[fdo-commits] r2461 - trunk/Providers/GenericRdbms
    svn_fdo at osgeo.org
    Fri Feb  9 18:09:02 EST 2007
Author: gregboone
Date: 2007-02-09 18:09:01 -0500 (Fri, 09 Feb 2007)
New Revision: 2461
   trunk/Providers/GenericRdbms/configure
   trunk/Providers/GenericRdbms/configure.in
Update FDO 3.3 build scripts
Modified: trunk/Providers/GenericRdbms/configure
--- trunk/Providers/GenericRdbms/configure	2007-02-09 23:08:35 UTC (rev 2460)
+++ trunk/Providers/GenericRdbms/configure	2007-02-09 23:09:01 UTC (rev 2461)
@@ -1,11 +1,10 @@
 #! /bin/sh
 # Guess values for system-dependent variables and create Makefiles.
-# Generated by GNU Autoconf 2.57 for FDORDBMS 3.2.0.
+# Generated by GNU Autoconf 2.59 for FDORDBMS 3.3.0.
 # Report bugs to <http://www.fdo.osgeo.org>.
-# Copyright 1992, 1993, 1994, 1995, 1996, 1998, 1999, 2000, 2001, 2002
-# Free Software Foundation, Inc.
+# Copyright (C) 2003 Free Software Foundation, Inc.
 # This configure script is free software; the Free Software Foundation
 # gives unlimited permission to copy, distribute and modify it.
@@ -22,9 +21,10 @@
 elif test -n "${BASH_VERSION+set}" && (set -o posix) >/dev/null 2>&1; then
   set -o posix
 fi
+DUALCASE=1; export DUALCASE # for MKS sh
 # Support unset when possible.
-if (FOO=FOO; unset FOO) >/dev/null 2>&1; then
+if ( (MAIL=60; unset MAIL) || exit) >/dev/null 2>&1; then
   as_unset=unset
 else
   as_unset=false
@@ -43,7 +43,7 @@
   LC_MEASUREMENT LC_MESSAGES LC_MONETARY LC_NAME LC_NUMERIC LC_PAPER \
   LC_TELEPHONE LC_TIME
 do
-  if (set +x; test -n "`(eval $as_var=C; export $as_var) 2>&1`"); then
+  if (set +x; test -z "`(eval $as_var=C; export $as_var) 2>&1`"); then
   else
     $as_unset $as_var
@@ -220,16 +220,17 @@
 if mkdir -p . 2>/dev/null; then
   as_mkdir_p=:
 else
+  test -d ./-p && rmdir ./-p
   as_mkdir_p=false
 fi
 as_executable_p="test -f"
 # Sed expression to map a string onto a valid CPP name.
-as_tr_cpp="sed y%*$as_cr_letters%P$as_cr_LETTERS%;s%[^_$as_cr_alnum]%_%g"
+as_tr_cpp="eval sed 'y%*$as_cr_letters%P$as_cr_LETTERS%;s%[^_$as_cr_alnum]%_%g'"
 # Sed expression to map a string onto a valid variable name.
-as_tr_sh="sed y%*+%pp%;s%[^_$as_cr_alnum]%_%g"
+as_tr_sh="eval sed 'y%*+%pp%;s%[^_$as_cr_alnum]%_%g'"
 # IFS
@@ -242,18 +243,7 @@
 $as_unset CDPATH
-# Find the correct PATH separator.  Usually this is `:', but
-# DJGPP uses `;' like DOS.
-if test "X${PATH_SEPARATOR+set}" != Xset; then
-  UNAME=${UNAME-`uname 2>/dev/null`}
-  case X$UNAME in
-    *-DOS) lt_cv_sys_path_separator=';' ;;
-    *)     lt_cv_sys_path_separator=':' ;;
-  esac
-  PATH_SEPARATOR=$lt_cv_sys_path_separator
-fi
 # Check that we are running under the correct shell.
 SHELL=${CONFIG_SHELL-/bin/sh}
@@ -271,7 +261,7 @@
 elif test "X$1" = X--fallback-echo; then
   # Avoid inline document here, it may be left over
-elif test "X`($echo '\t') 2>/dev/null`" = 'X\t'; then
+elif test "X`($echo '\t') 2>/dev/null`" = 'X\t' ; then
   # Yippee, $echo works!
 else
@@ -283,22 +273,22 @@
   # used as fallback echo
   shift
   cat <<EOF
 EOF
   exit 0
 fi
 # The HP-UX ksh and POSIX shell print the target directory to stdout
 # if CDPATH is set.
-if test "X${CDPATH+set}" = Xset; then CDPATH=:; export CDPATH; fi
+(unset CDPATH) >/dev/null 2>&1 && unset CDPATH
 if test -z "$ECHO"; then
 if test "X${echo_test_string+set}" != Xset; then
 # find a string as large as possible, as long as the shell can cope with it
   for cmd in 'sed 50q "$0"' 'sed 20q "$0"' 'sed 10q "$0"' 'sed 2q "$0"' 'echo test'; do
     # expected sizes: less than 2Kb, 1Kb, 512 bytes, 16 bytes, ...
-    if (echo_test_string="`eval $cmd`") 2>/dev/null &&
-       echo_test_string="`eval $cmd`" &&
+    if (echo_test_string=`eval $cmd`) 2>/dev/null &&
+       echo_test_string=`eval $cmd` &&
        (test "X$echo_test_string" = "X$echo_test_string") 2>/dev/null
     then
       break
@@ -317,8 +307,9 @@
   # So, first we look for a working echo in the user's PATH.
-  IFS="${IFS= 	}"; save_ifs="$IFS"; IFS=$PATH_SEPARATOR
+  lt_save_ifs="$IFS"; IFS=$PATH_SEPARATOR
   for dir in $PATH /usr/ucb; do
+    IFS="$lt_save_ifs"
     if (test -f $dir/echo || test -f $dir/echo$ac_exeext) &&
        test "X`($dir/echo '\t') 2>/dev/null`" = 'X\t' &&
        echo_testing_string=`($dir/echo "$echo_test_string") 2>/dev/null` &&
@@ -327,7 +318,7 @@
       break
     fi
   done
-  IFS="$save_ifs"
   if test "X$echo" = Xecho; then
     # We didn't find a better echo, so look for alternatives.
@@ -401,6 +392,11 @@
+tagnames=${tagnames+${tagnames},}CXX
+tagnames=${tagnames+${tagnames},}F77
 # Name of the host.
 # hostname on some systems (SVR3.2, Linux) returns a bogus exit status,
 # so uname gets run too.
@@ -427,8 +423,8 @@
 # Identity of this package.
 PACKAGE_NAME='FDORDBMS'
 PACKAGE_TARNAME='fdordbms'
-PACKAGE_VERSION='3.2.0'
-PACKAGE_STRING='FDO 3.2.0'
+PACKAGE_VERSION='3.3.0'
+PACKAGE_STRING='FDORDBMS 3.3.0'
 PACKAGE_BUGREPORT='http://www.fdo.osgeo.org'
 ac_unique_file="configure.in"
@@ -470,7 +466,7 @@
 # include <unistd.h>
 #endif"
-ac_subst_vars='SHELL PATH_SEPARATOR PACKAGE_NAME PACKAGE_TARNAME PACKAGE_VERSION PACKAGE_STRING PACKAGE_BUGREPORT exec_prefix prefix program_transform_name bindir sbindir libexecdir datadir sysconfdir sharedstatedir localstatedir libdir includedir oldincludedir infodir mandir build_alias host_alias target_alias DEFS ECHO_C ECHO_N ECHO_T LIBS INSTALL_PROGRAM INSTALL_SCRIPT INSTALL_DATA PACKAGE VERSION ACLOCAL AUTOCONF AUTOMAKE AUTOHEADER MAKEINFO AMTAR install_sh STRIP ac_ct_STRIP INSTALL_STRIP_PROGRAM AWK SET_MAKE CC CFLAGS LDFLAGS CPPFLAGS ac_ct_CC EXEEXT OBJEXT DEPDIR am__include am__quote AMDEP_TRUE AMDEP_FALSE AMDEPBACKSLASH CCDEPMODE CXX CXXFLAGS ac_ct_CXX CXXDEPMODE YACC build build_cpu build_vendor build_os host host_cpu host_vendor host_os LN_S ECHO RANLIB ac_ct_RANLIB CXXCPP EGREP LIBTOOL FDO FDOUTILITIES FDOTHIRDPARTY FDOMYSQL FDOODBC CXXFLAGS_SDF LIBOBJS LTLIBOBJS'
+ac_subst_vars='SHELL PATH_SEPARATOR PACKAGE_NAME PACKAGE_TARNAME PACKAGE_VERSION PACKAGE_STRING PACKAGE_BUGREPORT exec_prefix prefix program_transform_name bindir sbindir libexecdir datadir sysconfdir sharedstatedir localstatedir libdir includedir oldincludedir infodir mandir build_alias host_alias target_alias DEFS ECHO_C ECHO_N ECHO_T LIBS INSTALL_PROGRAM INSTALL_SCRIPT INSTALL_DATA CYGPATH_W PACKAGE VERSION ACLOCAL AUTOCONF AUTOMAKE AUTOHEADER MAKEINFO install_sh STRIP ac_ct_STRIP INSTALL_STRIP_PROGRAM mkdir_p AWK SET_MAKE am__leading_dot AMTAR am__tar am__untar CC CFLAGS LDFLAGS CPPFLAGS ac_ct_CC EXEEXT OBJEXT DEPDIR am__include am__quote AMDEP_TRUE AMDEP_FALSE AMDEPBACKSLASH CCDEPMODE am__fastdepCC_TRUE am__fastdepCC_FALSE CXX CXXFLAGS ac_ct_CXX CXXDEPMODE am__fastdepCXX_TRUE am__fastdepCXX_FALSE YACC build build_cpu build_vendor build_os host host_cpu host_vendor host_os EGREP LN_S ECHO AR ac_ct_AR RANLIB ac_ct_RANLIB CPP CXXCPP F77 FFLAGS ac_ct_F77 LIBTOOL FDO FDOUTILITIES FDOTHIRDPARTY FDOMYSQL FDOODBC CXXFLAGS_SDF LIBOBJS LTLIBOBJS'
 ac_subst_files=''
 # Initialize some variables set by options.
@@ -829,7 +825,7 @@
 # Be sure to have absolute paths.
 for ac_var in bindir sbindir libexecdir datadir sysconfdir sharedstatedir \
-              localstatedir libdir includedir oldincludedir infodir mandir
+	      localstatedir libdir includedir oldincludedir infodir mandir
 do
   eval ac_val=$`echo $ac_var`
   case $ac_val in
@@ -869,10 +865,10 @@
   # Try the directory containing this script, then its parent.
   ac_confdir=`(dirname "$0") 2>/dev/null ||
 $as_expr X"$0" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
-         X"$0" : 'X\(//\)[^/]' \| \
-         X"$0" : 'X\(//\)$' \| \
-         X"$0" : 'X\(/\)' \| \
-         .     : '\(.\)' 2>/dev/null ||
+	 X"$0" : 'X\(//\)[^/]' \| \
+	 X"$0" : 'X\(//\)$' \| \
+	 X"$0" : 'X\(/\)' \| \
+	 .     : '\(.\)' 2>/dev/null ||
 echo X"$0" |
     sed '/^X\(.*[^/]\)\/\/*[^/][^/]*\/*$/{ s//\1/; q; }
   	  /^X\(\/\/\)[^/].*/{ s//\1/; q; }
@@ -935,10 +931,22 @@
 ac_env_CXXFLAGS_value=$CXXFLAGS
 ac_cv_env_CXXFLAGS_set=${CXXFLAGS+set}
 ac_cv_env_CXXFLAGS_value=$CXXFLAGS
+ac_env_CPP_set=${CPP+set}
+ac_env_CPP_value=$CPP
+ac_cv_env_CPP_set=${CPP+set}
+ac_cv_env_CPP_value=$CPP
 ac_env_CXXCPP_set=${CXXCPP+set}
 ac_env_CXXCPP_value=$CXXCPP
 ac_cv_env_CXXCPP_set=${CXXCPP+set}
 ac_cv_env_CXXCPP_value=$CXXCPP
+ac_env_F77_set=${F77+set}
+ac_env_F77_value=$F77
+ac_cv_env_F77_set=${F77+set}
+ac_cv_env_F77_value=$F77
+ac_env_FFLAGS_set=${FFLAGS+set}
+ac_env_FFLAGS_value=$FFLAGS
+ac_cv_env_FFLAGS_set=${FFLAGS+set}
+ac_cv_env_FFLAGS_value=$FFLAGS
 # Report the --help message.
@@ -947,7 +955,7 @@
   # Omit some internal or obsolete options to make the list less imposing.
   # This message is too long to be a string in the A/UX 3.1 sh.
   cat <<_ACEOF
-\`configure' configures FDORDBMS 3.2.0 to adapt to many kinds of systems.
+\`configure' configures FDORDBMS 3.3.0 to adapt to many kinds of systems.
 Usage: $0 [OPTION]... [VAR=VALUE]...
@@ -972,9 +980,9 @@
   cat <<_ACEOF
 Installation directories:
   --prefix=PREFIX         install architecture-independent files in PREFIX
-                          [$ac_default_prefix]
+			  [$ac_default_prefix]
   --exec-prefix=EPREFIX   install architecture-dependent files in EPREFIX
-                          [PREFIX]
+			  [PREFIX]
 By default, \`make install' will install all the files in
 \`$ac_default_prefix/bin', \`$ac_default_prefix/lib' etc.  You can specify
@@ -1013,18 +1021,21 @@
 if test -n "$ac_init_help"; then
   case $ac_init_help in
-     short | recursive ) echo "Configuration of FDORDBMS 3.2.0:";;
+     short | recursive ) echo "Configuration of FDORDBMS 3.3.0:";;
    esac
   cat <<\_ACEOF
 Optional Features:
   --disable-FEATURE       do not include FEATURE (same as --enable-FEATURE=no)
   --enable-FEATURE[=ARG]  include FEATURE [ARG=yes]
-  --disable-dependency-tracking Speeds up one-time builds
-  --enable-dependency-tracking  Do not reject slow dependency extractors
-  --enable-static=PKGS  build static libraries default=no
-  --enable-shared=PKGS  build shared libraries default=yes
-  --enable-fast-install=PKGS  optimize for fast installation default=yes
+  --disable-dependency-tracking  speeds up one-time build
+  --enable-dependency-tracking   do not reject slow dependency extractors
+  --enable-static[=PKGS]
+                          build static libraries [default=no]
+  --enable-shared[=PKGS]
+                          build shared libraries [default=yes]
+  --enable-fast-install[=PKGS]
+                          optimize for fast installation [default=yes]
   --disable-libtool-lock  avoid locking (might break parallel builds)
 MAP_HELP_STRING(--enable-debug,
               	             enable debug build [default=no])
@@ -1032,8 +1043,11 @@
 Optional Packages:
   --with-PACKAGE[=ARG]    use PACKAGE [ARG=yes]
   --without-PACKAGE       do not use PACKAGE (same as --with-PACKAGE=no)
-  --with-gnu-ld           assume the C compiler uses GNU ld default=no
-  --with-pic              try to use only PIC/non-PIC objects default=use both
+  --with-gnu-ld           assume the C compiler uses GNU ld [default=no]
+  --with-pic              try to use only PIC/non-PIC objects [default=use
+                          both]
+  --with-tags[=TAGS]
+                          include additional configurations [automatic]
   --with-fdo              specifies directory for FDO API files
                           default=DEFAULT
   --with-fdo-utilities    specifies directory for FDO API Utility files
@@ -1054,7 +1068,10 @@
               headers in a nonstandard directory <include dir>
   CXX         C++ compiler command
   CXXFLAGS    C++ compiler flags
+  CPP         C preprocessor
   CXXCPP      C++ preprocessor
+  F77         Fortran 77 compiler command
+  FFLAGS      Fortran 77 compiler flags
 Use these variables to override the choices made by `configure' or to help
 it to find libraries and programs with nonstandard names/locations.
@@ -1093,13 +1110,46 @@
     ac_srcdir=$ac_top_builddir$srcdir$ac_dir_suffix
     ac_top_srcdir=$ac_top_builddir$srcdir ;;
 esac
-# Don't blindly perform a `cd "$ac_dir"/$ac_foo && pwd` since $ac_foo can be
-# absolute.
-ac_abs_builddir=`cd "$ac_dir" && cd $ac_builddir && pwd`
-ac_abs_top_builddir=`cd "$ac_dir" && cd ${ac_top_builddir}. && pwd`
-ac_abs_srcdir=`cd "$ac_dir" && cd $ac_srcdir && pwd`
-ac_abs_top_srcdir=`cd "$ac_dir" && cd $ac_top_srcdir && pwd`
+# Do not use `cd foo && pwd` to compute absolute paths, because
+# the directories may not exist.
+case `pwd` in
+.) ac_abs_builddir="$ac_dir";;
+  case "$ac_dir" in
+  .) ac_abs_builddir=`pwd`;;
+  [\\/]* | ?:[\\/]* ) ac_abs_builddir="$ac_dir";;
+  *) ac_abs_builddir=`pwd`/"$ac_dir";;
+  esac;;
+esac
+case $ac_abs_builddir in
+.) ac_abs_top_builddir=${ac_top_builddir}.;;
+  case ${ac_top_builddir}. in
+  .) ac_abs_top_builddir=$ac_abs_builddir;;
+  [\\/]* | ?:[\\/]* ) ac_abs_top_builddir=${ac_top_builddir}.;;
+  *) ac_abs_top_builddir=$ac_abs_builddir/${ac_top_builddir}.;;
+  esac;;
+esac
+.) ac_abs_srcdir=$ac_srcdir;;
+  case $ac_srcdir in
+  .) ac_abs_srcdir=$ac_abs_builddir;;
+  [\\/]* | ?:[\\/]* ) ac_abs_srcdir=$ac_srcdir;;
+  *) ac_abs_srcdir=$ac_abs_builddir/$ac_srcdir;;
+  esac;;
+esac
+.) ac_abs_top_srcdir=$ac_top_srcdir;;
+  case $ac_top_srcdir in
+  .) ac_abs_top_srcdir=$ac_abs_builddir;;
+  [\\/]* | ?:[\\/]* ) ac_abs_top_srcdir=$ac_top_srcdir;;
+  *) ac_abs_top_srcdir=$ac_abs_builddir/$ac_top_srcdir;;
+  esac;;
+esac
     cd $ac_dir
     # Check for guested configure; otherwise get Cygnus style configure.
     if test -f $ac_srcdir/configure.gnu; then
@@ -1109,7 +1159,7 @@
       echo
       $SHELL $ac_srcdir/configure  --help=recursive
     elif test -f $ac_srcdir/configure.ac ||
-           test -f $ac_srcdir/configure.in; then
+	   test -f $ac_srcdir/configure.in; then
       echo
       $ac_configure --help
     else
@@ -1122,11 +1172,10 @@
 test -n "$ac_init_help" && exit 0
 if $ac_init_version; then
   cat <<\_ACEOF
-FDORDBMS configure 3.2.0
-generated by GNU Autoconf 2.57
+FDORDBMS configure 3.3.0
+generated by GNU Autoconf 2.59
-Copyright 1992, 1993, 1994, 1995, 1996, 1998, 1999, 2000, 2001, 2002
-Free Software Foundation, Inc.
+Copyright (C) 2003 Free Software Foundation, Inc.
 _ACEOF
@@ -1137,8 +1186,8 @@
 This file contains any messages produced by compilers while
 running configure, to aid debugging if configure makes a mistake.
-It was created by FDORDBMS $as_me 3.2.0, which was
-generated by GNU Autoconf 2.57.  Invocation command line was
+It was created by FDORDBMS $as_me 3.3.0, which was
+generated by GNU Autoconf 2.59.  Invocation command line was
   $ $0 $@
@@ -1215,19 +1264,19 @@
     2)
       ac_configure_args1="$ac_configure_args1 '$ac_arg'"
       if test $ac_must_keep_next = true; then
-        ac_must_keep_next=false # Got value, back to normal.
+	ac_must_keep_next=false # Got value, back to normal.
       else
-        case $ac_arg in
-          *=* | --config-cache | -C | -disable-* | --disable-* \
-          | -enable-* | --enable-* | -gas | --g* | -nfp | --nf* \
-          | -q | -quiet | --q* | -silent | --sil* | -v | -verb* \
-          | -with-* | --with-* | -without-* | --without-* | --x)
-            case "$ac_configure_args0 " in
-              "$ac_configure_args1"*" '$ac_arg' "* ) continue ;;
-            esac
-          -* ) ac_must_keep_next=true ;;
-        esac
+	case $ac_arg in
+	  *=* | --config-cache | -C | -disable-* | --disable-* \
+	  | -enable-* | --enable-* | -gas | --g* | -nfp | --nf* \
+	  | -q | -quiet | --q* | -silent | --sil* | -v | -verb* \
+	  | -with-* | --with-* | -without-* | --without-* | --x)
+	    case "$ac_configure_args0 " in
+	      "$ac_configure_args1"*" '$ac_arg' "* ) continue ;;
+	    esac
+	  -* ) ac_must_keep_next=true ;;
+	esac
       fi
       ac_configure_args="$ac_configure_args$ac_sep'$ac_arg'"
       # Get rid of the leading space.
@@ -1261,12 +1310,12 @@
     case `(ac_space='"'"' '"'"'; set | grep ac_space) 2>&1` in
     *ac_space=\ *)
       sed -n \
-        "s/'"'"'/'"'"'\\\\'"'"''"'"'/g;
-    	  s/^\\([_$as_cr_alnum]*_cv_[_$as_cr_alnum]*\\)=\\(.*\\)/\\1='"'"'\\2'"'"'/p"
+	"s/'"'"'/'"'"'\\\\'"'"''"'"'/g;
+	  s/^\\([_$as_cr_alnum]*_cv_[_$as_cr_alnum]*\\)=\\(.*\\)/\\1='"'"'\\2'"'"'/p"
       sed -n \
-        "s/^\\([_$as_cr_alnum]*_cv_[_$as_cr_alnum]*\\)=\\(.*\\)/\\1=\\2/p"
+	"s/^\\([_$as_cr_alnum]*_cv_[_$as_cr_alnum]*\\)=\\(.*\\)/\\1=\\2/p"
     esac;
@@ -1295,7 +1344,7 @@
       for ac_var in $ac_subst_files
       do
-        echo "$ac_var='"'"'$ac_val'"'"'"
+	echo "$ac_var='"'"'$ac_val'"'"'"
       done | sort
       echo
     fi
@@ -1314,7 +1363,7 @@
       echo "$as_me: caught signal $ac_signal"
     echo "$as_me: exit $exit_status"
   } >&5
-  rm -f core core.* *.core &&
+  rm -f core *.core &&
   rm -rf conftest* confdefs* conf$$* $ac_clean_files &&
     exit $exit_status
      ' 0
@@ -1394,7 +1443,7 @@
 # value.
 ac_cache_corrupted=false
 for ac_var in `(set) 2>&1 |
-               sed -n 's/^ac_env_\([a-zA-Z_0-9]*\)_set=.*/\1/p'`; do
+	       sed -n 's/^ac_env_\([a-zA-Z_0-9]*\)_set=.*/\1/p'`; do
   eval ac_old_set=\$ac_cv_env_${ac_var}_set
   eval ac_new_set=\$ac_env_${ac_var}_set
   eval ac_old_val="\$ac_cv_env_${ac_var}_value"
@@ -1411,13 +1460,13 @@
       if test "x$ac_old_val" != "x$ac_new_val"; then
-        { echo "$as_me:$LINENO: error: \`$ac_var' has changed since the previous run:" >&5
+	{ echo "$as_me:$LINENO: error: \`$ac_var' has changed since the previous run:" >&5
 echo "$as_me: error: \`$ac_var' has changed since the previous run:" >&2;}
-        { echo "$as_me:$LINENO:   former value:  $ac_old_val" >&5
+	{ echo "$as_me:$LINENO:   former value:  $ac_old_val" >&5
 echo "$as_me:   former value:  $ac_old_val" >&2;}
-        { echo "$as_me:$LINENO:   current value: $ac_new_val" >&5
+	{ echo "$as_me:$LINENO:   current value: $ac_new_val" >&5
 echo "$as_me:   current value: $ac_new_val" >&2;}
-        ac_cache_corrupted=:
+	ac_cache_corrupted=:
       fi;;
   esac
   # Pass precious variables to config.status.
@@ -1474,7 +1523,7 @@
-am__api_version="1.6"
+am__api_version="1.9"
 ac_aux_dir=
 for ac_dir in $srcdir $srcdir/.. $srcdir/../..; do
   if test -f $ac_dir/install-sh; then
@@ -1511,6 +1560,7 @@
 # AIX 4 /usr/bin/installbsd, which doesn't work without a -g flag
 # AFS /usr/afsws/bin/install, which mishandles nonexistent args
 # SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
+# OS/2's system install, which has a completely different semantic
 # ./install, which can be erroneously created by make from ./install.sh.
 echo "$as_me:$LINENO: checking for a BSD-compatible install" >&5
 echo $ECHO_N "checking for a BSD-compatible install... $ECHO_C" >&6
@@ -1527,6 +1577,7 @@
 case $as_dir/ in
   ./ | .// | /cC/* | \
   /etc/* | /usr/sbin/* | /usr/etc/* | /sbin/* | /usr/afsws/bin/* | \
+  ?:\\/os2\\/install\\/* | ?:\\/OS2\\/INSTALL\\/* | \
   /usr/ucb/* ) ;;
     # OSF1 and SCO ODT 3.0 have their own names for install.
@@ -1534,20 +1585,20 @@
     # by default.
     for ac_prog in ginstall scoinst install; do
       for ac_exec_ext in '' $ac_executable_extensions; do
-        if $as_executable_p "$as_dir/$ac_prog$ac_exec_ext"; then
-          if test $ac_prog = install &&
-            grep dspmsg "$as_dir/$ac_prog$ac_exec_ext" >/dev/null 2>&1; then
-            # AIX install.  It has an incompatible calling convention.
-          elif test $ac_prog = install &&
-            grep pwplus "$as_dir/$ac_prog$ac_exec_ext" >/dev/null 2>&1; then
-            # program-specific install script used by HP pwplus--don't use.
-          else
-            ac_cv_path_install="$as_dir/$ac_prog$ac_exec_ext -c"
-            break 3
-          fi
-        fi
+	if $as_executable_p "$as_dir/$ac_prog$ac_exec_ext"; then
+	  if test $ac_prog = install &&
+	    grep dspmsg "$as_dir/$ac_prog$ac_exec_ext" >/dev/null 2>&1; then
+	    # AIX install.  It has an incompatible calling convention.
+	  elif test $ac_prog = install &&
+	    grep pwplus "$as_dir/$ac_prog$ac_exec_ext" >/dev/null 2>&1; then
+	    # program-specific install script used by HP pwplus--don't use.
+	  else
+	    ac_cv_path_install="$as_dir/$ac_prog$ac_exec_ext -c"
+	    break 3
+	  fi
+	fi
       done
     done
@@ -1635,7 +1686,6 @@
 program_transform_name=`echo $program_transform_name | sed -f conftest.sed`
 rm conftest.sed
 # expand $ac_aux_dir to an absolute path
 am_aux_dir=`cd $ac_aux_dir && pwd`
@@ -1649,6 +1699,39 @@
 echo "$as_me: WARNING: \`missing' script is too old or missing" >&2;}
 fi
+if mkdir -p --version . >/dev/null 2>&1 && test ! -d ./--version; then
+  # We used to keeping the `.' as first argument, in order to
+  # allow $(mkdir_p) to be used without argument.  As in
+  #   $(mkdir_p) $(somedir)
+  # where $(somedir) is conditionally defined.  However this is wrong
+  # for two reasons:
+  #  1. if the package is installed by a user who cannot write `.'
+  #     make install will fail,
+  #  2. the above comment should most certainly read
+  #     $(mkdir_p) $(DESTDIR)$(somedir)
+  #     so it does not work when $(somedir) is undefined and
+  #     $(DESTDIR) is not.
+  #  To support the latter case, we have to write
+  #     test -z "$(somedir)" || $(mkdir_p) $(DESTDIR)$(somedir),
+  #  so the `.' trick is pointless.
+  mkdir_p='mkdir -p --'
+else
+  # On NextStep and OpenStep, the `mkdir' command does not
+  # recognize any option.  It will interpret all options as
+  # directories to create, and then abort because `.' already
+  # exists.
+  for d in ./-p ./--version;
+  do
+    test -d $d && rmdir $d
+  done
+  # $(mkinstalldirs) is defined by Automake if mkinstalldirs exists.
+  if test -f "$ac_aux_dir/mkinstalldirs"; then
+    mkdir_p='$(mkinstalldirs)'
+  else
+    mkdir_p='$(install_sh) -d'
+  fi
+fi
 for ac_prog in gawk mawk nawk awk
 do
   # Extract the first word of "$ac_prog", so it can be a program name with args.
@@ -1691,7 +1774,7 @@
 echo "$as_me:$LINENO: checking whether ${MAKE-make} sets \$(MAKE)" >&5
 echo $ECHO_N "checking whether ${MAKE-make} sets \$(MAKE)... $ECHO_C" >&6
-set dummy ${MAKE-make}; ac_make=`echo "$2" | sed 'y,./+-,__p_,'`
+set dummy ${MAKE-make}; ac_make=`echo "$2" | sed 'y,:./+-,___p_,'`
 if eval "test \"\${ac_cv_prog_make_${ac_make}_set+set}\" = set"; then
   echo $ECHO_N "(cached) $ECHO_C" >&6
 else
@@ -1718,7 +1801,16 @@
   SET_MAKE="MAKE=${MAKE-make}"
 fi
- # test to see if srcdir already configured
+rm -rf .tst 2>/dev/null
+mkdir .tst 2>/dev/null
+if test -d .tst; then
+  am__leading_dot=.
+else
+  am__leading_dot=_
+fi
+rmdir .tst 2>/dev/null
+# test to see if srcdir already configured
 if test "`cd $srcdir && pwd`" != "`pwd`" &&
    test -f $srcdir/config.status; then
   { { echo "$as_me:$LINENO: error: source directory already configured; run \"make distclean\" there first" >&5
@@ -1726,9 +1818,19 @@
    { (exit 1); exit 1; }; }
 fi
+# test whether we have cygpath
+if test -z "$CYGPATH_W"; then
+  if (cygpath --version) >/dev/null 2>/dev/null; then
+    CYGPATH_W='cygpath -w'
+  else
+    CYGPATH_W=echo
+  fi
+fi
 # Define the identity of the package.
- PACKAGE=fdordbms
- VERSION=3.2.0
+ PACKAGE='fdordbms'
+ VERSION='3.3.0'
 cat >>confdefs.h <<_ACEOF
@@ -1756,9 +1858,6 @@
 MAKEINFO=${MAKEINFO-"${am_missing_run}makeinfo"}
-AMTAR=${AMTAR-"${am_missing_run}tar"}
 install_sh=${install_sh-"$am_aux_dir/install-sh"}
 # Installed binaries are usually stripped using `strip' when the user
@@ -1851,12 +1950,19 @@
 # We need awk for the "check" target.  The system "awk" is bad on
 # some platforms.
+# Always define AMTAR for backward compatibility.
+AMTAR=${AMTAR-"${am_missing_run}tar"}
+am__tar='${AMTAR} chof - "$$tardir"'; am__untar='${AMTAR} xf -'
 ac_ext=c
 ac_cpp='$CPP $CPPFLAGS'
 ac_compile='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5'
@@ -2199,7 +2305,6 @@
   (exit $ac_status); }
 cat >conftest.$ac_ext <<_ACEOF
-#line $LINENO "configure"
 /* confdefs.h.  */
 _ACEOF
 cat confdefs.h >>conftest.$ac_ext
@@ -2219,8 +2324,8 @@
 # Try to create an executable without -o first, disregard a.out.
 # It will help us diagnose broken compilers, and finding out an intuition
 # of exeext.
-echo "$as_me:$LINENO: checking for C compiler default output" >&5
-echo $ECHO_N "checking for C compiler default output... $ECHO_C" >&6
+echo "$as_me:$LINENO: checking for C compiler default output file name" >&5
+echo $ECHO_N "checking for C compiler default output file name... $ECHO_C" >&6
 ac_link_default=`echo "$ac_link" | sed 's/ -o *conftest[^ ]*//'`
 if { (eval echo "$as_me:$LINENO: \"$ac_link_default\"") >&5
   (eval $ac_link_default) 2>&5
@@ -2240,23 +2345,23 @@
   test -f "$ac_file" || continue
   case $ac_file in
     *.$ac_ext | *.xcoff | *.tds | *.d | *.pdb | *.xSYM | *.bb | *.bbg | *.o | *.obj )
     conftest.$ac_ext )
-        # This is the source file.
+	# This is the source file.
     [ab].out )
-        # We found the default executable, but exeext='' is most
-        # certainly right.
-        break;;
+	# We found the default executable, but exeext='' is most
+	# certainly right.
+	break;;
-        ac_cv_exeext=`expr "$ac_file" : '[^.]*\(\..*\)'`
-        # FIXME: I believe we export ac_cv_exeext for Libtool,
-        # but it would be cool to find out if it's true.  Does anybody
-        # maintain Libtool? --akim.
-        export ac_cv_exeext
-        break;;
+	ac_cv_exeext=`expr "$ac_file" : '[^.]*\(\..*\)'`
+	# FIXME: I believe we export ac_cv_exeext for Libtool,
+	# but it would be cool to find out if it's true.  Does anybody
+	# maintain Libtool? --akim.
+	export ac_cv_exeext
+	break;;
-        break;;
+	break;;
   esac
 done
 else
@@ -2330,8 +2435,8 @@
   case $ac_file in
     *.$ac_ext | *.xcoff | *.tds | *.d | *.pdb | *.xSYM | *.bb | *.bbg | *.o | *.obj ) ;;
     *.* ) ac_cv_exeext=`expr "$ac_file" : '[^.]*\(\..*\)'`
-          break;;
+	  break;;
     * ) break;;
   esac
 done
@@ -2356,7 +2461,6 @@
 else
 /* confdefs.h.  */
 _ACEOF
@@ -2407,7 +2511,6 @@
 else
 /* confdefs.h.  */
 _ACEOF
@@ -2427,15 +2530,25 @@
 _ACEOF
 rm -f conftest.$ac_objext
 if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
-  (eval $ac_compile) 2>&5
+  (eval $ac_compile) 2>conftest.er1
   ac_status=$?
+  grep -v '^ *+' conftest.er1 >conftest.err
+  rm -f conftest.er1
+  cat conftest.err >&5
   echo "$as_me:$LINENO: \$? = $ac_status" >&5
   (exit $ac_status); } &&
-         { ac_try='test -s conftest.$ac_objext'
+	 { ac_try='test -z "$ac_c_werror_flag"
+			 || test ! -s conftest.err'
   { (eval echo "$as_me:$LINENO: \"$ac_try\"") >&5
   (eval $ac_try) 2>&5
   ac_status=$?
+  (exit $ac_status); }; } &&
+	 { ac_try='test -s conftest.$ac_objext'
+  { (eval echo "$as_me:$LINENO: \"$ac_try\"") >&5
+  (eval $ac_try) 2>&5
+  ac_status=$?
+  echo "$as_me:$LINENO: \$? = $ac_status" >&5
   (exit $ac_status); }; }; then
   ac_compiler_gnu=yes
 else
@@ -2444,7 +2557,7 @@
 ac_compiler_gnu=no
 fi
-rm -f conftest.$ac_objext conftest.$ac_ext
+rm -f conftest.err conftest.$ac_objext conftest.$ac_ext
 ac_cv_c_compiler_gnu=$ac_compiler_gnu
 fi
@@ -2460,7 +2573,6 @@
 else
 /* confdefs.h.  */
 _ACEOF
@@ -2477,15 +2589,25 @@
 _ACEOF
   ac_status=$?
   (eval $ac_try) 2>&5
   ac_status=$?
+  ac_status=$?
   ac_cv_prog_cc_g=yes
 else
@@ -2494,7 +2616,7 @@
 ac_cv_prog_cc_g=no
 fi
 fi
 echo "$as_me:$LINENO: result: $ac_cv_prog_cc_g" >&5
 echo "${ECHO_T}$ac_cv_prog_cc_g" >&6
@@ -2521,7 +2643,6 @@
   ac_cv_prog_cc_stdc=no
 ac_save_CC=$CC
 /* confdefs.h.  */
 _ACEOF
@@ -2549,6 +2670,16 @@
   va_end (v);
   return s;
+/* OSF 4.0 Compaq cc is some sort of almost-ANSI by default.  It has
+   function prototypes and stuff, but not '\xHH' hex character constants.
+   These don't provoke an error unfortunately, instead are silently treated
+   as 'x'.  The following induces an error, until -std1 is added to get
+   proper ANSI mode.  Curiously '\x00'!='x' always comes out true, for an
+   array size at least.  It's necessary to write '\x00'==0 to get something
+   that's true only with -std1.  */
+int osf4_cc_array ['\x00' == 0 ? 1 : -1];
 int test (int i, double x);
 struct s1 {int (*f) (int a);};
 struct s2 {int (*f) (double a);};
@@ -2575,15 +2706,25 @@
   CC="$ac_save_CC $ac_arg"
   ac_status=$?
   (eval $ac_try) 2>&5
   ac_status=$?
+  ac_status=$?
   ac_cv_prog_cc_stdc=$ac_arg
 break
@@ -2592,7 +2733,7 @@
 sed 's/^/| /' conftest.$ac_ext >&5
 fi
 done
 rm -f conftest.$ac_ext conftest.$ac_objext
 CC=$ac_save_CC
@@ -2620,19 +2761,28 @@
 _ACEOF
   ac_status=$?
   (eval $ac_try) 2>&5
   ac_status=$?
+  ac_status=$?
   for ac_declaration in \
-   '#include <stdlib.h>' \
    'extern "C" void std::exit (int) throw (); using std::exit;' \
    'extern "C" void std::exit (int); using std::exit;' \
    'extern "C" void exit (int) throw ();' \
@@ -2640,14 +2790,13 @@
    'void exit (int);'
 do
 /* confdefs.h.  */
 _ACEOF
 cat >>conftest.$ac_ext <<_ACEOF
 /* end confdefs.h.  */
+$ac_declaration
 #include <stdlib.h>
-$ac_declaration
 int
 main ()
@@ -2658,15 +2807,25 @@
 _ACEOF
   ac_status=$?
   (eval $ac_try) 2>&5
   ac_status=$?
+  ac_status=$?
 else
@@ -2675,9 +2834,8 @@
 continue
 fi
 /* confdefs.h.  */
 _ACEOF
@@ -2694,15 +2852,25 @@
 _ACEOF
   ac_status=$?
   (eval $ac_try) 2>&5
   ac_status=$?
+  ac_status=$?
   break
 else
@@ -2710,7 +2878,7 @@
 fi
 done
 rm -f conftest*
 if test -n "$ac_declaration"; then
@@ -2724,30 +2892,22 @@
 fi
 ac_ext=c
 ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
 ac_compiler_gnu=$ac_cv_c_compiler_gnu
-rm -f .deps 2>/dev/null
-mkdir .deps 2>/dev/null
-if test -d .deps; then
-  DEPDIR=.deps
-else
-  # MS-DOS does not allow filenames that begin with a dot.
-  DEPDIR=_deps
-fi
-rmdir .deps 2>/dev/null
+DEPDIR="${am__leading_dot}deps"
           ac_config_commands="$ac_config_commands depfiles"
 am_make=${MAKE-make}
 cat > confinc << 'END'
-doit:
+am__doit:
 	@echo done
+.PHONY: am__doit
 END
 # If we don't find an include directive, just comment out the code.
 echo "$as_me:$LINENO: checking for style of include used by $am_make" >&5
@@ -2762,7 +2922,7 @@
 # In particular we don't look at `^make:' because GNU make might
 # be invoked under some other name (usually "gmake"), in which
 # case it prints its new name instead of `make'.
-if test "`$am_make -s -f confmf 2> /dev/null | fgrep -v 'ing directory'`" = "done"; then
+if test "`$am_make -s -f confmf 2> /dev/null | grep -v 'ing directory'`" = "done"; then
    am__include=include
    am__quote=
    _am_result=GNU
@@ -2822,18 +2982,34 @@
   # using a relative directory.
   cp "$am_depcomp" conftest.dir
   cd conftest.dir
+  # We will build objects and dependencies in a subdirectory because
+  # it helps to detect inapplicable dependency modes.  For instance
+  # both Tru64's cc and ICC support -MD to output dependencies as a
+  # side effect of compilation, but ICC will put the dependencies in
+  # the current directory while Tru64 will put them in the object
+  # directory.
+  mkdir sub
   am_cv_CC_dependencies_compiler_type=none
   if test "$am_compiler_list" = ""; then
      am_compiler_list=`sed -n 's/^#*\([a-zA-Z0-9]*\))$/\1/p' < ./depcomp`
   fi
   for depmode in $am_compiler_list; do
+    # Setup a source with many dependencies, because some compilers
+    # like to wrap large dependency lists on column 80 (with \), and
+    # we should not choose a depcomp mode which is confused by this.
     # We need to recreate these files for each test, as the compiler may
     # overwrite some of them when testing with obscure command lines.
     # This happens at least with the AIX C compiler.
-    echo '#include "conftest.h"' > conftest.c
-    echo 'int i;' > conftest.h
-    echo "${am__include} ${am__quote}conftest.Po${am__quote}" > confmf
+    : > sub/conftest.c
+    for i in 1 2 3 4 5 6; do
+      echo '#include "conftst'$i'.h"' >> sub/conftest.c
+      # Using `: > sub/conftst$i.h' creates only sub/conftst1.h with
+      # Solaris 8's {/usr,}/bin/sh.
+      touch sub/conftst$i.h
+    done
+    echo "${am__include} ${am__quote}sub/conftest.Po${am__quote}" > confmf
     case $depmode in
     nosideeffect)
@@ -2851,13 +3027,25 @@
     # mode.  It turns out that the SunPro C++ compiler does not properly
     # handle `-M -o', and we need to detect this.
     if depmode=$depmode \
-       source=conftest.c object=conftest.o \
-       depfile=conftest.Po tmpdepfile=conftest.TPo \
-       $SHELL ./depcomp $depcc -c conftest.c -o conftest.o >/dev/null 2>&1 &&
-       grep conftest.h conftest.Po > /dev/null 2>&1 &&
+       source=sub/conftest.c object=sub/conftest.${OBJEXT-o} \
+       depfile=sub/conftest.Po tmpdepfile=sub/conftest.TPo \
+       $SHELL ./depcomp $depcc -c -o sub/conftest.${OBJEXT-o} sub/conftest.c \
+         >/dev/null 2>conftest.err &&
+       grep sub/conftst6.h sub/conftest.Po > /dev/null 2>&1 &&
+       grep sub/conftest.${OBJEXT-o} sub/conftest.Po > /dev/null 2>&1 &&
        ${MAKE-make} -s -f confmf > /dev/null 2>&1; then
-      am_cv_CC_dependencies_compiler_type=$depmode
-      break
+      # icc doesn't choke on unknown options, it will just issue warnings
+      # or remarks (even with -Werror).  So we grep stderr for any message
+      # that says an option was ignored or not supported.
+      # When given -MP, icc 7.0 and 7.1 complain thusly:
+      #   icc: Command line warning: ignoring option '-M'; no argument required
+      # The diagnosis changed in icc 8.0:
+      #   icc: Command line remark: option '-MP' not supported
+      if (grep 'ignoring option' conftest.err ||
+          grep 'not supported' conftest.err) >/dev/null 2>&1; then :; else
+        am_cv_CC_dependencies_compiler_type=$depmode
+        break
+      fi
     fi
   done
@@ -2873,6 +3061,18 @@
 CCDEPMODE=depmode=$am_cv_CC_dependencies_compiler_type
+if
+  test "x$enable_dependency_tracking" != xno \
+  && test "$am_cv_CC_dependencies_compiler_type" = gcc3; then
+  am__fastdepCC_TRUE=
+  am__fastdepCC_FALSE='#'
+else
+  am__fastdepCC_TRUE='#'
+fi
 ac_ext=cc
 ac_cpp='$CXXCPP $CPPFLAGS'
 ac_compile='$CXX -c $CXXFLAGS $CPPFLAGS conftest.$ac_ext >&5'
@@ -2998,7 +3198,6 @@
 else
 /* confdefs.h.  */
 _ACEOF
@@ -3018,15 +3217,25 @@
 _ACEOF
   ac_status=$?
+	 { ac_try='test -z "$ac_cxx_werror_flag"
   (eval $ac_try) 2>&5
   ac_status=$?
+  ac_status=$?
   ac_compiler_gnu=yes
 else
@@ -3035,7 +3244,7 @@
 ac_compiler_gnu=no
 fi
 ac_cv_cxx_compiler_gnu=$ac_compiler_gnu
 fi
@@ -3051,7 +3260,6 @@
 else
 /* confdefs.h.  */
 _ACEOF
@@ -3068,15 +3276,25 @@
 _ACEOF
   ac_status=$?
   (eval $ac_try) 2>&5
   ac_status=$?
+  ac_status=$?
   ac_cv_prog_cxx_g=yes
 else
@@ -3085,7 +3303,7 @@
 ac_cv_prog_cxx_g=no
 fi
 fi
 echo "$as_me:$LINENO: result: $ac_cv_prog_cxx_g" >&5
 echo "${ECHO_T}$ac_cv_prog_cxx_g" >&6
@@ -3105,8 +3323,7 @@
   fi
 fi
@@ -3114,14 +3331,13 @@
    'void exit (int);'
 do
 /* confdefs.h.  */
 _ACEOF
+$ac_declaration
 #include <stdlib.h>
-$ac_declaration
 int
 main ()
@@ -3132,15 +3348,25 @@
 _ACEOF
   ac_status=$?
   (eval $ac_try) 2>&5
   ac_status=$?
+  ac_status=$?
 else
@@ -3149,9 +3375,8 @@
 continue
 fi
 /* confdefs.h.  */
 _ACEOF
@@ -3168,15 +3393,25 @@
 _ACEOF
   ac_status=$?
   (eval $ac_try) 2>&5
   ac_status=$?
+  ac_status=$?
   break
 else
@@ -3184,7 +3419,7 @@
 fi
 done
 rm -f conftest*
@@ -3217,18 +3452,34 @@
   cd conftest.dir
+  # directory.
+  mkdir sub
   am_cv_CXX_dependencies_compiler_type=none
   fi
+    done
     case $depmode in
     nosideeffect)
@@ -3246,13 +3497,25 @@
-      am_cv_CXX_dependencies_compiler_type=$depmode
-      break
+        am_cv_CXX_dependencies_compiler_type=$depmode
+        break
+      fi
     fi
   done
@@ -3268,6 +3531,18 @@
 CXXDEPMODE=depmode=$am_cv_CXX_dependencies_compiler_type
+if
+  && test "$am_cv_CXX_dependencies_compiler_type" = gcc3; then
+  am__fastdepCXX_TRUE=
+  am__fastdepCXX_FALSE='#'
+else
+  am__fastdepCXX_TRUE='#'
+fi
 for ac_prog in 'bison -y' byacc
 do
@@ -3313,68 +3588,75 @@
 if test "${enable_static+set}" = set; then
   enableval="$enable_static"
   p=${PACKAGE-default}
-case $enableval in
-yes) enable_static=yes ;;
-no) enable_static=no ;;
-  enable_static=no
-  # Look at the argument we got.  We use all the common list separators.
-  IFS="${IFS= 	}"; ac_save_ifs="$IFS"; IFS="${IFS}:,"
-  for pkg in $enableval; do
-    if test "X$pkg" = "X$p"; then
-      enable_static=yes
-    fi
-  done
-  IFS="$ac_save_ifs"
-esac
+    case $enableval in
+    yes) enable_static=yes ;;
+    no) enable_static=no ;;
+     enable_static=no
+      # Look at the argument we got.  We use all the common list separators.
+      lt_save_ifs="$IFS"; IFS="${IFS}$PATH_SEPARATOR,"
+      for pkg in $enableval; do
+	if test "X$pkg" = "X$p"; then
+	  enable_static=yes
+	fi
+      done
+    esac
 else
   enable_static=no
 fi;
 # Check whether --enable-shared or --disable-shared was given.
 if test "${enable_shared+set}" = set; then
   enableval="$enable_shared"
-case $enableval in
-yes) enable_shared=yes ;;
-no) enable_shared=no ;;
-  enable_shared=no
-      enable_shared=yes
-    fi
-  done
-esac
+    yes) enable_shared=yes ;;
+    no) enable_shared=no ;;
+      enable_shared=no
+	  enable_shared=yes
+	fi
+      done
+    esac
 else
   enable_shared=yes
 fi;
 # Check whether --enable-fast-install or --disable-fast-install was given.
 if test "${enable_fast_install+set}" = set; then
   enableval="$enable_fast_install"
-case $enableval in
-yes) enable_fast_install=yes ;;
-no) enable_fast_install=no ;;
-  enable_fast_install=no
-      enable_fast_install=yes
-    fi
-  done
-esac
+    yes) enable_fast_install=yes ;;
+    no) enable_fast_install=no ;;
+      enable_fast_install=no
+	  enable_fast_install=yes
+	fi
+      done
+    esac
 else
 fi;
 # Make sure we can run config.sub.
 $ac_config_sub sun4 >/dev/null 2>&1 ||
   { { echo "$as_me:$LINENO: error: cannot run $ac_config_sub" >&5
@@ -3429,18 +3711,79 @@
 host_os=`echo $ac_cv_host | sed 's/^\([^-]*\)-\([^-]*\)-\(.*\)$/\3/'`
-  case X$UNAME in
-  esac
+echo "$as_me:$LINENO: checking for a sed that does not truncate output" >&5
+echo $ECHO_N "checking for a sed that does not truncate output... $ECHO_C" >&6
+if test "${lt_cv_path_SED+set}" = set; then
+  echo $ECHO_N "(cached) $ECHO_C" >&6
+else
+  # Loop through the user's path and test for sed and gsed.
+# Then use that list of sed's as ones to test for truncation.
+as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
+for as_dir in $PATH
+do
+  IFS=$as_save_IFS
+  test -z "$as_dir" && as_dir=.
+  for lt_ac_prog in sed gsed; do
+    for ac_exec_ext in '' $ac_executable_extensions; do
+      if $as_executable_p "$as_dir/$lt_ac_prog$ac_exec_ext"; then
+        lt_ac_sed_list="$lt_ac_sed_list $as_dir/$lt_ac_prog$ac_exec_ext"
+      fi
+    done
+  done
+done
+lt_ac_max=0
+lt_ac_count=0
+# Add /usr/xpg4/bin/sed as it is typically found on Solaris
+# along with /bin/sed that truncates output.
+for lt_ac_sed in $lt_ac_sed_list /usr/xpg4/bin/sed; do
+  test ! -f $lt_ac_sed && continue
+  cat /dev/null > conftest.in
+  lt_ac_count=0
+  echo $ECHO_N "0123456789$ECHO_C" >conftest.in
+  # Check for GNU sed and select it if it is found.
+  if "$lt_ac_sed" --version 2>&1 < /dev/null | grep 'GNU' > /dev/null; then
+    lt_cv_path_SED=$lt_ac_sed
+    break
+  fi
+  while true; do
+    cat conftest.in conftest.in >conftest.tmp
+    mv conftest.tmp conftest.in
+    cp conftest.in conftest.nl
+    echo >>conftest.nl
+    $lt_ac_sed -e 's/a$//' < conftest.nl >conftest.out || break
+    cmp -s conftest.out conftest.nl || break
+    # 10000 chars as input seems more than enough
+    test $lt_ac_count -gt 10 && break
+    lt_ac_count=`expr $lt_ac_count + 1`
+    if test $lt_ac_count -gt $lt_ac_max; then
+      lt_ac_max=$lt_ac_count
+    fi
+  done
+done
 fi
+SED=$lt_cv_path_SED
+echo "$as_me:$LINENO: result: $SED" >&5
+echo "${ECHO_T}$SED" >&6
+echo "$as_me:$LINENO: checking for egrep" >&5
+echo $ECHO_N "checking for egrep... $ECHO_C" >&6
+if test "${ac_cv_prog_egrep+set}" = set; then
+else
+  if echo a | (grep -E '(a|b)') >/dev/null 2>&1
+    then ac_cv_prog_egrep='grep -E'
+    else ac_cv_prog_egrep='egrep'
+    fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_prog_egrep" >&5
+echo "${ECHO_T}$ac_cv_prog_egrep" >&6
+ EGREP=$ac_cv_prog_egrep
 # Check whether --with-gnu-ld or --without-gnu-ld was given.
 if test "${with_gnu_ld+set}" = set; then
   withval="$with_gnu_ld"
@@ -3451,8 +3794,8 @@
 ac_prog=ld
 if test "$GCC" = yes; then
   # Check if gcc -print-prog-name=ld gives a path.
-  echo "$as_me:$LINENO: checking for ld used by GCC" >&5
-echo $ECHO_N "checking for ld used by GCC... $ECHO_C" >&6
+  echo "$as_me:$LINENO: checking for ld used by $CC" >&5
+echo $ECHO_N "checking for ld used by $CC... $ECHO_C" >&6
   case $host in
   *-*-mingw*)
     # gcc leaves a trailing carriage return which upsets mingw
@@ -3462,12 +3805,12 @@
   esac
   case $ac_prog in
     # Accept absolute paths.
-    [\\/]* | [A-Za-z]:[\\/]*)
       re_direlt='/[^/][^/]*/\.\./'
-      # Canonicalize the path of ld
-      ac_prog=`echo $ac_prog| sed 's%\\\\%/%g'`
+      # Canonicalize the pathname of ld
+      ac_prog=`echo $ac_prog| $SED 's%\\\\%/%g'`
       while echo $ac_prog | grep "$re_direlt" > /dev/null 2>&1; do
-	ac_prog=`echo $ac_prog| sed "s%$re_direlt%/%"`
+	ac_prog=`echo $ac_prog| $SED "s%$re_direlt%/%"`
       done
       test -z "$LD" && LD="$ac_prog"
@@ -3491,22 +3834,26 @@
 else
   if test -z "$LD"; then
-  IFS="${IFS= 	}"; ac_save_ifs="$IFS"; IFS=$PATH_SEPARATOR
   for ac_dir in $PATH; do
     test -z "$ac_dir" && ac_dir=.
     if test -f "$ac_dir/$ac_prog" || test -f "$ac_dir/$ac_prog$ac_exeext"; then
       lt_cv_path_LD="$ac_dir/$ac_prog"
       # Check to see if the program is GNU ld.  I'd rather use --version,
-      # but apparently some GNU ld's only accept -v.
+      # but apparently some variants of GNU ld only accept -v.
       # Break only if it was the GNU/non-GNU ld that we prefer.
-      if "$lt_cv_path_LD" -v 2>&1 < /dev/null | egrep '(GNU|with BFD)' > /dev/null; then
+      case `"$lt_cv_path_LD" -v 2>&1 </dev/null` in
+      *GNU* | *'with BFD'*)
 	test "$with_gnu_ld" != no && break
-      else
 	test "$with_gnu_ld" != yes && break
-      fi
+      esac
     fi
   done
 else
   lt_cv_path_LD="$LD" # Let the user override the test with a path.
 fi
@@ -3528,13 +3875,16 @@
 if test "${lt_cv_prog_gnu_ld+set}" = set; then
 else
-  # I'd rather use --version here, but apparently some GNU ld's only accept -v.
-if $LD -v 2>&1 </dev/null | egrep '(GNU|with BFD)' 1>&5; then
+  # I'd rather use --version here, but apparently some GNU lds only accept -v.
+case `$LD -v 2>&1 </dev/null` in
+*GNU* | *'with BFD'*)
   lt_cv_prog_gnu_ld=yes
-else
   lt_cv_prog_gnu_ld=no
+esac
 fi
-fi
 echo "$as_me:$LINENO: result: $lt_cv_prog_gnu_ld" >&5
 echo "${ECHO_T}$lt_cv_prog_gnu_ld" >&6
 with_gnu_ld=$lt_cv_prog_gnu_ld
@@ -3550,7 +3900,20 @@
 echo "$as_me:$LINENO: result: $lt_cv_ld_reload_flag" >&5
 echo "${ECHO_T}$lt_cv_ld_reload_flag" >&6
 reload_flag=$lt_cv_ld_reload_flag
-test -n "$reload_flag" && reload_flag=" $reload_flag"
+case $reload_flag in
+*) reload_flag=" $reload_flag" ;;
+esac
+reload_cmds='$LD$reload_flag -o $output$reload_objs'
+case $host_os in
+  darwin*)
+    if test "$GCC" = yes; then
+      reload_cmds='$LTCC $LTCFLAGS -nostdlib ${wl}-r -o $output$reload_objs'
+    else
+      reload_cmds='$LD$reload_flag -o $output$reload_objs'
+    fi
+esac
 echo "$as_me:$LINENO: checking for BSD-compatible nm" >&5
 echo $ECHO_N "checking for BSD-compatible nm... $ECHO_C" >&6
@@ -3561,121 +3924,50 @@
   # Let the user override the test.
   lt_cv_path_NM="$NM"
 else
-  for ac_dir in $PATH /usr/ccs/bin /usr/ucb /bin; do
-    test -z "$ac_dir" && ac_dir=.
-    tmp_nm=$ac_dir/${ac_tool_prefix}nm
-    if test -f $tmp_nm || test -f $tmp_nm$ac_exeext ; then
-      # Check to see if the nm accepts a BSD-compat flag.
-      # Adding the `sed 1q' prevents false positives on HP-UX, which says:
-      #   nm: unknown option "B" ignored
-      # Tru64's nm complains that /dev/null is an invalid object file
-      if ($tmp_nm -B /dev/null 2>&1 | sed '1q'; exit 0) | egrep '(/dev/null|Invalid file or object type)' >/dev/null; then
-	lt_cv_path_NM="$tmp_nm -B"
-	break
-      elif ($tmp_nm -p /dev/null 2>&1 | sed '1q'; exit 0) | egrep /dev/null >/dev/null; then
-	lt_cv_path_NM="$tmp_nm -p"
-	break
-      else
-	lt_cv_path_NM=${lt_cv_path_NM="$tmp_nm"} # keep the first match, but
-	continue # so that we can try to find one that supports BSD flags
+  lt_nm_to_check="${ac_tool_prefix}nm"
+  if test -n "$ac_tool_prefix" && test "$build" = "$host"; then
+    lt_nm_to_check="$lt_nm_to_check nm"
+  fi
+  for lt_tmp_nm in $lt_nm_to_check; do
+    for ac_dir in $PATH /usr/ccs/bin/elf /usr/ccs/bin /usr/ucb /bin; do
+      test -z "$ac_dir" && ac_dir=.
+      tmp_nm="$ac_dir/$lt_tmp_nm"
+      if test -f "$tmp_nm" || test -f "$tmp_nm$ac_exeext" ; then
+	# Check to see if the nm accepts a BSD-compat flag.
+	# Adding the `sed 1q' prevents false positives on HP-UX, which says:
+	#   nm: unknown option "B" ignored
+	# Tru64's nm complains that /dev/null is an invalid object file
+	case `"$tmp_nm" -B /dev/null 2>&1 | sed '1q'` in
+	*/dev/null* | *'Invalid file or object type'*)
+	  lt_cv_path_NM="$tmp_nm -B"
+	  break
+	  case `"$tmp_nm" -p /dev/null 2>&1 | sed '1q'` in
+	  */dev/null*)
+	    lt_cv_path_NM="$tmp_nm -p"
+	    break
+	    lt_cv_path_NM=${lt_cv_path_NM="$tmp_nm"} # keep the first match, but
+	    continue # so that we can try to find one that supports BSD flags
+	  esac
+	esac
       fi
-    fi
+    done
   done
   test -z "$lt_cv_path_NM" && lt_cv_path_NM=nm
 fi
 fi
+echo "$as_me:$LINENO: result: $lt_cv_path_NM" >&5
+echo "${ECHO_T}$lt_cv_path_NM" >&6
 NM="$lt_cv_path_NM"
-echo "$as_me:$LINENO: result: $NM" >&5
-echo "${ECHO_T}$NM" >&6
-echo "$as_me:$LINENO: checking for a sed that does not truncate output" >&5
-echo $ECHO_N "checking for a sed that does not truncate output... $ECHO_C" >&6
-if test "${lt_cv_path_SED+set}" = set; then
-  echo $ECHO_N "(cached) $ECHO_C" >&6
-else
-  # Loop through the user's path and test for sed and gsed.
-# Then use that list of sed's as ones to test for truncation.
-as_executable_p="test -f"
-as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
-for as_dir in $PATH
-do
-  IFS=$as_save_IFS
-  test -z "$as_dir" && as_dir=.
-  for ac_prog in sed gsed; do
-    for ac_exec_ext in '' $ac_executable_extensions; do
-        _sed_list="$_sed_list $as_dir/$ac_prog$ac_exec_ext"
-      fi
-    done
-  done
-done
-  # Create a temporary directory, and hook for its removal unless debugging.
-$debug ||
-  trap 'exit_status=$?; rm -rf $tmp && exit $exit_status' 0
-  trap '{ (exit 1); exit 1; }' 1 2 13 15
-# Create a (secure) tmp directory for tmp files.
-: ${TMPDIR=/tmp}
-  tmp=`(umask 077 && mktemp -d -q "$TMPDIR/sedXXXXXX") 2>/dev/null` &&
-  test -n "$tmp" && test -d "$tmp"
-  tmp=$TMPDIR/sed$$-$RANDOM
-  (umask 077 && mkdir $tmp)
-   echo "$me: cannot create a temporary directory in $TMPDIR" >&2
-   { (exit 1); exit 1; }
-  _max=0
-  _count=0
-  # Add /usr/xpg4/bin/sed as it is typically found on Solaris
-  # along with /bin/sed that truncates output.
-  for _sed in $_sed_list /usr/xpg4/bin/sed; do
-    test ! -f ${_sed} && break
-    cat /dev/null > "$tmp/sed.in"
-    _count=0
-    echo ${ECHO_N-$ac_n} "0123456789${ECHO_C-$ac_c}" >"$tmp/sed.in"
-    # Check for GNU sed and select it if it is found.
-    if "${_sed}" --version 2>&1 < /dev/null | egrep '(GNU)' > /dev/null; then
-      lt_cv_path_SED=${_sed}
-      break
-    fi
-    while true; do
-      cat "$tmp/sed.in" "$tmp/sed.in" >"$tmp/sed.tmp"
-      mv "$tmp/sed.tmp" "$tmp/sed.in"
-      cp "$tmp/sed.in" "$tmp/sed.nl"
-      echo >>"$tmp/sed.nl"
-      ${_sed} -e 's/a$//' < "$tmp/sed.nl" >"$tmp/sed.out" || break
-      cmp -s "$tmp/sed.out" "$tmp/sed.nl" || break
-      # 40000 chars as input seems more than enough
-      test $_count -gt 10 && break
-      _count=`expr $_count + 1`
-      if test $_count -gt $_max; then
-        _max=$_count
-        lt_cv_path_SED=$_sed
-      fi
-    done
-  done
-  rm -rf "$tmp"
-fi
-if test "X$SED" != "X"; then
-  lt_cv_path_SED=$SED
-else
-  SED=$lt_cv_path_SED
-fi
-echo "$as_me:$LINENO: result: $SED" >&5
-echo "${ECHO_T}$SED" >&6
 echo "$as_me:$LINENO: checking whether ln -s works" >&5
 echo $ECHO_N "checking whether ln -s works... $ECHO_C" >&6
 LN_S=$as_ln_s
@@ -3702,7 +3994,7 @@
 # 'pass_all' -- all dependencies passed with no checks.
 # 'test_compile' -- check by making test program.
 # 'file_magic [[regex]]' -- check by looking for files in library path
-# which responds to the $file_magic_cmd with a given egrep regex.
+# which responds to the $file_magic_cmd with a given extended regex.
 # If you have `file' or equivalent on your system and you're not sure
 # whether `pass_all' will *always* work, you probably want this one.
@@ -3715,37 +4007,36 @@
   lt_cv_deplibs_check_method=pass_all
-bsdi4*)
+bsdi[45]*)
   lt_cv_deplibs_check_method='file_magic ELF [0-9][0-9]*-bit [ML]SB (shared object|dynamic lib)'
   lt_cv_file_magic_cmd='/usr/bin/file -L'
   lt_cv_file_magic_test_file=/shlib/libc.so
-cygwin* | mingw* | pw32*)
+cygwin*)
+  # func_win32_libid is a shell function defined in ltmain.sh
+  lt_cv_deplibs_check_method='file_magic ^x86 archive import|^x86 DLL'
+  lt_cv_file_magic_cmd='func_win32_libid'
+mingw* | pw32*)
+  # Base MSYS/MinGW do not provide the 'file' command needed by
+  # func_win32_libid shell function, so use a weaker test based on 'objdump'.
   lt_cv_deplibs_check_method='file_magic file format pei*-i386(.*architecture: i386)?'
   lt_cv_file_magic_cmd='$OBJDUMP -f'
 darwin* | rhapsody*)
-  lt_cv_deplibs_check_method='file_magic Mach-O dynamically linked shared library'
-  lt_cv_file_magic_cmd='/usr/bin/file -L'
-  case "$host_os" in
-  rhapsody* | darwin1.[012])
-    lt_cv_file_magic_test_file=`echo /System/Library/Frameworks/System.framework/Versions/*/System | head -1`
-  *) # Darwin 1.3 on
-    lt_cv_file_magic_test_file='/usr/lib/libSystem.dylib'
-  esac
+  lt_cv_deplibs_check_method=pass_all
-freebsd*)
+freebsd* | kfreebsd*-gnu | dragonfly*)
   if echo __ELF__ | $CC -E - | grep __ELF__ > /dev/null; then
     case $host_cpu in
     i*86 )
       # Not sure whether the presence of OpenBSD here was a mistake.
       # Let's accept both of them until this is cleared up.
-      lt_cv_deplibs_check_method='file_magic (FreeBSD|OpenBSD)/i[3-9]86 (compact )?demand paged shared library'
+      lt_cv_deplibs_check_method='file_magic (FreeBSD|OpenBSD|DragonFly)/i[3-9]86 (compact )?demand paged shared library'
       lt_cv_file_magic_cmd=/usr/bin/file
       lt_cv_file_magic_test_file=`echo /usr/lib/libc.so.*`
@@ -3759,50 +4050,49 @@
-hpux10.20*|hpux11*)
-  lt_cv_deplibs_check_method='file_magic (s[0-9][0-9][0-9]|PA-RISC[0-9].[0-9]) shared library'
+hpux10.20* | hpux11*)
-  lt_cv_file_magic_test_file=/usr/lib/libc.sl
-irix5* | irix6* | nonstopux*)
-  case $host_os in
-  irix5* | nonstopux*)
-    # this will be overridden with pass_all, but let us keep it just in case
-    lt_cv_deplibs_check_method="file_magic ELF 32-bit MSB dynamic lib MIPS - version 1"
+  case $host_cpu in
+  ia64*)
+    lt_cv_deplibs_check_method='file_magic (s[0-9][0-9][0-9]|ELF-[0-9][0-9]) shared object file - IA64'
+    lt_cv_file_magic_test_file=/usr/lib/hpux32/libc.so
+  hppa*64*)
+    lt_cv_deplibs_check_method='file_magic (s[0-9][0-9][0-9]|ELF-[0-9][0-9]) shared object file - PA-RISC [0-9].[0-9]'
+    lt_cv_file_magic_test_file=/usr/lib/pa20_64/libc.sl
-    case $LD in
-    *-32|*"-32 ") libmagic=32-bit;;
-    *-n32|*"-n32 ") libmagic=N32;;
-    *-64|*"-64 ") libmagic=64-bit;;
-    *) libmagic=never-match;;
-    esac
-    lt_cv_deplibs_check_method="file_magic ELF ${libmagic} MSB mips-[1234] dynamic lib MIPS - version 1"
+    lt_cv_deplibs_check_method='file_magic (s[0-9][0-9][0-9]|PA-RISC[0-9].[0-9]) shared library'
+    lt_cv_file_magic_test_file=/usr/lib/libc.sl
   esac
-  lt_cv_file_magic_test_file=`echo /lib${libsuff}/libc.so*`
+interix3*)
+  # PIC code is broken on Interix 3.x, that's why |\.a not |_pic\.a here
+  lt_cv_deplibs_check_method='match_pattern /lib[^/]+(\.so|\.a)$'
+irix5* | irix6* | nonstopux*)
+  case $LD in
+  *-32|*"-32 ") libmagic=32-bit;;
+  *-n32|*"-n32 ") libmagic=N32;;
+  *-64|*"-64 ") libmagic=64-bit;;
+  *) libmagic=never-match;;
+  esac
 # This must be Linux ELF.
-linux-gnu*)
-  case $host_cpu in
-  alpha* | hppa* | i*86 | mips | mipsel | powerpc* | sparc* | ia64* | s390* | x86_64*)
-    lt_cv_deplibs_check_method=pass_all ;;
-    # glibc up to 2.1.1 does not perform some relocations on ARM
-    lt_cv_deplibs_check_method='file_magic ELF [0-9][0-9]*-bit [LM]SB (shared object|dynamic lib )' ;;
-  esac
-  lt_cv_file_magic_test_file=`echo /lib/libc.so* /lib/libc-*.so`
+linux*)
 netbsd*)
-    lt_cv_deplibs_check_method='match_pattern /lib[^/\.]+\.so\.[0-9]+\.[0-9]+$'
+    lt_cv_deplibs_check_method='match_pattern /lib[^/]+(\.so\.[0-9]+\.[0-9]+|_pic\.a)$'
   else
-    lt_cv_deplibs_check_method='match_pattern /lib[^/\.]+\.so$'
+    lt_cv_deplibs_check_method='match_pattern /lib[^/]+(\.so|_pic\.a)$'
   fi
@@ -3812,37 +4102,27 @@
   lt_cv_file_magic_test_file=/usr/lib/libnls.so
+nto-qnx*)
+  lt_cv_deplibs_check_method=unknown
 openbsd*)
-  lt_cv_file_magic_cmd=/usr/bin/file
-  lt_cv_file_magic_test_file=`echo /usr/lib/libc.so.*`
   if test -z "`echo __ELF__ | $CC -E - | grep __ELF__`" || test "$host_os-$host_cpu" = "openbsd2.8-powerpc"; then
-    lt_cv_deplibs_check_method='file_magic ELF [0-9][0-9]*-bit [LM]SB shared object'
+    lt_cv_deplibs_check_method='match_pattern /lib[^/]+(\.so\.[0-9]+\.[0-9]+|\.so|_pic\.a)$'
   else
-    lt_cv_deplibs_check_method='file_magic OpenBSD.* shared library'
   fi
 osf3* | osf4* | osf5*)
-  lt_cv_deplibs_check_method='file_magic COFF format alpha shared library'
-  lt_cv_file_magic_test_file=/shlib/libc.so
-sco3.2v5*)
 solaris*)
-  lt_cv_file_magic_test_file=/lib/libc.so
-sysv5uw[78]* | sysv4*uw2*)
-sysv4 | sysv4.2uw2* | sysv4.3* | sysv5*)
+sysv4 | sysv4.3*)
   case $host_vendor in
   motorola)
     lt_cv_deplibs_check_method='file_magic ELF [0-9][0-9]*-bit [ML]SB (shared object|dynamic lib) M[0-9][0-9]* Version [0-9]'
@@ -3863,8 +4143,15 @@
   siemens)
+  pc)
   esac
+sysv5* | sco3.2v5* | sco5v6* | unixware* | OpenUNIX* | sysv4*uw2*)
 esac
 fi
@@ -3872,229 +4159,254 @@
 echo "${ECHO_T}$lt_cv_deplibs_check_method" >&6
 file_magic_cmd=$lt_cv_file_magic_cmd
 deplibs_check_method=$lt_cv_deplibs_check_method
+test -z "$deplibs_check_method" && deplibs_check_method=unknown
+# If no C compiler was specified, use CC.
+LTCC=${LTCC-"$CC"}
+# If no C compiler flags were specified, use CFLAGS.
+LTCFLAGS=${LTCFLAGS-"$CFLAGS"}
+# Allow CC to be a program name with arguments.
+compiler=$CC
-# Check for command to grab the raw symbol name followed by C symbol from nm.
-echo "$as_me:$LINENO: checking command to parse $NM output" >&5
-echo $ECHO_N "checking command to parse $NM output... $ECHO_C" >&6
-if test "${lt_cv_sys_global_symbol_pipe+set}" = set; then
-else
+# Check whether --enable-libtool-lock or --disable-libtool-lock was given.
+if test "${enable_libtool_lock+set}" = set; then
+  enableval="$enable_libtool_lock"
-# These are sane defaults that work on at least a few old systems.
-# [They come from Ultrix.  What could be older than Ultrix?!! ;)]
+fi;
+test "x$enable_libtool_lock" != xno && enable_libtool_lock=yes
-# Character class describing NM global symbol codes.
-symcode='[BCDEGRST]'
-# Regexp to match symbols that can be accessed directly from C.
-sympat='\([_A-Za-z][_A-Za-z0-9]*\)'
-# Transform the above into a raw symbol and a C symbol.
-symxfrm='\1 \2\3 \3'
-# Transform an extracted symbol line into a proper C declaration
-lt_cv_global_symbol_to_cdecl="sed -n -e 's/^. .* \(.*\)$/extern char \1;/p'"
-# Transform an extracted symbol line into symbol name and symbol address
-lt_cv_global_symbol_to_c_name_address="sed -n -e 's/^: \([^ ]*\) $/  {\\\"\1\\\", (lt_ptr) 0},/p' -e 's/^$symcode \([^ ]*\) \([^ ]*\)$/  {\"\2\", (lt_ptr) \&\2},/p'"
-# Define system-specific variables.
-case $host_os in
-aix*)
-  symcode='[BCDT]'
+# Some flags need to be propagated to the compiler or linker for good
+# libtool support.
+case $host in
+ia64-*-hpux*)
+  # Find out which ABI we are using.
+  echo 'int i;' > conftest.$ac_ext
+  if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
+  (eval $ac_compile) 2>&5
+  ac_status=$?
+  (exit $ac_status); }; then
+    case `/usr/bin/file conftest.$ac_objext` in
+    *ELF-32*)
+      HPUX_IA64_MODE="32"
+    *ELF-64*)
+      HPUX_IA64_MODE="64"
+    esac
+  fi
+  rm -rf conftest*
-  symcode='[ABCDGISTW]'
+*-*-irix6*)
+  echo '#line 4208 "configure"' > conftest.$ac_ext
+  ac_status=$?
+   if test "$lt_cv_prog_gnu_ld" = yes; then
+    *32-bit*)
+      LD="${LD-ld} -melf32bsmip"
+    *N32*)
+      LD="${LD-ld} -melf32bmipn32"
+    *64-bit*)
+      LD="${LD-ld} -melf64bmip"
+    esac
+   else
+    *32-bit*)
+      LD="${LD-ld} -32"
+    *N32*)
+      LD="${LD-ld} -n32"
+    *64-bit*)
+      LD="${LD-ld} -64"
+    esac
+   fi
+  fi
+  rm -rf conftest*
-hpux*) # Its linker distinguishes data from code symbols
-  lt_cv_global_symbol_to_cdecl="sed -n -e 's/^T .* \(.*\)$/extern char \1();/p' -e 's/^$symcode* .* \(.*\)$/extern char \1;/p'"
-  lt_cv_global_symbol_to_c_name_address="sed -n -e 's/^: \([^ ]*\) $/  {\\\"\1\\\", (lt_ptr) 0},/p' -e 's/^$symcode* \([^ ]*\) \([^ ]*\)$/  {\"\2\", (lt_ptr) \&\2},/p'"
-irix* | nonstopux*)
-  symcode='[BCDEGRST]'
-osf*)
-  symcode='[BCDEGQRST]'
-solaris* | sysv5*)
-  symcode='[BDT]'
-sysv4)
-  symcode='[DFNSTU]'
-esac
-# Handle CRLF in mingw tool chain
-opt_cr=
-case $host_os in
-mingw*)
-  opt_cr=`echo 'x\{0,1\}' | tr x '\015'` # option cr in regexp
+x86_64-*linux*|ppc*-*linux*|powerpc*-*linux*|s390*-*linux*|sparc*-*linux*)
+  ac_status=$?
+    case `/usr/bin/file conftest.o` in
+    *32-bit*)
+      case $host in
+        x86_64-*linux*)
+          LD="${LD-ld} -m elf_i386"
+        ppc64-*linux*|powerpc64-*linux*)
+          LD="${LD-ld} -m elf32ppclinux"
+        s390x-*linux*)
+          LD="${LD-ld} -m elf_s390"
+        sparc64-*linux*)
+          LD="${LD-ld} -m elf32_sparc"
+      esac
+    *64-bit*)
+      case $host in
+        x86_64-*linux*)
+          LD="${LD-ld} -m elf_x86_64"
+        ppc*-*linux*|powerpc*-*linux*)
+          LD="${LD-ld} -m elf64ppc"
+        s390*-*linux*)
+          LD="${LD-ld} -m elf64_s390"
+        sparc*-*linux*)
+          LD="${LD-ld} -m elf64_sparc"
+      esac
+    esac
+  fi
+  rm -rf conftest*
-esac
-# If we're using GNU nm, then use its standard symbol codes.
-if $NM -V 2>&1 | egrep '(GNU|with BFD)' > /dev/null; then
-fi
+*-*-sco3.2v5*)
+  # On SCO OpenServer 5, we need -belf to get full-featured binaries.
+  SAVE_CFLAGS="$CFLAGS"
+  CFLAGS="$CFLAGS -belf"
+  echo "$as_me:$LINENO: checking whether the C compiler needs -belf" >&5
+echo $ECHO_N "checking whether the C compiler needs -belf... $ECHO_C" >&6
+if test "${lt_cv_cc_needs_belf+set}" = set; then
+else
+  ac_ext=c
+ac_cpp='$CPP $CPPFLAGS'
+ac_compile='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5'
+ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
+ac_compiler_gnu=$ac_cv_c_compiler_gnu
-# Try without a prefix undercore, then with it.
-for ac_symprfx in "" "_"; do
+     cat >conftest.$ac_ext <<_ACEOF
+/* confdefs.h.  */
+_ACEOF
+cat confdefs.h >>conftest.$ac_ext
+cat >>conftest.$ac_ext <<_ACEOF
+/* end confdefs.h.  */
-  # Write the raw and C identifiers.
-lt_cv_sys_global_symbol_pipe="sed -n -e 's/^.*[ 	]\($symcode$symcode*\)[ 	][ 	]*\($ac_symprfx\)$sympat$opt_cr$/$symxfrm/p'"
+int
+main ()
-  # Check to see that the pipe works correctly.
-  pipe_works=no
-  rm -f conftest*
-  cat > conftest.$ac_ext <<EOF
-#ifdef __cplusplus
-extern "C" {
-#endif
-char nm_test_var;
-void nm_test_func(){}
-#ifdef __cplusplus
+  return 0;
-#endif
-int main(){nm_test_var='a';nm_test_func();return(0);}
-EOF
-  if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
+_ACEOF
+rm -f conftest.$ac_objext conftest$ac_exeext
+if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
+  (eval $ac_link) 2>conftest.er1
   ac_status=$?
-  (exit $ac_status); }; then
-    # Now try to grab the symbols.
-    nlist=conftest.nm
-    if { (eval echo "$as_me:$LINENO: \"$NM conftest.$ac_objext \| $lt_cv_sys_global_symbol_pipe \> $nlist\"") >&5
-  (eval $NM conftest.$ac_objext \| $lt_cv_sys_global_symbol_pipe \> $nlist) 2>&5
+  (exit $ac_status); } &&
   ac_status=$?
-  (exit $ac_status); } && test -s "$nlist"; then
-      # Try sorting and uniquifying the output.
-      if sort "$nlist" | uniq > "$nlist"T; then
-	mv -f "$nlist"T "$nlist"
-      else
-	rm -f "$nlist"T
-      fi
+	 { ac_try='test -s conftest$ac_exeext'
+  ac_status=$?
+  (exit $ac_status); }; }; then
+  lt_cv_cc_needs_belf=yes
+else
+  echo "$as_me: failed program was:" >&5
+sed 's/^/| /' conftest.$ac_ext >&5
-      # Make sure that we snagged all the symbols we need.
-      if egrep ' nm_test_var$' "$nlist" >/dev/null; then
-	if egrep ' nm_test_func$' "$nlist" >/dev/null; then
-	  cat <<EOF > conftest.$ac_ext
-#ifdef __cplusplus
-extern "C" {
-#endif
+lt_cv_cc_needs_belf=no
+fi
+rm -f conftest.err conftest.$ac_objext \
+      conftest$ac_exeext conftest.$ac_ext
+     ac_ext=c
-EOF
-	  # Now generate the symbol file.
-	  eval "$lt_cv_global_symbol_to_cdecl"' < "$nlist" >> conftest.$ac_ext'
-	  cat <<EOF >> conftest.$ac_ext
-#if defined (__STDC__) && __STDC__
-# define lt_ptr void *
-#else
-# define lt_ptr char *
-# define const
-#endif
-/* The mapping between symbol names and symbols. */
-const struct {
-  const char *name;
-  lt_ptr address;
-lt_preloaded_symbols[] =
-EOF
-	  sed "s/^$symcode$symcode* \(.*\) \(.*\)$/  {\"\2\", (lt_ptr) \&\2},/" < "$nlist" >> conftest.$ac_ext
-	  cat <<\EOF >> conftest.$ac_ext
-  {0, (lt_ptr) 0}
-#ifdef __cplusplus
-#endif
-EOF
-	  # Now try linking the two files.
-	  mv conftest.$ac_objext conftstm.$ac_objext
-	  save_LIBS="$LIBS"
-	  save_CFLAGS="$CFLAGS"
-	  LIBS="conftstm.$ac_objext"
-	  CFLAGS="$CFLAGS$no_builtin_flag"
-	  if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
-  (eval $ac_link) 2>&5
+fi
+echo "$as_me:$LINENO: result: $lt_cv_cc_needs_belf" >&5
+echo "${ECHO_T}$lt_cv_cc_needs_belf" >&6
+  if test x"$lt_cv_cc_needs_belf" != x"yes"; then
+    # this is probably gcc 2.8.0, egcs 1.0 or newer; no need for -belf
+    CFLAGS="$SAVE_CFLAGS"
+  fi
+sparc*-*solaris*)
   ac_status=$?
-  (exit $ac_status); } && test -s conftest$ac_exeext; then
-	    pipe_works=yes
-	  fi
-	  LIBS="$save_LIBS"
-	  CFLAGS="$save_CFLAGS"
-	else
-	  echo "cannot find nm_test_func in $nlist" >&5
-	fi
-      else
-	echo "cannot find nm_test_var in $nlist" >&5
-      fi
-    else
-      echo "cannot run $lt_cv_sys_global_symbol_pipe" >&5
-    fi
-  else
-    echo "$progname: failed program was:" >&5
-    cat conftest.$ac_ext >&5
+    *64-bit*)
+      case $lt_cv_prog_gnu_ld in
+      yes*) LD="${LD-ld} -m elf64_sparc" ;;
+      *)    LD="${LD-ld} -64" ;;
+      esac
+    esac
   fi
-  rm -f conftest* conftst*
+  rm -rf conftest*
-  # Do not use the global_symbol_pipe unless it works.
-  if test "$pipe_works" = yes; then
-    break
-  else
-    lt_cv_sys_global_symbol_pipe=
-  fi
-done
-fi
+esac
-global_symbol_pipe="$lt_cv_sys_global_symbol_pipe"
-if test -z "$lt_cv_sys_global_symbol_pipe"; then
-  global_symbol_to_cdecl=
-  global_symbol_to_c_name_address=
-else
-  global_symbol_to_cdecl="$lt_cv_global_symbol_to_cdecl"
-  global_symbol_to_c_name_address="$lt_cv_global_symbol_to_c_name_address"
-fi
-if test -z "$global_symbol_pipe$global_symbol_to_cdec$global_symbol_to_c_name_address";
-then
-  echo "$as_me:$LINENO: result: failed" >&5
-echo "${ECHO_T}failed" >&6
-else
-  echo "$as_me:$LINENO: result: ok" >&5
-echo "${ECHO_T}ok" >&6
-fi
+need_locks="$enable_libtool_lock"
-ac_ext=cc
-ac_cpp='$CXXCPP $CPPFLAGS'
-ac_compile='$CXX -c $CXXFLAGS $CPPFLAGS conftest.$ac_ext >&5'
-ac_link='$CXX -o conftest$ac_exeext $CXXFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
-ac_compiler_gnu=$ac_cv_cxx_compiler_gnu
-echo "$as_me:$LINENO: checking how to run the C++ preprocessor" >&5
-echo $ECHO_N "checking how to run the C++ preprocessor... $ECHO_C" >&6
-if test -z "$CXXCPP"; then
-  if test "${ac_cv_prog_CXXCPP+set}" = set; then
+ac_ext=c
+echo "$as_me:$LINENO: checking how to run the C preprocessor" >&5
+echo $ECHO_N "checking how to run the C preprocessor... $ECHO_C" >&6
+# On Suns, sometimes $CPP names a directory.
+if test -n "$CPP" && test -d "$CPP"; then
+  CPP=
+fi
+if test -z "$CPP"; then
+  if test "${ac_cv_prog_CPP+set}" = set; then
 else
-      # Double quotes because CXXCPP needs to be expanded
-    for CXXCPP in "$CXX -E" "/lib/cpp"
+      # Double quotes because CPP needs to be expanded
+    for CPP in "$CC -E" "$CC -E -traditional-cpp" "/lib/cpp"
     do
       ac_preproc_ok=false
-for ac_cxx_preproc_warn_flag in '' yes
+for ac_c_preproc_warn_flag in '' yes
 do
   # Use a header file that comes with gcc, so configuring glibc
   # with a fresh cross-compiler works.
@@ -4103,7 +4415,6 @@
   # On the NeXT, cc -E runs the code through the compiler's parser,
   # not just through cpp. "Syntax error" is here to catch this case.
 /* confdefs.h.  */
 _ACEOF
@@ -4114,7 +4425,7 @@
 #else
 # include <assert.h>
 #endif
-                     Syntax error
+		     Syntax error
 _ACEOF
 if { (eval echo "$as_me:$LINENO: \"$ac_cpp conftest.$ac_ext\"") >&5
   (eval $ac_cpp conftest.$ac_ext) 2>conftest.er1
@@ -4125,7 +4436,8 @@
   (exit $ac_status); } >/dev/null; then
   if test -s conftest.err; then
-    ac_cpp_err=$ac_cxx_preproc_warn_flag
+    ac_cpp_err=$ac_c_preproc_warn_flag
+    ac_cpp_err=$ac_cpp_err$ac_c_werror_flag
   else
     ac_cpp_err=
   fi
@@ -4146,7 +4458,6 @@
   # OK, works on sane cases.  Now check whether non-existent headers
   # can be detected and how.
 /* confdefs.h.  */
 _ACEOF
@@ -4163,7 +4474,8 @@
   else
     ac_cpp_err=
   fi
@@ -4191,17 +4503,17 @@
 fi
     done
-    ac_cv_prog_CXXCPP=$CXXCPP
+    ac_cv_prog_CPP=$CPP
 fi
-  CXXCPP=$ac_cv_prog_CXXCPP
+  CPP=$ac_cv_prog_CPP
 else
 fi
-echo "$as_me:$LINENO: result: $CXXCPP" >&5
-echo "${ECHO_T}$CXXCPP" >&6
+echo "$as_me:$LINENO: result: $CPP" >&5
+echo "${ECHO_T}$CPP" >&6
 ac_preproc_ok=false
 do
@@ -4210,7 +4522,6 @@
 /* confdefs.h.  */
 _ACEOF
@@ -4221,7 +4532,7 @@
 #else
 #endif
-                     Syntax error
+		     Syntax error
 _ACEOF
@@ -4232,7 +4543,8 @@
   else
     ac_cpp_err=
   fi
@@ -4253,7 +4565,6 @@
 /* confdefs.h.  */
 _ACEOF
@@ -4270,7 +4581,8 @@
   else
     ac_cpp_err=
   fi
@@ -4296,42 +4608,26 @@
 if $ac_preproc_ok; then
 else
-  { { echo "$as_me:$LINENO: error: C++ preprocessor \"$CXXCPP\" fails sanity check
+  { { echo "$as_me:$LINENO: error: C preprocessor \"$CPP\" fails sanity check
 See \`config.log' for more details." >&5
-echo "$as_me: error: C++ preprocessor \"$CXXCPP\" fails sanity check
+echo "$as_me: error: C preprocessor \"$CPP\" fails sanity check
 See \`config.log' for more details." >&2;}
 fi
-ac_ext=cc
+ac_ext=c
-echo "$as_me:$LINENO: checking for egrep" >&5
-echo $ECHO_N "checking for egrep... $ECHO_C" >&6
-if test "${ac_cv_prog_egrep+set}" = set; then
-else
-  if echo a | (grep -E '(a|b)') >/dev/null 2>&1
-    then ac_cv_prog_egrep='grep -E'
-    else ac_cv_prog_egrep='egrep'
-    fi
-fi
-echo "$as_me:$LINENO: result: $ac_cv_prog_egrep" >&5
-echo "${ECHO_T}$ac_cv_prog_egrep" >&6
- EGREP=$ac_cv_prog_egrep
 echo "$as_me:$LINENO: checking for ANSI C header files" >&5
 echo $ECHO_N "checking for ANSI C header files... $ECHO_C" >&6
 if test "${ac_cv_header_stdc+set}" = set; then
 else
 /* confdefs.h.  */
 _ACEOF
@@ -4352,15 +4648,25 @@
 _ACEOF
   ac_status=$?
   (eval $ac_try) 2>&5
   ac_status=$?
+  ac_status=$?
   ac_cv_header_stdc=yes
 else
@@ -4369,12 +4675,11 @@
 ac_cv_header_stdc=no
 fi
 if test $ac_cv_header_stdc = yes; then
   # SunOS 4.x string.h does not declare mem*, contrary to ANSI.
 /* confdefs.h.  */
 _ACEOF
@@ -4396,7 +4701,6 @@
   # ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
 /* confdefs.h.  */
 _ACEOF
@@ -4421,7 +4725,6 @@
 else
 /* confdefs.h.  */
 _ACEOF
@@ -4433,9 +4736,9 @@
 # define TOUPPER(c) (ISLOWER(c) ? 'A' + ((c) - 'a') : (c))
 #else
 # define ISLOWER(c) \
-                   (('a' <= (c) && (c) <= 'i') \
-                     || ('j' <= (c) && (c) <= 'r') \
-                     || ('s' <= (c) && (c) <= 'z'))
+		   (('a' <= (c) && (c) <= 'i') \
+		     || ('j' <= (c) && (c) <= 'r') \
+		     || ('s' <= (c) && (c) <= 'z'))
 # define TOUPPER(c) (ISLOWER(c) ? ((c) | 0x40) : (c))
 #endif
@@ -4446,7 +4749,7 @@
   int i;
   for (i = 0; i < 256; i++)
     if (XOR (islower (i), ISLOWER (i))
-        || toupper (i) != TOUPPER (i))
+	|| toupper (i) != TOUPPER (i))
       exit(2);
   exit (0);
@@ -4471,7 +4774,7 @@
 ( exit $ac_status )
 fi
-rm -f core core.* *.core gmon.out bb.out conftest$ac_exeext conftest.$ac_objext conftest.$ac_ext
+rm -f core *.core gmon.out bb.out conftest$ac_exeext conftest.$ac_objext conftest.$ac_ext
 fi
 fi
 fi
@@ -4496,7 +4799,7 @@
 for ac_header in sys/types.h sys/stat.h stdlib.h string.h memory.h strings.h \
-                  inttypes.h stdint.h unistd.h
+		  inttypes.h stdint.h unistd.h
 do
 as_ac_Header=`echo "ac_cv_header_$ac_header" | $as_tr_sh`
 echo "$as_me:$LINENO: checking for $ac_header" >&5
@@ -4505,7 +4808,6 @@
 else
 /* confdefs.h.  */
 _ACEOF
@@ -4517,15 +4819,25 @@
 _ACEOF
   ac_status=$?
   (eval $ac_try) 2>&5
   ac_status=$?
+  ac_status=$?
   eval "$as_ac_Header=yes"
 else
@@ -4534,7 +4846,7 @@
 eval "$as_ac_Header=no"
 fi
 fi
 echo "$as_me:$LINENO: result: `eval echo '${'$as_ac_Header'}'`" >&5
 echo "${ECHO_T}`eval echo '${'$as_ac_Header'}'`" >&6
@@ -4565,7 +4877,6 @@
 echo "$as_me:$LINENO: checking $ac_header usability" >&5
 echo $ECHO_N "checking $ac_header usability... $ECHO_C" >&6
 /* confdefs.h.  */
 _ACEOF
@@ -4576,15 +4887,25 @@
 _ACEOF
   ac_status=$?
   (eval $ac_try) 2>&5
   ac_status=$?
+  ac_status=$?
   ac_header_compiler=yes
 else
@@ -4593,7 +4914,7 @@
 ac_header_compiler=no
 fi
 echo "$as_me:$LINENO: result: $ac_header_compiler" >&5
 echo "${ECHO_T}$ac_header_compiler" >&6
@@ -4601,7 +4922,6 @@
 echo "$as_me:$LINENO: checking $ac_header presence" >&5
 echo $ECHO_N "checking $ac_header presence... $ECHO_C" >&6
 /* confdefs.h.  */
 _ACEOF
@@ -4618,7 +4938,8 @@
   else
     ac_cpp_err=
   fi
@@ -4638,33 +4959,32 @@
 echo "${ECHO_T}$ac_header_preproc" >&6
 # So?  What about this header?
-case $ac_header_compiler:$ac_header_preproc in
-  yes:no )
+case $ac_header_compiler:$ac_header_preproc:$ac_c_preproc_warn_flag in
+  yes:no: )
     { echo "$as_me:$LINENO: WARNING: $ac_header: accepted by the compiler, rejected by the preprocessor!" >&5
 echo "$as_me: WARNING: $ac_header: accepted by the compiler, rejected by the preprocessor!" >&2;}
-    { echo "$as_me:$LINENO: WARNING: $ac_header: proceeding with the preprocessor's result" >&5
-echo "$as_me: WARNING: $ac_header: proceeding with the preprocessor's result" >&2;}
-      cat <<\_ASBOX
-## Report this to bug-autoconf at gnu.org. ##
-_ASBOX
-      sed "s/^/$as_me: WARNING:     /" >&2
+    { echo "$as_me:$LINENO: WARNING: $ac_header: proceeding with the compiler's result" >&5
+echo "$as_me: WARNING: $ac_header: proceeding with the compiler's result" >&2;}
+    ac_header_preproc=yes
-  no:yes )
+  no:yes:* )
     { echo "$as_me:$LINENO: WARNING: $ac_header: present but cannot be compiled" >&5
 echo "$as_me: WARNING: $ac_header: present but cannot be compiled" >&2;}
-    { echo "$as_me:$LINENO: WARNING: $ac_header: check for missing prerequisite headers?" >&5
-echo "$as_me: WARNING: $ac_header: check for missing prerequisite headers?" >&2;}
+    { echo "$as_me:$LINENO: WARNING: $ac_header:     check for missing prerequisite headers?" >&5
+echo "$as_me: WARNING: $ac_header:     check for missing prerequisite headers?" >&2;}
+    { echo "$as_me:$LINENO: WARNING: $ac_header: see the Autoconf documentation" >&5
+echo "$as_me: WARNING: $ac_header: see the Autoconf documentation" >&2;}
+    { echo "$as_me:$LINENO: WARNING: $ac_header:     section \"Present But Cannot Be Compiled\"" >&5
+echo "$as_me: WARNING: $ac_header:     section \"Present But Cannot Be Compiled\"" >&2;}
+    { echo "$as_me:$LINENO: WARNING: $ac_header: in the future, the compiler will take precedence" >&5
+echo "$as_me: WARNING: $ac_header: in the future, the compiler will take precedence" >&2;}
       cat <<\_ASBOX
+## Report this to http://www.fdo.osgeo.org ##
 _ASBOX
@@ -4675,7 +4995,7 @@
 if eval "test \"\${$as_ac_Header+set}\" = set"; then
 else
-  eval "$as_ac_Header=$ac_header_preproc"
+  eval "$as_ac_Header=\$ac_header_preproc"
 fi
@@ -4692,147 +5012,958 @@
+if test -n "$CXX" && ( test "X$CXX" != "Xno" &&
+    ( (test "X$CXX" = "Xg++" && `g++ -v >/dev/null 2>&1` ) ||
+    (test "X$CXX" != "Xg++"))) ; then
+  ac_ext=cc
+ac_cpp='$CXXCPP $CPPFLAGS'
+ac_compile='$CXX -c $CXXFLAGS $CPPFLAGS conftest.$ac_ext >&5'
+ac_link='$CXX -o conftest$ac_exeext $CXXFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
+ac_compiler_gnu=$ac_cv_cxx_compiler_gnu
+echo "$as_me:$LINENO: checking how to run the C++ preprocessor" >&5
+echo $ECHO_N "checking how to run the C++ preprocessor... $ECHO_C" >&6
+if test -z "$CXXCPP"; then
+  if test "${ac_cv_prog_CXXCPP+set}" = set; then
+else
+      # Double quotes because CXXCPP needs to be expanded
+    for CXXCPP in "$CXX -E" "/lib/cpp"
+    do
+      ac_preproc_ok=false
+for ac_cxx_preproc_warn_flag in '' yes
+do
+  # Use a header file that comes with gcc, so configuring glibc
+  # with a fresh cross-compiler works.
+  # Prefer <limits.h> to <assert.h> if __STDC__ is defined, since
+  # <limits.h> exists even on freestanding compilers.
+  # On the NeXT, cc -E runs the code through the compiler's parser,
+  # not just through cpp. "Syntax error" is here to catch this case.
+/* confdefs.h.  */
+_ACEOF
+#ifdef __STDC__
+# include <limits.h>
+#else
+# include <assert.h>
+#endif
+		     Syntax error
+_ACEOF
+if { (eval echo "$as_me:$LINENO: \"$ac_cpp conftest.$ac_ext\"") >&5
+  (eval $ac_cpp conftest.$ac_ext) 2>conftest.er1
+  ac_status=$?
+  (exit $ac_status); } >/dev/null; then
+  if test -s conftest.err; then
+    ac_cpp_err=$ac_cxx_preproc_warn_flag
+    ac_cpp_err=$ac_cpp_err$ac_cxx_werror_flag
+  else
+    ac_cpp_err=
+  fi
+else
+  ac_cpp_err=yes
+fi
+if test -z "$ac_cpp_err"; then
+else
+  # Broken: fails on valid input.
+continue
+fi
+rm -f conftest.err conftest.$ac_ext
+  # OK, works on sane cases.  Now check whether non-existent headers
+  # can be detected and how.
+/* confdefs.h.  */
+_ACEOF
+#include <ac_nonexistent.h>
+_ACEOF
+  ac_status=$?
+  else
+    ac_cpp_err=
+  fi
+else
+  ac_cpp_err=yes
+fi
+  # Broken: success on invalid input.
+continue
+else
-# Only perform the check for file, if the check method requires it
-case $deplibs_check_method in
-file_magic*)
-  if test "$file_magic_cmd" = '$MAGIC_CMD'; then
-    echo "$as_me:$LINENO: checking for ${ac_tool_prefix}file" >&5
-echo $ECHO_N "checking for ${ac_tool_prefix}file... $ECHO_C" >&6
-if test "${lt_cv_path_MAGIC_CMD+set}" = set; then
+  # Passes both tests.
+ac_preproc_ok=:
+break
+fi
+done
+# Because of `break', _AC_PREPROC_IFELSE's cleaning code was skipped.
+if $ac_preproc_ok; then
+  break
+fi
+    done
+    ac_cv_prog_CXXCPP=$CXXCPP
+fi
+  CXXCPP=$ac_cv_prog_CXXCPP
+else
+fi
+echo "$as_me:$LINENO: result: $CXXCPP" >&5
+echo "${ECHO_T}$CXXCPP" >&6
+ac_preproc_ok=false
+do
+/* confdefs.h.  */
+_ACEOF
+#ifdef __STDC__
+#else
+#endif
+		     Syntax error
+_ACEOF
+  ac_status=$?
+  else
+    ac_cpp_err=
+  fi
+else
+  ac_cpp_err=yes
+fi
+else
+continue
+fi
+/* confdefs.h.  */
+_ACEOF
+_ACEOF
+  ac_status=$?
+  else
+    ac_cpp_err=
+  fi
+else
+  ac_cpp_err=yes
+fi
+continue
+else
+ac_preproc_ok=:
+break
+fi
+done
+else
+  { { echo "$as_me:$LINENO: error: C++ preprocessor \"$CXXCPP\" fails sanity check
+See \`config.log' for more details." >&5
+echo "$as_me: error: C++ preprocessor \"$CXXCPP\" fails sanity check
+See \`config.log' for more details." >&2;}
+   { (exit 1); exit 1; }; }
+fi
+ac_ext=cc
+fi
+ac_ext=f
+ac_compile='$F77 -c $FFLAGS conftest.$ac_ext >&5'
+ac_link='$F77 -o conftest$ac_exeext $FFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
+ac_compiler_gnu=$ac_cv_f77_compiler_gnu
+if test -n "$ac_tool_prefix"; then
+  for ac_prog in g77 f77 xlf frt pgf77 fort77 fl32 af77 f90 xlf90 pgf90 epcf90 f95 fort xlf95 ifc efc pgf95 lf95 gfortran
+  do
+    # Extract the first word of "$ac_tool_prefix$ac_prog", so it can be a program name with args.
+set dummy $ac_tool_prefix$ac_prog; ac_word=$2
+echo "$as_me:$LINENO: checking for $ac_word" >&5
+echo $ECHO_N "checking for $ac_word... $ECHO_C" >&6
+if test "${ac_cv_prog_F77+set}" = set; then
 else
-  case $MAGIC_CMD in
-  lt_cv_path_MAGIC_CMD="$MAGIC_CMD" # Let the user override the test with a path.
-  lt_cv_path_MAGIC_CMD="$MAGIC_CMD" # Let the user override the test with a dos path.
-  ac_save_MAGIC_CMD="$MAGIC_CMD"
-  IFS="${IFS=   }"; ac_save_ifs="$IFS"; IFS=":"
-  ac_dummy="/usr/bin:$PATH"
-  for ac_dir in $ac_dummy; do
-    if test -f $ac_dir/${ac_tool_prefix}file; then
-      lt_cv_path_MAGIC_CMD="$ac_dir/${ac_tool_prefix}file"
-      if test -n "$file_magic_test_file"; then
-	case $deplibs_check_method in
-	"file_magic "*)
-	  file_magic_regex="`expr \"$deplibs_check_method\" : \"file_magic \(.*\)\"`"
-	  MAGIC_CMD="$lt_cv_path_MAGIC_CMD"
-	  if eval $file_magic_cmd \$file_magic_test_file 2> /dev/null |
-	    egrep "$file_magic_regex" > /dev/null; then
-	  else
-	    cat <<EOF 1>&2
+  if test -n "$F77"; then
+  ac_cv_prog_F77="$F77" # Let the user override the test.
+else
+do
+  IFS=$as_save_IFS
+  if $as_executable_p "$as_dir/$ac_word$ac_exec_ext"; then
+    ac_cv_prog_F77="$ac_tool_prefix$ac_prog"
+    echo "$as_me:$LINENO: found $as_dir/$ac_word$ac_exec_ext" >&5
+    break 2
+  fi
+done
+done
-*** Warning: the command libtool uses to detect shared libraries,
-*** $file_magic_cmd, produces output that libtool cannot recognize.
-*** The result is that libtool may fail to recognize shared libraries
-*** as such.  This will affect the creation of libtool libraries that
-*** depend on shared libraries, but programs linked with such libtool
-*** libraries will work regardless of this problem.  Nevertheless, you
-*** may want to report the problem to your system manager and/or to
-*** bug-libtool at gnu.org
+fi
+fi
+F77=$ac_cv_prog_F77
+if test -n "$F77"; then
+  echo "$as_me:$LINENO: result: $F77" >&5
+echo "${ECHO_T}$F77" >&6
+else
+  echo "$as_me:$LINENO: result: no" >&5
+echo "${ECHO_T}no" >&6
+fi
-EOF
-	  fi ;;
-	esac
-      fi
-      break
-    fi
+    test -n "$F77" && break
   done
-  MAGIC_CMD="$ac_save_MAGIC_CMD"
-esac
 fi
+if test -z "$F77"; then
+  ac_ct_F77=$F77
+do
+  # Extract the first word of "$ac_prog", so it can be a program name with args.
+set dummy $ac_prog; ac_word=$2
+if test "${ac_cv_prog_ac_ct_F77+set}" = set; then
+else
+  if test -n "$ac_ct_F77"; then
+  ac_cv_prog_ac_ct_F77="$ac_ct_F77" # Let the user override the test.
+else
+do
+  IFS=$as_save_IFS
+    ac_cv_prog_ac_ct_F77="$ac_prog"
+    break 2
+  fi
+done
+done
-MAGIC_CMD="$lt_cv_path_MAGIC_CMD"
-if test -n "$MAGIC_CMD"; then
-  echo "$as_me:$LINENO: result: $MAGIC_CMD" >&5
-echo "${ECHO_T}$MAGIC_CMD" >&6
+fi
+fi
+ac_ct_F77=$ac_cv_prog_ac_ct_F77
+if test -n "$ac_ct_F77"; then
+  echo "$as_me:$LINENO: result: $ac_ct_F77" >&5
+echo "${ECHO_T}$ac_ct_F77" >&6
 else
 fi
-if test -z "$lt_cv_path_MAGIC_CMD"; then
-  if test -n "$ac_tool_prefix"; then
-    echo "$as_me:$LINENO: checking for file" >&5
-echo $ECHO_N "checking for file... $ECHO_C" >&6
+  test -n "$ac_ct_F77" && break
+done
+  F77=$ac_ct_F77
+fi
+# Provide some information about the compiler.
+echo "$as_me:5343:" \
+     "checking for Fortran 77 compiler version" >&5
+ac_compiler=`set X $ac_compile; echo $2`
+{ (eval echo "$as_me:$LINENO: \"$ac_compiler --version </dev/null >&5\"") >&5
+  (eval $ac_compiler --version </dev/null >&5) 2>&5
+  ac_status=$?
+{ (eval echo "$as_me:$LINENO: \"$ac_compiler -v </dev/null >&5\"") >&5
+  (eval $ac_compiler -v </dev/null >&5) 2>&5
+  ac_status=$?
+{ (eval echo "$as_me:$LINENO: \"$ac_compiler -V </dev/null >&5\"") >&5
+  (eval $ac_compiler -V </dev/null >&5) 2>&5
+  ac_status=$?
+rm -f a.out
+# If we don't use `.F' as extension, the preprocessor is not run on the
+# input file.  (Note that this only needs to work for GNU compilers.)
+ac_save_ext=$ac_ext
+ac_ext=F
+echo "$as_me:$LINENO: checking whether we are using the GNU Fortran 77 compiler" >&5
+echo $ECHO_N "checking whether we are using the GNU Fortran 77 compiler... $ECHO_C" >&6
+if test "${ac_cv_f77_compiler_gnu+set}" = set; then
 else
+      program main
+#ifndef __GNUC__
+       choke me
+#endif
+      end
+_ACEOF
+if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
+  ac_status=$?
+	 { ac_try='test -z "$ac_f77_werror_flag"
+  ac_status=$?
+  ac_status=$?
+  ac_compiler_gnu=yes
+else
+ac_compiler_gnu=no
+fi
+ac_cv_f77_compiler_gnu=$ac_compiler_gnu
+fi
+echo "$as_me:$LINENO: result: $ac_cv_f77_compiler_gnu" >&5
+echo "${ECHO_T}$ac_cv_f77_compiler_gnu" >&6
+ac_ext=$ac_save_ext
+ac_test_FFLAGS=${FFLAGS+set}
+ac_save_FFLAGS=$FFLAGS
+FFLAGS=
+echo "$as_me:$LINENO: checking whether $F77 accepts -g" >&5
+echo $ECHO_N "checking whether $F77 accepts -g... $ECHO_C" >&6
+if test "${ac_cv_prog_f77_g+set}" = set; then
+else
+  FFLAGS=-g
+cat >conftest.$ac_ext <<_ACEOF
+      program main
+      end
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_cv_prog_f77_g=yes
+else
+ac_cv_prog_f77_g=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_prog_f77_g" >&5
+echo "${ECHO_T}$ac_cv_prog_f77_g" >&6
+if test "$ac_test_FFLAGS" = set; then
+  FFLAGS=$ac_save_FFLAGS
+elif test $ac_cv_prog_f77_g = yes; then
+  if test "x$ac_cv_f77_compiler_gnu" = xyes; then
+    FFLAGS="-g -O2"
+  else
+    FFLAGS="-g"
+  fi
+else
+    FFLAGS="-O2"
+  else
+    FFLAGS=
+  fi
+fi
+G77=`test $ac_compiler_gnu = yes && echo yes`
+ac_ext=cc
+# Autoconf 2.13's AC_OBJEXT and AC_EXEEXT macros only works for C compilers!
+# find the maximum length of command line arguments
+echo "$as_me:$LINENO: checking the maximum length of command line arguments" >&5
+echo $ECHO_N "checking the maximum length of command line arguments... $ECHO_C" >&6
+if test "${lt_cv_sys_max_cmd_len+set}" = set; then
+else
+    i=0
+  teststring="ABCD"
+  case $build_os in
+  msdosdjgpp*)
+    # On DJGPP, this test can blow up pretty badly due to problems in libc
+    # (any single argument exceeding 2000 bytes causes a buffer overrun
+    # during glob expansion).  Even if it were fixed, the result of this
+    # check would be larger than it should be.
+    lt_cv_sys_max_cmd_len=12288;    # 12K is about right
+  gnu*)
+    # Under GNU Hurd, this test is not required because there is
+    # no limit to the length of command line arguments.
+    # Libtool will interpret -1 as no limit whatsoever
+    lt_cv_sys_max_cmd_len=-1;
+  cygwin* | mingw*)
+    # On Win9x/ME, this test blows up -- it succeeds, but takes
+    # about 5 minutes as the teststring grows exponentially.
+    # Worse, since 9x/ME are not pre-emptively multitasking,
+    # you end up with a "frozen" computer, even though with patience
+    # the test eventually succeeds (with a max line length of 256k).
+    # Instead, let's just punt: use the minimum linelength reported by
+    # all of the supported platforms: 8192 (on NT/2K/XP).
+    lt_cv_sys_max_cmd_len=8192;
+  amigaos*)
+    # On AmigaOS with pdksh, this test takes hours, literally.
+    # So we just punt and use a minimum line length of 8192.
+  netbsd* | freebsd* | openbsd* | darwin* | dragonfly*)
+    # This has been around since 386BSD, at least.  Likely further.
+    if test -x /sbin/sysctl; then
+      lt_cv_sys_max_cmd_len=`/sbin/sysctl -n kern.argmax`
+    elif test -x /usr/sbin/sysctl; then
+      lt_cv_sys_max_cmd_len=`/usr/sbin/sysctl -n kern.argmax`
+    else
+      lt_cv_sys_max_cmd_len=65536	# usable default for all BSDs
+    fi
+    # And add a safety zone
+    lt_cv_sys_max_cmd_len=`expr $lt_cv_sys_max_cmd_len \/ 4`
+    lt_cv_sys_max_cmd_len=`expr $lt_cv_sys_max_cmd_len \* 3`
+  interix*)
+    # We know the value 262144 and hardcode it with a safety zone (like BSD)
+    lt_cv_sys_max_cmd_len=196608
+  osf*)
+    # Dr. Hans Ekkehard Plesser reports seeing a kernel panic running configure
+    # due to this test when exec_disable_arg_limit is 1 on Tru64. It is not
+    # nice to cause kernel panics so lets avoid the loop below.
+    # First set a reasonable default.
+    lt_cv_sys_max_cmd_len=16384
+    if test -x /sbin/sysconfig; then
+      case `/sbin/sysconfig -q proc exec_disable_arg_limit` in
+        *1*) lt_cv_sys_max_cmd_len=-1 ;;
+      esac
+    fi
+  sco3.2v5*)
+    lt_cv_sys_max_cmd_len=102400
+  sysv5* | sco5v6* | sysv4.2uw2*)
+    kargmax=`grep ARG_MAX /etc/conf/cf.d/stune 2>/dev/null`
+    if test -n "$kargmax"; then
+      lt_cv_sys_max_cmd_len=`echo $kargmax | sed 's/.*[ 	]//'`
+    else
+      lt_cv_sys_max_cmd_len=32768
+    fi
+    # If test is not a shell built-in, we'll probably end up computing a
+    # maximum length that is only half of the actual maximum length, but
+    # we can't tell.
+    SHELL=${SHELL-${CONFIG_SHELL-/bin/sh}}
+    while (test "X"`$SHELL $0 --fallback-echo "X$teststring" 2>/dev/null` \
+	       = "XX$teststring") >/dev/null 2>&1 &&
+	    new_result=`expr "X$teststring" : ".*" 2>&1` &&
+	    lt_cv_sys_max_cmd_len=$new_result &&
+	    test $i != 17 # 1/2 MB should be enough
+    do
+      i=`expr $i + 1`
+      teststring=$teststring$teststring
+    done
+    teststring=
+    # Add a significant safety factor because C++ compilers can tack on massive
+    # amounts of additional arguments before passing them to the linker.
+    # It appears as though 1/2 is a usable value.
+    lt_cv_sys_max_cmd_len=`expr $lt_cv_sys_max_cmd_len \/ 2`
+  esac
+fi
+if test -n $lt_cv_sys_max_cmd_len ; then
+  echo "$as_me:$LINENO: result: $lt_cv_sys_max_cmd_len" >&5
+echo "${ECHO_T}$lt_cv_sys_max_cmd_len" >&6
+else
+  echo "$as_me:$LINENO: result: none" >&5
+echo "${ECHO_T}none" >&6
+fi
+# Check for command to grab the raw symbol name followed by C symbol from nm.
+echo "$as_me:$LINENO: checking command to parse $NM output from $compiler object" >&5
+echo $ECHO_N "checking command to parse $NM output from $compiler object... $ECHO_C" >&6
+if test "${lt_cv_sys_global_symbol_pipe+set}" = set; then
+else
+# These are sane defaults that work on at least a few old systems.
+# [They come from Ultrix.  What could be older than Ultrix?!! ;)]
+# Character class describing NM global symbol codes.
+symcode='[BCDEGRST]'
+# Regexp to match symbols that can be accessed directly from C.
+sympat='\([_A-Za-z][_A-Za-z0-9]*\)'
+# Transform an extracted symbol line into a proper C declaration
+lt_cv_sys_global_symbol_to_cdecl="sed -n -e 's/^. .* \(.*\)$/extern int \1;/p'"
+# Transform an extracted symbol line into symbol name and symbol address
+lt_cv_sys_global_symbol_to_c_name_address="sed -n -e 's/^: \([^ ]*\) $/  {\\\"\1\\\", (lt_ptr) 0},/p' -e 's/^$symcode \([^ ]*\) \([^ ]*\)$/  {\"\2\", (lt_ptr) \&\2},/p'"
+# Define system-specific variables.
+case $host_os in
+aix*)
+  symcode='[BCDT]'
+cygwin* | mingw* | pw32*)
+  symcode='[ABCDGISTW]'
-    if test -f $ac_dir/file; then
-      lt_cv_path_MAGIC_CMD="$ac_dir/file"
-	"file_magic "*)
-	  else
-	    cat <<EOF 1>&2
+hpux*) # Its linker distinguishes data from code symbols
+  if test "$host_cpu" = ia64; then
+    symcode='[ABCDEGRST]'
+  fi
+  lt_cv_sys_global_symbol_to_cdecl="sed -n -e 's/^T .* \(.*\)$/extern int \1();/p' -e 's/^$symcode* .* \(.*\)$/extern char \1;/p'"
+  lt_cv_sys_global_symbol_to_c_name_address="sed -n -e 's/^: \([^ ]*\) $/  {\\\"\1\\\", (lt_ptr) 0},/p' -e 's/^$symcode* \([^ ]*\) \([^ ]*\)$/  {\"\2\", (lt_ptr) \&\2},/p'"
+linux*)
+    symcode='[ABCDGIRSTW]'
+  fi
+irix* | nonstopux*)
+  symcode='[BCDEGRST]'
+osf*)
+  symcode='[BCDEGQRST]'
+solaris*)
+  symcode='[BDRT]'
+sco3.2v5*)
+  symcode='[DT]'
+sysv4.2uw2*)
+  symcode='[DT]'
+sysv5* | sco5v6* | unixware* | OpenUNIX*)
+  symcode='[ABDT]'
+sysv4)
+  symcode='[DFNSTU]'
+esac
+# Handle CRLF in mingw tool chain
+opt_cr=
+case $build_os in
+mingw*)
+  opt_cr=`echo 'x\{0,1\}' | tr x '\015'` # option cr in regexp
+esac
+# If we're using GNU nm, then use its standard symbol codes.
+case `$NM -V 2>&1` in
+  symcode='[ABCDGIRSTW]' ;;
+esac
+# Try without a prefix undercore, then with it.
+for ac_symprfx in "" "_"; do
+  # Transform symcode, sympat, and symprfx into a raw symbol and a C symbol.
+  symxfrm="\\1 $ac_symprfx\\2 \\2"
+  # Write the raw and C identifiers.
+  lt_cv_sys_global_symbol_pipe="sed -n -e 's/^.*[ 	]\($symcode$symcode*\)[ 	][ 	]*$ac_symprfx$sympat$opt_cr$/$symxfrm/p'"
+  # Check to see that the pipe works correctly.
+  pipe_works=no
+  rm -f conftest*
+  cat > conftest.$ac_ext <<EOF
+#ifdef __cplusplus
+extern "C" {
+#endif
+char nm_test_var;
+void nm_test_func(){}
+#ifdef __cplusplus
+#endif
+int main(){nm_test_var='a';nm_test_func();return(0);}
 EOF
-	  fi ;;
-	esac
+  ac_status=$?
+    # Now try to grab the symbols.
+    nlist=conftest.nm
+    if { (eval echo "$as_me:$LINENO: \"$NM conftest.$ac_objext \| $lt_cv_sys_global_symbol_pipe \> $nlist\"") >&5
+  (eval $NM conftest.$ac_objext \| $lt_cv_sys_global_symbol_pipe \> $nlist) 2>&5
+  ac_status=$?
+  (exit $ac_status); } && test -s "$nlist"; then
+      # Try sorting and uniquifying the output.
+      if sort "$nlist" | uniq > "$nlist"T; then
+	mv -f "$nlist"T "$nlist"
+      else
+	rm -f "$nlist"T
       fi
-      break
+      # Make sure that we snagged all the symbols we need.
+      if grep ' nm_test_var$' "$nlist" >/dev/null; then
+	if grep ' nm_test_func$' "$nlist" >/dev/null; then
+	  cat <<EOF > conftest.$ac_ext
+#ifdef __cplusplus
+extern "C" {
+#endif
+EOF
+	  # Now generate the symbol file.
+	  eval "$lt_cv_sys_global_symbol_to_cdecl"' < "$nlist" | grep -v main >> conftest.$ac_ext'
+	  cat <<EOF >> conftest.$ac_ext
+#if defined (__STDC__) && __STDC__
+# define lt_ptr_t void *
+#else
+# define lt_ptr_t char *
+# define const
+#endif
+/* The mapping between symbol names and symbols. */
+const struct {
+  const char *name;
+  lt_ptr_t address;
+lt_preloaded_symbols[] =
+EOF
+	  $SED "s/^$symcode$symcode* \(.*\) \(.*\)$/  {\"\2\", (lt_ptr_t) \&\2},/" < "$nlist" | grep -v main >> conftest.$ac_ext
+	  cat <<\EOF >> conftest.$ac_ext
+  {0, (lt_ptr_t) 0}
+#ifdef __cplusplus
+#endif
+EOF
+	  # Now try linking the two files.
+	  mv conftest.$ac_objext conftstm.$ac_objext
+	  lt_save_LIBS="$LIBS"
+	  lt_save_CFLAGS="$CFLAGS"
+	  LIBS="conftstm.$ac_objext"
+	  CFLAGS="$CFLAGS$lt_prog_compiler_no_builtin_flag"
+	  if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
+  (eval $ac_link) 2>&5
+  ac_status=$?
+  echo "$as_me:$LINENO: \$? = $ac_status" >&5
+  (exit $ac_status); } && test -s conftest${ac_exeext}; then
+	    pipe_works=yes
+	  fi
+	  LIBS="$lt_save_LIBS"
+	  CFLAGS="$lt_save_CFLAGS"
+	else
+	  echo "cannot find nm_test_func in $nlist" >&5
+	fi
+      else
+	echo "cannot find nm_test_var in $nlist" >&5
+      fi
+    else
+      echo "cannot run $lt_cv_sys_global_symbol_pipe" >&5
     fi
-  done
+  else
+    echo "$progname: failed program was:" >&5
+    cat conftest.$ac_ext >&5
+  fi
+  rm -f conftest* conftst*
+  # Do not use the global_symbol_pipe unless it works.
+  if test "$pipe_works" = yes; then
+    break
+  else
+  fi
+done
+fi
+if test -z "$lt_cv_sys_global_symbol_pipe"; then
+fi
+if test -z "$lt_cv_sys_global_symbol_pipe$lt_cv_sys_global_symbol_to_cdecl"; then
+  echo "$as_me:$LINENO: result: failed" >&5
+echo "${ECHO_T}failed" >&6
+else
+  echo "$as_me:$LINENO: result: ok" >&5
+echo "${ECHO_T}ok" >&6
+fi
+echo "$as_me:$LINENO: checking for objdir" >&5
+echo $ECHO_N "checking for objdir... $ECHO_C" >&6
+if test "${lt_cv_objdir+set}" = set; then
+else
+  rm -f .libs 2>/dev/null
+mkdir .libs 2>/dev/null
+if test -d .libs; then
+  lt_cv_objdir=.libs
+else
+  # MS-DOS does not allow filenames that begin with a dot.
+  lt_cv_objdir=_libs
+fi
+rmdir .libs 2>/dev/null
+fi
+echo "$as_me:$LINENO: result: $lt_cv_objdir" >&5
+echo "${ECHO_T}$lt_cv_objdir" >&6
+objdir=$lt_cv_objdir
+case $host_os in
+aix3*)
+  # AIX sometimes has problems with the GCC collect2 program.  For some
+  # reason, if we set the COLLECT_NAMES environment variable, the problems
+  # vanish in a puff of smoke.
+  if test "X${COLLECT_NAMES+set}" != Xset; then
+    COLLECT_NAMES=
+    export COLLECT_NAMES
+  fi
 esac
-fi
+# Sed substitution that helps us do robust quoting.  It backslashifies
+# metacharacters that are still active within double-quoted strings.
+Xsed='sed -e 1s/^X//'
+sed_quote_subst='s/\([\\"\\`$\\\\]\)/\\\1/g'
+# Same as above, but do not quote variable references.
+double_quote_subst='s/\([\\"\\`\\\\]\)/\\\1/g'
+# Sed substitution to delay expansion of an escaped shell variable in a
+# double_quote_subst'ed string.
+delay_variable_subst='s/\\\\\\\\\\\$/\\\\\\$/g'
+# Sed substitution to avoid accidental globbing in evaled expressions
+no_glob_subst='s/\*/\\\*/g'
+# Constants:
+rm="rm -f"
+# Global variables:
+default_ofile=libtool
+can_build_shared=yes
+# All known linkers require a `.a' archive for static linking (except MSVC,
+# which needs '.lib').
+libext=a
+ltmain="$ac_aux_dir/ltmain.sh"
+ofile="$default_ofile"
+with_gnu_ld="$lt_cv_prog_gnu_ld"
+  # Extract the first word of "${ac_tool_prefix}ar", so it can be a program name with args.
+set dummy ${ac_tool_prefix}ar; ac_word=$2
+if test "${ac_cv_prog_AR+set}" = set; then
 else
+  if test -n "$AR"; then
+  ac_cv_prog_AR="$AR" # Let the user override the test.
+else
+do
+  IFS=$as_save_IFS
+    ac_cv_prog_AR="${ac_tool_prefix}ar"
+    break 2
+  fi
+done
+done
+fi
+fi
+AR=$ac_cv_prog_AR
+if test -n "$AR"; then
+  echo "$as_me:$LINENO: result: $AR" >&5
+echo "${ECHO_T}$AR" >&6
+else
 fi
-  else
-    MAGIC_CMD=:
+fi
+if test -z "$ac_cv_prog_AR"; then
+  ac_ct_AR=$AR
+  # Extract the first word of "ar", so it can be a program name with args.
+set dummy ar; ac_word=$2
+if test "${ac_cv_prog_ac_ct_AR+set}" = set; then
+else
+  if test -n "$ac_ct_AR"; then
+  ac_cv_prog_ac_ct_AR="$ac_ct_AR" # Let the user override the test.
+else
+do
+  IFS=$as_save_IFS
+    ac_cv_prog_ac_ct_AR="ar"
+    break 2
   fi
+done
+done
+  test -z "$ac_cv_prog_ac_ct_AR" && ac_cv_prog_ac_ct_AR="false"
 fi
+fi
+ac_ct_AR=$ac_cv_prog_ac_ct_AR
+if test -n "$ac_ct_AR"; then
+  echo "$as_me:$LINENO: result: $ac_ct_AR" >&5
+echo "${ECHO_T}$ac_ct_AR" >&6
+else
+fi
-  fi
-esac
+  AR=$ac_ct_AR
+else
+  AR="$ac_cv_prog_AR"
+fi
   # Extract the first word of "${ac_tool_prefix}ranlib", so it can be a program name with args.
@@ -4995,140 +6126,6 @@
 fi
-enable_dlopen=no
-enable_win32_dll=no
-# Check whether --enable-libtool-lock or --disable-libtool-lock was given.
-if test "${enable_libtool_lock+set}" = set; then
-  enableval="$enable_libtool_lock"
-fi;
-test "x$enable_libtool_lock" != xno && enable_libtool_lock=yes
-# Some flags need to be propagated to the compiler or linker for good
-# libtool support.
-case $host in
-*-*-irix6*)
-  # Find out which ABI we are using.
-  echo '#line 5013 "configure"' > conftest.$ac_ext
-  (eval $ac_compile) 2>&5
-  ac_status=$?
-  echo "$as_me:$LINENO: \$? = $ac_status" >&5
-    case `/usr/bin/file conftest.$ac_objext` in
-    *32-bit*)
-      LD="${LD-ld} -32"
-    *N32*)
-      LD="${LD-ld} -n32"
-    *64-bit*)
-      LD="${LD-ld} -64"
-    esac
-  fi
-  rm -rf conftest*
-*-*-sco3.2v5*)
-  # On SCO OpenServer 5, we need -belf to get full-featured binaries.
-  SAVE_CFLAGS="$CFLAGS"
-  CFLAGS="$CFLAGS -belf"
-  echo "$as_me:$LINENO: checking whether the C compiler needs -belf" >&5
-echo $ECHO_N "checking whether the C compiler needs -belf... $ECHO_C" >&6
-if test "${lt_cv_cc_needs_belf+set}" = set; then
-else
-     ac_ext=c
-ac_cpp='$CPP $CPPFLAGS'
-ac_compile='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5'
-ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
-ac_compiler_gnu=$ac_cv_c_compiler_gnu
-     cat >conftest.$ac_ext <<_ACEOF
-#line $LINENO "configure"
-/* confdefs.h.  */
-_ACEOF
-cat confdefs.h >>conftest.$ac_ext
-cat >>conftest.$ac_ext <<_ACEOF
-/* end confdefs.h.  */
-int
-main ()
-  return 0;
-_ACEOF
-rm -f conftest.$ac_objext conftest$ac_exeext
-if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
-  ac_status=$?
-         { ac_try='test -s conftest$ac_exeext'
-  { (eval echo "$as_me:$LINENO: \"$ac_try\"") >&5
-  (eval $ac_try) 2>&5
-  ac_status=$?
-  (exit $ac_status); }; }; then
-  lt_cv_cc_needs_belf=yes
-else
-  echo "$as_me: failed program was:" >&5
-sed 's/^/| /' conftest.$ac_ext >&5
-lt_cv_cc_needs_belf=no
-fi
-rm -f conftest.$ac_objext conftest$ac_exeext conftest.$ac_ext
-     ac_ext=cc
-fi
-echo "$as_me:$LINENO: result: $lt_cv_cc_needs_belf" >&5
-echo "${ECHO_T}$lt_cv_cc_needs_belf" >&6
-  if test x"$lt_cv_cc_needs_belf" != x"yes"; then
-    # this is probably gcc 2.8.0, egcs 1.0 or newer; no need for -belf
-    CFLAGS="$SAVE_CFLAGS"
-  fi
-esac
-# Sed substitution that helps us do robust quoting.  It backslashifies
-# metacharacters that are still active within double-quoted strings.
-Xsed='sed -e s/^X//'
-sed_quote_subst='s/\([\\"\\`$\\\\]\)/\\\1/g'
-# Same as above, but do not quote variable references.
-double_quote_subst='s/\([\\"\\`\\\\]\)/\\\1/g'
-# Sed substitution to delay expansion of an escaped shell variable in a
-# double_quote_subst'ed string.
-delay_variable_subst='s/\\\\\\\\\\\$/\\\\\\$/g'
-# Constants:
-rm="rm -f"
-# Global variables:
-default_ofile=libtool
-can_build_shared=yes
-# All known linkers require a `.a' archive for static linking (except M$VC,
-# which needs '.lib').
-libext=a
-ltmain="$ac_aux_dir/ltmain.sh"
-ofile="$default_ofile"
-with_gnu_ld="$lt_cv_prog_gnu_ld"
-need_locks="$enable_libtool_lock"
 old_CC="$CC"
 old_CFLAGS="$CFLAGS"
@@ -5137,40 +6134,19 @@
 test -z "$AR_FLAGS" && AR_FLAGS=cru
 test -z "$AS" && AS=as
 test -z "$CC" && CC=cc
+test -z "$LTCC" && LTCC=$CC
+test -z "$LTCFLAGS" && LTCFLAGS=$CFLAGS
 test -z "$DLLTOOL" && DLLTOOL=dlltool
 test -z "$LD" && LD=ld
 test -z "$LN_S" && LN_S="ln -s"
 test -z "$MAGIC_CMD" && MAGIC_CMD=file
 test -z "$NM" && NM=nm
+test -z "$SED" && SED=sed
 test -z "$OBJDUMP" && OBJDUMP=objdump
 test -z "$RANLIB" && RANLIB=:
 test -z "$STRIP" && STRIP=:
 test -z "$ac_objext" && ac_objext=o
-if test x"$host" != x"$build"; then
-  ac_tool_prefix=${host_alias}-
-else
-  ac_tool_prefix=
-fi
-# Transform linux* to *-*-linux-gnu*, to support old configure scripts.
-case $host_os in
-linux-gnu*) ;;
-linux*) host=`echo $host | sed 's/^\(.*-.*-linux\)\(.*\)$/\1-gnu\2/'`
-esac
-case $host_os in
-aix3*)
-  # AIX sometimes has problems with the GCC collect2 program.  For some
-  # reason, if we set the COLLECT_NAMES environment variable, the problems
-  # vanish in a puff of smoke.
-  if test "X${COLLECT_NAMES+set}" != Xset; then
-    COLLECT_NAMES=
-    export COLLECT_NAMES
-  fi
-esac
 # Determine commands to create old-style static archives.
 old_archive_cmds='$AR $AR_FLAGS $oldlib$oldobjs$old_deplibs'
 old_postinstall_cmds='chmod 644 $oldlib'
@@ -5179,35 +6155,172 @@
 if test -n "$RANLIB"; then
   case $host_os in
   openbsd*)
-    old_postinstall_cmds="\$RANLIB -t \$oldlib~$old_postinstall_cmds"
+    old_postinstall_cmds="$old_postinstall_cmds~\$RANLIB -t \$oldlib"
-    old_postinstall_cmds="\$RANLIB \$oldlib~$old_postinstall_cmds"
+    old_postinstall_cmds="$old_postinstall_cmds~\$RANLIB \$oldlib"
   esac
   old_archive_cmds="$old_archive_cmds~\$RANLIB \$oldlib"
 fi
-# Allow CC to be a program name with arguments.
-set dummy $CC
-compiler="$2"
+for cc_temp in $compiler""; do
+  case $cc_temp in
+    compile | *[\\/]compile | ccache | *[\\/]ccache ) ;;
+    distcc | *[\\/]distcc | purify | *[\\/]purify ) ;;
+    *) break;;
+  esac
+done
+cc_basename=`$echo "X$cc_temp" | $Xsed -e 's%.*/%%' -e "s%^$host_alias-%%"`
-echo "$as_me:$LINENO: checking for objdir" >&5
-echo $ECHO_N "checking for objdir... $ECHO_C" >&6
-rm -f .libs 2>/dev/null
-mkdir .libs 2>/dev/null
-if test -d .libs; then
-  objdir=.libs
+# Only perform the check for file, if the check method requires it
+case $deplibs_check_method in
+file_magic*)
+  if test "$file_magic_cmd" = '$MAGIC_CMD'; then
+    echo "$as_me:$LINENO: checking for ${ac_tool_prefix}file" >&5
+echo $ECHO_N "checking for ${ac_tool_prefix}file... $ECHO_C" >&6
+if test "${lt_cv_path_MAGIC_CMD+set}" = set; then
 else
-  # MS-DOS does not allow filenames that begin with a dot.
-  objdir=_libs
+  case $MAGIC_CMD in
+  lt_cv_path_MAGIC_CMD="$MAGIC_CMD" # Let the user override the test with a path.
+  lt_save_MAGIC_CMD="$MAGIC_CMD"
+  lt_save_ifs="$IFS"; IFS=$PATH_SEPARATOR
+  ac_dummy="/usr/bin$PATH_SEPARATOR$PATH"
+  for ac_dir in $ac_dummy; do
+    IFS="$lt_save_ifs"
+    if test -f $ac_dir/${ac_tool_prefix}file; then
+      lt_cv_path_MAGIC_CMD="$ac_dir/${ac_tool_prefix}file"
+      if test -n "$file_magic_test_file"; then
+	case $deplibs_check_method in
+	"file_magic "*)
+	  file_magic_regex=`expr "$deplibs_check_method" : "file_magic \(.*\)"`
+	  MAGIC_CMD="$lt_cv_path_MAGIC_CMD"
+	  if eval $file_magic_cmd \$file_magic_test_file 2> /dev/null |
+	    $EGREP "$file_magic_regex" > /dev/null; then
+	  else
+	    cat <<EOF 1>&2
+*** Warning: the command libtool uses to detect shared libraries,
+*** $file_magic_cmd, produces output that libtool cannot recognize.
+*** The result is that libtool may fail to recognize shared libraries
+*** as such.  This will affect the creation of libtool libraries that
+*** depend on shared libraries, but programs linked with such libtool
+*** libraries will work regardless of this problem.  Nevertheless, you
+*** may want to report the problem to your system manager and/or to
+*** bug-libtool at gnu.org
+EOF
+	  fi ;;
+	esac
+      fi
+      break
+    fi
+  done
+  MAGIC_CMD="$lt_save_MAGIC_CMD"
+esac
 fi
-rmdir .libs 2>/dev/null
-echo "$as_me:$LINENO: result: $objdir" >&5
-echo "${ECHO_T}$objdir" >&6
+MAGIC_CMD="$lt_cv_path_MAGIC_CMD"
+if test -n "$MAGIC_CMD"; then
+  echo "$as_me:$LINENO: result: $MAGIC_CMD" >&5
+echo "${ECHO_T}$MAGIC_CMD" >&6
+else
+fi
+if test -z "$lt_cv_path_MAGIC_CMD"; then
+  if test -n "$ac_tool_prefix"; then
+    echo "$as_me:$LINENO: checking for file" >&5
+echo $ECHO_N "checking for file... $ECHO_C" >&6
+  echo $ECHO_N "(cached) $ECHO_C" >&6
+else
+    if test -f $ac_dir/file; then
+      lt_cv_path_MAGIC_CMD="$ac_dir/file"
+	"file_magic "*)
+	  else
+	    cat <<EOF 1>&2
+EOF
+	  fi ;;
+	esac
+      fi
+      break
+    fi
+  done
+esac
+fi
+else
+fi
+  else
+    MAGIC_CMD=:
+  fi
+fi
+  fi
+esac
+enable_dlopen=no
+enable_win32_dll=no
+fi;
 # Check whether --with-pic or --without-pic was given.
 if test "${with_pic+set}" = set; then
   withval="$with_pic"
@@ -5217,370 +6330,904 @@
 fi;
 test -z "$pic_mode" && pic_mode=default
-# We assume here that the value for lt_cv_prog_cc_pic will not be cached
-# in isolation, and that seeing it set (from the cache) indicates that
-# the associated values are set (in the cache) correctly too.
-echo "$as_me:$LINENO: checking for $compiler option to produce PIC" >&5
-echo $ECHO_N "checking for $compiler option to produce PIC... $ECHO_C" >&6
-if test "${lt_cv_prog_cc_pic+set}" = set; then
+# Use C for the default configuration in the libtool script
+tagname=
+lt_save_CC="$CC"
+ac_ext=c
+# Source file extension for C test sources.
+ac_ext=c
+# Object file extension for compiled C test sources.
+objext=o
+objext=$objext
+# Code to be used in simple compile tests
+lt_simple_compile_test_code="int some_variable = 0;\n"
+# Code to be used in simple link tests
+lt_simple_link_test_code='int main(){return(0);}\n'
+LTCC=${LTCC-"$CC"}
+compiler=$CC
+# save warnings/boilerplate of simple test code
+ac_outfile=conftest.$ac_objext
+printf "$lt_simple_compile_test_code" >conftest.$ac_ext
+eval "$ac_compile" 2>&1 >/dev/null | $SED '/^$/d; /^ *+/d' >conftest.err
+_lt_compiler_boilerplate=`cat conftest.err`
+$rm conftest*
+printf "$lt_simple_link_test_code" >conftest.$ac_ext
+eval "$ac_link" 2>&1 >/dev/null | $SED '/^$/d; /^ *+/d' >conftest.err
+_lt_linker_boilerplate=`cat conftest.err`
+$rm conftest*
+lt_prog_compiler_no_builtin_flag=
+if test "$GCC" = yes; then
+  lt_prog_compiler_no_builtin_flag=' -fno-builtin'
+echo "$as_me:$LINENO: checking if $compiler supports -fno-rtti -fno-exceptions" >&5
+echo $ECHO_N "checking if $compiler supports -fno-rtti -fno-exceptions... $ECHO_C" >&6
+if test "${lt_cv_prog_compiler_rtti_exceptions+set}" = set; then
 else
-   lt_cv_prog_cc_pic=
-  lt_cv_prog_cc_shlib=
-  lt_cv_prog_cc_wl=
-  lt_cv_prog_cc_static=
-  lt_cv_prog_cc_no_builtin=
-  lt_cv_prog_cc_can_build_shared=$can_build_shared
+  lt_cv_prog_compiler_rtti_exceptions=no
+  ac_outfile=conftest.$ac_objext
+   printf "$lt_simple_compile_test_code" > conftest.$ac_ext
+   lt_compiler_flag="-fno-rtti -fno-exceptions"
+   # Insert the option either (1) after the last *FLAGS variable, or
+   # (2) before a word containing "conftest.", or (3) at the end.
+   # Note that $ac_compile itself does not contain backslashes and begins
+   # with a dollar sign (not a hyphen), so the echo should work correctly.
+   # The option is referenced via a variable to avoid confusing sed.
+   lt_compile=`echo "$ac_compile" | $SED \
+   -e 's:.*FLAGS}\{0,1\} :&$lt_compiler_flag :; t' \
+   -e 's: [^ ]*conftest\.: $lt_compiler_flag&:; t' \
+   -e 's:$: $lt_compiler_flag:'`
+   (eval echo "\"\$as_me:6406: $lt_compile\"" >&5)
+   (eval "$lt_compile" 2>conftest.err)
+   ac_status=$?
+   cat conftest.err >&5
+   echo "$as_me:6410: \$? = $ac_status" >&5
+   if (exit $ac_status) && test -s "$ac_outfile"; then
+     # The compiler can only warn and ignore the option if not recognized
+     # So say no if there are warnings other than the usual output.
+     $echo "X$_lt_compiler_boilerplate" | $Xsed -e '/^$/d' >conftest.exp
+     $SED '/^$/d; /^ *+/d' conftest.err >conftest.er2
+     if test ! -s conftest.er2 || diff conftest.exp conftest.er2 >/dev/null; then
+       lt_cv_prog_compiler_rtti_exceptions=yes
+     fi
+   fi
+   $rm conftest*
+fi
+echo "$as_me:$LINENO: result: $lt_cv_prog_compiler_rtti_exceptions" >&5
+echo "${ECHO_T}$lt_cv_prog_compiler_rtti_exceptions" >&6
+if test x"$lt_cv_prog_compiler_rtti_exceptions" = xyes; then
+    lt_prog_compiler_no_builtin_flag="$lt_prog_compiler_no_builtin_flag -fno-rtti -fno-exceptions"
+else
+fi
+fi
+lt_prog_compiler_wl=
+lt_prog_compiler_pic=
+lt_prog_compiler_static=
+echo "$as_me:$LINENO: checking for $compiler option to produce PIC" >&5
+echo $ECHO_N "checking for $compiler option to produce PIC... $ECHO_C" >&6
-    lt_cv_prog_cc_wl='-Wl,'
-    lt_cv_prog_cc_static='-static'
+    lt_prog_compiler_wl='-Wl,'
+    lt_prog_compiler_static='-static'
     case $host_os in
-    aix*)
-      # Below there is a dirty hack to force normal static linking with -ldl
-      # The problem is because libdl dynamically linked with both libc and
-      # libC (AIX C++ library), which obviously doesn't included in libraries
-      # list by gcc. This cause undefined symbols with -static flags.
-      # This hack allows C programs to be linked with "-static -ldl", but
-      # not sure about C++ programs.
-      lt_cv_prog_cc_static="$lt_cv_prog_cc_static ${lt_cv_prog_cc_wl}-lC"
+      aix*)
+      # All AIX code is PIC.
+	# AIX 5 now supports IA64 processor
+	lt_prog_compiler_static='-Bstatic'
+      fi
     amigaos*)
       # FIXME: we need at least 68020 code to build shared libraries, but
       # adding the `-m68020' flag to GCC prevents building anything better,
       # like `-m68040'.
-      lt_cv_prog_cc_pic='-m68020 -resident32 -malways-restore-a4'
+      lt_prog_compiler_pic='-m68020 -resident32 -malways-restore-a4'
-    beos* | irix5* | irix6* | nonstopux* | osf3* | osf4* | osf5*)
+    beos* | cygwin* | irix5* | irix6* | nonstopux* | osf3* | osf4* | osf5*)
       # PIC is the default for these OSes.
+    mingw* | pw32* | os2*)
+      # This hack is so that the source file can tell whether it is being
+      # built for inclusion in a dll (and should export symbols for example).
+      lt_prog_compiler_pic='-DDLL_EXPORT'
       # PIC is the default on this platform
       # Common symbols not allowed in MH_DYLIB files
-      lt_cv_prog_cc_pic='-fno-common'
+      lt_prog_compiler_pic='-fno-common'
-    cygwin* | mingw* | pw32* | os2*)
-      # This hack is so that the source file can tell whether it is being
-      # built for inclusion in a dll (and should export symbols for example).
-      lt_cv_prog_cc_pic='-DDLL_EXPORT'
+    interix3*)
+      # Interix 3.x gcc -fpic/-fPIC options generate broken code.
+      # Instead, we relocate shared libraries at runtime.
+    msdosdjgpp*)
+      # Just because we use GCC doesn't mean we suddenly get shared libraries
+      # on systems that don't support them.
+      lt_prog_compiler_can_build_shared=no
+      enable_shared=no
     sysv4*MP*)
       if test -d /usr/nec; then
-	 lt_cv_prog_cc_pic=-Kconform_pic
+	lt_prog_compiler_pic=-Kconform_pic
       fi
+    hpux*)
+      # PIC is the default for IA64 HP-UX and 64-bit HP-UX, but
+      # not for PA HP-UX.
+      case $host_cpu in
+      hppa*64*|ia64*)
+	# +Z the default
+	lt_prog_compiler_pic='-fPIC'
+      esac
-      lt_cv_prog_cc_pic='-fPIC'
     esac
   else
-    # PORTME Check for PIC flags for the system compiler.
+    # PORTME Check for flag to pass linker flags through the system compiler.
     case $host_os in
-    aix3* | aix4* | aix5*)
-      # All AIX code is PIC.
+    aix*)
-	lt_cv_prog_cc_static='-Bstatic'
       else
-	lt_cv_prog_cc_static='-bnso -bI:/lib/syscalls.exp'
+	lt_prog_compiler_static='-bnso -bI:/lib/syscalls.exp'
       fi
+      darwin*)
+        # PIC is the default on this platform
+        # Common symbols not allowed in MH_DYLIB files
+       case $cc_basename in
+         xlc*)
+         lt_prog_compiler_pic='-qnocommon'
+       esac
     hpux9* | hpux10* | hpux11*)
-      # Is there a better lt_cv_prog_cc_static that works with the bundled CC?
-      lt_cv_prog_cc_static="${lt_cv_prog_cc_wl}-a ${lt_cv_prog_cc_wl}archive"
-      lt_cv_prog_cc_pic='+Z'
+      case $host_cpu in
+      hppa*64*|ia64*)
+	# +Z the default
+	lt_prog_compiler_pic='+Z'
+      esac
+      # Is there a better lt_prog_compiler_static that works with the bundled CC?
+      lt_prog_compiler_static='${wl}-a ${wl}archive'
-      lt_cv_prog_cc_static='-non_shared'
       # PIC (with -KPIC) is the default.
+      lt_prog_compiler_static='-non_shared'
+    newsos6)
+      lt_prog_compiler_pic='-KPIC'
-    newsos6)
-      lt_cv_prog_cc_pic='-KPIC'
+    linux*)
+      icc* | ecc*)
+      pgcc* | pgf77* | pgf90* | pgf95*)
+        # Portland Group compilers (*not* the Pentium gcc compiler,
+	# which looks to be a dead project)
+	lt_prog_compiler_pic='-fpic'
+      ccc*)
+        # All Alpha code is PIC.
+      esac
       # All OSF/1 code is PIC.
-    sco3.2v5*)
-      lt_cv_prog_cc_pic='-Kpic'
-      lt_cv_prog_cc_static='-dn'
-      lt_cv_prog_cc_shlib='-belf'
     solaris*)
+      f77* | f90* | f95*)
+	lt_prog_compiler_wl='-Qoption ld ';;
+	lt_prog_compiler_wl='-Wl,';;
+      esac
     sunos4*)
-      lt_cv_prog_cc_pic='-PIC'
-      lt_cv_prog_cc_wl='-Qoption ld '
+      lt_prog_compiler_pic='-PIC'
-    sysv4 | sysv4.2uw2* | sysv4.3* | sysv5*)
+    sysv4 | sysv4.2uw2* | sysv4.3*)
-    uts4*)
-      lt_cv_prog_cc_pic='-pic'
     sysv4*MP*)
       if test -d /usr/nec ;then
-	lt_cv_prog_cc_pic='-Kconform_pic'
+	lt_prog_compiler_pic='-Kconform_pic'
       fi
+    sysv5* | unixware* | sco3.2v5* | sco5v6* | OpenUNIX*)
+    unicos*)
+    uts4*)
+      lt_prog_compiler_pic='-pic'
-      lt_cv_prog_cc_can_build_shared=no
     esac
   fi
-fi
+echo "$as_me:$LINENO: result: $lt_prog_compiler_pic" >&5
+echo "${ECHO_T}$lt_prog_compiler_pic" >&6
-if test -z "$lt_cv_prog_cc_pic"; then
-  echo "$as_me:$LINENO: result: none" >&5
-echo "${ECHO_T}none" >&6
-else
-  echo "$as_me:$LINENO: result: $lt_cv_prog_cc_pic" >&5
-echo "${ECHO_T}$lt_cv_prog_cc_pic" >&6
+# Check to make sure the PIC flag actually works.
+if test -n "$lt_prog_compiler_pic"; then
-  # Check to make sure the pic_flag actually works.
-  echo "$as_me:$LINENO: checking if $compiler PIC flag $lt_cv_prog_cc_pic works" >&5
-echo $ECHO_N "checking if $compiler PIC flag $lt_cv_prog_cc_pic works... $ECHO_C" >&6
-  if test "${lt_cv_prog_cc_pic_works+set}" = set; then
+echo "$as_me:$LINENO: checking if $compiler PIC flag $lt_prog_compiler_pic works" >&5
+echo $ECHO_N "checking if $compiler PIC flag $lt_prog_compiler_pic works... $ECHO_C" >&6
+if test "${lt_prog_compiler_pic_works+set}" = set; then
 else
-    CFLAGS="$CFLAGS $lt_cv_prog_cc_pic -DPIC"
-/* confdefs.h.  */
-_ACEOF
+  lt_prog_compiler_pic_works=no
+   lt_compiler_flag="$lt_prog_compiler_pic -DPIC"
+   (eval echo "\"\$as_me:6674: $lt_compile\"" >&5)
+   ac_status=$?
+   echo "$as_me:6678: \$? = $ac_status" >&5
+       lt_prog_compiler_pic_works=yes
+     fi
+   fi
+   $rm conftest*
-int
-main ()
+fi
+echo "$as_me:$LINENO: result: $lt_prog_compiler_pic_works" >&5
+echo "${ECHO_T}$lt_prog_compiler_pic_works" >&6
-  return 0;
-_ACEOF
-if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
-  ac_status=$?
-         { ac_try='test -s conftest.$ac_objext'
-  ac_status=$?
-        case $host_os in
-      hpux9* | hpux10* | hpux11*)
-	# On HP-UX, both CC and GCC only warn that PIC is supported... then
-	# they create non-PIC objects.  So, if there were any warnings, we
-	# assume that PIC is not supported.
-	if test -s conftest.err; then
-	  lt_cv_prog_cc_pic_works=no
-	else
-	  lt_cv_prog_cc_pic_works=yes
-	fi
-      esac
+if test x"$lt_prog_compiler_pic_works" = xyes; then
+    case $lt_prog_compiler_pic in
+     *) lt_prog_compiler_pic=" $lt_prog_compiler_pic" ;;
+     esac
+else
+fi
+fi
+case $host_os in
+  # For platforms which do not support PIC, -DPIC is meaningless:
+  *djgpp*)
+    lt_prog_compiler_pic="$lt_prog_compiler_pic -DPIC"
+esac
+# Check to make sure the static flag actually works.
+wl=$lt_prog_compiler_wl eval lt_tmp_static_flag=\"$lt_prog_compiler_static\"
+echo "$as_me:$LINENO: checking if $compiler static flag $lt_tmp_static_flag works" >&5
+echo $ECHO_N "checking if $compiler static flag $lt_tmp_static_flag works... $ECHO_C" >&6
+if test "${lt_prog_compiler_static_works+set}" = set; then
 else
+  lt_prog_compiler_static_works=no
+   save_LDFLAGS="$LDFLAGS"
+   LDFLAGS="$LDFLAGS $lt_tmp_static_flag"
+   printf "$lt_simple_link_test_code" > conftest.$ac_ext
+   if (eval $ac_link 2>conftest.err) && test -s conftest$ac_exeext; then
+     # The linker can only warn and ignore the option if not recognized
+       # Append any errors to the config.log.
+       cat conftest.err 1>&5
+       $echo "X$_lt_linker_boilerplate" | $Xsed -e '/^$/d' > conftest.exp
+       if diff conftest.exp conftest.er2 >/dev/null; then
+         lt_prog_compiler_static_works=yes
+       fi
+     else
+     fi
+   fi
+   $rm conftest*
+   LDFLAGS="$save_LDFLAGS"
 fi
-rm -f conftest.$ac_objext conftest.$ac_ext
+echo "$as_me:$LINENO: result: $lt_prog_compiler_static_works" >&5
+echo "${ECHO_T}$lt_prog_compiler_static_works" >&6
+if test x"$lt_prog_compiler_static_works" = xyes; then
+else
 fi
-  if test "X$lt_cv_prog_cc_pic_works" = Xno; then
-  else
-    lt_cv_prog_cc_pic=" $lt_cv_prog_cc_pic"
-  fi
+echo "$as_me:$LINENO: checking if $compiler supports -c -o file.$ac_objext" >&5
+echo $ECHO_N "checking if $compiler supports -c -o file.$ac_objext... $ECHO_C" >&6
+if test "${lt_cv_prog_compiler_c_o+set}" = set; then
+else
+  lt_cv_prog_compiler_c_o=no
+   $rm -r conftest 2>/dev/null
+   mkdir conftest
+   cd conftest
+   mkdir out
-  echo "$as_me:$LINENO: result: $lt_cv_prog_cc_pic_works" >&5
-echo "${ECHO_T}$lt_cv_prog_cc_pic_works" >&6
+   lt_compiler_flag="-o out/conftest2.$ac_objext"
+   (eval echo "\"\$as_me:6778: $lt_compile\"" >&5)
+   (eval "$lt_compile" 2>out/conftest.err)
+   ac_status=$?
+   cat out/conftest.err >&5
+   echo "$as_me:6782: \$? = $ac_status" >&5
+   if (exit $ac_status) && test -s out/conftest2.$ac_objext
+   then
+     $echo "X$_lt_compiler_boilerplate" | $Xsed -e '/^$/d' > out/conftest.exp
+     $SED '/^$/d; /^ *+/d' out/conftest.err >out/conftest.er2
+     if test ! -s out/conftest.er2 || diff out/conftest.exp out/conftest.er2 >/dev/null; then
+       lt_cv_prog_compiler_c_o=yes
+     fi
+   fi
+   chmod u+w . 2>&5
+   $rm conftest*
+   # SGI C++ compiler will create directory out/ii_files/ for
+   # template instantiation
+   test -d out/ii_files && $rm out/ii_files/* && rmdir out/ii_files
+   $rm out/* && rmdir out
+   cd ..
+   rmdir conftest
+   $rm conftest*
 fi
+echo "$as_me:$LINENO: result: $lt_cv_prog_compiler_c_o" >&5
+echo "${ECHO_T}$lt_cv_prog_compiler_c_o" >&6
-# Check for any special shared library compilation flags.
-if test -n "$lt_cv_prog_cc_shlib"; then
-  { echo "$as_me:$LINENO: WARNING: \`$CC' requires \`$lt_cv_prog_cc_shlib' to build shared libraries" >&5
-echo "$as_me: WARNING: \`$CC' requires \`$lt_cv_prog_cc_shlib' to build shared libraries" >&2;}
-  if echo "$old_CC $old_CFLAGS " | egrep -e "[ 	]$lt_cv_prog_cc_shlib[ 	]" >/dev/null; then :
-  else
-   { echo "$as_me:$LINENO: WARNING: add \`$lt_cv_prog_cc_shlib' to the CC or CFLAGS env variable and reconfigure" >&5
-echo "$as_me: WARNING: add \`$lt_cv_prog_cc_shlib' to the CC or CFLAGS env variable and reconfigure" >&2;}
+hard_links="nottested"
+if test "$lt_cv_prog_compiler_c_o" = no && test "$need_locks" != no; then
+  # do not overwrite the value of need_locks provided by the user
+  echo "$as_me:$LINENO: checking if we can lock with hard links" >&5
+echo $ECHO_N "checking if we can lock with hard links... $ECHO_C" >&6
+  hard_links=yes
+  $rm conftest*
+  ln conftest.a conftest.b 2>/dev/null && hard_links=no
+  touch conftest.a
+  ln conftest.a conftest.b 2>&5 || hard_links=no
+  echo "$as_me:$LINENO: result: $hard_links" >&5
+echo "${ECHO_T}$hard_links" >&6
+  if test "$hard_links" = no; then
+    { echo "$as_me:$LINENO: WARNING: \`$CC' does not support \`-c -o', so \`make -j' may be unsafe" >&5
+echo "$as_me: WARNING: \`$CC' does not support \`-c -o', so \`make -j' may be unsafe" >&2;}
+    need_locks=warn
   fi
+else
+  need_locks=no
 fi
-echo "$as_me:$LINENO: checking if $compiler static flag $lt_cv_prog_cc_static works" >&5
-echo $ECHO_N "checking if $compiler static flag $lt_cv_prog_cc_static works... $ECHO_C" >&6
-if test "${lt_cv_prog_cc_static_works+set}" = set; then
-  echo $ECHO_N "(cached) $ECHO_C" >&6
-else
-    lt_cv_prog_cc_static_works=no
-  save_LDFLAGS="$LDFLAGS"
-  LDFLAGS="$LDFLAGS $lt_cv_prog_cc_static"
-/* confdefs.h.  */
-_ACEOF
+echo "$as_me:$LINENO: checking whether the $compiler linker ($LD) supports shared libraries" >&5
+echo $ECHO_N "checking whether the $compiler linker ($LD) supports shared libraries... $ECHO_C" >&6
-int
-main ()
+  runpath_var=
+  allow_undefined_flag=
+  enable_shared_with_static_runtimes=no
+  archive_cmds=
+  archive_expsym_cmds=
+  old_archive_From_new_cmds=
+  old_archive_from_expsyms_cmds=
+  export_dynamic_flag_spec=
+  whole_archive_flag_spec=
+  thread_safe_flag_spec=
+  hardcode_libdir_flag_spec=
+  hardcode_libdir_flag_spec_ld=
+  hardcode_libdir_separator=
+  hardcode_direct=no
+  hardcode_minus_L=no
+  hardcode_shlibpath_var=unsupported
+  link_all_deplibs=unknown
+  hardcode_automatic=no
+  module_cmds=
+  module_expsym_cmds=
+  always_export_symbols=no
+  export_symbols_cmds='$NM $libobjs $convenience | $global_symbol_pipe | $SED '\''s/.* //'\'' | sort | uniq > $export_symbols'
+  # include_expsyms should be a list of space-separated symbols to be *always*
+  # included in the symbol list
+  include_expsyms=
+  # exclude_expsyms can be an extended regexp of symbols to exclude
+  # it will be wrapped by ` (' and `)$', so one must not match beginning or
+  # end of line.  Example: `a|bc|.*d.*' will exclude the symbols `a' and `bc',
+  # as well as any symbol that contains `d'.
+  exclude_expsyms="_GLOBAL_OFFSET_TABLE_"
+  # Although _GLOBAL_OFFSET_TABLE_ is a valid symbol C name, most a.out
+  # platforms (ab)use it in PIC code, but their linkers get confused if
+  # the symbol is explicitly referenced.  Since portable code cannot
+  # rely on this symbol name, it's probably fine to never include it in
+  # preloaded symbol tables.
+  extract_expsyms_cmds=
+  # Just being paranoid about ensuring that cc_basename is set.
+  for cc_temp in $compiler""; do
+  case $cc_temp in
+    *) break;;
+  esac
+done
-  return 0;
-_ACEOF
-  ac_status=$?
-  ac_status=$?
-  lt_cv_prog_cc_static_works=yes
-else
+  case $host_os in
+  cygwin* | mingw* | pw32*)
+    # FIXME: the MSVC++ port hasn't been tested in a loooong time
+    # When not using gcc, we currently assume that we are using
+    # Microsoft Visual C++.
+    if test "$GCC" != yes; then
+      with_gnu_ld=no
+    fi
+  interix*)
+    # we just hope/assume this is gcc and not c89 (= MSVC++)
+    with_gnu_ld=yes
+  openbsd*)
+    with_gnu_ld=no
+  esac
-fi
-  LDFLAGS="$save_LDFLAGS"
+  ld_shlibs=yes
+  if test "$with_gnu_ld" = yes; then
+    # If archive_cmds runs LD, not CC, wlarc should be empty
+    wlarc='${wl}'
-fi
+    # Set some defaults for GNU ld with shared library support. These
+    # are reset later if shared libraries are not supported. Putting them
+    # here allows them to be overridden if necessary.
+    runpath_var=LD_RUN_PATH
+    hardcode_libdir_flag_spec='${wl}--rpath ${wl}$libdir'
+    export_dynamic_flag_spec='${wl}--export-dynamic'
+    # ancient GNU ld didn't support --whole-archive et. al.
+    if $LD --help 2>&1 | grep 'no-whole-archive' > /dev/null; then
+	whole_archive_flag_spec="$wlarc"'--whole-archive$convenience '"$wlarc"'--no-whole-archive'
+      else
+    fi
+    supports_anon_versioning=no
+    case `$LD -v 2>/dev/null` in
+      *\ [01].* | *\ 2.[0-9].* | *\ 2.10.*) ;; # catch versions < 2.11
+      *\ 2.11.93.0.2\ *) supports_anon_versioning=yes ;; # RH7.3 ...
+      *\ 2.11.92.0.12\ *) supports_anon_versioning=yes ;; # Mandrake 8.2 ...
+      *\ 2.11.*) ;; # other 2.11 versions
+      *) supports_anon_versioning=yes ;;
+    esac
+    # See if GNU ld supports shared libraries.
+    case $host_os in
+    aix3* | aix4* | aix5*)
+      # On AIX/PPC, the GNU linker is very broken
+      if test "$host_cpu" != ia64; then
+	ld_shlibs=no
+	cat <<EOF 1>&2
-# Belt *and* braces to stop my trousers falling down:
-test "X$lt_cv_prog_cc_static_works" = Xno && lt_cv_prog_cc_static=
-echo "$as_me:$LINENO: result: $lt_cv_prog_cc_static_works" >&5
-echo "${ECHO_T}$lt_cv_prog_cc_static_works" >&6
+*** Warning: the GNU linker, at least up to release 2.9.1, is reported
+*** to be unable to reliably create shared libraries on AIX.
+*** Therefore, libtool is disabling shared libraries support.  If you
+*** really care for shared libraries, you may want to modify your PATH
+*** so that a non-GNU linker is found, and then restart.
-pic_flag="$lt_cv_prog_cc_pic"
-special_shlib_compile_flags="$lt_cv_prog_cc_shlib"
-wl="$lt_cv_prog_cc_wl"
-link_static_flag="$lt_cv_prog_cc_static"
-no_builtin_flag="$lt_cv_prog_cc_no_builtin"
-can_build_shared="$lt_cv_prog_cc_can_build_shared"
+EOF
+      fi
+    amigaos*)
+      archive_cmds='$rm $output_objdir/a2ixlibrary.data~$echo "#define NAME $libname" > $output_objdir/a2ixlibrary.data~$echo "#define LIBRARY_ID 1" >> $output_objdir/a2ixlibrary.data~$echo "#define VERSION $major" >> $output_objdir/a2ixlibrary.data~$echo "#define REVISION $revision" >> $output_objdir/a2ixlibrary.data~$AR $AR_FLAGS $lib $libobjs~$RANLIB $lib~(cd $output_objdir && a2ixlibrary -32)'
+      hardcode_libdir_flag_spec='-L$libdir'
+      hardcode_minus_L=yes
-# Check to see if options -o and -c are simultaneously supported by compiler
-echo "$as_me:$LINENO: checking if $compiler supports -c -o file.$ac_objext" >&5
-echo $ECHO_N "checking if $compiler supports -c -o file.$ac_objext... $ECHO_C" >&6
-if test "${lt_cv_compiler_c_o+set}" = set; then
-else
+      # Samuel A. Falvo II <kc5tja at dolphin.openprojects.net> reports
+      # that the semantics of dynamic libraries on AmigaOS, at least up
+      # to version 4, is to share data among multiple programs linked
+      # with the same dynamic library.  Since this doesn't match the
+      # behavior of shared libraries on other platforms, we can't use
+      # them.
+      ld_shlibs=no
-$rm -r conftest 2>/dev/null
-mkdir conftest
-cd conftest
-echo "int some_variable = 0;" > conftest.$ac_ext
-mkdir out
-# According to Tom Tromey, Ian Lance Taylor reported there are C compilers
-# that will create temporary files in the current directory regardless of
-# the output directory.  Thus, making CWD read-only will cause this test
-# to fail, enabling locking or at least warning the user not to do parallel
-# builds.
-chmod -w .
-save_CFLAGS="$CFLAGS"
-CFLAGS="$CFLAGS -o out/conftest2.$ac_objext"
-compiler_c_o=no
-if { (eval echo configure:5542: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>out/conftest.err; } && test -s out/conftest2.$ac_objext; then
-  # The compiler can only warn and ignore the option if not recognized
-  # So say no if there are warnings
-  if test -s out/conftest.err; then
-    lt_cv_compiler_c_o=no
+    beos*)
+      if $LD --help 2>&1 | grep ': supported targets:.* elf' > /dev/null; then
+	allow_undefined_flag=unsupported
+	# Joseph Beckenbach <jrb3 at best.com> says some releases of gcc
+	# support --undefined.  This deserves some investigation.  FIXME
+	archive_cmds='$CC -nostart $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
+      else
+	ld_shlibs=no
+      fi
+      # _LT_AC_TAGVAR(hardcode_libdir_flag_spec, ) is actually meaningless,
+      # as there is no search path for DLLs.
+      enable_shared_with_static_runtimes=yes
+      export_symbols_cmds='$NM $libobjs $convenience | $global_symbol_pipe | $SED -e '\''/^[BCDGRS] /s/.* \([^ ]*\)/\1 DATA/'\'' | $SED -e '\''/^[AITW] /s/.* //'\'' | sort | uniq > $export_symbols'
+      if $LD --help 2>&1 | grep 'auto-import' > /dev/null; then
+        archive_cmds='$CC -shared $libobjs $deplibs $compiler_flags -o $output_objdir/$soname ${wl}--enable-auto-image-base -Xlinker --out-implib -Xlinker $lib'
+	# If the export-symbols file already is a .def file (1st line
+	# is EXPORTS), use it as is; otherwise, prepend...
+	archive_expsym_cmds='if test "x`$SED 1q $export_symbols`" = xEXPORTS; then
+	  cp $export_symbols $output_objdir/$soname.def;
+	else
+	  echo EXPORTS > $output_objdir/$soname.def;
+	  cat $export_symbols >> $output_objdir/$soname.def;
+	fi~
+	$CC -shared $output_objdir/$soname.def $libobjs $deplibs $compiler_flags -o $output_objdir/$soname ${wl}--enable-auto-image-base -Xlinker --out-implib -Xlinker $lib'
+      else
+	ld_shlibs=no
+      fi
+    interix3*)
+      hardcode_shlibpath_var=no
+      hardcode_libdir_flag_spec='${wl}-rpath,$libdir'
+      export_dynamic_flag_spec='${wl}-E'
+      # Hack: On Interix 3.x, we cannot compile PIC because of a broken gcc.
+      # Instead, shared libraries are loaded at an image base (0x10000000 by
+      # default) and relocated if they conflict, which is a slow very memory
+      # consuming and fragmenting process.  To avoid this, we pick a random,
+      # 256 KiB-aligned image base between 0x50000000 and 0x6FFC0000 at link
+      # time.  Moving up from 0x10000000 also allows more sbrk(2) space.
+      archive_cmds='$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-h,$soname ${wl}--image-base,`expr ${RANDOM-$$} % 4096 / 2 \* 262144 + 1342177280` -o $lib'
+      archive_expsym_cmds='sed "s,^,_," $export_symbols >$output_objdir/$soname.expsym~$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-h,$soname ${wl}--retain-symbols-file,$output_objdir/$soname.expsym ${wl}--image-base,`expr ${RANDOM-$$} % 4096 / 2 \* 262144 + 1342177280` -o $lib'
+    linux*)
+	tmp_addflag=
+	case $cc_basename,$host_cpu in
+	pgcc*)				# Portland Group C compiler
+	  whole_archive_flag_spec='${wl}--whole-archive`for conv in $convenience\"\"; do test  -n \"$conv\" && new_convenience=\"$new_convenience,$conv\"; done; $echo \"$new_convenience\"` ${wl}--no-whole-archive'
+	  tmp_addflag=' $pic_flag'
+	pgf77* | pgf90* | pgf95*)	# Portland Group f77 and f90 compilers
+	  tmp_addflag=' $pic_flag -Mnomain' ;;
+	ecc*,ia64* | icc*,ia64*)		# Intel C compiler on ia64
+	  tmp_addflag=' -i_dynamic' ;;
+	efc*,ia64* | ifort*,ia64*)	# Intel Fortran compiler on ia64
+	  tmp_addflag=' -i_dynamic -nofor_main' ;;
+	ifc* | ifort*)			# Intel Fortran compiler
+	  tmp_addflag=' -nofor_main' ;;
+	esac
+	archive_cmds='$CC -shared'"$tmp_addflag"' $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
+	if test $supports_anon_versioning = yes; then
+	  archive_expsym_cmds='$echo "{ global:" > $output_objdir/$libname.ver~
+  cat $export_symbols | sed -e "s/\(.*\)/\1;/" >> $output_objdir/$libname.ver~
+  $echo "local: *; };" >> $output_objdir/$libname.ver~
+	  $CC -shared'"$tmp_addflag"' $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-version-script ${wl}$output_objdir/$libname.ver -o $lib'
+	fi
+      else
+	ld_shlibs=no
+      fi
+    netbsd*)
+      if echo __ELF__ | $CC -E - | grep __ELF__ >/dev/null; then
+	archive_cmds='$LD -Bshareable $libobjs $deplibs $linker_flags -o $lib'
+	wlarc=
+      else
+	archive_cmds='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
+	archive_expsym_cmds='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
+      fi
+    solaris*)
+      if $LD -v 2>&1 | grep 'BFD 2\.8' > /dev/null; then
+	ld_shlibs=no
+	cat <<EOF 1>&2
+*** Warning: The releases 2.8.* of the GNU linker cannot reliably
+*** create shared libraries on Solaris systems.  Therefore, libtool
+*** is disabling shared libraries support.  We urge you to upgrade GNU
+*** binutils to release 2.9.1 or newer.  Another option is to modify
+*** your PATH or compiler configuration so that the native linker is
+*** used, and then restart.
+EOF
+      elif $LD --help 2>&1 | grep ': supported targets:.* elf' > /dev/null; then
+      else
+	ld_shlibs=no
+      fi
+    sysv5* | sco3.2v5* | sco5v6* | unixware* | OpenUNIX*)
+      case `$LD -v 2>&1` in
+        *\ [01].* | *\ 2.[0-9].* | *\ 2.1[0-5].*)
+	ld_shlibs=no
+	cat <<_LT_EOF 1>&2
+*** Warning: Releases of the GNU linker prior to 2.16.91.0.3 can not
+*** reliably create shared libraries on SCO systems.  Therefore, libtool
+*** binutils to release 2.16.91.0.3 or newer.  Another option is to modify
+_LT_EOF
+	    hardcode_libdir_flag_spec='`test -z "$SCOABSPATH" && echo ${wl}-rpath,$libdir`'
+	    archive_cmds='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib'
+	    archive_expsym_cmds='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname,\${SCOABSPATH:+${install_libdir}/}$soname,-retain-symbols-file,$export_symbols -o $lib'
+	  else
+	    ld_shlibs=no
+	  fi
+      esac
+    sunos4*)
+      archive_cmds='$LD -assert pure-text -Bshareable -o $lib $libobjs $deplibs $linker_flags'
+      wlarc=
+      hardcode_direct=yes
+      else
+	ld_shlibs=no
+      fi
+    esac
+    if test "$ld_shlibs" = no; then
+      runpath_var=
+    fi
   else
-    lt_cv_compiler_c_o=yes
-  fi
-else
-  # Append any errors to the config.log.
-  cat out/conftest.err 1>&5
-fi
-CFLAGS="$save_CFLAGS"
-chmod u+w .
-$rm conftest* out/*
-rmdir out
-cd ..
-rmdir conftest
+    # PORTME fill in a description of your system's linker (not GNU ld)
+    case $host_os in
+    aix3*)
+      always_export_symbols=yes
+      archive_expsym_cmds='$LD -o $output_objdir/$soname $libobjs $deplibs $linker_flags -bE:$export_symbols -T512 -H512 -bM:SRE~$AR $AR_FLAGS $lib $output_objdir/$soname'
+      # Note: this linker hardcodes the directories in LIBPATH if there
+      # are no directories specified by -L.
+      if test "$GCC" = yes && test -z "$lt_prog_compiler_static"; then
+	# Neither direct hardcoding nor static linking is supported with a
+	# broken collect2.
+	hardcode_direct=unsupported
+      fi
-fi
+    aix4* | aix5*)
+	# On IA64, the linker does run time linking by default, so we don't
+	# have to do anything special.
+	aix_use_runtimelinking=no
+	exp_sym_flag='-Bexport'
+	no_entry_flag=""
+      else
+	# If we're using GNU nm, then we don't want the "-C" option.
+	# -C means demangle to AIX nm, but means don't demangle with GNU nm
+	if $NM -V 2>&1 | grep 'GNU' > /dev/null; then
+	  export_symbols_cmds='$NM -Bpg $libobjs $convenience | awk '\''{ if (((\$2 == "T") || (\$2 == "D") || (\$2 == "B")) && (substr(\$3,1,1) != ".")) { print \$3 } }'\'' | sort -u > $export_symbols'
+	else
+	  export_symbols_cmds='$NM -BCpg $libobjs $convenience | awk '\''{ if (((\$2 == "T") || (\$2 == "D") || (\$2 == "B")) && (substr(\$3,1,1) != ".")) { print \$3 } }'\'' | sort -u > $export_symbols'
+	fi
-compiler_c_o=$lt_cv_compiler_c_o
-echo "$as_me:$LINENO: result: $compiler_c_o" >&5
-echo "${ECHO_T}$compiler_c_o" >&6
+	# Test if we are trying to use run time linking or normal
+	# AIX style linking. If -brtl is somewhere in LDFLAGS, we
+	# need to do runtime linking.
+	case $host_os in aix4.[23]|aix4.[23].*|aix5*)
+	  for ld_flag in $LDFLAGS; do
+  	  if (test $ld_flag = "-brtl" || test $ld_flag = "-Wl,-brtl"); then
+  	    aix_use_runtimelinking=yes
+  	    break
+  	  fi
+	  done
+	esac
-if test x"$compiler_c_o" = x"yes"; then
-  # Check to see if we can write to a .lo
-  echo "$as_me:$LINENO: checking if $compiler supports -c -o file.lo" >&5
-echo $ECHO_N "checking if $compiler supports -c -o file.lo... $ECHO_C" >&6
-  if test "${lt_cv_compiler_o_lo+set}" = set; then
-else
+	exp_sym_flag='-bexport'
+	no_entry_flag='-bnoentry'
+      fi
-  lt_cv_compiler_o_lo=no
-  save_CFLAGS="$CFLAGS"
-  CFLAGS="$CFLAGS -c -o conftest.lo"
-  save_objext="$ac_objext"
-  ac_objext=lo
+      # When large executables or shared objects are built, AIX ld can
+      # have problems creating the table of contents.  If linking a library
+      # or program results in "error TOC overflow" add -mminimal-toc to
+      # CXXFLAGS/CFLAGS for g++/gcc.  In the cases where that is not
+      # enough to fix the problem, add -Wl,-bbigtoc to LDFLAGS.
+      archive_cmds=''
+      hardcode_libdir_separator=':'
+      link_all_deplibs=yes
+      if test "$GCC" = yes; then
+	case $host_os in aix4.[012]|aix4.[012].*)
+	# We only want to do this on AIX 4.2 and lower, the check
+	# below for broken collect2 doesn't work under 4.3+
+	  collect2name=`${CC} -print-prog-name=collect2`
+	  if test -f "$collect2name" && \
+  	   strings "$collect2name" | grep resolve_lib_name >/dev/null
+	  then
+  	  # We have reworked collect2
+	  else
+  	  # We have old collect2
+  	  # It fails to find uninstalled libraries when the uninstalled
+  	  # path is not listed in the libpath.  Setting hardcode_minus_L
+  	  # to unsupported forces relinking
+	  fi
+	esac
+	shared_flag='-shared'
+	if test "$aix_use_runtimelinking" = yes; then
+	  shared_flag="$shared_flag "'${wl}-G'
+	fi
+      else
+	# not using gcc
+  	# VisualAge C++, Version 5.5 for AIX 5L for IA-64, Beta 3 Release
+  	# chokes on -Wl,-G. The following line is correct:
+	  shared_flag='-G'
+	else
+	    shared_flag='${wl}-G'
+	  else
+	    shared_flag='${wl}-bM:SRE'
+	  fi
+	fi
+      fi
+      # It seems that -bexpall does not export symbols beginning with
+      # underscore (_), so it is better to generate a list of symbols to export.
+	# Warning - without using the other runtime loading flags (-brtl),
+	# -berok will link without error, but may produce a broken library.
+	allow_undefined_flag='-berok'
+       # Determine the default libpath from the value encoded in an empty executable.
+       cat >conftest.$ac_ext <<_ACEOF
 /* confdefs.h.  */
 _ACEOF
@@ -5590,82 +7237,58 @@
 int
 main ()
-int some_variable = 0;
   return 0;
 _ACEOF
+rm -f conftest.$ac_objext conftest$ac_exeext
+if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
+  (eval $ac_link) 2>conftest.er1
   ac_status=$?
+  grep -v '^ *+' conftest.er1 >conftest.err
+  rm -f conftest.er1
+	 { ac_try='test -z "$ac_c_werror_flag"
+			 || test ! -s conftest.err'
   (eval $ac_try) 2>&5
   ac_status=$?
+  (exit $ac_status); }; } &&
+	 { ac_try='test -s conftest$ac_exeext'
+  { (eval echo "$as_me:$LINENO: \"$ac_try\"") >&5
+  (eval $ac_try) 2>&5
+  ac_status=$?
-    else
-      lt_cv_compiler_o_lo=yes
-    fi
+aix_libpath=`dump -H conftest$ac_exeext 2>/dev/null | $SED -n -e '/Import File Strings/,/^$/ { /^0/ { s/^0  *\(.*\)$/\1/; p; }
+# Check for a 64-bit object if we didn't find anything.
+if test -z "$aix_libpath"; then aix_libpath=`dump -HX64 conftest$ac_exeext 2>/dev/null | $SED -n -e '/Import File Strings/,/^$/ { /^0/ { s/^0  *\(.*\)$/\1/; p; }
+}'`; fi
 else
 fi
-  ac_objext="$save_objext"
-  CFLAGS="$save_CFLAGS"
+rm -f conftest.err conftest.$ac_objext \
+      conftest$ac_exeext conftest.$ac_ext
+if test -z "$aix_libpath"; then aix_libpath="/usr/lib:/lib"; fi
-fi
-  compiler_o_lo=$lt_cv_compiler_o_lo
-  echo "$as_me:$LINENO: result: $compiler_o_lo" >&5
-echo "${ECHO_T}$compiler_o_lo" >&6
-else
-  compiler_o_lo=no
-fi
-# Check to see if we can do hard links to lock some files if needed
-hard_links="nottested"
-if test "$compiler_c_o" = no && test "$need_locks" != no; then
-  # do not overwrite the value of need_locks provided by the user
-  echo "$as_me:$LINENO: checking if we can lock with hard links" >&5
-echo $ECHO_N "checking if we can lock with hard links... $ECHO_C" >&6
-  hard_links=yes
-  $rm conftest*
-  ln conftest.a conftest.b 2>/dev/null && hard_links=no
-  touch conftest.a
-  ln conftest.a conftest.b 2>&5 || hard_links=no
-  echo "$as_me:$LINENO: result: $hard_links" >&5
-echo "${ECHO_T}$hard_links" >&6
-  if test "$hard_links" = no; then
-    { echo "$as_me:$LINENO: WARNING: \`$CC' does not support \`-c -o', so \`make -j' may be unsafe" >&5
-echo "$as_me: WARNING: \`$CC' does not support \`-c -o', so \`make -j' may be unsafe" >&2;}
-    need_locks=warn
-  fi
-else
-  need_locks=no
-fi
-if test "$GCC" = yes; then
-  # Check to see if options -fno-rtti -fno-exceptions are supported by compiler
-  echo "$as_me:$LINENO: checking if $compiler supports -fno-rtti -fno-exceptions" >&5
-echo $ECHO_N "checking if $compiler supports -fno-rtti -fno-exceptions... $ECHO_C" >&6
-  echo "int some_variable = 0;" > conftest.$ac_ext
-  CFLAGS="$CFLAGS -fno-rtti -fno-exceptions -c conftest.$ac_ext"
-  compiler_rtti_exceptions=no
+       hardcode_libdir_flag_spec='${wl}-blibpath:$libdir:'"$aix_libpath"
+	archive_expsym_cmds="\$CC"' -o $output_objdir/$soname $libobjs $deplibs '"\${wl}$no_entry_flag"' $compiler_flags `if test "x${allow_undefined_flag}" != "x"; then echo "${wl}${allow_undefined_flag}"; else :; fi` '"\${wl}$exp_sym_flag:\$export_symbols $shared_flag"
+       else
+	  hardcode_libdir_flag_spec='${wl}-R $libdir:/usr/lib:/lib'
+	  allow_undefined_flag="-z nodefs"
+	  archive_expsym_cmds="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs '"\${wl}$no_entry_flag"' $compiler_flags ${wl}${allow_undefined_flag} '"\${wl}$exp_sym_flag:\$export_symbols"
+	else
 /* confdefs.h.  */
 _ACEOF
@@ -5675,799 +7298,566 @@
 int
 main ()
   return 0;
 _ACEOF
   ac_status=$?
   (eval $ac_try) 2>&5
   ac_status=$?
+  ac_status=$?
-    else
-      compiler_rtti_exceptions=yes
-    fi
+}'`; fi
 else
 fi
-  echo "$as_me:$LINENO: result: $compiler_rtti_exceptions" >&5
-echo "${ECHO_T}$compiler_rtti_exceptions" >&6
-  if test "$compiler_rtti_exceptions" = "yes"; then
-    no_builtin_flag=' -fno-builtin -fno-rtti -fno-exceptions'
-  else
-    no_builtin_flag=' -fno-builtin'
-  fi
-fi
+	  # Warning - without using the other run time loading flags,
+	  no_undefined_flag=' ${wl}-bernotok'
+	  allow_undefined_flag=' ${wl}-berok'
+	  # Exported symbols can be pulled into shared objects from archives
+	  whole_archive_flag_spec='$convenience'
+	  archive_cmds_need_lc=yes
+	  # This is similar to how AIX traditionally builds its shared libraries.
+	  archive_expsym_cmds="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs ${wl}-bnoentry $compiler_flags ${wl}-bE:$export_symbols${allow_undefined_flag}~$AR $AR_FLAGS $output_objdir/$libname$release.a $output_objdir/$soname'
+	fi
+      fi
-# See if the linker supports building shared libraries.
-echo "$as_me:$LINENO: checking whether the linker ($LD) supports shared libraries" >&5
-echo $ECHO_N "checking whether the linker ($LD) supports shared libraries... $ECHO_C" >&6
+    amigaos*)
+      # see comment about different semantics on the GNU ld section
+      ld_shlibs=no
-allow_undefined_flag=
-no_undefined_flag=
-need_lib_prefix=unknown
-need_version=unknown
-# when you set need_version to no, make sure it does not cause -set_version
-# flags to be left without arguments
-archive_cmds=
-archive_expsym_cmds=
-old_archive_from_new_cmds=
-old_archive_from_expsyms_cmds=
-export_dynamic_flag_spec=
-whole_archive_flag_spec=
-thread_safe_flag_spec=
-hardcode_into_libs=no
-hardcode_libdir_flag_spec=
-hardcode_libdir_separator=
-hardcode_direct=no
-hardcode_minus_L=no
-hardcode_shlibpath_var=unsupported
-runpath_var=
-link_all_deplibs=unknown
-always_export_symbols=no
-export_symbols_cmds='$NM $libobjs $convenience | $global_symbol_pipe | sed '\''s/.* //'\'' | sort | uniq > $export_symbols'
-# include_expsyms should be a list of space-separated symbols to be *always*
-# included in the symbol list
-include_expsyms=
-# exclude_expsyms can be an egrep regular expression of symbols to exclude
-# it will be wrapped by ` (' and `)$', so one must not match beginning or
-# end of line.  Example: `a|bc|.*d.*' will exclude the symbols `a' and `bc',
-# as well as any symbol that contains `d'.
-exclude_expsyms="_GLOBAL_OFFSET_TABLE_"
-# Although _GLOBAL_OFFSET_TABLE_ is a valid symbol C name, most a.out
-# platforms (ab)use it in PIC code, but their linkers get confused if
-# the symbol is explicitly referenced.  Since portable code cannot
-# rely on this symbol name, it's probably fine to never include it in
-# preloaded symbol tables.
-extract_expsyms_cmds=
+    bsdi[45]*)
+      export_dynamic_flag_spec=-rdynamic
-case $host_os in
-cygwin* | mingw* | pw32*)
-  # FIXME: the MSVC++ port hasn't been tested in a loooong time
-  # When not using gcc, we currently assume that we are using
-  # Microsoft Visual C++.
-  if test "$GCC" != yes; then
-    with_gnu_ld=no
-  fi
-openbsd*)
-  with_gnu_ld=no
-esac
+      # hardcode_libdir_flag_spec is actually meaningless, as there is
+      # no search path for DLLs.
+      hardcode_libdir_flag_spec=' '
+      # Tell ltmain to make .lib files, not .a files.
+      libext=lib
+      # Tell ltmain to make .dll files, not .so files.
+      shrext_cmds=".dll"
+      # FIXME: Setting linknames here is a bad hack.
+      archive_cmds='$CC -o $lib $libobjs $compiler_flags `echo "$deplibs" | $SED -e '\''s/ -lc$//'\''` -link -dll~linknames='
+      # The linker will automatically build a .lib file if we build a DLL.
+      old_archive_From_new_cmds='true'
+      # FIXME: Should let the user specify the lib program.
+      old_archive_cmds='lib /OUT:$oldlib$oldobjs$old_deplibs'
+      fix_srcfile_path='`cygpath -w "$srcfile"`'
-ld_shlibs=yes
-if test "$with_gnu_ld" = yes; then
-  # If archive_cmds runs LD, not CC, wlarc should be empty
-  wlarc='${wl}'
-  # See if GNU ld supports shared libraries.
-  case $host_os in
-    # On AIX, the GNU linker is very broken
-    # Note:Check GNU linker on AIX 5-IA64 when/if it becomes available.
-    ld_shlibs=no
-    cat <<EOF 1>&2
-*** Warning: the GNU linker, at least up to release 2.9.1, is reported
-*** to be unable to reliably create shared libraries on AIX.
-*** Therefore, libtool is disabling shared libraries support.  If you
-*** really care for shared libraries, you may want to modify your PATH
-*** so that a non-GNU linker is found, and then restart.
-EOF
-  amigaos*)
-    archive_cmds='$rm $output_objdir/a2ixlibrary.data~$echo "#define NAME $libname" > $output_objdir/a2ixlibrary.data~$echo "#define LIBRARY_ID 1" >> $output_objdir/a2ixlibrary.data~$echo "#define VERSION $major" >> $output_objdir/a2ixlibrary.data~$echo "#define REVISION $revision" >> $output_objdir/a2ixlibrary.data~$AR $AR_FLAGS $lib $libobjs~$RANLIB $lib~(cd $output_objdir && a2ixlibrary -32)'
-    hardcode_libdir_flag_spec='-L$libdir'
-    hardcode_minus_L=yes
-    # Samuel A. Falvo II <kc5tja at dolphin.openprojects.net> reports
-    # that the semantics of dynamic libraries on AmigaOS, at least up
-    # to version 4, is to share data among multiple programs linked
-    # with the same dynamic library.  Since this doesn't match the
-    # behavior of shared libraries on other platforms, we can use
-    # them.
-    ld_shlibs=no
-  beos*)
-    if $LD --help 2>&1 | egrep ': supported targets:.* elf' > /dev/null; then
-      allow_undefined_flag=unsupported
-      # Joseph Beckenbach <jrb3 at best.com> says some releases of gcc
-      # support --undefined.  This deserves some investigation.  FIXME
-      archive_cmds='$CC -nostart $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
+    darwin* | rhapsody*)
+      case $host_os in
+        rhapsody* | darwin1.[012])
+         allow_undefined_flag='${wl}-undefined ${wl}suppress'
+       *) # Darwin 1.3 on
+         if test -z ${MACOSX_DEPLOYMENT_TARGET} ; then
+           allow_undefined_flag='${wl}-flat_namespace ${wl}-undefined ${wl}suppress'
+         else
+           case ${MACOSX_DEPLOYMENT_TARGET} in
+             10.[012])
+             10.*)
+               allow_undefined_flag='${wl}-undefined ${wl}dynamic_lookup'
+           esac
+         fi
+      esac
+      archive_cmds_need_lc=no
+      hardcode_automatic=yes
+      whole_archive_flag_spec=''
+    if test "$GCC" = yes ; then
+    	output_verbose_link_cmd='echo'
+        archive_cmds='$CC -dynamiclib $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring'
+      module_cmds='$CC $allow_undefined_flag -o $lib -bundle $libobjs $deplibs$compiler_flags'
+      # Don't fix this by using the ld -exported_symbols_list flag, it doesn't exist in older darwin lds
+      archive_expsym_cmds='sed -e "s,#.*,," -e "s,^[    ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -dynamiclib $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
+      module_expsym_cmds='sed -e "s,#.*,," -e "s,^[    ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC $allow_undefined_flag  -o $lib -bundle $libobjs $deplibs$compiler_flags~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
     else
-      ld_shlibs=no
+        xlc*)
+         archive_cmds='$CC -qmkshrobj $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-install_name ${wl}`echo $rpath/$soname` $verstring'
+         archive_expsym_cmds='sed -e "s,#.*,," -e "s,^[    ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -qmkshrobj $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-install_name ${wl}$rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
+         ld_shlibs=no
+      esac
     fi
-  cygwin* | mingw* | pw32*)
-    # hardcode_libdir_flag_spec is actually meaningless, as there is
-    # no search path for DLLs.
-    always_export_symbols=yes
+    dgux*)
+      archive_cmds='$LD -G -h $soname -o $lib $libobjs $deplibs $linker_flags'
-    extract_expsyms_cmds='test -f $output_objdir/impgen.c || \
-      sed -e "/^# \/\* impgen\.c starts here \*\//,/^# \/\* impgen.c ends here \*\// { s/^# //;s/^# *$//; p; }" -e d < $''0 > $output_objdir/impgen.c~
-      test -f $output_objdir/impgen.exe || (cd $output_objdir && \
-      if test "x$HOST_CC" != "x" ; then $HOST_CC -o impgen impgen.c ; \
-      else $CC -o impgen impgen.c ; fi)~
-      $output_objdir/impgen $dir/$soroot > $output_objdir/$soname-def'
+    freebsd1*)
+      ld_shlibs=no
-    old_archive_from_expsyms_cmds='$DLLTOOL --as=$AS --dllname $soname --def $output_objdir/$soname-def --output-lib $output_objdir/$newlib'
+    # FreeBSD 2.2.[012] allows us to include c++rt0.o to get C++ constructor
+    # support.  Future versions do this automatically, but an explicit c++rt0.o
+    # does not break anything, and helps significantly (at the cost of a little
+    # extra space).
+    freebsd2.2*)
+      archive_cmds='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags /usr/lib/c++rt0.o'
+      hardcode_libdir_flag_spec='-R$libdir'
-    # cygwin and mingw dlls have different entry points and sets of symbols
-    # to exclude.
-    # FIXME: what about values for MSVC?
-    dll_entry=__cygwin_dll_entry at 12
-    dll_exclude_symbols=DllMain at 12,_cygwin_dll_entry at 12,_cygwin_noncygwin_dll_entry at 12~
-    case $host_os in
-    mingw*)
-      # mingw values
-      dll_entry=_DllMainCRTStartup at 12
-      dll_exclude_symbols=DllMain at 12,DllMainCRTStartup at 12,DllEntryPoint at 12~
+    # Unfortunately, older versions of FreeBSD 2 do not have this feature.
+    freebsd2*)
+      archive_cmds='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags'
-    esac
-    # mingw and cygwin differ, and it's simplest to just exclude the union
-    # of the two symbol sets.
-    dll_exclude_symbols=DllMain at 12,_cygwin_dll_entry at 12,_cygwin_noncygwin_dll_entry at 12,DllMainCRTStartup at 12,DllEntryPoint at 12
+    # FreeBSD 3 and greater uses gcc -shared to do shared libraries.
+    freebsd* | kfreebsd*-gnu | dragonfly*)
+      archive_cmds='$CC -shared -o $lib $libobjs $deplibs $compiler_flags'
-    # recent cygwin and mingw systems supply a stub DllMain which the user
-    # can override, but on older systems we have to supply one (in ltdll.c)
-    if test "x$lt_cv_need_dllmain" = "xyes"; then
-      ltdll_obj='$output_objdir/$soname-ltdll.'"$ac_objext "
-      ltdll_cmds='test -f $output_objdir/$soname-ltdll.c || sed -e "/^# \/\* ltdll\.c starts here \*\//,/^# \/\* ltdll.c ends here \*\// { s/^# //; p; }" -e d < $''0 > $output_objdir/$soname-ltdll.c~
-	test -f $output_objdir/$soname-ltdll.$ac_objext || (cd $output_objdir && $CC -c $soname-ltdll.c)~'
-    else
-      ltdll_obj=
-      ltdll_cmds=
-    fi
+    hpux9*)
+	archive_cmds='$rm $output_objdir/$soname~$CC -shared -fPIC ${wl}+b ${wl}$install_libdir -o $output_objdir/$soname $libobjs $deplibs $compiler_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
+      else
+	archive_cmds='$rm $output_objdir/$soname~$LD -b +b $install_libdir -o $output_objdir/$soname $libobjs $deplibs $linker_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
+      fi
+      hardcode_libdir_flag_spec='${wl}+b ${wl}$libdir'
+      hardcode_libdir_separator=:
-    # Extract the symbol export list from an `--export-all' def file,
-    # then regenerate the def file from the symbol export list, so that
-    # the compiled dll only exports the symbol export list.
-    # Be careful not to strip the DATA tag left be newer dlltools.
-    export_symbols_cmds="$ltdll_cmds"'
-      $DLLTOOL --export-all --exclude-symbols '$dll_exclude_symbols' --output-def $output_objdir/$soname-def '$ltdll_obj'$libobjs $convenience~
-      sed -e "1,/EXPORTS/d" -e "s/ @ [0-9]*//" -e "s/ *;.*$//" < $output_objdir/$soname-def > $export_symbols'
+      # hardcode_minus_L: Not really in the search PATH,
+      # but as the default location of the library.
-    # If the export-symbols file already is a .def file (1st line
-    # is EXPORTS), use it as is.
-    # If DATA tags from a recent dlltool are present, honour them!
-    archive_expsym_cmds='if test "x`sed 1q $export_symbols`" = xEXPORTS; then
-	cp $export_symbols $output_objdir/$soname-def;
+    hpux10*)
+      if test "$GCC" = yes -a "$with_gnu_ld" = no; then
+	archive_cmds='$CC -shared -fPIC ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $libobjs $deplibs $compiler_flags'
       else
-	echo EXPORTS > $output_objdir/$soname-def;
-	_lt_hint=1;
-	cat $export_symbols | while read symbol; do
-	 set dummy \$symbol;
-	 case \$# in
-	   2) echo "   \$2 @ \$_lt_hint ; " >> $output_objdir/$soname-def;;
-	   4) echo "   \$2 \$3 \$4 ; " >> $output_objdir/$soname-def; _lt_hint=`expr \$_lt_hint - 1`;;
-	   *) echo "     \$2 @ \$_lt_hint \$3 ; " >> $output_objdir/$soname-def;;
-	 esac;
-	 _lt_hint=`expr 1 + \$_lt_hint`;
-	done;
-      fi~
-      '"$ltdll_cmds"'
-      $CC -Wl,--base-file,$output_objdir/$soname-base '$lt_cv_cc_dll_switch' -Wl,-e,'$dll_entry' -o $output_objdir/$soname '$ltdll_obj'$libobjs $deplibs $compiler_flags~
-      $DLLTOOL --as=$AS --dllname $soname --exclude-symbols '$dll_exclude_symbols' --def $output_objdir/$soname-def --base-file $output_objdir/$soname-base --output-exp $output_objdir/$soname-exp~
-      $CC -Wl,--base-file,$output_objdir/$soname-base $output_objdir/$soname-exp '$lt_cv_cc_dll_switch' -Wl,-e,'$dll_entry' -o $output_objdir/$soname '$ltdll_obj'$libobjs $deplibs $compiler_flags~
-      $DLLTOOL --as=$AS --dllname $soname --exclude-symbols '$dll_exclude_symbols' --def $output_objdir/$soname-def --base-file $output_objdir/$soname-base --output-exp $output_objdir/$soname-exp --output-lib $output_objdir/$libname.dll.a~
-      $CC $output_objdir/$soname-exp '$lt_cv_cc_dll_switch' -Wl,-e,'$dll_entry' -o $output_objdir/$soname '$ltdll_obj'$libobjs $deplibs $compiler_flags'
+	archive_cmds='$LD -b +h $soname +b $install_libdir -o $lib $libobjs $deplibs $linker_flags'
+      fi
+      if test "$with_gnu_ld" = no; then
-  netbsd*)
-    if echo __ELF__ | $CC -E - | grep __ELF__ >/dev/null; then
-      archive_cmds='$LD -Bshareable $libobjs $deplibs $linker_flags -o $lib'
-      wlarc=
-    else
-      archive_cmds='$CC -shared -nodefaultlibs $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
-      archive_expsym_cmds='$CC -shared -nodefaultlibs $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
-    fi
-  solaris* | sysv5*)
-    if $LD -v 2>&1 | egrep 'BFD 2\.8' > /dev/null; then
-      ld_shlibs=no
-      cat <<EOF 1>&2
+      fi
-*** Warning: The releases 2.8.* of the GNU linker cannot reliably
-*** create shared libraries on Solaris systems.  Therefore, libtool
-*** is disabling shared libraries support.  We urge you to upgrade GNU
-*** binutils to release 2.9.1 or newer.  Another option is to modify
-*** your PATH or compiler configuration so that the native linker is
-*** used, and then restart.
-EOF
-    elif $LD --help 2>&1 | egrep ': supported targets:.* elf' > /dev/null; then
-      archive_cmds='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
-      archive_expsym_cmds='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
-    else
-      ld_shlibs=no
-    fi
-  sunos4*)
-    archive_cmds='$LD -assert pure-text -Bshareable -o $lib $libobjs $deplibs $linker_flags'
-    wlarc=
-    hardcode_direct=yes
-    hardcode_shlibpath_var=no
-    else
-      ld_shlibs=no
-    fi
-  esac
-  if test "$ld_shlibs" = yes; then
-    runpath_var=LD_RUN_PATH
-    hardcode_libdir_flag_spec='${wl}--rpath ${wl}$libdir'
-    export_dynamic_flag_spec='${wl}--export-dynamic'
-    case $host_os in
-      # dlltool doesn't understand --whole-archive et. al.
-      whole_archive_flag_spec=
-      # ancient GNU ld didn't support --whole-archive et. al.
-      if $LD --help 2>&1 | egrep 'no-whole-archive' > /dev/null; then
-	whole_archive_flag_spec="$wlarc"'--whole-archive$convenience '"$wlarc"'--no-whole-archive'
+    hpux11*)
+	case $host_cpu in
+	hppa*64*)
+	  archive_cmds='$CC -shared ${wl}+h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	ia64*)
+	  archive_cmds='$CC -shared ${wl}+h ${wl}$soname ${wl}+nodefaultrpath -o $lib $libobjs $deplibs $compiler_flags'
+	esac
       else
+	case $host_cpu in
+	hppa*64*)
+	  archive_cmds='$CC -b ${wl}+h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	ia64*)
+	  archive_cmds='$CC -b ${wl}+h ${wl}$soname ${wl}+nodefaultrpath -o $lib $libobjs $deplibs $compiler_flags'
+	  archive_cmds='$CC -b ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $libobjs $deplibs $compiler_flags'
+	esac
       fi
-    esac
-  fi
-else
-  # PORTME fill in a description of your system's linker (not GNU ld)
-  case $host_os in
-  aix3*)
-    archive_expsym_cmds='$LD -o $output_objdir/$soname $libobjs $deplibs $linker_flags -bE:$export_symbols -T512 -H512 -bM:SRE~$AR $AR_FLAGS $lib $output_objdir/$soname'
-    # Note: this linker hardcodes the directories in LIBPATH if there
-    # are no directories specified by -L.
-    if test "$GCC" = yes && test -z "$link_static_flag"; then
-      # Neither direct hardcoding nor static linking is supported with a
-      # broken collect2.
-      hardcode_direct=unsupported
-    fi
-  aix4* | aix5*)
-    if test "$host_cpu" = ia64; then
-      # On IA64, the linker does run time linking by default, so we don't
-      # have to do anything special.
-      aix_use_runtimelinking=no
-      exp_sym_flag='-Bexport'
-      no_entry_flag=""
-    else
-      # Test if we are trying to use run time linking or normal
-      # AIX style linking. If -brtl is somewhere in LDFLAGS, we
-      # need to do runtime linking.
-      case $host_os in aix4.[23]|aix4.[23].*|aix5*)
-	for ld_flag in $LDFLAGS; do
-	  case $ld_flag in
-	  *-brtl*)
-	    aix_use_runtimelinking=yes
-	    break
+	case $host_cpu in
+	hppa*64*|ia64*)
+	  hardcode_libdir_flag_spec_ld='+b $libdir'
-	  esac
-	done
-      esac
-      exp_sym_flag='-bexport'
-      no_entry_flag='-bnoentry'
-    fi
-    # When large executables or shared objects are built, AIX ld can
-    # have problems creating the table of contents.  If linking a library
-    # or program results in "error TOC overflow" add -mminimal-toc to
-    # CXXFLAGS/CFLAGS for g++/gcc.  In the cases where that is not
-    # enough to fix the problem, add -Wl,-bbigtoc to LDFLAGS.
-    archive_cmds=''
-    hardcode_libdir_separator=':'
-    if test "$GCC" = yes; then
-      case $host_os in aix4.[012]|aix4.[012].*)
-	collect2name=`${CC} -print-prog-name=collect2`
-	if test -f "$collect2name" && \
-	  strings "$collect2name" | grep resolve_lib_name >/dev/null
-	then
-	  # We have reworked collect2
-	else
-	  # We have old collect2
-	  # It fails to find uninstalled libraries when the uninstalled
-	  # path is not listed in the libpath.  Setting hardcode_minus_L
-	  # to unsupported forces relinking
-	fi
-      esac
+	esac
+      fi
-      shared_flag='-shared'
-    else
-      # not using gcc
-	shared_flag='${wl}-G'
+    irix5* | irix6* | nonstopux*)
+	archive_cmds='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
       else
-	if test "$aix_use_runtimelinking" = yes; then
-	else
-	  shared_flag='${wl}-bM:SRE'
-	fi
+	archive_cmds='$LD -shared $libobjs $deplibs $linker_flags -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
+	hardcode_libdir_flag_spec_ld='-rpath $libdir'
       fi
-    fi
+      hardcode_libdir_flag_spec='${wl}-rpath ${wl}$libdir'
-    # It seems that -bexpall can do strange things, so it is better to
-    # generate a list of symbols to export.
-      # Warning - without using the other runtime loading flags (-brtl),
-      # -berok will link without error, but may produce a broken library.
-      allow_undefined_flag='-berok'
-      hardcode_libdir_flag_spec='${wl}-blibpath:$libdir:/usr/lib:/lib'
-      archive_expsym_cmds="\$CC"' -o $output_objdir/$soname $libobjs $deplibs $compiler_flags `if test "x${allow_undefined_flag}" != "x"; then echo "${wl}${allow_undefined_flag}"; else :; fi` '"\${wl}$no_entry_flag \${wl}$exp_sym_flag:\$export_symbols $shared_flag"
-    else
-	hardcode_libdir_flag_spec='${wl}-R $libdir:/usr/lib:/lib'
-	allow_undefined_flag="-z nodefs"
-	archive_expsym_cmds="\$CC $shared_flag"' -o $output_objdir/$soname ${wl}-h$soname $libobjs $deplibs $compiler_flags ${wl}${allow_undefined_flag} '"\${wl}$no_entry_flag \${wl}$exp_sym_flag:\$export_symbols"
+    netbsd*)
+	archive_cmds='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags'  # a.out
       else
-	hardcode_libdir_flag_spec='${wl}-bnolibpath ${wl}-blibpath:$libdir:/usr/lib:/lib'
-	# Warning - without using the other run time loading flags,
-	allow_undefined_flag='${wl}-berok'
-	# This is a bit strange, but is similar to how AIX traditionally builds
-	# it's shared libraries.
-	archive_expsym_cmds="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs $compiler_flags ${allow_undefined_flag} '"\${wl}$no_entry_flag \${wl}$exp_sym_flag:\$export_symbols"' ~$AR -crlo $objdir/$libname$release.a $objdir/$soname'
+	archive_cmds='$LD -shared -o $lib $libobjs $deplibs $linker_flags'      # ELF
       fi
-    fi
-  amigaos*)
-    # see comment about different semantics on the GNU ld section
-    ld_shlibs=no
+    newsos6)
-    hardcode_libdir_flag_spec=' '
-    # Tell ltmain to make .lib files, not .a files.
-    libext=lib
-    # FIXME: Setting linknames here is a bad hack.
-    archive_cmds='$CC -o $lib $libobjs $compiler_flags `echo "$deplibs" | sed -e '\''s/ -lc$//'\''` -link -dll~linknames='
-    # The linker will automatically build a .lib file if we build a DLL.
-    old_archive_from_new_cmds='true'
-    # FIXME: Should let the user specify the lib program.
-    old_archive_cmds='lib /OUT:$oldlib$oldobjs$old_deplibs'
-    fix_srcfile_path='`cygpath -w "$srcfile"`'
+    openbsd*)
+      if test -z "`echo __ELF__ | $CC -E - | grep __ELF__`" || test "$host_os-$host_cpu" = "openbsd2.8-powerpc"; then
+	archive_cmds='$CC -shared $pic_flag -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds='$CC -shared $pic_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-retain-symbols-file,$export_symbols'
+      else
+       case $host_os in
+	 openbsd[01].* | openbsd2.[0-7] | openbsd2.[0-7].*)
+       esac
+      fi
-  darwin* | rhapsody*)
-    case "$host_os" in
-    rhapsody* | darwin1.[012])
-      allow_undefined_flag='-undefined suppress'
+    os2*)
+      archive_cmds='$echo "LIBRARY $libname INITINSTANCE" > $output_objdir/$libname.def~$echo "DESCRIPTION \"$libname\"" >> $output_objdir/$libname.def~$echo DATA >> $output_objdir/$libname.def~$echo " SINGLE NONSHARED" >> $output_objdir/$libname.def~$echo EXPORTS >> $output_objdir/$libname.def~emxexp $libobjs >> $output_objdir/$libname.def~$CC -Zdll -Zcrtdll -o $lib $libobjs $deplibs $compiler_flags $output_objdir/$libname.def'
+      old_archive_From_new_cmds='emximp -o $output_objdir/$libname.a $output_objdir/$libname.def'
-    *) # Darwin 1.3 on
-      allow_undefined_flag='-flat_namespace -undefined suppress'
-    esac
-    # FIXME: Relying on posixy $() will cause problems for
-    #        cross-compilation, but unfortunately the echo tests do not
-    #        yet detect zsh echo's removal of \ escapes.  Also zsh mangles
-    #	     `"' quotes if we put them in here... so don't!
-    archive_cmds='$CC -r -keep_private_externs -nostdlib -o ${lib}-master.o $libobjs && $CC $(test .$module = .yes && echo -bundle || echo -dynamiclib) $allow_undefined_flag -o $lib ${lib}-master.o $deplibs$linker_flags $(test .$module != .yes && echo -install_name $rpath/$soname $verstring)'
-    # We need to add '_' to the symbols in $export_symbols first
-    #archive_expsym_cmds="$archive_cmds"' && strip -s $export_symbols'
-    whole_archive_flag_spec='-all_load $convenience'
-  freebsd1*)
-    ld_shlibs=no
-  # FreeBSD 2.2.[012] allows us to include c++rt0.o to get C++ constructor
-  # support.  Future versions do this automatically, but an explicit c++rt0.o
-  # does not break anything, and helps significantly (at the cost of a little
-  # extra space).
-  freebsd2.2*)
-    archive_cmds='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags /usr/lib/c++rt0.o'
-    hardcode_libdir_flag_spec='-R$libdir'
-  # Unfortunately, older versions of FreeBSD 2 do not have this feature.
-  freebsd2*)
-    archive_cmds='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags'
-  # FreeBSD 3 and greater uses gcc -shared to do shared libraries.
-  freebsd*)
-    archive_cmds='$CC -shared -o $lib $libobjs $deplibs $compiler_flags'
-    case $host_os in
-    hpux9*) archive_cmds='$rm $output_objdir/$soname~$LD -b +b $install_libdir -o $output_objdir/$soname $libobjs $deplibs $linker_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib' ;;
-    *) archive_cmds='$LD -b +h $soname +b $install_libdir -o $lib $libobjs $deplibs $linker_flags' ;;
-    esac
-    hardcode_libdir_flag_spec='${wl}+b ${wl}$libdir'
-    hardcode_libdir_separator=:
-    hardcode_minus_L=yes # Not in the search PATH, but as the default
-			 # location of the library.
-    export_dynamic_flag_spec='${wl}-E'
-  irix5* | irix6* | nonstopux*)
-      archive_cmds='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
+    osf3*)
+	allow_undefined_flag=' ${wl}-expect_unresolved ${wl}\*'
+	archive_cmds='$CC -shared${allow_undefined_flag} $libobjs $deplibs $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
+      else
+	allow_undefined_flag=' -expect_unresolved \*'
+	archive_cmds='$LD -shared${allow_undefined_flag} $libobjs $deplibs $linker_flags -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
+      fi
-    else
-      archive_cmds='$LD -shared $libobjs $deplibs $linker_flags -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
-      hardcode_libdir_flag_spec='-rpath $libdir'
-    fi
-    link_all_deplibs=yes
-  netbsd*)
-      archive_cmds='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags'  # a.out
-    else
-      archive_cmds='$LD -shared -o $lib $libobjs $deplibs $linker_flags'      # ELF
-    fi
+    osf4* | osf5*)	# as osf3* with the addition of -msym flag
+	archive_cmds='$CC -shared${allow_undefined_flag} $libobjs $deplibs $compiler_flags ${wl}-msym ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
+      else
+	archive_cmds='$LD -shared${allow_undefined_flag} $libobjs $deplibs $linker_flags -msym -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
+	archive_expsym_cmds='for i in `cat $export_symbols`; do printf "%s %s\\n" -exported_symbol "\$i" >> $lib.exp; done; echo "-hidden">> $lib.exp~
+	$LD -shared${allow_undefined_flag} -input $lib.exp $linker_flags $libobjs $deplibs -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib~$rm $lib.exp'
-  newsos6)
-    archive_cmds='$LD -G -h $soname -o $lib $libobjs $deplibs $linker_flags'
-    hardcode_libdir_flag_spec='${wl}-rpath ${wl}$libdir'
+	# Both c and cxx compiler support -rpath directly
+	hardcode_libdir_flag_spec='-rpath $libdir'
+      fi
-  openbsd*)
-    if test -z "`echo __ELF__ | $CC -E - | grep __ELF__`" || test "$host_os-$host_cpu" = "openbsd2.8-powerpc"; then
-      archive_cmds='$CC -shared $pic_flag -o $lib $libobjs $deplibs $compiler_flags'
-      hardcode_libdir_flag_spec='${wl}-rpath,$libdir'
-    else
-      openbsd[01].* | openbsd2.[0-7] | openbsd2.[0-7].*)
+    solaris*)
+      no_undefined_flag=' -z text'
+	wlarc='${wl}'
+	archive_cmds='$CC -shared ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds='$echo "{ global:" > $lib.exp~cat $export_symbols | $SED -e "s/\(.*\)/\1;/" >> $lib.exp~$echo "local: *; };" >> $lib.exp~
+	  $CC -shared ${wl}-M ${wl}$lib.exp ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags~$rm $lib.exp'
+      else
+	wlarc=''
+	archive_cmds='$LD -G${allow_undefined_flag} -h $soname -o $lib $libobjs $deplibs $linker_flags'
+  	$LD -G${allow_undefined_flag} -M $lib.exp -h $soname -o $lib $libobjs $deplibs $linker_flags~$rm $lib.exp'
+      fi
+      case $host_os in
+      solaris2.[0-5] | solaris2.[0-5].*) ;;
+ 	# The compiler driver will combine linker options so we
+ 	# cannot just pass the convience library names through
+ 	# without $wl, iff we do not link with $LD.
+ 	# Luckily, gcc supports the same syntax we need for Sun Studio.
+ 	# Supported since Solaris 2.6 (maybe 2.5.1?)
+ 	case $wlarc in
+ 	  whole_archive_flag_spec='-z allextract$convenience -z defaultextract' ;;
+ 	  whole_archive_flag_spec='${wl}-z ${wl}allextract`for conv in $convenience\"\"; do test -n \"$conv\" && new_convenience=\"$new_convenience,$conv\"; done; $echo \"$new_convenience\"` ${wl}-z ${wl}defaultextract' ;;
+ 	esac ;;
       esac
-    fi
-  os2*)
-    archive_cmds='$echo "LIBRARY $libname INITINSTANCE" > $output_objdir/$libname.def~$echo "DESCRIPTION \"$libname\"" >> $output_objdir/$libname.def~$echo DATA >> $output_objdir/$libname.def~$echo " SINGLE NONSHARED" >> $output_objdir/$libname.def~$echo EXPORTS >> $output_objdir/$libname.def~emxexp $libobjs >> $output_objdir/$libname.def~$CC -Zdll -Zcrtdll -o $lib $libobjs $deplibs $compiler_flags $output_objdir/$libname.def'
-    old_archive_from_new_cmds='emximp -o $output_objdir/$libname.a $output_objdir/$libname.def'
+    sunos4*)
+      if test "x$host_vendor" = xsequent; then
+	# Use $CC to link under sequent, because it throws in some extra .o
+	# files that make .init and .fini sections work.
+	archive_cmds='$CC -G ${wl}-h $soname -o $lib $libobjs $deplibs $compiler_flags'
+      else
+	archive_cmds='$LD -assert pure-text -Bstatic -o $lib $libobjs $deplibs $linker_flags'
+      fi
-  osf3*)
-      allow_undefined_flag=' ${wl}-expect_unresolved ${wl}\*'
-      archive_cmds='$CC -shared${allow_undefined_flag} $libobjs $deplibs $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
-    else
-      allow_undefined_flag=' -expect_unresolved \*'
-      archive_cmds='$LD -shared${allow_undefined_flag} $libobjs $deplibs $linker_flags -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
-    fi
-  osf4* | osf5*)	# as osf3* with the addition of -msym flag
-      archive_cmds='$CC -shared${allow_undefined_flag} $libobjs $deplibs $compiler_flags ${wl}-msym ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
-    else
-      archive_cmds='$LD -shared${allow_undefined_flag} $libobjs $deplibs $linker_flags -msym -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
-      archive_expsym_cmds='for i in `cat $export_symbols`; do printf "-exported_symbol " >> $lib.exp; echo "\$i" >> $lib.exp; done; echo "-hidden">> $lib.exp~
-      $LD -shared${allow_undefined_flag} -input $lib.exp $linker_flags $libobjs $deplibs -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${objdir}/so_locations -o $lib~$rm $lib.exp'
-      #Both c and cxx compiler support -rpath directly
-    fi
-  sco3.2v5*)
-    hardcode_runpath_var=yes
-    export_dynamic_flag_spec='${wl}-Bexport'
-  solaris*)
-    # gcc --version < 3.0 without binutils cannot create self contained
-    # shared libraries reliably, requiring libgcc.a to resolve some of
-    # the object symbols generated in some cases.  Libraries that use
-    # assert need libgcc.a to resolve __eprintf, for example.  Linking
-    # a copy of libgcc.a into every shared library to guarantee resolving
-    # such symbols causes other problems:  According to Tim Van Holder
-    # <tim.van.holder at pandora.be>, C++ libraries end up with a separate
-    # (to the application) exception stack for one thing.
-    no_undefined_flag=' -z defs'
-      case `$CC --version 2>/dev/null` in
-      [12].*)
-	cat <<EOF 1>&2
-*** Warning: Releases of GCC earlier than version 3.0 cannot reliably
-*** create self contained shared libraries on Solaris systems, without
-*** introducing a dependency on libgcc.a.  Therefore, libtool is disabling
-*** -no-undefined support, which will at least allow you to build shared
-*** libraries.  However, you may find that when you link such libraries
-*** into an application without using GCC, you have to manually add
-*** \`gcc --print-libgcc-file-name\` to the link command.  We urge you to
-*** upgrade to a newer version of GCC.  Another option is to rebuild your
-*** current GCC to use the GNU linker from GNU binutils 2.9.1 or newer.
-EOF
+    sysv4)
+      case $host_vendor in
+	sni)
+	  hardcode_direct=yes # is this really true???
+	siemens)
+	  ## LD is ld it makes a PLAMLIB
+	  ## CC just makes a GrossModule.
+	  archive_cmds='$LD -G -o $lib $libobjs $deplibs $linker_flags'
+	  reload_cmds='$CC -r -o $output$reload_objs'
+	motorola)
+	  hardcode_direct=no #Motorola manual says yes, but my tests say they lie
       esac
-    fi
-    # $CC -shared without GNU ld will not create a library from C++
-    # object files and a static libstdc++, better avoid it by now
-    archive_cmds='$LD -G${allow_undefined_flag} -h $soname -o $lib $libobjs $deplibs $linker_flags'
-    archive_expsym_cmds='$echo "{ global:" > $lib.exp~cat $export_symbols | sed -e "s/\(.*\)/\1;/" >> $lib.exp~$echo "local: *; };" >> $lib.exp~
-		$LD -G${allow_undefined_flag} -M $lib.exp -h $soname -o $lib $libobjs $deplibs $linker_flags~$rm $lib.exp'
-    case $host_os in
-    solaris2.[0-5] | solaris2.[0-5].*) ;;
-    *) # Supported since Solaris 2.6 (maybe 2.5.1?)
-      whole_archive_flag_spec='-z allextract$convenience -z defaultextract' ;;
-    esac
+      runpath_var='LD_RUN_PATH'
-  sunos4*)
-    if test "x$host_vendor" = xsequent; then
-      # Use $CC to link under sequent, because it throws in some extra .o
-      # files that make .init and .fini sections work.
-      archive_cmds='$CC -G ${wl}-h $soname -o $lib $libobjs $deplibs $compiler_flags'
-    else
-      archive_cmds='$LD -assert pure-text -Bstatic -o $lib $libobjs $deplibs $linker_flags'
-    fi
+    sysv4.3*)
+      export_dynamic_flag_spec='-Bexport'
-  sysv4)
-    case $host_vendor in
-      sni)
-        hardcode_direct=yes # is this really true???
-      siemens)
-        ## LD is ld it makes a PLAMLIB
-        ## CC just makes a GrossModule.
-        archive_cmds='$LD -G -o $lib $libobjs $deplibs $linker_flags'
-        reload_cmds='$CC -r -o $output$reload_objs'
-        hardcode_direct=no
-      motorola)
-        hardcode_direct=no #Motorola manual says yes, but my tests say they lie
-    esac
-    runpath_var='LD_RUN_PATH'
+    sysv4*MP*)
+      if test -d /usr/nec; then
+	hardcode_runpath_var=yes
+	ld_shlibs=yes
+      fi
-  sysv4.3*)
-    export_dynamic_flag_spec='-Bexport'
+    sysv4*uw2* | sysv5OpenUNIX* | sysv5UnixWare7.[01].[10]* | unixware7*)
+      no_undefined_flag='${wl}-z,text'
-  sysv5*)
-    no_undefined_flag=' -z text'
+	archive_cmds='$CC -shared ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds='$CC -shared ${wl}-Bexport:$export_symbols ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+      else
+	archive_cmds='$CC -G ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds='$CC -G ${wl}-Bexport:$export_symbols ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+      fi
-  uts4*)
+    sysv5* | sco3.2v5* | sco5v6*)
+      # Note: We can NOT use -z defs as we might desire, because we do not
+      # link with -lc, and that would cause any symbols used from libc to
+      # always be unresolved, which means just about no library would
+      # ever link correctly.  If we're not using GNU ld we use -z text
+      # though, which does catch some bad symbols but isn't as heavy-handed
+      # as -z defs.
+      allow_undefined_flag='${wl}-z,nodefs'
+      hardcode_libdir_flag_spec='`test -z "$SCOABSPATH" && echo ${wl}-R,$libdir`'
+      export_dynamic_flag_spec='${wl}-Bexport'
-  dgux*)
+	archive_cmds='$CC -shared ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds='$CC -shared ${wl}-Bexport:$export_symbols ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+      else
+	archive_cmds='$CC -G ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds='$CC -G ${wl}-Bexport:$export_symbols ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+      fi
-  sysv4*MP*)
-    if test -d /usr/nec; then
+    uts4*)
-      ld_shlibs=yes
-    fi
-  sysv4.2uw2*)
-    hardcode_minus_L=no
+      ld_shlibs=no
+    esac
+  fi
-  sysv5uw7* | unixware7*)
-    no_undefined_flag='${wl}-z ${wl}text'
-      archive_cmds='$CC -shared ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
-    else
-      archive_cmds='$CC -G ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
-    fi
-    ld_shlibs=no
-  esac
-fi
 echo "$as_me:$LINENO: result: $ld_shlibs" >&5
 echo "${ECHO_T}$ld_shlibs" >&6
 test "$ld_shlibs" = no && can_build_shared=no
-# Check hardcoding attributes.
-echo "$as_me:$LINENO: checking how to hardcode library paths into programs" >&5
-echo $ECHO_N "checking how to hardcode library paths into programs... $ECHO_C" >&6
-hardcode_action=
-if test -n "$hardcode_libdir_flag_spec" || \
-   test -n "$runpath_var"; then
+# Do we need to explicitly link libc?
+case "x$archive_cmds_need_lc" in
+x|xyes)
+  # Assume -lc should be added
-  # We can hardcode non-existant directories.
-  if test "$hardcode_direct" != no &&
-     # If the only mechanism to avoid hardcoding is shlibpath_var, we
-     # have to relink, otherwise we might link with an installed library
-     # when we should be linking with a yet-to-be-installed one
-     ## test "$hardcode_shlibpath_var" != no &&
-     test "$hardcode_minus_L" != no; then
-    # Linking always hardcodes the temporary library directory.
-    hardcode_action=relink
-  else
-    # We can link without hardcoding, and we can hardcode nonexisting dirs.
-    hardcode_action=immediate
+  if test "$enable_shared" = yes && test "$GCC" = yes; then
+    case $archive_cmds in
+      # FIXME: we may have to deal with multi-command sequences.
+    '$CC '*)
+      # Test whether the compiler implicitly links with -lc since on some
+      # systems, -lgcc has to come before -lc. If gcc already passes -lc
+      # to ld, don't add -lc before -lgcc.
+      echo "$as_me:$LINENO: checking whether -lc should be explicitly linked in" >&5
+echo $ECHO_N "checking whether -lc should be explicitly linked in... $ECHO_C" >&6
+      $rm conftest*
+      printf "$lt_simple_compile_test_code" > conftest.$ac_ext
+      if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
+  (eval $ac_compile) 2>&5
+  ac_status=$?
+  echo "$as_me:$LINENO: \$? = $ac_status" >&5
+  (exit $ac_status); } 2>conftest.err; then
+        soname=conftest
+        lib=conftest
+        libobjs=conftest.$ac_objext
+        deplibs=
+        wl=$lt_prog_compiler_wl
+	pic_flag=$lt_prog_compiler_pic
+        compiler_flags=-v
+        linker_flags=-v
+        verstring=
+        output_objdir=.
+        libname=conftest
+        lt_save_allow_undefined_flag=$allow_undefined_flag
+        if { (eval echo "$as_me:$LINENO: \"$archive_cmds 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1\"") >&5
+  (eval $archive_cmds 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1) 2>&5
+  ac_status=$?
+        then
+        else
+        fi
+        allow_undefined_flag=$lt_save_allow_undefined_flag
+      else
+        cat conftest.err 1>&5
+      fi
+      $rm conftest*
+      echo "$as_me:$LINENO: result: $archive_cmds_need_lc" >&5
+echo "${ECHO_T}$archive_cmds_need_lc" >&6
+    esac
   fi
-else
-  # We cannot hardcode anything, or else we can only hardcode existing
-  # directories.
-  hardcode_action=unsupported
-fi
-echo "$as_me:$LINENO: result: $hardcode_action" >&5
-echo "${ECHO_T}$hardcode_action" >&6
+esac
-striplib=
-old_striplib=
-echo "$as_me:$LINENO: checking whether stripping libraries is possible" >&5
-echo $ECHO_N "checking whether stripping libraries is possible... $ECHO_C" >&6
-if test -n "$STRIP" && $STRIP -V 2>&1 | grep "GNU strip" >/dev/null; then
-  test -z "$old_striplib" && old_striplib="$STRIP --strip-debug"
-  test -z "$striplib" && striplib="$STRIP --strip-unneeded"
-  echo "$as_me:$LINENO: result: yes" >&5
-echo "${ECHO_T}yes" >&6
-else
-  echo "$as_me:$LINENO: result: no" >&5
-echo "${ECHO_T}no" >&6
-fi
-reload_cmds='$LD$reload_flag -o $output$reload_objs'
-test -z "$deplibs_check_method" && deplibs_check_method=unknown
-# PORTME Fill in your ld.so characteristics
 echo "$as_me:$LINENO: checking dynamic linker characteristics" >&5
 echo $ECHO_N "checking dynamic linker characteristics... $ECHO_C" >&6
 library_names_spec=
 libname_spec='lib$name'
 soname_spec=
+shrext_cmds=".so"
 postinstall_cmds=
 postuninstall_cmds=
 finish_cmds=
@@ -6477,16 +7867,35 @@
 version_type=none
 dynamic_linker="$host_os ld.so"
 sys_lib_dlsearch_path_spec="/lib /usr/lib"
-sys_lib_search_path_spec="/lib /usr/lib /usr/local/lib"
+if test "$GCC" = yes; then
+  sys_lib_search_path_spec=`$CC -print-search-dirs | grep "^libraries:" | $SED -e "s/^libraries://" -e "s,=/,/,g"`
+  if echo "$sys_lib_search_path_spec" | grep ';' >/dev/null ; then
+    # if the path contains ";" then we assume it to be the separator
+    # otherwise default to the standard path separator (i.e. ":") - it is
+    # assumed that no part of a normal pathname contains ";" but that should
+    # okay in the real world where ";" in dirpaths is itself problematic.
+    sys_lib_search_path_spec=`echo "$sys_lib_search_path_spec" | $SED -e 's/;/ /g'`
+  else
+    sys_lib_search_path_spec=`echo "$sys_lib_search_path_spec" | $SED  -e "s/$PATH_SEPARATOR/ /g"`
+  fi
+else
+  sys_lib_search_path_spec="/lib /usr/lib /usr/local/lib"
+fi
+need_lib_prefix=unknown
+hardcode_into_libs=no
+# when you set need_version to no, make sure it does not cause -set_version
+# flags to be left without arguments
+need_version=unknown
 case $host_os in
 aix3*)
   version_type=linux
-  library_names_spec='${libname}${release}.so$versuffix $libname.a'
+  library_names_spec='${libname}${release}${shared_ext}$versuffix $libname.a'
   shlibpath_var=LIBPATH
-  # AIX has no versioning support, so we append a major version to the name.
-  soname_spec='${libname}${release}.so$major'
+  # AIX 3 has no versioning support, so we append a major version to the name.
+  soname_spec='${libname}${release}${shared_ext}$major'
 aix4* | aix5*)
@@ -6496,7 +7905,7 @@
   hardcode_into_libs=yes
     # AIX 5 supports IA64
-    library_names_spec='${libname}${release}.so$major ${libname}${release}.so$versuffix $libname.so'
+    library_names_spec='${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext}$versuffix $libname${shared_ext}'
     shlibpath_var=LD_LIBRARY_PATH
   else
     # With GCC up to 2.95.x, collect2 would create an import file
@@ -6506,57 +7915,54 @@
     # development snapshots of GCC prior to 3.0.
     case $host_os in
       aix4 | aix4.[01] | aix4.[01].*)
-	if { echo '#if __GNUC__ > 2 || (__GNUC__ == 2 && __GNUC_MINOR__ >= 97)'
-	     echo ' yes '
-	     echo '#endif'; } | ${CC} -E - | grep yes > /dev/null; then
-	else
-	  can_build_shared=no
-	fi
+      if { echo '#if __GNUC__ > 2 || (__GNUC__ == 2 && __GNUC_MINOR__ >= 97)'
+	   echo ' yes '
+	   echo '#endif'; } | ${CC} -E - | grep yes > /dev/null; then
+      else
+	can_build_shared=no
+      fi
     esac
-    # AIX (on Power*) has no versioning support, so currently we can
-    # not hardcode correct soname into executable. Probably we can
-    # add versioning support to collect2, so additional links can
-    # be useful in future.
+    # AIX (on Power*) has no versioning support, so currently we can not hardcode correct
+    # soname into executable. Probably we can add versioning support to
+    # collect2, so additional links can be useful in future.
       # If using run time linking (on AIX 4.2 or later) use lib<name>.so
       # instead of lib<name>.a to let people know that these are not
       # typical AIX shared libraries.
-      library_names_spec='${libname}${release}.so$versuffix ${libname}${release}.so$major $libname.so'
+      library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname${shared_ext}'
     else
       # We preserve .a as extension for shared libraries through AIX4.2
       # and later when we are not doing run time linking.
       library_names_spec='${libname}${release}.a $libname.a'
     fi
   fi
-  hardcode_into_libs=yes
 amigaos*)
   library_names_spec='$libname.ixlibrary $libname.a'
   # Create ${libname}_ixlibrary.a entries in /sys/libs.
-  finish_eval='for lib in `ls $libdir/*.ixlibrary 2>/dev/null`; do libname=`$echo "X$lib" | $Xsed -e '\''s%^.*/\([^/]*\)\.ixlibrary$%\1%'\''`; test $rm /sys/libs/${libname}_ixlibrary.a; $show "(cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a)"; (cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a) || exit 1; done'
+  finish_eval='for lib in `ls $libdir/*.ixlibrary 2>/dev/null`; do libname=`$echo "X$lib" | $Xsed -e '\''s%^.*/\([^/]*\)\.ixlibrary$%\1%'\''`; test $rm /sys/libs/${libname}_ixlibrary.a; $show "cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a"; cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a || exit 1; done'
 beos*)
-  library_names_spec='${libname}.so'
+  library_names_spec='${libname}${shared_ext}'
   shlibpath_var=LIBRARY_PATH
-bsdi4*)
+bsdi[45]*)
   version_type=linux
   need_version=no
   finish_cmds='PATH="\$PATH:/sbin" ldconfig $libdir'
   sys_lib_search_path_spec="/shlib /usr/lib /usr/X11/lib /usr/contrib/lib /lib /usr/local/lib"
   sys_lib_dlsearch_path_spec="/shlib /usr/lib /usr/local/lib"
-  export_dynamic_flag_spec=-rdynamic
   # the default ld.so.conf also contains /usr/contrib/lib and
   # /usr/X11R6/lib (/usr/X11 is a link to /usr/X11R6), but let us allow
   # libtool to hard-code these into programs
@@ -6564,29 +7970,56 @@
   version_type=windows
   need_version=no
   need_lib_prefix=no
   case $GCC,$host_os in
-  yes,cygwin*)
+  yes,cygwin* | yes,mingw* | yes,pw32*)
     library_names_spec='$libname.dll.a'
-    soname_spec='`echo ${libname} | sed -e 's/^lib/cyg/'``echo ${release} | sed -e 's/[.]/-/g'`${versuffix}.dll'
-    postinstall_cmds='dlpath=`bash 2>&1 -c '\''. $dir/${file}i;echo \$dlname'\''`~
+    # DLL is installed to $(libdir)/../bin by postinstall_cmds
+    postinstall_cmds='base_file=`basename \${file}`~
+      dlpath=`$SHELL 2>&1 -c '\''. $dir/'\''\${base_file}'\''i;echo \$dlname'\''`~
       dldir=$destdir/`dirname \$dlpath`~
       test -d \$dldir || mkdir -p \$dldir~
-      $install_prog .libs/$dlname \$dldir/$dlname'
-    postuninstall_cmds='dldll=`bash 2>&1 -c '\''. $file; echo \$dlname'\''`~
+      $install_prog $dir/$dlname \$dldir/$dlname~
+      chmod a+x \$dldir/$dlname'
+    postuninstall_cmds='dldll=`$SHELL 2>&1 -c '\''. $file; echo \$dlname'\''`~
       dlpath=$dir/\$dldll~
        $rm \$dlpath'
+    shlibpath_overrides_runpath=yes
+    case $host_os in
+    cygwin*)
+      # Cygwin DLLs use 'cyg' prefix rather than 'lib'
+      soname_spec='`echo ${libname} | sed -e 's/^lib/cyg/'``echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
+      sys_lib_search_path_spec="/usr/lib /lib/w32api /lib /usr/local/lib"
+    mingw*)
+      # MinGW DLLs use traditional 'lib' prefix
+      soname_spec='${libname}`echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
+      if echo "$sys_lib_search_path_spec" | grep ';[c-zC-Z]:/' >/dev/null; then
+        # It is most probably a Windows format PATH printed by
+        # mingw gcc, but we are running on Cygwin. Gcc prints its search
+        # path with ; separators, and with drive letters. We can handle the
+        # drive letters (cygwin fileutils understands them), so leave them,
+        # especially as we might pass files found there to a mingw objdump,
+        # which wouldn't understand a cygwinified path. Ahh.
+      else
+      fi
+    pw32*)
+      # pw32 DLLs use 'pw' prefix rather than 'lib'
+      library_names_spec='`echo ${libname} | sed -e 's/^lib/pw/'``echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
+    esac
-  yes,mingw*)
-    library_names_spec='${libname}`echo ${release} | sed -e 's/[.]/-/g'`${versuffix}.dll'
-    sys_lib_search_path_spec=`$CC -print-search-dirs | grep "^libraries:" | sed -e "s/^libraries://" -e "s/;/ /g" -e "s,=/,/,g"`
-  yes,pw32*)
-    library_names_spec='`echo ${libname} | sed -e 's/^lib/pw/'``echo ${release} | sed -e 's/./-/g'`${versuffix}.dll'
-    library_names_spec='${libname}`echo ${release} | sed -e 's/[.]/-/g'`${versuffix}.dll $libname.lib'
+    library_names_spec='${libname}`echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext} $libname.lib'
   esac
   dynamic_linker='Win32 ld.exe'
@@ -6599,30 +8032,65 @@
   version_type=darwin
   need_lib_prefix=no
   need_version=no
-  library_names_spec='${libname}${release}${versuffix}.$(test .$module = .yes && echo so || echo dylib) ${libname}${release}${major}.$(test .$module = .yes && echo so || echo dylib) ${libname}.$(test .$module = .yes && echo so || echo dylib)'
-  soname_spec='${libname}${release}${major}.$(test .$module = .yes && echo so || echo dylib)'
+  library_names_spec='${libname}${release}${versuffix}$shared_ext ${libname}${release}${major}$shared_ext ${libname}$shared_ext'
+  soname_spec='${libname}${release}${major}$shared_ext'
   shlibpath_var=DYLD_LIBRARY_PATH
+  shrext_cmds='`test .$module = .yes && echo .so || echo .dylib`'
+  # Apple's gcc prints 'gcc -print-search-dirs' doesn't operate the same.
+    sys_lib_search_path_spec=`$CC -print-search-dirs | tr "\n" "$PATH_SEPARATOR" | sed -e 's/libraries:/@libraries:/' | tr "@" "\n" | grep "^libraries:" | sed -e "s/^libraries://" -e "s,=/,/,g" -e "s,$PATH_SEPARATOR, ,g" -e "s,.*,& /lib /usr/lib /usr/local/lib,g"`
+  else
+    sys_lib_search_path_spec='/lib /usr/lib /usr/local/lib'
+  fi
+  sys_lib_dlsearch_path_spec='/usr/local/lib /lib /usr/lib'
+dgux*)
+  version_type=linux
+  need_lib_prefix=no
+  need_version=no
+  library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname$shared_ext'
+  shlibpath_var=LD_LIBRARY_PATH
 freebsd1*)
   dynamic_linker=no
-freebsd*)
-  objformat=`test -x /usr/bin/objformat && /usr/bin/objformat || echo aout`
+kfreebsd*-gnu)
+  need_version=no
+  library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${shared_ext}'
+  shlibpath_overrides_runpath=no
+  hardcode_into_libs=yes
+  dynamic_linker='GNU ld.so'
+freebsd* | dragonfly*)
+  # DragonFly does not have aout.  When/if they implement a new
+  # versioning mechanism, adjust this.
+  if test -x /usr/bin/objformat; then
+    objformat=`/usr/bin/objformat`
+  else
+    case $host_os in
+    freebsd[123]*) objformat=aout ;;
+    *) objformat=elf ;;
+    esac
+  fi
   version_type=freebsd-$objformat
   case $version_type in
     freebsd-elf*)
-      library_names_spec='${libname}${release}.so$versuffix ${libname}${release}.so $libname.so'
+      library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext} $libname${shared_ext}'
       need_version=no
       need_lib_prefix=no
     freebsd-*)
-      library_names_spec='${libname}${release}.so$versuffix $libname.so$versuffix'
+      library_names_spec='${libname}${release}${shared_ext}$versuffix $libname${shared_ext}$versuffix'
       need_version=yes
   esac
@@ -6631,10 +8099,19 @@
   freebsd2*)
+  freebsd3.[01]* | freebsdelf3.[01]*)
+  freebsd3.[2-9]* | freebsdelf3.[2-9]* | \
+  freebsd4.[0-5] | freebsdelf4.[0-5] | freebsd4.1.1 | freebsdelf4.1.1)
+  freebsd*) # from 4.6 on
   esac
@@ -6642,8 +8119,8 @@
   version_type=linux
   need_lib_prefix=no
   need_version=no
-  library_names_spec='${libname}${release}.so$versuffix ${libname}${release}.so${major} ${libname}.so'
+  library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}${major} ${libname}${shared_ext}'
@@ -6651,36 +8128,87 @@
 hpux9* | hpux10* | hpux11*)
   # Give a soname corresponding to the major version so that dld.sl refuses to
   # link against other versions.
-  dynamic_linker="$host_os dld.sl"
   version_type=sunos
   need_lib_prefix=no
   need_version=no
-  shlibpath_var=SHLIB_PATH
-  shlibpath_overrides_runpath=no # +s is required to enable SHLIB_PATH
-  library_names_spec='${libname}${release}.sl$versuffix ${libname}${release}.sl$major $libname.sl'
-  soname_spec='${libname}${release}.sl$major'
+  case $host_cpu in
+  ia64*)
+    shrext_cmds='.so'
+    dynamic_linker="$host_os dld.so"
+    shlibpath_overrides_runpath=yes # Unless +noenvvar is specified.
+    if test "X$HPUX_IA64_MODE" = X32; then
+      sys_lib_search_path_spec="/usr/lib/hpux32 /usr/local/lib/hpux32 /usr/local/lib"
+    else
+      sys_lib_search_path_spec="/usr/lib/hpux64 /usr/local/lib/hpux64"
+    fi
+    sys_lib_dlsearch_path_spec=$sys_lib_search_path_spec
+   hppa*64*)
+     shrext_cmds='.sl'
+     dynamic_linker="$host_os dld.sl"
+     shlibpath_var=LD_LIBRARY_PATH # How should we handle SHLIB_PATH
+     sys_lib_search_path_spec="/usr/lib/pa20_64 /usr/ccs/lib/pa20_64"
+    shrext_cmds='.sl'
+    shlibpath_var=SHLIB_PATH
+    shlibpath_overrides_runpath=no # +s is required to enable SHLIB_PATH
+  esac
   # HP-UX runs *really* slowly unless shared libraries are mode 555.
   postinstall_cmds='chmod 555 $lib'
+interix3*)
+  need_version=no
+  dynamic_linker='Interix 3.x ld.so.1 (PE, like ELF)'
   case $host_os in
     nonstopux*) version_type=nonstopux ;;
-    *)          version_type=irix ;;
+	if test "$lt_cv_prog_gnu_ld" = yes; then
+	else
+		version_type=irix
+	fi ;;
   esac
   need_lib_prefix=no
   need_version=no
-  library_names_spec='${libname}${release}.so$versuffix ${libname}${release}.so$major ${libname}${release}.so $libname.so'
+  library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext} $libname${shared_ext}'
   case $host_os in
   irix5* | nonstopux*)
     libsuff= shlibsuff=
     case $LD in # libtool.m4 will add one of these switches to LD
-    *-32|*"-32 ") libsuff= shlibsuff= libmagic=32-bit;;
-    *-n32|*"-n32 ") libsuff=32 shlibsuff=N32 libmagic=N32;;
-    *-64|*"-64 ") libsuff=64 shlibsuff=64 libmagic=64-bit;;
+    *-32|*"-32 "|*-melf32bsmip|*"-melf32bsmip ")
+      libsuff= shlibsuff= libmagic=32-bit;;
+    *-n32|*"-n32 "|*-melf32bmipn32|*"-melf32bmipn32 ")
+      libsuff=32 shlibsuff=N32 libmagic=N32;;
+    *-64|*"-64 "|*-melf64bmip|*"-melf64bmip ")
+      libsuff=64 shlibsuff=64 libmagic=64-bit;;
     *) libsuff= shlibsuff= libmagic=never-match;;
     esac
@@ -6689,20 +8217,21 @@
   sys_lib_search_path_spec="/usr/lib${libsuff} /lib${libsuff} /usr/local/lib${libsuff}"
   sys_lib_dlsearch_path_spec="/usr/lib${libsuff} /lib${libsuff}"
 # No shared lib support for Linux oldld, aout, or coff.
-linux-gnuoldld* | linux-gnuaout* | linux-gnucoff*)
+linux*oldld* | linux*aout* | linux*coff*)
   dynamic_linker=no
 # This must be Linux ELF.
-linux-gnu*)
+linux*)
   version_type=linux
   need_lib_prefix=no
   need_version=no
   finish_cmds='PATH="\$PATH:/sbin" ldconfig -n $libdir'
@@ -6711,19 +8240,11 @@
   # before this can be enabled.
-  # We used to test for /lib/ld.so.1 and disable shared libraries on
-  # powerpc, because MkLinux only supported shared libraries with the
-  # GNU dynamic linker.  Since this was broken with cross compilers,
-  # most powerpc-linux boxes support dynamic linking these days and
-  # people can always --disable-shared, the test was removed, and we
-  # assume the GNU/Linux dynamic linker is in use.
-  dynamic_linker='GNU/Linux ld.so'
-  # Find out which ABI we are using (multilib Linux x86_64 hack).
+  # find out which ABI we are using
   libsuff=
   case "$host_cpu" in
-  x86_64*|s390x*)
-    echo '#line 6726 "configure"' > conftest.$ac_ext
+  x86_64*|s390x*|powerpc64*)
+    echo '#line 8247 "configure"' > conftest.$ac_ext
   ac_status=$?
@@ -6732,29 +8253,52 @@
       case `/usr/bin/file conftest.$ac_objext` in
       *64-bit*)
         libsuff=64
+        sys_lib_search_path_spec="/lib${libsuff} /usr/lib${libsuff} /usr/local/lib${libsuff}"
       esac
     fi
     rm -rf conftest*
   esac
-  sys_lib_dlsearch_path_spec="/lib${libsuff} /usr/lib${libsuff}"
-  sys_lib_search_path_spec="/lib${libsuff} /usr/lib${libsuff} /usr/local/lib${libsuff}"
+  # Append ld.so.conf contents to the search path
+  if test -f /etc/ld.so.conf; then
+    lt_ld_extra=`awk '/^include / { system(sprintf("cd /etc; cat %s", \$2)); skip = 1; } { if (!skip) print \$0; skip = 0; }' < /etc/ld.so.conf | $SED -e 's/#.*//;s/[:,	]/ /g;s/=[^=]*$//;s/=[^= ]* / /g;/^$/d' | tr '\n' ' '`
+    sys_lib_dlsearch_path_spec="/lib${libsuff} /usr/lib${libsuff} $lt_ld_extra"
+  fi
+  # We used to test for /lib/ld.so.1 and disable shared libraries on
+  # powerpc, because MkLinux only supported shared libraries with the
+  # GNU dynamic linker.  Since this was broken with cross compilers,
+  # most powerpc-linux boxes support dynamic linking these days and
+  # people can always --disable-shared, the test was removed, and we
+  # assume the GNU/Linux dynamic linker is in use.
+  dynamic_linker='GNU/Linux ld.so'
+knetbsd*-gnu)
+  need_version=no
 netbsd*)
   version_type=sunos
   need_lib_prefix=no
   need_version=no
-    library_names_spec='${libname}${release}.so$versuffix ${libname}.so$versuffix'
+    library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${shared_ext}$versuffix'
     finish_cmds='PATH="\$PATH:/sbin" ldconfig -m $libdir'
     dynamic_linker='NetBSD (a.out) ld.so'
   else
-    library_names_spec='${libname}${release}.so$versuffix ${libname}${release}.so$major ${libname}${release}.so ${libname}.so'
     dynamic_linker='NetBSD ld.elf_so'
   fi
@@ -6764,64 +8308,73 @@
 newsos6)
   version_type=linux
+nto-qnx*)
+  need_version=no
 openbsd*)
   version_type=sunos
+  sys_lib_dlsearch_path_spec="/usr/lib"
   need_lib_prefix=no
-  need_version=no
+  # Some older versions of OpenBSD (3.3 at least) *do* need versioned libs.
+  case $host_os in
+    openbsd3.3 | openbsd3.3.*) need_version=yes ;;
+    *)                         need_version=no  ;;
+  esac
+  finish_cmds='PATH="\$PATH:/sbin" ldconfig -m $libdir'
-    openbsd2.[89] | openbsd2.[89].*)
-      shlibpath_overrides_runpath=yes
-    esac
+    case $host_os in
+      openbsd2.[89] | openbsd2.[89].*)
+      esac
   else
   fi
-  finish_cmds='PATH="\$PATH:/sbin" ldconfig -m $libdir'
-  shlibpath_var=LD_LIBRARY_PATH
 os2*)
   libname_spec='$name'
   need_lib_prefix=no
-  library_names_spec='$libname.dll $libname.a'
+  library_names_spec='$libname${shared_ext} $libname.a'
   dynamic_linker='OS/2 ld.exe'
 osf3* | osf4* | osf5*)
   version_type=osf
   need_version=no
   sys_lib_search_path_spec="/usr/shlib /usr/ccs/lib /usr/lib/cmplrs/cc /usr/lib /usr/local/lib /var/shlib"
   sys_lib_dlsearch_path_spec="$sys_lib_search_path_spec"
-sco3.2v5*)
-  version_type=osf
 solaris*)
   version_type=linux
   need_lib_prefix=no
   need_version=no
@@ -6831,7 +8384,7 @@
 sunos4*)
   version_type=sunos
   finish_cmds='PATH="\$PATH:/usr/etc" ldconfig $libdir'
@@ -6841,10 +8394,10 @@
   need_version=yes
-sysv4 | sysv4.2uw2* | sysv4.3* | sysv5*)
+sysv4 | sysv4.3*)
   version_type=linux
     sni)
@@ -6865,29 +8418,43 @@
   esac
-uts4*)
-  version_type=linux
+sysv4*MP*)
+  if test -d /usr/nec ;then
+    library_names_spec='$libname${shared_ext}.$versuffix $libname${shared_ext}.$major $libname${shared_ext}'
+    soname_spec='$libname${shared_ext}.$major'
+  fi
-dgux*)
+sysv5* | sco3.2v5* | sco5v6* | unixware* | OpenUNIX* | sysv4*uw2*)
+  version_type=freebsd-elf
   need_lib_prefix=no
   need_version=no
+  if test "$with_gnu_ld" = yes; then
+    sys_lib_search_path_spec='/usr/local/lib /usr/gnu/lib /usr/ccs/lib /usr/lib /lib'
+  else
+    sys_lib_search_path_spec='/usr/ccs/lib /usr/lib'
+    case $host_os in
+      sco3.2v5*)
+        sys_lib_search_path_spec="$sys_lib_search_path_spec /lib"
+    esac
+  fi
+  sys_lib_dlsearch_path_spec='/usr/lib'
-sysv4*MP*)
-  if test -d /usr/nec ;then
-    library_names_spec='$libname.so.$versuffix $libname.so.$major $libname.so'
-    soname_spec='$libname.so.$major'
-  fi
+uts4*)
@@ -6898,43 +8465,39 @@
 echo "${ECHO_T}$dynamic_linker" >&6
 test "$dynamic_linker" = no && can_build_shared=no
-# Report the final consequences.
-echo "$as_me:$LINENO: checking if libtool supports shared libraries" >&5
-echo $ECHO_N "checking if libtool supports shared libraries... $ECHO_C" >&6
-echo "$as_me:$LINENO: result: $can_build_shared" >&5
-echo "${ECHO_T}$can_build_shared" >&6
+variables_saved_for_relink="PATH $shlibpath_var $runpath_var"
+  variables_saved_for_relink="$variables_saved_for_relink GCC_EXEC_PREFIX COMPILER_PATH LIBRARY_PATH"
+fi
-echo "$as_me:$LINENO: checking whether to build shared libraries" >&5
-echo $ECHO_N "checking whether to build shared libraries... $ECHO_C" >&6
-test "$can_build_shared" = "no" && enable_shared=no
+echo "$as_me:$LINENO: checking how to hardcode library paths into programs" >&5
+echo $ECHO_N "checking how to hardcode library paths into programs... $ECHO_C" >&6
+hardcode_action=
+if test -n "$hardcode_libdir_flag_spec" || \
+   test -n "$runpath_var" || \
+   test "X$hardcode_automatic" = "Xyes" ; then
-# On AIX, shared libraries and static libraries use the same namespace, and
-# are all built from PIC.
-case "$host_os" in
-aix3*)
-  test "$enable_shared" = yes && enable_static=no
-  if test -n "$RANLIB"; then
-    archive_cmds="$archive_cmds~\$RANLIB \$lib"
-    postinstall_cmds='$RANLIB $lib'
+  # We can hardcode non-existant directories.
+  if test "$hardcode_direct" != no &&
+     # If the only mechanism to avoid hardcoding is shlibpath_var, we
+     # have to relink, otherwise we might link with an installed library
+     # when we should be linking with a yet-to-be-installed one
+     ## test "$_LT_AC_TAGVAR(hardcode_shlibpath_var, )" != no &&
+     test "$hardcode_minus_L" != no; then
+    # Linking always hardcodes the temporary library directory.
+    hardcode_action=relink
+  else
+    # We can link without hardcoding, and we can hardcode nonexisting dirs.
+    hardcode_action=immediate
   fi
+else
+  # We cannot hardcode anything, or else we can only hardcode existing
+  # directories.
+  hardcode_action=unsupported
+fi
+echo "$as_me:$LINENO: result: $hardcode_action" >&5
+echo "${ECHO_T}$hardcode_action" >&6
-aix4*)
-  if test "$host_cpu" != ia64 && test "$aix_use_runtimelinking" = no ; then
-  fi
-esac
-echo "$as_me:$LINENO: result: $enable_shared" >&5
-echo "${ECHO_T}$enable_shared" >&6
-echo "$as_me:$LINENO: checking whether to build static libraries" >&5
-echo $ECHO_N "checking whether to build static libraries... $ECHO_C" >&6
-# Make sure either enable_shared or enable_static is yes.
-test "$enable_shared" = yes || enable_static=yes
-echo "$as_me:$LINENO: result: $enable_static" >&5
-echo "${ECHO_T}$enable_static" >&6
 if test "$hardcode_action" = relink; then
   # Fast installation is not supported
   enable_fast_install=no
@@ -6944,10 +8507,34 @@
   enable_fast_install=needless
 fi
-variables_saved_for_relink="PATH $shlibpath_var $runpath_var"
-if test "$GCC" = yes; then
-  variables_saved_for_relink="$variables_saved_for_relink GCC_EXEC_PREFIX COMPILER_PATH LIBRARY_PATH"
+striplib=
+old_striplib=
+echo "$as_me:$LINENO: checking whether stripping libraries is possible" >&5
+echo $ECHO_N "checking whether stripping libraries is possible... $ECHO_C" >&6
+if test -n "$STRIP" && $STRIP -V 2>&1 | grep "GNU strip" >/dev/null; then
+  test -z "$old_striplib" && old_striplib="$STRIP --strip-debug"
+  test -z "$striplib" && striplib="$STRIP --strip-unneeded"
+  echo "$as_me:$LINENO: result: yes" >&5
+echo "${ECHO_T}yes" >&6
+else
+# FIXME - insert some real tests, host_os isn't really good enough
+  case $host_os in
+   darwin*)
+       if test -n "$STRIP" ; then
+         striplib="$STRIP -x"
+       else
+  echo "$as_me:$LINENO: result: no" >&5
+echo "${ECHO_T}no" >&6
 fi
+  esac
+fi
 if test "x$enable_dlopen" != xyes; then
   enable_dlopen=unknown
@@ -6964,11 +8551,94 @@
     lt_cv_dlopen_self=yes
+  mingw* | pw32*)
     lt_cv_dlopen="LoadLibrary"
     lt_cv_dlopen_libs=
+  cygwin*)
+    lt_cv_dlopen="dlopen"
+    lt_cv_dlopen_libs=
+  darwin*)
+  # if libdl is installed we need to link against it
+    echo "$as_me:$LINENO: checking for dlopen in -ldl" >&5
+echo $ECHO_N "checking for dlopen in -ldl... $ECHO_C" >&6
+if test "${ac_cv_lib_dl_dlopen+set}" = set; then
+  echo $ECHO_N "(cached) $ECHO_C" >&6
+else
+  ac_check_lib_save_LIBS=$LIBS
+LIBS="-ldl  $LIBS"
+cat >conftest.$ac_ext <<_ACEOF
+/* confdefs.h.  */
+_ACEOF
+cat confdefs.h >>conftest.$ac_ext
+cat >>conftest.$ac_ext <<_ACEOF
+/* end confdefs.h.  */
+/* Override any gcc2 internal prototype to avoid an error.  */
+#ifdef __cplusplus
+extern "C"
+#endif
+/* We use char because int might match the return type of a gcc2
+   builtin and then its argument prototype would still apply.  */
+char dlopen ();
+int
+main ()
+dlopen ();
+  return 0;
+_ACEOF
+rm -f conftest.$ac_objext conftest$ac_exeext
+if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
+  (eval $ac_link) 2>conftest.er1
+  ac_status=$?
+  grep -v '^ *+' conftest.er1 >conftest.err
+  rm -f conftest.er1
+  cat conftest.err >&5
+  (exit $ac_status); } &&
+	 { ac_try='test -z "$ac_c_werror_flag"
+			 || test ! -s conftest.err'
+  { (eval echo "$as_me:$LINENO: \"$ac_try\"") >&5
+  (eval $ac_try) 2>&5
+  ac_status=$?
+  (exit $ac_status); }; } &&
+	 { ac_try='test -s conftest$ac_exeext'
+  ac_status=$?
+  (exit $ac_status); }; }; then
+  ac_cv_lib_dl_dlopen=yes
+else
+  echo "$as_me: failed program was:" >&5
+sed 's/^/| /' conftest.$ac_ext >&5
+ac_cv_lib_dl_dlopen=no
+fi
+rm -f conftest.err conftest.$ac_objext \
+      conftest$ac_exeext conftest.$ac_ext
+LIBS=$ac_check_lib_save_LIBS
+fi
+echo "$as_me:$LINENO: result: $ac_cv_lib_dl_dlopen" >&5
+echo "${ECHO_T}$ac_cv_lib_dl_dlopen" >&6
+if test $ac_cv_lib_dl_dlopen = yes; then
+  lt_cv_dlopen="dlopen" lt_cv_dlopen_libs="-ldl"
+else
+    lt_cv_dlopen="dyld"
+    lt_cv_dlopen_self=yes
+fi
     echo "$as_me:$LINENO: checking for shl_load" >&5
 echo $ECHO_N "checking for shl_load... $ECHO_C" >&6
@@ -6976,21 +8646,28 @@
 else
-#line $LINENO "configure"
 /* confdefs.h.  */
 _ACEOF
+/* Define shl_load to an innocuous variant, in case <limits.h> declares shl_load.
+   For example, HP-UX 11i <limits.h> declares gettimeofday.  */
+#define shl_load innocuous_shl_load
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char shl_load (); below.
     Prefer <limits.h> to <assert.h> if __STDC__ is defined, since
     <limits.h> exists even on freestanding compilers.  */
 #ifdef __STDC__
 # include <limits.h>
 #else
 # include <assert.h>
 #endif
+#undef shl_load
 #ifdef __cplusplus
 extern "C"
@@ -7021,15 +8698,25 @@
 _ACEOF
-  (eval $ac_link) 2>&5
   ac_status=$?
-         { ac_try='test -s conftest$ac_exeext'
   (eval $ac_try) 2>&5
   ac_status=$?
+  ac_status=$?
   ac_cv_func_shl_load=yes
 else
@@ -7038,7 +8725,8 @@
 ac_cv_func_shl_load=no
 fi
-rm -f conftest.$ac_objext conftest$ac_exeext conftest.$ac_ext
 fi
 echo "$as_me:$LINENO: result: $ac_cv_func_shl_load" >&5
 echo "${ECHO_T}$ac_cv_func_shl_load" >&6
@@ -7053,7 +8741,6 @@
 LIBS="-ldld  $LIBS"
 /* confdefs.h.  */
 _ACEOF
@@ -7077,15 +8764,25 @@
 _ACEOF
   ac_status=$?
   (eval $ac_try) 2>&5
   ac_status=$?
+  ac_status=$?
   ac_cv_lib_dld_shl_load=yes
 else
@@ -7094,7 +8791,8 @@
 ac_cv_lib_dld_shl_load=no
 fi
 fi
 echo "$as_me:$LINENO: result: $ac_cv_lib_dld_shl_load" >&5
@@ -7108,21 +8806,28 @@
 else
 /* confdefs.h.  */
 _ACEOF
+/* Define dlopen to an innocuous variant, in case <limits.h> declares dlopen.
+#define dlopen innocuous_dlopen
     which can conflict with char dlopen (); below.
 #ifdef __STDC__
 #else
 #endif
+#undef dlopen
 #ifdef __cplusplus
 extern "C"
@@ -7153,15 +8858,25 @@
 _ACEOF
   ac_status=$?
   (eval $ac_try) 2>&5
   ac_status=$?
+  ac_status=$?
   ac_cv_func_dlopen=yes
 else
@@ -7170,7 +8885,8 @@
 ac_cv_func_dlopen=no
 fi
 fi
 echo "$as_me:$LINENO: result: $ac_cv_func_dlopen" >&5
 echo "${ECHO_T}$ac_cv_func_dlopen" >&6
@@ -7185,7 +8901,6 @@
 LIBS="-ldl  $LIBS"
 /* confdefs.h.  */
 _ACEOF
@@ -7209,15 +8924,25 @@
 _ACEOF
   ac_status=$?
   (eval $ac_try) 2>&5
   ac_status=$?
+  ac_status=$?
 else
@@ -7226,7 +8951,8 @@
 fi
 fi
@@ -7242,7 +8968,6 @@
 LIBS="-lsvld  $LIBS"
 /* confdefs.h.  */
 _ACEOF
@@ -7266,15 +8991,25 @@
 _ACEOF
   ac_status=$?
   (eval $ac_try) 2>&5
   ac_status=$?
+  ac_status=$?
   ac_cv_lib_svld_dlopen=yes
 else
@@ -7283,7 +9018,8 @@
 ac_cv_lib_svld_dlopen=no
 fi
 fi
 echo "$as_me:$LINENO: result: $ac_cv_lib_svld_dlopen" >&5
@@ -7299,7 +9035,6 @@
 LIBS="-ldld  $LIBS"
 /* confdefs.h.  */
 _ACEOF
@@ -7323,15 +9058,25 @@
 _ACEOF
   ac_status=$?
   (eval $ac_try) 2>&5
   ac_status=$?
+  ac_status=$?
   ac_cv_lib_dld_dld_link=yes
 else
@@ -7340,7 +9085,8 @@
 ac_cv_lib_dld_dld_link=no
 fi
 fi
 echo "$as_me:$LINENO: result: $ac_cv_lib_dld_dld_link" >&5
@@ -7376,10 +9122,10 @@
   case $lt_cv_dlopen in
   dlopen)
     save_CPPFLAGS="$CPPFLAGS"
-        test "x$ac_cv_header_dlfcn_h" = xyes && CPPFLAGS="$CPPFLAGS -DHAVE_DLFCN_H"
+    test "x$ac_cv_header_dlfcn_h" = xyes && CPPFLAGS="$CPPFLAGS -DHAVE_DLFCN_H"
     save_LDFLAGS="$LDFLAGS"
-    eval LDFLAGS=\"\$LDFLAGS $export_dynamic_flag_spec\"
+    wl=$lt_prog_compiler_wl eval LDFLAGS=\"\$LDFLAGS $export_dynamic_flag_spec\"
     save_LIBS="$LIBS"
     LIBS="$lt_cv_dlopen_libs $LIBS"
@@ -7392,10 +9138,10 @@
   	  if test "$cross_compiling" = yes; then :
   lt_cv_dlopen_self=cross
 else
-    lt_dlunknown=0; lt_dlno_uscore=1; lt_dlneed_uscore=2
+  lt_dlunknown=0; lt_dlno_uscore=1; lt_dlneed_uscore=2
   lt_status=$lt_dlunknown
   cat > conftest.$ac_ext <<EOF
-#line 7398 "configure"
+#line 9144 "configure"
 #include "confdefs.h"
 #if HAVE_DLFCN_H
@@ -7452,6 +9198,8 @@
       else if (dlsym( self,"_fnord")) status = $lt_dlneed_uscore;
       /* dlclose (self); */
+  else
+    puts (dlerror ());
     exit (status);
@@ -7461,12 +9209,12 @@
   ac_status=$?
   (exit $ac_status); } && test -s conftest${ac_exeext} 2>/dev/null; then
-    (./conftest; exit; ) 2>/dev/null
+    (./conftest; exit; ) >&5 2>/dev/null
     lt_status=$?
     case x$lt_status in
       x$lt_dlno_uscore) lt_cv_dlopen_self=yes ;;
       x$lt_dlneed_uscore) lt_cv_dlopen_self=yes ;;
-      x$lt_unknown|x*) lt_cv_dlopen_self=no ;;
+      x$lt_dlunknown|x*) lt_cv_dlopen_self=no ;;
     esac
   else :
     # compilation failed
@@ -7481,7 +9229,7 @@
 echo "${ECHO_T}$lt_cv_dlopen_self" >&6
     if test "x$lt_cv_dlopen_self" = xyes; then
-      LDFLAGS="$LDFLAGS $link_static_flag"
+      wl=$lt_prog_compiler_wl eval LDFLAGS=\"\$LDFLAGS $lt_prog_compiler_static\"
       echo "$as_me:$LINENO: checking whether a statically linked program can dlopen itself" >&5
 echo $ECHO_N "checking whether a statically linked program can dlopen itself... $ECHO_C" >&6
 if test "${lt_cv_dlopen_self_static+set}" = set; then
@@ -7490,10 +9238,10 @@
   lt_cv_dlopen_self_static=cross
 else
-#line 7496 "configure"
+#line 9244 "configure"
 #if HAVE_DLFCN_H
@@ -7550,6 +9298,8 @@
+  else
     exit (status);
@@ -7559,12 +9309,12 @@
   ac_status=$?
     lt_status=$?
     case x$lt_status in
       x$lt_dlno_uscore) lt_cv_dlopen_self_static=yes ;;
       x$lt_dlneed_uscore) lt_cv_dlopen_self_static=yes ;;
-      x$lt_unknown|x*) lt_cv_dlopen_self_static=no ;;
+      x$lt_dlunknown|x*) lt_cv_dlopen_self_static=no ;;
     esac
   else :
@@ -7597,109 +9347,114 @@
 fi
-if test "$enable_shared" = yes && test "$GCC" = yes; then
-  case $archive_cmds in
-    # FIXME: we may have to deal with multi-command sequences.
-  '$CC '*)
-    # Test whether the compiler implicitly links with -lc since on some
-    # systems, -lgcc has to come before -lc. If gcc already passes -lc
-    # to ld, don't add -lc before -lgcc.
-    echo "$as_me:$LINENO: checking whether -lc should be explicitly linked in" >&5
-echo $ECHO_N "checking whether -lc should be explicitly linked in... $ECHO_C" >&6
-    if test "${lt_cv_archive_cmds_need_lc+set}" = set; then
-  echo $ECHO_N "(cached) $ECHO_C" >&6
-else
-  $rm conftest*
-    echo 'static int dummy;' > conftest.$ac_ext
+# Report which library types will actually be built
+echo "$as_me:$LINENO: checking if libtool supports shared libraries" >&5
+echo $ECHO_N "checking if libtool supports shared libraries... $ECHO_C" >&6
+echo "$as_me:$LINENO: result: $can_build_shared" >&5
+echo "${ECHO_T}$can_build_shared" >&6
-    if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
-  (eval $ac_compile) 2>&5
-  ac_status=$?
-  echo "$as_me:$LINENO: \$? = $ac_status" >&5
-  (exit $ac_status); }; then
-      soname=conftest
-      lib=conftest
-      libobjs=conftest.$ac_objext
-      deplibs=
-      wl=$lt_cv_prog_cc_wl
-      compiler_flags=-v
-      linker_flags=-v
-      verstring=
-      output_objdir=.
-      libname=conftest
-      save_allow_undefined_flag=$allow_undefined_flag
-      if { (eval echo "$as_me:$LINENO: \"$archive_cmds 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1\"") >&5
-  (eval $archive_cmds 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1) 2>&5
-  ac_status=$?
-      then
-	lt_cv_archive_cmds_need_lc=no
-      else
-	lt_cv_archive_cmds_need_lc=yes
-      fi
-      allow_undefined_flag=$save_allow_undefined_flag
-    else
-      cat conftest.err 1>&5
-    fi
-fi
+echo "$as_me:$LINENO: checking whether to build shared libraries" >&5
+echo $ECHO_N "checking whether to build shared libraries... $ECHO_C" >&6
+test "$can_build_shared" = "no" && enable_shared=no
-    echo "$as_me:$LINENO: result: $lt_cv_archive_cmds_need_lc" >&5
-echo "${ECHO_T}$lt_cv_archive_cmds_need_lc" >&6
+# On AIX, shared libraries and static libraries use the same namespace, and
+# are all built from PIC.
+case $host_os in
+aix3*)
+  test "$enable_shared" = yes && enable_static=no
+  if test -n "$RANLIB"; then
+    archive_cmds="$archive_cmds~\$RANLIB \$lib"
+    postinstall_cmds='$RANLIB $lib'
+  fi
+aix4* | aix5*)
+  if test "$host_cpu" != ia64 && test "$aix_use_runtimelinking" = no ; then
+  fi
-  esac
-fi
-need_lc=${lt_cv_archive_cmds_need_lc-yes}
+esac
+echo "$as_me:$LINENO: result: $enable_shared" >&5
+echo "${ECHO_T}$enable_shared" >&6
-# The second clause should only fire when bootstrapping the
+echo "$as_me:$LINENO: checking whether to build static libraries" >&5
+echo $ECHO_N "checking whether to build static libraries... $ECHO_C" >&6
+# Make sure either enable_shared or enable_static is yes.
+test "$enable_shared" = yes || enable_static=yes
+echo "$as_me:$LINENO: result: $enable_static" >&5
+echo "${ECHO_T}$enable_static" >&6
+# The else clause should only fire when bootstrapping the
 # libtool distribution, otherwise you forgot to ship ltmain.sh
 # with your package, and you will get complaints that there are
 # no rules to generate ltmain.sh.
 if test -f "$ltmain"; then
-else
-  # If there is no Makefile yet, we rely on a make rule to execute
-  # `config.status --recheck' to rerun these tests and create the
-  # libtool script then.
-  test -f Makefile && make "$ltmain"
-fi
-if test -f "$ltmain"; then
-  trap "$rm \"${ofile}T\"; exit 1" 1 2 15
-  $rm -f "${ofile}T"
-  echo creating $ofile
+  # See if we are running on zsh, and set the options which allow our commands through
+  # without removal of \ escapes.
+  if test -n "${ZSH_VERSION+set}" ; then
+    setopt NO_GLOB_SUBST
+  fi
   # Now quote all the things that may contain metacharacters while being
   # careful not to overquote the AC_SUBSTed values.  We take copies of the
   # variables and quote the copies for generation of the libtool script.
-  for var in echo old_CC old_CFLAGS SED \
-    AR AR_FLAGS CC LD LN_S NM SHELL \
-    reload_flag reload_cmds wl \
-    pic_flag link_static_flag no_builtin_flag export_dynamic_flag_spec \
-    thread_safe_flag_spec whole_archive_flag_spec libname_spec \
-    library_names_spec soname_spec \
-    RANLIB old_archive_cmds old_archive_from_new_cmds old_postinstall_cmds \
-    old_postuninstall_cmds archive_cmds archive_expsym_cmds postinstall_cmds \
-    postuninstall_cmds extract_expsyms_cmds old_archive_from_expsyms_cmds \
-    old_striplib striplib file_magic_cmd export_symbols_cmds \
-    deplibs_check_method allow_undefined_flag no_undefined_flag \
-    finish_cmds finish_eval global_symbol_pipe global_symbol_to_cdecl \
-    global_symbol_to_c_name_address \
-    hardcode_libdir_flag_spec hardcode_libdir_separator  \
+  for var in echo old_CC old_CFLAGS AR AR_FLAGS EGREP RANLIB LN_S LTCC LTCFLAGS NM \
+    SED SHELL STRIP \
+    libname_spec library_names_spec soname_spec extract_expsyms_cmds \
+    old_striplib striplib file_magic_cmd finish_cmds finish_eval \
+    deplibs_check_method reload_flag reload_cmds need_locks \
+    lt_cv_sys_global_symbol_pipe lt_cv_sys_global_symbol_to_cdecl \
+    lt_cv_sys_global_symbol_to_c_name_address \
     sys_lib_search_path_spec sys_lib_dlsearch_path_spec \
-    compiler_c_o compiler_o_lo need_locks exclude_expsyms include_expsyms; do
+    old_postinstall_cmds old_postuninstall_cmds \
+    compiler \
+    CC \
+    LD \
+    lt_prog_compiler_wl \
+    lt_prog_compiler_pic \
+    lt_prog_compiler_static \
+    lt_prog_compiler_no_builtin_flag \
+    export_dynamic_flag_spec \
+    thread_safe_flag_spec \
+    whole_archive_flag_spec \
+    enable_shared_with_static_runtimes \
+    old_archive_cmds \
+    old_archive_from_new_cmds \
+    predep_objects \
+    postdep_objects \
+    predeps \
+    postdeps \
+    compiler_lib_search_path \
+    archive_cmds \
+    archive_expsym_cmds \
+    postinstall_cmds \
+    postuninstall_cmds \
+    old_archive_from_expsyms_cmds \
+    allow_undefined_flag \
+    no_undefined_flag \
+    export_symbols_cmds \
+    hardcode_libdir_flag_spec \
+    hardcode_libdir_flag_spec_ld \
+    hardcode_libdir_separator \
+    hardcode_automatic \
+    module_cmds \
+    module_expsym_cmds \
+    lt_cv_prog_compiler_c_o \
+    exclude_expsyms \
+    include_expsyms; do
     case $var in
-    reload_cmds | old_archive_cmds | old_archive_from_new_cmds | \
+    old_archive_cmds | \
+    old_archive_from_new_cmds | \
+    archive_cmds | \
+    archive_expsym_cmds | \
+    module_cmds | \
+    module_expsym_cmds | \
+    old_archive_from_expsyms_cmds | \
+    export_symbols_cmds | \
+    extract_expsyms_cmds | reload_cmds | finish_cmds | \
+    postinstall_cmds | postuninstall_cmds | \
     old_postinstall_cmds | old_postuninstall_cmds | \
-    export_symbols_cmds | archive_cmds | archive_expsym_cmds | \
-    extract_expsyms_cmds | old_archive_from_expsyms_cmds | \
-    postinstall_cmds | postuninstall_cmds | \
-    finish_cmds | sys_lib_search_path_spec | sys_lib_dlsearch_path_spec)
+    sys_lib_search_path_spec | sys_lib_dlsearch_path_spec)
       # Double-quote double-evaled strings.
       eval "lt_$var=\\\"\`\$echo \"X\$$var\" | \$Xsed -e \"\$double_quote_subst\" -e \"\$sed_quote_subst\" -e \"\$delay_variable_subst\"\`\\\""
@@ -7709,14 +9464,29 @@
     esac
   done
-  cat <<__EOF__ > "${ofile}T"
+  case $lt_echo in
+  *'\$0 --fallback-echo"')
+    lt_echo=`$echo "X$lt_echo" | $Xsed -e 's/\\\\\\\$0 --fallback-echo"$/$0 --fallback-echo"/'`
+  esac
+cfgfile="${ofile}T"
+  trap "$rm \"$cfgfile\"; exit 1" 1 2 15
+  $rm -f "$cfgfile"
+  { echo "$as_me:$LINENO: creating $ofile" >&5
+echo "$as_me: creating $ofile" >&6;}
+  cat <<__EOF__ >> "$cfgfile"
 #! $SHELL
-# `$echo "$ofile" | sed 's%^.*/%%'` - Provide generalized library-building support services.
+# `$echo "$cfgfile" | sed 's%^.*/%%'` - Provide generalized library-building support services.
 # Generated automatically by $PROGRAM (GNU $PACKAGE $VERSION$TIMESTAMP)
 # NOTE: Changes made to this file will be lost: look at ltmain.sh.
-# Copyright (C) 1996-2000 Free Software Foundation, Inc.
+# Copyright (C) 1996, 1997, 1998, 1999, 2000, 2001
+# Free Software Foundation, Inc.
+# This file is part of GNU Libtool:
 # Originally by Gordon Matzigkeit <gord at gnu.ai.mit.edu>, 1996
 # This program is free software; you can redistribute it and/or modify
@@ -7731,23 +9501,26 @@
 # You should have received a copy of the GNU General Public License
 # along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+# Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301, USA.
 # As a special exception to the GNU General Public License, if you
 # distribute this file as part of a program that contains a
 # configuration script generated by Autoconf, you may include it under
 # the same distribution terms that you use for the rest of that program.
-# A sed that does not truncate output.
+# A sed program that does not truncate output.
 SED=$lt_SED
 # Sed that helps us avoid accidentally triggering echo(1) options like -n.
-Xsed="${SED} -e s/^X//"
+Xsed="$SED -e 1s/^X//"
 # The HP-UX ksh and POSIX shell print the target directory to stdout
 # if CDPATH is set.
-if test "X\${CDPATH+set}" = Xset; then CDPATH=:; export CDPATH; fi
+(unset CDPATH) >/dev/null 2>&1 && unset CDPATH
+# The names of the tagged configurations supported by this script.
+available_tags=
 # ### BEGIN LIBTOOL CONFIG
 # Libtool was configured on host `(hostname || uname -n) 2>/dev/null | sed 1q`:
@@ -7762,15 +9535,24 @@
 build_old_libs=$enable_static
 # Whether or not to add -lc for building shared libraries.
-build_libtool_need_lc=$need_lc
+build_libtool_need_lc=$archive_cmds_need_lc
+# Whether or not to disallow shared libs when runtime libs are static
+allow_libtool_libs_with_static_runtimes=$enable_shared_with_static_runtimes
 # Whether or not to optimize for fast installation.
 fast_install=$enable_fast_install
 # The host system.
 host_alias=$host_alias
 host=$host
+host_os=$host_os
+# The build system.
+build_alias=$build_alias
+build=$build
+build_os=$build_os
 # An echo program that does not interpret backslashes.
 echo=$lt_echo
@@ -7778,12 +9560,21 @@
 AR=$lt_AR
 AR_FLAGS=$lt_AR_FLAGS
-# The default C compiler.
-CC=$lt_CC
+# A C compiler.
+LTCC=$lt_LTCC
+# LTCC compiler flags.
+LTCFLAGS=$lt_LTCFLAGS
+# A language-specific compiler.
+CC=$lt_compiler
 # Is the compiler the GNU C compiler?
 with_gcc=$GCC
+# An ERE matcher.
+EGREP=$lt_EGREP
 # The linker used to build libraries.
 LD=$lt_LD
@@ -7794,7 +9585,7 @@
 NM=$lt_NM
 # A symbol stripping program
-STRIP=$STRIP
+STRIP=$lt_STRIP
 # Used to examine libraries when file_magic_cmd begins "file"
 MAGIC_CMD=$MAGIC_CMD
@@ -7816,7 +9607,7 @@
 reload_cmds=$lt_reload_cmds
 # How to pass a linker flag through the compiler.
-wl=$lt_wl
+wl=$lt_lt_prog_compiler_wl
 # Object file suffix (normally "o").
 objext="$ac_objext"
@@ -7824,20 +9615,23 @@
 # Old archive suffix (normally "a").
 libext="$libext"
+# Shared library suffix (normally ".so").
+shrext_cmds='$shrext_cmds'
 # Executable file suffix (normally "").
 exeext="$exeext"
 # Additional compiler flags for building library objects.
-pic_flag=$lt_pic_flag
+pic_flag=$lt_lt_prog_compiler_pic
 pic_mode=$pic_mode
+# What is the maximum length of a command?
+max_cmd_len=$lt_cv_sys_max_cmd_len
 # Does compiler simultaneously support -c and -o options?
-compiler_c_o=$lt_compiler_c_o
+compiler_c_o=$lt_lt_cv_prog_compiler_c_o
-# Can we write directly to a .lo ?
-compiler_o_lo=$lt_compiler_o_lo
-# Must we lock files when doing compilation ?
+# Must we lock files when doing compilation?
 need_locks=$lt_need_locks
 # Do we need the lib prefix for modules?
@@ -7856,10 +9650,10 @@
 dlopen_self_static=$enable_dlopen_self_static
 # Compiler flag to prevent dynamic linking.
-link_static_flag=$lt_link_static_flag
+link_static_flag=$lt_lt_prog_compiler_static
 # Compiler flag to turn off builtin functions.
-no_builtin_flag=$lt_no_builtin_flag
+no_builtin_flag=$lt_lt_prog_compiler_no_builtin_flag
 # Compiler flag to allow reflexive dlopens.
 export_dynamic_flag_spec=$lt_export_dynamic_flag_spec
@@ -7901,10 +9695,34 @@
 postinstall_cmds=$lt_postinstall_cmds
 postuninstall_cmds=$lt_postuninstall_cmds
+# Commands used to build a loadable module (assumed same as above if empty)
+module_cmds=$lt_module_cmds
+module_expsym_cmds=$lt_module_expsym_cmds
 # Commands to strip libraries.
 old_striplib=$lt_old_striplib
 striplib=$lt_striplib
+# Dependencies to place before the objects being linked to create a
+# shared library.
+predep_objects=$lt_predep_objects
+# Dependencies to place after the objects being linked to create a
+# shared library.
+postdep_objects=$lt_postdep_objects
+# shared library.
+predeps=$lt_predeps
+# shared library.
+postdeps=$lt_postdeps
+# The library search path used internally by the compiler when linking
+# a shared library.
+compiler_lib_search_path=$lt_compiler_lib_search_path
 # Method to check whether dependent libraries are shared objects.
 deplibs_check_method=$lt_deplibs_check_method
@@ -7924,13 +9742,13 @@
 finish_eval=$lt_finish_eval
 # Take the output of nm and produce a listing of raw symbols and C names.
-global_symbol_pipe=$lt_global_symbol_pipe
+global_symbol_pipe=$lt_lt_cv_sys_global_symbol_pipe
 # Transform the output of nm in a proper C declaration
-global_symbol_to_cdecl=$lt_global_symbol_to_cdecl
+global_symbol_to_cdecl=$lt_lt_cv_sys_global_symbol_to_cdecl
 # Transform the output of nm in a C name address pair
-global_symbol_to_c_name_address=$lt_global_symbol_to_c_name_address
+global_symbol_to_c_name_address=$lt_lt_cv_sys_global_symbol_to_c_name_address
 # This is the shared library runtime path variable.
 runpath_var=$runpath_var
@@ -7951,10 +9769,15 @@
 # This must work even if \$libdir does not exist.
 hardcode_libdir_flag_spec=$lt_hardcode_libdir_flag_spec
+# If ld is used when linking, flag to hardcode \$libdir into
+# a binary during linking. This must work even if \$libdir does
+# not exist.
+hardcode_libdir_flag_spec_ld=$lt_hardcode_libdir_flag_spec_ld
 # Whether we need a single -rpath flag with a separated argument.
 hardcode_libdir_separator=$lt_hardcode_libdir_separator
-# Set to yes if using DIR/libNAME.so during linking hardcodes DIR into the
+# Set to yes if using DIR/libNAME${shared_ext} during linking hardcodes DIR into the
 # resulting binary.
 hardcode_direct=$hardcode_direct
@@ -7966,6 +9789,10 @@
 # the resulting binary.
 hardcode_shlibpath_var=$hardcode_shlibpath_var
+# Set to yes if building a shared library automatically hardcodes DIR into the library
+# and all subsequent libraries and executables linked against it.
+hardcode_automatic=$hardcode_automatic
 # Variables whose values should be saved in libtool wrapper scripts and
 # restored at relink time.
 variables_saved_for_relink="$variables_saved_for_relink"
@@ -8001,9 +9828,10 @@
 __EOF__
   case $host_os in
   aix3*)
-    cat <<\EOF >> "${ofile}T"
+    cat <<\EOF >> "$cfgfile"
 # AIX sometimes has problems with the GCC collect2 program.  For some
 # reason, if we set the COLLECT_NAMES environment variable, the problems
@@ -8016,201 +9844,8799 @@
   esac
-  case $host_os in
-  cygwin* | mingw* | pw32* | os2*)
-    cat <<'EOF' >> "${ofile}T"
-      # This is a source program that is used to create dlls on Windows
-      # Don't remove nor modify the starting and closing comments
-# /* ltdll.c starts here */
-# #define WIN32_LEAN_AND_MEAN
-# #include <windows.h>
-# #undef WIN32_LEAN_AND_MEAN
-# #include <stdio.h>
+  # We use sed instead of cat because bash on DJGPP gets confused if
+  # if finds mixed CR/LF and LF-only lines.  Since sed operates in
+  # text mode, it properly converts lines to CR/LF.  This bash problem
+  # is reportedly fixed, but why not run on old versions too?
+  sed '$q' "$ltmain" >> "$cfgfile" || (rm -f "$cfgfile"; exit 1)
+  mv -f "$cfgfile" "$ofile" || \
+    (rm -f "$ofile" && cp "$cfgfile" "$ofile" && rm -f "$cfgfile")
+  chmod +x "$ofile"
+else
+  # If there is no Makefile yet, we rely on a make rule to execute
+  # `config.status --recheck' to rerun these tests and create the
+  # libtool script then.
+  ltmain_in=`echo $ltmain | sed -e 's/\.sh$/.in/'`
+  if test -f "$ltmain_in"; then
+    test -f Makefile && make "$ltmain"
+  fi
+fi
+ac_ext=cc
+ac_cpp='$CXXCPP $CPPFLAGS'
+ac_compile='$CXX -c $CXXFLAGS $CPPFLAGS conftest.$ac_ext >&5'
+ac_link='$CXX -o conftest$ac_exeext $CXXFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
+ac_compiler_gnu=$ac_cv_cxx_compiler_gnu
+CC="$lt_save_CC"
+# Check whether --with-tags or --without-tags was given.
+if test "${with_tags+set}" = set; then
+  withval="$with_tags"
+  tagnames="$withval"
+fi;
+if test -f "$ltmain" && test -n "$tagnames"; then
+  if test ! -f "${ofile}"; then
+    { echo "$as_me:$LINENO: WARNING: output file \`$ofile' does not exist" >&5
+echo "$as_me: WARNING: output file \`$ofile' does not exist" >&2;}
+  fi
+  if test -z "$LTCC"; then
+    eval "`$SHELL ${ofile} --config | grep '^LTCC='`"
+      { echo "$as_me:$LINENO: WARNING: output file \`$ofile' does not look like a libtool script" >&5
+echo "$as_me: WARNING: output file \`$ofile' does not look like a libtool script" >&2;}
+    else
+      { echo "$as_me:$LINENO: WARNING: using \`LTCC=$LTCC', extracted from \`$ofile'" >&5
+echo "$as_me: WARNING: using \`LTCC=$LTCC', extracted from \`$ofile'" >&2;}
+    fi
+  fi
+  if test -z "$LTCFLAGS"; then
+    eval "`$SHELL ${ofile} --config | grep '^LTCFLAGS='`"
+  fi
+  # Extract list of available tagged configurations in $ofile.
+  # Note that this assumes the entire list is on one line.
+  available_tags=`grep "^available_tags=" "${ofile}" | $SED -e 's/available_tags=\(.*$\)/\1/' -e 's/\"//g'`
+  lt_save_ifs="$IFS"; IFS="${IFS}$PATH_SEPARATOR,"
+  for tagname in $tagnames; do
+    IFS="$lt_save_ifs"
+    # Check whether tagname contains only valid characters
+    case `$echo "X$tagname" | $Xsed -e 's:[-_ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz1234567890,/]::g'` in
+    *)  { { echo "$as_me:$LINENO: error: invalid tag name: $tagname" >&5
+echo "$as_me: error: invalid tag name: $tagname" >&2;}
+   { (exit 1); exit 1; }; }
+    esac
+    if grep "^# ### BEGIN LIBTOOL TAG CONFIG: $tagname$" < "${ofile}" > /dev/null
+    then
+      { { echo "$as_me:$LINENO: error: tag name \"$tagname\" already exists" >&5
+echo "$as_me: error: tag name \"$tagname\" already exists" >&2;}
+    fi
+    # Update the list of available tags.
+    if test -n "$tagname"; then
+      echo appending configuration tag \"$tagname\" to $ofile
+      case $tagname in
+      CXX)
+	if test -n "$CXX" && ( test "X$CXX" != "Xno" &&
+	    ( (test "X$CXX" = "Xg++" && `g++ -v >/dev/null 2>&1` ) ||
+	    (test "X$CXX" != "Xg++"))) ; then
+	  ac_ext=cc
+archive_cmds_need_lc_CXX=no
+allow_undefined_flag_CXX=
+always_export_symbols_CXX=no
+archive_expsym_cmds_CXX=
+export_dynamic_flag_spec_CXX=
+hardcode_direct_CXX=no
+hardcode_libdir_flag_spec_CXX=
+hardcode_libdir_flag_spec_ld_CXX=
+hardcode_libdir_separator_CXX=
+hardcode_minus_L_CXX=no
+hardcode_shlibpath_var_CXX=unsupported
+hardcode_automatic_CXX=no
+module_cmds_CXX=
+module_expsym_cmds_CXX=
+link_all_deplibs_CXX=unknown
+old_archive_cmds_CXX=$old_archive_cmds
+no_undefined_flag_CXX=
+whole_archive_flag_spec_CXX=
+enable_shared_with_static_runtimes_CXX=no
+# Dependencies to place before and after the object being linked:
+predep_objects_CXX=
+postdep_objects_CXX=
+predeps_CXX=
+postdeps_CXX=
+compiler_lib_search_path_CXX=
+# Source file extension for C++ test sources.
+ac_ext=cpp
+# Object file extension for compiled C++ test sources.
+objext=o
+objext_CXX=$objext
+# Code to be used in simple compile tests
+lt_simple_compile_test_code="int some_variable = 0;\n"
+# Code to be used in simple link tests
+lt_simple_link_test_code='int main(int, char *[]) { return(0); }\n'
+# ltmain only uses $CC for tagged configurations so make sure $CC is set.
+# If no C compiler was specified, use CC.
+LTCC=${LTCC-"$CC"}
+# If no C compiler flags were specified, use CFLAGS.
+LTCFLAGS=${LTCFLAGS-"$CFLAGS"}
+# Allow CC to be a program name with arguments.
+compiler=$CC
+# save warnings/boilerplate of simple test code
+ac_outfile=conftest.$ac_objext
+printf "$lt_simple_compile_test_code" >conftest.$ac_ext
+eval "$ac_compile" 2>&1 >/dev/null | $SED '/^$/d; /^ *+/d' >conftest.err
+_lt_compiler_boilerplate=`cat conftest.err`
+$rm conftest*
+printf "$lt_simple_link_test_code" >conftest.$ac_ext
+eval "$ac_link" 2>&1 >/dev/null | $SED '/^$/d; /^ *+/d' >conftest.err
+_lt_linker_boilerplate=`cat conftest.err`
+$rm conftest*
+lt_save_CC=$CC
+lt_save_LD=$LD
+lt_save_GCC=$GCC
+GCC=$GXX
+lt_save_with_gnu_ld=$with_gnu_ld
+lt_save_path_LD=$lt_cv_path_LD
+if test -n "${lt_cv_prog_gnu_ldcxx+set}"; then
+  lt_cv_prog_gnu_ld=$lt_cv_prog_gnu_ldcxx
+else
+  $as_unset lt_cv_prog_gnu_ld
+fi
+if test -n "${lt_cv_path_LDCXX+set}"; then
+  lt_cv_path_LD=$lt_cv_path_LDCXX
+else
+  $as_unset lt_cv_path_LD
+fi
+test -z "${LDCXX+set}" || LD=$LDCXX
+CC=${CXX-"c++"}
+compiler=$CC
+compiler_CXX=$CC
+for cc_temp in $compiler""; do
+  case $cc_temp in
+    compile | *[\\/]compile | ccache | *[\\/]ccache ) ;;
+    distcc | *[\\/]distcc | purify | *[\\/]purify ) ;;
+    *) break;;
+  esac
+done
+cc_basename=`$echo "X$cc_temp" | $Xsed -e 's%.*/%%' -e "s%^$host_alias-%%"`
+# We don't want -fno-exception wen compiling C++ code, so set the
+# no_builtin_flag separately
+if test "$GXX" = yes; then
+  lt_prog_compiler_no_builtin_flag_CXX=' -fno-builtin'
+else
+fi
+  # Set up default GNU C++ configuration
+# Check whether --with-gnu-ld or --without-gnu-ld was given.
+if test "${with_gnu_ld+set}" = set; then
+  withval="$with_gnu_ld"
+  test "$withval" = no || with_gnu_ld=yes
+else
+  with_gnu_ld=no
+fi;
+ac_prog=ld
+  # Check if gcc -print-prog-name=ld gives a path.
+  echo "$as_me:$LINENO: checking for ld used by $CC" >&5
+echo $ECHO_N "checking for ld used by $CC... $ECHO_C" >&6
+  case $host in
+  *-*-mingw*)
+    # gcc leaves a trailing carriage return which upsets mingw
+    ac_prog=`($CC -print-prog-name=ld) 2>&5 | tr -d '\015'` ;;
+    ac_prog=`($CC -print-prog-name=ld) 2>&5` ;;
+  esac
+  case $ac_prog in
+    # Accept absolute paths.
+      re_direlt='/[^/][^/]*/\.\./'
+      # Canonicalize the pathname of ld
+      ac_prog=`echo $ac_prog| $SED 's%\\\\%/%g'`
+      while echo $ac_prog | grep "$re_direlt" > /dev/null 2>&1; do
+	ac_prog=`echo $ac_prog| $SED "s%$re_direlt%/%"`
+      done
+      test -z "$LD" && LD="$ac_prog"
+    # If it fails, then pretend we aren't using GCC.
+    ac_prog=ld
+    # If it is relative, then search for the first ld in PATH.
+    with_gnu_ld=unknown
+  esac
+elif test "$with_gnu_ld" = yes; then
+  echo "$as_me:$LINENO: checking for GNU ld" >&5
+echo $ECHO_N "checking for GNU ld... $ECHO_C" >&6
+else
+  echo "$as_me:$LINENO: checking for non-GNU ld" >&5
+echo $ECHO_N "checking for non-GNU ld... $ECHO_C" >&6
+fi
+if test "${lt_cv_path_LD+set}" = set; then
+else
+  if test -z "$LD"; then
+  lt_save_ifs="$IFS"; IFS=$PATH_SEPARATOR
+  for ac_dir in $PATH; do
+    test -z "$ac_dir" && ac_dir=.
+    if test -f "$ac_dir/$ac_prog" || test -f "$ac_dir/$ac_prog$ac_exeext"; then
+      lt_cv_path_LD="$ac_dir/$ac_prog"
+      # Check to see if the program is GNU ld.  I'd rather use --version,
+      # but apparently some variants of GNU ld only accept -v.
+      # Break only if it was the GNU/non-GNU ld that we prefer.
+      case `"$lt_cv_path_LD" -v 2>&1 </dev/null` in
+      *GNU* | *'with BFD'*)
+	test "$with_gnu_ld" != no && break
+	test "$with_gnu_ld" != yes && break
+      esac
+    fi
+  done
+else
+  lt_cv_path_LD="$LD" # Let the user override the test with a path.
+fi
+fi
+LD="$lt_cv_path_LD"
+if test -n "$LD"; then
+  echo "$as_me:$LINENO: result: $LD" >&5
+echo "${ECHO_T}$LD" >&6
+else
+fi
+test -z "$LD" && { { echo "$as_me:$LINENO: error: no acceptable ld found in \$PATH" >&5
+echo "$as_me: error: no acceptable ld found in \$PATH" >&2;}
+echo "$as_me:$LINENO: checking if the linker ($LD) is GNU ld" >&5
+echo $ECHO_N "checking if the linker ($LD) is GNU ld... $ECHO_C" >&6
+if test "${lt_cv_prog_gnu_ld+set}" = set; then
+else
+  # I'd rather use --version here, but apparently some GNU lds only accept -v.
+case `$LD -v 2>&1 </dev/null` in
+*GNU* | *'with BFD'*)
+  lt_cv_prog_gnu_ld=yes
+  lt_cv_prog_gnu_ld=no
+esac
+fi
+echo "$as_me:$LINENO: result: $lt_cv_prog_gnu_ld" >&5
+echo "${ECHO_T}$lt_cv_prog_gnu_ld" >&6
+with_gnu_ld=$lt_cv_prog_gnu_ld
+  # Check if GNU C++ uses GNU ld as the underlying linker, since the
+  # archiving commands below assume that GNU ld is being used.
+    archive_cmds_CXX='$CC -shared -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $wl$soname -o $lib'
+    archive_expsym_cmds_CXX='$CC -shared -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
+    hardcode_libdir_flag_spec_CXX='${wl}--rpath ${wl}$libdir'
+    export_dynamic_flag_spec_CXX='${wl}--export-dynamic'
+    # If archive_cmds runs LD, not CC, wlarc should be empty
+    # XXX I think wlarc can be eliminated in ltcf-cxx, but I need to
+    #     investigate it a little bit more. (MM)
+    wlarc='${wl}'
+    # ancient GNU ld didn't support --whole-archive et. al.
+    if eval "`$CC -print-prog-name=ld` --help 2>&1" | \
+	grep 'no-whole-archive' > /dev/null; then
+      whole_archive_flag_spec_CXX="$wlarc"'--whole-archive$convenience '"$wlarc"'--no-whole-archive'
+    else
+    fi
+  else
+    with_gnu_ld=no
+    wlarc=
+    # A generic and very simple default shared library creation
+    # command for GNU C++ for the case where it uses the native
+    # linker, instead of GNU ld.  If possible, this setting should
+    # overridden to take advantage of the native linker features on
+    # the platform it is being used on.
+    archive_cmds_CXX='$CC -shared -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -o $lib'
+  fi
+  # Commands to make compiler produce verbose output that lists
+  # what "hidden" libraries, object files and flags are used when
+  # linking a shared library.
+  output_verbose_link_cmd='$CC -shared $CFLAGS -v conftest.$objext 2>&1 | grep "\-L"'
+else
+  GXX=no
+  with_gnu_ld=no
+  wlarc=
+fi
+# PORTME: fill in a description of your system's C++ link characteristics
+echo "$as_me:$LINENO: checking whether the $compiler linker ($LD) supports shared libraries" >&5
+echo $ECHO_N "checking whether the $compiler linker ($LD) supports shared libraries... $ECHO_C" >&6
+ld_shlibs_CXX=yes
+case $host_os in
+  aix3*)
+    # FIXME: insert proper C++ library support
+    ld_shlibs_CXX=no
+  aix4* | aix5*)
+    if test "$host_cpu" = ia64; then
+      # On IA64, the linker does run time linking by default, so we don't
+      # have to do anything special.
+      aix_use_runtimelinking=no
+      exp_sym_flag='-Bexport'
+      no_entry_flag=""
+    else
+      # Test if we are trying to use run time linking or normal
+      # AIX style linking. If -brtl is somewhere in LDFLAGS, we
+      # need to do runtime linking.
+      case $host_os in aix4.[23]|aix4.[23].*|aix5*)
+	for ld_flag in $LDFLAGS; do
+	  case $ld_flag in
+	  *-brtl*)
+	    aix_use_runtimelinking=yes
+	    break
+	  esac
+	done
+      esac
+      exp_sym_flag='-bexport'
+      no_entry_flag='-bnoentry'
+    fi
+    # When large executables or shared objects are built, AIX ld can
+    # have problems creating the table of contents.  If linking a library
+    # or program results in "error TOC overflow" add -mminimal-toc to
+    # CXXFLAGS/CFLAGS for g++/gcc.  In the cases where that is not
+    # enough to fix the problem, add -Wl,-bbigtoc to LDFLAGS.
+    archive_cmds_CXX=''
+    hardcode_direct_CXX=yes
+    hardcode_libdir_separator_CXX=':'
+    link_all_deplibs_CXX=yes
+    if test "$GXX" = yes; then
+      case $host_os in aix4.[012]|aix4.[012].*)
+      # We only want to do this on AIX 4.2 and lower, the check
+      # below for broken collect2 doesn't work under 4.3+
+	collect2name=`${CC} -print-prog-name=collect2`
+	if test -f "$collect2name" && \
+	   strings "$collect2name" | grep resolve_lib_name >/dev/null
+	then
+	  # We have reworked collect2
+	else
+	  # We have old collect2
+	  hardcode_direct_CXX=unsupported
+	  # It fails to find uninstalled libraries when the uninstalled
+	  # path is not listed in the libpath.  Setting hardcode_minus_L
+	  # to unsupported forces relinking
+	  hardcode_minus_L_CXX=yes
+	  hardcode_libdir_flag_spec_CXX='-L$libdir'
+	fi
+      esac
+      shared_flag='-shared'
+      if test "$aix_use_runtimelinking" = yes; then
+	shared_flag="$shared_flag "'${wl}-G'
+      fi
+    else
+      # not using gcc
+	# VisualAge C++, Version 5.5 for AIX 5L for IA-64, Beta 3 Release
+	# chokes on -Wl,-G. The following line is correct:
+	shared_flag='-G'
+      else
+	  shared_flag='${wl}-G'
+	else
+	  shared_flag='${wl}-bM:SRE'
+	fi
+      fi
+    fi
+    # It seems that -bexpall does not export symbols beginning with
+    # underscore (_), so it is better to generate a list of symbols to export.
+    always_export_symbols_CXX=yes
+      # Warning - without using the other runtime loading flags (-brtl),
+      # -berok will link without error, but may produce a broken library.
+      allow_undefined_flag_CXX='-berok'
+      # Determine the default libpath from the value encoded in an empty executable.
+      cat >conftest.$ac_ext <<_ACEOF
+/* confdefs.h.  */
+_ACEOF
+int
+main ()
+  return 0;
+_ACEOF
+  ac_status=$?
+	 { ac_try='test -z "$ac_cxx_werror_flag"
+  ac_status=$?
+  ac_status=$?
+  echo "$as_me:$LINENO: \$? = $ac_status" >&5
+aix_libpath=`dump -H conftest$ac_exeext 2>/dev/null | $SED -n -e '/Import File Strings/,/^$/ { /^0/ { s/^0  *\(.*\)$/\1/; p; }
+# Check for a 64-bit object if we didn't find anything.
+if test -z "$aix_libpath"; then aix_libpath=`dump -HX64 conftest$ac_exeext 2>/dev/null | $SED -n -e '/Import File Strings/,/^$/ { /^0/ { s/^0  *\(.*\)$/\1/; p; }
+}'`; fi
+else
+fi
+if test -z "$aix_libpath"; then aix_libpath="/usr/lib:/lib"; fi
+      hardcode_libdir_flag_spec_CXX='${wl}-blibpath:$libdir:'"$aix_libpath"
+      archive_expsym_cmds_CXX="\$CC"' -o $output_objdir/$soname $libobjs $deplibs '"\${wl}$no_entry_flag"' $compiler_flags `if test "x${allow_undefined_flag}" != "x"; then echo "${wl}${allow_undefined_flag}"; else :; fi` '"\${wl}$exp_sym_flag:\$export_symbols $shared_flag"
+     else
+	hardcode_libdir_flag_spec_CXX='${wl}-R $libdir:/usr/lib:/lib'
+	allow_undefined_flag_CXX="-z nodefs"
+	archive_expsym_cmds_CXX="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs '"\${wl}$no_entry_flag"' $compiler_flags ${wl}${allow_undefined_flag} '"\${wl}$exp_sym_flag:\$export_symbols"
+      else
+/* confdefs.h.  */
+_ACEOF
+int
+main ()
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+}'`; fi
+else
+fi
+	# Warning - without using the other run time loading flags,
+	no_undefined_flag_CXX=' ${wl}-bernotok'
+	allow_undefined_flag_CXX=' ${wl}-berok'
+	# Exported symbols can be pulled into shared objects from archives
+	whole_archive_flag_spec_CXX='$convenience'
+	archive_cmds_need_lc_CXX=yes
+	# This is similar to how AIX traditionally builds its shared libraries.
+	archive_expsym_cmds_CXX="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs ${wl}-bnoentry $compiler_flags ${wl}-bE:$export_symbols${allow_undefined_flag}~$AR $AR_FLAGS $output_objdir/$libname$release.a $output_objdir/$soname'
+      fi
+    fi
+  beos*)
+    if $LD --help 2>&1 | grep ': supported targets:.* elf' > /dev/null; then
+      allow_undefined_flag_CXX=unsupported
+      # Joseph Beckenbach <jrb3 at best.com> says some releases of gcc
+      # support --undefined.  This deserves some investigation.  FIXME
+      archive_cmds_CXX='$CC -nostart $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
+    else
+      ld_shlibs_CXX=no
+    fi
+  chorus*)
+    case $cc_basename in
+	ld_shlibs_CXX=no
+    esac
+  cygwin* | mingw* | pw32*)
+    # _LT_AC_TAGVAR(hardcode_libdir_flag_spec, CXX) is actually meaningless,
+    # as there is no search path for DLLs.
+    always_export_symbols_CXX=no
+    enable_shared_with_static_runtimes_CXX=yes
+    if $LD --help 2>&1 | grep 'auto-import' > /dev/null; then
+      archive_cmds_CXX='$CC -shared -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -o $output_objdir/$soname ${wl}--enable-auto-image-base -Xlinker --out-implib -Xlinker $lib'
+      # If the export-symbols file already is a .def file (1st line
+      # is EXPORTS), use it as is; otherwise, prepend...
+      archive_expsym_cmds_CXX='if test "x`$SED 1q $export_symbols`" = xEXPORTS; then
+	cp $export_symbols $output_objdir/$soname.def;
+      else
+	echo EXPORTS > $output_objdir/$soname.def;
+	cat $export_symbols >> $output_objdir/$soname.def;
+      fi~
+      $CC -shared -nostdlib $output_objdir/$soname.def $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -o $output_objdir/$soname ${wl}--enable-auto-image-base -Xlinker --out-implib -Xlinker $lib'
+    else
+      ld_shlibs_CXX=no
+    fi
+      darwin* | rhapsody*)
+        case $host_os in
+        rhapsody* | darwin1.[012])
+         allow_undefined_flag_CXX='${wl}-undefined ${wl}suppress'
+       *) # Darwin 1.3 on
+         if test -z ${MACOSX_DEPLOYMENT_TARGET} ; then
+           allow_undefined_flag_CXX='${wl}-flat_namespace ${wl}-undefined ${wl}suppress'
+         else
+           case ${MACOSX_DEPLOYMENT_TARGET} in
+             10.[012])
+             10.*)
+               allow_undefined_flag_CXX='${wl}-undefined ${wl}dynamic_lookup'
+           esac
+         fi
+        esac
+      archive_cmds_need_lc_CXX=no
+      hardcode_direct_CXX=no
+      hardcode_automatic_CXX=yes
+      hardcode_shlibpath_var_CXX=unsupported
+      whole_archive_flag_spec_CXX=''
+    if test "$GXX" = yes ; then
+      lt_int_apple_cc_single_mod=no
+      output_verbose_link_cmd='echo'
+      if $CC -dumpspecs 2>&1 | $EGREP 'single_module' >/dev/null ; then
+       lt_int_apple_cc_single_mod=yes
+      fi
+      if test "X$lt_int_apple_cc_single_mod" = Xyes ; then
+       archive_cmds_CXX='$CC -dynamiclib -single_module $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring'
+      else
+          archive_cmds_CXX='$CC -r -keep_private_externs -nostdlib -o ${lib}-master.o $libobjs~$CC -dynamiclib $allow_undefined_flag -o $lib ${lib}-master.o $deplibs $compiler_flags -install_name $rpath/$soname $verstring'
+        fi
+        module_cmds_CXX='$CC $allow_undefined_flag -o $lib -bundle $libobjs $deplibs$compiler_flags'
+        # Don't fix this by using the ld -exported_symbols_list flag, it doesn't exist in older darwin lds
+            archive_expsym_cmds_CXX='sed -e "s,#.*,," -e "s,^[    ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -dynamiclib -single_module $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
+          else
+            archive_expsym_cmds_CXX='sed -e "s,#.*,," -e "s,^[    ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -r -keep_private_externs -nostdlib -o ${lib}-master.o $libobjs~$CC -dynamiclib $allow_undefined_flag -o $lib ${lib}-master.o $deplibs $compiler_flags -install_name $rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
+          fi
+            module_expsym_cmds_CXX='sed -e "s,#.*,," -e "s,^[    ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC $allow_undefined_flag  -o $lib -bundle $libobjs $deplibs$compiler_flags~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
+      else
+        xlc*)
+          archive_cmds_CXX='$CC -qmkshrobj ${wl}-single_module $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-install_name ${wl}`echo $rpath/$soname` $verstring'
+          archive_expsym_cmds_CXX='sed -e "s,#.*,," -e "s,^[    ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -qmkshrobj ${wl}-single_module $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-install_name ${wl}$rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
+         ld_shlibs_CXX=no
+      esac
+      fi
+  dgux*)
+      ec++*)
+	ld_shlibs_CXX=no
+      ghcx*)
+	# Green Hills C++ Compiler
+	ld_shlibs_CXX=no
+	ld_shlibs_CXX=no
+    esac
+  freebsd[12]*)
+    # C++ shared libraries reported to be fairly broken before switch to ELF
+    ld_shlibs_CXX=no
+  freebsd-elf*)
+  freebsd* | kfreebsd*-gnu | dragonfly*)
+    # FreeBSD 3 and later use GNU C++ and GNU ld with standard ELF
+    # conventions
+    ld_shlibs_CXX=yes
+  gnu*)
+  hpux9*)
+    hardcode_libdir_flag_spec_CXX='${wl}+b ${wl}$libdir'
+    hardcode_libdir_separator_CXX=:
+    export_dynamic_flag_spec_CXX='${wl}-E'
+    hardcode_minus_L_CXX=yes # Not in the search PATH,
+				# but as the default
+				# location of the library.
+    CC*)
+      ld_shlibs_CXX=no
+    aCC*)
+      archive_cmds_CXX='$rm $output_objdir/$soname~$CC -b ${wl}+b ${wl}$install_libdir -o $output_objdir/$soname $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
+      # There doesn't appear to be a way to prevent this compiler from
+      # explicitly linking system object files so we need to strip them
+      # from the output so that they don't get included in the library
+      # dependencies.
+      output_verbose_link_cmd='templist=`($CC -b $CFLAGS -v conftest.$objext 2>&1) | grep "[-]L"`; list=""; for z in $templist; do case $z in conftest.$objext) list="$list $z";; *.$objext);; *) list="$list $z";;esac; done; echo $list'
+        archive_cmds_CXX='$rm $output_objdir/$soname~$CC -shared -nostdlib -fPIC ${wl}+b ${wl}$install_libdir -o $output_objdir/$soname $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
+      else
+        ld_shlibs_CXX=no
+      fi
+    esac
+  hpux10*|hpux11*)
+    if test $with_gnu_ld = no; then
+      case $host_cpu in
+      hppa*64*|ia64*)
+	hardcode_libdir_flag_spec_ld_CXX='+b $libdir'
+      esac
+    fi
+    case $host_cpu in
+    hppa*64*|ia64*)
+      hardcode_shlibpath_var_CXX=no
+    esac
+      CC*)
+	ld_shlibs_CXX=no
+      aCC*)
+	case $host_cpu in
+	hppa*64*)
+	  archive_cmds_CXX='$CC -b ${wl}+h ${wl}$soname -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
+	ia64*)
+	  archive_cmds_CXX='$CC -b ${wl}+h ${wl}$soname ${wl}+nodefaultrpath -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
+	  archive_cmds_CXX='$CC -b ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
+	esac
+	# dependencies.
+	output_verbose_link_cmd='templist=`($CC -b $CFLAGS -v conftest.$objext 2>&1) | grep "\-L"`; list=""; for z in $templist; do case $z in conftest.$objext) list="$list $z";; *.$objext);; *) list="$list $z";;esac; done; echo $list'
+	    case $host_cpu in
+	    hppa*64*)
+	      archive_cmds_CXX='$CC -shared -nostdlib -fPIC ${wl}+h ${wl}$soname -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
+	    ia64*)
+	      archive_cmds_CXX='$CC -shared -nostdlib -fPIC ${wl}+h ${wl}$soname ${wl}+nodefaultrpath -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
+	      archive_cmds_CXX='$CC -shared -nostdlib -fPIC ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
+	    esac
+	  fi
+	else
+	  ld_shlibs_CXX=no
+	fi
+    esac
+  interix3*)
+    hardcode_libdir_flag_spec_CXX='${wl}-rpath,$libdir'
+    # Hack: On Interix 3.x, we cannot compile PIC because of a broken gcc.
+    # Instead, shared libraries are loaded at an image base (0x10000000 by
+    # default) and relocated if they conflict, which is a slow very memory
+    # consuming and fragmenting process.  To avoid this, we pick a random,
+    # 256 KiB-aligned image base between 0x50000000 and 0x6FFC0000 at link
+    # time.  Moving up from 0x10000000 also allows more sbrk(2) space.
+    archive_cmds_CXX='$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-h,$soname ${wl}--image-base,`expr ${RANDOM-$$} % 4096 / 2 \* 262144 + 1342177280` -o $lib'
+    archive_expsym_cmds_CXX='sed "s,^,_," $export_symbols >$output_objdir/$soname.expsym~$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-h,$soname ${wl}--retain-symbols-file,$output_objdir/$soname.expsym ${wl}--image-base,`expr ${RANDOM-$$} % 4096 / 2 \* 262144 + 1342177280` -o $lib'
+  irix5* | irix6*)
+      CC*)
+	# SGI C++
+	archive_cmds_CXX='$CC -shared -all -multigot $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
+	# Archives containing C++ object files must be created using
+	# "CC -ar", where "CC" is the IRIX C++ compiler.  This is
+	# necessary to make sure instantiated templates are included
+	# in the archive.
+	old_archive_cmds_CXX='$CC -ar -WR,-u -o $oldlib $oldobjs'
+	  if test "$with_gnu_ld" = no; then
+	    archive_cmds_CXX='$CC -shared -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
+	  else
+	    archive_cmds_CXX='$CC -shared -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` -o $lib'
+	  fi
+	fi
+    esac
+    hardcode_libdir_flag_spec_CXX='${wl}-rpath ${wl}$libdir'
+  linux*)
+      KCC*)
+	# Kuck and Associates, Inc. (KAI) C++ Compiler
+	# KCC will only create a shared library if the output file
+	# ends with ".so" (or ".sl" for HP-UX), so rename the library
+	# to its proper name (with version) after linking.
+	archive_cmds_CXX='tempext=`echo $shared_ext | $SED -e '\''s/\([^()0-9A-Za-z{}]\)/\\\\\1/g'\''`; templib=`echo $lib | $SED -e "s/\${tempext}\..*/.so/"`; $CC $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags --soname $soname -o \$templib; mv \$templib $lib'
+	archive_expsym_cmds_CXX='tempext=`echo $shared_ext | $SED -e '\''s/\([^()0-9A-Za-z{}]\)/\\\\\1/g'\''`; templib=`echo $lib | $SED -e "s/\${tempext}\..*/.so/"`; $CC $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags --soname $soname -o \$templib ${wl}-retain-symbols-file,$export_symbols; mv \$templib $lib'
+	# dependencies.
+	output_verbose_link_cmd='templist=`$CC $CFLAGS -v conftest.$objext -o libconftest$shared_ext 2>&1 | grep "ld"`; rm -f libconftest$shared_ext; list=""; for z in $templist; do case $z in conftest.$objext) list="$list $z";; *.$objext);; *) list="$list $z";;esac; done; echo $list'
+	hardcode_libdir_flag_spec_CXX='${wl}--rpath,$libdir'
+	# "CC -Bstatic", where "CC" is the KAI C++ compiler.
+	old_archive_cmds_CXX='$CC -Bstatic -o $oldlib $oldobjs'
+      icpc*)
+	# Intel C++
+	with_gnu_ld=yes
+	# version 8.0 and above of icpc choke on multiply defined symbols
+	# if we add $predep_objects and $postdep_objects, however 7.1 and
+	# earlier do not add the objects themselves.
+	case `$CC -V 2>&1` in
+	*"Version 7."*)
+  	  archive_cmds_CXX='$CC -shared $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $wl$soname -o $lib'
+  	  archive_expsym_cmds_CXX='$CC -shared $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
+	*)  # Version 8.0 or newer
+	  tmp_idyn=
+	  case $host_cpu in
+	    ia64*) tmp_idyn=' -i_dynamic';;
+	  esac
+  	  archive_cmds_CXX='$CC -shared'"$tmp_idyn"' $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
+	  archive_expsym_cmds_CXX='$CC -shared'"$tmp_idyn"' $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
+	esac
+	whole_archive_flag_spec_CXX='${wl}--whole-archive$convenience ${wl}--no-whole-archive'
+      pgCC*)
+        # Portland Group C++ compiler
+	archive_cmds_CXX='$CC -shared $pic_flag $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname ${wl}$soname -o $lib'
+  	archive_expsym_cmds_CXX='$CC -shared $pic_flag $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname ${wl}$soname ${wl}-retain-symbols-file ${wl}$export_symbols -o $lib'
+	whole_archive_flag_spec_CXX='${wl}--whole-archive`for conv in $convenience\"\"; do test  -n \"$conv\" && new_convenience=\"$new_convenience,$conv\"; done; $echo \"$new_convenience\"` ${wl}--no-whole-archive'
+      cxx*)
+	# Compaq C++
+	archive_expsym_cmds_CXX='$CC -shared $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $wl$soname  -o $lib ${wl}-retain-symbols-file $wl$export_symbols'
+	runpath_var=LD_RUN_PATH
+	hardcode_libdir_flag_spec_CXX='-rpath $libdir'
+	# dependencies.
+	output_verbose_link_cmd='templist=`$CC -shared $CFLAGS -v conftest.$objext 2>&1 | grep "ld"`; templist=`echo $templist | $SED "s/\(^.*ld.*\)\( .*ld .*$\)/\1/"`; list=""; for z in $templist; do case $z in conftest.$objext) list="$list $z";; *.$objext);; *) list="$list $z";;esac; done; echo $list'
+    esac
+  lynxos*)
+    ld_shlibs_CXX=no
+  m88k*)
+    ld_shlibs_CXX=no
+  mvs*)
+      cxx*)
+	ld_shlibs_CXX=no
+	ld_shlibs_CXX=no
+    esac
+  netbsd*)
+    if echo __ELF__ | $CC -E - | grep __ELF__ >/dev/null; then
+      archive_cmds_CXX='$LD -Bshareable  -o $lib $predep_objects $libobjs $deplibs $postdep_objects $linker_flags'
+      wlarc=
+      hardcode_libdir_flag_spec_CXX='-R$libdir'
+    fi
+    # Workaround some broken pre-1.5 toolchains
+    output_verbose_link_cmd='$CC -shared $CFLAGS -v conftest.$objext 2>&1 | grep conftest.$objext | $SED -e "s:-lgcc -lc -lgcc::"'
+  openbsd2*)
+    # C++ shared libraries are fairly broken
+    ld_shlibs_CXX=no
+  openbsd*)
+    archive_cmds_CXX='$CC -shared $pic_flag $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -o $lib'
+    if test -z "`echo __ELF__ | $CC -E - | grep __ELF__`" || test "$host_os-$host_cpu" = "openbsd2.8-powerpc"; then
+      archive_expsym_cmds_CXX='$CC -shared $pic_flag $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-retain-symbols-file,$export_symbols -o $lib'
+    fi
+  osf3*)
+      KCC*)
+      RCC*)
+	# Rational C++ 2.4.1
+	ld_shlibs_CXX=no
+      cxx*)
+	allow_undefined_flag_CXX=' ${wl}-expect_unresolved ${wl}\*'
+	archive_cmds_CXX='$CC -shared${allow_undefined_flag} $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $soname `test -n "$verstring" && echo ${wl}-set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
+	# dependencies.
+	output_verbose_link_cmd='templist=`$CC -shared $CFLAGS -v conftest.$objext 2>&1 | grep "ld" | grep -v "ld:"`; templist=`echo $templist | $SED "s/\(^.*ld.*\)\( .*ld.*$\)/\1/"`; list=""; for z in $templist; do case $z in conftest.$objext) list="$list $z";; *.$objext);; *) list="$list $z";;esac; done; echo $list'
+	if test "$GXX" = yes && test "$with_gnu_ld" = no; then
+	  archive_cmds_CXX='$CC -shared -nostdlib ${allow_undefined_flag} $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
+	else
+	  ld_shlibs_CXX=no
+	fi
+    esac
+  osf4* | osf5*)
+      KCC*)
+	# the KAI C++ compiler.
+	old_archive_cmds_CXX='$CC -o $oldlib $oldobjs'
+      RCC*)
+	ld_shlibs_CXX=no
+      cxx*)
+	allow_undefined_flag_CXX=' -expect_unresolved \*'
+	archive_cmds_CXX='$CC -shared${allow_undefined_flag} $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -msym -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
+	archive_expsym_cmds_CXX='for i in `cat $export_symbols`; do printf "%s %s\\n" -exported_symbol "\$i" >> $lib.exp; done~
+	  echo "-hidden">> $lib.exp~
+	  $CC -shared$allow_undefined_flag $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -msym -soname $soname -Wl,-input -Wl,$lib.exp  `test -n "$verstring" && echo -set_version	$verstring` -update_registry ${output_objdir}/so_locations -o $lib~
+	  $rm $lib.exp'
+	# dependencies.
+	 archive_cmds_CXX='$CC -shared -nostdlib ${allow_undefined_flag} $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-msym ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
+	else
+	  ld_shlibs_CXX=no
+	fi
+    esac
+  psos*)
+    ld_shlibs_CXX=no
+  sunos4*)
+      CC*)
+	# Sun C++ 4.x
+	ld_shlibs_CXX=no
+      lcc*)
+	# Lucid
+	ld_shlibs_CXX=no
+	ld_shlibs_CXX=no
+    esac
+  solaris*)
+      CC*)
+	# Sun C++ 4.2, 5.x and Centerline C++
+	no_undefined_flag_CXX=' -zdefs'
+	archive_cmds_CXX='$CC -G${allow_undefined_flag}  -h$soname -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
+	archive_expsym_cmds_CXX='$echo "{ global:" > $lib.exp~cat $export_symbols | $SED -e "s/\(.*\)/\1;/" >> $lib.exp~$echo "local: *; };" >> $lib.exp~
+	$CC -G${allow_undefined_flag}  ${wl}-M ${wl}$lib.exp -h$soname -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags~$rm $lib.exp'
+	case $host_os in
+	  solaris2.[0-5] | solaris2.[0-5].*) ;;
+	    # The C++ compiler is used as linker so we must use $wl
+	    # flag to pass the commands to the underlying system
+	    # linker. We must also pass each convience library through
+	    # to the system linker between allextract/defaultextract.
+	    # The C++ compiler will combine linker options so we
+	    # cannot just pass the convience library names through
+	    # without $wl.
+	    # Supported since Solaris 2.6 (maybe 2.5.1?)
+	    whole_archive_flag_spec_CXX='${wl}-z ${wl}allextract`for conv in $convenience\"\"; do test -n \"$conv\" && new_convenience=\"$new_convenience,$conv\"; done; $echo \"$new_convenience\"` ${wl}-z ${wl}defaultextract'
+	esac
+	# "CC -xar", where "CC" is the Sun C++ compiler.  This is
+	# in the archive.
+	old_archive_cmds_CXX='$CC -xar -o $oldlib $oldobjs'
+      gcx*)
+	archive_cmds_CXX='$CC -shared $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-h $wl$soname -o $lib'
+	# The C++ compiler must be used to create the archive.
+	old_archive_cmds_CXX='$CC $LDFLAGS -archive -o $oldlib $oldobjs'
+	# GNU C++ compiler with Solaris linker
+	  no_undefined_flag_CXX=' ${wl}-z ${wl}defs'
+	  if $CC --version | grep -v '^2\.7' > /dev/null; then
+	    archive_cmds_CXX='$CC -shared -nostdlib $LDFLAGS $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-h $wl$soname -o $lib'
+		$CC -shared -nostdlib ${wl}-M $wl$lib.exp -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags~$rm $lib.exp'
+	    output_verbose_link_cmd="$CC -shared $CFLAGS -v conftest.$objext 2>&1 | grep \"\-L\""
+	  else
+	    # g++ 2.7 appears to require `-G' NOT `-shared' on this
+	    # platform.
+	    archive_cmds_CXX='$CC -G -nostdlib $LDFLAGS $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-h $wl$soname -o $lib'
+		$CC -G -nostdlib ${wl}-M $wl$lib.exp -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags~$rm $lib.exp'
+	    output_verbose_link_cmd="$CC -G $CFLAGS -v conftest.$objext 2>&1 | grep \"\-L\""
+	  fi
+	  hardcode_libdir_flag_spec_CXX='${wl}-R $wl$libdir'
+	fi
+    esac
+  sysv4*uw2* | sysv5OpenUNIX* | sysv5UnixWare7.[01].[10]* | unixware7* | sco3.2v5.0.[024]*)
+    no_undefined_flag_CXX='${wl}-z,text'
+    runpath_var='LD_RUN_PATH'
+      CC*)
+	archive_cmds_CXX='$CC -G ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds_CXX='$CC -G ${wl}-Bexport:$export_symbols ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_cmds_CXX='$CC -shared ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds_CXX='$CC -shared ${wl}-Bexport:$export_symbols ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+    esac
+  sysv5* | sco3.2v5* | sco5v6*)
+    # Note: We can NOT use -z defs as we might desire, because we do not
+    # link with -lc, and that would cause any symbols used from libc to
+    # always be unresolved, which means just about no library would
+    # ever link correctly.  If we're not using GNU ld we use -z text
+    # though, which does catch some bad symbols but isn't as heavy-handed
+    # as -z defs.
+    # For security reasons, it is highly recommended that you always
+    # use absolute paths for naming shared libraries, and exclude the
+    # DT_RUNPATH tag from executables and libraries.  But doing so
+    # requires that you compile everything twice, which is a pain.
+    # So that behaviour is only enabled if SCOABSPATH is set to a
+    # non-empty value in the environment.  Most likely only useful for
+    # creating official distributions of packages.
+    # This is a hack until libtool officially supports absolute path
+    # names for shared libraries.
+    allow_undefined_flag_CXX='${wl}-z,nodefs'
+    hardcode_libdir_flag_spec_CXX='`test -z "$SCOABSPATH" && echo ${wl}-R,$libdir`'
+    export_dynamic_flag_spec_CXX='${wl}-Bexport'
+      CC*)
+	archive_cmds_CXX='$CC -G ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds_CXX='$CC -G ${wl}-Bexport:$export_symbols ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_cmds_CXX='$CC -shared ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds_CXX='$CC -shared ${wl}-Bexport:$export_symbols ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+    esac
+  tandem*)
+      NCC*)
+	# NonStop-UX NCC 3.20
+	ld_shlibs_CXX=no
+	ld_shlibs_CXX=no
+    esac
+  vxworks*)
+    ld_shlibs_CXX=no
+    ld_shlibs_CXX=no
+esac
+echo "$as_me:$LINENO: result: $ld_shlibs_CXX" >&5
+echo "${ECHO_T}$ld_shlibs_CXX" >&6
+test "$ld_shlibs_CXX" = no && can_build_shared=no
+GCC_CXX="$GXX"
+LD_CXX="$LD"
+cat > conftest.$ac_ext <<EOF
+class Foo
+public:
+  Foo (void) { a = 0; }
+private:
+  int a;
+EOF
+if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
+  (eval $ac_compile) 2>&5
+  ac_status=$?
+  (exit $ac_status); }; then
+  # Parse the compiler output and extract the necessary
+  # objects, libraries and library flags.
+  # Sentinel used to keep track of whether or not we are before
+  # the conftest object file.
+  pre_test_object_deps_done=no
+  # The `*' in the case matches for architectures that use `case' in
+  # $output_verbose_cmd can trigger glob expansion during the loop
+  # eval without this substitution.
+  output_verbose_link_cmd=`$echo "X$output_verbose_link_cmd" | $Xsed -e "$no_glob_subst"`
+  for p in `eval $output_verbose_link_cmd`; do
+    case $p in
+    -L* | -R* | -l*)
+       # Some compilers place space between "-{L,R}" and the path.
+       # Remove the space.
+       if test $p = "-L" \
+	  || test $p = "-R"; then
+	 prev=$p
+	 continue
+       else
+	 prev=
+       fi
+       if test "$pre_test_object_deps_done" = no; then
+	 case $p in
+	 -L* | -R*)
+	   # Internal compiler library paths should come after those
+	   # provided the user.  The postdeps already come after the
+	   # user supplied libs so there is no need to process them.
+	   if test -z "$compiler_lib_search_path_CXX"; then
+	     compiler_lib_search_path_CXX="${prev}${p}"
+	   else
+	     compiler_lib_search_path_CXX="${compiler_lib_search_path_CXX} ${prev}${p}"
+	   fi
+	 # The "-l" case would never come before the object being
+	 # linked, so don't bother handling this case.
+	 esac
+       else
+	 if test -z "$postdeps_CXX"; then
+	   postdeps_CXX="${prev}${p}"
+	 else
+	   postdeps_CXX="${postdeps_CXX} ${prev}${p}"
+	 fi
+       fi
+    *.$objext)
+       # This assumes that the test object file only shows up
+       # once in the compiler output.
+       if test "$p" = "conftest.$objext"; then
+	 pre_test_object_deps_done=yes
+	 continue
+       fi
+	 if test -z "$predep_objects_CXX"; then
+	   predep_objects_CXX="$p"
+	 else
+	   predep_objects_CXX="$predep_objects_CXX $p"
+	 fi
+       else
+	 if test -z "$postdep_objects_CXX"; then
+	   postdep_objects_CXX="$p"
+	 else
+	   postdep_objects_CXX="$postdep_objects_CXX $p"
+	 fi
+       fi
+    *) ;; # Ignore the rest.
+    esac
+  done
+  # Clean up.
+  rm -f a.out a.exe
+else
+  echo "libtool.m4: error: problem compiling CXX test program"
+fi
+$rm -f confest.$objext
+# PORTME: override above test on systems where it is broken
+case $host_os in
+interix3*)
+  # Interix 3.5 installs completely hosed .la files for C++, so rather than
+  # hack all around it, let's just trust "g++" to DTRT.
+  postdeps_CXX=
+solaris*)
+  CC*)
+    # Adding this requires a known-good setup of shared libraries for
+    # Sun compiler versions before 5.6, else PIC objects from an old
+    # archive will be linked into the output, leading to subtle bugs.
+    postdeps_CXX='-lCstd -lCrun'
+  esac
+esac
+case " $postdeps_CXX " in
+*" -lc "*) archive_cmds_need_lc_CXX=no ;;
+esac
+lt_prog_compiler_wl_CXX=
+lt_prog_compiler_pic_CXX=
+lt_prog_compiler_static_CXX=
+echo "$as_me:$LINENO: checking for $compiler option to produce PIC" >&5
+echo $ECHO_N "checking for $compiler option to produce PIC... $ECHO_C" >&6
+  # C++ specific cases for pic, static, wl, etc.
+    lt_prog_compiler_wl_CXX='-Wl,'
+    lt_prog_compiler_static_CXX='-static'
+    case $host_os in
+    aix*)
+      # All AIX code is PIC.
+	# AIX 5 now supports IA64 processor
+	lt_prog_compiler_static_CXX='-Bstatic'
+      fi
+    amigaos*)
+      # FIXME: we need at least 68020 code to build shared libraries, but
+      # adding the `-m68020' flag to GCC prevents building anything better,
+      # like `-m68040'.
+      lt_prog_compiler_pic_CXX='-m68020 -resident32 -malways-restore-a4'
+    beos* | cygwin* | irix5* | irix6* | nonstopux* | osf3* | osf4* | osf5*)
+      # PIC is the default for these OSes.
+    mingw* | os2* | pw32*)
+      # This hack is so that the source file can tell whether it is being
+      # built for inclusion in a dll (and should export symbols for example).
+      lt_prog_compiler_pic_CXX='-DDLL_EXPORT'
+      # PIC is the default on this platform
+      # Common symbols not allowed in MH_DYLIB files
+      lt_prog_compiler_pic_CXX='-fno-common'
+    *djgpp*)
+      # DJGPP does not support shared libraries at all
+    interix3*)
+      # Interix 3.x gcc -fpic/-fPIC options generate broken code.
+      # Instead, we relocate shared libraries at runtime.
+    sysv4*MP*)
+      if test -d /usr/nec; then
+	lt_prog_compiler_pic_CXX=-Kconform_pic
+      fi
+    hpux*)
+      # PIC is the default for IA64 HP-UX and 64-bit HP-UX, but
+      # not for PA HP-UX.
+      case $host_cpu in
+      hppa*64*|ia64*)
+	lt_prog_compiler_pic_CXX='-fPIC'
+      esac
+    esac
+  else
+    case $host_os in
+      aix4* | aix5*)
+	else
+	  lt_prog_compiler_static_CXX='-bnso -bI:/lib/syscalls.exp'
+	fi
+      chorus*)
+	cxch68*)
+	  # _LT_AC_TAGVAR(lt_prog_compiler_static, CXX)="--no_auto_instantiation -u __main -u __premain -u _abort -r $COOL_DIR/lib/libOrb.a $MVME_DIR/lib/CC/libC.a $MVME_DIR/lib/classix/libcx.s.a"
+	esac
+       darwin*)
+           xlc*)
+           lt_prog_compiler_pic_CXX='-qnocommon'
+         esac
+      dgux*)
+	  ec++*)
+	    lt_prog_compiler_pic_CXX='-KPIC'
+	  ghcx*)
+	    lt_prog_compiler_pic_CXX='-pic'
+	esac
+	# FreeBSD uses GNU C++
+      hpux9* | hpux10* | hpux11*)
+	  CC*)
+	    lt_prog_compiler_static_CXX='${wl}-a ${wl}archive'
+	    if test "$host_cpu" != ia64; then
+	      lt_prog_compiler_pic_CXX='+Z'
+	    fi
+	  aCC*)
+	    case $host_cpu in
+	    hppa*64*|ia64*)
+	      # +Z the default
+	    esac
+	esac
+      interix*)
+	# This is c89, which is MS Visual C++ (no shared libs)
+	# Anyone wants to do a port?
+      irix5* | irix6* | nonstopux*)
+	  CC*)
+	    lt_prog_compiler_static_CXX='-non_shared'
+	    # CC pic flag -KPIC is the default.
+	esac
+      linux*)
+	  KCC*)
+	    # KAI C++ Compiler
+	    lt_prog_compiler_wl_CXX='--backend -Wl,'
+	  icpc* | ecpc*)
+	    # Intel C++
+	  pgCC*)
+	    # Portland Group C++ compiler.
+	    lt_prog_compiler_pic_CXX='-fpic'
+	  cxx*)
+	    # Compaq C++
+	    # Make sure the PIC flag is empty.  It appears that all Alpha
+	    # Linux and Compaq Tru64 Unix objects are PIC.
+	esac
+      lynxos*)
+      m88k*)
+      mvs*)
+	  cxx*)
+	    lt_prog_compiler_pic_CXX='-W c,exportall'
+	esac
+      netbsd*)
+      osf3* | osf4* | osf5*)
+	  KCC*)
+	  RCC*)
+	  cxx*)
+	    # Digital/Compaq C++
+	esac
+      psos*)
+      solaris*)
+	  CC*)
+	    lt_prog_compiler_wl_CXX='-Qoption ld '
+	  gcx*)
+	    lt_prog_compiler_pic_CXX='-PIC'
+	esac
+      sunos4*)
+	  CC*)
+	    # Sun C++ 4.x
+	  lcc*)
+	    # Lucid
+	esac
+      tandem*)
+	  NCC*)
+	esac
+      sysv5* | unixware* | sco3.2v5* | sco5v6* | OpenUNIX*)
+	  CC*)
+	esac
+      vxworks*)
+	lt_prog_compiler_can_build_shared_CXX=no
+    esac
+  fi
+echo "$as_me:$LINENO: result: $lt_prog_compiler_pic_CXX" >&5
+echo "${ECHO_T}$lt_prog_compiler_pic_CXX" >&6
-# #ifndef __CYGWIN__
-# #  ifdef __CYGWIN32__
-# #    define __CYGWIN__ __CYGWIN32__
-# #  endif
-# #endif
+# Check to make sure the PIC flag actually works.
-# #ifdef __cplusplus
-# extern "C" {
-# #endif
-# BOOL APIENTRY DllMain (HINSTANCE hInst, DWORD reason, LPVOID reserved);
-# #endif
+if test -n "$lt_prog_compiler_pic_CXX"; then
+echo "$as_me:$LINENO: checking if $compiler PIC flag $lt_prog_compiler_pic_CXX works" >&5
+echo $ECHO_N "checking if $compiler PIC flag $lt_prog_compiler_pic_CXX works... $ECHO_C" >&6
+if test "${lt_prog_compiler_pic_works_CXX+set}" = set; then
+  echo $ECHO_N "(cached) $ECHO_C" >&6
+else
+  lt_prog_compiler_pic_works_CXX=no
+  ac_outfile=conftest.$ac_objext
+   printf "$lt_simple_compile_test_code" > conftest.$ac_ext
+   lt_compiler_flag="$lt_prog_compiler_pic_CXX -DPIC"
+   # Insert the option either (1) after the last *FLAGS variable, or
+   # (2) before a word containing "conftest.", or (3) at the end.
+   # Note that $ac_compile itself does not contain backslashes and begins
+   # with a dollar sign (not a hyphen), so the echo should work correctly.
+   # The option is referenced via a variable to avoid confusing sed.
+   lt_compile=`echo "$ac_compile" | $SED \
+   -e 's:.*FLAGS}\{0,1\} :&$lt_compiler_flag :; t' \
+   -e 's: [^ ]*conftest\.: $lt_compiler_flag&:; t' \
+   -e 's:$: $lt_compiler_flag:'`
+   (eval echo "\"\$as_me:11584: $lt_compile\"" >&5)
+   (eval "$lt_compile" 2>conftest.err)
+   ac_status=$?
+   cat conftest.err >&5
+   echo "$as_me:11588: \$? = $ac_status" >&5
+   if (exit $ac_status) && test -s "$ac_outfile"; then
+     # The compiler can only warn and ignore the option if not recognized
+     # So say no if there are warnings other than the usual output.
+     $echo "X$_lt_compiler_boilerplate" | $Xsed -e '/^$/d' >conftest.exp
+     $SED '/^$/d; /^ *+/d' conftest.err >conftest.er2
+     if test ! -s conftest.er2 || diff conftest.exp conftest.er2 >/dev/null; then
+       lt_prog_compiler_pic_works_CXX=yes
+     fi
+   fi
+   $rm conftest*
+fi
+echo "$as_me:$LINENO: result: $lt_prog_compiler_pic_works_CXX" >&5
+echo "${ECHO_T}$lt_prog_compiler_pic_works_CXX" >&6
+if test x"$lt_prog_compiler_pic_works_CXX" = xyes; then
+    case $lt_prog_compiler_pic_CXX in
+     *) lt_prog_compiler_pic_CXX=" $lt_prog_compiler_pic_CXX" ;;
+     esac
+else
+fi
+fi
+case $host_os in
+  # For platforms which do not support PIC, -DPIC is meaningless:
+  *djgpp*)
+    lt_prog_compiler_pic_CXX="$lt_prog_compiler_pic_CXX -DPIC"
+esac
-# #ifdef __CYGWIN__
-# #include <cygwin/cygwin_dll.h>
-# DECLARE_CYGWIN_DLL( DllMain );
-# #endif
-# HINSTANCE __hDllInstance_base;
+# Check to make sure the static flag actually works.
-# BOOL APIENTRY
-# DllMain (HINSTANCE hInst, DWORD reason, LPVOID reserved)
-#   __hDllInstance_base = hInst;
-#   return TRUE;
-# /* ltdll.c ends here */
-	# This is a source program that is used to create import libraries
-	# on Windows for dlls which lack them. Don't remove nor modify the
-	# starting and closing comments
-# /* impgen.c starts here */
-# /*   Copyright (C) 1999-2000 Free Software Foundation, Inc.
+wl=$lt_prog_compiler_wl_CXX eval lt_tmp_static_flag=\"$lt_prog_compiler_static_CXX\"
+echo "$as_me:$LINENO: checking if $compiler static flag $lt_tmp_static_flag works" >&5
+echo $ECHO_N "checking if $compiler static flag $lt_tmp_static_flag works... $ECHO_C" >&6
+if test "${lt_prog_compiler_static_works_CXX+set}" = set; then
+else
+  lt_prog_compiler_static_works_CXX=no
+   save_LDFLAGS="$LDFLAGS"
+   LDFLAGS="$LDFLAGS $lt_tmp_static_flag"
+   printf "$lt_simple_link_test_code" > conftest.$ac_ext
+   if (eval $ac_link 2>conftest.err) && test -s conftest$ac_exeext; then
+     # The linker can only warn and ignore the option if not recognized
+     if test -s conftest.err; then
+       # Append any errors to the config.log.
+       cat conftest.err 1>&5
+       $echo "X$_lt_linker_boilerplate" | $Xsed -e '/^$/d' > conftest.exp
+       if diff conftest.exp conftest.er2 >/dev/null; then
+         lt_prog_compiler_static_works_CXX=yes
+       fi
+     else
+     fi
+   fi
+   $rm conftest*
+   LDFLAGS="$save_LDFLAGS"
+fi
+echo "$as_me:$LINENO: result: $lt_prog_compiler_static_works_CXX" >&5
+echo "${ECHO_T}$lt_prog_compiler_static_works_CXX" >&6
+if test x"$lt_prog_compiler_static_works_CXX" = xyes; then
+else
+fi
+echo "$as_me:$LINENO: checking if $compiler supports -c -o file.$ac_objext" >&5
+echo $ECHO_N "checking if $compiler supports -c -o file.$ac_objext... $ECHO_C" >&6
+if test "${lt_cv_prog_compiler_c_o_CXX+set}" = set; then
+else
+  lt_cv_prog_compiler_c_o_CXX=no
+   $rm -r conftest 2>/dev/null
+   mkdir conftest
+   cd conftest
+   mkdir out
+   lt_compiler_flag="-o out/conftest2.$ac_objext"
+   (eval echo "\"\$as_me:11688: $lt_compile\"" >&5)
+   (eval "$lt_compile" 2>out/conftest.err)
+   ac_status=$?
+   cat out/conftest.err >&5
+   echo "$as_me:11692: \$? = $ac_status" >&5
+   if (exit $ac_status) && test -s out/conftest2.$ac_objext
+   then
+     $echo "X$_lt_compiler_boilerplate" | $Xsed -e '/^$/d' > out/conftest.exp
+     $SED '/^$/d; /^ *+/d' out/conftest.err >out/conftest.er2
+     if test ! -s out/conftest.er2 || diff out/conftest.exp out/conftest.er2 >/dev/null; then
+       lt_cv_prog_compiler_c_o_CXX=yes
+     fi
+   fi
+   chmod u+w . 2>&5
+   $rm conftest*
+   # SGI C++ compiler will create directory out/ii_files/ for
+   # template instantiation
+   test -d out/ii_files && $rm out/ii_files/* && rmdir out/ii_files
+   $rm out/* && rmdir out
+   cd ..
+   rmdir conftest
+   $rm conftest*
+fi
+echo "$as_me:$LINENO: result: $lt_cv_prog_compiler_c_o_CXX" >&5
+echo "${ECHO_T}$lt_cv_prog_compiler_c_o_CXX" >&6
+hard_links="nottested"
+if test "$lt_cv_prog_compiler_c_o_CXX" = no && test "$need_locks" != no; then
+  # do not overwrite the value of need_locks provided by the user
+  echo "$as_me:$LINENO: checking if we can lock with hard links" >&5
+echo $ECHO_N "checking if we can lock with hard links... $ECHO_C" >&6
+  hard_links=yes
+  $rm conftest*
+  ln conftest.a conftest.b 2>/dev/null && hard_links=no
+  touch conftest.a
+  ln conftest.a conftest.b 2>&5 || hard_links=no
+  echo "$as_me:$LINENO: result: $hard_links" >&5
+echo "${ECHO_T}$hard_links" >&6
+  if test "$hard_links" = no; then
+    { echo "$as_me:$LINENO: WARNING: \`$CC' does not support \`-c -o', so \`make -j' may be unsafe" >&5
+echo "$as_me: WARNING: \`$CC' does not support \`-c -o', so \`make -j' may be unsafe" >&2;}
+    need_locks=warn
+  fi
+else
+  need_locks=no
+fi
+  export_symbols_cmds_CXX='$NM $libobjs $convenience | $global_symbol_pipe | $SED '\''s/.* //'\'' | sort | uniq > $export_symbols'
+  case $host_os in
+  aix4* | aix5*)
+    # If we're using GNU nm, then we don't want the "-C" option.
+    # -C means demangle to AIX nm, but means don't demangle with GNU nm
+    if $NM -V 2>&1 | grep 'GNU' > /dev/null; then
+      export_symbols_cmds_CXX='$NM -Bpg $libobjs $convenience | awk '\''{ if (((\$2 == "T") || (\$2 == "D") || (\$2 == "B")) && (substr(\$3,1,1) != ".")) { print \$3 } }'\'' | sort -u > $export_symbols'
+    else
+      export_symbols_cmds_CXX='$NM -BCpg $libobjs $convenience | awk '\''{ if (((\$2 == "T") || (\$2 == "D") || (\$2 == "B")) && (substr(\$3,1,1) != ".")) { print \$3 } }'\'' | sort -u > $export_symbols'
+    fi
+  pw32*)
+    export_symbols_cmds_CXX="$ltdll_cmds"
+  cygwin* | mingw*)
+    export_symbols_cmds_CXX='$NM $libobjs $convenience | $global_symbol_pipe | $SED -e '\''/^[BCDGRS] /s/.* \([^ ]*\)/\1 DATA/;/^.* __nm__/s/^.* __nm__\([^ ]*\) [^ ]*/\1 DATA/;/^I /d;/^[AITW] /s/.* //'\'' | sort | uniq > $export_symbols'
+  esac
-#  This file is part of GNU libtool.
+# Do we need to explicitly link libc?
-#  This program is free software; you can redistribute it and/or modify
-#  it under the terms of the GNU General Public License as published by
-#  the Free Software Foundation; either version 2 of the License, or
-#  (at your option) any later version.
+case "x$archive_cmds_need_lc_CXX" in
+x|xyes)
+  # Assume -lc should be added
+  if test "$enable_shared" = yes && test "$GCC" = yes; then
+    case $archive_cmds_CXX in
+      # FIXME: we may have to deal with multi-command sequences.
+    '$CC '*)
+      # Test whether the compiler implicitly links with -lc since on some
+      # systems, -lgcc has to come before -lc. If gcc already passes -lc
+      # to ld, don't add -lc before -lgcc.
+      echo "$as_me:$LINENO: checking whether -lc should be explicitly linked in" >&5
+echo $ECHO_N "checking whether -lc should be explicitly linked in... $ECHO_C" >&6
+      $rm conftest*
+      if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
+  ac_status=$?
+  (exit $ac_status); } 2>conftest.err; then
+        soname=conftest
+        lib=conftest
+        libobjs=conftest.$ac_objext
+        deplibs=
+        wl=$lt_prog_compiler_wl_CXX
+	pic_flag=$lt_prog_compiler_pic_CXX
+        compiler_flags=-v
+        linker_flags=-v
+        verstring=
+        output_objdir=.
+        libname=conftest
+        lt_save_allow_undefined_flag=$allow_undefined_flag_CXX
+        if { (eval echo "$as_me:$LINENO: \"$archive_cmds_CXX 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1\"") >&5
+  (eval $archive_cmds_CXX 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1) 2>&5
+  ac_status=$?
+        then
+        else
+        fi
+        allow_undefined_flag_CXX=$lt_save_allow_undefined_flag
+      else
+      fi
+      $rm conftest*
+      echo "$as_me:$LINENO: result: $archive_cmds_need_lc_CXX" >&5
+echo "${ECHO_T}$archive_cmds_need_lc_CXX" >&6
+    esac
+  fi
+esac
+echo "$as_me:$LINENO: checking dynamic linker characteristics" >&5
+echo $ECHO_N "checking dynamic linker characteristics... $ECHO_C" >&6
+library_names_spec=
+libname_spec='lib$name'
+soname_spec=
+shrext_cmds=".so"
+postinstall_cmds=
+postuninstall_cmds=
+finish_cmds=
+finish_eval=
+shlibpath_var=
+shlibpath_overrides_runpath=unknown
+version_type=none
+dynamic_linker="$host_os ld.so"
+sys_lib_dlsearch_path_spec="/lib /usr/lib"
+if test "$GCC" = yes; then
+  sys_lib_search_path_spec=`$CC -print-search-dirs | grep "^libraries:" | $SED -e "s/^libraries://" -e "s,=/,/,g"`
+  if echo "$sys_lib_search_path_spec" | grep ';' >/dev/null ; then
+    # if the path contains ";" then we assume it to be the separator
+    # otherwise default to the standard path separator (i.e. ":") - it is
+    # assumed that no part of a normal pathname contains ";" but that should
+    # okay in the real world where ";" in dirpaths is itself problematic.
+    sys_lib_search_path_spec=`echo "$sys_lib_search_path_spec" | $SED -e 's/;/ /g'`
+  else
+    sys_lib_search_path_spec=`echo "$sys_lib_search_path_spec" | $SED  -e "s/$PATH_SEPARATOR/ /g"`
+  fi
+else
+  sys_lib_search_path_spec="/lib /usr/lib /usr/local/lib"
+fi
+need_lib_prefix=unknown
+hardcode_into_libs=no
+# when you set need_version to no, make sure it does not cause -set_version
+# flags to be left without arguments
+need_version=unknown
+case $host_os in
+aix3*)
+  version_type=linux
+  library_names_spec='${libname}${release}${shared_ext}$versuffix $libname.a'
+  shlibpath_var=LIBPATH
+  # AIX 3 has no versioning support, so we append a major version to the name.
+  soname_spec='${libname}${release}${shared_ext}$major'
+aix4* | aix5*)
+  need_lib_prefix=no
+  need_version=no
+  hardcode_into_libs=yes
+    # AIX 5 supports IA64
+    library_names_spec='${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext}$versuffix $libname${shared_ext}'
+    shlibpath_var=LD_LIBRARY_PATH
+  else
+    # With GCC up to 2.95.x, collect2 would create an import file
+    # for dependence libraries.  The import file would start with
+    # the line `#! .'.  This would cause the generated library to
+    # depend on `.', always an invalid library.  This was fixed in
+    # development snapshots of GCC prior to 3.0.
+    case $host_os in
+      aix4 | aix4.[01] | aix4.[01].*)
+      if { echo '#if __GNUC__ > 2 || (__GNUC__ == 2 && __GNUC_MINOR__ >= 97)'
+	   echo ' yes '
+	   echo '#endif'; } | ${CC} -E - | grep yes > /dev/null; then
+      else
+	can_build_shared=no
+      fi
+    esac
+    # AIX (on Power*) has no versioning support, so currently we can not hardcode correct
+    # soname into executable. Probably we can add versioning support to
+    # collect2, so additional links can be useful in future.
+      # If using run time linking (on AIX 4.2 or later) use lib<name>.so
+      # instead of lib<name>.a to let people know that these are not
+      # typical AIX shared libraries.
+      library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname${shared_ext}'
+    else
+      # We preserve .a as extension for shared libraries through AIX4.2
+      # and later when we are not doing run time linking.
+      library_names_spec='${libname}${release}.a $libname.a'
+    fi
+  fi
+amigaos*)
+  library_names_spec='$libname.ixlibrary $libname.a'
+  # Create ${libname}_ixlibrary.a entries in /sys/libs.
+  finish_eval='for lib in `ls $libdir/*.ixlibrary 2>/dev/null`; do libname=`$echo "X$lib" | $Xsed -e '\''s%^.*/\([^/]*\)\.ixlibrary$%\1%'\''`; test $rm /sys/libs/${libname}_ixlibrary.a; $show "cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a"; cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a || exit 1; done'
+beos*)
+  library_names_spec='${libname}${shared_ext}'
+  dynamic_linker="$host_os ld.so"
+  shlibpath_var=LIBRARY_PATH
+bsdi[45]*)
+  need_version=no
+  finish_cmds='PATH="\$PATH:/sbin" ldconfig $libdir'
+  sys_lib_search_path_spec="/shlib /usr/lib /usr/X11/lib /usr/contrib/lib /lib /usr/local/lib"
+  sys_lib_dlsearch_path_spec="/shlib /usr/lib /usr/local/lib"
+  # the default ld.so.conf also contains /usr/contrib/lib and
+  # /usr/X11R6/lib (/usr/X11 is a link to /usr/X11R6), but let us allow
+  # libtool to hard-code these into programs
+cygwin* | mingw* | pw32*)
+  version_type=windows
+  shrext_cmds=".dll"
+  need_version=no
+  case $GCC,$host_os in
+  yes,cygwin* | yes,mingw* | yes,pw32*)
+    library_names_spec='$libname.dll.a'
+    # DLL is installed to $(libdir)/../bin by postinstall_cmds
+    postinstall_cmds='base_file=`basename \${file}`~
+      dlpath=`$SHELL 2>&1 -c '\''. $dir/'\''\${base_file}'\''i;echo \$dlname'\''`~
+      dldir=$destdir/`dirname \$dlpath`~
+      test -d \$dldir || mkdir -p \$dldir~
+      $install_prog $dir/$dlname \$dldir/$dlname~
+      chmod a+x \$dldir/$dlname'
+    postuninstall_cmds='dldll=`$SHELL 2>&1 -c '\''. $file; echo \$dlname'\''`~
+      dlpath=$dir/\$dldll~
+       $rm \$dlpath'
+    shlibpath_overrides_runpath=yes
+    case $host_os in
+    cygwin*)
+      # Cygwin DLLs use 'cyg' prefix rather than 'lib'
+      soname_spec='`echo ${libname} | sed -e 's/^lib/cyg/'``echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
+      sys_lib_search_path_spec="/usr/lib /lib/w32api /lib /usr/local/lib"
+    mingw*)
+      # MinGW DLLs use traditional 'lib' prefix
+      soname_spec='${libname}`echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
+      if echo "$sys_lib_search_path_spec" | grep ';[c-zC-Z]:/' >/dev/null; then
+        # It is most probably a Windows format PATH printed by
+        # mingw gcc, but we are running on Cygwin. Gcc prints its search
+        # path with ; separators, and with drive letters. We can handle the
+        # drive letters (cygwin fileutils understands them), so leave them,
+        # especially as we might pass files found there to a mingw objdump,
+        # which wouldn't understand a cygwinified path. Ahh.
+      else
+      fi
+    pw32*)
+      # pw32 DLLs use 'pw' prefix rather than 'lib'
+      library_names_spec='`echo ${libname} | sed -e 's/^lib/pw/'``echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
+    esac
+    library_names_spec='${libname}`echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext} $libname.lib'
+  esac
+  dynamic_linker='Win32 ld.exe'
+  # FIXME: first we should search . and the directory the executable is in
+  shlibpath_var=PATH
+darwin* | rhapsody*)
+  dynamic_linker="$host_os dyld"
+  version_type=darwin
+  need_version=no
+  library_names_spec='${libname}${release}${versuffix}$shared_ext ${libname}${release}${major}$shared_ext ${libname}$shared_ext'
+  soname_spec='${libname}${release}${major}$shared_ext'
+  shlibpath_var=DYLD_LIBRARY_PATH
+  shrext_cmds='`test .$module = .yes && echo .so || echo .dylib`'
+  # Apple's gcc prints 'gcc -print-search-dirs' doesn't operate the same.
+  if test "$GCC" = yes; then
+    sys_lib_search_path_spec=`$CC -print-search-dirs | tr "\n" "$PATH_SEPARATOR" | sed -e 's/libraries:/@libraries:/' | tr "@" "\n" | grep "^libraries:" | sed -e "s/^libraries://" -e "s,=/,/,g" -e "s,$PATH_SEPARATOR, ,g" -e "s,.*,& /lib /usr/lib /usr/local/lib,g"`
+  else
+    sys_lib_search_path_spec='/lib /usr/lib /usr/local/lib'
+  fi
+  sys_lib_dlsearch_path_spec='/usr/local/lib /lib /usr/lib'
+dgux*)
+  need_version=no
+  library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname$shared_ext'
+freebsd1*)
+  dynamic_linker=no
+kfreebsd*-gnu)
+  need_version=no
+  library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${shared_ext}'
+  shlibpath_overrides_runpath=no
+  dynamic_linker='GNU ld.so'
+freebsd* | dragonfly*)
+  # DragonFly does not have aout.  When/if they implement a new
+  # versioning mechanism, adjust this.
+  if test -x /usr/bin/objformat; then
+    objformat=`/usr/bin/objformat`
+  else
+    case $host_os in
+    freebsd[123]*) objformat=aout ;;
+    *) objformat=elf ;;
+    esac
+  fi
+  version_type=freebsd-$objformat
+  case $version_type in
+    freebsd-elf*)
+      library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext} $libname${shared_ext}'
+      need_version=no
+    freebsd-*)
+      library_names_spec='${libname}${release}${shared_ext}$versuffix $libname${shared_ext}$versuffix'
+      need_version=yes
+  esac
+  case $host_os in
+  freebsd2*)
+  freebsd3.[01]* | freebsdelf3.[01]*)
+  freebsd3.[2-9]* | freebsdelf3.[2-9]* | \
+  freebsd4.[0-5] | freebsdelf4.[0-5] | freebsd4.1.1 | freebsdelf4.1.1)
+  freebsd*) # from 4.6 on
+  esac
+gnu*)
+  need_version=no
+  library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}${major} ${libname}${shared_ext}'
+hpux9* | hpux10* | hpux11*)
+  # Give a soname corresponding to the major version so that dld.sl refuses to
+  # link against other versions.
+  version_type=sunos
+  need_version=no
+  case $host_cpu in
+  ia64*)
+    shrext_cmds='.so'
+    dynamic_linker="$host_os dld.so"
+    shlibpath_overrides_runpath=yes # Unless +noenvvar is specified.
+    if test "X$HPUX_IA64_MODE" = X32; then
+      sys_lib_search_path_spec="/usr/lib/hpux32 /usr/local/lib/hpux32 /usr/local/lib"
+    else
+      sys_lib_search_path_spec="/usr/lib/hpux64 /usr/local/lib/hpux64"
+    fi
+    sys_lib_dlsearch_path_spec=$sys_lib_search_path_spec
+   hppa*64*)
+     shrext_cmds='.sl'
+     dynamic_linker="$host_os dld.sl"
+     shlibpath_var=LD_LIBRARY_PATH # How should we handle SHLIB_PATH
+     sys_lib_search_path_spec="/usr/lib/pa20_64 /usr/ccs/lib/pa20_64"
+    shrext_cmds='.sl'
+    shlibpath_var=SHLIB_PATH
+    shlibpath_overrides_runpath=no # +s is required to enable SHLIB_PATH
+  esac
+  # HP-UX runs *really* slowly unless shared libraries are mode 555.
+  postinstall_cmds='chmod 555 $lib'
+interix3*)
+  need_version=no
+  dynamic_linker='Interix 3.x ld.so.1 (PE, like ELF)'
+irix5* | irix6* | nonstopux*)
+  case $host_os in
+    nonstopux*) version_type=nonstopux ;;
+	if test "$lt_cv_prog_gnu_ld" = yes; then
+	else
+		version_type=irix
+	fi ;;
+  esac
+  need_version=no
+  library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext} $libname${shared_ext}'
+  case $host_os in
+  irix5* | nonstopux*)
+    libsuff= shlibsuff=
+    case $LD in # libtool.m4 will add one of these switches to LD
+    *-32|*"-32 "|*-melf32bsmip|*"-melf32bsmip ")
+      libsuff= shlibsuff= libmagic=32-bit;;
+    *-n32|*"-n32 "|*-melf32bmipn32|*"-melf32bmipn32 ")
+      libsuff=32 shlibsuff=N32 libmagic=N32;;
+    *-64|*"-64 "|*-melf64bmip|*"-melf64bmip ")
+      libsuff=64 shlibsuff=64 libmagic=64-bit;;
+    *) libsuff= shlibsuff= libmagic=never-match;;
+    esac
+  esac
+  shlibpath_var=LD_LIBRARY${shlibsuff}_PATH
+  sys_lib_search_path_spec="/usr/lib${libsuff} /lib${libsuff} /usr/local/lib${libsuff}"
+  sys_lib_dlsearch_path_spec="/usr/lib${libsuff} /lib${libsuff}"
+# No shared lib support for Linux oldld, aout, or coff.
+linux*oldld* | linux*aout* | linux*coff*)
+  dynamic_linker=no
+# This must be Linux ELF.
+linux*)
+  need_version=no
+  finish_cmds='PATH="\$PATH:/sbin" ldconfig -n $libdir'
+  # This implies no fast_install, which is unacceptable.
+  # Some rework will be needed to allow for fast_install
+  # before this can be enabled.
+  # find out which ABI we are using
+  libsuff=
+  case "$host_cpu" in
+  x86_64*|s390x*|powerpc64*)
+    echo '#line 12224 "configure"' > conftest.$ac_ext
+  ac_status=$?
+      case `/usr/bin/file conftest.$ac_objext` in
+      *64-bit*)
+        libsuff=64
+        sys_lib_search_path_spec="/lib${libsuff} /usr/lib${libsuff} /usr/local/lib${libsuff}"
+      esac
+    fi
+    rm -rf conftest*
+  esac
+  # Append ld.so.conf contents to the search path
+  if test -f /etc/ld.so.conf; then
+    lt_ld_extra=`awk '/^include / { system(sprintf("cd /etc; cat %s", \$2)); skip = 1; } { if (!skip) print \$0; skip = 0; }' < /etc/ld.so.conf | $SED -e 's/#.*//;s/[:,	]/ /g;s/=[^=]*$//;s/=[^= ]* / /g;/^$/d' | tr '\n' ' '`
+    sys_lib_dlsearch_path_spec="/lib${libsuff} /usr/lib${libsuff} $lt_ld_extra"
+  fi
+  # We used to test for /lib/ld.so.1 and disable shared libraries on
+  # powerpc, because MkLinux only supported shared libraries with the
+  # GNU dynamic linker.  Since this was broken with cross compilers,
+  # most powerpc-linux boxes support dynamic linking these days and
+  # people can always --disable-shared, the test was removed, and we
+  # assume the GNU/Linux dynamic linker is in use.
+  dynamic_linker='GNU/Linux ld.so'
+knetbsd*-gnu)
+  need_version=no
+netbsd*)
+  need_version=no
+    library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${shared_ext}$versuffix'
+    finish_cmds='PATH="\$PATH:/sbin" ldconfig -m $libdir'
+    dynamic_linker='NetBSD (a.out) ld.so'
+  else
+    dynamic_linker='NetBSD ld.elf_so'
+  fi
+newsos6)
+nto-qnx*)
+  need_version=no
+openbsd*)
+  sys_lib_dlsearch_path_spec="/usr/lib"
+  # Some older versions of OpenBSD (3.3 at least) *do* need versioned libs.
+  case $host_os in
+    openbsd3.3 | openbsd3.3.*) need_version=yes ;;
+    *)                         need_version=no  ;;
+  esac
+    case $host_os in
+      openbsd2.[89] | openbsd2.[89].*)
+      esac
+  else
+  fi
+os2*)
+  libname_spec='$name'
+  library_names_spec='$libname${shared_ext} $libname.a'
+  dynamic_linker='OS/2 ld.exe'
+osf3* | osf4* | osf5*)
+  version_type=osf
+  need_version=no
+  sys_lib_search_path_spec="/usr/shlib /usr/ccs/lib /usr/lib/cmplrs/cc /usr/lib /usr/local/lib /var/shlib"
+  sys_lib_dlsearch_path_spec="$sys_lib_search_path_spec"
+solaris*)
+  need_version=no
+  # ldd complains unless libraries are executable
+  postinstall_cmds='chmod +x $lib'
+sunos4*)
+  finish_cmds='PATH="\$PATH:/usr/etc" ldconfig $libdir'
+  if test "$with_gnu_ld" = yes; then
+  fi
+  need_version=yes
+sysv4 | sysv4.3*)
+  case $host_vendor in
+    sni)
+      export_dynamic_flag_spec='${wl}-Blargedynsym'
+    siemens)
+    motorola)
+      need_version=no
+      sys_lib_search_path_spec='/lib /usr/lib /usr/ccs/lib'
+  esac
+sysv4*MP*)
+  if test -d /usr/nec ;then
+    library_names_spec='$libname${shared_ext}.$versuffix $libname${shared_ext}.$major $libname${shared_ext}'
+    soname_spec='$libname${shared_ext}.$major'
+  fi
+sysv5* | sco3.2v5* | sco5v6* | unixware* | OpenUNIX* | sysv4*uw2*)
+  version_type=freebsd-elf
+  need_version=no
+    sys_lib_search_path_spec='/usr/local/lib /usr/gnu/lib /usr/ccs/lib /usr/lib /lib'
+  else
+    sys_lib_search_path_spec='/usr/ccs/lib /usr/lib'
+    case $host_os in
+      sco3.2v5*)
+        sys_lib_search_path_spec="$sys_lib_search_path_spec /lib"
+    esac
+  fi
+  sys_lib_dlsearch_path_spec='/usr/lib'
+uts4*)
+  dynamic_linker=no
+esac
+echo "$as_me:$LINENO: result: $dynamic_linker" >&5
+echo "${ECHO_T}$dynamic_linker" >&6
+test "$dynamic_linker" = no && can_build_shared=no
+variables_saved_for_relink="PATH $shlibpath_var $runpath_var"
+  variables_saved_for_relink="$variables_saved_for_relink GCC_EXEC_PREFIX COMPILER_PATH LIBRARY_PATH"
+fi
+echo "$as_me:$LINENO: checking how to hardcode library paths into programs" >&5
+echo $ECHO_N "checking how to hardcode library paths into programs... $ECHO_C" >&6
+hardcode_action_CXX=
+if test -n "$hardcode_libdir_flag_spec_CXX" || \
+   test -n "$runpath_var_CXX" || \
+   test "X$hardcode_automatic_CXX" = "Xyes" ; then
+  # We can hardcode non-existant directories.
+  if test "$hardcode_direct_CXX" != no &&
+     # If the only mechanism to avoid hardcoding is shlibpath_var, we
+     # have to relink, otherwise we might link with an installed library
+     # when we should be linking with a yet-to-be-installed one
+     ## test "$_LT_AC_TAGVAR(hardcode_shlibpath_var, CXX)" != no &&
+     test "$hardcode_minus_L_CXX" != no; then
+    # Linking always hardcodes the temporary library directory.
+    hardcode_action_CXX=relink
+  else
+    # We can link without hardcoding, and we can hardcode nonexisting dirs.
+    hardcode_action_CXX=immediate
+  fi
+else
+  # We cannot hardcode anything, or else we can only hardcode existing
+  # directories.
+  hardcode_action_CXX=unsupported
+fi
+echo "$as_me:$LINENO: result: $hardcode_action_CXX" >&5
+echo "${ECHO_T}$hardcode_action_CXX" >&6
+if test "$hardcode_action_CXX" = relink; then
+  # Fast installation is not supported
+  enable_fast_install=no
+elif test "$shlibpath_overrides_runpath" = yes ||
+     test "$enable_shared" = no; then
+  # Fast installation is not necessary
+  enable_fast_install=needless
+fi
+# The else clause should only fire when bootstrapping the
+# libtool distribution, otherwise you forgot to ship ltmain.sh
+# with your package, and you will get complaints that there are
+# no rules to generate ltmain.sh.
+if test -f "$ltmain"; then
+  # See if we are running on zsh, and set the options which allow our commands through
+  # without removal of \ escapes.
+  if test -n "${ZSH_VERSION+set}" ; then
+    setopt NO_GLOB_SUBST
+  fi
+  # Now quote all the things that may contain metacharacters while being
+  # careful not to overquote the AC_SUBSTed values.  We take copies of the
+  # variables and quote the copies for generation of the libtool script.
+  for var in echo old_CC old_CFLAGS AR AR_FLAGS EGREP RANLIB LN_S LTCC LTCFLAGS NM \
+    SED SHELL STRIP \
+    libname_spec library_names_spec soname_spec extract_expsyms_cmds \
+    old_striplib striplib file_magic_cmd finish_cmds finish_eval \
+    deplibs_check_method reload_flag reload_cmds need_locks \
+    lt_cv_sys_global_symbol_pipe lt_cv_sys_global_symbol_to_cdecl \
+    lt_cv_sys_global_symbol_to_c_name_address \
+    sys_lib_search_path_spec sys_lib_dlsearch_path_spec \
+    old_postinstall_cmds old_postuninstall_cmds \
+    compiler_CXX \
+    CC_CXX \
+    LD_CXX \
+    lt_prog_compiler_wl_CXX \
+    lt_prog_compiler_pic_CXX \
+    lt_prog_compiler_static_CXX \
+    lt_prog_compiler_no_builtin_flag_CXX \
+    export_dynamic_flag_spec_CXX \
+    thread_safe_flag_spec_CXX \
+    whole_archive_flag_spec_CXX \
+    enable_shared_with_static_runtimes_CXX \
+    old_archive_cmds_CXX \
+    old_archive_from_new_cmds_CXX \
+    predep_objects_CXX \
+    postdep_objects_CXX \
+    predeps_CXX \
+    postdeps_CXX \
+    compiler_lib_search_path_CXX \
+    archive_cmds_CXX \
+    archive_expsym_cmds_CXX \
+    postinstall_cmds_CXX \
+    postuninstall_cmds_CXX \
+    old_archive_from_expsyms_cmds_CXX \
+    allow_undefined_flag_CXX \
+    no_undefined_flag_CXX \
+    export_symbols_cmds_CXX \
+    hardcode_libdir_flag_spec_CXX \
+    hardcode_libdir_flag_spec_ld_CXX \
+    hardcode_libdir_separator_CXX \
+    hardcode_automatic_CXX \
+    module_cmds_CXX \
+    module_expsym_cmds_CXX \
+    lt_cv_prog_compiler_c_o_CXX \
+    exclude_expsyms_CXX \
+    include_expsyms_CXX; do
+    case $var in
+    old_archive_cmds_CXX | \
+    old_archive_from_new_cmds_CXX | \
+    archive_cmds_CXX | \
+    archive_expsym_cmds_CXX | \
+    module_cmds_CXX | \
+    module_expsym_cmds_CXX | \
+    old_archive_from_expsyms_cmds_CXX | \
+    export_symbols_cmds_CXX | \
+    extract_expsyms_cmds | reload_cmds | finish_cmds | \
+    postinstall_cmds | postuninstall_cmds | \
+    old_postinstall_cmds | old_postuninstall_cmds | \
+    sys_lib_search_path_spec | sys_lib_dlsearch_path_spec)
+      # Double-quote double-evaled strings.
+      eval "lt_$var=\\\"\`\$echo \"X\$$var\" | \$Xsed -e \"\$double_quote_subst\" -e \"\$sed_quote_subst\" -e \"\$delay_variable_subst\"\`\\\""
+      eval "lt_$var=\\\"\`\$echo \"X\$$var\" | \$Xsed -e \"\$sed_quote_subst\"\`\\\""
+    esac
+  done
+  case $lt_echo in
+  *'\$0 --fallback-echo"')
+    lt_echo=`$echo "X$lt_echo" | $Xsed -e 's/\\\\\\\$0 --fallback-echo"$/$0 --fallback-echo"/'`
+  esac
+cfgfile="$ofile"
+  cat <<__EOF__ >> "$cfgfile"
+# ### BEGIN LIBTOOL TAG CONFIG: $tagname
+# Libtool was configured on host `(hostname || uname -n) 2>/dev/null | sed 1q`:
+# Shell to use when invoking shell scripts.
+SHELL=$lt_SHELL
+# Whether or not to build shared libraries.
+build_libtool_libs=$enable_shared
+# Whether or not to build static libraries.
+build_old_libs=$enable_static
+# Whether or not to add -lc for building shared libraries.
+build_libtool_need_lc=$archive_cmds_need_lc_CXX
+# Whether or not to disallow shared libs when runtime libs are static
+allow_libtool_libs_with_static_runtimes=$enable_shared_with_static_runtimes_CXX
+# Whether or not to optimize for fast installation.
+fast_install=$enable_fast_install
+# The host system.
+host_alias=$host_alias
+host=$host
+host_os=$host_os
+# The build system.
+build_alias=$build_alias
+build=$build
+build_os=$build_os
+# An echo program that does not interpret backslashes.
+echo=$lt_echo
+# The archiver.
+AR=$lt_AR
+AR_FLAGS=$lt_AR_FLAGS
+# A C compiler.
+LTCC=$lt_LTCC
+# LTCC compiler flags.
+LTCFLAGS=$lt_LTCFLAGS
+# A language-specific compiler.
+CC=$lt_compiler_CXX
+# Is the compiler the GNU C compiler?
+with_gcc=$GCC_CXX
+# An ERE matcher.
+EGREP=$lt_EGREP
+# The linker used to build libraries.
+LD=$lt_LD_CXX
+# Whether we need hard or soft links.
+LN_S=$lt_LN_S
+# A BSD-compatible nm program.
+NM=$lt_NM
+# A symbol stripping program
+STRIP=$lt_STRIP
+# Used to examine libraries when file_magic_cmd begins "file"
+MAGIC_CMD=$MAGIC_CMD
+# Used on cygwin: DLL creation program.
+DLLTOOL="$DLLTOOL"
+# Used on cygwin: object dumper.
+OBJDUMP="$OBJDUMP"
+# Used on cygwin: assembler.
+AS="$AS"
+# The name of the directory that contains temporary libtool files.
+objdir=$objdir
+# How to create reloadable object files.
+reload_flag=$lt_reload_flag
+reload_cmds=$lt_reload_cmds
+# How to pass a linker flag through the compiler.
+wl=$lt_lt_prog_compiler_wl_CXX
+# Object file suffix (normally "o").
+objext="$ac_objext"
+# Old archive suffix (normally "a").
+libext="$libext"
+# Shared library suffix (normally ".so").
+shrext_cmds='$shrext_cmds'
+# Executable file suffix (normally "").
+exeext="$exeext"
+# Additional compiler flags for building library objects.
+pic_flag=$lt_lt_prog_compiler_pic_CXX
+pic_mode=$pic_mode
+# What is the maximum length of a command?
+max_cmd_len=$lt_cv_sys_max_cmd_len
+# Does compiler simultaneously support -c and -o options?
+compiler_c_o=$lt_lt_cv_prog_compiler_c_o_CXX
+# Must we lock files when doing compilation?
+need_locks=$lt_need_locks
+# Do we need the lib prefix for modules?
+need_lib_prefix=$need_lib_prefix
+# Do we need a version for libraries?
+need_version=$need_version
+# Whether dlopen is supported.
+dlopen_support=$enable_dlopen
+# Whether dlopen of programs is supported.
+dlopen_self=$enable_dlopen_self
+# Whether dlopen of statically linked programs is supported.
+dlopen_self_static=$enable_dlopen_self_static
+# Compiler flag to prevent dynamic linking.
+link_static_flag=$lt_lt_prog_compiler_static_CXX
+# Compiler flag to turn off builtin functions.
+no_builtin_flag=$lt_lt_prog_compiler_no_builtin_flag_CXX
+# Compiler flag to allow reflexive dlopens.
+export_dynamic_flag_spec=$lt_export_dynamic_flag_spec_CXX
+# Compiler flag to generate shared objects directly from archives.
+whole_archive_flag_spec=$lt_whole_archive_flag_spec_CXX
+# Compiler flag to generate thread-safe objects.
+thread_safe_flag_spec=$lt_thread_safe_flag_spec_CXX
+# Library versioning type.
+version_type=$version_type
+# Format of library name prefix.
+libname_spec=$lt_libname_spec
+# List of archive names.  First name is the real one, the rest are links.
+# The last name is the one that the linker finds with -lNAME.
+library_names_spec=$lt_library_names_spec
+# The coded name of the library, if different from the real name.
+soname_spec=$lt_soname_spec
+# Commands used to build and install an old-style archive.
+RANLIB=$lt_RANLIB
+old_archive_cmds=$lt_old_archive_cmds_CXX
+old_postinstall_cmds=$lt_old_postinstall_cmds
+old_postuninstall_cmds=$lt_old_postuninstall_cmds
+# Create an old-style archive from a shared archive.
+old_archive_from_new_cmds=$lt_old_archive_from_new_cmds_CXX
+# Create a temporary old-style archive to link instead of a shared archive.
+old_archive_from_expsyms_cmds=$lt_old_archive_from_expsyms_cmds_CXX
+# Commands used to build and install a shared archive.
+archive_cmds=$lt_archive_cmds_CXX
+archive_expsym_cmds=$lt_archive_expsym_cmds_CXX
+postinstall_cmds=$lt_postinstall_cmds
+postuninstall_cmds=$lt_postuninstall_cmds
+# Commands used to build a loadable module (assumed same as above if empty)
+module_cmds=$lt_module_cmds_CXX
+module_expsym_cmds=$lt_module_expsym_cmds_CXX
+# Commands to strip libraries.
+old_striplib=$lt_old_striplib
+striplib=$lt_striplib
+# Dependencies to place before the objects being linked to create a
+# shared library.
+predep_objects=$lt_predep_objects_CXX
+# Dependencies to place after the objects being linked to create a
+# shared library.
+postdep_objects=$lt_postdep_objects_CXX
+# shared library.
+predeps=$lt_predeps_CXX
+# shared library.
+postdeps=$lt_postdeps_CXX
+# The library search path used internally by the compiler when linking
+# a shared library.
+compiler_lib_search_path=$lt_compiler_lib_search_path_CXX
+# Method to check whether dependent libraries are shared objects.
+deplibs_check_method=$lt_deplibs_check_method
+# Command to use when deplibs_check_method == file_magic.
+file_magic_cmd=$lt_file_magic_cmd
+# Flag that allows shared libraries with undefined symbols to be built.
+allow_undefined_flag=$lt_allow_undefined_flag_CXX
+# Flag that forces no undefined symbols.
+no_undefined_flag=$lt_no_undefined_flag_CXX
+# Commands used to finish a libtool library installation in a directory.
+finish_cmds=$lt_finish_cmds
+# Same as above, but a single script fragment to be evaled but not shown.
+finish_eval=$lt_finish_eval
+# Take the output of nm and produce a listing of raw symbols and C names.
+global_symbol_pipe=$lt_lt_cv_sys_global_symbol_pipe
+# Transform the output of nm in a proper C declaration
+global_symbol_to_cdecl=$lt_lt_cv_sys_global_symbol_to_cdecl
+# Transform the output of nm in a C name address pair
+global_symbol_to_c_name_address=$lt_lt_cv_sys_global_symbol_to_c_name_address
+# This is the shared library runtime path variable.
+runpath_var=$runpath_var
+# This is the shared library path variable.
+shlibpath_var=$shlibpath_var
+# Is shlibpath searched before the hard-coded library search path?
+shlibpath_overrides_runpath=$shlibpath_overrides_runpath
+# How to hardcode a shared library path into an executable.
+hardcode_action=$hardcode_action_CXX
+# Whether we should hardcode library paths into libraries.
+hardcode_into_libs=$hardcode_into_libs
+# Flag to hardcode \$libdir into a binary during linking.
+# This must work even if \$libdir does not exist.
+hardcode_libdir_flag_spec=$lt_hardcode_libdir_flag_spec_CXX
+# If ld is used when linking, flag to hardcode \$libdir into
+# a binary during linking. This must work even if \$libdir does
+# not exist.
+hardcode_libdir_flag_spec_ld=$lt_hardcode_libdir_flag_spec_ld_CXX
+# Whether we need a single -rpath flag with a separated argument.
+hardcode_libdir_separator=$lt_hardcode_libdir_separator_CXX
+# Set to yes if using DIR/libNAME${shared_ext} during linking hardcodes DIR into the
+# resulting binary.
+hardcode_direct=$hardcode_direct_CXX
+# Set to yes if using the -LDIR flag during linking hardcodes DIR into the
+hardcode_minus_L=$hardcode_minus_L_CXX
+# Set to yes if using SHLIBPATH_VAR=DIR during linking hardcodes DIR into
+# the resulting binary.
+hardcode_shlibpath_var=$hardcode_shlibpath_var_CXX
+# Set to yes if building a shared library automatically hardcodes DIR into the library
+# and all subsequent libraries and executables linked against it.
+hardcode_automatic=$hardcode_automatic_CXX
+# Variables whose values should be saved in libtool wrapper scripts and
+# restored at relink time.
+variables_saved_for_relink="$variables_saved_for_relink"
+# Whether libtool must link a program against all its dependency libraries.
+link_all_deplibs=$link_all_deplibs_CXX
+# Compile-time system search path for libraries
+sys_lib_search_path_spec=$lt_sys_lib_search_path_spec
+# Run-time system search path for libraries
+sys_lib_dlsearch_path_spec=$lt_sys_lib_dlsearch_path_spec
+# Fix the shell variable \$srcfile for the compiler.
+fix_srcfile_path="$fix_srcfile_path_CXX"
+# Set to yes if exported symbols are required.
+always_export_symbols=$always_export_symbols_CXX
+# The commands to list exported symbols.
+export_symbols_cmds=$lt_export_symbols_cmds_CXX
+# The commands to extract the exported symbol list from a shared archive.
+extract_expsyms_cmds=$lt_extract_expsyms_cmds
+# Symbols that should not be listed in the preloaded symbols.
+exclude_expsyms=$lt_exclude_expsyms_CXX
+# Symbols that must always be exported.
+include_expsyms=$lt_include_expsyms_CXX
+# ### END LIBTOOL TAG CONFIG: $tagname
+__EOF__
+else
+  # If there is no Makefile yet, we rely on a make rule to execute
+  # `config.status --recheck' to rerun these tests and create the
+  # libtool script then.
+  ltmain_in=`echo $ltmain | sed -e 's/\.sh$/.in/'`
+  if test -f "$ltmain_in"; then
+    test -f Makefile && make "$ltmain"
+  fi
+fi
+ac_ext=cc
+ac_cpp='$CXXCPP $CPPFLAGS'
+ac_compile='$CXX -c $CXXFLAGS $CPPFLAGS conftest.$ac_ext >&5'
+ac_link='$CXX -o conftest$ac_exeext $CXXFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
+ac_compiler_gnu=$ac_cv_cxx_compiler_gnu
+CC=$lt_save_CC
+LDCXX=$LD
+LD=$lt_save_LD
+GCC=$lt_save_GCC
+with_gnu_ldcxx=$with_gnu_ld
+with_gnu_ld=$lt_save_with_gnu_ld
+lt_cv_path_LDCXX=$lt_cv_path_LD
+lt_cv_path_LD=$lt_save_path_LD
+lt_cv_prog_gnu_ldcxx=$lt_cv_prog_gnu_ld
+lt_cv_prog_gnu_ld=$lt_save_with_gnu_ld
+	else
+	  tagname=""
+	fi
+      F77)
+	if test -n "$F77" && test "X$F77" != "Xno"; then
+ac_ext=f
+ac_compile='$F77 -c $FFLAGS conftest.$ac_ext >&5'
+ac_link='$F77 -o conftest$ac_exeext $FFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
+ac_compiler_gnu=$ac_cv_f77_compiler_gnu
+archive_cmds_need_lc_F77=no
+allow_undefined_flag_F77=
+always_export_symbols_F77=no
+archive_expsym_cmds_F77=
+export_dynamic_flag_spec_F77=
+hardcode_direct_F77=no
+hardcode_libdir_flag_spec_F77=
+hardcode_libdir_flag_spec_ld_F77=
+hardcode_libdir_separator_F77=
+hardcode_minus_L_F77=no
+hardcode_automatic_F77=no
+module_cmds_F77=
+module_expsym_cmds_F77=
+link_all_deplibs_F77=unknown
+old_archive_cmds_F77=$old_archive_cmds
+no_undefined_flag_F77=
+whole_archive_flag_spec_F77=
+enable_shared_with_static_runtimes_F77=no
+# Source file extension for f77 test sources.
+ac_ext=f
+# Object file extension for compiled f77 test sources.
+objext=o
+objext_F77=$objext
+# Code to be used in simple compile tests
+lt_simple_compile_test_code="      subroutine t\n      return\n      end\n"
+# Code to be used in simple link tests
+lt_simple_link_test_code="      program t\n      end\n"
+# ltmain only uses $CC for tagged configurations so make sure $CC is set.
+# If no C compiler was specified, use CC.
+LTCC=${LTCC-"$CC"}
+# If no C compiler flags were specified, use CFLAGS.
+LTCFLAGS=${LTCFLAGS-"$CFLAGS"}
+# Allow CC to be a program name with arguments.
+compiler=$CC
+# save warnings/boilerplate of simple test code
+ac_outfile=conftest.$ac_objext
+printf "$lt_simple_compile_test_code" >conftest.$ac_ext
+eval "$ac_compile" 2>&1 >/dev/null | $SED '/^$/d; /^ *+/d' >conftest.err
+_lt_compiler_boilerplate=`cat conftest.err`
+$rm conftest*
+printf "$lt_simple_link_test_code" >conftest.$ac_ext
+eval "$ac_link" 2>&1 >/dev/null | $SED '/^$/d; /^ *+/d' >conftest.err
+_lt_linker_boilerplate=`cat conftest.err`
+$rm conftest*
+lt_save_CC="$CC"
+CC=${F77-"f77"}
+compiler=$CC
+compiler_F77=$CC
+for cc_temp in $compiler""; do
+  case $cc_temp in
+    compile | *[\\/]compile | ccache | *[\\/]ccache ) ;;
+    distcc | *[\\/]distcc | purify | *[\\/]purify ) ;;
+    *) break;;
+  esac
+done
+cc_basename=`$echo "X$cc_temp" | $Xsed -e 's%.*/%%' -e "s%^$host_alias-%%"`
+echo "$as_me:$LINENO: checking if libtool supports shared libraries" >&5
+echo $ECHO_N "checking if libtool supports shared libraries... $ECHO_C" >&6
+echo "$as_me:$LINENO: result: $can_build_shared" >&5
+echo "${ECHO_T}$can_build_shared" >&6
+echo "$as_me:$LINENO: checking whether to build shared libraries" >&5
+echo $ECHO_N "checking whether to build shared libraries... $ECHO_C" >&6
+test "$can_build_shared" = "no" && enable_shared=no
+# On AIX, shared libraries and static libraries use the same namespace, and
+# are all built from PIC.
+case $host_os in
+aix3*)
+  test "$enable_shared" = yes && enable_static=no
+  if test -n "$RANLIB"; then
+    archive_cmds="$archive_cmds~\$RANLIB \$lib"
+    postinstall_cmds='$RANLIB $lib'
+  fi
+aix4* | aix5*)
+  if test "$host_cpu" != ia64 && test "$aix_use_runtimelinking" = no ; then
+  fi
+esac
+echo "$as_me:$LINENO: result: $enable_shared" >&5
+echo "${ECHO_T}$enable_shared" >&6
+echo "$as_me:$LINENO: checking whether to build static libraries" >&5
+echo $ECHO_N "checking whether to build static libraries... $ECHO_C" >&6
+# Make sure either enable_shared or enable_static is yes.
+test "$enable_shared" = yes || enable_static=yes
+echo "$as_me:$LINENO: result: $enable_static" >&5
+echo "${ECHO_T}$enable_static" >&6
+GCC_F77="$G77"
+LD_F77="$LD"
+lt_prog_compiler_wl_F77=
+lt_prog_compiler_pic_F77=
+lt_prog_compiler_static_F77=
+    lt_prog_compiler_wl_F77='-Wl,'
+    lt_prog_compiler_static_F77='-static'
+    case $host_os in
+      aix*)
+      if test "$host_cpu" = ia64; then
+	lt_prog_compiler_static_F77='-Bstatic'
+      fi
+    amigaos*)
+      # like `-m68040'.
+      lt_prog_compiler_pic_F77='-m68020 -resident32 -malways-restore-a4'
+    mingw* | pw32* | os2*)
+      lt_prog_compiler_pic_F77='-DDLL_EXPORT'
+    darwin* | rhapsody*)
+      lt_prog_compiler_pic_F77='-fno-common'
+    interix3*)
+    msdosdjgpp*)
+      # Just because we use GCC doesn't mean we suddenly get shared libraries
+      # on systems that don't support them.
+      lt_prog_compiler_can_build_shared_F77=no
+      enable_shared=no
+    sysv4*MP*)
+	lt_prog_compiler_pic_F77=-Kconform_pic
+      fi
+    hpux*)
+      case $host_cpu in
+      hppa*64*|ia64*)
+	# +Z the default
+	lt_prog_compiler_pic_F77='-fPIC'
+      esac
+    esac
+  else
+    # PORTME Check for flag to pass linker flags through the system compiler.
+    case $host_os in
+    aix*)
+      else
+	lt_prog_compiler_static_F77='-bnso -bI:/lib/syscalls.exp'
+      fi
+      darwin*)
+       case $cc_basename in
+         xlc*)
+         lt_prog_compiler_pic_F77='-qnocommon'
+       esac
+      case $host_cpu in
+      hppa*64*|ia64*)
+	# +Z the default
+	lt_prog_compiler_pic_F77='+Z'
+      esac
+      # Is there a better lt_prog_compiler_static that works with the bundled CC?
+      lt_prog_compiler_static_F77='${wl}-a ${wl}archive'
+      # PIC (with -KPIC) is the default.
+      lt_prog_compiler_static_F77='-non_shared'
+    newsos6)
+      lt_prog_compiler_pic_F77='-KPIC'
+    linux*)
+      icc* | ecc*)
+      pgcc* | pgf77* | pgf90* | pgf95*)
+        # Portland Group compilers (*not* the Pentium gcc compiler,
+	# which looks to be a dead project)
+	lt_prog_compiler_pic_F77='-fpic'
+      ccc*)
+        # All Alpha code is PIC.
+      esac
+      # All OSF/1 code is PIC.
+    solaris*)
+      f77* | f90* | f95*)
+	lt_prog_compiler_wl_F77='-Qoption ld ';;
+	lt_prog_compiler_wl_F77='-Wl,';;
+      esac
+    sunos4*)
+      lt_prog_compiler_pic_F77='-PIC'
+    sysv4 | sysv4.2uw2* | sysv4.3*)
+    sysv4*MP*)
+	lt_prog_compiler_pic_F77='-Kconform_pic'
+      fi
+    unicos*)
+    uts4*)
+      lt_prog_compiler_pic_F77='-pic'
+    esac
+  fi
+echo "$as_me:$LINENO: result: $lt_prog_compiler_pic_F77" >&5
+echo "${ECHO_T}$lt_prog_compiler_pic_F77" >&6
-#  This program is distributed in the hope that it will be useful,
-#  but WITHOUT ANY WARRANTY; without even the implied warranty of
-#  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-#  GNU General Public License for more details.
-#  You should have received a copy of the GNU General Public License
-#  along with this program; if not, write to the Free Software
-#  Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+if test -n "$lt_prog_compiler_pic_F77"; then
+echo "$as_me:$LINENO: checking if $compiler PIC flag $lt_prog_compiler_pic_F77 works" >&5
+echo $ECHO_N "checking if $compiler PIC flag $lt_prog_compiler_pic_F77 works... $ECHO_C" >&6
+if test "${lt_prog_compiler_pic_works_F77+set}" = set; then
+else
+  lt_prog_compiler_pic_works_F77=no
+   lt_compiler_flag="$lt_prog_compiler_pic_F77"
+   (eval echo "\"\$as_me:13279: $lt_compile\"" >&5)
+   ac_status=$?
+   echo "$as_me:13283: \$? = $ac_status" >&5
+       lt_prog_compiler_pic_works_F77=yes
+     fi
+   fi
+   $rm conftest*
+fi
+echo "$as_me:$LINENO: result: $lt_prog_compiler_pic_works_F77" >&5
+echo "${ECHO_T}$lt_prog_compiler_pic_works_F77" >&6
+if test x"$lt_prog_compiler_pic_works_F77" = xyes; then
+    case $lt_prog_compiler_pic_F77 in
+     *) lt_prog_compiler_pic_F77=" $lt_prog_compiler_pic_F77" ;;
+     esac
+else
+fi
+fi
+case $host_os in
+  *djgpp*)
+    lt_prog_compiler_pic_F77="$lt_prog_compiler_pic_F77"
+esac
-# #include <stdio.h>		/* for printf() */
-# #include <unistd.h>		/* for open(), lseek(), read() */
-# #include <fcntl.h>		/* for O_RDONLY, O_BINARY */
-# #include <string.h>		/* for strdup() */
-# /* O_BINARY isn't required (or even defined sometimes) under Unix */
-# #ifndef O_BINARY
-# #define O_BINARY 0
-# #endif
+wl=$lt_prog_compiler_wl_F77 eval lt_tmp_static_flag=\"$lt_prog_compiler_static_F77\"
+if test "${lt_prog_compiler_static_works_F77+set}" = set; then
+else
+  lt_prog_compiler_static_works_F77=no
+         lt_prog_compiler_static_works_F77=yes
+       fi
+     else
+     fi
+   fi
+   $rm conftest*
+fi
+echo "$as_me:$LINENO: result: $lt_prog_compiler_static_works_F77" >&5
+echo "${ECHO_T}$lt_prog_compiler_static_works_F77" >&6
+if test x"$lt_prog_compiler_static_works_F77" = xyes; then
+else
+fi
+if test "${lt_cv_prog_compiler_c_o_F77+set}" = set; then
+else
+  lt_cv_prog_compiler_c_o_F77=no
+   mkdir conftest
+   cd conftest
+   mkdir out
+   (eval echo "\"\$as_me:13383: $lt_compile\"" >&5)
+   ac_status=$?
+   echo "$as_me:13387: \$? = $ac_status" >&5
+   then
+       lt_cv_prog_compiler_c_o_F77=yes
+     fi
+   fi
+   chmod u+w . 2>&5
+   $rm conftest*
+   cd ..
+   rmdir conftest
+   $rm conftest*
+fi
+echo "$as_me:$LINENO: result: $lt_cv_prog_compiler_c_o_F77" >&5
+echo "${ECHO_T}$lt_cv_prog_compiler_c_o_F77" >&6
+if test "$lt_cv_prog_compiler_c_o_F77" = no && test "$need_locks" != no; then
+  hard_links=yes
+  $rm conftest*
+  touch conftest.a
+    need_locks=warn
+  fi
+else
+  need_locks=no
+fi
+echo "$as_me:$LINENO: checking whether the $compiler linker ($LD) supports shared libraries" >&5
+echo $ECHO_N "checking whether the $compiler linker ($LD) supports shared libraries... $ECHO_C" >&6
+  runpath_var=
+  allow_undefined_flag_F77=
+  enable_shared_with_static_runtimes_F77=no
+  archive_cmds_F77=
+  archive_expsym_cmds_F77=
+  old_archive_From_new_cmds_F77=
+  old_archive_from_expsyms_cmds_F77=
+  export_dynamic_flag_spec_F77=
+  whole_archive_flag_spec_F77=
+  thread_safe_flag_spec_F77=
+  hardcode_libdir_flag_spec_F77=
+  hardcode_libdir_flag_spec_ld_F77=
+  hardcode_libdir_separator_F77=
+  hardcode_direct_F77=no
+  hardcode_minus_L_F77=no
+  hardcode_shlibpath_var_F77=unsupported
+  link_all_deplibs_F77=unknown
+  hardcode_automatic_F77=no
+  module_cmds_F77=
+  module_expsym_cmds_F77=
+  always_export_symbols_F77=no
+  export_symbols_cmds_F77='$NM $libobjs $convenience | $global_symbol_pipe | $SED '\''s/.* //'\'' | sort | uniq > $export_symbols'
+  # include_expsyms should be a list of space-separated symbols to be *always*
+  # included in the symbol list
+  include_expsyms_F77=
+  # exclude_expsyms can be an extended regexp of symbols to exclude
+  # it will be wrapped by ` (' and `)$', so one must not match beginning or
+  # end of line.  Example: `a|bc|.*d.*' will exclude the symbols `a' and `bc',
+  # as well as any symbol that contains `d'.
+  exclude_expsyms_F77="_GLOBAL_OFFSET_TABLE_"
+  # Although _GLOBAL_OFFSET_TABLE_ is a valid symbol C name, most a.out
+  # platforms (ab)use it in PIC code, but their linkers get confused if
+  # the symbol is explicitly referenced.  Since portable code cannot
+  # rely on this symbol name, it's probably fine to never include it in
+  # preloaded symbol tables.
+  extract_expsyms_cmds=
+  # Just being paranoid about ensuring that cc_basename is set.
+  for cc_temp in $compiler""; do
+  case $cc_temp in
+    *) break;;
+  esac
+done
+  case $host_os in
+  cygwin* | mingw* | pw32*)
+    # FIXME: the MSVC++ port hasn't been tested in a loooong time
+    # When not using gcc, we currently assume that we are using
+    # Microsoft Visual C++.
+    if test "$GCC" != yes; then
+      with_gnu_ld=no
+    fi
+  interix*)
+    # we just hope/assume this is gcc and not c89 (= MSVC++)
+    with_gnu_ld=yes
+  openbsd*)
+    with_gnu_ld=no
+  esac
+  ld_shlibs_F77=yes
+    # If archive_cmds runs LD, not CC, wlarc should be empty
+    wlarc='${wl}'
+    # Set some defaults for GNU ld with shared library support. These
+    # are reset later if shared libraries are not supported. Putting them
+    # here allows them to be overridden if necessary.
+    runpath_var=LD_RUN_PATH
+    hardcode_libdir_flag_spec_F77='${wl}--rpath ${wl}$libdir'
+    export_dynamic_flag_spec_F77='${wl}--export-dynamic'
+    # ancient GNU ld didn't support --whole-archive et. al.
+    if $LD --help 2>&1 | grep 'no-whole-archive' > /dev/null; then
+	whole_archive_flag_spec_F77="$wlarc"'--whole-archive$convenience '"$wlarc"'--no-whole-archive'
+      else
+    fi
+    supports_anon_versioning=no
+    case `$LD -v 2>/dev/null` in
+      *\ [01].* | *\ 2.[0-9].* | *\ 2.10.*) ;; # catch versions < 2.11
+      *\ 2.11.93.0.2\ *) supports_anon_versioning=yes ;; # RH7.3 ...
+      *\ 2.11.92.0.12\ *) supports_anon_versioning=yes ;; # Mandrake 8.2 ...
+      *\ 2.11.*) ;; # other 2.11 versions
+      *) supports_anon_versioning=yes ;;
+    esac
+    # See if GNU ld supports shared libraries.
+    case $host_os in
+    aix3* | aix4* | aix5*)
+      # On AIX/PPC, the GNU linker is very broken
+	ld_shlibs_F77=no
+	cat <<EOF 1>&2
+*** Warning: the GNU linker, at least up to release 2.9.1, is reported
+*** to be unable to reliably create shared libraries on AIX.
+*** Therefore, libtool is disabling shared libraries support.  If you
+*** really care for shared libraries, you may want to modify your PATH
+*** so that a non-GNU linker is found, and then restart.
+EOF
+      fi
+    amigaos*)
+      archive_cmds_F77='$rm $output_objdir/a2ixlibrary.data~$echo "#define NAME $libname" > $output_objdir/a2ixlibrary.data~$echo "#define LIBRARY_ID 1" >> $output_objdir/a2ixlibrary.data~$echo "#define VERSION $major" >> $output_objdir/a2ixlibrary.data~$echo "#define REVISION $revision" >> $output_objdir/a2ixlibrary.data~$AR $AR_FLAGS $lib $libobjs~$RANLIB $lib~(cd $output_objdir && a2ixlibrary -32)'
+      hardcode_libdir_flag_spec_F77='-L$libdir'
+      hardcode_minus_L_F77=yes
+      # Samuel A. Falvo II <kc5tja at dolphin.openprojects.net> reports
+      # that the semantics of dynamic libraries on AmigaOS, at least up
+      # to version 4, is to share data among multiple programs linked
+      # with the same dynamic library.  Since this doesn't match the
+      # behavior of shared libraries on other platforms, we can't use
+      # them.
+      ld_shlibs_F77=no
+    beos*)
+      if $LD --help 2>&1 | grep ': supported targets:.* elf' > /dev/null; then
+	allow_undefined_flag_F77=unsupported
+	# Joseph Beckenbach <jrb3 at best.com> says some releases of gcc
+	# support --undefined.  This deserves some investigation.  FIXME
+	archive_cmds_F77='$CC -nostart $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
+      else
+	ld_shlibs_F77=no
+      fi
+      # _LT_AC_TAGVAR(hardcode_libdir_flag_spec, F77) is actually meaningless,
+      # as there is no search path for DLLs.
+      enable_shared_with_static_runtimes_F77=yes
+      export_symbols_cmds_F77='$NM $libobjs $convenience | $global_symbol_pipe | $SED -e '\''/^[BCDGRS] /s/.* \([^ ]*\)/\1 DATA/'\'' | $SED -e '\''/^[AITW] /s/.* //'\'' | sort | uniq > $export_symbols'
+      if $LD --help 2>&1 | grep 'auto-import' > /dev/null; then
+        archive_cmds_F77='$CC -shared $libobjs $deplibs $compiler_flags -o $output_objdir/$soname ${wl}--enable-auto-image-base -Xlinker --out-implib -Xlinker $lib'
+	# If the export-symbols file already is a .def file (1st line
+	# is EXPORTS), use it as is; otherwise, prepend...
+	archive_expsym_cmds_F77='if test "x`$SED 1q $export_symbols`" = xEXPORTS; then
+	  cp $export_symbols $output_objdir/$soname.def;
+	else
+	  echo EXPORTS > $output_objdir/$soname.def;
+	  cat $export_symbols >> $output_objdir/$soname.def;
+	fi~
+	$CC -shared $output_objdir/$soname.def $libobjs $deplibs $compiler_flags -o $output_objdir/$soname ${wl}--enable-auto-image-base -Xlinker --out-implib -Xlinker $lib'
+      else
+	ld_shlibs_F77=no
+      fi
+    interix3*)
+      hardcode_shlibpath_var_F77=no
+      hardcode_libdir_flag_spec_F77='${wl}-rpath,$libdir'
+      export_dynamic_flag_spec_F77='${wl}-E'
+      # Hack: On Interix 3.x, we cannot compile PIC because of a broken gcc.
+      # Instead, shared libraries are loaded at an image base (0x10000000 by
+      # default) and relocated if they conflict, which is a slow very memory
+      # consuming and fragmenting process.  To avoid this, we pick a random,
+      # 256 KiB-aligned image base between 0x50000000 and 0x6FFC0000 at link
+      # time.  Moving up from 0x10000000 also allows more sbrk(2) space.
+      archive_cmds_F77='$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-h,$soname ${wl}--image-base,`expr ${RANDOM-$$} % 4096 / 2 \* 262144 + 1342177280` -o $lib'
+      archive_expsym_cmds_F77='sed "s,^,_," $export_symbols >$output_objdir/$soname.expsym~$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-h,$soname ${wl}--retain-symbols-file,$output_objdir/$soname.expsym ${wl}--image-base,`expr ${RANDOM-$$} % 4096 / 2 \* 262144 + 1342177280` -o $lib'
+    linux*)
+	tmp_addflag=
+	case $cc_basename,$host_cpu in
+	pgcc*)				# Portland Group C compiler
+	  whole_archive_flag_spec_F77='${wl}--whole-archive`for conv in $convenience\"\"; do test  -n \"$conv\" && new_convenience=\"$new_convenience,$conv\"; done; $echo \"$new_convenience\"` ${wl}--no-whole-archive'
+	  tmp_addflag=' $pic_flag'
+	pgf77* | pgf90* | pgf95*)	# Portland Group f77 and f90 compilers
+	  tmp_addflag=' $pic_flag -Mnomain' ;;
+	ecc*,ia64* | icc*,ia64*)		# Intel C compiler on ia64
+	  tmp_addflag=' -i_dynamic' ;;
+	efc*,ia64* | ifort*,ia64*)	# Intel Fortran compiler on ia64
+	  tmp_addflag=' -i_dynamic -nofor_main' ;;
+	ifc* | ifort*)			# Intel Fortran compiler
+	  tmp_addflag=' -nofor_main' ;;
+	esac
+	archive_cmds_F77='$CC -shared'"$tmp_addflag"' $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
+	if test $supports_anon_versioning = yes; then
+	  archive_expsym_cmds_F77='$echo "{ global:" > $output_objdir/$libname.ver~
+  cat $export_symbols | sed -e "s/\(.*\)/\1;/" >> $output_objdir/$libname.ver~
+  $echo "local: *; };" >> $output_objdir/$libname.ver~
+	  $CC -shared'"$tmp_addflag"' $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-version-script ${wl}$output_objdir/$libname.ver -o $lib'
+	fi
+      else
+	ld_shlibs_F77=no
+      fi
+    netbsd*)
+      if echo __ELF__ | $CC -E - | grep __ELF__ >/dev/null; then
+	archive_cmds_F77='$LD -Bshareable $libobjs $deplibs $linker_flags -o $lib'
+	wlarc=
+      else
+	archive_cmds_F77='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
+	archive_expsym_cmds_F77='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
+      fi
+    solaris*)
+      if $LD -v 2>&1 | grep 'BFD 2\.8' > /dev/null; then
+	ld_shlibs_F77=no
+	cat <<EOF 1>&2
+*** Warning: The releases 2.8.* of the GNU linker cannot reliably
+*** create shared libraries on Solaris systems.  Therefore, libtool
+*** is disabling shared libraries support.  We urge you to upgrade GNU
+*** binutils to release 2.9.1 or newer.  Another option is to modify
+*** your PATH or compiler configuration so that the native linker is
+*** used, and then restart.
+EOF
+      elif $LD --help 2>&1 | grep ': supported targets:.* elf' > /dev/null; then
+      else
+	ld_shlibs_F77=no
+      fi
+    sysv5* | sco3.2v5* | sco5v6* | unixware* | OpenUNIX*)
+      case `$LD -v 2>&1` in
+        *\ [01].* | *\ 2.[0-9].* | *\ 2.1[0-5].*)
+	ld_shlibs_F77=no
+	cat <<_LT_EOF 1>&2
+*** Warning: Releases of the GNU linker prior to 2.16.91.0.3 can not
+*** reliably create shared libraries on SCO systems.  Therefore, libtool
+*** binutils to release 2.16.91.0.3 or newer.  Another option is to modify
+_LT_EOF
+	    hardcode_libdir_flag_spec_F77='`test -z "$SCOABSPATH" && echo ${wl}-rpath,$libdir`'
+	    archive_cmds_F77='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib'
+	    archive_expsym_cmds_F77='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname,\${SCOABSPATH:+${install_libdir}/}$soname,-retain-symbols-file,$export_symbols -o $lib'
+	  else
+	    ld_shlibs_F77=no
+	  fi
+      esac
+    sunos4*)
+      archive_cmds_F77='$LD -assert pure-text -Bshareable -o $lib $libobjs $deplibs $linker_flags'
+      wlarc=
+      hardcode_direct_F77=yes
+      else
+	ld_shlibs_F77=no
+      fi
+    esac
+    if test "$ld_shlibs_F77" = no; then
+      runpath_var=
+    fi
+  else
+    # PORTME fill in a description of your system's linker (not GNU ld)
+    case $host_os in
+    aix3*)
+      always_export_symbols_F77=yes
+      archive_expsym_cmds_F77='$LD -o $output_objdir/$soname $libobjs $deplibs $linker_flags -bE:$export_symbols -T512 -H512 -bM:SRE~$AR $AR_FLAGS $lib $output_objdir/$soname'
+      # Note: this linker hardcodes the directories in LIBPATH if there
+      # are no directories specified by -L.
+      if test "$GCC" = yes && test -z "$lt_prog_compiler_static"; then
+	# Neither direct hardcoding nor static linking is supported with a
+	# broken collect2.
+	hardcode_direct_F77=unsupported
+      fi
+    aix4* | aix5*)
+	# On IA64, the linker does run time linking by default, so we don't
+	# have to do anything special.
+	aix_use_runtimelinking=no
+	exp_sym_flag='-Bexport'
+	no_entry_flag=""
+      else
+	  export_symbols_cmds_F77='$NM -Bpg $libobjs $convenience | awk '\''{ if (((\$2 == "T") || (\$2 == "D") || (\$2 == "B")) && (substr(\$3,1,1) != ".")) { print \$3 } }'\'' | sort -u > $export_symbols'
+	else
+	  export_symbols_cmds_F77='$NM -BCpg $libobjs $convenience | awk '\''{ if (((\$2 == "T") || (\$2 == "D") || (\$2 == "B")) && (substr(\$3,1,1) != ".")) { print \$3 } }'\'' | sort -u > $export_symbols'
+	fi
+	# Test if we are trying to use run time linking or normal
+	# AIX style linking. If -brtl is somewhere in LDFLAGS, we
+	# need to do runtime linking.
+	case $host_os in aix4.[23]|aix4.[23].*|aix5*)
+	  for ld_flag in $LDFLAGS; do
+  	  if (test $ld_flag = "-brtl" || test $ld_flag = "-Wl,-brtl"); then
+  	    aix_use_runtimelinking=yes
+  	    break
+  	  fi
+	  done
+	esac
+	exp_sym_flag='-bexport'
+	no_entry_flag='-bnoentry'
+      fi
+      # When large executables or shared objects are built, AIX ld can
+      # have problems creating the table of contents.  If linking a library
+      # or program results in "error TOC overflow" add -mminimal-toc to
+      # CXXFLAGS/CFLAGS for g++/gcc.  In the cases where that is not
+      # enough to fix the problem, add -Wl,-bbigtoc to LDFLAGS.
+      archive_cmds_F77=''
+      hardcode_libdir_separator_F77=':'
+      link_all_deplibs_F77=yes
+	case $host_os in aix4.[012]|aix4.[012].*)
+	# We only want to do this on AIX 4.2 and lower, the check
+	# below for broken collect2 doesn't work under 4.3+
+	  collect2name=`${CC} -print-prog-name=collect2`
+	  if test -f "$collect2name" && \
+  	   strings "$collect2name" | grep resolve_lib_name >/dev/null
+	  then
+  	  # We have reworked collect2
+	  else
+  	  # We have old collect2
+  	  # It fails to find uninstalled libraries when the uninstalled
+  	  # path is not listed in the libpath.  Setting hardcode_minus_L
+  	  # to unsupported forces relinking
+	  fi
+	esac
+	shared_flag='-shared'
+	if test "$aix_use_runtimelinking" = yes; then
+	  shared_flag="$shared_flag "'${wl}-G'
+	fi
+      else
+	# not using gcc
+  	# VisualAge C++, Version 5.5 for AIX 5L for IA-64, Beta 3 Release
+  	# chokes on -Wl,-G. The following line is correct:
+	  shared_flag='-G'
+	else
+	    shared_flag='${wl}-G'
+	  else
+	    shared_flag='${wl}-bM:SRE'
+	  fi
+	fi
+      fi
+      # It seems that -bexpall does not export symbols beginning with
+      # underscore (_), so it is better to generate a list of symbols to export.
+	# Warning - without using the other runtime loading flags (-brtl),
+	# -berok will link without error, but may produce a broken library.
+	allow_undefined_flag_F77='-berok'
+       # Determine the default libpath from the value encoded in an empty executable.
+       cat >conftest.$ac_ext <<_ACEOF
+      program main
+      end
+_ACEOF
+rm -f conftest.$ac_objext conftest$ac_exeext
+if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
+  (eval $ac_link) 2>conftest.er1
+  ac_status=$?
+  grep -v '^ *+' conftest.er1 >conftest.err
+  rm -f conftest.er1
+  echo "$as_me:$LINENO: \$? = $ac_status" >&5
+  (exit $ac_status); } &&
+	 { ac_try='test -z "$ac_f77_werror_flag"
+			 || test ! -s conftest.err'
+  { (eval echo "$as_me:$LINENO: \"$ac_try\"") >&5
+  (eval $ac_try) 2>&5
+  ac_status=$?
+  (exit $ac_status); }; } &&
+	 { ac_try='test -s conftest$ac_exeext'
+  ac_status=$?
+  (exit $ac_status); }; }; then
+aix_libpath=`dump -H conftest$ac_exeext 2>/dev/null | $SED -n -e '/Import File Strings/,/^$/ { /^0/ { s/^0  *\(.*\)$/\1/; p; }
+# Check for a 64-bit object if we didn't find anything.
+if test -z "$aix_libpath"; then aix_libpath=`dump -HX64 conftest$ac_exeext 2>/dev/null | $SED -n -e '/Import File Strings/,/^$/ { /^0/ { s/^0  *\(.*\)$/\1/; p; }
+}'`; fi
+else
+  echo "$as_me: failed program was:" >&5
+sed 's/^/| /' conftest.$ac_ext >&5
+fi
+rm -f conftest.err conftest.$ac_objext \
+      conftest$ac_exeext conftest.$ac_ext
+if test -z "$aix_libpath"; then aix_libpath="/usr/lib:/lib"; fi
+       hardcode_libdir_flag_spec_F77='${wl}-blibpath:$libdir:'"$aix_libpath"
+	archive_expsym_cmds_F77="\$CC"' -o $output_objdir/$soname $libobjs $deplibs '"\${wl}$no_entry_flag"' $compiler_flags `if test "x${allow_undefined_flag}" != "x"; then echo "${wl}${allow_undefined_flag}"; else :; fi` '"\${wl}$exp_sym_flag:\$export_symbols $shared_flag"
+       else
+	  hardcode_libdir_flag_spec_F77='${wl}-R $libdir:/usr/lib:/lib'
+	  allow_undefined_flag_F77="-z nodefs"
+	  archive_expsym_cmds_F77="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs '"\${wl}$no_entry_flag"' $compiler_flags ${wl}${allow_undefined_flag} '"\${wl}$exp_sym_flag:\$export_symbols"
+	else
+      program main
+      end
+_ACEOF
+  ac_status=$?
+  cat conftest.err >&5
+  ac_status=$?
+  ac_status=$?
+}'`; fi
+else
+fi
+	  # Warning - without using the other run time loading flags,
+	  no_undefined_flag_F77=' ${wl}-bernotok'
+	  allow_undefined_flag_F77=' ${wl}-berok'
+	  # Exported symbols can be pulled into shared objects from archives
+	  whole_archive_flag_spec_F77='$convenience'
+	  archive_cmds_need_lc_F77=yes
+	  # This is similar to how AIX traditionally builds its shared libraries.
+	  archive_expsym_cmds_F77="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs ${wl}-bnoentry $compiler_flags ${wl}-bE:$export_symbols${allow_undefined_flag}~$AR $AR_FLAGS $output_objdir/$libname$release.a $output_objdir/$soname'
+	fi
+      fi
+    amigaos*)
+      # see comment about different semantics on the GNU ld section
+      ld_shlibs_F77=no
+    bsdi[45]*)
+      export_dynamic_flag_spec_F77=-rdynamic
+      # hardcode_libdir_flag_spec is actually meaningless, as there is
+      # no search path for DLLs.
+      hardcode_libdir_flag_spec_F77=' '
+      # Tell ltmain to make .lib files, not .a files.
+      libext=lib
+      # Tell ltmain to make .dll files, not .so files.
+      # FIXME: Setting linknames here is a bad hack.
+      archive_cmds_F77='$CC -o $lib $libobjs $compiler_flags `echo "$deplibs" | $SED -e '\''s/ -lc$//'\''` -link -dll~linknames='
+      # The linker will automatically build a .lib file if we build a DLL.
+      old_archive_From_new_cmds_F77='true'
+      # FIXME: Should let the user specify the lib program.
+      old_archive_cmds_F77='lib /OUT:$oldlib$oldobjs$old_deplibs'
+      fix_srcfile_path_F77='`cygpath -w "$srcfile"`'
+      case $host_os in
+        rhapsody* | darwin1.[012])
+         allow_undefined_flag_F77='${wl}-undefined ${wl}suppress'
+       *) # Darwin 1.3 on
+         if test -z ${MACOSX_DEPLOYMENT_TARGET} ; then
+           allow_undefined_flag_F77='${wl}-flat_namespace ${wl}-undefined ${wl}suppress'
+         else
+           case ${MACOSX_DEPLOYMENT_TARGET} in
+             10.[012])
+             10.*)
+               allow_undefined_flag_F77='${wl}-undefined ${wl}dynamic_lookup'
+           esac
+         fi
+      esac
+      archive_cmds_need_lc_F77=no
+      hardcode_automatic_F77=yes
+      whole_archive_flag_spec_F77=''
+    if test "$GCC" = yes ; then
+    	output_verbose_link_cmd='echo'
+        archive_cmds_F77='$CC -dynamiclib $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring'
+      module_cmds_F77='$CC $allow_undefined_flag -o $lib -bundle $libobjs $deplibs$compiler_flags'
+      # Don't fix this by using the ld -exported_symbols_list flag, it doesn't exist in older darwin lds
+      archive_expsym_cmds_F77='sed -e "s,#.*,," -e "s,^[    ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -dynamiclib $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
+      module_expsym_cmds_F77='sed -e "s,#.*,," -e "s,^[    ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC $allow_undefined_flag  -o $lib -bundle $libobjs $deplibs$compiler_flags~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
+    else
+        xlc*)
+         archive_cmds_F77='$CC -qmkshrobj $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-install_name ${wl}`echo $rpath/$soname` $verstring'
+         archive_expsym_cmds_F77='sed -e "s,#.*,," -e "s,^[    ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -qmkshrobj $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-install_name ${wl}$rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
+         ld_shlibs_F77=no
+      esac
+    fi
+    dgux*)
+      archive_cmds_F77='$LD -G -h $soname -o $lib $libobjs $deplibs $linker_flags'
+    freebsd1*)
+      ld_shlibs_F77=no
+    # FreeBSD 2.2.[012] allows us to include c++rt0.o to get C++ constructor
+    # support.  Future versions do this automatically, but an explicit c++rt0.o
+    # does not break anything, and helps significantly (at the cost of a little
+    # extra space).
+    freebsd2.2*)
+      archive_cmds_F77='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags /usr/lib/c++rt0.o'
+      hardcode_libdir_flag_spec_F77='-R$libdir'
+    # Unfortunately, older versions of FreeBSD 2 do not have this feature.
+    freebsd2*)
+      archive_cmds_F77='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags'
+    # FreeBSD 3 and greater uses gcc -shared to do shared libraries.
+    freebsd* | kfreebsd*-gnu | dragonfly*)
+      archive_cmds_F77='$CC -shared -o $lib $libobjs $deplibs $compiler_flags'
+    hpux9*)
+	archive_cmds_F77='$rm $output_objdir/$soname~$CC -shared -fPIC ${wl}+b ${wl}$install_libdir -o $output_objdir/$soname $libobjs $deplibs $compiler_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
+      else
+	archive_cmds_F77='$rm $output_objdir/$soname~$LD -b +b $install_libdir -o $output_objdir/$soname $libobjs $deplibs $linker_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
+      fi
+      hardcode_libdir_flag_spec_F77='${wl}+b ${wl}$libdir'
+      hardcode_libdir_separator_F77=:
+      # hardcode_minus_L: Not really in the search PATH,
+      # but as the default location of the library.
+    hpux10*)
+      if test "$GCC" = yes -a "$with_gnu_ld" = no; then
+	archive_cmds_F77='$CC -shared -fPIC ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $libobjs $deplibs $compiler_flags'
+      else
+	archive_cmds_F77='$LD -b +h $soname +b $install_libdir -o $lib $libobjs $deplibs $linker_flags'
+      fi
+      if test "$with_gnu_ld" = no; then
+      fi
+    hpux11*)
+	case $host_cpu in
+	hppa*64*)
+	  archive_cmds_F77='$CC -shared ${wl}+h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	ia64*)
+	  archive_cmds_F77='$CC -shared ${wl}+h ${wl}$soname ${wl}+nodefaultrpath -o $lib $libobjs $deplibs $compiler_flags'
+	esac
+      else
+	case $host_cpu in
+	hppa*64*)
+	  archive_cmds_F77='$CC -b ${wl}+h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	ia64*)
+	  archive_cmds_F77='$CC -b ${wl}+h ${wl}$soname ${wl}+nodefaultrpath -o $lib $libobjs $deplibs $compiler_flags'
+	  archive_cmds_F77='$CC -b ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $libobjs $deplibs $compiler_flags'
+	esac
+      fi
+	case $host_cpu in
+	hppa*64*|ia64*)
+	  hardcode_libdir_flag_spec_ld_F77='+b $libdir'
+	esac
+      fi
+    irix5* | irix6* | nonstopux*)
+	archive_cmds_F77='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
+      else
+	archive_cmds_F77='$LD -shared $libobjs $deplibs $linker_flags -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
+	hardcode_libdir_flag_spec_ld_F77='-rpath $libdir'
+      fi
+      hardcode_libdir_flag_spec_F77='${wl}-rpath ${wl}$libdir'
+    netbsd*)
+	archive_cmds_F77='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags'  # a.out
+      else
+	archive_cmds_F77='$LD -shared -o $lib $libobjs $deplibs $linker_flags'      # ELF
+      fi
+    newsos6)
+    openbsd*)
+      if test -z "`echo __ELF__ | $CC -E - | grep __ELF__`" || test "$host_os-$host_cpu" = "openbsd2.8-powerpc"; then
+	archive_cmds_F77='$CC -shared $pic_flag -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds_F77='$CC -shared $pic_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-retain-symbols-file,$export_symbols'
+      else
+       case $host_os in
+	 openbsd[01].* | openbsd2.[0-7] | openbsd2.[0-7].*)
+       esac
+      fi
+    os2*)
+      archive_cmds_F77='$echo "LIBRARY $libname INITINSTANCE" > $output_objdir/$libname.def~$echo "DESCRIPTION \"$libname\"" >> $output_objdir/$libname.def~$echo DATA >> $output_objdir/$libname.def~$echo " SINGLE NONSHARED" >> $output_objdir/$libname.def~$echo EXPORTS >> $output_objdir/$libname.def~emxexp $libobjs >> $output_objdir/$libname.def~$CC -Zdll -Zcrtdll -o $lib $libobjs $deplibs $compiler_flags $output_objdir/$libname.def'
+      old_archive_From_new_cmds_F77='emximp -o $output_objdir/$libname.a $output_objdir/$libname.def'
+    osf3*)
+	allow_undefined_flag_F77=' ${wl}-expect_unresolved ${wl}\*'
+	archive_cmds_F77='$CC -shared${allow_undefined_flag} $libobjs $deplibs $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
+      else
+	allow_undefined_flag_F77=' -expect_unresolved \*'
+	archive_cmds_F77='$LD -shared${allow_undefined_flag} $libobjs $deplibs $linker_flags -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
+      fi
+    osf4* | osf5*)	# as osf3* with the addition of -msym flag
+	archive_cmds_F77='$CC -shared${allow_undefined_flag} $libobjs $deplibs $compiler_flags ${wl}-msym ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
+      else
+	archive_cmds_F77='$LD -shared${allow_undefined_flag} $libobjs $deplibs $linker_flags -msym -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
+	archive_expsym_cmds_F77='for i in `cat $export_symbols`; do printf "%s %s\\n" -exported_symbol "\$i" >> $lib.exp; done; echo "-hidden">> $lib.exp~
+	$LD -shared${allow_undefined_flag} -input $lib.exp $linker_flags $libobjs $deplibs -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib~$rm $lib.exp'
+	# Both c and cxx compiler support -rpath directly
+	hardcode_libdir_flag_spec_F77='-rpath $libdir'
+      fi
+    solaris*)
+      no_undefined_flag_F77=' -z text'
+	wlarc='${wl}'
+	archive_cmds_F77='$CC -shared ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds_F77='$echo "{ global:" > $lib.exp~cat $export_symbols | $SED -e "s/\(.*\)/\1;/" >> $lib.exp~$echo "local: *; };" >> $lib.exp~
+	  $CC -shared ${wl}-M ${wl}$lib.exp ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags~$rm $lib.exp'
+      else
+	wlarc=''
+	archive_cmds_F77='$LD -G${allow_undefined_flag} -h $soname -o $lib $libobjs $deplibs $linker_flags'
+  	$LD -G${allow_undefined_flag} -M $lib.exp -h $soname -o $lib $libobjs $deplibs $linker_flags~$rm $lib.exp'
+      fi
+      case $host_os in
+      solaris2.[0-5] | solaris2.[0-5].*) ;;
+ 	# The compiler driver will combine linker options so we
+ 	# cannot just pass the convience library names through
+ 	# without $wl, iff we do not link with $LD.
+ 	# Luckily, gcc supports the same syntax we need for Sun Studio.
+ 	# Supported since Solaris 2.6 (maybe 2.5.1?)
+ 	case $wlarc in
+ 	  whole_archive_flag_spec_F77='-z allextract$convenience -z defaultextract' ;;
+ 	  whole_archive_flag_spec_F77='${wl}-z ${wl}allextract`for conv in $convenience\"\"; do test -n \"$conv\" && new_convenience=\"$new_convenience,$conv\"; done; $echo \"$new_convenience\"` ${wl}-z ${wl}defaultextract' ;;
+ 	esac ;;
+      esac
+    sunos4*)
+      if test "x$host_vendor" = xsequent; then
+	# Use $CC to link under sequent, because it throws in some extra .o
+	# files that make .init and .fini sections work.
+	archive_cmds_F77='$CC -G ${wl}-h $soname -o $lib $libobjs $deplibs $compiler_flags'
+      else
+	archive_cmds_F77='$LD -assert pure-text -Bstatic -o $lib $libobjs $deplibs $linker_flags'
+      fi
+    sysv4)
+	sni)
+	  hardcode_direct_F77=yes # is this really true???
+	siemens)
+	  ## LD is ld it makes a PLAMLIB
+	  ## CC just makes a GrossModule.
+	  archive_cmds_F77='$LD -G -o $lib $libobjs $deplibs $linker_flags'
+	  reload_cmds_F77='$CC -r -o $output$reload_objs'
+	motorola)
+	  hardcode_direct_F77=no #Motorola manual says yes, but my tests say they lie
+      esac
+      runpath_var='LD_RUN_PATH'
+    sysv4.3*)
+      export_dynamic_flag_spec_F77='-Bexport'
+    sysv4*MP*)
+      if test -d /usr/nec; then
+	hardcode_runpath_var=yes
+	ld_shlibs_F77=yes
+      fi
+    sysv4*uw2* | sysv5OpenUNIX* | sysv5UnixWare7.[01].[10]* | unixware7*)
+      no_undefined_flag_F77='${wl}-z,text'
+	archive_cmds_F77='$CC -shared ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds_F77='$CC -shared ${wl}-Bexport:$export_symbols ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+      else
+	archive_cmds_F77='$CC -G ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds_F77='$CC -G ${wl}-Bexport:$export_symbols ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+      fi
+    sysv5* | sco3.2v5* | sco5v6*)
+      # Note: We can NOT use -z defs as we might desire, because we do not
+      # link with -lc, and that would cause any symbols used from libc to
+      # always be unresolved, which means just about no library would
+      # ever link correctly.  If we're not using GNU ld we use -z text
+      # though, which does catch some bad symbols but isn't as heavy-handed
+      # as -z defs.
+      allow_undefined_flag_F77='${wl}-z,nodefs'
+      hardcode_libdir_flag_spec_F77='`test -z "$SCOABSPATH" && echo ${wl}-R,$libdir`'
+      export_dynamic_flag_spec_F77='${wl}-Bexport'
+	archive_cmds_F77='$CC -shared ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds_F77='$CC -shared ${wl}-Bexport:$export_symbols ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+      else
+	archive_cmds_F77='$CC -G ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds_F77='$CC -G ${wl}-Bexport:$export_symbols ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+      fi
+    uts4*)
+      ld_shlibs_F77=no
+    esac
+  fi
+echo "$as_me:$LINENO: result: $ld_shlibs_F77" >&5
+echo "${ECHO_T}$ld_shlibs_F77" >&6
+test "$ld_shlibs_F77" = no && can_build_shared=no
-# static unsigned int
-# pe_get16 (fd, offset)
-#      int fd;
-#      int offset;
-#   unsigned char b[2];
-#   lseek (fd, offset, SEEK_SET);
-#   read (fd, b, 2);
-#   return b[0] + (b[1]<<8);
+# Do we need to explicitly link libc?
-# pe_get32 (fd, offset)
-#     int fd;
-#     int offset;
-#   unsigned char b[4];
-#   read (fd, b, 4);
-#   return b[0] + (b[1]<<8) + (b[2]<<16) + (b[3]<<24);
+case "x$archive_cmds_need_lc_F77" in
+x|xyes)
+  # Assume -lc should be added
+  if test "$enable_shared" = yes && test "$GCC" = yes; then
+    case $archive_cmds_F77 in
+      # FIXME: we may have to deal with multi-command sequences.
+    '$CC '*)
+      # Test whether the compiler implicitly links with -lc since on some
+      # systems, -lgcc has to come before -lc. If gcc already passes -lc
+      # to ld, don't add -lc before -lgcc.
+      echo "$as_me:$LINENO: checking whether -lc should be explicitly linked in" >&5
+echo $ECHO_N "checking whether -lc should be explicitly linked in... $ECHO_C" >&6
+      $rm conftest*
+      printf "$lt_simple_compile_test_code" > conftest.$ac_ext
+      if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
+  (eval $ac_compile) 2>&5
+  ac_status=$?
+  (exit $ac_status); } 2>conftest.err; then
+        soname=conftest
+        lib=conftest
+        libobjs=conftest.$ac_objext
+        deplibs=
+        wl=$lt_prog_compiler_wl_F77
+	pic_flag=$lt_prog_compiler_pic_F77
+        compiler_flags=-v
+        linker_flags=-v
+        verstring=
+        output_objdir=.
+        libname=conftest
+        lt_save_allow_undefined_flag=$allow_undefined_flag_F77
+        if { (eval echo "$as_me:$LINENO: \"$archive_cmds_F77 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1\"") >&5
+  (eval $archive_cmds_F77 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1) 2>&5
+  ac_status=$?
+        then
+        else
+        fi
+        allow_undefined_flag_F77=$lt_save_allow_undefined_flag
+      else
+        cat conftest.err 1>&5
+      fi
+      $rm conftest*
+      echo "$as_me:$LINENO: result: $archive_cmds_need_lc_F77" >&5
+echo "${ECHO_T}$archive_cmds_need_lc_F77" >&6
+    esac
+  fi
+esac
+echo "$as_me:$LINENO: checking dynamic linker characteristics" >&5
+echo $ECHO_N "checking dynamic linker characteristics... $ECHO_C" >&6
+libname_spec='lib$name'
+soname_spec=
+shrext_cmds=".so"
+postinstall_cmds=
+finish_cmds=
+finish_eval=
+shlibpath_var=
+shlibpath_overrides_runpath=unknown
+version_type=none
+dynamic_linker="$host_os ld.so"
+sys_lib_dlsearch_path_spec="/lib /usr/lib"
+if test "$GCC" = yes; then
+  sys_lib_search_path_spec=`$CC -print-search-dirs | grep "^libraries:" | $SED -e "s/^libraries://" -e "s,=/,/,g"`
+  if echo "$sys_lib_search_path_spec" | grep ';' >/dev/null ; then
+    # if the path contains ";" then we assume it to be the separator
+    # otherwise default to the standard path separator (i.e. ":") - it is
+    # assumed that no part of a normal pathname contains ";" but that should
+    # okay in the real world where ";" in dirpaths is itself problematic.
+    sys_lib_search_path_spec=`echo "$sys_lib_search_path_spec" | $SED -e 's/;/ /g'`
+  else
+    sys_lib_search_path_spec=`echo "$sys_lib_search_path_spec" | $SED  -e "s/$PATH_SEPARATOR/ /g"`
+  fi
+else
+  sys_lib_search_path_spec="/lib /usr/lib /usr/local/lib"
+fi
+need_lib_prefix=unknown
+hardcode_into_libs=no
+# when you set need_version to no, make sure it does not cause -set_version
+# flags to be left without arguments
+need_version=unknown
+case $host_os in
+aix3*)
+  version_type=linux
+  library_names_spec='${libname}${release}${shared_ext}$versuffix $libname.a'
+  shlibpath_var=LIBPATH
+  # AIX 3 has no versioning support, so we append a major version to the name.
+  soname_spec='${libname}${release}${shared_ext}$major'
+aix4* | aix5*)
+  need_lib_prefix=no
+  need_version=no
+  hardcode_into_libs=yes
+    # AIX 5 supports IA64
+    library_names_spec='${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext}$versuffix $libname${shared_ext}'
+    shlibpath_var=LD_LIBRARY_PATH
+  else
+    # With GCC up to 2.95.x, collect2 would create an import file
+    # for dependence libraries.  The import file would start with
+    # the line `#! .'.  This would cause the generated library to
+    # depend on `.', always an invalid library.  This was fixed in
+    # development snapshots of GCC prior to 3.0.
+    case $host_os in
+      aix4 | aix4.[01] | aix4.[01].*)
+      if { echo '#if __GNUC__ > 2 || (__GNUC__ == 2 && __GNUC_MINOR__ >= 97)'
+	   echo ' yes '
+	   echo '#endif'; } | ${CC} -E - | grep yes > /dev/null; then
+      else
+	can_build_shared=no
+      fi
+    esac
+    # AIX (on Power*) has no versioning support, so currently we can not hardcode correct
+    # soname into executable. Probably we can add versioning support to
+    # collect2, so additional links can be useful in future.
+      # If using run time linking (on AIX 4.2 or later) use lib<name>.so
+      # instead of lib<name>.a to let people know that these are not
+      # typical AIX shared libraries.
+      library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname${shared_ext}'
+    else
+      # We preserve .a as extension for shared libraries through AIX4.2
+      # and later when we are not doing run time linking.
+      library_names_spec='${libname}${release}.a $libname.a'
+    fi
+  fi
+amigaos*)
+  library_names_spec='$libname.ixlibrary $libname.a'
+  # Create ${libname}_ixlibrary.a entries in /sys/libs.
+  finish_eval='for lib in `ls $libdir/*.ixlibrary 2>/dev/null`; do libname=`$echo "X$lib" | $Xsed -e '\''s%^.*/\([^/]*\)\.ixlibrary$%\1%'\''`; test $rm /sys/libs/${libname}_ixlibrary.a; $show "cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a"; cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a || exit 1; done'
+beos*)
+  library_names_spec='${libname}${shared_ext}'
+  dynamic_linker="$host_os ld.so"
+  shlibpath_var=LIBRARY_PATH
+bsdi[45]*)
+  need_version=no
+  finish_cmds='PATH="\$PATH:/sbin" ldconfig $libdir'
+  sys_lib_search_path_spec="/shlib /usr/lib /usr/X11/lib /usr/contrib/lib /lib /usr/local/lib"
+  sys_lib_dlsearch_path_spec="/shlib /usr/lib /usr/local/lib"
+  # the default ld.so.conf also contains /usr/contrib/lib and
+  # /usr/X11R6/lib (/usr/X11 is a link to /usr/X11R6), but let us allow
+  # libtool to hard-code these into programs
+cygwin* | mingw* | pw32*)
+  version_type=windows
+  shrext_cmds=".dll"
+  need_version=no
+  case $GCC,$host_os in
+  yes,cygwin* | yes,mingw* | yes,pw32*)
+    library_names_spec='$libname.dll.a'
+    # DLL is installed to $(libdir)/../bin by postinstall_cmds
+    postinstall_cmds='base_file=`basename \${file}`~
+      dlpath=`$SHELL 2>&1 -c '\''. $dir/'\''\${base_file}'\''i;echo \$dlname'\''`~
+      dldir=$destdir/`dirname \$dlpath`~
+      test -d \$dldir || mkdir -p \$dldir~
+      $install_prog $dir/$dlname \$dldir/$dlname~
+      chmod a+x \$dldir/$dlname'
+    postuninstall_cmds='dldll=`$SHELL 2>&1 -c '\''. $file; echo \$dlname'\''`~
+      dlpath=$dir/\$dldll~
+       $rm \$dlpath'
+    shlibpath_overrides_runpath=yes
+    case $host_os in
+    cygwin*)
+      # Cygwin DLLs use 'cyg' prefix rather than 'lib'
+      soname_spec='`echo ${libname} | sed -e 's/^lib/cyg/'``echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
+      sys_lib_search_path_spec="/usr/lib /lib/w32api /lib /usr/local/lib"
+    mingw*)
+      # MinGW DLLs use traditional 'lib' prefix
+      soname_spec='${libname}`echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
+      if echo "$sys_lib_search_path_spec" | grep ';[c-zC-Z]:/' >/dev/null; then
+        # It is most probably a Windows format PATH printed by
+        # mingw gcc, but we are running on Cygwin. Gcc prints its search
+        # path with ; separators, and with drive letters. We can handle the
+        # drive letters (cygwin fileutils understands them), so leave them,
+        # especially as we might pass files found there to a mingw objdump,
+        # which wouldn't understand a cygwinified path. Ahh.
+      else
+      fi
+    pw32*)
+      # pw32 DLLs use 'pw' prefix rather than 'lib'
+      library_names_spec='`echo ${libname} | sed -e 's/^lib/pw/'``echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
+    esac
+    library_names_spec='${libname}`echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext} $libname.lib'
+  esac
+  dynamic_linker='Win32 ld.exe'
+  # FIXME: first we should search . and the directory the executable is in
+  shlibpath_var=PATH
+darwin* | rhapsody*)
+  dynamic_linker="$host_os dyld"
+  version_type=darwin
+  need_version=no
+  library_names_spec='${libname}${release}${versuffix}$shared_ext ${libname}${release}${major}$shared_ext ${libname}$shared_ext'
+  soname_spec='${libname}${release}${major}$shared_ext'
+  shlibpath_var=DYLD_LIBRARY_PATH
+  shrext_cmds='`test .$module = .yes && echo .so || echo .dylib`'
+  # Apple's gcc prints 'gcc -print-search-dirs' doesn't operate the same.
+  if test "$GCC" = yes; then
+    sys_lib_search_path_spec=`$CC -print-search-dirs | tr "\n" "$PATH_SEPARATOR" | sed -e 's/libraries:/@libraries:/' | tr "@" "\n" | grep "^libraries:" | sed -e "s/^libraries://" -e "s,=/,/,g" -e "s,$PATH_SEPARATOR, ,g" -e "s,.*,& /lib /usr/lib /usr/local/lib,g"`
+  else
+    sys_lib_search_path_spec='/lib /usr/lib /usr/local/lib'
+  fi
+  sys_lib_dlsearch_path_spec='/usr/local/lib /lib /usr/lib'
+dgux*)
+  need_version=no
+  library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname$shared_ext'
+freebsd1*)
+  dynamic_linker=no
+kfreebsd*-gnu)
+  need_version=no
+  library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${shared_ext}'
+  shlibpath_overrides_runpath=no
+  dynamic_linker='GNU ld.so'
+freebsd* | dragonfly*)
+  # DragonFly does not have aout.  When/if they implement a new
+  # versioning mechanism, adjust this.
+  if test -x /usr/bin/objformat; then
+    objformat=`/usr/bin/objformat`
+  else
+    case $host_os in
+    freebsd[123]*) objformat=aout ;;
+    *) objformat=elf ;;
+    esac
+  fi
+  version_type=freebsd-$objformat
+  case $version_type in
+    freebsd-elf*)
+      library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext} $libname${shared_ext}'
+      need_version=no
+    freebsd-*)
+      library_names_spec='${libname}${release}${shared_ext}$versuffix $libname${shared_ext}$versuffix'
+      need_version=yes
+  esac
+  case $host_os in
+  freebsd2*)
+  freebsd3.[01]* | freebsdelf3.[01]*)
+  freebsd3.[2-9]* | freebsdelf3.[2-9]* | \
+  freebsd4.[0-5] | freebsdelf4.[0-5] | freebsd4.1.1 | freebsdelf4.1.1)
+  freebsd*) # from 4.6 on
+  esac
+gnu*)
+  need_version=no
+  library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}${major} ${libname}${shared_ext}'
+hpux9* | hpux10* | hpux11*)
+  # Give a soname corresponding to the major version so that dld.sl refuses to
+  # link against other versions.
+  version_type=sunos
+  need_version=no
+  case $host_cpu in
+  ia64*)
+    shrext_cmds='.so'
+    dynamic_linker="$host_os dld.so"
+    shlibpath_overrides_runpath=yes # Unless +noenvvar is specified.
+    if test "X$HPUX_IA64_MODE" = X32; then
+      sys_lib_search_path_spec="/usr/lib/hpux32 /usr/local/lib/hpux32 /usr/local/lib"
+    else
+      sys_lib_search_path_spec="/usr/lib/hpux64 /usr/local/lib/hpux64"
+    fi
+    sys_lib_dlsearch_path_spec=$sys_lib_search_path_spec
+   hppa*64*)
+     shrext_cmds='.sl'
+     dynamic_linker="$host_os dld.sl"
+     shlibpath_var=LD_LIBRARY_PATH # How should we handle SHLIB_PATH
+     sys_lib_search_path_spec="/usr/lib/pa20_64 /usr/ccs/lib/pa20_64"
+    shrext_cmds='.sl'
+    shlibpath_var=SHLIB_PATH
+    shlibpath_overrides_runpath=no # +s is required to enable SHLIB_PATH
+  esac
+  # HP-UX runs *really* slowly unless shared libraries are mode 555.
+  postinstall_cmds='chmod 555 $lib'
+interix3*)
+  need_version=no
+  dynamic_linker='Interix 3.x ld.so.1 (PE, like ELF)'
+irix5* | irix6* | nonstopux*)
+  case $host_os in
+    nonstopux*) version_type=nonstopux ;;
+	if test "$lt_cv_prog_gnu_ld" = yes; then
+	else
+		version_type=irix
+	fi ;;
+  esac
+  need_version=no
+  library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext} $libname${shared_ext}'
+  case $host_os in
+  irix5* | nonstopux*)
+    libsuff= shlibsuff=
+    case $LD in # libtool.m4 will add one of these switches to LD
+    *-32|*"-32 "|*-melf32bsmip|*"-melf32bsmip ")
+      libsuff= shlibsuff= libmagic=32-bit;;
+    *-n32|*"-n32 "|*-melf32bmipn32|*"-melf32bmipn32 ")
+      libsuff=32 shlibsuff=N32 libmagic=N32;;
+    *-64|*"-64 "|*-melf64bmip|*"-melf64bmip ")
+      libsuff=64 shlibsuff=64 libmagic=64-bit;;
+    *) libsuff= shlibsuff= libmagic=never-match;;
+    esac
+  esac
+  shlibpath_var=LD_LIBRARY${shlibsuff}_PATH
+  sys_lib_search_path_spec="/usr/lib${libsuff} /lib${libsuff} /usr/local/lib${libsuff}"
+  sys_lib_dlsearch_path_spec="/usr/lib${libsuff} /lib${libsuff}"
+# No shared lib support for Linux oldld, aout, or coff.
+linux*oldld* | linux*aout* | linux*coff*)
+  dynamic_linker=no
+# This must be Linux ELF.
+linux*)
+  need_version=no
+  finish_cmds='PATH="\$PATH:/sbin" ldconfig -n $libdir'
+  # This implies no fast_install, which is unacceptable.
+  # Some rework will be needed to allow for fast_install
+  # before this can be enabled.
+  # find out which ABI we are using
+  libsuff=
+  case "$host_cpu" in
+  x86_64*|s390x*|powerpc64*)
+    echo '#line 14832 "configure"' > conftest.$ac_ext
+  ac_status=$?
+  (exit $ac_status); }; then
+      case `/usr/bin/file conftest.$ac_objext` in
+      *64-bit*)
+        libsuff=64
+        sys_lib_search_path_spec="/lib${libsuff} /usr/lib${libsuff} /usr/local/lib${libsuff}"
+      esac
+    fi
+    rm -rf conftest*
+  esac
+  # Append ld.so.conf contents to the search path
+  if test -f /etc/ld.so.conf; then
+    lt_ld_extra=`awk '/^include / { system(sprintf("cd /etc; cat %s", \$2)); skip = 1; } { if (!skip) print \$0; skip = 0; }' < /etc/ld.so.conf | $SED -e 's/#.*//;s/[:,	]/ /g;s/=[^=]*$//;s/=[^= ]* / /g;/^$/d' | tr '\n' ' '`
+    sys_lib_dlsearch_path_spec="/lib${libsuff} /usr/lib${libsuff} $lt_ld_extra"
+  fi
+  # We used to test for /lib/ld.so.1 and disable shared libraries on
+  # powerpc, because MkLinux only supported shared libraries with the
+  # GNU dynamic linker.  Since this was broken with cross compilers,
+  # most powerpc-linux boxes support dynamic linking these days and
+  # people can always --disable-shared, the test was removed, and we
+  # assume the GNU/Linux dynamic linker is in use.
+  dynamic_linker='GNU/Linux ld.so'
+knetbsd*-gnu)
+  need_version=no
+netbsd*)
+  need_version=no
+    library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${shared_ext}$versuffix'
+    finish_cmds='PATH="\$PATH:/sbin" ldconfig -m $libdir'
+    dynamic_linker='NetBSD (a.out) ld.so'
+  else
+    dynamic_linker='NetBSD ld.elf_so'
+  fi
+newsos6)
+nto-qnx*)
+  need_version=no
+openbsd*)
+  sys_lib_dlsearch_path_spec="/usr/lib"
+  # Some older versions of OpenBSD (3.3 at least) *do* need versioned libs.
+  case $host_os in
+    openbsd3.3 | openbsd3.3.*) need_version=yes ;;
+    *)                         need_version=no  ;;
+  esac
+    case $host_os in
+      openbsd2.[89] | openbsd2.[89].*)
+      esac
+  else
+  fi
+os2*)
+  libname_spec='$name'
+  library_names_spec='$libname${shared_ext} $libname.a'
+  dynamic_linker='OS/2 ld.exe'
+osf3* | osf4* | osf5*)
+  version_type=osf
+  need_version=no
+  sys_lib_search_path_spec="/usr/shlib /usr/ccs/lib /usr/lib/cmplrs/cc /usr/lib /usr/local/lib /var/shlib"
+  sys_lib_dlsearch_path_spec="$sys_lib_search_path_spec"
+solaris*)
+  need_version=no
+  # ldd complains unless libraries are executable
+  postinstall_cmds='chmod +x $lib'
+sunos4*)
+  finish_cmds='PATH="\$PATH:/usr/etc" ldconfig $libdir'
+  if test "$with_gnu_ld" = yes; then
+  fi
+  need_version=yes
+sysv4 | sysv4.3*)
+  case $host_vendor in
+    sni)
+      export_dynamic_flag_spec='${wl}-Blargedynsym'
+    siemens)
+    motorola)
+      need_version=no
+      sys_lib_search_path_spec='/lib /usr/lib /usr/ccs/lib'
+  esac
+sysv4*MP*)
+  if test -d /usr/nec ;then
+    library_names_spec='$libname${shared_ext}.$versuffix $libname${shared_ext}.$major $libname${shared_ext}'
+    soname_spec='$libname${shared_ext}.$major'
+  fi
+sysv5* | sco3.2v5* | sco5v6* | unixware* | OpenUNIX* | sysv4*uw2*)
+  version_type=freebsd-elf
+  need_version=no
+    sys_lib_search_path_spec='/usr/local/lib /usr/gnu/lib /usr/ccs/lib /usr/lib /lib'
+  else
+    sys_lib_search_path_spec='/usr/ccs/lib /usr/lib'
+    case $host_os in
+      sco3.2v5*)
+        sys_lib_search_path_spec="$sys_lib_search_path_spec /lib"
+    esac
+  fi
+  sys_lib_dlsearch_path_spec='/usr/lib'
+uts4*)
+  dynamic_linker=no
+esac
+echo "$as_me:$LINENO: result: $dynamic_linker" >&5
+echo "${ECHO_T}$dynamic_linker" >&6
+test "$dynamic_linker" = no && can_build_shared=no
+variables_saved_for_relink="PATH $shlibpath_var $runpath_var"
+  variables_saved_for_relink="$variables_saved_for_relink GCC_EXEC_PREFIX COMPILER_PATH LIBRARY_PATH"
+fi
+echo "$as_me:$LINENO: checking how to hardcode library paths into programs" >&5
+echo $ECHO_N "checking how to hardcode library paths into programs... $ECHO_C" >&6
+hardcode_action_F77=
+if test -n "$hardcode_libdir_flag_spec_F77" || \
+   test -n "$runpath_var_F77" || \
+   test "X$hardcode_automatic_F77" = "Xyes" ; then
+  # We can hardcode non-existant directories.
+  if test "$hardcode_direct_F77" != no &&
+     # If the only mechanism to avoid hardcoding is shlibpath_var, we
+     # have to relink, otherwise we might link with an installed library
+     # when we should be linking with a yet-to-be-installed one
+     ## test "$_LT_AC_TAGVAR(hardcode_shlibpath_var, F77)" != no &&
+     test "$hardcode_minus_L_F77" != no; then
+    # Linking always hardcodes the temporary library directory.
+    hardcode_action_F77=relink
+  else
+    # We can link without hardcoding, and we can hardcode nonexisting dirs.
+    hardcode_action_F77=immediate
+  fi
+else
+  # We cannot hardcode anything, or else we can only hardcode existing
+  # directories.
+  hardcode_action_F77=unsupported
+fi
+echo "$as_me:$LINENO: result: $hardcode_action_F77" >&5
+echo "${ECHO_T}$hardcode_action_F77" >&6
+if test "$hardcode_action_F77" = relink; then
+  # Fast installation is not supported
+  enable_fast_install=no
+elif test "$shlibpath_overrides_runpath" = yes ||
+     test "$enable_shared" = no; then
+  # Fast installation is not necessary
+  enable_fast_install=needless
+fi
+# The else clause should only fire when bootstrapping the
+# libtool distribution, otherwise you forgot to ship ltmain.sh
+# with your package, and you will get complaints that there are
+# no rules to generate ltmain.sh.
+if test -f "$ltmain"; then
+  # See if we are running on zsh, and set the options which allow our commands through
+  # without removal of \ escapes.
+  if test -n "${ZSH_VERSION+set}" ; then
+    setopt NO_GLOB_SUBST
+  fi
+  # Now quote all the things that may contain metacharacters while being
+  # careful not to overquote the AC_SUBSTed values.  We take copies of the
+  # variables and quote the copies for generation of the libtool script.
+  for var in echo old_CC old_CFLAGS AR AR_FLAGS EGREP RANLIB LN_S LTCC LTCFLAGS NM \
+    SED SHELL STRIP \
+    libname_spec library_names_spec soname_spec extract_expsyms_cmds \
+    old_striplib striplib file_magic_cmd finish_cmds finish_eval \
+    deplibs_check_method reload_flag reload_cmds need_locks \
+    lt_cv_sys_global_symbol_pipe lt_cv_sys_global_symbol_to_cdecl \
+    lt_cv_sys_global_symbol_to_c_name_address \
+    sys_lib_search_path_spec sys_lib_dlsearch_path_spec \
+    old_postinstall_cmds old_postuninstall_cmds \
+    compiler_F77 \
+    CC_F77 \
+    LD_F77 \
+    lt_prog_compiler_wl_F77 \
+    lt_prog_compiler_pic_F77 \
+    lt_prog_compiler_static_F77 \
+    lt_prog_compiler_no_builtin_flag_F77 \
+    export_dynamic_flag_spec_F77 \
+    thread_safe_flag_spec_F77 \
+    whole_archive_flag_spec_F77 \
+    enable_shared_with_static_runtimes_F77 \
+    old_archive_cmds_F77 \
+    old_archive_from_new_cmds_F77 \
+    predep_objects_F77 \
+    postdep_objects_F77 \
+    predeps_F77 \
+    postdeps_F77 \
+    compiler_lib_search_path_F77 \
+    archive_cmds_F77 \
+    archive_expsym_cmds_F77 \
+    postinstall_cmds_F77 \
+    postuninstall_cmds_F77 \
+    old_archive_from_expsyms_cmds_F77 \
+    allow_undefined_flag_F77 \
+    no_undefined_flag_F77 \
+    export_symbols_cmds_F77 \
+    hardcode_libdir_flag_spec_F77 \
+    hardcode_libdir_flag_spec_ld_F77 \
+    hardcode_libdir_separator_F77 \
+    hardcode_automatic_F77 \
+    module_cmds_F77 \
+    module_expsym_cmds_F77 \
+    lt_cv_prog_compiler_c_o_F77 \
+    exclude_expsyms_F77 \
+    include_expsyms_F77; do
+    case $var in
+    old_archive_cmds_F77 | \
+    old_archive_from_new_cmds_F77 | \
+    archive_cmds_F77 | \
+    archive_expsym_cmds_F77 | \
+    module_cmds_F77 | \
+    module_expsym_cmds_F77 | \
+    old_archive_from_expsyms_cmds_F77 | \
+    export_symbols_cmds_F77 | \
+    extract_expsyms_cmds | reload_cmds | finish_cmds | \
+    postinstall_cmds | postuninstall_cmds | \
+    old_postinstall_cmds | old_postuninstall_cmds | \
+    sys_lib_search_path_spec | sys_lib_dlsearch_path_spec)
+      # Double-quote double-evaled strings.
+      eval "lt_$var=\\\"\`\$echo \"X\$$var\" | \$Xsed -e \"\$double_quote_subst\" -e \"\$sed_quote_subst\" -e \"\$delay_variable_subst\"\`\\\""
+      eval "lt_$var=\\\"\`\$echo \"X\$$var\" | \$Xsed -e \"\$sed_quote_subst\"\`\\\""
+    esac
+  done
+  case $lt_echo in
+  *'\$0 --fallback-echo"')
+    lt_echo=`$echo "X$lt_echo" | $Xsed -e 's/\\\\\\\$0 --fallback-echo"$/$0 --fallback-echo"/'`
+  esac
+cfgfile="$ofile"
+  cat <<__EOF__ >> "$cfgfile"
+# ### BEGIN LIBTOOL TAG CONFIG: $tagname
+# Libtool was configured on host `(hostname || uname -n) 2>/dev/null | sed 1q`:
+# Shell to use when invoking shell scripts.
+SHELL=$lt_SHELL
+# Whether or not to build shared libraries.
+build_libtool_libs=$enable_shared
+# Whether or not to build static libraries.
+build_old_libs=$enable_static
+# Whether or not to add -lc for building shared libraries.
+build_libtool_need_lc=$archive_cmds_need_lc_F77
+# Whether or not to disallow shared libs when runtime libs are static
+allow_libtool_libs_with_static_runtimes=$enable_shared_with_static_runtimes_F77
+# Whether or not to optimize for fast installation.
+fast_install=$enable_fast_install
+# The host system.
+host_alias=$host_alias
+host=$host
+host_os=$host_os
+# The build system.
+build_alias=$build_alias
+build=$build
+build_os=$build_os
+# An echo program that does not interpret backslashes.
+echo=$lt_echo
+# The archiver.
+AR=$lt_AR
+AR_FLAGS=$lt_AR_FLAGS
+# A C compiler.
+LTCC=$lt_LTCC
+# LTCC compiler flags.
+LTCFLAGS=$lt_LTCFLAGS
+# A language-specific compiler.
+CC=$lt_compiler_F77
+# Is the compiler the GNU C compiler?
+with_gcc=$GCC_F77
+# An ERE matcher.
+EGREP=$lt_EGREP
+# The linker used to build libraries.
+LD=$lt_LD_F77
+# Whether we need hard or soft links.
+LN_S=$lt_LN_S
+# A BSD-compatible nm program.
+NM=$lt_NM
+# A symbol stripping program
+STRIP=$lt_STRIP
+# Used to examine libraries when file_magic_cmd begins "file"
+MAGIC_CMD=$MAGIC_CMD
+# Used on cygwin: DLL creation program.
+DLLTOOL="$DLLTOOL"
+# Used on cygwin: object dumper.
+OBJDUMP="$OBJDUMP"
+# Used on cygwin: assembler.
+AS="$AS"
+# The name of the directory that contains temporary libtool files.
+objdir=$objdir
+# How to create reloadable object files.
+reload_flag=$lt_reload_flag
+reload_cmds=$lt_reload_cmds
+# How to pass a linker flag through the compiler.
+wl=$lt_lt_prog_compiler_wl_F77
+# Object file suffix (normally "o").
+objext="$ac_objext"
+# Old archive suffix (normally "a").
+libext="$libext"
+# Shared library suffix (normally ".so").
+shrext_cmds='$shrext_cmds'
+# Executable file suffix (normally "").
+exeext="$exeext"
+# Additional compiler flags for building library objects.
+pic_flag=$lt_lt_prog_compiler_pic_F77
+pic_mode=$pic_mode
+# What is the maximum length of a command?
+max_cmd_len=$lt_cv_sys_max_cmd_len
+# Does compiler simultaneously support -c and -o options?
+compiler_c_o=$lt_lt_cv_prog_compiler_c_o_F77
+# Must we lock files when doing compilation?
+need_locks=$lt_need_locks
+# Do we need the lib prefix for modules?
+need_lib_prefix=$need_lib_prefix
+# Do we need a version for libraries?
+need_version=$need_version
+# Whether dlopen is supported.
+dlopen_support=$enable_dlopen
+# Whether dlopen of programs is supported.
+dlopen_self=$enable_dlopen_self
+# Whether dlopen of statically linked programs is supported.
+dlopen_self_static=$enable_dlopen_self_static
+# Compiler flag to prevent dynamic linking.
+link_static_flag=$lt_lt_prog_compiler_static_F77
+# Compiler flag to turn off builtin functions.
+no_builtin_flag=$lt_lt_prog_compiler_no_builtin_flag_F77
+# Compiler flag to allow reflexive dlopens.
+export_dynamic_flag_spec=$lt_export_dynamic_flag_spec_F77
+# Compiler flag to generate shared objects directly from archives.
+whole_archive_flag_spec=$lt_whole_archive_flag_spec_F77
+# Compiler flag to generate thread-safe objects.
+thread_safe_flag_spec=$lt_thread_safe_flag_spec_F77
+# Library versioning type.
+version_type=$version_type
+# Format of library name prefix.
+libname_spec=$lt_libname_spec
+# List of archive names.  First name is the real one, the rest are links.
+# The last name is the one that the linker finds with -lNAME.
+library_names_spec=$lt_library_names_spec
+# The coded name of the library, if different from the real name.
+soname_spec=$lt_soname_spec
+# Commands used to build and install an old-style archive.
+RANLIB=$lt_RANLIB
+old_archive_cmds=$lt_old_archive_cmds_F77
+old_postinstall_cmds=$lt_old_postinstall_cmds
+old_postuninstall_cmds=$lt_old_postuninstall_cmds
+# Create an old-style archive from a shared archive.
+old_archive_from_new_cmds=$lt_old_archive_from_new_cmds_F77
+# Create a temporary old-style archive to link instead of a shared archive.
+old_archive_from_expsyms_cmds=$lt_old_archive_from_expsyms_cmds_F77
+# Commands used to build and install a shared archive.
+archive_cmds=$lt_archive_cmds_F77
+archive_expsym_cmds=$lt_archive_expsym_cmds_F77
+postinstall_cmds=$lt_postinstall_cmds
+postuninstall_cmds=$lt_postuninstall_cmds
+# Commands used to build a loadable module (assumed same as above if empty)
+module_cmds=$lt_module_cmds_F77
+module_expsym_cmds=$lt_module_expsym_cmds_F77
+# Commands to strip libraries.
+old_striplib=$lt_old_striplib
+striplib=$lt_striplib
+# Dependencies to place before the objects being linked to create a
+# shared library.
+predep_objects=$lt_predep_objects_F77
+# Dependencies to place after the objects being linked to create a
+# shared library.
+postdep_objects=$lt_postdep_objects_F77
+# shared library.
+predeps=$lt_predeps_F77
+# shared library.
+postdeps=$lt_postdeps_F77
+# The library search path used internally by the compiler when linking
+# a shared library.
+compiler_lib_search_path=$lt_compiler_lib_search_path_F77
+# Method to check whether dependent libraries are shared objects.
+deplibs_check_method=$lt_deplibs_check_method
+# Command to use when deplibs_check_method == file_magic.
+file_magic_cmd=$lt_file_magic_cmd
+# Flag that allows shared libraries with undefined symbols to be built.
+allow_undefined_flag=$lt_allow_undefined_flag_F77
+# Flag that forces no undefined symbols.
+no_undefined_flag=$lt_no_undefined_flag_F77
+# Commands used to finish a libtool library installation in a directory.
+finish_cmds=$lt_finish_cmds
+# Same as above, but a single script fragment to be evaled but not shown.
+finish_eval=$lt_finish_eval
+# Take the output of nm and produce a listing of raw symbols and C names.
+global_symbol_pipe=$lt_lt_cv_sys_global_symbol_pipe
+# Transform the output of nm in a proper C declaration
+global_symbol_to_cdecl=$lt_lt_cv_sys_global_symbol_to_cdecl
+# Transform the output of nm in a C name address pair
+global_symbol_to_c_name_address=$lt_lt_cv_sys_global_symbol_to_c_name_address
+# This is the shared library runtime path variable.
+runpath_var=$runpath_var
+# This is the shared library path variable.
+shlibpath_var=$shlibpath_var
+# Is shlibpath searched before the hard-coded library search path?
+shlibpath_overrides_runpath=$shlibpath_overrides_runpath
+# How to hardcode a shared library path into an executable.
+hardcode_action=$hardcode_action_F77
+# Whether we should hardcode library paths into libraries.
+hardcode_into_libs=$hardcode_into_libs
+# Flag to hardcode \$libdir into a binary during linking.
+# This must work even if \$libdir does not exist.
+hardcode_libdir_flag_spec=$lt_hardcode_libdir_flag_spec_F77
+# If ld is used when linking, flag to hardcode \$libdir into
+# a binary during linking. This must work even if \$libdir does
+# not exist.
+hardcode_libdir_flag_spec_ld=$lt_hardcode_libdir_flag_spec_ld_F77
+# Whether we need a single -rpath flag with a separated argument.
+hardcode_libdir_separator=$lt_hardcode_libdir_separator_F77
+# Set to yes if using DIR/libNAME${shared_ext} during linking hardcodes DIR into the
+# resulting binary.
+hardcode_direct=$hardcode_direct_F77
+# Set to yes if using the -LDIR flag during linking hardcodes DIR into the
+hardcode_minus_L=$hardcode_minus_L_F77
+# Set to yes if using SHLIBPATH_VAR=DIR during linking hardcodes DIR into
+# the resulting binary.
+hardcode_shlibpath_var=$hardcode_shlibpath_var_F77
+# Set to yes if building a shared library automatically hardcodes DIR into the library
+# and all subsequent libraries and executables linked against it.
+hardcode_automatic=$hardcode_automatic_F77
+# Variables whose values should be saved in libtool wrapper scripts and
+# restored at relink time.
+variables_saved_for_relink="$variables_saved_for_relink"
+# Whether libtool must link a program against all its dependency libraries.
+link_all_deplibs=$link_all_deplibs_F77
+# Compile-time system search path for libraries
+sys_lib_search_path_spec=$lt_sys_lib_search_path_spec
+# Run-time system search path for libraries
+sys_lib_dlsearch_path_spec=$lt_sys_lib_dlsearch_path_spec
+# Fix the shell variable \$srcfile for the compiler.
+fix_srcfile_path="$fix_srcfile_path_F77"
+# Set to yes if exported symbols are required.
+always_export_symbols=$always_export_symbols_F77
+# The commands to list exported symbols.
+export_symbols_cmds=$lt_export_symbols_cmds_F77
+# The commands to extract the exported symbol list from a shared archive.
+extract_expsyms_cmds=$lt_extract_expsyms_cmds
+# Symbols that should not be listed in the preloaded symbols.
+exclude_expsyms=$lt_exclude_expsyms_F77
+# Symbols that must always be exported.
+include_expsyms=$lt_include_expsyms_F77
+# ### END LIBTOOL TAG CONFIG: $tagname
+__EOF__
+else
+  # If there is no Makefile yet, we rely on a make rule to execute
+  # `config.status --recheck' to rerun these tests and create the
+  # libtool script then.
+  ltmain_in=`echo $ltmain | sed -e 's/\.sh$/.in/'`
+  if test -f "$ltmain_in"; then
+    test -f Makefile && make "$ltmain"
+  fi
+fi
+ac_ext=cc
+ac_cpp='$CXXCPP $CPPFLAGS'
+ac_compile='$CXX -c $CXXFLAGS $CPPFLAGS conftest.$ac_ext >&5'
+ac_link='$CXX -o conftest$ac_exeext $CXXFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
+ac_compiler_gnu=$ac_cv_cxx_compiler_gnu
+CC="$lt_save_CC"
+	else
+	  tagname=""
+	fi
+      GCJ)
+	if test -n "$GCJ" && test "X$GCJ" != "Xno"; then
+# Source file extension for Java test sources.
+ac_ext=java
+# Object file extension for compiled Java test sources.
+objext=o
+objext_GCJ=$objext
+# Code to be used in simple compile tests
+lt_simple_compile_test_code="class foo {}\n"
+# Code to be used in simple link tests
+lt_simple_link_test_code='public class conftest { public static void main(String[] argv) {}; }\n'
+# ltmain only uses $CC for tagged configurations so make sure $CC is set.
+# If no C compiler was specified, use CC.
+LTCC=${LTCC-"$CC"}
+# If no C compiler flags were specified, use CFLAGS.
+LTCFLAGS=${LTCFLAGS-"$CFLAGS"}
+# Allow CC to be a program name with arguments.
+compiler=$CC
+# save warnings/boilerplate of simple test code
+ac_outfile=conftest.$ac_objext
+printf "$lt_simple_compile_test_code" >conftest.$ac_ext
+eval "$ac_compile" 2>&1 >/dev/null | $SED '/^$/d; /^ *+/d' >conftest.err
+_lt_compiler_boilerplate=`cat conftest.err`
+$rm conftest*
+printf "$lt_simple_link_test_code" >conftest.$ac_ext
+eval "$ac_link" 2>&1 >/dev/null | $SED '/^$/d; /^ *+/d' >conftest.err
+_lt_linker_boilerplate=`cat conftest.err`
+$rm conftest*
+lt_save_CC="$CC"
+CC=${GCJ-"gcj"}
+compiler=$CC
+compiler_GCJ=$CC
+for cc_temp in $compiler""; do
+  case $cc_temp in
+    compile | *[\\/]compile | ccache | *[\\/]ccache ) ;;
+    distcc | *[\\/]distcc | purify | *[\\/]purify ) ;;
+    *) break;;
+  esac
+done
+cc_basename=`$echo "X$cc_temp" | $Xsed -e 's%.*/%%' -e "s%^$host_alias-%%"`
+# GCJ did not exist at the time GCC didn't implicitly link libc in.
+archive_cmds_need_lc_GCJ=no
+old_archive_cmds_GCJ=$old_archive_cmds
+lt_prog_compiler_no_builtin_flag_GCJ=
+  lt_prog_compiler_no_builtin_flag_GCJ=' -fno-builtin'
+echo "$as_me:$LINENO: checking if $compiler supports -fno-rtti -fno-exceptions" >&5
+echo $ECHO_N "checking if $compiler supports -fno-rtti -fno-exceptions... $ECHO_C" >&6
+if test "${lt_cv_prog_compiler_rtti_exceptions+set}" = set; then
+  echo $ECHO_N "(cached) $ECHO_C" >&6
+else
+  lt_cv_prog_compiler_rtti_exceptions=no
+  ac_outfile=conftest.$ac_objext
+   lt_compiler_flag="-fno-rtti -fno-exceptions"
+   # Insert the option either (1) after the last *FLAGS variable, or
+   # (2) before a word containing "conftest.", or (3) at the end.
+   # Note that $ac_compile itself does not contain backslashes and begins
+   # with a dollar sign (not a hyphen), so the echo should work correctly.
+   # The option is referenced via a variable to avoid confusing sed.
+   lt_compile=`echo "$ac_compile" | $SED \
+   -e 's:.*FLAGS}\{0,1\} :&$lt_compiler_flag :; t' \
+   -e 's: [^ ]*conftest\.: $lt_compiler_flag&:; t' \
+   -e 's:$: $lt_compiler_flag:'`
+   (eval echo "\"\$as_me:15607: $lt_compile\"" >&5)
+   (eval "$lt_compile" 2>conftest.err)
+   ac_status=$?
+   echo "$as_me:15611: \$? = $ac_status" >&5
+   if (exit $ac_status) && test -s "$ac_outfile"; then
+     # The compiler can only warn and ignore the option if not recognized
+     # So say no if there are warnings other than the usual output.
+     $echo "X$_lt_compiler_boilerplate" | $Xsed -e '/^$/d' >conftest.exp
+     $SED '/^$/d; /^ *+/d' conftest.err >conftest.er2
+     if test ! -s conftest.er2 || diff conftest.exp conftest.er2 >/dev/null; then
+       lt_cv_prog_compiler_rtti_exceptions=yes
+     fi
+   fi
+   $rm conftest*
+fi
+echo "$as_me:$LINENO: result: $lt_cv_prog_compiler_rtti_exceptions" >&5
+echo "${ECHO_T}$lt_cv_prog_compiler_rtti_exceptions" >&6
+if test x"$lt_cv_prog_compiler_rtti_exceptions" = xyes; then
+    lt_prog_compiler_no_builtin_flag_GCJ="$lt_prog_compiler_no_builtin_flag_GCJ -fno-rtti -fno-exceptions"
+else
+fi
+fi
+lt_prog_compiler_wl_GCJ=
+lt_prog_compiler_pic_GCJ=
+lt_prog_compiler_static_GCJ=
+echo "$as_me:$LINENO: checking for $compiler option to produce PIC" >&5
+echo $ECHO_N "checking for $compiler option to produce PIC... $ECHO_C" >&6
+    lt_prog_compiler_wl_GCJ='-Wl,'
+    lt_prog_compiler_static_GCJ='-static'
+    case $host_os in
+      aix*)
+      # All AIX code is PIC.
+      if test "$host_cpu" = ia64; then
+	# AIX 5 now supports IA64 processor
+	lt_prog_compiler_static_GCJ='-Bstatic'
+      fi
+    amigaos*)
+      # FIXME: we need at least 68020 code to build shared libraries, but
+      # adding the `-m68020' flag to GCC prevents building anything better,
+      # like `-m68040'.
+      lt_prog_compiler_pic_GCJ='-m68020 -resident32 -malways-restore-a4'
+    beos* | cygwin* | irix5* | irix6* | nonstopux* | osf3* | osf4* | osf5*)
+      # PIC is the default for these OSes.
+    mingw* | pw32* | os2*)
+      # This hack is so that the source file can tell whether it is being
+      # built for inclusion in a dll (and should export symbols for example).
+      lt_prog_compiler_pic_GCJ='-DDLL_EXPORT'
+    darwin* | rhapsody*)
+      # PIC is the default on this platform
+      # Common symbols not allowed in MH_DYLIB files
+      lt_prog_compiler_pic_GCJ='-fno-common'
+    interix3*)
+      # Interix 3.x gcc -fpic/-fPIC options generate broken code.
+      # Instead, we relocate shared libraries at runtime.
+    msdosdjgpp*)
+      # Just because we use GCC doesn't mean we suddenly get shared libraries
+      # on systems that don't support them.
+      lt_prog_compiler_can_build_shared_GCJ=no
+      enable_shared=no
+    sysv4*MP*)
+	lt_prog_compiler_pic_GCJ=-Kconform_pic
+      fi
+    hpux*)
+      # PIC is the default for IA64 HP-UX and 64-bit HP-UX, but
+      # not for PA HP-UX.
+      case $host_cpu in
+      hppa*64*|ia64*)
+	# +Z the default
+	lt_prog_compiler_pic_GCJ='-fPIC'
+      esac
+    esac
+  else
+    # PORTME Check for flag to pass linker flags through the system compiler.
+    case $host_os in
+    aix*)
+      else
+	lt_prog_compiler_static_GCJ='-bnso -bI:/lib/syscalls.exp'
+      fi
+      darwin*)
+       case $cc_basename in
+         xlc*)
+         lt_prog_compiler_pic_GCJ='-qnocommon'
+       esac
+    hpux9* | hpux10* | hpux11*)
+      case $host_cpu in
+      hppa*64*|ia64*)
+	# +Z the default
+	lt_prog_compiler_pic_GCJ='+Z'
+      esac
+      # Is there a better lt_prog_compiler_static that works with the bundled CC?
+      lt_prog_compiler_static_GCJ='${wl}-a ${wl}archive'
+      # PIC (with -KPIC) is the default.
+      lt_prog_compiler_static_GCJ='-non_shared'
+    newsos6)
+      lt_prog_compiler_pic_GCJ='-KPIC'
+    linux*)
+      icc* | ecc*)
+      pgcc* | pgf77* | pgf90* | pgf95*)
+        # Portland Group compilers (*not* the Pentium gcc compiler,
+	# which looks to be a dead project)
+	lt_prog_compiler_pic_GCJ='-fpic'
+      ccc*)
+        # All Alpha code is PIC.
+      esac
+    osf3* | osf4* | osf5*)
+      # All OSF/1 code is PIC.
+    solaris*)
+      f77* | f90* | f95*)
+	lt_prog_compiler_wl_GCJ='-Qoption ld ';;
+	lt_prog_compiler_wl_GCJ='-Wl,';;
+      esac
+    sunos4*)
+      lt_prog_compiler_pic_GCJ='-PIC'
+    sysv4 | sysv4.2uw2* | sysv4.3*)
+    sysv4*MP*)
+	lt_prog_compiler_pic_GCJ='-Kconform_pic'
+      fi
+    sysv5* | unixware* | sco3.2v5* | sco5v6* | OpenUNIX*)
+    unicos*)
+    uts4*)
+      lt_prog_compiler_pic_GCJ='-pic'
+    esac
+  fi
+echo "$as_me:$LINENO: result: $lt_prog_compiler_pic_GCJ" >&5
+echo "${ECHO_T}$lt_prog_compiler_pic_GCJ" >&6
-# pe_as32 (ptr)
-#      void *ptr;
-#   unsigned char *b = ptr;
+# Check to make sure the PIC flag actually works.
-# int
-# main (argc, argv)
-#     int argc;
-#     char *argv[];
-#     int dll;
-#     unsigned long pe_header_offset, opthdr_ofs, num_entries, i;
-#     unsigned long export_rva, export_size, nsections, secptr, expptr;
-#     unsigned long name_rvas, nexp;
-#     unsigned char *expdata, *erva;
-#     char *filename, *dll_name;
+if test -n "$lt_prog_compiler_pic_GCJ"; then
+echo "$as_me:$LINENO: checking if $compiler PIC flag $lt_prog_compiler_pic_GCJ works" >&5
+echo $ECHO_N "checking if $compiler PIC flag $lt_prog_compiler_pic_GCJ works... $ECHO_C" >&6
+if test "${lt_prog_compiler_pic_works_GCJ+set}" = set; then
+else
+  lt_prog_compiler_pic_works_GCJ=no
+   lt_compiler_flag="$lt_prog_compiler_pic_GCJ"
+   (eval echo "\"\$as_me:15875: $lt_compile\"" >&5)
+   ac_status=$?
+   echo "$as_me:15879: \$? = $ac_status" >&5
+       lt_prog_compiler_pic_works_GCJ=yes
+     fi
+   fi
+   $rm conftest*
+fi
+echo "$as_me:$LINENO: result: $lt_prog_compiler_pic_works_GCJ" >&5
+echo "${ECHO_T}$lt_prog_compiler_pic_works_GCJ" >&6
+if test x"$lt_prog_compiler_pic_works_GCJ" = xyes; then
+    case $lt_prog_compiler_pic_GCJ in
+     *) lt_prog_compiler_pic_GCJ=" $lt_prog_compiler_pic_GCJ" ;;
+     esac
+else
+fi
+fi
+case $host_os in
+  # For platforms which do not support PIC, -DPIC is meaningless:
+  *djgpp*)
+    lt_prog_compiler_pic_GCJ="$lt_prog_compiler_pic_GCJ"
+esac
-#     filename = argv[1];
+# Check to make sure the static flag actually works.
-#     dll = open(filename, O_RDONLY|O_BINARY);
-#     if (dll < 1)
-# 	return 1;
+wl=$lt_prog_compiler_wl_GCJ eval lt_tmp_static_flag=\"$lt_prog_compiler_static_GCJ\"
+echo "$as_me:$LINENO: checking if $compiler static flag $lt_tmp_static_flag works" >&5
+echo $ECHO_N "checking if $compiler static flag $lt_tmp_static_flag works... $ECHO_C" >&6
+if test "${lt_prog_compiler_static_works_GCJ+set}" = set; then
+else
+  lt_prog_compiler_static_works_GCJ=no
+   save_LDFLAGS="$LDFLAGS"
+   LDFLAGS="$LDFLAGS $lt_tmp_static_flag"
+   printf "$lt_simple_link_test_code" > conftest.$ac_ext
+   if (eval $ac_link 2>conftest.err) && test -s conftest$ac_exeext; then
+     # The linker can only warn and ignore the option if not recognized
+     if test -s conftest.err; then
+       # Append any errors to the config.log.
+       $echo "X$_lt_linker_boilerplate" | $Xsed -e '/^$/d' > conftest.exp
+       if diff conftest.exp conftest.er2 >/dev/null; then
+         lt_prog_compiler_static_works_GCJ=yes
+       fi
+     else
+     fi
+   fi
+   $rm conftest*
+   LDFLAGS="$save_LDFLAGS"
+fi
+echo "$as_me:$LINENO: result: $lt_prog_compiler_static_works_GCJ" >&5
+echo "${ECHO_T}$lt_prog_compiler_static_works_GCJ" >&6
+if test x"$lt_prog_compiler_static_works_GCJ" = xyes; then
+else
+fi
+echo "$as_me:$LINENO: checking if $compiler supports -c -o file.$ac_objext" >&5
+echo $ECHO_N "checking if $compiler supports -c -o file.$ac_objext... $ECHO_C" >&6
+if test "${lt_cv_prog_compiler_c_o_GCJ+set}" = set; then
+else
+  lt_cv_prog_compiler_c_o_GCJ=no
+   $rm -r conftest 2>/dev/null
+   mkdir conftest
+   cd conftest
+   mkdir out
+   lt_compiler_flag="-o out/conftest2.$ac_objext"
+   (eval echo "\"\$as_me:15979: $lt_compile\"" >&5)
+   (eval "$lt_compile" 2>out/conftest.err)
+   ac_status=$?
+   cat out/conftest.err >&5
+   echo "$as_me:15983: \$? = $ac_status" >&5
+   if (exit $ac_status) && test -s out/conftest2.$ac_objext
+   then
+     $echo "X$_lt_compiler_boilerplate" | $Xsed -e '/^$/d' > out/conftest.exp
+     $SED '/^$/d; /^ *+/d' out/conftest.err >out/conftest.er2
+     if test ! -s out/conftest.er2 || diff out/conftest.exp out/conftest.er2 >/dev/null; then
+       lt_cv_prog_compiler_c_o_GCJ=yes
+     fi
+   fi
+   chmod u+w . 2>&5
+   $rm conftest*
+   # SGI C++ compiler will create directory out/ii_files/ for
+   # template instantiation
+   test -d out/ii_files && $rm out/ii_files/* && rmdir out/ii_files
+   $rm out/* && rmdir out
+   cd ..
+   rmdir conftest
+   $rm conftest*
+fi
+echo "$as_me:$LINENO: result: $lt_cv_prog_compiler_c_o_GCJ" >&5
+echo "${ECHO_T}$lt_cv_prog_compiler_c_o_GCJ" >&6
+hard_links="nottested"
+if test "$lt_cv_prog_compiler_c_o_GCJ" = no && test "$need_locks" != no; then
+  # do not overwrite the value of need_locks provided by the user
+  echo "$as_me:$LINENO: checking if we can lock with hard links" >&5
+echo $ECHO_N "checking if we can lock with hard links... $ECHO_C" >&6
+  hard_links=yes
+  $rm conftest*
+  ln conftest.a conftest.b 2>/dev/null && hard_links=no
+  touch conftest.a
+  ln conftest.a conftest.b 2>&5 || hard_links=no
+  echo "$as_me:$LINENO: result: $hard_links" >&5
+echo "${ECHO_T}$hard_links" >&6
+  if test "$hard_links" = no; then
+    { echo "$as_me:$LINENO: WARNING: \`$CC' does not support \`-c -o', so \`make -j' may be unsafe" >&5
+echo "$as_me: WARNING: \`$CC' does not support \`-c -o', so \`make -j' may be unsafe" >&2;}
+    need_locks=warn
+  fi
+else
+  need_locks=no
+fi
+echo "$as_me:$LINENO: checking whether the $compiler linker ($LD) supports shared libraries" >&5
+echo $ECHO_N "checking whether the $compiler linker ($LD) supports shared libraries... $ECHO_C" >&6
+  runpath_var=
+  allow_undefined_flag_GCJ=
+  enable_shared_with_static_runtimes_GCJ=no
+  archive_cmds_GCJ=
+  archive_expsym_cmds_GCJ=
+  old_archive_From_new_cmds_GCJ=
+  old_archive_from_expsyms_cmds_GCJ=
+  export_dynamic_flag_spec_GCJ=
+  whole_archive_flag_spec_GCJ=
+  thread_safe_flag_spec_GCJ=
+  hardcode_libdir_flag_spec_GCJ=
+  hardcode_libdir_flag_spec_ld_GCJ=
+  hardcode_libdir_separator_GCJ=
+  hardcode_direct_GCJ=no
+  hardcode_minus_L_GCJ=no
+  hardcode_shlibpath_var_GCJ=unsupported
+  link_all_deplibs_GCJ=unknown
+  hardcode_automatic_GCJ=no
+  module_cmds_GCJ=
+  module_expsym_cmds_GCJ=
+  always_export_symbols_GCJ=no
+  export_symbols_cmds_GCJ='$NM $libobjs $convenience | $global_symbol_pipe | $SED '\''s/.* //'\'' | sort | uniq > $export_symbols'
+  # include_expsyms should be a list of space-separated symbols to be *always*
+  # included in the symbol list
+  include_expsyms_GCJ=
+  # exclude_expsyms can be an extended regexp of symbols to exclude
+  # it will be wrapped by ` (' and `)$', so one must not match beginning or
+  # end of line.  Example: `a|bc|.*d.*' will exclude the symbols `a' and `bc',
+  # as well as any symbol that contains `d'.
+  exclude_expsyms_GCJ="_GLOBAL_OFFSET_TABLE_"
+  # Although _GLOBAL_OFFSET_TABLE_ is a valid symbol C name, most a.out
+  # platforms (ab)use it in PIC code, but their linkers get confused if
+  # the symbol is explicitly referenced.  Since portable code cannot
+  # rely on this symbol name, it's probably fine to never include it in
+  # preloaded symbol tables.
+  extract_expsyms_cmds=
+  # Just being paranoid about ensuring that cc_basename is set.
+  for cc_temp in $compiler""; do
+  case $cc_temp in
+    *) break;;
+  esac
+done
+  case $host_os in
+  cygwin* | mingw* | pw32*)
+    # FIXME: the MSVC++ port hasn't been tested in a loooong time
+    # When not using gcc, we currently assume that we are using
+    # Microsoft Visual C++.
+    if test "$GCC" != yes; then
+      with_gnu_ld=no
+    fi
+  interix*)
+    # we just hope/assume this is gcc and not c89 (= MSVC++)
+    with_gnu_ld=yes
+  openbsd*)
+    with_gnu_ld=no
+  esac
+  ld_shlibs_GCJ=yes
+    # If archive_cmds runs LD, not CC, wlarc should be empty
+    wlarc='${wl}'
+    # Set some defaults for GNU ld with shared library support. These
+    # are reset later if shared libraries are not supported. Putting them
+    # here allows them to be overridden if necessary.
+    runpath_var=LD_RUN_PATH
+    hardcode_libdir_flag_spec_GCJ='${wl}--rpath ${wl}$libdir'
+    export_dynamic_flag_spec_GCJ='${wl}--export-dynamic'
+    # ancient GNU ld didn't support --whole-archive et. al.
+    if $LD --help 2>&1 | grep 'no-whole-archive' > /dev/null; then
+	whole_archive_flag_spec_GCJ="$wlarc"'--whole-archive$convenience '"$wlarc"'--no-whole-archive'
+      else
+    fi
+    supports_anon_versioning=no
+    case `$LD -v 2>/dev/null` in
+      *\ [01].* | *\ 2.[0-9].* | *\ 2.10.*) ;; # catch versions < 2.11
+      *\ 2.11.93.0.2\ *) supports_anon_versioning=yes ;; # RH7.3 ...
+      *\ 2.11.92.0.12\ *) supports_anon_versioning=yes ;; # Mandrake 8.2 ...
+      *\ 2.11.*) ;; # other 2.11 versions
+      *) supports_anon_versioning=yes ;;
+    esac
+    # See if GNU ld supports shared libraries.
+    case $host_os in
+    aix3* | aix4* | aix5*)
+      # On AIX/PPC, the GNU linker is very broken
+      if test "$host_cpu" != ia64; then
+	ld_shlibs_GCJ=no
+	cat <<EOF 1>&2
+*** Warning: the GNU linker, at least up to release 2.9.1, is reported
+*** to be unable to reliably create shared libraries on AIX.
+*** Therefore, libtool is disabling shared libraries support.  If you
+*** really care for shared libraries, you may want to modify your PATH
+*** so that a non-GNU linker is found, and then restart.
+EOF
+      fi
+    amigaos*)
+      archive_cmds_GCJ='$rm $output_objdir/a2ixlibrary.data~$echo "#define NAME $libname" > $output_objdir/a2ixlibrary.data~$echo "#define LIBRARY_ID 1" >> $output_objdir/a2ixlibrary.data~$echo "#define VERSION $major" >> $output_objdir/a2ixlibrary.data~$echo "#define REVISION $revision" >> $output_objdir/a2ixlibrary.data~$AR $AR_FLAGS $lib $libobjs~$RANLIB $lib~(cd $output_objdir && a2ixlibrary -32)'
+      hardcode_libdir_flag_spec_GCJ='-L$libdir'
+      hardcode_minus_L_GCJ=yes
+      # Samuel A. Falvo II <kc5tja at dolphin.openprojects.net> reports
+      # that the semantics of dynamic libraries on AmigaOS, at least up
+      # to version 4, is to share data among multiple programs linked
+      # with the same dynamic library.  Since this doesn't match the
+      # behavior of shared libraries on other platforms, we can't use
+      # them.
+      ld_shlibs_GCJ=no
+    beos*)
+      if $LD --help 2>&1 | grep ': supported targets:.* elf' > /dev/null; then
+	allow_undefined_flag_GCJ=unsupported
+	# Joseph Beckenbach <jrb3 at best.com> says some releases of gcc
+	# support --undefined.  This deserves some investigation.  FIXME
+	archive_cmds_GCJ='$CC -nostart $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
+      else
+	ld_shlibs_GCJ=no
+      fi
+      # _LT_AC_TAGVAR(hardcode_libdir_flag_spec, GCJ) is actually meaningless,
+      # as there is no search path for DLLs.
+      enable_shared_with_static_runtimes_GCJ=yes
+      export_symbols_cmds_GCJ='$NM $libobjs $convenience | $global_symbol_pipe | $SED -e '\''/^[BCDGRS] /s/.* \([^ ]*\)/\1 DATA/'\'' | $SED -e '\''/^[AITW] /s/.* //'\'' | sort | uniq > $export_symbols'
+      if $LD --help 2>&1 | grep 'auto-import' > /dev/null; then
+        archive_cmds_GCJ='$CC -shared $libobjs $deplibs $compiler_flags -o $output_objdir/$soname ${wl}--enable-auto-image-base -Xlinker --out-implib -Xlinker $lib'
+	# If the export-symbols file already is a .def file (1st line
+	# is EXPORTS), use it as is; otherwise, prepend...
+	archive_expsym_cmds_GCJ='if test "x`$SED 1q $export_symbols`" = xEXPORTS; then
+	  cp $export_symbols $output_objdir/$soname.def;
+	else
+	  echo EXPORTS > $output_objdir/$soname.def;
+	  cat $export_symbols >> $output_objdir/$soname.def;
+	fi~
+	$CC -shared $output_objdir/$soname.def $libobjs $deplibs $compiler_flags -o $output_objdir/$soname ${wl}--enable-auto-image-base -Xlinker --out-implib -Xlinker $lib'
+      else
+	ld_shlibs_GCJ=no
+      fi
+    interix3*)
+      hardcode_shlibpath_var_GCJ=no
+      hardcode_libdir_flag_spec_GCJ='${wl}-rpath,$libdir'
+      export_dynamic_flag_spec_GCJ='${wl}-E'
+      # Hack: On Interix 3.x, we cannot compile PIC because of a broken gcc.
+      # Instead, shared libraries are loaded at an image base (0x10000000 by
+      # default) and relocated if they conflict, which is a slow very memory
+      # consuming and fragmenting process.  To avoid this, we pick a random,
+      # 256 KiB-aligned image base between 0x50000000 and 0x6FFC0000 at link
+      # time.  Moving up from 0x10000000 also allows more sbrk(2) space.
+      archive_cmds_GCJ='$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-h,$soname ${wl}--image-base,`expr ${RANDOM-$$} % 4096 / 2 \* 262144 + 1342177280` -o $lib'
+      archive_expsym_cmds_GCJ='sed "s,^,_," $export_symbols >$output_objdir/$soname.expsym~$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-h,$soname ${wl}--retain-symbols-file,$output_objdir/$soname.expsym ${wl}--image-base,`expr ${RANDOM-$$} % 4096 / 2 \* 262144 + 1342177280` -o $lib'
+    linux*)
+	tmp_addflag=
+	case $cc_basename,$host_cpu in
+	pgcc*)				# Portland Group C compiler
+	  whole_archive_flag_spec_GCJ='${wl}--whole-archive`for conv in $convenience\"\"; do test  -n \"$conv\" && new_convenience=\"$new_convenience,$conv\"; done; $echo \"$new_convenience\"` ${wl}--no-whole-archive'
+	  tmp_addflag=' $pic_flag'
+	pgf77* | pgf90* | pgf95*)	# Portland Group f77 and f90 compilers
+	  tmp_addflag=' $pic_flag -Mnomain' ;;
+	ecc*,ia64* | icc*,ia64*)		# Intel C compiler on ia64
+	  tmp_addflag=' -i_dynamic' ;;
+	efc*,ia64* | ifort*,ia64*)	# Intel Fortran compiler on ia64
+	  tmp_addflag=' -i_dynamic -nofor_main' ;;
+	ifc* | ifort*)			# Intel Fortran compiler
+	  tmp_addflag=' -nofor_main' ;;
+	esac
+	archive_cmds_GCJ='$CC -shared'"$tmp_addflag"' $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
+	if test $supports_anon_versioning = yes; then
+	  archive_expsym_cmds_GCJ='$echo "{ global:" > $output_objdir/$libname.ver~
+  cat $export_symbols | sed -e "s/\(.*\)/\1;/" >> $output_objdir/$libname.ver~
+  $echo "local: *; };" >> $output_objdir/$libname.ver~
+	  $CC -shared'"$tmp_addflag"' $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-version-script ${wl}$output_objdir/$libname.ver -o $lib'
+	fi
+      else
+	ld_shlibs_GCJ=no
+      fi
+    netbsd*)
+      if echo __ELF__ | $CC -E - | grep __ELF__ >/dev/null; then
+	archive_cmds_GCJ='$LD -Bshareable $libobjs $deplibs $linker_flags -o $lib'
+	wlarc=
+      else
+	archive_cmds_GCJ='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
+	archive_expsym_cmds_GCJ='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
+      fi
+    solaris*)
+      if $LD -v 2>&1 | grep 'BFD 2\.8' > /dev/null; then
+	ld_shlibs_GCJ=no
+	cat <<EOF 1>&2
+*** Warning: The releases 2.8.* of the GNU linker cannot reliably
+*** create shared libraries on Solaris systems.  Therefore, libtool
+*** is disabling shared libraries support.  We urge you to upgrade GNU
+*** binutils to release 2.9.1 or newer.  Another option is to modify
+*** your PATH or compiler configuration so that the native linker is
+*** used, and then restart.
+EOF
+      elif $LD --help 2>&1 | grep ': supported targets:.* elf' > /dev/null; then
+      else
+	ld_shlibs_GCJ=no
+      fi
+    sysv5* | sco3.2v5* | sco5v6* | unixware* | OpenUNIX*)
+      case `$LD -v 2>&1` in
+        *\ [01].* | *\ 2.[0-9].* | *\ 2.1[0-5].*)
+	ld_shlibs_GCJ=no
+	cat <<_LT_EOF 1>&2
+*** Warning: Releases of the GNU linker prior to 2.16.91.0.3 can not
+*** reliably create shared libraries on SCO systems.  Therefore, libtool
+*** binutils to release 2.16.91.0.3 or newer.  Another option is to modify
+_LT_EOF
+	    hardcode_libdir_flag_spec_GCJ='`test -z "$SCOABSPATH" && echo ${wl}-rpath,$libdir`'
+	    archive_cmds_GCJ='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib'
+	    archive_expsym_cmds_GCJ='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname,\${SCOABSPATH:+${install_libdir}/}$soname,-retain-symbols-file,$export_symbols -o $lib'
+	  else
+	    ld_shlibs_GCJ=no
+	  fi
+      esac
+    sunos4*)
+      archive_cmds_GCJ='$LD -assert pure-text -Bshareable -o $lib $libobjs $deplibs $linker_flags'
+      wlarc=
+      hardcode_direct_GCJ=yes
+      else
+	ld_shlibs_GCJ=no
+      fi
+    esac
+    if test "$ld_shlibs_GCJ" = no; then
+      runpath_var=
+    fi
+  else
+    # PORTME fill in a description of your system's linker (not GNU ld)
+    case $host_os in
+    aix3*)
+      always_export_symbols_GCJ=yes
+      archive_expsym_cmds_GCJ='$LD -o $output_objdir/$soname $libobjs $deplibs $linker_flags -bE:$export_symbols -T512 -H512 -bM:SRE~$AR $AR_FLAGS $lib $output_objdir/$soname'
+      # Note: this linker hardcodes the directories in LIBPATH if there
+      # are no directories specified by -L.
+      if test "$GCC" = yes && test -z "$lt_prog_compiler_static"; then
+	# Neither direct hardcoding nor static linking is supported with a
+	# broken collect2.
+	hardcode_direct_GCJ=unsupported
+      fi
+    aix4* | aix5*)
+	# On IA64, the linker does run time linking by default, so we don't
+	# have to do anything special.
+	aix_use_runtimelinking=no
+	exp_sym_flag='-Bexport'
+	no_entry_flag=""
+      else
+	# If we're using GNU nm, then we don't want the "-C" option.
+	# -C means demangle to AIX nm, but means don't demangle with GNU nm
+	if $NM -V 2>&1 | grep 'GNU' > /dev/null; then
+	  export_symbols_cmds_GCJ='$NM -Bpg $libobjs $convenience | awk '\''{ if (((\$2 == "T") || (\$2 == "D") || (\$2 == "B")) && (substr(\$3,1,1) != ".")) { print \$3 } }'\'' | sort -u > $export_symbols'
+	else
+	  export_symbols_cmds_GCJ='$NM -BCpg $libobjs $convenience | awk '\''{ if (((\$2 == "T") || (\$2 == "D") || (\$2 == "B")) && (substr(\$3,1,1) != ".")) { print \$3 } }'\'' | sort -u > $export_symbols'
+	fi
+	# Test if we are trying to use run time linking or normal
+	# AIX style linking. If -brtl is somewhere in LDFLAGS, we
+	# need to do runtime linking.
+	case $host_os in aix4.[23]|aix4.[23].*|aix5*)
+	  for ld_flag in $LDFLAGS; do
+  	  if (test $ld_flag = "-brtl" || test $ld_flag = "-Wl,-brtl"); then
+  	    aix_use_runtimelinking=yes
+  	    break
+  	  fi
+	  done
+	esac
+	exp_sym_flag='-bexport'
+	no_entry_flag='-bnoentry'
+      fi
+      # When large executables or shared objects are built, AIX ld can
+      # have problems creating the table of contents.  If linking a library
+      # or program results in "error TOC overflow" add -mminimal-toc to
+      # CXXFLAGS/CFLAGS for g++/gcc.  In the cases where that is not
+      # enough to fix the problem, add -Wl,-bbigtoc to LDFLAGS.
+      archive_cmds_GCJ=''
+      hardcode_libdir_separator_GCJ=':'
+      link_all_deplibs_GCJ=yes
+	case $host_os in aix4.[012]|aix4.[012].*)
+	# We only want to do this on AIX 4.2 and lower, the check
+	# below for broken collect2 doesn't work under 4.3+
+	  collect2name=`${CC} -print-prog-name=collect2`
+	  if test -f "$collect2name" && \
+  	   strings "$collect2name" | grep resolve_lib_name >/dev/null
+	  then
+  	  # We have reworked collect2
+	  else
+  	  # We have old collect2
+  	  # It fails to find uninstalled libraries when the uninstalled
+  	  # path is not listed in the libpath.  Setting hardcode_minus_L
+  	  # to unsupported forces relinking
+	  fi
+	esac
+	shared_flag='-shared'
+	if test "$aix_use_runtimelinking" = yes; then
+	  shared_flag="$shared_flag "'${wl}-G'
+	fi
+      else
+	# not using gcc
+  	# VisualAge C++, Version 5.5 for AIX 5L for IA-64, Beta 3 Release
+  	# chokes on -Wl,-G. The following line is correct:
+	  shared_flag='-G'
+	else
+	    shared_flag='${wl}-G'
+	  else
+	    shared_flag='${wl}-bM:SRE'
+	  fi
+	fi
+      fi
+      # It seems that -bexpall does not export symbols beginning with
+      # underscore (_), so it is better to generate a list of symbols to export.
+	# Warning - without using the other runtime loading flags (-brtl),
+	# -berok will link without error, but may produce a broken library.
+	allow_undefined_flag_GCJ='-berok'
+       # Determine the default libpath from the value encoded in an empty executable.
+       cat >conftest.$ac_ext <<_ACEOF
+/* confdefs.h.  */
+_ACEOF
+cat confdefs.h >>conftest.$ac_ext
+cat >>conftest.$ac_ext <<_ACEOF
+/* end confdefs.h.  */
+int
+main ()
+  return 0;
+_ACEOF
+rm -f conftest.$ac_objext conftest$ac_exeext
+if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
+  (eval $ac_link) 2>conftest.er1
+  ac_status=$?
+  grep -v '^ *+' conftest.er1 >conftest.err
+  rm -f conftest.er1
+  cat conftest.err >&5
+  echo "$as_me:$LINENO: \$? = $ac_status" >&5
+  (exit $ac_status); } &&
+	 { ac_try='test -z "$ac_cxx_werror_flag"
+			 || test ! -s conftest.err'
+  { (eval echo "$as_me:$LINENO: \"$ac_try\"") >&5
+  (eval $ac_try) 2>&5
+  ac_status=$?
+  (exit $ac_status); }; } &&
+	 { ac_try='test -s conftest$ac_exeext'
+  ac_status=$?
+  (exit $ac_status); }; }; then
+aix_libpath=`dump -H conftest$ac_exeext 2>/dev/null | $SED -n -e '/Import File Strings/,/^$/ { /^0/ { s/^0  *\(.*\)$/\1/; p; }
+# Check for a 64-bit object if we didn't find anything.
+if test -z "$aix_libpath"; then aix_libpath=`dump -HX64 conftest$ac_exeext 2>/dev/null | $SED -n -e '/Import File Strings/,/^$/ { /^0/ { s/^0  *\(.*\)$/\1/; p; }
+}'`; fi
+else
+  echo "$as_me: failed program was:" >&5
+sed 's/^/| /' conftest.$ac_ext >&5
+fi
+rm -f conftest.err conftest.$ac_objext \
+      conftest$ac_exeext conftest.$ac_ext
+if test -z "$aix_libpath"; then aix_libpath="/usr/lib:/lib"; fi
+       hardcode_libdir_flag_spec_GCJ='${wl}-blibpath:$libdir:'"$aix_libpath"
+	archive_expsym_cmds_GCJ="\$CC"' -o $output_objdir/$soname $libobjs $deplibs '"\${wl}$no_entry_flag"' $compiler_flags `if test "x${allow_undefined_flag}" != "x"; then echo "${wl}${allow_undefined_flag}"; else :; fi` '"\${wl}$exp_sym_flag:\$export_symbols $shared_flag"
+       else
+	  hardcode_libdir_flag_spec_GCJ='${wl}-R $libdir:/usr/lib:/lib'
+	  allow_undefined_flag_GCJ="-z nodefs"
+	  archive_expsym_cmds_GCJ="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs '"\${wl}$no_entry_flag"' $compiler_flags ${wl}${allow_undefined_flag} '"\${wl}$exp_sym_flag:\$export_symbols"
+	else
+/* confdefs.h.  */
+_ACEOF
+int
+main ()
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+}'`; fi
+else
+fi
+	  # Warning - without using the other run time loading flags,
+	  no_undefined_flag_GCJ=' ${wl}-bernotok'
+	  allow_undefined_flag_GCJ=' ${wl}-berok'
+	  # Exported symbols can be pulled into shared objects from archives
+	  whole_archive_flag_spec_GCJ='$convenience'
+	  archive_cmds_need_lc_GCJ=yes
+	  # This is similar to how AIX traditionally builds its shared libraries.
+	  archive_expsym_cmds_GCJ="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs ${wl}-bnoentry $compiler_flags ${wl}-bE:$export_symbols${allow_undefined_flag}~$AR $AR_FLAGS $output_objdir/$libname$release.a $output_objdir/$soname'
+	fi
+      fi
+    amigaos*)
+      # see comment about different semantics on the GNU ld section
+      ld_shlibs_GCJ=no
+    bsdi[45]*)
+      export_dynamic_flag_spec_GCJ=-rdynamic
+      # hardcode_libdir_flag_spec is actually meaningless, as there is
+      # no search path for DLLs.
+      hardcode_libdir_flag_spec_GCJ=' '
+      # Tell ltmain to make .lib files, not .a files.
+      libext=lib
+      # Tell ltmain to make .dll files, not .so files.
+      # FIXME: Setting linknames here is a bad hack.
+      archive_cmds_GCJ='$CC -o $lib $libobjs $compiler_flags `echo "$deplibs" | $SED -e '\''s/ -lc$//'\''` -link -dll~linknames='
+      # The linker will automatically build a .lib file if we build a DLL.
+      old_archive_From_new_cmds_GCJ='true'
+      # FIXME: Should let the user specify the lib program.
+      old_archive_cmds_GCJ='lib /OUT:$oldlib$oldobjs$old_deplibs'
+      fix_srcfile_path_GCJ='`cygpath -w "$srcfile"`'
+      case $host_os in
+        rhapsody* | darwin1.[012])
+         allow_undefined_flag_GCJ='${wl}-undefined ${wl}suppress'
+       *) # Darwin 1.3 on
+         if test -z ${MACOSX_DEPLOYMENT_TARGET} ; then
+           allow_undefined_flag_GCJ='${wl}-flat_namespace ${wl}-undefined ${wl}suppress'
+         else
+           case ${MACOSX_DEPLOYMENT_TARGET} in
+             10.[012])
+             10.*)
+               allow_undefined_flag_GCJ='${wl}-undefined ${wl}dynamic_lookup'
+           esac
+         fi
+      esac
+      archive_cmds_need_lc_GCJ=no
+      hardcode_automatic_GCJ=yes
+      whole_archive_flag_spec_GCJ=''
+    if test "$GCC" = yes ; then
+    	output_verbose_link_cmd='echo'
+        archive_cmds_GCJ='$CC -dynamiclib $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring'
+      module_cmds_GCJ='$CC $allow_undefined_flag -o $lib -bundle $libobjs $deplibs$compiler_flags'
+      # Don't fix this by using the ld -exported_symbols_list flag, it doesn't exist in older darwin lds
+      archive_expsym_cmds_GCJ='sed -e "s,#.*,," -e "s,^[    ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -dynamiclib $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
+      module_expsym_cmds_GCJ='sed -e "s,#.*,," -e "s,^[    ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC $allow_undefined_flag  -o $lib -bundle $libobjs $deplibs$compiler_flags~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
+    else
+        xlc*)
+         archive_cmds_GCJ='$CC -qmkshrobj $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-install_name ${wl}`echo $rpath/$soname` $verstring'
+         archive_expsym_cmds_GCJ='sed -e "s,#.*,," -e "s,^[    ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -qmkshrobj $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-install_name ${wl}$rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
+         ld_shlibs_GCJ=no
+      esac
+    fi
+    dgux*)
+      archive_cmds_GCJ='$LD -G -h $soname -o $lib $libobjs $deplibs $linker_flags'
+    freebsd1*)
+      ld_shlibs_GCJ=no
+    # FreeBSD 2.2.[012] allows us to include c++rt0.o to get C++ constructor
+    # support.  Future versions do this automatically, but an explicit c++rt0.o
+    # does not break anything, and helps significantly (at the cost of a little
+    # extra space).
+    freebsd2.2*)
+      archive_cmds_GCJ='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags /usr/lib/c++rt0.o'
+      hardcode_libdir_flag_spec_GCJ='-R$libdir'
+    # Unfortunately, older versions of FreeBSD 2 do not have this feature.
+    freebsd2*)
+      archive_cmds_GCJ='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags'
+    # FreeBSD 3 and greater uses gcc -shared to do shared libraries.
+    freebsd* | kfreebsd*-gnu | dragonfly*)
+      archive_cmds_GCJ='$CC -shared -o $lib $libobjs $deplibs $compiler_flags'
+    hpux9*)
+	archive_cmds_GCJ='$rm $output_objdir/$soname~$CC -shared -fPIC ${wl}+b ${wl}$install_libdir -o $output_objdir/$soname $libobjs $deplibs $compiler_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
+      else
+	archive_cmds_GCJ='$rm $output_objdir/$soname~$LD -b +b $install_libdir -o $output_objdir/$soname $libobjs $deplibs $linker_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
+      fi
+      hardcode_libdir_flag_spec_GCJ='${wl}+b ${wl}$libdir'
+      hardcode_libdir_separator_GCJ=:
+      # hardcode_minus_L: Not really in the search PATH,
+      # but as the default location of the library.
+    hpux10*)
+      if test "$GCC" = yes -a "$with_gnu_ld" = no; then
+	archive_cmds_GCJ='$CC -shared -fPIC ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $libobjs $deplibs $compiler_flags'
+      else
+	archive_cmds_GCJ='$LD -b +h $soname +b $install_libdir -o $lib $libobjs $deplibs $linker_flags'
+      fi
+      if test "$with_gnu_ld" = no; then
+      fi
+    hpux11*)
+	case $host_cpu in
+	hppa*64*)
+	  archive_cmds_GCJ='$CC -shared ${wl}+h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	ia64*)
+	  archive_cmds_GCJ='$CC -shared ${wl}+h ${wl}$soname ${wl}+nodefaultrpath -o $lib $libobjs $deplibs $compiler_flags'
+	esac
+      else
+	case $host_cpu in
+	hppa*64*)
+	  archive_cmds_GCJ='$CC -b ${wl}+h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	ia64*)
+	  archive_cmds_GCJ='$CC -b ${wl}+h ${wl}$soname ${wl}+nodefaultrpath -o $lib $libobjs $deplibs $compiler_flags'
+	  archive_cmds_GCJ='$CC -b ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $libobjs $deplibs $compiler_flags'
+	esac
+      fi
+	case $host_cpu in
+	hppa*64*|ia64*)
+	  hardcode_libdir_flag_spec_ld_GCJ='+b $libdir'
+	esac
+      fi
+    irix5* | irix6* | nonstopux*)
+	archive_cmds_GCJ='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
+      else
+	archive_cmds_GCJ='$LD -shared $libobjs $deplibs $linker_flags -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
+	hardcode_libdir_flag_spec_ld_GCJ='-rpath $libdir'
+      fi
+      hardcode_libdir_flag_spec_GCJ='${wl}-rpath ${wl}$libdir'
+    netbsd*)
+	archive_cmds_GCJ='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags'  # a.out
+      else
+	archive_cmds_GCJ='$LD -shared -o $lib $libobjs $deplibs $linker_flags'      # ELF
+      fi
+    newsos6)
+    openbsd*)
+      if test -z "`echo __ELF__ | $CC -E - | grep __ELF__`" || test "$host_os-$host_cpu" = "openbsd2.8-powerpc"; then
+	archive_cmds_GCJ='$CC -shared $pic_flag -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds_GCJ='$CC -shared $pic_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-retain-symbols-file,$export_symbols'
+      else
+       case $host_os in
+	 openbsd[01].* | openbsd2.[0-7] | openbsd2.[0-7].*)
+       esac
+      fi
+    os2*)
+      archive_cmds_GCJ='$echo "LIBRARY $libname INITINSTANCE" > $output_objdir/$libname.def~$echo "DESCRIPTION \"$libname\"" >> $output_objdir/$libname.def~$echo DATA >> $output_objdir/$libname.def~$echo " SINGLE NONSHARED" >> $output_objdir/$libname.def~$echo EXPORTS >> $output_objdir/$libname.def~emxexp $libobjs >> $output_objdir/$libname.def~$CC -Zdll -Zcrtdll -o $lib $libobjs $deplibs $compiler_flags $output_objdir/$libname.def'
+      old_archive_From_new_cmds_GCJ='emximp -o $output_objdir/$libname.a $output_objdir/$libname.def'
+    osf3*)
+	allow_undefined_flag_GCJ=' ${wl}-expect_unresolved ${wl}\*'
+	archive_cmds_GCJ='$CC -shared${allow_undefined_flag} $libobjs $deplibs $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
+      else
+	allow_undefined_flag_GCJ=' -expect_unresolved \*'
+	archive_cmds_GCJ='$LD -shared${allow_undefined_flag} $libobjs $deplibs $linker_flags -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
+      fi
+    osf4* | osf5*)	# as osf3* with the addition of -msym flag
+	archive_cmds_GCJ='$CC -shared${allow_undefined_flag} $libobjs $deplibs $compiler_flags ${wl}-msym ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
+      else
+	archive_cmds_GCJ='$LD -shared${allow_undefined_flag} $libobjs $deplibs $linker_flags -msym -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
+	archive_expsym_cmds_GCJ='for i in `cat $export_symbols`; do printf "%s %s\\n" -exported_symbol "\$i" >> $lib.exp; done; echo "-hidden">> $lib.exp~
+	$LD -shared${allow_undefined_flag} -input $lib.exp $linker_flags $libobjs $deplibs -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib~$rm $lib.exp'
+	# Both c and cxx compiler support -rpath directly
+	hardcode_libdir_flag_spec_GCJ='-rpath $libdir'
+      fi
+    solaris*)
+      no_undefined_flag_GCJ=' -z text'
+	wlarc='${wl}'
+	archive_cmds_GCJ='$CC -shared ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds_GCJ='$echo "{ global:" > $lib.exp~cat $export_symbols | $SED -e "s/\(.*\)/\1;/" >> $lib.exp~$echo "local: *; };" >> $lib.exp~
+	  $CC -shared ${wl}-M ${wl}$lib.exp ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags~$rm $lib.exp'
+      else
+	wlarc=''
+	archive_cmds_GCJ='$LD -G${allow_undefined_flag} -h $soname -o $lib $libobjs $deplibs $linker_flags'
+  	$LD -G${allow_undefined_flag} -M $lib.exp -h $soname -o $lib $libobjs $deplibs $linker_flags~$rm $lib.exp'
+      fi
+      case $host_os in
+      solaris2.[0-5] | solaris2.[0-5].*) ;;
+ 	# The compiler driver will combine linker options so we
+ 	# cannot just pass the convience library names through
+ 	# without $wl, iff we do not link with $LD.
+ 	# Luckily, gcc supports the same syntax we need for Sun Studio.
+ 	# Supported since Solaris 2.6 (maybe 2.5.1?)
+ 	case $wlarc in
+ 	  whole_archive_flag_spec_GCJ='-z allextract$convenience -z defaultextract' ;;
+ 	  whole_archive_flag_spec_GCJ='${wl}-z ${wl}allextract`for conv in $convenience\"\"; do test -n \"$conv\" && new_convenience=\"$new_convenience,$conv\"; done; $echo \"$new_convenience\"` ${wl}-z ${wl}defaultextract' ;;
+ 	esac ;;
+      esac
+    sunos4*)
+      if test "x$host_vendor" = xsequent; then
+	# Use $CC to link under sequent, because it throws in some extra .o
+	# files that make .init and .fini sections work.
+	archive_cmds_GCJ='$CC -G ${wl}-h $soname -o $lib $libobjs $deplibs $compiler_flags'
+      else
+	archive_cmds_GCJ='$LD -assert pure-text -Bstatic -o $lib $libobjs $deplibs $linker_flags'
+      fi
+    sysv4)
+	sni)
+	  hardcode_direct_GCJ=yes # is this really true???
+	siemens)
+	  ## LD is ld it makes a PLAMLIB
+	  ## CC just makes a GrossModule.
+	  archive_cmds_GCJ='$LD -G -o $lib $libobjs $deplibs $linker_flags'
+	  reload_cmds_GCJ='$CC -r -o $output$reload_objs'
+	motorola)
+	  hardcode_direct_GCJ=no #Motorola manual says yes, but my tests say they lie
+      esac
+      runpath_var='LD_RUN_PATH'
+    sysv4.3*)
+      export_dynamic_flag_spec_GCJ='-Bexport'
+    sysv4*MP*)
+      if test -d /usr/nec; then
+	hardcode_runpath_var=yes
+	ld_shlibs_GCJ=yes
+      fi
+    sysv4*uw2* | sysv5OpenUNIX* | sysv5UnixWare7.[01].[10]* | unixware7*)
+      no_undefined_flag_GCJ='${wl}-z,text'
+      if test "$GCC" = yes; then
+	archive_cmds_GCJ='$CC -shared ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds_GCJ='$CC -shared ${wl}-Bexport:$export_symbols ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+      else
+	archive_cmds_GCJ='$CC -G ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds_GCJ='$CC -G ${wl}-Bexport:$export_symbols ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+      fi
+    sysv5* | sco3.2v5* | sco5v6*)
+      # Note: We can NOT use -z defs as we might desire, because we do not
+      # link with -lc, and that would cause any symbols used from libc to
+      # always be unresolved, which means just about no library would
+      # ever link correctly.  If we're not using GNU ld we use -z text
+      # though, which does catch some bad symbols but isn't as heavy-handed
+      # as -z defs.
+      allow_undefined_flag_GCJ='${wl}-z,nodefs'
+      hardcode_libdir_flag_spec_GCJ='`test -z "$SCOABSPATH" && echo ${wl}-R,$libdir`'
+      export_dynamic_flag_spec_GCJ='${wl}-Bexport'
+	archive_cmds_GCJ='$CC -shared ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds_GCJ='$CC -shared ${wl}-Bexport:$export_symbols ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+      else
+	archive_cmds_GCJ='$CC -G ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds_GCJ='$CC -G ${wl}-Bexport:$export_symbols ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+      fi
+    uts4*)
+      ld_shlibs_GCJ=no
+    esac
+  fi
+echo "$as_me:$LINENO: result: $ld_shlibs_GCJ" >&5
+echo "${ECHO_T}$ld_shlibs_GCJ" >&6
+test "$ld_shlibs_GCJ" = no && can_build_shared=no
-#     dll_name = filename;
+# Do we need to explicitly link libc?
-#     for (i=0; filename[i]; i++)
-# 	if (filename[i] == '/' || filename[i] == '\\'  || filename[i] == ':')
-# 	    dll_name = filename + i +1;
-#     pe_header_offset = pe_get32 (dll, 0x3c);
-#     opthdr_ofs = pe_header_offset + 4 + 20;
-#     num_entries = pe_get32 (dll, opthdr_ofs + 92);
-#     if (num_entries < 1) /* no exports */
-# 	return 1;
-#     export_rva = pe_get32 (dll, opthdr_ofs + 96);
-#     export_size = pe_get32 (dll, opthdr_ofs + 100);
-#     nsections = pe_get16 (dll, pe_header_offset + 4 +2);
-#     secptr = (pe_header_offset + 4 + 20 +
-# 	      pe_get16 (dll, pe_header_offset + 4 + 16));
-#     expptr = 0;
-#     for (i = 0; i < nsections; i++)
-# 	char sname[8];
-# 	unsigned long secptr1 = secptr + 40 * i;
-# 	unsigned long vaddr = pe_get32 (dll, secptr1 + 12);
-# 	unsigned long vsize = pe_get32 (dll, secptr1 + 16);
-# 	unsigned long fptr = pe_get32 (dll, secptr1 + 20);
-# 	lseek(dll, secptr1, SEEK_SET);
-# 	read(dll, sname, 8);
-# 	if (vaddr <= export_rva && vaddr+vsize > export_rva)
-# 	    expptr = fptr + (export_rva - vaddr);
-# 	    if (export_rva + export_size > vaddr + vsize)
-# 		export_size = vsize - (export_rva - vaddr);
-# 	    break;
-#     expdata = (unsigned char*)malloc(export_size);
-#     lseek (dll, expptr, SEEK_SET);
-#     read (dll, expdata, export_size);
-#     erva = expdata - export_rva;
-#     nexp = pe_as32 (expdata+24);
-#     name_rvas = pe_as32 (expdata+32);
-#     printf ("EXPORTS\n");
-#     for (i = 0; i<nexp; i++)
-# 	unsigned long name_rva = pe_as32 (erva+name_rvas+i*4);
-# 	printf ("\t%s @ %ld ;\n", erva+name_rva, 1+ i);
-#     return 0;
-# /* impgen.c ends here */
+case "x$archive_cmds_need_lc_GCJ" in
+x|xyes)
+  # Assume -lc should be added
-EOF
+  if test "$enable_shared" = yes && test "$GCC" = yes; then
+    case $archive_cmds_GCJ in
+      # FIXME: we may have to deal with multi-command sequences.
+    '$CC '*)
+      # Test whether the compiler implicitly links with -lc since on some
+      # systems, -lgcc has to come before -lc. If gcc already passes -lc
+      # to ld, don't add -lc before -lgcc.
+      echo "$as_me:$LINENO: checking whether -lc should be explicitly linked in" >&5
+echo $ECHO_N "checking whether -lc should be explicitly linked in... $ECHO_C" >&6
+      $rm conftest*
+      printf "$lt_simple_compile_test_code" > conftest.$ac_ext
+      if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
+  (eval $ac_compile) 2>&5
+  ac_status=$?
+  (exit $ac_status); } 2>conftest.err; then
+        soname=conftest
+        lib=conftest
+        libobjs=conftest.$ac_objext
+        deplibs=
+        wl=$lt_prog_compiler_wl_GCJ
+	pic_flag=$lt_prog_compiler_pic_GCJ
+        compiler_flags=-v
+        linker_flags=-v
+        verstring=
+        output_objdir=.
+        libname=conftest
+        lt_save_allow_undefined_flag=$allow_undefined_flag_GCJ
+        if { (eval echo "$as_me:$LINENO: \"$archive_cmds_GCJ 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1\"") >&5
+  (eval $archive_cmds_GCJ 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1) 2>&5
+  ac_status=$?
+        then
+        else
+        fi
+        allow_undefined_flag_GCJ=$lt_save_allow_undefined_flag
+      else
+        cat conftest.err 1>&5
+      fi
+      $rm conftest*
+      echo "$as_me:$LINENO: result: $archive_cmds_need_lc_GCJ" >&5
+echo "${ECHO_T}$archive_cmds_need_lc_GCJ" >&6
+    esac
+  fi
+esac
+echo "$as_me:$LINENO: checking dynamic linker characteristics" >&5
+echo $ECHO_N "checking dynamic linker characteristics... $ECHO_C" >&6
+libname_spec='lib$name'
+soname_spec=
+shrext_cmds=".so"
+postinstall_cmds=
+finish_cmds=
+finish_eval=
+shlibpath_var=
+shlibpath_overrides_runpath=unknown
+version_type=none
+dynamic_linker="$host_os ld.so"
+sys_lib_dlsearch_path_spec="/lib /usr/lib"
+if test "$GCC" = yes; then
+  sys_lib_search_path_spec=`$CC -print-search-dirs | grep "^libraries:" | $SED -e "s/^libraries://" -e "s,=/,/,g"`
+  if echo "$sys_lib_search_path_spec" | grep ';' >/dev/null ; then
+    # if the path contains ";" then we assume it to be the separator
+    # otherwise default to the standard path separator (i.e. ":") - it is
+    # assumed that no part of a normal pathname contains ";" but that should
+    # okay in the real world where ";" in dirpaths is itself problematic.
+    sys_lib_search_path_spec=`echo "$sys_lib_search_path_spec" | $SED -e 's/;/ /g'`
+  else
+    sys_lib_search_path_spec=`echo "$sys_lib_search_path_spec" | $SED  -e "s/$PATH_SEPARATOR/ /g"`
+  fi
+else
+  sys_lib_search_path_spec="/lib /usr/lib /usr/local/lib"
+fi
+need_lib_prefix=unknown
+hardcode_into_libs=no
+# when you set need_version to no, make sure it does not cause -set_version
+# flags to be left without arguments
+need_version=unknown
+case $host_os in
+aix3*)
+  version_type=linux
+  library_names_spec='${libname}${release}${shared_ext}$versuffix $libname.a'
+  shlibpath_var=LIBPATH
+  # AIX 3 has no versioning support, so we append a major version to the name.
+  soname_spec='${libname}${release}${shared_ext}$major'
+aix4* | aix5*)
+  need_lib_prefix=no
+  need_version=no
+  hardcode_into_libs=yes
+    # AIX 5 supports IA64
+    library_names_spec='${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext}$versuffix $libname${shared_ext}'
+    shlibpath_var=LD_LIBRARY_PATH
+  else
+    # With GCC up to 2.95.x, collect2 would create an import file
+    # for dependence libraries.  The import file would start with
+    # the line `#! .'.  This would cause the generated library to
+    # depend on `.', always an invalid library.  This was fixed in
+    # development snapshots of GCC prior to 3.0.
+    case $host_os in
+      aix4 | aix4.[01] | aix4.[01].*)
+      if { echo '#if __GNUC__ > 2 || (__GNUC__ == 2 && __GNUC_MINOR__ >= 97)'
+	   echo ' yes '
+	   echo '#endif'; } | ${CC} -E - | grep yes > /dev/null; then
+      else
+	can_build_shared=no
+      fi
+    esac
+    # AIX (on Power*) has no versioning support, so currently we can not hardcode correct
+    # soname into executable. Probably we can add versioning support to
+    # collect2, so additional links can be useful in future.
+      # If using run time linking (on AIX 4.2 or later) use lib<name>.so
+      # instead of lib<name>.a to let people know that these are not
+      # typical AIX shared libraries.
+      library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname${shared_ext}'
+    else
+      # We preserve .a as extension for shared libraries through AIX4.2
+      # and later when we are not doing run time linking.
+      library_names_spec='${libname}${release}.a $libname.a'
+    fi
+  fi
+amigaos*)
+  library_names_spec='$libname.ixlibrary $libname.a'
+  # Create ${libname}_ixlibrary.a entries in /sys/libs.
+  finish_eval='for lib in `ls $libdir/*.ixlibrary 2>/dev/null`; do libname=`$echo "X$lib" | $Xsed -e '\''s%^.*/\([^/]*\)\.ixlibrary$%\1%'\''`; test $rm /sys/libs/${libname}_ixlibrary.a; $show "cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a"; cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a || exit 1; done'
+beos*)
+  library_names_spec='${libname}${shared_ext}'
+  dynamic_linker="$host_os ld.so"
+  shlibpath_var=LIBRARY_PATH
+bsdi[45]*)
+  need_version=no
+  finish_cmds='PATH="\$PATH:/sbin" ldconfig $libdir'
+  sys_lib_search_path_spec="/shlib /usr/lib /usr/X11/lib /usr/contrib/lib /lib /usr/local/lib"
+  sys_lib_dlsearch_path_spec="/shlib /usr/lib /usr/local/lib"
+  # the default ld.so.conf also contains /usr/contrib/lib and
+  # /usr/X11R6/lib (/usr/X11 is a link to /usr/X11R6), but let us allow
+  # libtool to hard-code these into programs
+cygwin* | mingw* | pw32*)
+  version_type=windows
+  shrext_cmds=".dll"
+  need_version=no
+  case $GCC,$host_os in
+  yes,cygwin* | yes,mingw* | yes,pw32*)
+    library_names_spec='$libname.dll.a'
+    # DLL is installed to $(libdir)/../bin by postinstall_cmds
+    postinstall_cmds='base_file=`basename \${file}`~
+      dlpath=`$SHELL 2>&1 -c '\''. $dir/'\''\${base_file}'\''i;echo \$dlname'\''`~
+      dldir=$destdir/`dirname \$dlpath`~
+      test -d \$dldir || mkdir -p \$dldir~
+      $install_prog $dir/$dlname \$dldir/$dlname~
+      chmod a+x \$dldir/$dlname'
+    postuninstall_cmds='dldll=`$SHELL 2>&1 -c '\''. $file; echo \$dlname'\''`~
+      dlpath=$dir/\$dldll~
+       $rm \$dlpath'
+    shlibpath_overrides_runpath=yes
+    case $host_os in
+    cygwin*)
+      # Cygwin DLLs use 'cyg' prefix rather than 'lib'
+      soname_spec='`echo ${libname} | sed -e 's/^lib/cyg/'``echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
+      sys_lib_search_path_spec="/usr/lib /lib/w32api /lib /usr/local/lib"
+    mingw*)
+      # MinGW DLLs use traditional 'lib' prefix
+      soname_spec='${libname}`echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
+      if echo "$sys_lib_search_path_spec" | grep ';[c-zC-Z]:/' >/dev/null; then
+        # It is most probably a Windows format PATH printed by
+        # mingw gcc, but we are running on Cygwin. Gcc prints its search
+        # path with ; separators, and with drive letters. We can handle the
+        # drive letters (cygwin fileutils understands them), so leave them,
+        # especially as we might pass files found there to a mingw objdump,
+        # which wouldn't understand a cygwinified path. Ahh.
+      else
+      fi
+    pw32*)
+      # pw32 DLLs use 'pw' prefix rather than 'lib'
+      library_names_spec='`echo ${libname} | sed -e 's/^lib/pw/'``echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
+    esac
+    library_names_spec='${libname}`echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext} $libname.lib'
   esac
+  dynamic_linker='Win32 ld.exe'
+  # FIXME: first we should search . and the directory the executable is in
+  shlibpath_var=PATH
-  # We use sed instead of cat because bash on DJGPP gets confused if
-  # if finds mixed CR/LF and LF-only lines.  Since sed operates in
-  # text mode, it properly converts lines to CR/LF.  This bash problem
-  # is reportedly fixed, but why not run on old versions too?
-  sed '$q' "$ltmain" >> "${ofile}T" || (rm -f "${ofile}T"; exit 1)
+darwin* | rhapsody*)
+  dynamic_linker="$host_os dyld"
+  version_type=darwin
+  need_version=no
+  library_names_spec='${libname}${release}${versuffix}$shared_ext ${libname}${release}${major}$shared_ext ${libname}$shared_ext'
+  soname_spec='${libname}${release}${major}$shared_ext'
+  shlibpath_var=DYLD_LIBRARY_PATH
+  shrext_cmds='`test .$module = .yes && echo .so || echo .dylib`'
+  # Apple's gcc prints 'gcc -print-search-dirs' doesn't operate the same.
+    sys_lib_search_path_spec=`$CC -print-search-dirs | tr "\n" "$PATH_SEPARATOR" | sed -e 's/libraries:/@libraries:/' | tr "@" "\n" | grep "^libraries:" | sed -e "s/^libraries://" -e "s,=/,/,g" -e "s,$PATH_SEPARATOR, ,g" -e "s,.*,& /lib /usr/lib /usr/local/lib,g"`
+  else
+    sys_lib_search_path_spec='/lib /usr/lib /usr/local/lib'
+  fi
+  sys_lib_dlsearch_path_spec='/usr/local/lib /lib /usr/lib'
-  mv -f "${ofile}T" "$ofile" || \
-    (rm -f "$ofile" && cp "${ofile}T" "$ofile" && rm -f "${ofile}T")
-  chmod +x "$ofile"
+dgux*)
+  need_version=no
+  library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname$shared_ext'
+freebsd1*)
+  dynamic_linker=no
+kfreebsd*-gnu)
+  need_version=no
+  library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${shared_ext}'
+  shlibpath_overrides_runpath=no
+  dynamic_linker='GNU ld.so'
+freebsd* | dragonfly*)
+  # DragonFly does not have aout.  When/if they implement a new
+  # versioning mechanism, adjust this.
+  if test -x /usr/bin/objformat; then
+    objformat=`/usr/bin/objformat`
+  else
+    case $host_os in
+    freebsd[123]*) objformat=aout ;;
+    *) objformat=elf ;;
+    esac
+  fi
+  version_type=freebsd-$objformat
+  case $version_type in
+    freebsd-elf*)
+      library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext} $libname${shared_ext}'
+      need_version=no
+    freebsd-*)
+      library_names_spec='${libname}${release}${shared_ext}$versuffix $libname${shared_ext}$versuffix'
+      need_version=yes
+  esac
+  case $host_os in
+  freebsd2*)
+  freebsd3.[01]* | freebsdelf3.[01]*)
+  freebsd3.[2-9]* | freebsdelf3.[2-9]* | \
+  freebsd4.[0-5] | freebsdelf4.[0-5] | freebsd4.1.1 | freebsdelf4.1.1)
+  freebsd*) # from 4.6 on
+  esac
+gnu*)
+  need_version=no
+  library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}${major} ${libname}${shared_ext}'
+hpux9* | hpux10* | hpux11*)
+  # Give a soname corresponding to the major version so that dld.sl refuses to
+  # link against other versions.
+  version_type=sunos
+  need_version=no
+  case $host_cpu in
+  ia64*)
+    shrext_cmds='.so'
+    dynamic_linker="$host_os dld.so"
+    shlibpath_overrides_runpath=yes # Unless +noenvvar is specified.
+    if test "X$HPUX_IA64_MODE" = X32; then
+      sys_lib_search_path_spec="/usr/lib/hpux32 /usr/local/lib/hpux32 /usr/local/lib"
+    else
+      sys_lib_search_path_spec="/usr/lib/hpux64 /usr/local/lib/hpux64"
+    fi
+    sys_lib_dlsearch_path_spec=$sys_lib_search_path_spec
+   hppa*64*)
+     shrext_cmds='.sl'
+     dynamic_linker="$host_os dld.sl"
+     shlibpath_var=LD_LIBRARY_PATH # How should we handle SHLIB_PATH
+     sys_lib_search_path_spec="/usr/lib/pa20_64 /usr/ccs/lib/pa20_64"
+    shrext_cmds='.sl'
+    shlibpath_var=SHLIB_PATH
+    shlibpath_overrides_runpath=no # +s is required to enable SHLIB_PATH
+  esac
+  # HP-UX runs *really* slowly unless shared libraries are mode 555.
+  postinstall_cmds='chmod 555 $lib'
+interix3*)
+  need_version=no
+  dynamic_linker='Interix 3.x ld.so.1 (PE, like ELF)'
+irix5* | irix6* | nonstopux*)
+  case $host_os in
+    nonstopux*) version_type=nonstopux ;;
+	if test "$lt_cv_prog_gnu_ld" = yes; then
+	else
+		version_type=irix
+	fi ;;
+  esac
+  need_version=no
+  library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext} $libname${shared_ext}'
+  case $host_os in
+  irix5* | nonstopux*)
+    libsuff= shlibsuff=
+    case $LD in # libtool.m4 will add one of these switches to LD
+    *-32|*"-32 "|*-melf32bsmip|*"-melf32bsmip ")
+      libsuff= shlibsuff= libmagic=32-bit;;
+    *-n32|*"-n32 "|*-melf32bmipn32|*"-melf32bmipn32 ")
+      libsuff=32 shlibsuff=N32 libmagic=N32;;
+    *-64|*"-64 "|*-melf64bmip|*"-melf64bmip ")
+      libsuff=64 shlibsuff=64 libmagic=64-bit;;
+    *) libsuff= shlibsuff= libmagic=never-match;;
+    esac
+  esac
+  shlibpath_var=LD_LIBRARY${shlibsuff}_PATH
+  sys_lib_search_path_spec="/usr/lib${libsuff} /lib${libsuff} /usr/local/lib${libsuff}"
+  sys_lib_dlsearch_path_spec="/usr/lib${libsuff} /lib${libsuff}"
+# No shared lib support for Linux oldld, aout, or coff.
+linux*oldld* | linux*aout* | linux*coff*)
+  dynamic_linker=no
+# This must be Linux ELF.
+linux*)
+  need_version=no
+  finish_cmds='PATH="\$PATH:/sbin" ldconfig -n $libdir'
+  # This implies no fast_install, which is unacceptable.
+  # Some rework will be needed to allow for fast_install
+  # before this can be enabled.
+  # find out which ABI we are using
+  libsuff=
+  case "$host_cpu" in
+  x86_64*|s390x*|powerpc64*)
+    echo '#line 17448 "configure"' > conftest.$ac_ext
+  ac_status=$?
+  (exit $ac_status); }; then
+      case `/usr/bin/file conftest.$ac_objext` in
+      *64-bit*)
+        libsuff=64
+        sys_lib_search_path_spec="/lib${libsuff} /usr/lib${libsuff} /usr/local/lib${libsuff}"
+      esac
+    fi
+    rm -rf conftest*
+  esac
+  # Append ld.so.conf contents to the search path
+  if test -f /etc/ld.so.conf; then
+    lt_ld_extra=`awk '/^include / { system(sprintf("cd /etc; cat %s", \$2)); skip = 1; } { if (!skip) print \$0; skip = 0; }' < /etc/ld.so.conf | $SED -e 's/#.*//;s/[:,	]/ /g;s/=[^=]*$//;s/=[^= ]* / /g;/^$/d' | tr '\n' ' '`
+    sys_lib_dlsearch_path_spec="/lib${libsuff} /usr/lib${libsuff} $lt_ld_extra"
+  fi
+  # We used to test for /lib/ld.so.1 and disable shared libraries on
+  # powerpc, because MkLinux only supported shared libraries with the
+  # GNU dynamic linker.  Since this was broken with cross compilers,
+  # most powerpc-linux boxes support dynamic linking these days and
+  # people can always --disable-shared, the test was removed, and we
+  # assume the GNU/Linux dynamic linker is in use.
+  dynamic_linker='GNU/Linux ld.so'
+knetbsd*-gnu)
+  need_version=no
+netbsd*)
+  need_version=no
+    library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${shared_ext}$versuffix'
+    finish_cmds='PATH="\$PATH:/sbin" ldconfig -m $libdir'
+    dynamic_linker='NetBSD (a.out) ld.so'
+  else
+    dynamic_linker='NetBSD ld.elf_so'
+  fi
+newsos6)
+nto-qnx*)
+  need_version=no
+openbsd*)
+  sys_lib_dlsearch_path_spec="/usr/lib"
+  # Some older versions of OpenBSD (3.3 at least) *do* need versioned libs.
+  case $host_os in
+    openbsd3.3 | openbsd3.3.*) need_version=yes ;;
+    *)                         need_version=no  ;;
+  esac
+    case $host_os in
+      openbsd2.[89] | openbsd2.[89].*)
+      esac
+  else
+  fi
+os2*)
+  libname_spec='$name'
+  library_names_spec='$libname${shared_ext} $libname.a'
+  dynamic_linker='OS/2 ld.exe'
+osf3* | osf4* | osf5*)
+  version_type=osf
+  need_version=no
+  sys_lib_search_path_spec="/usr/shlib /usr/ccs/lib /usr/lib/cmplrs/cc /usr/lib /usr/local/lib /var/shlib"
+  sys_lib_dlsearch_path_spec="$sys_lib_search_path_spec"
+solaris*)
+  need_version=no
+  # ldd complains unless libraries are executable
+  postinstall_cmds='chmod +x $lib'
+sunos4*)
+  finish_cmds='PATH="\$PATH:/usr/etc" ldconfig $libdir'
+  if test "$with_gnu_ld" = yes; then
+  fi
+  need_version=yes
+sysv4 | sysv4.3*)
+  case $host_vendor in
+    sni)
+      export_dynamic_flag_spec='${wl}-Blargedynsym'
+    siemens)
+    motorola)
+      need_version=no
+      sys_lib_search_path_spec='/lib /usr/lib /usr/ccs/lib'
+  esac
+sysv4*MP*)
+  if test -d /usr/nec ;then
+    library_names_spec='$libname${shared_ext}.$versuffix $libname${shared_ext}.$major $libname${shared_ext}'
+    soname_spec='$libname${shared_ext}.$major'
+  fi
+sysv5* | sco3.2v5* | sco5v6* | unixware* | OpenUNIX* | sysv4*uw2*)
+  version_type=freebsd-elf
+  need_version=no
+    sys_lib_search_path_spec='/usr/local/lib /usr/gnu/lib /usr/ccs/lib /usr/lib /lib'
+  else
+    sys_lib_search_path_spec='/usr/ccs/lib /usr/lib'
+    case $host_os in
+      sco3.2v5*)
+        sys_lib_search_path_spec="$sys_lib_search_path_spec /lib"
+    esac
+  fi
+  sys_lib_dlsearch_path_spec='/usr/lib'
+uts4*)
+  dynamic_linker=no
+esac
+echo "$as_me:$LINENO: result: $dynamic_linker" >&5
+echo "${ECHO_T}$dynamic_linker" >&6
+test "$dynamic_linker" = no && can_build_shared=no
+variables_saved_for_relink="PATH $shlibpath_var $runpath_var"
+  variables_saved_for_relink="$variables_saved_for_relink GCC_EXEC_PREFIX COMPILER_PATH LIBRARY_PATH"
 fi
+echo "$as_me:$LINENO: checking how to hardcode library paths into programs" >&5
+echo $ECHO_N "checking how to hardcode library paths into programs... $ECHO_C" >&6
+hardcode_action_GCJ=
+if test -n "$hardcode_libdir_flag_spec_GCJ" || \
+   test -n "$runpath_var_GCJ" || \
+   test "X$hardcode_automatic_GCJ" = "Xyes" ; then
+  # We can hardcode non-existant directories.
+  if test "$hardcode_direct_GCJ" != no &&
+     # If the only mechanism to avoid hardcoding is shlibpath_var, we
+     # have to relink, otherwise we might link with an installed library
+     # when we should be linking with a yet-to-be-installed one
+     ## test "$_LT_AC_TAGVAR(hardcode_shlibpath_var, GCJ)" != no &&
+     test "$hardcode_minus_L_GCJ" != no; then
+    # Linking always hardcodes the temporary library directory.
+    hardcode_action_GCJ=relink
+  else
+    # We can link without hardcoding, and we can hardcode nonexisting dirs.
+    hardcode_action_GCJ=immediate
+  fi
+else
+  # We cannot hardcode anything, or else we can only hardcode existing
+  # directories.
+  hardcode_action_GCJ=unsupported
+fi
+echo "$as_me:$LINENO: result: $hardcode_action_GCJ" >&5
+echo "${ECHO_T}$hardcode_action_GCJ" >&6
+if test "$hardcode_action_GCJ" = relink; then
+  # Fast installation is not supported
+  enable_fast_install=no
+elif test "$shlibpath_overrides_runpath" = yes ||
+     test "$enable_shared" = no; then
+  # Fast installation is not necessary
+  enable_fast_install=needless
+fi
+# The else clause should only fire when bootstrapping the
+# libtool distribution, otherwise you forgot to ship ltmain.sh
+# with your package, and you will get complaints that there are
+# no rules to generate ltmain.sh.
+if test -f "$ltmain"; then
+  # See if we are running on zsh, and set the options which allow our commands through
+  # without removal of \ escapes.
+  if test -n "${ZSH_VERSION+set}" ; then
+    setopt NO_GLOB_SUBST
+  fi
+  # Now quote all the things that may contain metacharacters while being
+  # careful not to overquote the AC_SUBSTed values.  We take copies of the
+  # variables and quote the copies for generation of the libtool script.
+  for var in echo old_CC old_CFLAGS AR AR_FLAGS EGREP RANLIB LN_S LTCC LTCFLAGS NM \
+    SED SHELL STRIP \
+    libname_spec library_names_spec soname_spec extract_expsyms_cmds \
+    old_striplib striplib file_magic_cmd finish_cmds finish_eval \
+    deplibs_check_method reload_flag reload_cmds need_locks \
+    lt_cv_sys_global_symbol_pipe lt_cv_sys_global_symbol_to_cdecl \
+    lt_cv_sys_global_symbol_to_c_name_address \
+    sys_lib_search_path_spec sys_lib_dlsearch_path_spec \
+    old_postinstall_cmds old_postuninstall_cmds \
+    compiler_GCJ \
+    CC_GCJ \
+    LD_GCJ \
+    lt_prog_compiler_wl_GCJ \
+    lt_prog_compiler_pic_GCJ \
+    lt_prog_compiler_static_GCJ \
+    lt_prog_compiler_no_builtin_flag_GCJ \
+    export_dynamic_flag_spec_GCJ \
+    thread_safe_flag_spec_GCJ \
+    whole_archive_flag_spec_GCJ \
+    enable_shared_with_static_runtimes_GCJ \
+    old_archive_cmds_GCJ \
+    old_archive_from_new_cmds_GCJ \
+    predep_objects_GCJ \
+    postdep_objects_GCJ \
+    predeps_GCJ \
+    postdeps_GCJ \
+    compiler_lib_search_path_GCJ \
+    archive_cmds_GCJ \
+    archive_expsym_cmds_GCJ \
+    postinstall_cmds_GCJ \
+    postuninstall_cmds_GCJ \
+    old_archive_from_expsyms_cmds_GCJ \
+    allow_undefined_flag_GCJ \
+    no_undefined_flag_GCJ \
+    export_symbols_cmds_GCJ \
+    hardcode_libdir_flag_spec_GCJ \
+    hardcode_libdir_flag_spec_ld_GCJ \
+    hardcode_libdir_separator_GCJ \
+    hardcode_automatic_GCJ \
+    module_cmds_GCJ \
+    module_expsym_cmds_GCJ \
+    lt_cv_prog_compiler_c_o_GCJ \
+    exclude_expsyms_GCJ \
+    include_expsyms_GCJ; do
+    case $var in
+    old_archive_cmds_GCJ | \
+    old_archive_from_new_cmds_GCJ | \
+    archive_cmds_GCJ | \
+    archive_expsym_cmds_GCJ | \
+    module_cmds_GCJ | \
+    module_expsym_cmds_GCJ | \
+    old_archive_from_expsyms_cmds_GCJ | \
+    export_symbols_cmds_GCJ | \
+    extract_expsyms_cmds | reload_cmds | finish_cmds | \
+    postinstall_cmds | postuninstall_cmds | \
+    old_postinstall_cmds | old_postuninstall_cmds | \
+    sys_lib_search_path_spec | sys_lib_dlsearch_path_spec)
+      # Double-quote double-evaled strings.
+      eval "lt_$var=\\\"\`\$echo \"X\$$var\" | \$Xsed -e \"\$double_quote_subst\" -e \"\$sed_quote_subst\" -e \"\$delay_variable_subst\"\`\\\""
+      eval "lt_$var=\\\"\`\$echo \"X\$$var\" | \$Xsed -e \"\$sed_quote_subst\"\`\\\""
+    esac
+  done
+  case $lt_echo in
+  *'\$0 --fallback-echo"')
+    lt_echo=`$echo "X$lt_echo" | $Xsed -e 's/\\\\\\\$0 --fallback-echo"$/$0 --fallback-echo"/'`
+  esac
+cfgfile="$ofile"
+  cat <<__EOF__ >> "$cfgfile"
+# ### BEGIN LIBTOOL TAG CONFIG: $tagname
+# Libtool was configured on host `(hostname || uname -n) 2>/dev/null | sed 1q`:
+# Shell to use when invoking shell scripts.
+SHELL=$lt_SHELL
+# Whether or not to build shared libraries.
+build_libtool_libs=$enable_shared
+# Whether or not to build static libraries.
+build_old_libs=$enable_static
+# Whether or not to add -lc for building shared libraries.
+build_libtool_need_lc=$archive_cmds_need_lc_GCJ
+# Whether or not to disallow shared libs when runtime libs are static
+allow_libtool_libs_with_static_runtimes=$enable_shared_with_static_runtimes_GCJ
+# Whether or not to optimize for fast installation.
+fast_install=$enable_fast_install
+# The host system.
+host_alias=$host_alias
+host=$host
+host_os=$host_os
+# The build system.
+build_alias=$build_alias
+build=$build
+build_os=$build_os
+# An echo program that does not interpret backslashes.
+echo=$lt_echo
+# The archiver.
+AR=$lt_AR
+AR_FLAGS=$lt_AR_FLAGS
+# A C compiler.
+LTCC=$lt_LTCC
+# LTCC compiler flags.
+LTCFLAGS=$lt_LTCFLAGS
+# A language-specific compiler.
+CC=$lt_compiler_GCJ
+# Is the compiler the GNU C compiler?
+with_gcc=$GCC_GCJ
+# An ERE matcher.
+EGREP=$lt_EGREP
+# The linker used to build libraries.
+LD=$lt_LD_GCJ
+# Whether we need hard or soft links.
+LN_S=$lt_LN_S
+# A BSD-compatible nm program.
+NM=$lt_NM
+# A symbol stripping program
+STRIP=$lt_STRIP
+# Used to examine libraries when file_magic_cmd begins "file"
+MAGIC_CMD=$MAGIC_CMD
+# Used on cygwin: DLL creation program.
+DLLTOOL="$DLLTOOL"
+# Used on cygwin: object dumper.
+OBJDUMP="$OBJDUMP"
+# Used on cygwin: assembler.
+AS="$AS"
+# The name of the directory that contains temporary libtool files.
+objdir=$objdir
+# How to create reloadable object files.
+reload_flag=$lt_reload_flag
+reload_cmds=$lt_reload_cmds
+# How to pass a linker flag through the compiler.
+wl=$lt_lt_prog_compiler_wl_GCJ
+# Object file suffix (normally "o").
+objext="$ac_objext"
+# Old archive suffix (normally "a").
+libext="$libext"
+# Shared library suffix (normally ".so").
+shrext_cmds='$shrext_cmds'
+# Executable file suffix (normally "").
+exeext="$exeext"
+# Additional compiler flags for building library objects.
+pic_flag=$lt_lt_prog_compiler_pic_GCJ
+pic_mode=$pic_mode
+# What is the maximum length of a command?
+max_cmd_len=$lt_cv_sys_max_cmd_len
+# Does compiler simultaneously support -c and -o options?
+compiler_c_o=$lt_lt_cv_prog_compiler_c_o_GCJ
+# Must we lock files when doing compilation?
+need_locks=$lt_need_locks
+# Do we need the lib prefix for modules?
+need_lib_prefix=$need_lib_prefix
+# Do we need a version for libraries?
+need_version=$need_version
+# Whether dlopen is supported.
+dlopen_support=$enable_dlopen
+# Whether dlopen of programs is supported.
+dlopen_self=$enable_dlopen_self
+# Whether dlopen of statically linked programs is supported.
+dlopen_self_static=$enable_dlopen_self_static
+# Compiler flag to prevent dynamic linking.
+link_static_flag=$lt_lt_prog_compiler_static_GCJ
+# Compiler flag to turn off builtin functions.
+no_builtin_flag=$lt_lt_prog_compiler_no_builtin_flag_GCJ
+# Compiler flag to allow reflexive dlopens.
+export_dynamic_flag_spec=$lt_export_dynamic_flag_spec_GCJ
+# Compiler flag to generate shared objects directly from archives.
+whole_archive_flag_spec=$lt_whole_archive_flag_spec_GCJ
+# Compiler flag to generate thread-safe objects.
+thread_safe_flag_spec=$lt_thread_safe_flag_spec_GCJ
+# Library versioning type.
+version_type=$version_type
+# Format of library name prefix.
+libname_spec=$lt_libname_spec
+# List of archive names.  First name is the real one, the rest are links.
+# The last name is the one that the linker finds with -lNAME.
+library_names_spec=$lt_library_names_spec
+# The coded name of the library, if different from the real name.
+soname_spec=$lt_soname_spec
+# Commands used to build and install an old-style archive.
+RANLIB=$lt_RANLIB
+old_archive_cmds=$lt_old_archive_cmds_GCJ
+old_postinstall_cmds=$lt_old_postinstall_cmds
+old_postuninstall_cmds=$lt_old_postuninstall_cmds
+# Create an old-style archive from a shared archive.
+old_archive_from_new_cmds=$lt_old_archive_from_new_cmds_GCJ
+# Create a temporary old-style archive to link instead of a shared archive.
+old_archive_from_expsyms_cmds=$lt_old_archive_from_expsyms_cmds_GCJ
+# Commands used to build and install a shared archive.
+archive_cmds=$lt_archive_cmds_GCJ
+archive_expsym_cmds=$lt_archive_expsym_cmds_GCJ
+postinstall_cmds=$lt_postinstall_cmds
+postuninstall_cmds=$lt_postuninstall_cmds
+# Commands used to build a loadable module (assumed same as above if empty)
+module_cmds=$lt_module_cmds_GCJ
+module_expsym_cmds=$lt_module_expsym_cmds_GCJ
+# Commands to strip libraries.
+old_striplib=$lt_old_striplib
+striplib=$lt_striplib
+# Dependencies to place before the objects being linked to create a
+# shared library.
+predep_objects=$lt_predep_objects_GCJ
+# Dependencies to place after the objects being linked to create a
+# shared library.
+postdep_objects=$lt_postdep_objects_GCJ
+# shared library.
+predeps=$lt_predeps_GCJ
+# shared library.
+postdeps=$lt_postdeps_GCJ
+# The library search path used internally by the compiler when linking
+# a shared library.
+compiler_lib_search_path=$lt_compiler_lib_search_path_GCJ
+# Method to check whether dependent libraries are shared objects.
+deplibs_check_method=$lt_deplibs_check_method
+# Command to use when deplibs_check_method == file_magic.
+file_magic_cmd=$lt_file_magic_cmd
+# Flag that allows shared libraries with undefined symbols to be built.
+allow_undefined_flag=$lt_allow_undefined_flag_GCJ
+# Flag that forces no undefined symbols.
+no_undefined_flag=$lt_no_undefined_flag_GCJ
+# Commands used to finish a libtool library installation in a directory.
+finish_cmds=$lt_finish_cmds
+# Same as above, but a single script fragment to be evaled but not shown.
+finish_eval=$lt_finish_eval
+# Take the output of nm and produce a listing of raw symbols and C names.
+global_symbol_pipe=$lt_lt_cv_sys_global_symbol_pipe
+# Transform the output of nm in a proper C declaration
+global_symbol_to_cdecl=$lt_lt_cv_sys_global_symbol_to_cdecl
+# Transform the output of nm in a C name address pair
+global_symbol_to_c_name_address=$lt_lt_cv_sys_global_symbol_to_c_name_address
+# This is the shared library runtime path variable.
+runpath_var=$runpath_var
+# This is the shared library path variable.
+shlibpath_var=$shlibpath_var
+# Is shlibpath searched before the hard-coded library search path?
+shlibpath_overrides_runpath=$shlibpath_overrides_runpath
+# How to hardcode a shared library path into an executable.
+hardcode_action=$hardcode_action_GCJ
+# Whether we should hardcode library paths into libraries.
+hardcode_into_libs=$hardcode_into_libs
+# Flag to hardcode \$libdir into a binary during linking.
+# This must work even if \$libdir does not exist.
+hardcode_libdir_flag_spec=$lt_hardcode_libdir_flag_spec_GCJ
+# If ld is used when linking, flag to hardcode \$libdir into
+# a binary during linking. This must work even if \$libdir does
+# not exist.
+hardcode_libdir_flag_spec_ld=$lt_hardcode_libdir_flag_spec_ld_GCJ
+# Whether we need a single -rpath flag with a separated argument.
+hardcode_libdir_separator=$lt_hardcode_libdir_separator_GCJ
+# Set to yes if using DIR/libNAME${shared_ext} during linking hardcodes DIR into the
+# resulting binary.
+hardcode_direct=$hardcode_direct_GCJ
+# Set to yes if using the -LDIR flag during linking hardcodes DIR into the
+hardcode_minus_L=$hardcode_minus_L_GCJ
+# Set to yes if using SHLIBPATH_VAR=DIR during linking hardcodes DIR into
+# the resulting binary.
+hardcode_shlibpath_var=$hardcode_shlibpath_var_GCJ
+# Set to yes if building a shared library automatically hardcodes DIR into the library
+# and all subsequent libraries and executables linked against it.
+hardcode_automatic=$hardcode_automatic_GCJ
+# Variables whose values should be saved in libtool wrapper scripts and
+# restored at relink time.
+variables_saved_for_relink="$variables_saved_for_relink"
+# Whether libtool must link a program against all its dependency libraries.
+link_all_deplibs=$link_all_deplibs_GCJ
+# Compile-time system search path for libraries
+sys_lib_search_path_spec=$lt_sys_lib_search_path_spec
+# Run-time system search path for libraries
+sys_lib_dlsearch_path_spec=$lt_sys_lib_dlsearch_path_spec
+# Fix the shell variable \$srcfile for the compiler.
+fix_srcfile_path="$fix_srcfile_path_GCJ"
+# Set to yes if exported symbols are required.
+always_export_symbols=$always_export_symbols_GCJ
+# The commands to list exported symbols.
+export_symbols_cmds=$lt_export_symbols_cmds_GCJ
+# The commands to extract the exported symbol list from a shared archive.
+extract_expsyms_cmds=$lt_extract_expsyms_cmds
+# Symbols that should not be listed in the preloaded symbols.
+exclude_expsyms=$lt_exclude_expsyms_GCJ
+# Symbols that must always be exported.
+include_expsyms=$lt_include_expsyms_GCJ
+# ### END LIBTOOL TAG CONFIG: $tagname
+__EOF__
+else
+  # If there is no Makefile yet, we rely on a make rule to execute
+  # `config.status --recheck' to rerun these tests and create the
+  # libtool script then.
+  ltmain_in=`echo $ltmain | sed -e 's/\.sh$/.in/'`
+  if test -f "$ltmain_in"; then
+    test -f Makefile && make "$ltmain"
+  fi
+fi
+ac_ext=cc
+ac_cpp='$CXXCPP $CPPFLAGS'
+ac_compile='$CXX -c $CXXFLAGS $CPPFLAGS conftest.$ac_ext >&5'
+ac_link='$CXX -o conftest$ac_exeext $CXXFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
+ac_compiler_gnu=$ac_cv_cxx_compiler_gnu
+CC="$lt_save_CC"
+	else
+	  tagname=""
+	fi
+      RC)
+# Source file extension for RC test sources.
+ac_ext=rc
+# Object file extension for compiled RC test sources.
+objext=o
+objext_RC=$objext
+# Code to be used in simple compile tests
+lt_simple_compile_test_code='sample MENU { MENUITEM "&Soup", 100, CHECKED }\n'
+# Code to be used in simple link tests
+lt_simple_link_test_code="$lt_simple_compile_test_code"
+# ltmain only uses $CC for tagged configurations so make sure $CC is set.
+# If no C compiler was specified, use CC.
+LTCC=${LTCC-"$CC"}
+# If no C compiler flags were specified, use CFLAGS.
+LTCFLAGS=${LTCFLAGS-"$CFLAGS"}
+# Allow CC to be a program name with arguments.
+compiler=$CC
+# save warnings/boilerplate of simple test code
+ac_outfile=conftest.$ac_objext
+printf "$lt_simple_compile_test_code" >conftest.$ac_ext
+eval "$ac_compile" 2>&1 >/dev/null | $SED '/^$/d; /^ *+/d' >conftest.err
+_lt_compiler_boilerplate=`cat conftest.err`
+$rm conftest*
+printf "$lt_simple_link_test_code" >conftest.$ac_ext
+eval "$ac_link" 2>&1 >/dev/null | $SED '/^$/d; /^ *+/d' >conftest.err
+_lt_linker_boilerplate=`cat conftest.err`
+$rm conftest*
+lt_save_CC="$CC"
+CC=${RC-"windres"}
+compiler=$CC
+compiler_RC=$CC
+for cc_temp in $compiler""; do
+  case $cc_temp in
+    compile | *[\\/]compile | ccache | *[\\/]ccache ) ;;
+    distcc | *[\\/]distcc | purify | *[\\/]purify ) ;;
+    *) break;;
+  esac
+done
+cc_basename=`$echo "X$cc_temp" | $Xsed -e 's%.*/%%' -e "s%^$host_alias-%%"`
+lt_cv_prog_compiler_c_o_RC=yes
+  fi
+    SED SHELL STRIP \
+    compiler_RC \
+    CC_RC \
+    LD_RC \
+    lt_prog_compiler_wl_RC \
+    lt_prog_compiler_pic_RC \
+    lt_prog_compiler_static_RC \
+    lt_prog_compiler_no_builtin_flag_RC \
+    export_dynamic_flag_spec_RC \
+    thread_safe_flag_spec_RC \
+    whole_archive_flag_spec_RC \
+    enable_shared_with_static_runtimes_RC \
+    old_archive_cmds_RC \
+    old_archive_from_new_cmds_RC \
+    predep_objects_RC \
+    postdep_objects_RC \
+    predeps_RC \
+    postdeps_RC \
+    compiler_lib_search_path_RC \
+    archive_cmds_RC \
+    archive_expsym_cmds_RC \
+    postinstall_cmds_RC \
+    postuninstall_cmds_RC \
+    old_archive_from_expsyms_cmds_RC \
+    allow_undefined_flag_RC \
+    no_undefined_flag_RC \
+    export_symbols_cmds_RC \
+    hardcode_libdir_flag_spec_RC \
+    hardcode_libdir_flag_spec_ld_RC \
+    hardcode_libdir_separator_RC \
+    hardcode_automatic_RC \
+    module_cmds_RC \
+    module_expsym_cmds_RC \
+    lt_cv_prog_compiler_c_o_RC \
+    exclude_expsyms_RC \
+    include_expsyms_RC; do
+    case $var in
+    old_archive_cmds_RC | \
+    old_archive_from_new_cmds_RC | \
+    archive_cmds_RC | \
+    archive_expsym_cmds_RC | \
+    module_cmds_RC | \
+    module_expsym_cmds_RC | \
+    old_archive_from_expsyms_cmds_RC | \
+    export_symbols_cmds_RC | \
+    esac
+  done
+  case $lt_echo in
+  esac
+cfgfile="$ofile"
+SHELL=$lt_SHELL
+build_libtool_need_lc=$archive_cmds_need_lc_RC
+allow_libtool_libs_with_static_runtimes=$enable_shared_with_static_runtimes_RC
+# The host system.
+host=$host
+host_os=$host_os
+build=$build
+build_os=$build_os
+echo=$lt_echo
+# The archiver.
+AR=$lt_AR
+# A C compiler.
+LTCC=$lt_LTCC
+CC=$lt_compiler_RC
+with_gcc=$GCC_RC
+# An ERE matcher.
+EGREP=$lt_EGREP
+LD=$lt_LD_RC
+LN_S=$lt_LN_S
+NM=$lt_NM
+STRIP=$lt_STRIP
+DLLTOOL="$DLLTOOL"
+OBJDUMP="$OBJDUMP"
+AS="$AS"
+objdir=$objdir
+wl=$lt_lt_prog_compiler_wl_RC
+libext="$libext"
+exeext="$exeext"
+pic_flag=$lt_lt_prog_compiler_pic_RC
+pic_mode=$pic_mode
+compiler_c_o=$lt_lt_cv_prog_compiler_c_o_RC
+link_static_flag=$lt_lt_prog_compiler_static_RC
+no_builtin_flag=$lt_lt_prog_compiler_no_builtin_flag_RC
+export_dynamic_flag_spec=$lt_export_dynamic_flag_spec_RC
+whole_archive_flag_spec=$lt_whole_archive_flag_spec_RC
+thread_safe_flag_spec=$lt_thread_safe_flag_spec_RC
+RANLIB=$lt_RANLIB
+old_archive_cmds=$lt_old_archive_cmds_RC
+old_archive_from_new_cmds=$lt_old_archive_from_new_cmds_RC
+old_archive_from_expsyms_cmds=$lt_old_archive_from_expsyms_cmds_RC
+archive_cmds=$lt_archive_cmds_RC
+archive_expsym_cmds=$lt_archive_expsym_cmds_RC
+module_cmds=$lt_module_cmds_RC
+module_expsym_cmds=$lt_module_expsym_cmds_RC
+# shared library.
+predep_objects=$lt_predep_objects_RC
+# shared library.
+postdep_objects=$lt_postdep_objects_RC
+# shared library.
+predeps=$lt_predeps_RC
+# shared library.
+postdeps=$lt_postdeps_RC
+compiler_lib_search_path=$lt_compiler_lib_search_path_RC
+allow_undefined_flag=$lt_allow_undefined_flag_RC
+no_undefined_flag=$lt_no_undefined_flag_RC
+hardcode_action=$hardcode_action_RC
+hardcode_libdir_flag_spec=$lt_hardcode_libdir_flag_spec_RC
+# not exist.
+hardcode_libdir_flag_spec_ld=$lt_hardcode_libdir_flag_spec_ld_RC
+hardcode_libdir_separator=$lt_hardcode_libdir_separator_RC
+hardcode_direct=$hardcode_direct_RC
+hardcode_minus_L=$hardcode_minus_L_RC
+hardcode_shlibpath_var=$hardcode_shlibpath_var_RC
+hardcode_automatic=$hardcode_automatic_RC
+link_all_deplibs=$link_all_deplibs_RC
+fix_srcfile_path="$fix_srcfile_path_RC"
+always_export_symbols=$always_export_symbols_RC
+export_symbols_cmds=$lt_export_symbols_cmds_RC
+exclude_expsyms=$lt_exclude_expsyms_RC
+include_expsyms=$lt_include_expsyms_RC
+__EOF__
+else
+  fi
+fi
+ac_ext=cc
+CC="$lt_save_CC"
+	{ { echo "$as_me:$LINENO: error: Unsupported tag name: $tagname" >&5
+echo "$as_me: error: Unsupported tag name: $tagname" >&2;}
+   { (exit 1); exit 1; }; }
+      esac
+      # Append the new tag name to the list of available tags.
+      if test -n "$tagname" ; then
+      available_tags="$available_tags $tagname"
+    fi
+    fi
+  done
+  IFS="$lt_save_ifs"
+  # Now substitute the updated list of available tags.
+  if eval "sed -e 's/^available_tags=.*\$/available_tags=\"$available_tags\"/' \"$ofile\" > \"${ofile}T\""; then
+    mv "${ofile}T" "$ofile"
+    chmod +x "$ofile"
+  else
+    rm -f "${ofile}T"
+    { { echo "$as_me:$LINENO: error: unable to update list of available tagged configurations." >&5
+echo "$as_me: error: unable to update list of available tagged configurations." >&2;}
+  fi
+fi
 # This can be used to rebuild libtool when needed
 LIBTOOL_DEPS="$ac_aux_dir/ltmain.sh"
@@ -8221,9 +18647,27 @@
-VERSION="3.2.0"
+VERSION="3.3.0"
 # custom Fdo path specification
@@ -8330,9 +18774,7 @@
   	{ echo "$as_me:$LINENO: Building with default location of MySQL SDK files at $FDOMYSQL" >&5
 echo "$as_me: Building with default location of MySQL SDK files at $FDOMYSQL" >&6;}
   else
- 	{ { echo "$as_me:$LINENO: error: The default MySQL SDK path $custom_fdo_mysql is not a valid directory. Please use the custom option" >&5
-echo "$as_me: error: The default MySQL SDK path $custom_fdo_mysql is not a valid directory. Please use the custom option" >&2;}
-   { (exit 1); exit 1; }; }
+  	FDOMYSQL="/usr/local/mysql"
   fi
 else
   if test -d $custom_fdo_mysql; then
@@ -8360,9 +18802,7 @@
   	{ echo "$as_me:$LINENO: Building with default location of ODBC SDK files at $FDOODBC" >&5
 echo "$as_me: Building with default location of ODBC SDK files at $FDOODBC" >&6;}
   else
- 	{ { echo "$as_me:$LINENO: error: The default ODBC SDK path $custom_fdo_odbc is not a valid directory. Please use the custom option" >&5
-echo "$as_me: error: The default ODBC SDK path $custom_fdo_odbc is not a valid directory. Please use the custom option" >&2;}
+  	FDOODBC="/usr"
   fi
 else
   if test -d $custom_fdo_odbc; then
@@ -8413,20 +18853,23 @@
 ##output Makefiles##
           ac_config_files="$ac_config_files Makefile"
-          ac_config_files="$ac_config_files Docs/Makefile Docs/doc_src/Makefile Docs/doc_src/headers_and_footers/Makefile Docs/doc_src/headers_and_footers/MySQL/Makefile Docs/doc_src/headers_and_footers/ODBC/Makefile Docs/doc_src/group_and_page_definitions/Makefile Docs/doc_src/group_and_page_definitions/MySQL/Makefile Docs/doc_src/group_and_page_definitions/ODBC/Makefile"
 #MySQL
-          ac_config_files="$ac_config_files com/Makefile Inc/Makefile Nls/Makefile Src/Makefile Src/Fdo/Makefile Src/Fdo/Capability/Makefile Src/Fdo/Connection/Makefile Src/Fdo/Custom/Makefile Src/Fdo/DataStore/Makefile Src/Fdo/FeatureCommands/Makefile Src/Fdo/Filter/Makefile Src/Fdo/Lock/Makefile Src/Fdo/Lt/Makefile Src/Fdo/Other/Makefile Src/Fdo/Pvc/Makefile Src/Fdo/Schema/Makefile Src/Fdo/SpatialContext/Makefile Src/Gdbi/Makefile Src/Geometry/Makefile Src/Geometry/Fgf/Makefile Src/LongTransactionManager/Makefile Src/LockManager/Makefile Src/MySQL/Makefile Src/MySQL/Driver/Makefile Src/MySQL/Fdo/Makefile Src/MySQL/SchemaMgr/Makefile Src/MySQL/SchemaMgr/Lp/Makefile Src/MySQL/SchemaMgr/Ov/Makefile Src/MySQL/SchemaMgr/Ph/Makefile Src/MySQL/SchemaMgr/Ph/Rd/Makefile Src/Rdbi/Makefile Src/SchemaMgr/Makefile Src/SchemaMgr/Lp/Makefile Src/SchemaMgr/Ov/Makefile Src/SchemaMgr/Ph/Makefile Src/SchemaMgr/Ph/Cfg/Makefile Src/SchemaMgr/Ph/Rd/Makefile Src/Util/Makefile Src/UnitTest/Common/Makefile Src/UnitTest/MySql/Makefile Src/UnitTest/Makefile"
+        ac_config_files="$ac_config_files com/Makefile Docs/Makefile Inc/Makefile Nls/Makefile Src/Makefile Src/Fdo/Makefile Src/Fdo/Capability/Makefile Src/Fdo/Connection/Makefile Src/Fdo/Custom/Makefile Src/Fdo/DataStore/Makefile Src/Fdo/FeatureCommands/Makefile Src/Fdo/Filter/Makefile Src/Fdo/Lock/Makefile Src/Fdo/Lt/Makefile Src/Fdo/Other/Makefile Src/Fdo/Pvc/Makefile Src/Fdo/Schema/Makefile Src/Fdo/SpatialContext/Makefile Src/Gdbi/Makefile Src/Geometry/Makefile Src/Geometry/Fgf/Makefile Src/LongTransactionManager/Makefile Src/LockManager/Makefile Src/MySQL/Makefile Src/MySQL/Driver/Makefile Src/MySQL/Fdo/Makefile Src/MySQL/SchemaMgr/Makefile Src/MySQL/SchemaMgr/Lp/Makefile Src/MySQL/SchemaMgr/Ov/Makefile Src/MySQL/SchemaMgr/Ph/Makefile Src/MySQL/SchemaMgr/Ph/Rd/Makefile Src/Rdbi/Makefile Src/SchemaMgr/Makefile Src/SchemaMgr/Lp/Makefile Src/SchemaMgr/Ov/Makefile Src/SchemaMgr/Ph/Makefile Src/SchemaMgr/Ph/Cfg/Makefile Src/SchemaMgr/Ph/Rd/Makefile Src/UnitTest/Common/Makefile Src/UnitTest/MySql/Makefile Src/UnitTest/Makefile Src/Util/Makefile"
 #ODBCDriver
           ac_config_files="$ac_config_files Src/ODBCDriver/Makefile"
 #ODBC
-          ac_config_files="$ac_config_files Src/ODBC/Makefile Src/ODBC/Fdo/Makefile Src/ODBC/SchemaMgr/Makefile Src/ODBC/SchemaMgr/Lp/Makefile Src/ODBC/SchemaMgr/Ov/Makefile Src/ODBC/SchemaMgr/Ph/Makefile Src/ODBC/SchemaMgr/Ph/Rd/Makefile Src/UnitTest/Odbc/Makefile"
+        ac_config_files="$ac_config_files Src/ODBC/Makefile Src/ODBC/Fdo/Makefile Src/ODBC/SchemaMgr/Makefile Src/ODBC/SchemaMgr/Lp/Makefile Src/ODBC/SchemaMgr/Ov/Makefile Src/ODBC/SchemaMgr/Ph/Makefile Src/ODBC/SchemaMgr/Ph/Rd/Makefile Src/UnitTest/Odbc/Makefile"
+        ac_config_files="$ac_config_files Docs/doc_src/Makefile Docs/doc_src/group_and_page_definitions/Makefile Docs/doc_src/headers_and_footers/Makefile Docs/doc_src/headers_and_footers/MySQL/Makefile Docs/doc_src/headers_and_footers/ODBC/Makefile Docs/doc_src/group_and_page_definitions/MySQL/Makefile Docs/doc_src/group_and_page_definitions/ODBC/Makefile"
 cat >confcache <<\_ACEOF
 # This file is a shell script that caches the results of configure
 # tests run on this system so they can be shared between configure
@@ -8455,13 +18898,13 @@
       # `set' does not quote correctly, so add quotes (double-quote
       # substitution turns \\\\ into \\, and sed turns \\ into \).
       sed -n \
-        "s/'/'\\\\''/g;
-    	  s/^\\([_$as_cr_alnum]*_cv_[_$as_cr_alnum]*\\)=\\(.*\\)/\\1='\\2'/p"
+	"s/'/'\\\\''/g;
+	  s/^\\([_$as_cr_alnum]*_cv_[_$as_cr_alnum]*\\)=\\(.*\\)/\\1='\\2'/p"
       # `set' quotes correctly as required by POSIX, so do not add quotes.
       sed -n \
-        "s/^\\([_$as_cr_alnum]*_cv_[_$as_cr_alnum]*\\)=\\(.*\\)/\\1=\\2/p"
+	"s/^\\([_$as_cr_alnum]*_cv_[_$as_cr_alnum]*\\)=\\(.*\\)/\\1=\\2/p"
     esac;
@@ -8491,13 +18934,13 @@
 # trailing colons and then remove the whole line if VPATH becomes empty
 # (actually we leave an empty line to preserve line numbers).
 if test "x$srcdir" = x.; then
-  ac_vpsub='/^[ 	]*VPATH[ 	]*=/{
+  ac_vpsub='/^[	 ]*VPATH[	 ]*=/{
 s/:*\$(srcdir):*/:/;
 s/:*\${srcdir}:*/:/;
 s/:*@srcdir@:*/:/;
-s/^\([^=]*=[ 	]*\):*/\1/;
+s/^\([^=]*=[	 ]*\):*/\1/;
 s/:*$//;
-s/^[^=]*=[ 	]*$//;
+s/^[^=]*=[	 ]*$//;
 fi
@@ -8511,13 +18954,13 @@
 cat >confdef2opt.sed <<\_ACEOF
 t clear
 : clear
-s,^[ 	]*#[ 	]*define[ 	][ 	]*\([^ 	(][^ 	(]*([^)]*)\)[ 	]*\(.*\),-D\1=\2,g
+s,^[	 ]*#[	 ]*define[	 ][	 ]*\([^	 (][^	 (]*([^)]*)\)[	 ]*\(.*\),-D\1=\2,g
 t quote
-s,^[ 	]*#[ 	]*define[ 	][ 	]*\([^ 	][^ 	]*\)[ 	]*\(.*\),-D\1=\2,g
+s,^[	 ]*#[	 ]*define[	 ][	 ]*\([^	 ][^	 ]*\)[	 ]*\(.*\),-D\1=\2,g
 t quote
 d
 : quote
-s,[ 	`~#$^&*(){}\\|;'"<>?],\\&,g
+s,[	 `~#$^&*(){}\\|;'"<>?],\\&,g
 s,\[,\\&,g
 s,\],\\&,g
 s,\$,$$,g
@@ -8539,7 +18982,7 @@
 for ac_i in : $LIBOBJS; do test "x$ac_i" = x: && continue
   # 1. Remove the extension, and $U if already installed.
   ac_i=`echo "$ac_i" |
-         sed 's/\$U\././;s/\.o$//;s/\.obj$//'`
+	 sed 's/\$U\././;s/\.o$//;s/\.obj$//'`
   # 2. Add them.
   ac_libobjs="$ac_libobjs $ac_i\$U.$ac_objext"
   ac_ltlibobjs="$ac_ltlibobjs $ac_i"'$U.lo'
@@ -8556,6 +18999,20 @@
 Usually this means the macro was only invoked conditionally." >&2;}
 fi
+if test -z "${am__fastdepCC_TRUE}" && test -z "${am__fastdepCC_FALSE}"; then
+  { { echo "$as_me:$LINENO: error: conditional \"am__fastdepCC\" was never defined.
+Usually this means the macro was only invoked conditionally." >&5
+echo "$as_me: error: conditional \"am__fastdepCC\" was never defined.
+Usually this means the macro was only invoked conditionally." >&2;}
+fi
+if test -z "${am__fastdepCXX_TRUE}" && test -z "${am__fastdepCXX_FALSE}"; then
+  { { echo "$as_me:$LINENO: error: conditional \"am__fastdepCXX\" was never defined.
+echo "$as_me: error: conditional \"am__fastdepCXX\" was never defined.
+fi
 : ${CONFIG_STATUS=./config.status}
 ac_clean_files_save=$ac_clean_files
@@ -8590,9 +19047,10 @@
 elif test -n "${BASH_VERSION+set}" && (set -o posix) >/dev/null 2>&1; then
   set -o posix
 fi
+DUALCASE=1; export DUALCASE # for MKS sh
 # Support unset when possible.
-if (FOO=FOO; unset FOO) >/dev/null 2>&1; then
+if ( (MAIL=60; unset MAIL) || exit) >/dev/null 2>&1; then
   as_unset=unset
 else
   as_unset=false
@@ -8611,7 +19069,7 @@
   LC_MEASUREMENT LC_MESSAGES LC_MONETARY LC_NAME LC_NUMERIC LC_PAPER \
   LC_TELEPHONE LC_TIME
 do
-  if (set +x; test -n "`(eval $as_var=C; export $as_var) 2>&1`"); then
+  if (set +x; test -z "`(eval $as_var=C; export $as_var) 2>&1`"); then
   else
     $as_unset $as_var
@@ -8790,16 +19248,17 @@
 if mkdir -p . 2>/dev/null; then
   as_mkdir_p=:
 else
+  test -d ./-p && rmdir ./-p
   as_mkdir_p=false
 fi
 as_executable_p="test -f"
 # Sed expression to map a string onto a valid CPP name.
-as_tr_cpp="sed y%*$as_cr_letters%P$as_cr_LETTERS%;s%[^_$as_cr_alnum]%_%g"
+as_tr_cpp="eval sed 'y%*$as_cr_letters%P$as_cr_LETTERS%;s%[^_$as_cr_alnum]%_%g'"
 # Sed expression to map a string onto a valid variable name.
-as_tr_sh="sed y%*+%pp%;s%[^_$as_cr_alnum]%_%g"
+as_tr_sh="eval sed 'y%*+%pp%;s%[^_$as_cr_alnum]%_%g'"
 # IFS
@@ -8825,8 +19284,8 @@
 } >&5
 cat >&5 <<_CSEOF
-This file was extended by FDORDBMS $as_me 3.2.0, which was
-generated by GNU Autoconf 2.57.  Invocation command line was
+This file was extended by FDORDBMS $as_me 3.3.0, which was
+generated by GNU Autoconf 2.59.  Invocation command line was
   CONFIG_FILES    = $CONFIG_FILES
   CONFIG_HEADERS  = $CONFIG_HEADERS
@@ -8870,7 +19329,7 @@
   -d, --debug      don't remove temporary files
       --recheck    update $as_me by reconfiguring in the same conditions
   --file=FILE[:TEMPLATE]
-                   instantiate the configuration file FILE
+		   instantiate the configuration file FILE
 Configuration files:
 $config_files
@@ -8883,12 +19342,11 @@
 cat >>$CONFIG_STATUS <<_ACEOF
 ac_cs_version="\\
-FDORDBMS config.status 3.2.0
-configured by $0, generated by GNU Autoconf 2.57,
+FDORDBMS config.status 3.3.0
+configured by $0, generated by GNU Autoconf 2.59,
   with options \\"`echo "$ac_configure_args" | sed 's/[\\""\`\$]/\\\\&/g'`\\"
-Copyright 1992, 1993, 1994, 1995, 1996, 1998, 1999, 2000, 2001
-Free Software Foundation, Inc.
+Copyright (C) 2003 Free Software Foundation, Inc.
 This config.status script is free software; the Free Software Foundation
 gives unlimited permission to copy, distribute and modify it."
 srcdir=$srcdir
@@ -8997,13 +19455,6 @@
   "Makefile" ) CONFIG_FILES="$CONFIG_FILES Makefile" ;;
   "com/Makefile" ) CONFIG_FILES="$CONFIG_FILES com/Makefile" ;;
   "Docs/Makefile" ) CONFIG_FILES="$CONFIG_FILES Docs/Makefile" ;;
-  "Docs/doc_src/Makefile" ) CONFIG_FILES="$CONFIG_FILES Docs/doc_src/Makefile" ;;
-  "Docs/doc_src/group_and_page_definitions/Makefile" ) CONFIG_FILES="$CONFIG_FILES Docs/doc_src/group_and_page_definitions/Makefile" ;;
-  "Docs/doc_src/headers_and_footers/Makefile" ) CONFIG_FILES="$CONFIG_FILES Docs/doc_src/headers_and_footers/Makefile" ;;
-  "Docs/doc_src/headers_and_footers/MySQL/Makefile" ) CONFIG_FILES="$CONFIG_FILES Docs/doc_src/headers_and_footers/MySQL/Makefile" ;;
-  "Docs/doc_src/headers_and_footers/ODBC/Makefile" ) CONFIG_FILES="$CONFIG_FILES Docs/doc_src/headers_and_footers/ODBC/Makefile" ;;
-  "Docs/doc_src/group_and_page_definitions/MySQL/Makefile" ) CONFIG_FILES="$CONFIG_FILES Docs/doc_src/group_and_page_definitions/MySQL/Makefile" ;;
-  "Docs/doc_src/group_and_page_definitions/ODBC/Makefile" ) CONFIG_FILES="$CONFIG_FILES Docs/doc_src/group_and_page_definitions/ODBC/Makefile" ;;
   "Inc/Makefile" ) CONFIG_FILES="$CONFIG_FILES Inc/Makefile" ;;
   "Nls/Makefile" ) CONFIG_FILES="$CONFIG_FILES Nls/Makefile" ;;
   "Src/Makefile" ) CONFIG_FILES="$CONFIG_FILES Src/Makefile" ;;
@@ -9023,8 +19474,8 @@
   "Src/Gdbi/Makefile" ) CONFIG_FILES="$CONFIG_FILES Src/Gdbi/Makefile" ;;
   "Src/Geometry/Makefile" ) CONFIG_FILES="$CONFIG_FILES Src/Geometry/Makefile" ;;
   "Src/Geometry/Fgf/Makefile" ) CONFIG_FILES="$CONFIG_FILES Src/Geometry/Fgf/Makefile" ;;
+  "Src/LongTransactionManager/Makefile" ) CONFIG_FILES="$CONFIG_FILES Src/LongTransactionManager/Makefile" ;;
   "Src/LockManager/Makefile" ) CONFIG_FILES="$CONFIG_FILES Src/LockManager/Makefile" ;;
-  "Src/LongTransactionManager/Makefile" ) CONFIG_FILES="$CONFIG_FILES Src/LongTransactionManager/Makefile" ;;
   "Src/MySQL/Makefile" ) CONFIG_FILES="$CONFIG_FILES Src/MySQL/Makefile" ;;
   "Src/MySQL/Driver/Makefile" ) CONFIG_FILES="$CONFIG_FILES Src/MySQL/Driver/Makefile" ;;
   "Src/MySQL/Fdo/Makefile" ) CONFIG_FILES="$CONFIG_FILES Src/MySQL/Fdo/Makefile" ;;
@@ -9040,6 +19491,9 @@
   "Src/SchemaMgr/Ph/Makefile" ) CONFIG_FILES="$CONFIG_FILES Src/SchemaMgr/Ph/Makefile" ;;
   "Src/SchemaMgr/Ph/Cfg/Makefile" ) CONFIG_FILES="$CONFIG_FILES Src/SchemaMgr/Ph/Cfg/Makefile" ;;
   "Src/SchemaMgr/Ph/Rd/Makefile" ) CONFIG_FILES="$CONFIG_FILES Src/SchemaMgr/Ph/Rd/Makefile" ;;
+  "Src/UnitTest/Common/Makefile" ) CONFIG_FILES="$CONFIG_FILES Src/UnitTest/Common/Makefile" ;;
+  "Src/UnitTest/MySql/Makefile" ) CONFIG_FILES="$CONFIG_FILES Src/UnitTest/MySql/Makefile" ;;
+  "Src/UnitTest/Makefile" ) CONFIG_FILES="$CONFIG_FILES Src/UnitTest/Makefile" ;;
   "Src/Util/Makefile" ) CONFIG_FILES="$CONFIG_FILES Src/Util/Makefile" ;;
   "Src/ODBCDriver/Makefile" ) CONFIG_FILES="$CONFIG_FILES Src/ODBCDriver/Makefile" ;;
   "Src/ODBC/Makefile" ) CONFIG_FILES="$CONFIG_FILES Src/ODBC/Makefile" ;;
@@ -9049,10 +19503,14 @@
   "Src/ODBC/SchemaMgr/Ov/Makefile" ) CONFIG_FILES="$CONFIG_FILES Src/ODBC/SchemaMgr/Ov/Makefile" ;;
   "Src/ODBC/SchemaMgr/Ph/Makefile" ) CONFIG_FILES="$CONFIG_FILES Src/ODBC/SchemaMgr/Ph/Makefile" ;;
   "Src/ODBC/SchemaMgr/Ph/Rd/Makefile" ) CONFIG_FILES="$CONFIG_FILES Src/ODBC/SchemaMgr/Ph/Rd/Makefile" ;;
-  "Src/UnitTest/Common/Makefile" ) CONFIG_FILES="$CONFIG_FILES Src/UnitTest/Common/Makefile" ;;
-  "Src/UnitTest/MySql/Makefile" ) CONFIG_FILES="$CONFIG_FILES Src/UnitTest/MySql/Makefile" ;;
   "Src/UnitTest/Odbc/Makefile" ) CONFIG_FILES="$CONFIG_FILES Src/UnitTest/Odbc/Makefile" ;;
-  "Src/UnitTest/Makefile" ) CONFIG_FILES="$CONFIG_FILES Src/UnitTest/Makefile" ;;
+  "Docs/doc_src/Makefile" ) CONFIG_FILES="$CONFIG_FILES Docs/doc_src/Makefile" ;;
+  "Docs/doc_src/group_and_page_definitions/Makefile" ) CONFIG_FILES="$CONFIG_FILES Docs/doc_src/group_and_page_definitions/Makefile" ;;
+  "Docs/doc_src/headers_and_footers/Makefile" ) CONFIG_FILES="$CONFIG_FILES Docs/doc_src/headers_and_footers/Makefile" ;;
+  "Docs/doc_src/headers_and_footers/MySQL/Makefile" ) CONFIG_FILES="$CONFIG_FILES Docs/doc_src/headers_and_footers/MySQL/Makefile" ;;
+  "Docs/doc_src/headers_and_footers/ODBC/Makefile" ) CONFIG_FILES="$CONFIG_FILES Docs/doc_src/headers_and_footers/ODBC/Makefile" ;;
+  "Docs/doc_src/group_and_page_definitions/MySQL/Makefile" ) CONFIG_FILES="$CONFIG_FILES Docs/doc_src/group_and_page_definitions/MySQL/Makefile" ;;
+  "Docs/doc_src/group_and_page_definitions/ODBC/Makefile" ) CONFIG_FILES="$CONFIG_FILES Docs/doc_src/group_and_page_definitions/ODBC/Makefile" ;;
   "depfiles" ) CONFIG_COMMANDS="$CONFIG_COMMANDS depfiles" ;;
   *) { { echo "$as_me:$LINENO: error: invalid argument: $ac_config_target" >&5
 echo "$as_me: error: invalid argument: $ac_config_target" >&2;}
@@ -9141,6 +19599,7 @@
 s, at INSTALL_PROGRAM@,$INSTALL_PROGRAM,;t t
 s, at INSTALL_SCRIPT@,$INSTALL_SCRIPT,;t t
 s, at INSTALL_DATA@,$INSTALL_DATA,;t t
+s, at CYGPATH_W@,$CYGPATH_W,;t t
 s, at PACKAGE@,$PACKAGE,;t t
 s, at VERSION@,$VERSION,;t t
 s, at ACLOCAL@,$ACLOCAL,;t t
@@ -9148,13 +19607,17 @@
 s, at AUTOMAKE@,$AUTOMAKE,;t t
 s, at AUTOHEADER@,$AUTOHEADER,;t t
 s, at MAKEINFO@,$MAKEINFO,;t t
-s, at AMTAR@,$AMTAR,;t t
 s, at install_sh@,$install_sh,;t t
 s, at STRIP@,$STRIP,;t t
 s, at ac_ct_STRIP@,$ac_ct_STRIP,;t t
 s, at INSTALL_STRIP_PROGRAM@,$INSTALL_STRIP_PROGRAM,;t t
+s, at mkdir_p@,$mkdir_p,;t t
 s, at AWK@,$AWK,;t t
 s, at SET_MAKE@,$SET_MAKE,;t t
+s, at am__leading_dot@,$am__leading_dot,;t t
+s, at AMTAR@,$AMTAR,;t t
+s, at am__tar@,$am__tar,;t t
+s, at am__untar@,$am__untar,;t t
 s, at CC@,$CC,;t t
 s, at CFLAGS@,$CFLAGS,;t t
 s, at LDFLAGS@,$LDFLAGS,;t t
@@ -9169,10 +19632,14 @@
 s, at AMDEP_FALSE@,$AMDEP_FALSE,;t t
 s, at AMDEPBACKSLASH@,$AMDEPBACKSLASH,;t t
 s, at CCDEPMODE@,$CCDEPMODE,;t t
+s, at am__fastdepCC_TRUE@,$am__fastdepCC_TRUE,;t t
+s, at am__fastdepCC_FALSE@,$am__fastdepCC_FALSE,;t t
 s, at CXX@,$CXX,;t t
 s, at CXXFLAGS@,$CXXFLAGS,;t t
 s, at ac_ct_CXX@,$ac_ct_CXX,;t t
 s, at CXXDEPMODE@,$CXXDEPMODE,;t t
+s, at am__fastdepCXX_TRUE@,$am__fastdepCXX_TRUE,;t t
+s, at am__fastdepCXX_FALSE@,$am__fastdepCXX_FALSE,;t t
 s, at YACC@,$YACC,;t t
 s, at build@,$build,;t t
 s, at build_cpu@,$build_cpu,;t t
@@ -9182,12 +19649,18 @@
 s, at host_cpu@,$host_cpu,;t t
 s, at host_vendor@,$host_vendor,;t t
 s, at host_os@,$host_os,;t t
+s, at EGREP@,$EGREP,;t t
 s, at LN_S@,$LN_S,;t t
 s, at ECHO@,$ECHO,;t t
+s, at AR@,$AR,;t t
+s, at ac_ct_AR@,$ac_ct_AR,;t t
 s, at RANLIB@,$RANLIB,;t t
 s, at ac_ct_RANLIB@,$ac_ct_RANLIB,;t t
+s, at CPP@,$CPP,;t t
 s, at CXXCPP@,$CXXCPP,;t t
-s, at EGREP@,$EGREP,;t t
+s, at F77@,$F77,;t t
+s, at FFLAGS@,$FFLAGS,;t t
+s, at ac_ct_F77@,$ac_ct_F77,;t t
 s, at LIBTOOL@,$LIBTOOL,;t t
 s, at FDO@,$FDO,;t t
 s, at FDOUTILITIES@,$FDOUTILITIES,;t t
@@ -9226,9 +19699,9 @@
       (echo ':t
   /@[a-zA-Z_][a-zA-Z_0-9]*@/!b' && cat $tmp/subs.frag) >$tmp/subs-$ac_sed_frag.sed
       if test -z "$ac_sed_cmds"; then
-  	ac_sed_cmds="sed -f $tmp/subs-$ac_sed_frag.sed"
+	ac_sed_cmds="sed -f $tmp/subs-$ac_sed_frag.sed"
       else
-  	ac_sed_cmds="$ac_sed_cmds | sed -f $tmp/subs-$ac_sed_frag.sed"
+	ac_sed_cmds="$ac_sed_cmds | sed -f $tmp/subs-$ac_sed_frag.sed"
       fi
       ac_sed_frag=`expr $ac_sed_frag + 1`
       ac_beg=$ac_end
@@ -9246,21 +19719,21 @@
   # Support "outfile[:infile[:infile...]]", defaulting infile="outfile.in".
   case $ac_file in
   - | *:- | *:-:* ) # input from stdin
-        cat >$tmp/stdin
-        ac_file_in=`echo "$ac_file" | sed 's,[^:]*:,,'`
-        ac_file=`echo "$ac_file" | sed 's,:.*,,'` ;;
+	cat >$tmp/stdin
+	ac_file_in=`echo "$ac_file" | sed 's,[^:]*:,,'`
+	ac_file=`echo "$ac_file" | sed 's,:.*,,'` ;;
   *:* ) ac_file_in=`echo "$ac_file" | sed 's,[^:]*:,,'`
   * )   ac_file_in=$ac_file.in ;;
   esac
   # Compute @srcdir@, @top_srcdir@, and @INSTALL@ for subdirectories.
   ac_dir=`(dirname "$ac_file") 2>/dev/null ||
 $as_expr X"$ac_file" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
-         X"$ac_file" : 'X\(//\)[^/]' \| \
-         X"$ac_file" : 'X\(//\)$' \| \
-         X"$ac_file" : 'X\(/\)' \| \
-         .     : '\(.\)' 2>/dev/null ||
+	 X"$ac_file" : 'X\(//\)[^/]' \| \
+	 X"$ac_file" : 'X\(//\)$' \| \
+	 X"$ac_file" : 'X\(/\)' \| \
+	 .     : '\(.\)' 2>/dev/null ||
 echo X"$ac_file" |
     sed '/^X\(.*[^/]\)\/\/*[^/][^/]*\/*$/{ s//\1/; q; }
   	  /^X\(\/\/\)[^/].*/{ s//\1/; q; }
@@ -9276,10 +19749,10 @@
       as_dirs="$as_dir $as_dirs"
       as_dir=`(dirname "$as_dir") 2>/dev/null ||
 $as_expr X"$as_dir" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
-         X"$as_dir" : 'X\(//\)[^/]' \| \
-         X"$as_dir" : 'X\(//\)$' \| \
-         X"$as_dir" : 'X\(/\)' \| \
+	 X"$as_dir" : 'X\(//\)[^/]' \| \
+	 X"$as_dir" : 'X\(//\)$' \| \
+	 X"$as_dir" : 'X\(/\)' \| \
 echo X"$as_dir" |
@@ -9317,14 +19790,47 @@
     ac_srcdir=$ac_top_builddir$srcdir$ac_dir_suffix
     ac_top_srcdir=$ac_top_builddir$srcdir ;;
 esac
-# Don't blindly perform a `cd "$ac_dir"/$ac_foo && pwd` since $ac_foo can be
-# absolute.
-ac_abs_builddir=`cd "$ac_dir" && cd $ac_builddir && pwd`
-ac_abs_top_builddir=`cd "$ac_dir" && cd ${ac_top_builddir}. && pwd`
-ac_abs_srcdir=`cd "$ac_dir" && cd $ac_srcdir && pwd`
-ac_abs_top_srcdir=`cd "$ac_dir" && cd $ac_top_srcdir && pwd`
+# Do not use `cd foo && pwd` to compute absolute paths, because
+# the directories may not exist.
+case `pwd` in
+.) ac_abs_builddir="$ac_dir";;
+  case "$ac_dir" in
+  .) ac_abs_builddir=`pwd`;;
+  [\\/]* | ?:[\\/]* ) ac_abs_builddir="$ac_dir";;
+  *) ac_abs_builddir=`pwd`/"$ac_dir";;
+  esac;;
+esac
+case $ac_abs_builddir in
+.) ac_abs_top_builddir=${ac_top_builddir}.;;
+  case ${ac_top_builddir}. in
+  .) ac_abs_top_builddir=$ac_abs_builddir;;
+  [\\/]* | ?:[\\/]* ) ac_abs_top_builddir=${ac_top_builddir}.;;
+  *) ac_abs_top_builddir=$ac_abs_builddir/${ac_top_builddir}.;;
+  esac;;
+esac
+.) ac_abs_srcdir=$ac_srcdir;;
+  case $ac_srcdir in
+  .) ac_abs_srcdir=$ac_abs_builddir;;
+  [\\/]* | ?:[\\/]* ) ac_abs_srcdir=$ac_srcdir;;
+  *) ac_abs_srcdir=$ac_abs_builddir/$ac_srcdir;;
+  esac;;
+esac
+.) ac_abs_top_srcdir=$ac_top_srcdir;;
+  case $ac_top_srcdir in
+  .) ac_abs_top_srcdir=$ac_abs_builddir;;
+  [\\/]* | ?:[\\/]* ) ac_abs_top_srcdir=$ac_top_srcdir;;
+  *) ac_abs_top_srcdir=$ac_abs_builddir/$ac_top_srcdir;;
+  esac;;
+esac
   case $INSTALL in
   [\\/$]* | ?:[\\/]* ) ac_INSTALL=$INSTALL ;;
   *) ac_INSTALL=$ac_top_builddir$INSTALL ;;
@@ -9344,7 +19850,7 @@
     configure_input="$ac_file.  "
   fi
   configure_input=$configure_input"Generated from `echo $ac_file_in |
-                                     sed 's,.*/,,'` by configure."
+				     sed 's,.*/,,'` by configure."
   # First look for the input files in the build tree, otherwise in the
   # src tree.
@@ -9353,24 +19859,24 @@
       case $f in
       -) echo $tmp/stdin ;;
-         # Absolute (can't be DOS-style, as IFS=:)
-         test -f "$f" || { { echo "$as_me:$LINENO: error: cannot find input file: $f" >&5
+	 # Absolute (can't be DOS-style, as IFS=:)
+	 test -f "$f" || { { echo "$as_me:$LINENO: error: cannot find input file: $f" >&5
 echo "$as_me: error: cannot find input file: $f" >&2;}
-         echo $f;;
+	 echo "$f";;
       *) # Relative
-         if test -f "$f"; then
-           # Build tree
-           echo $f
-         elif test -f "$srcdir/$f"; then
-           # Source tree
-           echo $srcdir/$f
-         else
-           # /dev/null tree
-           { { echo "$as_me:$LINENO: error: cannot find input file: $f" >&5
+	 if test -f "$f"; then
+	   # Build tree
+	   echo "$f"
+	 elif test -f "$srcdir/$f"; then
+	   # Source tree
+	   echo "$srcdir/$f"
+	 else
+	   # /dev/null tree
+	   { { echo "$as_me:$LINENO: error: cannot find input file: $f" >&5
-         fi;;
+	 fi;;
       esac
     done` || { (exit 1); exit 1; }
 _ACEOF
@@ -9412,16 +19918,41 @@
   ac_source=`echo "$ac_file" | sed 's,[^:]*:,,'`
   ac_dir=`(dirname "$ac_dest") 2>/dev/null ||
 $as_expr X"$ac_dest" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
-         X"$ac_dest" : 'X\(//\)[^/]' \| \
-         X"$ac_dest" : 'X\(//\)$' \| \
-         X"$ac_dest" : 'X\(/\)' \| \
+	 X"$ac_dest" : 'X\(//\)[^/]' \| \
+	 X"$ac_dest" : 'X\(//\)$' \| \
+	 X"$ac_dest" : 'X\(/\)' \| \
 echo X"$ac_dest" |
   	  /^X\(\/\/\)$/{ s//\1/; q; }
   	  /^X\(\/\).*/{ s//\1/; q; }
   	  s/.*/./; q'`
+  { if $as_mkdir_p; then
+    mkdir -p "$ac_dir"
+  else
+    as_dir="$ac_dir"
+    as_dirs=
+    while test ! -d "$as_dir"; do
+      as_dirs="$as_dir $as_dirs"
+      as_dir=`(dirname "$as_dir") 2>/dev/null ||
+$as_expr X"$as_dir" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
+echo X"$as_dir" |
+    sed '/^X\(.*[^/]\)\/\/*[^/][^/]*\/*$/{ s//\1/; q; }
+  	  /^X\(\/\/\)[^/].*/{ s//\1/; q; }
+  	  /^X\(\/\/\)$/{ s//\1/; q; }
+  	  /^X\(\/\).*/{ s//\1/; q; }
+  	  s/.*/./; q'`
+    done
+    test ! -n "$as_dirs" || mkdir $as_dirs
+  fi || { { echo "$as_me:$LINENO: error: cannot create directory \"$ac_dir\"" >&5
+echo "$as_me: error: cannot create directory \"$ac_dir\"" >&2;}
+   { (exit 1); exit 1; }; }; }
   ac_builddir=.
 if test "$ac_dir" != .; then
@@ -9447,14 +19978,47 @@
 esac
-# absolute.
+case `pwd` in
+  case "$ac_dir" in
+  esac;;
+esac
+  esac;;
+esac
+  esac;;
+esac
+  esac;;
+esac
   { echo "$as_me:$LINENO: executing $ac_dest commands" >&5
 echo "$as_me: executing $ac_dest commands" >&6;}
   case $ac_dest in
@@ -9470,10 +20034,10 @@
   if grep '^#.*generated by automake' $mf > /dev/null 2>&1; then
     dirpart=`(dirname "$mf") 2>/dev/null ||
 $as_expr X"$mf" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
-         X"$mf" : 'X\(//\)[^/]' \| \
-         X"$mf" : 'X\(//\)$' \| \
-         X"$mf" : 'X\(/\)' \| \
+	 X"$mf" : 'X\(//\)[^/]' \| \
+	 X"$mf" : 'X\(//\)$' \| \
+	 X"$mf" : 'X\(/\)' \| \
 echo X"$mf" |
@@ -9483,36 +20047,30 @@
   else
     continue
   fi
-  grep '^DEP_FILES *= *[^ #]' < "$mf" > /dev/null || continue
-  # Extract the definition of DEP_FILES from the Makefile without
-  # running `make'.
-  DEPDIR=`sed -n -e '/^DEPDIR = / s///p' < "$mf"`
+  # Extract the definition of DEPDIR, am__include, and am__quote
+  # from the Makefile without running `make'.
+  DEPDIR=`sed -n 's/^DEPDIR = //p' < "$mf"`
   test -z "$DEPDIR" && continue
+  am__include=`sed -n 's/^am__include = //p' < "$mf"`
+  test -z "am__include" && continue
+  am__quote=`sed -n 's/^am__quote = //p' < "$mf"`
   # When using ansi2knr, U may be empty or an underscore; expand it
-  U=`sed -n -e '/^U = / s///p' < "$mf"`
-  test -d "$dirpart/$DEPDIR" || mkdir "$dirpart/$DEPDIR"
-  # We invoke sed twice because it is the simplest approach to
-  # changing $(DEPDIR) to its actual value in the expansion.
-  for file in `sed -n -e '
-    /^DEP_FILES = .*\\\\$/ {
-      s/^DEP_FILES = //
-      :loop
-	s/\\\\$//
-	p
-	n
-	/\\\\$/ b loop
-      p
-    /^DEP_FILES = / s/^DEP_FILES = //p' < "$mf" | \
+  U=`sed -n 's/^U = //p' < "$mf"`
+  # Find all dependency output files, they are included files with
+  # $(DEPDIR) in their names.  We invoke sed twice because it is the
+  # simplest approach to changing $(DEPDIR) to its actual value in the
+  # expansion.
+  for file in `sed -n "
+    s/^$am__include $am__quote\(.*(DEPDIR).*\)$am__quote"'$/\1/p' <"$mf" | \
        sed -e 's/\$(DEPDIR)/'"$DEPDIR"'/g' -e 's/\$U/'"$U"'/g'`; do
     # Make sure the directory exists.
     test -f "$dirpart/$file" && continue
     fdir=`(dirname "$file") 2>/dev/null ||
 $as_expr X"$file" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
-         X"$file" : 'X\(//\)[^/]' \| \
-         X"$file" : 'X\(//\)$' \| \
-         X"$file" : 'X\(/\)' \| \
+	 X"$file" : 'X\(//\)[^/]' \| \
+	 X"$file" : 'X\(//\)$' \| \
+	 X"$file" : 'X\(/\)' \| \
 echo X"$file" |
@@ -9528,10 +20086,10 @@
 echo X"$as_dir" |
Modified: trunk/Providers/GenericRdbms/configure.in
--- trunk/Providers/GenericRdbms/configure.in	2007-02-09 23:08:35 UTC (rev 2460)
+++ trunk/Providers/GenericRdbms/configure.in	2007-02-09 23:09:01 UTC (rev 2461)
@@ -21,7 +21,7 @@
 # Variables
 # Following are the makefile directories
-AC_INIT(FDORDBMS,3.2.0,http://www.fdo.osgeo.org)
+AC_INIT(FDORDBMS,3.3.0,http://www.fdo.osgeo.org)
 AC_CONFIG_SRCDIR(configure.in)
 AM_INIT_AUTOMAKE
@@ -35,10 +35,10 @@
 AC_DISABLE_STATIC
 AM_PROG_LIBTOOL
-AC_SUBST(VERSION, "3.2.0")
+AC_SUBST(VERSION, "3.3.0")
 dnl *******************************************************
-dnl FDO 3.2.0 Configuration
+dnl FDO 3.3.0 Configuration
 dnl FDO / FDO Utilities / FDO Thirdpary paths
More information about the fdo-commits
