[fdo-commits] r2463 - trunk/Providers/SHP
svn_fdo at osgeo.org
Fri Feb 9 18:10:00 EST 2007
Author: gregboone
Date: 2007-02-09 18:09:59 -0500 (Fri, 09 Feb 2007)
New Revision: 2463
trunk/Providers/SHP/configure
trunk/Providers/SHP/configure.in
Update FDO 3.3 build scripts
Modified: trunk/Providers/SHP/configure
--- trunk/Providers/SHP/configure 2007-02-09 23:09:32 UTC (rev 2462)
+++ trunk/Providers/SHP/configure 2007-02-09 23:09:59 UTC (rev 2463)
@@ -1,11 +1,10 @@
#! /bin/sh
# Guess values for system-dependent variables and create Makefiles.
-# Generated by GNU Autoconf 2.57 for FDOSHP 3.2.0.
+# Generated by GNU Autoconf 2.59 for FDOSHP 3.3.0.
# Report bugs to <http://www.fdo.osgeo.org>.
-# Copyright 1992, 1993, 1994, 1995, 1996, 1998, 1999, 2000, 2001, 2002
-# Free Software Foundation, Inc.
+# Copyright (C) 2003 Free Software Foundation, Inc.
# This configure script is free software; the Free Software Foundation
# gives unlimited permission to copy, distribute and modify it.
@@ -22,9 +21,10 @@
elif test -n "${BASH_VERSION+set}" && (set -o posix) >/dev/null 2>&1; then
set -o posix
fi
+DUALCASE=1; export DUALCASE # for MKS sh
# Support unset when possible.
-if (FOO=FOO; unset FOO) >/dev/null 2>&1; then
+if ( (MAIL=60; unset MAIL) || exit) >/dev/null 2>&1; then
as_unset=unset
else
as_unset=false
@@ -43,7 +43,7 @@
LC_MEASUREMENT LC_MESSAGES LC_MONETARY LC_NAME LC_NUMERIC LC_PAPER \
LC_TELEPHONE LC_TIME
do
- if (set +x; test -n "`(eval $as_var=C; export $as_var) 2>&1`"); then
+ if (set +x; test -z "`(eval $as_var=C; export $as_var) 2>&1`"); then
else
$as_unset $as_var
@@ -220,16 +220,17 @@
if mkdir -p . 2>/dev/null; then
as_mkdir_p=:
else
+ test -d ./-p && rmdir ./-p
as_mkdir_p=false
fi
as_executable_p="test -f"
# Sed expression to map a string onto a valid CPP name.
-as_tr_cpp="sed y%*$as_cr_letters%P$as_cr_LETTERS%;s%[^_$as_cr_alnum]%_%g"
+as_tr_cpp="eval sed 'y%*$as_cr_letters%P$as_cr_LETTERS%;s%[^_$as_cr_alnum]%_%g'"
# Sed expression to map a string onto a valid variable name.
-as_tr_sh="sed y%*+%pp%;s%[^_$as_cr_alnum]%_%g"
+as_tr_sh="eval sed 'y%*+%pp%;s%[^_$as_cr_alnum]%_%g'"
# IFS
@@ -242,18 +243,7 @@
$as_unset CDPATH
-# Find the correct PATH separator. Usually this is `:', but
-# DJGPP uses `;' like DOS.
-if test "X${PATH_SEPARATOR+set}" != Xset; then
- UNAME=${UNAME-`uname 2>/dev/null`}
- case X$UNAME in
- *-DOS) lt_cv_sys_path_separator=';' ;;
- *) lt_cv_sys_path_separator=':' ;;
- esac
- PATH_SEPARATOR=$lt_cv_sys_path_separator
-fi
# Check that we are running under the correct shell.
SHELL=${CONFIG_SHELL-/bin/sh}
@@ -271,7 +261,7 @@
elif test "X$1" = X--fallback-echo; then
# Avoid inline document here, it may be left over
-elif test "X`($echo '\t') 2>/dev/null`" = 'X\t'; then
+elif test "X`($echo '\t') 2>/dev/null`" = 'X\t' ; then
# Yippee, $echo works!
else
@@ -283,22 +273,22 @@
# used as fallback echo
shift
cat <<EOF
EOF
exit 0
fi
# The HP-UX ksh and POSIX shell print the target directory to stdout
# if CDPATH is set.
-if test "X${CDPATH+set}" = Xset; then CDPATH=:; export CDPATH; fi
+(unset CDPATH) >/dev/null 2>&1 && unset CDPATH
if test -z "$ECHO"; then
if test "X${echo_test_string+set}" != Xset; then
# find a string as large as possible, as long as the shell can cope with it
for cmd in 'sed 50q "$0"' 'sed 20q "$0"' 'sed 10q "$0"' 'sed 2q "$0"' 'echo test'; do
# expected sizes: less than 2Kb, 1Kb, 512 bytes, 16 bytes, ...
- if (echo_test_string="`eval $cmd`") 2>/dev/null &&
- echo_test_string="`eval $cmd`" &&
+ if (echo_test_string=`eval $cmd`) 2>/dev/null &&
+ echo_test_string=`eval $cmd` &&
(test "X$echo_test_string" = "X$echo_test_string") 2>/dev/null
then
break
@@ -317,8 +307,9 @@
# So, first we look for a working echo in the user's PATH.
- IFS="${IFS= }"; save_ifs="$IFS"; IFS=$PATH_SEPARATOR
+ lt_save_ifs="$IFS"; IFS=$PATH_SEPARATOR
for dir in $PATH /usr/ucb; do
+ IFS="$lt_save_ifs"
if (test -f $dir/echo || test -f $dir/echo$ac_exeext) &&
test "X`($dir/echo '\t') 2>/dev/null`" = 'X\t' &&
echo_testing_string=`($dir/echo "$echo_test_string") 2>/dev/null` &&
@@ -327,7 +318,7 @@
break
fi
done
- IFS="$save_ifs"
if test "X$echo" = Xecho; then
# We didn't find a better echo, so look for alternatives.
@@ -401,6 +392,11 @@
+tagnames=${tagnames+${tagnames},}CXX
+tagnames=${tagnames+${tagnames},}F77
# Name of the host.
# hostname on some systems (SVR3.2, Linux) returns a bogus exit status,
# so uname gets run too.
@@ -427,8 +423,8 @@
# Identity of this package.
PACKAGE_NAME='FDOSHP'
PACKAGE_TARNAME='fdoshp'
-PACKAGE_VERSION='3.2.0'
-PACKAGE_STRING='FDOSHP 3.2.0'
+PACKAGE_VERSION='3.3.0'
+PACKAGE_STRING='FDOSHP 3.3.0'
PACKAGE_BUGREPORT='http://www.fdo.osgeo.org'
ac_unique_file="configure.in"
@@ -470,7 +466,7 @@
# include <unistd.h>
#endif"
-ac_subst_vars='SHELL PATH_SEPARATOR PACKAGE_NAME PACKAGE_TARNAME PACKAGE_VERSION PACKAGE_STRING PACKAGE_BUGREPORT exec_prefix prefix program_transform_name bindir sbindir libexecdir datadir sysconfdir sharedstatedir localstatedir libdir includedir oldincludedir infodir mandir build_alias host_alias target_alias DEFS ECHO_C ECHO_N ECHO_T LIBS INSTALL_PROGRAM INSTALL_SCRIPT INSTALL_DATA PACKAGE VERSION ACLOCAL AUTOCONF AUTOMAKE AUTOHEADER MAKEINFO AMTAR install_sh STRIP ac_ct_STRIP INSTALL_STRIP_PROGRAM AWK SET_MAKE CC CFLAGS LDFLAGS CPPFLAGS ac_ct_CC EXEEXT OBJEXT DEPDIR am__include am__quote AMDEP_TRUE AMDEP_FALSE AMDEPBACKSLASH CCDEPMODE CXX CXXFLAGS ac_ct_CXX CXXDEPMODE YACC build build_cpu build_vendor build_os host host_cpu host_vendor host_os LN_S ECHO RANLIB ac_ct_RANLIB CXXCPP EGREP LIBTOOL FDO FDOUTILITIES FDOTHIRDPARTY CXXFLAGS_SDF LIBOBJS LTLIBOBJS'
+ac_subst_vars='SHELL PATH_SEPARATOR PACKAGE_NAME PACKAGE_TARNAME PACKAGE_VERSION PACKAGE_STRING PACKAGE_BUGREPORT exec_prefix prefix program_transform_name bindir sbindir libexecdir datadir sysconfdir sharedstatedir localstatedir libdir includedir oldincludedir infodir mandir build_alias host_alias target_alias DEFS ECHO_C ECHO_N ECHO_T LIBS INSTALL_PROGRAM INSTALL_SCRIPT INSTALL_DATA CYGPATH_W PACKAGE VERSION ACLOCAL AUTOCONF AUTOMAKE AUTOHEADER MAKEINFO install_sh STRIP ac_ct_STRIP INSTALL_STRIP_PROGRAM mkdir_p AWK SET_MAKE am__leading_dot AMTAR am__tar am__untar CC CFLAGS LDFLAGS CPPFLAGS ac_ct_CC EXEEXT OBJEXT DEPDIR am__include am__quote AMDEP_TRUE AMDEP_FALSE AMDEPBACKSLASH CCDEPMODE am__fastdepCC_TRUE am__fastdepCC_FALSE CXX CXXFLAGS ac_ct_CXX CXXDEPMODE am__fastdepCXX_TRUE am__fastdepCXX_FALSE YACC build build_cpu build_vendor build_os host host_cpu host_vendor host_os EGREP LN_S ECHO AR ac_ct_AR RANLIB ac_ct_RANLIB CPP CXXCPP F77 FFLAGS ac_ct_F77 LIBTOOL FDO FDOUTILITIES FDOTHIRDPARTY CXXFLAGS_SDF LIBOBJS LTLIBOBJS'
ac_subst_files=''
# Initialize some variables set by options.
@@ -829,7 +825,7 @@
# Be sure to have absolute paths.
for ac_var in bindir sbindir libexecdir datadir sysconfdir sharedstatedir \
- localstatedir libdir includedir oldincludedir infodir mandir
+ localstatedir libdir includedir oldincludedir infodir mandir
do
eval ac_val=$`echo $ac_var`
case $ac_val in
@@ -869,10 +865,10 @@
# Try the directory containing this script, then its parent.
ac_confdir=`(dirname "$0") 2>/dev/null ||
$as_expr X"$0" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
- X"$0" : 'X\(//\)[^/]' \| \
- X"$0" : 'X\(//\)$' \| \
- X"$0" : 'X\(/\)' \| \
- . : '\(.\)' 2>/dev/null ||
+ X"$0" : 'X\(//\)[^/]' \| \
+ X"$0" : 'X\(//\)$' \| \
+ X"$0" : 'X\(/\)' \| \
+ . : '\(.\)' 2>/dev/null ||
echo X"$0" |
sed '/^X\(.*[^/]\)\/\/*[^/][^/]*\/*$/{ s//\1/; q; }
/^X\(\/\/\)[^/].*/{ s//\1/; q; }
@@ -935,10 +931,22 @@
ac_env_CXXFLAGS_value=$CXXFLAGS
ac_cv_env_CXXFLAGS_set=${CXXFLAGS+set}
ac_cv_env_CXXFLAGS_value=$CXXFLAGS
+ac_env_CPP_set=${CPP+set}
+ac_env_CPP_value=$CPP
+ac_cv_env_CPP_set=${CPP+set}
+ac_cv_env_CPP_value=$CPP
ac_env_CXXCPP_set=${CXXCPP+set}
ac_env_CXXCPP_value=$CXXCPP
ac_cv_env_CXXCPP_set=${CXXCPP+set}
ac_cv_env_CXXCPP_value=$CXXCPP
+ac_env_F77_set=${F77+set}
+ac_env_F77_value=$F77
+ac_cv_env_F77_set=${F77+set}
+ac_cv_env_F77_value=$F77
+ac_env_FFLAGS_set=${FFLAGS+set}
+ac_env_FFLAGS_value=$FFLAGS
+ac_cv_env_FFLAGS_set=${FFLAGS+set}
+ac_cv_env_FFLAGS_value=$FFLAGS
# Report the --help message.
@@ -947,7 +955,7 @@
# Omit some internal or obsolete options to make the list less imposing.
# This message is too long to be a string in the A/UX 3.1 sh.
cat <<_ACEOF
-\`configure' configures FDOSHP 3.2.0 to adapt to many kinds of systems.
+\`configure' configures FDOSHP 3.3.0 to adapt to many kinds of systems.
Usage: $0 [OPTION]... [VAR=VALUE]...
@@ -972,9 +980,9 @@
cat <<_ACEOF
Installation directories:
--prefix=PREFIX install architecture-independent files in PREFIX
- [$ac_default_prefix]
+ [$ac_default_prefix]
--exec-prefix=EPREFIX install architecture-dependent files in EPREFIX
- [PREFIX]
+ [PREFIX]
By default, \`make install' will install all the files in
\`$ac_default_prefix/bin', \`$ac_default_prefix/lib' etc. You can specify
@@ -1013,18 +1021,21 @@
if test -n "$ac_init_help"; then
case $ac_init_help in
- short | recursive ) echo "Configuration of FDOSHP 3.2.0:";;
+ short | recursive ) echo "Configuration of FDOSHP 3.3.0:";;
esac
cat <<\_ACEOF
Optional Features:
--disable-FEATURE do not include FEATURE (same as --enable-FEATURE=no)
--enable-FEATURE[=ARG] include FEATURE [ARG=yes]
- --disable-dependency-tracking Speeds up one-time builds
- --enable-dependency-tracking Do not reject slow dependency extractors
- --enable-static=PKGS build static libraries default=no
- --enable-shared=PKGS build shared libraries default=yes
- --enable-fast-install=PKGS optimize for fast installation default=yes
+ --disable-dependency-tracking speeds up one-time build
+ --enable-dependency-tracking do not reject slow dependency extractors
+ --enable-static[=PKGS]
+ build static libraries [default=no]
+ --enable-shared[=PKGS]
+ build shared libraries [default=yes]
+ --enable-fast-install[=PKGS]
+ optimize for fast installation [default=yes]
--disable-libtool-lock avoid locking (might break parallel builds)
MAP_HELP_STRING(--enable-debug,
enable debug build [default=no])
@@ -1032,8 +1043,11 @@
Optional Packages:
--with-PACKAGE[=ARG] use PACKAGE [ARG=yes]
--without-PACKAGE do not use PACKAGE (same as --with-PACKAGE=no)
- --with-gnu-ld assume the C compiler uses GNU ld default=no
- --with-pic try to use only PIC/non-PIC objects default=use both
+ --with-gnu-ld assume the C compiler uses GNU ld [default=no]
+ --with-pic try to use only PIC/non-PIC objects [default=use
+ both]
+ --with-tags[=TAGS]
+ include additional configurations [automatic]
--with-fdo specifies directory for FDO API files
default=DEFAULT
--with-fdo-utilities specifies directory for FDO API Utility files
@@ -1050,7 +1064,10 @@
headers in a nonstandard directory <include dir>
CXX C++ compiler command
CXXFLAGS C++ compiler flags
+ CPP C preprocessor
CXXCPP C++ preprocessor
+ F77 Fortran 77 compiler command
+ FFLAGS Fortran 77 compiler flags
Use these variables to override the choices made by `configure' or to help
it to find libraries and programs with nonstandard names/locations.
@@ -1089,13 +1106,46 @@
ac_srcdir=$ac_top_builddir$srcdir$ac_dir_suffix
ac_top_srcdir=$ac_top_builddir$srcdir ;;
esac
-# Don't blindly perform a `cd "$ac_dir"/$ac_foo && pwd` since $ac_foo can be
-# absolute.
-ac_abs_builddir=`cd "$ac_dir" && cd $ac_builddir && pwd`
-ac_abs_top_builddir=`cd "$ac_dir" && cd ${ac_top_builddir}. && pwd`
-ac_abs_srcdir=`cd "$ac_dir" && cd $ac_srcdir && pwd`
-ac_abs_top_srcdir=`cd "$ac_dir" && cd $ac_top_srcdir && pwd`
+# Do not use `cd foo && pwd` to compute absolute paths, because
+# the directories may not exist.
+case `pwd` in
+.) ac_abs_builddir="$ac_dir";;
+ case "$ac_dir" in
+ .) ac_abs_builddir=`pwd`;;
+ [\\/]* | ?:[\\/]* ) ac_abs_builddir="$ac_dir";;
+ *) ac_abs_builddir=`pwd`/"$ac_dir";;
+ esac;;
+esac
+case $ac_abs_builddir in
+.) ac_abs_top_builddir=${ac_top_builddir}.;;
+ case ${ac_top_builddir}. in
+ .) ac_abs_top_builddir=$ac_abs_builddir;;
+ [\\/]* | ?:[\\/]* ) ac_abs_top_builddir=${ac_top_builddir}.;;
+ *) ac_abs_top_builddir=$ac_abs_builddir/${ac_top_builddir}.;;
+ esac;;
+esac
+.) ac_abs_srcdir=$ac_srcdir;;
+ case $ac_srcdir in
+ .) ac_abs_srcdir=$ac_abs_builddir;;
+ [\\/]* | ?:[\\/]* ) ac_abs_srcdir=$ac_srcdir;;
+ *) ac_abs_srcdir=$ac_abs_builddir/$ac_srcdir;;
+ esac;;
+esac
+.) ac_abs_top_srcdir=$ac_top_srcdir;;
+ case $ac_top_srcdir in
+ .) ac_abs_top_srcdir=$ac_abs_builddir;;
+ [\\/]* | ?:[\\/]* ) ac_abs_top_srcdir=$ac_top_srcdir;;
+ *) ac_abs_top_srcdir=$ac_abs_builddir/$ac_top_srcdir;;
+ esac;;
+esac
cd $ac_dir
# Check for guested configure; otherwise get Cygnus style configure.
if test -f $ac_srcdir/configure.gnu; then
@@ -1105,7 +1155,7 @@
echo
$SHELL $ac_srcdir/configure --help=recursive
elif test -f $ac_srcdir/configure.ac ||
- test -f $ac_srcdir/configure.in; then
+ test -f $ac_srcdir/configure.in; then
echo
$ac_configure --help
else
@@ -1118,11 +1168,10 @@
test -n "$ac_init_help" && exit 0
if $ac_init_version; then
cat <<\_ACEOF
-FDOSHP configure 3.2.0
-generated by GNU Autoconf 2.57
+FDOSHP configure 3.3.0
+generated by GNU Autoconf 2.59
-Copyright 1992, 1993, 1994, 1995, 1996, 1998, 1999, 2000, 2001, 2002
-Free Software Foundation, Inc.
+Copyright (C) 2003 Free Software Foundation, Inc.
_ACEOF
@@ -1133,8 +1182,8 @@
This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
-It was created by FDOSHP $as_me 3.2.0, which was
-generated by GNU Autoconf 2.57. Invocation command line was
+It was created by FDOSHP $as_me 3.3.0, which was
+generated by GNU Autoconf 2.59. Invocation command line was
$ $0 $@
@@ -1211,19 +1260,19 @@
2)
ac_configure_args1="$ac_configure_args1 '$ac_arg'"
if test $ac_must_keep_next = true; then
- ac_must_keep_next=false # Got value, back to normal.
+ ac_must_keep_next=false # Got value, back to normal.
else
- case $ac_arg in
- *=* | --config-cache | -C | -disable-* | --disable-* \
- | -enable-* | --enable-* | -gas | --g* | -nfp | --nf* \
- | -q | -quiet | --q* | -silent | --sil* | -v | -verb* \
- | -with-* | --with-* | -without-* | --without-* | --x)
- case "$ac_configure_args0 " in
- "$ac_configure_args1"*" '$ac_arg' "* ) continue ;;
- esac
- -* ) ac_must_keep_next=true ;;
- esac
+ case $ac_arg in
+ *=* | --config-cache | -C | -disable-* | --disable-* \
+ | -enable-* | --enable-* | -gas | --g* | -nfp | --nf* \
+ | -q | -quiet | --q* | -silent | --sil* | -v | -verb* \
+ | -with-* | --with-* | -without-* | --without-* | --x)
+ case "$ac_configure_args0 " in
+ "$ac_configure_args1"*" '$ac_arg' "* ) continue ;;
+ esac
+ -* ) ac_must_keep_next=true ;;
+ esac
fi
ac_configure_args="$ac_configure_args$ac_sep'$ac_arg'"
# Get rid of the leading space.
@@ -1257,12 +1306,12 @@
case `(ac_space='"'"' '"'"'; set | grep ac_space) 2>&1` in
*ac_space=\ *)
sed -n \
- "s/'"'"'/'"'"'\\\\'"'"''"'"'/g;
- s/^\\([_$as_cr_alnum]*_cv_[_$as_cr_alnum]*\\)=\\(.*\\)/\\1='"'"'\\2'"'"'/p"
+ "s/'"'"'/'"'"'\\\\'"'"''"'"'/g;
+ s/^\\([_$as_cr_alnum]*_cv_[_$as_cr_alnum]*\\)=\\(.*\\)/\\1='"'"'\\2'"'"'/p"
sed -n \
- "s/^\\([_$as_cr_alnum]*_cv_[_$as_cr_alnum]*\\)=\\(.*\\)/\\1=\\2/p"
+ "s/^\\([_$as_cr_alnum]*_cv_[_$as_cr_alnum]*\\)=\\(.*\\)/\\1=\\2/p"
esac;
@@ -1291,7 +1340,7 @@
for ac_var in $ac_subst_files
do
- echo "$ac_var='"'"'$ac_val'"'"'"
+ echo "$ac_var='"'"'$ac_val'"'"'"
done | sort
echo
fi
@@ -1310,7 +1359,7 @@
echo "$as_me: caught signal $ac_signal"
echo "$as_me: exit $exit_status"
} >&5
- rm -f core core.* *.core &&
+ rm -f core *.core &&
rm -rf conftest* confdefs* conf$$* $ac_clean_files &&
exit $exit_status
' 0
@@ -1390,7 +1439,7 @@
# value.
ac_cache_corrupted=false
for ac_var in `(set) 2>&1 |
- sed -n 's/^ac_env_\([a-zA-Z_0-9]*\)_set=.*/\1/p'`; do
+ sed -n 's/^ac_env_\([a-zA-Z_0-9]*\)_set=.*/\1/p'`; do
eval ac_old_set=\$ac_cv_env_${ac_var}_set
eval ac_new_set=\$ac_env_${ac_var}_set
eval ac_old_val="\$ac_cv_env_${ac_var}_value"
@@ -1407,13 +1456,13 @@
if test "x$ac_old_val" != "x$ac_new_val"; then
- { echo "$as_me:$LINENO: error: \`$ac_var' has changed since the previous run:" >&5
+ { echo "$as_me:$LINENO: error: \`$ac_var' has changed since the previous run:" >&5
echo "$as_me: error: \`$ac_var' has changed since the previous run:" >&2;}
- { echo "$as_me:$LINENO: former value: $ac_old_val" >&5
+ { echo "$as_me:$LINENO: former value: $ac_old_val" >&5
echo "$as_me: former value: $ac_old_val" >&2;}
- { echo "$as_me:$LINENO: current value: $ac_new_val" >&5
+ { echo "$as_me:$LINENO: current value: $ac_new_val" >&5
echo "$as_me: current value: $ac_new_val" >&2;}
- ac_cache_corrupted=:
+ ac_cache_corrupted=:
fi;;
esac
# Pass precious variables to config.status.
@@ -1470,7 +1519,7 @@
-am__api_version="1.6"
+am__api_version="1.9"
ac_aux_dir=
for ac_dir in $srcdir $srcdir/.. $srcdir/../..; do
if test -f $ac_dir/install-sh; then
@@ -1507,6 +1556,7 @@
# AIX 4 /usr/bin/installbsd, which doesn't work without a -g flag
# AFS /usr/afsws/bin/install, which mishandles nonexistent args
# SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
+# OS/2's system install, which has a completely different semantic
# ./install, which can be erroneously created by make from ./install.sh.
echo "$as_me:$LINENO: checking for a BSD-compatible install" >&5
echo $ECHO_N "checking for a BSD-compatible install... $ECHO_C" >&6
@@ -1523,6 +1573,7 @@
case $as_dir/ in
./ | .// | /cC/* | \
/etc/* | /usr/sbin/* | /usr/etc/* | /sbin/* | /usr/afsws/bin/* | \
+ ?:\\/os2\\/install\\/* | ?:\\/OS2\\/INSTALL\\/* | \
/usr/ucb/* ) ;;
# OSF1 and SCO ODT 3.0 have their own names for install.
@@ -1530,20 +1581,20 @@
# by default.
for ac_prog in ginstall scoinst install; do
for ac_exec_ext in '' $ac_executable_extensions; do
- if $as_executable_p "$as_dir/$ac_prog$ac_exec_ext"; then
- if test $ac_prog = install &&
- grep dspmsg "$as_dir/$ac_prog$ac_exec_ext" >/dev/null 2>&1; then
- # AIX install. It has an incompatible calling convention.
- elif test $ac_prog = install &&
- grep pwplus "$as_dir/$ac_prog$ac_exec_ext" >/dev/null 2>&1; then
- # program-specific install script used by HP pwplus--don't use.
- else
- ac_cv_path_install="$as_dir/$ac_prog$ac_exec_ext -c"
- break 3
- fi
- fi
+ if $as_executable_p "$as_dir/$ac_prog$ac_exec_ext"; then
+ if test $ac_prog = install &&
+ grep dspmsg "$as_dir/$ac_prog$ac_exec_ext" >/dev/null 2>&1; then
+ # AIX install. It has an incompatible calling convention.
+ elif test $ac_prog = install &&
+ grep pwplus "$as_dir/$ac_prog$ac_exec_ext" >/dev/null 2>&1; then
+ # program-specific install script used by HP pwplus--don't use.
+ else
+ ac_cv_path_install="$as_dir/$ac_prog$ac_exec_ext -c"
+ break 3
+ fi
+ fi
done
done
@@ -1631,7 +1682,6 @@
program_transform_name=`echo $program_transform_name | sed -f conftest.sed`
rm conftest.sed
# expand $ac_aux_dir to an absolute path
am_aux_dir=`cd $ac_aux_dir && pwd`
@@ -1645,6 +1695,39 @@
echo "$as_me: WARNING: \`missing' script is too old or missing" >&2;}
fi
+if mkdir -p --version . >/dev/null 2>&1 && test ! -d ./--version; then
+ # We used to keeping the `.' as first argument, in order to
+ # allow $(mkdir_p) to be used without argument. As in
+ # $(mkdir_p) $(somedir)
+ # where $(somedir) is conditionally defined. However this is wrong
+ # for two reasons:
+ # 1. if the package is installed by a user who cannot write `.'
+ # make install will fail,
+ # 2. the above comment should most certainly read
+ # $(mkdir_p) $(DESTDIR)$(somedir)
+ # so it does not work when $(somedir) is undefined and
+ # $(DESTDIR) is not.
+ # To support the latter case, we have to write
+ # test -z "$(somedir)" || $(mkdir_p) $(DESTDIR)$(somedir),
+ # so the `.' trick is pointless.
+ mkdir_p='mkdir -p --'
+else
+ # On NextStep and OpenStep, the `mkdir' command does not
+ # recognize any option. It will interpret all options as
+ # directories to create, and then abort because `.' already
+ # exists.
+ for d in ./-p ./--version;
+ do
+ test -d $d && rmdir $d
+ done
+ # $(mkinstalldirs) is defined by Automake if mkinstalldirs exists.
+ if test -f "$ac_aux_dir/mkinstalldirs"; then
+ mkdir_p='$(mkinstalldirs)'
+ else
+ mkdir_p='$(install_sh) -d'
+ fi
+fi
for ac_prog in gawk mawk nawk awk
do
# Extract the first word of "$ac_prog", so it can be a program name with args.
@@ -1687,7 +1770,7 @@
echo "$as_me:$LINENO: checking whether ${MAKE-make} sets \$(MAKE)" >&5
echo $ECHO_N "checking whether ${MAKE-make} sets \$(MAKE)... $ECHO_C" >&6
-set dummy ${MAKE-make}; ac_make=`echo "$2" | sed 'y,./+-,__p_,'`
+set dummy ${MAKE-make}; ac_make=`echo "$2" | sed 'y,:./+-,___p_,'`
if eval "test \"\${ac_cv_prog_make_${ac_make}_set+set}\" = set"; then
echo $ECHO_N "(cached) $ECHO_C" >&6
else
@@ -1714,7 +1797,16 @@
SET_MAKE="MAKE=${MAKE-make}"
fi
- # test to see if srcdir already configured
+rm -rf .tst 2>/dev/null
+mkdir .tst 2>/dev/null
+if test -d .tst; then
+ am__leading_dot=.
+else
+ am__leading_dot=_
+fi
+rmdir .tst 2>/dev/null
+# test to see if srcdir already configured
if test "`cd $srcdir && pwd`" != "`pwd`" &&
test -f $srcdir/config.status; then
{ { echo "$as_me:$LINENO: error: source directory already configured; run \"make distclean\" there first" >&5
@@ -1722,9 +1814,19 @@
{ (exit 1); exit 1; }; }
fi
+# test whether we have cygpath
+if test -z "$CYGPATH_W"; then
+ if (cygpath --version) >/dev/null 2>/dev/null; then
+ CYGPATH_W='cygpath -w'
+ else
+ CYGPATH_W=echo
+ fi
+fi
# Define the identity of the package.
- PACKAGE=fdoshp
- VERSION=3.2.0
+ PACKAGE='fdoshp'
+ VERSION='3.3.0'
cat >>confdefs.h <<_ACEOF
@@ -1752,9 +1854,6 @@
MAKEINFO=${MAKEINFO-"${am_missing_run}makeinfo"}
-AMTAR=${AMTAR-"${am_missing_run}tar"}
install_sh=${install_sh-"$am_aux_dir/install-sh"}
# Installed binaries are usually stripped using `strip' when the user
@@ -1847,12 +1946,19 @@
# We need awk for the "check" target. The system "awk" is bad on
# some platforms.
+# Always define AMTAR for backward compatibility.
+AMTAR=${AMTAR-"${am_missing_run}tar"}
+am__tar='${AMTAR} chof - "$$tardir"'; am__untar='${AMTAR} xf -'
ac_ext=c
ac_cpp='$CPP $CPPFLAGS'
ac_compile='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5'
@@ -2195,7 +2301,6 @@
(exit $ac_status); }
cat >conftest.$ac_ext <<_ACEOF
-#line $LINENO "configure"
/* confdefs.h. */
_ACEOF
cat confdefs.h >>conftest.$ac_ext
@@ -2215,8 +2320,8 @@
# Try to create an executable without -o first, disregard a.out.
# It will help us diagnose broken compilers, and finding out an intuition
# of exeext.
-echo "$as_me:$LINENO: checking for C compiler default output" >&5
-echo $ECHO_N "checking for C compiler default output... $ECHO_C" >&6
+echo "$as_me:$LINENO: checking for C compiler default output file name" >&5
+echo $ECHO_N "checking for C compiler default output file name... $ECHO_C" >&6
ac_link_default=`echo "$ac_link" | sed 's/ -o *conftest[^ ]*//'`
if { (eval echo "$as_me:$LINENO: \"$ac_link_default\"") >&5
(eval $ac_link_default) 2>&5
@@ -2236,23 +2341,23 @@
test -f "$ac_file" || continue
case $ac_file in
*.$ac_ext | *.xcoff | *.tds | *.d | *.pdb | *.xSYM | *.bb | *.bbg | *.o | *.obj )
conftest.$ac_ext )
- # This is the source file.
+ # This is the source file.
[ab].out )
- # We found the default executable, but exeext='' is most
- # certainly right.
- break;;
+ # We found the default executable, but exeext='' is most
+ # certainly right.
+ break;;
- ac_cv_exeext=`expr "$ac_file" : '[^.]*\(\..*\)'`
- # FIXME: I believe we export ac_cv_exeext for Libtool,
- # but it would be cool to find out if it's true. Does anybody
- # maintain Libtool? --akim.
- export ac_cv_exeext
- break;;
+ ac_cv_exeext=`expr "$ac_file" : '[^.]*\(\..*\)'`
+ # FIXME: I believe we export ac_cv_exeext for Libtool,
+ # but it would be cool to find out if it's true. Does anybody
+ # maintain Libtool? --akim.
+ export ac_cv_exeext
+ break;;
- break;;
+ break;;
esac
done
else
@@ -2326,8 +2431,8 @@
case $ac_file in
*.$ac_ext | *.xcoff | *.tds | *.d | *.pdb | *.xSYM | *.bb | *.bbg | *.o | *.obj ) ;;
*.* ) ac_cv_exeext=`expr "$ac_file" : '[^.]*\(\..*\)'`
- break;;
+ break;;
* ) break;;
esac
done
@@ -2352,7 +2457,6 @@
else
/* confdefs.h. */
_ACEOF
@@ -2403,7 +2507,6 @@
else
/* confdefs.h. */
_ACEOF
@@ -2423,15 +2526,25 @@
_ACEOF
rm -f conftest.$ac_objext
if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
- (eval $ac_compile) 2>&5
+ (eval $ac_compile) 2>conftest.er1
ac_status=$?
+ grep -v '^ *+' conftest.er1 >conftest.err
+ rm -f conftest.er1
+ cat conftest.err >&5
echo "$as_me:$LINENO: \$? = $ac_status" >&5
(exit $ac_status); } &&
- { ac_try='test -s conftest.$ac_objext'
+ { ac_try='test -z "$ac_c_werror_flag"
+ || test ! -s conftest.err'
{ (eval echo "$as_me:$LINENO: \"$ac_try\"") >&5
(eval $ac_try) 2>&5
ac_status=$?
+ (exit $ac_status); }; } &&
+ { ac_try='test -s conftest.$ac_objext'
+ { (eval echo "$as_me:$LINENO: \"$ac_try\"") >&5
+ (eval $ac_try) 2>&5
+ ac_status=$?
+ echo "$as_me:$LINENO: \$? = $ac_status" >&5
(exit $ac_status); }; }; then
ac_compiler_gnu=yes
else
@@ -2440,7 +2553,7 @@
ac_compiler_gnu=no
fi
-rm -f conftest.$ac_objext conftest.$ac_ext
+rm -f conftest.err conftest.$ac_objext conftest.$ac_ext
ac_cv_c_compiler_gnu=$ac_compiler_gnu
fi
@@ -2456,7 +2569,6 @@
else
/* confdefs.h. */
_ACEOF
@@ -2473,15 +2585,25 @@
_ACEOF
ac_status=$?
(eval $ac_try) 2>&5
ac_status=$?
+ ac_status=$?
ac_cv_prog_cc_g=yes
else
@@ -2490,7 +2612,7 @@
ac_cv_prog_cc_g=no
fi
fi
echo "$as_me:$LINENO: result: $ac_cv_prog_cc_g" >&5
echo "${ECHO_T}$ac_cv_prog_cc_g" >&6
@@ -2517,7 +2639,6 @@
ac_cv_prog_cc_stdc=no
ac_save_CC=$CC
/* confdefs.h. */
_ACEOF
@@ -2545,6 +2666,16 @@
va_end (v);
return s;
+/* OSF 4.0 Compaq cc is some sort of almost-ANSI by default. It has
+ function prototypes and stuff, but not '\xHH' hex character constants.
+ These don't provoke an error unfortunately, instead are silently treated
+ as 'x'. The following induces an error, until -std1 is added to get
+ proper ANSI mode. Curiously '\x00'!='x' always comes out true, for an
+ array size at least. It's necessary to write '\x00'==0 to get something
+ that's true only with -std1. */
+int osf4_cc_array ['\x00' == 0 ? 1 : -1];
int test (int i, double x);
struct s1 {int (*f) (int a);};
struct s2 {int (*f) (double a);};
@@ -2571,15 +2702,25 @@
CC="$ac_save_CC $ac_arg"
ac_status=$?
(eval $ac_try) 2>&5
ac_status=$?
+ ac_status=$?
ac_cv_prog_cc_stdc=$ac_arg
break
@@ -2588,7 +2729,7 @@
sed 's/^/| /' conftest.$ac_ext >&5
fi
done
rm -f conftest.$ac_ext conftest.$ac_objext
CC=$ac_save_CC
@@ -2616,19 +2757,28 @@
_ACEOF
ac_status=$?
(eval $ac_try) 2>&5
ac_status=$?
+ ac_status=$?
for ac_declaration in \
- '#include <stdlib.h>' \
'extern "C" void std::exit (int) throw (); using std::exit;' \
'extern "C" void std::exit (int); using std::exit;' \
'extern "C" void exit (int) throw ();' \
@@ -2636,14 +2786,13 @@
'void exit (int);'
do
/* confdefs.h. */
_ACEOF
cat >>conftest.$ac_ext <<_ACEOF
/* end confdefs.h. */
+$ac_declaration
#include <stdlib.h>
-$ac_declaration
int
main ()
@@ -2654,15 +2803,25 @@
_ACEOF
ac_status=$?
(eval $ac_try) 2>&5
ac_status=$?
+ ac_status=$?
else
@@ -2671,9 +2830,8 @@
continue
fi
/* confdefs.h. */
_ACEOF
@@ -2690,15 +2848,25 @@
_ACEOF
ac_status=$?
(eval $ac_try) 2>&5
ac_status=$?
+ ac_status=$?
break
else
@@ -2706,7 +2874,7 @@
fi
done
rm -f conftest*
if test -n "$ac_declaration"; then
@@ -2720,30 +2888,22 @@
fi
ac_ext=c
ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
ac_compiler_gnu=$ac_cv_c_compiler_gnu
-rm -f .deps 2>/dev/null
-mkdir .deps 2>/dev/null
-if test -d .deps; then
- DEPDIR=.deps
-else
- # MS-DOS does not allow filenames that begin with a dot.
- DEPDIR=_deps
-fi
-rmdir .deps 2>/dev/null
+DEPDIR="${am__leading_dot}deps"
ac_config_commands="$ac_config_commands depfiles"
am_make=${MAKE-make}
cat > confinc << 'END'
-doit:
+am__doit:
@echo done
+.PHONY: am__doit
END
# If we don't find an include directive, just comment out the code.
echo "$as_me:$LINENO: checking for style of include used by $am_make" >&5
@@ -2758,7 +2918,7 @@
# In particular we don't look at `^make:' because GNU make might
# be invoked under some other name (usually "gmake"), in which
# case it prints its new name instead of `make'.
-if test "`$am_make -s -f confmf 2> /dev/null | fgrep -v 'ing directory'`" = "done"; then
+if test "`$am_make -s -f confmf 2> /dev/null | grep -v 'ing directory'`" = "done"; then
am__include=include
am__quote=
_am_result=GNU
@@ -2818,18 +2978,34 @@
# using a relative directory.
cp "$am_depcomp" conftest.dir
cd conftest.dir
+ # We will build objects and dependencies in a subdirectory because
+ # it helps to detect inapplicable dependency modes. For instance
+ # both Tru64's cc and ICC support -MD to output dependencies as a
+ # side effect of compilation, but ICC will put the dependencies in
+ # the current directory while Tru64 will put them in the object
+ # directory.
+ mkdir sub
am_cv_CC_dependencies_compiler_type=none
if test "$am_compiler_list" = ""; then
am_compiler_list=`sed -n 's/^#*\([a-zA-Z0-9]*\))$/\1/p' < ./depcomp`
fi
for depmode in $am_compiler_list; do
+ # Setup a source with many dependencies, because some compilers
+ # like to wrap large dependency lists on column 80 (with \), and
+ # we should not choose a depcomp mode which is confused by this.
# We need to recreate these files for each test, as the compiler may
# overwrite some of them when testing with obscure command lines.
# This happens at least with the AIX C compiler.
- echo '#include "conftest.h"' > conftest.c
- echo 'int i;' > conftest.h
- echo "${am__include} ${am__quote}conftest.Po${am__quote}" > confmf
+ : > sub/conftest.c
+ for i in 1 2 3 4 5 6; do
+ echo '#include "conftst'$i'.h"' >> sub/conftest.c
+ # Using `: > sub/conftst$i.h' creates only sub/conftst1.h with
+ # Solaris 8's {/usr,}/bin/sh.
+ touch sub/conftst$i.h
+ done
+ echo "${am__include} ${am__quote}sub/conftest.Po${am__quote}" > confmf
case $depmode in
nosideeffect)
@@ -2847,13 +3023,25 @@
# mode. It turns out that the SunPro C++ compiler does not properly
# handle `-M -o', and we need to detect this.
if depmode=$depmode \
- source=conftest.c object=conftest.o \
- depfile=conftest.Po tmpdepfile=conftest.TPo \
- $SHELL ./depcomp $depcc -c conftest.c -o conftest.o >/dev/null 2>&1 &&
- grep conftest.h conftest.Po > /dev/null 2>&1 &&
+ source=sub/conftest.c object=sub/conftest.${OBJEXT-o} \
+ depfile=sub/conftest.Po tmpdepfile=sub/conftest.TPo \
+ $SHELL ./depcomp $depcc -c -o sub/conftest.${OBJEXT-o} sub/conftest.c \
+ >/dev/null 2>conftest.err &&
+ grep sub/conftst6.h sub/conftest.Po > /dev/null 2>&1 &&
+ grep sub/conftest.${OBJEXT-o} sub/conftest.Po > /dev/null 2>&1 &&
${MAKE-make} -s -f confmf > /dev/null 2>&1; then
- am_cv_CC_dependencies_compiler_type=$depmode
- break
+ # icc doesn't choke on unknown options, it will just issue warnings
+ # or remarks (even with -Werror). So we grep stderr for any message
+ # that says an option was ignored or not supported.
+ # When given -MP, icc 7.0 and 7.1 complain thusly:
+ # icc: Command line warning: ignoring option '-M'; no argument required
+ # The diagnosis changed in icc 8.0:
+ # icc: Command line remark: option '-MP' not supported
+ if (grep 'ignoring option' conftest.err ||
+ grep 'not supported' conftest.err) >/dev/null 2>&1; then :; else
+ am_cv_CC_dependencies_compiler_type=$depmode
+ break
+ fi
fi
done
@@ -2869,6 +3057,18 @@
CCDEPMODE=depmode=$am_cv_CC_dependencies_compiler_type
+if
+ test "x$enable_dependency_tracking" != xno \
+ && test "$am_cv_CC_dependencies_compiler_type" = gcc3; then
+ am__fastdepCC_TRUE=
+ am__fastdepCC_FALSE='#'
+else
+ am__fastdepCC_TRUE='#'
+fi
ac_ext=cc
ac_cpp='$CXXCPP $CPPFLAGS'
ac_compile='$CXX -c $CXXFLAGS $CPPFLAGS conftest.$ac_ext >&5'
@@ -2994,7 +3194,6 @@
else
/* confdefs.h. */
_ACEOF
@@ -3014,15 +3213,25 @@
_ACEOF
ac_status=$?
+ { ac_try='test -z "$ac_cxx_werror_flag"
(eval $ac_try) 2>&5
ac_status=$?
+ ac_status=$?
ac_compiler_gnu=yes
else
@@ -3031,7 +3240,7 @@
ac_compiler_gnu=no
fi
ac_cv_cxx_compiler_gnu=$ac_compiler_gnu
fi
@@ -3047,7 +3256,6 @@
else
/* confdefs.h. */
_ACEOF
@@ -3064,15 +3272,25 @@
_ACEOF
ac_status=$?
(eval $ac_try) 2>&5
ac_status=$?
+ ac_status=$?
ac_cv_prog_cxx_g=yes
else
@@ -3081,7 +3299,7 @@
ac_cv_prog_cxx_g=no
fi
fi
echo "$as_me:$LINENO: result: $ac_cv_prog_cxx_g" >&5
echo "${ECHO_T}$ac_cv_prog_cxx_g" >&6
@@ -3101,8 +3319,7 @@
fi
fi
@@ -3110,14 +3327,13 @@
'void exit (int);'
do
/* confdefs.h. */
_ACEOF
+$ac_declaration
#include <stdlib.h>
-$ac_declaration
int
main ()
@@ -3128,15 +3344,25 @@
_ACEOF
ac_status=$?
(eval $ac_try) 2>&5
ac_status=$?
+ ac_status=$?
else
@@ -3145,9 +3371,8 @@
continue
fi
/* confdefs.h. */
_ACEOF
@@ -3164,15 +3389,25 @@
_ACEOF
ac_status=$?
(eval $ac_try) 2>&5
ac_status=$?
+ ac_status=$?
break
else
@@ -3180,7 +3415,7 @@
fi
done
rm -f conftest*
@@ -3213,18 +3448,34 @@
cd conftest.dir
+ # directory.
+ mkdir sub
am_cv_CXX_dependencies_compiler_type=none
fi
+ done
case $depmode in
nosideeffect)
@@ -3242,13 +3493,25 @@
- am_cv_CXX_dependencies_compiler_type=$depmode
- break
+ am_cv_CXX_dependencies_compiler_type=$depmode
+ break
+ fi
fi
done
@@ -3264,6 +3527,18 @@
CXXDEPMODE=depmode=$am_cv_CXX_dependencies_compiler_type
+if
+ && test "$am_cv_CXX_dependencies_compiler_type" = gcc3; then
+ am__fastdepCXX_TRUE=
+ am__fastdepCXX_FALSE='#'
+else
+ am__fastdepCXX_TRUE='#'
+fi
for ac_prog in 'bison -y' byacc
do
@@ -3309,68 +3584,75 @@
if test "${enable_static+set}" = set; then
enableval="$enable_static"
p=${PACKAGE-default}
-case $enableval in
-yes) enable_static=yes ;;
-no) enable_static=no ;;
- enable_static=no
- # Look at the argument we got. We use all the common list separators.
- IFS="${IFS= }"; ac_save_ifs="$IFS"; IFS="${IFS}:,"
- for pkg in $enableval; do
- if test "X$pkg" = "X$p"; then
- enable_static=yes
- fi
- done
- IFS="$ac_save_ifs"
-esac
+ case $enableval in
+ yes) enable_static=yes ;;
+ no) enable_static=no ;;
+ enable_static=no
+ # Look at the argument we got. We use all the common list separators.
+ lt_save_ifs="$IFS"; IFS="${IFS}$PATH_SEPARATOR,"
+ for pkg in $enableval; do
+ if test "X$pkg" = "X$p"; then
+ enable_static=yes
+ fi
+ done
+ esac
else
enable_static=no
fi;
# Check whether --enable-shared or --disable-shared was given.
if test "${enable_shared+set}" = set; then
enableval="$enable_shared"
-case $enableval in
-yes) enable_shared=yes ;;
-no) enable_shared=no ;;
- enable_shared=no
- enable_shared=yes
- fi
- done
-esac
+ yes) enable_shared=yes ;;
+ no) enable_shared=no ;;
+ enable_shared=no
+ enable_shared=yes
+ fi
+ done
+ esac
else
enable_shared=yes
fi;
# Check whether --enable-fast-install or --disable-fast-install was given.
if test "${enable_fast_install+set}" = set; then
enableval="$enable_fast_install"
-case $enableval in
-yes) enable_fast_install=yes ;;
-no) enable_fast_install=no ;;
- enable_fast_install=no
- enable_fast_install=yes
- fi
- done
-esac
+ yes) enable_fast_install=yes ;;
+ no) enable_fast_install=no ;;
+ enable_fast_install=no
+ enable_fast_install=yes
+ fi
+ done
+ esac
else
fi;
# Make sure we can run config.sub.
$ac_config_sub sun4 >/dev/null 2>&1 ||
{ { echo "$as_me:$LINENO: error: cannot run $ac_config_sub" >&5
@@ -3425,18 +3707,79 @@
host_os=`echo $ac_cv_host | sed 's/^\([^-]*\)-\([^-]*\)-\(.*\)$/\3/'`
- case X$UNAME in
- esac
+echo "$as_me:$LINENO: checking for a sed that does not truncate output" >&5
+echo $ECHO_N "checking for a sed that does not truncate output... $ECHO_C" >&6
+if test "${lt_cv_path_SED+set}" = set; then
+ echo $ECHO_N "(cached) $ECHO_C" >&6
+else
+ # Loop through the user's path and test for sed and gsed.
+# Then use that list of sed's as ones to test for truncation.
+as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
+for as_dir in $PATH
+do
+ IFS=$as_save_IFS
+ test -z "$as_dir" && as_dir=.
+ for lt_ac_prog in sed gsed; do
+ for ac_exec_ext in '' $ac_executable_extensions; do
+ if $as_executable_p "$as_dir/$lt_ac_prog$ac_exec_ext"; then
+ lt_ac_sed_list="$lt_ac_sed_list $as_dir/$lt_ac_prog$ac_exec_ext"
+ fi
+ done
+ done
+done
+lt_ac_max=0
+lt_ac_count=0
+# Add /usr/xpg4/bin/sed as it is typically found on Solaris
+# along with /bin/sed that truncates output.
+for lt_ac_sed in $lt_ac_sed_list /usr/xpg4/bin/sed; do
+ test ! -f $lt_ac_sed && continue
+ cat /dev/null > conftest.in
+ lt_ac_count=0
+ echo $ECHO_N "0123456789$ECHO_C" >conftest.in
+ # Check for GNU sed and select it if it is found.
+ if "$lt_ac_sed" --version 2>&1 < /dev/null | grep 'GNU' > /dev/null; then
+ lt_cv_path_SED=$lt_ac_sed
+ break
+ fi
+ while true; do
+ cat conftest.in conftest.in >conftest.tmp
+ mv conftest.tmp conftest.in
+ cp conftest.in conftest.nl
+ echo >>conftest.nl
+ $lt_ac_sed -e 's/a$//' < conftest.nl >conftest.out || break
+ cmp -s conftest.out conftest.nl || break
+ # 10000 chars as input seems more than enough
+ test $lt_ac_count -gt 10 && break
+ lt_ac_count=`expr $lt_ac_count + 1`
+ if test $lt_ac_count -gt $lt_ac_max; then
+ lt_ac_max=$lt_ac_count
+ fi
+ done
+done
fi
+SED=$lt_cv_path_SED
+echo "$as_me:$LINENO: result: $SED" >&5
+echo "${ECHO_T}$SED" >&6
+echo "$as_me:$LINENO: checking for egrep" >&5
+echo $ECHO_N "checking for egrep... $ECHO_C" >&6
+if test "${ac_cv_prog_egrep+set}" = set; then
+else
+ if echo a | (grep -E '(a|b)') >/dev/null 2>&1
+ then ac_cv_prog_egrep='grep -E'
+ else ac_cv_prog_egrep='egrep'
+ fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_prog_egrep" >&5
+echo "${ECHO_T}$ac_cv_prog_egrep" >&6
+ EGREP=$ac_cv_prog_egrep
# Check whether --with-gnu-ld or --without-gnu-ld was given.
if test "${with_gnu_ld+set}" = set; then
withval="$with_gnu_ld"
@@ -3447,8 +3790,8 @@
ac_prog=ld
if test "$GCC" = yes; then
# Check if gcc -print-prog-name=ld gives a path.
- echo "$as_me:$LINENO: checking for ld used by GCC" >&5
-echo $ECHO_N "checking for ld used by GCC... $ECHO_C" >&6
+ echo "$as_me:$LINENO: checking for ld used by $CC" >&5
+echo $ECHO_N "checking for ld used by $CC... $ECHO_C" >&6
case $host in
*-*-mingw*)
# gcc leaves a trailing carriage return which upsets mingw
@@ -3458,12 +3801,12 @@
esac
case $ac_prog in
# Accept absolute paths.
- [\\/]* | [A-Za-z]:[\\/]*)
re_direlt='/[^/][^/]*/\.\./'
- # Canonicalize the path of ld
- ac_prog=`echo $ac_prog| sed 's%\\\\%/%g'`
+ # Canonicalize the pathname of ld
+ ac_prog=`echo $ac_prog| $SED 's%\\\\%/%g'`
while echo $ac_prog | grep "$re_direlt" > /dev/null 2>&1; do
- ac_prog=`echo $ac_prog| sed "s%$re_direlt%/%"`
+ ac_prog=`echo $ac_prog| $SED "s%$re_direlt%/%"`
done
test -z "$LD" && LD="$ac_prog"
@@ -3487,22 +3830,26 @@
else
if test -z "$LD"; then
- IFS="${IFS= }"; ac_save_ifs="$IFS"; IFS=$PATH_SEPARATOR
for ac_dir in $PATH; do
test -z "$ac_dir" && ac_dir=.
if test -f "$ac_dir/$ac_prog" || test -f "$ac_dir/$ac_prog$ac_exeext"; then
lt_cv_path_LD="$ac_dir/$ac_prog"
# Check to see if the program is GNU ld. I'd rather use --version,
- # but apparently some GNU ld's only accept -v.
+ # but apparently some variants of GNU ld only accept -v.
# Break only if it was the GNU/non-GNU ld that we prefer.
- if "$lt_cv_path_LD" -v 2>&1 < /dev/null | egrep '(GNU|with BFD)' > /dev/null; then
+ case `"$lt_cv_path_LD" -v 2>&1 </dev/null` in
+ *GNU* | *'with BFD'*)
test "$with_gnu_ld" != no && break
- else
test "$with_gnu_ld" != yes && break
- fi
+ esac
fi
done
else
lt_cv_path_LD="$LD" # Let the user override the test with a path.
fi
@@ -3524,13 +3871,16 @@
if test "${lt_cv_prog_gnu_ld+set}" = set; then
else
- # I'd rather use --version here, but apparently some GNU ld's only accept -v.
-if $LD -v 2>&1 </dev/null | egrep '(GNU|with BFD)' 1>&5; then
+ # I'd rather use --version here, but apparently some GNU lds only accept -v.
+case `$LD -v 2>&1 </dev/null` in
+*GNU* | *'with BFD'*)
lt_cv_prog_gnu_ld=yes
-else
lt_cv_prog_gnu_ld=no
+esac
fi
-fi
echo "$as_me:$LINENO: result: $lt_cv_prog_gnu_ld" >&5
echo "${ECHO_T}$lt_cv_prog_gnu_ld" >&6
with_gnu_ld=$lt_cv_prog_gnu_ld
@@ -3546,7 +3896,20 @@
echo "$as_me:$LINENO: result: $lt_cv_ld_reload_flag" >&5
echo "${ECHO_T}$lt_cv_ld_reload_flag" >&6
reload_flag=$lt_cv_ld_reload_flag
-test -n "$reload_flag" && reload_flag=" $reload_flag"
+case $reload_flag in
+*) reload_flag=" $reload_flag" ;;
+esac
+reload_cmds='$LD$reload_flag -o $output$reload_objs'
+case $host_os in
+ darwin*)
+ if test "$GCC" = yes; then
+ reload_cmds='$LTCC $LTCFLAGS -nostdlib ${wl}-r -o $output$reload_objs'
+ else
+ reload_cmds='$LD$reload_flag -o $output$reload_objs'
+ fi
+esac
echo "$as_me:$LINENO: checking for BSD-compatible nm" >&5
echo $ECHO_N "checking for BSD-compatible nm... $ECHO_C" >&6
@@ -3557,121 +3920,50 @@
# Let the user override the test.
lt_cv_path_NM="$NM"
else
- for ac_dir in $PATH /usr/ccs/bin /usr/ucb /bin; do
- test -z "$ac_dir" && ac_dir=.
- tmp_nm=$ac_dir/${ac_tool_prefix}nm
- if test -f $tmp_nm || test -f $tmp_nm$ac_exeext ; then
- # Check to see if the nm accepts a BSD-compat flag.
- # Adding the `sed 1q' prevents false positives on HP-UX, which says:
- # nm: unknown option "B" ignored
- # Tru64's nm complains that /dev/null is an invalid object file
- if ($tmp_nm -B /dev/null 2>&1 | sed '1q'; exit 0) | egrep '(/dev/null|Invalid file or object type)' >/dev/null; then
- lt_cv_path_NM="$tmp_nm -B"
- break
- elif ($tmp_nm -p /dev/null 2>&1 | sed '1q'; exit 0) | egrep /dev/null >/dev/null; then
- lt_cv_path_NM="$tmp_nm -p"
- break
- else
- lt_cv_path_NM=${lt_cv_path_NM="$tmp_nm"} # keep the first match, but
- continue # so that we can try to find one that supports BSD flags
+ lt_nm_to_check="${ac_tool_prefix}nm"
+ if test -n "$ac_tool_prefix" && test "$build" = "$host"; then
+ lt_nm_to_check="$lt_nm_to_check nm"
+ fi
+ for lt_tmp_nm in $lt_nm_to_check; do
+ for ac_dir in $PATH /usr/ccs/bin/elf /usr/ccs/bin /usr/ucb /bin; do
+ test -z "$ac_dir" && ac_dir=.
+ tmp_nm="$ac_dir/$lt_tmp_nm"
+ if test -f "$tmp_nm" || test -f "$tmp_nm$ac_exeext" ; then
+ # Check to see if the nm accepts a BSD-compat flag.
+ # Adding the `sed 1q' prevents false positives on HP-UX, which says:
+ # nm: unknown option "B" ignored
+ # Tru64's nm complains that /dev/null is an invalid object file
+ case `"$tmp_nm" -B /dev/null 2>&1 | sed '1q'` in
+ */dev/null* | *'Invalid file or object type'*)
+ lt_cv_path_NM="$tmp_nm -B"
+ break
+ case `"$tmp_nm" -p /dev/null 2>&1 | sed '1q'` in
+ */dev/null*)
+ lt_cv_path_NM="$tmp_nm -p"
+ break
+ lt_cv_path_NM=${lt_cv_path_NM="$tmp_nm"} # keep the first match, but
+ continue # so that we can try to find one that supports BSD flags
+ esac
+ esac
fi
- fi
+ done
done
test -z "$lt_cv_path_NM" && lt_cv_path_NM=nm
fi
fi
+echo "$as_me:$LINENO: result: $lt_cv_path_NM" >&5
+echo "${ECHO_T}$lt_cv_path_NM" >&6
NM="$lt_cv_path_NM"
-echo "$as_me:$LINENO: result: $NM" >&5
-echo "${ECHO_T}$NM" >&6
-echo "$as_me:$LINENO: checking for a sed that does not truncate output" >&5
-echo $ECHO_N "checking for a sed that does not truncate output... $ECHO_C" >&6
-if test "${lt_cv_path_SED+set}" = set; then
- echo $ECHO_N "(cached) $ECHO_C" >&6
-else
- # Loop through the user's path and test for sed and gsed.
-# Then use that list of sed's as ones to test for truncation.
-as_executable_p="test -f"
-as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
-for as_dir in $PATH
-do
- IFS=$as_save_IFS
- test -z "$as_dir" && as_dir=.
- for ac_prog in sed gsed; do
- for ac_exec_ext in '' $ac_executable_extensions; do
- _sed_list="$_sed_list $as_dir/$ac_prog$ac_exec_ext"
- fi
- done
- done
-done
- # Create a temporary directory, and hook for its removal unless debugging.
-$debug ||
- trap 'exit_status=$?; rm -rf $tmp && exit $exit_status' 0
- trap '{ (exit 1); exit 1; }' 1 2 13 15
-# Create a (secure) tmp directory for tmp files.
-: ${TMPDIR=/tmp}
- tmp=`(umask 077 && mktemp -d -q "$TMPDIR/sedXXXXXX") 2>/dev/null` &&
- test -n "$tmp" && test -d "$tmp"
- tmp=$TMPDIR/sed$$-$RANDOM
- (umask 077 && mkdir $tmp)
- echo "$me: cannot create a temporary directory in $TMPDIR" >&2
- { (exit 1); exit 1; }
- _max=0
- _count=0
- # Add /usr/xpg4/bin/sed as it is typically found on Solaris
- # along with /bin/sed that truncates output.
- for _sed in $_sed_list /usr/xpg4/bin/sed; do
- test ! -f ${_sed} && break
- cat /dev/null > "$tmp/sed.in"
- _count=0
- echo ${ECHO_N-$ac_n} "0123456789${ECHO_C-$ac_c}" >"$tmp/sed.in"
- # Check for GNU sed and select it if it is found.
- if "${_sed}" --version 2>&1 < /dev/null | egrep '(GNU)' > /dev/null; then
- lt_cv_path_SED=${_sed}
- break
- fi
- while true; do
- cat "$tmp/sed.in" "$tmp/sed.in" >"$tmp/sed.tmp"
- mv "$tmp/sed.tmp" "$tmp/sed.in"
- cp "$tmp/sed.in" "$tmp/sed.nl"
- echo >>"$tmp/sed.nl"
- ${_sed} -e 's/a$//' < "$tmp/sed.nl" >"$tmp/sed.out" || break
- cmp -s "$tmp/sed.out" "$tmp/sed.nl" || break
- # 40000 chars as input seems more than enough
- test $_count -gt 10 && break
- _count=`expr $_count + 1`
- if test $_count -gt $_max; then
- _max=$_count
- lt_cv_path_SED=$_sed
- fi
- done
- done
- rm -rf "$tmp"
-fi
-if test "X$SED" != "X"; then
- lt_cv_path_SED=$SED
-else
- SED=$lt_cv_path_SED
-fi
-echo "$as_me:$LINENO: result: $SED" >&5
-echo "${ECHO_T}$SED" >&6
echo "$as_me:$LINENO: checking whether ln -s works" >&5
echo $ECHO_N "checking whether ln -s works... $ECHO_C" >&6
LN_S=$as_ln_s
@@ -3698,7 +3990,7 @@
# 'pass_all' -- all dependencies passed with no checks.
# 'test_compile' -- check by making test program.
# 'file_magic [[regex]]' -- check by looking for files in library path
-# which responds to the $file_magic_cmd with a given egrep regex.
+# which responds to the $file_magic_cmd with a given extended regex.
# If you have `file' or equivalent on your system and you're not sure
# whether `pass_all' will *always* work, you probably want this one.
@@ -3711,37 +4003,36 @@
lt_cv_deplibs_check_method=pass_all
-bsdi4*)
+bsdi[45]*)
lt_cv_deplibs_check_method='file_magic ELF [0-9][0-9]*-bit [ML]SB (shared object|dynamic lib)'
lt_cv_file_magic_cmd='/usr/bin/file -L'
lt_cv_file_magic_test_file=/shlib/libc.so
-cygwin* | mingw* | pw32*)
+cygwin*)
+ # func_win32_libid is a shell function defined in ltmain.sh
+ lt_cv_deplibs_check_method='file_magic ^x86 archive import|^x86 DLL'
+ lt_cv_file_magic_cmd='func_win32_libid'
+mingw* | pw32*)
+ # Base MSYS/MinGW do not provide the 'file' command needed by
+ # func_win32_libid shell function, so use a weaker test based on 'objdump'.
lt_cv_deplibs_check_method='file_magic file format pei*-i386(.*architecture: i386)?'
lt_cv_file_magic_cmd='$OBJDUMP -f'
darwin* | rhapsody*)
- lt_cv_deplibs_check_method='file_magic Mach-O dynamically linked shared library'
- lt_cv_file_magic_cmd='/usr/bin/file -L'
- case "$host_os" in
- rhapsody* | darwin1.[012])
- lt_cv_file_magic_test_file=`echo /System/Library/Frameworks/System.framework/Versions/*/System | head -1`
- *) # Darwin 1.3 on
- lt_cv_file_magic_test_file='/usr/lib/libSystem.dylib'
- esac
+ lt_cv_deplibs_check_method=pass_all
-freebsd*)
+freebsd* | kfreebsd*-gnu | dragonfly*)
if echo __ELF__ | $CC -E - | grep __ELF__ > /dev/null; then
case $host_cpu in
i*86 )
# Not sure whether the presence of OpenBSD here was a mistake.
# Let's accept both of them until this is cleared up.
- lt_cv_deplibs_check_method='file_magic (FreeBSD|OpenBSD)/i[3-9]86 (compact )?demand paged shared library'
+ lt_cv_deplibs_check_method='file_magic (FreeBSD|OpenBSD|DragonFly)/i[3-9]86 (compact )?demand paged shared library'
lt_cv_file_magic_cmd=/usr/bin/file
lt_cv_file_magic_test_file=`echo /usr/lib/libc.so.*`
@@ -3755,50 +4046,49 @@
-hpux10.20*|hpux11*)
- lt_cv_deplibs_check_method='file_magic (s[0-9][0-9][0-9]|PA-RISC[0-9].[0-9]) shared library'
+hpux10.20* | hpux11*)
- lt_cv_file_magic_test_file=/usr/lib/libc.sl
-irix5* | irix6* | nonstopux*)
- case $host_os in
- irix5* | nonstopux*)
- # this will be overridden with pass_all, but let us keep it just in case
- lt_cv_deplibs_check_method="file_magic ELF 32-bit MSB dynamic lib MIPS - version 1"
+ case $host_cpu in
+ ia64*)
+ lt_cv_deplibs_check_method='file_magic (s[0-9][0-9][0-9]|ELF-[0-9][0-9]) shared object file - IA64'
+ lt_cv_file_magic_test_file=/usr/lib/hpux32/libc.so
+ hppa*64*)
+ lt_cv_deplibs_check_method='file_magic (s[0-9][0-9][0-9]|ELF-[0-9][0-9]) shared object file - PA-RISC [0-9].[0-9]'
+ lt_cv_file_magic_test_file=/usr/lib/pa20_64/libc.sl
- case $LD in
- *-32|*"-32 ") libmagic=32-bit;;
- *-n32|*"-n32 ") libmagic=N32;;
- *-64|*"-64 ") libmagic=64-bit;;
- *) libmagic=never-match;;
- esac
- lt_cv_deplibs_check_method="file_magic ELF ${libmagic} MSB mips-[1234] dynamic lib MIPS - version 1"
+ lt_cv_deplibs_check_method='file_magic (s[0-9][0-9][0-9]|PA-RISC[0-9].[0-9]) shared library'
+ lt_cv_file_magic_test_file=/usr/lib/libc.sl
esac
- lt_cv_file_magic_test_file=`echo /lib${libsuff}/libc.so*`
+interix3*)
+ # PIC code is broken on Interix 3.x, that's why |\.a not |_pic\.a here
+ lt_cv_deplibs_check_method='match_pattern /lib[^/]+(\.so|\.a)$'
+irix5* | irix6* | nonstopux*)
+ case $LD in
+ *-32|*"-32 ") libmagic=32-bit;;
+ *-n32|*"-n32 ") libmagic=N32;;
+ *-64|*"-64 ") libmagic=64-bit;;
+ *) libmagic=never-match;;
+ esac
# This must be Linux ELF.
-linux-gnu*)
- case $host_cpu in
- alpha* | hppa* | i*86 | mips | mipsel | powerpc* | sparc* | ia64* | s390* | x86_64*)
- lt_cv_deplibs_check_method=pass_all ;;
- # glibc up to 2.1.1 does not perform some relocations on ARM
- lt_cv_deplibs_check_method='file_magic ELF [0-9][0-9]*-bit [LM]SB (shared object|dynamic lib )' ;;
- esac
- lt_cv_file_magic_test_file=`echo /lib/libc.so* /lib/libc-*.so`
+linux*)
netbsd*)
- lt_cv_deplibs_check_method='match_pattern /lib[^/\.]+\.so\.[0-9]+\.[0-9]+$'
+ lt_cv_deplibs_check_method='match_pattern /lib[^/]+(\.so\.[0-9]+\.[0-9]+|_pic\.a)$'
else
- lt_cv_deplibs_check_method='match_pattern /lib[^/\.]+\.so$'
+ lt_cv_deplibs_check_method='match_pattern /lib[^/]+(\.so|_pic\.a)$'
fi
@@ -3808,37 +4098,27 @@
lt_cv_file_magic_test_file=/usr/lib/libnls.so
+nto-qnx*)
+ lt_cv_deplibs_check_method=unknown
openbsd*)
- lt_cv_file_magic_cmd=/usr/bin/file
- lt_cv_file_magic_test_file=`echo /usr/lib/libc.so.*`
if test -z "`echo __ELF__ | $CC -E - | grep __ELF__`" || test "$host_os-$host_cpu" = "openbsd2.8-powerpc"; then
- lt_cv_deplibs_check_method='file_magic ELF [0-9][0-9]*-bit [LM]SB shared object'
+ lt_cv_deplibs_check_method='match_pattern /lib[^/]+(\.so\.[0-9]+\.[0-9]+|\.so|_pic\.a)$'
else
- lt_cv_deplibs_check_method='file_magic OpenBSD.* shared library'
fi
osf3* | osf4* | osf5*)
- lt_cv_deplibs_check_method='file_magic COFF format alpha shared library'
- lt_cv_file_magic_test_file=/shlib/libc.so
-sco3.2v5*)
solaris*)
- lt_cv_file_magic_test_file=/lib/libc.so
-sysv5uw[78]* | sysv4*uw2*)
-sysv4 | sysv4.2uw2* | sysv4.3* | sysv5*)
+sysv4 | sysv4.3*)
case $host_vendor in
motorola)
lt_cv_deplibs_check_method='file_magic ELF [0-9][0-9]*-bit [ML]SB (shared object|dynamic lib) M[0-9][0-9]* Version [0-9]'
@@ -3859,8 +4139,15 @@
siemens)
+ pc)
esac
+sysv5* | sco3.2v5* | sco5v6* | unixware* | OpenUNIX* | sysv4*uw2*)
esac
fi
@@ -3868,229 +4155,254 @@
echo "${ECHO_T}$lt_cv_deplibs_check_method" >&6
file_magic_cmd=$lt_cv_file_magic_cmd
deplibs_check_method=$lt_cv_deplibs_check_method
+test -z "$deplibs_check_method" && deplibs_check_method=unknown
+# If no C compiler was specified, use CC.
+LTCC=${LTCC-"$CC"}
+# If no C compiler flags were specified, use CFLAGS.
+LTCFLAGS=${LTCFLAGS-"$CFLAGS"}
+# Allow CC to be a program name with arguments.
+compiler=$CC
-# Check for command to grab the raw symbol name followed by C symbol from nm.
-echo "$as_me:$LINENO: checking command to parse $NM output" >&5
-echo $ECHO_N "checking command to parse $NM output... $ECHO_C" >&6
-if test "${lt_cv_sys_global_symbol_pipe+set}" = set; then
-else
+# Check whether --enable-libtool-lock or --disable-libtool-lock was given.
+if test "${enable_libtool_lock+set}" = set; then
+ enableval="$enable_libtool_lock"
-# These are sane defaults that work on at least a few old systems.
-# [They come from Ultrix. What could be older than Ultrix?!! ;)]
+fi;
+test "x$enable_libtool_lock" != xno && enable_libtool_lock=yes
-# Character class describing NM global symbol codes.
-symcode='[BCDEGRST]'
-# Regexp to match symbols that can be accessed directly from C.
-sympat='\([_A-Za-z][_A-Za-z0-9]*\)'
-# Transform the above into a raw symbol and a C symbol.
-symxfrm='\1 \2\3 \3'
-# Transform an extracted symbol line into a proper C declaration
-lt_cv_global_symbol_to_cdecl="sed -n -e 's/^. .* \(.*\)$/extern char \1;/p'"
-# Transform an extracted symbol line into symbol name and symbol address
-lt_cv_global_symbol_to_c_name_address="sed -n -e 's/^: \([^ ]*\) $/ {\\\"\1\\\", (lt_ptr) 0},/p' -e 's/^$symcode \([^ ]*\) \([^ ]*\)$/ {\"\2\", (lt_ptr) \&\2},/p'"
-# Define system-specific variables.
-case $host_os in
-aix*)
- symcode='[BCDT]'
+# Some flags need to be propagated to the compiler or linker for good
+# libtool support.
+case $host in
+ia64-*-hpux*)
+ # Find out which ABI we are using.
+ echo 'int i;' > conftest.$ac_ext
+ if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
+ (eval $ac_compile) 2>&5
+ ac_status=$?
+ (exit $ac_status); }; then
+ case `/usr/bin/file conftest.$ac_objext` in
+ *ELF-32*)
+ HPUX_IA64_MODE="32"
+ *ELF-64*)
+ HPUX_IA64_MODE="64"
+ esac
+ fi
+ rm -rf conftest*
- symcode='[ABCDGISTW]'
+*-*-irix6*)
+ echo '#line 4204 "configure"' > conftest.$ac_ext
+ ac_status=$?
+ if test "$lt_cv_prog_gnu_ld" = yes; then
+ *32-bit*)
+ LD="${LD-ld} -melf32bsmip"
+ *N32*)
+ LD="${LD-ld} -melf32bmipn32"
+ *64-bit*)
+ LD="${LD-ld} -melf64bmip"
+ esac
+ else
+ *32-bit*)
+ LD="${LD-ld} -32"
+ *N32*)
+ LD="${LD-ld} -n32"
+ *64-bit*)
+ LD="${LD-ld} -64"
+ esac
+ fi
+ fi
+ rm -rf conftest*
-hpux*) # Its linker distinguishes data from code symbols
- lt_cv_global_symbol_to_cdecl="sed -n -e 's/^T .* \(.*\)$/extern char \1();/p' -e 's/^$symcode* .* \(.*\)$/extern char \1;/p'"
- lt_cv_global_symbol_to_c_name_address="sed -n -e 's/^: \([^ ]*\) $/ {\\\"\1\\\", (lt_ptr) 0},/p' -e 's/^$symcode* \([^ ]*\) \([^ ]*\)$/ {\"\2\", (lt_ptr) \&\2},/p'"
-irix* | nonstopux*)
- symcode='[BCDEGRST]'
-osf*)
- symcode='[BCDEGQRST]'
-solaris* | sysv5*)
- symcode='[BDT]'
-sysv4)
- symcode='[DFNSTU]'
-esac
-# Handle CRLF in mingw tool chain
-opt_cr=
-case $host_os in
-mingw*)
- opt_cr=`echo 'x\{0,1\}' | tr x '\015'` # option cr in regexp
+x86_64-*linux*|ppc*-*linux*|powerpc*-*linux*|s390*-*linux*|sparc*-*linux*)
+ ac_status=$?
+ case `/usr/bin/file conftest.o` in
+ *32-bit*)
+ case $host in
+ x86_64-*linux*)
+ LD="${LD-ld} -m elf_i386"
+ ppc64-*linux*|powerpc64-*linux*)
+ LD="${LD-ld} -m elf32ppclinux"
+ s390x-*linux*)
+ LD="${LD-ld} -m elf_s390"
+ sparc64-*linux*)
+ LD="${LD-ld} -m elf32_sparc"
+ esac
+ *64-bit*)
+ case $host in
+ x86_64-*linux*)
+ LD="${LD-ld} -m elf_x86_64"
+ ppc*-*linux*|powerpc*-*linux*)
+ LD="${LD-ld} -m elf64ppc"
+ s390*-*linux*)
+ LD="${LD-ld} -m elf64_s390"
+ sparc*-*linux*)
+ LD="${LD-ld} -m elf64_sparc"
+ esac
+ esac
+ fi
+ rm -rf conftest*
-esac
-# If we're using GNU nm, then use its standard symbol codes.
-if $NM -V 2>&1 | egrep '(GNU|with BFD)' > /dev/null; then
-fi
+*-*-sco3.2v5*)
+ # On SCO OpenServer 5, we need -belf to get full-featured binaries.
+ SAVE_CFLAGS="$CFLAGS"
+ CFLAGS="$CFLAGS -belf"
+ echo "$as_me:$LINENO: checking whether the C compiler needs -belf" >&5
+echo $ECHO_N "checking whether the C compiler needs -belf... $ECHO_C" >&6
+if test "${lt_cv_cc_needs_belf+set}" = set; then
+else
+ ac_ext=c
+ac_cpp='$CPP $CPPFLAGS'
+ac_compile='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5'
+ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
+ac_compiler_gnu=$ac_cv_c_compiler_gnu
-# Try without a prefix undercore, then with it.
-for ac_symprfx in "" "_"; do
+ cat >conftest.$ac_ext <<_ACEOF
+/* confdefs.h. */
+_ACEOF
+cat confdefs.h >>conftest.$ac_ext
+cat >>conftest.$ac_ext <<_ACEOF
+/* end confdefs.h. */
- # Write the raw and C identifiers.
-lt_cv_sys_global_symbol_pipe="sed -n -e 's/^.*[ ]\($symcode$symcode*\)[ ][ ]*\($ac_symprfx\)$sympat$opt_cr$/$symxfrm/p'"
+int
+main ()
- # Check to see that the pipe works correctly.
- pipe_works=no
- rm -f conftest*
- cat > conftest.$ac_ext <<EOF
-#ifdef __cplusplus
-extern "C" {
-#endif
-char nm_test_var;
-void nm_test_func(){}
-#ifdef __cplusplus
+ return 0;
-#endif
-int main(){nm_test_var='a';nm_test_func();return(0);}
-EOF
- if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
+_ACEOF
+rm -f conftest.$ac_objext conftest$ac_exeext
+if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
+ (eval $ac_link) 2>conftest.er1
ac_status=$?
- (exit $ac_status); }; then
- # Now try to grab the symbols.
- nlist=conftest.nm
- if { (eval echo "$as_me:$LINENO: \"$NM conftest.$ac_objext \| $lt_cv_sys_global_symbol_pipe \> $nlist\"") >&5
- (eval $NM conftest.$ac_objext \| $lt_cv_sys_global_symbol_pipe \> $nlist) 2>&5
+ (exit $ac_status); } &&
ac_status=$?
- (exit $ac_status); } && test -s "$nlist"; then
- # Try sorting and uniquifying the output.
- if sort "$nlist" | uniq > "$nlist"T; then
- mv -f "$nlist"T "$nlist"
- else
- rm -f "$nlist"T
- fi
+ { ac_try='test -s conftest$ac_exeext'
+ ac_status=$?
+ (exit $ac_status); }; }; then
+ lt_cv_cc_needs_belf=yes
+else
+ echo "$as_me: failed program was:" >&5
+sed 's/^/| /' conftest.$ac_ext >&5
- # Make sure that we snagged all the symbols we need.
- if egrep ' nm_test_var$' "$nlist" >/dev/null; then
- if egrep ' nm_test_func$' "$nlist" >/dev/null; then
- cat <<EOF > conftest.$ac_ext
-#ifdef __cplusplus
-extern "C" {
-#endif
+lt_cv_cc_needs_belf=no
+fi
+rm -f conftest.err conftest.$ac_objext \
+ conftest$ac_exeext conftest.$ac_ext
+ ac_ext=c
-EOF
- # Now generate the symbol file.
- eval "$lt_cv_global_symbol_to_cdecl"' < "$nlist" >> conftest.$ac_ext'
- cat <<EOF >> conftest.$ac_ext
-#if defined (__STDC__) && __STDC__
-# define lt_ptr void *
-#else
-# define lt_ptr char *
-# define const
-#endif
-/* The mapping between symbol names and symbols. */
-const struct {
- const char *name;
- lt_ptr address;
-lt_preloaded_symbols[] =
-EOF
- sed "s/^$symcode$symcode* \(.*\) \(.*\)$/ {\"\2\", (lt_ptr) \&\2},/" < "$nlist" >> conftest.$ac_ext
- cat <<\EOF >> conftest.$ac_ext
- {0, (lt_ptr) 0}
-#ifdef __cplusplus
-#endif
-EOF
- # Now try linking the two files.
- mv conftest.$ac_objext conftstm.$ac_objext
- save_LIBS="$LIBS"
- save_CFLAGS="$CFLAGS"
- LIBS="conftstm.$ac_objext"
- CFLAGS="$CFLAGS$no_builtin_flag"
- if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
- (eval $ac_link) 2>&5
+fi
+echo "$as_me:$LINENO: result: $lt_cv_cc_needs_belf" >&5
+echo "${ECHO_T}$lt_cv_cc_needs_belf" >&6
+ if test x"$lt_cv_cc_needs_belf" != x"yes"; then
+ # this is probably gcc 2.8.0, egcs 1.0 or newer; no need for -belf
+ CFLAGS="$SAVE_CFLAGS"
+ fi
+sparc*-*solaris*)
ac_status=$?
- (exit $ac_status); } && test -s conftest$ac_exeext; then
- pipe_works=yes
- fi
- LIBS="$save_LIBS"
- CFLAGS="$save_CFLAGS"
- else
- echo "cannot find nm_test_func in $nlist" >&5
- fi
- else
- echo "cannot find nm_test_var in $nlist" >&5
- fi
- else
- echo "cannot run $lt_cv_sys_global_symbol_pipe" >&5
- fi
- else
- echo "$progname: failed program was:" >&5
- cat conftest.$ac_ext >&5
+ *64-bit*)
+ case $lt_cv_prog_gnu_ld in
+ yes*) LD="${LD-ld} -m elf64_sparc" ;;
+ *) LD="${LD-ld} -64" ;;
+ esac
+ esac
fi
- rm -f conftest* conftst*
+ rm -rf conftest*
- # Do not use the global_symbol_pipe unless it works.
- if test "$pipe_works" = yes; then
- break
- else
- lt_cv_sys_global_symbol_pipe=
- fi
-done
-fi
+esac
-global_symbol_pipe="$lt_cv_sys_global_symbol_pipe"
-if test -z "$lt_cv_sys_global_symbol_pipe"; then
- global_symbol_to_cdecl=
- global_symbol_to_c_name_address=
-else
- global_symbol_to_cdecl="$lt_cv_global_symbol_to_cdecl"
- global_symbol_to_c_name_address="$lt_cv_global_symbol_to_c_name_address"
-fi
-if test -z "$global_symbol_pipe$global_symbol_to_cdec$global_symbol_to_c_name_address";
-then
- echo "$as_me:$LINENO: result: failed" >&5
-echo "${ECHO_T}failed" >&6
-else
- echo "$as_me:$LINENO: result: ok" >&5
-echo "${ECHO_T}ok" >&6
-fi
+need_locks="$enable_libtool_lock"
-ac_ext=cc
-ac_cpp='$CXXCPP $CPPFLAGS'
-ac_compile='$CXX -c $CXXFLAGS $CPPFLAGS conftest.$ac_ext >&5'
-ac_link='$CXX -o conftest$ac_exeext $CXXFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
-ac_compiler_gnu=$ac_cv_cxx_compiler_gnu
-echo "$as_me:$LINENO: checking how to run the C++ preprocessor" >&5
-echo $ECHO_N "checking how to run the C++ preprocessor... $ECHO_C" >&6
-if test -z "$CXXCPP"; then
- if test "${ac_cv_prog_CXXCPP+set}" = set; then
+ac_ext=c
+echo "$as_me:$LINENO: checking how to run the C preprocessor" >&5
+echo $ECHO_N "checking how to run the C preprocessor... $ECHO_C" >&6
+# On Suns, sometimes $CPP names a directory.
+if test -n "$CPP" && test -d "$CPP"; then
+ CPP=
+fi
+if test -z "$CPP"; then
+ if test "${ac_cv_prog_CPP+set}" = set; then
else
- # Double quotes because CXXCPP needs to be expanded
- for CXXCPP in "$CXX -E" "/lib/cpp"
+ # Double quotes because CPP needs to be expanded
+ for CPP in "$CC -E" "$CC -E -traditional-cpp" "/lib/cpp"
do
ac_preproc_ok=false
-for ac_cxx_preproc_warn_flag in '' yes
+for ac_c_preproc_warn_flag in '' yes
do
# Use a header file that comes with gcc, so configuring glibc
# with a fresh cross-compiler works.
@@ -4099,7 +4411,6 @@
# On the NeXT, cc -E runs the code through the compiler's parser,
# not just through cpp. "Syntax error" is here to catch this case.
/* confdefs.h. */
_ACEOF
@@ -4110,7 +4421,7 @@
#else
# include <assert.h>
#endif
- Syntax error
+ Syntax error
_ACEOF
if { (eval echo "$as_me:$LINENO: \"$ac_cpp conftest.$ac_ext\"") >&5
(eval $ac_cpp conftest.$ac_ext) 2>conftest.er1
@@ -4121,7 +4432,8 @@
(exit $ac_status); } >/dev/null; then
if test -s conftest.err; then
- ac_cpp_err=$ac_cxx_preproc_warn_flag
+ ac_cpp_err=$ac_c_preproc_warn_flag
+ ac_cpp_err=$ac_cpp_err$ac_c_werror_flag
else
ac_cpp_err=
fi
@@ -4142,7 +4454,6 @@
# OK, works on sane cases. Now check whether non-existent headers
# can be detected and how.
/* confdefs.h. */
_ACEOF
@@ -4159,7 +4470,8 @@
else
ac_cpp_err=
fi
@@ -4187,17 +4499,17 @@
fi
done
- ac_cv_prog_CXXCPP=$CXXCPP
+ ac_cv_prog_CPP=$CPP
fi
- CXXCPP=$ac_cv_prog_CXXCPP
+ CPP=$ac_cv_prog_CPP
else
fi
-echo "$as_me:$LINENO: result: $CXXCPP" >&5
-echo "${ECHO_T}$CXXCPP" >&6
+echo "$as_me:$LINENO: result: $CPP" >&5
+echo "${ECHO_T}$CPP" >&6
ac_preproc_ok=false
do
@@ -4206,7 +4518,6 @@
/* confdefs.h. */
_ACEOF
@@ -4217,7 +4528,7 @@
#else
#endif
- Syntax error
+ Syntax error
_ACEOF
@@ -4228,7 +4539,8 @@
else
ac_cpp_err=
fi
@@ -4249,7 +4561,6 @@
/* confdefs.h. */
_ACEOF
@@ -4266,7 +4577,8 @@
else
ac_cpp_err=
fi
@@ -4292,42 +4604,26 @@
if $ac_preproc_ok; then
else
- { { echo "$as_me:$LINENO: error: C++ preprocessor \"$CXXCPP\" fails sanity check
+ { { echo "$as_me:$LINENO: error: C preprocessor \"$CPP\" fails sanity check
See \`config.log' for more details." >&5
-echo "$as_me: error: C++ preprocessor \"$CXXCPP\" fails sanity check
+echo "$as_me: error: C preprocessor \"$CPP\" fails sanity check
See \`config.log' for more details." >&2;}
fi
-ac_ext=cc
+ac_ext=c
-echo "$as_me:$LINENO: checking for egrep" >&5
-echo $ECHO_N "checking for egrep... $ECHO_C" >&6
-if test "${ac_cv_prog_egrep+set}" = set; then
-else
- if echo a | (grep -E '(a|b)') >/dev/null 2>&1
- then ac_cv_prog_egrep='grep -E'
- else ac_cv_prog_egrep='egrep'
- fi
-fi
-echo "$as_me:$LINENO: result: $ac_cv_prog_egrep" >&5
-echo "${ECHO_T}$ac_cv_prog_egrep" >&6
- EGREP=$ac_cv_prog_egrep
echo "$as_me:$LINENO: checking for ANSI C header files" >&5
echo $ECHO_N "checking for ANSI C header files... $ECHO_C" >&6
if test "${ac_cv_header_stdc+set}" = set; then
else
/* confdefs.h. */
_ACEOF
@@ -4348,15 +4644,25 @@
_ACEOF
ac_status=$?
(eval $ac_try) 2>&5
ac_status=$?
+ ac_status=$?
ac_cv_header_stdc=yes
else
@@ -4365,12 +4671,11 @@
ac_cv_header_stdc=no
fi
if test $ac_cv_header_stdc = yes; then
# SunOS 4.x string.h does not declare mem*, contrary to ANSI.
/* confdefs.h. */
_ACEOF
@@ -4392,7 +4697,6 @@
# ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
/* confdefs.h. */
_ACEOF
@@ -4417,7 +4721,6 @@
else
/* confdefs.h. */
_ACEOF
@@ -4429,9 +4732,9 @@
# define TOUPPER(c) (ISLOWER(c) ? 'A' + ((c) - 'a') : (c))
#else
# define ISLOWER(c) \
- (('a' <= (c) && (c) <= 'i') \
- || ('j' <= (c) && (c) <= 'r') \
- || ('s' <= (c) && (c) <= 'z'))
+ (('a' <= (c) && (c) <= 'i') \
+ || ('j' <= (c) && (c) <= 'r') \
+ || ('s' <= (c) && (c) <= 'z'))
# define TOUPPER(c) (ISLOWER(c) ? ((c) | 0x40) : (c))
#endif
@@ -4442,7 +4745,7 @@
int i;
for (i = 0; i < 256; i++)
if (XOR (islower (i), ISLOWER (i))
- || toupper (i) != TOUPPER (i))
+ || toupper (i) != TOUPPER (i))
exit(2);
exit (0);
@@ -4467,7 +4770,7 @@
( exit $ac_status )
fi
-rm -f core core.* *.core gmon.out bb.out conftest$ac_exeext conftest.$ac_objext conftest.$ac_ext
+rm -f core *.core gmon.out bb.out conftest$ac_exeext conftest.$ac_objext conftest.$ac_ext
fi
fi
fi
@@ -4492,7 +4795,7 @@
for ac_header in sys/types.h sys/stat.h stdlib.h string.h memory.h strings.h \
- inttypes.h stdint.h unistd.h
+ inttypes.h stdint.h unistd.h
do
as_ac_Header=`echo "ac_cv_header_$ac_header" | $as_tr_sh`
echo "$as_me:$LINENO: checking for $ac_header" >&5
@@ -4501,7 +4804,6 @@
else
/* confdefs.h. */
_ACEOF
@@ -4513,15 +4815,25 @@
_ACEOF
ac_status=$?
(eval $ac_try) 2>&5
ac_status=$?
+ ac_status=$?
eval "$as_ac_Header=yes"
else
@@ -4530,7 +4842,7 @@
eval "$as_ac_Header=no"
fi
fi
echo "$as_me:$LINENO: result: `eval echo '${'$as_ac_Header'}'`" >&5
echo "${ECHO_T}`eval echo '${'$as_ac_Header'}'`" >&6
@@ -4561,7 +4873,6 @@
echo "$as_me:$LINENO: checking $ac_header usability" >&5
echo $ECHO_N "checking $ac_header usability... $ECHO_C" >&6
/* confdefs.h. */
_ACEOF
@@ -4572,15 +4883,25 @@
_ACEOF
ac_status=$?
(eval $ac_try) 2>&5
ac_status=$?
+ ac_status=$?
ac_header_compiler=yes
else
@@ -4589,7 +4910,7 @@
ac_header_compiler=no
fi
echo "$as_me:$LINENO: result: $ac_header_compiler" >&5
echo "${ECHO_T}$ac_header_compiler" >&6
@@ -4597,7 +4918,6 @@
echo "$as_me:$LINENO: checking $ac_header presence" >&5
echo $ECHO_N "checking $ac_header presence... $ECHO_C" >&6
/* confdefs.h. */
_ACEOF
@@ -4614,7 +4934,8 @@
else
ac_cpp_err=
fi
@@ -4634,33 +4955,32 @@
echo "${ECHO_T}$ac_header_preproc" >&6
# So? What about this header?
-case $ac_header_compiler:$ac_header_preproc in
- yes:no )
+case $ac_header_compiler:$ac_header_preproc:$ac_c_preproc_warn_flag in
+ yes:no: )
{ echo "$as_me:$LINENO: WARNING: $ac_header: accepted by the compiler, rejected by the preprocessor!" >&5
echo "$as_me: WARNING: $ac_header: accepted by the compiler, rejected by the preprocessor!" >&2;}
- { echo "$as_me:$LINENO: WARNING: $ac_header: proceeding with the preprocessor's result" >&5
-echo "$as_me: WARNING: $ac_header: proceeding with the preprocessor's result" >&2;}
- cat <<\_ASBOX
-## Report this to bug-autoconf at gnu.org. ##
-_ASBOX
- sed "s/^/$as_me: WARNING: /" >&2
+ { echo "$as_me:$LINENO: WARNING: $ac_header: proceeding with the compiler's result" >&5
+echo "$as_me: WARNING: $ac_header: proceeding with the compiler's result" >&2;}
+ ac_header_preproc=yes
- no:yes )
+ no:yes:* )
{ echo "$as_me:$LINENO: WARNING: $ac_header: present but cannot be compiled" >&5
echo "$as_me: WARNING: $ac_header: present but cannot be compiled" >&2;}
- { echo "$as_me:$LINENO: WARNING: $ac_header: check for missing prerequisite headers?" >&5
-echo "$as_me: WARNING: $ac_header: check for missing prerequisite headers?" >&2;}
+ { echo "$as_me:$LINENO: WARNING: $ac_header: check for missing prerequisite headers?" >&5
+echo "$as_me: WARNING: $ac_header: check for missing prerequisite headers?" >&2;}
+ { echo "$as_me:$LINENO: WARNING: $ac_header: see the Autoconf documentation" >&5
+echo "$as_me: WARNING: $ac_header: see the Autoconf documentation" >&2;}
+ { echo "$as_me:$LINENO: WARNING: $ac_header: section \"Present But Cannot Be Compiled\"" >&5
+echo "$as_me: WARNING: $ac_header: section \"Present But Cannot Be Compiled\"" >&2;}
+ { echo "$as_me:$LINENO: WARNING: $ac_header: in the future, the compiler will take precedence" >&5
+echo "$as_me: WARNING: $ac_header: in the future, the compiler will take precedence" >&2;}
cat <<\_ASBOX
+## Report this to http://www.fdo.osgeo.org ##
_ASBOX
@@ -4671,7 +4991,7 @@
if eval "test \"\${$as_ac_Header+set}\" = set"; then
else
- eval "$as_ac_Header=$ac_header_preproc"
+ eval "$as_ac_Header=\$ac_header_preproc"
fi
@@ -4688,147 +5008,958 @@
+if test -n "$CXX" && ( test "X$CXX" != "Xno" &&
+ ( (test "X$CXX" = "Xg++" && `g++ -v >/dev/null 2>&1` ) ||
+ (test "X$CXX" != "Xg++"))) ; then
+ ac_ext=cc
+ac_cpp='$CXXCPP $CPPFLAGS'
+ac_compile='$CXX -c $CXXFLAGS $CPPFLAGS conftest.$ac_ext >&5'
+ac_link='$CXX -o conftest$ac_exeext $CXXFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
+ac_compiler_gnu=$ac_cv_cxx_compiler_gnu
+echo "$as_me:$LINENO: checking how to run the C++ preprocessor" >&5
+echo $ECHO_N "checking how to run the C++ preprocessor... $ECHO_C" >&6
+if test -z "$CXXCPP"; then
+ if test "${ac_cv_prog_CXXCPP+set}" = set; then
+else
+ # Double quotes because CXXCPP needs to be expanded
+ for CXXCPP in "$CXX -E" "/lib/cpp"
+ do
+ ac_preproc_ok=false
+for ac_cxx_preproc_warn_flag in '' yes
+do
+ # Use a header file that comes with gcc, so configuring glibc
+ # with a fresh cross-compiler works.
+ # Prefer <limits.h> to <assert.h> if __STDC__ is defined, since
+ # <limits.h> exists even on freestanding compilers.
+ # On the NeXT, cc -E runs the code through the compiler's parser,
+ # not just through cpp. "Syntax error" is here to catch this case.
+/* confdefs.h. */
+_ACEOF
+#ifdef __STDC__
+# include <limits.h>
+#else
+# include <assert.h>
+#endif
+ Syntax error
+_ACEOF
+if { (eval echo "$as_me:$LINENO: \"$ac_cpp conftest.$ac_ext\"") >&5
+ (eval $ac_cpp conftest.$ac_ext) 2>conftest.er1
+ ac_status=$?
+ (exit $ac_status); } >/dev/null; then
+ if test -s conftest.err; then
+ ac_cpp_err=$ac_cxx_preproc_warn_flag
+ ac_cpp_err=$ac_cpp_err$ac_cxx_werror_flag
+ else
+ ac_cpp_err=
+ fi
+else
+ ac_cpp_err=yes
+fi
+if test -z "$ac_cpp_err"; then
+else
+ # Broken: fails on valid input.
+continue
+fi
+rm -f conftest.err conftest.$ac_ext
+ # OK, works on sane cases. Now check whether non-existent headers
+ # can be detected and how.
+/* confdefs.h. */
+_ACEOF
+#include <ac_nonexistent.h>
+_ACEOF
+ ac_status=$?
+ else
+ ac_cpp_err=
+ fi
+else
+ ac_cpp_err=yes
+fi
+ # Broken: success on invalid input.
+continue
+else
-# Only perform the check for file, if the check method requires it
-case $deplibs_check_method in
-file_magic*)
- if test "$file_magic_cmd" = '$MAGIC_CMD'; then
- echo "$as_me:$LINENO: checking for ${ac_tool_prefix}file" >&5
-echo $ECHO_N "checking for ${ac_tool_prefix}file... $ECHO_C" >&6
-if test "${lt_cv_path_MAGIC_CMD+set}" = set; then
+ # Passes both tests.
+ac_preproc_ok=:
+break
+fi
+done
+# Because of `break', _AC_PREPROC_IFELSE's cleaning code was skipped.
+if $ac_preproc_ok; then
+ break
+fi
+ done
+ ac_cv_prog_CXXCPP=$CXXCPP
+fi
+ CXXCPP=$ac_cv_prog_CXXCPP
+else
+fi
+echo "$as_me:$LINENO: result: $CXXCPP" >&5
+echo "${ECHO_T}$CXXCPP" >&6
+ac_preproc_ok=false
+do
+/* confdefs.h. */
+_ACEOF
+#ifdef __STDC__
+#else
+#endif
+ Syntax error
+_ACEOF
+ ac_status=$?
+ else
+ ac_cpp_err=
+ fi
+else
+ ac_cpp_err=yes
+fi
+else
+continue
+fi
+/* confdefs.h. */
+_ACEOF
+_ACEOF
+ ac_status=$?
+ else
+ ac_cpp_err=
+ fi
+else
+ ac_cpp_err=yes
+fi
+continue
+else
+ac_preproc_ok=:
+break
+fi
+done
+else
+ { { echo "$as_me:$LINENO: error: C++ preprocessor \"$CXXCPP\" fails sanity check
+See \`config.log' for more details." >&5
+echo "$as_me: error: C++ preprocessor \"$CXXCPP\" fails sanity check
+See \`config.log' for more details." >&2;}
+ { (exit 1); exit 1; }; }
+fi
+ac_ext=cc
+fi
+ac_ext=f
+ac_compile='$F77 -c $FFLAGS conftest.$ac_ext >&5'
+ac_link='$F77 -o conftest$ac_exeext $FFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
+ac_compiler_gnu=$ac_cv_f77_compiler_gnu
+if test -n "$ac_tool_prefix"; then
+ for ac_prog in g77 f77 xlf frt pgf77 fort77 fl32 af77 f90 xlf90 pgf90 epcf90 f95 fort xlf95 ifc efc pgf95 lf95 gfortran
+ do
+ # Extract the first word of "$ac_tool_prefix$ac_prog", so it can be a program name with args.
+set dummy $ac_tool_prefix$ac_prog; ac_word=$2
+echo "$as_me:$LINENO: checking for $ac_word" >&5
+echo $ECHO_N "checking for $ac_word... $ECHO_C" >&6
+if test "${ac_cv_prog_F77+set}" = set; then
else
- case $MAGIC_CMD in
- lt_cv_path_MAGIC_CMD="$MAGIC_CMD" # Let the user override the test with a path.
- lt_cv_path_MAGIC_CMD="$MAGIC_CMD" # Let the user override the test with a dos path.
- ac_save_MAGIC_CMD="$MAGIC_CMD"
- IFS="${IFS= }"; ac_save_ifs="$IFS"; IFS=":"
- ac_dummy="/usr/bin:$PATH"
- for ac_dir in $ac_dummy; do
- if test -f $ac_dir/${ac_tool_prefix}file; then
- lt_cv_path_MAGIC_CMD="$ac_dir/${ac_tool_prefix}file"
- if test -n "$file_magic_test_file"; then
- case $deplibs_check_method in
- "file_magic "*)
- file_magic_regex="`expr \"$deplibs_check_method\" : \"file_magic \(.*\)\"`"
- MAGIC_CMD="$lt_cv_path_MAGIC_CMD"
- if eval $file_magic_cmd \$file_magic_test_file 2> /dev/null |
- egrep "$file_magic_regex" > /dev/null; then
- else
- cat <<EOF 1>&2
+ if test -n "$F77"; then
+ ac_cv_prog_F77="$F77" # Let the user override the test.
+else
+do
+ IFS=$as_save_IFS
+ if $as_executable_p "$as_dir/$ac_word$ac_exec_ext"; then
+ ac_cv_prog_F77="$ac_tool_prefix$ac_prog"
+ echo "$as_me:$LINENO: found $as_dir/$ac_word$ac_exec_ext" >&5
+ break 2
+ fi
+done
+done
-*** Warning: the command libtool uses to detect shared libraries,
-*** $file_magic_cmd, produces output that libtool cannot recognize.
-*** The result is that libtool may fail to recognize shared libraries
-*** as such. This will affect the creation of libtool libraries that
-*** depend on shared libraries, but programs linked with such libtool
-*** libraries will work regardless of this problem. Nevertheless, you
-*** may want to report the problem to your system manager and/or to
-*** bug-libtool at gnu.org
+fi
+fi
+F77=$ac_cv_prog_F77
+if test -n "$F77"; then
+ echo "$as_me:$LINENO: result: $F77" >&5
+echo "${ECHO_T}$F77" >&6
+else
+ echo "$as_me:$LINENO: result: no" >&5
+echo "${ECHO_T}no" >&6
+fi
-EOF
- fi ;;
- esac
- fi
- break
- fi
+ test -n "$F77" && break
done
- MAGIC_CMD="$ac_save_MAGIC_CMD"
-esac
fi
+if test -z "$F77"; then
+ ac_ct_F77=$F77
+do
+ # Extract the first word of "$ac_prog", so it can be a program name with args.
+set dummy $ac_prog; ac_word=$2
+if test "${ac_cv_prog_ac_ct_F77+set}" = set; then
+else
+ if test -n "$ac_ct_F77"; then
+ ac_cv_prog_ac_ct_F77="$ac_ct_F77" # Let the user override the test.
+else
+do
+ IFS=$as_save_IFS
+ ac_cv_prog_ac_ct_F77="$ac_prog"
+ break 2
+ fi
+done
+done
-MAGIC_CMD="$lt_cv_path_MAGIC_CMD"
-if test -n "$MAGIC_CMD"; then
- echo "$as_me:$LINENO: result: $MAGIC_CMD" >&5
-echo "${ECHO_T}$MAGIC_CMD" >&6
+fi
+fi
+ac_ct_F77=$ac_cv_prog_ac_ct_F77
+if test -n "$ac_ct_F77"; then
+ echo "$as_me:$LINENO: result: $ac_ct_F77" >&5
+echo "${ECHO_T}$ac_ct_F77" >&6
else
fi
-if test -z "$lt_cv_path_MAGIC_CMD"; then
- if test -n "$ac_tool_prefix"; then
- echo "$as_me:$LINENO: checking for file" >&5
-echo $ECHO_N "checking for file... $ECHO_C" >&6
+ test -n "$ac_ct_F77" && break
+done
+ F77=$ac_ct_F77
+fi
+# Provide some information about the compiler.
+echo "$as_me:5339:" \
+ "checking for Fortran 77 compiler version" >&5
+ac_compiler=`set X $ac_compile; echo $2`
+{ (eval echo "$as_me:$LINENO: \"$ac_compiler --version </dev/null >&5\"") >&5
+ (eval $ac_compiler --version </dev/null >&5) 2>&5
+ ac_status=$?
+{ (eval echo "$as_me:$LINENO: \"$ac_compiler -v </dev/null >&5\"") >&5
+ (eval $ac_compiler -v </dev/null >&5) 2>&5
+ ac_status=$?
+{ (eval echo "$as_me:$LINENO: \"$ac_compiler -V </dev/null >&5\"") >&5
+ (eval $ac_compiler -V </dev/null >&5) 2>&5
+ ac_status=$?
+rm -f a.out
+# If we don't use `.F' as extension, the preprocessor is not run on the
+# input file. (Note that this only needs to work for GNU compilers.)
+ac_save_ext=$ac_ext
+ac_ext=F
+echo "$as_me:$LINENO: checking whether we are using the GNU Fortran 77 compiler" >&5
+echo $ECHO_N "checking whether we are using the GNU Fortran 77 compiler... $ECHO_C" >&6
+if test "${ac_cv_f77_compiler_gnu+set}" = set; then
else
+ program main
+#ifndef __GNUC__
+ choke me
+#endif
+ end
+_ACEOF
+if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
+ ac_status=$?
+ { ac_try='test -z "$ac_f77_werror_flag"
+ ac_status=$?
+ ac_status=$?
+ ac_compiler_gnu=yes
+else
+ac_compiler_gnu=no
+fi
+ac_cv_f77_compiler_gnu=$ac_compiler_gnu
+fi
+echo "$as_me:$LINENO: result: $ac_cv_f77_compiler_gnu" >&5
+echo "${ECHO_T}$ac_cv_f77_compiler_gnu" >&6
+ac_ext=$ac_save_ext
+ac_test_FFLAGS=${FFLAGS+set}
+ac_save_FFLAGS=$FFLAGS
+FFLAGS=
+echo "$as_me:$LINENO: checking whether $F77 accepts -g" >&5
+echo $ECHO_N "checking whether $F77 accepts -g... $ECHO_C" >&6
+if test "${ac_cv_prog_f77_g+set}" = set; then
+else
+ FFLAGS=-g
+cat >conftest.$ac_ext <<_ACEOF
+ program main
+ end
+_ACEOF
+ ac_status=$?
+ ac_status=$?
+ ac_status=$?
+ ac_cv_prog_f77_g=yes
+else
+ac_cv_prog_f77_g=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_prog_f77_g" >&5
+echo "${ECHO_T}$ac_cv_prog_f77_g" >&6
+if test "$ac_test_FFLAGS" = set; then
+ FFLAGS=$ac_save_FFLAGS
+elif test $ac_cv_prog_f77_g = yes; then
+ if test "x$ac_cv_f77_compiler_gnu" = xyes; then
+ FFLAGS="-g -O2"
+ else
+ FFLAGS="-g"
+ fi
+else
+ FFLAGS="-O2"
+ else
+ FFLAGS=
+ fi
+fi
+G77=`test $ac_compiler_gnu = yes && echo yes`
+ac_ext=cc
+# Autoconf 2.13's AC_OBJEXT and AC_EXEEXT macros only works for C compilers!
+# find the maximum length of command line arguments
+echo "$as_me:$LINENO: checking the maximum length of command line arguments" >&5
+echo $ECHO_N "checking the maximum length of command line arguments... $ECHO_C" >&6
+if test "${lt_cv_sys_max_cmd_len+set}" = set; then
+else
+ i=0
+ teststring="ABCD"
+ case $build_os in
+ msdosdjgpp*)
+ # On DJGPP, this test can blow up pretty badly due to problems in libc
+ # (any single argument exceeding 2000 bytes causes a buffer overrun
+ # during glob expansion). Even if it were fixed, the result of this
+ # check would be larger than it should be.
+ lt_cv_sys_max_cmd_len=12288; # 12K is about right
+ gnu*)
+ # Under GNU Hurd, this test is not required because there is
+ # no limit to the length of command line arguments.
+ # Libtool will interpret -1 as no limit whatsoever
+ lt_cv_sys_max_cmd_len=-1;
+ cygwin* | mingw*)
+ # On Win9x/ME, this test blows up -- it succeeds, but takes
+ # about 5 minutes as the teststring grows exponentially.
+ # Worse, since 9x/ME are not pre-emptively multitasking,
+ # you end up with a "frozen" computer, even though with patience
+ # the test eventually succeeds (with a max line length of 256k).
+ # Instead, let's just punt: use the minimum linelength reported by
+ # all of the supported platforms: 8192 (on NT/2K/XP).
+ lt_cv_sys_max_cmd_len=8192;
+ amigaos*)
+ # On AmigaOS with pdksh, this test takes hours, literally.
+ # So we just punt and use a minimum line length of 8192.
+ netbsd* | freebsd* | openbsd* | darwin* | dragonfly*)
+ # This has been around since 386BSD, at least. Likely further.
+ if test -x /sbin/sysctl; then
+ lt_cv_sys_max_cmd_len=`/sbin/sysctl -n kern.argmax`
+ elif test -x /usr/sbin/sysctl; then
+ lt_cv_sys_max_cmd_len=`/usr/sbin/sysctl -n kern.argmax`
+ else
+ lt_cv_sys_max_cmd_len=65536 # usable default for all BSDs
+ fi
+ # And add a safety zone
+ lt_cv_sys_max_cmd_len=`expr $lt_cv_sys_max_cmd_len \/ 4`
+ lt_cv_sys_max_cmd_len=`expr $lt_cv_sys_max_cmd_len \* 3`
+ interix*)
+ # We know the value 262144 and hardcode it with a safety zone (like BSD)
+ lt_cv_sys_max_cmd_len=196608
+ osf*)
+ # Dr. Hans Ekkehard Plesser reports seeing a kernel panic running configure
+ # due to this test when exec_disable_arg_limit is 1 on Tru64. It is not
+ # nice to cause kernel panics so lets avoid the loop below.
+ # First set a reasonable default.
+ lt_cv_sys_max_cmd_len=16384
+ if test -x /sbin/sysconfig; then
+ case `/sbin/sysconfig -q proc exec_disable_arg_limit` in
+ *1*) lt_cv_sys_max_cmd_len=-1 ;;
+ esac
+ fi
+ sco3.2v5*)
+ lt_cv_sys_max_cmd_len=102400
+ sysv5* | sco5v6* | sysv4.2uw2*)
+ kargmax=`grep ARG_MAX /etc/conf/cf.d/stune 2>/dev/null`
+ if test -n "$kargmax"; then
+ lt_cv_sys_max_cmd_len=`echo $kargmax | sed 's/.*[ ]//'`
+ else
+ lt_cv_sys_max_cmd_len=32768
+ fi
+ # If test is not a shell built-in, we'll probably end up computing a
+ # maximum length that is only half of the actual maximum length, but
+ # we can't tell.
+ SHELL=${SHELL-${CONFIG_SHELL-/bin/sh}}
+ while (test "X"`$SHELL $0 --fallback-echo "X$teststring" 2>/dev/null` \
+ = "XX$teststring") >/dev/null 2>&1 &&
+ new_result=`expr "X$teststring" : ".*" 2>&1` &&
+ lt_cv_sys_max_cmd_len=$new_result &&
+ test $i != 17 # 1/2 MB should be enough
+ do
+ i=`expr $i + 1`
+ teststring=$teststring$teststring
+ done
+ teststring=
+ # Add a significant safety factor because C++ compilers can tack on massive
+ # amounts of additional arguments before passing them to the linker.
+ # It appears as though 1/2 is a usable value.
+ lt_cv_sys_max_cmd_len=`expr $lt_cv_sys_max_cmd_len \/ 2`
+ esac
+fi
+if test -n $lt_cv_sys_max_cmd_len ; then
+ echo "$as_me:$LINENO: result: $lt_cv_sys_max_cmd_len" >&5
+echo "${ECHO_T}$lt_cv_sys_max_cmd_len" >&6
+else
+ echo "$as_me:$LINENO: result: none" >&5
+echo "${ECHO_T}none" >&6
+fi
+# Check for command to grab the raw symbol name followed by C symbol from nm.
+echo "$as_me:$LINENO: checking command to parse $NM output from $compiler object" >&5
+echo $ECHO_N "checking command to parse $NM output from $compiler object... $ECHO_C" >&6
+if test "${lt_cv_sys_global_symbol_pipe+set}" = set; then
+else
+# These are sane defaults that work on at least a few old systems.
+# [They come from Ultrix. What could be older than Ultrix?!! ;)]
+# Character class describing NM global symbol codes.
+symcode='[BCDEGRST]'
+# Regexp to match symbols that can be accessed directly from C.
+sympat='\([_A-Za-z][_A-Za-z0-9]*\)'
+# Transform an extracted symbol line into a proper C declaration
+lt_cv_sys_global_symbol_to_cdecl="sed -n -e 's/^. .* \(.*\)$/extern int \1;/p'"
+# Transform an extracted symbol line into symbol name and symbol address
+lt_cv_sys_global_symbol_to_c_name_address="sed -n -e 's/^: \([^ ]*\) $/ {\\\"\1\\\", (lt_ptr) 0},/p' -e 's/^$symcode \([^ ]*\) \([^ ]*\)$/ {\"\2\", (lt_ptr) \&\2},/p'"
+# Define system-specific variables.
+case $host_os in
+aix*)
+ symcode='[BCDT]'
+cygwin* | mingw* | pw32*)
+ symcode='[ABCDGISTW]'
- if test -f $ac_dir/file; then
- lt_cv_path_MAGIC_CMD="$ac_dir/file"
- "file_magic "*)
- else
- cat <<EOF 1>&2
+hpux*) # Its linker distinguishes data from code symbols
+ if test "$host_cpu" = ia64; then
+ symcode='[ABCDEGRST]'
+ fi
+ lt_cv_sys_global_symbol_to_cdecl="sed -n -e 's/^T .* \(.*\)$/extern int \1();/p' -e 's/^$symcode* .* \(.*\)$/extern char \1;/p'"
+ lt_cv_sys_global_symbol_to_c_name_address="sed -n -e 's/^: \([^ ]*\) $/ {\\\"\1\\\", (lt_ptr) 0},/p' -e 's/^$symcode* \([^ ]*\) \([^ ]*\)$/ {\"\2\", (lt_ptr) \&\2},/p'"
+linux*)
+ symcode='[ABCDGIRSTW]'
+ fi
+irix* | nonstopux*)
+ symcode='[BCDEGRST]'
+osf*)
+ symcode='[BCDEGQRST]'
+solaris*)
+ symcode='[BDRT]'
+sco3.2v5*)
+ symcode='[DT]'
+sysv4.2uw2*)
+ symcode='[DT]'
+sysv5* | sco5v6* | unixware* | OpenUNIX*)
+ symcode='[ABDT]'
+sysv4)
+ symcode='[DFNSTU]'
+esac
+# Handle CRLF in mingw tool chain
+opt_cr=
+case $build_os in
+mingw*)
+ opt_cr=`echo 'x\{0,1\}' | tr x '\015'` # option cr in regexp
+esac
+# If we're using GNU nm, then use its standard symbol codes.
+case `$NM -V 2>&1` in
+ symcode='[ABCDGIRSTW]' ;;
+esac
+# Try without a prefix undercore, then with it.
+for ac_symprfx in "" "_"; do
+ # Transform symcode, sympat, and symprfx into a raw symbol and a C symbol.
+ symxfrm="\\1 $ac_symprfx\\2 \\2"
+ # Write the raw and C identifiers.
+ lt_cv_sys_global_symbol_pipe="sed -n -e 's/^.*[ ]\($symcode$symcode*\)[ ][ ]*$ac_symprfx$sympat$opt_cr$/$symxfrm/p'"
+ # Check to see that the pipe works correctly.
+ pipe_works=no
+ rm -f conftest*
+ cat > conftest.$ac_ext <<EOF
+#ifdef __cplusplus
+extern "C" {
+#endif
+char nm_test_var;
+void nm_test_func(){}
+#ifdef __cplusplus
+#endif
+int main(){nm_test_var='a';nm_test_func();return(0);}
EOF
- fi ;;
- esac
+ ac_status=$?
+ # Now try to grab the symbols.
+ nlist=conftest.nm
+ if { (eval echo "$as_me:$LINENO: \"$NM conftest.$ac_objext \| $lt_cv_sys_global_symbol_pipe \> $nlist\"") >&5
+ (eval $NM conftest.$ac_objext \| $lt_cv_sys_global_symbol_pipe \> $nlist) 2>&5
+ ac_status=$?
+ (exit $ac_status); } && test -s "$nlist"; then
+ # Try sorting and uniquifying the output.
+ if sort "$nlist" | uniq > "$nlist"T; then
+ mv -f "$nlist"T "$nlist"
+ else
+ rm -f "$nlist"T
fi
- break
+ # Make sure that we snagged all the symbols we need.
+ if grep ' nm_test_var$' "$nlist" >/dev/null; then
+ if grep ' nm_test_func$' "$nlist" >/dev/null; then
+ cat <<EOF > conftest.$ac_ext
+#ifdef __cplusplus
+extern "C" {
+#endif
+EOF
+ # Now generate the symbol file.
+ eval "$lt_cv_sys_global_symbol_to_cdecl"' < "$nlist" | grep -v main >> conftest.$ac_ext'
+ cat <<EOF >> conftest.$ac_ext
+#if defined (__STDC__) && __STDC__
+# define lt_ptr_t void *
+#else
+# define lt_ptr_t char *
+# define const
+#endif
+/* The mapping between symbol names and symbols. */
+const struct {
+ const char *name;
+ lt_ptr_t address;
+lt_preloaded_symbols[] =
+EOF
+ $SED "s/^$symcode$symcode* \(.*\) \(.*\)$/ {\"\2\", (lt_ptr_t) \&\2},/" < "$nlist" | grep -v main >> conftest.$ac_ext
+ cat <<\EOF >> conftest.$ac_ext
+ {0, (lt_ptr_t) 0}
+#ifdef __cplusplus
+#endif
+EOF
+ # Now try linking the two files.
+ mv conftest.$ac_objext conftstm.$ac_objext
+ lt_save_LIBS="$LIBS"
+ lt_save_CFLAGS="$CFLAGS"
+ LIBS="conftstm.$ac_objext"
+ CFLAGS="$CFLAGS$lt_prog_compiler_no_builtin_flag"
+ if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
+ (eval $ac_link) 2>&5
+ ac_status=$?
+ echo "$as_me:$LINENO: \$? = $ac_status" >&5
+ (exit $ac_status); } && test -s conftest${ac_exeext}; then
+ pipe_works=yes
+ fi
+ LIBS="$lt_save_LIBS"
+ CFLAGS="$lt_save_CFLAGS"
+ else
+ echo "cannot find nm_test_func in $nlist" >&5
+ fi
+ else
+ echo "cannot find nm_test_var in $nlist" >&5
+ fi
+ else
+ echo "cannot run $lt_cv_sys_global_symbol_pipe" >&5
fi
- done
+ else
+ echo "$progname: failed program was:" >&5
+ cat conftest.$ac_ext >&5
+ fi
+ rm -f conftest* conftst*
+ # Do not use the global_symbol_pipe unless it works.
+ if test "$pipe_works" = yes; then
+ break
+ else
+ fi
+done
+fi
+if test -z "$lt_cv_sys_global_symbol_pipe"; then
+fi
+if test -z "$lt_cv_sys_global_symbol_pipe$lt_cv_sys_global_symbol_to_cdecl"; then
+ echo "$as_me:$LINENO: result: failed" >&5
+echo "${ECHO_T}failed" >&6
+else
+ echo "$as_me:$LINENO: result: ok" >&5
+echo "${ECHO_T}ok" >&6
+fi
+echo "$as_me:$LINENO: checking for objdir" >&5
+echo $ECHO_N "checking for objdir... $ECHO_C" >&6
+if test "${lt_cv_objdir+set}" = set; then
+else
+ rm -f .libs 2>/dev/null
+mkdir .libs 2>/dev/null
+if test -d .libs; then
+ lt_cv_objdir=.libs
+else
+ # MS-DOS does not allow filenames that begin with a dot.
+ lt_cv_objdir=_libs
+fi
+rmdir .libs 2>/dev/null
+fi
+echo "$as_me:$LINENO: result: $lt_cv_objdir" >&5
+echo "${ECHO_T}$lt_cv_objdir" >&6
+objdir=$lt_cv_objdir
+case $host_os in
+aix3*)
+ # AIX sometimes has problems with the GCC collect2 program. For some
+ # reason, if we set the COLLECT_NAMES environment variable, the problems
+ # vanish in a puff of smoke.
+ if test "X${COLLECT_NAMES+set}" != Xset; then
+ COLLECT_NAMES=
+ export COLLECT_NAMES
+ fi
esac
-fi
+# Sed substitution that helps us do robust quoting. It backslashifies
+# metacharacters that are still active within double-quoted strings.
+Xsed='sed -e 1s/^X//'
+sed_quote_subst='s/\([\\"\\`$\\\\]\)/\\\1/g'
+# Same as above, but do not quote variable references.
+double_quote_subst='s/\([\\"\\`\\\\]\)/\\\1/g'
+# Sed substitution to delay expansion of an escaped shell variable in a
+# double_quote_subst'ed string.
+delay_variable_subst='s/\\\\\\\\\\\$/\\\\\\$/g'
+# Sed substitution to avoid accidental globbing in evaled expressions
+no_glob_subst='s/\*/\\\*/g'
+# Constants:
+rm="rm -f"
+# Global variables:
+default_ofile=libtool
+can_build_shared=yes
+# All known linkers require a `.a' archive for static linking (except MSVC,
+# which needs '.lib').
+libext=a
+ltmain="$ac_aux_dir/ltmain.sh"
+ofile="$default_ofile"
+with_gnu_ld="$lt_cv_prog_gnu_ld"
+ # Extract the first word of "${ac_tool_prefix}ar", so it can be a program name with args.
+set dummy ${ac_tool_prefix}ar; ac_word=$2
+if test "${ac_cv_prog_AR+set}" = set; then
else
+ if test -n "$AR"; then
+ ac_cv_prog_AR="$AR" # Let the user override the test.
+else
+do
+ IFS=$as_save_IFS
+ ac_cv_prog_AR="${ac_tool_prefix}ar"
+ break 2
+ fi
+done
+done
+fi
+fi
+AR=$ac_cv_prog_AR
+if test -n "$AR"; then
+ echo "$as_me:$LINENO: result: $AR" >&5
+echo "${ECHO_T}$AR" >&6
+else
fi
- else
- MAGIC_CMD=:
+fi
+if test -z "$ac_cv_prog_AR"; then
+ ac_ct_AR=$AR
+ # Extract the first word of "ar", so it can be a program name with args.
+set dummy ar; ac_word=$2
+if test "${ac_cv_prog_ac_ct_AR+set}" = set; then
+else
+ if test -n "$ac_ct_AR"; then
+ ac_cv_prog_ac_ct_AR="$ac_ct_AR" # Let the user override the test.
+else
+do
+ IFS=$as_save_IFS
+ ac_cv_prog_ac_ct_AR="ar"
+ break 2
fi
+done
+done
+ test -z "$ac_cv_prog_ac_ct_AR" && ac_cv_prog_ac_ct_AR="false"
fi
+fi
+ac_ct_AR=$ac_cv_prog_ac_ct_AR
+if test -n "$ac_ct_AR"; then
+ echo "$as_me:$LINENO: result: $ac_ct_AR" >&5
+echo "${ECHO_T}$ac_ct_AR" >&6
+else
+fi
- fi
-esac
+ AR=$ac_ct_AR
+else
+ AR="$ac_cv_prog_AR"
+fi
# Extract the first word of "${ac_tool_prefix}ranlib", so it can be a program name with args.
@@ -4991,140 +6122,6 @@
fi
-enable_dlopen=no
-enable_win32_dll=no
-# Check whether --enable-libtool-lock or --disable-libtool-lock was given.
-if test "${enable_libtool_lock+set}" = set; then
- enableval="$enable_libtool_lock"
-fi;
-test "x$enable_libtool_lock" != xno && enable_libtool_lock=yes
-# Some flags need to be propagated to the compiler or linker for good
-# libtool support.
-case $host in
-*-*-irix6*)
- # Find out which ABI we are using.
- echo '#line 5009 "configure"' > conftest.$ac_ext
- (eval $ac_compile) 2>&5
- ac_status=$?
- echo "$as_me:$LINENO: \$? = $ac_status" >&5
- case `/usr/bin/file conftest.$ac_objext` in
- *32-bit*)
- LD="${LD-ld} -32"
- *N32*)
- LD="${LD-ld} -n32"
- *64-bit*)
- LD="${LD-ld} -64"
- esac
- fi
- rm -rf conftest*
-*-*-sco3.2v5*)
- # On SCO OpenServer 5, we need -belf to get full-featured binaries.
- SAVE_CFLAGS="$CFLAGS"
- CFLAGS="$CFLAGS -belf"
- echo "$as_me:$LINENO: checking whether the C compiler needs -belf" >&5
-echo $ECHO_N "checking whether the C compiler needs -belf... $ECHO_C" >&6
-if test "${lt_cv_cc_needs_belf+set}" = set; then
-else
- ac_ext=c
-ac_cpp='$CPP $CPPFLAGS'
-ac_compile='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5'
-ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
-ac_compiler_gnu=$ac_cv_c_compiler_gnu
- cat >conftest.$ac_ext <<_ACEOF
-#line $LINENO "configure"
-/* confdefs.h. */
-_ACEOF
-cat confdefs.h >>conftest.$ac_ext
-cat >>conftest.$ac_ext <<_ACEOF
-/* end confdefs.h. */
-int
-main ()
- return 0;
-_ACEOF
-rm -f conftest.$ac_objext conftest$ac_exeext
-if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
- ac_status=$?
- { ac_try='test -s conftest$ac_exeext'
- { (eval echo "$as_me:$LINENO: \"$ac_try\"") >&5
- (eval $ac_try) 2>&5
- ac_status=$?
- (exit $ac_status); }; }; then
- lt_cv_cc_needs_belf=yes
-else
- echo "$as_me: failed program was:" >&5
-sed 's/^/| /' conftest.$ac_ext >&5
-lt_cv_cc_needs_belf=no
-fi
-rm -f conftest.$ac_objext conftest$ac_exeext conftest.$ac_ext
- ac_ext=cc
-fi
-echo "$as_me:$LINENO: result: $lt_cv_cc_needs_belf" >&5
-echo "${ECHO_T}$lt_cv_cc_needs_belf" >&6
- if test x"$lt_cv_cc_needs_belf" != x"yes"; then
- # this is probably gcc 2.8.0, egcs 1.0 or newer; no need for -belf
- CFLAGS="$SAVE_CFLAGS"
- fi
-esac
-# Sed substitution that helps us do robust quoting. It backslashifies
-# metacharacters that are still active within double-quoted strings.
-Xsed='sed -e s/^X//'
-sed_quote_subst='s/\([\\"\\`$\\\\]\)/\\\1/g'
-# Same as above, but do not quote variable references.
-double_quote_subst='s/\([\\"\\`\\\\]\)/\\\1/g'
-# Sed substitution to delay expansion of an escaped shell variable in a
-# double_quote_subst'ed string.
-delay_variable_subst='s/\\\\\\\\\\\$/\\\\\\$/g'
-# Constants:
-rm="rm -f"
-# Global variables:
-default_ofile=libtool
-can_build_shared=yes
-# All known linkers require a `.a' archive for static linking (except M$VC,
-# which needs '.lib').
-libext=a
-ltmain="$ac_aux_dir/ltmain.sh"
-ofile="$default_ofile"
-with_gnu_ld="$lt_cv_prog_gnu_ld"
-need_locks="$enable_libtool_lock"
old_CC="$CC"
old_CFLAGS="$CFLAGS"
@@ -5133,40 +6130,19 @@
test -z "$AR_FLAGS" && AR_FLAGS=cru
test -z "$AS" && AS=as
test -z "$CC" && CC=cc
+test -z "$LTCC" && LTCC=$CC
+test -z "$LTCFLAGS" && LTCFLAGS=$CFLAGS
test -z "$DLLTOOL" && DLLTOOL=dlltool
test -z "$LD" && LD=ld
test -z "$LN_S" && LN_S="ln -s"
test -z "$MAGIC_CMD" && MAGIC_CMD=file
test -z "$NM" && NM=nm
+test -z "$SED" && SED=sed
test -z "$OBJDUMP" && OBJDUMP=objdump
test -z "$RANLIB" && RANLIB=:
test -z "$STRIP" && STRIP=:
test -z "$ac_objext" && ac_objext=o
-if test x"$host" != x"$build"; then
- ac_tool_prefix=${host_alias}-
-else
- ac_tool_prefix=
-fi
-# Transform linux* to *-*-linux-gnu*, to support old configure scripts.
-case $host_os in
-linux-gnu*) ;;
-linux*) host=`echo $host | sed 's/^\(.*-.*-linux\)\(.*\)$/\1-gnu\2/'`
-esac
-case $host_os in
-aix3*)
- # AIX sometimes has problems with the GCC collect2 program. For some
- # reason, if we set the COLLECT_NAMES environment variable, the problems
- # vanish in a puff of smoke.
- if test "X${COLLECT_NAMES+set}" != Xset; then
- COLLECT_NAMES=
- export COLLECT_NAMES
- fi
-esac
# Determine commands to create old-style static archives.
old_archive_cmds='$AR $AR_FLAGS $oldlib$oldobjs$old_deplibs'
old_postinstall_cmds='chmod 644 $oldlib'
@@ -5175,35 +6151,172 @@
if test -n "$RANLIB"; then
case $host_os in
openbsd*)
- old_postinstall_cmds="\$RANLIB -t \$oldlib~$old_postinstall_cmds"
+ old_postinstall_cmds="$old_postinstall_cmds~\$RANLIB -t \$oldlib"
- old_postinstall_cmds="\$RANLIB \$oldlib~$old_postinstall_cmds"
+ old_postinstall_cmds="$old_postinstall_cmds~\$RANLIB \$oldlib"
esac
old_archive_cmds="$old_archive_cmds~\$RANLIB \$oldlib"
fi
-# Allow CC to be a program name with arguments.
-set dummy $CC
-compiler="$2"
+for cc_temp in $compiler""; do
+ case $cc_temp in
+ compile | *[\\/]compile | ccache | *[\\/]ccache ) ;;
+ distcc | *[\\/]distcc | purify | *[\\/]purify ) ;;
+ *) break;;
+ esac
+done
+cc_basename=`$echo "X$cc_temp" | $Xsed -e 's%.*/%%' -e "s%^$host_alias-%%"`
-echo "$as_me:$LINENO: checking for objdir" >&5
-echo $ECHO_N "checking for objdir... $ECHO_C" >&6
-rm -f .libs 2>/dev/null
-mkdir .libs 2>/dev/null
-if test -d .libs; then
- objdir=.libs
+# Only perform the check for file, if the check method requires it
+case $deplibs_check_method in
+file_magic*)
+ if test "$file_magic_cmd" = '$MAGIC_CMD'; then
+ echo "$as_me:$LINENO: checking for ${ac_tool_prefix}file" >&5
+echo $ECHO_N "checking for ${ac_tool_prefix}file... $ECHO_C" >&6
+if test "${lt_cv_path_MAGIC_CMD+set}" = set; then
else
- # MS-DOS does not allow filenames that begin with a dot.
- objdir=_libs
+ case $MAGIC_CMD in
+ lt_cv_path_MAGIC_CMD="$MAGIC_CMD" # Let the user override the test with a path.
+ lt_save_MAGIC_CMD="$MAGIC_CMD"
+ lt_save_ifs="$IFS"; IFS=$PATH_SEPARATOR
+ ac_dummy="/usr/bin$PATH_SEPARATOR$PATH"
+ for ac_dir in $ac_dummy; do
+ IFS="$lt_save_ifs"
+ if test -f $ac_dir/${ac_tool_prefix}file; then
+ lt_cv_path_MAGIC_CMD="$ac_dir/${ac_tool_prefix}file"
+ if test -n "$file_magic_test_file"; then
+ case $deplibs_check_method in
+ "file_magic "*)
+ file_magic_regex=`expr "$deplibs_check_method" : "file_magic \(.*\)"`
+ MAGIC_CMD="$lt_cv_path_MAGIC_CMD"
+ if eval $file_magic_cmd \$file_magic_test_file 2> /dev/null |
+ $EGREP "$file_magic_regex" > /dev/null; then
+ else
+ cat <<EOF 1>&2
+*** Warning: the command libtool uses to detect shared libraries,
+*** $file_magic_cmd, produces output that libtool cannot recognize.
+*** The result is that libtool may fail to recognize shared libraries
+*** as such. This will affect the creation of libtool libraries that
+*** depend on shared libraries, but programs linked with such libtool
+*** libraries will work regardless of this problem. Nevertheless, you
+*** may want to report the problem to your system manager and/or to
+*** bug-libtool at gnu.org
+EOF
+ fi ;;
+ esac
+ fi
+ break
+ fi
+ done
+ MAGIC_CMD="$lt_save_MAGIC_CMD"
+esac
fi
-rmdir .libs 2>/dev/null
-echo "$as_me:$LINENO: result: $objdir" >&5
-echo "${ECHO_T}$objdir" >&6
+MAGIC_CMD="$lt_cv_path_MAGIC_CMD"
+if test -n "$MAGIC_CMD"; then
+ echo "$as_me:$LINENO: result: $MAGIC_CMD" >&5
+echo "${ECHO_T}$MAGIC_CMD" >&6
+else
+fi
+if test -z "$lt_cv_path_MAGIC_CMD"; then
+ if test -n "$ac_tool_prefix"; then
+ echo "$as_me:$LINENO: checking for file" >&5
+echo $ECHO_N "checking for file... $ECHO_C" >&6
+ echo $ECHO_N "(cached) $ECHO_C" >&6
+else
+ if test -f $ac_dir/file; then
+ lt_cv_path_MAGIC_CMD="$ac_dir/file"
+ "file_magic "*)
+ else
+ cat <<EOF 1>&2
+EOF
+ fi ;;
+ esac
+ fi
+ break
+ fi
+ done
+esac
+fi
+else
+fi
+ else
+ MAGIC_CMD=:
+ fi
+fi
+ fi
+esac
+enable_dlopen=no
+enable_win32_dll=no
+fi;
# Check whether --with-pic or --without-pic was given.
if test "${with_pic+set}" = set; then
withval="$with_pic"
@@ -5213,370 +6326,904 @@
fi;
test -z "$pic_mode" && pic_mode=default
-# We assume here that the value for lt_cv_prog_cc_pic will not be cached
-# in isolation, and that seeing it set (from the cache) indicates that
-# the associated values are set (in the cache) correctly too.
-echo "$as_me:$LINENO: checking for $compiler option to produce PIC" >&5
-echo $ECHO_N "checking for $compiler option to produce PIC... $ECHO_C" >&6
-if test "${lt_cv_prog_cc_pic+set}" = set; then
+# Use C for the default configuration in the libtool script
+tagname=
+lt_save_CC="$CC"
+ac_ext=c
+# Source file extension for C test sources.
+ac_ext=c
+# Object file extension for compiled C test sources.
+objext=o
+objext=$objext
+# Code to be used in simple compile tests
+lt_simple_compile_test_code="int some_variable = 0;\n"
+# Code to be used in simple link tests
+lt_simple_link_test_code='int main(){return(0);}\n'
+LTCC=${LTCC-"$CC"}
+compiler=$CC
+# save warnings/boilerplate of simple test code
+ac_outfile=conftest.$ac_objext
+printf "$lt_simple_compile_test_code" >conftest.$ac_ext
+eval "$ac_compile" 2>&1 >/dev/null | $SED '/^$/d; /^ *+/d' >conftest.err
+_lt_compiler_boilerplate=`cat conftest.err`
+$rm conftest*
+printf "$lt_simple_link_test_code" >conftest.$ac_ext
+eval "$ac_link" 2>&1 >/dev/null | $SED '/^$/d; /^ *+/d' >conftest.err
+_lt_linker_boilerplate=`cat conftest.err`
+$rm conftest*
+lt_prog_compiler_no_builtin_flag=
+if test "$GCC" = yes; then
+ lt_prog_compiler_no_builtin_flag=' -fno-builtin'
+echo "$as_me:$LINENO: checking if $compiler supports -fno-rtti -fno-exceptions" >&5
+echo $ECHO_N "checking if $compiler supports -fno-rtti -fno-exceptions... $ECHO_C" >&6
+if test "${lt_cv_prog_compiler_rtti_exceptions+set}" = set; then
else
- lt_cv_prog_cc_pic=
- lt_cv_prog_cc_shlib=
- lt_cv_prog_cc_wl=
- lt_cv_prog_cc_static=
- lt_cv_prog_cc_no_builtin=
- lt_cv_prog_cc_can_build_shared=$can_build_shared
+ lt_cv_prog_compiler_rtti_exceptions=no
+ ac_outfile=conftest.$ac_objext
+ printf "$lt_simple_compile_test_code" > conftest.$ac_ext
+ lt_compiler_flag="-fno-rtti -fno-exceptions"
+ # Insert the option either (1) after the last *FLAGS variable, or
+ # (2) before a word containing "conftest.", or (3) at the end.
+ # Note that $ac_compile itself does not contain backslashes and begins
+ # with a dollar sign (not a hyphen), so the echo should work correctly.
+ # The option is referenced via a variable to avoid confusing sed.
+ lt_compile=`echo "$ac_compile" | $SED \
+ -e 's:.*FLAGS}\{0,1\} :&$lt_compiler_flag :; t' \
+ -e 's: [^ ]*conftest\.: $lt_compiler_flag&:; t' \
+ -e 's:$: $lt_compiler_flag:'`
+ (eval echo "\"\$as_me:6402: $lt_compile\"" >&5)
+ (eval "$lt_compile" 2>conftest.err)
+ ac_status=$?
+ cat conftest.err >&5
+ echo "$as_me:6406: \$? = $ac_status" >&5
+ if (exit $ac_status) && test -s "$ac_outfile"; then
+ # The compiler can only warn and ignore the option if not recognized
+ # So say no if there are warnings other than the usual output.
+ $echo "X$_lt_compiler_boilerplate" | $Xsed -e '/^$/d' >conftest.exp
+ $SED '/^$/d; /^ *+/d' conftest.err >conftest.er2
+ if test ! -s conftest.er2 || diff conftest.exp conftest.er2 >/dev/null; then
+ lt_cv_prog_compiler_rtti_exceptions=yes
+ fi
+ fi
+ $rm conftest*
+fi
+echo "$as_me:$LINENO: result: $lt_cv_prog_compiler_rtti_exceptions" >&5
+echo "${ECHO_T}$lt_cv_prog_compiler_rtti_exceptions" >&6
+if test x"$lt_cv_prog_compiler_rtti_exceptions" = xyes; then
+ lt_prog_compiler_no_builtin_flag="$lt_prog_compiler_no_builtin_flag -fno-rtti -fno-exceptions"
+else
+fi
+fi
+lt_prog_compiler_wl=
+lt_prog_compiler_pic=
+lt_prog_compiler_static=
+echo "$as_me:$LINENO: checking for $compiler option to produce PIC" >&5
+echo $ECHO_N "checking for $compiler option to produce PIC... $ECHO_C" >&6
- lt_cv_prog_cc_wl='-Wl,'
- lt_cv_prog_cc_static='-static'
+ lt_prog_compiler_wl='-Wl,'
+ lt_prog_compiler_static='-static'
case $host_os in
- aix*)
- # Below there is a dirty hack to force normal static linking with -ldl
- # The problem is because libdl dynamically linked with both libc and
- # libC (AIX C++ library), which obviously doesn't included in libraries
- # list by gcc. This cause undefined symbols with -static flags.
- # This hack allows C programs to be linked with "-static -ldl", but
- # not sure about C++ programs.
- lt_cv_prog_cc_static="$lt_cv_prog_cc_static ${lt_cv_prog_cc_wl}-lC"
+ aix*)
+ # All AIX code is PIC.
+ # AIX 5 now supports IA64 processor
+ lt_prog_compiler_static='-Bstatic'
+ fi
amigaos*)
# FIXME: we need at least 68020 code to build shared libraries, but
# adding the `-m68020' flag to GCC prevents building anything better,
# like `-m68040'.
- lt_cv_prog_cc_pic='-m68020 -resident32 -malways-restore-a4'
+ lt_prog_compiler_pic='-m68020 -resident32 -malways-restore-a4'
- beos* | irix5* | irix6* | nonstopux* | osf3* | osf4* | osf5*)
+ beos* | cygwin* | irix5* | irix6* | nonstopux* | osf3* | osf4* | osf5*)
# PIC is the default for these OSes.
+ mingw* | pw32* | os2*)
+ # This hack is so that the source file can tell whether it is being
+ # built for inclusion in a dll (and should export symbols for example).
+ lt_prog_compiler_pic='-DDLL_EXPORT'
# PIC is the default on this platform
# Common symbols not allowed in MH_DYLIB files
- lt_cv_prog_cc_pic='-fno-common'
+ lt_prog_compiler_pic='-fno-common'
- cygwin* | mingw* | pw32* | os2*)
- # This hack is so that the source file can tell whether it is being
- # built for inclusion in a dll (and should export symbols for example).
- lt_cv_prog_cc_pic='-DDLL_EXPORT'
+ interix3*)
+ # Interix 3.x gcc -fpic/-fPIC options generate broken code.
+ # Instead, we relocate shared libraries at runtime.
+ msdosdjgpp*)
+ # Just because we use GCC doesn't mean we suddenly get shared libraries
+ # on systems that don't support them.
+ lt_prog_compiler_can_build_shared=no
+ enable_shared=no
sysv4*MP*)
if test -d /usr/nec; then
- lt_cv_prog_cc_pic=-Kconform_pic
+ lt_prog_compiler_pic=-Kconform_pic
fi
+ hpux*)
+ # PIC is the default for IA64 HP-UX and 64-bit HP-UX, but
+ # not for PA HP-UX.
+ case $host_cpu in
+ hppa*64*|ia64*)
+ # +Z the default
+ lt_prog_compiler_pic='-fPIC'
+ esac
- lt_cv_prog_cc_pic='-fPIC'
esac
else
- # PORTME Check for PIC flags for the system compiler.
+ # PORTME Check for flag to pass linker flags through the system compiler.
case $host_os in
- aix3* | aix4* | aix5*)
- # All AIX code is PIC.
+ aix*)
- lt_cv_prog_cc_static='-Bstatic'
else
- lt_cv_prog_cc_static='-bnso -bI:/lib/syscalls.exp'
+ lt_prog_compiler_static='-bnso -bI:/lib/syscalls.exp'
fi
+ darwin*)
+ # PIC is the default on this platform
+ # Common symbols not allowed in MH_DYLIB files
+ case $cc_basename in
+ xlc*)
+ lt_prog_compiler_pic='-qnocommon'
+ esac
hpux9* | hpux10* | hpux11*)
- # Is there a better lt_cv_prog_cc_static that works with the bundled CC?
- lt_cv_prog_cc_static="${lt_cv_prog_cc_wl}-a ${lt_cv_prog_cc_wl}archive"
- lt_cv_prog_cc_pic='+Z'
+ case $host_cpu in
+ hppa*64*|ia64*)
+ # +Z the default
+ lt_prog_compiler_pic='+Z'
+ esac
+ # Is there a better lt_prog_compiler_static that works with the bundled CC?
+ lt_prog_compiler_static='${wl}-a ${wl}archive'
- lt_cv_prog_cc_static='-non_shared'
# PIC (with -KPIC) is the default.
+ lt_prog_compiler_static='-non_shared'
+ newsos6)
+ lt_prog_compiler_pic='-KPIC'
- newsos6)
- lt_cv_prog_cc_pic='-KPIC'
+ linux*)
+ icc* | ecc*)
+ pgcc* | pgf77* | pgf90* | pgf95*)
+ # Portland Group compilers (*not* the Pentium gcc compiler,
+ # which looks to be a dead project)
+ lt_prog_compiler_pic='-fpic'
+ ccc*)
+ # All Alpha code is PIC.
+ esac
# All OSF/1 code is PIC.
- sco3.2v5*)
- lt_cv_prog_cc_pic='-Kpic'
- lt_cv_prog_cc_static='-dn'
- lt_cv_prog_cc_shlib='-belf'
solaris*)
+ f77* | f90* | f95*)
+ lt_prog_compiler_wl='-Qoption ld ';;
+ lt_prog_compiler_wl='-Wl,';;
+ esac
sunos4*)
- lt_cv_prog_cc_pic='-PIC'
- lt_cv_prog_cc_wl='-Qoption ld '
+ lt_prog_compiler_pic='-PIC'
- sysv4 | sysv4.2uw2* | sysv4.3* | sysv5*)
+ sysv4 | sysv4.2uw2* | sysv4.3*)
- uts4*)
- lt_cv_prog_cc_pic='-pic'
sysv4*MP*)
if test -d /usr/nec ;then
- lt_cv_prog_cc_pic='-Kconform_pic'
+ lt_prog_compiler_pic='-Kconform_pic'
fi
+ sysv5* | unixware* | sco3.2v5* | sco5v6* | OpenUNIX*)
+ unicos*)
+ uts4*)
+ lt_prog_compiler_pic='-pic'
- lt_cv_prog_cc_can_build_shared=no
esac
fi
-fi
+echo "$as_me:$LINENO: result: $lt_prog_compiler_pic" >&5
+echo "${ECHO_T}$lt_prog_compiler_pic" >&6
-if test -z "$lt_cv_prog_cc_pic"; then
- echo "$as_me:$LINENO: result: none" >&5
-echo "${ECHO_T}none" >&6
-else
- echo "$as_me:$LINENO: result: $lt_cv_prog_cc_pic" >&5
-echo "${ECHO_T}$lt_cv_prog_cc_pic" >&6
+# Check to make sure the PIC flag actually works.
+if test -n "$lt_prog_compiler_pic"; then
- # Check to make sure the pic_flag actually works.
- echo "$as_me:$LINENO: checking if $compiler PIC flag $lt_cv_prog_cc_pic works" >&5
-echo $ECHO_N "checking if $compiler PIC flag $lt_cv_prog_cc_pic works... $ECHO_C" >&6
- if test "${lt_cv_prog_cc_pic_works+set}" = set; then
+echo "$as_me:$LINENO: checking if $compiler PIC flag $lt_prog_compiler_pic works" >&5
+echo $ECHO_N "checking if $compiler PIC flag $lt_prog_compiler_pic works... $ECHO_C" >&6
+if test "${lt_prog_compiler_pic_works+set}" = set; then
else
- CFLAGS="$CFLAGS $lt_cv_prog_cc_pic -DPIC"
-/* confdefs.h. */
-_ACEOF
+ lt_prog_compiler_pic_works=no
+ lt_compiler_flag="$lt_prog_compiler_pic -DPIC"
+ (eval echo "\"\$as_me:6670: $lt_compile\"" >&5)
+ ac_status=$?
+ echo "$as_me:6674: \$? = $ac_status" >&5
+ lt_prog_compiler_pic_works=yes
+ fi
+ fi
+ $rm conftest*
-int
-main ()
+fi
+echo "$as_me:$LINENO: result: $lt_prog_compiler_pic_works" >&5
+echo "${ECHO_T}$lt_prog_compiler_pic_works" >&6
- return 0;
-_ACEOF
-if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
- ac_status=$?
- { ac_try='test -s conftest.$ac_objext'
- ac_status=$?
- case $host_os in
- hpux9* | hpux10* | hpux11*)
- # On HP-UX, both CC and GCC only warn that PIC is supported... then
- # they create non-PIC objects. So, if there were any warnings, we
- # assume that PIC is not supported.
- if test -s conftest.err; then
- lt_cv_prog_cc_pic_works=no
- else
- lt_cv_prog_cc_pic_works=yes
- fi
- esac
+if test x"$lt_prog_compiler_pic_works" = xyes; then
+ case $lt_prog_compiler_pic in
+ *) lt_prog_compiler_pic=" $lt_prog_compiler_pic" ;;
+ esac
+else
+fi
+fi
+case $host_os in
+ # For platforms which do not support PIC, -DPIC is meaningless:
+ *djgpp*)
+ lt_prog_compiler_pic="$lt_prog_compiler_pic -DPIC"
+esac
+# Check to make sure the static flag actually works.
+wl=$lt_prog_compiler_wl eval lt_tmp_static_flag=\"$lt_prog_compiler_static\"
+echo "$as_me:$LINENO: checking if $compiler static flag $lt_tmp_static_flag works" >&5
+echo $ECHO_N "checking if $compiler static flag $lt_tmp_static_flag works... $ECHO_C" >&6
+if test "${lt_prog_compiler_static_works+set}" = set; then
else
+ lt_prog_compiler_static_works=no
+ save_LDFLAGS="$LDFLAGS"
+ LDFLAGS="$LDFLAGS $lt_tmp_static_flag"
+ printf "$lt_simple_link_test_code" > conftest.$ac_ext
+ if (eval $ac_link 2>conftest.err) && test -s conftest$ac_exeext; then
+ # The linker can only warn and ignore the option if not recognized
+ # Append any errors to the config.log.
+ cat conftest.err 1>&5
+ $echo "X$_lt_linker_boilerplate" | $Xsed -e '/^$/d' > conftest.exp
+ if diff conftest.exp conftest.er2 >/dev/null; then
+ lt_prog_compiler_static_works=yes
+ fi
+ else
+ fi
+ fi
+ $rm conftest*
+ LDFLAGS="$save_LDFLAGS"
fi
-rm -f conftest.$ac_objext conftest.$ac_ext
+echo "$as_me:$LINENO: result: $lt_prog_compiler_static_works" >&5
+echo "${ECHO_T}$lt_prog_compiler_static_works" >&6
+if test x"$lt_prog_compiler_static_works" = xyes; then
+else
fi
- if test "X$lt_cv_prog_cc_pic_works" = Xno; then
- else
- lt_cv_prog_cc_pic=" $lt_cv_prog_cc_pic"
- fi
+echo "$as_me:$LINENO: checking if $compiler supports -c -o file.$ac_objext" >&5
+echo $ECHO_N "checking if $compiler supports -c -o file.$ac_objext... $ECHO_C" >&6
+if test "${lt_cv_prog_compiler_c_o+set}" = set; then
+else
+ lt_cv_prog_compiler_c_o=no
+ $rm -r conftest 2>/dev/null
+ mkdir conftest
+ cd conftest
+ mkdir out
- echo "$as_me:$LINENO: result: $lt_cv_prog_cc_pic_works" >&5
-echo "${ECHO_T}$lt_cv_prog_cc_pic_works" >&6
+ lt_compiler_flag="-o out/conftest2.$ac_objext"
+ (eval echo "\"\$as_me:6774: $lt_compile\"" >&5)
+ (eval "$lt_compile" 2>out/conftest.err)
+ ac_status=$?
+ cat out/conftest.err >&5
+ echo "$as_me:6778: \$? = $ac_status" >&5
+ if (exit $ac_status) && test -s out/conftest2.$ac_objext
+ then
+ $echo "X$_lt_compiler_boilerplate" | $Xsed -e '/^$/d' > out/conftest.exp
+ $SED '/^$/d; /^ *+/d' out/conftest.err >out/conftest.er2
+ if test ! -s out/conftest.er2 || diff out/conftest.exp out/conftest.er2 >/dev/null; then
+ lt_cv_prog_compiler_c_o=yes
+ fi
+ fi
+ chmod u+w . 2>&5
+ $rm conftest*
+ # SGI C++ compiler will create directory out/ii_files/ for
+ # template instantiation
+ test -d out/ii_files && $rm out/ii_files/* && rmdir out/ii_files
+ $rm out/* && rmdir out
+ cd ..
+ rmdir conftest
+ $rm conftest*
fi
+echo "$as_me:$LINENO: result: $lt_cv_prog_compiler_c_o" >&5
+echo "${ECHO_T}$lt_cv_prog_compiler_c_o" >&6
-# Check for any special shared library compilation flags.
-if test -n "$lt_cv_prog_cc_shlib"; then
- { echo "$as_me:$LINENO: WARNING: \`$CC' requires \`$lt_cv_prog_cc_shlib' to build shared libraries" >&5
-echo "$as_me: WARNING: \`$CC' requires \`$lt_cv_prog_cc_shlib' to build shared libraries" >&2;}
- if echo "$old_CC $old_CFLAGS " | egrep -e "[ ]$lt_cv_prog_cc_shlib[ ]" >/dev/null; then :
- else
- { echo "$as_me:$LINENO: WARNING: add \`$lt_cv_prog_cc_shlib' to the CC or CFLAGS env variable and reconfigure" >&5
-echo "$as_me: WARNING: add \`$lt_cv_prog_cc_shlib' to the CC or CFLAGS env variable and reconfigure" >&2;}
+hard_links="nottested"
+if test "$lt_cv_prog_compiler_c_o" = no && test "$need_locks" != no; then
+ # do not overwrite the value of need_locks provided by the user
+ echo "$as_me:$LINENO: checking if we can lock with hard links" >&5
+echo $ECHO_N "checking if we can lock with hard links... $ECHO_C" >&6
+ hard_links=yes
+ $rm conftest*
+ ln conftest.a conftest.b 2>/dev/null && hard_links=no
+ touch conftest.a
+ ln conftest.a conftest.b 2>&5 || hard_links=no
+ echo "$as_me:$LINENO: result: $hard_links" >&5
+echo "${ECHO_T}$hard_links" >&6
+ if test "$hard_links" = no; then
+ { echo "$as_me:$LINENO: WARNING: \`$CC' does not support \`-c -o', so \`make -j' may be unsafe" >&5
+echo "$as_me: WARNING: \`$CC' does not support \`-c -o', so \`make -j' may be unsafe" >&2;}
+ need_locks=warn
fi
+else
+ need_locks=no
fi
-echo "$as_me:$LINENO: checking if $compiler static flag $lt_cv_prog_cc_static works" >&5
-echo $ECHO_N "checking if $compiler static flag $lt_cv_prog_cc_static works... $ECHO_C" >&6
-if test "${lt_cv_prog_cc_static_works+set}" = set; then
- echo $ECHO_N "(cached) $ECHO_C" >&6
-else
- lt_cv_prog_cc_static_works=no
- save_LDFLAGS="$LDFLAGS"
- LDFLAGS="$LDFLAGS $lt_cv_prog_cc_static"
-/* confdefs.h. */
-_ACEOF
+echo "$as_me:$LINENO: checking whether the $compiler linker ($LD) supports shared libraries" >&5
+echo $ECHO_N "checking whether the $compiler linker ($LD) supports shared libraries... $ECHO_C" >&6
-int
-main ()
+ runpath_var=
+ allow_undefined_flag=
+ enable_shared_with_static_runtimes=no
+ archive_cmds=
+ archive_expsym_cmds=
+ old_archive_From_new_cmds=
+ old_archive_from_expsyms_cmds=
+ export_dynamic_flag_spec=
+ whole_archive_flag_spec=
+ thread_safe_flag_spec=
+ hardcode_libdir_flag_spec=
+ hardcode_libdir_flag_spec_ld=
+ hardcode_libdir_separator=
+ hardcode_direct=no
+ hardcode_minus_L=no
+ hardcode_shlibpath_var=unsupported
+ link_all_deplibs=unknown
+ hardcode_automatic=no
+ module_cmds=
+ module_expsym_cmds=
+ always_export_symbols=no
+ export_symbols_cmds='$NM $libobjs $convenience | $global_symbol_pipe | $SED '\''s/.* //'\'' | sort | uniq > $export_symbols'
+ # include_expsyms should be a list of space-separated symbols to be *always*
+ # included in the symbol list
+ include_expsyms=
+ # exclude_expsyms can be an extended regexp of symbols to exclude
+ # it will be wrapped by ` (' and `)$', so one must not match beginning or
+ # end of line. Example: `a|bc|.*d.*' will exclude the symbols `a' and `bc',
+ # as well as any symbol that contains `d'.
+ exclude_expsyms="_GLOBAL_OFFSET_TABLE_"
+ # Although _GLOBAL_OFFSET_TABLE_ is a valid symbol C name, most a.out
+ # platforms (ab)use it in PIC code, but their linkers get confused if
+ # the symbol is explicitly referenced. Since portable code cannot
+ # rely on this symbol name, it's probably fine to never include it in
+ # preloaded symbol tables.
+ extract_expsyms_cmds=
+ # Just being paranoid about ensuring that cc_basename is set.
+ for cc_temp in $compiler""; do
+ case $cc_temp in
+ *) break;;
+ esac
+done
- return 0;
-_ACEOF
- ac_status=$?
- ac_status=$?
- lt_cv_prog_cc_static_works=yes
-else
+ case $host_os in
+ cygwin* | mingw* | pw32*)
+ # FIXME: the MSVC++ port hasn't been tested in a loooong time
+ # When not using gcc, we currently assume that we are using
+ # Microsoft Visual C++.
+ if test "$GCC" != yes; then
+ with_gnu_ld=no
+ fi
+ interix*)
+ # we just hope/assume this is gcc and not c89 (= MSVC++)
+ with_gnu_ld=yes
+ openbsd*)
+ with_gnu_ld=no
+ esac
-fi
- LDFLAGS="$save_LDFLAGS"
+ ld_shlibs=yes
+ if test "$with_gnu_ld" = yes; then
+ # If archive_cmds runs LD, not CC, wlarc should be empty
+ wlarc='${wl}'
-fi
+ # Set some defaults for GNU ld with shared library support. These
+ # are reset later if shared libraries are not supported. Putting them
+ # here allows them to be overridden if necessary.
+ runpath_var=LD_RUN_PATH
+ hardcode_libdir_flag_spec='${wl}--rpath ${wl}$libdir'
+ export_dynamic_flag_spec='${wl}--export-dynamic'
+ # ancient GNU ld didn't support --whole-archive et. al.
+ if $LD --help 2>&1 | grep 'no-whole-archive' > /dev/null; then
+ whole_archive_flag_spec="$wlarc"'--whole-archive$convenience '"$wlarc"'--no-whole-archive'
+ else
+ fi
+ supports_anon_versioning=no
+ case `$LD -v 2>/dev/null` in
+ *\ [01].* | *\ 2.[0-9].* | *\ 2.10.*) ;; # catch versions < 2.11
+ *\ 2.11.93.0.2\ *) supports_anon_versioning=yes ;; # RH7.3 ...
+ *\ 2.11.92.0.12\ *) supports_anon_versioning=yes ;; # Mandrake 8.2 ...
+ *\ 2.11.*) ;; # other 2.11 versions
+ *) supports_anon_versioning=yes ;;
+ esac
+ # See if GNU ld supports shared libraries.
+ case $host_os in
+ aix3* | aix4* | aix5*)
+ # On AIX/PPC, the GNU linker is very broken
+ if test "$host_cpu" != ia64; then
+ ld_shlibs=no
+ cat <<EOF 1>&2
-# Belt *and* braces to stop my trousers falling down:
-test "X$lt_cv_prog_cc_static_works" = Xno && lt_cv_prog_cc_static=
-echo "$as_me:$LINENO: result: $lt_cv_prog_cc_static_works" >&5
-echo "${ECHO_T}$lt_cv_prog_cc_static_works" >&6
+*** Warning: the GNU linker, at least up to release 2.9.1, is reported
+*** to be unable to reliably create shared libraries on AIX.
+*** Therefore, libtool is disabling shared libraries support. If you
+*** really care for shared libraries, you may want to modify your PATH
+*** so that a non-GNU linker is found, and then restart.
-pic_flag="$lt_cv_prog_cc_pic"
-special_shlib_compile_flags="$lt_cv_prog_cc_shlib"
-wl="$lt_cv_prog_cc_wl"
-link_static_flag="$lt_cv_prog_cc_static"
-no_builtin_flag="$lt_cv_prog_cc_no_builtin"
-can_build_shared="$lt_cv_prog_cc_can_build_shared"
+EOF
+ fi
+ amigaos*)
+ archive_cmds='$rm $output_objdir/a2ixlibrary.data~$echo "#define NAME $libname" > $output_objdir/a2ixlibrary.data~$echo "#define LIBRARY_ID 1" >> $output_objdir/a2ixlibrary.data~$echo "#define VERSION $major" >> $output_objdir/a2ixlibrary.data~$echo "#define REVISION $revision" >> $output_objdir/a2ixlibrary.data~$AR $AR_FLAGS $lib $libobjs~$RANLIB $lib~(cd $output_objdir && a2ixlibrary -32)'
+ hardcode_libdir_flag_spec='-L$libdir'
+ hardcode_minus_L=yes
-# Check to see if options -o and -c are simultaneously supported by compiler
-echo "$as_me:$LINENO: checking if $compiler supports -c -o file.$ac_objext" >&5
-echo $ECHO_N "checking if $compiler supports -c -o file.$ac_objext... $ECHO_C" >&6
-if test "${lt_cv_compiler_c_o+set}" = set; then
-else
+ # Samuel A. Falvo II <kc5tja at dolphin.openprojects.net> reports
+ # that the semantics of dynamic libraries on AmigaOS, at least up
+ # to version 4, is to share data among multiple programs linked
+ # with the same dynamic library. Since this doesn't match the
+ # behavior of shared libraries on other platforms, we can't use
+ # them.
+ ld_shlibs=no
-$rm -r conftest 2>/dev/null
-mkdir conftest
-cd conftest
-echo "int some_variable = 0;" > conftest.$ac_ext
-mkdir out
-# According to Tom Tromey, Ian Lance Taylor reported there are C compilers
-# that will create temporary files in the current directory regardless of
-# the output directory. Thus, making CWD read-only will cause this test
-# to fail, enabling locking or at least warning the user not to do parallel
-# builds.
-chmod -w .
-save_CFLAGS="$CFLAGS"
-CFLAGS="$CFLAGS -o out/conftest2.$ac_objext"
-compiler_c_o=no
-if { (eval echo configure:5538: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>out/conftest.err; } && test -s out/conftest2.$ac_objext; then
- # The compiler can only warn and ignore the option if not recognized
- # So say no if there are warnings
- if test -s out/conftest.err; then
- lt_cv_compiler_c_o=no
+ beos*)
+ if $LD --help 2>&1 | grep ': supported targets:.* elf' > /dev/null; then
+ allow_undefined_flag=unsupported
+ # Joseph Beckenbach <jrb3 at best.com> says some releases of gcc
+ # support --undefined. This deserves some investigation. FIXME
+ archive_cmds='$CC -nostart $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
+ else
+ ld_shlibs=no
+ fi
+ # _LT_AC_TAGVAR(hardcode_libdir_flag_spec, ) is actually meaningless,
+ # as there is no search path for DLLs.
+ enable_shared_with_static_runtimes=yes
+ export_symbols_cmds='$NM $libobjs $convenience | $global_symbol_pipe | $SED -e '\''/^[BCDGRS] /s/.* \([^ ]*\)/\1 DATA/'\'' | $SED -e '\''/^[AITW] /s/.* //'\'' | sort | uniq > $export_symbols'
+ if $LD --help 2>&1 | grep 'auto-import' > /dev/null; then
+ archive_cmds='$CC -shared $libobjs $deplibs $compiler_flags -o $output_objdir/$soname ${wl}--enable-auto-image-base -Xlinker --out-implib -Xlinker $lib'
+ # If the export-symbols file already is a .def file (1st line
+ # is EXPORTS), use it as is; otherwise, prepend...
+ archive_expsym_cmds='if test "x`$SED 1q $export_symbols`" = xEXPORTS; then
+ cp $export_symbols $output_objdir/$soname.def;
+ else
+ echo EXPORTS > $output_objdir/$soname.def;
+ cat $export_symbols >> $output_objdir/$soname.def;
+ fi~
+ $CC -shared $output_objdir/$soname.def $libobjs $deplibs $compiler_flags -o $output_objdir/$soname ${wl}--enable-auto-image-base -Xlinker --out-implib -Xlinker $lib'
+ else
+ ld_shlibs=no
+ fi
+ interix3*)
+ hardcode_shlibpath_var=no
+ hardcode_libdir_flag_spec='${wl}-rpath,$libdir'
+ export_dynamic_flag_spec='${wl}-E'
+ # Hack: On Interix 3.x, we cannot compile PIC because of a broken gcc.
+ # Instead, shared libraries are loaded at an image base (0x10000000 by
+ # default) and relocated if they conflict, which is a slow very memory
+ # consuming and fragmenting process. To avoid this, we pick a random,
+ # 256 KiB-aligned image base between 0x50000000 and 0x6FFC0000 at link
+ # time. Moving up from 0x10000000 also allows more sbrk(2) space.
+ archive_cmds='$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-h,$soname ${wl}--image-base,`expr ${RANDOM-$$} % 4096 / 2 \* 262144 + 1342177280` -o $lib'
+ archive_expsym_cmds='sed "s,^,_," $export_symbols >$output_objdir/$soname.expsym~$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-h,$soname ${wl}--retain-symbols-file,$output_objdir/$soname.expsym ${wl}--image-base,`expr ${RANDOM-$$} % 4096 / 2 \* 262144 + 1342177280` -o $lib'
+ linux*)
+ tmp_addflag=
+ case $cc_basename,$host_cpu in
+ pgcc*) # Portland Group C compiler
+ whole_archive_flag_spec='${wl}--whole-archive`for conv in $convenience\"\"; do test -n \"$conv\" && new_convenience=\"$new_convenience,$conv\"; done; $echo \"$new_convenience\"` ${wl}--no-whole-archive'
+ tmp_addflag=' $pic_flag'
+ pgf77* | pgf90* | pgf95*) # Portland Group f77 and f90 compilers
+ tmp_addflag=' $pic_flag -Mnomain' ;;
+ ecc*,ia64* | icc*,ia64*) # Intel C compiler on ia64
+ tmp_addflag=' -i_dynamic' ;;
+ efc*,ia64* | ifort*,ia64*) # Intel Fortran compiler on ia64
+ tmp_addflag=' -i_dynamic -nofor_main' ;;
+ ifc* | ifort*) # Intel Fortran compiler
+ tmp_addflag=' -nofor_main' ;;
+ esac
+ archive_cmds='$CC -shared'"$tmp_addflag"' $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
+ if test $supports_anon_versioning = yes; then
+ archive_expsym_cmds='$echo "{ global:" > $output_objdir/$libname.ver~
+ cat $export_symbols | sed -e "s/\(.*\)/\1;/" >> $output_objdir/$libname.ver~
+ $echo "local: *; };" >> $output_objdir/$libname.ver~
+ $CC -shared'"$tmp_addflag"' $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-version-script ${wl}$output_objdir/$libname.ver -o $lib'
+ fi
+ else
+ ld_shlibs=no
+ fi
+ netbsd*)
+ if echo __ELF__ | $CC -E - | grep __ELF__ >/dev/null; then
+ archive_cmds='$LD -Bshareable $libobjs $deplibs $linker_flags -o $lib'
+ wlarc=
+ else
+ archive_cmds='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
+ archive_expsym_cmds='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
+ fi
+ solaris*)
+ if $LD -v 2>&1 | grep 'BFD 2\.8' > /dev/null; then
+ ld_shlibs=no
+ cat <<EOF 1>&2
+*** Warning: The releases 2.8.* of the GNU linker cannot reliably
+*** create shared libraries on Solaris systems. Therefore, libtool
+*** is disabling shared libraries support. We urge you to upgrade GNU
+*** binutils to release 2.9.1 or newer. Another option is to modify
+*** your PATH or compiler configuration so that the native linker is
+*** used, and then restart.
+EOF
+ elif $LD --help 2>&1 | grep ': supported targets:.* elf' > /dev/null; then
+ else
+ ld_shlibs=no
+ fi
+ sysv5* | sco3.2v5* | sco5v6* | unixware* | OpenUNIX*)
+ case `$LD -v 2>&1` in
+ *\ [01].* | *\ 2.[0-9].* | *\ 2.1[0-5].*)
+ ld_shlibs=no
+ cat <<_LT_EOF 1>&2
+*** Warning: Releases of the GNU linker prior to 2.16.91.0.3 can not
+*** reliably create shared libraries on SCO systems. Therefore, libtool
+*** binutils to release 2.16.91.0.3 or newer. Another option is to modify
+_LT_EOF
+ hardcode_libdir_flag_spec='`test -z "$SCOABSPATH" && echo ${wl}-rpath,$libdir`'
+ archive_cmds='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib'
+ archive_expsym_cmds='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname,\${SCOABSPATH:+${install_libdir}/}$soname,-retain-symbols-file,$export_symbols -o $lib'
+ else
+ ld_shlibs=no
+ fi
+ esac
+ sunos4*)
+ archive_cmds='$LD -assert pure-text -Bshareable -o $lib $libobjs $deplibs $linker_flags'
+ wlarc=
+ hardcode_direct=yes
+ else
+ ld_shlibs=no
+ fi
+ esac
+ if test "$ld_shlibs" = no; then
+ runpath_var=
+ fi
else
- lt_cv_compiler_c_o=yes
- fi
-else
- # Append any errors to the config.log.
- cat out/conftest.err 1>&5
-fi
-CFLAGS="$save_CFLAGS"
-chmod u+w .
-$rm conftest* out/*
-rmdir out
-cd ..
-rmdir conftest
+ # PORTME fill in a description of your system's linker (not GNU ld)
+ case $host_os in
+ aix3*)
+ always_export_symbols=yes
+ archive_expsym_cmds='$LD -o $output_objdir/$soname $libobjs $deplibs $linker_flags -bE:$export_symbols -T512 -H512 -bM:SRE~$AR $AR_FLAGS $lib $output_objdir/$soname'
+ # Note: this linker hardcodes the directories in LIBPATH if there
+ # are no directories specified by -L.
+ if test "$GCC" = yes && test -z "$lt_prog_compiler_static"; then
+ # Neither direct hardcoding nor static linking is supported with a
+ # broken collect2.
+ hardcode_direct=unsupported
+ fi
-fi
+ aix4* | aix5*)
+ # On IA64, the linker does run time linking by default, so we don't
+ # have to do anything special.
+ aix_use_runtimelinking=no
+ exp_sym_flag='-Bexport'
+ no_entry_flag=""
+ else
+ # If we're using GNU nm, then we don't want the "-C" option.
+ # -C means demangle to AIX nm, but means don't demangle with GNU nm
+ if $NM -V 2>&1 | grep 'GNU' > /dev/null; then
+ export_symbols_cmds='$NM -Bpg $libobjs $convenience | awk '\''{ if (((\$2 == "T") || (\$2 == "D") || (\$2 == "B")) && (substr(\$3,1,1) != ".")) { print \$3 } }'\'' | sort -u > $export_symbols'
+ else
+ export_symbols_cmds='$NM -BCpg $libobjs $convenience | awk '\''{ if (((\$2 == "T") || (\$2 == "D") || (\$2 == "B")) && (substr(\$3,1,1) != ".")) { print \$3 } }'\'' | sort -u > $export_symbols'
+ fi
-compiler_c_o=$lt_cv_compiler_c_o
-echo "$as_me:$LINENO: result: $compiler_c_o" >&5
-echo "${ECHO_T}$compiler_c_o" >&6
+ # Test if we are trying to use run time linking or normal
+ # AIX style linking. If -brtl is somewhere in LDFLAGS, we
+ # need to do runtime linking.
+ case $host_os in aix4.[23]|aix4.[23].*|aix5*)
+ for ld_flag in $LDFLAGS; do
+ if (test $ld_flag = "-brtl" || test $ld_flag = "-Wl,-brtl"); then
+ aix_use_runtimelinking=yes
+ break
+ fi
+ done
+ esac
-if test x"$compiler_c_o" = x"yes"; then
- # Check to see if we can write to a .lo
- echo "$as_me:$LINENO: checking if $compiler supports -c -o file.lo" >&5
-echo $ECHO_N "checking if $compiler supports -c -o file.lo... $ECHO_C" >&6
- if test "${lt_cv_compiler_o_lo+set}" = set; then
-else
+ exp_sym_flag='-bexport'
+ no_entry_flag='-bnoentry'
+ fi
- lt_cv_compiler_o_lo=no
- save_CFLAGS="$CFLAGS"
- CFLAGS="$CFLAGS -c -o conftest.lo"
- save_objext="$ac_objext"
- ac_objext=lo
+ # When large executables or shared objects are built, AIX ld can
+ # have problems creating the table of contents. If linking a library
+ # or program results in "error TOC overflow" add -mminimal-toc to
+ # CXXFLAGS/CFLAGS for g++/gcc. In the cases where that is not
+ # enough to fix the problem, add -Wl,-bbigtoc to LDFLAGS.
+ archive_cmds=''
+ hardcode_libdir_separator=':'
+ link_all_deplibs=yes
+ if test "$GCC" = yes; then
+ case $host_os in aix4.[012]|aix4.[012].*)
+ # We only want to do this on AIX 4.2 and lower, the check
+ # below for broken collect2 doesn't work under 4.3+
+ collect2name=`${CC} -print-prog-name=collect2`
+ if test -f "$collect2name" && \
+ strings "$collect2name" | grep resolve_lib_name >/dev/null
+ then
+ # We have reworked collect2
+ else
+ # We have old collect2
+ # It fails to find uninstalled libraries when the uninstalled
+ # path is not listed in the libpath. Setting hardcode_minus_L
+ # to unsupported forces relinking
+ fi
+ esac
+ shared_flag='-shared'
+ if test "$aix_use_runtimelinking" = yes; then
+ shared_flag="$shared_flag "'${wl}-G'
+ fi
+ else
+ # not using gcc
+ # VisualAge C++, Version 5.5 for AIX 5L for IA-64, Beta 3 Release
+ # chokes on -Wl,-G. The following line is correct:
+ shared_flag='-G'
+ else
+ shared_flag='${wl}-G'
+ else
+ shared_flag='${wl}-bM:SRE'
+ fi
+ fi
+ fi
+ # It seems that -bexpall does not export symbols beginning with
+ # underscore (_), so it is better to generate a list of symbols to export.
+ # Warning - without using the other runtime loading flags (-brtl),
+ # -berok will link without error, but may produce a broken library.
+ allow_undefined_flag='-berok'
+ # Determine the default libpath from the value encoded in an empty executable.
+ cat >conftest.$ac_ext <<_ACEOF
/* confdefs.h. */
_ACEOF
@@ -5586,82 +7233,58 @@
int
main ()
-int some_variable = 0;
return 0;
_ACEOF
+rm -f conftest.$ac_objext conftest$ac_exeext
+if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
+ (eval $ac_link) 2>conftest.er1
ac_status=$?
+ grep -v '^ *+' conftest.er1 >conftest.err
+ rm -f conftest.er1
+ { ac_try='test -z "$ac_c_werror_flag"
+ || test ! -s conftest.err'
(eval $ac_try) 2>&5
ac_status=$?
+ (exit $ac_status); }; } &&
+ { ac_try='test -s conftest$ac_exeext'
+ { (eval echo "$as_me:$LINENO: \"$ac_try\"") >&5
+ (eval $ac_try) 2>&5
+ ac_status=$?
- else
- lt_cv_compiler_o_lo=yes
- fi
+aix_libpath=`dump -H conftest$ac_exeext 2>/dev/null | $SED -n -e '/Import File Strings/,/^$/ { /^0/ { s/^0 *\(.*\)$/\1/; p; }
+# Check for a 64-bit object if we didn't find anything.
+if test -z "$aix_libpath"; then aix_libpath=`dump -HX64 conftest$ac_exeext 2>/dev/null | $SED -n -e '/Import File Strings/,/^$/ { /^0/ { s/^0 *\(.*\)$/\1/; p; }
+}'`; fi
else
fi
- ac_objext="$save_objext"
- CFLAGS="$save_CFLAGS"
+rm -f conftest.err conftest.$ac_objext \
+ conftest$ac_exeext conftest.$ac_ext
+if test -z "$aix_libpath"; then aix_libpath="/usr/lib:/lib"; fi
-fi
- compiler_o_lo=$lt_cv_compiler_o_lo
- echo "$as_me:$LINENO: result: $compiler_o_lo" >&5
-echo "${ECHO_T}$compiler_o_lo" >&6
-else
- compiler_o_lo=no
-fi
-# Check to see if we can do hard links to lock some files if needed
-hard_links="nottested"
-if test "$compiler_c_o" = no && test "$need_locks" != no; then
- # do not overwrite the value of need_locks provided by the user
- echo "$as_me:$LINENO: checking if we can lock with hard links" >&5
-echo $ECHO_N "checking if we can lock with hard links... $ECHO_C" >&6
- hard_links=yes
- $rm conftest*
- ln conftest.a conftest.b 2>/dev/null && hard_links=no
- touch conftest.a
- ln conftest.a conftest.b 2>&5 || hard_links=no
- echo "$as_me:$LINENO: result: $hard_links" >&5
-echo "${ECHO_T}$hard_links" >&6
- if test "$hard_links" = no; then
- { echo "$as_me:$LINENO: WARNING: \`$CC' does not support \`-c -o', so \`make -j' may be unsafe" >&5
-echo "$as_me: WARNING: \`$CC' does not support \`-c -o', so \`make -j' may be unsafe" >&2;}
- need_locks=warn
- fi
-else
- need_locks=no
-fi
-if test "$GCC" = yes; then
- # Check to see if options -fno-rtti -fno-exceptions are supported by compiler
- echo "$as_me:$LINENO: checking if $compiler supports -fno-rtti -fno-exceptions" >&5
-echo $ECHO_N "checking if $compiler supports -fno-rtti -fno-exceptions... $ECHO_C" >&6
- echo "int some_variable = 0;" > conftest.$ac_ext
- CFLAGS="$CFLAGS -fno-rtti -fno-exceptions -c conftest.$ac_ext"
- compiler_rtti_exceptions=no
+ hardcode_libdir_flag_spec='${wl}-blibpath:$libdir:'"$aix_libpath"
+ archive_expsym_cmds="\$CC"' -o $output_objdir/$soname $libobjs $deplibs '"\${wl}$no_entry_flag"' $compiler_flags `if test "x${allow_undefined_flag}" != "x"; then echo "${wl}${allow_undefined_flag}"; else :; fi` '"\${wl}$exp_sym_flag:\$export_symbols $shared_flag"
+ else
+ hardcode_libdir_flag_spec='${wl}-R $libdir:/usr/lib:/lib'
+ allow_undefined_flag="-z nodefs"
+ archive_expsym_cmds="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs '"\${wl}$no_entry_flag"' $compiler_flags ${wl}${allow_undefined_flag} '"\${wl}$exp_sym_flag:\$export_symbols"
+ else
/* confdefs.h. */
_ACEOF
@@ -5671,799 +7294,566 @@
int
main ()
return 0;
_ACEOF
ac_status=$?
(eval $ac_try) 2>&5
ac_status=$?
+ ac_status=$?
- else
- compiler_rtti_exceptions=yes
- fi
+}'`; fi
else
fi
- echo "$as_me:$LINENO: result: $compiler_rtti_exceptions" >&5
-echo "${ECHO_T}$compiler_rtti_exceptions" >&6
- if test "$compiler_rtti_exceptions" = "yes"; then
- no_builtin_flag=' -fno-builtin -fno-rtti -fno-exceptions'
- else
- no_builtin_flag=' -fno-builtin'
- fi
-fi
+ # Warning - without using the other run time loading flags,
+ no_undefined_flag=' ${wl}-bernotok'
+ allow_undefined_flag=' ${wl}-berok'
+ # Exported symbols can be pulled into shared objects from archives
+ whole_archive_flag_spec='$convenience'
+ archive_cmds_need_lc=yes
+ # This is similar to how AIX traditionally builds its shared libraries.
+ archive_expsym_cmds="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs ${wl}-bnoentry $compiler_flags ${wl}-bE:$export_symbols${allow_undefined_flag}~$AR $AR_FLAGS $output_objdir/$libname$release.a $output_objdir/$soname'
+ fi
+ fi
-# See if the linker supports building shared libraries.
-echo "$as_me:$LINENO: checking whether the linker ($LD) supports shared libraries" >&5
-echo $ECHO_N "checking whether the linker ($LD) supports shared libraries... $ECHO_C" >&6
+ amigaos*)
+ # see comment about different semantics on the GNU ld section
+ ld_shlibs=no
-allow_undefined_flag=
-no_undefined_flag=
-need_lib_prefix=unknown
-need_version=unknown
-# when you set need_version to no, make sure it does not cause -set_version
-# flags to be left without arguments
-archive_cmds=
-archive_expsym_cmds=
-old_archive_from_new_cmds=
-old_archive_from_expsyms_cmds=
-export_dynamic_flag_spec=
-whole_archive_flag_spec=
-thread_safe_flag_spec=
-hardcode_into_libs=no
-hardcode_libdir_flag_spec=
-hardcode_libdir_separator=
-hardcode_direct=no
-hardcode_minus_L=no
-hardcode_shlibpath_var=unsupported
-runpath_var=
-link_all_deplibs=unknown
-always_export_symbols=no
-export_symbols_cmds='$NM $libobjs $convenience | $global_symbol_pipe | sed '\''s/.* //'\'' | sort | uniq > $export_symbols'
-# include_expsyms should be a list of space-separated symbols to be *always*
-# included in the symbol list
-include_expsyms=
-# exclude_expsyms can be an egrep regular expression of symbols to exclude
-# it will be wrapped by ` (' and `)$', so one must not match beginning or
-# end of line. Example: `a|bc|.*d.*' will exclude the symbols `a' and `bc',
-# as well as any symbol that contains `d'.
-exclude_expsyms="_GLOBAL_OFFSET_TABLE_"
-# Although _GLOBAL_OFFSET_TABLE_ is a valid symbol C name, most a.out
-# platforms (ab)use it in PIC code, but their linkers get confused if
-# the symbol is explicitly referenced. Since portable code cannot
-# rely on this symbol name, it's probably fine to never include it in
-# preloaded symbol tables.
-extract_expsyms_cmds=
+ bsdi[45]*)
+ export_dynamic_flag_spec=-rdynamic
-case $host_os in
-cygwin* | mingw* | pw32*)
- # FIXME: the MSVC++ port hasn't been tested in a loooong time
- # When not using gcc, we currently assume that we are using
- # Microsoft Visual C++.
- if test "$GCC" != yes; then
- with_gnu_ld=no
- fi
-openbsd*)
- with_gnu_ld=no
-esac
+ # hardcode_libdir_flag_spec is actually meaningless, as there is
+ # no search path for DLLs.
+ hardcode_libdir_flag_spec=' '
+ # Tell ltmain to make .lib files, not .a files.
+ libext=lib
+ # Tell ltmain to make .dll files, not .so files.
+ shrext_cmds=".dll"
+ # FIXME: Setting linknames here is a bad hack.
+ archive_cmds='$CC -o $lib $libobjs $compiler_flags `echo "$deplibs" | $SED -e '\''s/ -lc$//'\''` -link -dll~linknames='
+ # The linker will automatically build a .lib file if we build a DLL.
+ old_archive_From_new_cmds='true'
+ # FIXME: Should let the user specify the lib program.
+ old_archive_cmds='lib /OUT:$oldlib$oldobjs$old_deplibs'
+ fix_srcfile_path='`cygpath -w "$srcfile"`'
-ld_shlibs=yes
-if test "$with_gnu_ld" = yes; then
- # If archive_cmds runs LD, not CC, wlarc should be empty
- wlarc='${wl}'
- # See if GNU ld supports shared libraries.
- case $host_os in
- # On AIX, the GNU linker is very broken
- # Note:Check GNU linker on AIX 5-IA64 when/if it becomes available.
- ld_shlibs=no
- cat <<EOF 1>&2
-*** Warning: the GNU linker, at least up to release 2.9.1, is reported
-*** to be unable to reliably create shared libraries on AIX.
-*** Therefore, libtool is disabling shared libraries support. If you
-*** really care for shared libraries, you may want to modify your PATH
-*** so that a non-GNU linker is found, and then restart.
-EOF
- amigaos*)
- archive_cmds='$rm $output_objdir/a2ixlibrary.data~$echo "#define NAME $libname" > $output_objdir/a2ixlibrary.data~$echo "#define LIBRARY_ID 1" >> $output_objdir/a2ixlibrary.data~$echo "#define VERSION $major" >> $output_objdir/a2ixlibrary.data~$echo "#define REVISION $revision" >> $output_objdir/a2ixlibrary.data~$AR $AR_FLAGS $lib $libobjs~$RANLIB $lib~(cd $output_objdir && a2ixlibrary -32)'
- hardcode_libdir_flag_spec='-L$libdir'
- hardcode_minus_L=yes
- # Samuel A. Falvo II <kc5tja at dolphin.openprojects.net> reports
- # that the semantics of dynamic libraries on AmigaOS, at least up
- # to version 4, is to share data among multiple programs linked
- # with the same dynamic library. Since this doesn't match the
- # behavior of shared libraries on other platforms, we can use
- # them.
- ld_shlibs=no
- beos*)
- if $LD --help 2>&1 | egrep ': supported targets:.* elf' > /dev/null; then
- allow_undefined_flag=unsupported
- # Joseph Beckenbach <jrb3 at best.com> says some releases of gcc
- # support --undefined. This deserves some investigation. FIXME
- archive_cmds='$CC -nostart $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
+ darwin* | rhapsody*)
+ case $host_os in
+ rhapsody* | darwin1.[012])
+ allow_undefined_flag='${wl}-undefined ${wl}suppress'
+ *) # Darwin 1.3 on
+ if test -z ${MACOSX_DEPLOYMENT_TARGET} ; then
+ allow_undefined_flag='${wl}-flat_namespace ${wl}-undefined ${wl}suppress'
+ else
+ case ${MACOSX_DEPLOYMENT_TARGET} in
+ 10.[012])
+ 10.*)
+ allow_undefined_flag='${wl}-undefined ${wl}dynamic_lookup'
+ esac
+ fi
+ esac
+ archive_cmds_need_lc=no
+ hardcode_automatic=yes
+ whole_archive_flag_spec=''
+ if test "$GCC" = yes ; then
+ output_verbose_link_cmd='echo'
+ archive_cmds='$CC -dynamiclib $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring'
+ module_cmds='$CC $allow_undefined_flag -o $lib -bundle $libobjs $deplibs$compiler_flags'
+ # Don't fix this by using the ld -exported_symbols_list flag, it doesn't exist in older darwin lds
+ archive_expsym_cmds='sed -e "s,#.*,," -e "s,^[ ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -dynamiclib $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
+ module_expsym_cmds='sed -e "s,#.*,," -e "s,^[ ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC $allow_undefined_flag -o $lib -bundle $libobjs $deplibs$compiler_flags~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
else
- ld_shlibs=no
+ xlc*)
+ archive_cmds='$CC -qmkshrobj $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-install_name ${wl}`echo $rpath/$soname` $verstring'
+ archive_expsym_cmds='sed -e "s,#.*,," -e "s,^[ ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -qmkshrobj $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-install_name ${wl}$rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
+ ld_shlibs=no
+ esac
fi
- cygwin* | mingw* | pw32*)
- # hardcode_libdir_flag_spec is actually meaningless, as there is
- # no search path for DLLs.
- always_export_symbols=yes
+ dgux*)
+ archive_cmds='$LD -G -h $soname -o $lib $libobjs $deplibs $linker_flags'
- extract_expsyms_cmds='test -f $output_objdir/impgen.c || \
- sed -e "/^# \/\* impgen\.c starts here \*\//,/^# \/\* impgen.c ends here \*\// { s/^# //;s/^# *$//; p; }" -e d < $''0 > $output_objdir/impgen.c~
- test -f $output_objdir/impgen.exe || (cd $output_objdir && \
- if test "x$HOST_CC" != "x" ; then $HOST_CC -o impgen impgen.c ; \
- else $CC -o impgen impgen.c ; fi)~
- $output_objdir/impgen $dir/$soroot > $output_objdir/$soname-def'
+ freebsd1*)
+ ld_shlibs=no
- old_archive_from_expsyms_cmds='$DLLTOOL --as=$AS --dllname $soname --def $output_objdir/$soname-def --output-lib $output_objdir/$newlib'
+ # FreeBSD 2.2.[012] allows us to include c++rt0.o to get C++ constructor
+ # support. Future versions do this automatically, but an explicit c++rt0.o
+ # does not break anything, and helps significantly (at the cost of a little
+ # extra space).
+ freebsd2.2*)
+ archive_cmds='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags /usr/lib/c++rt0.o'
+ hardcode_libdir_flag_spec='-R$libdir'
- # cygwin and mingw dlls have different entry points and sets of symbols
- # to exclude.
- # FIXME: what about values for MSVC?
- dll_entry=__cygwin_dll_entry at 12
- dll_exclude_symbols=DllMain at 12,_cygwin_dll_entry at 12,_cygwin_noncygwin_dll_entry at 12~
- case $host_os in
- mingw*)
- # mingw values
- dll_entry=_DllMainCRTStartup at 12
- dll_exclude_symbols=DllMain at 12,DllMainCRTStartup at 12,DllEntryPoint at 12~
+ # Unfortunately, older versions of FreeBSD 2 do not have this feature.
+ freebsd2*)
+ archive_cmds='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags'
- esac
- # mingw and cygwin differ, and it's simplest to just exclude the union
- # of the two symbol sets.
- dll_exclude_symbols=DllMain at 12,_cygwin_dll_entry at 12,_cygwin_noncygwin_dll_entry at 12,DllMainCRTStartup at 12,DllEntryPoint at 12
+ # FreeBSD 3 and greater uses gcc -shared to do shared libraries.
+ freebsd* | kfreebsd*-gnu | dragonfly*)
+ archive_cmds='$CC -shared -o $lib $libobjs $deplibs $compiler_flags'
- # recent cygwin and mingw systems supply a stub DllMain which the user
- # can override, but on older systems we have to supply one (in ltdll.c)
- if test "x$lt_cv_need_dllmain" = "xyes"; then
- ltdll_obj='$output_objdir/$soname-ltdll.'"$ac_objext "
- ltdll_cmds='test -f $output_objdir/$soname-ltdll.c || sed -e "/^# \/\* ltdll\.c starts here \*\//,/^# \/\* ltdll.c ends here \*\// { s/^# //; p; }" -e d < $''0 > $output_objdir/$soname-ltdll.c~
- test -f $output_objdir/$soname-ltdll.$ac_objext || (cd $output_objdir && $CC -c $soname-ltdll.c)~'
- else
- ltdll_obj=
- ltdll_cmds=
- fi
+ hpux9*)
+ archive_cmds='$rm $output_objdir/$soname~$CC -shared -fPIC ${wl}+b ${wl}$install_libdir -o $output_objdir/$soname $libobjs $deplibs $compiler_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
+ else
+ archive_cmds='$rm $output_objdir/$soname~$LD -b +b $install_libdir -o $output_objdir/$soname $libobjs $deplibs $linker_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
+ fi
+ hardcode_libdir_flag_spec='${wl}+b ${wl}$libdir'
+ hardcode_libdir_separator=:
- # Extract the symbol export list from an `--export-all' def file,
- # then regenerate the def file from the symbol export list, so that
- # the compiled dll only exports the symbol export list.
- # Be careful not to strip the DATA tag left be newer dlltools.
- export_symbols_cmds="$ltdll_cmds"'
- $DLLTOOL --export-all --exclude-symbols '$dll_exclude_symbols' --output-def $output_objdir/$soname-def '$ltdll_obj'$libobjs $convenience~
- sed -e "1,/EXPORTS/d" -e "s/ @ [0-9]*//" -e "s/ *;.*$//" < $output_objdir/$soname-def > $export_symbols'
+ # hardcode_minus_L: Not really in the search PATH,
+ # but as the default location of the library.
- # If the export-symbols file already is a .def file (1st line
- # is EXPORTS), use it as is.
- # If DATA tags from a recent dlltool are present, honour them!
- archive_expsym_cmds='if test "x`sed 1q $export_symbols`" = xEXPORTS; then
- cp $export_symbols $output_objdir/$soname-def;
+ hpux10*)
+ if test "$GCC" = yes -a "$with_gnu_ld" = no; then
+ archive_cmds='$CC -shared -fPIC ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $libobjs $deplibs $compiler_flags'
else
- echo EXPORTS > $output_objdir/$soname-def;
- _lt_hint=1;
- cat $export_symbols | while read symbol; do
- set dummy \$symbol;
- case \$# in
- 2) echo " \$2 @ \$_lt_hint ; " >> $output_objdir/$soname-def;;
- 4) echo " \$2 \$3 \$4 ; " >> $output_objdir/$soname-def; _lt_hint=`expr \$_lt_hint - 1`;;
- *) echo " \$2 @ \$_lt_hint \$3 ; " >> $output_objdir/$soname-def;;
- esac;
- _lt_hint=`expr 1 + \$_lt_hint`;
- done;
- fi~
- '"$ltdll_cmds"'
- $CC -Wl,--base-file,$output_objdir/$soname-base '$lt_cv_cc_dll_switch' -Wl,-e,'$dll_entry' -o $output_objdir/$soname '$ltdll_obj'$libobjs $deplibs $compiler_flags~
- $DLLTOOL --as=$AS --dllname $soname --exclude-symbols '$dll_exclude_symbols' --def $output_objdir/$soname-def --base-file $output_objdir/$soname-base --output-exp $output_objdir/$soname-exp~
- $CC -Wl,--base-file,$output_objdir/$soname-base $output_objdir/$soname-exp '$lt_cv_cc_dll_switch' -Wl,-e,'$dll_entry' -o $output_objdir/$soname '$ltdll_obj'$libobjs $deplibs $compiler_flags~
- $DLLTOOL --as=$AS --dllname $soname --exclude-symbols '$dll_exclude_symbols' --def $output_objdir/$soname-def --base-file $output_objdir/$soname-base --output-exp $output_objdir/$soname-exp --output-lib $output_objdir/$libname.dll.a~
- $CC $output_objdir/$soname-exp '$lt_cv_cc_dll_switch' -Wl,-e,'$dll_entry' -o $output_objdir/$soname '$ltdll_obj'$libobjs $deplibs $compiler_flags'
+ archive_cmds='$LD -b +h $soname +b $install_libdir -o $lib $libobjs $deplibs $linker_flags'
+ fi
+ if test "$with_gnu_ld" = no; then
- netbsd*)
- if echo __ELF__ | $CC -E - | grep __ELF__ >/dev/null; then
- archive_cmds='$LD -Bshareable $libobjs $deplibs $linker_flags -o $lib'
- wlarc=
- else
- archive_cmds='$CC -shared -nodefaultlibs $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
- archive_expsym_cmds='$CC -shared -nodefaultlibs $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
- fi
- solaris* | sysv5*)
- if $LD -v 2>&1 | egrep 'BFD 2\.8' > /dev/null; then
- ld_shlibs=no
- cat <<EOF 1>&2
+ fi
-*** Warning: The releases 2.8.* of the GNU linker cannot reliably
-*** create shared libraries on Solaris systems. Therefore, libtool
-*** is disabling shared libraries support. We urge you to upgrade GNU
-*** binutils to release 2.9.1 or newer. Another option is to modify
-*** your PATH or compiler configuration so that the native linker is
-*** used, and then restart.
-EOF
- elif $LD --help 2>&1 | egrep ': supported targets:.* elf' > /dev/null; then
- archive_cmds='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
- archive_expsym_cmds='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
- else
- ld_shlibs=no
- fi
- sunos4*)
- archive_cmds='$LD -assert pure-text -Bshareable -o $lib $libobjs $deplibs $linker_flags'
- wlarc=
- hardcode_direct=yes
- hardcode_shlibpath_var=no
- else
- ld_shlibs=no
- fi
- esac
- if test "$ld_shlibs" = yes; then
- runpath_var=LD_RUN_PATH
- hardcode_libdir_flag_spec='${wl}--rpath ${wl}$libdir'
- export_dynamic_flag_spec='${wl}--export-dynamic'
- case $host_os in
- # dlltool doesn't understand --whole-archive et. al.
- whole_archive_flag_spec=
- # ancient GNU ld didn't support --whole-archive et. al.
- if $LD --help 2>&1 | egrep 'no-whole-archive' > /dev/null; then
- whole_archive_flag_spec="$wlarc"'--whole-archive$convenience '"$wlarc"'--no-whole-archive'
+ hpux11*)
+ case $host_cpu in
+ hppa*64*)
+ archive_cmds='$CC -shared ${wl}+h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
+ ia64*)
+ archive_cmds='$CC -shared ${wl}+h ${wl}$soname ${wl}+nodefaultrpath -o $lib $libobjs $deplibs $compiler_flags'
+ esac
else
+ case $host_cpu in
+ hppa*64*)
+ archive_cmds='$CC -b ${wl}+h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
+ ia64*)
+ archive_cmds='$CC -b ${wl}+h ${wl}$soname ${wl}+nodefaultrpath -o $lib $libobjs $deplibs $compiler_flags'
+ archive_cmds='$CC -b ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $libobjs $deplibs $compiler_flags'
+ esac
fi
- esac
- fi
-else
- # PORTME fill in a description of your system's linker (not GNU ld)
- case $host_os in
- aix3*)
- archive_expsym_cmds='$LD -o $output_objdir/$soname $libobjs $deplibs $linker_flags -bE:$export_symbols -T512 -H512 -bM:SRE~$AR $AR_FLAGS $lib $output_objdir/$soname'
- # Note: this linker hardcodes the directories in LIBPATH if there
- # are no directories specified by -L.
- if test "$GCC" = yes && test -z "$link_static_flag"; then
- # Neither direct hardcoding nor static linking is supported with a
- # broken collect2.
- hardcode_direct=unsupported
- fi
- aix4* | aix5*)
- if test "$host_cpu" = ia64; then
- # On IA64, the linker does run time linking by default, so we don't
- # have to do anything special.
- aix_use_runtimelinking=no
- exp_sym_flag='-Bexport'
- no_entry_flag=""
- else
- # Test if we are trying to use run time linking or normal
- # AIX style linking. If -brtl is somewhere in LDFLAGS, we
- # need to do runtime linking.
- case $host_os in aix4.[23]|aix4.[23].*|aix5*)
- for ld_flag in $LDFLAGS; do
- case $ld_flag in
- *-brtl*)
- aix_use_runtimelinking=yes
- break
+ case $host_cpu in
+ hppa*64*|ia64*)
+ hardcode_libdir_flag_spec_ld='+b $libdir'
- esac
- done
- esac
- exp_sym_flag='-bexport'
- no_entry_flag='-bnoentry'
- fi
- # When large executables or shared objects are built, AIX ld can
- # have problems creating the table of contents. If linking a library
- # or program results in "error TOC overflow" add -mminimal-toc to
- # CXXFLAGS/CFLAGS for g++/gcc. In the cases where that is not
- # enough to fix the problem, add -Wl,-bbigtoc to LDFLAGS.
- archive_cmds=''
- hardcode_libdir_separator=':'
- if test "$GCC" = yes; then
- case $host_os in aix4.[012]|aix4.[012].*)
- collect2name=`${CC} -print-prog-name=collect2`
- if test -f "$collect2name" && \
- strings "$collect2name" | grep resolve_lib_name >/dev/null
- then
- # We have reworked collect2
- else
- # We have old collect2
- # It fails to find uninstalled libraries when the uninstalled
- # path is not listed in the libpath. Setting hardcode_minus_L
- # to unsupported forces relinking
- fi
- esac
+ esac
+ fi
- shared_flag='-shared'
- else
- # not using gcc
- shared_flag='${wl}-G'
+ irix5* | irix6* | nonstopux*)
+ archive_cmds='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
else
- if test "$aix_use_runtimelinking" = yes; then
- else
- shared_flag='${wl}-bM:SRE'
- fi
+ archive_cmds='$LD -shared $libobjs $deplibs $linker_flags -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
+ hardcode_libdir_flag_spec_ld='-rpath $libdir'
fi
- fi
+ hardcode_libdir_flag_spec='${wl}-rpath ${wl}$libdir'
- # It seems that -bexpall can do strange things, so it is better to
- # generate a list of symbols to export.
- # Warning - without using the other runtime loading flags (-brtl),
- # -berok will link without error, but may produce a broken library.
- allow_undefined_flag='-berok'
- hardcode_libdir_flag_spec='${wl}-blibpath:$libdir:/usr/lib:/lib'
- archive_expsym_cmds="\$CC"' -o $output_objdir/$soname $libobjs $deplibs $compiler_flags `if test "x${allow_undefined_flag}" != "x"; then echo "${wl}${allow_undefined_flag}"; else :; fi` '"\${wl}$no_entry_flag \${wl}$exp_sym_flag:\$export_symbols $shared_flag"
- else
- hardcode_libdir_flag_spec='${wl}-R $libdir:/usr/lib:/lib'
- allow_undefined_flag="-z nodefs"
- archive_expsym_cmds="\$CC $shared_flag"' -o $output_objdir/$soname ${wl}-h$soname $libobjs $deplibs $compiler_flags ${wl}${allow_undefined_flag} '"\${wl}$no_entry_flag \${wl}$exp_sym_flag:\$export_symbols"
+ netbsd*)
+ archive_cmds='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags' # a.out
else
- hardcode_libdir_flag_spec='${wl}-bnolibpath ${wl}-blibpath:$libdir:/usr/lib:/lib'
- # Warning - without using the other run time loading flags,
- allow_undefined_flag='${wl}-berok'
- # This is a bit strange, but is similar to how AIX traditionally builds
- # it's shared libraries.
- archive_expsym_cmds="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs $compiler_flags ${allow_undefined_flag} '"\${wl}$no_entry_flag \${wl}$exp_sym_flag:\$export_symbols"' ~$AR -crlo $objdir/$libname$release.a $objdir/$soname'
+ archive_cmds='$LD -shared -o $lib $libobjs $deplibs $linker_flags' # ELF
fi
- fi
- amigaos*)
- # see comment about different semantics on the GNU ld section
- ld_shlibs=no
+ newsos6)
- hardcode_libdir_flag_spec=' '
- # Tell ltmain to make .lib files, not .a files.
- libext=lib
- # FIXME: Setting linknames here is a bad hack.
- archive_cmds='$CC -o $lib $libobjs $compiler_flags `echo "$deplibs" | sed -e '\''s/ -lc$//'\''` -link -dll~linknames='
- # The linker will automatically build a .lib file if we build a DLL.
- old_archive_from_new_cmds='true'
- # FIXME: Should let the user specify the lib program.
- old_archive_cmds='lib /OUT:$oldlib$oldobjs$old_deplibs'
- fix_srcfile_path='`cygpath -w "$srcfile"`'
+ openbsd*)
+ if test -z "`echo __ELF__ | $CC -E - | grep __ELF__`" || test "$host_os-$host_cpu" = "openbsd2.8-powerpc"; then
+ archive_cmds='$CC -shared $pic_flag -o $lib $libobjs $deplibs $compiler_flags'
+ archive_expsym_cmds='$CC -shared $pic_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-retain-symbols-file,$export_symbols'
+ else
+ case $host_os in
+ openbsd[01].* | openbsd2.[0-7] | openbsd2.[0-7].*)
+ esac
+ fi
- darwin* | rhapsody*)
- case "$host_os" in
- rhapsody* | darwin1.[012])
- allow_undefined_flag='-undefined suppress'
+ os2*)
+ archive_cmds='$echo "LIBRARY $libname INITINSTANCE" > $output_objdir/$libname.def~$echo "DESCRIPTION \"$libname\"" >> $output_objdir/$libname.def~$echo DATA >> $output_objdir/$libname.def~$echo " SINGLE NONSHARED" >> $output_objdir/$libname.def~$echo EXPORTS >> $output_objdir/$libname.def~emxexp $libobjs >> $output_objdir/$libname.def~$CC -Zdll -Zcrtdll -o $lib $libobjs $deplibs $compiler_flags $output_objdir/$libname.def'
+ old_archive_From_new_cmds='emximp -o $output_objdir/$libname.a $output_objdir/$libname.def'
- *) # Darwin 1.3 on
- allow_undefined_flag='-flat_namespace -undefined suppress'
- esac
- # FIXME: Relying on posixy $() will cause problems for
- # cross-compilation, but unfortunately the echo tests do not
- # yet detect zsh echo's removal of \ escapes. Also zsh mangles
- # `"' quotes if we put them in here... so don't!
- archive_cmds='$CC -r -keep_private_externs -nostdlib -o ${lib}-master.o $libobjs && $CC $(test .$module = .yes && echo -bundle || echo -dynamiclib) $allow_undefined_flag -o $lib ${lib}-master.o $deplibs$linker_flags $(test .$module != .yes && echo -install_name $rpath/$soname $verstring)'
- # We need to add '_' to the symbols in $export_symbols first
- #archive_expsym_cmds="$archive_cmds"' && strip -s $export_symbols'
- whole_archive_flag_spec='-all_load $convenience'
- freebsd1*)
- ld_shlibs=no
- # FreeBSD 2.2.[012] allows us to include c++rt0.o to get C++ constructor
- # support. Future versions do this automatically, but an explicit c++rt0.o
- # does not break anything, and helps significantly (at the cost of a little
- # extra space).
- freebsd2.2*)
- archive_cmds='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags /usr/lib/c++rt0.o'
- hardcode_libdir_flag_spec='-R$libdir'
- # Unfortunately, older versions of FreeBSD 2 do not have this feature.
- freebsd2*)
- archive_cmds='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags'
- # FreeBSD 3 and greater uses gcc -shared to do shared libraries.
- freebsd*)
- archive_cmds='$CC -shared -o $lib $libobjs $deplibs $compiler_flags'
- case $host_os in
- hpux9*) archive_cmds='$rm $output_objdir/$soname~$LD -b +b $install_libdir -o $output_objdir/$soname $libobjs $deplibs $linker_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib' ;;
- *) archive_cmds='$LD -b +h $soname +b $install_libdir -o $lib $libobjs $deplibs $linker_flags' ;;
- esac
- hardcode_libdir_flag_spec='${wl}+b ${wl}$libdir'
- hardcode_libdir_separator=:
- hardcode_minus_L=yes # Not in the search PATH, but as the default
- # location of the library.
- export_dynamic_flag_spec='${wl}-E'
- irix5* | irix6* | nonstopux*)
- archive_cmds='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
+ osf3*)
+ allow_undefined_flag=' ${wl}-expect_unresolved ${wl}\*'
+ archive_cmds='$CC -shared${allow_undefined_flag} $libobjs $deplibs $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
+ else
+ allow_undefined_flag=' -expect_unresolved \*'
+ archive_cmds='$LD -shared${allow_undefined_flag} $libobjs $deplibs $linker_flags -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
+ fi
- else
- archive_cmds='$LD -shared $libobjs $deplibs $linker_flags -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
- hardcode_libdir_flag_spec='-rpath $libdir'
- fi
- link_all_deplibs=yes
- netbsd*)
- archive_cmds='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags' # a.out
- else
- archive_cmds='$LD -shared -o $lib $libobjs $deplibs $linker_flags' # ELF
- fi
+ osf4* | osf5*) # as osf3* with the addition of -msym flag
+ archive_cmds='$CC -shared${allow_undefined_flag} $libobjs $deplibs $compiler_flags ${wl}-msym ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
+ else
+ archive_cmds='$LD -shared${allow_undefined_flag} $libobjs $deplibs $linker_flags -msym -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
+ archive_expsym_cmds='for i in `cat $export_symbols`; do printf "%s %s\\n" -exported_symbol "\$i" >> $lib.exp; done; echo "-hidden">> $lib.exp~
+ $LD -shared${allow_undefined_flag} -input $lib.exp $linker_flags $libobjs $deplibs -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib~$rm $lib.exp'
- newsos6)
- archive_cmds='$LD -G -h $soname -o $lib $libobjs $deplibs $linker_flags'
- hardcode_libdir_flag_spec='${wl}-rpath ${wl}$libdir'
+ # Both c and cxx compiler support -rpath directly
+ hardcode_libdir_flag_spec='-rpath $libdir'
+ fi
- openbsd*)
- if test -z "`echo __ELF__ | $CC -E - | grep __ELF__`" || test "$host_os-$host_cpu" = "openbsd2.8-powerpc"; then
- archive_cmds='$CC -shared $pic_flag -o $lib $libobjs $deplibs $compiler_flags'
- hardcode_libdir_flag_spec='${wl}-rpath,$libdir'
- else
- openbsd[01].* | openbsd2.[0-7] | openbsd2.[0-7].*)
+ solaris*)
+ no_undefined_flag=' -z text'
+ wlarc='${wl}'
+ archive_cmds='$CC -shared ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
+ archive_expsym_cmds='$echo "{ global:" > $lib.exp~cat $export_symbols | $SED -e "s/\(.*\)/\1;/" >> $lib.exp~$echo "local: *; };" >> $lib.exp~
+ $CC -shared ${wl}-M ${wl}$lib.exp ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags~$rm $lib.exp'
+ else
+ wlarc=''
+ archive_cmds='$LD -G${allow_undefined_flag} -h $soname -o $lib $libobjs $deplibs $linker_flags'
+ $LD -G${allow_undefined_flag} -M $lib.exp -h $soname -o $lib $libobjs $deplibs $linker_flags~$rm $lib.exp'
+ fi
+ case $host_os in
+ solaris2.[0-5] | solaris2.[0-5].*) ;;
+ # The compiler driver will combine linker options so we
+ # cannot just pass the convience library names through
+ # without $wl, iff we do not link with $LD.
+ # Luckily, gcc supports the same syntax we need for Sun Studio.
+ # Supported since Solaris 2.6 (maybe 2.5.1?)
+ case $wlarc in
+ whole_archive_flag_spec='-z allextract$convenience -z defaultextract' ;;
+ whole_archive_flag_spec='${wl}-z ${wl}allextract`for conv in $convenience\"\"; do test -n \"$conv\" && new_convenience=\"$new_convenience,$conv\"; done; $echo \"$new_convenience\"` ${wl}-z ${wl}defaultextract' ;;
+ esac ;;
esac
- fi
- os2*)
- archive_cmds='$echo "LIBRARY $libname INITINSTANCE" > $output_objdir/$libname.def~$echo "DESCRIPTION \"$libname\"" >> $output_objdir/$libname.def~$echo DATA >> $output_objdir/$libname.def~$echo " SINGLE NONSHARED" >> $output_objdir/$libname.def~$echo EXPORTS >> $output_objdir/$libname.def~emxexp $libobjs >> $output_objdir/$libname.def~$CC -Zdll -Zcrtdll -o $lib $libobjs $deplibs $compiler_flags $output_objdir/$libname.def'
- old_archive_from_new_cmds='emximp -o $output_objdir/$libname.a $output_objdir/$libname.def'
+ sunos4*)
+ if test "x$host_vendor" = xsequent; then
+ # Use $CC to link under sequent, because it throws in some extra .o
+ # files that make .init and .fini sections work.
+ archive_cmds='$CC -G ${wl}-h $soname -o $lib $libobjs $deplibs $compiler_flags'
+ else
+ archive_cmds='$LD -assert pure-text -Bstatic -o $lib $libobjs $deplibs $linker_flags'
+ fi
- osf3*)
- allow_undefined_flag=' ${wl}-expect_unresolved ${wl}\*'
- archive_cmds='$CC -shared${allow_undefined_flag} $libobjs $deplibs $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
- else
- allow_undefined_flag=' -expect_unresolved \*'
- archive_cmds='$LD -shared${allow_undefined_flag} $libobjs $deplibs $linker_flags -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
- fi
- osf4* | osf5*) # as osf3* with the addition of -msym flag
- archive_cmds='$CC -shared${allow_undefined_flag} $libobjs $deplibs $compiler_flags ${wl}-msym ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
- else
- archive_cmds='$LD -shared${allow_undefined_flag} $libobjs $deplibs $linker_flags -msym -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
- archive_expsym_cmds='for i in `cat $export_symbols`; do printf "-exported_symbol " >> $lib.exp; echo "\$i" >> $lib.exp; done; echo "-hidden">> $lib.exp~
- $LD -shared${allow_undefined_flag} -input $lib.exp $linker_flags $libobjs $deplibs -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${objdir}/so_locations -o $lib~$rm $lib.exp'
- #Both c and cxx compiler support -rpath directly
- fi
- sco3.2v5*)
- hardcode_runpath_var=yes
- export_dynamic_flag_spec='${wl}-Bexport'
- solaris*)
- # gcc --version < 3.0 without binutils cannot create self contained
- # shared libraries reliably, requiring libgcc.a to resolve some of
- # the object symbols generated in some cases. Libraries that use
- # assert need libgcc.a to resolve __eprintf, for example. Linking
- # a copy of libgcc.a into every shared library to guarantee resolving
- # such symbols causes other problems: According to Tim Van Holder
- # <tim.van.holder at pandora.be>, C++ libraries end up with a separate
- # (to the application) exception stack for one thing.
- no_undefined_flag=' -z defs'
- case `$CC --version 2>/dev/null` in
- [12].*)
- cat <<EOF 1>&2
-*** Warning: Releases of GCC earlier than version 3.0 cannot reliably
-*** create self contained shared libraries on Solaris systems, without
-*** introducing a dependency on libgcc.a. Therefore, libtool is disabling
-*** -no-undefined support, which will at least allow you to build shared
-*** libraries. However, you may find that when you link such libraries
-*** into an application without using GCC, you have to manually add
-*** \`gcc --print-libgcc-file-name\` to the link command. We urge you to
-*** upgrade to a newer version of GCC. Another option is to rebuild your
-*** current GCC to use the GNU linker from GNU binutils 2.9.1 or newer.
-EOF
+ sysv4)
+ case $host_vendor in
+ sni)
+ hardcode_direct=yes # is this really true???
+ siemens)
+ ## LD is ld it makes a PLAMLIB
+ ## CC just makes a GrossModule.
+ archive_cmds='$LD -G -o $lib $libobjs $deplibs $linker_flags'
+ reload_cmds='$CC -r -o $output$reload_objs'
+ motorola)
+ hardcode_direct=no #Motorola manual says yes, but my tests say they lie
esac
- fi
- # $CC -shared without GNU ld will not create a library from C++
- # object files and a static libstdc++, better avoid it by now
- archive_cmds='$LD -G${allow_undefined_flag} -h $soname -o $lib $libobjs $deplibs $linker_flags'
- archive_expsym_cmds='$echo "{ global:" > $lib.exp~cat $export_symbols | sed -e "s/\(.*\)/\1;/" >> $lib.exp~$echo "local: *; };" >> $lib.exp~
- $LD -G${allow_undefined_flag} -M $lib.exp -h $soname -o $lib $libobjs $deplibs $linker_flags~$rm $lib.exp'
- case $host_os in
- solaris2.[0-5] | solaris2.[0-5].*) ;;
- *) # Supported since Solaris 2.6 (maybe 2.5.1?)
- whole_archive_flag_spec='-z allextract$convenience -z defaultextract' ;;
- esac
+ runpath_var='LD_RUN_PATH'
- sunos4*)
- if test "x$host_vendor" = xsequent; then
- # Use $CC to link under sequent, because it throws in some extra .o
- # files that make .init and .fini sections work.
- archive_cmds='$CC -G ${wl}-h $soname -o $lib $libobjs $deplibs $compiler_flags'
- else
- archive_cmds='$LD -assert pure-text -Bstatic -o $lib $libobjs $deplibs $linker_flags'
- fi
+ sysv4.3*)
+ export_dynamic_flag_spec='-Bexport'
- sysv4)
- case $host_vendor in
- sni)
- hardcode_direct=yes # is this really true???
- siemens)
- ## LD is ld it makes a PLAMLIB
- ## CC just makes a GrossModule.
- archive_cmds='$LD -G -o $lib $libobjs $deplibs $linker_flags'
- reload_cmds='$CC -r -o $output$reload_objs'
- hardcode_direct=no
- motorola)
- hardcode_direct=no #Motorola manual says yes, but my tests say they lie
- esac
- runpath_var='LD_RUN_PATH'
+ sysv4*MP*)
+ if test -d /usr/nec; then
+ hardcode_runpath_var=yes
+ ld_shlibs=yes
+ fi
- sysv4.3*)
- export_dynamic_flag_spec='-Bexport'
+ sysv4*uw2* | sysv5OpenUNIX* | sysv5UnixWare7.[01].[10]* | unixware7*)
+ no_undefined_flag='${wl}-z,text'
- sysv5*)
- no_undefined_flag=' -z text'
+ archive_cmds='$CC -shared ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+ archive_expsym_cmds='$CC -shared ${wl}-Bexport:$export_symbols ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+ else
+ archive_cmds='$CC -G ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+ archive_expsym_cmds='$CC -G ${wl}-Bexport:$export_symbols ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+ fi
- uts4*)
+ sysv5* | sco3.2v5* | sco5v6*)
+ # Note: We can NOT use -z defs as we might desire, because we do not
+ # link with -lc, and that would cause any symbols used from libc to
+ # always be unresolved, which means just about no library would
+ # ever link correctly. If we're not using GNU ld we use -z text
+ # though, which does catch some bad symbols but isn't as heavy-handed
+ # as -z defs.
+ allow_undefined_flag='${wl}-z,nodefs'
+ hardcode_libdir_flag_spec='`test -z "$SCOABSPATH" && echo ${wl}-R,$libdir`'
+ export_dynamic_flag_spec='${wl}-Bexport'
- dgux*)
+ archive_cmds='$CC -shared ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+ archive_expsym_cmds='$CC -shared ${wl}-Bexport:$export_symbols ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+ else
+ archive_cmds='$CC -G ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+ archive_expsym_cmds='$CC -G ${wl}-Bexport:$export_symbols ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+ fi
- sysv4*MP*)
- if test -d /usr/nec; then
+ uts4*)
- ld_shlibs=yes
- fi
- sysv4.2uw2*)
- hardcode_minus_L=no
+ ld_shlibs=no
+ esac
+ fi
- sysv5uw7* | unixware7*)
- no_undefined_flag='${wl}-z ${wl}text'
- archive_cmds='$CC -shared ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
- else
- archive_cmds='$CC -G ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
- fi
- ld_shlibs=no
- esac
-fi
echo "$as_me:$LINENO: result: $ld_shlibs" >&5
echo "${ECHO_T}$ld_shlibs" >&6
test "$ld_shlibs" = no && can_build_shared=no
-# Check hardcoding attributes.
-echo "$as_me:$LINENO: checking how to hardcode library paths into programs" >&5
-echo $ECHO_N "checking how to hardcode library paths into programs... $ECHO_C" >&6
-hardcode_action=
-if test -n "$hardcode_libdir_flag_spec" || \
- test -n "$runpath_var"; then
+# Do we need to explicitly link libc?
+case "x$archive_cmds_need_lc" in
+x|xyes)
+ # Assume -lc should be added
- # We can hardcode non-existant directories.
- if test "$hardcode_direct" != no &&
- # If the only mechanism to avoid hardcoding is shlibpath_var, we
- # have to relink, otherwise we might link with an installed library
- # when we should be linking with a yet-to-be-installed one
- ## test "$hardcode_shlibpath_var" != no &&
- test "$hardcode_minus_L" != no; then
- # Linking always hardcodes the temporary library directory.
- hardcode_action=relink
- else
- # We can link without hardcoding, and we can hardcode nonexisting dirs.
- hardcode_action=immediate
+ if test "$enable_shared" = yes && test "$GCC" = yes; then
+ case $archive_cmds in
+ # FIXME: we may have to deal with multi-command sequences.
+ '$CC '*)
+ # Test whether the compiler implicitly links with -lc since on some
+ # systems, -lgcc has to come before -lc. If gcc already passes -lc
+ # to ld, don't add -lc before -lgcc.
+ echo "$as_me:$LINENO: checking whether -lc should be explicitly linked in" >&5
+echo $ECHO_N "checking whether -lc should be explicitly linked in... $ECHO_C" >&6
+ $rm conftest*
+ printf "$lt_simple_compile_test_code" > conftest.$ac_ext
+ if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
+ (eval $ac_compile) 2>&5
+ ac_status=$?
+ echo "$as_me:$LINENO: \$? = $ac_status" >&5
+ (exit $ac_status); } 2>conftest.err; then
+ soname=conftest
+ lib=conftest
+ libobjs=conftest.$ac_objext
+ deplibs=
+ wl=$lt_prog_compiler_wl
+ pic_flag=$lt_prog_compiler_pic
+ compiler_flags=-v
+ linker_flags=-v
+ verstring=
+ output_objdir=.
+ libname=conftest
+ lt_save_allow_undefined_flag=$allow_undefined_flag
+ if { (eval echo "$as_me:$LINENO: \"$archive_cmds 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1\"") >&5
+ (eval $archive_cmds 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1) 2>&5
+ ac_status=$?
+ then
+ else
+ fi
+ allow_undefined_flag=$lt_save_allow_undefined_flag
+ else
+ cat conftest.err 1>&5
+ fi
+ $rm conftest*
+ echo "$as_me:$LINENO: result: $archive_cmds_need_lc" >&5
+echo "${ECHO_T}$archive_cmds_need_lc" >&6
+ esac
fi
-else
- # We cannot hardcode anything, or else we can only hardcode existing
- # directories.
- hardcode_action=unsupported
-fi
-echo "$as_me:$LINENO: result: $hardcode_action" >&5
-echo "${ECHO_T}$hardcode_action" >&6
+esac
-striplib=
-old_striplib=
-echo "$as_me:$LINENO: checking whether stripping libraries is possible" >&5
-echo $ECHO_N "checking whether stripping libraries is possible... $ECHO_C" >&6
-if test -n "$STRIP" && $STRIP -V 2>&1 | grep "GNU strip" >/dev/null; then
- test -z "$old_striplib" && old_striplib="$STRIP --strip-debug"
- test -z "$striplib" && striplib="$STRIP --strip-unneeded"
- echo "$as_me:$LINENO: result: yes" >&5
-echo "${ECHO_T}yes" >&6
-else
- echo "$as_me:$LINENO: result: no" >&5
-echo "${ECHO_T}no" >&6
-fi
-reload_cmds='$LD$reload_flag -o $output$reload_objs'
-test -z "$deplibs_check_method" && deplibs_check_method=unknown
-# PORTME Fill in your ld.so characteristics
echo "$as_me:$LINENO: checking dynamic linker characteristics" >&5
echo $ECHO_N "checking dynamic linker characteristics... $ECHO_C" >&6
library_names_spec=
libname_spec='lib$name'
soname_spec=
+shrext_cmds=".so"
postinstall_cmds=
postuninstall_cmds=
finish_cmds=
@@ -6473,16 +7863,35 @@
version_type=none
dynamic_linker="$host_os ld.so"
sys_lib_dlsearch_path_spec="/lib /usr/lib"
-sys_lib_search_path_spec="/lib /usr/lib /usr/local/lib"
+if test "$GCC" = yes; then
+ sys_lib_search_path_spec=`$CC -print-search-dirs | grep "^libraries:" | $SED -e "s/^libraries://" -e "s,=/,/,g"`
+ if echo "$sys_lib_search_path_spec" | grep ';' >/dev/null ; then
+ # if the path contains ";" then we assume it to be the separator
+ # otherwise default to the standard path separator (i.e. ":") - it is
+ # assumed that no part of a normal pathname contains ";" but that should
+ # okay in the real world where ";" in dirpaths is itself problematic.
+ sys_lib_search_path_spec=`echo "$sys_lib_search_path_spec" | $SED -e 's/;/ /g'`
+ else
+ sys_lib_search_path_spec=`echo "$sys_lib_search_path_spec" | $SED -e "s/$PATH_SEPARATOR/ /g"`
+ fi
+else
+ sys_lib_search_path_spec="/lib /usr/lib /usr/local/lib"
+fi
+need_lib_prefix=unknown
+hardcode_into_libs=no
+# when you set need_version to no, make sure it does not cause -set_version
+# flags to be left without arguments
+need_version=unknown
case $host_os in
aix3*)
version_type=linux
- library_names_spec='${libname}${release}.so$versuffix $libname.a'
+ library_names_spec='${libname}${release}${shared_ext}$versuffix $libname.a'
shlibpath_var=LIBPATH
- # AIX has no versioning support, so we append a major version to the name.
- soname_spec='${libname}${release}.so$major'
+ # AIX 3 has no versioning support, so we append a major version to the name.
+ soname_spec='${libname}${release}${shared_ext}$major'
aix4* | aix5*)
@@ -6492,7 +7901,7 @@
hardcode_into_libs=yes
# AIX 5 supports IA64
- library_names_spec='${libname}${release}.so$major ${libname}${release}.so$versuffix $libname.so'
+ library_names_spec='${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext}$versuffix $libname${shared_ext}'
shlibpath_var=LD_LIBRARY_PATH
else
# With GCC up to 2.95.x, collect2 would create an import file
@@ -6502,57 +7911,54 @@
# development snapshots of GCC prior to 3.0.
case $host_os in
aix4 | aix4.[01] | aix4.[01].*)
- if { echo '#if __GNUC__ > 2 || (__GNUC__ == 2 && __GNUC_MINOR__ >= 97)'
- echo ' yes '
- echo '#endif'; } | ${CC} -E - | grep yes > /dev/null; then
- else
- can_build_shared=no
- fi
+ if { echo '#if __GNUC__ > 2 || (__GNUC__ == 2 && __GNUC_MINOR__ >= 97)'
+ echo ' yes '
+ echo '#endif'; } | ${CC} -E - | grep yes > /dev/null; then
+ else
+ can_build_shared=no
+ fi
esac
- # AIX (on Power*) has no versioning support, so currently we can
- # not hardcode correct soname into executable. Probably we can
- # add versioning support to collect2, so additional links can
- # be useful in future.
+ # AIX (on Power*) has no versioning support, so currently we can not hardcode correct
+ # soname into executable. Probably we can add versioning support to
+ # collect2, so additional links can be useful in future.
# If using run time linking (on AIX 4.2 or later) use lib<name>.so
# instead of lib<name>.a to let people know that these are not
# typical AIX shared libraries.
- library_names_spec='${libname}${release}.so$versuffix ${libname}${release}.so$major $libname.so'
+ library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname${shared_ext}'
else
# We preserve .a as extension for shared libraries through AIX4.2
# and later when we are not doing run time linking.
library_names_spec='${libname}${release}.a $libname.a'
fi
fi
- hardcode_into_libs=yes
amigaos*)
library_names_spec='$libname.ixlibrary $libname.a'
# Create ${libname}_ixlibrary.a entries in /sys/libs.
- finish_eval='for lib in `ls $libdir/*.ixlibrary 2>/dev/null`; do libname=`$echo "X$lib" | $Xsed -e '\''s%^.*/\([^/]*\)\.ixlibrary$%\1%'\''`; test $rm /sys/libs/${libname}_ixlibrary.a; $show "(cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a)"; (cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a) || exit 1; done'
+ finish_eval='for lib in `ls $libdir/*.ixlibrary 2>/dev/null`; do libname=`$echo "X$lib" | $Xsed -e '\''s%^.*/\([^/]*\)\.ixlibrary$%\1%'\''`; test $rm /sys/libs/${libname}_ixlibrary.a; $show "cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a"; cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a || exit 1; done'
beos*)
- library_names_spec='${libname}.so'
+ library_names_spec='${libname}${shared_ext}'
shlibpath_var=LIBRARY_PATH
-bsdi4*)
+bsdi[45]*)
version_type=linux
need_version=no
finish_cmds='PATH="\$PATH:/sbin" ldconfig $libdir'
sys_lib_search_path_spec="/shlib /usr/lib /usr/X11/lib /usr/contrib/lib /lib /usr/local/lib"
sys_lib_dlsearch_path_spec="/shlib /usr/lib /usr/local/lib"
- export_dynamic_flag_spec=-rdynamic
# the default ld.so.conf also contains /usr/contrib/lib and
# /usr/X11R6/lib (/usr/X11 is a link to /usr/X11R6), but let us allow
# libtool to hard-code these into programs
@@ -6560,29 +7966,56 @@
version_type=windows
need_version=no
need_lib_prefix=no
case $GCC,$host_os in
- yes,cygwin*)
+ yes,cygwin* | yes,mingw* | yes,pw32*)
library_names_spec='$libname.dll.a'
- soname_spec='`echo ${libname} | sed -e 's/^lib/cyg/'``echo ${release} | sed -e 's/[.]/-/g'`${versuffix}.dll'
- postinstall_cmds='dlpath=`bash 2>&1 -c '\''. $dir/${file}i;echo \$dlname'\''`~
+ # DLL is installed to $(libdir)/../bin by postinstall_cmds
+ postinstall_cmds='base_file=`basename \${file}`~
+ dlpath=`$SHELL 2>&1 -c '\''. $dir/'\''\${base_file}'\''i;echo \$dlname'\''`~
dldir=$destdir/`dirname \$dlpath`~
test -d \$dldir || mkdir -p \$dldir~
- $install_prog .libs/$dlname \$dldir/$dlname'
- postuninstall_cmds='dldll=`bash 2>&1 -c '\''. $file; echo \$dlname'\''`~
+ $install_prog $dir/$dlname \$dldir/$dlname~
+ chmod a+x \$dldir/$dlname'
+ postuninstall_cmds='dldll=`$SHELL 2>&1 -c '\''. $file; echo \$dlname'\''`~
dlpath=$dir/\$dldll~
$rm \$dlpath'
+ shlibpath_overrides_runpath=yes
+ case $host_os in
+ cygwin*)
+ # Cygwin DLLs use 'cyg' prefix rather than 'lib'
+ soname_spec='`echo ${libname} | sed -e 's/^lib/cyg/'``echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
+ sys_lib_search_path_spec="/usr/lib /lib/w32api /lib /usr/local/lib"
+ mingw*)
+ # MinGW DLLs use traditional 'lib' prefix
+ soname_spec='${libname}`echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
+ if echo "$sys_lib_search_path_spec" | grep ';[c-zC-Z]:/' >/dev/null; then
+ # It is most probably a Windows format PATH printed by
+ # mingw gcc, but we are running on Cygwin. Gcc prints its search
+ # path with ; separators, and with drive letters. We can handle the
+ # drive letters (cygwin fileutils understands them), so leave them,
+ # especially as we might pass files found there to a mingw objdump,
+ # which wouldn't understand a cygwinified path. Ahh.
+ else
+ fi
+ pw32*)
+ # pw32 DLLs use 'pw' prefix rather than 'lib'
+ library_names_spec='`echo ${libname} | sed -e 's/^lib/pw/'``echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
+ esac
- yes,mingw*)
- library_names_spec='${libname}`echo ${release} | sed -e 's/[.]/-/g'`${versuffix}.dll'
- sys_lib_search_path_spec=`$CC -print-search-dirs | grep "^libraries:" | sed -e "s/^libraries://" -e "s/;/ /g" -e "s,=/,/,g"`
- yes,pw32*)
- library_names_spec='`echo ${libname} | sed -e 's/^lib/pw/'``echo ${release} | sed -e 's/./-/g'`${versuffix}.dll'
- library_names_spec='${libname}`echo ${release} | sed -e 's/[.]/-/g'`${versuffix}.dll $libname.lib'
+ library_names_spec='${libname}`echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext} $libname.lib'
esac
dynamic_linker='Win32 ld.exe'
@@ -6595,30 +8028,65 @@
version_type=darwin
need_lib_prefix=no
need_version=no
- library_names_spec='${libname}${release}${versuffix}.$(test .$module = .yes && echo so || echo dylib) ${libname}${release}${major}.$(test .$module = .yes && echo so || echo dylib) ${libname}.$(test .$module = .yes && echo so || echo dylib)'
- soname_spec='${libname}${release}${major}.$(test .$module = .yes && echo so || echo dylib)'
+ library_names_spec='${libname}${release}${versuffix}$shared_ext ${libname}${release}${major}$shared_ext ${libname}$shared_ext'
+ soname_spec='${libname}${release}${major}$shared_ext'
shlibpath_var=DYLD_LIBRARY_PATH
+ shrext_cmds='`test .$module = .yes && echo .so || echo .dylib`'
+ # Apple's gcc prints 'gcc -print-search-dirs' doesn't operate the same.
+ sys_lib_search_path_spec=`$CC -print-search-dirs | tr "\n" "$PATH_SEPARATOR" | sed -e 's/libraries:/@libraries:/' | tr "@" "\n" | grep "^libraries:" | sed -e "s/^libraries://" -e "s,=/,/,g" -e "s,$PATH_SEPARATOR, ,g" -e "s,.*,& /lib /usr/lib /usr/local/lib,g"`
+ else
+ sys_lib_search_path_spec='/lib /usr/lib /usr/local/lib'
+ fi
+ sys_lib_dlsearch_path_spec='/usr/local/lib /lib /usr/lib'
+dgux*)
+ version_type=linux
+ need_lib_prefix=no
+ need_version=no
+ library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname$shared_ext'
+ shlibpath_var=LD_LIBRARY_PATH
freebsd1*)
dynamic_linker=no
-freebsd*)
- objformat=`test -x /usr/bin/objformat && /usr/bin/objformat || echo aout`
+kfreebsd*-gnu)
+ need_version=no
+ library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${shared_ext}'
+ shlibpath_overrides_runpath=no
+ hardcode_into_libs=yes
+ dynamic_linker='GNU ld.so'
+freebsd* | dragonfly*)
+ # DragonFly does not have aout. When/if they implement a new
+ # versioning mechanism, adjust this.
+ if test -x /usr/bin/objformat; then
+ objformat=`/usr/bin/objformat`
+ else
+ case $host_os in
+ freebsd[123]*) objformat=aout ;;
+ *) objformat=elf ;;
+ esac
+ fi
version_type=freebsd-$objformat
case $version_type in
freebsd-elf*)
- library_names_spec='${libname}${release}.so$versuffix ${libname}${release}.so $libname.so'
+ library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext} $libname${shared_ext}'
need_version=no
need_lib_prefix=no
freebsd-*)
- library_names_spec='${libname}${release}.so$versuffix $libname.so$versuffix'
+ library_names_spec='${libname}${release}${shared_ext}$versuffix $libname${shared_ext}$versuffix'
need_version=yes
esac
@@ -6627,10 +8095,19 @@
freebsd2*)
+ freebsd3.[01]* | freebsdelf3.[01]*)
+ freebsd3.[2-9]* | freebsdelf3.[2-9]* | \
+ freebsd4.[0-5] | freebsdelf4.[0-5] | freebsd4.1.1 | freebsdelf4.1.1)
+ freebsd*) # from 4.6 on
esac
@@ -6638,8 +8115,8 @@
version_type=linux
need_lib_prefix=no
need_version=no
- library_names_spec='${libname}${release}.so$versuffix ${libname}${release}.so${major} ${libname}.so'
+ library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}${major} ${libname}${shared_ext}'
@@ -6647,36 +8124,87 @@
hpux9* | hpux10* | hpux11*)
# Give a soname corresponding to the major version so that dld.sl refuses to
# link against other versions.
- dynamic_linker="$host_os dld.sl"
version_type=sunos
need_lib_prefix=no
need_version=no
- shlibpath_var=SHLIB_PATH
- shlibpath_overrides_runpath=no # +s is required to enable SHLIB_PATH
- library_names_spec='${libname}${release}.sl$versuffix ${libname}${release}.sl$major $libname.sl'
- soname_spec='${libname}${release}.sl$major'
+ case $host_cpu in
+ ia64*)
+ shrext_cmds='.so'
+ dynamic_linker="$host_os dld.so"
+ shlibpath_overrides_runpath=yes # Unless +noenvvar is specified.
+ if test "X$HPUX_IA64_MODE" = X32; then
+ sys_lib_search_path_spec="/usr/lib/hpux32 /usr/local/lib/hpux32 /usr/local/lib"
+ else
+ sys_lib_search_path_spec="/usr/lib/hpux64 /usr/local/lib/hpux64"
+ fi
+ sys_lib_dlsearch_path_spec=$sys_lib_search_path_spec
+ hppa*64*)
+ shrext_cmds='.sl'
+ dynamic_linker="$host_os dld.sl"
+ shlibpath_var=LD_LIBRARY_PATH # How should we handle SHLIB_PATH
+ sys_lib_search_path_spec="/usr/lib/pa20_64 /usr/ccs/lib/pa20_64"
+ shrext_cmds='.sl'
+ shlibpath_var=SHLIB_PATH
+ shlibpath_overrides_runpath=no # +s is required to enable SHLIB_PATH
+ esac
# HP-UX runs *really* slowly unless shared libraries are mode 555.
postinstall_cmds='chmod 555 $lib'
+interix3*)
+ need_version=no
+ dynamic_linker='Interix 3.x ld.so.1 (PE, like ELF)'
case $host_os in
nonstopux*) version_type=nonstopux ;;
- *) version_type=irix ;;
+ if test "$lt_cv_prog_gnu_ld" = yes; then
+ else
+ version_type=irix
+ fi ;;
esac
need_lib_prefix=no
need_version=no
- library_names_spec='${libname}${release}.so$versuffix ${libname}${release}.so$major ${libname}${release}.so $libname.so'
+ library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext} $libname${shared_ext}'
case $host_os in
irix5* | nonstopux*)
libsuff= shlibsuff=
case $LD in # libtool.m4 will add one of these switches to LD
- *-32|*"-32 ") libsuff= shlibsuff= libmagic=32-bit;;
- *-n32|*"-n32 ") libsuff=32 shlibsuff=N32 libmagic=N32;;
- *-64|*"-64 ") libsuff=64 shlibsuff=64 libmagic=64-bit;;
+ *-32|*"-32 "|*-melf32bsmip|*"-melf32bsmip ")
+ libsuff= shlibsuff= libmagic=32-bit;;
+ *-n32|*"-n32 "|*-melf32bmipn32|*"-melf32bmipn32 ")
+ libsuff=32 shlibsuff=N32 libmagic=N32;;
+ *-64|*"-64 "|*-melf64bmip|*"-melf64bmip ")
+ libsuff=64 shlibsuff=64 libmagic=64-bit;;
*) libsuff= shlibsuff= libmagic=never-match;;
esac
@@ -6685,20 +8213,21 @@
sys_lib_search_path_spec="/usr/lib${libsuff} /lib${libsuff} /usr/local/lib${libsuff}"
sys_lib_dlsearch_path_spec="/usr/lib${libsuff} /lib${libsuff}"
# No shared lib support for Linux oldld, aout, or coff.
-linux-gnuoldld* | linux-gnuaout* | linux-gnucoff*)
+linux*oldld* | linux*aout* | linux*coff*)
dynamic_linker=no
# This must be Linux ELF.
-linux-gnu*)
+linux*)
version_type=linux
need_lib_prefix=no
need_version=no
finish_cmds='PATH="\$PATH:/sbin" ldconfig -n $libdir'
@@ -6707,19 +8236,11 @@
# before this can be enabled.
- # We used to test for /lib/ld.so.1 and disable shared libraries on
- # powerpc, because MkLinux only supported shared libraries with the
- # GNU dynamic linker. Since this was broken with cross compilers,
- # most powerpc-linux boxes support dynamic linking these days and
- # people can always --disable-shared, the test was removed, and we
- # assume the GNU/Linux dynamic linker is in use.
- dynamic_linker='GNU/Linux ld.so'
- # Find out which ABI we are using (multilib Linux x86_64 hack).
+ # find out which ABI we are using
libsuff=
case "$host_cpu" in
- x86_64*|s390x*)
- echo '#line 6722 "configure"' > conftest.$ac_ext
+ x86_64*|s390x*|powerpc64*)
+ echo '#line 8243 "configure"' > conftest.$ac_ext
ac_status=$?
@@ -6728,29 +8249,52 @@
case `/usr/bin/file conftest.$ac_objext` in
*64-bit*)
libsuff=64
+ sys_lib_search_path_spec="/lib${libsuff} /usr/lib${libsuff} /usr/local/lib${libsuff}"
esac
fi
rm -rf conftest*
esac
- sys_lib_dlsearch_path_spec="/lib${libsuff} /usr/lib${libsuff}"
- sys_lib_search_path_spec="/lib${libsuff} /usr/lib${libsuff} /usr/local/lib${libsuff}"
+ # Append ld.so.conf contents to the search path
+ if test -f /etc/ld.so.conf; then
+ lt_ld_extra=`awk '/^include / { system(sprintf("cd /etc; cat %s", \$2)); skip = 1; } { if (!skip) print \$0; skip = 0; }' < /etc/ld.so.conf | $SED -e 's/#.*//;s/[:, ]/ /g;s/=[^=]*$//;s/=[^= ]* / /g;/^$/d' | tr '\n' ' '`
+ sys_lib_dlsearch_path_spec="/lib${libsuff} /usr/lib${libsuff} $lt_ld_extra"
+ fi
+ # We used to test for /lib/ld.so.1 and disable shared libraries on
+ # powerpc, because MkLinux only supported shared libraries with the
+ # GNU dynamic linker. Since this was broken with cross compilers,
+ # most powerpc-linux boxes support dynamic linking these days and
+ # people can always --disable-shared, the test was removed, and we
+ # assume the GNU/Linux dynamic linker is in use.
+ dynamic_linker='GNU/Linux ld.so'
+knetbsd*-gnu)
+ need_version=no
netbsd*)
version_type=sunos
need_lib_prefix=no
need_version=no
- library_names_spec='${libname}${release}.so$versuffix ${libname}.so$versuffix'
+ library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${shared_ext}$versuffix'
finish_cmds='PATH="\$PATH:/sbin" ldconfig -m $libdir'
dynamic_linker='NetBSD (a.out) ld.so'
else
- library_names_spec='${libname}${release}.so$versuffix ${libname}${release}.so$major ${libname}${release}.so ${libname}.so'
dynamic_linker='NetBSD ld.elf_so'
fi
@@ -6760,64 +8304,73 @@
newsos6)
version_type=linux
+nto-qnx*)
+ need_version=no
openbsd*)
version_type=sunos
+ sys_lib_dlsearch_path_spec="/usr/lib"
need_lib_prefix=no
- need_version=no
+ # Some older versions of OpenBSD (3.3 at least) *do* need versioned libs.
+ case $host_os in
+ openbsd3.3 | openbsd3.3.*) need_version=yes ;;
+ *) need_version=no ;;
+ esac
+ finish_cmds='PATH="\$PATH:/sbin" ldconfig -m $libdir'
- openbsd2.[89] | openbsd2.[89].*)
- shlibpath_overrides_runpath=yes
- esac
+ case $host_os in
+ openbsd2.[89] | openbsd2.[89].*)
+ esac
else
fi
- finish_cmds='PATH="\$PATH:/sbin" ldconfig -m $libdir'
- shlibpath_var=LD_LIBRARY_PATH
os2*)
libname_spec='$name'
need_lib_prefix=no
- library_names_spec='$libname.dll $libname.a'
+ library_names_spec='$libname${shared_ext} $libname.a'
dynamic_linker='OS/2 ld.exe'
osf3* | osf4* | osf5*)
version_type=osf
need_version=no
sys_lib_search_path_spec="/usr/shlib /usr/ccs/lib /usr/lib/cmplrs/cc /usr/lib /usr/local/lib /var/shlib"
sys_lib_dlsearch_path_spec="$sys_lib_search_path_spec"
-sco3.2v5*)
- version_type=osf
solaris*)
version_type=linux
need_lib_prefix=no
need_version=no
@@ -6827,7 +8380,7 @@
sunos4*)
version_type=sunos
finish_cmds='PATH="\$PATH:/usr/etc" ldconfig $libdir'
@@ -6837,10 +8390,10 @@
need_version=yes
-sysv4 | sysv4.2uw2* | sysv4.3* | sysv5*)
+sysv4 | sysv4.3*)
version_type=linux
sni)
@@ -6861,29 +8414,43 @@
esac
-uts4*)
- version_type=linux
+sysv4*MP*)
+ if test -d /usr/nec ;then
+ library_names_spec='$libname${shared_ext}.$versuffix $libname${shared_ext}.$major $libname${shared_ext}'
+ soname_spec='$libname${shared_ext}.$major'
+ fi
-dgux*)
+sysv5* | sco3.2v5* | sco5v6* | unixware* | OpenUNIX* | sysv4*uw2*)
+ version_type=freebsd-elf
need_lib_prefix=no
need_version=no
+ if test "$with_gnu_ld" = yes; then
+ sys_lib_search_path_spec='/usr/local/lib /usr/gnu/lib /usr/ccs/lib /usr/lib /lib'
+ else
+ sys_lib_search_path_spec='/usr/ccs/lib /usr/lib'
+ case $host_os in
+ sco3.2v5*)
+ sys_lib_search_path_spec="$sys_lib_search_path_spec /lib"
+ esac
+ fi
+ sys_lib_dlsearch_path_spec='/usr/lib'
-sysv4*MP*)
- if test -d /usr/nec ;then
- library_names_spec='$libname.so.$versuffix $libname.so.$major $libname.so'
- soname_spec='$libname.so.$major'
- fi
+uts4*)
@@ -6894,43 +8461,39 @@
echo "${ECHO_T}$dynamic_linker" >&6
test "$dynamic_linker" = no && can_build_shared=no
-# Report the final consequences.
-echo "$as_me:$LINENO: checking if libtool supports shared libraries" >&5
-echo $ECHO_N "checking if libtool supports shared libraries... $ECHO_C" >&6
-echo "$as_me:$LINENO: result: $can_build_shared" >&5
-echo "${ECHO_T}$can_build_shared" >&6
+variables_saved_for_relink="PATH $shlibpath_var $runpath_var"
+ variables_saved_for_relink="$variables_saved_for_relink GCC_EXEC_PREFIX COMPILER_PATH LIBRARY_PATH"
+fi
-echo "$as_me:$LINENO: checking whether to build shared libraries" >&5
-echo $ECHO_N "checking whether to build shared libraries... $ECHO_C" >&6
-test "$can_build_shared" = "no" && enable_shared=no
+echo "$as_me:$LINENO: checking how to hardcode library paths into programs" >&5
+echo $ECHO_N "checking how to hardcode library paths into programs... $ECHO_C" >&6
+hardcode_action=
+if test -n "$hardcode_libdir_flag_spec" || \
+ test -n "$runpath_var" || \
+ test "X$hardcode_automatic" = "Xyes" ; then
-# On AIX, shared libraries and static libraries use the same namespace, and
-# are all built from PIC.
-case "$host_os" in
-aix3*)
- test "$enable_shared" = yes && enable_static=no
- if test -n "$RANLIB"; then
- archive_cmds="$archive_cmds~\$RANLIB \$lib"
- postinstall_cmds='$RANLIB $lib'
+ # We can hardcode non-existant directories.
+ if test "$hardcode_direct" != no &&
+ # If the only mechanism to avoid hardcoding is shlibpath_var, we
+ # have to relink, otherwise we might link with an installed library
+ # when we should be linking with a yet-to-be-installed one
+ ## test "$_LT_AC_TAGVAR(hardcode_shlibpath_var, )" != no &&
+ test "$hardcode_minus_L" != no; then
+ # Linking always hardcodes the temporary library directory.
+ hardcode_action=relink
+ else
+ # We can link without hardcoding, and we can hardcode nonexisting dirs.
+ hardcode_action=immediate
fi
+else
+ # We cannot hardcode anything, or else we can only hardcode existing
+ # directories.
+ hardcode_action=unsupported
+fi
+echo "$as_me:$LINENO: result: $hardcode_action" >&5
+echo "${ECHO_T}$hardcode_action" >&6
-aix4*)
- if test "$host_cpu" != ia64 && test "$aix_use_runtimelinking" = no ; then
- fi
-esac
-echo "$as_me:$LINENO: result: $enable_shared" >&5
-echo "${ECHO_T}$enable_shared" >&6
-echo "$as_me:$LINENO: checking whether to build static libraries" >&5
-echo $ECHO_N "checking whether to build static libraries... $ECHO_C" >&6
-# Make sure either enable_shared or enable_static is yes.
-test "$enable_shared" = yes || enable_static=yes
-echo "$as_me:$LINENO: result: $enable_static" >&5
-echo "${ECHO_T}$enable_static" >&6
if test "$hardcode_action" = relink; then
# Fast installation is not supported
enable_fast_install=no
@@ -6940,10 +8503,34 @@
enable_fast_install=needless
fi
-variables_saved_for_relink="PATH $shlibpath_var $runpath_var"
-if test "$GCC" = yes; then
- variables_saved_for_relink="$variables_saved_for_relink GCC_EXEC_PREFIX COMPILER_PATH LIBRARY_PATH"
+striplib=
+old_striplib=
+echo "$as_me:$LINENO: checking whether stripping libraries is possible" >&5
+echo $ECHO_N "checking whether stripping libraries is possible... $ECHO_C" >&6
+if test -n "$STRIP" && $STRIP -V 2>&1 | grep "GNU strip" >/dev/null; then
+ test -z "$old_striplib" && old_striplib="$STRIP --strip-debug"
+ test -z "$striplib" && striplib="$STRIP --strip-unneeded"
+ echo "$as_me:$LINENO: result: yes" >&5
+echo "${ECHO_T}yes" >&6
+else
+# FIXME - insert some real tests, host_os isn't really good enough
+ case $host_os in
+ darwin*)
+ if test -n "$STRIP" ; then
+ striplib="$STRIP -x"
+ else
+ echo "$as_me:$LINENO: result: no" >&5
+echo "${ECHO_T}no" >&6
fi
+ esac
+fi
if test "x$enable_dlopen" != xyes; then
enable_dlopen=unknown
@@ -6960,11 +8547,94 @@
lt_cv_dlopen_self=yes
+ mingw* | pw32*)
lt_cv_dlopen="LoadLibrary"
lt_cv_dlopen_libs=
+ cygwin*)
+ lt_cv_dlopen="dlopen"
+ lt_cv_dlopen_libs=
+ darwin*)
+ # if libdl is installed we need to link against it
+ echo "$as_me:$LINENO: checking for dlopen in -ldl" >&5
+echo $ECHO_N "checking for dlopen in -ldl... $ECHO_C" >&6
+if test "${ac_cv_lib_dl_dlopen+set}" = set; then
+ echo $ECHO_N "(cached) $ECHO_C" >&6
+else
+ ac_check_lib_save_LIBS=$LIBS
+LIBS="-ldl $LIBS"
+cat >conftest.$ac_ext <<_ACEOF
+/* confdefs.h. */
+_ACEOF
+cat confdefs.h >>conftest.$ac_ext
+cat >>conftest.$ac_ext <<_ACEOF
+/* end confdefs.h. */
+/* Override any gcc2 internal prototype to avoid an error. */
+#ifdef __cplusplus
+extern "C"
+#endif
+/* We use char because int might match the return type of a gcc2
+ builtin and then its argument prototype would still apply. */
+char dlopen ();
+int
+main ()
+dlopen ();
+ return 0;
+_ACEOF
+rm -f conftest.$ac_objext conftest$ac_exeext
+if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
+ (eval $ac_link) 2>conftest.er1
+ ac_status=$?
+ grep -v '^ *+' conftest.er1 >conftest.err
+ rm -f conftest.er1
+ cat conftest.err >&5
+ (exit $ac_status); } &&
+ { ac_try='test -z "$ac_c_werror_flag"
+ || test ! -s conftest.err'
+ { (eval echo "$as_me:$LINENO: \"$ac_try\"") >&5
+ (eval $ac_try) 2>&5
+ ac_status=$?
+ (exit $ac_status); }; } &&
+ { ac_try='test -s conftest$ac_exeext'
+ ac_status=$?
+ (exit $ac_status); }; }; then
+ ac_cv_lib_dl_dlopen=yes
+else
+ echo "$as_me: failed program was:" >&5
+sed 's/^/| /' conftest.$ac_ext >&5
+ac_cv_lib_dl_dlopen=no
+fi
+rm -f conftest.err conftest.$ac_objext \
+ conftest$ac_exeext conftest.$ac_ext
+LIBS=$ac_check_lib_save_LIBS
+fi
+echo "$as_me:$LINENO: result: $ac_cv_lib_dl_dlopen" >&5
+echo "${ECHO_T}$ac_cv_lib_dl_dlopen" >&6
+if test $ac_cv_lib_dl_dlopen = yes; then
+ lt_cv_dlopen="dlopen" lt_cv_dlopen_libs="-ldl"
+else
+ lt_cv_dlopen="dyld"
+ lt_cv_dlopen_self=yes
+fi
echo "$as_me:$LINENO: checking for shl_load" >&5
echo $ECHO_N "checking for shl_load... $ECHO_C" >&6
@@ -6972,21 +8642,28 @@
else
-#line $LINENO "configure"
/* confdefs.h. */
_ACEOF
+/* Define shl_load to an innocuous variant, in case <limits.h> declares shl_load.
+ For example, HP-UX 11i <limits.h> declares gettimeofday. */
+#define shl_load innocuous_shl_load
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char shl_load (); below.
Prefer <limits.h> to <assert.h> if __STDC__ is defined, since
<limits.h> exists even on freestanding compilers. */
#ifdef __STDC__
# include <limits.h>
#else
# include <assert.h>
#endif
+#undef shl_load
#ifdef __cplusplus
extern "C"
@@ -7017,15 +8694,25 @@
_ACEOF
- (eval $ac_link) 2>&5
ac_status=$?
- { ac_try='test -s conftest$ac_exeext'
(eval $ac_try) 2>&5
ac_status=$?
+ ac_status=$?
ac_cv_func_shl_load=yes
else
@@ -7034,7 +8721,8 @@
ac_cv_func_shl_load=no
fi
-rm -f conftest.$ac_objext conftest$ac_exeext conftest.$ac_ext
fi
echo "$as_me:$LINENO: result: $ac_cv_func_shl_load" >&5
echo "${ECHO_T}$ac_cv_func_shl_load" >&6
@@ -7049,7 +8737,6 @@
LIBS="-ldld $LIBS"
/* confdefs.h. */
_ACEOF
@@ -7073,15 +8760,25 @@
_ACEOF
ac_status=$?
(eval $ac_try) 2>&5
ac_status=$?
+ ac_status=$?
ac_cv_lib_dld_shl_load=yes
else
@@ -7090,7 +8787,8 @@
ac_cv_lib_dld_shl_load=no
fi
fi
echo "$as_me:$LINENO: result: $ac_cv_lib_dld_shl_load" >&5
@@ -7104,21 +8802,28 @@
else
/* confdefs.h. */
_ACEOF
+/* Define dlopen to an innocuous variant, in case <limits.h> declares dlopen.
+#define dlopen innocuous_dlopen
which can conflict with char dlopen (); below.
#ifdef __STDC__
#else
#endif
+#undef dlopen
#ifdef __cplusplus
extern "C"
@@ -7149,15 +8854,25 @@
_ACEOF
ac_status=$?
(eval $ac_try) 2>&5
ac_status=$?
+ ac_status=$?
ac_cv_func_dlopen=yes
else
@@ -7166,7 +8881,8 @@
ac_cv_func_dlopen=no
fi
fi
echo "$as_me:$LINENO: result: $ac_cv_func_dlopen" >&5
echo "${ECHO_T}$ac_cv_func_dlopen" >&6
@@ -7181,7 +8897,6 @@
LIBS="-ldl $LIBS"
/* confdefs.h. */
_ACEOF
@@ -7205,15 +8920,25 @@
_ACEOF
ac_status=$?
(eval $ac_try) 2>&5
ac_status=$?
+ ac_status=$?
else
@@ -7222,7 +8947,8 @@
fi
fi
@@ -7238,7 +8964,6 @@
LIBS="-lsvld $LIBS"
/* confdefs.h. */
_ACEOF
@@ -7262,15 +8987,25 @@
_ACEOF
ac_status=$?
(eval $ac_try) 2>&5
ac_status=$?
+ ac_status=$?
ac_cv_lib_svld_dlopen=yes
else
@@ -7279,7 +9014,8 @@
ac_cv_lib_svld_dlopen=no
fi
fi
echo "$as_me:$LINENO: result: $ac_cv_lib_svld_dlopen" >&5
@@ -7295,7 +9031,6 @@
LIBS="-ldld $LIBS"
/* confdefs.h. */
_ACEOF
@@ -7319,15 +9054,25 @@
_ACEOF
ac_status=$?
(eval $ac_try) 2>&5
ac_status=$?
+ ac_status=$?
ac_cv_lib_dld_dld_link=yes
else
@@ -7336,7 +9081,8 @@
ac_cv_lib_dld_dld_link=no
fi
fi
echo "$as_me:$LINENO: result: $ac_cv_lib_dld_dld_link" >&5
@@ -7372,10 +9118,10 @@
case $lt_cv_dlopen in
dlopen)
save_CPPFLAGS="$CPPFLAGS"
- test "x$ac_cv_header_dlfcn_h" = xyes && CPPFLAGS="$CPPFLAGS -DHAVE_DLFCN_H"
+ test "x$ac_cv_header_dlfcn_h" = xyes && CPPFLAGS="$CPPFLAGS -DHAVE_DLFCN_H"
save_LDFLAGS="$LDFLAGS"
- eval LDFLAGS=\"\$LDFLAGS $export_dynamic_flag_spec\"
+ wl=$lt_prog_compiler_wl eval LDFLAGS=\"\$LDFLAGS $export_dynamic_flag_spec\"
save_LIBS="$LIBS"
LIBS="$lt_cv_dlopen_libs $LIBS"
@@ -7388,10 +9134,10 @@
if test "$cross_compiling" = yes; then :
lt_cv_dlopen_self=cross
else
- lt_dlunknown=0; lt_dlno_uscore=1; lt_dlneed_uscore=2
+ lt_dlunknown=0; lt_dlno_uscore=1; lt_dlneed_uscore=2
lt_status=$lt_dlunknown
cat > conftest.$ac_ext <<EOF
-#line 7394 "configure"
+#line 9140 "configure"
#include "confdefs.h"
#if HAVE_DLFCN_H
@@ -7448,6 +9194,8 @@
else if (dlsym( self,"_fnord")) status = $lt_dlneed_uscore;
/* dlclose (self); */
+ else
+ puts (dlerror ());
exit (status);
@@ -7457,12 +9205,12 @@
ac_status=$?
(exit $ac_status); } && test -s conftest${ac_exeext} 2>/dev/null; then
- (./conftest; exit; ) 2>/dev/null
+ (./conftest; exit; ) >&5 2>/dev/null
lt_status=$?
case x$lt_status in
x$lt_dlno_uscore) lt_cv_dlopen_self=yes ;;
x$lt_dlneed_uscore) lt_cv_dlopen_self=yes ;;
- x$lt_unknown|x*) lt_cv_dlopen_self=no ;;
+ x$lt_dlunknown|x*) lt_cv_dlopen_self=no ;;
esac
else :
# compilation failed
@@ -7477,7 +9225,7 @@
echo "${ECHO_T}$lt_cv_dlopen_self" >&6
if test "x$lt_cv_dlopen_self" = xyes; then
- LDFLAGS="$LDFLAGS $link_static_flag"
+ wl=$lt_prog_compiler_wl eval LDFLAGS=\"\$LDFLAGS $lt_prog_compiler_static\"
echo "$as_me:$LINENO: checking whether a statically linked program can dlopen itself" >&5
echo $ECHO_N "checking whether a statically linked program can dlopen itself... $ECHO_C" >&6
if test "${lt_cv_dlopen_self_static+set}" = set; then
@@ -7486,10 +9234,10 @@
lt_cv_dlopen_self_static=cross
else
-#line 7492 "configure"
+#line 9240 "configure"
#if HAVE_DLFCN_H
@@ -7546,6 +9294,8 @@
+ else
exit (status);
@@ -7555,12 +9305,12 @@
ac_status=$?
lt_status=$?
case x$lt_status in
x$lt_dlno_uscore) lt_cv_dlopen_self_static=yes ;;
x$lt_dlneed_uscore) lt_cv_dlopen_self_static=yes ;;
- x$lt_unknown|x*) lt_cv_dlopen_self_static=no ;;
+ x$lt_dlunknown|x*) lt_cv_dlopen_self_static=no ;;
esac
else :
@@ -7593,109 +9343,114 @@
fi
-if test "$enable_shared" = yes && test "$GCC" = yes; then
- case $archive_cmds in
- # FIXME: we may have to deal with multi-command sequences.
- '$CC '*)
- # Test whether the compiler implicitly links with -lc since on some
- # systems, -lgcc has to come before -lc. If gcc already passes -lc
- # to ld, don't add -lc before -lgcc.
- echo "$as_me:$LINENO: checking whether -lc should be explicitly linked in" >&5
-echo $ECHO_N "checking whether -lc should be explicitly linked in... $ECHO_C" >&6
- if test "${lt_cv_archive_cmds_need_lc+set}" = set; then
- echo $ECHO_N "(cached) $ECHO_C" >&6
-else
- $rm conftest*
- echo 'static int dummy;' > conftest.$ac_ext
+# Report which library types will actually be built
+echo "$as_me:$LINENO: checking if libtool supports shared libraries" >&5
+echo $ECHO_N "checking if libtool supports shared libraries... $ECHO_C" >&6
+echo "$as_me:$LINENO: result: $can_build_shared" >&5
+echo "${ECHO_T}$can_build_shared" >&6
- if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
- (eval $ac_compile) 2>&5
- ac_status=$?
- echo "$as_me:$LINENO: \$? = $ac_status" >&5
- (exit $ac_status); }; then
- soname=conftest
- lib=conftest
- libobjs=conftest.$ac_objext
- deplibs=
- wl=$lt_cv_prog_cc_wl
- compiler_flags=-v
- linker_flags=-v
- verstring=
- output_objdir=.
- libname=conftest
- save_allow_undefined_flag=$allow_undefined_flag
- if { (eval echo "$as_me:$LINENO: \"$archive_cmds 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1\"") >&5
- (eval $archive_cmds 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1) 2>&5
- ac_status=$?
- then
- lt_cv_archive_cmds_need_lc=no
- else
- lt_cv_archive_cmds_need_lc=yes
- fi
- allow_undefined_flag=$save_allow_undefined_flag
- else
- cat conftest.err 1>&5
- fi
-fi
+echo "$as_me:$LINENO: checking whether to build shared libraries" >&5
+echo $ECHO_N "checking whether to build shared libraries... $ECHO_C" >&6
+test "$can_build_shared" = "no" && enable_shared=no
- echo "$as_me:$LINENO: result: $lt_cv_archive_cmds_need_lc" >&5
-echo "${ECHO_T}$lt_cv_archive_cmds_need_lc" >&6
+# On AIX, shared libraries and static libraries use the same namespace, and
+# are all built from PIC.
+case $host_os in
+aix3*)
+ test "$enable_shared" = yes && enable_static=no
+ if test -n "$RANLIB"; then
+ archive_cmds="$archive_cmds~\$RANLIB \$lib"
+ postinstall_cmds='$RANLIB $lib'
+ fi
+aix4* | aix5*)
+ if test "$host_cpu" != ia64 && test "$aix_use_runtimelinking" = no ; then
+ fi
- esac
-fi
-need_lc=${lt_cv_archive_cmds_need_lc-yes}
+esac
+echo "$as_me:$LINENO: result: $enable_shared" >&5
+echo "${ECHO_T}$enable_shared" >&6
-# The second clause should only fire when bootstrapping the
+echo "$as_me:$LINENO: checking whether to build static libraries" >&5
+echo $ECHO_N "checking whether to build static libraries... $ECHO_C" >&6
+# Make sure either enable_shared or enable_static is yes.
+test "$enable_shared" = yes || enable_static=yes
+echo "$as_me:$LINENO: result: $enable_static" >&5
+echo "${ECHO_T}$enable_static" >&6
+# The else clause should only fire when bootstrapping the
# libtool distribution, otherwise you forgot to ship ltmain.sh
# with your package, and you will get complaints that there are
# no rules to generate ltmain.sh.
if test -f "$ltmain"; then
-else
- # If there is no Makefile yet, we rely on a make rule to execute
- # `config.status --recheck' to rerun these tests and create the
- # libtool script then.
- test -f Makefile && make "$ltmain"
-fi
-if test -f "$ltmain"; then
- trap "$rm \"${ofile}T\"; exit 1" 1 2 15
- $rm -f "${ofile}T"
- echo creating $ofile
+ # See if we are running on zsh, and set the options which allow our commands through
+ # without removal of \ escapes.
+ if test -n "${ZSH_VERSION+set}" ; then
+ setopt NO_GLOB_SUBST
+ fi
# Now quote all the things that may contain metacharacters while being
# careful not to overquote the AC_SUBSTed values. We take copies of the
# variables and quote the copies for generation of the libtool script.
- for var in echo old_CC old_CFLAGS SED \
- AR AR_FLAGS CC LD LN_S NM SHELL \
- reload_flag reload_cmds wl \
- pic_flag link_static_flag no_builtin_flag export_dynamic_flag_spec \
- thread_safe_flag_spec whole_archive_flag_spec libname_spec \
- library_names_spec soname_spec \
- RANLIB old_archive_cmds old_archive_from_new_cmds old_postinstall_cmds \
- old_postuninstall_cmds archive_cmds archive_expsym_cmds postinstall_cmds \
- postuninstall_cmds extract_expsyms_cmds old_archive_from_expsyms_cmds \
- old_striplib striplib file_magic_cmd export_symbols_cmds \
- deplibs_check_method allow_undefined_flag no_undefined_flag \
- finish_cmds finish_eval global_symbol_pipe global_symbol_to_cdecl \
- global_symbol_to_c_name_address \
- hardcode_libdir_flag_spec hardcode_libdir_separator \
+ for var in echo old_CC old_CFLAGS AR AR_FLAGS EGREP RANLIB LN_S LTCC LTCFLAGS NM \
+ SED SHELL STRIP \
+ libname_spec library_names_spec soname_spec extract_expsyms_cmds \
+ old_striplib striplib file_magic_cmd finish_cmds finish_eval \
+ deplibs_check_method reload_flag reload_cmds need_locks \
+ lt_cv_sys_global_symbol_pipe lt_cv_sys_global_symbol_to_cdecl \
+ lt_cv_sys_global_symbol_to_c_name_address \
sys_lib_search_path_spec sys_lib_dlsearch_path_spec \
- compiler_c_o compiler_o_lo need_locks exclude_expsyms include_expsyms; do
+ old_postinstall_cmds old_postuninstall_cmds \
+ compiler \
+ CC \
+ LD \
+ lt_prog_compiler_wl \
+ lt_prog_compiler_pic \
+ lt_prog_compiler_static \
+ lt_prog_compiler_no_builtin_flag \
+ export_dynamic_flag_spec \
+ thread_safe_flag_spec \
+ whole_archive_flag_spec \
+ enable_shared_with_static_runtimes \
+ old_archive_cmds \
+ old_archive_from_new_cmds \
+ predep_objects \
+ postdep_objects \
+ predeps \
+ postdeps \
+ compiler_lib_search_path \
+ archive_cmds \
+ archive_expsym_cmds \
+ postinstall_cmds \
+ postuninstall_cmds \
+ old_archive_from_expsyms_cmds \
+ allow_undefined_flag \
+ no_undefined_flag \
+ export_symbols_cmds \
+ hardcode_libdir_flag_spec \
+ hardcode_libdir_flag_spec_ld \
+ hardcode_libdir_separator \
+ hardcode_automatic \
+ module_cmds \
+ module_expsym_cmds \
+ lt_cv_prog_compiler_c_o \
+ exclude_expsyms \
+ include_expsyms; do
case $var in
- reload_cmds | old_archive_cmds | old_archive_from_new_cmds | \
+ old_archive_cmds | \
+ old_archive_from_new_cmds | \
+ archive_cmds | \
+ archive_expsym_cmds | \
+ module_cmds | \
+ module_expsym_cmds | \
+ old_archive_from_expsyms_cmds | \
+ export_symbols_cmds | \
+ extract_expsyms_cmds | reload_cmds | finish_cmds | \
+ postinstall_cmds | postuninstall_cmds | \
old_postinstall_cmds | old_postuninstall_cmds | \
- export_symbols_cmds | archive_cmds | archive_expsym_cmds | \
- extract_expsyms_cmds | old_archive_from_expsyms_cmds | \
- postinstall_cmds | postuninstall_cmds | \
- finish_cmds | sys_lib_search_path_spec | sys_lib_dlsearch_path_spec)
+ sys_lib_search_path_spec | sys_lib_dlsearch_path_spec)
# Double-quote double-evaled strings.
eval "lt_$var=\\\"\`\$echo \"X\$$var\" | \$Xsed -e \"\$double_quote_subst\" -e \"\$sed_quote_subst\" -e \"\$delay_variable_subst\"\`\\\""
@@ -7705,14 +9460,29 @@
esac
done
- cat <<__EOF__ > "${ofile}T"
+ case $lt_echo in
+ *'\$0 --fallback-echo"')
+ lt_echo=`$echo "X$lt_echo" | $Xsed -e 's/\\\\\\\$0 --fallback-echo"$/$0 --fallback-echo"/'`
+ esac
+cfgfile="${ofile}T"
+ trap "$rm \"$cfgfile\"; exit 1" 1 2 15
+ $rm -f "$cfgfile"
+ { echo "$as_me:$LINENO: creating $ofile" >&5
+echo "$as_me: creating $ofile" >&6;}
+ cat <<__EOF__ >> "$cfgfile"
#! $SHELL
-# `$echo "$ofile" | sed 's%^.*/%%'` - Provide generalized library-building support services.
+# `$echo "$cfgfile" | sed 's%^.*/%%'` - Provide generalized library-building support services.
# Generated automatically by $PROGRAM (GNU $PACKAGE $VERSION$TIMESTAMP)
# NOTE: Changes made to this file will be lost: look at ltmain.sh.
-# Copyright (C) 1996-2000 Free Software Foundation, Inc.
+# Copyright (C) 1996, 1997, 1998, 1999, 2000, 2001
+# Free Software Foundation, Inc.
+# This file is part of GNU Libtool:
# Originally by Gordon Matzigkeit <gord at gnu.ai.mit.edu>, 1996
# This program is free software; you can redistribute it and/or modify
@@ -7727,23 +9497,26 @@
# You should have received a copy of the GNU General Public License
# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+# Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301, USA.
# As a special exception to the GNU General Public License, if you
# distribute this file as part of a program that contains a
# configuration script generated by Autoconf, you may include it under
# the same distribution terms that you use for the rest of that program.
-# A sed that does not truncate output.
+# A sed program that does not truncate output.
SED=$lt_SED
# Sed that helps us avoid accidentally triggering echo(1) options like -n.
-Xsed="${SED} -e s/^X//"
+Xsed="$SED -e 1s/^X//"
# The HP-UX ksh and POSIX shell print the target directory to stdout
# if CDPATH is set.
-if test "X\${CDPATH+set}" = Xset; then CDPATH=:; export CDPATH; fi
+(unset CDPATH) >/dev/null 2>&1 && unset CDPATH
+# The names of the tagged configurations supported by this script.
+available_tags=
# ### BEGIN LIBTOOL CONFIG
# Libtool was configured on host `(hostname || uname -n) 2>/dev/null | sed 1q`:
@@ -7758,15 +9531,24 @@
build_old_libs=$enable_static
# Whether or not to add -lc for building shared libraries.
-build_libtool_need_lc=$need_lc
+build_libtool_need_lc=$archive_cmds_need_lc
+# Whether or not to disallow shared libs when runtime libs are static
+allow_libtool_libs_with_static_runtimes=$enable_shared_with_static_runtimes
# Whether or not to optimize for fast installation.
fast_install=$enable_fast_install
# The host system.
host_alias=$host_alias
host=$host
+host_os=$host_os
+# The build system.
+build_alias=$build_alias
+build=$build
+build_os=$build_os
# An echo program that does not interpret backslashes.
echo=$lt_echo
@@ -7774,12 +9556,21 @@
AR=$lt_AR
AR_FLAGS=$lt_AR_FLAGS
-# The default C compiler.
-CC=$lt_CC
+# A C compiler.
+LTCC=$lt_LTCC
+# LTCC compiler flags.
+LTCFLAGS=$lt_LTCFLAGS
+# A language-specific compiler.
+CC=$lt_compiler
# Is the compiler the GNU C compiler?
with_gcc=$GCC
+# An ERE matcher.
+EGREP=$lt_EGREP
# The linker used to build libraries.
LD=$lt_LD
@@ -7790,7 +9581,7 @@
NM=$lt_NM
# A symbol stripping program
-STRIP=$STRIP
+STRIP=$lt_STRIP
# Used to examine libraries when file_magic_cmd begins "file"
MAGIC_CMD=$MAGIC_CMD
@@ -7812,7 +9603,7 @@
reload_cmds=$lt_reload_cmds
# How to pass a linker flag through the compiler.
-wl=$lt_wl
+wl=$lt_lt_prog_compiler_wl
# Object file suffix (normally "o").
objext="$ac_objext"
@@ -7820,20 +9611,23 @@
# Old archive suffix (normally "a").
libext="$libext"
+# Shared library suffix (normally ".so").
+shrext_cmds='$shrext_cmds'
# Executable file suffix (normally "").
exeext="$exeext"
# Additional compiler flags for building library objects.
-pic_flag=$lt_pic_flag
+pic_flag=$lt_lt_prog_compiler_pic
pic_mode=$pic_mode
+# What is the maximum length of a command?
+max_cmd_len=$lt_cv_sys_max_cmd_len
# Does compiler simultaneously support -c and -o options?
-compiler_c_o=$lt_compiler_c_o
+compiler_c_o=$lt_lt_cv_prog_compiler_c_o
-# Can we write directly to a .lo ?
-compiler_o_lo=$lt_compiler_o_lo
-# Must we lock files when doing compilation ?
+# Must we lock files when doing compilation?
need_locks=$lt_need_locks
# Do we need the lib prefix for modules?
@@ -7852,10 +9646,10 @@
dlopen_self_static=$enable_dlopen_self_static
# Compiler flag to prevent dynamic linking.
-link_static_flag=$lt_link_static_flag
+link_static_flag=$lt_lt_prog_compiler_static
# Compiler flag to turn off builtin functions.
-no_builtin_flag=$lt_no_builtin_flag
+no_builtin_flag=$lt_lt_prog_compiler_no_builtin_flag
# Compiler flag to allow reflexive dlopens.
export_dynamic_flag_spec=$lt_export_dynamic_flag_spec
@@ -7897,10 +9691,34 @@
postinstall_cmds=$lt_postinstall_cmds
postuninstall_cmds=$lt_postuninstall_cmds
+# Commands used to build a loadable module (assumed same as above if empty)
+module_cmds=$lt_module_cmds
+module_expsym_cmds=$lt_module_expsym_cmds
# Commands to strip libraries.
old_striplib=$lt_old_striplib
striplib=$lt_striplib
+# Dependencies to place before the objects being linked to create a
+# shared library.
+predep_objects=$lt_predep_objects
+# Dependencies to place after the objects being linked to create a
+# shared library.
+postdep_objects=$lt_postdep_objects
+# shared library.
+predeps=$lt_predeps
+# shared library.
+postdeps=$lt_postdeps
+# The library search path used internally by the compiler when linking
+# a shared library.
+compiler_lib_search_path=$lt_compiler_lib_search_path
# Method to check whether dependent libraries are shared objects.
deplibs_check_method=$lt_deplibs_check_method
@@ -7920,13 +9738,13 @@
finish_eval=$lt_finish_eval
# Take the output of nm and produce a listing of raw symbols and C names.
-global_symbol_pipe=$lt_global_symbol_pipe
+global_symbol_pipe=$lt_lt_cv_sys_global_symbol_pipe
# Transform the output of nm in a proper C declaration
-global_symbol_to_cdecl=$lt_global_symbol_to_cdecl
+global_symbol_to_cdecl=$lt_lt_cv_sys_global_symbol_to_cdecl
# Transform the output of nm in a C name address pair
-global_symbol_to_c_name_address=$lt_global_symbol_to_c_name_address
+global_symbol_to_c_name_address=$lt_lt_cv_sys_global_symbol_to_c_name_address
# This is the shared library runtime path variable.
runpath_var=$runpath_var
@@ -7947,10 +9765,15 @@
# This must work even if \$libdir does not exist.
hardcode_libdir_flag_spec=$lt_hardcode_libdir_flag_spec
+# If ld is used when linking, flag to hardcode \$libdir into
+# a binary during linking. This must work even if \$libdir does
+# not exist.
+hardcode_libdir_flag_spec_ld=$lt_hardcode_libdir_flag_spec_ld
# Whether we need a single -rpath flag with a separated argument.
hardcode_libdir_separator=$lt_hardcode_libdir_separator
-# Set to yes if using DIR/libNAME.so during linking hardcodes DIR into the
+# Set to yes if using DIR/libNAME${shared_ext} during linking hardcodes DIR into the
# resulting binary.
hardcode_direct=$hardcode_direct
@@ -7962,6 +9785,10 @@
# the resulting binary.
hardcode_shlibpath_var=$hardcode_shlibpath_var
+# Set to yes if building a shared library automatically hardcodes DIR into the library
+# and all subsequent libraries and executables linked against it.
+hardcode_automatic=$hardcode_automatic
# Variables whose values should be saved in libtool wrapper scripts and
# restored at relink time.
variables_saved_for_relink="$variables_saved_for_relink"
@@ -7997,9 +9824,10 @@
__EOF__
case $host_os in
aix3*)
- cat <<\EOF >> "${ofile}T"
+ cat <<\EOF >> "$cfgfile"
# AIX sometimes has problems with the GCC collect2 program. For some
# reason, if we set the COLLECT_NAMES environment variable, the problems
@@ -8012,201 +9840,8799 @@
esac
- case $host_os in
- cygwin* | mingw* | pw32* | os2*)
- cat <<'EOF' >> "${ofile}T"
- # This is a source program that is used to create dlls on Windows
- # Don't remove nor modify the starting and closing comments
-# /* ltdll.c starts here */
-# #define WIN32_LEAN_AND_MEAN
-# #include <windows.h>
-# #undef WIN32_LEAN_AND_MEAN
-# #include <stdio.h>
+ # We use sed instead of cat because bash on DJGPP gets confused if
+ # if finds mixed CR/LF and LF-only lines. Since sed operates in
+ # text mode, it properly converts lines to CR/LF. This bash problem
+ # is reportedly fixed, but why not run on old versions too?
+ sed '$q' "$ltmain" >> "$cfgfile" || (rm -f "$cfgfile"; exit 1)
+ mv -f "$cfgfile" "$ofile" || \
+ (rm -f "$ofile" && cp "$cfgfile" "$ofile" && rm -f "$cfgfile")
+ chmod +x "$ofile"
+else
+ # If there is no Makefile yet, we rely on a make rule to execute
+ # `config.status --recheck' to rerun these tests and create the
+ # libtool script then.
+ ltmain_in=`echo $ltmain | sed -e 's/\.sh$/.in/'`
+ if test -f "$ltmain_in"; then
+ test -f Makefile && make "$ltmain"
+ fi
+fi
+ac_ext=cc
+ac_cpp='$CXXCPP $CPPFLAGS'
+ac_compile='$CXX -c $CXXFLAGS $CPPFLAGS conftest.$ac_ext >&5'
+ac_link='$CXX -o conftest$ac_exeext $CXXFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
+ac_compiler_gnu=$ac_cv_cxx_compiler_gnu
+CC="$lt_save_CC"
+# Check whether --with-tags or --without-tags was given.
+if test "${with_tags+set}" = set; then
+ withval="$with_tags"
+ tagnames="$withval"
+fi;
+if test -f "$ltmain" && test -n "$tagnames"; then
+ if test ! -f "${ofile}"; then
+ { echo "$as_me:$LINENO: WARNING: output file \`$ofile' does not exist" >&5
+echo "$as_me: WARNING: output file \`$ofile' does not exist" >&2;}
+ fi
+ if test -z "$LTCC"; then
+ eval "`$SHELL ${ofile} --config | grep '^LTCC='`"
+ { echo "$as_me:$LINENO: WARNING: output file \`$ofile' does not look like a libtool script" >&5
+echo "$as_me: WARNING: output file \`$ofile' does not look like a libtool script" >&2;}
+ else
+ { echo "$as_me:$LINENO: WARNING: using \`LTCC=$LTCC', extracted from \`$ofile'" >&5
+echo "$as_me: WARNING: using \`LTCC=$LTCC', extracted from \`$ofile'" >&2;}
+ fi
+ fi
+ if test -z "$LTCFLAGS"; then
+ eval "`$SHELL ${ofile} --config | grep '^LTCFLAGS='`"
+ fi
+ # Extract list of available tagged configurations in $ofile.
+ # Note that this assumes the entire list is on one line.
+ available_tags=`grep "^available_tags=" "${ofile}" | $SED -e 's/available_tags=\(.*$\)/\1/' -e 's/\"//g'`
+ lt_save_ifs="$IFS"; IFS="${IFS}$PATH_SEPARATOR,"
+ for tagname in $tagnames; do
+ IFS="$lt_save_ifs"
+ # Check whether tagname contains only valid characters
+ case `$echo "X$tagname" | $Xsed -e 's:[-_ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz1234567890,/]::g'` in
+ *) { { echo "$as_me:$LINENO: error: invalid tag name: $tagname" >&5
+echo "$as_me: error: invalid tag name: $tagname" >&2;}
+ { (exit 1); exit 1; }; }
+ esac
+ if grep "^# ### BEGIN LIBTOOL TAG CONFIG: $tagname$" < "${ofile}" > /dev/null
+ then
+ { { echo "$as_me:$LINENO: error: tag name \"$tagname\" already exists" >&5
+echo "$as_me: error: tag name \"$tagname\" already exists" >&2;}
+ fi
+ # Update the list of available tags.
+ if test -n "$tagname"; then
+ echo appending configuration tag \"$tagname\" to $ofile
+ case $tagname in
+ CXX)
+ if test -n "$CXX" && ( test "X$CXX" != "Xno" &&
+ ( (test "X$CXX" = "Xg++" && `g++ -v >/dev/null 2>&1` ) ||
+ (test "X$CXX" != "Xg++"))) ; then
+ ac_ext=cc
+archive_cmds_need_lc_CXX=no
+allow_undefined_flag_CXX=
+always_export_symbols_CXX=no
+archive_expsym_cmds_CXX=
+export_dynamic_flag_spec_CXX=
+hardcode_direct_CXX=no
+hardcode_libdir_flag_spec_CXX=
+hardcode_libdir_flag_spec_ld_CXX=
+hardcode_libdir_separator_CXX=
+hardcode_minus_L_CXX=no
+hardcode_shlibpath_var_CXX=unsupported
+hardcode_automatic_CXX=no
+module_cmds_CXX=
+module_expsym_cmds_CXX=
+link_all_deplibs_CXX=unknown
+old_archive_cmds_CXX=$old_archive_cmds
+no_undefined_flag_CXX=
+whole_archive_flag_spec_CXX=
+enable_shared_with_static_runtimes_CXX=no
+# Dependencies to place before and after the object being linked:
+predep_objects_CXX=
+postdep_objects_CXX=
+predeps_CXX=
+postdeps_CXX=
+compiler_lib_search_path_CXX=
+# Source file extension for C++ test sources.
+ac_ext=cpp
+# Object file extension for compiled C++ test sources.
+objext=o
+objext_CXX=$objext
+# Code to be used in simple compile tests
+lt_simple_compile_test_code="int some_variable = 0;\n"
+# Code to be used in simple link tests
+lt_simple_link_test_code='int main(int, char *[]) { return(0); }\n'
+# ltmain only uses $CC for tagged configurations so make sure $CC is set.
+# If no C compiler was specified, use CC.
+LTCC=${LTCC-"$CC"}
+# If no C compiler flags were specified, use CFLAGS.
+LTCFLAGS=${LTCFLAGS-"$CFLAGS"}
+# Allow CC to be a program name with arguments.
+compiler=$CC
+# save warnings/boilerplate of simple test code
+ac_outfile=conftest.$ac_objext
+printf "$lt_simple_compile_test_code" >conftest.$ac_ext
+eval "$ac_compile" 2>&1 >/dev/null | $SED '/^$/d; /^ *+/d' >conftest.err
+_lt_compiler_boilerplate=`cat conftest.err`
+$rm conftest*
+printf "$lt_simple_link_test_code" >conftest.$ac_ext
+eval "$ac_link" 2>&1 >/dev/null | $SED '/^$/d; /^ *+/d' >conftest.err
+_lt_linker_boilerplate=`cat conftest.err`
+$rm conftest*
+lt_save_CC=$CC
+lt_save_LD=$LD
+lt_save_GCC=$GCC
+GCC=$GXX
+lt_save_with_gnu_ld=$with_gnu_ld
+lt_save_path_LD=$lt_cv_path_LD
+if test -n "${lt_cv_prog_gnu_ldcxx+set}"; then
+ lt_cv_prog_gnu_ld=$lt_cv_prog_gnu_ldcxx
+else
+ $as_unset lt_cv_prog_gnu_ld
+fi
+if test -n "${lt_cv_path_LDCXX+set}"; then
+ lt_cv_path_LD=$lt_cv_path_LDCXX
+else
+ $as_unset lt_cv_path_LD
+fi
+test -z "${LDCXX+set}" || LD=$LDCXX
+CC=${CXX-"c++"}
+compiler=$CC
+compiler_CXX=$CC
+for cc_temp in $compiler""; do
+ case $cc_temp in
+ compile | *[\\/]compile | ccache | *[\\/]ccache ) ;;
+ distcc | *[\\/]distcc | purify | *[\\/]purify ) ;;
+ *) break;;
+ esac
+done
+cc_basename=`$echo "X$cc_temp" | $Xsed -e 's%.*/%%' -e "s%^$host_alias-%%"`
+# We don't want -fno-exception wen compiling C++ code, so set the
+# no_builtin_flag separately
+if test "$GXX" = yes; then
+ lt_prog_compiler_no_builtin_flag_CXX=' -fno-builtin'
+else
+fi
+ # Set up default GNU C++ configuration
+# Check whether --with-gnu-ld or --without-gnu-ld was given.
+if test "${with_gnu_ld+set}" = set; then
+ withval="$with_gnu_ld"
+ test "$withval" = no || with_gnu_ld=yes
+else
+ with_gnu_ld=no
+fi;
+ac_prog=ld
+ # Check if gcc -print-prog-name=ld gives a path.
+ echo "$as_me:$LINENO: checking for ld used by $CC" >&5
+echo $ECHO_N "checking for ld used by $CC... $ECHO_C" >&6
+ case $host in
+ *-*-mingw*)
+ # gcc leaves a trailing carriage return which upsets mingw
+ ac_prog=`($CC -print-prog-name=ld) 2>&5 | tr -d '\015'` ;;
+ ac_prog=`($CC -print-prog-name=ld) 2>&5` ;;
+ esac
+ case $ac_prog in
+ # Accept absolute paths.
+ re_direlt='/[^/][^/]*/\.\./'
+ # Canonicalize the pathname of ld
+ ac_prog=`echo $ac_prog| $SED 's%\\\\%/%g'`
+ while echo $ac_prog | grep "$re_direlt" > /dev/null 2>&1; do
+ ac_prog=`echo $ac_prog| $SED "s%$re_direlt%/%"`
+ done
+ test -z "$LD" && LD="$ac_prog"
+ # If it fails, then pretend we aren't using GCC.
+ ac_prog=ld
+ # If it is relative, then search for the first ld in PATH.
+ with_gnu_ld=unknown
+ esac
+elif test "$with_gnu_ld" = yes; then
+ echo "$as_me:$LINENO: checking for GNU ld" >&5
+echo $ECHO_N "checking for GNU ld... $ECHO_C" >&6
+else
+ echo "$as_me:$LINENO: checking for non-GNU ld" >&5
+echo $ECHO_N "checking for non-GNU ld... $ECHO_C" >&6
+fi
+if test "${lt_cv_path_LD+set}" = set; then
+else
+ if test -z "$LD"; then
+ lt_save_ifs="$IFS"; IFS=$PATH_SEPARATOR
+ for ac_dir in $PATH; do
+ test -z "$ac_dir" && ac_dir=.
+ if test -f "$ac_dir/$ac_prog" || test -f "$ac_dir/$ac_prog$ac_exeext"; then
+ lt_cv_path_LD="$ac_dir/$ac_prog"
+ # Check to see if the program is GNU ld. I'd rather use --version,
+ # but apparently some variants of GNU ld only accept -v.
+ # Break only if it was the GNU/non-GNU ld that we prefer.
+ case `"$lt_cv_path_LD" -v 2>&1 </dev/null` in
+ *GNU* | *'with BFD'*)
+ test "$with_gnu_ld" != no && break
+ test "$with_gnu_ld" != yes && break
+ esac
+ fi
+ done
+else
+ lt_cv_path_LD="$LD" # Let the user override the test with a path.
+fi
+fi
+LD="$lt_cv_path_LD"
+if test -n "$LD"; then
+ echo "$as_me:$LINENO: result: $LD" >&5
+echo "${ECHO_T}$LD" >&6
+else
+fi
+test -z "$LD" && { { echo "$as_me:$LINENO: error: no acceptable ld found in \$PATH" >&5
+echo "$as_me: error: no acceptable ld found in \$PATH" >&2;}
+echo "$as_me:$LINENO: checking if the linker ($LD) is GNU ld" >&5
+echo $ECHO_N "checking if the linker ($LD) is GNU ld... $ECHO_C" >&6
+if test "${lt_cv_prog_gnu_ld+set}" = set; then
+else
+ # I'd rather use --version here, but apparently some GNU lds only accept -v.
+case `$LD -v 2>&1 </dev/null` in
+*GNU* | *'with BFD'*)
+ lt_cv_prog_gnu_ld=yes
+ lt_cv_prog_gnu_ld=no
+esac
+fi
+echo "$as_me:$LINENO: result: $lt_cv_prog_gnu_ld" >&5
+echo "${ECHO_T}$lt_cv_prog_gnu_ld" >&6
+with_gnu_ld=$lt_cv_prog_gnu_ld
+ # Check if GNU C++ uses GNU ld as the underlying linker, since the
+ # archiving commands below assume that GNU ld is being used.
+ archive_cmds_CXX='$CC -shared -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $wl$soname -o $lib'
+ archive_expsym_cmds_CXX='$CC -shared -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
+ hardcode_libdir_flag_spec_CXX='${wl}--rpath ${wl}$libdir'
+ export_dynamic_flag_spec_CXX='${wl}--export-dynamic'
+ # If archive_cmds runs LD, not CC, wlarc should be empty
+ # XXX I think wlarc can be eliminated in ltcf-cxx, but I need to
+ # investigate it a little bit more. (MM)
+ wlarc='${wl}'
+ # ancient GNU ld didn't support --whole-archive et. al.
+ if eval "`$CC -print-prog-name=ld` --help 2>&1" | \
+ grep 'no-whole-archive' > /dev/null; then
+ whole_archive_flag_spec_CXX="$wlarc"'--whole-archive$convenience '"$wlarc"'--no-whole-archive'
+ else
+ fi
+ else
+ with_gnu_ld=no
+ wlarc=
+ # A generic and very simple default shared library creation
+ # command for GNU C++ for the case where it uses the native
+ # linker, instead of GNU ld. If possible, this setting should
+ # overridden to take advantage of the native linker features on
+ # the platform it is being used on.
+ archive_cmds_CXX='$CC -shared -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -o $lib'
+ fi
+ # Commands to make compiler produce verbose output that lists
+ # what "hidden" libraries, object files and flags are used when
+ # linking a shared library.
+ output_verbose_link_cmd='$CC -shared $CFLAGS -v conftest.$objext 2>&1 | grep "\-L"'
+else
+ GXX=no
+ with_gnu_ld=no
+ wlarc=
+fi
+# PORTME: fill in a description of your system's C++ link characteristics
+echo "$as_me:$LINENO: checking whether the $compiler linker ($LD) supports shared libraries" >&5
+echo $ECHO_N "checking whether the $compiler linker ($LD) supports shared libraries... $ECHO_C" >&6
+ld_shlibs_CXX=yes
+case $host_os in
+ aix3*)
+ # FIXME: insert proper C++ library support
+ ld_shlibs_CXX=no
+ aix4* | aix5*)
+ if test "$host_cpu" = ia64; then
+ # On IA64, the linker does run time linking by default, so we don't
+ # have to do anything special.
+ aix_use_runtimelinking=no
+ exp_sym_flag='-Bexport'
+ no_entry_flag=""
+ else
+ # Test if we are trying to use run time linking or normal
+ # AIX style linking. If -brtl is somewhere in LDFLAGS, we
+ # need to do runtime linking.
+ case $host_os in aix4.[23]|aix4.[23].*|aix5*)
+ for ld_flag in $LDFLAGS; do
+ case $ld_flag in
+ *-brtl*)
+ aix_use_runtimelinking=yes
+ break
+ esac
+ done
+ esac
+ exp_sym_flag='-bexport'
+ no_entry_flag='-bnoentry'
+ fi
+ # When large executables or shared objects are built, AIX ld can
+ # have problems creating the table of contents. If linking a library
+ # or program results in "error TOC overflow" add -mminimal-toc to
+ # CXXFLAGS/CFLAGS for g++/gcc. In the cases where that is not
+ # enough to fix the problem, add -Wl,-bbigtoc to LDFLAGS.
+ archive_cmds_CXX=''
+ hardcode_direct_CXX=yes
+ hardcode_libdir_separator_CXX=':'
+ link_all_deplibs_CXX=yes
+ if test "$GXX" = yes; then
+ case $host_os in aix4.[012]|aix4.[012].*)
+ # We only want to do this on AIX 4.2 and lower, the check
+ # below for broken collect2 doesn't work under 4.3+
+ collect2name=`${CC} -print-prog-name=collect2`
+ if test -f "$collect2name" && \
+ strings "$collect2name" | grep resolve_lib_name >/dev/null
+ then
+ # We have reworked collect2
+ else
+ # We have old collect2
+ hardcode_direct_CXX=unsupported
+ # It fails to find uninstalled libraries when the uninstalled
+ # path is not listed in the libpath. Setting hardcode_minus_L
+ # to unsupported forces relinking
+ hardcode_minus_L_CXX=yes
+ hardcode_libdir_flag_spec_CXX='-L$libdir'
+ fi
+ esac
+ shared_flag='-shared'
+ if test "$aix_use_runtimelinking" = yes; then
+ shared_flag="$shared_flag "'${wl}-G'
+ fi
+ else
+ # not using gcc
+ # VisualAge C++, Version 5.5 for AIX 5L for IA-64, Beta 3 Release
+ # chokes on -Wl,-G. The following line is correct:
+ shared_flag='-G'
+ else
+ shared_flag='${wl}-G'
+ else
+ shared_flag='${wl}-bM:SRE'
+ fi
+ fi
+ fi
+ # It seems that -bexpall does not export symbols beginning with
+ # underscore (_), so it is better to generate a list of symbols to export.
+ always_export_symbols_CXX=yes
+ # Warning - without using the other runtime loading flags (-brtl),
+ # -berok will link without error, but may produce a broken library.
+ allow_undefined_flag_CXX='-berok'
+ # Determine the default libpath from the value encoded in an empty executable.
+ cat >conftest.$ac_ext <<_ACEOF
+/* confdefs.h. */
+_ACEOF
+int
+main ()
+ return 0;
+_ACEOF
+ ac_status=$?
+ { ac_try='test -z "$ac_cxx_werror_flag"
+ ac_status=$?
+ ac_status=$?
+ echo "$as_me:$LINENO: \$? = $ac_status" >&5
+aix_libpath=`dump -H conftest$ac_exeext 2>/dev/null | $SED -n -e '/Import File Strings/,/^$/ { /^0/ { s/^0 *\(.*\)$/\1/; p; }
+# Check for a 64-bit object if we didn't find anything.
+if test -z "$aix_libpath"; then aix_libpath=`dump -HX64 conftest$ac_exeext 2>/dev/null | $SED -n -e '/Import File Strings/,/^$/ { /^0/ { s/^0 *\(.*\)$/\1/; p; }
+}'`; fi
+else
+fi
+if test -z "$aix_libpath"; then aix_libpath="/usr/lib:/lib"; fi
+ hardcode_libdir_flag_spec_CXX='${wl}-blibpath:$libdir:'"$aix_libpath"
+ archive_expsym_cmds_CXX="\$CC"' -o $output_objdir/$soname $libobjs $deplibs '"\${wl}$no_entry_flag"' $compiler_flags `if test "x${allow_undefined_flag}" != "x"; then echo "${wl}${allow_undefined_flag}"; else :; fi` '"\${wl}$exp_sym_flag:\$export_symbols $shared_flag"
+ else
+ hardcode_libdir_flag_spec_CXX='${wl}-R $libdir:/usr/lib:/lib'
+ allow_undefined_flag_CXX="-z nodefs"
+ archive_expsym_cmds_CXX="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs '"\${wl}$no_entry_flag"' $compiler_flags ${wl}${allow_undefined_flag} '"\${wl}$exp_sym_flag:\$export_symbols"
+ else
+/* confdefs.h. */
+_ACEOF
+int
+main ()
+ return 0;
+_ACEOF
+ ac_status=$?
+ ac_status=$?
+ ac_status=$?
+}'`; fi
+else
+fi
+ # Warning - without using the other run time loading flags,
+ no_undefined_flag_CXX=' ${wl}-bernotok'
+ allow_undefined_flag_CXX=' ${wl}-berok'
+ # Exported symbols can be pulled into shared objects from archives
+ whole_archive_flag_spec_CXX='$convenience'
+ archive_cmds_need_lc_CXX=yes
+ # This is similar to how AIX traditionally builds its shared libraries.
+ archive_expsym_cmds_CXX="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs ${wl}-bnoentry $compiler_flags ${wl}-bE:$export_symbols${allow_undefined_flag}~$AR $AR_FLAGS $output_objdir/$libname$release.a $output_objdir/$soname'
+ fi
+ fi
+ beos*)
+ if $LD --help 2>&1 | grep ': supported targets:.* elf' > /dev/null; then
+ allow_undefined_flag_CXX=unsupported
+ # Joseph Beckenbach <jrb3 at best.com> says some releases of gcc
+ # support --undefined. This deserves some investigation. FIXME
+ archive_cmds_CXX='$CC -nostart $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
+ else
+ ld_shlibs_CXX=no
+ fi
+ chorus*)
+ case $cc_basename in
+ ld_shlibs_CXX=no
+ esac
+ cygwin* | mingw* | pw32*)
+ # _LT_AC_TAGVAR(hardcode_libdir_flag_spec, CXX) is actually meaningless,
+ # as there is no search path for DLLs.
+ always_export_symbols_CXX=no
+ enable_shared_with_static_runtimes_CXX=yes
+ if $LD --help 2>&1 | grep 'auto-import' > /dev/null; then
+ archive_cmds_CXX='$CC -shared -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -o $output_objdir/$soname ${wl}--enable-auto-image-base -Xlinker --out-implib -Xlinker $lib'
+ # If the export-symbols file already is a .def file (1st line
+ # is EXPORTS), use it as is; otherwise, prepend...
+ archive_expsym_cmds_CXX='if test "x`$SED 1q $export_symbols`" = xEXPORTS; then
+ cp $export_symbols $output_objdir/$soname.def;
+ else
+ echo EXPORTS > $output_objdir/$soname.def;
+ cat $export_symbols >> $output_objdir/$soname.def;
+ fi~
+ $CC -shared -nostdlib $output_objdir/$soname.def $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -o $output_objdir/$soname ${wl}--enable-auto-image-base -Xlinker --out-implib -Xlinker $lib'
+ else
+ ld_shlibs_CXX=no
+ fi
+ darwin* | rhapsody*)
+ case $host_os in
+ rhapsody* | darwin1.[012])
+ allow_undefined_flag_CXX='${wl}-undefined ${wl}suppress'
+ *) # Darwin 1.3 on
+ if test -z ${MACOSX_DEPLOYMENT_TARGET} ; then
+ allow_undefined_flag_CXX='${wl}-flat_namespace ${wl}-undefined ${wl}suppress'
+ else
+ case ${MACOSX_DEPLOYMENT_TARGET} in
+ 10.[012])
+ 10.*)
+ allow_undefined_flag_CXX='${wl}-undefined ${wl}dynamic_lookup'
+ esac
+ fi
+ esac
+ archive_cmds_need_lc_CXX=no
+ hardcode_direct_CXX=no
+ hardcode_automatic_CXX=yes
+ hardcode_shlibpath_var_CXX=unsupported
+ whole_archive_flag_spec_CXX=''
+ if test "$GXX" = yes ; then
+ lt_int_apple_cc_single_mod=no
+ output_verbose_link_cmd='echo'
+ if $CC -dumpspecs 2>&1 | $EGREP 'single_module' >/dev/null ; then
+ lt_int_apple_cc_single_mod=yes
+ fi
+ if test "X$lt_int_apple_cc_single_mod" = Xyes ; then
+ archive_cmds_CXX='$CC -dynamiclib -single_module $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring'
+ else
+ archive_cmds_CXX='$CC -r -keep_private_externs -nostdlib -o ${lib}-master.o $libobjs~$CC -dynamiclib $allow_undefined_flag -o $lib ${lib}-master.o $deplibs $compiler_flags -install_name $rpath/$soname $verstring'
+ fi
+ module_cmds_CXX='$CC $allow_undefined_flag -o $lib -bundle $libobjs $deplibs$compiler_flags'
+ # Don't fix this by using the ld -exported_symbols_list flag, it doesn't exist in older darwin lds
+ archive_expsym_cmds_CXX='sed -e "s,#.*,," -e "s,^[ ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -dynamiclib -single_module $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
+ else
+ archive_expsym_cmds_CXX='sed -e "s,#.*,," -e "s,^[ ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -r -keep_private_externs -nostdlib -o ${lib}-master.o $libobjs~$CC -dynamiclib $allow_undefined_flag -o $lib ${lib}-master.o $deplibs $compiler_flags -install_name $rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
+ fi
+ module_expsym_cmds_CXX='sed -e "s,#.*,," -e "s,^[ ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC $allow_undefined_flag -o $lib -bundle $libobjs $deplibs$compiler_flags~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
+ else
+ xlc*)
+ archive_cmds_CXX='$CC -qmkshrobj ${wl}-single_module $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-install_name ${wl}`echo $rpath/$soname` $verstring'
+ archive_expsym_cmds_CXX='sed -e "s,#.*,," -e "s,^[ ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -qmkshrobj ${wl}-single_module $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-install_name ${wl}$rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
+ ld_shlibs_CXX=no
+ esac
+ fi
+ dgux*)
+ ec++*)
+ ld_shlibs_CXX=no
+ ghcx*)
+ # Green Hills C++ Compiler
+ ld_shlibs_CXX=no
+ ld_shlibs_CXX=no
+ esac
+ freebsd[12]*)
+ # C++ shared libraries reported to be fairly broken before switch to ELF
+ ld_shlibs_CXX=no
+ freebsd-elf*)
+ freebsd* | kfreebsd*-gnu | dragonfly*)
+ # FreeBSD 3 and later use GNU C++ and GNU ld with standard ELF
+ # conventions
+ ld_shlibs_CXX=yes
+ gnu*)
+ hpux9*)
+ hardcode_libdir_flag_spec_CXX='${wl}+b ${wl}$libdir'
+ hardcode_libdir_separator_CXX=:
+ export_dynamic_flag_spec_CXX='${wl}-E'
+ hardcode_minus_L_CXX=yes # Not in the search PATH,
+ # but as the default
+ # location of the library.
+ CC*)
+ ld_shlibs_CXX=no
+ aCC*)
+ archive_cmds_CXX='$rm $output_objdir/$soname~$CC -b ${wl}+b ${wl}$install_libdir -o $output_objdir/$soname $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
+ # There doesn't appear to be a way to prevent this compiler from
+ # explicitly linking system object files so we need to strip them
+ # from the output so that they don't get included in the library
+ # dependencies.
+ output_verbose_link_cmd='templist=`($CC -b $CFLAGS -v conftest.$objext 2>&1) | grep "[-]L"`; list=""; for z in $templist; do case $z in conftest.$objext) list="$list $z";; *.$objext);; *) list="$list $z";;esac; done; echo $list'
+ archive_cmds_CXX='$rm $output_objdir/$soname~$CC -shared -nostdlib -fPIC ${wl}+b ${wl}$install_libdir -o $output_objdir/$soname $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
+ else
+ ld_shlibs_CXX=no
+ fi
+ esac
+ hpux10*|hpux11*)
+ if test $with_gnu_ld = no; then
+ case $host_cpu in
+ hppa*64*|ia64*)
+ hardcode_libdir_flag_spec_ld_CXX='+b $libdir'
+ esac
+ fi
+ case $host_cpu in
+ hppa*64*|ia64*)
+ hardcode_shlibpath_var_CXX=no
+ esac
+ CC*)
+ ld_shlibs_CXX=no
+ aCC*)
+ case $host_cpu in
+ hppa*64*)
+ archive_cmds_CXX='$CC -b ${wl}+h ${wl}$soname -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
+ ia64*)
+ archive_cmds_CXX='$CC -b ${wl}+h ${wl}$soname ${wl}+nodefaultrpath -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
+ archive_cmds_CXX='$CC -b ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
+ esac
+ # dependencies.
+ output_verbose_link_cmd='templist=`($CC -b $CFLAGS -v conftest.$objext 2>&1) | grep "\-L"`; list=""; for z in $templist; do case $z in conftest.$objext) list="$list $z";; *.$objext);; *) list="$list $z";;esac; done; echo $list'
+ case $host_cpu in
+ hppa*64*)
+ archive_cmds_CXX='$CC -shared -nostdlib -fPIC ${wl}+h ${wl}$soname -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
+ ia64*)
+ archive_cmds_CXX='$CC -shared -nostdlib -fPIC ${wl}+h ${wl}$soname ${wl}+nodefaultrpath -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
+ archive_cmds_CXX='$CC -shared -nostdlib -fPIC ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
+ esac
+ fi
+ else
+ ld_shlibs_CXX=no
+ fi
+ esac
+ interix3*)
+ hardcode_libdir_flag_spec_CXX='${wl}-rpath,$libdir'
+ # Hack: On Interix 3.x, we cannot compile PIC because of a broken gcc.
+ # Instead, shared libraries are loaded at an image base (0x10000000 by
+ # default) and relocated if they conflict, which is a slow very memory
+ # consuming and fragmenting process. To avoid this, we pick a random,
+ # 256 KiB-aligned image base between 0x50000000 and 0x6FFC0000 at link
+ # time. Moving up from 0x10000000 also allows more sbrk(2) space.
+ archive_cmds_CXX='$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-h,$soname ${wl}--image-base,`expr ${RANDOM-$$} % 4096 / 2 \* 262144 + 1342177280` -o $lib'
+ archive_expsym_cmds_CXX='sed "s,^,_," $export_symbols >$output_objdir/$soname.expsym~$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-h,$soname ${wl}--retain-symbols-file,$output_objdir/$soname.expsym ${wl}--image-base,`expr ${RANDOM-$$} % 4096 / 2 \* 262144 + 1342177280` -o $lib'
+ irix5* | irix6*)
+ CC*)
+ # SGI C++
+ archive_cmds_CXX='$CC -shared -all -multigot $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
+ # Archives containing C++ object files must be created using
+ # "CC -ar", where "CC" is the IRIX C++ compiler. This is
+ # necessary to make sure instantiated templates are included
+ # in the archive.
+ old_archive_cmds_CXX='$CC -ar -WR,-u -o $oldlib $oldobjs'
+ if test "$with_gnu_ld" = no; then
+ archive_cmds_CXX='$CC -shared -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
+ else
+ archive_cmds_CXX='$CC -shared -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` -o $lib'
+ fi
+ fi
+ esac
+ hardcode_libdir_flag_spec_CXX='${wl}-rpath ${wl}$libdir'
+ linux*)
+ KCC*)
+ # Kuck and Associates, Inc. (KAI) C++ Compiler
+ # KCC will only create a shared library if the output file
+ # ends with ".so" (or ".sl" for HP-UX), so rename the library
+ # to its proper name (with version) after linking.
+ archive_cmds_CXX='tempext=`echo $shared_ext | $SED -e '\''s/\([^()0-9A-Za-z{}]\)/\\\\\1/g'\''`; templib=`echo $lib | $SED -e "s/\${tempext}\..*/.so/"`; $CC $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags --soname $soname -o \$templib; mv \$templib $lib'
+ archive_expsym_cmds_CXX='tempext=`echo $shared_ext | $SED -e '\''s/\([^()0-9A-Za-z{}]\)/\\\\\1/g'\''`; templib=`echo $lib | $SED -e "s/\${tempext}\..*/.so/"`; $CC $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags --soname $soname -o \$templib ${wl}-retain-symbols-file,$export_symbols; mv \$templib $lib'
+ # dependencies.
+ output_verbose_link_cmd='templist=`$CC $CFLAGS -v conftest.$objext -o libconftest$shared_ext 2>&1 | grep "ld"`; rm -f libconftest$shared_ext; list=""; for z in $templist; do case $z in conftest.$objext) list="$list $z";; *.$objext);; *) list="$list $z";;esac; done; echo $list'
+ hardcode_libdir_flag_spec_CXX='${wl}--rpath,$libdir'
+ # "CC -Bstatic", where "CC" is the KAI C++ compiler.
+ old_archive_cmds_CXX='$CC -Bstatic -o $oldlib $oldobjs'
+ icpc*)
+ # Intel C++
+ with_gnu_ld=yes
+ # version 8.0 and above of icpc choke on multiply defined symbols
+ # if we add $predep_objects and $postdep_objects, however 7.1 and
+ # earlier do not add the objects themselves.
+ case `$CC -V 2>&1` in
+ *"Version 7."*)
+ archive_cmds_CXX='$CC -shared $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $wl$soname -o $lib'
+ archive_expsym_cmds_CXX='$CC -shared $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
+ *) # Version 8.0 or newer
+ tmp_idyn=
+ case $host_cpu in
+ ia64*) tmp_idyn=' -i_dynamic';;
+ esac
+ archive_cmds_CXX='$CC -shared'"$tmp_idyn"' $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
+ archive_expsym_cmds_CXX='$CC -shared'"$tmp_idyn"' $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
+ esac
+ whole_archive_flag_spec_CXX='${wl}--whole-archive$convenience ${wl}--no-whole-archive'
+ pgCC*)
+ # Portland Group C++ compiler
+ archive_cmds_CXX='$CC -shared $pic_flag $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname ${wl}$soname -o $lib'
+ archive_expsym_cmds_CXX='$CC -shared $pic_flag $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname ${wl}$soname ${wl}-retain-symbols-file ${wl}$export_symbols -o $lib'
+ whole_archive_flag_spec_CXX='${wl}--whole-archive`for conv in $convenience\"\"; do test -n \"$conv\" && new_convenience=\"$new_convenience,$conv\"; done; $echo \"$new_convenience\"` ${wl}--no-whole-archive'
+ cxx*)
+ # Compaq C++
+ archive_expsym_cmds_CXX='$CC -shared $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $wl$soname -o $lib ${wl}-retain-symbols-file $wl$export_symbols'
+ runpath_var=LD_RUN_PATH
+ hardcode_libdir_flag_spec_CXX='-rpath $libdir'
+ # dependencies.
+ output_verbose_link_cmd='templist=`$CC -shared $CFLAGS -v conftest.$objext 2>&1 | grep "ld"`; templist=`echo $templist | $SED "s/\(^.*ld.*\)\( .*ld .*$\)/\1/"`; list=""; for z in $templist; do case $z in conftest.$objext) list="$list $z";; *.$objext);; *) list="$list $z";;esac; done; echo $list'
+ esac
+ lynxos*)
+ ld_shlibs_CXX=no
+ m88k*)
+ ld_shlibs_CXX=no
+ mvs*)
+ cxx*)
+ ld_shlibs_CXX=no
+ ld_shlibs_CXX=no
+ esac
+ netbsd*)
+ if echo __ELF__ | $CC -E - | grep __ELF__ >/dev/null; then
+ archive_cmds_CXX='$LD -Bshareable -o $lib $predep_objects $libobjs $deplibs $postdep_objects $linker_flags'
+ wlarc=
+ hardcode_libdir_flag_spec_CXX='-R$libdir'
+ fi
+ # Workaround some broken pre-1.5 toolchains
+ output_verbose_link_cmd='$CC -shared $CFLAGS -v conftest.$objext 2>&1 | grep conftest.$objext | $SED -e "s:-lgcc -lc -lgcc::"'
+ openbsd2*)
+ # C++ shared libraries are fairly broken
+ ld_shlibs_CXX=no
+ openbsd*)
+ archive_cmds_CXX='$CC -shared $pic_flag $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -o $lib'
+ if test -z "`echo __ELF__ | $CC -E - | grep __ELF__`" || test "$host_os-$host_cpu" = "openbsd2.8-powerpc"; then
+ archive_expsym_cmds_CXX='$CC -shared $pic_flag $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-retain-symbols-file,$export_symbols -o $lib'
+ fi
+ osf3*)
+ KCC*)
+ RCC*)
+ # Rational C++ 2.4.1
+ ld_shlibs_CXX=no
+ cxx*)
+ allow_undefined_flag_CXX=' ${wl}-expect_unresolved ${wl}\*'
+ archive_cmds_CXX='$CC -shared${allow_undefined_flag} $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $soname `test -n "$verstring" && echo ${wl}-set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
+ # dependencies.
+ output_verbose_link_cmd='templist=`$CC -shared $CFLAGS -v conftest.$objext 2>&1 | grep "ld" | grep -v "ld:"`; templist=`echo $templist | $SED "s/\(^.*ld.*\)\( .*ld.*$\)/\1/"`; list=""; for z in $templist; do case $z in conftest.$objext) list="$list $z";; *.$objext);; *) list="$list $z";;esac; done; echo $list'
+ if test "$GXX" = yes && test "$with_gnu_ld" = no; then
+ archive_cmds_CXX='$CC -shared -nostdlib ${allow_undefined_flag} $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
+ else
+ ld_shlibs_CXX=no
+ fi
+ esac
+ osf4* | osf5*)
+ KCC*)
+ # the KAI C++ compiler.
+ old_archive_cmds_CXX='$CC -o $oldlib $oldobjs'
+ RCC*)
+ ld_shlibs_CXX=no
+ cxx*)
+ allow_undefined_flag_CXX=' -expect_unresolved \*'
+ archive_cmds_CXX='$CC -shared${allow_undefined_flag} $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -msym -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
+ archive_expsym_cmds_CXX='for i in `cat $export_symbols`; do printf "%s %s\\n" -exported_symbol "\$i" >> $lib.exp; done~
+ echo "-hidden">> $lib.exp~
+ $CC -shared$allow_undefined_flag $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -msym -soname $soname -Wl,-input -Wl,$lib.exp `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib~
+ $rm $lib.exp'
+ # dependencies.
+ archive_cmds_CXX='$CC -shared -nostdlib ${allow_undefined_flag} $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-msym ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
+ else
+ ld_shlibs_CXX=no
+ fi
+ esac
+ psos*)
+ ld_shlibs_CXX=no
+ sunos4*)
+ CC*)
+ # Sun C++ 4.x
+ ld_shlibs_CXX=no
+ lcc*)
+ # Lucid
+ ld_shlibs_CXX=no
+ ld_shlibs_CXX=no
+ esac
+ solaris*)
+ CC*)
+ # Sun C++ 4.2, 5.x and Centerline C++
+ no_undefined_flag_CXX=' -zdefs'
+ archive_cmds_CXX='$CC -G${allow_undefined_flag} -h$soname -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
+ archive_expsym_cmds_CXX='$echo "{ global:" > $lib.exp~cat $export_symbols | $SED -e "s/\(.*\)/\1;/" >> $lib.exp~$echo "local: *; };" >> $lib.exp~
+ $CC -G${allow_undefined_flag} ${wl}-M ${wl}$lib.exp -h$soname -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags~$rm $lib.exp'
+ case $host_os in
+ solaris2.[0-5] | solaris2.[0-5].*) ;;
+ # The C++ compiler is used as linker so we must use $wl
+ # flag to pass the commands to the underlying system
+ # linker. We must also pass each convience library through
+ # to the system linker between allextract/defaultextract.
+ # The C++ compiler will combine linker options so we
+ # cannot just pass the convience library names through
+ # without $wl.
+ # Supported since Solaris 2.6 (maybe 2.5.1?)
+ whole_archive_flag_spec_CXX='${wl}-z ${wl}allextract`for conv in $convenience\"\"; do test -n \"$conv\" && new_convenience=\"$new_convenience,$conv\"; done; $echo \"$new_convenience\"` ${wl}-z ${wl}defaultextract'
+ esac
+ # "CC -xar", where "CC" is the Sun C++ compiler. This is
+ # in the archive.
+ old_archive_cmds_CXX='$CC -xar -o $oldlib $oldobjs'
+ gcx*)
+ archive_cmds_CXX='$CC -shared $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-h $wl$soname -o $lib'
+ # The C++ compiler must be used to create the archive.
+ old_archive_cmds_CXX='$CC $LDFLAGS -archive -o $oldlib $oldobjs'
+ # GNU C++ compiler with Solaris linker
+ no_undefined_flag_CXX=' ${wl}-z ${wl}defs'
+ if $CC --version | grep -v '^2\.7' > /dev/null; then
+ archive_cmds_CXX='$CC -shared -nostdlib $LDFLAGS $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-h $wl$soname -o $lib'
+ $CC -shared -nostdlib ${wl}-M $wl$lib.exp -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags~$rm $lib.exp'
+ output_verbose_link_cmd="$CC -shared $CFLAGS -v conftest.$objext 2>&1 | grep \"\-L\""
+ else
+ # g++ 2.7 appears to require `-G' NOT `-shared' on this
+ # platform.
+ archive_cmds_CXX='$CC -G -nostdlib $LDFLAGS $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-h $wl$soname -o $lib'
+ $CC -G -nostdlib ${wl}-M $wl$lib.exp -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags~$rm $lib.exp'
+ output_verbose_link_cmd="$CC -G $CFLAGS -v conftest.$objext 2>&1 | grep \"\-L\""
+ fi
+ hardcode_libdir_flag_spec_CXX='${wl}-R $wl$libdir'
+ fi
+ esac
+ sysv4*uw2* | sysv5OpenUNIX* | sysv5UnixWare7.[01].[10]* | unixware7* | sco3.2v5.0.[024]*)
+ no_undefined_flag_CXX='${wl}-z,text'
+ runpath_var='LD_RUN_PATH'
+ CC*)
+ archive_cmds_CXX='$CC -G ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+ archive_expsym_cmds_CXX='$CC -G ${wl}-Bexport:$export_symbols ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+ archive_cmds_CXX='$CC -shared ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+ archive_expsym_cmds_CXX='$CC -shared ${wl}-Bexport:$export_symbols ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+ esac
+ sysv5* | sco3.2v5* | sco5v6*)
+ # Note: We can NOT use -z defs as we might desire, because we do not
+ # link with -lc, and that would cause any symbols used from libc to
+ # always be unresolved, which means just about no library would
+ # ever link correctly. If we're not using GNU ld we use -z text
+ # though, which does catch some bad symbols but isn't as heavy-handed
+ # as -z defs.
+ # For security reasons, it is highly recommended that you always
+ # use absolute paths for naming shared libraries, and exclude the
+ # DT_RUNPATH tag from executables and libraries. But doing so
+ # requires that you compile everything twice, which is a pain.
+ # So that behaviour is only enabled if SCOABSPATH is set to a
+ # non-empty value in the environment. Most likely only useful for
+ # creating official distributions of packages.
+ # This is a hack until libtool officially supports absolute path
+ # names for shared libraries.
+ allow_undefined_flag_CXX='${wl}-z,nodefs'
+ hardcode_libdir_flag_spec_CXX='`test -z "$SCOABSPATH" && echo ${wl}-R,$libdir`'
+ export_dynamic_flag_spec_CXX='${wl}-Bexport'
+ CC*)
+ archive_cmds_CXX='$CC -G ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+ archive_expsym_cmds_CXX='$CC -G ${wl}-Bexport:$export_symbols ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+ archive_cmds_CXX='$CC -shared ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+ archive_expsym_cmds_CXX='$CC -shared ${wl}-Bexport:$export_symbols ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+ esac
+ tandem*)
+ NCC*)
+ # NonStop-UX NCC 3.20
+ ld_shlibs_CXX=no
+ ld_shlibs_CXX=no
+ esac
+ vxworks*)
+ ld_shlibs_CXX=no
+ ld_shlibs_CXX=no
+esac
+echo "$as_me:$LINENO: result: $ld_shlibs_CXX" >&5
+echo "${ECHO_T}$ld_shlibs_CXX" >&6
+test "$ld_shlibs_CXX" = no && can_build_shared=no
+GCC_CXX="$GXX"
+LD_CXX="$LD"
+cat > conftest.$ac_ext <<EOF
+class Foo
+public:
+ Foo (void) { a = 0; }
+private:
+ int a;
+EOF
+if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
+ (eval $ac_compile) 2>&5
+ ac_status=$?
+ (exit $ac_status); }; then
+ # Parse the compiler output and extract the necessary
+ # objects, libraries and library flags.
+ # Sentinel used to keep track of whether or not we are before
+ # the conftest object file.
+ pre_test_object_deps_done=no
+ # The `*' in the case matches for architectures that use `case' in
+ # $output_verbose_cmd can trigger glob expansion during the loop
+ # eval without this substitution.
+ output_verbose_link_cmd=`$echo "X$output_verbose_link_cmd" | $Xsed -e "$no_glob_subst"`
+ for p in `eval $output_verbose_link_cmd`; do
+ case $p in
+ -L* | -R* | -l*)
+ # Some compilers place space between "-{L,R}" and the path.
+ # Remove the space.
+ if test $p = "-L" \
+ || test $p = "-R"; then
+ prev=$p
+ continue
+ else
+ prev=
+ fi
+ if test "$pre_test_object_deps_done" = no; then
+ case $p in
+ -L* | -R*)
+ # Internal compiler library paths should come after those
+ # provided the user. The postdeps already come after the
+ # user supplied libs so there is no need to process them.
+ if test -z "$compiler_lib_search_path_CXX"; then
+ compiler_lib_search_path_CXX="${prev}${p}"
+ else
+ compiler_lib_search_path_CXX="${compiler_lib_search_path_CXX} ${prev}${p}"
+ fi
+ # The "-l" case would never come before the object being
+ # linked, so don't bother handling this case.
+ esac
+ else
+ if test -z "$postdeps_CXX"; then
+ postdeps_CXX="${prev}${p}"
+ else
+ postdeps_CXX="${postdeps_CXX} ${prev}${p}"
+ fi
+ fi
+ *.$objext)
+ # This assumes that the test object file only shows up
+ # once in the compiler output.
+ if test "$p" = "conftest.$objext"; then
+ pre_test_object_deps_done=yes
+ continue
+ fi
+ if test -z "$predep_objects_CXX"; then
+ predep_objects_CXX="$p"
+ else
+ predep_objects_CXX="$predep_objects_CXX $p"
+ fi
+ else
+ if test -z "$postdep_objects_CXX"; then
+ postdep_objects_CXX="$p"
+ else
+ postdep_objects_CXX="$postdep_objects_CXX $p"
+ fi
+ fi
+ *) ;; # Ignore the rest.
+ esac
+ done
+ # Clean up.
+ rm -f a.out a.exe
+else
+ echo "libtool.m4: error: problem compiling CXX test program"
+fi
+$rm -f confest.$objext
+# PORTME: override above test on systems where it is broken
+case $host_os in
+interix3*)
+ # Interix 3.5 installs completely hosed .la files for C++, so rather than
+ # hack all around it, let's just trust "g++" to DTRT.
+ postdeps_CXX=
+solaris*)
+ CC*)
+ # Adding this requires a known-good setup of shared libraries for
+ # Sun compiler versions before 5.6, else PIC objects from an old
+ # archive will be linked into the output, leading to subtle bugs.
+ postdeps_CXX='-lCstd -lCrun'
+ esac
+esac
+case " $postdeps_CXX " in
+*" -lc "*) archive_cmds_need_lc_CXX=no ;;
+esac
+lt_prog_compiler_wl_CXX=
+lt_prog_compiler_pic_CXX=
+lt_prog_compiler_static_CXX=
+echo "$as_me:$LINENO: checking for $compiler option to produce PIC" >&5
+echo $ECHO_N "checking for $compiler option to produce PIC... $ECHO_C" >&6
+ # C++ specific cases for pic, static, wl, etc.
+ lt_prog_compiler_wl_CXX='-Wl,'
+ lt_prog_compiler_static_CXX='-static'
+ case $host_os in
+ aix*)
+ # All AIX code is PIC.
+ # AIX 5 now supports IA64 processor
+ lt_prog_compiler_static_CXX='-Bstatic'
+ fi
+ amigaos*)
+ # FIXME: we need at least 68020 code to build shared libraries, but
+ # adding the `-m68020' flag to GCC prevents building anything better,
+ # like `-m68040'.
+ lt_prog_compiler_pic_CXX='-m68020 -resident32 -malways-restore-a4'
+ beos* | cygwin* | irix5* | irix6* | nonstopux* | osf3* | osf4* | osf5*)
+ # PIC is the default for these OSes.
+ mingw* | os2* | pw32*)
+ # This hack is so that the source file can tell whether it is being
+ # built for inclusion in a dll (and should export symbols for example).
+ lt_prog_compiler_pic_CXX='-DDLL_EXPORT'
+ # PIC is the default on this platform
+ # Common symbols not allowed in MH_DYLIB files
+ lt_prog_compiler_pic_CXX='-fno-common'
+ *djgpp*)
+ # DJGPP does not support shared libraries at all
+ interix3*)
+ # Interix 3.x gcc -fpic/-fPIC options generate broken code.
+ # Instead, we relocate shared libraries at runtime.
+ sysv4*MP*)
+ if test -d /usr/nec; then
+ lt_prog_compiler_pic_CXX=-Kconform_pic
+ fi
+ hpux*)
+ # PIC is the default for IA64 HP-UX and 64-bit HP-UX, but
+ # not for PA HP-UX.
+ case $host_cpu in
+ hppa*64*|ia64*)
+ lt_prog_compiler_pic_CXX='-fPIC'
+ esac
+ esac
+ else
+ case $host_os in
+ aix4* | aix5*)
+ else
+ lt_prog_compiler_static_CXX='-bnso -bI:/lib/syscalls.exp'
+ fi
+ chorus*)
+ cxch68*)
+ # _LT_AC_TAGVAR(lt_prog_compiler_static, CXX)="--no_auto_instantiation -u __main -u __premain -u _abort -r $COOL_DIR/lib/libOrb.a $MVME_DIR/lib/CC/libC.a $MVME_DIR/lib/classix/libcx.s.a"
+ esac
+ darwin*)
+ xlc*)
+ lt_prog_compiler_pic_CXX='-qnocommon'
+ esac
+ dgux*)
+ ec++*)
+ lt_prog_compiler_pic_CXX='-KPIC'
+ ghcx*)
+ lt_prog_compiler_pic_CXX='-pic'
+ esac
+ # FreeBSD uses GNU C++
+ hpux9* | hpux10* | hpux11*)
+ CC*)
+ lt_prog_compiler_static_CXX='${wl}-a ${wl}archive'
+ if test "$host_cpu" != ia64; then
+ lt_prog_compiler_pic_CXX='+Z'
+ fi
+ aCC*)
+ case $host_cpu in
+ hppa*64*|ia64*)
+ # +Z the default
+ esac
+ esac
+ interix*)
+ # This is c89, which is MS Visual C++ (no shared libs)
+ # Anyone wants to do a port?
+ irix5* | irix6* | nonstopux*)
+ CC*)
+ lt_prog_compiler_static_CXX='-non_shared'
+ # CC pic flag -KPIC is the default.
+ esac
+ linux*)
+ KCC*)
+ # KAI C++ Compiler
+ lt_prog_compiler_wl_CXX='--backend -Wl,'
+ icpc* | ecpc*)
+ # Intel C++
+ pgCC*)
+ # Portland Group C++ compiler.
+ lt_prog_compiler_pic_CXX='-fpic'
+ cxx*)
+ # Compaq C++
+ # Make sure the PIC flag is empty. It appears that all Alpha
+ # Linux and Compaq Tru64 Unix objects are PIC.
+ esac
+ lynxos*)
+ m88k*)
+ mvs*)
+ cxx*)
+ lt_prog_compiler_pic_CXX='-W c,exportall'
+ esac
+ netbsd*)
+ osf3* | osf4* | osf5*)
+ KCC*)
+ RCC*)
+ cxx*)
+ # Digital/Compaq C++
+ esac
+ psos*)
+ solaris*)
+ CC*)
+ lt_prog_compiler_wl_CXX='-Qoption ld '
+ gcx*)
+ lt_prog_compiler_pic_CXX='-PIC'
+ esac
+ sunos4*)
+ CC*)
+ # Sun C++ 4.x
+ lcc*)
+ # Lucid
+ esac
+ tandem*)
+ NCC*)
+ esac
+ sysv5* | unixware* | sco3.2v5* | sco5v6* | OpenUNIX*)
+ CC*)
+ esac
+ vxworks*)
+ lt_prog_compiler_can_build_shared_CXX=no
+ esac
+ fi
+echo "$as_me:$LINENO: result: $lt_prog_compiler_pic_CXX" >&5
+echo "${ECHO_T}$lt_prog_compiler_pic_CXX" >&6
-# #ifndef __CYGWIN__
-# # ifdef __CYGWIN32__
-# # define __CYGWIN__ __CYGWIN32__
-# # endif
-# #endif
+# Check to make sure the PIC flag actually works.
-# #ifdef __cplusplus
-# extern "C" {
-# #endif
-# BOOL APIENTRY DllMain (HINSTANCE hInst, DWORD reason, LPVOID reserved);
-# #endif
+if test -n "$lt_prog_compiler_pic_CXX"; then
+echo "$as_me:$LINENO: checking if $compiler PIC flag $lt_prog_compiler_pic_CXX works" >&5
+echo $ECHO_N "checking if $compiler PIC flag $lt_prog_compiler_pic_CXX works... $ECHO_C" >&6
+if test "${lt_prog_compiler_pic_works_CXX+set}" = set; then
+ echo $ECHO_N "(cached) $ECHO_C" >&6
+else
+ lt_prog_compiler_pic_works_CXX=no
+ ac_outfile=conftest.$ac_objext
+ printf "$lt_simple_compile_test_code" > conftest.$ac_ext
+ lt_compiler_flag="$lt_prog_compiler_pic_CXX -DPIC"
+ # Insert the option either (1) after the last *FLAGS variable, or
+ # (2) before a word containing "conftest.", or (3) at the end.
+ # Note that $ac_compile itself does not contain backslashes and begins
+ # with a dollar sign (not a hyphen), so the echo should work correctly.
+ # The option is referenced via a variable to avoid confusing sed.
+ lt_compile=`echo "$ac_compile" | $SED \
+ -e 's:.*FLAGS}\{0,1\} :&$lt_compiler_flag :; t' \
+ -e 's: [^ ]*conftest\.: $lt_compiler_flag&:; t' \
+ -e 's:$: $lt_compiler_flag:'`
+ (eval echo "\"\$as_me:11580: $lt_compile\"" >&5)
+ (eval "$lt_compile" 2>conftest.err)
+ ac_status=$?
+ cat conftest.err >&5
+ echo "$as_me:11584: \$? = $ac_status" >&5
+ if (exit $ac_status) && test -s "$ac_outfile"; then
+ # The compiler can only warn and ignore the option if not recognized
+ # So say no if there are warnings other than the usual output.
+ $echo "X$_lt_compiler_boilerplate" | $Xsed -e '/^$/d' >conftest.exp
+ $SED '/^$/d; /^ *+/d' conftest.err >conftest.er2
+ if test ! -s conftest.er2 || diff conftest.exp conftest.er2 >/dev/null; then
+ lt_prog_compiler_pic_works_CXX=yes
+ fi
+ fi
+ $rm conftest*
+fi
+echo "$as_me:$LINENO: result: $lt_prog_compiler_pic_works_CXX" >&5
+echo "${ECHO_T}$lt_prog_compiler_pic_works_CXX" >&6
+if test x"$lt_prog_compiler_pic_works_CXX" = xyes; then
+ case $lt_prog_compiler_pic_CXX in
+ *) lt_prog_compiler_pic_CXX=" $lt_prog_compiler_pic_CXX" ;;
+ esac
+else
+fi
+fi
+case $host_os in
+ # For platforms which do not support PIC, -DPIC is meaningless:
+ *djgpp*)
+ lt_prog_compiler_pic_CXX="$lt_prog_compiler_pic_CXX -DPIC"
+esac
-# #ifdef __CYGWIN__
-# #include <cygwin/cygwin_dll.h>
-# DECLARE_CYGWIN_DLL( DllMain );
-# #endif
-# HINSTANCE __hDllInstance_base;
+# Check to make sure the static flag actually works.
-# BOOL APIENTRY
-# DllMain (HINSTANCE hInst, DWORD reason, LPVOID reserved)
-# __hDllInstance_base = hInst;
-# return TRUE;
-# /* ltdll.c ends here */
- # This is a source program that is used to create import libraries
- # on Windows for dlls which lack them. Don't remove nor modify the
- # starting and closing comments
-# /* impgen.c starts here */
-# /* Copyright (C) 1999-2000 Free Software Foundation, Inc.
+wl=$lt_prog_compiler_wl_CXX eval lt_tmp_static_flag=\"$lt_prog_compiler_static_CXX\"
+echo "$as_me:$LINENO: checking if $compiler static flag $lt_tmp_static_flag works" >&5
+echo $ECHO_N "checking if $compiler static flag $lt_tmp_static_flag works... $ECHO_C" >&6
+if test "${lt_prog_compiler_static_works_CXX+set}" = set; then
+else
+ lt_prog_compiler_static_works_CXX=no
+ save_LDFLAGS="$LDFLAGS"
+ LDFLAGS="$LDFLAGS $lt_tmp_static_flag"
+ printf "$lt_simple_link_test_code" > conftest.$ac_ext
+ if (eval $ac_link 2>conftest.err) && test -s conftest$ac_exeext; then
+ # The linker can only warn and ignore the option if not recognized
+ if test -s conftest.err; then
+ # Append any errors to the config.log.
+ cat conftest.err 1>&5
+ $echo "X$_lt_linker_boilerplate" | $Xsed -e '/^$/d' > conftest.exp
+ if diff conftest.exp conftest.er2 >/dev/null; then
+ lt_prog_compiler_static_works_CXX=yes
+ fi
+ else
+ fi
+ fi
+ $rm conftest*
+ LDFLAGS="$save_LDFLAGS"
+fi
+echo "$as_me:$LINENO: result: $lt_prog_compiler_static_works_CXX" >&5
+echo "${ECHO_T}$lt_prog_compiler_static_works_CXX" >&6
+if test x"$lt_prog_compiler_static_works_CXX" = xyes; then
+else
+fi
+echo "$as_me:$LINENO: checking if $compiler supports -c -o file.$ac_objext" >&5
+echo $ECHO_N "checking if $compiler supports -c -o file.$ac_objext... $ECHO_C" >&6
+if test "${lt_cv_prog_compiler_c_o_CXX+set}" = set; then
+else
+ lt_cv_prog_compiler_c_o_CXX=no
+ $rm -r conftest 2>/dev/null
+ mkdir conftest
+ cd conftest
+ mkdir out
+ lt_compiler_flag="-o out/conftest2.$ac_objext"
+ (eval echo "\"\$as_me:11684: $lt_compile\"" >&5)
+ (eval "$lt_compile" 2>out/conftest.err)
+ ac_status=$?
+ cat out/conftest.err >&5
+ echo "$as_me:11688: \$? = $ac_status" >&5
+ if (exit $ac_status) && test -s out/conftest2.$ac_objext
+ then
+ $echo "X$_lt_compiler_boilerplate" | $Xsed -e '/^$/d' > out/conftest.exp
+ $SED '/^$/d; /^ *+/d' out/conftest.err >out/conftest.er2
+ if test ! -s out/conftest.er2 || diff out/conftest.exp out/conftest.er2 >/dev/null; then
+ lt_cv_prog_compiler_c_o_CXX=yes
+ fi
+ fi
+ chmod u+w . 2>&5
+ $rm conftest*
+ # SGI C++ compiler will create directory out/ii_files/ for
+ # template instantiation
+ test -d out/ii_files && $rm out/ii_files/* && rmdir out/ii_files
+ $rm out/* && rmdir out
+ cd ..
+ rmdir conftest
+ $rm conftest*
+fi
+echo "$as_me:$LINENO: result: $lt_cv_prog_compiler_c_o_CXX" >&5
+echo "${ECHO_T}$lt_cv_prog_compiler_c_o_CXX" >&6
+hard_links="nottested"
+if test "$lt_cv_prog_compiler_c_o_CXX" = no && test "$need_locks" != no; then
+ # do not overwrite the value of need_locks provided by the user
+ echo "$as_me:$LINENO: checking if we can lock with hard links" >&5
+echo $ECHO_N "checking if we can lock with hard links... $ECHO_C" >&6
+ hard_links=yes
+ $rm conftest*
+ ln conftest.a conftest.b 2>/dev/null && hard_links=no
+ touch conftest.a
+ ln conftest.a conftest.b 2>&5 || hard_links=no
+ echo "$as_me:$LINENO: result: $hard_links" >&5
+echo "${ECHO_T}$hard_links" >&6
+ if test "$hard_links" = no; then
+ { echo "$as_me:$LINENO: WARNING: \`$CC' does not support \`-c -o', so \`make -j' may be unsafe" >&5
+echo "$as_me: WARNING: \`$CC' does not support \`-c -o', so \`make -j' may be unsafe" >&2;}
+ need_locks=warn
+ fi
+else
+ need_locks=no
+fi
+ export_symbols_cmds_CXX='$NM $libobjs $convenience | $global_symbol_pipe | $SED '\''s/.* //'\'' | sort | uniq > $export_symbols'
+ case $host_os in
+ aix4* | aix5*)
+ # If we're using GNU nm, then we don't want the "-C" option.
+ # -C means demangle to AIX nm, but means don't demangle with GNU nm
+ if $NM -V 2>&1 | grep 'GNU' > /dev/null; then
+ export_symbols_cmds_CXX='$NM -Bpg $libobjs $convenience | awk '\''{ if (((\$2 == "T") || (\$2 == "D") || (\$2 == "B")) && (substr(\$3,1,1) != ".")) { print \$3 } }'\'' | sort -u > $export_symbols'
+ else
+ export_symbols_cmds_CXX='$NM -BCpg $libobjs $convenience | awk '\''{ if (((\$2 == "T") || (\$2 == "D") || (\$2 == "B")) && (substr(\$3,1,1) != ".")) { print \$3 } }'\'' | sort -u > $export_symbols'
+ fi
+ pw32*)
+ export_symbols_cmds_CXX="$ltdll_cmds"
+ cygwin* | mingw*)
+ export_symbols_cmds_CXX='$NM $libobjs $convenience | $global_symbol_pipe | $SED -e '\''/^[BCDGRS] /s/.* \([^ ]*\)/\1 DATA/;/^.* __nm__/s/^.* __nm__\([^ ]*\) [^ ]*/\1 DATA/;/^I /d;/^[AITW] /s/.* //'\'' | sort | uniq > $export_symbols'
+ esac
-# This file is part of GNU libtool.
+# Do we need to explicitly link libc?
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2 of the License, or
-# (at your option) any later version.
+case "x$archive_cmds_need_lc_CXX" in
+x|xyes)
+ # Assume -lc should be added
+ if test "$enable_shared" = yes && test "$GCC" = yes; then
+ case $archive_cmds_CXX in
+ # FIXME: we may have to deal with multi-command sequences.
+ '$CC '*)
+ # Test whether the compiler implicitly links with -lc since on some
+ # systems, -lgcc has to come before -lc. If gcc already passes -lc
+ # to ld, don't add -lc before -lgcc.
+ echo "$as_me:$LINENO: checking whether -lc should be explicitly linked in" >&5
+echo $ECHO_N "checking whether -lc should be explicitly linked in... $ECHO_C" >&6
+ $rm conftest*
+ if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
+ ac_status=$?
+ (exit $ac_status); } 2>conftest.err; then
+ soname=conftest
+ lib=conftest
+ libobjs=conftest.$ac_objext
+ deplibs=
+ wl=$lt_prog_compiler_wl_CXX
+ pic_flag=$lt_prog_compiler_pic_CXX
+ compiler_flags=-v
+ linker_flags=-v
+ verstring=
+ output_objdir=.
+ libname=conftest
+ lt_save_allow_undefined_flag=$allow_undefined_flag_CXX
+ if { (eval echo "$as_me:$LINENO: \"$archive_cmds_CXX 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1\"") >&5
+ (eval $archive_cmds_CXX 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1) 2>&5
+ ac_status=$?
+ then
+ else
+ fi
+ allow_undefined_flag_CXX=$lt_save_allow_undefined_flag
+ else
+ fi
+ $rm conftest*
+ echo "$as_me:$LINENO: result: $archive_cmds_need_lc_CXX" >&5
+echo "${ECHO_T}$archive_cmds_need_lc_CXX" >&6
+ esac
+ fi
+esac
+echo "$as_me:$LINENO: checking dynamic linker characteristics" >&5
+echo $ECHO_N "checking dynamic linker characteristics... $ECHO_C" >&6
+library_names_spec=
+libname_spec='lib$name'
+soname_spec=
+shrext_cmds=".so"
+postinstall_cmds=
+postuninstall_cmds=
+finish_cmds=
+finish_eval=
+shlibpath_var=
+shlibpath_overrides_runpath=unknown
+version_type=none
+dynamic_linker="$host_os ld.so"
+sys_lib_dlsearch_path_spec="/lib /usr/lib"
+if test "$GCC" = yes; then
+ sys_lib_search_path_spec=`$CC -print-search-dirs | grep "^libraries:" | $SED -e "s/^libraries://" -e "s,=/,/,g"`
+ if echo "$sys_lib_search_path_spec" | grep ';' >/dev/null ; then
+ # if the path contains ";" then we assume it to be the separator
+ # otherwise default to the standard path separator (i.e. ":") - it is
+ # assumed that no part of a normal pathname contains ";" but that should
+ # okay in the real world where ";" in dirpaths is itself problematic.
+ sys_lib_search_path_spec=`echo "$sys_lib_search_path_spec" | $SED -e 's/;/ /g'`
+ else
+ sys_lib_search_path_spec=`echo "$sys_lib_search_path_spec" | $SED -e "s/$PATH_SEPARATOR/ /g"`
+ fi
+else
+ sys_lib_search_path_spec="/lib /usr/lib /usr/local/lib"
+fi
+need_lib_prefix=unknown
+hardcode_into_libs=no
+# when you set need_version to no, make sure it does not cause -set_version
+# flags to be left without arguments
+need_version=unknown
+case $host_os in
+aix3*)
+ version_type=linux
+ library_names_spec='${libname}${release}${shared_ext}$versuffix $libname.a'
+ shlibpath_var=LIBPATH
+ # AIX 3 has no versioning support, so we append a major version to the name.
+ soname_spec='${libname}${release}${shared_ext}$major'
+aix4* | aix5*)
+ need_lib_prefix=no
+ need_version=no
+ hardcode_into_libs=yes
+ # AIX 5 supports IA64
+ library_names_spec='${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext}$versuffix $libname${shared_ext}'
+ shlibpath_var=LD_LIBRARY_PATH
+ else
+ # With GCC up to 2.95.x, collect2 would create an import file
+ # for dependence libraries. The import file would start with
+ # the line `#! .'. This would cause the generated library to
+ # depend on `.', always an invalid library. This was fixed in
+ # development snapshots of GCC prior to 3.0.
+ case $host_os in
+ aix4 | aix4.[01] | aix4.[01].*)
+ if { echo '#if __GNUC__ > 2 || (__GNUC__ == 2 && __GNUC_MINOR__ >= 97)'
+ echo ' yes '
+ echo '#endif'; } | ${CC} -E - | grep yes > /dev/null; then
+ else
+ can_build_shared=no
+ fi
+ esac
+ # AIX (on Power*) has no versioning support, so currently we can not hardcode correct
+ # soname into executable. Probably we can add versioning support to
+ # collect2, so additional links can be useful in future.
+ # If using run time linking (on AIX 4.2 or later) use lib<name>.so
+ # instead of lib<name>.a to let people know that these are not
+ # typical AIX shared libraries.
+ library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname${shared_ext}'
+ else
+ # We preserve .a as extension for shared libraries through AIX4.2
+ # and later when we are not doing run time linking.
+ library_names_spec='${libname}${release}.a $libname.a'
+ fi
+ fi
+amigaos*)
+ library_names_spec='$libname.ixlibrary $libname.a'
+ # Create ${libname}_ixlibrary.a entries in /sys/libs.
+ finish_eval='for lib in `ls $libdir/*.ixlibrary 2>/dev/null`; do libname=`$echo "X$lib" | $Xsed -e '\''s%^.*/\([^/]*\)\.ixlibrary$%\1%'\''`; test $rm /sys/libs/${libname}_ixlibrary.a; $show "cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a"; cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a || exit 1; done'
+beos*)
+ library_names_spec='${libname}${shared_ext}'
+ dynamic_linker="$host_os ld.so"
+ shlibpath_var=LIBRARY_PATH
+bsdi[45]*)
+ need_version=no
+ finish_cmds='PATH="\$PATH:/sbin" ldconfig $libdir'
+ sys_lib_search_path_spec="/shlib /usr/lib /usr/X11/lib /usr/contrib/lib /lib /usr/local/lib"
+ sys_lib_dlsearch_path_spec="/shlib /usr/lib /usr/local/lib"
+ # the default ld.so.conf also contains /usr/contrib/lib and
+ # /usr/X11R6/lib (/usr/X11 is a link to /usr/X11R6), but let us allow
+ # libtool to hard-code these into programs
+cygwin* | mingw* | pw32*)
+ version_type=windows
+ shrext_cmds=".dll"
+ need_version=no
+ case $GCC,$host_os in
+ yes,cygwin* | yes,mingw* | yes,pw32*)
+ library_names_spec='$libname.dll.a'
+ # DLL is installed to $(libdir)/../bin by postinstall_cmds
+ postinstall_cmds='base_file=`basename \${file}`~
+ dlpath=`$SHELL 2>&1 -c '\''. $dir/'\''\${base_file}'\''i;echo \$dlname'\''`~
+ dldir=$destdir/`dirname \$dlpath`~
+ test -d \$dldir || mkdir -p \$dldir~
+ $install_prog $dir/$dlname \$dldir/$dlname~
+ chmod a+x \$dldir/$dlname'
+ postuninstall_cmds='dldll=`$SHELL 2>&1 -c '\''. $file; echo \$dlname'\''`~
+ dlpath=$dir/\$dldll~
+ $rm \$dlpath'
+ shlibpath_overrides_runpath=yes
+ case $host_os in
+ cygwin*)
+ # Cygwin DLLs use 'cyg' prefix rather than 'lib'
+ soname_spec='`echo ${libname} | sed -e 's/^lib/cyg/'``echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
+ sys_lib_search_path_spec="/usr/lib /lib/w32api /lib /usr/local/lib"
+ mingw*)
+ # MinGW DLLs use traditional 'lib' prefix
+ soname_spec='${libname}`echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
+ if echo "$sys_lib_search_path_spec" | grep ';[c-zC-Z]:/' >/dev/null; then
+ # It is most probably a Windows format PATH printed by
+ # mingw gcc, but we are running on Cygwin. Gcc prints its search
+ # path with ; separators, and with drive letters. We can handle the
+ # drive letters (cygwin fileutils understands them), so leave them,
+ # especially as we might pass files found there to a mingw objdump,
+ # which wouldn't understand a cygwinified path. Ahh.
+ else
+ fi
+ pw32*)
+ # pw32 DLLs use 'pw' prefix rather than 'lib'
+ library_names_spec='`echo ${libname} | sed -e 's/^lib/pw/'``echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
+ esac
+ library_names_spec='${libname}`echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext} $libname.lib'
+ esac
+ dynamic_linker='Win32 ld.exe'
+ # FIXME: first we should search . and the directory the executable is in
+ shlibpath_var=PATH
+darwin* | rhapsody*)
+ dynamic_linker="$host_os dyld"
+ version_type=darwin
+ need_version=no
+ library_names_spec='${libname}${release}${versuffix}$shared_ext ${libname}${release}${major}$shared_ext ${libname}$shared_ext'
+ soname_spec='${libname}${release}${major}$shared_ext'
+ shlibpath_var=DYLD_LIBRARY_PATH
+ shrext_cmds='`test .$module = .yes && echo .so || echo .dylib`'
+ # Apple's gcc prints 'gcc -print-search-dirs' doesn't operate the same.
+ if test "$GCC" = yes; then
+ sys_lib_search_path_spec=`$CC -print-search-dirs | tr "\n" "$PATH_SEPARATOR" | sed -e 's/libraries:/@libraries:/' | tr "@" "\n" | grep "^libraries:" | sed -e "s/^libraries://" -e "s,=/,/,g" -e "s,$PATH_SEPARATOR, ,g" -e "s,.*,& /lib /usr/lib /usr/local/lib,g"`
+ else
+ sys_lib_search_path_spec='/lib /usr/lib /usr/local/lib'
+ fi
+ sys_lib_dlsearch_path_spec='/usr/local/lib /lib /usr/lib'
+dgux*)
+ need_version=no
+ library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname$shared_ext'
+freebsd1*)
+ dynamic_linker=no
+kfreebsd*-gnu)
+ need_version=no
+ library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${shared_ext}'
+ shlibpath_overrides_runpath=no
+ dynamic_linker='GNU ld.so'
+freebsd* | dragonfly*)
+ # DragonFly does not have aout. When/if they implement a new
+ # versioning mechanism, adjust this.
+ if test -x /usr/bin/objformat; then
+ objformat=`/usr/bin/objformat`
+ else
+ case $host_os in
+ freebsd[123]*) objformat=aout ;;
+ *) objformat=elf ;;
+ esac
+ fi
+ version_type=freebsd-$objformat
+ case $version_type in
+ freebsd-elf*)
+ library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext} $libname${shared_ext}'
+ need_version=no
+ freebsd-*)
+ library_names_spec='${libname}${release}${shared_ext}$versuffix $libname${shared_ext}$versuffix'
+ need_version=yes
+ esac
+ case $host_os in
+ freebsd2*)
+ freebsd3.[01]* | freebsdelf3.[01]*)
+ freebsd3.[2-9]* | freebsdelf3.[2-9]* | \
+ freebsd4.[0-5] | freebsdelf4.[0-5] | freebsd4.1.1 | freebsdelf4.1.1)
+ freebsd*) # from 4.6 on
+ esac
+gnu*)
+ need_version=no
+ library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}${major} ${libname}${shared_ext}'
+hpux9* | hpux10* | hpux11*)
+ # Give a soname corresponding to the major version so that dld.sl refuses to
+ # link against other versions.
+ version_type=sunos
+ need_version=no
+ case $host_cpu in
+ ia64*)
+ shrext_cmds='.so'
+ dynamic_linker="$host_os dld.so"
+ shlibpath_overrides_runpath=yes # Unless +noenvvar is specified.
+ if test "X$HPUX_IA64_MODE" = X32; then
+ sys_lib_search_path_spec="/usr/lib/hpux32 /usr/local/lib/hpux32 /usr/local/lib"
+ else
+ sys_lib_search_path_spec="/usr/lib/hpux64 /usr/local/lib/hpux64"
+ fi
+ sys_lib_dlsearch_path_spec=$sys_lib_search_path_spec
+ hppa*64*)
+ shrext_cmds='.sl'
+ dynamic_linker="$host_os dld.sl"
+ shlibpath_var=LD_LIBRARY_PATH # How should we handle SHLIB_PATH
+ sys_lib_search_path_spec="/usr/lib/pa20_64 /usr/ccs/lib/pa20_64"
+ shrext_cmds='.sl'
+ shlibpath_var=SHLIB_PATH
+ shlibpath_overrides_runpath=no # +s is required to enable SHLIB_PATH
+ esac
+ # HP-UX runs *really* slowly unless shared libraries are mode 555.
+ postinstall_cmds='chmod 555 $lib'
+interix3*)
+ need_version=no
+ dynamic_linker='Interix 3.x ld.so.1 (PE, like ELF)'
+irix5* | irix6* | nonstopux*)
+ case $host_os in
+ nonstopux*) version_type=nonstopux ;;
+ if test "$lt_cv_prog_gnu_ld" = yes; then
+ else
+ version_type=irix
+ fi ;;
+ esac
+ need_version=no
+ library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext} $libname${shared_ext}'
+ case $host_os in
+ irix5* | nonstopux*)
+ libsuff= shlibsuff=
+ case $LD in # libtool.m4 will add one of these switches to LD
+ *-32|*"-32 "|*-melf32bsmip|*"-melf32bsmip ")
+ libsuff= shlibsuff= libmagic=32-bit;;
+ *-n32|*"-n32 "|*-melf32bmipn32|*"-melf32bmipn32 ")
+ libsuff=32 shlibsuff=N32 libmagic=N32;;
+ *-64|*"-64 "|*-melf64bmip|*"-melf64bmip ")
+ libsuff=64 shlibsuff=64 libmagic=64-bit;;
+ *) libsuff= shlibsuff= libmagic=never-match;;
+ esac
+ esac
+ shlibpath_var=LD_LIBRARY${shlibsuff}_PATH
+ sys_lib_search_path_spec="/usr/lib${libsuff} /lib${libsuff} /usr/local/lib${libsuff}"
+ sys_lib_dlsearch_path_spec="/usr/lib${libsuff} /lib${libsuff}"
+# No shared lib support for Linux oldld, aout, or coff.
+linux*oldld* | linux*aout* | linux*coff*)
+ dynamic_linker=no
+# This must be Linux ELF.
+linux*)
+ need_version=no
+ finish_cmds='PATH="\$PATH:/sbin" ldconfig -n $libdir'
+ # This implies no fast_install, which is unacceptable.
+ # Some rework will be needed to allow for fast_install
+ # before this can be enabled.
+ # find out which ABI we are using
+ libsuff=
+ case "$host_cpu" in
+ x86_64*|s390x*|powerpc64*)
+ echo '#line 12220 "configure"' > conftest.$ac_ext
+ ac_status=$?
+ case `/usr/bin/file conftest.$ac_objext` in
+ *64-bit*)
+ libsuff=64
+ sys_lib_search_path_spec="/lib${libsuff} /usr/lib${libsuff} /usr/local/lib${libsuff}"
+ esac
+ fi
+ rm -rf conftest*
+ esac
+ # Append ld.so.conf contents to the search path
+ if test -f /etc/ld.so.conf; then
+ lt_ld_extra=`awk '/^include / { system(sprintf("cd /etc; cat %s", \$2)); skip = 1; } { if (!skip) print \$0; skip = 0; }' < /etc/ld.so.conf | $SED -e 's/#.*//;s/[:, ]/ /g;s/=[^=]*$//;s/=[^= ]* / /g;/^$/d' | tr '\n' ' '`
+ sys_lib_dlsearch_path_spec="/lib${libsuff} /usr/lib${libsuff} $lt_ld_extra"
+ fi
+ # We used to test for /lib/ld.so.1 and disable shared libraries on
+ # powerpc, because MkLinux only supported shared libraries with the
+ # GNU dynamic linker. Since this was broken with cross compilers,
+ # most powerpc-linux boxes support dynamic linking these days and
+ # people can always --disable-shared, the test was removed, and we
+ # assume the GNU/Linux dynamic linker is in use.
+ dynamic_linker='GNU/Linux ld.so'
+knetbsd*-gnu)
+ need_version=no
+netbsd*)
+ need_version=no
+ library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${shared_ext}$versuffix'
+ finish_cmds='PATH="\$PATH:/sbin" ldconfig -m $libdir'
+ dynamic_linker='NetBSD (a.out) ld.so'
+ else
+ dynamic_linker='NetBSD ld.elf_so'
+ fi
+newsos6)
+nto-qnx*)
+ need_version=no
+openbsd*)
+ sys_lib_dlsearch_path_spec="/usr/lib"
+ # Some older versions of OpenBSD (3.3 at least) *do* need versioned libs.
+ case $host_os in
+ openbsd3.3 | openbsd3.3.*) need_version=yes ;;
+ *) need_version=no ;;
+ esac
+ case $host_os in
+ openbsd2.[89] | openbsd2.[89].*)
+ esac
+ else
+ fi
+os2*)
+ libname_spec='$name'
+ library_names_spec='$libname${shared_ext} $libname.a'
+ dynamic_linker='OS/2 ld.exe'
+osf3* | osf4* | osf5*)
+ version_type=osf
+ need_version=no
+ sys_lib_search_path_spec="/usr/shlib /usr/ccs/lib /usr/lib/cmplrs/cc /usr/lib /usr/local/lib /var/shlib"
+ sys_lib_dlsearch_path_spec="$sys_lib_search_path_spec"
+solaris*)
+ need_version=no
+ # ldd complains unless libraries are executable
+ postinstall_cmds='chmod +x $lib'
+sunos4*)
+ finish_cmds='PATH="\$PATH:/usr/etc" ldconfig $libdir'
+ if test "$with_gnu_ld" = yes; then
+ fi
+ need_version=yes
+sysv4 | sysv4.3*)
+ case $host_vendor in
+ sni)
+ export_dynamic_flag_spec='${wl}-Blargedynsym'
+ siemens)
+ motorola)
+ need_version=no
+ sys_lib_search_path_spec='/lib /usr/lib /usr/ccs/lib'
+ esac
+sysv4*MP*)
+ if test -d /usr/nec ;then
+ library_names_spec='$libname${shared_ext}.$versuffix $libname${shared_ext}.$major $libname${shared_ext}'
+ soname_spec='$libname${shared_ext}.$major'
+ fi
+sysv5* | sco3.2v5* | sco5v6* | unixware* | OpenUNIX* | sysv4*uw2*)
+ version_type=freebsd-elf
+ need_version=no
+ sys_lib_search_path_spec='/usr/local/lib /usr/gnu/lib /usr/ccs/lib /usr/lib /lib'
+ else
+ sys_lib_search_path_spec='/usr/ccs/lib /usr/lib'
+ case $host_os in
+ sco3.2v5*)
+ sys_lib_search_path_spec="$sys_lib_search_path_spec /lib"
+ esac
+ fi
+ sys_lib_dlsearch_path_spec='/usr/lib'
+uts4*)
+ dynamic_linker=no
+esac
+echo "$as_me:$LINENO: result: $dynamic_linker" >&5
+echo "${ECHO_T}$dynamic_linker" >&6
+test "$dynamic_linker" = no && can_build_shared=no
+variables_saved_for_relink="PATH $shlibpath_var $runpath_var"
+ variables_saved_for_relink="$variables_saved_for_relink GCC_EXEC_PREFIX COMPILER_PATH LIBRARY_PATH"
+fi
+echo "$as_me:$LINENO: checking how to hardcode library paths into programs" >&5
+echo $ECHO_N "checking how to hardcode library paths into programs... $ECHO_C" >&6
+hardcode_action_CXX=
+if test -n "$hardcode_libdir_flag_spec_CXX" || \
+ test -n "$runpath_var_CXX" || \
+ test "X$hardcode_automatic_CXX" = "Xyes" ; then
+ # We can hardcode non-existant directories.
+ if test "$hardcode_direct_CXX" != no &&
+ # If the only mechanism to avoid hardcoding is shlibpath_var, we
+ # have to relink, otherwise we might link with an installed library
+ # when we should be linking with a yet-to-be-installed one
+ ## test "$_LT_AC_TAGVAR(hardcode_shlibpath_var, CXX)" != no &&
+ test "$hardcode_minus_L_CXX" != no; then
+ # Linking always hardcodes the temporary library directory.
+ hardcode_action_CXX=relink
+ else
+ # We can link without hardcoding, and we can hardcode nonexisting dirs.
+ hardcode_action_CXX=immediate
+ fi
+else
+ # We cannot hardcode anything, or else we can only hardcode existing
+ # directories.
+ hardcode_action_CXX=unsupported
+fi
+echo "$as_me:$LINENO: result: $hardcode_action_CXX" >&5
+echo "${ECHO_T}$hardcode_action_CXX" >&6
+if test "$hardcode_action_CXX" = relink; then
+ # Fast installation is not supported
+ enable_fast_install=no
+elif test "$shlibpath_overrides_runpath" = yes ||
+ test "$enable_shared" = no; then
+ # Fast installation is not necessary
+ enable_fast_install=needless
+fi
+# The else clause should only fire when bootstrapping the
+# libtool distribution, otherwise you forgot to ship ltmain.sh
+# with your package, and you will get complaints that there are
+# no rules to generate ltmain.sh.
+if test -f "$ltmain"; then
+ # See if we are running on zsh, and set the options which allow our commands through
+ # without removal of \ escapes.
+ if test -n "${ZSH_VERSION+set}" ; then
+ setopt NO_GLOB_SUBST
+ fi
+ # Now quote all the things that may contain metacharacters while being
+ # careful not to overquote the AC_SUBSTed values. We take copies of the
+ # variables and quote the copies for generation of the libtool script.
+ for var in echo old_CC old_CFLAGS AR AR_FLAGS EGREP RANLIB LN_S LTCC LTCFLAGS NM \
+ SED SHELL STRIP \
+ libname_spec library_names_spec soname_spec extract_expsyms_cmds \
+ old_striplib striplib file_magic_cmd finish_cmds finish_eval \
+ deplibs_check_method reload_flag reload_cmds need_locks \
+ lt_cv_sys_global_symbol_pipe lt_cv_sys_global_symbol_to_cdecl \
+ lt_cv_sys_global_symbol_to_c_name_address \
+ sys_lib_search_path_spec sys_lib_dlsearch_path_spec \
+ old_postinstall_cmds old_postuninstall_cmds \
+ compiler_CXX \
+ CC_CXX \
+ LD_CXX \
+ lt_prog_compiler_wl_CXX \
+ lt_prog_compiler_pic_CXX \
+ lt_prog_compiler_static_CXX \
+ lt_prog_compiler_no_builtin_flag_CXX \
+ export_dynamic_flag_spec_CXX \
+ thread_safe_flag_spec_CXX \
+ whole_archive_flag_spec_CXX \
+ enable_shared_with_static_runtimes_CXX \
+ old_archive_cmds_CXX \
+ old_archive_from_new_cmds_CXX \
+ predep_objects_CXX \
+ postdep_objects_CXX \
+ predeps_CXX \
+ postdeps_CXX \
+ compiler_lib_search_path_CXX \
+ archive_cmds_CXX \
+ archive_expsym_cmds_CXX \
+ postinstall_cmds_CXX \
+ postuninstall_cmds_CXX \
+ old_archive_from_expsyms_cmds_CXX \
+ allow_undefined_flag_CXX \
+ no_undefined_flag_CXX \
+ export_symbols_cmds_CXX \
+ hardcode_libdir_flag_spec_CXX \
+ hardcode_libdir_flag_spec_ld_CXX \
+ hardcode_libdir_separator_CXX \
+ hardcode_automatic_CXX \
+ module_cmds_CXX \
+ module_expsym_cmds_CXX \
+ lt_cv_prog_compiler_c_o_CXX \
+ exclude_expsyms_CXX \
+ include_expsyms_CXX; do
+ case $var in
+ old_archive_cmds_CXX | \
+ old_archive_from_new_cmds_CXX | \
+ archive_cmds_CXX | \
+ archive_expsym_cmds_CXX | \
+ module_cmds_CXX | \
+ module_expsym_cmds_CXX | \
+ old_archive_from_expsyms_cmds_CXX | \
+ export_symbols_cmds_CXX | \
+ extract_expsyms_cmds | reload_cmds | finish_cmds | \
+ postinstall_cmds | postuninstall_cmds | \
+ old_postinstall_cmds | old_postuninstall_cmds | \
+ sys_lib_search_path_spec | sys_lib_dlsearch_path_spec)
+ # Double-quote double-evaled strings.
+ eval "lt_$var=\\\"\`\$echo \"X\$$var\" | \$Xsed -e \"\$double_quote_subst\" -e \"\$sed_quote_subst\" -e \"\$delay_variable_subst\"\`\\\""
+ eval "lt_$var=\\\"\`\$echo \"X\$$var\" | \$Xsed -e \"\$sed_quote_subst\"\`\\\""
+ esac
+ done
+ case $lt_echo in
+ *'\$0 --fallback-echo"')
+ lt_echo=`$echo "X$lt_echo" | $Xsed -e 's/\\\\\\\$0 --fallback-echo"$/$0 --fallback-echo"/'`
+ esac
+cfgfile="$ofile"
+ cat <<__EOF__ >> "$cfgfile"
+# ### BEGIN LIBTOOL TAG CONFIG: $tagname
+# Libtool was configured on host `(hostname || uname -n) 2>/dev/null | sed 1q`:
+# Shell to use when invoking shell scripts.
+SHELL=$lt_SHELL
+# Whether or not to build shared libraries.
+build_libtool_libs=$enable_shared
+# Whether or not to build static libraries.
+build_old_libs=$enable_static
+# Whether or not to add -lc for building shared libraries.
+build_libtool_need_lc=$archive_cmds_need_lc_CXX
+# Whether or not to disallow shared libs when runtime libs are static
+allow_libtool_libs_with_static_runtimes=$enable_shared_with_static_runtimes_CXX
+# Whether or not to optimize for fast installation.
+fast_install=$enable_fast_install
+# The host system.
+host_alias=$host_alias
+host=$host
+host_os=$host_os
+# The build system.
+build_alias=$build_alias
+build=$build
+build_os=$build_os
+# An echo program that does not interpret backslashes.
+echo=$lt_echo
+# The archiver.
+AR=$lt_AR
+AR_FLAGS=$lt_AR_FLAGS
+# A C compiler.
+LTCC=$lt_LTCC
+# LTCC compiler flags.
+LTCFLAGS=$lt_LTCFLAGS
+# A language-specific compiler.
+CC=$lt_compiler_CXX
+# Is the compiler the GNU C compiler?
+with_gcc=$GCC_CXX
+# An ERE matcher.
+EGREP=$lt_EGREP
+# The linker used to build libraries.
+LD=$lt_LD_CXX
+# Whether we need hard or soft links.
+LN_S=$lt_LN_S
+# A BSD-compatible nm program.
+NM=$lt_NM
+# A symbol stripping program
+STRIP=$lt_STRIP
+# Used to examine libraries when file_magic_cmd begins "file"
+MAGIC_CMD=$MAGIC_CMD
+# Used on cygwin: DLL creation program.
+DLLTOOL="$DLLTOOL"
+# Used on cygwin: object dumper.
+OBJDUMP="$OBJDUMP"
+# Used on cygwin: assembler.
+AS="$AS"
+# The name of the directory that contains temporary libtool files.
+objdir=$objdir
+# How to create reloadable object files.
+reload_flag=$lt_reload_flag
+reload_cmds=$lt_reload_cmds
+# How to pass a linker flag through the compiler.
+wl=$lt_lt_prog_compiler_wl_CXX
+# Object file suffix (normally "o").
+objext="$ac_objext"
+# Old archive suffix (normally "a").
+libext="$libext"
+# Shared library suffix (normally ".so").
+shrext_cmds='$shrext_cmds'
+# Executable file suffix (normally "").
+exeext="$exeext"
+# Additional compiler flags for building library objects.
+pic_flag=$lt_lt_prog_compiler_pic_CXX
+pic_mode=$pic_mode
+# What is the maximum length of a command?
+max_cmd_len=$lt_cv_sys_max_cmd_len
+# Does compiler simultaneously support -c and -o options?
+compiler_c_o=$lt_lt_cv_prog_compiler_c_o_CXX
+# Must we lock files when doing compilation?
+need_locks=$lt_need_locks
+# Do we need the lib prefix for modules?
+need_lib_prefix=$need_lib_prefix
+# Do we need a version for libraries?
+need_version=$need_version
+# Whether dlopen is supported.
+dlopen_support=$enable_dlopen
+# Whether dlopen of programs is supported.
+dlopen_self=$enable_dlopen_self
+# Whether dlopen of statically linked programs is supported.
+dlopen_self_static=$enable_dlopen_self_static
+# Compiler flag to prevent dynamic linking.
+link_static_flag=$lt_lt_prog_compiler_static_CXX
+# Compiler flag to turn off builtin functions.
+no_builtin_flag=$lt_lt_prog_compiler_no_builtin_flag_CXX
+# Compiler flag to allow reflexive dlopens.
+export_dynamic_flag_spec=$lt_export_dynamic_flag_spec_CXX
+# Compiler flag to generate shared objects directly from archives.
+whole_archive_flag_spec=$lt_whole_archive_flag_spec_CXX
+# Compiler flag to generate thread-safe objects.
+thread_safe_flag_spec=$lt_thread_safe_flag_spec_CXX
+# Library versioning type.
+version_type=$version_type
+# Format of library name prefix.
+libname_spec=$lt_libname_spec
+# List of archive names. First name is the real one, the rest are links.
+# The last name is the one that the linker finds with -lNAME.
+library_names_spec=$lt_library_names_spec
+# The coded name of the library, if different from the real name.
+soname_spec=$lt_soname_spec
+# Commands used to build and install an old-style archive.
+RANLIB=$lt_RANLIB
+old_archive_cmds=$lt_old_archive_cmds_CXX
+old_postinstall_cmds=$lt_old_postinstall_cmds
+old_postuninstall_cmds=$lt_old_postuninstall_cmds
+# Create an old-style archive from a shared archive.
+old_archive_from_new_cmds=$lt_old_archive_from_new_cmds_CXX
+# Create a temporary old-style archive to link instead of a shared archive.
+old_archive_from_expsyms_cmds=$lt_old_archive_from_expsyms_cmds_CXX
+# Commands used to build and install a shared archive.
+archive_cmds=$lt_archive_cmds_CXX
+archive_expsym_cmds=$lt_archive_expsym_cmds_CXX
+postinstall_cmds=$lt_postinstall_cmds
+postuninstall_cmds=$lt_postuninstall_cmds
+# Commands used to build a loadable module (assumed same as above if empty)
+module_cmds=$lt_module_cmds_CXX
+module_expsym_cmds=$lt_module_expsym_cmds_CXX
+# Commands to strip libraries.
+old_striplib=$lt_old_striplib
+striplib=$lt_striplib
+# Dependencies to place before the objects being linked to create a
+# shared library.
+predep_objects=$lt_predep_objects_CXX
+# Dependencies to place after the objects being linked to create a
+# shared library.
+postdep_objects=$lt_postdep_objects_CXX
+# shared library.
+predeps=$lt_predeps_CXX
+# shared library.
+postdeps=$lt_postdeps_CXX
+# The library search path used internally by the compiler when linking
+# a shared library.
+compiler_lib_search_path=$lt_compiler_lib_search_path_CXX
+# Method to check whether dependent libraries are shared objects.
+deplibs_check_method=$lt_deplibs_check_method
+# Command to use when deplibs_check_method == file_magic.
+file_magic_cmd=$lt_file_magic_cmd
+# Flag that allows shared libraries with undefined symbols to be built.
+allow_undefined_flag=$lt_allow_undefined_flag_CXX
+# Flag that forces no undefined symbols.
+no_undefined_flag=$lt_no_undefined_flag_CXX
+# Commands used to finish a libtool library installation in a directory.
+finish_cmds=$lt_finish_cmds
+# Same as above, but a single script fragment to be evaled but not shown.
+finish_eval=$lt_finish_eval
+# Take the output of nm and produce a listing of raw symbols and C names.
+global_symbol_pipe=$lt_lt_cv_sys_global_symbol_pipe
+# Transform the output of nm in a proper C declaration
+global_symbol_to_cdecl=$lt_lt_cv_sys_global_symbol_to_cdecl
+# Transform the output of nm in a C name address pair
+global_symbol_to_c_name_address=$lt_lt_cv_sys_global_symbol_to_c_name_address
+# This is the shared library runtime path variable.
+runpath_var=$runpath_var
+# This is the shared library path variable.
+shlibpath_var=$shlibpath_var
+# Is shlibpath searched before the hard-coded library search path?
+shlibpath_overrides_runpath=$shlibpath_overrides_runpath
+# How to hardcode a shared library path into an executable.
+hardcode_action=$hardcode_action_CXX
+# Whether we should hardcode library paths into libraries.
+hardcode_into_libs=$hardcode_into_libs
+# Flag to hardcode \$libdir into a binary during linking.
+# This must work even if \$libdir does not exist.
+hardcode_libdir_flag_spec=$lt_hardcode_libdir_flag_spec_CXX
+# If ld is used when linking, flag to hardcode \$libdir into
+# a binary during linking. This must work even if \$libdir does
+# not exist.
+hardcode_libdir_flag_spec_ld=$lt_hardcode_libdir_flag_spec_ld_CXX
+# Whether we need a single -rpath flag with a separated argument.
+hardcode_libdir_separator=$lt_hardcode_libdir_separator_CXX
+# Set to yes if using DIR/libNAME${shared_ext} during linking hardcodes DIR into the
+# resulting binary.
+hardcode_direct=$hardcode_direct_CXX
+# Set to yes if using the -LDIR flag during linking hardcodes DIR into the
+hardcode_minus_L=$hardcode_minus_L_CXX
+# Set to yes if using SHLIBPATH_VAR=DIR during linking hardcodes DIR into
+# the resulting binary.
+hardcode_shlibpath_var=$hardcode_shlibpath_var_CXX
+# Set to yes if building a shared library automatically hardcodes DIR into the library
+# and all subsequent libraries and executables linked against it.
+hardcode_automatic=$hardcode_automatic_CXX
+# Variables whose values should be saved in libtool wrapper scripts and
+# restored at relink time.
+variables_saved_for_relink="$variables_saved_for_relink"
+# Whether libtool must link a program against all its dependency libraries.
+link_all_deplibs=$link_all_deplibs_CXX
+# Compile-time system search path for libraries
+sys_lib_search_path_spec=$lt_sys_lib_search_path_spec
+# Run-time system search path for libraries
+sys_lib_dlsearch_path_spec=$lt_sys_lib_dlsearch_path_spec
+# Fix the shell variable \$srcfile for the compiler.
+fix_srcfile_path="$fix_srcfile_path_CXX"
+# Set to yes if exported symbols are required.
+always_export_symbols=$always_export_symbols_CXX
+# The commands to list exported symbols.
+export_symbols_cmds=$lt_export_symbols_cmds_CXX
+# The commands to extract the exported symbol list from a shared archive.
+extract_expsyms_cmds=$lt_extract_expsyms_cmds
+# Symbols that should not be listed in the preloaded symbols.
+exclude_expsyms=$lt_exclude_expsyms_CXX
+# Symbols that must always be exported.
+include_expsyms=$lt_include_expsyms_CXX
+# ### END LIBTOOL TAG CONFIG: $tagname
+__EOF__
+else
+ # If there is no Makefile yet, we rely on a make rule to execute
+ # `config.status --recheck' to rerun these tests and create the
+ # libtool script then.
+ ltmain_in=`echo $ltmain | sed -e 's/\.sh$/.in/'`
+ if test -f "$ltmain_in"; then
+ test -f Makefile && make "$ltmain"
+ fi
+fi
+ac_ext=cc
+ac_cpp='$CXXCPP $CPPFLAGS'
+ac_compile='$CXX -c $CXXFLAGS $CPPFLAGS conftest.$ac_ext >&5'
+ac_link='$CXX -o conftest$ac_exeext $CXXFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
+ac_compiler_gnu=$ac_cv_cxx_compiler_gnu
+CC=$lt_save_CC
+LDCXX=$LD
+LD=$lt_save_LD
+GCC=$lt_save_GCC
+with_gnu_ldcxx=$with_gnu_ld
+with_gnu_ld=$lt_save_with_gnu_ld
+lt_cv_path_LDCXX=$lt_cv_path_LD
+lt_cv_path_LD=$lt_save_path_LD
+lt_cv_prog_gnu_ldcxx=$lt_cv_prog_gnu_ld
+lt_cv_prog_gnu_ld=$lt_save_with_gnu_ld
+ else
+ tagname=""
+ fi
+ F77)
+ if test -n "$F77" && test "X$F77" != "Xno"; then
+ac_ext=f
+ac_compile='$F77 -c $FFLAGS conftest.$ac_ext >&5'
+ac_link='$F77 -o conftest$ac_exeext $FFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
+ac_compiler_gnu=$ac_cv_f77_compiler_gnu
+archive_cmds_need_lc_F77=no
+allow_undefined_flag_F77=
+always_export_symbols_F77=no
+archive_expsym_cmds_F77=
+export_dynamic_flag_spec_F77=
+hardcode_direct_F77=no
+hardcode_libdir_flag_spec_F77=
+hardcode_libdir_flag_spec_ld_F77=
+hardcode_libdir_separator_F77=
+hardcode_minus_L_F77=no
+hardcode_automatic_F77=no
+module_cmds_F77=
+module_expsym_cmds_F77=
+link_all_deplibs_F77=unknown
+old_archive_cmds_F77=$old_archive_cmds
+no_undefined_flag_F77=
+whole_archive_flag_spec_F77=
+enable_shared_with_static_runtimes_F77=no
+# Source file extension for f77 test sources.
+ac_ext=f
+# Object file extension for compiled f77 test sources.
+objext=o
+objext_F77=$objext
+# Code to be used in simple compile tests
+lt_simple_compile_test_code=" subroutine t\n return\n end\n"
+# Code to be used in simple link tests
+lt_simple_link_test_code=" program t\n end\n"
+# ltmain only uses $CC for tagged configurations so make sure $CC is set.
+# If no C compiler was specified, use CC.
+LTCC=${LTCC-"$CC"}
+# If no C compiler flags were specified, use CFLAGS.
+LTCFLAGS=${LTCFLAGS-"$CFLAGS"}
+# Allow CC to be a program name with arguments.
+compiler=$CC
+# save warnings/boilerplate of simple test code
+ac_outfile=conftest.$ac_objext
+printf "$lt_simple_compile_test_code" >conftest.$ac_ext
+eval "$ac_compile" 2>&1 >/dev/null | $SED '/^$/d; /^ *+/d' >conftest.err
+_lt_compiler_boilerplate=`cat conftest.err`
+$rm conftest*
+printf "$lt_simple_link_test_code" >conftest.$ac_ext
+eval "$ac_link" 2>&1 >/dev/null | $SED '/^$/d; /^ *+/d' >conftest.err
+_lt_linker_boilerplate=`cat conftest.err`
+$rm conftest*
+lt_save_CC="$CC"
+CC=${F77-"f77"}
+compiler=$CC
+compiler_F77=$CC
+for cc_temp in $compiler""; do
+ case $cc_temp in
+ compile | *[\\/]compile | ccache | *[\\/]ccache ) ;;
+ distcc | *[\\/]distcc | purify | *[\\/]purify ) ;;
+ *) break;;
+ esac
+done
+cc_basename=`$echo "X$cc_temp" | $Xsed -e 's%.*/%%' -e "s%^$host_alias-%%"`
+echo "$as_me:$LINENO: checking if libtool supports shared libraries" >&5
+echo $ECHO_N "checking if libtool supports shared libraries... $ECHO_C" >&6
+echo "$as_me:$LINENO: result: $can_build_shared" >&5
+echo "${ECHO_T}$can_build_shared" >&6
+echo "$as_me:$LINENO: checking whether to build shared libraries" >&5
+echo $ECHO_N "checking whether to build shared libraries... $ECHO_C" >&6
+test "$can_build_shared" = "no" && enable_shared=no
+# On AIX, shared libraries and static libraries use the same namespace, and
+# are all built from PIC.
+case $host_os in
+aix3*)
+ test "$enable_shared" = yes && enable_static=no
+ if test -n "$RANLIB"; then
+ archive_cmds="$archive_cmds~\$RANLIB \$lib"
+ postinstall_cmds='$RANLIB $lib'
+ fi
+aix4* | aix5*)
+ if test "$host_cpu" != ia64 && test "$aix_use_runtimelinking" = no ; then
+ fi
+esac
+echo "$as_me:$LINENO: result: $enable_shared" >&5
+echo "${ECHO_T}$enable_shared" >&6
+echo "$as_me:$LINENO: checking whether to build static libraries" >&5
+echo $ECHO_N "checking whether to build static libraries... $ECHO_C" >&6
+# Make sure either enable_shared or enable_static is yes.
+test "$enable_shared" = yes || enable_static=yes
+echo "$as_me:$LINENO: result: $enable_static" >&5
+echo "${ECHO_T}$enable_static" >&6
+GCC_F77="$G77"
+LD_F77="$LD"
+lt_prog_compiler_wl_F77=
+lt_prog_compiler_pic_F77=
+lt_prog_compiler_static_F77=
+ lt_prog_compiler_wl_F77='-Wl,'
+ lt_prog_compiler_static_F77='-static'
+ case $host_os in
+ aix*)
+ if test "$host_cpu" = ia64; then
+ lt_prog_compiler_static_F77='-Bstatic'
+ fi
+ amigaos*)
+ # like `-m68040'.
+ lt_prog_compiler_pic_F77='-m68020 -resident32 -malways-restore-a4'
+ mingw* | pw32* | os2*)
+ lt_prog_compiler_pic_F77='-DDLL_EXPORT'
+ darwin* | rhapsody*)
+ lt_prog_compiler_pic_F77='-fno-common'
+ interix3*)
+ msdosdjgpp*)
+ # Just because we use GCC doesn't mean we suddenly get shared libraries
+ # on systems that don't support them.
+ lt_prog_compiler_can_build_shared_F77=no
+ enable_shared=no
+ sysv4*MP*)
+ lt_prog_compiler_pic_F77=-Kconform_pic
+ fi
+ hpux*)
+ case $host_cpu in
+ hppa*64*|ia64*)
+ # +Z the default
+ lt_prog_compiler_pic_F77='-fPIC'
+ esac
+ esac
+ else
+ # PORTME Check for flag to pass linker flags through the system compiler.
+ case $host_os in
+ aix*)
+ else
+ lt_prog_compiler_static_F77='-bnso -bI:/lib/syscalls.exp'
+ fi
+ darwin*)
+ case $cc_basename in
+ xlc*)
+ lt_prog_compiler_pic_F77='-qnocommon'
+ esac
+ case $host_cpu in
+ hppa*64*|ia64*)
+ # +Z the default
+ lt_prog_compiler_pic_F77='+Z'
+ esac
+ # Is there a better lt_prog_compiler_static that works with the bundled CC?
+ lt_prog_compiler_static_F77='${wl}-a ${wl}archive'
+ # PIC (with -KPIC) is the default.
+ lt_prog_compiler_static_F77='-non_shared'
+ newsos6)
+ lt_prog_compiler_pic_F77='-KPIC'
+ linux*)
+ icc* | ecc*)
+ pgcc* | pgf77* | pgf90* | pgf95*)
+ # Portland Group compilers (*not* the Pentium gcc compiler,
+ # which looks to be a dead project)
+ lt_prog_compiler_pic_F77='-fpic'
+ ccc*)
+ # All Alpha code is PIC.
+ esac
+ # All OSF/1 code is PIC.
+ solaris*)
+ f77* | f90* | f95*)
+ lt_prog_compiler_wl_F77='-Qoption ld ';;
+ lt_prog_compiler_wl_F77='-Wl,';;
+ esac
+ sunos4*)
+ lt_prog_compiler_pic_F77='-PIC'
+ sysv4 | sysv4.2uw2* | sysv4.3*)
+ sysv4*MP*)
+ lt_prog_compiler_pic_F77='-Kconform_pic'
+ fi
+ unicos*)
+ uts4*)
+ lt_prog_compiler_pic_F77='-pic'
+ esac
+ fi
+echo "$as_me:$LINENO: result: $lt_prog_compiler_pic_F77" >&5
+echo "${ECHO_T}$lt_prog_compiler_pic_F77" >&6
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+if test -n "$lt_prog_compiler_pic_F77"; then
+echo "$as_me:$LINENO: checking if $compiler PIC flag $lt_prog_compiler_pic_F77 works" >&5
+echo $ECHO_N "checking if $compiler PIC flag $lt_prog_compiler_pic_F77 works... $ECHO_C" >&6
+if test "${lt_prog_compiler_pic_works_F77+set}" = set; then
+else
+ lt_prog_compiler_pic_works_F77=no
+ lt_compiler_flag="$lt_prog_compiler_pic_F77"
+ (eval echo "\"\$as_me:13275: $lt_compile\"" >&5)
+ ac_status=$?
+ echo "$as_me:13279: \$? = $ac_status" >&5
+ lt_prog_compiler_pic_works_F77=yes
+ fi
+ fi
+ $rm conftest*
+fi
+echo "$as_me:$LINENO: result: $lt_prog_compiler_pic_works_F77" >&5
+echo "${ECHO_T}$lt_prog_compiler_pic_works_F77" >&6
+if test x"$lt_prog_compiler_pic_works_F77" = xyes; then
+ case $lt_prog_compiler_pic_F77 in
+ *) lt_prog_compiler_pic_F77=" $lt_prog_compiler_pic_F77" ;;
+ esac
+else
+fi
+fi
+case $host_os in
+ *djgpp*)
+ lt_prog_compiler_pic_F77="$lt_prog_compiler_pic_F77"
+esac
-# #include <stdio.h> /* for printf() */
-# #include <unistd.h> /* for open(), lseek(), read() */
-# #include <fcntl.h> /* for O_RDONLY, O_BINARY */
-# #include <string.h> /* for strdup() */
-# /* O_BINARY isn't required (or even defined sometimes) under Unix */
-# #ifndef O_BINARY
-# #define O_BINARY 0
-# #endif
+wl=$lt_prog_compiler_wl_F77 eval lt_tmp_static_flag=\"$lt_prog_compiler_static_F77\"
+if test "${lt_prog_compiler_static_works_F77+set}" = set; then
+else
+ lt_prog_compiler_static_works_F77=no
+ lt_prog_compiler_static_works_F77=yes
+ fi
+ else
+ fi
+ fi
+ $rm conftest*
+fi
+echo "$as_me:$LINENO: result: $lt_prog_compiler_static_works_F77" >&5
+echo "${ECHO_T}$lt_prog_compiler_static_works_F77" >&6
+if test x"$lt_prog_compiler_static_works_F77" = xyes; then
+else
+fi
+if test "${lt_cv_prog_compiler_c_o_F77+set}" = set; then
+else
+ lt_cv_prog_compiler_c_o_F77=no
+ mkdir conftest
+ cd conftest
+ mkdir out
+ (eval echo "\"\$as_me:13379: $lt_compile\"" >&5)
+ ac_status=$?
+ echo "$as_me:13383: \$? = $ac_status" >&5
+ then
+ lt_cv_prog_compiler_c_o_F77=yes
+ fi
+ fi
+ chmod u+w . 2>&5
+ $rm conftest*
+ cd ..
+ rmdir conftest
+ $rm conftest*
+fi
+echo "$as_me:$LINENO: result: $lt_cv_prog_compiler_c_o_F77" >&5
+echo "${ECHO_T}$lt_cv_prog_compiler_c_o_F77" >&6
+if test "$lt_cv_prog_compiler_c_o_F77" = no && test "$need_locks" != no; then
+ hard_links=yes
+ $rm conftest*
+ touch conftest.a
+ need_locks=warn
+ fi
+else
+ need_locks=no
+fi
+echo "$as_me:$LINENO: checking whether the $compiler linker ($LD) supports shared libraries" >&5
+echo $ECHO_N "checking whether the $compiler linker ($LD) supports shared libraries... $ECHO_C" >&6
+ runpath_var=
+ allow_undefined_flag_F77=
+ enable_shared_with_static_runtimes_F77=no
+ archive_cmds_F77=
+ archive_expsym_cmds_F77=
+ old_archive_From_new_cmds_F77=
+ old_archive_from_expsyms_cmds_F77=
+ export_dynamic_flag_spec_F77=
+ whole_archive_flag_spec_F77=
+ thread_safe_flag_spec_F77=
+ hardcode_libdir_flag_spec_F77=
+ hardcode_libdir_flag_spec_ld_F77=
+ hardcode_libdir_separator_F77=
+ hardcode_direct_F77=no
+ hardcode_minus_L_F77=no
+ hardcode_shlibpath_var_F77=unsupported
+ link_all_deplibs_F77=unknown
+ hardcode_automatic_F77=no
+ module_cmds_F77=
+ module_expsym_cmds_F77=
+ always_export_symbols_F77=no
+ export_symbols_cmds_F77='$NM $libobjs $convenience | $global_symbol_pipe | $SED '\''s/.* //'\'' | sort | uniq > $export_symbols'
+ # include_expsyms should be a list of space-separated symbols to be *always*
+ # included in the symbol list
+ include_expsyms_F77=
+ # exclude_expsyms can be an extended regexp of symbols to exclude
+ # it will be wrapped by ` (' and `)$', so one must not match beginning or
+ # end of line. Example: `a|bc|.*d.*' will exclude the symbols `a' and `bc',
+ # as well as any symbol that contains `d'.
+ exclude_expsyms_F77="_GLOBAL_OFFSET_TABLE_"
+ # Although _GLOBAL_OFFSET_TABLE_ is a valid symbol C name, most a.out
+ # platforms (ab)use it in PIC code, but their linkers get confused if
+ # the symbol is explicitly referenced. Since portable code cannot
+ # rely on this symbol name, it's probably fine to never include it in
+ # preloaded symbol tables.
+ extract_expsyms_cmds=
+ # Just being paranoid about ensuring that cc_basename is set.
+ for cc_temp in $compiler""; do
+ case $cc_temp in
+ *) break;;
+ esac
+done
+ case $host_os in
+ cygwin* | mingw* | pw32*)
+ # FIXME: the MSVC++ port hasn't been tested in a loooong time
+ # When not using gcc, we currently assume that we are using
+ # Microsoft Visual C++.
+ if test "$GCC" != yes; then
+ with_gnu_ld=no
+ fi
+ interix*)
+ # we just hope/assume this is gcc and not c89 (= MSVC++)
+ with_gnu_ld=yes
+ openbsd*)
+ with_gnu_ld=no
+ esac
+ ld_shlibs_F77=yes
+ # If archive_cmds runs LD, not CC, wlarc should be empty
+ wlarc='${wl}'
+ # Set some defaults for GNU ld with shared library support. These
+ # are reset later if shared libraries are not supported. Putting them
+ # here allows them to be overridden if necessary.
+ runpath_var=LD_RUN_PATH
+ hardcode_libdir_flag_spec_F77='${wl}--rpath ${wl}$libdir'
+ export_dynamic_flag_spec_F77='${wl}--export-dynamic'
+ # ancient GNU ld didn't support --whole-archive et. al.
+ if $LD --help 2>&1 | grep 'no-whole-archive' > /dev/null; then
+ whole_archive_flag_spec_F77="$wlarc"'--whole-archive$convenience '"$wlarc"'--no-whole-archive'
+ else
+ fi
+ supports_anon_versioning=no
+ case `$LD -v 2>/dev/null` in
+ *\ [01].* | *\ 2.[0-9].* | *\ 2.10.*) ;; # catch versions < 2.11
+ *\ 2.11.93.0.2\ *) supports_anon_versioning=yes ;; # RH7.3 ...
+ *\ 2.11.92.0.12\ *) supports_anon_versioning=yes ;; # Mandrake 8.2 ...
+ *\ 2.11.*) ;; # other 2.11 versions
+ *) supports_anon_versioning=yes ;;
+ esac
+ # See if GNU ld supports shared libraries.
+ case $host_os in
+ aix3* | aix4* | aix5*)
+ # On AIX/PPC, the GNU linker is very broken
+ ld_shlibs_F77=no
+ cat <<EOF 1>&2
+*** Warning: the GNU linker, at least up to release 2.9.1, is reported
+*** to be unable to reliably create shared libraries on AIX.
+*** Therefore, libtool is disabling shared libraries support. If you
+*** really care for shared libraries, you may want to modify your PATH
+*** so that a non-GNU linker is found, and then restart.
+EOF
+ fi
+ amigaos*)
+ archive_cmds_F77='$rm $output_objdir/a2ixlibrary.data~$echo "#define NAME $libname" > $output_objdir/a2ixlibrary.data~$echo "#define LIBRARY_ID 1" >> $output_objdir/a2ixlibrary.data~$echo "#define VERSION $major" >> $output_objdir/a2ixlibrary.data~$echo "#define REVISION $revision" >> $output_objdir/a2ixlibrary.data~$AR $AR_FLAGS $lib $libobjs~$RANLIB $lib~(cd $output_objdir && a2ixlibrary -32)'
+ hardcode_libdir_flag_spec_F77='-L$libdir'
+ hardcode_minus_L_F77=yes
+ # Samuel A. Falvo II <kc5tja at dolphin.openprojects.net> reports
+ # that the semantics of dynamic libraries on AmigaOS, at least up
+ # to version 4, is to share data among multiple programs linked
+ # with the same dynamic library. Since this doesn't match the
+ # behavior of shared libraries on other platforms, we can't use
+ # them.
+ ld_shlibs_F77=no
+ beos*)
+ if $LD --help 2>&1 | grep ': supported targets:.* elf' > /dev/null; then
+ allow_undefined_flag_F77=unsupported
+ # Joseph Beckenbach <jrb3 at best.com> says some releases of gcc
+ # support --undefined. This deserves some investigation. FIXME
+ archive_cmds_F77='$CC -nostart $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
+ else
+ ld_shlibs_F77=no
+ fi
+ # _LT_AC_TAGVAR(hardcode_libdir_flag_spec, F77) is actually meaningless,
+ # as there is no search path for DLLs.
+ enable_shared_with_static_runtimes_F77=yes
+ export_symbols_cmds_F77='$NM $libobjs $convenience | $global_symbol_pipe | $SED -e '\''/^[BCDGRS] /s/.* \([^ ]*\)/\1 DATA/'\'' | $SED -e '\''/^[AITW] /s/.* //'\'' | sort | uniq > $export_symbols'
+ if $LD --help 2>&1 | grep 'auto-import' > /dev/null; then
+ archive_cmds_F77='$CC -shared $libobjs $deplibs $compiler_flags -o $output_objdir/$soname ${wl}--enable-auto-image-base -Xlinker --out-implib -Xlinker $lib'
+ # If the export-symbols file already is a .def file (1st line
+ # is EXPORTS), use it as is; otherwise, prepend...
+ archive_expsym_cmds_F77='if test "x`$SED 1q $export_symbols`" = xEXPORTS; then
+ cp $export_symbols $output_objdir/$soname.def;
+ else
+ echo EXPORTS > $output_objdir/$soname.def;
+ cat $export_symbols >> $output_objdir/$soname.def;
+ fi~
+ $CC -shared $output_objdir/$soname.def $libobjs $deplibs $compiler_flags -o $output_objdir/$soname ${wl}--enable-auto-image-base -Xlinker --out-implib -Xlinker $lib'
+ else
+ ld_shlibs_F77=no
+ fi
+ interix3*)
+ hardcode_shlibpath_var_F77=no
+ hardcode_libdir_flag_spec_F77='${wl}-rpath,$libdir'
+ export_dynamic_flag_spec_F77='${wl}-E'
+ # Hack: On Interix 3.x, we cannot compile PIC because of a broken gcc.
+ # Instead, shared libraries are loaded at an image base (0x10000000 by
+ # default) and relocated if they conflict, which is a slow very memory
+ # consuming and fragmenting process. To avoid this, we pick a random,
+ # 256 KiB-aligned image base between 0x50000000 and 0x6FFC0000 at link
+ # time. Moving up from 0x10000000 also allows more sbrk(2) space.
+ archive_cmds_F77='$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-h,$soname ${wl}--image-base,`expr ${RANDOM-$$} % 4096 / 2 \* 262144 + 1342177280` -o $lib'
+ archive_expsym_cmds_F77='sed "s,^,_," $export_symbols >$output_objdir/$soname.expsym~$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-h,$soname ${wl}--retain-symbols-file,$output_objdir/$soname.expsym ${wl}--image-base,`expr ${RANDOM-$$} % 4096 / 2 \* 262144 + 1342177280` -o $lib'
+ linux*)
+ tmp_addflag=
+ case $cc_basename,$host_cpu in
+ pgcc*) # Portland Group C compiler
+ whole_archive_flag_spec_F77='${wl}--whole-archive`for conv in $convenience\"\"; do test -n \"$conv\" && new_convenience=\"$new_convenience,$conv\"; done; $echo \"$new_convenience\"` ${wl}--no-whole-archive'
+ tmp_addflag=' $pic_flag'
+ pgf77* | pgf90* | pgf95*) # Portland Group f77 and f90 compilers
+ tmp_addflag=' $pic_flag -Mnomain' ;;
+ ecc*,ia64* | icc*,ia64*) # Intel C compiler on ia64
+ tmp_addflag=' -i_dynamic' ;;
+ efc*,ia64* | ifort*,ia64*) # Intel Fortran compiler on ia64
+ tmp_addflag=' -i_dynamic -nofor_main' ;;
+ ifc* | ifort*) # Intel Fortran compiler
+ tmp_addflag=' -nofor_main' ;;
+ esac
+ archive_cmds_F77='$CC -shared'"$tmp_addflag"' $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
+ if test $supports_anon_versioning = yes; then
+ archive_expsym_cmds_F77='$echo "{ global:" > $output_objdir/$libname.ver~
+ cat $export_symbols | sed -e "s/\(.*\)/\1;/" >> $output_objdir/$libname.ver~
+ $echo "local: *; };" >> $output_objdir/$libname.ver~
+ $CC -shared'"$tmp_addflag"' $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-version-script ${wl}$output_objdir/$libname.ver -o $lib'
+ fi
+ else
+ ld_shlibs_F77=no
+ fi
+ netbsd*)
+ if echo __ELF__ | $CC -E - | grep __ELF__ >/dev/null; then
+ archive_cmds_F77='$LD -Bshareable $libobjs $deplibs $linker_flags -o $lib'
+ wlarc=
+ else
+ archive_cmds_F77='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
+ archive_expsym_cmds_F77='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
+ fi
+ solaris*)
+ if $LD -v 2>&1 | grep 'BFD 2\.8' > /dev/null; then
+ ld_shlibs_F77=no
+ cat <<EOF 1>&2
+*** Warning: The releases 2.8.* of the GNU linker cannot reliably
+*** create shared libraries on Solaris systems. Therefore, libtool
+*** is disabling shared libraries support. We urge you to upgrade GNU
+*** binutils to release 2.9.1 or newer. Another option is to modify
+*** your PATH or compiler configuration so that the native linker is
+*** used, and then restart.
+EOF
+ elif $LD --help 2>&1 | grep ': supported targets:.* elf' > /dev/null; then
+ else
+ ld_shlibs_F77=no
+ fi
+ sysv5* | sco3.2v5* | sco5v6* | unixware* | OpenUNIX*)
+ case `$LD -v 2>&1` in
+ *\ [01].* | *\ 2.[0-9].* | *\ 2.1[0-5].*)
+ ld_shlibs_F77=no
+ cat <<_LT_EOF 1>&2
+*** Warning: Releases of the GNU linker prior to 2.16.91.0.3 can not
+*** reliably create shared libraries on SCO systems. Therefore, libtool
+*** binutils to release 2.16.91.0.3 or newer. Another option is to modify
+_LT_EOF
+ hardcode_libdir_flag_spec_F77='`test -z "$SCOABSPATH" && echo ${wl}-rpath,$libdir`'
+ archive_cmds_F77='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib'
+ archive_expsym_cmds_F77='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname,\${SCOABSPATH:+${install_libdir}/}$soname,-retain-symbols-file,$export_symbols -o $lib'
+ else
+ ld_shlibs_F77=no
+ fi
+ esac
+ sunos4*)
+ archive_cmds_F77='$LD -assert pure-text -Bshareable -o $lib $libobjs $deplibs $linker_flags'
+ wlarc=
+ hardcode_direct_F77=yes
+ else
+ ld_shlibs_F77=no
+ fi
+ esac
+ if test "$ld_shlibs_F77" = no; then
+ runpath_var=
+ fi
+ else
+ # PORTME fill in a description of your system's linker (not GNU ld)
+ case $host_os in
+ aix3*)
+ always_export_symbols_F77=yes
+ archive_expsym_cmds_F77='$LD -o $output_objdir/$soname $libobjs $deplibs $linker_flags -bE:$export_symbols -T512 -H512 -bM:SRE~$AR $AR_FLAGS $lib $output_objdir/$soname'
+ # Note: this linker hardcodes the directories in LIBPATH if there
+ # are no directories specified by -L.
+ if test "$GCC" = yes && test -z "$lt_prog_compiler_static"; then
+ # Neither direct hardcoding nor static linking is supported with a
+ # broken collect2.
+ hardcode_direct_F77=unsupported
+ fi
+ aix4* | aix5*)
+ # On IA64, the linker does run time linking by default, so we don't
+ # have to do anything special.
+ aix_use_runtimelinking=no
+ exp_sym_flag='-Bexport'
+ no_entry_flag=""
+ else
+ export_symbols_cmds_F77='$NM -Bpg $libobjs $convenience | awk '\''{ if (((\$2 == "T") || (\$2 == "D") || (\$2 == "B")) && (substr(\$3,1,1) != ".")) { print \$3 } }'\'' | sort -u > $export_symbols'
+ else
+ export_symbols_cmds_F77='$NM -BCpg $libobjs $convenience | awk '\''{ if (((\$2 == "T") || (\$2 == "D") || (\$2 == "B")) && (substr(\$3,1,1) != ".")) { print \$3 } }'\'' | sort -u > $export_symbols'
+ fi
+ # Test if we are trying to use run time linking or normal
+ # AIX style linking. If -brtl is somewhere in LDFLAGS, we
+ # need to do runtime linking.
+ case $host_os in aix4.[23]|aix4.[23].*|aix5*)
+ for ld_flag in $LDFLAGS; do
+ if (test $ld_flag = "-brtl" || test $ld_flag = "-Wl,-brtl"); then
+ aix_use_runtimelinking=yes
+ break
+ fi
+ done
+ esac
+ exp_sym_flag='-bexport'
+ no_entry_flag='-bnoentry'
+ fi
+ # When large executables or shared objects are built, AIX ld can
+ # have problems creating the table of contents. If linking a library
+ # or program results in "error TOC overflow" add -mminimal-toc to
+ # CXXFLAGS/CFLAGS for g++/gcc. In the cases where that is not
+ # enough to fix the problem, add -Wl,-bbigtoc to LDFLAGS.
+ archive_cmds_F77=''
+ hardcode_libdir_separator_F77=':'
+ link_all_deplibs_F77=yes
+ case $host_os in aix4.[012]|aix4.[012].*)
+ # We only want to do this on AIX 4.2 and lower, the check
+ # below for broken collect2 doesn't work under 4.3+
+ collect2name=`${CC} -print-prog-name=collect2`
+ if test -f "$collect2name" && \
+ strings "$collect2name" | grep resolve_lib_name >/dev/null
+ then
+ # We have reworked collect2
+ else
+ # We have old collect2
+ # It fails to find uninstalled libraries when the uninstalled
+ # path is not listed in the libpath. Setting hardcode_minus_L
+ # to unsupported forces relinking
+ fi
+ esac
+ shared_flag='-shared'
+ if test "$aix_use_runtimelinking" = yes; then
+ shared_flag="$shared_flag "'${wl}-G'
+ fi
+ else
+ # not using gcc
+ # VisualAge C++, Version 5.5 for AIX 5L for IA-64, Beta 3 Release
+ # chokes on -Wl,-G. The following line is correct:
+ shared_flag='-G'
+ else
+ shared_flag='${wl}-G'
+ else
+ shared_flag='${wl}-bM:SRE'
+ fi
+ fi
+ fi
+ # It seems that -bexpall does not export symbols beginning with
+ # underscore (_), so it is better to generate a list of symbols to export.
+ # Warning - without using the other runtime loading flags (-brtl),
+ # -berok will link without error, but may produce a broken library.
+ allow_undefined_flag_F77='-berok'
+ # Determine the default libpath from the value encoded in an empty executable.
+ cat >conftest.$ac_ext <<_ACEOF
+ program main
+ end
+_ACEOF
+rm -f conftest.$ac_objext conftest$ac_exeext
+if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
+ (eval $ac_link) 2>conftest.er1
+ ac_status=$?
+ grep -v '^ *+' conftest.er1 >conftest.err
+ rm -f conftest.er1
+ echo "$as_me:$LINENO: \$? = $ac_status" >&5
+ (exit $ac_status); } &&
+ { ac_try='test -z "$ac_f77_werror_flag"
+ || test ! -s conftest.err'
+ { (eval echo "$as_me:$LINENO: \"$ac_try\"") >&5
+ (eval $ac_try) 2>&5
+ ac_status=$?
+ (exit $ac_status); }; } &&
+ { ac_try='test -s conftest$ac_exeext'
+ ac_status=$?
+ (exit $ac_status); }; }; then
+aix_libpath=`dump -H conftest$ac_exeext 2>/dev/null | $SED -n -e '/Import File Strings/,/^$/ { /^0/ { s/^0 *\(.*\)$/\1/; p; }
+# Check for a 64-bit object if we didn't find anything.
+if test -z "$aix_libpath"; then aix_libpath=`dump -HX64 conftest$ac_exeext 2>/dev/null | $SED -n -e '/Import File Strings/,/^$/ { /^0/ { s/^0 *\(.*\)$/\1/; p; }
+}'`; fi
+else
+ echo "$as_me: failed program was:" >&5
+sed 's/^/| /' conftest.$ac_ext >&5
+fi
+rm -f conftest.err conftest.$ac_objext \
+ conftest$ac_exeext conftest.$ac_ext
+if test -z "$aix_libpath"; then aix_libpath="/usr/lib:/lib"; fi
+ hardcode_libdir_flag_spec_F77='${wl}-blibpath:$libdir:'"$aix_libpath"
+ archive_expsym_cmds_F77="\$CC"' -o $output_objdir/$soname $libobjs $deplibs '"\${wl}$no_entry_flag"' $compiler_flags `if test "x${allow_undefined_flag}" != "x"; then echo "${wl}${allow_undefined_flag}"; else :; fi` '"\${wl}$exp_sym_flag:\$export_symbols $shared_flag"
+ else
+ hardcode_libdir_flag_spec_F77='${wl}-R $libdir:/usr/lib:/lib'
+ allow_undefined_flag_F77="-z nodefs"
+ archive_expsym_cmds_F77="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs '"\${wl}$no_entry_flag"' $compiler_flags ${wl}${allow_undefined_flag} '"\${wl}$exp_sym_flag:\$export_symbols"
+ else
+ program main
+ end
+_ACEOF
+ ac_status=$?
+ cat conftest.err >&5
+ ac_status=$?
+ ac_status=$?
+}'`; fi
+else
+fi
+ # Warning - without using the other run time loading flags,
+ no_undefined_flag_F77=' ${wl}-bernotok'
+ allow_undefined_flag_F77=' ${wl}-berok'
+ # Exported symbols can be pulled into shared objects from archives
+ whole_archive_flag_spec_F77='$convenience'
+ archive_cmds_need_lc_F77=yes
+ # This is similar to how AIX traditionally builds its shared libraries.
+ archive_expsym_cmds_F77="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs ${wl}-bnoentry $compiler_flags ${wl}-bE:$export_symbols${allow_undefined_flag}~$AR $AR_FLAGS $output_objdir/$libname$release.a $output_objdir/$soname'
+ fi
+ fi
+ amigaos*)
+ # see comment about different semantics on the GNU ld section
+ ld_shlibs_F77=no
+ bsdi[45]*)
+ export_dynamic_flag_spec_F77=-rdynamic
+ # hardcode_libdir_flag_spec is actually meaningless, as there is
+ # no search path for DLLs.
+ hardcode_libdir_flag_spec_F77=' '
+ # Tell ltmain to make .lib files, not .a files.
+ libext=lib
+ # Tell ltmain to make .dll files, not .so files.
+ # FIXME: Setting linknames here is a bad hack.
+ archive_cmds_F77='$CC -o $lib $libobjs $compiler_flags `echo "$deplibs" | $SED -e '\''s/ -lc$//'\''` -link -dll~linknames='
+ # The linker will automatically build a .lib file if we build a DLL.
+ old_archive_From_new_cmds_F77='true'
+ # FIXME: Should let the user specify the lib program.
+ old_archive_cmds_F77='lib /OUT:$oldlib$oldobjs$old_deplibs'
+ fix_srcfile_path_F77='`cygpath -w "$srcfile"`'
+ case $host_os in
+ rhapsody* | darwin1.[012])
+ allow_undefined_flag_F77='${wl}-undefined ${wl}suppress'
+ *) # Darwin 1.3 on
+ if test -z ${MACOSX_DEPLOYMENT_TARGET} ; then
+ allow_undefined_flag_F77='${wl}-flat_namespace ${wl}-undefined ${wl}suppress'
+ else
+ case ${MACOSX_DEPLOYMENT_TARGET} in
+ 10.[012])
+ 10.*)
+ allow_undefined_flag_F77='${wl}-undefined ${wl}dynamic_lookup'
+ esac
+ fi
+ esac
+ archive_cmds_need_lc_F77=no
+ hardcode_automatic_F77=yes
+ whole_archive_flag_spec_F77=''
+ if test "$GCC" = yes ; then
+ output_verbose_link_cmd='echo'
+ archive_cmds_F77='$CC -dynamiclib $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring'
+ module_cmds_F77='$CC $allow_undefined_flag -o $lib -bundle $libobjs $deplibs$compiler_flags'
+ # Don't fix this by using the ld -exported_symbols_list flag, it doesn't exist in older darwin lds
+ archive_expsym_cmds_F77='sed -e "s,#.*,," -e "s,^[ ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -dynamiclib $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
+ module_expsym_cmds_F77='sed -e "s,#.*,," -e "s,^[ ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC $allow_undefined_flag -o $lib -bundle $libobjs $deplibs$compiler_flags~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
+ else
+ xlc*)
+ archive_cmds_F77='$CC -qmkshrobj $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-install_name ${wl}`echo $rpath/$soname` $verstring'
+ archive_expsym_cmds_F77='sed -e "s,#.*,," -e "s,^[ ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -qmkshrobj $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-install_name ${wl}$rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
+ ld_shlibs_F77=no
+ esac
+ fi
+ dgux*)
+ archive_cmds_F77='$LD -G -h $soname -o $lib $libobjs $deplibs $linker_flags'
+ freebsd1*)
+ ld_shlibs_F77=no
+ # FreeBSD 2.2.[012] allows us to include c++rt0.o to get C++ constructor
+ # support. Future versions do this automatically, but an explicit c++rt0.o
+ # does not break anything, and helps significantly (at the cost of a little
+ # extra space).
+ freebsd2.2*)
+ archive_cmds_F77='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags /usr/lib/c++rt0.o'
+ hardcode_libdir_flag_spec_F77='-R$libdir'
+ # Unfortunately, older versions of FreeBSD 2 do not have this feature.
+ freebsd2*)
+ archive_cmds_F77='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags'
+ # FreeBSD 3 and greater uses gcc -shared to do shared libraries.
+ freebsd* | kfreebsd*-gnu | dragonfly*)
+ archive_cmds_F77='$CC -shared -o $lib $libobjs $deplibs $compiler_flags'
+ hpux9*)
+ archive_cmds_F77='$rm $output_objdir/$soname~$CC -shared -fPIC ${wl}+b ${wl}$install_libdir -o $output_objdir/$soname $libobjs $deplibs $compiler_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
+ else
+ archive_cmds_F77='$rm $output_objdir/$soname~$LD -b +b $install_libdir -o $output_objdir/$soname $libobjs $deplibs $linker_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
+ fi
+ hardcode_libdir_flag_spec_F77='${wl}+b ${wl}$libdir'
+ hardcode_libdir_separator_F77=:
+ # hardcode_minus_L: Not really in the search PATH,
+ # but as the default location of the library.
+ hpux10*)
+ if test "$GCC" = yes -a "$with_gnu_ld" = no; then
+ archive_cmds_F77='$CC -shared -fPIC ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $libobjs $deplibs $compiler_flags'
+ else
+ archive_cmds_F77='$LD -b +h $soname +b $install_libdir -o $lib $libobjs $deplibs $linker_flags'
+ fi
+ if test "$with_gnu_ld" = no; then
+ fi
+ hpux11*)
+ case $host_cpu in
+ hppa*64*)
+ archive_cmds_F77='$CC -shared ${wl}+h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
+ ia64*)
+ archive_cmds_F77='$CC -shared ${wl}+h ${wl}$soname ${wl}+nodefaultrpath -o $lib $libobjs $deplibs $compiler_flags'
+ esac
+ else
+ case $host_cpu in
+ hppa*64*)
+ archive_cmds_F77='$CC -b ${wl}+h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
+ ia64*)
+ archive_cmds_F77='$CC -b ${wl}+h ${wl}$soname ${wl}+nodefaultrpath -o $lib $libobjs $deplibs $compiler_flags'
+ archive_cmds_F77='$CC -b ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $libobjs $deplibs $compiler_flags'
+ esac
+ fi
+ case $host_cpu in
+ hppa*64*|ia64*)
+ hardcode_libdir_flag_spec_ld_F77='+b $libdir'
+ esac
+ fi
+ irix5* | irix6* | nonstopux*)
+ archive_cmds_F77='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
+ else
+ archive_cmds_F77='$LD -shared $libobjs $deplibs $linker_flags -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
+ hardcode_libdir_flag_spec_ld_F77='-rpath $libdir'
+ fi
+ hardcode_libdir_flag_spec_F77='${wl}-rpath ${wl}$libdir'
+ netbsd*)
+ archive_cmds_F77='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags' # a.out
+ else
+ archive_cmds_F77='$LD -shared -o $lib $libobjs $deplibs $linker_flags' # ELF
+ fi
+ newsos6)
+ openbsd*)
+ if test -z "`echo __ELF__ | $CC -E - | grep __ELF__`" || test "$host_os-$host_cpu" = "openbsd2.8-powerpc"; then
+ archive_cmds_F77='$CC -shared $pic_flag -o $lib $libobjs $deplibs $compiler_flags'
+ archive_expsym_cmds_F77='$CC -shared $pic_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-retain-symbols-file,$export_symbols'
+ else
+ case $host_os in
+ openbsd[01].* | openbsd2.[0-7] | openbsd2.[0-7].*)
+ esac
+ fi
+ os2*)
+ archive_cmds_F77='$echo "LIBRARY $libname INITINSTANCE" > $output_objdir/$libname.def~$echo "DESCRIPTION \"$libname\"" >> $output_objdir/$libname.def~$echo DATA >> $output_objdir/$libname.def~$echo " SINGLE NONSHARED" >> $output_objdir/$libname.def~$echo EXPORTS >> $output_objdir/$libname.def~emxexp $libobjs >> $output_objdir/$libname.def~$CC -Zdll -Zcrtdll -o $lib $libobjs $deplibs $compiler_flags $output_objdir/$libname.def'
+ old_archive_From_new_cmds_F77='emximp -o $output_objdir/$libname.a $output_objdir/$libname.def'
+ osf3*)
+ allow_undefined_flag_F77=' ${wl}-expect_unresolved ${wl}\*'
+ archive_cmds_F77='$CC -shared${allow_undefined_flag} $libobjs $deplibs $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
+ else
+ allow_undefined_flag_F77=' -expect_unresolved \*'
+ archive_cmds_F77='$LD -shared${allow_undefined_flag} $libobjs $deplibs $linker_flags -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
+ fi
+ osf4* | osf5*) # as osf3* with the addition of -msym flag
+ archive_cmds_F77='$CC -shared${allow_undefined_flag} $libobjs $deplibs $compiler_flags ${wl}-msym ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
+ else
+ archive_cmds_F77='$LD -shared${allow_undefined_flag} $libobjs $deplibs $linker_flags -msym -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
+ archive_expsym_cmds_F77='for i in `cat $export_symbols`; do printf "%s %s\\n" -exported_symbol "\$i" >> $lib.exp; done; echo "-hidden">> $lib.exp~
+ $LD -shared${allow_undefined_flag} -input $lib.exp $linker_flags $libobjs $deplibs -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib~$rm $lib.exp'
+ # Both c and cxx compiler support -rpath directly
+ hardcode_libdir_flag_spec_F77='-rpath $libdir'
+ fi
+ solaris*)
+ no_undefined_flag_F77=' -z text'
+ wlarc='${wl}'
+ archive_cmds_F77='$CC -shared ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
+ archive_expsym_cmds_F77='$echo "{ global:" > $lib.exp~cat $export_symbols | $SED -e "s/\(.*\)/\1;/" >> $lib.exp~$echo "local: *; };" >> $lib.exp~
+ $CC -shared ${wl}-M ${wl}$lib.exp ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags~$rm $lib.exp'
+ else
+ wlarc=''
+ archive_cmds_F77='$LD -G${allow_undefined_flag} -h $soname -o $lib $libobjs $deplibs $linker_flags'
+ $LD -G${allow_undefined_flag} -M $lib.exp -h $soname -o $lib $libobjs $deplibs $linker_flags~$rm $lib.exp'
+ fi
+ case $host_os in
+ solaris2.[0-5] | solaris2.[0-5].*) ;;
+ # The compiler driver will combine linker options so we
+ # cannot just pass the convience library names through
+ # without $wl, iff we do not link with $LD.
+ # Luckily, gcc supports the same syntax we need for Sun Studio.
+ # Supported since Solaris 2.6 (maybe 2.5.1?)
+ case $wlarc in
+ whole_archive_flag_spec_F77='-z allextract$convenience -z defaultextract' ;;
+ whole_archive_flag_spec_F77='${wl}-z ${wl}allextract`for conv in $convenience\"\"; do test -n \"$conv\" && new_convenience=\"$new_convenience,$conv\"; done; $echo \"$new_convenience\"` ${wl}-z ${wl}defaultextract' ;;
+ esac ;;
+ esac
+ sunos4*)
+ if test "x$host_vendor" = xsequent; then
+ # Use $CC to link under sequent, because it throws in some extra .o
+ # files that make .init and .fini sections work.
+ archive_cmds_F77='$CC -G ${wl}-h $soname -o $lib $libobjs $deplibs $compiler_flags'
+ else
+ archive_cmds_F77='$LD -assert pure-text -Bstatic -o $lib $libobjs $deplibs $linker_flags'
+ fi
+ sysv4)
+ sni)
+ hardcode_direct_F77=yes # is this really true???
+ siemens)
+ ## LD is ld it makes a PLAMLIB
+ ## CC just makes a GrossModule.
+ archive_cmds_F77='$LD -G -o $lib $libobjs $deplibs $linker_flags'
+ reload_cmds_F77='$CC -r -o $output$reload_objs'
+ motorola)
+ hardcode_direct_F77=no #Motorola manual says yes, but my tests say they lie
+ esac
+ runpath_var='LD_RUN_PATH'
+ sysv4.3*)
+ export_dynamic_flag_spec_F77='-Bexport'
+ sysv4*MP*)
+ if test -d /usr/nec; then
+ hardcode_runpath_var=yes
+ ld_shlibs_F77=yes
+ fi
+ sysv4*uw2* | sysv5OpenUNIX* | sysv5UnixWare7.[01].[10]* | unixware7*)
+ no_undefined_flag_F77='${wl}-z,text'
+ archive_cmds_F77='$CC -shared ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+ archive_expsym_cmds_F77='$CC -shared ${wl}-Bexport:$export_symbols ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+ else
+ archive_cmds_F77='$CC -G ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+ archive_expsym_cmds_F77='$CC -G ${wl}-Bexport:$export_symbols ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+ fi
+ sysv5* | sco3.2v5* | sco5v6*)
+ # Note: We can NOT use -z defs as we might desire, because we do not
+ # link with -lc, and that would cause any symbols used from libc to
+ # always be unresolved, which means just about no library would
+ # ever link correctly. If we're not using GNU ld we use -z text
+ # though, which does catch some bad symbols but isn't as heavy-handed
+ # as -z defs.
+ allow_undefined_flag_F77='${wl}-z,nodefs'
+ hardcode_libdir_flag_spec_F77='`test -z "$SCOABSPATH" && echo ${wl}-R,$libdir`'
+ export_dynamic_flag_spec_F77='${wl}-Bexport'
+ archive_cmds_F77='$CC -shared ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+ archive_expsym_cmds_F77='$CC -shared ${wl}-Bexport:$export_symbols ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+ else
+ archive_cmds_F77='$CC -G ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+ archive_expsym_cmds_F77='$CC -G ${wl}-Bexport:$export_symbols ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+ fi
+ uts4*)
+ ld_shlibs_F77=no
+ esac
+ fi
+echo "$as_me:$LINENO: result: $ld_shlibs_F77" >&5
+echo "${ECHO_T}$ld_shlibs_F77" >&6
+test "$ld_shlibs_F77" = no && can_build_shared=no
-# static unsigned int
-# pe_get16 (fd, offset)
-# int fd;
-# int offset;
-# unsigned char b[2];
-# lseek (fd, offset, SEEK_SET);
-# read (fd, b, 2);
-# return b[0] + (b[1]<<8);
+# Do we need to explicitly link libc?
-# pe_get32 (fd, offset)
-# int fd;
-# int offset;
-# unsigned char b[4];
-# read (fd, b, 4);
-# return b[0] + (b[1]<<8) + (b[2]<<16) + (b[3]<<24);
+case "x$archive_cmds_need_lc_F77" in
+x|xyes)
+ # Assume -lc should be added
+ if test "$enable_shared" = yes && test "$GCC" = yes; then
+ case $archive_cmds_F77 in
+ # FIXME: we may have to deal with multi-command sequences.
+ '$CC '*)
+ # Test whether the compiler implicitly links with -lc since on some
+ # systems, -lgcc has to come before -lc. If gcc already passes -lc
+ # to ld, don't add -lc before -lgcc.
+ echo "$as_me:$LINENO: checking whether -lc should be explicitly linked in" >&5
+echo $ECHO_N "checking whether -lc should be explicitly linked in... $ECHO_C" >&6
+ $rm conftest*
+ printf "$lt_simple_compile_test_code" > conftest.$ac_ext
+ if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
+ (eval $ac_compile) 2>&5
+ ac_status=$?
+ (exit $ac_status); } 2>conftest.err; then
+ soname=conftest
+ lib=conftest
+ libobjs=conftest.$ac_objext
+ deplibs=
+ wl=$lt_prog_compiler_wl_F77
+ pic_flag=$lt_prog_compiler_pic_F77
+ compiler_flags=-v
+ linker_flags=-v
+ verstring=
+ output_objdir=.
+ libname=conftest
+ lt_save_allow_undefined_flag=$allow_undefined_flag_F77
+ if { (eval echo "$as_me:$LINENO: \"$archive_cmds_F77 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1\"") >&5
+ (eval $archive_cmds_F77 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1) 2>&5
+ ac_status=$?
+ then
+ else
+ fi
+ allow_undefined_flag_F77=$lt_save_allow_undefined_flag
+ else
+ cat conftest.err 1>&5
+ fi
+ $rm conftest*
+ echo "$as_me:$LINENO: result: $archive_cmds_need_lc_F77" >&5
+echo "${ECHO_T}$archive_cmds_need_lc_F77" >&6
+ esac
+ fi
+esac
+echo "$as_me:$LINENO: checking dynamic linker characteristics" >&5
+echo $ECHO_N "checking dynamic linker characteristics... $ECHO_C" >&6
+libname_spec='lib$name'
+soname_spec=
+shrext_cmds=".so"
+postinstall_cmds=
+finish_cmds=
+finish_eval=
+shlibpath_var=
+shlibpath_overrides_runpath=unknown
+version_type=none
+dynamic_linker="$host_os ld.so"
+sys_lib_dlsearch_path_spec="/lib /usr/lib"
+if test "$GCC" = yes; then
+ sys_lib_search_path_spec=`$CC -print-search-dirs | grep "^libraries:" | $SED -e "s/^libraries://" -e "s,=/,/,g"`
+ if echo "$sys_lib_search_path_spec" | grep ';' >/dev/null ; then
+ # if the path contains ";" then we assume it to be the separator
+ # otherwise default to the standard path separator (i.e. ":") - it is
+ # assumed that no part of a normal pathname contains ";" but that should
+ # okay in the real world where ";" in dirpaths is itself problematic.
+ sys_lib_search_path_spec=`echo "$sys_lib_search_path_spec" | $SED -e 's/;/ /g'`
+ else
+ sys_lib_search_path_spec=`echo "$sys_lib_search_path_spec" | $SED -e "s/$PATH_SEPARATOR/ /g"`
+ fi
+else
+ sys_lib_search_path_spec="/lib /usr/lib /usr/local/lib"
+fi
+need_lib_prefix=unknown
+hardcode_into_libs=no
+# when you set need_version to no, make sure it does not cause -set_version
+# flags to be left without arguments
+need_version=unknown
+case $host_os in
+aix3*)
+ version_type=linux
+ library_names_spec='${libname}${release}${shared_ext}$versuffix $libname.a'
+ shlibpath_var=LIBPATH
+ # AIX 3 has no versioning support, so we append a major version to the name.
+ soname_spec='${libname}${release}${shared_ext}$major'
+aix4* | aix5*)
+ need_lib_prefix=no
+ need_version=no
+ hardcode_into_libs=yes
+ # AIX 5 supports IA64
+ library_names_spec='${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext}$versuffix $libname${shared_ext}'
+ shlibpath_var=LD_LIBRARY_PATH
+ else
+ # With GCC up to 2.95.x, collect2 would create an import file
+ # for dependence libraries. The import file would start with
+ # the line `#! .'. This would cause the generated library to
+ # depend on `.', always an invalid library. This was fixed in
+ # development snapshots of GCC prior to 3.0.
+ case $host_os in
+ aix4 | aix4.[01] | aix4.[01].*)
+ if { echo '#if __GNUC__ > 2 || (__GNUC__ == 2 && __GNUC_MINOR__ >= 97)'
+ echo ' yes '
+ echo '#endif'; } | ${CC} -E - | grep yes > /dev/null; then
+ else
+ can_build_shared=no
+ fi
+ esac
+ # AIX (on Power*) has no versioning support, so currently we can not hardcode correct
+ # soname into executable. Probably we can add versioning support to
+ # collect2, so additional links can be useful in future.
+ # If using run time linking (on AIX 4.2 or later) use lib<name>.so
+ # instead of lib<name>.a to let people know that these are not
+ # typical AIX shared libraries.
+ library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname${shared_ext}'
+ else
+ # We preserve .a as extension for shared libraries through AIX4.2
+ # and later when we are not doing run time linking.
+ library_names_spec='${libname}${release}.a $libname.a'
+ fi
+ fi
+amigaos*)
+ library_names_spec='$libname.ixlibrary $libname.a'
+ # Create ${libname}_ixlibrary.a entries in /sys/libs.
+ finish_eval='for lib in `ls $libdir/*.ixlibrary 2>/dev/null`; do libname=`$echo "X$lib" | $Xsed -e '\''s%^.*/\([^/]*\)\.ixlibrary$%\1%'\''`; test $rm /sys/libs/${libname}_ixlibrary.a; $show "cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a"; cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a || exit 1; done'
+beos*)
+ library_names_spec='${libname}${shared_ext}'
+ dynamic_linker="$host_os ld.so"
+ shlibpath_var=LIBRARY_PATH
+bsdi[45]*)
+ need_version=no
+ finish_cmds='PATH="\$PATH:/sbin" ldconfig $libdir'
+ sys_lib_search_path_spec="/shlib /usr/lib /usr/X11/lib /usr/contrib/lib /lib /usr/local/lib"
+ sys_lib_dlsearch_path_spec="/shlib /usr/lib /usr/local/lib"
+ # the default ld.so.conf also contains /usr/contrib/lib and
+ # /usr/X11R6/lib (/usr/X11 is a link to /usr/X11R6), but let us allow
+ # libtool to hard-code these into programs
+cygwin* | mingw* | pw32*)
+ version_type=windows
+ shrext_cmds=".dll"
+ need_version=no
+ case $GCC,$host_os in
+ yes,cygwin* | yes,mingw* | yes,pw32*)
+ library_names_spec='$libname.dll.a'
+ # DLL is installed to $(libdir)/../bin by postinstall_cmds
+ postinstall_cmds='base_file=`basename \${file}`~
+ dlpath=`$SHELL 2>&1 -c '\''. $dir/'\''\${base_file}'\''i;echo \$dlname'\''`~
+ dldir=$destdir/`dirname \$dlpath`~
+ test -d \$dldir || mkdir -p \$dldir~
+ $install_prog $dir/$dlname \$dldir/$dlname~
+ chmod a+x \$dldir/$dlname'
+ postuninstall_cmds='dldll=`$SHELL 2>&1 -c '\''. $file; echo \$dlname'\''`~
+ dlpath=$dir/\$dldll~
+ $rm \$dlpath'
+ shlibpath_overrides_runpath=yes
+ case $host_os in
+ cygwin*)
+ # Cygwin DLLs use 'cyg' prefix rather than 'lib'
+ soname_spec='`echo ${libname} | sed -e 's/^lib/cyg/'``echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
+ sys_lib_search_path_spec="/usr/lib /lib/w32api /lib /usr/local/lib"
+ mingw*)
+ # MinGW DLLs use traditional 'lib' prefix
+ soname_spec='${libname}`echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
+ if echo "$sys_lib_search_path_spec" | grep ';[c-zC-Z]:/' >/dev/null; then
+ # It is most probably a Windows format PATH printed by
+ # mingw gcc, but we are running on Cygwin. Gcc prints its search
+ # path with ; separators, and with drive letters. We can handle the
+ # drive letters (cygwin fileutils understands them), so leave them,
+ # especially as we might pass files found there to a mingw objdump,
+ # which wouldn't understand a cygwinified path. Ahh.
+ else
+ fi
+ pw32*)
+ # pw32 DLLs use 'pw' prefix rather than 'lib'
+ library_names_spec='`echo ${libname} | sed -e 's/^lib/pw/'``echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
+ esac
+ library_names_spec='${libname}`echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext} $libname.lib'
+ esac
+ dynamic_linker='Win32 ld.exe'
+ # FIXME: first we should search . and the directory the executable is in
+ shlibpath_var=PATH
+darwin* | rhapsody*)
+ dynamic_linker="$host_os dyld"
+ version_type=darwin
+ need_version=no
+ library_names_spec='${libname}${release}${versuffix}$shared_ext ${libname}${release}${major}$shared_ext ${libname}$shared_ext'
+ soname_spec='${libname}${release}${major}$shared_ext'
+ shlibpath_var=DYLD_LIBRARY_PATH
+ shrext_cmds='`test .$module = .yes && echo .so || echo .dylib`'
+ # Apple's gcc prints 'gcc -print-search-dirs' doesn't operate the same.
+ if test "$GCC" = yes; then
+ sys_lib_search_path_spec=`$CC -print-search-dirs | tr "\n" "$PATH_SEPARATOR" | sed -e 's/libraries:/@libraries:/' | tr "@" "\n" | grep "^libraries:" | sed -e "s/^libraries://" -e "s,=/,/,g" -e "s,$PATH_SEPARATOR, ,g" -e "s,.*,& /lib /usr/lib /usr/local/lib,g"`
+ else
+ sys_lib_search_path_spec='/lib /usr/lib /usr/local/lib'
+ fi
+ sys_lib_dlsearch_path_spec='/usr/local/lib /lib /usr/lib'
+dgux*)
+ need_version=no
+ library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname$shared_ext'
+freebsd1*)
+ dynamic_linker=no
+kfreebsd*-gnu)
+ need_version=no
+ library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${shared_ext}'
+ shlibpath_overrides_runpath=no
+ dynamic_linker='GNU ld.so'
+freebsd* | dragonfly*)
+ # DragonFly does not have aout. When/if they implement a new
+ # versioning mechanism, adjust this.
+ if test -x /usr/bin/objformat; then
+ objformat=`/usr/bin/objformat`
+ else
+ case $host_os in
+ freebsd[123]*) objformat=aout ;;
+ *) objformat=elf ;;
+ esac
+ fi
+ version_type=freebsd-$objformat
+ case $version_type in
+ freebsd-elf*)
+ library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext} $libname${shared_ext}'
+ need_version=no
+ freebsd-*)
+ library_names_spec='${libname}${release}${shared_ext}$versuffix $libname${shared_ext}$versuffix'
+ need_version=yes
+ esac
+ case $host_os in
+ freebsd2*)
+ freebsd3.[01]* | freebsdelf3.[01]*)
+ freebsd3.[2-9]* | freebsdelf3.[2-9]* | \
+ freebsd4.[0-5] | freebsdelf4.[0-5] | freebsd4.1.1 | freebsdelf4.1.1)
+ freebsd*) # from 4.6 on
+ esac
+gnu*)
+ need_version=no
+ library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}${major} ${libname}${shared_ext}'
+hpux9* | hpux10* | hpux11*)
+ # Give a soname corresponding to the major version so that dld.sl refuses to
+ # link against other versions.
+ version_type=sunos
+ need_version=no
+ case $host_cpu in
+ ia64*)
+ shrext_cmds='.so'
+ dynamic_linker="$host_os dld.so"
+ shlibpath_overrides_runpath=yes # Unless +noenvvar is specified.
+ if test "X$HPUX_IA64_MODE" = X32; then
+ sys_lib_search_path_spec="/usr/lib/hpux32 /usr/local/lib/hpux32 /usr/local/lib"
+ else
+ sys_lib_search_path_spec="/usr/lib/hpux64 /usr/local/lib/hpux64"
+ fi
+ sys_lib_dlsearch_path_spec=$sys_lib_search_path_spec
+ hppa*64*)
+ shrext_cmds='.sl'
+ dynamic_linker="$host_os dld.sl"
+ shlibpath_var=LD_LIBRARY_PATH # How should we handle SHLIB_PATH
+ sys_lib_search_path_spec="/usr/lib/pa20_64 /usr/ccs/lib/pa20_64"
+ shrext_cmds='.sl'
+ shlibpath_var=SHLIB_PATH
+ shlibpath_overrides_runpath=no # +s is required to enable SHLIB_PATH
+ esac
+ # HP-UX runs *really* slowly unless shared libraries are mode 555.
+ postinstall_cmds='chmod 555 $lib'
+interix3*)
+ need_version=no
+ dynamic_linker='Interix 3.x ld.so.1 (PE, like ELF)'
+irix5* | irix6* | nonstopux*)
+ case $host_os in
+ nonstopux*) version_type=nonstopux ;;
+ if test "$lt_cv_prog_gnu_ld" = yes; then
+ else
+ version_type=irix
+ fi ;;
+ esac
+ need_version=no
+ library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext} $libname${shared_ext}'
+ case $host_os in
+ irix5* | nonstopux*)
+ libsuff= shlibsuff=
+ case $LD in # libtool.m4 will add one of these switches to LD
+ *-32|*"-32 "|*-melf32bsmip|*"-melf32bsmip ")
+ libsuff= shlibsuff= libmagic=32-bit;;
+ *-n32|*"-n32 "|*-melf32bmipn32|*"-melf32bmipn32 ")
+ libsuff=32 shlibsuff=N32 libmagic=N32;;
+ *-64|*"-64 "|*-melf64bmip|*"-melf64bmip ")
+ libsuff=64 shlibsuff=64 libmagic=64-bit;;
+ *) libsuff= shlibsuff= libmagic=never-match;;
+ esac
+ esac
+ shlibpath_var=LD_LIBRARY${shlibsuff}_PATH
+ sys_lib_search_path_spec="/usr/lib${libsuff} /lib${libsuff} /usr/local/lib${libsuff}"
+ sys_lib_dlsearch_path_spec="/usr/lib${libsuff} /lib${libsuff}"
+# No shared lib support for Linux oldld, aout, or coff.
+linux*oldld* | linux*aout* | linux*coff*)
+ dynamic_linker=no
+# This must be Linux ELF.
+linux*)
+ need_version=no
+ finish_cmds='PATH="\$PATH:/sbin" ldconfig -n $libdir'
+ # This implies no fast_install, which is unacceptable.
+ # Some rework will be needed to allow for fast_install
+ # before this can be enabled.
+ # find out which ABI we are using
+ libsuff=
+ case "$host_cpu" in
+ x86_64*|s390x*|powerpc64*)
+ echo '#line 14828 "configure"' > conftest.$ac_ext
+ ac_status=$?
+ (exit $ac_status); }; then
+ case `/usr/bin/file conftest.$ac_objext` in
+ *64-bit*)
+ libsuff=64
+ sys_lib_search_path_spec="/lib${libsuff} /usr/lib${libsuff} /usr/local/lib${libsuff}"
+ esac
+ fi
+ rm -rf conftest*
+ esac
+ # Append ld.so.conf contents to the search path
+ if test -f /etc/ld.so.conf; then
+ lt_ld_extra=`awk '/^include / { system(sprintf("cd /etc; cat %s", \$2)); skip = 1; } { if (!skip) print \$0; skip = 0; }' < /etc/ld.so.conf | $SED -e 's/#.*//;s/[:, ]/ /g;s/=[^=]*$//;s/=[^= ]* / /g;/^$/d' | tr '\n' ' '`
+ sys_lib_dlsearch_path_spec="/lib${libsuff} /usr/lib${libsuff} $lt_ld_extra"
+ fi
+ # We used to test for /lib/ld.so.1 and disable shared libraries on
+ # powerpc, because MkLinux only supported shared libraries with the
+ # GNU dynamic linker. Since this was broken with cross compilers,
+ # most powerpc-linux boxes support dynamic linking these days and
+ # people can always --disable-shared, the test was removed, and we
+ # assume the GNU/Linux dynamic linker is in use.
+ dynamic_linker='GNU/Linux ld.so'
+knetbsd*-gnu)
+ need_version=no
+netbsd*)
+ need_version=no
+ library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${shared_ext}$versuffix'
+ finish_cmds='PATH="\$PATH:/sbin" ldconfig -m $libdir'
+ dynamic_linker='NetBSD (a.out) ld.so'
+ else
+ dynamic_linker='NetBSD ld.elf_so'
+ fi
+newsos6)
+nto-qnx*)
+ need_version=no
+openbsd*)
+ sys_lib_dlsearch_path_spec="/usr/lib"
+ # Some older versions of OpenBSD (3.3 at least) *do* need versioned libs.
+ case $host_os in
+ openbsd3.3 | openbsd3.3.*) need_version=yes ;;
+ *) need_version=no ;;
+ esac
+ case $host_os in
+ openbsd2.[89] | openbsd2.[89].*)
+ esac
+ else
+ fi
+os2*)
+ libname_spec='$name'
+ library_names_spec='$libname${shared_ext} $libname.a'
+ dynamic_linker='OS/2 ld.exe'
+osf3* | osf4* | osf5*)
+ version_type=osf
+ need_version=no
+ sys_lib_search_path_spec="/usr/shlib /usr/ccs/lib /usr/lib/cmplrs/cc /usr/lib /usr/local/lib /var/shlib"
+ sys_lib_dlsearch_path_spec="$sys_lib_search_path_spec"
+solaris*)
+ need_version=no
+ # ldd complains unless libraries are executable
+ postinstall_cmds='chmod +x $lib'
+sunos4*)
+ finish_cmds='PATH="\$PATH:/usr/etc" ldconfig $libdir'
+ if test "$with_gnu_ld" = yes; then
+ fi
+ need_version=yes
+sysv4 | sysv4.3*)
+ case $host_vendor in
+ sni)
+ export_dynamic_flag_spec='${wl}-Blargedynsym'
+ siemens)
+ motorola)
+ need_version=no
+ sys_lib_search_path_spec='/lib /usr/lib /usr/ccs/lib'
+ esac
+sysv4*MP*)
+ if test -d /usr/nec ;then
+ library_names_spec='$libname${shared_ext}.$versuffix $libname${shared_ext}.$major $libname${shared_ext}'
+ soname_spec='$libname${shared_ext}.$major'
+ fi
+sysv5* | sco3.2v5* | sco5v6* | unixware* | OpenUNIX* | sysv4*uw2*)
+ version_type=freebsd-elf
+ need_version=no
+ sys_lib_search_path_spec='/usr/local/lib /usr/gnu/lib /usr/ccs/lib /usr/lib /lib'
+ else
+ sys_lib_search_path_spec='/usr/ccs/lib /usr/lib'
+ case $host_os in
+ sco3.2v5*)
+ sys_lib_search_path_spec="$sys_lib_search_path_spec /lib"
+ esac
+ fi
+ sys_lib_dlsearch_path_spec='/usr/lib'
+uts4*)
+ dynamic_linker=no
+esac
+echo "$as_me:$LINENO: result: $dynamic_linker" >&5
+echo "${ECHO_T}$dynamic_linker" >&6
+test "$dynamic_linker" = no && can_build_shared=no
+variables_saved_for_relink="PATH $shlibpath_var $runpath_var"
+ variables_saved_for_relink="$variables_saved_for_relink GCC_EXEC_PREFIX COMPILER_PATH LIBRARY_PATH"
+fi
+echo "$as_me:$LINENO: checking how to hardcode library paths into programs" >&5
+echo $ECHO_N "checking how to hardcode library paths into programs... $ECHO_C" >&6
+hardcode_action_F77=
+if test -n "$hardcode_libdir_flag_spec_F77" || \
+ test -n "$runpath_var_F77" || \
+ test "X$hardcode_automatic_F77" = "Xyes" ; then
+ # We can hardcode non-existant directories.
+ if test "$hardcode_direct_F77" != no &&
+ # If the only mechanism to avoid hardcoding is shlibpath_var, we
+ # have to relink, otherwise we might link with an installed library
+ # when we should be linking with a yet-to-be-installed one
+ ## test "$_LT_AC_TAGVAR(hardcode_shlibpath_var, F77)" != no &&
+ test "$hardcode_minus_L_F77" != no; then
+ # Linking always hardcodes the temporary library directory.
+ hardcode_action_F77=relink
+ else
+ # We can link without hardcoding, and we can hardcode nonexisting dirs.
+ hardcode_action_F77=immediate
+ fi
+else
+ # We cannot hardcode anything, or else we can only hardcode existing
+ # directories.
+ hardcode_action_F77=unsupported
+fi
+echo "$as_me:$LINENO: result: $hardcode_action_F77" >&5
+echo "${ECHO_T}$hardcode_action_F77" >&6
+if test "$hardcode_action_F77" = relink; then
+ # Fast installation is not supported
+ enable_fast_install=no
+elif test "$shlibpath_overrides_runpath" = yes ||
+ test "$enable_shared" = no; then
+ # Fast installation is not necessary
+ enable_fast_install=needless
+fi
+# The else clause should only fire when bootstrapping the
+# libtool distribution, otherwise you forgot to ship ltmain.sh
+# with your package, and you will get complaints that there are
+# no rules to generate ltmain.sh.
+if test -f "$ltmain"; then
+ # See if we are running on zsh, and set the options which allow our commands through
+ # without removal of \ escapes.
+ if test -n "${ZSH_VERSION+set}" ; then
+ setopt NO_GLOB_SUBST
+ fi
+ # Now quote all the things that may contain metacharacters while being
+ # careful not to overquote the AC_SUBSTed values. We take copies of the
+ # variables and quote the copies for generation of the libtool script.
+ for var in echo old_CC old_CFLAGS AR AR_FLAGS EGREP RANLIB LN_S LTCC LTCFLAGS NM \
+ SED SHELL STRIP \
+ libname_spec library_names_spec soname_spec extract_expsyms_cmds \
+ old_striplib striplib file_magic_cmd finish_cmds finish_eval \
+ deplibs_check_method reload_flag reload_cmds need_locks \
+ lt_cv_sys_global_symbol_pipe lt_cv_sys_global_symbol_to_cdecl \
+ lt_cv_sys_global_symbol_to_c_name_address \
+ sys_lib_search_path_spec sys_lib_dlsearch_path_spec \
+ old_postinstall_cmds old_postuninstall_cmds \
+ compiler_F77 \
+ CC_F77 \
+ LD_F77 \
+ lt_prog_compiler_wl_F77 \
+ lt_prog_compiler_pic_F77 \
+ lt_prog_compiler_static_F77 \
+ lt_prog_compiler_no_builtin_flag_F77 \
+ export_dynamic_flag_spec_F77 \
+ thread_safe_flag_spec_F77 \
+ whole_archive_flag_spec_F77 \
+ enable_shared_with_static_runtimes_F77 \
+ old_archive_cmds_F77 \
+ old_archive_from_new_cmds_F77 \
+ predep_objects_F77 \
+ postdep_objects_F77 \
+ predeps_F77 \
+ postdeps_F77 \
+ compiler_lib_search_path_F77 \
+ archive_cmds_F77 \
+ archive_expsym_cmds_F77 \
+ postinstall_cmds_F77 \
+ postuninstall_cmds_F77 \
+ old_archive_from_expsyms_cmds_F77 \
+ allow_undefined_flag_F77 \
+ no_undefined_flag_F77 \
+ export_symbols_cmds_F77 \
+ hardcode_libdir_flag_spec_F77 \
+ hardcode_libdir_flag_spec_ld_F77 \
+ hardcode_libdir_separator_F77 \
+ hardcode_automatic_F77 \
+ module_cmds_F77 \
+ module_expsym_cmds_F77 \
+ lt_cv_prog_compiler_c_o_F77 \
+ exclude_expsyms_F77 \
+ include_expsyms_F77; do
+ case $var in
+ old_archive_cmds_F77 | \
+ old_archive_from_new_cmds_F77 | \
+ archive_cmds_F77 | \
+ archive_expsym_cmds_F77 | \
+ module_cmds_F77 | \
+ module_expsym_cmds_F77 | \
+ old_archive_from_expsyms_cmds_F77 | \
+ export_symbols_cmds_F77 | \
+ extract_expsyms_cmds | reload_cmds | finish_cmds | \
+ postinstall_cmds | postuninstall_cmds | \
+ old_postinstall_cmds | old_postuninstall_cmds | \
+ sys_lib_search_path_spec | sys_lib_dlsearch_path_spec)
+ # Double-quote double-evaled strings.
+ eval "lt_$var=\\\"\`\$echo \"X\$$var\" | \$Xsed -e \"\$double_quote_subst\" -e \"\$sed_quote_subst\" -e \"\$delay_variable_subst\"\`\\\""
+ eval "lt_$var=\\\"\`\$echo \"X\$$var\" | \$Xsed -e \"\$sed_quote_subst\"\`\\\""
+ esac
+ done
+ case $lt_echo in
+ *'\$0 --fallback-echo"')
+ lt_echo=`$echo "X$lt_echo" | $Xsed -e 's/\\\\\\\$0 --fallback-echo"$/$0 --fallback-echo"/'`
+ esac
+cfgfile="$ofile"
+ cat <<__EOF__ >> "$cfgfile"
+# ### BEGIN LIBTOOL TAG CONFIG: $tagname
+# Libtool was configured on host `(hostname || uname -n) 2>/dev/null | sed 1q`:
+# Shell to use when invoking shell scripts.
+SHELL=$lt_SHELL
+# Whether or not to build shared libraries.
+build_libtool_libs=$enable_shared
+# Whether or not to build static libraries.
+build_old_libs=$enable_static
+# Whether or not to add -lc for building shared libraries.
+build_libtool_need_lc=$archive_cmds_need_lc_F77
+# Whether or not to disallow shared libs when runtime libs are static
+allow_libtool_libs_with_static_runtimes=$enable_shared_with_static_runtimes_F77
+# Whether or not to optimize for fast installation.
+fast_install=$enable_fast_install
+# The host system.
+host_alias=$host_alias
+host=$host
+host_os=$host_os
+# The build system.
+build_alias=$build_alias
+build=$build
+build_os=$build_os
+# An echo program that does not interpret backslashes.
+echo=$lt_echo
+# The archiver.
+AR=$lt_AR
+AR_FLAGS=$lt_AR_FLAGS
+# A C compiler.
+LTCC=$lt_LTCC
+# LTCC compiler flags.
+LTCFLAGS=$lt_LTCFLAGS
+# A language-specific compiler.
+CC=$lt_compiler_F77
+# Is the compiler the GNU C compiler?
+with_gcc=$GCC_F77
+# An ERE matcher.
+EGREP=$lt_EGREP
+# The linker used to build libraries.
+LD=$lt_LD_F77
+# Whether we need hard or soft links.
+LN_S=$lt_LN_S
+# A BSD-compatible nm program.
+NM=$lt_NM
+# A symbol stripping program
+STRIP=$lt_STRIP
+# Used to examine libraries when file_magic_cmd begins "file"
+MAGIC_CMD=$MAGIC_CMD
+# Used on cygwin: DLL creation program.
+DLLTOOL="$DLLTOOL"
+# Used on cygwin: object dumper.
+OBJDUMP="$OBJDUMP"
+# Used on cygwin: assembler.
+AS="$AS"
+# The name of the directory that contains temporary libtool files.
+objdir=$objdir
+# How to create reloadable object files.
+reload_flag=$lt_reload_flag
+reload_cmds=$lt_reload_cmds
+# How to pass a linker flag through the compiler.
+wl=$lt_lt_prog_compiler_wl_F77
+# Object file suffix (normally "o").
+objext="$ac_objext"
+# Old archive suffix (normally "a").
+libext="$libext"
+# Shared library suffix (normally ".so").
+shrext_cmds='$shrext_cmds'
+# Executable file suffix (normally "").
+exeext="$exeext"
+# Additional compiler flags for building library objects.
+pic_flag=$lt_lt_prog_compiler_pic_F77
+pic_mode=$pic_mode
+# What is the maximum length of a command?
+max_cmd_len=$lt_cv_sys_max_cmd_len
+# Does compiler simultaneously support -c and -o options?
+compiler_c_o=$lt_lt_cv_prog_compiler_c_o_F77
+# Must we lock files when doing compilation?
+need_locks=$lt_need_locks
+# Do we need the lib prefix for modules?
+need_lib_prefix=$need_lib_prefix
+# Do we need a version for libraries?
+need_version=$need_version
+# Whether dlopen is supported.
+dlopen_support=$enable_dlopen
+# Whether dlopen of programs is supported.
+dlopen_self=$enable_dlopen_self
+# Whether dlopen of statically linked programs is supported.
+dlopen_self_static=$enable_dlopen_self_static
+# Compiler flag to prevent dynamic linking.
+link_static_flag=$lt_lt_prog_compiler_static_F77
+# Compiler flag to turn off builtin functions.
+no_builtin_flag=$lt_lt_prog_compiler_no_builtin_flag_F77
+# Compiler flag to allow reflexive dlopens.
+export_dynamic_flag_spec=$lt_export_dynamic_flag_spec_F77
+# Compiler flag to generate shared objects directly from archives.
+whole_archive_flag_spec=$lt_whole_archive_flag_spec_F77
+# Compiler flag to generate thread-safe objects.
+thread_safe_flag_spec=$lt_thread_safe_flag_spec_F77
+# Library versioning type.
+version_type=$version_type
+# Format of library name prefix.
+libname_spec=$lt_libname_spec
+# List of archive names. First name is the real one, the rest are links.
+# The last name is the one that the linker finds with -lNAME.
+library_names_spec=$lt_library_names_spec
+# The coded name of the library, if different from the real name.
+soname_spec=$lt_soname_spec
+# Commands used to build and install an old-style archive.
+RANLIB=$lt_RANLIB
+old_archive_cmds=$lt_old_archive_cmds_F77
+old_postinstall_cmds=$lt_old_postinstall_cmds
+old_postuninstall_cmds=$lt_old_postuninstall_cmds
+# Create an old-style archive from a shared archive.
+old_archive_from_new_cmds=$lt_old_archive_from_new_cmds_F77
+# Create a temporary old-style archive to link instead of a shared archive.
+old_archive_from_expsyms_cmds=$lt_old_archive_from_expsyms_cmds_F77
+# Commands used to build and install a shared archive.
+archive_cmds=$lt_archive_cmds_F77
+archive_expsym_cmds=$lt_archive_expsym_cmds_F77
+postinstall_cmds=$lt_postinstall_cmds
+postuninstall_cmds=$lt_postuninstall_cmds
+# Commands used to build a loadable module (assumed same as above if empty)
+module_cmds=$lt_module_cmds_F77
+module_expsym_cmds=$lt_module_expsym_cmds_F77
+# Commands to strip libraries.
+old_striplib=$lt_old_striplib
+striplib=$lt_striplib
+# Dependencies to place before the objects being linked to create a
+# shared library.
+predep_objects=$lt_predep_objects_F77
+# Dependencies to place after the objects being linked to create a
+# shared library.
+postdep_objects=$lt_postdep_objects_F77
+# shared library.
+predeps=$lt_predeps_F77
+# shared library.
+postdeps=$lt_postdeps_F77
+# The library search path used internally by the compiler when linking
+# a shared library.
+compiler_lib_search_path=$lt_compiler_lib_search_path_F77
+# Method to check whether dependent libraries are shared objects.
+deplibs_check_method=$lt_deplibs_check_method
+# Command to use when deplibs_check_method == file_magic.
+file_magic_cmd=$lt_file_magic_cmd
+# Flag that allows shared libraries with undefined symbols to be built.
+allow_undefined_flag=$lt_allow_undefined_flag_F77
+# Flag that forces no undefined symbols.
+no_undefined_flag=$lt_no_undefined_flag_F77
+# Commands used to finish a libtool library installation in a directory.
+finish_cmds=$lt_finish_cmds
+# Same as above, but a single script fragment to be evaled but not shown.
+finish_eval=$lt_finish_eval
+# Take the output of nm and produce a listing of raw symbols and C names.
+global_symbol_pipe=$lt_lt_cv_sys_global_symbol_pipe
+# Transform the output of nm in a proper C declaration
+global_symbol_to_cdecl=$lt_lt_cv_sys_global_symbol_to_cdecl
+# Transform the output of nm in a C name address pair
+global_symbol_to_c_name_address=$lt_lt_cv_sys_global_symbol_to_c_name_address
+# This is the shared library runtime path variable.
+runpath_var=$runpath_var
+# This is the shared library path variable.
+shlibpath_var=$shlibpath_var
+# Is shlibpath searched before the hard-coded library search path?
+shlibpath_overrides_runpath=$shlibpath_overrides_runpath
+# How to hardcode a shared library path into an executable.
+hardcode_action=$hardcode_action_F77
+# Whether we should hardcode library paths into libraries.
+hardcode_into_libs=$hardcode_into_libs
+# Flag to hardcode \$libdir into a binary during linking.
+# This must work even if \$libdir does not exist.
+hardcode_libdir_flag_spec=$lt_hardcode_libdir_flag_spec_F77
+# If ld is used when linking, flag to hardcode \$libdir into
+# a binary during linking. This must work even if \$libdir does
+# not exist.
+hardcode_libdir_flag_spec_ld=$lt_hardcode_libdir_flag_spec_ld_F77
+# Whether we need a single -rpath flag with a separated argument.
+hardcode_libdir_separator=$lt_hardcode_libdir_separator_F77
+# Set to yes if using DIR/libNAME${shared_ext} during linking hardcodes DIR into the
+# resulting binary.
+hardcode_direct=$hardcode_direct_F77
+# Set to yes if using the -LDIR flag during linking hardcodes DIR into the
+hardcode_minus_L=$hardcode_minus_L_F77
+# Set to yes if using SHLIBPATH_VAR=DIR during linking hardcodes DIR into
+# the resulting binary.
+hardcode_shlibpath_var=$hardcode_shlibpath_var_F77
+# Set to yes if building a shared library automatically hardcodes DIR into the library
+# and all subsequent libraries and executables linked against it.
+hardcode_automatic=$hardcode_automatic_F77
+# Variables whose values should be saved in libtool wrapper scripts and
+# restored at relink time.
+variables_saved_for_relink="$variables_saved_for_relink"
+# Whether libtool must link a program against all its dependency libraries.
+link_all_deplibs=$link_all_deplibs_F77
+# Compile-time system search path for libraries
+sys_lib_search_path_spec=$lt_sys_lib_search_path_spec
+# Run-time system search path for libraries
+sys_lib_dlsearch_path_spec=$lt_sys_lib_dlsearch_path_spec
+# Fix the shell variable \$srcfile for the compiler.
+fix_srcfile_path="$fix_srcfile_path_F77"
+# Set to yes if exported symbols are required.
+always_export_symbols=$always_export_symbols_F77
+# The commands to list exported symbols.
+export_symbols_cmds=$lt_export_symbols_cmds_F77
+# The commands to extract the exported symbol list from a shared archive.
+extract_expsyms_cmds=$lt_extract_expsyms_cmds
+# Symbols that should not be listed in the preloaded symbols.
+exclude_expsyms=$lt_exclude_expsyms_F77
+# Symbols that must always be exported.
+include_expsyms=$lt_include_expsyms_F77
+# ### END LIBTOOL TAG CONFIG: $tagname
+__EOF__
+else
+ # If there is no Makefile yet, we rely on a make rule to execute
+ # `config.status --recheck' to rerun these tests and create the
+ # libtool script then.
+ ltmain_in=`echo $ltmain | sed -e 's/\.sh$/.in/'`
+ if test -f "$ltmain_in"; then
+ test -f Makefile && make "$ltmain"
+ fi
+fi
+ac_ext=cc
+ac_cpp='$CXXCPP $CPPFLAGS'
+ac_compile='$CXX -c $CXXFLAGS $CPPFLAGS conftest.$ac_ext >&5'
+ac_link='$CXX -o conftest$ac_exeext $CXXFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
+ac_compiler_gnu=$ac_cv_cxx_compiler_gnu
+CC="$lt_save_CC"
+ else
+ tagname=""
+ fi
+ GCJ)
+ if test -n "$GCJ" && test "X$GCJ" != "Xno"; then
+# Source file extension for Java test sources.
+ac_ext=java
+# Object file extension for compiled Java test sources.
+objext=o
+objext_GCJ=$objext
+# Code to be used in simple compile tests
+lt_simple_compile_test_code="class foo {}\n"
+# Code to be used in simple link tests
+lt_simple_link_test_code='public class conftest { public static void main(String[] argv) {}; }\n'
+# ltmain only uses $CC for tagged configurations so make sure $CC is set.
+# If no C compiler was specified, use CC.
+LTCC=${LTCC-"$CC"}
+# If no C compiler flags were specified, use CFLAGS.
+LTCFLAGS=${LTCFLAGS-"$CFLAGS"}
+# Allow CC to be a program name with arguments.
+compiler=$CC
+# save warnings/boilerplate of simple test code
+ac_outfile=conftest.$ac_objext
+printf "$lt_simple_compile_test_code" >conftest.$ac_ext
+eval "$ac_compile" 2>&1 >/dev/null | $SED '/^$/d; /^ *+/d' >conftest.err
+_lt_compiler_boilerplate=`cat conftest.err`
+$rm conftest*
+printf "$lt_simple_link_test_code" >conftest.$ac_ext
+eval "$ac_link" 2>&1 >/dev/null | $SED '/^$/d; /^ *+/d' >conftest.err
+_lt_linker_boilerplate=`cat conftest.err`
+$rm conftest*
+lt_save_CC="$CC"
+CC=${GCJ-"gcj"}
+compiler=$CC
+compiler_GCJ=$CC
+for cc_temp in $compiler""; do
+ case $cc_temp in
+ compile | *[\\/]compile | ccache | *[\\/]ccache ) ;;
+ distcc | *[\\/]distcc | purify | *[\\/]purify ) ;;
+ *) break;;
+ esac
+done
+cc_basename=`$echo "X$cc_temp" | $Xsed -e 's%.*/%%' -e "s%^$host_alias-%%"`
+# GCJ did not exist at the time GCC didn't implicitly link libc in.
+archive_cmds_need_lc_GCJ=no
+old_archive_cmds_GCJ=$old_archive_cmds
+lt_prog_compiler_no_builtin_flag_GCJ=
+ lt_prog_compiler_no_builtin_flag_GCJ=' -fno-builtin'
+echo "$as_me:$LINENO: checking if $compiler supports -fno-rtti -fno-exceptions" >&5
+echo $ECHO_N "checking if $compiler supports -fno-rtti -fno-exceptions... $ECHO_C" >&6
+if test "${lt_cv_prog_compiler_rtti_exceptions+set}" = set; then
+ echo $ECHO_N "(cached) $ECHO_C" >&6
+else
+ lt_cv_prog_compiler_rtti_exceptions=no
+ ac_outfile=conftest.$ac_objext
+ lt_compiler_flag="-fno-rtti -fno-exceptions"
+ # Insert the option either (1) after the last *FLAGS variable, or
+ # (2) before a word containing "conftest.", or (3) at the end.
+ # Note that $ac_compile itself does not contain backslashes and begins
+ # with a dollar sign (not a hyphen), so the echo should work correctly.
+ # The option is referenced via a variable to avoid confusing sed.
+ lt_compile=`echo "$ac_compile" | $SED \
+ -e 's:.*FLAGS}\{0,1\} :&$lt_compiler_flag :; t' \
+ -e 's: [^ ]*conftest\.: $lt_compiler_flag&:; t' \
+ -e 's:$: $lt_compiler_flag:'`
+ (eval echo "\"\$as_me:15603: $lt_compile\"" >&5)
+ (eval "$lt_compile" 2>conftest.err)
+ ac_status=$?
+ echo "$as_me:15607: \$? = $ac_status" >&5
+ if (exit $ac_status) && test -s "$ac_outfile"; then
+ # The compiler can only warn and ignore the option if not recognized
+ # So say no if there are warnings other than the usual output.
+ $echo "X$_lt_compiler_boilerplate" | $Xsed -e '/^$/d' >conftest.exp
+ $SED '/^$/d; /^ *+/d' conftest.err >conftest.er2
+ if test ! -s conftest.er2 || diff conftest.exp conftest.er2 >/dev/null; then
+ lt_cv_prog_compiler_rtti_exceptions=yes
+ fi
+ fi
+ $rm conftest*
+fi
+echo "$as_me:$LINENO: result: $lt_cv_prog_compiler_rtti_exceptions" >&5
+echo "${ECHO_T}$lt_cv_prog_compiler_rtti_exceptions" >&6
+if test x"$lt_cv_prog_compiler_rtti_exceptions" = xyes; then
+ lt_prog_compiler_no_builtin_flag_GCJ="$lt_prog_compiler_no_builtin_flag_GCJ -fno-rtti -fno-exceptions"
+else
+fi
+fi
+lt_prog_compiler_wl_GCJ=
+lt_prog_compiler_pic_GCJ=
+lt_prog_compiler_static_GCJ=
+echo "$as_me:$LINENO: checking for $compiler option to produce PIC" >&5
+echo $ECHO_N "checking for $compiler option to produce PIC... $ECHO_C" >&6
+ lt_prog_compiler_wl_GCJ='-Wl,'
+ lt_prog_compiler_static_GCJ='-static'
+ case $host_os in
+ aix*)
+ # All AIX code is PIC.
+ if test "$host_cpu" = ia64; then
+ # AIX 5 now supports IA64 processor
+ lt_prog_compiler_static_GCJ='-Bstatic'
+ fi
+ amigaos*)
+ # FIXME: we need at least 68020 code to build shared libraries, but
+ # adding the `-m68020' flag to GCC prevents building anything better,
+ # like `-m68040'.
+ lt_prog_compiler_pic_GCJ='-m68020 -resident32 -malways-restore-a4'
+ beos* | cygwin* | irix5* | irix6* | nonstopux* | osf3* | osf4* | osf5*)
+ # PIC is the default for these OSes.
+ mingw* | pw32* | os2*)
+ # This hack is so that the source file can tell whether it is being
+ # built for inclusion in a dll (and should export symbols for example).
+ lt_prog_compiler_pic_GCJ='-DDLL_EXPORT'
+ darwin* | rhapsody*)
+ # PIC is the default on this platform
+ # Common symbols not allowed in MH_DYLIB files
+ lt_prog_compiler_pic_GCJ='-fno-common'
+ interix3*)
+ # Interix 3.x gcc -fpic/-fPIC options generate broken code.
+ # Instead, we relocate shared libraries at runtime.
+ msdosdjgpp*)
+ # Just because we use GCC doesn't mean we suddenly get shared libraries
+ # on systems that don't support them.
+ lt_prog_compiler_can_build_shared_GCJ=no
+ enable_shared=no
+ sysv4*MP*)
+ lt_prog_compiler_pic_GCJ=-Kconform_pic
+ fi
+ hpux*)
+ # PIC is the default for IA64 HP-UX and 64-bit HP-UX, but
+ # not for PA HP-UX.
+ case $host_cpu in
+ hppa*64*|ia64*)
+ # +Z the default
+ lt_prog_compiler_pic_GCJ='-fPIC'
+ esac
+ esac
+ else
+ # PORTME Check for flag to pass linker flags through the system compiler.
+ case $host_os in
+ aix*)
+ else
+ lt_prog_compiler_static_GCJ='-bnso -bI:/lib/syscalls.exp'
+ fi
+ darwin*)
+ case $cc_basename in
+ xlc*)
+ lt_prog_compiler_pic_GCJ='-qnocommon'
+ esac
+ hpux9* | hpux10* | hpux11*)
+ case $host_cpu in
+ hppa*64*|ia64*)
+ # +Z the default
+ lt_prog_compiler_pic_GCJ='+Z'
+ esac
+ # Is there a better lt_prog_compiler_static that works with the bundled CC?
+ lt_prog_compiler_static_GCJ='${wl}-a ${wl}archive'
+ # PIC (with -KPIC) is the default.
+ lt_prog_compiler_static_GCJ='-non_shared'
+ newsos6)
+ lt_prog_compiler_pic_GCJ='-KPIC'
+ linux*)
+ icc* | ecc*)
+ pgcc* | pgf77* | pgf90* | pgf95*)
+ # Portland Group compilers (*not* the Pentium gcc compiler,
+ # which looks to be a dead project)
+ lt_prog_compiler_pic_GCJ='-fpic'
+ ccc*)
+ # All Alpha code is PIC.
+ esac
+ osf3* | osf4* | osf5*)
+ # All OSF/1 code is PIC.
+ solaris*)
+ f77* | f90* | f95*)
+ lt_prog_compiler_wl_GCJ='-Qoption ld ';;
+ lt_prog_compiler_wl_GCJ='-Wl,';;
+ esac
+ sunos4*)
+ lt_prog_compiler_pic_GCJ='-PIC'
+ sysv4 | sysv4.2uw2* | sysv4.3*)
+ sysv4*MP*)
+ lt_prog_compiler_pic_GCJ='-Kconform_pic'
+ fi
+ sysv5* | unixware* | sco3.2v5* | sco5v6* | OpenUNIX*)
+ unicos*)
+ uts4*)
+ lt_prog_compiler_pic_GCJ='-pic'
+ esac
+ fi
+echo "$as_me:$LINENO: result: $lt_prog_compiler_pic_GCJ" >&5
+echo "${ECHO_T}$lt_prog_compiler_pic_GCJ" >&6
-# pe_as32 (ptr)
-# void *ptr;
-# unsigned char *b = ptr;
+# Check to make sure the PIC flag actually works.
-# int
-# main (argc, argv)
-# int argc;
-# char *argv[];
-# int dll;
-# unsigned long pe_header_offset, opthdr_ofs, num_entries, i;
-# unsigned long export_rva, export_size, nsections, secptr, expptr;
-# unsigned long name_rvas, nexp;
-# unsigned char *expdata, *erva;
-# char *filename, *dll_name;
+if test -n "$lt_prog_compiler_pic_GCJ"; then
+echo "$as_me:$LINENO: checking if $compiler PIC flag $lt_prog_compiler_pic_GCJ works" >&5
+echo $ECHO_N "checking if $compiler PIC flag $lt_prog_compiler_pic_GCJ works... $ECHO_C" >&6
+if test "${lt_prog_compiler_pic_works_GCJ+set}" = set; then
+else
+ lt_prog_compiler_pic_works_GCJ=no
+ lt_compiler_flag="$lt_prog_compiler_pic_GCJ"
+ (eval echo "\"\$as_me:15871: $lt_compile\"" >&5)
+ ac_status=$?
+ echo "$as_me:15875: \$? = $ac_status" >&5
+ lt_prog_compiler_pic_works_GCJ=yes
+ fi
+ fi
+ $rm conftest*
+fi
+echo "$as_me:$LINENO: result: $lt_prog_compiler_pic_works_GCJ" >&5
+echo "${ECHO_T}$lt_prog_compiler_pic_works_GCJ" >&6
+if test x"$lt_prog_compiler_pic_works_GCJ" = xyes; then
+ case $lt_prog_compiler_pic_GCJ in
+ *) lt_prog_compiler_pic_GCJ=" $lt_prog_compiler_pic_GCJ" ;;
+ esac
+else
+fi
+fi
+case $host_os in
+ # For platforms which do not support PIC, -DPIC is meaningless:
+ *djgpp*)
+ lt_prog_compiler_pic_GCJ="$lt_prog_compiler_pic_GCJ"
+esac
-# filename = argv[1];
+# Check to make sure the static flag actually works.
-# dll = open(filename, O_RDONLY|O_BINARY);
-# if (dll < 1)
-# return 1;
+wl=$lt_prog_compiler_wl_GCJ eval lt_tmp_static_flag=\"$lt_prog_compiler_static_GCJ\"
+echo "$as_me:$LINENO: checking if $compiler static flag $lt_tmp_static_flag works" >&5
+echo $ECHO_N "checking if $compiler static flag $lt_tmp_static_flag works... $ECHO_C" >&6
+if test "${lt_prog_compiler_static_works_GCJ+set}" = set; then
+else
+ lt_prog_compiler_static_works_GCJ=no
+ save_LDFLAGS="$LDFLAGS"
+ LDFLAGS="$LDFLAGS $lt_tmp_static_flag"
+ printf "$lt_simple_link_test_code" > conftest.$ac_ext
+ if (eval $ac_link 2>conftest.err) && test -s conftest$ac_exeext; then
+ # The linker can only warn and ignore the option if not recognized
+ if test -s conftest.err; then
+ # Append any errors to the config.log.
+ $echo "X$_lt_linker_boilerplate" | $Xsed -e '/^$/d' > conftest.exp
+ if diff conftest.exp conftest.er2 >/dev/null; then
+ lt_prog_compiler_static_works_GCJ=yes
+ fi
+ else
+ fi
+ fi
+ $rm conftest*
+ LDFLAGS="$save_LDFLAGS"
+fi
+echo "$as_me:$LINENO: result: $lt_prog_compiler_static_works_GCJ" >&5
+echo "${ECHO_T}$lt_prog_compiler_static_works_GCJ" >&6
+if test x"$lt_prog_compiler_static_works_GCJ" = xyes; then
+else
+fi
+echo "$as_me:$LINENO: checking if $compiler supports -c -o file.$ac_objext" >&5
+echo $ECHO_N "checking if $compiler supports -c -o file.$ac_objext... $ECHO_C" >&6
+if test "${lt_cv_prog_compiler_c_o_GCJ+set}" = set; then
+else
+ lt_cv_prog_compiler_c_o_GCJ=no
+ $rm -r conftest 2>/dev/null
+ mkdir conftest
+ cd conftest
+ mkdir out
+ lt_compiler_flag="-o out/conftest2.$ac_objext"
+ (eval echo "\"\$as_me:15975: $lt_compile\"" >&5)
+ (eval "$lt_compile" 2>out/conftest.err)
+ ac_status=$?
+ cat out/conftest.err >&5
+ echo "$as_me:15979: \$? = $ac_status" >&5
+ if (exit $ac_status) && test -s out/conftest2.$ac_objext
+ then
+ $echo "X$_lt_compiler_boilerplate" | $Xsed -e '/^$/d' > out/conftest.exp
+ $SED '/^$/d; /^ *+/d' out/conftest.err >out/conftest.er2
+ if test ! -s out/conftest.er2 || diff out/conftest.exp out/conftest.er2 >/dev/null; then
+ lt_cv_prog_compiler_c_o_GCJ=yes
+ fi
+ fi
+ chmod u+w . 2>&5
+ $rm conftest*
+ # SGI C++ compiler will create directory out/ii_files/ for
+ # template instantiation
+ test -d out/ii_files && $rm out/ii_files/* && rmdir out/ii_files
+ $rm out/* && rmdir out
+ cd ..
+ rmdir conftest
+ $rm conftest*
+fi
+echo "$as_me:$LINENO: result: $lt_cv_prog_compiler_c_o_GCJ" >&5
+echo "${ECHO_T}$lt_cv_prog_compiler_c_o_GCJ" >&6
+hard_links="nottested"
+if test "$lt_cv_prog_compiler_c_o_GCJ" = no && test "$need_locks" != no; then
+ # do not overwrite the value of need_locks provided by the user
+ echo "$as_me:$LINENO: checking if we can lock with hard links" >&5
+echo $ECHO_N "checking if we can lock with hard links... $ECHO_C" >&6
+ hard_links=yes
+ $rm conftest*
+ ln conftest.a conftest.b 2>/dev/null && hard_links=no
+ touch conftest.a
+ ln conftest.a conftest.b 2>&5 || hard_links=no
+ echo "$as_me:$LINENO: result: $hard_links" >&5
+echo "${ECHO_T}$hard_links" >&6
+ if test "$hard_links" = no; then
+ { echo "$as_me:$LINENO: WARNING: \`$CC' does not support \`-c -o', so \`make -j' may be unsafe" >&5
+echo "$as_me: WARNING: \`$CC' does not support \`-c -o', so \`make -j' may be unsafe" >&2;}
+ need_locks=warn
+ fi
+else
+ need_locks=no
+fi
+echo "$as_me:$LINENO: checking whether the $compiler linker ($LD) supports shared libraries" >&5
+echo $ECHO_N "checking whether the $compiler linker ($LD) supports shared libraries... $ECHO_C" >&6
+ runpath_var=
+ allow_undefined_flag_GCJ=
+ enable_shared_with_static_runtimes_GCJ=no
+ archive_cmds_GCJ=
+ archive_expsym_cmds_GCJ=
+ old_archive_From_new_cmds_GCJ=
+ old_archive_from_expsyms_cmds_GCJ=
+ export_dynamic_flag_spec_GCJ=
+ whole_archive_flag_spec_GCJ=
+ thread_safe_flag_spec_GCJ=
+ hardcode_libdir_flag_spec_GCJ=
+ hardcode_libdir_flag_spec_ld_GCJ=
+ hardcode_libdir_separator_GCJ=
+ hardcode_direct_GCJ=no
+ hardcode_minus_L_GCJ=no
+ hardcode_shlibpath_var_GCJ=unsupported
+ link_all_deplibs_GCJ=unknown
+ hardcode_automatic_GCJ=no
+ module_cmds_GCJ=
+ module_expsym_cmds_GCJ=
+ always_export_symbols_GCJ=no
+ export_symbols_cmds_GCJ='$NM $libobjs $convenience | $global_symbol_pipe | $SED '\''s/.* //'\'' | sort | uniq > $export_symbols'
+ # include_expsyms should be a list of space-separated symbols to be *always*
+ # included in the symbol list
+ include_expsyms_GCJ=
+ # exclude_expsyms can be an extended regexp of symbols to exclude
+ # it will be wrapped by ` (' and `)$', so one must not match beginning or
+ # end of line. Example: `a|bc|.*d.*' will exclude the symbols `a' and `bc',
+ # as well as any symbol that contains `d'.
+ exclude_expsyms_GCJ="_GLOBAL_OFFSET_TABLE_"
+ # Although _GLOBAL_OFFSET_TABLE_ is a valid symbol C name, most a.out
+ # platforms (ab)use it in PIC code, but their linkers get confused if
+ # the symbol is explicitly referenced. Since portable code cannot
+ # rely on this symbol name, it's probably fine to never include it in
+ # preloaded symbol tables.
+ extract_expsyms_cmds=
+ # Just being paranoid about ensuring that cc_basename is set.
+ for cc_temp in $compiler""; do
+ case $cc_temp in
+ *) break;;
+ esac
+done
+ case $host_os in
+ cygwin* | mingw* | pw32*)
+ # FIXME: the MSVC++ port hasn't been tested in a loooong time
+ # When not using gcc, we currently assume that we are using
+ # Microsoft Visual C++.
+ if test "$GCC" != yes; then
+ with_gnu_ld=no
+ fi
+ interix*)
+ # we just hope/assume this is gcc and not c89 (= MSVC++)
+ with_gnu_ld=yes
+ openbsd*)
+ with_gnu_ld=no
+ esac
+ ld_shlibs_GCJ=yes
+ # If archive_cmds runs LD, not CC, wlarc should be empty
+ wlarc='${wl}'
+ # Set some defaults for GNU ld with shared library support. These
+ # are reset later if shared libraries are not supported. Putting them
+ # here allows them to be overridden if necessary.
+ runpath_var=LD_RUN_PATH
+ hardcode_libdir_flag_spec_GCJ='${wl}--rpath ${wl}$libdir'
+ export_dynamic_flag_spec_GCJ='${wl}--export-dynamic'
+ # ancient GNU ld didn't support --whole-archive et. al.
+ if $LD --help 2>&1 | grep 'no-whole-archive' > /dev/null; then
+ whole_archive_flag_spec_GCJ="$wlarc"'--whole-archive$convenience '"$wlarc"'--no-whole-archive'
+ else
+ fi
+ supports_anon_versioning=no
+ case `$LD -v 2>/dev/null` in
+ *\ [01].* | *\ 2.[0-9].* | *\ 2.10.*) ;; # catch versions < 2.11
+ *\ 2.11.93.0.2\ *) supports_anon_versioning=yes ;; # RH7.3 ...
+ *\ 2.11.92.0.12\ *) supports_anon_versioning=yes ;; # Mandrake 8.2 ...
+ *\ 2.11.*) ;; # other 2.11 versions
+ *) supports_anon_versioning=yes ;;
+ esac
+ # See if GNU ld supports shared libraries.
+ case $host_os in
+ aix3* | aix4* | aix5*)
+ # On AIX/PPC, the GNU linker is very broken
+ if test "$host_cpu" != ia64; then
+ ld_shlibs_GCJ=no
+ cat <<EOF 1>&2
+*** Warning: the GNU linker, at least up to release 2.9.1, is reported
+*** to be unable to reliably create shared libraries on AIX.
+*** Therefore, libtool is disabling shared libraries support. If you
+*** really care for shared libraries, you may want to modify your PATH
+*** so that a non-GNU linker is found, and then restart.
+EOF
+ fi
+ amigaos*)
+ archive_cmds_GCJ='$rm $output_objdir/a2ixlibrary.data~$echo "#define NAME $libname" > $output_objdir/a2ixlibrary.data~$echo "#define LIBRARY_ID 1" >> $output_objdir/a2ixlibrary.data~$echo "#define VERSION $major" >> $output_objdir/a2ixlibrary.data~$echo "#define REVISION $revision" >> $output_objdir/a2ixlibrary.data~$AR $AR_FLAGS $lib $libobjs~$RANLIB $lib~(cd $output_objdir && a2ixlibrary -32)'
+ hardcode_libdir_flag_spec_GCJ='-L$libdir'
+ hardcode_minus_L_GCJ=yes
+ # Samuel A. Falvo II <kc5tja at dolphin.openprojects.net> reports
+ # that the semantics of dynamic libraries on AmigaOS, at least up
+ # to version 4, is to share data among multiple programs linked
+ # with the same dynamic library. Since this doesn't match the
+ # behavior of shared libraries on other platforms, we can't use
+ # them.
+ ld_shlibs_GCJ=no
+ beos*)
+ if $LD --help 2>&1 | grep ': supported targets:.* elf' > /dev/null; then
+ allow_undefined_flag_GCJ=unsupported
+ # Joseph Beckenbach <jrb3 at best.com> says some releases of gcc
+ # support --undefined. This deserves some investigation. FIXME
+ archive_cmds_GCJ='$CC -nostart $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
+ else
+ ld_shlibs_GCJ=no
+ fi
+ # _LT_AC_TAGVAR(hardcode_libdir_flag_spec, GCJ) is actually meaningless,
+ # as there is no search path for DLLs.
+ enable_shared_with_static_runtimes_GCJ=yes
+ export_symbols_cmds_GCJ='$NM $libobjs $convenience | $global_symbol_pipe | $SED -e '\''/^[BCDGRS] /s/.* \([^ ]*\)/\1 DATA/'\'' | $SED -e '\''/^[AITW] /s/.* //'\'' | sort | uniq > $export_symbols'
+ if $LD --help 2>&1 | grep 'auto-import' > /dev/null; then
+ archive_cmds_GCJ='$CC -shared $libobjs $deplibs $compiler_flags -o $output_objdir/$soname ${wl}--enable-auto-image-base -Xlinker --out-implib -Xlinker $lib'
+ # If the export-symbols file already is a .def file (1st line
+ # is EXPORTS), use it as is; otherwise, prepend...
+ archive_expsym_cmds_GCJ='if test "x`$SED 1q $export_symbols`" = xEXPORTS; then
+ cp $export_symbols $output_objdir/$soname.def;
+ else
+ echo EXPORTS > $output_objdir/$soname.def;
+ cat $export_symbols >> $output_objdir/$soname.def;
+ fi~
+ $CC -shared $output_objdir/$soname.def $libobjs $deplibs $compiler_flags -o $output_objdir/$soname ${wl}--enable-auto-image-base -Xlinker --out-implib -Xlinker $lib'
+ else
+ ld_shlibs_GCJ=no
+ fi
+ interix3*)
+ hardcode_shlibpath_var_GCJ=no
+ hardcode_libdir_flag_spec_GCJ='${wl}-rpath,$libdir'
+ export_dynamic_flag_spec_GCJ='${wl}-E'
+ # Hack: On Interix 3.x, we cannot compile PIC because of a broken gcc.
+ # Instead, shared libraries are loaded at an image base (0x10000000 by
+ # default) and relocated if they conflict, which is a slow very memory
+ # consuming and fragmenting process. To avoid this, we pick a random,
+ # 256 KiB-aligned image base between 0x50000000 and 0x6FFC0000 at link
+ # time. Moving up from 0x10000000 also allows more sbrk(2) space.
+ archive_cmds_GCJ='$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-h,$soname ${wl}--image-base,`expr ${RANDOM-$$} % 4096 / 2 \* 262144 + 1342177280` -o $lib'
+ archive_expsym_cmds_GCJ='sed "s,^,_," $export_symbols >$output_objdir/$soname.expsym~$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-h,$soname ${wl}--retain-symbols-file,$output_objdir/$soname.expsym ${wl}--image-base,`expr ${RANDOM-$$} % 4096 / 2 \* 262144 + 1342177280` -o $lib'
+ linux*)
+ tmp_addflag=
+ case $cc_basename,$host_cpu in
+ pgcc*) # Portland Group C compiler
+ whole_archive_flag_spec_GCJ='${wl}--whole-archive`for conv in $convenience\"\"; do test -n \"$conv\" && new_convenience=\"$new_convenience,$conv\"; done; $echo \"$new_convenience\"` ${wl}--no-whole-archive'
+ tmp_addflag=' $pic_flag'
+ pgf77* | pgf90* | pgf95*) # Portland Group f77 and f90 compilers
+ tmp_addflag=' $pic_flag -Mnomain' ;;
+ ecc*,ia64* | icc*,ia64*) # Intel C compiler on ia64
+ tmp_addflag=' -i_dynamic' ;;
+ efc*,ia64* | ifort*,ia64*) # Intel Fortran compiler on ia64
+ tmp_addflag=' -i_dynamic -nofor_main' ;;
+ ifc* | ifort*) # Intel Fortran compiler
+ tmp_addflag=' -nofor_main' ;;
+ esac
+ archive_cmds_GCJ='$CC -shared'"$tmp_addflag"' $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
+ if test $supports_anon_versioning = yes; then
+ archive_expsym_cmds_GCJ='$echo "{ global:" > $output_objdir/$libname.ver~
+ cat $export_symbols | sed -e "s/\(.*\)/\1;/" >> $output_objdir/$libname.ver~
+ $echo "local: *; };" >> $output_objdir/$libname.ver~
+ $CC -shared'"$tmp_addflag"' $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-version-script ${wl}$output_objdir/$libname.ver -o $lib'
+ fi
+ else
+ ld_shlibs_GCJ=no
+ fi
+ netbsd*)
+ if echo __ELF__ | $CC -E - | grep __ELF__ >/dev/null; then
+ archive_cmds_GCJ='$LD -Bshareable $libobjs $deplibs $linker_flags -o $lib'
+ wlarc=
+ else
+ archive_cmds_GCJ='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
+ archive_expsym_cmds_GCJ='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
+ fi
+ solaris*)
+ if $LD -v 2>&1 | grep 'BFD 2\.8' > /dev/null; then
+ ld_shlibs_GCJ=no
+ cat <<EOF 1>&2
+*** Warning: The releases 2.8.* of the GNU linker cannot reliably
+*** create shared libraries on Solaris systems. Therefore, libtool
+*** is disabling shared libraries support. We urge you to upgrade GNU
+*** binutils to release 2.9.1 or newer. Another option is to modify
+*** your PATH or compiler configuration so that the native linker is
+*** used, and then restart.
+EOF
+ elif $LD --help 2>&1 | grep ': supported targets:.* elf' > /dev/null; then
+ else
+ ld_shlibs_GCJ=no
+ fi
+ sysv5* | sco3.2v5* | sco5v6* | unixware* | OpenUNIX*)
+ case `$LD -v 2>&1` in
+ *\ [01].* | *\ 2.[0-9].* | *\ 2.1[0-5].*)
+ ld_shlibs_GCJ=no
+ cat <<_LT_EOF 1>&2
+*** Warning: Releases of the GNU linker prior to 2.16.91.0.3 can not
+*** reliably create shared libraries on SCO systems. Therefore, libtool
+*** binutils to release 2.16.91.0.3 or newer. Another option is to modify
+_LT_EOF
+ hardcode_libdir_flag_spec_GCJ='`test -z "$SCOABSPATH" && echo ${wl}-rpath,$libdir`'
+ archive_cmds_GCJ='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib'
+ archive_expsym_cmds_GCJ='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname,\${SCOABSPATH:+${install_libdir}/}$soname,-retain-symbols-file,$export_symbols -o $lib'
+ else
+ ld_shlibs_GCJ=no
+ fi
+ esac
+ sunos4*)
+ archive_cmds_GCJ='$LD -assert pure-text -Bshareable -o $lib $libobjs $deplibs $linker_flags'
+ wlarc=
+ hardcode_direct_GCJ=yes
+ else
+ ld_shlibs_GCJ=no
+ fi
+ esac
+ if test "$ld_shlibs_GCJ" = no; then
+ runpath_var=
+ fi
+ else
+ # PORTME fill in a description of your system's linker (not GNU ld)
+ case $host_os in
+ aix3*)
+ always_export_symbols_GCJ=yes
+ archive_expsym_cmds_GCJ='$LD -o $output_objdir/$soname $libobjs $deplibs $linker_flags -bE:$export_symbols -T512 -H512 -bM:SRE~$AR $AR_FLAGS $lib $output_objdir/$soname'
+ # Note: this linker hardcodes the directories in LIBPATH if there
+ # are no directories specified by -L.
+ if test "$GCC" = yes && test -z "$lt_prog_compiler_static"; then
+ # Neither direct hardcoding nor static linking is supported with a
+ # broken collect2.
+ hardcode_direct_GCJ=unsupported
+ fi
+ aix4* | aix5*)
+ # On IA64, the linker does run time linking by default, so we don't
+ # have to do anything special.
+ aix_use_runtimelinking=no
+ exp_sym_flag='-Bexport'
+ no_entry_flag=""
+ else
+ # If we're using GNU nm, then we don't want the "-C" option.
+ # -C means demangle to AIX nm, but means don't demangle with GNU nm
+ if $NM -V 2>&1 | grep 'GNU' > /dev/null; then
+ export_symbols_cmds_GCJ='$NM -Bpg $libobjs $convenience | awk '\''{ if (((\$2 == "T") || (\$2 == "D") || (\$2 == "B")) && (substr(\$3,1,1) != ".")) { print \$3 } }'\'' | sort -u > $export_symbols'
+ else
+ export_symbols_cmds_GCJ='$NM -BCpg $libobjs $convenience | awk '\''{ if (((\$2 == "T") || (\$2 == "D") || (\$2 == "B")) && (substr(\$3,1,1) != ".")) { print \$3 } }'\'' | sort -u > $export_symbols'
+ fi
+ # Test if we are trying to use run time linking or normal
+ # AIX style linking. If -brtl is somewhere in LDFLAGS, we
+ # need to do runtime linking.
+ case $host_os in aix4.[23]|aix4.[23].*|aix5*)
+ for ld_flag in $LDFLAGS; do
+ if (test $ld_flag = "-brtl" || test $ld_flag = "-Wl,-brtl"); then
+ aix_use_runtimelinking=yes
+ break
+ fi
+ done
+ esac
+ exp_sym_flag='-bexport'
+ no_entry_flag='-bnoentry'
+ fi
+ # When large executables or shared objects are built, AIX ld can
+ # have problems creating the table of contents. If linking a library
+ # or program results in "error TOC overflow" add -mminimal-toc to
+ # CXXFLAGS/CFLAGS for g++/gcc. In the cases where that is not
+ # enough to fix the problem, add -Wl,-bbigtoc to LDFLAGS.
+ archive_cmds_GCJ=''
+ hardcode_libdir_separator_GCJ=':'
+ link_all_deplibs_GCJ=yes
+ case $host_os in aix4.[012]|aix4.[012].*)
+ # We only want to do this on AIX 4.2 and lower, the check
+ # below for broken collect2 doesn't work under 4.3+
+ collect2name=`${CC} -print-prog-name=collect2`
+ if test -f "$collect2name" && \
+ strings "$collect2name" | grep resolve_lib_name >/dev/null
+ then
+ # We have reworked collect2
+ else
+ # We have old collect2
+ # It fails to find uninstalled libraries when the uninstalled
+ # path is not listed in the libpath. Setting hardcode_minus_L
+ # to unsupported forces relinking
+ fi
+ esac
+ shared_flag='-shared'
+ if test "$aix_use_runtimelinking" = yes; then
+ shared_flag="$shared_flag "'${wl}-G'
+ fi
+ else
+ # not using gcc
+ # VisualAge C++, Version 5.5 for AIX 5L for IA-64, Beta 3 Release
+ # chokes on -Wl,-G. The following line is correct:
+ shared_flag='-G'
+ else
+ shared_flag='${wl}-G'
+ else
+ shared_flag='${wl}-bM:SRE'
+ fi
+ fi
+ fi
+ # It seems that -bexpall does not export symbols beginning with
+ # underscore (_), so it is better to generate a list of symbols to export.
+ # Warning - without using the other runtime loading flags (-brtl),
+ # -berok will link without error, but may produce a broken library.
+ allow_undefined_flag_GCJ='-berok'
+ # Determine the default libpath from the value encoded in an empty executable.
+ cat >conftest.$ac_ext <<_ACEOF
+/* confdefs.h. */
+_ACEOF
+cat confdefs.h >>conftest.$ac_ext
+cat >>conftest.$ac_ext <<_ACEOF
+/* end confdefs.h. */
+int
+main ()
+ return 0;
+_ACEOF
+rm -f conftest.$ac_objext conftest$ac_exeext
+if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
+ (eval $ac_link) 2>conftest.er1
+ ac_status=$?
+ grep -v '^ *+' conftest.er1 >conftest.err
+ rm -f conftest.er1
+ cat conftest.err >&5
+ echo "$as_me:$LINENO: \$? = $ac_status" >&5
+ (exit $ac_status); } &&
+ { ac_try='test -z "$ac_cxx_werror_flag"
+ || test ! -s conftest.err'
+ { (eval echo "$as_me:$LINENO: \"$ac_try\"") >&5
+ (eval $ac_try) 2>&5
+ ac_status=$?
+ (exit $ac_status); }; } &&
+ { ac_try='test -s conftest$ac_exeext'
+ ac_status=$?
+ (exit $ac_status); }; }; then
+aix_libpath=`dump -H conftest$ac_exeext 2>/dev/null | $SED -n -e '/Import File Strings/,/^$/ { /^0/ { s/^0 *\(.*\)$/\1/; p; }
+# Check for a 64-bit object if we didn't find anything.
+if test -z "$aix_libpath"; then aix_libpath=`dump -HX64 conftest$ac_exeext 2>/dev/null | $SED -n -e '/Import File Strings/,/^$/ { /^0/ { s/^0 *\(.*\)$/\1/; p; }
+}'`; fi
+else
+ echo "$as_me: failed program was:" >&5
+sed 's/^/| /' conftest.$ac_ext >&5
+fi
+rm -f conftest.err conftest.$ac_objext \
+ conftest$ac_exeext conftest.$ac_ext
+if test -z "$aix_libpath"; then aix_libpath="/usr/lib:/lib"; fi
+ hardcode_libdir_flag_spec_GCJ='${wl}-blibpath:$libdir:'"$aix_libpath"
+ archive_expsym_cmds_GCJ="\$CC"' -o $output_objdir/$soname $libobjs $deplibs '"\${wl}$no_entry_flag"' $compiler_flags `if test "x${allow_undefined_flag}" != "x"; then echo "${wl}${allow_undefined_flag}"; else :; fi` '"\${wl}$exp_sym_flag:\$export_symbols $shared_flag"
+ else
+ hardcode_libdir_flag_spec_GCJ='${wl}-R $libdir:/usr/lib:/lib'
+ allow_undefined_flag_GCJ="-z nodefs"
+ archive_expsym_cmds_GCJ="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs '"\${wl}$no_entry_flag"' $compiler_flags ${wl}${allow_undefined_flag} '"\${wl}$exp_sym_flag:\$export_symbols"
+ else
+/* confdefs.h. */
+_ACEOF
+int
+main ()
+ return 0;
+_ACEOF
+ ac_status=$?
+ ac_status=$?
+ ac_status=$?
+}'`; fi
+else
+fi
+ # Warning - without using the other run time loading flags,
+ no_undefined_flag_GCJ=' ${wl}-bernotok'
+ allow_undefined_flag_GCJ=' ${wl}-berok'
+ # Exported symbols can be pulled into shared objects from archives
+ whole_archive_flag_spec_GCJ='$convenience'
+ archive_cmds_need_lc_GCJ=yes
+ # This is similar to how AIX traditionally builds its shared libraries.
+ archive_expsym_cmds_GCJ="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs ${wl}-bnoentry $compiler_flags ${wl}-bE:$export_symbols${allow_undefined_flag}~$AR $AR_FLAGS $output_objdir/$libname$release.a $output_objdir/$soname'
+ fi
+ fi
+ amigaos*)
+ # see comment about different semantics on the GNU ld section
+ ld_shlibs_GCJ=no
+ bsdi[45]*)
+ export_dynamic_flag_spec_GCJ=-rdynamic
+ # hardcode_libdir_flag_spec is actually meaningless, as there is
+ # no search path for DLLs.
+ hardcode_libdir_flag_spec_GCJ=' '
+ # Tell ltmain to make .lib files, not .a files.
+ libext=lib
+ # Tell ltmain to make .dll files, not .so files.
+ # FIXME: Setting linknames here is a bad hack.
+ archive_cmds_GCJ='$CC -o $lib $libobjs $compiler_flags `echo "$deplibs" | $SED -e '\''s/ -lc$//'\''` -link -dll~linknames='
+ # The linker will automatically build a .lib file if we build a DLL.
+ old_archive_From_new_cmds_GCJ='true'
+ # FIXME: Should let the user specify the lib program.
+ old_archive_cmds_GCJ='lib /OUT:$oldlib$oldobjs$old_deplibs'
+ fix_srcfile_path_GCJ='`cygpath -w "$srcfile"`'
+ case $host_os in
+ rhapsody* | darwin1.[012])
+ allow_undefined_flag_GCJ='${wl}-undefined ${wl}suppress'
+ *) # Darwin 1.3 on
+ if test -z ${MACOSX_DEPLOYMENT_TARGET} ; then
+ allow_undefined_flag_GCJ='${wl}-flat_namespace ${wl}-undefined ${wl}suppress'
+ else
+ case ${MACOSX_DEPLOYMENT_TARGET} in
+ 10.[012])
+ 10.*)
+ allow_undefined_flag_GCJ='${wl}-undefined ${wl}dynamic_lookup'
+ esac
+ fi
+ esac
+ archive_cmds_need_lc_GCJ=no
+ hardcode_automatic_GCJ=yes
+ whole_archive_flag_spec_GCJ=''
+ if test "$GCC" = yes ; then
+ output_verbose_link_cmd='echo'
+ archive_cmds_GCJ='$CC -dynamiclib $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring'
+ module_cmds_GCJ='$CC $allow_undefined_flag -o $lib -bundle $libobjs $deplibs$compiler_flags'
+ # Don't fix this by using the ld -exported_symbols_list flag, it doesn't exist in older darwin lds
+ archive_expsym_cmds_GCJ='sed -e "s,#.*,," -e "s,^[ ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -dynamiclib $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
+ module_expsym_cmds_GCJ='sed -e "s,#.*,," -e "s,^[ ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC $allow_undefined_flag -o $lib -bundle $libobjs $deplibs$compiler_flags~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
+ else
+ xlc*)
+ archive_cmds_GCJ='$CC -qmkshrobj $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-install_name ${wl}`echo $rpath/$soname` $verstring'
+ archive_expsym_cmds_GCJ='sed -e "s,#.*,," -e "s,^[ ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -qmkshrobj $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-install_name ${wl}$rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
+ ld_shlibs_GCJ=no
+ esac
+ fi
+ dgux*)
+ archive_cmds_GCJ='$LD -G -h $soname -o $lib $libobjs $deplibs $linker_flags'
+ freebsd1*)
+ ld_shlibs_GCJ=no
+ # FreeBSD 2.2.[012] allows us to include c++rt0.o to get C++ constructor
+ # support. Future versions do this automatically, but an explicit c++rt0.o
+ # does not break anything, and helps significantly (at the cost of a little
+ # extra space).
+ freebsd2.2*)
+ archive_cmds_GCJ='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags /usr/lib/c++rt0.o'
+ hardcode_libdir_flag_spec_GCJ='-R$libdir'
+ # Unfortunately, older versions of FreeBSD 2 do not have this feature.
+ freebsd2*)
+ archive_cmds_GCJ='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags'
+ # FreeBSD 3 and greater uses gcc -shared to do shared libraries.
+ freebsd* | kfreebsd*-gnu | dragonfly*)
+ archive_cmds_GCJ='$CC -shared -o $lib $libobjs $deplibs $compiler_flags'
+ hpux9*)
+ archive_cmds_GCJ='$rm $output_objdir/$soname~$CC -shared -fPIC ${wl}+b ${wl}$install_libdir -o $output_objdir/$soname $libobjs $deplibs $compiler_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
+ else
+ archive_cmds_GCJ='$rm $output_objdir/$soname~$LD -b +b $install_libdir -o $output_objdir/$soname $libobjs $deplibs $linker_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
+ fi
+ hardcode_libdir_flag_spec_GCJ='${wl}+b ${wl}$libdir'
+ hardcode_libdir_separator_GCJ=:
+ # hardcode_minus_L: Not really in the search PATH,
+ # but as the default location of the library.
+ hpux10*)
+ if test "$GCC" = yes -a "$with_gnu_ld" = no; then
+ archive_cmds_GCJ='$CC -shared -fPIC ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $libobjs $deplibs $compiler_flags'
+ else
+ archive_cmds_GCJ='$LD -b +h $soname +b $install_libdir -o $lib $libobjs $deplibs $linker_flags'
+ fi
+ if test "$with_gnu_ld" = no; then
+ fi
+ hpux11*)
+ case $host_cpu in
+ hppa*64*)
+ archive_cmds_GCJ='$CC -shared ${wl}+h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
+ ia64*)
+ archive_cmds_GCJ='$CC -shared ${wl}+h ${wl}$soname ${wl}+nodefaultrpath -o $lib $libobjs $deplibs $compiler_flags'
+ esac
+ else
+ case $host_cpu in
+ hppa*64*)
+ archive_cmds_GCJ='$CC -b ${wl}+h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
+ ia64*)
+ archive_cmds_GCJ='$CC -b ${wl}+h ${wl}$soname ${wl}+nodefaultrpath -o $lib $libobjs $deplibs $compiler_flags'
+ archive_cmds_GCJ='$CC -b ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $libobjs $deplibs $compiler_flags'
+ esac
+ fi
+ case $host_cpu in
+ hppa*64*|ia64*)
+ hardcode_libdir_flag_spec_ld_GCJ='+b $libdir'
+ esac
+ fi
+ irix5* | irix6* | nonstopux*)
+ archive_cmds_GCJ='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
+ else
+ archive_cmds_GCJ='$LD -shared $libobjs $deplibs $linker_flags -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
+ hardcode_libdir_flag_spec_ld_GCJ='-rpath $libdir'
+ fi
+ hardcode_libdir_flag_spec_GCJ='${wl}-rpath ${wl}$libdir'
+ netbsd*)
+ archive_cmds_GCJ='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags' # a.out
+ else
+ archive_cmds_GCJ='$LD -shared -o $lib $libobjs $deplibs $linker_flags' # ELF
+ fi
+ newsos6)
+ openbsd*)
+ if test -z "`echo __ELF__ | $CC -E - | grep __ELF__`" || test "$host_os-$host_cpu" = "openbsd2.8-powerpc"; then
+ archive_cmds_GCJ='$CC -shared $pic_flag -o $lib $libobjs $deplibs $compiler_flags'
+ archive_expsym_cmds_GCJ='$CC -shared $pic_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-retain-symbols-file,$export_symbols'
+ else
+ case $host_os in
+ openbsd[01].* | openbsd2.[0-7] | openbsd2.[0-7].*)
+ esac
+ fi
+ os2*)
+ archive_cmds_GCJ='$echo "LIBRARY $libname INITINSTANCE" > $output_objdir/$libname.def~$echo "DESCRIPTION \"$libname\"" >> $output_objdir/$libname.def~$echo DATA >> $output_objdir/$libname.def~$echo " SINGLE NONSHARED" >> $output_objdir/$libname.def~$echo EXPORTS >> $output_objdir/$libname.def~emxexp $libobjs >> $output_objdir/$libname.def~$CC -Zdll -Zcrtdll -o $lib $libobjs $deplibs $compiler_flags $output_objdir/$libname.def'
+ old_archive_From_new_cmds_GCJ='emximp -o $output_objdir/$libname.a $output_objdir/$libname.def'
+ osf3*)
+ allow_undefined_flag_GCJ=' ${wl}-expect_unresolved ${wl}\*'
+ archive_cmds_GCJ='$CC -shared${allow_undefined_flag} $libobjs $deplibs $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
+ else
+ allow_undefined_flag_GCJ=' -expect_unresolved \*'
+ archive_cmds_GCJ='$LD -shared${allow_undefined_flag} $libobjs $deplibs $linker_flags -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
+ fi
+ osf4* | osf5*) # as osf3* with the addition of -msym flag
+ archive_cmds_GCJ='$CC -shared${allow_undefined_flag} $libobjs $deplibs $compiler_flags ${wl}-msym ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
+ else
+ archive_cmds_GCJ='$LD -shared${allow_undefined_flag} $libobjs $deplibs $linker_flags -msym -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
+ archive_expsym_cmds_GCJ='for i in `cat $export_symbols`; do printf "%s %s\\n" -exported_symbol "\$i" >> $lib.exp; done; echo "-hidden">> $lib.exp~
+ $LD -shared${allow_undefined_flag} -input $lib.exp $linker_flags $libobjs $deplibs -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib~$rm $lib.exp'
+ # Both c and cxx compiler support -rpath directly
+ hardcode_libdir_flag_spec_GCJ='-rpath $libdir'
+ fi
+ solaris*)
+ no_undefined_flag_GCJ=' -z text'
+ wlarc='${wl}'
+ archive_cmds_GCJ='$CC -shared ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
+ archive_expsym_cmds_GCJ='$echo "{ global:" > $lib.exp~cat $export_symbols | $SED -e "s/\(.*\)/\1;/" >> $lib.exp~$echo "local: *; };" >> $lib.exp~
+ $CC -shared ${wl}-M ${wl}$lib.exp ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags~$rm $lib.exp'
+ else
+ wlarc=''
+ archive_cmds_GCJ='$LD -G${allow_undefined_flag} -h $soname -o $lib $libobjs $deplibs $linker_flags'
+ $LD -G${allow_undefined_flag} -M $lib.exp -h $soname -o $lib $libobjs $deplibs $linker_flags~$rm $lib.exp'
+ fi
+ case $host_os in
+ solaris2.[0-5] | solaris2.[0-5].*) ;;
+ # The compiler driver will combine linker options so we
+ # cannot just pass the convience library names through
+ # without $wl, iff we do not link with $LD.
+ # Luckily, gcc supports the same syntax we need for Sun Studio.
+ # Supported since Solaris 2.6 (maybe 2.5.1?)
+ case $wlarc in
+ whole_archive_flag_spec_GCJ='-z allextract$convenience -z defaultextract' ;;
+ whole_archive_flag_spec_GCJ='${wl}-z ${wl}allextract`for conv in $convenience\"\"; do test -n \"$conv\" && new_convenience=\"$new_convenience,$conv\"; done; $echo \"$new_convenience\"` ${wl}-z ${wl}defaultextract' ;;
+ esac ;;
+ esac
+ sunos4*)
+ if test "x$host_vendor" = xsequent; then
+ # Use $CC to link under sequent, because it throws in some extra .o
+ # files that make .init and .fini sections work.
+ archive_cmds_GCJ='$CC -G ${wl}-h $soname -o $lib $libobjs $deplibs $compiler_flags'
+ else
+ archive_cmds_GCJ='$LD -assert pure-text -Bstatic -o $lib $libobjs $deplibs $linker_flags'
+ fi
+ sysv4)
+ sni)
+ hardcode_direct_GCJ=yes # is this really true???
+ siemens)
+ ## LD is ld it makes a PLAMLIB
+ ## CC just makes a GrossModule.
+ archive_cmds_GCJ='$LD -G -o $lib $libobjs $deplibs $linker_flags'
+ reload_cmds_GCJ='$CC -r -o $output$reload_objs'
+ motorola)
+ hardcode_direct_GCJ=no #Motorola manual says yes, but my tests say they lie
+ esac
+ runpath_var='LD_RUN_PATH'
+ sysv4.3*)
+ export_dynamic_flag_spec_GCJ='-Bexport'
+ sysv4*MP*)
+ if test -d /usr/nec; then
+ hardcode_runpath_var=yes
+ ld_shlibs_GCJ=yes
+ fi
+ sysv4*uw2* | sysv5OpenUNIX* | sysv5UnixWare7.[01].[10]* | unixware7*)
+ no_undefined_flag_GCJ='${wl}-z,text'
+ if test "$GCC" = yes; then
+ archive_cmds_GCJ='$CC -shared ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+ archive_expsym_cmds_GCJ='$CC -shared ${wl}-Bexport:$export_symbols ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+ else
+ archive_cmds_GCJ='$CC -G ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+ archive_expsym_cmds_GCJ='$CC -G ${wl}-Bexport:$export_symbols ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+ fi
+ sysv5* | sco3.2v5* | sco5v6*)
+ # Note: We can NOT use -z defs as we might desire, because we do not
+ # link with -lc, and that would cause any symbols used from libc to
+ # always be unresolved, which means just about no library would
+ # ever link correctly. If we're not using GNU ld we use -z text
+ # though, which does catch some bad symbols but isn't as heavy-handed
+ # as -z defs.
+ allow_undefined_flag_GCJ='${wl}-z,nodefs'
+ hardcode_libdir_flag_spec_GCJ='`test -z "$SCOABSPATH" && echo ${wl}-R,$libdir`'
+ export_dynamic_flag_spec_GCJ='${wl}-Bexport'
+ archive_cmds_GCJ='$CC -shared ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+ archive_expsym_cmds_GCJ='$CC -shared ${wl}-Bexport:$export_symbols ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+ else
+ archive_cmds_GCJ='$CC -G ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+ archive_expsym_cmds_GCJ='$CC -G ${wl}-Bexport:$export_symbols ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+ fi
+ uts4*)
+ ld_shlibs_GCJ=no
+ esac
+ fi
+echo "$as_me:$LINENO: result: $ld_shlibs_GCJ" >&5
+echo "${ECHO_T}$ld_shlibs_GCJ" >&6
+test "$ld_shlibs_GCJ" = no && can_build_shared=no
-# dll_name = filename;
+# Do we need to explicitly link libc?
-# for (i=0; filename[i]; i++)
-# if (filename[i] == '/' || filename[i] == '\\' || filename[i] == ':')
-# dll_name = filename + i +1;
-# pe_header_offset = pe_get32 (dll, 0x3c);
-# opthdr_ofs = pe_header_offset + 4 + 20;
-# num_entries = pe_get32 (dll, opthdr_ofs + 92);
-# if (num_entries < 1) /* no exports */
-# return 1;
-# export_rva = pe_get32 (dll, opthdr_ofs + 96);
-# export_size = pe_get32 (dll, opthdr_ofs + 100);
-# nsections = pe_get16 (dll, pe_header_offset + 4 +2);
-# secptr = (pe_header_offset + 4 + 20 +
-# pe_get16 (dll, pe_header_offset + 4 + 16));
-# expptr = 0;
-# for (i = 0; i < nsections; i++)
-# char sname[8];
-# unsigned long secptr1 = secptr + 40 * i;
-# unsigned long vaddr = pe_get32 (dll, secptr1 + 12);
-# unsigned long vsize = pe_get32 (dll, secptr1 + 16);
-# unsigned long fptr = pe_get32 (dll, secptr1 + 20);
-# lseek(dll, secptr1, SEEK_SET);
-# read(dll, sname, 8);
-# if (vaddr <= export_rva && vaddr+vsize > export_rva)
-# expptr = fptr + (export_rva - vaddr);
-# if (export_rva + export_size > vaddr + vsize)
-# export_size = vsize - (export_rva - vaddr);
-# break;
-# expdata = (unsigned char*)malloc(export_size);
-# lseek (dll, expptr, SEEK_SET);
-# read (dll, expdata, export_size);
-# erva = expdata - export_rva;
-# nexp = pe_as32 (expdata+24);
-# name_rvas = pe_as32 (expdata+32);
-# printf ("EXPORTS\n");
-# for (i = 0; i<nexp; i++)
-# unsigned long name_rva = pe_as32 (erva+name_rvas+i*4);
-# printf ("\t%s @ %ld ;\n", erva+name_rva, 1+ i);
-# return 0;
-# /* impgen.c ends here */
+case "x$archive_cmds_need_lc_GCJ" in
+x|xyes)
+ # Assume -lc should be added
-EOF
+ if test "$enable_shared" = yes && test "$GCC" = yes; then
+ case $archive_cmds_GCJ in
+ # FIXME: we may have to deal with multi-command sequences.
+ '$CC '*)
+ # Test whether the compiler implicitly links with -lc since on some
+ # systems, -lgcc has to come before -lc. If gcc already passes -lc
+ # to ld, don't add -lc before -lgcc.
+ echo "$as_me:$LINENO: checking whether -lc should be explicitly linked in" >&5
+echo $ECHO_N "checking whether -lc should be explicitly linked in... $ECHO_C" >&6
+ $rm conftest*
+ printf "$lt_simple_compile_test_code" > conftest.$ac_ext
+ if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
+ (eval $ac_compile) 2>&5
+ ac_status=$?
+ (exit $ac_status); } 2>conftest.err; then
+ soname=conftest
+ lib=conftest
+ libobjs=conftest.$ac_objext
+ deplibs=
+ wl=$lt_prog_compiler_wl_GCJ
+ pic_flag=$lt_prog_compiler_pic_GCJ
+ compiler_flags=-v
+ linker_flags=-v
+ verstring=
+ output_objdir=.
+ libname=conftest
+ lt_save_allow_undefined_flag=$allow_undefined_flag_GCJ
+ if { (eval echo "$as_me:$LINENO: \"$archive_cmds_GCJ 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1\"") >&5
+ (eval $archive_cmds_GCJ 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1) 2>&5
+ ac_status=$?
+ then
+ else
+ fi
+ allow_undefined_flag_GCJ=$lt_save_allow_undefined_flag
+ else
+ cat conftest.err 1>&5
+ fi
+ $rm conftest*
+ echo "$as_me:$LINENO: result: $archive_cmds_need_lc_GCJ" >&5
+echo "${ECHO_T}$archive_cmds_need_lc_GCJ" >&6
+ esac
+ fi
+esac
+echo "$as_me:$LINENO: checking dynamic linker characteristics" >&5
+echo $ECHO_N "checking dynamic linker characteristics... $ECHO_C" >&6
+libname_spec='lib$name'
+soname_spec=
+shrext_cmds=".so"
+postinstall_cmds=
+finish_cmds=
+finish_eval=
+shlibpath_var=
+shlibpath_overrides_runpath=unknown
+version_type=none
+dynamic_linker="$host_os ld.so"
+sys_lib_dlsearch_path_spec="/lib /usr/lib"
+if test "$GCC" = yes; then
+ sys_lib_search_path_spec=`$CC -print-search-dirs | grep "^libraries:" | $SED -e "s/^libraries://" -e "s,=/,/,g"`
+ if echo "$sys_lib_search_path_spec" | grep ';' >/dev/null ; then
+ # if the path contains ";" then we assume it to be the separator
+ # otherwise default to the standard path separator (i.e. ":") - it is
+ # assumed that no part of a normal pathname contains ";" but that should
+ # okay in the real world where ";" in dirpaths is itself problematic.
+ sys_lib_search_path_spec=`echo "$sys_lib_search_path_spec" | $SED -e 's/;/ /g'`
+ else
+ sys_lib_search_path_spec=`echo "$sys_lib_search_path_spec" | $SED -e "s/$PATH_SEPARATOR/ /g"`
+ fi
+else
+ sys_lib_search_path_spec="/lib /usr/lib /usr/local/lib"
+fi
+need_lib_prefix=unknown
+hardcode_into_libs=no
+# when you set need_version to no, make sure it does not cause -set_version
+# flags to be left without arguments
+need_version=unknown
+case $host_os in
+aix3*)
+ version_type=linux
+ library_names_spec='${libname}${release}${shared_ext}$versuffix $libname.a'
+ shlibpath_var=LIBPATH
+ # AIX 3 has no versioning support, so we append a major version to the name.
+ soname_spec='${libname}${release}${shared_ext}$major'
+aix4* | aix5*)
+ need_lib_prefix=no
+ need_version=no
+ hardcode_into_libs=yes
+ # AIX 5 supports IA64
+ library_names_spec='${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext}$versuffix $libname${shared_ext}'
+ shlibpath_var=LD_LIBRARY_PATH
+ else
+ # With GCC up to 2.95.x, collect2 would create an import file
+ # for dependence libraries. The import file would start with
+ # the line `#! .'. This would cause the generated library to
+ # depend on `.', always an invalid library. This was fixed in
+ # development snapshots of GCC prior to 3.0.
+ case $host_os in
+ aix4 | aix4.[01] | aix4.[01].*)
+ if { echo '#if __GNUC__ > 2 || (__GNUC__ == 2 && __GNUC_MINOR__ >= 97)'
+ echo ' yes '
+ echo '#endif'; } | ${CC} -E - | grep yes > /dev/null; then
+ else
+ can_build_shared=no
+ fi
+ esac
+ # AIX (on Power*) has no versioning support, so currently we can not hardcode correct
+ # soname into executable. Probably we can add versioning support to
+ # collect2, so additional links can be useful in future.
+ # If using run time linking (on AIX 4.2 or later) use lib<name>.so
+ # instead of lib<name>.a to let people know that these are not
+ # typical AIX shared libraries.
+ library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname${shared_ext}'
+ else
+ # We preserve .a as extension for shared libraries through AIX4.2
+ # and later when we are not doing run time linking.
+ library_names_spec='${libname}${release}.a $libname.a'
+ fi
+ fi
+amigaos*)
+ library_names_spec='$libname.ixlibrary $libname.a'
+ # Create ${libname}_ixlibrary.a entries in /sys/libs.
+ finish_eval='for lib in `ls $libdir/*.ixlibrary 2>/dev/null`; do libname=`$echo "X$lib" | $Xsed -e '\''s%^.*/\([^/]*\)\.ixlibrary$%\1%'\''`; test $rm /sys/libs/${libname}_ixlibrary.a; $show "cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a"; cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a || exit 1; done'
+beos*)
+ library_names_spec='${libname}${shared_ext}'
+ dynamic_linker="$host_os ld.so"
+ shlibpath_var=LIBRARY_PATH
+bsdi[45]*)
+ need_version=no
+ finish_cmds='PATH="\$PATH:/sbin" ldconfig $libdir'
+ sys_lib_search_path_spec="/shlib /usr/lib /usr/X11/lib /usr/contrib/lib /lib /usr/local/lib"
+ sys_lib_dlsearch_path_spec="/shlib /usr/lib /usr/local/lib"
+ # the default ld.so.conf also contains /usr/contrib/lib and
+ # /usr/X11R6/lib (/usr/X11 is a link to /usr/X11R6), but let us allow
+ # libtool to hard-code these into programs
+cygwin* | mingw* | pw32*)
+ version_type=windows
+ shrext_cmds=".dll"
+ need_version=no
+ case $GCC,$host_os in
+ yes,cygwin* | yes,mingw* | yes,pw32*)
+ library_names_spec='$libname.dll.a'
+ # DLL is installed to $(libdir)/../bin by postinstall_cmds
+ postinstall_cmds='base_file=`basename \${file}`~
+ dlpath=`$SHELL 2>&1 -c '\''. $dir/'\''\${base_file}'\''i;echo \$dlname'\''`~
+ dldir=$destdir/`dirname \$dlpath`~
+ test -d \$dldir || mkdir -p \$dldir~
+ $install_prog $dir/$dlname \$dldir/$dlname~
+ chmod a+x \$dldir/$dlname'
+ postuninstall_cmds='dldll=`$SHELL 2>&1 -c '\''. $file; echo \$dlname'\''`~
+ dlpath=$dir/\$dldll~
+ $rm \$dlpath'
+ shlibpath_overrides_runpath=yes
+ case $host_os in
+ cygwin*)
+ # Cygwin DLLs use 'cyg' prefix rather than 'lib'
+ soname_spec='`echo ${libname} | sed -e 's/^lib/cyg/'``echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
+ sys_lib_search_path_spec="/usr/lib /lib/w32api /lib /usr/local/lib"
+ mingw*)
+ # MinGW DLLs use traditional 'lib' prefix
+ soname_spec='${libname}`echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
+ if echo "$sys_lib_search_path_spec" | grep ';[c-zC-Z]:/' >/dev/null; then
+ # It is most probably a Windows format PATH printed by
+ # mingw gcc, but we are running on Cygwin. Gcc prints its search
+ # path with ; separators, and with drive letters. We can handle the
+ # drive letters (cygwin fileutils understands them), so leave them,
+ # especially as we might pass files found there to a mingw objdump,
+ # which wouldn't understand a cygwinified path. Ahh.
+ else
+ fi
+ pw32*)
+ # pw32 DLLs use 'pw' prefix rather than 'lib'
+ library_names_spec='`echo ${libname} | sed -e 's/^lib/pw/'``echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
+ esac
+ library_names_spec='${libname}`echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext} $libname.lib'
esac
+ dynamic_linker='Win32 ld.exe'
+ # FIXME: first we should search . and the directory the executable is in
+ shlibpath_var=PATH
- # We use sed instead of cat because bash on DJGPP gets confused if
- # if finds mixed CR/LF and LF-only lines. Since sed operates in
- # text mode, it properly converts lines to CR/LF. This bash problem
- # is reportedly fixed, but why not run on old versions too?
- sed '$q' "$ltmain" >> "${ofile}T" || (rm -f "${ofile}T"; exit 1)
+darwin* | rhapsody*)
+ dynamic_linker="$host_os dyld"
+ version_type=darwin
+ need_version=no
+ library_names_spec='${libname}${release}${versuffix}$shared_ext ${libname}${release}${major}$shared_ext ${libname}$shared_ext'
+ soname_spec='${libname}${release}${major}$shared_ext'
+ shlibpath_var=DYLD_LIBRARY_PATH
+ shrext_cmds='`test .$module = .yes && echo .so || echo .dylib`'
+ # Apple's gcc prints 'gcc -print-search-dirs' doesn't operate the same.
+ sys_lib_search_path_spec=`$CC -print-search-dirs | tr "\n" "$PATH_SEPARATOR" | sed -e 's/libraries:/@libraries:/' | tr "@" "\n" | grep "^libraries:" | sed -e "s/^libraries://" -e "s,=/,/,g" -e "s,$PATH_SEPARATOR, ,g" -e "s,.*,& /lib /usr/lib /usr/local/lib,g"`
+ else
+ sys_lib_search_path_spec='/lib /usr/lib /usr/local/lib'
+ fi
+ sys_lib_dlsearch_path_spec='/usr/local/lib /lib /usr/lib'
- mv -f "${ofile}T" "$ofile" || \
- (rm -f "$ofile" && cp "${ofile}T" "$ofile" && rm -f "${ofile}T")
- chmod +x "$ofile"
+dgux*)
+ need_version=no
+ library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname$shared_ext'
+freebsd1*)
+ dynamic_linker=no
+kfreebsd*-gnu)
+ need_version=no
+ library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${shared_ext}'
+ shlibpath_overrides_runpath=no
+ dynamic_linker='GNU ld.so'
+freebsd* | dragonfly*)
+ # DragonFly does not have aout. When/if they implement a new
+ # versioning mechanism, adjust this.
+ if test -x /usr/bin/objformat; then
+ objformat=`/usr/bin/objformat`
+ else
+ case $host_os in
+ freebsd[123]*) objformat=aout ;;
+ *) objformat=elf ;;
+ esac
+ fi
+ version_type=freebsd-$objformat
+ case $version_type in
+ freebsd-elf*)
+ library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext} $libname${shared_ext}'
+ need_version=no
+ freebsd-*)
+ library_names_spec='${libname}${release}${shared_ext}$versuffix $libname${shared_ext}$versuffix'
+ need_version=yes
+ esac
+ case $host_os in
+ freebsd2*)
+ freebsd3.[01]* | freebsdelf3.[01]*)
+ freebsd3.[2-9]* | freebsdelf3.[2-9]* | \
+ freebsd4.[0-5] | freebsdelf4.[0-5] | freebsd4.1.1 | freebsdelf4.1.1)
+ freebsd*) # from 4.6 on
+ esac
+gnu*)
+ need_version=no
+ library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}${major} ${libname}${shared_ext}'
+hpux9* | hpux10* | hpux11*)
+ # Give a soname corresponding to the major version so that dld.sl refuses to
+ # link against other versions.
+ version_type=sunos
+ need_version=no
+ case $host_cpu in
+ ia64*)
+ shrext_cmds='.so'
+ dynamic_linker="$host_os dld.so"
+ shlibpath_overrides_runpath=yes # Unless +noenvvar is specified.
+ if test "X$HPUX_IA64_MODE" = X32; then
+ sys_lib_search_path_spec="/usr/lib/hpux32 /usr/local/lib/hpux32 /usr/local/lib"
+ else
+ sys_lib_search_path_spec="/usr/lib/hpux64 /usr/local/lib/hpux64"
+ fi
+ sys_lib_dlsearch_path_spec=$sys_lib_search_path_spec
+ hppa*64*)
+ shrext_cmds='.sl'
+ dynamic_linker="$host_os dld.sl"
+ shlibpath_var=LD_LIBRARY_PATH # How should we handle SHLIB_PATH
+ sys_lib_search_path_spec="/usr/lib/pa20_64 /usr/ccs/lib/pa20_64"
+ shrext_cmds='.sl'
+ shlibpath_var=SHLIB_PATH
+ shlibpath_overrides_runpath=no # +s is required to enable SHLIB_PATH
+ esac
+ # HP-UX runs *really* slowly unless shared libraries are mode 555.
+ postinstall_cmds='chmod 555 $lib'
+interix3*)
+ need_version=no
+ dynamic_linker='Interix 3.x ld.so.1 (PE, like ELF)'
+irix5* | irix6* | nonstopux*)
+ case $host_os in
+ nonstopux*) version_type=nonstopux ;;
+ if test "$lt_cv_prog_gnu_ld" = yes; then
+ else
+ version_type=irix
+ fi ;;
+ esac
+ need_version=no
+ library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext} $libname${shared_ext}'
+ case $host_os in
+ irix5* | nonstopux*)
+ libsuff= shlibsuff=
+ case $LD in # libtool.m4 will add one of these switches to LD
+ *-32|*"-32 "|*-melf32bsmip|*"-melf32bsmip ")
+ libsuff= shlibsuff= libmagic=32-bit;;
+ *-n32|*"-n32 "|*-melf32bmipn32|*"-melf32bmipn32 ")
+ libsuff=32 shlibsuff=N32 libmagic=N32;;
+ *-64|*"-64 "|*-melf64bmip|*"-melf64bmip ")
+ libsuff=64 shlibsuff=64 libmagic=64-bit;;
+ *) libsuff= shlibsuff= libmagic=never-match;;
+ esac
+ esac
+ shlibpath_var=LD_LIBRARY${shlibsuff}_PATH
+ sys_lib_search_path_spec="/usr/lib${libsuff} /lib${libsuff} /usr/local/lib${libsuff}"
+ sys_lib_dlsearch_path_spec="/usr/lib${libsuff} /lib${libsuff}"
+# No shared lib support for Linux oldld, aout, or coff.
+linux*oldld* | linux*aout* | linux*coff*)
+ dynamic_linker=no
+# This must be Linux ELF.
+linux*)
+ need_version=no
+ finish_cmds='PATH="\$PATH:/sbin" ldconfig -n $libdir'
+ # This implies no fast_install, which is unacceptable.
+ # Some rework will be needed to allow for fast_install
+ # before this can be enabled.
+ # find out which ABI we are using
+ libsuff=
+ case "$host_cpu" in
+ x86_64*|s390x*|powerpc64*)
+ echo '#line 17444 "configure"' > conftest.$ac_ext
+ ac_status=$?
+ (exit $ac_status); }; then
+ case `/usr/bin/file conftest.$ac_objext` in
+ *64-bit*)
+ libsuff=64
+ sys_lib_search_path_spec="/lib${libsuff} /usr/lib${libsuff} /usr/local/lib${libsuff}"
+ esac
+ fi
+ rm -rf conftest*
+ esac
+ # Append ld.so.conf contents to the search path
+ if test -f /etc/ld.so.conf; then
+ lt_ld_extra=`awk '/^include / { system(sprintf("cd /etc; cat %s", \$2)); skip = 1; } { if (!skip) print \$0; skip = 0; }' < /etc/ld.so.conf | $SED -e 's/#.*//;s/[:, ]/ /g;s/=[^=]*$//;s/=[^= ]* / /g;/^$/d' | tr '\n' ' '`
+ sys_lib_dlsearch_path_spec="/lib${libsuff} /usr/lib${libsuff} $lt_ld_extra"
+ fi
+ # We used to test for /lib/ld.so.1 and disable shared libraries on
+ # powerpc, because MkLinux only supported shared libraries with the
+ # GNU dynamic linker. Since this was broken with cross compilers,
+ # most powerpc-linux boxes support dynamic linking these days and
+ # people can always --disable-shared, the test was removed, and we
+ # assume the GNU/Linux dynamic linker is in use.
+ dynamic_linker='GNU/Linux ld.so'
+knetbsd*-gnu)
+ need_version=no
+netbsd*)
+ need_version=no
+ library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${shared_ext}$versuffix'
+ finish_cmds='PATH="\$PATH:/sbin" ldconfig -m $libdir'
+ dynamic_linker='NetBSD (a.out) ld.so'
+ else
+ dynamic_linker='NetBSD ld.elf_so'
+ fi
+newsos6)
+nto-qnx*)
+ need_version=no
+openbsd*)
+ sys_lib_dlsearch_path_spec="/usr/lib"
+ # Some older versions of OpenBSD (3.3 at least) *do* need versioned libs.
+ case $host_os in
+ openbsd3.3 | openbsd3.3.*) need_version=yes ;;
+ *) need_version=no ;;
+ esac
+ case $host_os in
+ openbsd2.[89] | openbsd2.[89].*)
+ esac
+ else
+ fi
+os2*)
+ libname_spec='$name'
+ library_names_spec='$libname${shared_ext} $libname.a'
+ dynamic_linker='OS/2 ld.exe'
+osf3* | osf4* | osf5*)
+ version_type=osf
+ need_version=no
+ sys_lib_search_path_spec="/usr/shlib /usr/ccs/lib /usr/lib/cmplrs/cc /usr/lib /usr/local/lib /var/shlib"
+ sys_lib_dlsearch_path_spec="$sys_lib_search_path_spec"
+solaris*)
+ need_version=no
+ # ldd complains unless libraries are executable
+ postinstall_cmds='chmod +x $lib'
+sunos4*)
+ finish_cmds='PATH="\$PATH:/usr/etc" ldconfig $libdir'
+ if test "$with_gnu_ld" = yes; then
+ fi
+ need_version=yes
+sysv4 | sysv4.3*)
+ case $host_vendor in
+ sni)
+ export_dynamic_flag_spec='${wl}-Blargedynsym'
+ siemens)
+ motorola)
+ need_version=no
+ sys_lib_search_path_spec='/lib /usr/lib /usr/ccs/lib'
+ esac
+sysv4*MP*)
+ if test -d /usr/nec ;then
+ library_names_spec='$libname${shared_ext}.$versuffix $libname${shared_ext}.$major $libname${shared_ext}'
+ soname_spec='$libname${shared_ext}.$major'
+ fi
+sysv5* | sco3.2v5* | sco5v6* | unixware* | OpenUNIX* | sysv4*uw2*)
+ version_type=freebsd-elf
+ need_version=no
+ sys_lib_search_path_spec='/usr/local/lib /usr/gnu/lib /usr/ccs/lib /usr/lib /lib'
+ else
+ sys_lib_search_path_spec='/usr/ccs/lib /usr/lib'
+ case $host_os in
+ sco3.2v5*)
+ sys_lib_search_path_spec="$sys_lib_search_path_spec /lib"
+ esac
+ fi
+ sys_lib_dlsearch_path_spec='/usr/lib'
+uts4*)
+ dynamic_linker=no
+esac
+echo "$as_me:$LINENO: result: $dynamic_linker" >&5
+echo "${ECHO_T}$dynamic_linker" >&6
+test "$dynamic_linker" = no && can_build_shared=no
+variables_saved_for_relink="PATH $shlibpath_var $runpath_var"
+ variables_saved_for_relink="$variables_saved_for_relink GCC_EXEC_PREFIX COMPILER_PATH LIBRARY_PATH"
fi
+echo "$as_me:$LINENO: checking how to hardcode library paths into programs" >&5
+echo $ECHO_N "checking how to hardcode library paths into programs... $ECHO_C" >&6
+hardcode_action_GCJ=
+if test -n "$hardcode_libdir_flag_spec_GCJ" || \
+ test -n "$runpath_var_GCJ" || \
+ test "X$hardcode_automatic_GCJ" = "Xyes" ; then
+ # We can hardcode non-existant directories.
+ if test "$hardcode_direct_GCJ" != no &&
+ # If the only mechanism to avoid hardcoding is shlibpath_var, we
+ # have to relink, otherwise we might link with an installed library
+ # when we should be linking with a yet-to-be-installed one
+ ## test "$_LT_AC_TAGVAR(hardcode_shlibpath_var, GCJ)" != no &&
+ test "$hardcode_minus_L_GCJ" != no; then
+ # Linking always hardcodes the temporary library directory.
+ hardcode_action_GCJ=relink
+ else
+ # We can link without hardcoding, and we can hardcode nonexisting dirs.
+ hardcode_action_GCJ=immediate
+ fi
+else
+ # We cannot hardcode anything, or else we can only hardcode existing
+ # directories.
+ hardcode_action_GCJ=unsupported
+fi
+echo "$as_me:$LINENO: result: $hardcode_action_GCJ" >&5
+echo "${ECHO_T}$hardcode_action_GCJ" >&6
+if test "$hardcode_action_GCJ" = relink; then
+ # Fast installation is not supported
+ enable_fast_install=no
+elif test "$shlibpath_overrides_runpath" = yes ||
+ test "$enable_shared" = no; then
+ # Fast installation is not necessary
+ enable_fast_install=needless
+fi
+# The else clause should only fire when bootstrapping the
+# libtool distribution, otherwise you forgot to ship ltmain.sh
+# with your package, and you will get complaints that there are
+# no rules to generate ltmain.sh.
+if test -f "$ltmain"; then
+ # See if we are running on zsh, and set the options which allow our commands through
+ # without removal of \ escapes.
+ if test -n "${ZSH_VERSION+set}" ; then
+ setopt NO_GLOB_SUBST
+ fi
+ # Now quote all the things that may contain metacharacters while being
+ # careful not to overquote the AC_SUBSTed values. We take copies of the
+ # variables and quote the copies for generation of the libtool script.
+ for var in echo old_CC old_CFLAGS AR AR_FLAGS EGREP RANLIB LN_S LTCC LTCFLAGS NM \
+ SED SHELL STRIP \
+ libname_spec library_names_spec soname_spec extract_expsyms_cmds \
+ old_striplib striplib file_magic_cmd finish_cmds finish_eval \
+ deplibs_check_method reload_flag reload_cmds need_locks \
+ lt_cv_sys_global_symbol_pipe lt_cv_sys_global_symbol_to_cdecl \
+ lt_cv_sys_global_symbol_to_c_name_address \
+ sys_lib_search_path_spec sys_lib_dlsearch_path_spec \
+ old_postinstall_cmds old_postuninstall_cmds \
+ compiler_GCJ \
+ CC_GCJ \
+ LD_GCJ \
+ lt_prog_compiler_wl_GCJ \
+ lt_prog_compiler_pic_GCJ \
+ lt_prog_compiler_static_GCJ \
+ lt_prog_compiler_no_builtin_flag_GCJ \
+ export_dynamic_flag_spec_GCJ \
+ thread_safe_flag_spec_GCJ \
+ whole_archive_flag_spec_GCJ \
+ enable_shared_with_static_runtimes_GCJ \
+ old_archive_cmds_GCJ \
+ old_archive_from_new_cmds_GCJ \
+ predep_objects_GCJ \
+ postdep_objects_GCJ \
+ predeps_GCJ \
+ postdeps_GCJ \
+ compiler_lib_search_path_GCJ \
+ archive_cmds_GCJ \
+ archive_expsym_cmds_GCJ \
+ postinstall_cmds_GCJ \
+ postuninstall_cmds_GCJ \
+ old_archive_from_expsyms_cmds_GCJ \
+ allow_undefined_flag_GCJ \
+ no_undefined_flag_GCJ \
+ export_symbols_cmds_GCJ \
+ hardcode_libdir_flag_spec_GCJ \
+ hardcode_libdir_flag_spec_ld_GCJ \
+ hardcode_libdir_separator_GCJ \
+ hardcode_automatic_GCJ \
+ module_cmds_GCJ \
+ module_expsym_cmds_GCJ \
+ lt_cv_prog_compiler_c_o_GCJ \
+ exclude_expsyms_GCJ \
+ include_expsyms_GCJ; do
+ case $var in
+ old_archive_cmds_GCJ | \
+ old_archive_from_new_cmds_GCJ | \
+ archive_cmds_GCJ | \
+ archive_expsym_cmds_GCJ | \
+ module_cmds_GCJ | \
+ module_expsym_cmds_GCJ | \
+ old_archive_from_expsyms_cmds_GCJ | \
+ export_symbols_cmds_GCJ | \
+ extract_expsyms_cmds | reload_cmds | finish_cmds | \
+ postinstall_cmds | postuninstall_cmds | \
+ old_postinstall_cmds | old_postuninstall_cmds | \
+ sys_lib_search_path_spec | sys_lib_dlsearch_path_spec)
+ # Double-quote double-evaled strings.
+ eval "lt_$var=\\\"\`\$echo \"X\$$var\" | \$Xsed -e \"\$double_quote_subst\" -e \"\$sed_quote_subst\" -e \"\$delay_variable_subst\"\`\\\""
+ eval "lt_$var=\\\"\`\$echo \"X\$$var\" | \$Xsed -e \"\$sed_quote_subst\"\`\\\""
+ esac
+ done
+ case $lt_echo in
+ *'\$0 --fallback-echo"')
+ lt_echo=`$echo "X$lt_echo" | $Xsed -e 's/\\\\\\\$0 --fallback-echo"$/$0 --fallback-echo"/'`
+ esac
+cfgfile="$ofile"
+ cat <<__EOF__ >> "$cfgfile"
+# ### BEGIN LIBTOOL TAG CONFIG: $tagname
+# Libtool was configured on host `(hostname || uname -n) 2>/dev/null | sed 1q`:
+# Shell to use when invoking shell scripts.
+SHELL=$lt_SHELL
+# Whether or not to build shared libraries.
+build_libtool_libs=$enable_shared
+# Whether or not to build static libraries.
+build_old_libs=$enable_static
+# Whether or not to add -lc for building shared libraries.
+build_libtool_need_lc=$archive_cmds_need_lc_GCJ
+# Whether or not to disallow shared libs when runtime libs are static
+allow_libtool_libs_with_static_runtimes=$enable_shared_with_static_runtimes_GCJ
+# Whether or not to optimize for fast installation.
+fast_install=$enable_fast_install
+# The host system.
+host_alias=$host_alias
+host=$host
+host_os=$host_os
+# The build system.
+build_alias=$build_alias
+build=$build
+build_os=$build_os
+# An echo program that does not interpret backslashes.
+echo=$lt_echo
+# The archiver.
+AR=$lt_AR
+AR_FLAGS=$lt_AR_FLAGS
+# A C compiler.
+LTCC=$lt_LTCC
+# LTCC compiler flags.
+LTCFLAGS=$lt_LTCFLAGS
+# A language-specific compiler.
+CC=$lt_compiler_GCJ
+# Is the compiler the GNU C compiler?
+with_gcc=$GCC_GCJ
+# An ERE matcher.
+EGREP=$lt_EGREP
+# The linker used to build libraries.
+LD=$lt_LD_GCJ
+# Whether we need hard or soft links.
+LN_S=$lt_LN_S
+# A BSD-compatible nm program.
+NM=$lt_NM
+# A symbol stripping program
+STRIP=$lt_STRIP
+# Used to examine libraries when file_magic_cmd begins "file"
+MAGIC_CMD=$MAGIC_CMD
+# Used on cygwin: DLL creation program.
+DLLTOOL="$DLLTOOL"
+# Used on cygwin: object dumper.
+OBJDUMP="$OBJDUMP"
+# Used on cygwin: assembler.
+AS="$AS"
+# The name of the directory that contains temporary libtool files.
+objdir=$objdir
+# How to create reloadable object files.
+reload_flag=$lt_reload_flag
+reload_cmds=$lt_reload_cmds
+# How to pass a linker flag through the compiler.
+wl=$lt_lt_prog_compiler_wl_GCJ
+# Object file suffix (normally "o").
+objext="$ac_objext"
+# Old archive suffix (normally "a").
+libext="$libext"
+# Shared library suffix (normally ".so").
+shrext_cmds='$shrext_cmds'
+# Executable file suffix (normally "").
+exeext="$exeext"
+# Additional compiler flags for building library objects.
+pic_flag=$lt_lt_prog_compiler_pic_GCJ
+pic_mode=$pic_mode
+# What is the maximum length of a command?
+max_cmd_len=$lt_cv_sys_max_cmd_len
+# Does compiler simultaneously support -c and -o options?
+compiler_c_o=$lt_lt_cv_prog_compiler_c_o_GCJ
+# Must we lock files when doing compilation?
+need_locks=$lt_need_locks
+# Do we need the lib prefix for modules?
+need_lib_prefix=$need_lib_prefix
+# Do we need a version for libraries?
+need_version=$need_version
+# Whether dlopen is supported.
+dlopen_support=$enable_dlopen
+# Whether dlopen of programs is supported.
+dlopen_self=$enable_dlopen_self
+# Whether dlopen of statically linked programs is supported.
+dlopen_self_static=$enable_dlopen_self_static
+# Compiler flag to prevent dynamic linking.
+link_static_flag=$lt_lt_prog_compiler_static_GCJ
+# Compiler flag to turn off builtin functions.
+no_builtin_flag=$lt_lt_prog_compiler_no_builtin_flag_GCJ
+# Compiler flag to allow reflexive dlopens.
+export_dynamic_flag_spec=$lt_export_dynamic_flag_spec_GCJ
+# Compiler flag to generate shared objects directly from archives.
+whole_archive_flag_spec=$lt_whole_archive_flag_spec_GCJ
+# Compiler flag to generate thread-safe objects.
+thread_safe_flag_spec=$lt_thread_safe_flag_spec_GCJ
+# Library versioning type.
+version_type=$version_type
+# Format of library name prefix.
+libname_spec=$lt_libname_spec
+# List of archive names. First name is the real one, the rest are links.
+# The last name is the one that the linker finds with -lNAME.
+library_names_spec=$lt_library_names_spec
+# The coded name of the library, if different from the real name.
+soname_spec=$lt_soname_spec
+# Commands used to build and install an old-style archive.
+RANLIB=$lt_RANLIB
+old_archive_cmds=$lt_old_archive_cmds_GCJ
+old_postinstall_cmds=$lt_old_postinstall_cmds
+old_postuninstall_cmds=$lt_old_postuninstall_cmds
+# Create an old-style archive from a shared archive.
+old_archive_from_new_cmds=$lt_old_archive_from_new_cmds_GCJ
+# Create a temporary old-style archive to link instead of a shared archive.
+old_archive_from_expsyms_cmds=$lt_old_archive_from_expsyms_cmds_GCJ
+# Commands used to build and install a shared archive.
+archive_cmds=$lt_archive_cmds_GCJ
+archive_expsym_cmds=$lt_archive_expsym_cmds_GCJ
+postinstall_cmds=$lt_postinstall_cmds
+postuninstall_cmds=$lt_postuninstall_cmds
+# Commands used to build a loadable module (assumed same as above if empty)
+module_cmds=$lt_module_cmds_GCJ
+module_expsym_cmds=$lt_module_expsym_cmds_GCJ
+# Commands to strip libraries.
+old_striplib=$lt_old_striplib
+striplib=$lt_striplib
+# Dependencies to place before the objects being linked to create a
+# shared library.
+predep_objects=$lt_predep_objects_GCJ
+# Dependencies to place after the objects being linked to create a
+# shared library.
+postdep_objects=$lt_postdep_objects_GCJ
+# shared library.
+predeps=$lt_predeps_GCJ
+# shared library.
+postdeps=$lt_postdeps_GCJ
+# The library search path used internally by the compiler when linking
+# a shared library.
+compiler_lib_search_path=$lt_compiler_lib_search_path_GCJ
+# Method to check whether dependent libraries are shared objects.
+deplibs_check_method=$lt_deplibs_check_method
+# Command to use when deplibs_check_method == file_magic.
+file_magic_cmd=$lt_file_magic_cmd
+# Flag that allows shared libraries with undefined symbols to be built.
+allow_undefined_flag=$lt_allow_undefined_flag_GCJ
+# Flag that forces no undefined symbols.
+no_undefined_flag=$lt_no_undefined_flag_GCJ
+# Commands used to finish a libtool library installation in a directory.
+finish_cmds=$lt_finish_cmds
+# Same as above, but a single script fragment to be evaled but not shown.
+finish_eval=$lt_finish_eval
+# Take the output of nm and produce a listing of raw symbols and C names.
+global_symbol_pipe=$lt_lt_cv_sys_global_symbol_pipe
+# Transform the output of nm in a proper C declaration
+global_symbol_to_cdecl=$lt_lt_cv_sys_global_symbol_to_cdecl
+# Transform the output of nm in a C name address pair
+global_symbol_to_c_name_address=$lt_lt_cv_sys_global_symbol_to_c_name_address
+# This is the shared library runtime path variable.
+runpath_var=$runpath_var
+# This is the shared library path variable.
+shlibpath_var=$shlibpath_var
+# Is shlibpath searched before the hard-coded library search path?
+shlibpath_overrides_runpath=$shlibpath_overrides_runpath
+# How to hardcode a shared library path into an executable.
+hardcode_action=$hardcode_action_GCJ
+# Whether we should hardcode library paths into libraries.
+hardcode_into_libs=$hardcode_into_libs
+# Flag to hardcode \$libdir into a binary during linking.
+# This must work even if \$libdir does not exist.
+hardcode_libdir_flag_spec=$lt_hardcode_libdir_flag_spec_GCJ
+# If ld is used when linking, flag to hardcode \$libdir into
+# a binary during linking. This must work even if \$libdir does
+# not exist.
+hardcode_libdir_flag_spec_ld=$lt_hardcode_libdir_flag_spec_ld_GCJ
+# Whether we need a single -rpath flag with a separated argument.
+hardcode_libdir_separator=$lt_hardcode_libdir_separator_GCJ
+# Set to yes if using DIR/libNAME${shared_ext} during linking hardcodes DIR into the
+# resulting binary.
+hardcode_direct=$hardcode_direct_GCJ
+# Set to yes if using the -LDIR flag during linking hardcodes DIR into the
+hardcode_minus_L=$hardcode_minus_L_GCJ
+# Set to yes if using SHLIBPATH_VAR=DIR during linking hardcodes DIR into
+# the resulting binary.
+hardcode_shlibpath_var=$hardcode_shlibpath_var_GCJ
+# Set to yes if building a shared library automatically hardcodes DIR into the library
+# and all subsequent libraries and executables linked against it.
+hardcode_automatic=$hardcode_automatic_GCJ
+# Variables whose values should be saved in libtool wrapper scripts and
+# restored at relink time.
+variables_saved_for_relink="$variables_saved_for_relink"
+# Whether libtool must link a program against all its dependency libraries.
+link_all_deplibs=$link_all_deplibs_GCJ
+# Compile-time system search path for libraries
+sys_lib_search_path_spec=$lt_sys_lib_search_path_spec
+# Run-time system search path for libraries
+sys_lib_dlsearch_path_spec=$lt_sys_lib_dlsearch_path_spec
+# Fix the shell variable \$srcfile for the compiler.
+fix_srcfile_path="$fix_srcfile_path_GCJ"
+# Set to yes if exported symbols are required.
+always_export_symbols=$always_export_symbols_GCJ
+# The commands to list exported symbols.
+export_symbols_cmds=$lt_export_symbols_cmds_GCJ
+# The commands to extract the exported symbol list from a shared archive.
+extract_expsyms_cmds=$lt_extract_expsyms_cmds
+# Symbols that should not be listed in the preloaded symbols.
+exclude_expsyms=$lt_exclude_expsyms_GCJ
+# Symbols that must always be exported.
+include_expsyms=$lt_include_expsyms_GCJ
+# ### END LIBTOOL TAG CONFIG: $tagname
+__EOF__
+else
+ # If there is no Makefile yet, we rely on a make rule to execute
+ # `config.status --recheck' to rerun these tests and create the
+ # libtool script then.
+ ltmain_in=`echo $ltmain | sed -e 's/\.sh$/.in/'`
+ if test -f "$ltmain_in"; then
+ test -f Makefile && make "$ltmain"
+ fi
+fi
+ac_ext=cc
+ac_cpp='$CXXCPP $CPPFLAGS'
+ac_compile='$CXX -c $CXXFLAGS $CPPFLAGS conftest.$ac_ext >&5'
+ac_link='$CXX -o conftest$ac_exeext $CXXFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
+ac_compiler_gnu=$ac_cv_cxx_compiler_gnu
+CC="$lt_save_CC"
+ else
+ tagname=""
+ fi
+ RC)
+# Source file extension for RC test sources.
+ac_ext=rc
+# Object file extension for compiled RC test sources.
+objext=o
+objext_RC=$objext
+# Code to be used in simple compile tests
+lt_simple_compile_test_code='sample MENU { MENUITEM "&Soup", 100, CHECKED }\n'
+# Code to be used in simple link tests
+lt_simple_link_test_code="$lt_simple_compile_test_code"
+# ltmain only uses $CC for tagged configurations so make sure $CC is set.
+# If no C compiler was specified, use CC.
+LTCC=${LTCC-"$CC"}
+# If no C compiler flags were specified, use CFLAGS.
+LTCFLAGS=${LTCFLAGS-"$CFLAGS"}
+# Allow CC to be a program name with arguments.
+compiler=$CC
+# save warnings/boilerplate of simple test code
+ac_outfile=conftest.$ac_objext
+printf "$lt_simple_compile_test_code" >conftest.$ac_ext
+eval "$ac_compile" 2>&1 >/dev/null | $SED '/^$/d; /^ *+/d' >conftest.err
+_lt_compiler_boilerplate=`cat conftest.err`
+$rm conftest*
+printf "$lt_simple_link_test_code" >conftest.$ac_ext
+eval "$ac_link" 2>&1 >/dev/null | $SED '/^$/d; /^ *+/d' >conftest.err
+_lt_linker_boilerplate=`cat conftest.err`
+$rm conftest*
+lt_save_CC="$CC"
+CC=${RC-"windres"}
+compiler=$CC
+compiler_RC=$CC
+for cc_temp in $compiler""; do
+ case $cc_temp in
+ compile | *[\\/]compile | ccache | *[\\/]ccache ) ;;
+ distcc | *[\\/]distcc | purify | *[\\/]purify ) ;;
+ *) break;;
+ esac
+done
+cc_basename=`$echo "X$cc_temp" | $Xsed -e 's%.*/%%' -e "s%^$host_alias-%%"`
+lt_cv_prog_compiler_c_o_RC=yes
+ fi
+ SED SHELL STRIP \
+ compiler_RC \
+ CC_RC \
+ LD_RC \
+ lt_prog_compiler_wl_RC \
+ lt_prog_compiler_pic_RC \
+ lt_prog_compiler_static_RC \
+ lt_prog_compiler_no_builtin_flag_RC \
+ export_dynamic_flag_spec_RC \
+ thread_safe_flag_spec_RC \
+ whole_archive_flag_spec_RC \
+ enable_shared_with_static_runtimes_RC \
+ old_archive_cmds_RC \
+ old_archive_from_new_cmds_RC \
+ predep_objects_RC \
+ postdep_objects_RC \
+ predeps_RC \
+ postdeps_RC \
+ compiler_lib_search_path_RC \
+ archive_cmds_RC \
+ archive_expsym_cmds_RC \
+ postinstall_cmds_RC \
+ postuninstall_cmds_RC \
+ old_archive_from_expsyms_cmds_RC \
+ allow_undefined_flag_RC \
+ no_undefined_flag_RC \
+ export_symbols_cmds_RC \
+ hardcode_libdir_flag_spec_RC \
+ hardcode_libdir_flag_spec_ld_RC \
+ hardcode_libdir_separator_RC \
+ hardcode_automatic_RC \
+ module_cmds_RC \
+ module_expsym_cmds_RC \
+ lt_cv_prog_compiler_c_o_RC \
+ exclude_expsyms_RC \
+ include_expsyms_RC; do
+ case $var in
+ old_archive_cmds_RC | \
+ old_archive_from_new_cmds_RC | \
+ archive_cmds_RC | \
+ archive_expsym_cmds_RC | \
+ module_cmds_RC | \
+ module_expsym_cmds_RC | \
+ old_archive_from_expsyms_cmds_RC | \
+ export_symbols_cmds_RC | \
+ esac
+ done
+ case $lt_echo in
+ esac
+cfgfile="$ofile"
+SHELL=$lt_SHELL
+build_libtool_need_lc=$archive_cmds_need_lc_RC
+allow_libtool_libs_with_static_runtimes=$enable_shared_with_static_runtimes_RC
+# The host system.
+host=$host
+host_os=$host_os
+build=$build
+build_os=$build_os
+echo=$lt_echo
+# The archiver.
+AR=$lt_AR
+# A C compiler.
+LTCC=$lt_LTCC
+CC=$lt_compiler_RC
+with_gcc=$GCC_RC
+# An ERE matcher.
+EGREP=$lt_EGREP
+LD=$lt_LD_RC
+LN_S=$lt_LN_S
+NM=$lt_NM
+STRIP=$lt_STRIP
+DLLTOOL="$DLLTOOL"
+OBJDUMP="$OBJDUMP"
+AS="$AS"
+objdir=$objdir
+wl=$lt_lt_prog_compiler_wl_RC
+libext="$libext"
+exeext="$exeext"
+pic_flag=$lt_lt_prog_compiler_pic_RC
+pic_mode=$pic_mode
+compiler_c_o=$lt_lt_cv_prog_compiler_c_o_RC
+link_static_flag=$lt_lt_prog_compiler_static_RC
+no_builtin_flag=$lt_lt_prog_compiler_no_builtin_flag_RC
+export_dynamic_flag_spec=$lt_export_dynamic_flag_spec_RC
+whole_archive_flag_spec=$lt_whole_archive_flag_spec_RC
+thread_safe_flag_spec=$lt_thread_safe_flag_spec_RC
+RANLIB=$lt_RANLIB
+old_archive_cmds=$lt_old_archive_cmds_RC
+old_archive_from_new_cmds=$lt_old_archive_from_new_cmds_RC
+old_archive_from_expsyms_cmds=$lt_old_archive_from_expsyms_cmds_RC
+archive_cmds=$lt_archive_cmds_RC
+archive_expsym_cmds=$lt_archive_expsym_cmds_RC
+module_cmds=$lt_module_cmds_RC
+module_expsym_cmds=$lt_module_expsym_cmds_RC
+# shared library.
+predep_objects=$lt_predep_objects_RC
+# shared library.
+postdep_objects=$lt_postdep_objects_RC
+# shared library.
+predeps=$lt_predeps_RC
+# shared library.
+postdeps=$lt_postdeps_RC
+compiler_lib_search_path=$lt_compiler_lib_search_path_RC
+allow_undefined_flag=$lt_allow_undefined_flag_RC
+no_undefined_flag=$lt_no_undefined_flag_RC
+hardcode_action=$hardcode_action_RC
+hardcode_libdir_flag_spec=$lt_hardcode_libdir_flag_spec_RC
+# not exist.
+hardcode_libdir_flag_spec_ld=$lt_hardcode_libdir_flag_spec_ld_RC
+hardcode_libdir_separator=$lt_hardcode_libdir_separator_RC
+hardcode_direct=$hardcode_direct_RC
+hardcode_minus_L=$hardcode_minus_L_RC
+hardcode_shlibpath_var=$hardcode_shlibpath_var_RC
+hardcode_automatic=$hardcode_automatic_RC
+link_all_deplibs=$link_all_deplibs_RC
+fix_srcfile_path="$fix_srcfile_path_RC"
+always_export_symbols=$always_export_symbols_RC
+export_symbols_cmds=$lt_export_symbols_cmds_RC
+exclude_expsyms=$lt_exclude_expsyms_RC
+include_expsyms=$lt_include_expsyms_RC
+__EOF__
+else
+ fi
+fi
+ac_ext=cc
+CC="$lt_save_CC"
+ { { echo "$as_me:$LINENO: error: Unsupported tag name: $tagname" >&5
+echo "$as_me: error: Unsupported tag name: $tagname" >&2;}
+ { (exit 1); exit 1; }; }
+ esac
+ # Append the new tag name to the list of available tags.
+ if test -n "$tagname" ; then
+ available_tags="$available_tags $tagname"
+ fi
+ fi
+ done
+ IFS="$lt_save_ifs"
+ # Now substitute the updated list of available tags.
+ if eval "sed -e 's/^available_tags=.*\$/available_tags=\"$available_tags\"/' \"$ofile\" > \"${ofile}T\""; then
+ mv "${ofile}T" "$ofile"
+ chmod +x "$ofile"
+ else
+ rm -f "${ofile}T"
+ { { echo "$as_me:$LINENO: error: unable to update list of available tagged configurations." >&5
+echo "$as_me: error: unable to update list of available tagged configurations." >&2;}
+ fi
+fi
# This can be used to rebuild libtool when needed
LIBTOOL_DEPS="$ac_aux_dir/ltmain.sh"
@@ -8217,9 +18643,27 @@
-VERSION="3.2.0"
+VERSION="3.3.0"
# custom Fdo path specification
@@ -8383,13 +18827,13 @@
# `set' does not quote correctly, so add quotes (double-quote
# substitution turns \\\\ into \\, and sed turns \\ into \).
sed -n \
- "s/'/'\\\\''/g;
- s/^\\([_$as_cr_alnum]*_cv_[_$as_cr_alnum]*\\)=\\(.*\\)/\\1='\\2'/p"
+ "s/'/'\\\\''/g;
+ s/^\\([_$as_cr_alnum]*_cv_[_$as_cr_alnum]*\\)=\\(.*\\)/\\1='\\2'/p"
# `set' quotes correctly as required by POSIX, so do not add quotes.
sed -n \
- "s/^\\([_$as_cr_alnum]*_cv_[_$as_cr_alnum]*\\)=\\(.*\\)/\\1=\\2/p"
+ "s/^\\([_$as_cr_alnum]*_cv_[_$as_cr_alnum]*\\)=\\(.*\\)/\\1=\\2/p"
esac;
@@ -8419,13 +18863,13 @@
# trailing colons and then remove the whole line if VPATH becomes empty
# (actually we leave an empty line to preserve line numbers).
if test "x$srcdir" = x.; then
- ac_vpsub='/^[ ]*VPATH[ ]*=/{
+ ac_vpsub='/^[ ]*VPATH[ ]*=/{
s/:*\$(srcdir):*/:/;
s/:*\${srcdir}:*/:/;
s/:*@srcdir@:*/:/;
-s/^\([^=]*=[ ]*\):*/\1/;
+s/^\([^=]*=[ ]*\):*/\1/;
s/:*$//;
-s/^[^=]*=[ ]*$//;
+s/^[^=]*=[ ]*$//;
fi
@@ -8439,13 +18883,13 @@
cat >confdef2opt.sed <<\_ACEOF
t clear
: clear
-s,^[ ]*#[ ]*define[ ][ ]*\([^ (][^ (]*([^)]*)\)[ ]*\(.*\),-D\1=\2,g
+s,^[ ]*#[ ]*define[ ][ ]*\([^ (][^ (]*([^)]*)\)[ ]*\(.*\),-D\1=\2,g
t quote
-s,^[ ]*#[ ]*define[ ][ ]*\([^ ][^ ]*\)[ ]*\(.*\),-D\1=\2,g
+s,^[ ]*#[ ]*define[ ][ ]*\([^ ][^ ]*\)[ ]*\(.*\),-D\1=\2,g
t quote
d
: quote
-s,[ `~#$^&*(){}\\|;'"<>?],\\&,g
+s,[ `~#$^&*(){}\\|;'"<>?],\\&,g
s,\[,\\&,g
s,\],\\&,g
s,\$,$$,g
@@ -8467,7 +18911,7 @@
for ac_i in : $LIBOBJS; do test "x$ac_i" = x: && continue
# 1. Remove the extension, and $U if already installed.
ac_i=`echo "$ac_i" |
- sed 's/\$U\././;s/\.o$//;s/\.obj$//'`
+ sed 's/\$U\././;s/\.o$//;s/\.obj$//'`
# 2. Add them.
ac_libobjs="$ac_libobjs $ac_i\$U.$ac_objext"
ac_ltlibobjs="$ac_ltlibobjs $ac_i"'$U.lo'
@@ -8484,6 +18928,20 @@
Usually this means the macro was only invoked conditionally." >&2;}
fi
+if test -z "${am__fastdepCC_TRUE}" && test -z "${am__fastdepCC_FALSE}"; then
+ { { echo "$as_me:$LINENO: error: conditional \"am__fastdepCC\" was never defined.
+Usually this means the macro was only invoked conditionally." >&5
+echo "$as_me: error: conditional \"am__fastdepCC\" was never defined.
+Usually this means the macro was only invoked conditionally." >&2;}
+fi
+if test -z "${am__fastdepCXX_TRUE}" && test -z "${am__fastdepCXX_FALSE}"; then
+ { { echo "$as_me:$LINENO: error: conditional \"am__fastdepCXX\" was never defined.
+echo "$as_me: error: conditional \"am__fastdepCXX\" was never defined.
+fi
: ${CONFIG_STATUS=./config.status}
ac_clean_files_save=$ac_clean_files
@@ -8518,9 +18976,10 @@
elif test -n "${BASH_VERSION+set}" && (set -o posix) >/dev/null 2>&1; then
set -o posix
fi
+DUALCASE=1; export DUALCASE # for MKS sh
# Support unset when possible.
-if (FOO=FOO; unset FOO) >/dev/null 2>&1; then
+if ( (MAIL=60; unset MAIL) || exit) >/dev/null 2>&1; then
as_unset=unset
else
as_unset=false
@@ -8539,7 +18998,7 @@
LC_MEASUREMENT LC_MESSAGES LC_MONETARY LC_NAME LC_NUMERIC LC_PAPER \
LC_TELEPHONE LC_TIME
do
- if (set +x; test -n "`(eval $as_var=C; export $as_var) 2>&1`"); then
+ if (set +x; test -z "`(eval $as_var=C; export $as_var) 2>&1`"); then
else
$as_unset $as_var
@@ -8718,16 +19177,17 @@
if mkdir -p . 2>/dev/null; then
as_mkdir_p=:
else
+ test -d ./-p && rmdir ./-p
as_mkdir_p=false
fi
as_executable_p="test -f"
# Sed expression to map a string onto a valid CPP name.
-as_tr_cpp="sed y%*$as_cr_letters%P$as_cr_LETTERS%;s%[^_$as_cr_alnum]%_%g"
+as_tr_cpp="eval sed 'y%*$as_cr_letters%P$as_cr_LETTERS%;s%[^_$as_cr_alnum]%_%g'"
# Sed expression to map a string onto a valid variable name.
-as_tr_sh="sed y%*+%pp%;s%[^_$as_cr_alnum]%_%g"
+as_tr_sh="eval sed 'y%*+%pp%;s%[^_$as_cr_alnum]%_%g'"
# IFS
@@ -8753,8 +19213,8 @@
} >&5
cat >&5 <<_CSEOF
-This file was extended by FDOSHP $as_me 3.2.0, which was
-generated by GNU Autoconf 2.57. Invocation command line was
+This file was extended by FDOSHP $as_me 3.3.0, which was
+generated by GNU Autoconf 2.59. Invocation command line was
CONFIG_FILES = $CONFIG_FILES
CONFIG_HEADERS = $CONFIG_HEADERS
@@ -8798,7 +19258,7 @@
-d, --debug don't remove temporary files
--recheck update $as_me by reconfiguring in the same conditions
--file=FILE[:TEMPLATE]
- instantiate the configuration file FILE
+ instantiate the configuration file FILE
Configuration files:
$config_files
@@ -8811,12 +19271,11 @@
cat >>$CONFIG_STATUS <<_ACEOF
ac_cs_version="\\
-FDOSHP config.status 3.2.0
-configured by $0, generated by GNU Autoconf 2.57,
+FDOSHP config.status 3.3.0
+configured by $0, generated by GNU Autoconf 2.59,
with options \\"`echo "$ac_configure_args" | sed 's/[\\""\`\$]/\\\\&/g'`\\"
-Copyright 1992, 1993, 1994, 1995, 1996, 1998, 1999, 2000, 2001
-Free Software Foundation, Inc.
+Copyright (C) 2003 Free Software Foundation, Inc.
This config.status script is free software; the Free Software Foundation
gives unlimited permission to copy, distribute and modify it."
srcdir=$srcdir
@@ -9023,6 +19482,7 @@
s, at INSTALL_PROGRAM@,$INSTALL_PROGRAM,;t t
s, at INSTALL_SCRIPT@,$INSTALL_SCRIPT,;t t
s, at INSTALL_DATA@,$INSTALL_DATA,;t t
+s, at CYGPATH_W@,$CYGPATH_W,;t t
s, at PACKAGE@,$PACKAGE,;t t
s, at VERSION@,$VERSION,;t t
s, at ACLOCAL@,$ACLOCAL,;t t
@@ -9030,13 +19490,17 @@
s, at AUTOMAKE@,$AUTOMAKE,;t t
s, at AUTOHEADER@,$AUTOHEADER,;t t
s, at MAKEINFO@,$MAKEINFO,;t t
-s, at AMTAR@,$AMTAR,;t t
s, at install_sh@,$install_sh,;t t
s, at STRIP@,$STRIP,;t t
s, at ac_ct_STRIP@,$ac_ct_STRIP,;t t
s, at INSTALL_STRIP_PROGRAM@,$INSTALL_STRIP_PROGRAM,;t t
+s, at mkdir_p@,$mkdir_p,;t t
s, at AWK@,$AWK,;t t
s, at SET_MAKE@,$SET_MAKE,;t t
+s, at am__leading_dot@,$am__leading_dot,;t t
+s, at AMTAR@,$AMTAR,;t t
+s, at am__tar@,$am__tar,;t t
+s, at am__untar@,$am__untar,;t t
s, at CC@,$CC,;t t
s, at CFLAGS@,$CFLAGS,;t t
s, at LDFLAGS@,$LDFLAGS,;t t
@@ -9051,10 +19515,14 @@
s, at AMDEP_FALSE@,$AMDEP_FALSE,;t t
s, at AMDEPBACKSLASH@,$AMDEPBACKSLASH,;t t
s, at CCDEPMODE@,$CCDEPMODE,;t t
+s, at am__fastdepCC_TRUE@,$am__fastdepCC_TRUE,;t t
+s, at am__fastdepCC_FALSE@,$am__fastdepCC_FALSE,;t t
s, at CXX@,$CXX,;t t
s, at CXXFLAGS@,$CXXFLAGS,;t t
s, at ac_ct_CXX@,$ac_ct_CXX,;t t
s, at CXXDEPMODE@,$CXXDEPMODE,;t t
+s, at am__fastdepCXX_TRUE@,$am__fastdepCXX_TRUE,;t t
+s, at am__fastdepCXX_FALSE@,$am__fastdepCXX_FALSE,;t t
s, at YACC@,$YACC,;t t
s, at build@,$build,;t t
s, at build_cpu@,$build_cpu,;t t
@@ -9064,12 +19532,18 @@
s, at host_cpu@,$host_cpu,;t t
s, at host_vendor@,$host_vendor,;t t
s, at host_os@,$host_os,;t t
+s, at EGREP@,$EGREP,;t t
s, at LN_S@,$LN_S,;t t
s, at ECHO@,$ECHO,;t t
+s, at AR@,$AR,;t t
+s, at ac_ct_AR@,$ac_ct_AR,;t t
s, at RANLIB@,$RANLIB,;t t
s, at ac_ct_RANLIB@,$ac_ct_RANLIB,;t t
+s, at CPP@,$CPP,;t t
s, at CXXCPP@,$CXXCPP,;t t
-s, at EGREP@,$EGREP,;t t
+s, at F77@,$F77,;t t
+s, at FFLAGS@,$FFLAGS,;t t
+s, at ac_ct_F77@,$ac_ct_F77,;t t
s, at LIBTOOL@,$LIBTOOL,;t t
s, at FDO@,$FDO,;t t
s, at FDOUTILITIES@,$FDOUTILITIES,;t t
@@ -9106,9 +19580,9 @@
(echo ':t
/@[a-zA-Z_][a-zA-Z_0-9]*@/!b' && cat $tmp/subs.frag) >$tmp/subs-$ac_sed_frag.sed
if test -z "$ac_sed_cmds"; then
- ac_sed_cmds="sed -f $tmp/subs-$ac_sed_frag.sed"
+ ac_sed_cmds="sed -f $tmp/subs-$ac_sed_frag.sed"
else
- ac_sed_cmds="$ac_sed_cmds | sed -f $tmp/subs-$ac_sed_frag.sed"
+ ac_sed_cmds="$ac_sed_cmds | sed -f $tmp/subs-$ac_sed_frag.sed"
fi
ac_sed_frag=`expr $ac_sed_frag + 1`
ac_beg=$ac_end
@@ -9126,21 +19600,21 @@
# Support "outfile[:infile[:infile...]]", defaulting infile="outfile.in".
case $ac_file in
- | *:- | *:-:* ) # input from stdin
- cat >$tmp/stdin
- ac_file_in=`echo "$ac_file" | sed 's,[^:]*:,,'`
- ac_file=`echo "$ac_file" | sed 's,:.*,,'` ;;
+ cat >$tmp/stdin
+ ac_file_in=`echo "$ac_file" | sed 's,[^:]*:,,'`
+ ac_file=`echo "$ac_file" | sed 's,:.*,,'` ;;
*:* ) ac_file_in=`echo "$ac_file" | sed 's,[^:]*:,,'`
* ) ac_file_in=$ac_file.in ;;
esac
# Compute @srcdir@, @top_srcdir@, and @INSTALL@ for subdirectories.
ac_dir=`(dirname "$ac_file") 2>/dev/null ||
$as_expr X"$ac_file" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
- X"$ac_file" : 'X\(//\)[^/]' \| \
- X"$ac_file" : 'X\(//\)$' \| \
- X"$ac_file" : 'X\(/\)' \| \
- . : '\(.\)' 2>/dev/null ||
+ X"$ac_file" : 'X\(//\)[^/]' \| \
+ X"$ac_file" : 'X\(//\)$' \| \
+ X"$ac_file" : 'X\(/\)' \| \
+ . : '\(.\)' 2>/dev/null ||
echo X"$ac_file" |
sed '/^X\(.*[^/]\)\/\/*[^/][^/]*\/*$/{ s//\1/; q; }
/^X\(\/\/\)[^/].*/{ s//\1/; q; }
@@ -9156,10 +19630,10 @@
as_dirs="$as_dir $as_dirs"
as_dir=`(dirname "$as_dir") 2>/dev/null ||
$as_expr X"$as_dir" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
- X"$as_dir" : 'X\(//\)[^/]' \| \
- X"$as_dir" : 'X\(//\)$' \| \
- X"$as_dir" : 'X\(/\)' \| \
+ X"$as_dir" : 'X\(//\)[^/]' \| \
+ X"$as_dir" : 'X\(//\)$' \| \
+ X"$as_dir" : 'X\(/\)' \| \
echo X"$as_dir" |
@@ -9197,14 +19671,47 @@
ac_srcdir=$ac_top_builddir$srcdir$ac_dir_suffix
ac_top_srcdir=$ac_top_builddir$srcdir ;;
esac
-# Don't blindly perform a `cd "$ac_dir"/$ac_foo && pwd` since $ac_foo can be
-# absolute.
-ac_abs_builddir=`cd "$ac_dir" && cd $ac_builddir && pwd`
-ac_abs_top_builddir=`cd "$ac_dir" && cd ${ac_top_builddir}. && pwd`
-ac_abs_srcdir=`cd "$ac_dir" && cd $ac_srcdir && pwd`
-ac_abs_top_srcdir=`cd "$ac_dir" && cd $ac_top_srcdir && pwd`
+# Do not use `cd foo && pwd` to compute absolute paths, because
+# the directories may not exist.
+case `pwd` in
+.) ac_abs_builddir="$ac_dir";;
+ case "$ac_dir" in
+ .) ac_abs_builddir=`pwd`;;
+ [\\/]* | ?:[\\/]* ) ac_abs_builddir="$ac_dir";;
+ *) ac_abs_builddir=`pwd`/"$ac_dir";;
+ esac;;
+esac
+case $ac_abs_builddir in
+.) ac_abs_top_builddir=${ac_top_builddir}.;;
+ case ${ac_top_builddir}. in
+ .) ac_abs_top_builddir=$ac_abs_builddir;;
+ [\\/]* | ?:[\\/]* ) ac_abs_top_builddir=${ac_top_builddir}.;;
+ *) ac_abs_top_builddir=$ac_abs_builddir/${ac_top_builddir}.;;
+ esac;;
+esac
+.) ac_abs_srcdir=$ac_srcdir;;
+ case $ac_srcdir in
+ .) ac_abs_srcdir=$ac_abs_builddir;;
+ [\\/]* | ?:[\\/]* ) ac_abs_srcdir=$ac_srcdir;;
+ *) ac_abs_srcdir=$ac_abs_builddir/$ac_srcdir;;
+ esac;;
+esac
+.) ac_abs_top_srcdir=$ac_top_srcdir;;
+ case $ac_top_srcdir in
+ .) ac_abs_top_srcdir=$ac_abs_builddir;;
+ [\\/]* | ?:[\\/]* ) ac_abs_top_srcdir=$ac_top_srcdir;;
+ *) ac_abs_top_srcdir=$ac_abs_builddir/$ac_top_srcdir;;
+ esac;;
+esac
case $INSTALL in
[\\/$]* | ?:[\\/]* ) ac_INSTALL=$INSTALL ;;
*) ac_INSTALL=$ac_top_builddir$INSTALL ;;
@@ -9224,7 +19731,7 @@
configure_input="$ac_file. "
fi
configure_input=$configure_input"Generated from `echo $ac_file_in |
- sed 's,.*/,,'` by configure."
+ sed 's,.*/,,'` by configure."
# First look for the input files in the build tree, otherwise in the
# src tree.
@@ -9233,24 +19740,24 @@
case $f in
-) echo $tmp/stdin ;;
- # Absolute (can't be DOS-style, as IFS=:)
- test -f "$f" || { { echo "$as_me:$LINENO: error: cannot find input file: $f" >&5
+ # Absolute (can't be DOS-style, as IFS=:)
+ test -f "$f" || { { echo "$as_me:$LINENO: error: cannot find input file: $f" >&5
echo "$as_me: error: cannot find input file: $f" >&2;}
- echo $f;;
+ echo "$f";;
*) # Relative
- if test -f "$f"; then
- # Build tree
- echo $f
- elif test -f "$srcdir/$f"; then
- # Source tree
- echo $srcdir/$f
- else
- # /dev/null tree
- { { echo "$as_me:$LINENO: error: cannot find input file: $f" >&5
+ if test -f "$f"; then
+ # Build tree
+ echo "$f"
+ elif test -f "$srcdir/$f"; then
+ # Source tree
+ echo "$srcdir/$f"
+ else
+ # /dev/null tree
+ { { echo "$as_me:$LINENO: error: cannot find input file: $f" >&5
- fi;;
+ fi;;
esac
done` || { (exit 1); exit 1; }
_ACEOF
@@ -9292,16 +19799,41 @@
ac_source=`echo "$ac_file" | sed 's,[^:]*:,,'`
ac_dir=`(dirname "$ac_dest") 2>/dev/null ||
$as_expr X"$ac_dest" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
- X"$ac_dest" : 'X\(//\)[^/]' \| \
- X"$ac_dest" : 'X\(//\)$' \| \
- X"$ac_dest" : 'X\(/\)' \| \
+ X"$ac_dest" : 'X\(//\)[^/]' \| \
+ X"$ac_dest" : 'X\(//\)$' \| \
+ X"$ac_dest" : 'X\(/\)' \| \
echo X"$ac_dest" |
/^X\(\/\/\)$/{ s//\1/; q; }
/^X\(\/\).*/{ s//\1/; q; }
s/.*/./; q'`
+ { if $as_mkdir_p; then
+ mkdir -p "$ac_dir"
+ else
+ as_dir="$ac_dir"
+ as_dirs=
+ while test ! -d "$as_dir"; do
+ as_dirs="$as_dir $as_dirs"
+ as_dir=`(dirname "$as_dir") 2>/dev/null ||
+$as_expr X"$as_dir" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
+echo X"$as_dir" |
+ sed '/^X\(.*[^/]\)\/\/*[^/][^/]*\/*$/{ s//\1/; q; }
+ /^X\(\/\/\)[^/].*/{ s//\1/; q; }
+ /^X\(\/\/\)$/{ s//\1/; q; }
+ /^X\(\/\).*/{ s//\1/; q; }
+ s/.*/./; q'`
+ done
+ test ! -n "$as_dirs" || mkdir $as_dirs
+ fi || { { echo "$as_me:$LINENO: error: cannot create directory \"$ac_dir\"" >&5
+echo "$as_me: error: cannot create directory \"$ac_dir\"" >&2;}
+ { (exit 1); exit 1; }; }; }
ac_builddir=.
if test "$ac_dir" != .; then
@@ -9327,14 +19859,47 @@
esac
-# absolute.
+case `pwd` in
+ case "$ac_dir" in
+ esac;;
+esac
+ esac;;
+esac
+ esac;;
+esac
+ esac;;
+esac
{ echo "$as_me:$LINENO: executing $ac_dest commands" >&5
echo "$as_me: executing $ac_dest commands" >&6;}
case $ac_dest in
@@ -9350,10 +19915,10 @@
if grep '^#.*generated by automake' $mf > /dev/null 2>&1; then
dirpart=`(dirname "$mf") 2>/dev/null ||
$as_expr X"$mf" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
- X"$mf" : 'X\(//\)[^/]' \| \
- X"$mf" : 'X\(//\)$' \| \
- X"$mf" : 'X\(/\)' \| \
+ X"$mf" : 'X\(//\)[^/]' \| \
+ X"$mf" : 'X\(//\)$' \| \
+ X"$mf" : 'X\(/\)' \| \
echo X"$mf" |
@@ -9363,36 +19928,30 @@
else
continue
fi
- grep '^DEP_FILES *= *[^ #]' < "$mf" > /dev/null || continue
- # Extract the definition of DEP_FILES from the Makefile without
- # running `make'.
- DEPDIR=`sed -n -e '/^DEPDIR = / s///p' < "$mf"`
+ # Extract the definition of DEPDIR, am__include, and am__quote
+ # from the Makefile without running `make'.
+ DEPDIR=`sed -n 's/^DEPDIR = //p' < "$mf"`
test -z "$DEPDIR" && continue
+ am__include=`sed -n 's/^am__include = //p' < "$mf"`
+ test -z "am__include" && continue
+ am__quote=`sed -n 's/^am__quote = //p' < "$mf"`
# When using ansi2knr, U may be empty or an underscore; expand it
- U=`sed -n -e '/^U = / s///p' < "$mf"`
- test -d "$dirpart/$DEPDIR" || mkdir "$dirpart/$DEPDIR"
- # We invoke sed twice because it is the simplest approach to
- # changing $(DEPDIR) to its actual value in the expansion.
- for file in `sed -n -e '
- /^DEP_FILES = .*\\\\$/ {
- s/^DEP_FILES = //
- :loop
- s/\\\\$//
- p
- n
- /\\\\$/ b loop
- p
- /^DEP_FILES = / s/^DEP_FILES = //p' < "$mf" | \
+ U=`sed -n 's/^U = //p' < "$mf"`
+ # Find all dependency output files, they are included files with
+ # $(DEPDIR) in their names. We invoke sed twice because it is the
+ # simplest approach to changing $(DEPDIR) to its actual value in the
+ # expansion.
+ for file in `sed -n "
+ s/^$am__include $am__quote\(.*(DEPDIR).*\)$am__quote"'$/\1/p' <"$mf" | \
sed -e 's/\$(DEPDIR)/'"$DEPDIR"'/g' -e 's/\$U/'"$U"'/g'`; do
# Make sure the directory exists.
test -f "$dirpart/$file" && continue
fdir=`(dirname "$file") 2>/dev/null ||
$as_expr X"$file" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
- X"$file" : 'X\(//\)[^/]' \| \
- X"$file" : 'X\(//\)$' \| \
- X"$file" : 'X\(/\)' \| \
+ X"$file" : 'X\(//\)[^/]' \| \
+ X"$file" : 'X\(//\)$' \| \
+ X"$file" : 'X\(/\)' \| \
echo X"$file" |
@@ -9408,10 +19967,10 @@
echo X"$as_dir" |
Modified: trunk/Providers/SHP/configure.in
--- trunk/Providers/SHP/configure.in 2007-02-09 23:09:32 UTC (rev 2462)
+++ trunk/Providers/SHP/configure.in 2007-02-09 23:09:59 UTC (rev 2463)
@@ -21,7 +21,7 @@
# Variables
# Following are the makefile directories
-AC_INIT(FDOSHP,3.2.0,http://www.fdo.osgeo.org)
+AC_INIT(FDOSHP,3.3.0,http://www.fdo.osgeo.org)
AC_CONFIG_SRCDIR(configure.in)
AM_INIT_AUTOMAKE
@@ -35,10 +35,10 @@
AC_DISABLE_STATIC
AM_PROG_LIBTOOL
-AC_SUBST(VERSION, "3.2.0")
+AC_SUBST(VERSION, "3.3.0")
dnl *******************************************************
-dnl FDO 3.2.0 Configuration
+dnl FDO 3.3.0 Configuration
dnl FDO / FDO Utilities / FDO Thirdpary paths
More information about the fdo-commits
