[fdo-commits] r739 - in
branches/3.2.1/Providers/GenericRdbms/Src/UnitTest: . Common
svn_fdo at osgeo.org
Tue Feb 13 12:07:50 EST 2007
Author: brentrobinson
Date: 2007-02-13 12:07:50 -0500 (Tue, 13 Feb 2007)
New Revision: 739
branches/3.2.1/Providers/GenericRdbms/Src/UnitTest/Common/SchemaMgrTests.cpp
branches/3.2.1/Providers/GenericRdbms/Src/UnitTest/gen_default1_MySql_master.txt
branches/3.2.1/Providers/GenericRdbms/Src/UnitTest/gen_default1_Oracle_master.txt
branches/3.2.1/Providers/GenericRdbms/Src/UnitTest/gen_default1_SqlServer2005_master.txt
branches/3.2.1/Providers/GenericRdbms/Src/UnitTest/gen_default1_SqlServer_master.txt
Merged from 3.2.x branch: Skip Foreign Key with column type mismatch
Modified: branches/3.2.1/Providers/GenericRdbms/Src/UnitTest/Common/SchemaMgrTests.cpp
--- branches/3.2.1/Providers/GenericRdbms/Src/UnitTest/Common/SchemaMgrTests.cpp 2007-02-13 17:00:10 UTC (rev 738)
+++ branches/3.2.1/Providers/GenericRdbms/Src/UnitTest/Common/SchemaMgrTests.cpp 2007-02-13 17:07:50 UTC (rev 739)
@@ -184,7 +184,61 @@
column = view2->CreateColumnDouble( L"DOUBLE_COLUMN", true, L"DOUBLE_COLUMN" );
column = view2->CreateColumnGeom( L"GEOM_COLUMN", (FdoSmPhScInfo*) NULL, true, true, false, L"GEOM_COLUMN" );
+#ifndef RDBI_DEF_SSQL
+ table = owner->CreateTable( phMgr->GetDcDbObjectName(L"TABLE5" ));
+ column = table->CreateColumnDecimal( L"ID", false, 10, 2 );
+ table->AddPkeyCol( column->GetName() );
+ column = table->CreateColumnChar( L"STRING_COLUMN", false, 50 );
+ table = owner->CreateTable( phMgr->GetDcDbObjectName(L"RTABLE5" ));
+ FdoSmPhColumnP fkeyColumn5 = table->CreateColumnDouble( L"TABLE5_ID", false );
+ fkey = table->CreateFkey( "FK_RTABLE5_TABLE5", phMgr->GetDcDbObjectName("TABLE5" ));
+ fkey->AddFkeyColumn( fkeyColumn5, L"ID" );
+ table = owner->CreateTable( phMgr->GetDcDbObjectName(L"TABLE6" ));
+ column = table->CreateColumnDecimal( L"ID1", false, 10, 2 );
+ column = table->CreateColumnChar( L"ID2", false, 50 );
+ table = owner->CreateTable( phMgr->GetDcDbObjectName(L"RTABLE6" ));
+ FdoSmPhColumnP fkeyColumn6a = table->CreateColumnDouble( L"TABLE6_ID1", false );
+ FdoSmPhColumnP fkeyColumn6b = table->CreateColumnChar( L"TABLE6_ID2", false, 50 );
+ fkey = table->CreateFkey( "FK_RTABLE6_TABLE6", phMgr->GetDcDbObjectName("TABLE6" ));
+ fkey->AddFkeyColumn( fkeyColumn6a, L"ID1" );
+ fkey->AddFkeyColumn( fkeyColumn6b, L"ID2" );
+#endif
+ table = owner->CreateTable( phMgr->GetDcDbObjectName(L"TABLE7" ));
+ column = table->CreateColumnInt64( L"ID", false, true);
+ table = owner->CreateTable( phMgr->GetDcDbObjectName(L"RTABLE7" ));
+ column = table->CreateColumnInt64( L"ID", false);
+ FdoSmPhColumnP fkeyColumn7 = table->CreateColumnInt64( L"TABLE7_ID", false, true);
+ fkey = table->CreateFkey( "FK_RTABLE7_TABLE7", phMgr->GetDcDbObjectName("TABLE7" ));
+ fkey->AddFkeyColumn( fkeyColumn7, L"ID" );
+ FdoSmPhBatchColumnsP ukeys = table->GetUkeyColumns();
+ FdoSmPhColumnsP ukeyColumns = new FdoSmPhColumnCollection();
+ ukeys->Add( ukeyColumns );
+ table->AddUkeyCol( ukeys->GetCount() - 1, L"TABLE7_ID" );
database->Commit();
owner->DiscardDbObject(table);
// Make sure RTABLE2 got removed from the not found list.
CPPUNIT_ASSERT( owner->FindDbObject(phMgr->GetDcDbObjectName(L"RTABLE2")) != NULL );
Modified: branches/3.2.1/Providers/GenericRdbms/Src/UnitTest/gen_default1_MySql_master.txt
--- branches/3.2.1/Providers/GenericRdbms/Src/UnitTest/gen_default1_MySql_master.txt 2007-02-13 17:00:10 UTC (rev 738)
+++ branches/3.2.1/Providers/GenericRdbms/Src/UnitTest/gen_default1_MySql_master.txt 2007-02-13 17:07:50 UTC (rev 739)
@@ -110,6 +110,155 @@
</xs:extension>
</xs:complexContent>
</xs:complexType>
+<xs:element name="rtable5" type="AutoGen:rtable5Type" abstract="false" substitutionGroup="gml:_Feature">
+<xs:key name="rtable5Key">
+<xs:selector xpath=".//rtable5"/>
+<xs:field xpath="ID"/>
+</xs:key>
+</xs:element>
+<xs:complexType name="rtable5Type" abstract="false">
+<xs:annotation>
+<xs:documentation/>
+</xs:annotation>
+<xs:complexContent>
+<xs:extension base="fdo:ClassType">
+<xs:sequence>
+<xs:element name="ID">
+<xs:annotation>
+</xs:annotation>
+<xs:simpleType>
+<xs:restriction base="xs:decimal">
+<xs:totalDigits value="10"/>
+<xs:fractionDigits value="2"/>
+</xs:restriction>
+</xs:simpleType>
+</xs:element>
+<xs:element name="STRING_COLUMN">
+<xs:annotation>
+</xs:annotation>
+<xs:simpleType>
+<xs:restriction base="xs:string">
+<xs:maxLength value="50"/>
+</xs:restriction>
+</xs:simpleType>
+</xs:element>
+<xs:element name="TABLE5_ID">
+<xs:simpleType>
+<xs:restriction base="xs:double"/>
+</xs:simpleType>
+<xs:annotation>
+</xs:annotation>
+</xs:element>
+</xs:sequence>
+</xs:extension>
+</xs:complexContent>
+</xs:complexType>
+<xs:element name="rtable6" type="AutoGen:rtable6Type" abstract="false" substitutionGroup="gml:_Feature">
+<xs:key name="rtable6Key">
+<xs:selector xpath=".//rtable6"/>
+</xs:key>
+</xs:element>
+<xs:complexType name="rtable6Type" abstract="false">
+<xs:annotation>
+</xs:annotation>
+<xs:sequence>
+<xs:annotation>
+</xs:annotation>
+<xs:simpleType>
+</xs:restriction>
+</xs:simpleType>
+</xs:element>
+<xs:annotation>
+</xs:annotation>
+<xs:simpleType>
+</xs:restriction>
+</xs:simpleType>
+</xs:element>
+<xs:element name="TABLE6_ID1">
+<xs:simpleType>
+</xs:simpleType>
+<xs:annotation>
+</xs:annotation>
+</xs:element>
+<xs:element name="TABLE6_ID2">
+<xs:annotation>
+</xs:annotation>
+<xs:simpleType>
+</xs:restriction>
+</xs:simpleType>
+</xs:element>
+</xs:sequence>
+</xs:extension>
+</xs:complexType>
+<xs:element name="rtable7" type="AutoGen:rtable7Type" abstract="false" substitutionGroup="gml:_Feature">
+<xs:key name="rtable7Key">
+<xs:selector xpath=".//rtable7"/>
+</xs:key>
+<xs:unique name="rtable7Key_0">
+<xs:field xpath="TABLE7_ID"/>
+</xs:unique>
+</xs:element>
+<xs:complexType name="rtable7Type" abstract="false">
+<xs:annotation>
+</xs:annotation>
+<xs:sequence>
+<xs:simpleType>
+<xs:restriction base="fdo:int64"/>
+</xs:simpleType>
+<xs:annotation>
+</xs:annotation>
+</xs:element>
+<xs:annotation>
+</xs:annotation>
+<xs:simpleType>
+</xs:restriction>
+</xs:simpleType>
+</xs:element>
+<xs:element name="TABLE7_ID" fdo:readOnly="true" fdo:autogenerated="true">
+<xs:simpleType>
+</xs:simpleType>
+<xs:annotation>
+</xs:annotation>
+</xs:element>
+</xs:sequence>
+</xs:extension>
+</xs:complexType>
<xs:element name="table1" type="AutoGen:table1Type" abstract="false" substitutionGroup="gml:_Feature">
<xs:key name="table1Key">
<xs:selector xpath=".//table1"/>
@@ -596,5 +745,127 @@
</xs:extension>
</xs:complexType>
+<xs:element name="table5" type="AutoGen:table5Type" abstract="false" substitutionGroup="gml:_Feature">
+<xs:key name="table5Key">
+<xs:selector xpath=".//table5"/>
+</xs:key>
+</xs:element>
+<xs:complexType name="table5Type" abstract="false">
+<xs:annotation>
+</xs:annotation>
+<xs:sequence>
+<xs:annotation>
+</xs:annotation>
+<xs:simpleType>
+</xs:restriction>
+</xs:simpleType>
+</xs:element>
+<xs:annotation>
+</xs:annotation>
+<xs:simpleType>
+</xs:restriction>
+</xs:simpleType>
+</xs:element>
+</xs:sequence>
+</xs:extension>
+</xs:complexType>
+<xs:element name="table6" type="AutoGen:table6Type" abstract="false" substitutionGroup="gml:_Feature">
+<xs:key name="table6Key">
+<xs:selector xpath=".//table6"/>
+<xs:field xpath="ID1"/>
+<xs:field xpath="ID2"/>
+</xs:key>
+</xs:element>
+<xs:complexType name="table6Type" abstract="false">
+<xs:annotation>
+</xs:annotation>
+<xs:sequence>
+<xs:element name="ID1">
+<xs:annotation>
+</xs:annotation>
+<xs:simpleType>
+</xs:restriction>
+</xs:simpleType>
+</xs:element>
+<xs:element name="ID2">
+<xs:annotation>
+</xs:annotation>
+<xs:simpleType>
+</xs:restriction>
+</xs:simpleType>
+</xs:element>
+<xs:annotation>
+</xs:annotation>
+<xs:simpleType>
+</xs:restriction>
+</xs:simpleType>
+</xs:element>
+</xs:sequence>
+</xs:extension>
+</xs:complexType>
+<xs:element name="table7" type="AutoGen:table7Type" abstract="false" substitutionGroup="gml:_Feature">
+<xs:key name="table7Key">
+<xs:selector xpath=".//table7"/>
+</xs:key>
+</xs:element>
+<xs:complexType name="table7Type" abstract="false">
+<xs:annotation>
+</xs:annotation>
+<xs:sequence>
+<xs:element name="ID" fdo:readOnly="true" fdo:autogenerated="true">
+<xs:simpleType>
+</xs:simpleType>
+<xs:annotation>
+</xs:annotation>
+</xs:element>
+<xs:annotation>
+</xs:annotation>
+<xs:simpleType>
+</xs:restriction>
+</xs:simpleType>
+</xs:element>
+</xs:sequence>
+</xs:extension>
+</xs:complexType>
</xs:schema>
</fdo:DataStore>
Modified: branches/3.2.1/Providers/GenericRdbms/Src/UnitTest/gen_default1_Oracle_master.txt
--- branches/3.2.1/Providers/GenericRdbms/Src/UnitTest/gen_default1_Oracle_master.txt 2007-02-13 17:00:10 UTC (rev 738)
+++ branches/3.2.1/Providers/GenericRdbms/Src/UnitTest/gen_default1_Oracle_master.txt 2007-02-13 17:07:50 UTC (rev 739)
@@ -264,6 +264,185 @@
</xs:extension>
</xs:complexType>
+<xs:element name="RTABLE5" type="AutoGen:RTABLE5Type" abstract="false" substitutionGroup="gml:_Feature">
+<xs:key name="RTABLE5Key">
+<xs:selector xpath=".//RTABLE5"/>
+</xs:key>
+</xs:element>
+<xs:complexType name="RTABLE5Type" abstract="false">
+<xs:annotation>
+</xs:annotation>
+<xs:sequence>
+<xs:annotation>
+</xs:annotation>
+<xs:simpleType>
+</xs:restriction>
+</xs:simpleType>
+</xs:element>
+<xs:annotation>
+</xs:annotation>
+<xs:simpleType>
+</xs:restriction>
+</xs:simpleType>
+</xs:element>
+<xs:simpleType>
+</xs:simpleType>
+<xs:annotation>
+</xs:annotation>
+</xs:element>
+</xs:sequence>
+</xs:extension>
+</xs:complexType>
+<xs:element name="RTABLE6" type="AutoGen:RTABLE6Type" abstract="false" substitutionGroup="gml:_Feature">
+<xs:key name="RTABLE6Key">
+<xs:selector xpath=".//RTABLE6"/>
+</xs:key>
+</xs:element>
+<xs:complexType name="RTABLE6Type" abstract="false">
+<xs:annotation>
+</xs:annotation>
+<xs:sequence>
+<xs:annotation>
+</xs:annotation>
+<xs:simpleType>
+</xs:restriction>
+</xs:simpleType>
+</xs:element>
+<xs:annotation>
+</xs:annotation>
+<xs:simpleType>
+</xs:restriction>
+</xs:simpleType>
+</xs:element>
+<xs:simpleType>
+</xs:simpleType>
+<xs:annotation>
+</xs:annotation>
+</xs:element>
+<xs:annotation>
+</xs:annotation>
+<xs:simpleType>
+</xs:restriction>
+</xs:simpleType>
+</xs:element>
+</xs:sequence>
+</xs:extension>
+</xs:complexType>
+<xs:element name="RTABLE7" type="AutoGen:RTABLE7Type" abstract="false" substitutionGroup="gml:_Feature">
+<xs:key name="RTABLE7Key">
+<xs:selector xpath=".//RTABLE7"/>
+</xs:key>
+<xs:unique name="RTABLE7Key_0">
+</xs:unique>
+</xs:element>
+<xs:complexType name="RTABLE7Type" abstract="false">
+<xs:annotation>
+</xs:annotation>
+<xs:sequence>
+<xs:element name="FK_RTABLE7_TABLE7" minOccurs="0" maxOccurs="1" fdo:multiplicity="" fdo:deleteRule="Break" fdo:defaultIdentity="false">
+<xs:annotation>
+</xs:annotation>
+<xs:complexType>
+<xs:sequence>
+<xs:element name="TABLE7_ID">
+<xs:annotation>
+</xs:annotation>
+<xs:simpleType>
+<xs:totalDigits value="20"/>
+<xs:fractionDigits value=""/>
+</xs:restriction>
+</xs:simpleType>
+</xs:element>
+</xs:sequence>
+</xs:complexType>
+<xs:keyref name="AutoGen_RTABLE7_FK_RTABLE7_TABLE7" refer="AutoGen:TABLE7_RTABLE7AKey">
+</xs:keyref>
+</xs:element>
+<xs:annotation>
+</xs:annotation>
+<xs:simpleType>
+</xs:restriction>
+</xs:simpleType>
+</xs:element>
+<xs:annotation>
+</xs:annotation>
+<xs:simpleType>
+</xs:restriction>
+</xs:simpleType>
+</xs:element>
+<xs:annotation>
+</xs:annotation>
+<xs:simpleType>
+</xs:restriction>
+</xs:simpleType>
+</xs:element>
+</xs:sequence>
+</xs:extension>
+</xs:complexType>
<xs:element name="TABLE1" type="AutoGen:TABLE1Type" abstract="false" substitutionGroup="gml:_Feature">
<xs:key name="TABLE1Key">
<xs:selector xpath=".//TABLE1"/>
@@ -546,6 +725,135 @@
</xs:extension>
</xs:complexType>
+<xs:element name="TABLE5" type="AutoGen:TABLE5Type" abstract="false" substitutionGroup="gml:_Feature">
+<xs:key name="TABLE5Key">
+<xs:selector xpath=".//TABLE5"/>
+</xs:key>
+</xs:element>
+<xs:complexType name="TABLE5Type" abstract="false">
+<xs:annotation>
+</xs:annotation>
+<xs:sequence>
+<xs:annotation>
+</xs:annotation>
+<xs:simpleType>
+</xs:restriction>
+</xs:simpleType>
+</xs:element>
+<xs:annotation>
+</xs:annotation>
+<xs:simpleType>
+</xs:restriction>
+</xs:simpleType>
+</xs:element>
+</xs:sequence>
+</xs:extension>
+</xs:complexType>
+<xs:element name="TABLE6" type="AutoGen:TABLE6Type" abstract="false" substitutionGroup="gml:_Feature">
+<xs:key name="TABLE6Key">
+<xs:selector xpath=".//TABLE6"/>
+</xs:key>
+</xs:element>
+<xs:complexType name="TABLE6Type" abstract="false">
+<xs:annotation>
+</xs:annotation>
+<xs:sequence>
+<xs:annotation>
+</xs:annotation>
+<xs:simpleType>
+</xs:restriction>
+</xs:simpleType>
+</xs:element>
+<xs:annotation>
+</xs:annotation>
+<xs:simpleType>
+</xs:restriction>
+</xs:simpleType>
+</xs:element>
+<xs:annotation>
+</xs:annotation>
+<xs:simpleType>
+</xs:restriction>
+</xs:simpleType>
+</xs:element>
+</xs:sequence>
+</xs:extension>
+</xs:complexType>
+<xs:element name="TABLE7" type="AutoGen:TABLE7Type" abstract="false" substitutionGroup="gml:_Feature">
+<xs:key name="TABLE7Key">
+<xs:selector xpath=".//TABLE7"/>
+</xs:key>
+<xs:key name="TABLE7_RTABLE7AKey">
+<xs:selector xpath=".//AutoGen"/>
+</xs:key>
+</xs:element>
+<xs:complexType name="TABLE7Type" abstract="false">
+<xs:annotation>
+</xs:annotation>
+<xs:sequence>
+<xs:annotation>
+</xs:annotation>
+<xs:simpleType>
+</xs:restriction>
+</xs:simpleType>
+</xs:element>
+<xs:annotation>
+</xs:annotation>
+<xs:simpleType>
+</xs:restriction>
+</xs:simpleType>
+</xs:element>
+</xs:sequence>
+</xs:extension>
+</xs:complexType>
<xs:element name="VERTABLE1" type="AutoGen:VERTABLE1Type" abstract="false" substitutionGroup="gml:_Feature">
<xs:key name="VERTABLE1Key">
<xs:selector xpath=".//VERTABLE1"/>
Modified: branches/3.2.1/Providers/GenericRdbms/Src/UnitTest/gen_default1_SqlServer2005_master.txt
--- branches/3.2.1/Providers/GenericRdbms/Src/UnitTest/gen_default1_SqlServer2005_master.txt 2007-02-13 17:00:10 UTC (rev 738)
+++ branches/3.2.1/Providers/GenericRdbms/Src/UnitTest/gen_default1_SqlServer2005_master.txt 2007-02-13 17:07:50 UTC (rev 739)
@@ -186,6 +186,53 @@
</xs:extension>
</xs:complexType>
+<xs:element name="rtable7" type="dbo:rtable7Type" abstract="false" substitutionGroup="gml:_Feature">
+</xs:key>
+</xs:unique>
+</xs:element>
+<xs:annotation>
+</xs:annotation>
+<xs:sequence>
+<xs:simpleType>
+</xs:simpleType>
+<xs:annotation>
+</xs:annotation>
+</xs:element>
+<xs:annotation>
+</xs:annotation>
+<xs:simpleType>
+</xs:restriction>
+</xs:simpleType>
+</xs:element>
+<xs:simpleType>
+</xs:simpleType>
+<xs:annotation>
+</xs:annotation>
+</xs:element>
+</xs:sequence>
+</xs:extension>
+</xs:complexType>
<xs:element name="table1" type="dbo:table1Type" abstract="false" substitutionGroup="gml:_Feature">
@@ -595,6 +642,41 @@
</xs:extension>
</xs:complexType>
+<xs:element name="table7" type="dbo:table7Type" abstract="false" substitutionGroup="gml:_Feature">
+</xs:key>
+</xs:element>
+<xs:annotation>
+</xs:annotation>
+<xs:sequence>
+<xs:simpleType>
+</xs:simpleType>
+<xs:annotation>
+</xs:annotation>
+</xs:element>
+<xs:annotation>
+</xs:annotation>
+<xs:simpleType>
+</xs:restriction>
+</xs:simpleType>
+</xs:element>
+</xs:sequence>
+</xs:extension>
+</xs:complexType>
</xs:schema>
<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema" targetNamespace="http://fdo.osgeo.org/schemas/feature/guest" xmlns:fdo="http://fdo.osgeo.org/schemas" xmlns:gml="http://www.opengis.net/gml" xmlns:guest="http://fdo.osgeo.org/schemas/feature/guest" elementFormDefault="qualified" attributeFormDefault="unqualified">
<xs:annotation>
@@ -1660,6 +1742,9 @@
<complexType name="rtable2Type" identityIsGloballyUnique="false" identitySeed="0" identityIncrement="0" identityPropertyName="">
<Table tableFilegroup="PRIMARY" textInRow="NotInRow" pkeyName="pk_dbo_rtable2" name="dbo.rtable2"/>
</complexType>
+<complexType name="rtable7Type" identityIsGloballyUnique="false" identitySeed="1" identityIncrement="1" identityPropertyName="TABLE7_ID">
+<Table tableFilegroup="PRIMARY" textInRow="NotInRow" pkeyName="pk_dbo_rtable7" name="dbo.rtable7"/>
+</complexType>
<complexType name="table1Type" identityIsGloballyUnique="false" identitySeed="0" identityIncrement="0" identityPropertyName="">
<Table tableFilegroup="PRIMARY" textInRow="NotInRow" pkeyName="pk_dbo_table1" name="dbo.table1"/>
</complexType>
@@ -1669,6 +1754,9 @@
<complexType name="table4Type" identityIsGloballyUnique="false" identitySeed="0" identityIncrement="0" identityPropertyName="">
<Table tableFilegroup="PRIMARY" textInRow="NotInRow" pkeyName="pk_dbo_table4" name="dbo.table4"/>
</complexType>
+<complexType name="table7Type" identityIsGloballyUnique="false" identitySeed="1" identityIncrement="1" identityPropertyName="ID">
+<Table tableFilegroup="PRIMARY" textInRow="NotInRow" pkeyName="pk_dbo_table7" name="dbo.table7"/>
+</complexType>
</SchemaMapping>
<SchemaMapping xmlns:rdb="http://fdordbms.osgeo.org/schemas" xmlns="http://www.autodesk.com/isd/fdo/SqlServerProvider" textInRow="NotInRow" provider="Autodesk.SqlServer.3.2" name="guest">
<complexType name="vertable1Type" identityIsGloballyUnique="false" identitySeed="0" identityIncrement="0" identityPropertyName="">
Modified: branches/3.2.1/Providers/GenericRdbms/Src/UnitTest/gen_default1_SqlServer_master.txt
--- branches/3.2.1/Providers/GenericRdbms/Src/UnitTest/gen_default1_SqlServer_master.txt 2007-02-13 17:00:10 UTC (rev 738)
+++ branches/3.2.1/Providers/GenericRdbms/Src/UnitTest/gen_default1_SqlServer_master.txt 2007-02-13 17:07:50 UTC (rev 739)
</xs:extension>
</xs:complexType>
+</xs:key>
+</xs:unique>
+</xs:element>
+<xs:annotation>
+</xs:annotation>
+<xs:sequence>
+<xs:simpleType>
+</xs:simpleType>
+<xs:annotation>
+</xs:annotation>
+</xs:element>
+<xs:annotation>
+</xs:annotation>
+<xs:simpleType>
+</xs:restriction>
+</xs:simpleType>
+</xs:element>
+<xs:simpleType>
+</xs:simpleType>
+<xs:annotation>
+</xs:annotation>
+</xs:element>
+</xs:sequence>
+</xs:extension>
+</xs:complexType>
</xs:extension>
</xs:complexType>
+</xs:key>
+</xs:element>
+<xs:annotation>
+</xs:annotation>
+<xs:sequence>
+<xs:simpleType>
+</xs:simpleType>
+<xs:annotation>
+</xs:annotation>
+</xs:element>
+<xs:annotation>
+</xs:annotation>
+<xs:simpleType>
+</xs:restriction>
+</xs:simpleType>
+</xs:element>
+</xs:sequence>
+</xs:extension>
+</xs:complexType>
</xs:schema>
<SchemaMapping xmlns:rdb="http://fdordbms.osgeo.org/schemas" xmlns="http://www.autodesk.com/isd/fdo/SqlServerProvider" textInRow="NotInRow" provider="Autodesk.SqlServer.3.2" name="dbo">
<complexType name="rtable1Type" identityIsGloballyUnique="false" identitySeed="0" identityIncrement="0" identityPropertyName="">
@@ -603,6 +685,9 @@
</complexType>
+</complexType>
<Table tableFilegroup="PRIMARY" textFilegroup="PRIMARY" textInRow="NotInRow" pkeyName="pk_dbo_table1" name="dbo.table1"/>
</complexType>
@@ -612,5 +697,8 @@
<Table tableFilegroup="PRIMARY" textFilegroup="PRIMARY" textInRow="NotInRow" pkeyName="pk_dbo_table4" name="dbo.table4"/>
</complexType>
+</complexType>
</SchemaMapping>
</fdo:DataStore>
More information about the fdo-commits
