[fdo-commits] r2502 - trunk
svn_fdo at osgeo.org svn_fdo at osgeo.org
Mon Feb 12 14:49:52 EST 2007
Author: gregboone
Date: 2007-02-12 14:49:52 -0500 (Mon, 12 Feb 2007)
New Revision: 2502
   trunk/OpenSourceBuild__README.txt
Update FDO 3.3.0 build scripts
Modified: trunk/OpenSourceBuild__README.txt
--- trunk/OpenSourceBuild__README.txt	2007-02-12 16:27:33 UTC (rev 2501)
+++ trunk/OpenSourceBuild__README.txt	2007-02-12 19:49:52 UTC (rev 2502)
@@ -398,19 +398,24 @@
   1. cd [FDO OpenSource]
-  2. Open and modify setenvironment.bat to specify the locations of the Thirdparty SDK
-     components and build tools. (Refer to the Build Notes below)
+  2. Open and modify setenvironment.sh to specify the locations of the
+     Thirdparty SDK components and build tools. (Refer to the Build Notes
+     below)
-  3. source ./setenvironment.sh
+  3.  Source set environment script (bash or bourne compatible shells)
+      source ./setenvironment.sh
   4. ./build_thirdparty.sh
   5. ./build_linux.sh
-  NOTE: build_linux.sh is a simple helper script that assists developers to build the FDO
-        components. These scripts supplement standard support of configure and make.
+  NOTE: build_linux.sh is a simple helper script that assists developers to
+        build the FDO components. These scripts supplement standard support of
+        configure and make.
-        The implementation of the above build_linux.sh script in essence calls ...
+        The implementation of the above build_linux.sh script in essence
+        calls ...
         aclocal
         libtoolize --force
@@ -420,9 +425,10 @@
         make
         make install
-        for the fdo core API components as well as the set of FDO providers that are
-        currently supported in the automated build process. Users are free to call configure
-        and make without using the build_linux.sh helper script.
+        for the fdo core API components as well as the set of FDO providers
+        that are currently supported in the automated build process. Users are
+        free to call configure and make without using the build_linux.sh helper
+        script.
 II. Build Notes
@@ -441,23 +447,24 @@
        FDOTHIRDPARTY = [FDO OpenSource]/ThirdParty
   3. In order to build the ArcSDE Provider, you will need to have the
-     ArcSDE 9.1 Client SDK installed and the following environment variable set that
-     points to the installation location:
+     ArcSDE 9.1 Client SDK installed and the following environment variable set
+     that points to the installation location:
        SDEHOME=[ArcSDE developer components path]
-     Note that ArcSDE is licensed software and must be obtained from an ESRI vendor.
+     Note that ArcSDE is licensed software and must be obtained from an ESRI
+     vendor.
-  4. In order to build the MySQL Provider, you will need to download and extract
-     the MySQL client and MySQL 5.0 devloper components from MySQL. These
-     components are located at:
+  4. In order to build the MySQL Provider, you will need to download and
+     extract the MySQL client and MySQL 5.0 devloper components from MySQL.
+     These components are located at:
        http://dev.mysql.com/downloads/mysql/5.0.html
      For example, for Red Hat Enterprise Linux 3 RPM (x86)
-       Client:                      MySQL-client-standard-5.0.22-0.rhel3.i386.rpm
-       Headers and Libraries:       MySQL-devel-standard-5.0.22-0.rhel3.i386.rpm
+       Client:                   MySQL-client-standard-5.0.22-0.rhel3.i386.rpm
+       Headers and Libraries:    MySQL-devel-standard-5.0.22-0.rhel3.i386.rpm
      NOTE: Choosing the RPM install of the MySQL components is *strongly*
      recommended. However, if a non-RPM installation of MySQL is chosen,
@@ -467,8 +474,8 @@
   5. In order to build the ODBC Provider, you will need to either
-     a) download and install the Linux ODBC driver Manager, specifically
-        the unixODBC-CORE and unixODBC-devel packages relased by www.unixodbc.org
+     a) download and install the Linux ODBC driver Manager, specifically the
+        unixODBC-CORE and unixODBC-devel packages relased by www.unixodbc.org
            Home Page:
            http://www.unixodbc.org/
@@ -485,30 +492,34 @@
            usr/lib and usr/include
-           The FDO ODBC provider build will automatically locate thee files in this liocation.
+           The FDO ODBC provider build will automatically locate thee files in
+           this liocation.
-     b) install an unixODBC driver such as the EasySofy Oracle ODBC driver. This installation
-        will include the driver libraries as well as the unixODBC manager libraries.
-        If such an installation occurs the manager libraries and headers will not be
-        installed under /usr/lib or usr/include but will be installed in a custom location
-        as specified by the driver RPM package. If this is the case, you will need to set
-        the following FDO environment variable to point to the location of the unixODBC
-        components:
+     b) install an unixODBC driver such as the EasySofy Oracle ODBC driver.
+        This installation will include the driver libraries as well as the
+        unixODBC manager libraries.
+        If such an installation occurs the manager libraries and headers will
+        not be installed under /usr/lib or usr/include but will be installed
+        in a custom location as specified by the driver RPM package. If this
+        is the case, you will need to set the following FDO environment
+        variable to point to the location of the unixODBC components:
            FDOODBC=[unixODBC developer components path]
-  6. OPTIONAL: The FDO build process allows it's documentation to be regenerated.
-     If this is required, install the OpenSource Doxygen documentation generation
-     software.  Doxygen is a documentation system for C++, C, Java, Objective-C,
-     Python, IDL (Corba and Microsoft flavors) and to some extent PHP, C#, and D.
-     Doxygen is often automataically installed on Fedora Core and RedHat systems.
+  6. OPTIONAL: The FDO build process allows it's documentation to be
+     regenerated.  If this is required, install the OpenSource Doxygen
+     documentation generation software.  Doxygen is a documentation system for
+     C++, C, Java, Objective-C, Python, IDL (Corba and Microsoft flavors) and
+     to some extent PHP, C#, and D.  Doxygen is often automataically installed
+     on Fedora Core and RedHat systems.
      To install Doxygen, refer to: http://www.stack.nl/~dimitri/doxygen/
-     The FDO Doxygen documentation generation process will also use the "dot" tool
-     from graphviz 1.5 to generate more advanced diagrams and graphs. Graphviz is an
-     "open-sourced", cross-platform graph drawing toolkit from AT&T and Lucent
-     Bell Labs.
+     The FDO Doxygen documentation generation process will also use the "dot"
+     tool from graphviz 1.5 to generate more advanced diagrams and graphs.
+     Graphviz is an "open-sourced", cross-platform graph drawing toolkit from
+     AT&T and Lucent Bell Labs.
      To install graphviz, refer to: http://www.graphviz.org/
@@ -517,21 +528,22 @@
        export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/fdo-3.3.0/lib
        export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$SDEHOME/lib:$FDOTHIRDPARTY/ESRI/ArcSDEClient91/Linux/lib
-  8. NOTE: Several known problems exist if auto-mounted drives are used as locations
-     for the FDO Linux builds. It is recommended that users not use auto-mounted drives
-     when building FDO.
+  8. NOTE: Several known problems exist if auto-mounted drives are used as
+     locations for the FDO Linux builds. It is recommended that users not use
+     auto-mounted drives when building FDO.
-  9. NOTE: The FDO expression scripts (.y) are not automatially recompiled as a part of the
-     FDO build process. In order to recompile the .y files into their .cpp and .h
-     counterparts, execute the build_parse.sh script.
+  9. NOTE: The FDO expression scripts (.y) are not automatially recompiled as a
+     part of the FDO build process. In order to recompile the .y files into
+     their .cpp and .h counterparts, execute the build_parse.sh script.
- 10. NOTE: Use the [FDO OpenSource]\setenvironment.sh script to assist in setting and
-     maintaing the correct environment settings for the FDO build process.
-     This script can be modifed and used to set the correct environment variables
-     and PATH settings.
+ 10. NOTE: Use the [FDO OpenSource]\setenvironment.sh script to assist in
+     setting and maintaing the correct environment settings for the FDO build
+     process.  This script can be modifed and used to set the correct
+     environment variables and PATH settings.
- 11. The build_thirdparty.sh script is used to build the FDO Thirdparty binaries.
-     The following is a general guideline on how to use the build_thirdparty.bat build script.
+ 11. The build_thirdparty.sh script is used to build the FDO Thirdparty
+     binaries.  The following is a general guideline on how to use the
+     build_thirdparty.bat build script.
            build_thirdparty.sh [--h] [--a Action] [--m ConfigMakefiles]
@@ -558,7 +570,8 @@
  12. The build_linux.sh script is used to build and install the FDO OpenSource
-     libraries. The following is a general guideline on how to use build_linux.sh
+     libraries. The following is a general guideline on how to use
+     build_linux.sh
            build_linux.sh [--h]
@@ -577,7 +590,8 @@
                                        clean
            BuildDocs:       --d[ocs] skip(default), build
            ConfigMakefiles: --m[akefile] configure(default), noconfigure
-           WithModule:      --w[ith] fdocore(default),
+           WithModule:      --w[ith] all(default),
+									 fdocore,
                                      fdo,
                                      thirdparty,
                                      providers,
More information about the fdo-commits mailing list
