.2.x
svn_fdo at osgeo.org
Fri Feb 9 11:34:19 EST 2007
Author: gregboone
Date: 2007-02-09 11:34:19 -0500 (Fri, 09 Feb 2007)
New Revision: 756
branches/3.2.x/runtestbuild.sh
Update FDO 3.2.2 build scripts
Modified: branches/3.2.x/runtestbuild.sh
--- branches/3.2.x/runtestbuild.sh 2007-02-09 16:32:29 UTC (rev 755)
+++ branches/3.2.x/runtestbuild.sh 2007-02-09 16:34:19 UTC (rev 756)
@@ -202,8 +202,8 @@
export FDO="$PWD/Fdo"
export FDOUTILITIES="$PWD/Utilities"
export FDOTHIRDPARTY="$PWD/Thirdparty"
- mkdir -p "/usr/local/fdo-3.2.2/lib"
- export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/fdo-3.2.2/lib:$SDEHOME/lib
+ mkdir -p "/usr/local/fdo-3.2.0/lib"
+ export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/fdo-3.2.0/lib:$SDEHOME/lib
popd >& /dev/null
echo "*Starting thirdparty build"
More information about the fdo-commits
