[fdo-commits] r2457 - trunk
svn_fdo at osgeo.org svn_fdo at osgeo.org
Fri Feb 9 17:03:03 EST 2007
Author: gregboone
Date: 2007-02-09 17:03:02 -0500 (Fri, 09 Feb 2007)
New Revision: 2457
   trunk/checkoutsvn.sh
   trunk/configure
   trunk/configure.in
   trunk/createtarzipfiles.sh
Update FDO 3.3 build scripts
Modified: trunk/checkoutsvn.sh
--- trunk/checkoutsvn.sh	2007-02-09 21:30:43 UTC (rev 2456)
+++ trunk/checkoutsvn.sh	2007-02-09 22:03:02 UTC (rev 2457)
@@ -56,6 +56,7 @@
 RDBMSENABLECHK=no
 GDALENABLECHK=no
 KINGENABLECHK=no
+OGRENABLECHK=no
 SHOWHELP=no
 FDO_SVN_USERNAME=
@@ -132,6 +133,7 @@
         UTILENABLECHK=no
         GDALENABLECHK=no
         KINGENABLECHK=no
+        OGRENABLECHK=no
      fi
      if test -z "$1"; then
         echo "Invalid parameter"
@@ -153,6 +155,7 @@
         RDBMSENABLECHK=no
         GDALENABLECHK=no
         KINGENABLECHK=no
+        OGRENABLECHK=no
      elif test "$1" == fdocore; then
         FDOCOREENABLECHK=yes
         THRPENABLECHK=no
@@ -180,6 +183,8 @@
         GDALENABLECHK=yes
      elif test "$1" == king; then
         KINGENABLECHK=yes
+     elif test "$1" == ogr; then
+        OGRENABLECHK=yes
      else
 	exit 1
@@ -239,6 +244,7 @@
    echo "                         rdbms"
    echo "                         gdal"
    echo "                         king"
+   echo "                         ogr"
    echo "User:           --u[ser]=user id"
    echo "Password:       --p[assword]=user password"
    echo "**********************************************************"
@@ -323,4 +329,9 @@
    echo "Checking out https://osgeo.org/svn/fdo/$FDO_SVN_SOURCEDIR/Providers/KingOracle"
    svn checkout https://osgeo.org/svn/fdo/$FDO_SVN_SOURCEDIR/Providers/KingOracle "$FDO_SVN_DESTDIR/Providers/KingOracle" --username "$FDO_SVN_USERNAME" --password "$FDO_SVN_PASSWORD"
 fi
+# Check out OGR Provider source files
+if test "$OGRENABLECHK" == yes; then
+   echo "Checking out https://osgeo.org/svn/fdo/$FDO_SVN_SOURCEDIR/Providers/OGR"
+   svn checkout https://osgeo.org/svn/fdo/$FDO_SVN_SOURCEDIR/Providers/OGR "$FDO_SVN_DESTDIR/Providers/OGR" --username "$FDO_SVN_USERNAME" --password "$FDO_SVN_PASSWORD"
+fi
 exit 0
Modified: trunk/configure
--- trunk/configure	2007-02-09 21:30:43 UTC (rev 2456)
+++ trunk/configure	2007-02-09 22:03:02 UTC (rev 2457)
@@ -1,6 +1,6 @@
 #! /bin/sh
 # Guess values for system-dependent variables and create Makefiles.
-# Generated by GNU Autoconf 2.59 for FDO 3.2.0.
+# Generated by GNU Autoconf 2.59 for FDO 3.3.0.
 # Report bugs to <https://fdocore.osgeo.org>.
@@ -287,8 +287,8 @@
 # find a string as large as possible, as long as the shell can cope with it
   for cmd in 'sed 50q "$0"' 'sed 20q "$0"' 'sed 10q "$0"' 'sed 2q "$0"' 'echo test'; do
     # expected sizes: less than 2Kb, 1Kb, 512 bytes, 16 bytes, ...
-    if (echo_test_string="`eval $cmd`") 2>/dev/null &&
-       echo_test_string="`eval $cmd`" &&
+    if (echo_test_string=`eval $cmd`) 2>/dev/null &&
+       echo_test_string=`eval $cmd` &&
        (test "X$echo_test_string" = "X$echo_test_string") 2>/dev/null
     then
       break
@@ -423,8 +423,8 @@
 # Identity of this package.
 PACKAGE_NAME='FDO'
 PACKAGE_TARNAME='fdo'
-PACKAGE_VERSION='3.2.0'
-PACKAGE_STRING='FDO 3.2.0'
+PACKAGE_VERSION='3.3.0'
+PACKAGE_STRING='FDO 3.3.0'
 PACKAGE_BUGREPORT='https://fdocore.osgeo.org'
 ac_unique_file="configure.in"
@@ -955,7 +955,7 @@
   # Omit some internal or obsolete options to make the list less imposing.
   # This message is too long to be a string in the A/UX 3.1 sh.
   cat <<_ACEOF
-\`configure' configures FDO 3.2.0 to adapt to many kinds of systems.
+\`configure' configures FDO 3.3.0 to adapt to many kinds of systems.
 Usage: $0 [OPTION]... [VAR=VALUE]...
@@ -1021,7 +1021,7 @@
 if test -n "$ac_init_help"; then
   case $ac_init_help in
-     short | recursive ) echo "Configuration of FDO 3.2.0:";;
+     short | recursive ) echo "Configuration of FDO 3.3.0:";;
    esac
   cat <<\_ACEOF
@@ -1167,7 +1167,7 @@
 test -n "$ac_init_help" && exit 0
 if $ac_init_version; then
   cat <<\_ACEOF
-FDO configure 3.2.0
+FDO configure 3.3.0
 generated by GNU Autoconf 2.59
 Copyright (C) 2003 Free Software Foundation, Inc.
@@ -1181,7 +1181,7 @@
 This file contains any messages produced by compilers while
 running configure, to aid debugging if configure makes a mistake.
-It was created by FDO $as_me 3.2.0, which was
+It was created by FDO $as_me 3.3.0, which was
 generated by GNU Autoconf 2.59.  Invocation command line was
   $ $0 $@
@@ -1825,7 +1825,7 @@
 # Define the identity of the package.
  PACKAGE='fdo'
- VERSION='3.2.0'
+ VERSION='3.3.0'
 cat >>confdefs.h <<_ACEOF
@@ -3836,7 +3836,7 @@
     if test -f "$ac_dir/$ac_prog" || test -f "$ac_dir/$ac_prog$ac_exeext"; then
       lt_cv_path_LD="$ac_dir/$ac_prog"
       # Check to see if the program is GNU ld.  I'd rather use --version,
-      # but apparently some GNU ld's only accept -v.
+      # but apparently some variants of GNU ld only accept -v.
       # Break only if it was the GNU/non-GNU ld that we prefer.
       case `"$lt_cv_path_LD" -v 2>&1 </dev/null` in
       *GNU* | *'with BFD'*)
@@ -3870,7 +3870,7 @@
 if test "${lt_cv_prog_gnu_ld+set}" = set; then
   echo $ECHO_N "(cached) $ECHO_C" >&6
 else
-  # I'd rather use --version here, but apparently some GNU ld's only accept -v.
+  # I'd rather use --version here, but apparently some GNU lds only accept -v.
 case `$LD -v 2>&1 </dev/null` in
   lt_cv_prog_gnu_ld=yes
@@ -3903,7 +3903,7 @@
 case $host_os in
   darwin*)
     if test "$GCC" = yes; then
-      reload_cmds='$CC -nostdlib ${wl}-r -o $output$reload_objs'
+      reload_cmds='$LTCC $LTCFLAGS -nostdlib ${wl}-r -o $output$reload_objs'
     else
       reload_cmds='$LD$reload_flag -o $output$reload_objs'
     fi
@@ -3919,36 +3919,43 @@
   # Let the user override the test.
   lt_cv_path_NM="$NM"
 else
-  lt_save_ifs="$IFS"; IFS=$PATH_SEPARATOR
-  for ac_dir in $PATH /usr/ccs/bin /usr/ucb /bin; do
-    IFS="$lt_save_ifs"
-    test -z "$ac_dir" && ac_dir=.
-    tmp_nm="$ac_dir/${ac_tool_prefix}nm"
-    if test -f "$tmp_nm" || test -f "$tmp_nm$ac_exeext" ; then
-      # Check to see if the nm accepts a BSD-compat flag.
-      # Adding the `sed 1q' prevents false positives on HP-UX, which says:
-      #   nm: unknown option "B" ignored
-      # Tru64's nm complains that /dev/null is an invalid object file
-      case `"$tmp_nm" -B /dev/null 2>&1 | sed '1q'` in
-      */dev/null* | *'Invalid file or object type'*)
-	lt_cv_path_NM="$tmp_nm -B"
-	break
-	case `"$tmp_nm" -p /dev/null 2>&1 | sed '1q'` in
-	*/dev/null*)
-	  lt_cv_path_NM="$tmp_nm -p"
+  lt_nm_to_check="${ac_tool_prefix}nm"
+  if test -n "$ac_tool_prefix" && test "$build" = "$host"; then
+    lt_nm_to_check="$lt_nm_to_check nm"
+  fi
+  for lt_tmp_nm in $lt_nm_to_check; do
+    lt_save_ifs="$IFS"; IFS=$PATH_SEPARATOR
+    for ac_dir in $PATH /usr/ccs/bin/elf /usr/ccs/bin /usr/ucb /bin; do
+      IFS="$lt_save_ifs"
+      test -z "$ac_dir" && ac_dir=.
+      tmp_nm="$ac_dir/$lt_tmp_nm"
+      if test -f "$tmp_nm" || test -f "$tmp_nm$ac_exeext" ; then
+	# Check to see if the nm accepts a BSD-compat flag.
+	# Adding the `sed 1q' prevents false positives on HP-UX, which says:
+	#   nm: unknown option "B" ignored
+	# Tru64's nm complains that /dev/null is an invalid object file
+	case `"$tmp_nm" -B /dev/null 2>&1 | sed '1q'` in
+	*/dev/null* | *'Invalid file or object type'*)
+	  lt_cv_path_NM="$tmp_nm -B"
 	  break
-	  lt_cv_path_NM=${lt_cv_path_NM="$tmp_nm"} # keep the first match, but
-	  continue # so that we can try to find one that supports BSD flags
+	  case `"$tmp_nm" -p /dev/null 2>&1 | sed '1q'` in
+	  */dev/null*)
+	    lt_cv_path_NM="$tmp_nm -p"
+	    break
+	    lt_cv_path_NM=${lt_cv_path_NM="$tmp_nm"} # keep the first match, but
+	    continue # so that we can try to find one that supports BSD flags
+	  esac
 	esac
-      esac
-    fi
+      fi
+    done
   done
   test -z "$lt_cv_path_NM" && lt_cv_path_NM=nm
 fi
 fi
@@ -4040,7 +4047,7 @@
 hpux10.20* | hpux11*)
   lt_cv_file_magic_cmd=/usr/bin/file
-  case "$host_cpu" in
+  case $host_cpu in
   ia64*)
     lt_cv_deplibs_check_method='file_magic (s[0-9][0-9][0-9]|ELF-[0-9][0-9]) shared object file - IA64'
     lt_cv_file_magic_test_file=/usr/lib/hpux32/libc.so
@@ -4056,6 +4063,11 @@
   esac
+interix3*)
+  # PIC code is broken on Interix 3.x, that's why |\.a not |_pic\.a here
+  lt_cv_deplibs_check_method='match_pattern /lib[^/]+(\.so|\.a)$'
 irix5* | irix6* | nonstopux*)
   case $LD in
   *-32|*"-32 ") libmagic=32-bit;;
@@ -4101,15 +4113,11 @@
   lt_cv_deplibs_check_method=pass_all
-sco3.2v5*)
-  lt_cv_deplibs_check_method=pass_all
 solaris*)
-sysv4 | sysv4.2uw2* | sysv4.3* | sysv5*)
+sysv4 | sysv4.3*)
   case $host_vendor in
   motorola)
     lt_cv_deplibs_check_method='file_magic ELF [0-9][0-9]*-bit [ML]SB (shared object|dynamic lib) M[0-9][0-9]* Version [0-9]'
@@ -4130,10 +4138,13 @@
   siemens)
+  pc)
+    lt_cv_deplibs_check_method=pass_all
   esac
-sysv5OpenUNIX8* | sysv5UnixWare7* | sysv5uw[78]* | unixware7* | sysv4*uw2*)
+sysv5* | sco3.2v5* | sco5v6* | unixware* | OpenUNIX* | sysv4*uw2*)
 esac
@@ -4151,6 +4162,9 @@
 # If no C compiler was specified, use CC.
 LTCC=${LTCC-"$CC"}
+# If no C compiler flags were specified, use CFLAGS.
+LTCFLAGS=${LTCFLAGS-"$CFLAGS"}
 # Allow CC to be a program name with arguments.
 compiler=$CC
@@ -4186,7 +4200,7 @@
 *-*-irix6*)
   # Find out which ABI we are using.
-  echo '#line 4189 "configure"' > conftest.$ac_ext
+  echo '#line 4203 "configure"' > conftest.$ac_ext
   if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
   (eval $ac_compile) 2>&5
   ac_status=$?
@@ -4229,7 +4243,7 @@
   ac_status=$?
   echo "$as_me:$LINENO: \$? = $ac_status" >&5
   (exit $ac_status); }; then
-    case "`/usr/bin/file conftest.o`" in
+    case `/usr/bin/file conftest.o` in
     *32-bit*)
       case $host in
         x86_64-*linux*)
@@ -4342,7 +4356,27 @@
     CFLAGS="$SAVE_CFLAGS"
   fi
+sparc*-*solaris*)
+  # Find out which ABI we are using.
+  echo 'int i;' > conftest.$ac_ext
+  if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
+  (eval $ac_compile) 2>&5
+  ac_status=$?
+  echo "$as_me:$LINENO: \$? = $ac_status" >&5
+  (exit $ac_status); }; then
+    *64-bit*)
+      case $lt_cv_prog_gnu_ld in
+      yes*) LD="${LD-ld} -m elf64_sparc" ;;
+      *)    LD="${LD-ld} -64" ;;
+      esac
+    esac
+  fi
+  rm -rf conftest*
 esac
 need_locks="$enable_libtool_lock"
@@ -5301,7 +5335,7 @@
 # Provide some information about the compiler.
-echo "$as_me:5304:" \
+echo "$as_me:5338:" \
      "checking for Fortran 77 compiler version" >&5
 ac_compiler=`set X $ac_compile; echo $2`
 { (eval echo "$as_me:$LINENO: \"$ac_compiler --version </dev/null >&5\"") >&5
@@ -5498,12 +5532,18 @@
     elif test -x /usr/sbin/sysctl; then
       lt_cv_sys_max_cmd_len=`/usr/sbin/sysctl -n kern.argmax`
     else
-      lt_cv_sys_max_cmd_len=65536 # usable default for *BSD
+      lt_cv_sys_max_cmd_len=65536	# usable default for all BSDs
     fi
     # And add a safety zone
     lt_cv_sys_max_cmd_len=`expr $lt_cv_sys_max_cmd_len \/ 4`
     lt_cv_sys_max_cmd_len=`expr $lt_cv_sys_max_cmd_len \* 3`
+  interix*)
+    # We know the value 262144 and hardcode it with a safety zone (like BSD)
+    lt_cv_sys_max_cmd_len=196608
   osf*)
     # Dr. Hans Ekkehard Plesser reports seeing a kernel panic running configure
     # due to this test when exec_disable_arg_limit is 1 on Tru64. It is not
@@ -5517,6 +5557,17 @@
       esac
     fi
+  sco3.2v5*)
+    lt_cv_sys_max_cmd_len=102400
+  sysv5* | sco5v6* | sysv4.2uw2*)
+    kargmax=`grep ARG_MAX /etc/conf/cf.d/stune 2>/dev/null`
+    if test -n "$kargmax"; then
+      lt_cv_sys_max_cmd_len=`echo $kargmax | sed 's/.*[ 	]//'`
+    else
+      lt_cv_sys_max_cmd_len=32768
+    fi
     # If test is not a shell built-in, we'll probably end up computing a
     # maximum length that is only half of the actual maximum length, but
@@ -5602,9 +5653,18 @@
 osf*)
   symcode='[BCDEGQRST]'
-solaris* | sysv5*)
+solaris*)
   symcode='[BDRT]'
+sco3.2v5*)
+  symcode='[DT]'
+sysv4.2uw2*)
+  symcode='[DT]'
+sysv5* | sco5v6* | unixware* | OpenUNIX*)
+  symcode='[ABDT]'
 sysv4)
   symcode='[DFNSTU]'
@@ -5813,7 +5873,7 @@
 default_ofile=libtool
 can_build_shared=yes
-# All known linkers require a `.a' archive for static linking (except M$VC,
+# All known linkers require a `.a' archive for static linking (except MSVC,
 # which needs '.lib').
 libext=a
 ltmain="$ac_aux_dir/ltmain.sh"
@@ -6070,6 +6130,7 @@
 test -z "$AS" && AS=as
 test -z "$CC" && CC=cc
 test -z "$LTCC" && LTCC=$CC
+test -z "$LTCFLAGS" && LTCFLAGS=$CFLAGS
 test -z "$DLLTOOL" && DLLTOOL=dlltool
 test -z "$LD" && LD=ld
 test -z "$LN_S" && LN_S="ln -s"
@@ -6089,10 +6150,10 @@
 if test -n "$RANLIB"; then
   case $host_os in
   openbsd*)
-    old_postinstall_cmds="\$RANLIB -t \$oldlib~$old_postinstall_cmds"
+    old_postinstall_cmds="$old_postinstall_cmds~\$RANLIB -t \$oldlib"
-    old_postinstall_cmds="\$RANLIB \$oldlib~$old_postinstall_cmds"
+    old_postinstall_cmds="$old_postinstall_cmds~\$RANLIB \$oldlib"
   esac
   old_archive_cmds="$old_archive_cmds~\$RANLIB \$oldlib"
@@ -6134,7 +6195,7 @@
       if test -n "$file_magic_test_file"; then
 	case $deplibs_check_method in
 	"file_magic "*)
-	  file_magic_regex="`expr \"$deplibs_check_method\" : \"file_magic \(.*\)\"`"
+	  file_magic_regex=`expr "$deplibs_check_method" : "file_magic \(.*\)"`
 	  MAGIC_CMD="$lt_cv_path_MAGIC_CMD"
 	  if eval $file_magic_cmd \$file_magic_test_file 2> /dev/null |
 	    $EGREP "$file_magic_regex" > /dev/null; then
@@ -6196,7 +6257,7 @@
 	"file_magic "*)
@@ -6291,6 +6352,9 @@
 LTCC=${LTCC-"$CC"}
 compiler=$CC
@@ -6298,83 +6362,18 @@
 # save warnings/boilerplate of simple test code
 ac_outfile=conftest.$ac_objext
 printf "$lt_simple_compile_test_code" >conftest.$ac_ext
-eval "$ac_compile" 2>&1 >/dev/null | $SED '/^$/d' >conftest.err
+eval "$ac_compile" 2>&1 >/dev/null | $SED '/^$/d; /^ *+/d' >conftest.err
 _lt_compiler_boilerplate=`cat conftest.err`
 $rm conftest*
 printf "$lt_simple_link_test_code" >conftest.$ac_ext
-eval "$ac_link" 2>&1 >/dev/null | $SED '/^$/d' >conftest.err
+eval "$ac_link" 2>&1 >/dev/null | $SED '/^$/d; /^ *+/d' >conftest.err
 _lt_linker_boilerplate=`cat conftest.err`
 $rm conftest*
-# Check for any special shared library compilation flags.
-lt_prog_cc_shlib=
-if test "$GCC" = no; then
-  case $host_os in
-  sco3.2v5*)
-    lt_prog_cc_shlib='-belf'
-  esac
-fi
-if test -n "$lt_prog_cc_shlib"; then
-  { echo "$as_me:$LINENO: WARNING: \`$CC' requires \`$lt_prog_cc_shlib' to build shared libraries" >&5
-echo "$as_me: WARNING: \`$CC' requires \`$lt_prog_cc_shlib' to build shared libraries" >&2;}
-  if echo "$old_CC $old_CFLAGS " | grep "[ 	]$lt_prog_cc_shlib[ 	]" >/dev/null; then :
-  else
-    { echo "$as_me:$LINENO: WARNING: add \`$lt_prog_cc_shlib' to the CC or CFLAGS env variable and reconfigure" >&5
-echo "$as_me: WARNING: add \`$lt_prog_cc_shlib' to the CC or CFLAGS env variable and reconfigure" >&2;}
-    lt_cv_prog_cc_can_build_shared=no
-  fi
-fi
-# Check to make sure the static flag actually works.
-echo "$as_me:$LINENO: checking if $compiler static flag $lt_prog_compiler_static works" >&5
-echo $ECHO_N "checking if $compiler static flag $lt_prog_compiler_static works... $ECHO_C" >&6
-if test "${lt_prog_compiler_static_works+set}" = set; then
-  echo $ECHO_N "(cached) $ECHO_C" >&6
-else
-  lt_prog_compiler_static_works=no
-   save_LDFLAGS="$LDFLAGS"
-   LDFLAGS="$LDFLAGS $lt_prog_compiler_static"
-   printf "$lt_simple_link_test_code" > conftest.$ac_ext
-   if (eval $ac_link 2>conftest.err) && test -s conftest$ac_exeext; then
-     # The compiler can only warn and ignore the option if not recognized
-     # So say no if there are warnings
-     if test -s conftest.err; then
-       # Append any errors to the config.log.
-       cat conftest.err 1>&5
-       $echo "X$_lt_linker_boilerplate" | $Xsed > conftest.exp
-       $SED '/^$/d' conftest.err >conftest.er2
-       if diff conftest.exp conftest.er2 >/dev/null; then
-         lt_prog_compiler_static_works=yes
-       fi
-     else
-     fi
-   fi
-   $rm conftest*
-   LDFLAGS="$save_LDFLAGS"
-fi
-echo "$as_me:$LINENO: result: $lt_prog_compiler_static_works" >&5
-echo "${ECHO_T}$lt_prog_compiler_static_works" >&6
-if test x"$lt_prog_compiler_static_works" = xyes; then
-else
-    lt_prog_compiler_static=
-fi
 lt_prog_compiler_no_builtin_flag=
@@ -6396,20 +6395,20 @@
    # with a dollar sign (not a hyphen), so the echo should work correctly.
    # The option is referenced via a variable to avoid confusing sed.
    lt_compile=`echo "$ac_compile" | $SED \
-   -e 's:.*FLAGS}? :&$lt_compiler_flag :; t' \
+   -e 's:.*FLAGS}\{0,1\} :&$lt_compiler_flag :; t' \
    -e 's: [^ ]*conftest\.: $lt_compiler_flag&:; t' \
    -e 's:$: $lt_compiler_flag:'`
-   (eval echo "\"\$as_me:6402: $lt_compile\"" >&5)
+   (eval echo "\"\$as_me:6401: $lt_compile\"" >&5)
    (eval "$lt_compile" 2>conftest.err)
    ac_status=$?
    cat conftest.err >&5
-   echo "$as_me:6406: \$? = $ac_status" >&5
+   echo "$as_me:6405: \$? = $ac_status" >&5
    if (exit $ac_status) && test -s "$ac_outfile"; then
      # So say no if there are warnings other than the usual output.
-     $echo "X$_lt_compiler_boilerplate" | $Xsed >conftest.exp
-     if test ! -s conftest.err || diff conftest.exp conftest.er2 >/dev/null; then
+     $echo "X$_lt_compiler_boilerplate" | $Xsed -e '/^$/d' >conftest.exp
+     $SED '/^$/d; /^ *+/d' conftest.err >conftest.er2
+     if test ! -s conftest.er2 || diff conftest.exp conftest.er2 >/dev/null; then
        lt_cv_prog_compiler_rtti_exceptions=yes
      fi
    fi
@@ -6470,6 +6469,11 @@
       lt_prog_compiler_pic='-fno-common'
+    interix3*)
+      # Interix 3.x gcc -fpic/-fPIC options generate broken code.
+      # Instead, we relocate shared libraries at runtime.
     msdosdjgpp*)
       # Just because we use GCC doesn't mean we suddenly get shared libraries
       # on systems that don't support them.
@@ -6486,7 +6490,7 @@
     hpux*)
       # PIC is the default for IA64 HP-UX and 64-bit HP-UX, but
       # not for PA HP-UX.
+      case $host_cpu in
       hppa*64*|ia64*)
 	# +Z the default
@@ -6533,7 +6537,7 @@
       lt_prog_compiler_wl='-Wl,'
       # not for PA HP-UX.
+      case $host_cpu in
       hppa*64*|ia64*)
 	# +Z the default
@@ -6563,12 +6567,12 @@
 	lt_prog_compiler_pic='-KPIC'
 	lt_prog_compiler_static='-static'
-      pgcc* | pgf77* | pgf90*)
+      pgcc* | pgf77* | pgf90* | pgf95*)
         # Portland Group compilers (*not* the Pentium gcc compiler,
 	# which looks to be a dead project)
 	lt_prog_compiler_pic='-fpic'
-	lt_prog_compiler_static='-static'
+	lt_prog_compiler_static='-Bstatic'
       ccc*)
@@ -6584,11 +6588,6 @@
       lt_prog_compiler_static='-non_shared'
-    sco3.2v5*)
-      lt_prog_compiler_pic='-Kpic'
-      lt_prog_compiler_static='-dn'
     solaris*)
@@ -6606,7 +6605,7 @@
-    sysv4 | sysv4.2uw2* | sysv4.3* | sysv5*)
+    sysv4 | sysv4.2uw2* | sysv4.3*)
@@ -6619,6 +6618,12 @@
       fi
+    sysv5* | unixware* | sco3.2v5* | sco5v6* | OpenUNIX*)
+      lt_prog_compiler_wl='-Wl,'
+      lt_prog_compiler_pic='-KPIC'
     unicos*)
       lt_prog_compiler_can_build_shared=no
@@ -6658,20 +6663,20 @@
-   (eval echo "\"\$as_me:6664: $lt_compile\"" >&5)
+   (eval echo "\"\$as_me:6669: $lt_compile\"" >&5)
    ac_status=$?
-   echo "$as_me:6668: \$? = $ac_status" >&5
+   echo "$as_me:6673: \$? = $ac_status" >&5
        lt_prog_compiler_pic_works=yes
      fi
    fi
@@ -6692,7 +6697,7 @@
 fi
 fi
-case "$host_os" in
+case $host_os in
   # For platforms which do not support PIC, -DPIC is meaningless:
   *djgpp*)
@@ -6702,6 +6707,48 @@
 esac
+# Check to make sure the static flag actually works.
+wl=$lt_prog_compiler_wl eval lt_tmp_static_flag=\"$lt_prog_compiler_static\"
+echo "$as_me:$LINENO: checking if $compiler static flag $lt_tmp_static_flag works" >&5
+echo $ECHO_N "checking if $compiler static flag $lt_tmp_static_flag works... $ECHO_C" >&6
+if test "${lt_prog_compiler_static_works+set}" = set; then
+  echo $ECHO_N "(cached) $ECHO_C" >&6
+else
+  lt_prog_compiler_static_works=no
+   save_LDFLAGS="$LDFLAGS"
+   LDFLAGS="$LDFLAGS $lt_tmp_static_flag"
+   printf "$lt_simple_link_test_code" > conftest.$ac_ext
+   if (eval $ac_link 2>conftest.err) && test -s conftest$ac_exeext; then
+     # The linker can only warn and ignore the option if not recognized
+     # So say no if there are warnings
+     if test -s conftest.err; then
+       # Append any errors to the config.log.
+       cat conftest.err 1>&5
+       $echo "X$_lt_linker_boilerplate" | $Xsed -e '/^$/d' > conftest.exp
+       if diff conftest.exp conftest.er2 >/dev/null; then
+         lt_prog_compiler_static_works=yes
+       fi
+     else
+     fi
+   fi
+   $rm conftest*
+   LDFLAGS="$save_LDFLAGS"
+fi
+echo "$as_me:$LINENO: result: $lt_prog_compiler_static_works" >&5
+echo "${ECHO_T}$lt_prog_compiler_static_works" >&6
+if test x"$lt_prog_compiler_static_works" = xyes; then
+else
+fi
 echo "$as_me:$LINENO: checking if $compiler supports -c -o file.$ac_objext" >&5
 echo $ECHO_N "checking if $compiler supports -c -o file.$ac_objext... $ECHO_C" >&6
 if test "${lt_cv_prog_compiler_c_o+set}" = set; then
@@ -6720,25 +6767,25 @@
    # Note that $ac_compile itself does not contain backslashes and begins
-   (eval echo "\"\$as_me:6726: $lt_compile\"" >&5)
+   (eval echo "\"\$as_me:6773: $lt_compile\"" >&5)
    (eval "$lt_compile" 2>out/conftest.err)
    ac_status=$?
    cat out/conftest.err >&5
-   echo "$as_me:6730: \$? = $ac_status" >&5
+   echo "$as_me:6777: \$? = $ac_status" >&5
    if (exit $ac_status) && test -s out/conftest2.$ac_objext
    then
-     $echo "X$_lt_compiler_boilerplate" | $Xsed > out/conftest.exp
-     $SED '/^$/d' out/conftest.err >out/conftest.er2
-     if test ! -s out/conftest.err || diff out/conftest.exp out/conftest.er2 >/dev/null; then
+     $echo "X$_lt_compiler_boilerplate" | $Xsed -e '/^$/d' > out/conftest.exp
+     $SED '/^$/d; /^ *+/d' out/conftest.err >out/conftest.er2
+     if test ! -s out/conftest.er2 || diff out/conftest.exp out/conftest.er2 >/dev/null; then
        lt_cv_prog_compiler_c_o=yes
      fi
    fi
-   chmod u+w .
+   chmod u+w . 2>&5
    $rm conftest*
    # SGI C++ compiler will create directory out/ii_files/ for
    # template instantiation
@@ -6834,6 +6881,10 @@
       with_gnu_ld=no
     fi
+  interix*)
+    # we just hope/assume this is gcc and not c89 (= MSVC++)
+    with_gnu_ld=yes
   openbsd*)
     with_gnu_ld=no
@@ -6918,7 +6969,7 @@
       export_symbols_cmds='$NM $libobjs $convenience | $global_symbol_pipe | $SED -e '\''/^[BCDGRS] /s/.* \([^ ]*\)/\1 DATA/'\'' | $SED -e '\''/^[AITW] /s/.* //'\'' | sort | uniq > $export_symbols'
       if $LD --help 2>&1 | grep 'auto-import' > /dev/null; then
-        archive_cmds='$CC -shared $libobjs $deplibs $compiler_flags -o $output_objdir/$soname ${wl}--image-base=0x10000000 ${wl}--out-implib,$lib'
+        archive_cmds='$CC -shared $libobjs $deplibs $compiler_flags -o $output_objdir/$soname ${wl}--enable-auto-image-base -Xlinker --out-implib -Xlinker $lib'
 	# If the export-symbols file already is a .def file (1st line
 	# is EXPORTS), use it as is; otherwise, prepend...
 	archive_expsym_cmds='if test "x`$SED 1q $export_symbols`" = xEXPORTS; then
@@ -6927,22 +6978,38 @@
 	  echo EXPORTS > $output_objdir/$soname.def;
 	  cat $export_symbols >> $output_objdir/$soname.def;
 	fi~
-	$CC -shared $output_objdir/$soname.def $libobjs $deplibs $compiler_flags -o $output_objdir/$soname ${wl}--image-base=0x10000000  ${wl}--out-implib,$lib'
+	$CC -shared $output_objdir/$soname.def $libobjs $deplibs $compiler_flags -o $output_objdir/$soname ${wl}--enable-auto-image-base -Xlinker --out-implib -Xlinker $lib'
       else
 	ld_shlibs=no
       fi
+    interix3*)
+      hardcode_direct=no
+      hardcode_shlibpath_var=no
+      hardcode_libdir_flag_spec='${wl}-rpath,$libdir'
+      export_dynamic_flag_spec='${wl}-E'
+      # Hack: On Interix 3.x, we cannot compile PIC because of a broken gcc.
+      # Instead, shared libraries are loaded at an image base (0x10000000 by
+      # default) and relocated if they conflict, which is a slow very memory
+      # consuming and fragmenting process.  To avoid this, we pick a random,
+      # 256 KiB-aligned image base between 0x50000000 and 0x6FFC0000 at link
+      # time.  Moving up from 0x10000000 also allows more sbrk(2) space.
+      archive_cmds='$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-h,$soname ${wl}--image-base,`expr ${RANDOM-$$} % 4096 / 2 \* 262144 + 1342177280` -o $lib'
+      archive_expsym_cmds='sed "s,^,_," $export_symbols >$output_objdir/$soname.expsym~$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-h,$soname ${wl}--retain-symbols-file,$output_objdir/$soname.expsym ${wl}--image-base,`expr ${RANDOM-$$} % 4096 / 2 \* 262144 + 1342177280` -o $lib'
     linux*)
       if $LD --help 2>&1 | grep ': supported targets:.* elf' > /dev/null; then
 	tmp_addflag=
 	case $cc_basename,$host_cpu in
 	pgcc*)				# Portland Group C compiler
-	  whole_archive_flag_spec=
+	  whole_archive_flag_spec='${wl}--whole-archive`for conv in $convenience\"\"; do test  -n \"$conv\" && new_convenience=\"$new_convenience,$conv\"; done; $echo \"$new_convenience\"` ${wl}--no-whole-archive'
+	  tmp_addflag=' $pic_flag'
-	pgf77* | pgf90* )			# Portland Group f77 and f90 compilers
-	  tmp_addflag=' -fpic -Mnomain' ;;
+	pgf77* | pgf90* | pgf95*)	# Portland Group f77 and f90 compilers
+	  tmp_addflag=' $pic_flag -Mnomain' ;;
 	ecc*,ia64* | icc*,ia64*)		# Intel C compiler on ia64
 	  tmp_addflag=' -i_dynamic' ;;
 	efc*,ia64* | ifort*,ia64*)	# Intel Fortran compiler on ia64
@@ -6973,7 +7040,7 @@
       fi
-    solaris* | sysv5*)
+    solaris*)
       if $LD -v 2>&1 | grep 'BFD 2\.8' > /dev/null; then
 	ld_shlibs=no
 	cat <<EOF 1>&2
@@ -6994,6 +7061,33 @@
       fi
+    sysv5* | sco3.2v5* | sco5v6* | unixware* | OpenUNIX*)
+      case `$LD -v 2>&1` in
+        *\ [01].* | *\ 2.[0-9].* | *\ 2.1[0-5].*)
+	ld_shlibs=no
+	cat <<_LT_EOF 1>&2
+*** Warning: Releases of the GNU linker prior to 2.16.91.0.3 can not
+*** reliably create shared libraries on SCO systems.  Therefore, libtool
+*** is disabling shared libraries support.  We urge you to upgrade GNU
+*** binutils to release 2.16.91.0.3 or newer.  Another option is to modify
+*** your PATH or compiler configuration so that the native linker is
+*** used, and then restart.
+_LT_EOF
+	  if $LD --help 2>&1 | grep ': supported targets:.* elf' > /dev/null; then
+	    hardcode_libdir_flag_spec='`test -z "$SCOABSPATH" && echo ${wl}-rpath,$libdir`'
+	    archive_cmds='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib'
+	    archive_expsym_cmds='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname,\${SCOABSPATH:+${install_libdir}/}$soname,-retain-symbols-file,$export_symbols -o $lib'
+	  else
+	    ld_shlibs=no
+	  fi
+      esac
     sunos4*)
       archive_cmds='$LD -assert pure-text -Bshareable -o $lib $libobjs $deplibs $linker_flags'
       wlarc=
@@ -7027,7 +7121,7 @@
       # Note: this linker hardcodes the directories in LIBPATH if there
       # are no directories specified by -L.
       hardcode_minus_L=yes
-      if test "$GCC" = yes && test -z "$link_static_flag"; then
+      if test "$GCC" = yes && test -z "$lt_prog_compiler_static"; then
 	# Neither direct hardcoding nor static linking is supported with a
 	# broken collect2.
 	hardcode_direct=unsupported
@@ -7061,6 +7155,7 @@
   	    break
   	  fi
 	  done
 	esac
 	exp_sym_flag='-bexport'
@@ -7098,6 +7193,7 @@
   	  hardcode_libdir_flag_spec='-L$libdir'
   	  hardcode_libdir_separator=
 	  fi
 	esac
 	shared_flag='-shared'
 	if test "$aix_use_runtimelinking" = yes; then
@@ -7110,11 +7206,11 @@
   	# chokes on -Wl,-G. The following line is correct:
 	  shared_flag='-G'
 	else
-  	if test "$aix_use_runtimelinking" = yes; then
+	  if test "$aix_use_runtimelinking" = yes; then
 	    shared_flag='${wl}-G'
 	  else
 	    shared_flag='${wl}-bM:SRE'
-  	fi
+	  fi
 	fi
       fi
@@ -7179,12 +7275,12 @@
 if test -z "$aix_libpath"; then aix_libpath="/usr/lib:/lib"; fi
        hardcode_libdir_flag_spec='${wl}-blibpath:$libdir:'"$aix_libpath"
-	archive_expsym_cmds="\$CC"' -o $output_objdir/$soname $libobjs $deplibs $compiler_flags `if test "x${allow_undefined_flag}" != "x"; then echo "${wl}${allow_undefined_flag}"; else :; fi` '"\${wl}$no_entry_flag \${wl}$exp_sym_flag:\$export_symbols $shared_flag"
+	archive_expsym_cmds="\$CC"' -o $output_objdir/$soname $libobjs $deplibs '"\${wl}$no_entry_flag"' $compiler_flags `if test "x${allow_undefined_flag}" != "x"; then echo "${wl}${allow_undefined_flag}"; else :; fi` '"\${wl}$exp_sym_flag:\$export_symbols $shared_flag"
        else
 	if test "$host_cpu" = ia64; then
 	  hardcode_libdir_flag_spec='${wl}-R $libdir:/usr/lib:/lib'
 	  allow_undefined_flag="-z nodefs"
-	  archive_expsym_cmds="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs $compiler_flags ${wl}${allow_undefined_flag} '"\${wl}$no_entry_flag \${wl}$exp_sym_flag:\$export_symbols"
+	  archive_expsym_cmds="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs '"\${wl}$no_entry_flag"' $compiler_flags ${wl}${allow_undefined_flag} '"\${wl}$exp_sym_flag:\$export_symbols"
 	else
 	 # Determine the default libpath from the value encoded in an empty executable.
 	 cat >conftest.$ac_ext <<_ACEOF
@@ -7244,13 +7340,11 @@
 	  # -berok will link without error, but may produce a broken library.
 	  no_undefined_flag=' ${wl}-bernotok'
 	  allow_undefined_flag=' ${wl}-berok'
-	  # -bexpall does not export symbols beginning with underscore (_)
-	  always_export_symbols=yes
 	  # Exported symbols can be pulled into shared objects from archives
-	  whole_archive_flag_spec=' '
+	  whole_archive_flag_spec='$convenience'
 	  archive_cmds_need_lc=yes
-	  # This is similar to how AIX traditionally builds it's shared libraries.
-	  archive_expsym_cmds="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs $compiler_flags ${wl}-bE:$export_symbols ${wl}-bnoentry${allow_undefined_flag}~$AR $AR_FLAGS $output_objdir/$libname$release.a $output_objdir/$soname'
+	  # This is similar to how AIX traditionally builds its shared libraries.
+	  archive_expsym_cmds="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs ${wl}-bnoentry $compiler_flags ${wl}-bE:$export_symbols${allow_undefined_flag}~$AR $AR_FLAGS $output_objdir/$libname$release.a $output_objdir/$soname'
 	fi
       fi
@@ -7289,7 +7383,7 @@
     darwin* | rhapsody*)
-      case "$host_os" in
+      case $host_os in
         rhapsody* | darwin1.[012])
          allow_undefined_flag='${wl}-undefined ${wl}suppress'
@@ -7318,7 +7412,7 @@
     	output_verbose_link_cmd='echo'
         archive_cmds='$CC -dynamiclib $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring'
       module_cmds='$CC $allow_undefined_flag -o $lib -bundle $libobjs $deplibs$compiler_flags'
-      # Don't fix this by using the ld -exported_symbols_list flag, it doesn't exist in older darwin ld's
+      # Don't fix this by using the ld -exported_symbols_list flag, it doesn't exist in older darwin lds
       archive_expsym_cmds='sed -e "s,#.*,," -e "s,^[    ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -dynamiclib $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
       module_expsym_cmds='sed -e "s,#.*,," -e "s,^[    ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC $allow_undefined_flag  -o $lib -bundle $libobjs $deplibs$compiler_flags~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
     else
@@ -7327,7 +7421,7 @@
          archive_cmds='$CC -qmkshrobj $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-install_name ${wl}`echo $rpath/$soname` $verstring'
          archive_expsym_cmds='sed -e "s,#.*,," -e "s,^[    ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -qmkshrobj $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-install_name ${wl}$rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
@@ -7391,47 +7485,62 @@
-    hpux10* | hpux11*)
+    hpux10*)
       if test "$GCC" = yes -a "$with_gnu_ld" = no; then
-	hppa*64*|ia64*)
+	archive_cmds='$CC -shared -fPIC ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $libobjs $deplibs $compiler_flags'
+      else
+	archive_cmds='$LD -b +h $soname +b $install_libdir -o $lib $libobjs $deplibs $linker_flags'
+      fi
+      if test "$with_gnu_ld" = no; then
+	hardcode_libdir_flag_spec='${wl}+b ${wl}$libdir'
+	hardcode_libdir_separator=:
+	hardcode_direct=yes
+	# hardcode_minus_L: Not really in the search PATH,
+	# but as the default location of the library.
+	hardcode_minus_L=yes
+      fi
+    hpux11*)
+      if test "$GCC" = yes -a "$with_gnu_ld" = no; then
+	case $host_cpu in
+	hppa*64*)
 	  archive_cmds='$CC -shared ${wl}+h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	ia64*)
+	  archive_cmds='$CC -shared ${wl}+h ${wl}$soname ${wl}+nodefaultrpath -o $lib $libobjs $deplibs $compiler_flags'
 	esac
       else
-	hppa*64*|ia64*)
-	  archive_cmds='$LD -b +h $soname -o $lib $libobjs $deplibs $linker_flags'
+	case $host_cpu in
+	hppa*64*)
+	  archive_cmds='$CC -b ${wl}+h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	ia64*)
+	  archive_cmds='$CC -b ${wl}+h ${wl}$soname ${wl}+nodefaultrpath -o $lib $libobjs $deplibs $compiler_flags'
-	  archive_cmds='$LD -b +h $soname +b $install_libdir -o $lib $libobjs $deplibs $linker_flags'
+	  archive_cmds='$CC -b ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $libobjs $deplibs $compiler_flags'
 	esac
       fi
-	hppa*64*)
-	  hardcode_libdir_flag_spec='${wl}+b ${wl}$libdir'
+	case $host_cpu in
+	hppa*64*|ia64*)
 	  hardcode_libdir_flag_spec_ld='+b $libdir'
-	  hardcode_libdir_separator=:
 	  hardcode_direct=no
-	ia64*)
-	  hardcode_libdir_flag_spec='-L$libdir'
-	  hardcode_direct=no
-	  hardcode_shlibpath_var=no
-	  # hardcode_minus_L: Not really in the search PATH,
-	  # but as the default location of the library.
-	  hardcode_minus_L=yes
 	  hardcode_direct=yes
@@ -7533,14 +7642,6 @@
-    sco3.2v5*)
-      archive_cmds='$LD -G -h $soname -o $lib $libobjs $deplibs $linker_flags'
-      export_dynamic_flag_spec='${wl}-Bexport'
-      runpath_var=LD_RUN_PATH
-      hardcode_runpath_var=yes
     solaris*)
       no_undefined_flag=' -z text'
@@ -7626,36 +7727,45 @@
       fi
-    sysv4.2uw2*)
-      archive_cmds='$LD -G -o $lib $libobjs $deplibs $linker_flags'
-      hardcode_direct=yes
-      hardcode_minus_L=no
+    sysv4*uw2* | sysv5OpenUNIX* | sysv5UnixWare7.[01].[10]* | unixware7*)
+      no_undefined_flag='${wl}-z,text'
+      archive_cmds_need_lc=no
+      runpath_var='LD_RUN_PATH'
-   sysv5OpenUNIX8* | sysv5UnixWare7* |  sysv5uw[78]* | unixware7*)
-      no_undefined_flag='${wl}-z ${wl}text'
-	archive_cmds='$CC -shared ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_cmds='$CC -shared ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds='$CC -shared ${wl}-Bexport:$export_symbols ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
       else
-	archive_cmds='$CC -G ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_cmds='$CC -G ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds='$CC -G ${wl}-Bexport:$export_symbols ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
       fi
-      runpath_var='LD_RUN_PATH'
-    sysv5*)
-      no_undefined_flag=' -z text'
-      # $CC -shared without GNU ld will not create a library from C++
-      # object files and a static libstdc++, better avoid it by now
-      archive_cmds='$LD -G${allow_undefined_flag} -h $soname -o $lib $libobjs $deplibs $linker_flags'
-      archive_expsym_cmds='$echo "{ global:" > $lib.exp~cat $export_symbols | $SED -e "s/\(.*\)/\1;/" >> $lib.exp~$echo "local: *; };" >> $lib.exp~
-  		$LD -G${allow_undefined_flag} -M $lib.exp -h $soname -o $lib $libobjs $deplibs $linker_flags~$rm $lib.exp'
+    sysv5* | sco3.2v5* | sco5v6*)
+      # Note: We can NOT use -z defs as we might desire, because we do not
+      # link with -lc, and that would cause any symbols used from libc to
+      # always be unresolved, which means just about no library would
+      # ever link correctly.  If we're not using GNU ld we use -z text
+      # though, which does catch some bad symbols but isn't as heavy-handed
+      # as -z defs.
+      allow_undefined_flag='${wl}-z,nodefs'
+      hardcode_libdir_flag_spec='`test -z "$SCOABSPATH" && echo ${wl}-R,$libdir`'
+      hardcode_libdir_separator=':'
+      link_all_deplibs=yes
+      export_dynamic_flag_spec='${wl}-Bexport'
+      if test "$GCC" = yes; then
+	archive_cmds='$CC -shared ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds='$CC -shared ${wl}-Bexport:$export_symbols ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+      else
+	archive_cmds='$CC -G ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds='$CC -G ${wl}-Bexport:$export_symbols ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+      fi
     uts4*)
@@ -7674,11 +7784,6 @@
 echo "${ECHO_T}$ld_shlibs" >&6
 test "$ld_shlibs" = no && can_build_shared=no
-variables_saved_for_relink="PATH $shlibpath_var $runpath_var"
-if test "$GCC" = yes; then
-  variables_saved_for_relink="$variables_saved_for_relink GCC_EXEC_PREFIX COMPILER_PATH LIBRARY_PATH"
-fi
 # Do we need to explicitly link libc?
@@ -7711,6 +7816,7 @@
         libobjs=conftest.$ac_objext
         deplibs=
+	pic_flag=$lt_prog_compiler_pic
         compiler_flags=-v
         linker_flags=-v
         verstring=
@@ -7871,7 +7977,8 @@
       dlpath=`$SHELL 2>&1 -c '\''. $dir/'\''\${base_file}'\''i;echo \$dlname'\''`~
       dldir=$destdir/`dirname \$dlpath`~
       test -d \$dldir || mkdir -p \$dldir~
-      $install_prog $dir/$dlname \$dldir/$dlname'
+      $install_prog $dir/$dlname \$dldir/$dlname~
+      chmod a+x \$dldir/$dlname'
     postuninstall_cmds='dldll=`$SHELL 2>&1 -c '\''. $file; echo \$dlname'\''`~
       dlpath=$dir/\$dldll~
        $rm \$dlpath'
@@ -7924,7 +8031,7 @@
   soname_spec='${libname}${release}${major}$shared_ext'
   shlibpath_overrides_runpath=yes
   shlibpath_var=DYLD_LIBRARY_PATH
-  shrext_cmds='$(test .$module = .yes && echo .so || echo .dylib)'
+  shrext_cmds='`test .$module = .yes && echo .so || echo .dylib`'
   # Apple's gcc prints 'gcc -print-search-dirs' doesn't operate the same.
     sys_lib_search_path_spec=`$CC -print-search-dirs | tr "\n" "$PATH_SEPARATOR" | sed -e 's/libraries:/@libraries:/' | tr "@" "\n" | grep "^libraries:" | sed -e "s/^libraries://" -e "s,=/,/,g" -e "s,$PATH_SEPARATOR, ,g" -e "s,.*,& /lib /usr/lib /usr/local/lib,g"`
@@ -7962,7 +8069,14 @@
 freebsd* | dragonfly*)
   # DragonFly does not have aout.  When/if they implement a new
   # versioning mechanism, adjust this.
-  objformat=`test -x /usr/bin/objformat && /usr/bin/objformat || echo aout`
+  if test -x /usr/bin/objformat; then
+    objformat=`/usr/bin/objformat`
+  else
+    case $host_os in
+    freebsd[123]*) objformat=aout ;;
+    *) objformat=elf ;;
+    esac
+  fi
   version_type=freebsd-$objformat
   case $version_type in
     freebsd-elf*)
@@ -7984,10 +8098,15 @@
     hardcode_into_libs=yes
-  *) # from 3.2 on
+  freebsd3.[2-9]* | freebsdelf3.[2-9]* | \
+  freebsd4.[0-5] | freebsdelf4.[0-5] | freebsd4.1.1 | freebsdelf4.1.1)
     shlibpath_overrides_runpath=no
+  freebsd*) # from 4.6 on
+    shlibpath_overrides_runpath=yes
+    hardcode_into_libs=yes
   esac
@@ -8007,7 +8126,7 @@
   version_type=sunos
   need_lib_prefix=no
   need_version=no
+  case $host_cpu in
   ia64*)
     shrext_cmds='.so'
@@ -8047,6 +8166,18 @@
   postinstall_cmds='chmod 555 $lib'
+interix3*)
+  version_type=linux
+  need_lib_prefix=no
+  need_version=no
+  library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${shared_ext}'
+  soname_spec='${libname}${release}${shared_ext}$major'
+  dynamic_linker='Interix 3.x ld.so.1 (PE, like ELF)'
+  shlibpath_var=LD_LIBRARY_PATH
+  shlibpath_overrides_runpath=no
   case $host_os in
     nonstopux*) version_type=nonstopux ;;
@@ -8108,7 +8239,7 @@
   libsuff=
   case "$host_cpu" in
   x86_64*|s390x*|powerpc64*)
-    echo '#line 8111 "configure"' > conftest.$ac_ext
+    echo '#line 8242 "configure"' > conftest.$ac_ext
   ac_status=$?
@@ -8127,7 +8258,7 @@
   # Append ld.so.conf contents to the search path
   if test -f /etc/ld.so.conf; then
-    lt_ld_extra=`awk '/^include / { system(sprintf("cd /etc; cat %s", \$2)); skip = 1; } { if (!skip) print \$0; skip = 0; }' < /etc/ld.so.conf | $SED -e 's/#.*//;s/[:,\t]/ /g;s/=[^=]*$//;s/=[^= ]* / /g;/^$/d' | tr '\n' ' '`
+    lt_ld_extra=`awk '/^include / { system(sprintf("cd /etc; cat %s", \$2)); skip = 1; } { if (!skip) print \$0; skip = 0; }' < /etc/ld.so.conf | $SED -e 's/#.*//;s/[:,	]/ /g;s/=[^=]*$//;s/=[^= ]* / /g;/^$/d' | tr '\n' ' '`
     sys_lib_dlsearch_path_spec="/lib${libsuff} /usr/lib${libsuff} $lt_ld_extra"
   fi
@@ -8189,8 +8320,13 @@
 openbsd*)
   version_type=sunos
+  sys_lib_dlsearch_path_spec="/usr/lib"
   need_lib_prefix=no
-  need_version=no
+  # Some older versions of OpenBSD (3.3 at least) *do* need versioned libs.
+  case $host_os in
+    openbsd3.3 | openbsd3.3.*) need_version=yes ;;
+    *)                         need_version=no  ;;
+  esac
   library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${shared_ext}$versuffix'
   finish_cmds='PATH="\$PATH:/sbin" ldconfig -m $libdir'
@@ -8228,13 +8364,6 @@
   sys_lib_dlsearch_path_spec="$sys_lib_search_path_spec"
-sco3.2v5*)
-  version_type=osf
-  soname_spec='${libname}${release}${shared_ext}$major'
-  library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname${shared_ext}'
-  shlibpath_var=LD_LIBRARY_PATH
 solaris*)
   version_type=linux
   need_lib_prefix=no
@@ -8260,7 +8389,7 @@
   need_version=yes
+sysv4 | sysv4.3*)
   version_type=linux
@@ -8293,6 +8422,29 @@
   fi
+  version_type=freebsd-elf
+  need_version=no
+  library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext} $libname${shared_ext}'
+  if test "$with_gnu_ld" = yes; then
+    sys_lib_search_path_spec='/usr/local/lib /usr/gnu/lib /usr/ccs/lib /usr/lib /lib'
+  else
+    sys_lib_search_path_spec='/usr/ccs/lib /usr/lib'
+    case $host_os in
+      sco3.2v5*)
+        sys_lib_search_path_spec="$sys_lib_search_path_spec /lib"
+    esac
+  fi
+  sys_lib_dlsearch_path_spec='/usr/lib'
 uts4*)
   version_type=linux
@@ -8308,6 +8460,11 @@
 echo "${ECHO_T}$dynamic_linker" >&6
 test "$dynamic_linker" = no && can_build_shared=no
+variables_saved_for_relink="PATH $shlibpath_var $runpath_var"
+if test "$GCC" = yes; then
+  variables_saved_for_relink="$variables_saved_for_relink GCC_EXEC_PREFIX COMPILER_PATH LIBRARY_PATH"
+fi
 echo "$as_me:$LINENO: checking how to hardcode library paths into programs" >&5
 echo $ECHO_N "checking how to hardcode library paths into programs... $ECHO_C" >&6
 hardcode_action=
@@ -8963,7 +9120,7 @@
     test "x$ac_cv_header_dlfcn_h" = xyes && CPPFLAGS="$CPPFLAGS -DHAVE_DLFCN_H"
-    eval LDFLAGS=\"\$LDFLAGS $export_dynamic_flag_spec\"
+    wl=$lt_prog_compiler_wl eval LDFLAGS=\"\$LDFLAGS $export_dynamic_flag_spec\"
     save_LIBS="$LIBS"
     LIBS="$lt_cv_dlopen_libs $LIBS"
@@ -8979,7 +9136,7 @@
   lt_dlunknown=0; lt_dlno_uscore=1; lt_dlneed_uscore=2
   lt_status=$lt_dlunknown
   cat > conftest.$ac_ext <<EOF
-#line 8982 "configure"
+#line 9139 "configure"
 #include "confdefs.h"
 #if HAVE_DLFCN_H
@@ -9036,6 +9193,8 @@
       else if (dlsym( self,"_fnord")) status = $lt_dlneed_uscore;
       /* dlclose (self); */
+  else
+    puts (dlerror ());
     exit (status);
@@ -9045,12 +9204,12 @@
   ac_status=$?
   (exit $ac_status); } && test -s conftest${ac_exeext} 2>/dev/null; then
-    (./conftest; exit; ) 2>/dev/null
+    (./conftest; exit; ) >&5 2>/dev/null
     lt_status=$?
     case x$lt_status in
       x$lt_dlno_uscore) lt_cv_dlopen_self=yes ;;
       x$lt_dlneed_uscore) lt_cv_dlopen_self=yes ;;
-      x$lt_unknown|x*) lt_cv_dlopen_self=no ;;
+      x$lt_dlunknown|x*) lt_cv_dlopen_self=no ;;
     esac
   else :
     # compilation failed
@@ -9065,7 +9224,7 @@
 echo "${ECHO_T}$lt_cv_dlopen_self" >&6
     if test "x$lt_cv_dlopen_self" = xyes; then
-      LDFLAGS="$LDFLAGS $link_static_flag"
+      wl=$lt_prog_compiler_wl eval LDFLAGS=\"\$LDFLAGS $lt_prog_compiler_static\"
       echo "$as_me:$LINENO: checking whether a statically linked program can dlopen itself" >&5
 echo $ECHO_N "checking whether a statically linked program can dlopen itself... $ECHO_C" >&6
 if test "${lt_cv_dlopen_self_static+set}" = set; then
@@ -9077,7 +9236,7 @@
-#line 9080 "configure"
+#line 9239 "configure"
 #if HAVE_DLFCN_H
@@ -9134,6 +9293,8 @@
+  else
     exit (status);
@@ -9143,12 +9304,12 @@
   ac_status=$?
     lt_status=$?
     case x$lt_status in
       x$lt_dlno_uscore) lt_cv_dlopen_self_static=yes ;;
       x$lt_dlneed_uscore) lt_cv_dlopen_self_static=yes ;;
-      x$lt_unknown|x*) lt_cv_dlopen_self_static=no ;;
+      x$lt_dlunknown|x*) lt_cv_dlopen_self_static=no ;;
     esac
   else :
@@ -9181,7 +9342,7 @@
 fi
-# Report which librarie types wil actually be built
+# Report which library types will actually be built
 echo "$as_me:$LINENO: checking if libtool supports shared libraries" >&5
 echo $ECHO_N "checking if libtool supports shared libraries... $ECHO_C" >&6
 echo "$as_me:$LINENO: result: $can_build_shared" >&5
@@ -9193,7 +9354,7 @@
 # On AIX, shared libraries and static libraries use the same namespace, and
 # are all built from PIC.
-case "$host_os" in
+case $host_os in
 aix3*)
   test "$enable_shared" = yes && enable_static=no
@@ -9231,7 +9392,7 @@
   # Now quote all the things that may contain metacharacters while being
   # careful not to overquote the AC_SUBSTed values.  We take copies of the
   # variables and quote the copies for generation of the libtool script.
-  for var in echo old_CC old_CFLAGS AR AR_FLAGS EGREP RANLIB LN_S LTCC NM \
+  for var in echo old_CC old_CFLAGS AR AR_FLAGS EGREP RANLIB LN_S LTCC LTCFLAGS NM \
     SED SHELL STRIP \
     libname_spec library_names_spec soname_spec extract_expsyms_cmds \
     old_striplib striplib file_magic_cmd finish_cmds finish_eval \
@@ -9397,6 +9558,9 @@
 # A C compiler.
 LTCC=$lt_LTCC
+# LTCC compiler flags.
+LTCFLAGS=$lt_LTCFLAGS
 # A language-specific compiler.
 CC=$lt_compiler
@@ -9727,6 +9891,9 @@
 echo "$as_me: WARNING: using \`LTCC=$LTCC', extracted from \`$ofile'" >&2;}
     fi
   fi
+  if test -z "$LTCFLAGS"; then
+    eval "`$SHELL ${ofile} --config | grep '^LTCFLAGS='`"
+  fi
   # Extract list of available tagged configurations in $ofile.
   # Note that this assumes the entire list is on one line.
@@ -9779,6 +9946,7 @@
 hardcode_libdir_flag_spec_ld_CXX=
 hardcode_libdir_separator_CXX=
 hardcode_minus_L_CXX=no
+hardcode_shlibpath_var_CXX=unsupported
 hardcode_automatic_CXX=no
 module_cmds_CXX=
 module_expsym_cmds_CXX=
@@ -9796,7 +9964,7 @@
 compiler_lib_search_path_CXX=
 # Source file extension for C++ test sources.
-ac_ext=cc
+ac_ext=cpp
 # Object file extension for compiled C++ test sources.
 objext=o
@@ -9806,13 +9974,16 @@
 lt_simple_compile_test_code="int some_variable = 0;\n"
 # Code to be used in simple link tests
-lt_simple_link_test_code='int main(int, char *) { return(0); }\n'
+lt_simple_link_test_code='int main(int, char *[]) { return(0); }\n'
 # ltmain only uses $CC for tagged configurations so make sure $CC is set.
 LTCC=${LTCC-"$CC"}
 compiler=$CC
@@ -9820,13 +9991,13 @@
 $rm conftest*
 $rm conftest*
@@ -9841,12 +10012,12 @@
 if test -n "${lt_cv_prog_gnu_ldcxx+set}"; then
   lt_cv_prog_gnu_ld=$lt_cv_prog_gnu_ldcxx
 else
-  unset lt_cv_prog_gnu_ld
+  $as_unset lt_cv_prog_gnu_ld
 fi
 if test -n "${lt_cv_path_LDCXX+set}"; then
   lt_cv_path_LD=$lt_cv_path_LDCXX
 else
-  unset lt_cv_path_LD
+  $as_unset lt_cv_path_LD
 fi
 test -z "${LDCXX+set}" || LD=$LDCXX
 CC=${CXX-"c++"}
@@ -9932,7 +10103,7 @@
@@ -9966,7 +10137,7 @@
 else
@@ -10057,6 +10228,7 @@
 	  esac
 	done
       esac
@@ -10094,6 +10266,7 @@
 	  hardcode_libdir_flag_spec_CXX='-L$libdir'
 	fi
       esac
@@ -10176,12 +10349,12 @@
       hardcode_libdir_flag_spec_CXX='${wl}-blibpath:$libdir:'"$aix_libpath"
-      archive_expsym_cmds_CXX="\$CC"' -o $output_objdir/$soname $libobjs $deplibs $compiler_flags `if test "x${allow_undefined_flag}" != "x"; then echo "${wl}${allow_undefined_flag}"; else :; fi` '"\${wl}$no_entry_flag \${wl}$exp_sym_flag:\$export_symbols $shared_flag"
+      archive_expsym_cmds_CXX="\$CC"' -o $output_objdir/$soname $libobjs $deplibs '"\${wl}$no_entry_flag"' $compiler_flags `if test "x${allow_undefined_flag}" != "x"; then echo "${wl}${allow_undefined_flag}"; else :; fi` '"\${wl}$exp_sym_flag:\$export_symbols $shared_flag"
      else
 	hardcode_libdir_flag_spec_CXX='${wl}-R $libdir:/usr/lib:/lib'
 	allow_undefined_flag_CXX="-z nodefs"
-	archive_expsym_cmds_CXX="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs $compiler_flags ${wl}${allow_undefined_flag} '"\${wl}$no_entry_flag \${wl}$exp_sym_flag:\$export_symbols"
+	archive_expsym_cmds_CXX="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs '"\${wl}$no_entry_flag"' $compiler_flags ${wl}${allow_undefined_flag} '"\${wl}$exp_sym_flag:\$export_symbols"
       else
@@ -10241,16 +10414,26 @@
 	no_undefined_flag_CXX=' ${wl}-bernotok'
 	allow_undefined_flag_CXX=' ${wl}-berok'
-	always_export_symbols_CXX=yes
-	whole_archive_flag_spec_CXX=' '
+	whole_archive_flag_spec_CXX='$convenience'
 	archive_cmds_need_lc_CXX=yes
-	archive_expsym_cmds_CXX="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs $compiler_flags ${wl}-bE:$export_symbols ${wl}-bnoentry${allow_undefined_flag}~$AR $AR_FLAGS $output_objdir/$libname$release.a $output_objdir/$soname'
+	archive_expsym_cmds_CXX="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs ${wl}-bnoentry $compiler_flags ${wl}-bE:$export_symbols${allow_undefined_flag}~$AR $AR_FLAGS $output_objdir/$libname$release.a $output_objdir/$soname'
       fi
     fi
+  beos*)
+      allow_undefined_flag_CXX=unsupported
+      # Joseph Beckenbach <jrb3 at best.com> says some releases of gcc
+      # support --undefined.  This deserves some investigation.  FIXME
+      archive_cmds_CXX='$CC -nostart $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
+    else
+      ld_shlibs_CXX=no
+    fi
   chorus*)
     case $cc_basename in
@@ -10260,7 +10443,6 @@
     esac
   cygwin* | mingw* | pw32*)
     # _LT_AC_TAGVAR(hardcode_libdir_flag_spec, CXX) is actually meaningless,
     # as there is no search path for DLLs.
@@ -10270,7 +10452,7 @@
     enable_shared_with_static_runtimes_CXX=yes
-      archive_cmds_CXX='$CC -shared -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -o $output_objdir/$soname ${wl}--image-base=0x10000000 ${wl}--out-implib,$lib'
+      archive_cmds_CXX='$CC -shared -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -o $output_objdir/$soname ${wl}--enable-auto-image-base -Xlinker --out-implib -Xlinker $lib'
       archive_expsym_cmds_CXX='if test "x`$SED 1q $export_symbols`" = xEXPORTS; then
@@ -10279,13 +10461,13 @@
       fi~
-      $CC -shared -nostdlib $output_objdir/$soname.def $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -o $output_objdir/$soname ${wl}--image-base=0x10000000 ${wl}--out-implib,$lib'
+      $CC -shared -nostdlib $output_objdir/$soname.def $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -o $output_objdir/$soname ${wl}--enable-auto-image-base -Xlinker --out-implib -Xlinker $lib'
     else
       ld_shlibs_CXX=no
     fi
+        case $host_os in
          allow_undefined_flag_CXX='${wl}-undefined ${wl}suppress'
@@ -10323,7 +10505,7 @@
           archive_cmds_CXX='$CC -r -keep_private_externs -nostdlib -o ${lib}-master.o $libobjs~$CC -dynamiclib $allow_undefined_flag -o $lib ${lib}-master.o $deplibs $compiler_flags -install_name $rpath/$soname $verstring'
         fi
         module_cmds_CXX='$CC $allow_undefined_flag -o $lib -bundle $libobjs $deplibs$compiler_flags'
           if test "X$lt_int_apple_cc_single_mod" = Xyes ; then
             archive_expsym_cmds_CXX='sed -e "s,#.*,," -e "s,^[    ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -dynamiclib -single_module $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
           else
@@ -10336,7 +10518,7 @@
           archive_cmds_CXX='$CC -qmkshrobj ${wl}-single_module $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-install_name ${wl}`echo $rpath/$soname` $verstring'
           archive_expsym_cmds_CXX='sed -e "s,#.*,," -e "s,^[    ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -qmkshrobj ${wl}-single_module $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-install_name ${wl}$rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
           module_expsym_cmds_CXX='sed -e "s,#.*,," -e "s,^[    ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC $allow_undefined_flag  -o $lib -bundle $libobjs $deplibs$compiler_flags~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
@@ -10416,34 +10598,23 @@
   hpux10*|hpux11*)
     if test $with_gnu_ld = no; then
-      hppa*64*)
-	hardcode_libdir_flag_spec_CXX='${wl}+b ${wl}$libdir'
+      hardcode_libdir_flag_spec_CXX='${wl}+b ${wl}$libdir'
+      hardcode_libdir_separator_CXX=:
+      case $host_cpu in
+      hppa*64*|ia64*)
 	hardcode_libdir_flag_spec_ld_CXX='+b $libdir'
-	hardcode_libdir_separator_CXX=:
-      ia64*)
-	hardcode_libdir_flag_spec_CXX='-L$libdir'
 	export_dynamic_flag_spec_CXX='${wl}-E'
       esac
     fi
-    hppa*64*)
+    case $host_cpu in
+    hppa*64*|ia64*)
       hardcode_direct_CXX=no
       hardcode_shlibpath_var_CXX=no
-    ia64*)
-      hardcode_direct_CXX=no
-      hardcode_shlibpath_var_CXX=no
-      hardcode_minus_L_CXX=yes # Not in the search PATH,
-					      # location of the library.
       hardcode_direct_CXX=yes
@@ -10458,10 +10629,13 @@
 	ld_shlibs_CXX=no
       aCC*)
-	hppa*64*|ia64*)
-	  archive_cmds_CXX='$LD -b +h $soname -o $lib $linker_flags $libobjs $deplibs'
+	case $host_cpu in
+	hppa*64*)
+	  archive_cmds_CXX='$CC -b ${wl}+h ${wl}$soname -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
+	ia64*)
+	  archive_cmds_CXX='$CC -b ${wl}+h ${wl}$soname ${wl}+nodefaultrpath -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
 	  archive_cmds_CXX='$CC -b ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
@@ -10479,10 +10653,13 @@
 	if test "$GXX" = yes; then
-	    ia64*|hppa*64*)
+	    case $host_cpu in
+	    hppa*64*)
+	      archive_cmds_CXX='$CC -shared -nostdlib -fPIC ${wl}+h ${wl}$soname -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
+	    ia64*)
+	      archive_cmds_CXX='$CC -shared -nostdlib -fPIC ${wl}+h ${wl}$soname ${wl}+nodefaultrpath -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
 	      archive_cmds_CXX='$CC -shared -nostdlib -fPIC ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
@@ -10495,6 +10672,20 @@
     esac
+  interix3*)
+    hardcode_direct_CXX=no
+    hardcode_shlibpath_var_CXX=no
+    hardcode_libdir_flag_spec_CXX='${wl}-rpath,$libdir'
+    export_dynamic_flag_spec_CXX='${wl}-E'
+    archive_cmds_CXX='$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-h,$soname ${wl}--image-base,`expr ${RANDOM-$$} % 4096 / 2 \* 262144 + 1342177280` -o $lib'
+    archive_expsym_cmds_CXX='sed "s,^,_," $export_symbols >$output_objdir/$soname.expsym~$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-h,$soname ${wl}--retain-symbols-file,$output_objdir/$soname.expsym ${wl}--image-base,`expr ${RANDOM-$$} % 4096 / 2 \* 262144 + 1342177280` -o $lib'
   irix5* | irix6*)
       CC*)
@@ -10575,12 +10766,12 @@
       pgCC*)
         # Portland Group C++ compiler
-	archive_cmds_CXX='$CC -shared $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname ${wl}$soname -o $lib'
-  	archive_expsym_cmds_CXX='$CC -shared $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname ${wl}$soname ${wl}-retain-symbols-file ${wl}$export_symbols -o $lib'
+	archive_cmds_CXX='$CC -shared $pic_flag $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname ${wl}$soname -o $lib'
+  	archive_expsym_cmds_CXX='$CC -shared $pic_flag $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname ${wl}$soname ${wl}-retain-symbols-file ${wl}$export_symbols -o $lib'
 	hardcode_libdir_flag_spec_CXX='${wl}--rpath ${wl}$libdir'
 	export_dynamic_flag_spec_CXX='${wl}--export-dynamic'
-	whole_archive_flag_spec_CXX=''
+	whole_archive_flag_spec_CXX='${wl}--whole-archive`for conv in $convenience\"\"; do test  -n \"$conv\" && new_convenience=\"$new_convenience,$conv\"; done; $echo \"$new_convenience\"` ${wl}--no-whole-archive'
       cxx*)
 	# Compaq C++
@@ -10777,19 +10968,6 @@
     # FIXME: insert proper C++ library support
     ld_shlibs_CXX=no
-  sco*)
-    archive_cmds_need_lc_CXX=no
-    case $cc_basename in
-      CC*)
-	# FIXME: insert proper C++ library support
-	ld_shlibs_CXX=no
-	ld_shlibs_CXX=no
-    esac
   sunos4*)
       CC*)
@@ -10812,10 +10990,11 @@
       CC*)
 	# Sun C++ 4.2, 5.x and Centerline C++
+        archive_cmds_need_lc_CXX=yes
 	no_undefined_flag_CXX=' -zdefs'
-	archive_cmds_CXX='$CC -G${allow_undefined_flag} -nolib -h$soname -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
+	archive_cmds_CXX='$CC -G${allow_undefined_flag}  -h$soname -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
 	archive_expsym_cmds_CXX='$echo "{ global:" > $lib.exp~cat $export_symbols | $SED -e "s/\(.*\)/\1;/" >> $lib.exp~$echo "local: *; };" >> $lib.exp~
-	$CC -G${allow_undefined_flag} -nolib ${wl}-M ${wl}$lib.exp -h$soname -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags~$rm $lib.exp'
+	$CC -G${allow_undefined_flag}  ${wl}-M ${wl}$lib.exp -h$soname -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags~$rm $lib.exp'
 	hardcode_libdir_flag_spec_CXX='-R$libdir'
@@ -10835,15 +11014,7 @@
 	esac
 	link_all_deplibs_CXX=yes
-	# Commands to make compiler produce verbose output that lists
-	# what "hidden" libraries, object files and flags are used when
-	# linking a shared library.
-	# There doesn't appear to be a way to prevent this compiler from
-	# explicitly linking system object files so we need to strip them
-	# from the output so that they don't get included in the library
-	# dependencies.
-	output_verbose_link_cmd='templist=`$CC -G $CFLAGS -v conftest.$objext 2>&1 | grep "\-[LR]"`; list=""; for z in $templist; do case $z in conftest.$objext) list="$list $z";; *.$objext);; *) list="$list $z";;esac; done; echo $list'
+	output_verbose_link_cmd='echo'
 	# Archives containing C++ object files must be created using
 	# "CC -xar", where "CC" is the Sun C++ compiler.  This is
@@ -10889,9 +11060,60 @@
     esac
+  sysv4*uw2* | sysv5OpenUNIX* | sysv5UnixWare7.[01].[10]* | unixware7* | sco3.2v5.0.[024]*)
+    no_undefined_flag_CXX='${wl}-z,text'
+    case $cc_basename in
+      CC*)
+	archive_cmds_CXX='$CC -G ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds_CXX='$CC -G ${wl}-Bexport:$export_symbols ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_cmds_CXX='$CC -shared ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds_CXX='$CC -shared ${wl}-Bexport:$export_symbols ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+    esac
+    # as -z defs.
+    # For security reasons, it is highly recommended that you always
+    # use absolute paths for naming shared libraries, and exclude the
+    # DT_RUNPATH tag from executables and libraries.  But doing so
+    # requires that you compile everything twice, which is a pain.
+    # So that behaviour is only enabled if SCOABSPATH is set to a
+    # non-empty value in the environment.  Most likely only useful for
+    # creating official distributions of packages.
+    # This is a hack until libtool officially supports absolute path
+    # names for shared libraries.
+    allow_undefined_flag_CXX='${wl}-z,nodefs'
+    archive_cmds_need_lc_CXX=no
+    hardcode_libdir_flag_spec_CXX='`test -z "$SCOABSPATH" && echo ${wl}-R,$libdir`'
+    hardcode_libdir_separator_CXX=':'
+    link_all_deplibs_CXX=yes
+    export_dynamic_flag_spec_CXX='${wl}-Bexport'
+      CC*)
+	archive_cmds_CXX='$CC -G ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds_CXX='$CC -G ${wl}-Bexport:$export_symbols ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_cmds_CXX='$CC -shared ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds_CXX='$CC -shared ${wl}-Bexport:$export_symbols ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+    esac
   tandem*)
       NCC*)
@@ -10947,7 +11169,7 @@
   # The `*' in the case matches for architectures that use `case' in
   # $output_verbose_cmd can trigger glob expansion during the loop
   # eval without this substitution.
-  output_verbose_link_cmd="`$echo \"X$output_verbose_link_cmd\" | $Xsed -e \"$no_glob_subst\"`"
+  output_verbose_link_cmd=`$echo "X$output_verbose_link_cmd" | $Xsed -e "$no_glob_subst"`
   for p in `eval $output_verbose_link_cmd`; do
     case $p in
@@ -11023,6 +11245,29 @@
 $rm -f confest.$objext
+# PORTME: override above test on systems where it is broken
+case $host_os in
+interix3*)
+  # Interix 3.5 installs completely hosed .la files for C++, so rather than
+  # hack all around it, let's just trust "g++" to DTRT.
+  predep_objects_CXX=
+  postdep_objects_CXX=
+  postdeps_CXX=
+solaris*)
+  CC*)
+    # Adding this requires a known-good setup of shared libraries for
+    # Sun compiler versions before 5.6, else PIC objects from an old
+    # archive will be linked into the output, leading to subtle bugs.
+    postdeps_CXX='-lCstd -lCrun'
+  esac
+esac
 case " $postdeps_CXX " in
 *" -lc "*) archive_cmds_need_lc_CXX=no ;;
 esac
@@ -11070,6 +11315,10 @@
       # DJGPP does not support shared libraries at all
       lt_prog_compiler_pic_CXX=
+    interix3*)
     sysv4*MP*)
       if test -d /usr/nec; then
 	lt_prog_compiler_pic_CXX=-Kconform_pic
@@ -11078,7 +11327,7 @@
     hpux*)
       # not for PA HP-UX.
+      case $host_cpu in
       hppa*64*|ia64*)
@@ -11139,15 +11388,15 @@
 	  CC*)
 	    lt_prog_compiler_wl_CXX='-Wl,'
-	    lt_prog_compiler_static_CXX="${ac_cv_prog_cc_wl}-a ${ac_cv_prog_cc_wl}archive"
+	    lt_prog_compiler_static_CXX='${wl}-a ${wl}archive'
 	    if test "$host_cpu" != ia64; then
 	      lt_prog_compiler_pic_CXX='+Z'
 	    fi
 	  aCC*)
+	    case $host_cpu in
 	    hppa*64*|ia64*)
 	      # +Z the default
@@ -11160,6 +11409,10 @@
 	esac
+      interix*)
+	# This is c89, which is MS Visual C++ (no shared libs)
+	# Anyone wants to do a port?
 	  CC*)
@@ -11188,7 +11441,7 @@
 	    # Portland Group C++ compiler.
 	    lt_prog_compiler_pic_CXX='-fpic'
-	    lt_prog_compiler_static_CXX='-static'
+	    lt_prog_compiler_static_CXX='-Bstatic'
 	  cxx*)
 	    # Compaq C++
@@ -11239,15 +11492,6 @@
       psos*)
-      sco*)
-	  CC*)
-	    lt_prog_compiler_pic_CXX='-fPIC'
-	esac
       solaris*)
 	  CC*)
@@ -11289,7 +11533,14 @@
 	esac
-      unixware*)
+	  CC*)
+	    lt_prog_compiler_wl_CXX='-Wl,'
+	    lt_prog_compiler_pic_CXX='-KPIC'
+	esac
       vxworks*)
@@ -11322,20 +11573,20 @@
-   (eval echo "\"\$as_me:11328: $lt_compile\"" >&5)
+   (eval echo "\"\$as_me:11579: $lt_compile\"" >&5)
    ac_status=$?
-   echo "$as_me:11332: \$? = $ac_status" >&5
+   echo "$as_me:11583: \$? = $ac_status" >&5
        lt_prog_compiler_pic_works_CXX=yes
      fi
    fi
@@ -11356,7 +11607,7 @@
 fi
 fi
-case "$host_os" in
+case $host_os in
   *djgpp*)
@@ -11366,6 +11617,48 @@
 esac
+wl=$lt_prog_compiler_wl_CXX eval lt_tmp_static_flag=\"$lt_prog_compiler_static_CXX\"
+if test "${lt_prog_compiler_static_works_CXX+set}" = set; then
+else
+  lt_prog_compiler_static_works_CXX=no
+         lt_prog_compiler_static_works_CXX=yes
+       fi
+     else
+     fi
+   fi
+   $rm conftest*
+fi
+echo "$as_me:$LINENO: result: $lt_prog_compiler_static_works_CXX" >&5
+echo "${ECHO_T}$lt_prog_compiler_static_works_CXX" >&6
+if test x"$lt_prog_compiler_static_works_CXX" = xyes; then
+else
+fi
 if test "${lt_cv_prog_compiler_c_o_CXX+set}" = set; then
@@ -11384,25 +11677,25 @@
-   (eval echo "\"\$as_me:11390: $lt_compile\"" >&5)
+   (eval echo "\"\$as_me:11683: $lt_compile\"" >&5)
    ac_status=$?
-   echo "$as_me:11394: \$? = $ac_status" >&5
+   echo "$as_me:11687: \$? = $ac_status" >&5
    then
        lt_cv_prog_compiler_c_o_CXX=yes
      fi
    fi
-   chmod u+w .
+   chmod u+w . 2>&5
    $rm conftest*
@@ -11468,11 +11761,6 @@
 echo "${ECHO_T}$ld_shlibs_CXX" >&6
 test "$ld_shlibs_CXX" = no && can_build_shared=no
-fi
@@ -11505,6 +11793,7 @@
         deplibs=
+	pic_flag=$lt_prog_compiler_pic_CXX
         compiler_flags=-v
         linker_flags=-v
         verstring=
@@ -11665,7 +11954,8 @@
        $rm \$dlpath'
@@ -11718,7 +12008,7 @@
@@ -11756,7 +12046,14 @@
+  else
+    case $host_os in
+    esac
+  fi
     freebsd-elf*)
@@ -11778,10 +12075,15 @@
-  *) # from 3.2 on
   esac
@@ -11801,7 +12103,7 @@
   version_type=sunos
   need_lib_prefix=no
   need_version=no
+  case $host_cpu in
   ia64*)
     shrext_cmds='.so'
@@ -11841,6 +12143,18 @@
+interix3*)
+  need_version=no
   case $host_os in
@@ -11902,7 +12216,7 @@
   libsuff=
   case "$host_cpu" in
-    echo '#line 11905 "configure"' > conftest.$ac_ext
+    echo '#line 12219 "configure"' > conftest.$ac_ext
   ac_status=$?
@@ -11921,7 +12235,7 @@
   fi
@@ -11983,8 +12297,13 @@
 openbsd*)
   version_type=sunos
   need_lib_prefix=no
-  need_version=no
+  case $host_os in
+  esac
@@ -12022,13 +12341,6 @@
-sco3.2v5*)
-  version_type=osf
 solaris*)
   version_type=linux
   need_lib_prefix=no
@@ -12054,7 +12366,7 @@
   need_version=yes
+sysv4 | sysv4.3*)
   version_type=linux
@@ -12087,6 +12399,29 @@
   fi
+  need_version=no
+  else
+    case $host_os in
+      sco3.2v5*)
+    esac
+  fi
 uts4*)
   version_type=linux
@@ -12102,6 +12437,11 @@
+fi
 hardcode_action_CXX=
@@ -12139,842 +12479,7 @@
   enable_fast_install=needless
 fi
-striplib=
-old_striplib=
-echo "$as_me:$LINENO: checking whether stripping libraries is possible" >&5
-echo $ECHO_N "checking whether stripping libraries is possible... $ECHO_C" >&6
-if test -n "$STRIP" && $STRIP -V 2>&1 | grep "GNU strip" >/dev/null; then
-  test -z "$old_striplib" && old_striplib="$STRIP --strip-debug"
-  test -z "$striplib" && striplib="$STRIP --strip-unneeded"
-  echo "$as_me:$LINENO: result: yes" >&5
-echo "${ECHO_T}yes" >&6
-else
-# FIXME - insert some real tests, host_os isn't really good enough
-  case $host_os in
-   darwin*)
-       if test -n "$STRIP" ; then
-         striplib="$STRIP -x"
-       else
-  echo "$as_me:$LINENO: result: no" >&5
-echo "${ECHO_T}no" >&6
-fi
-  esac
-fi
-if test "x$enable_dlopen" != xyes; then
-  enable_dlopen=unknown
-  enable_dlopen_self=unknown
-  enable_dlopen_self_static=unknown
-else
-  lt_cv_dlopen=no
-  lt_cv_dlopen_libs=
-  case $host_os in
-  beos*)
-    lt_cv_dlopen="load_add_on"
-    lt_cv_dlopen_self=yes
-  mingw* | pw32*)
-    lt_cv_dlopen="LoadLibrary"
-  cygwin*)
-    lt_cv_dlopen="dlopen"
-  darwin*)
-  # if libdl is installed we need to link against it
-    echo "$as_me:$LINENO: checking for dlopen in -ldl" >&5
-echo $ECHO_N "checking for dlopen in -ldl... $ECHO_C" >&6
-if test "${ac_cv_lib_dl_dlopen+set}" = set; then
-else
-  ac_check_lib_save_LIBS=$LIBS
-LIBS="-ldl  $LIBS"
-cat >conftest.$ac_ext <<_ACEOF
-/* confdefs.h.  */
-_ACEOF
-cat confdefs.h >>conftest.$ac_ext
-cat >>conftest.$ac_ext <<_ACEOF
-/* end confdefs.h.  */
-/* Override any gcc2 internal prototype to avoid an error.  */
-#ifdef __cplusplus
-extern "C"
-#endif
-/* We use char because int might match the return type of a gcc2
-   builtin and then its argument prototype would still apply.  */
-char dlopen ();
-int
-main ()
-dlopen ();
-  return 0;
-_ACEOF
-rm -f conftest.$ac_objext conftest$ac_exeext
-if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
-  (eval $ac_link) 2>conftest.er1
-  ac_status=$?
-  grep -v '^ *+' conftest.er1 >conftest.err
-  rm -f conftest.er1
-  cat conftest.err >&5
-  echo "$as_me:$LINENO: \$? = $ac_status" >&5
-  (exit $ac_status); } &&
-	 { ac_try='test -z "$ac_cxx_werror_flag"
-			 || test ! -s conftest.err'
-  { (eval echo "$as_me:$LINENO: \"$ac_try\"") >&5
-  (eval $ac_try) 2>&5
-  ac_status=$?
-  (exit $ac_status); }; } &&
-	 { ac_try='test -s conftest$ac_exeext'
-  ac_status=$?
-  (exit $ac_status); }; }; then
-  ac_cv_lib_dl_dlopen=yes
-else
-  echo "$as_me: failed program was:" >&5
-sed 's/^/| /' conftest.$ac_ext >&5
-ac_cv_lib_dl_dlopen=no
-fi
-rm -f conftest.err conftest.$ac_objext \
-      conftest$ac_exeext conftest.$ac_ext
-LIBS=$ac_check_lib_save_LIBS
-fi
-echo "$as_me:$LINENO: result: $ac_cv_lib_dl_dlopen" >&5
-echo "${ECHO_T}$ac_cv_lib_dl_dlopen" >&6
-if test $ac_cv_lib_dl_dlopen = yes; then
-  lt_cv_dlopen="dlopen" lt_cv_dlopen_libs="-ldl"
-else
-    lt_cv_dlopen="dyld"
-fi
-    echo "$as_me:$LINENO: checking for shl_load" >&5
-echo $ECHO_N "checking for shl_load... $ECHO_C" >&6
-if test "${ac_cv_func_shl_load+set}" = set; then
-else
-  cat >conftest.$ac_ext <<_ACEOF
-/* confdefs.h.  */
-_ACEOF
-/* Define shl_load to an innocuous variant, in case <limits.h> declares shl_load.
-   For example, HP-UX 11i <limits.h> declares gettimeofday.  */
-#define shl_load innocuous_shl_load
-/* System header to define __stub macros and hopefully few prototypes,
-    which can conflict with char shl_load (); below.
-    Prefer <limits.h> to <assert.h> if __STDC__ is defined, since
-    <limits.h> exists even on freestanding compilers.  */
-#ifdef __STDC__
-# include <limits.h>
-#else
-# include <assert.h>
-#endif
-#undef shl_load
-#ifdef __cplusplus
-extern "C"
-#endif
-char shl_load ();
-/* The GNU C library defines this for functions which it implements
-    to always fail with ENOSYS.  Some functions are actually named
-    something starting with __ and the normal name is an alias.  */
-#if defined (__stub_shl_load) || defined (__stub___shl_load)
-choke me
-#else
-char (*f) () = shl_load;
-#endif
-#ifdef __cplusplus
-#endif
-int
-main ()
-return f != shl_load;
-  return 0;
-_ACEOF
-  ac_status=$?
-  ac_status=$?
-  ac_status=$?
-  ac_cv_func_shl_load=yes
-else
-ac_cv_func_shl_load=no
-fi
-fi
-echo "$as_me:$LINENO: result: $ac_cv_func_shl_load" >&5
-echo "${ECHO_T}$ac_cv_func_shl_load" >&6
-if test $ac_cv_func_shl_load = yes; then
-  lt_cv_dlopen="shl_load"
-else
-  echo "$as_me:$LINENO: checking for shl_load in -ldld" >&5
-echo $ECHO_N "checking for shl_load in -ldld... $ECHO_C" >&6
-if test "${ac_cv_lib_dld_shl_load+set}" = set; then
-else
-LIBS="-ldld  $LIBS"
-/* confdefs.h.  */
-_ACEOF
-#ifdef __cplusplus
-extern "C"
-#endif
-char shl_load ();
-int
-main ()
-shl_load ();
-  return 0;
-_ACEOF
-  ac_status=$?
-  ac_status=$?
-  ac_status=$?
-  ac_cv_lib_dld_shl_load=yes
-else
-ac_cv_lib_dld_shl_load=no
-fi
-fi
-echo "$as_me:$LINENO: result: $ac_cv_lib_dld_shl_load" >&5
-echo "${ECHO_T}$ac_cv_lib_dld_shl_load" >&6
-if test $ac_cv_lib_dld_shl_load = yes; then
-  lt_cv_dlopen="shl_load" lt_cv_dlopen_libs="-dld"
-else
-  echo "$as_me:$LINENO: checking for dlopen" >&5
-echo $ECHO_N "checking for dlopen... $ECHO_C" >&6
-if test "${ac_cv_func_dlopen+set}" = set; then
-else
-/* confdefs.h.  */
-_ACEOF
-/* Define dlopen to an innocuous variant, in case <limits.h> declares dlopen.
-#define dlopen innocuous_dlopen
-    which can conflict with char dlopen (); below.
-#ifdef __STDC__
-#else
-#endif
-#undef dlopen
-#ifdef __cplusplus
-extern "C"
-#endif
-char dlopen ();
-#if defined (__stub_dlopen) || defined (__stub___dlopen)
-choke me
-#else
-char (*f) () = dlopen;
-#endif
-#ifdef __cplusplus
-#endif
-int
-main ()
-return f != dlopen;
-  return 0;
-_ACEOF
-  ac_status=$?
-  ac_status=$?
-  ac_status=$?
-  ac_cv_func_dlopen=yes
-else
-ac_cv_func_dlopen=no
-fi
-fi
-echo "$as_me:$LINENO: result: $ac_cv_func_dlopen" >&5
-echo "${ECHO_T}$ac_cv_func_dlopen" >&6
-if test $ac_cv_func_dlopen = yes; then
-else
-else
-LIBS="-ldl  $LIBS"
-/* confdefs.h.  */
-_ACEOF
-#ifdef __cplusplus
-extern "C"
-#endif
-char dlopen ();
-int
-main ()
-dlopen ();
-  return 0;
-_ACEOF
-  ac_status=$?
-  ac_status=$?
-  ac_status=$?
-else
-fi
-fi
-else
-  echo "$as_me:$LINENO: checking for dlopen in -lsvld" >&5
-echo $ECHO_N "checking for dlopen in -lsvld... $ECHO_C" >&6
-if test "${ac_cv_lib_svld_dlopen+set}" = set; then
-else
-LIBS="-lsvld  $LIBS"
-/* confdefs.h.  */
-_ACEOF
-#ifdef __cplusplus
-extern "C"
-#endif
-char dlopen ();
-int
-main ()
-dlopen ();
-  return 0;
-_ACEOF
-  ac_status=$?
-  ac_status=$?
-  ac_status=$?
-  ac_cv_lib_svld_dlopen=yes
-else
-ac_cv_lib_svld_dlopen=no
-fi
-fi
-echo "$as_me:$LINENO: result: $ac_cv_lib_svld_dlopen" >&5
-echo "${ECHO_T}$ac_cv_lib_svld_dlopen" >&6
-if test $ac_cv_lib_svld_dlopen = yes; then
-  lt_cv_dlopen="dlopen" lt_cv_dlopen_libs="-lsvld"
-else
-  echo "$as_me:$LINENO: checking for dld_link in -ldld" >&5
-echo $ECHO_N "checking for dld_link in -ldld... $ECHO_C" >&6
-if test "${ac_cv_lib_dld_dld_link+set}" = set; then
-else
-LIBS="-ldld  $LIBS"
-/* confdefs.h.  */
-_ACEOF
-#ifdef __cplusplus
-extern "C"
-#endif
-char dld_link ();
-int
-main ()
-dld_link ();
-  return 0;
-_ACEOF
-  ac_status=$?
-  ac_status=$?
-  ac_status=$?
-  ac_cv_lib_dld_dld_link=yes
-else
-ac_cv_lib_dld_dld_link=no
-fi
-fi
-echo "$as_me:$LINENO: result: $ac_cv_lib_dld_dld_link" >&5
-echo "${ECHO_T}$ac_cv_lib_dld_dld_link" >&6
-if test $ac_cv_lib_dld_dld_link = yes; then
-  lt_cv_dlopen="dld_link" lt_cv_dlopen_libs="-dld"
-fi
-fi
-fi
-fi
-fi
-fi
-  esac
-  if test "x$lt_cv_dlopen" != xno; then
-    enable_dlopen=yes
-  else
-    enable_dlopen=no
-  fi
-  case $lt_cv_dlopen in
-  dlopen)
-    save_CPPFLAGS="$CPPFLAGS"
-    test "x$ac_cv_header_dlfcn_h" = xyes && CPPFLAGS="$CPPFLAGS -DHAVE_DLFCN_H"
-    save_LIBS="$LIBS"
-    LIBS="$lt_cv_dlopen_libs $LIBS"
-    echo "$as_me:$LINENO: checking whether a program can dlopen itself" >&5
-echo $ECHO_N "checking whether a program can dlopen itself... $ECHO_C" >&6
-if test "${lt_cv_dlopen_self+set}" = set; then
-else
-  	  if test "$cross_compiling" = yes; then :
-  lt_cv_dlopen_self=cross
-else
-  lt_dlunknown=0; lt_dlno_uscore=1; lt_dlneed_uscore=2
-  lt_status=$lt_dlunknown
-  cat > conftest.$ac_ext <<EOF
-#line 12776 "configure"
-#include "confdefs.h"
-#if HAVE_DLFCN_H
-#include <dlfcn.h>
-#endif
-#include <stdio.h>
-#ifdef RTLD_GLOBAL
-#  define LT_DLGLOBAL		RTLD_GLOBAL
-#else
-#  ifdef DL_GLOBAL
-#    define LT_DLGLOBAL		DL_GLOBAL
-#  else
-#    define LT_DLGLOBAL		0
-#  endif
-#endif
-/* We may have to define LT_DLLAZY_OR_NOW in the command line if we
-   find out it does not work in some platform. */
-#ifndef LT_DLLAZY_OR_NOW
-#  ifdef RTLD_LAZY
-#    define LT_DLLAZY_OR_NOW		RTLD_LAZY
-#  else
-#    ifdef DL_LAZY
-#      define LT_DLLAZY_OR_NOW		DL_LAZY
-#    else
-#      ifdef RTLD_NOW
-#        define LT_DLLAZY_OR_NOW	RTLD_NOW
-#      else
-#        ifdef DL_NOW
-#          define LT_DLLAZY_OR_NOW	DL_NOW
-#        else
-#          define LT_DLLAZY_OR_NOW	0
-#        endif
-#      endif
-#    endif
-#  endif
-#endif
-#ifdef __cplusplus
-extern "C" void exit (int);
-#endif
-void fnord() { int i=42;}
-int main ()
-  void *self = dlopen (0, LT_DLGLOBAL|LT_DLLAZY_OR_NOW);
-  int status = $lt_dlunknown;
-  if (self)
-      if (dlsym (self,"fnord"))       status = $lt_dlno_uscore;
-      else if (dlsym( self,"_fnord")) status = $lt_dlneed_uscore;
-      /* dlclose (self); */
-    exit (status);
-EOF
-  if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
-  (eval $ac_link) 2>&5
-  ac_status=$?
-  (exit $ac_status); } && test -s conftest${ac_exeext} 2>/dev/null; then
-    lt_status=$?
-    case x$lt_status in
-      x$lt_dlno_uscore) lt_cv_dlopen_self=yes ;;
-      x$lt_dlneed_uscore) lt_cv_dlopen_self=yes ;;
-    esac
-  else :
-    # compilation failed
-    lt_cv_dlopen_self=no
-  fi
-fi
-rm -fr conftest*
-fi
-echo "$as_me:$LINENO: result: $lt_cv_dlopen_self" >&5
-echo "${ECHO_T}$lt_cv_dlopen_self" >&6
-    if test "x$lt_cv_dlopen_self" = xyes; then
-      echo "$as_me:$LINENO: checking whether a statically linked program can dlopen itself" >&5
-echo $ECHO_N "checking whether a statically linked program can dlopen itself... $ECHO_C" >&6
-if test "${lt_cv_dlopen_self_static+set}" = set; then
-else
-  lt_cv_dlopen_self_static=cross
-else
-#line 12874 "configure"
-#if HAVE_DLFCN_H
-#include <dlfcn.h>
-#endif
-#include <stdio.h>
-#ifdef RTLD_GLOBAL
-#else
-#  ifdef DL_GLOBAL
-#  else
-#  endif
-#endif
-#  ifdef RTLD_LAZY
-#  else
-#    ifdef DL_LAZY
-#    else
-#      ifdef RTLD_NOW
-#      else
-#        ifdef DL_NOW
-#        else
-#        endif
-#      endif
-#    endif
-#  endif
-#endif
-#ifdef __cplusplus
-#endif
-int main ()
-  if (self)
-    exit (status);
-EOF
-  ac_status=$?
-    lt_status=$?
-      x$lt_dlno_uscore) lt_cv_dlopen_self_static=yes ;;
-      x$lt_dlneed_uscore) lt_cv_dlopen_self_static=yes ;;
-    esac
-  else :
-    lt_cv_dlopen_self_static=no
-  fi
-fi
-rm -fr conftest*
-fi
-echo "$as_me:$LINENO: result: $lt_cv_dlopen_self_static" >&5
-echo "${ECHO_T}$lt_cv_dlopen_self_static" >&6
-    fi
-    CPPFLAGS="$save_CPPFLAGS"
-    LIBS="$save_LIBS"
-  esac
-  case $lt_cv_dlopen_self in
-  yes|no) enable_dlopen_self=$lt_cv_dlopen_self ;;
-  *) enable_dlopen_self=unknown ;;
-  esac
-  case $lt_cv_dlopen_self_static in
-  yes|no) enable_dlopen_self_static=$lt_cv_dlopen_self_static ;;
-  *) enable_dlopen_self_static=unknown ;;
-  esac
-fi
 # The else clause should only fire when bootstrapping the
 # libtool distribution, otherwise you forgot to ship ltmain.sh
 # with your package, and you will get complaints that there are
@@ -12988,7 +12493,7 @@
     SED SHELL STRIP \
@@ -13106,6 +12611,9 @@
 # A C compiler.
 LTCC=$lt_LTCC
 CC=$lt_compiler_CXX
@@ -13448,6 +12956,9 @@
 # If no C compiler was specified, use CC.
 LTCC=${LTCC-"$CC"}
+# If no C compiler flags were specified, use CFLAGS.
+LTCFLAGS=${LTCFLAGS-"$CFLAGS"}
 # Allow CC to be a program name with arguments.
 compiler=$CC
@@ -13455,13 +12966,13 @@
 # save warnings/boilerplate of simple test code
 ac_outfile=conftest.$ac_objext
 printf "$lt_simple_compile_test_code" >conftest.$ac_ext
-eval "$ac_compile" 2>&1 >/dev/null | $SED '/^$/d' >conftest.err
+eval "$ac_compile" 2>&1 >/dev/null | $SED '/^$/d; /^ *+/d' >conftest.err
 _lt_compiler_boilerplate=`cat conftest.err`
 $rm conftest*
 printf "$lt_simple_link_test_code" >conftest.$ac_ext
-eval "$ac_link" 2>&1 >/dev/null | $SED '/^$/d' >conftest.err
+eval "$ac_link" 2>&1 >/dev/null | $SED '/^$/d; /^ *+/d' >conftest.err
 _lt_linker_boilerplate=`cat conftest.err`
 $rm conftest*
@@ -13493,7 +13004,7 @@
-case "$host_os" in
+case $host_os in
 aix3*)
   if test -n "$RANLIB"; then
@@ -13517,8 +13028,6 @@
 echo "$as_me:$LINENO: result: $enable_static" >&5
 echo "${ECHO_T}$enable_static" >&6
-test "$ld_shlibs_F77" = no && can_build_shared=no
 GCC_F77="$G77"
 LD_F77="$LD"
@@ -13565,6 +13074,11 @@
       lt_prog_compiler_pic_F77='-fno-common'
+    interix3*)
     msdosdjgpp*)
@@ -13581,7 +13095,7 @@
     hpux*)
       # not for PA HP-UX.
-      case "$host_cpu" in
+      case $host_cpu in
       hppa*64*|ia64*)
 	# +Z the default
@@ -13628,7 +13142,7 @@
       lt_prog_compiler_wl_F77='-Wl,'
       # not for PA HP-UX.
+      case $host_cpu in
       hppa*64*|ia64*)
 	# +Z the default
@@ -13658,12 +13172,12 @@
 	lt_prog_compiler_pic_F77='-KPIC'
 	lt_prog_compiler_static_F77='-static'
 	lt_prog_compiler_pic_F77='-fpic'
-	lt_prog_compiler_static_F77='-static'
+	lt_prog_compiler_static_F77='-Bstatic'
       ccc*)
@@ -13679,11 +13193,6 @@
       lt_prog_compiler_static_F77='-non_shared'
-    sco3.2v5*)
-      lt_prog_compiler_pic_F77='-Kpic'
-      lt_prog_compiler_static_F77='-dn'
     solaris*)
@@ -13701,7 +13210,7 @@
@@ -13714,6 +13223,12 @@
       fi
+      lt_prog_compiler_wl_F77='-Wl,'
+      lt_prog_compiler_pic_F77='-KPIC'
     unicos*)
       lt_prog_compiler_can_build_shared_F77=no
@@ -13753,20 +13268,20 @@
    # with a dollar sign (not a hyphen), so the echo should work correctly.
    # The option is referenced via a variable to avoid confusing sed.
    lt_compile=`echo "$ac_compile" | $SED \
-   -e 's:.*FLAGS}? :&$lt_compiler_flag :; t' \
+   -e 's:.*FLAGS}\{0,1\} :&$lt_compiler_flag :; t' \
    -e 's: [^ ]*conftest\.: $lt_compiler_flag&:; t' \
    -e 's:$: $lt_compiler_flag:'`
-   (eval echo "\"\$as_me:13759: $lt_compile\"" >&5)
+   (eval echo "\"\$as_me:13274: $lt_compile\"" >&5)
    (eval "$lt_compile" 2>conftest.err)
    ac_status=$?
-   echo "$as_me:13763: \$? = $ac_status" >&5
+   echo "$as_me:13278: \$? = $ac_status" >&5
    if (exit $ac_status) && test -s "$ac_outfile"; then
      # The compiler can only warn and ignore the option if not recognized
      # So say no if there are warnings other than the usual output.
-     $echo "X$_lt_compiler_boilerplate" | $Xsed >conftest.exp
-     $SED '/^$/d' conftest.err >conftest.er2
-     if test ! -s conftest.err || diff conftest.exp conftest.er2 >/dev/null; then
+     $echo "X$_lt_compiler_boilerplate" | $Xsed -e '/^$/d' >conftest.exp
+     $SED '/^$/d; /^ *+/d' conftest.err >conftest.er2
+     if test ! -s conftest.er2 || diff conftest.exp conftest.er2 >/dev/null; then
        lt_prog_compiler_pic_works_F77=yes
      fi
    fi
@@ -13787,7 +13302,7 @@
 fi
 fi
-case "$host_os" in
+case $host_os in
   *djgpp*)
@@ -13797,6 +13312,48 @@
 esac
+wl=$lt_prog_compiler_wl_F77 eval lt_tmp_static_flag=\"$lt_prog_compiler_static_F77\"
+if test "${lt_prog_compiler_static_works_F77+set}" = set; then
+else
+  lt_prog_compiler_static_works_F77=no
+         lt_prog_compiler_static_works_F77=yes
+       fi
+     else
+     fi
+   fi
+   $rm conftest*
+fi
+echo "$as_me:$LINENO: result: $lt_prog_compiler_static_works_F77" >&5
+echo "${ECHO_T}$lt_prog_compiler_static_works_F77" >&6
+if test x"$lt_prog_compiler_static_works_F77" = xyes; then
+else
+fi
 if test "${lt_cv_prog_compiler_c_o_F77+set}" = set; then
@@ -13815,25 +13372,25 @@
-   (eval echo "\"\$as_me:13821: $lt_compile\"" >&5)
+   (eval echo "\"\$as_me:13378: $lt_compile\"" >&5)
    ac_status=$?
-   echo "$as_me:13825: \$? = $ac_status" >&5
+   echo "$as_me:13382: \$? = $ac_status" >&5
    then
        lt_cv_prog_compiler_c_o_F77=yes
      fi
    fi
-   chmod u+w .
+   chmod u+w . 2>&5
    $rm conftest*
@@ -13929,6 +13486,10 @@
       with_gnu_ld=no
     fi
+  interix*)
+    with_gnu_ld=yes
   openbsd*)
     with_gnu_ld=no
@@ -14013,7 +13574,7 @@
       export_symbols_cmds_F77='$NM $libobjs $convenience | $global_symbol_pipe | $SED -e '\''/^[BCDGRS] /s/.* \([^ ]*\)/\1 DATA/'\'' | $SED -e '\''/^[AITW] /s/.* //'\'' | sort | uniq > $export_symbols'
-        archive_cmds_F77='$CC -shared $libobjs $deplibs $compiler_flags -o $output_objdir/$soname ${wl}--image-base=0x10000000 ${wl}--out-implib,$lib'
+        archive_cmds_F77='$CC -shared $libobjs $deplibs $compiler_flags -o $output_objdir/$soname ${wl}--enable-auto-image-base -Xlinker --out-implib -Xlinker $lib'
 	archive_expsym_cmds_F77='if test "x`$SED 1q $export_symbols`" = xEXPORTS; then
@@ -14022,22 +13583,38 @@
 	fi~
       else
 	ld_shlibs_F77=no
       fi
+    interix3*)
+      hardcode_direct_F77=no
+      hardcode_shlibpath_var_F77=no
+      hardcode_libdir_flag_spec_F77='${wl}-rpath,$libdir'
+      export_dynamic_flag_spec_F77='${wl}-E'
+      archive_cmds_F77='$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-h,$soname ${wl}--image-base,`expr ${RANDOM-$$} % 4096 / 2 \* 262144 + 1342177280` -o $lib'
+      archive_expsym_cmds_F77='sed "s,^,_," $export_symbols >$output_objdir/$soname.expsym~$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-h,$soname ${wl}--retain-symbols-file,$output_objdir/$soname.expsym ${wl}--image-base,`expr ${RANDOM-$$} % 4096 / 2 \* 262144 + 1342177280` -o $lib'
     linux*)
 	tmp_addflag=
-	  whole_archive_flag_spec_F77=
+	  whole_archive_flag_spec_F77='${wl}--whole-archive`for conv in $convenience\"\"; do test  -n \"$conv\" && new_convenience=\"$new_convenience,$conv\"; done; $echo \"$new_convenience\"` ${wl}--no-whole-archive'
@@ -14068,7 +13645,7 @@
       fi
+    solaris*)
 	ld_shlibs_F77=no
 	cat <<EOF 1>&2
@@ -14089,6 +13666,33 @@
       fi
+	ld_shlibs_F77=no
+_LT_EOF
+	    hardcode_libdir_flag_spec_F77='`test -z "$SCOABSPATH" && echo ${wl}-rpath,$libdir`'
+	    archive_cmds_F77='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib'
+	    archive_expsym_cmds_F77='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname,\${SCOABSPATH:+${install_libdir}/}$soname,-retain-symbols-file,$export_symbols -o $lib'
+	  else
+	    ld_shlibs_F77=no
+	  fi
+      esac
     sunos4*)
       archive_cmds_F77='$LD -assert pure-text -Bshareable -o $lib $libobjs $deplibs $linker_flags'
       wlarc=
@@ -14122,7 +13726,7 @@
       hardcode_minus_L_F77=yes
 	# broken collect2.
 	hardcode_direct_F77=unsupported
@@ -14156,6 +13760,7 @@
   	    break
   	  fi
 	  done
 	esac
@@ -14193,6 +13798,7 @@
   	  hardcode_libdir_flag_spec_F77='-L$libdir'
   	  hardcode_libdir_separator_F77=
 	  fi
 	esac
@@ -14205,11 +13811,11 @@
 	  shared_flag='-G'
 	else
 	  else
-  	fi
+	  fi
 	fi
       fi
@@ -14264,12 +13870,12 @@
        hardcode_libdir_flag_spec_F77='${wl}-blibpath:$libdir:'"$aix_libpath"
-	archive_expsym_cmds_F77="\$CC"' -o $output_objdir/$soname $libobjs $deplibs $compiler_flags `if test "x${allow_undefined_flag}" != "x"; then echo "${wl}${allow_undefined_flag}"; else :; fi` '"\${wl}$no_entry_flag \${wl}$exp_sym_flag:\$export_symbols $shared_flag"
+	archive_expsym_cmds_F77="\$CC"' -o $output_objdir/$soname $libobjs $deplibs '"\${wl}$no_entry_flag"' $compiler_flags `if test "x${allow_undefined_flag}" != "x"; then echo "${wl}${allow_undefined_flag}"; else :; fi` '"\${wl}$exp_sym_flag:\$export_symbols $shared_flag"
        else
 	  hardcode_libdir_flag_spec_F77='${wl}-R $libdir:/usr/lib:/lib'
 	  allow_undefined_flag_F77="-z nodefs"
-	  archive_expsym_cmds_F77="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs $compiler_flags ${wl}${allow_undefined_flag} '"\${wl}$no_entry_flag \${wl}$exp_sym_flag:\$export_symbols"
+	  archive_expsym_cmds_F77="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs '"\${wl}$no_entry_flag"' $compiler_flags ${wl}${allow_undefined_flag} '"\${wl}$exp_sym_flag:\$export_symbols"
 	else
@@ -14319,13 +13925,11 @@
 	  no_undefined_flag_F77=' ${wl}-bernotok'
 	  allow_undefined_flag_F77=' ${wl}-berok'
-	  always_export_symbols_F77=yes
-	  whole_archive_flag_spec_F77=' '
+	  whole_archive_flag_spec_F77='$convenience'
 	  archive_cmds_need_lc_F77=yes
-	  archive_expsym_cmds_F77="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs $compiler_flags ${wl}-bE:$export_symbols ${wl}-bnoentry${allow_undefined_flag}~$AR $AR_FLAGS $output_objdir/$libname$release.a $output_objdir/$soname'
+	  archive_expsym_cmds_F77="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs ${wl}-bnoentry $compiler_flags ${wl}-bE:$export_symbols${allow_undefined_flag}~$AR $AR_FLAGS $output_objdir/$libname$release.a $output_objdir/$soname'
 	fi
       fi
@@ -14364,7 +13968,7 @@
+      case $host_os in
          allow_undefined_flag_F77='${wl}-undefined ${wl}suppress'
@@ -14393,7 +13997,7 @@
         archive_cmds_F77='$CC -dynamiclib $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring'
       module_cmds_F77='$CC $allow_undefined_flag -o $lib -bundle $libobjs $deplibs$compiler_flags'
       archive_expsym_cmds_F77='sed -e "s,#.*,," -e "s,^[    ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -dynamiclib $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
       module_expsym_cmds_F77='sed -e "s,#.*,," -e "s,^[    ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC $allow_undefined_flag  -o $lib -bundle $libobjs $deplibs$compiler_flags~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
     else
@@ -14402,7 +14006,7 @@
          archive_cmds_F77='$CC -qmkshrobj $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-install_name ${wl}`echo $rpath/$soname` $verstring'
          archive_expsym_cmds_F77='sed -e "s,#.*,," -e "s,^[    ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -qmkshrobj $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-install_name ${wl}$rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
@@ -14466,47 +14070,62 @@
+    hpux10*)
-	hppa*64*|ia64*)
+	archive_cmds_F77='$CC -shared -fPIC ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $libobjs $deplibs $compiler_flags'
+      else
+	archive_cmds_F77='$LD -b +h $soname +b $install_libdir -o $lib $libobjs $deplibs $linker_flags'
+      fi
+	hardcode_libdir_flag_spec_F77='${wl}+b ${wl}$libdir'
+	hardcode_libdir_separator_F77=:
+	hardcode_direct_F77=yes
+	hardcode_minus_L_F77=yes
+      fi
+    hpux11*)
+	case $host_cpu in
+	hppa*64*)
 	  archive_cmds_F77='$CC -shared ${wl}+h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	ia64*)
+	  archive_cmds_F77='$CC -shared ${wl}+h ${wl}$soname ${wl}+nodefaultrpath -o $lib $libobjs $deplibs $compiler_flags'
 	esac
       else
-	hppa*64*|ia64*)
-	  archive_cmds_F77='$LD -b +h $soname -o $lib $libobjs $deplibs $linker_flags'
+	case $host_cpu in
+	hppa*64*)
+	  archive_cmds_F77='$CC -b ${wl}+h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	ia64*)
+	  archive_cmds_F77='$CC -b ${wl}+h ${wl}$soname ${wl}+nodefaultrpath -o $lib $libobjs $deplibs $compiler_flags'
-	  archive_cmds_F77='$LD -b +h $soname +b $install_libdir -o $lib $libobjs $deplibs $linker_flags'
+	  archive_cmds_F77='$CC -b ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $libobjs $deplibs $compiler_flags'
 	esac
       fi
-	hppa*64*)
-	  hardcode_libdir_flag_spec_F77='${wl}+b ${wl}$libdir'
+	case $host_cpu in
+	hppa*64*|ia64*)
 	  hardcode_libdir_flag_spec_ld_F77='+b $libdir'
-	  hardcode_libdir_separator_F77=:
-	ia64*)
-	  hardcode_libdir_flag_spec_F77='-L$libdir'
-	  hardcode_direct_F77=no
-	  hardcode_shlibpath_var_F77=no
-	  hardcode_minus_L_F77=yes
@@ -14608,14 +14227,6 @@
-    sco3.2v5*)
-      archive_cmds_F77='$LD -G -h $soname -o $lib $libobjs $deplibs $linker_flags'
-      export_dynamic_flag_spec_F77='${wl}-Bexport'
     solaris*)
       no_undefined_flag_F77=' -z text'
@@ -14701,36 +14312,45 @@
       fi
-    sysv4.2uw2*)
-      archive_cmds_F77='$LD -G -o $lib $libobjs $deplibs $linker_flags'
-      hardcode_direct_F77=yes
-      hardcode_minus_L_F77=no
+      no_undefined_flag_F77='${wl}-z,text'
+      archive_cmds_need_lc_F77=no
-      no_undefined_flag_F77='${wl}-z ${wl}text'
-	archive_cmds_F77='$CC -shared ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_cmds_F77='$CC -shared ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds_F77='$CC -shared ${wl}-Bexport:$export_symbols ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
       else
-	archive_cmds_F77='$CC -G ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_cmds_F77='$CC -G ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds_F77='$CC -G ${wl}-Bexport:$export_symbols ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
       fi
-    sysv5*)
-      no_undefined_flag_F77=' -z text'
-      archive_cmds_F77='$LD -G${allow_undefined_flag} -h $soname -o $lib $libobjs $deplibs $linker_flags'
-      archive_expsym_cmds_F77='$echo "{ global:" > $lib.exp~cat $export_symbols | $SED -e "s/\(.*\)/\1;/" >> $lib.exp~$echo "local: *; };" >> $lib.exp~
+      # as -z defs.
+      allow_undefined_flag_F77='${wl}-z,nodefs'
+      hardcode_libdir_flag_spec_F77='`test -z "$SCOABSPATH" && echo ${wl}-R,$libdir`'
+      hardcode_libdir_separator_F77=':'
+      link_all_deplibs_F77=yes
+      export_dynamic_flag_spec_F77='${wl}-Bexport'
+	archive_cmds_F77='$CC -shared ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds_F77='$CC -shared ${wl}-Bexport:$export_symbols ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+      else
+	archive_cmds_F77='$CC -G ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds_F77='$CC -G ${wl}-Bexport:$export_symbols ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+      fi
     uts4*)
@@ -14749,11 +14369,6 @@
 echo "${ECHO_T}$ld_shlibs_F77" >&6
-fi
@@ -14786,6 +14401,7 @@
         deplibs=
+	pic_flag=$lt_prog_compiler_pic_F77
         compiler_flags=-v
         linker_flags=-v
         verstring=
@@ -14946,7 +14562,8 @@
        $rm \$dlpath'
@@ -14999,7 +14616,7 @@
@@ -15037,7 +14654,14 @@
+  else
+    case $host_os in
+    esac
+  fi
     freebsd-elf*)
@@ -15059,10 +14683,15 @@
-  *) # from 3.2 on
   esac
@@ -15082,7 +14711,7 @@
   version_type=sunos
   need_lib_prefix=no
   need_version=no
+  case $host_cpu in
   ia64*)
     shrext_cmds='.so'
@@ -15122,6 +14751,18 @@
+interix3*)
+  need_version=no
 irix5* | irix6* | nonstopux*)
   case $host_os in
@@ -15183,7 +14824,7 @@
   libsuff=
   case "$host_cpu" in
-    echo '#line 15186 "configure"' > conftest.$ac_ext
+    echo '#line 14827 "configure"' > conftest.$ac_ext
     if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
   (eval $ac_compile) 2>&5
   ac_status=$?
@@ -15202,7 +14843,7 @@
   fi
@@ -15264,8 +14905,13 @@
 openbsd*)
   version_type=sunos
   need_lib_prefix=no
-  need_version=no
+  case $host_os in
+  esac
@@ -15303,13 +14949,6 @@
-sco3.2v5*)
-  version_type=osf
 solaris*)
   version_type=linux
   need_lib_prefix=no
@@ -15335,7 +14974,7 @@
   need_version=yes
-sysv4 | sysv4.2uw2* | sysv4.3* | sysv5*)
+sysv4 | sysv4.3*)
   version_type=linux
@@ -15368,6 +15007,29 @@
   fi
+sysv5* | sco3.2v5* | sco5v6* | unixware* | OpenUNIX* | sysv4*uw2*)
+  need_version=no
+  else
+    case $host_os in
+      sco3.2v5*)
+    esac
+  fi
 uts4*)
   version_type=linux
@@ -15383,6 +15045,11 @@
+fi
 hardcode_action_F77=
@@ -15420,37 +15087,7 @@
 fi
-striplib=
-old_striplib=
-else
-  case $host_os in
-   darwin*)
-       else
-fi
-  esac
-fi
@@ -15464,7 +15101,7 @@
     SED SHELL STRIP \
@@ -15582,6 +15219,9 @@
 # A C compiler.
 LTCC=$lt_LTCC
 CC=$lt_compiler_F77
@@ -15892,6 +15532,9 @@
 LTCC=${LTCC-"$CC"}
 compiler=$CC
@@ -15899,13 +15542,13 @@
 $rm conftest*
 $rm conftest*
@@ -15953,20 +15596,20 @@
-   (eval echo "\"\$as_me:15959: $lt_compile\"" >&5)
+   (eval echo "\"\$as_me:15602: $lt_compile\"" >&5)
    ac_status=$?
-   echo "$as_me:15963: \$? = $ac_status" >&5
+   echo "$as_me:15606: \$? = $ac_status" >&5
        lt_cv_prog_compiler_rtti_exceptions=yes
      fi
    fi
@@ -16027,6 +15670,11 @@
       lt_prog_compiler_pic_GCJ='-fno-common'
+    interix3*)
+      # Interix 3.x gcc -fpic/-fPIC options generate broken code.
+      # Instead, we relocate shared libraries at runtime.
     msdosdjgpp*)
       # Just because we use GCC doesn't mean we suddenly get shared libraries
       # on systems that don't support them.
@@ -16043,7 +15691,7 @@
     hpux*)
       # PIC is the default for IA64 HP-UX and 64-bit HP-UX, but
       # not for PA HP-UX.
+      case $host_cpu in
       hppa*64*|ia64*)
 	# +Z the default
@@ -16090,7 +15738,7 @@
       lt_prog_compiler_wl_GCJ='-Wl,'
       # not for PA HP-UX.
+      case $host_cpu in
       hppa*64*|ia64*)
 	# +Z the default
@@ -16120,12 +15768,12 @@
 	lt_prog_compiler_pic_GCJ='-KPIC'
 	lt_prog_compiler_static_GCJ='-static'
-      pgcc* | pgf77* | pgf90*)
+      pgcc* | pgf77* | pgf90* | pgf95*)
         # Portland Group compilers (*not* the Pentium gcc compiler,
 	# which looks to be a dead project)
 	lt_prog_compiler_pic_GCJ='-fpic'
-	lt_prog_compiler_static_GCJ='-static'
+	lt_prog_compiler_static_GCJ='-Bstatic'
       ccc*)
@@ -16141,11 +15789,6 @@
       lt_prog_compiler_static_GCJ='-non_shared'
-    sco3.2v5*)
-      lt_prog_compiler_pic_GCJ='-Kpic'
-      lt_prog_compiler_static_GCJ='-dn'
     solaris*)
@@ -16163,7 +15806,7 @@
-    sysv4 | sysv4.2uw2* | sysv4.3* | sysv5*)
+    sysv4 | sysv4.2uw2* | sysv4.3*)
@@ -16176,6 +15819,12 @@
       fi
+    sysv5* | unixware* | sco3.2v5* | sco5v6* | OpenUNIX*)
+      lt_prog_compiler_wl_GCJ='-Wl,'
+      lt_prog_compiler_pic_GCJ='-KPIC'
     unicos*)
       lt_prog_compiler_can_build_shared_GCJ=no
@@ -16215,20 +15864,20 @@
-   (eval echo "\"\$as_me:16221: $lt_compile\"" >&5)
+   (eval echo "\"\$as_me:15870: $lt_compile\"" >&5)
    ac_status=$?
-   echo "$as_me:16225: \$? = $ac_status" >&5
+   echo "$as_me:15874: \$? = $ac_status" >&5
        lt_prog_compiler_pic_works_GCJ=yes
      fi
    fi
@@ -16249,7 +15898,7 @@
 fi
 fi
-case "$host_os" in
+case $host_os in
   # For platforms which do not support PIC, -DPIC is meaningless:
   *djgpp*)
@@ -16259,6 +15908,48 @@
 esac
+# Check to make sure the static flag actually works.
+wl=$lt_prog_compiler_wl_GCJ eval lt_tmp_static_flag=\"$lt_prog_compiler_static_GCJ\"
+echo "$as_me:$LINENO: checking if $compiler static flag $lt_tmp_static_flag works" >&5
+echo $ECHO_N "checking if $compiler static flag $lt_tmp_static_flag works... $ECHO_C" >&6
+if test "${lt_prog_compiler_static_works_GCJ+set}" = set; then
+  echo $ECHO_N "(cached) $ECHO_C" >&6
+else
+  lt_prog_compiler_static_works_GCJ=no
+   save_LDFLAGS="$LDFLAGS"
+   LDFLAGS="$LDFLAGS $lt_tmp_static_flag"
+   printf "$lt_simple_link_test_code" > conftest.$ac_ext
+   if (eval $ac_link 2>conftest.err) && test -s conftest$ac_exeext; then
+     # The linker can only warn and ignore the option if not recognized
+     # So say no if there are warnings
+     if test -s conftest.err; then
+       # Append any errors to the config.log.
+       cat conftest.err 1>&5
+       $echo "X$_lt_linker_boilerplate" | $Xsed -e '/^$/d' > conftest.exp
+       if diff conftest.exp conftest.er2 >/dev/null; then
+         lt_prog_compiler_static_works_GCJ=yes
+       fi
+     else
+     fi
+   fi
+   $rm conftest*
+   LDFLAGS="$save_LDFLAGS"
+fi
+echo "$as_me:$LINENO: result: $lt_prog_compiler_static_works_GCJ" >&5
+echo "${ECHO_T}$lt_prog_compiler_static_works_GCJ" >&6
+if test x"$lt_prog_compiler_static_works_GCJ" = xyes; then
+else
+fi
 echo "$as_me:$LINENO: checking if $compiler supports -c -o file.$ac_objext" >&5
 echo $ECHO_N "checking if $compiler supports -c -o file.$ac_objext... $ECHO_C" >&6
 if test "${lt_cv_prog_compiler_c_o_GCJ+set}" = set; then
@@ -16277,25 +15968,25 @@
    # Note that $ac_compile itself does not contain backslashes and begins
-   (eval echo "\"\$as_me:16283: $lt_compile\"" >&5)
+   (eval echo "\"\$as_me:15974: $lt_compile\"" >&5)
    (eval "$lt_compile" 2>out/conftest.err)
    ac_status=$?
    cat out/conftest.err >&5
-   echo "$as_me:16287: \$? = $ac_status" >&5
+   echo "$as_me:15978: \$? = $ac_status" >&5
    if (exit $ac_status) && test -s out/conftest2.$ac_objext
    then
-     $echo "X$_lt_compiler_boilerplate" | $Xsed > out/conftest.exp
-     $SED '/^$/d' out/conftest.err >out/conftest.er2
-     if test ! -s out/conftest.err || diff out/conftest.exp out/conftest.er2 >/dev/null; then
+     $echo "X$_lt_compiler_boilerplate" | $Xsed -e '/^$/d' > out/conftest.exp
+     $SED '/^$/d; /^ *+/d' out/conftest.err >out/conftest.er2
+     if test ! -s out/conftest.er2 || diff out/conftest.exp out/conftest.er2 >/dev/null; then
        lt_cv_prog_compiler_c_o_GCJ=yes
      fi
    fi
-   chmod u+w .
+   chmod u+w . 2>&5
    $rm conftest*
    # SGI C++ compiler will create directory out/ii_files/ for
    # template instantiation
@@ -16391,6 +16082,10 @@
       with_gnu_ld=no
     fi
+  interix*)
+    # we just hope/assume this is gcc and not c89 (= MSVC++)
+    with_gnu_ld=yes
   openbsd*)
     with_gnu_ld=no
@@ -16475,7 +16170,7 @@
       export_symbols_cmds_GCJ='$NM $libobjs $convenience | $global_symbol_pipe | $SED -e '\''/^[BCDGRS] /s/.* \([^ ]*\)/\1 DATA/'\'' | $SED -e '\''/^[AITW] /s/.* //'\'' | sort | uniq > $export_symbols'
       if $LD --help 2>&1 | grep 'auto-import' > /dev/null; then
-        archive_cmds_GCJ='$CC -shared $libobjs $deplibs $compiler_flags -o $output_objdir/$soname ${wl}--image-base=0x10000000 ${wl}--out-implib,$lib'
+        archive_cmds_GCJ='$CC -shared $libobjs $deplibs $compiler_flags -o $output_objdir/$soname ${wl}--enable-auto-image-base -Xlinker --out-implib -Xlinker $lib'
 	# If the export-symbols file already is a .def file (1st line
 	# is EXPORTS), use it as is; otherwise, prepend...
 	archive_expsym_cmds_GCJ='if test "x`$SED 1q $export_symbols`" = xEXPORTS; then
@@ -16484,22 +16179,38 @@
 	  echo EXPORTS > $output_objdir/$soname.def;
 	  cat $export_symbols >> $output_objdir/$soname.def;
 	fi~
-	$CC -shared $output_objdir/$soname.def $libobjs $deplibs $compiler_flags -o $output_objdir/$soname ${wl}--image-base=0x10000000  ${wl}--out-implib,$lib'
+	$CC -shared $output_objdir/$soname.def $libobjs $deplibs $compiler_flags -o $output_objdir/$soname ${wl}--enable-auto-image-base -Xlinker --out-implib -Xlinker $lib'
       else
 	ld_shlibs_GCJ=no
       fi
+    interix3*)
+      hardcode_direct_GCJ=no
+      hardcode_shlibpath_var_GCJ=no
+      hardcode_libdir_flag_spec_GCJ='${wl}-rpath,$libdir'
+      export_dynamic_flag_spec_GCJ='${wl}-E'
+      # Hack: On Interix 3.x, we cannot compile PIC because of a broken gcc.
+      # Instead, shared libraries are loaded at an image base (0x10000000 by
+      # default) and relocated if they conflict, which is a slow very memory
+      # consuming and fragmenting process.  To avoid this, we pick a random,
+      # 256 KiB-aligned image base between 0x50000000 and 0x6FFC0000 at link
+      # time.  Moving up from 0x10000000 also allows more sbrk(2) space.
+      archive_cmds_GCJ='$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-h,$soname ${wl}--image-base,`expr ${RANDOM-$$} % 4096 / 2 \* 262144 + 1342177280` -o $lib'
+      archive_expsym_cmds_GCJ='sed "s,^,_," $export_symbols >$output_objdir/$soname.expsym~$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-h,$soname ${wl}--retain-symbols-file,$output_objdir/$soname.expsym ${wl}--image-base,`expr ${RANDOM-$$} % 4096 / 2 \* 262144 + 1342177280` -o $lib'
     linux*)
       if $LD --help 2>&1 | grep ': supported targets:.* elf' > /dev/null; then
 	tmp_addflag=
 	case $cc_basename,$host_cpu in
 	pgcc*)				# Portland Group C compiler
-	  whole_archive_flag_spec_GCJ=
+	  whole_archive_flag_spec_GCJ='${wl}--whole-archive`for conv in $convenience\"\"; do test  -n \"$conv\" && new_convenience=\"$new_convenience,$conv\"; done; $echo \"$new_convenience\"` ${wl}--no-whole-archive'
+	  tmp_addflag=' $pic_flag'
-	pgf77* | pgf90* )			# Portland Group f77 and f90 compilers
-	  tmp_addflag=' -fpic -Mnomain' ;;
+	pgf77* | pgf90* | pgf95*)	# Portland Group f77 and f90 compilers
+	  tmp_addflag=' $pic_flag -Mnomain' ;;
 	ecc*,ia64* | icc*,ia64*)		# Intel C compiler on ia64
 	  tmp_addflag=' -i_dynamic' ;;
 	efc*,ia64* | ifort*,ia64*)	# Intel Fortran compiler on ia64
@@ -16530,7 +16241,7 @@
       fi
-    solaris* | sysv5*)
+    solaris*)
       if $LD -v 2>&1 | grep 'BFD 2\.8' > /dev/null; then
 	ld_shlibs_GCJ=no
 	cat <<EOF 1>&2
@@ -16551,6 +16262,33 @@
       fi
+    sysv5* | sco3.2v5* | sco5v6* | unixware* | OpenUNIX*)
+      case `$LD -v 2>&1` in
+        *\ [01].* | *\ 2.[0-9].* | *\ 2.1[0-5].*)
+	ld_shlibs_GCJ=no
+	cat <<_LT_EOF 1>&2
+*** Warning: Releases of the GNU linker prior to 2.16.91.0.3 can not
+*** reliably create shared libraries on SCO systems.  Therefore, libtool
+*** is disabling shared libraries support.  We urge you to upgrade GNU
+*** binutils to release 2.16.91.0.3 or newer.  Another option is to modify
+*** your PATH or compiler configuration so that the native linker is
+*** used, and then restart.
+_LT_EOF
+	  if $LD --help 2>&1 | grep ': supported targets:.* elf' > /dev/null; then
+	    hardcode_libdir_flag_spec_GCJ='`test -z "$SCOABSPATH" && echo ${wl}-rpath,$libdir`'
+	    archive_cmds_GCJ='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib'
+	    archive_expsym_cmds_GCJ='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname,\${SCOABSPATH:+${install_libdir}/}$soname,-retain-symbols-file,$export_symbols -o $lib'
+	  else
+	    ld_shlibs_GCJ=no
+	  fi
+      esac
     sunos4*)
       archive_cmds_GCJ='$LD -assert pure-text -Bshareable -o $lib $libobjs $deplibs $linker_flags'
       wlarc=
@@ -16584,7 +16322,7 @@
       # Note: this linker hardcodes the directories in LIBPATH if there
       # are no directories specified by -L.
       hardcode_minus_L_GCJ=yes
-      if test "$GCC" = yes && test -z "$link_static_flag"; then
+      if test "$GCC" = yes && test -z "$lt_prog_compiler_static"; then
 	# Neither direct hardcoding nor static linking is supported with a
 	# broken collect2.
 	hardcode_direct_GCJ=unsupported
@@ -16618,6 +16356,7 @@
   	    break
   	  fi
 	  done
 	esac
 	exp_sym_flag='-bexport'
@@ -16655,6 +16394,7 @@
   	  hardcode_libdir_flag_spec_GCJ='-L$libdir'
   	  hardcode_libdir_separator_GCJ=
 	  fi
 	esac
 	shared_flag='-shared'
 	if test "$aix_use_runtimelinking" = yes; then
@@ -16667,11 +16407,11 @@
   	# chokes on -Wl,-G. The following line is correct:
 	  shared_flag='-G'
 	else
-  	if test "$aix_use_runtimelinking" = yes; then
+	  if test "$aix_use_runtimelinking" = yes; then
 	    shared_flag='${wl}-G'
 	  else
 	    shared_flag='${wl}-bM:SRE'
-  	fi
+	  fi
 	fi
       fi
@@ -16736,12 +16476,12 @@
 if test -z "$aix_libpath"; then aix_libpath="/usr/lib:/lib"; fi
        hardcode_libdir_flag_spec_GCJ='${wl}-blibpath:$libdir:'"$aix_libpath"
-	archive_expsym_cmds_GCJ="\$CC"' -o $output_objdir/$soname $libobjs $deplibs $compiler_flags `if test "x${allow_undefined_flag}" != "x"; then echo "${wl}${allow_undefined_flag}"; else :; fi` '"\${wl}$no_entry_flag \${wl}$exp_sym_flag:\$export_symbols $shared_flag"
+	archive_expsym_cmds_GCJ="\$CC"' -o $output_objdir/$soname $libobjs $deplibs '"\${wl}$no_entry_flag"' $compiler_flags `if test "x${allow_undefined_flag}" != "x"; then echo "${wl}${allow_undefined_flag}"; else :; fi` '"\${wl}$exp_sym_flag:\$export_symbols $shared_flag"
        else
 	if test "$host_cpu" = ia64; then
 	  hardcode_libdir_flag_spec_GCJ='${wl}-R $libdir:/usr/lib:/lib'
 	  allow_undefined_flag_GCJ="-z nodefs"
-	  archive_expsym_cmds_GCJ="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs $compiler_flags ${wl}${allow_undefined_flag} '"\${wl}$no_entry_flag \${wl}$exp_sym_flag:\$export_symbols"
+	  archive_expsym_cmds_GCJ="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs '"\${wl}$no_entry_flag"' $compiler_flags ${wl}${allow_undefined_flag} '"\${wl}$exp_sym_flag:\$export_symbols"
 	else
 	 # Determine the default libpath from the value encoded in an empty executable.
@@ -16801,13 +16541,11 @@
 	  # -berok will link without error, but may produce a broken library.
 	  no_undefined_flag_GCJ=' ${wl}-bernotok'
 	  allow_undefined_flag_GCJ=' ${wl}-berok'
-	  # -bexpall does not export symbols beginning with underscore (_)
-	  always_export_symbols_GCJ=yes
 	  # Exported symbols can be pulled into shared objects from archives
-	  whole_archive_flag_spec_GCJ=' '
+	  whole_archive_flag_spec_GCJ='$convenience'
 	  archive_cmds_need_lc_GCJ=yes
-	  # This is similar to how AIX traditionally builds it's shared libraries.
-	  archive_expsym_cmds_GCJ="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs $compiler_flags ${wl}-bE:$export_symbols ${wl}-bnoentry${allow_undefined_flag}~$AR $AR_FLAGS $output_objdir/$libname$release.a $output_objdir/$soname'
+	  # This is similar to how AIX traditionally builds its shared libraries.
+	  archive_expsym_cmds_GCJ="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs ${wl}-bnoentry $compiler_flags ${wl}-bE:$export_symbols${allow_undefined_flag}~$AR $AR_FLAGS $output_objdir/$libname$release.a $output_objdir/$soname'
 	fi
       fi
@@ -16846,7 +16584,7 @@
     darwin* | rhapsody*)
-      case "$host_os" in
+      case $host_os in
         rhapsody* | darwin1.[012])
          allow_undefined_flag_GCJ='${wl}-undefined ${wl}suppress'
@@ -16875,7 +16613,7 @@
         archive_cmds_GCJ='$CC -dynamiclib $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring'
       module_cmds_GCJ='$CC $allow_undefined_flag -o $lib -bundle $libobjs $deplibs$compiler_flags'
-      # Don't fix this by using the ld -exported_symbols_list flag, it doesn't exist in older darwin ld's
+      # Don't fix this by using the ld -exported_symbols_list flag, it doesn't exist in older darwin lds
       archive_expsym_cmds_GCJ='sed -e "s,#.*,," -e "s,^[    ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -dynamiclib $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
       module_expsym_cmds_GCJ='sed -e "s,#.*,," -e "s,^[    ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC $allow_undefined_flag  -o $lib -bundle $libobjs $deplibs$compiler_flags~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
     else
@@ -16884,7 +16622,7 @@
          archive_cmds_GCJ='$CC -qmkshrobj $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-install_name ${wl}`echo $rpath/$soname` $verstring'
          archive_expsym_cmds_GCJ='sed -e "s,#.*,," -e "s,^[    ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -qmkshrobj $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-install_name ${wl}$rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
@@ -16948,47 +16686,62 @@
-    hpux10* | hpux11*)
+    hpux10*)
       if test "$GCC" = yes -a "$with_gnu_ld" = no; then
-	hppa*64*|ia64*)
+	archive_cmds_GCJ='$CC -shared -fPIC ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $libobjs $deplibs $compiler_flags'
+      else
+	archive_cmds_GCJ='$LD -b +h $soname +b $install_libdir -o $lib $libobjs $deplibs $linker_flags'
+      fi
+      if test "$with_gnu_ld" = no; then
+	hardcode_libdir_flag_spec_GCJ='${wl}+b ${wl}$libdir'
+	hardcode_libdir_separator_GCJ=:
+	hardcode_direct_GCJ=yes
+	# hardcode_minus_L: Not really in the search PATH,
+	# but as the default location of the library.
+	hardcode_minus_L_GCJ=yes
+      fi
+    hpux11*)
+      if test "$GCC" = yes -a "$with_gnu_ld" = no; then
+	case $host_cpu in
+	hppa*64*)
 	  archive_cmds_GCJ='$CC -shared ${wl}+h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	ia64*)
+	  archive_cmds_GCJ='$CC -shared ${wl}+h ${wl}$soname ${wl}+nodefaultrpath -o $lib $libobjs $deplibs $compiler_flags'
 	esac
       else
-	hppa*64*|ia64*)
-	  archive_cmds_GCJ='$LD -b +h $soname -o $lib $libobjs $deplibs $linker_flags'
+	case $host_cpu in
+	hppa*64*)
+	  archive_cmds_GCJ='$CC -b ${wl}+h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	ia64*)
+	  archive_cmds_GCJ='$CC -b ${wl}+h ${wl}$soname ${wl}+nodefaultrpath -o $lib $libobjs $deplibs $compiler_flags'
-	  archive_cmds_GCJ='$LD -b +h $soname +b $install_libdir -o $lib $libobjs $deplibs $linker_flags'
+	  archive_cmds_GCJ='$CC -b ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $libobjs $deplibs $compiler_flags'
 	esac
       fi
-	hppa*64*)
-	  hardcode_libdir_flag_spec_GCJ='${wl}+b ${wl}$libdir'
+	case $host_cpu in
+	hppa*64*|ia64*)
 	  hardcode_libdir_flag_spec_ld_GCJ='+b $libdir'
-	  hardcode_libdir_separator_GCJ=:
-	ia64*)
-	  hardcode_libdir_flag_spec_GCJ='-L$libdir'
-	  hardcode_direct_GCJ=no
-	  hardcode_shlibpath_var_GCJ=no
-	  # hardcode_minus_L: Not really in the search PATH,
-	  # but as the default location of the library.
-	  hardcode_minus_L_GCJ=yes
@@ -17090,14 +16843,6 @@
-    sco3.2v5*)
-      archive_cmds_GCJ='$LD -G -h $soname -o $lib $libobjs $deplibs $linker_flags'
-      export_dynamic_flag_spec_GCJ='${wl}-Bexport'
-      runpath_var=LD_RUN_PATH
-      hardcode_runpath_var=yes
     solaris*)
       no_undefined_flag_GCJ=' -z text'
       if test "$GCC" = yes; then
@@ -17183,36 +16928,45 @@
       fi
-    sysv4.2uw2*)
-      archive_cmds_GCJ='$LD -G -o $lib $libobjs $deplibs $linker_flags'
-      hardcode_direct_GCJ=yes
-      hardcode_minus_L_GCJ=no
+    sysv4*uw2* | sysv5OpenUNIX* | sysv5UnixWare7.[01].[10]* | unixware7*)
+      no_undefined_flag_GCJ='${wl}-z,text'
+      archive_cmds_need_lc_GCJ=no
+      runpath_var='LD_RUN_PATH'
-   sysv5OpenUNIX8* | sysv5UnixWare7* |  sysv5uw[78]* | unixware7*)
-      no_undefined_flag_GCJ='${wl}-z ${wl}text'
-	archive_cmds_GCJ='$CC -shared ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_cmds_GCJ='$CC -shared ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds_GCJ='$CC -shared ${wl}-Bexport:$export_symbols ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
       else
-	archive_cmds_GCJ='$CC -G ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_cmds_GCJ='$CC -G ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds_GCJ='$CC -G ${wl}-Bexport:$export_symbols ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
       fi
-      runpath_var='LD_RUN_PATH'
-    sysv5*)
-      no_undefined_flag_GCJ=' -z text'
-      # $CC -shared without GNU ld will not create a library from C++
-      # object files and a static libstdc++, better avoid it by now
-      archive_cmds_GCJ='$LD -G${allow_undefined_flag} -h $soname -o $lib $libobjs $deplibs $linker_flags'
-      archive_expsym_cmds_GCJ='$echo "{ global:" > $lib.exp~cat $export_symbols | $SED -e "s/\(.*\)/\1;/" >> $lib.exp~$echo "local: *; };" >> $lib.exp~
-  		$LD -G${allow_undefined_flag} -M $lib.exp -h $soname -o $lib $libobjs $deplibs $linker_flags~$rm $lib.exp'
+    sysv5* | sco3.2v5* | sco5v6*)
+      # Note: We can NOT use -z defs as we might desire, because we do not
+      # link with -lc, and that would cause any symbols used from libc to
+      # always be unresolved, which means just about no library would
+      # ever link correctly.  If we're not using GNU ld we use -z text
+      # though, which does catch some bad symbols but isn't as heavy-handed
+      # as -z defs.
+      allow_undefined_flag_GCJ='${wl}-z,nodefs'
+      hardcode_libdir_flag_spec_GCJ='`test -z "$SCOABSPATH" && echo ${wl}-R,$libdir`'
+      hardcode_libdir_separator_GCJ=':'
+      link_all_deplibs_GCJ=yes
+      export_dynamic_flag_spec_GCJ='${wl}-Bexport'
+      if test "$GCC" = yes; then
+	archive_cmds_GCJ='$CC -shared ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds_GCJ='$CC -shared ${wl}-Bexport:$export_symbols ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+      else
+	archive_cmds_GCJ='$CC -G ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds_GCJ='$CC -G ${wl}-Bexport:$export_symbols ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+      fi
     uts4*)
@@ -17231,11 +16985,6 @@
 echo "${ECHO_T}$ld_shlibs_GCJ" >&6
 test "$ld_shlibs_GCJ" = no && can_build_shared=no
-variables_saved_for_relink="PATH $shlibpath_var $runpath_var"
-if test "$GCC" = yes; then
-  variables_saved_for_relink="$variables_saved_for_relink GCC_EXEC_PREFIX COMPILER_PATH LIBRARY_PATH"
-fi
 # Do we need to explicitly link libc?
@@ -17268,6 +17017,7 @@
         libobjs=conftest.$ac_objext
         deplibs=
+	pic_flag=$lt_prog_compiler_pic_GCJ
         compiler_flags=-v
         linker_flags=-v
         verstring=
@@ -17428,7 +17178,8 @@
       dlpath=`$SHELL 2>&1 -c '\''. $dir/'\''\${base_file}'\''i;echo \$dlname'\''`~
       dldir=$destdir/`dirname \$dlpath`~
       test -d \$dldir || mkdir -p \$dldir~
-      $install_prog $dir/$dlname \$dldir/$dlname'
+      $install_prog $dir/$dlname \$dldir/$dlname~
+      chmod a+x \$dldir/$dlname'
     postuninstall_cmds='dldll=`$SHELL 2>&1 -c '\''. $file; echo \$dlname'\''`~
       dlpath=$dir/\$dldll~
        $rm \$dlpath'
@@ -17481,7 +17232,7 @@
   soname_spec='${libname}${release}${major}$shared_ext'
   shlibpath_overrides_runpath=yes
   shlibpath_var=DYLD_LIBRARY_PATH
-  shrext_cmds='$(test .$module = .yes && echo .so || echo .dylib)'
+  shrext_cmds='`test .$module = .yes && echo .so || echo .dylib`'
   # Apple's gcc prints 'gcc -print-search-dirs' doesn't operate the same.
     sys_lib_search_path_spec=`$CC -print-search-dirs | tr "\n" "$PATH_SEPARATOR" | sed -e 's/libraries:/@libraries:/' | tr "@" "\n" | grep "^libraries:" | sed -e "s/^libraries://" -e "s,=/,/,g" -e "s,$PATH_SEPARATOR, ,g" -e "s,.*,& /lib /usr/lib /usr/local/lib,g"`
@@ -17519,7 +17270,14 @@
 freebsd* | dragonfly*)
   # DragonFly does not have aout.  When/if they implement a new
   # versioning mechanism, adjust this.
-  objformat=`test -x /usr/bin/objformat && /usr/bin/objformat || echo aout`
+  if test -x /usr/bin/objformat; then
+    objformat=`/usr/bin/objformat`
+  else
+    case $host_os in
+    freebsd[123]*) objformat=aout ;;
+    *) objformat=elf ;;
+    esac
+  fi
   version_type=freebsd-$objformat
   case $version_type in
     freebsd-elf*)
@@ -17541,10 +17299,15 @@
     hardcode_into_libs=yes
-  *) # from 3.2 on
+  freebsd3.[2-9]* | freebsdelf3.[2-9]* | \
+  freebsd4.[0-5] | freebsdelf4.[0-5] | freebsd4.1.1 | freebsdelf4.1.1)
     shlibpath_overrides_runpath=no
+  freebsd*) # from 4.6 on
+    shlibpath_overrides_runpath=yes
+    hardcode_into_libs=yes
   esac
@@ -17564,7 +17327,7 @@
   version_type=sunos
   need_lib_prefix=no
   need_version=no
+  case $host_cpu in
   ia64*)
     shrext_cmds='.so'
@@ -17604,6 +17367,18 @@
   postinstall_cmds='chmod 555 $lib'
+interix3*)
+  version_type=linux
+  need_lib_prefix=no
+  need_version=no
+  library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${shared_ext}'
+  soname_spec='${libname}${release}${shared_ext}$major'
+  dynamic_linker='Interix 3.x ld.so.1 (PE, like ELF)'
+  shlibpath_var=LD_LIBRARY_PATH
+  shlibpath_overrides_runpath=no
   case $host_os in
     nonstopux*) version_type=nonstopux ;;
@@ -17665,7 +17440,7 @@
   libsuff=
   case "$host_cpu" in
   x86_64*|s390x*|powerpc64*)
-    echo '#line 17668 "configure"' > conftest.$ac_ext
+    echo '#line 17443 "configure"' > conftest.$ac_ext
   ac_status=$?
@@ -17684,7 +17459,7 @@
   # Append ld.so.conf contents to the search path
   if test -f /etc/ld.so.conf; then
-    lt_ld_extra=`awk '/^include / { system(sprintf("cd /etc; cat %s", \$2)); skip = 1; } { if (!skip) print \$0; skip = 0; }' < /etc/ld.so.conf | $SED -e 's/#.*//;s/[:,\t]/ /g;s/=[^=]*$//;s/=[^= ]* / /g;/^$/d' | tr '\n' ' '`
+    lt_ld_extra=`awk '/^include / { system(sprintf("cd /etc; cat %s", \$2)); skip = 1; } { if (!skip) print \$0; skip = 0; }' < /etc/ld.so.conf | $SED -e 's/#.*//;s/[:,	]/ /g;s/=[^=]*$//;s/=[^= ]* / /g;/^$/d' | tr '\n' ' '`
     sys_lib_dlsearch_path_spec="/lib${libsuff} /usr/lib${libsuff} $lt_ld_extra"
   fi
@@ -17746,8 +17521,13 @@
 openbsd*)
   version_type=sunos
+  sys_lib_dlsearch_path_spec="/usr/lib"
   need_lib_prefix=no
-  need_version=no
+  # Some older versions of OpenBSD (3.3 at least) *do* need versioned libs.
+  case $host_os in
+    openbsd3.3 | openbsd3.3.*) need_version=yes ;;
+    *)                         need_version=no  ;;
+  esac
   library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${shared_ext}$versuffix'
   finish_cmds='PATH="\$PATH:/sbin" ldconfig -m $libdir'
@@ -17785,13 +17565,6 @@
   sys_lib_dlsearch_path_spec="$sys_lib_search_path_spec"
-sco3.2v5*)
-  version_type=osf
-  soname_spec='${libname}${release}${shared_ext}$major'
-  library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname${shared_ext}'
-  shlibpath_var=LD_LIBRARY_PATH
 solaris*)
   version_type=linux
   need_lib_prefix=no
@@ -17817,7 +17590,7 @@
   need_version=yes
+sysv4 | sysv4.3*)
   version_type=linux
@@ -17850,6 +17623,29 @@
   fi
+  version_type=freebsd-elf
+  need_version=no
+  library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext} $libname${shared_ext}'
+  if test "$with_gnu_ld" = yes; then
+    sys_lib_search_path_spec='/usr/local/lib /usr/gnu/lib /usr/ccs/lib /usr/lib /lib'
+  else
+    sys_lib_search_path_spec='/usr/ccs/lib /usr/lib'
+    case $host_os in
+      sco3.2v5*)
+        sys_lib_search_path_spec="$sys_lib_search_path_spec /lib"
+    esac
+  fi
+  sys_lib_dlsearch_path_spec='/usr/lib'
 uts4*)
   version_type=linux
@@ -17865,6 +17661,11 @@
 echo "${ECHO_T}$dynamic_linker" >&6
 test "$dynamic_linker" = no && can_build_shared=no
+variables_saved_for_relink="PATH $shlibpath_var $runpath_var"
+if test "$GCC" = yes; then
+  variables_saved_for_relink="$variables_saved_for_relink GCC_EXEC_PREFIX COMPILER_PATH LIBRARY_PATH"
+fi
 echo "$as_me:$LINENO: checking how to hardcode library paths into programs" >&5
 echo $ECHO_N "checking how to hardcode library paths into programs... $ECHO_C" >&6
 hardcode_action_GCJ=
@@ -17902,842 +17703,7 @@
 fi
-striplib=
-old_striplib=
-else
-  case $host_os in
-   darwin*)
-       else
-fi
-  esac
-fi
-else
-  lt_cv_dlopen=no
-  case $host_os in
-  beos*)
-  mingw* | pw32*)
-  cygwin*)
-  darwin*)
-  echo $ECHO_N "(cached) $ECHO_C" >&6
-else
-LIBS="-ldl  $LIBS"
-/* confdefs.h.  */
-_ACEOF
-#ifdef __cplusplus
-extern "C"
-#endif
-char dlopen ();
-int
-main ()
-dlopen ();
-  return 0;
-_ACEOF
-  ac_status=$?
-  ac_status=$?
-  ac_status=$?
-else
-fi
-fi
-else
-fi
-else
-/* confdefs.h.  */
-_ACEOF
-#ifdef __STDC__
-#else
-#endif
-#undef shl_load
-#ifdef __cplusplus
-extern "C"
-#endif
-char shl_load ();
-choke me
-#else
-#endif
-#ifdef __cplusplus
-#endif
-int
-main ()
-  return 0;
-_ACEOF
-  ac_status=$?
-  ac_status=$?
-  ac_status=$?
-else
-fi
-fi
-else
-else
-LIBS="-ldld  $LIBS"
-/* confdefs.h.  */
-_ACEOF
-#ifdef __cplusplus
-extern "C"
-#endif
-char shl_load ();
-int
-main ()
-shl_load ();
-  return 0;
-_ACEOF
-  ac_status=$?
-  ac_status=$?
-  ac_status=$?
-else
-fi
-fi
-else
-else
-/* confdefs.h.  */
-_ACEOF
-#ifdef __STDC__
-#else
-#endif
-#undef dlopen
-#ifdef __cplusplus
-extern "C"
-#endif
-char dlopen ();
-choke me
-#else
-#endif
-#ifdef __cplusplus
-#endif
-int
-main ()
-  return 0;
-_ACEOF
-  ac_status=$?
-  ac_status=$?
-  ac_status=$?
-else
-fi
-fi
-else
-else
-LIBS="-ldl  $LIBS"
-/* confdefs.h.  */
-_ACEOF
-#ifdef __cplusplus
-extern "C"
-#endif
-char dlopen ();
-int
-main ()
-dlopen ();
-  return 0;
-_ACEOF
-  ac_status=$?
-  ac_status=$?
-  ac_status=$?
-else
-fi
-fi
-else
-else
-/* confdefs.h.  */
-_ACEOF
-#ifdef __cplusplus
-extern "C"
-#endif
-char dlopen ();
-int
-main ()
-dlopen ();
-  return 0;
-_ACEOF
-  ac_status=$?
-  ac_status=$?
-  ac_status=$?
-else
-fi
-fi
-else
-else
-LIBS="-ldld  $LIBS"
-/* confdefs.h.  */
-_ACEOF
-#ifdef __cplusplus
-extern "C"
-#endif
-char dld_link ();
-int
-main ()
-dld_link ();
-  return 0;
-_ACEOF
-  ac_status=$?
-  ac_status=$?
-  ac_status=$?
-else
-fi
-fi
-fi
-fi
-fi
-fi
-fi
-fi
-  esac
-    enable_dlopen=yes
-  else
-    enable_dlopen=no
-  fi
-  dlopen)
-    save_LDFLAGS="$LDFLAGS"
-    eval LDFLAGS=\"\$LDFLAGS $export_dynamic_flag_spec\"
-    save_LIBS="$LIBS"
-else
-else
-#line 18539 "configure"
-#if HAVE_DLFCN_H
-#include <dlfcn.h>
-#endif
-#include <stdio.h>
-#ifdef RTLD_GLOBAL
-#else
-#  ifdef DL_GLOBAL
-#  else
-#  endif
-#endif
-#  ifdef RTLD_LAZY
-#  else
-#    ifdef DL_LAZY
-#    else
-#      ifdef RTLD_NOW
-#      else
-#        ifdef DL_NOW
-#        else
-#        endif
-#      endif
-#    endif
-#  endif
-#endif
-#ifdef __cplusplus
-#endif
-int main ()
-  if (self)
-    exit (status);
-EOF
-  ac_status=$?
-    (./conftest; exit; ) 2>/dev/null
-    lt_status=$?
-      x$lt_unknown|x*) lt_cv_dlopen_self=no ;;
-    esac
-  else :
-  fi
-fi
-rm -fr conftest*
-fi
-      LDFLAGS="$LDFLAGS $link_static_flag"
-else
-else
-#line 18637 "configure"
-#if HAVE_DLFCN_H
-#include <dlfcn.h>
-#endif
-#include <stdio.h>
-#ifdef RTLD_GLOBAL
-#else
-#  ifdef DL_GLOBAL
-#  else
-#  endif
-#endif
-#  ifdef RTLD_LAZY
-#  else
-#    ifdef DL_LAZY
-#    else
-#      ifdef RTLD_NOW
-#      else
-#        ifdef DL_NOW
-#        else
-#        endif
-#      endif
-#    endif
-#  endif
-#endif
-#ifdef __cplusplus
-#endif
-int main ()
-  if (self)
-    exit (status);
-EOF
-  ac_status=$?
-    lt_status=$?
-      x$lt_unknown|x*) lt_cv_dlopen_self_static=no ;;
-    esac
-  else :
-  fi
-fi
-rm -fr conftest*
-fi
-    fi
-    LDFLAGS="$save_LDFLAGS"
-    LIBS="$save_LIBS"
-  esac
-  esac
-  esac
-fi
@@ -18751,7 +17717,7 @@
   # Now quote all the things that may contain metacharacters while being
   # careful not to overquote the AC_SUBSTed values.  We take copies of the
   # variables and quote the copies for generation of the libtool script.
-  for var in echo old_CC old_CFLAGS AR AR_FLAGS EGREP RANLIB LN_S LTCC NM \
+  for var in echo old_CC old_CFLAGS AR AR_FLAGS EGREP RANLIB LN_S LTCC LTCFLAGS NM \
     SED SHELL STRIP \
     libname_spec library_names_spec soname_spec extract_expsyms_cmds \
     old_striplib striplib file_magic_cmd finish_cmds finish_eval \
@@ -18869,6 +17835,9 @@
 # A C compiler.
 LTCC=$lt_LTCC
+# LTCC compiler flags.
+LTCFLAGS=$lt_LTCFLAGS
 # A language-specific compiler.
 CC=$lt_compiler_GCJ
@@ -19178,6 +18147,9 @@
 LTCC=${LTCC-"$CC"}
 compiler=$CC
@@ -19185,13 +18157,13 @@
 $rm conftest*
 $rm conftest*
@@ -19226,7 +18198,7 @@
     SED SHELL STRIP \
@@ -19344,6 +18316,9 @@
 # A C compiler.
 LTCC=$lt_LTCC
 CC=$lt_compiler_RC
@@ -19850,9 +18825,11 @@
 #FdoCommon
           ac_config_files="$ac_config_files Utilities/Common/Makefile"
 #TestCommon
           ac_config_files="$ac_config_files Utilities/TestCommon/Makefile"
 #SQLiteInterface
           ac_config_files="$ac_config_files Utilities/SQLiteInterface/Makefile"
@@ -20280,7 +19257,7 @@
 } >&5
 cat >&5 <<_CSEOF
-This file was extended by FDO $as_me 3.2.0, which was
+This file was extended by FDO $as_me 3.3.0, which was
 generated by GNU Autoconf 2.59.  Invocation command line was
   CONFIG_FILES    = $CONFIG_FILES
@@ -20338,7 +19315,7 @@
 cat >>$CONFIG_STATUS <<_ACEOF
 ac_cs_version="\\
-FDO config.status 3.2.0
+FDO config.status 3.3.0
 configured by $0, generated by GNU Autoconf 2.59,
   with options \\"`echo "$ac_configure_args" | sed 's/[\\""\`\$]/\\\\&/g'`\\"
Modified: trunk/configure.in
--- trunk/configure.in	2007-02-09 21:30:43 UTC (rev 2456)
+++ trunk/configure.in	2007-02-09 22:03:02 UTC (rev 2457)
@@ -21,7 +21,7 @@
 # Variables
 # Following are the makefile directories
-AC_INIT(FDO,3.2.0,https://fdocore.osgeo.org)
+AC_INIT(FDO,3.3.0,https://fdocore.osgeo.org)
 AC_CONFIG_SRCDIR(configure.in)
 AM_INIT_AUTOMAKE
@@ -38,7 +38,7 @@
 AC_SUBST(VERSION, "3.2.0")
 dnl *******************************************************
-dnl FDO 3.2.0 Configuration
+dnl FDO 3.3.0 Configuration
 dnl FDO / FDO Utilities / FDO Thirdpary paths
 # custom Fdo path specification
Modified: trunk/createtarzipfiles.sh
--- trunk/createtarzipfiles.sh	2007-02-09 21:30:43 UTC (rev 2456)
+++ trunk/createtarzipfiles.sh	2007-02-09 22:03:02 UTC (rev 2457)
@@ -50,7 +50,11 @@
 ARCENABLECHK=yes
 RDBMSENABLECHK=yes
 GDALENABLECHK=yes
+KINGENABLECHK=yes
+OGRENABLECHK=yes
 SHOWHELP=no
 FDOTARZIPFOLDER=/OpenSource_FDO
 FDOBUILDNUMBER=GXXX
@@ -70,7 +74,7 @@
   -b | --b | --build)
      if test -z	 "$1"; then
         echo "build number cannot be empty"
-	exit 1
+	    exit 1
      else
         FDOBUILDNUMBER="$1"
      fi
@@ -79,7 +83,7 @@
   -o | --o | --outpath)
         echo "Destination folder can not be empty"
-	exit 1
+	    exit 1
      else
         FDOTARZIPFOLDER="$1"
      fi
@@ -88,7 +92,7 @@
   -i | --i | --inpath)
-	exit 1
+	    exit 1
      else
         FDOSVNROOT="$1"
      fi
@@ -96,41 +100,47 @@
   -w | --w | --with)
      if test "$DEFMODIFYCHK" == no; then
-	DEFMODIFYCHK=yes
-	FDOCOREENABLECHK=no
-	SHPENABLECHK=no
-	SDFENABLECHK=no
-	WFSENABLECHK=no
-	WMSENABLECHK=no
-	ARCENABLECHK=no
-	RDBMSENABLECHK=no
-	GDALENABLECHK=no
+	    DEFMODIFYCHK=yes
+	    FDOCOREENABLECHK=no
+	    SHPENABLECHK=no
+	    SDFENABLECHK=no
+	    WFSENABLECHK=no
+	    WMSENABLECHK=no
+	    ARCENABLECHK=no
+	    RDBMSENABLECHK=no
+	    GDALENABLECHK=no
+	    KINGENABLECHK=no
+	    OGRENABLECHK=no
      fi
         echo "Invalid parameter"
-	exit 1
+	    exit 1
      elif test "$1" == providers; then
-	SHPENABLECHK=yes
-	SDFENABLECHK=yes
-	WFSENABLECHK=yes
-	WMSENABLECHK=yes
-	ARCENABLECHK=yes
-	RDBMSENABLECHK=yes
-	GDALENABLECHK=yes
+	    SHPENABLECHK=yes
+	    SDFENABLECHK=yes
+	    WFSENABLECHK=yes
+	    WMSENABLECHK=yes
+	    ARCENABLECHK=yes
+	    RDBMSENABLECHK=yes
+	    GDALENABLECHK=yes
+	    KINGENABLECHK=yes
+	    OGRENABLECHK=yes
      elif test "$1" == all; then
-	FDOCOREENABLECHK=yes
-	SHPENABLECHK=yes
-	SDFENABLECHK=yes
-	WFSENABLECHK=yes
-	WMSENABLECHK=yes
-	ARCENABLECHK=yes
-	GDALENABLECHK=yes
+	    FDOCOREENABLECHK=yes
+	    SHPENABLECHK=yes
+	    SDFENABLECHK=yes
+	    WFSENABLECHK=yes
+	    WMSENABLECHK=yes
+	    ARCENABLECHK=yes
+	    GDALENABLECHK=yes
+	    KINGENABLECHK=yes
+	    OGRENABLECHK=yes
      elif test "$1" == fdo; then
-	THRPENABLECHK=no
-	FDOENABLECHK=no
-	UTILENABLECHK=no
+	    THRPENABLECHK=no
+	    FDOENABLECHK=no
+	    UTILENABLECHK=no
      elif test "$1" == shp; then
         SHPENABLECHK=yes
      elif test "$1" == sdf; then
@@ -145,6 +155,10 @@
         RDBMSENABLECHK=yes
      elif test "$1" == gdal; then
         GDALENABLECHK=yes
+     elif test "$1" == king; then
+        KINGENABLECHK=yes
+     elif test "$1" == ogr; then
+        OGRENABLECHK=yes
      else
 	exit 1
@@ -189,6 +203,8 @@
    echo "                         arcsde"
    echo "                         rdbms"
    echo "                         gdal"
+   echo "                         king"
+   echo "                         ogr"
    echo "BuildNumber:    --b[uild]=User-Defined build number appended"
    echo "                          to the end of the tar.gz files"
    echo "**************************************************************************"
@@ -278,6 +294,26 @@
    gzip -9 fdogdal-3.3.0_"$FDOBUILDNUMBER".tar
    rm -rf "$FDOTARZIPFOLDER"
 fi
+if test "$KINGENABLECHK" == yes; then
+   mkdir -p "$FDOTARZIPFOLDER"/Providers/KingOracle
+   svn export "$FDOSVNROOT"/Providers/KingOracle "$FDOTARZIPFOLDER"/Providers/KingOracle --force
+   find "$FDOTARZIPFOLDER" -name .svn | xargs rm -rf
+   rm -f fdoking-3.3.0_"$FDOBUILDNUMBER".tar
+   tar -cf fdoking-3.3.0_"$FDOBUILDNUMBER".tar "$FDOTARZIPFOLDER"
+   rm -f fdoking-3.3.0_"$FDOBUILDNUMBER".tar.gz
+   gzip -9 fdoking-3.3.0_"$FDOBUILDNUMBER".tar
+   rm -rf "$FDOTARZIPFOLDER"
+fi
+if test "$OGRENABLECHK" == yes; then
+   mkdir -p "$FDOTARZIPFOLDER"/Providers/OGR
+   svn export "$FDOSVNROOT"/Providers/OGR "$FDOTARZIPFOLDER"/Providers/OGR --force
+   rm -f fdoogr-3.3.0_"$FDOBUILDNUMBER".tar
+   tar -cf fdoogr-3.3.0_"$FDOBUILDNUMBER".tar "$FDOTARZIPFOLDER"
+   rm -f fdoogr-3.3.0_"$FDOBUILDNUMBER".tar.gz
+   gzip -9 fdoogr-3.3.0_"$FDOBUILDNUMBER".tar
+fi
 echo "End creation of tar files"
More information about the fdo-commits mailing list
