[fdo-commits] r770 - in branches/3.2.x/Utilities/SchemaMgr: .
Inc/Sm/Ph Inc/Sm/Ph/Rd Nls Src/Sm/Ph Src/Sm/Ph/Rd
svn_fdo at osgeo.org
Tue Feb 13 18:25:44 EST 2007
Author: brentrobinson
Date: 2007-02-13 18:25:40 -0500 (Tue, 13 Feb 2007)
New Revision: 770
Added:
branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/BaseObject.h
branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/BaseObjectCollection.h
branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/Rd/BaseObjectReader.h
branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/BaseObject.cpp
branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Rd/BaseObjectReader.cpp
branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/Column.h
branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/ColumnDecimal.h
branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/ColumnGeom.h
branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/ColumnVarlen.h
branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/Database.h
branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/DbObject.h
branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/Mgr.h
branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/Owner.h
branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/Rd/ClassReader.h
branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/Rd/PropertyReader.h
branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/Table.h
branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/View.h
branches/3.2.x/Utilities/SchemaMgr/LogicalPhysical.vcproj
branches/3.2.x/Utilities/SchemaMgr/Nls/SmMessage.mc
branches/3.2.x/Utilities/SchemaMgr/Physical.vcproj
branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Column.cpp
branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/ColumnDecimal.cpp
branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/ColumnGeom.cpp
branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/ColumnVarlen.cpp
branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Database.cpp
branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/DbObject.cpp
branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Makefile.am
branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Mgr.cpp
branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Owner.cpp
branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Rd/ClassReader.cpp
branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Rd/Makefile.am
branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Rd/PropertyReader.cpp
branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Table.cpp
branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/View.cpp
View to Fdo ClassDefinition support.
Added: branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/BaseObject.h
--- branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/BaseObject.h (rev 0)
+++ branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/BaseObject.h 2007-02-13 23:25:40 UTC (rev 770)
@@ -0,0 +1,87 @@
+#ifndef FDOSMPHBASEOBJECT_H
+#define FDOSMPHBASEOBJECT_H 1
+ * Copyright (C) 2004-2006 Autodesk, Inc.
+ * This library is free software; you can redistribute it and/or
+ * modify it under the terms of version 2.1 of the GNU Lesser
+ * General Public License as published by the Free Software Foundation.
+ * This library is distributed in the hope that it will be useful,
+ * but WITHOUT ANY WARRANTY; without even the implied warranty of
+ * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+ * Lesser General Public License for more details.
+ * You should have received a copy of the GNU Lesser General Public
+ * License along with this library; if not, write to the Free Software
+ * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
+#include <Sm/Ph/DbElement.h>
+class FdoSmPhDbObject;
+// This represents a base object reference (typically a reference from a view to
+// a table or view that it is derived from).
+class FdoSmPhBaseObject : public FdoSmPhDbElement
+public:
+ /// Constructs an instance of a base object reference, given the referenced object's name.
+ /// Parameters:
+ /// name: referenced object name
+ /// parent: referencing object
+ /// ownerName: referenced object's owner name. Defaults to referencing objects owner name.
+ /// databaseName: referenced object's database name. Defaults to current database.
+ FdoSmPhBaseObject(
+ FdoStringP name,
+ FdoPtr<FdoSmPhDbObject> parent,
+ FdoStringP ownerName = L"",
+ FdoStringP databaseName = L""
+ /// Constructs an instance of a base object reference, given the referenced object.
+ /// Parameters:
+ /// dbObject: referenced object
+ FdoPtr<FdoSmPhDbObject> dbObject,
+ /// Get the referenced object
+ const FdoSmPhDbObject* RefDbObject() const;
+ FdoPtr<FdoSmPhDbObject> GetDbObject();
+ /// Get the referenced object's owner name
+ FdoStringP GetOwnerName() const;
+ /// Get the referenced object's database name
+ FdoStringP GetDatabaseName() const;
+protected:
+ /// unused constructor needed only to build on Linux
+ FdoSmPhBaseObject();
+ virtual ~FdoSmPhBaseObject(void);
+ // Base object references are not directly persisted in RDBMS.
+ virtual bool Add() {return true;}
+ virtual bool Modify() {return true;}
+ virtual bool Delete() {return true;}
+private:
+ FdoStringP mOwnerName;
+ FdoStringP mDatabaseName;
+ FdoPtr<FdoSmPhDbObject> mDbObject;
+typedef FdoPtr<FdoSmPhBaseObject> FdoSmPhBaseObjectP;
+#endif
Added: branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/BaseObjectCollection.h
--- branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/BaseObjectCollection.h (rev 0)
+++ branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/BaseObjectCollection.h 2007-02-13 23:25:40 UTC (rev 770)
@@ -0,0 +1,45 @@
+#ifndef FDOSMPHBASEOBJECTCOLLECTION_H
+#define FDOSMPHBASEOBJECTCOLLECTION_H 1
+// Copyright (C) 2004-2006 Autodesk, Inc.
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of version 2.1 of the GNU Lesser
+// General Public License as published by the Free Software Foundation.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
+#ifdef _WIN32
+#pragma once
+#endif
+#include <Sm/Ph/../NamedCollection.h>
+#include <Sm/Ph/BaseObject.h>
+// Represents a collection of Table Objects.
+class FdoSmPhBaseObjectCollection : public FdoSmNamedCollection<FdoSmPhBaseObject>
+public:
+ FdoSmPhBaseObjectCollection(const FdoSmSchemaElement* pParent) :
+ FdoSmNamedCollection<FdoSmPhBaseObject>(pParent)
+ ~FdoSmPhBaseObjectCollection(void) {}
+protected:
+ FdoSmPhBaseObjectCollection() {}
+typedef FdoPtr<FdoSmPhBaseObjectCollection> FdoSmPhBaseObjectsP;
+#endif
Modified: branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/Column.h
--- branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/Column.h 2007-02-13 22:45:07 UTC (rev 769)
+++ branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/Column.h 2007-02-13 23:25:40 UTC (rev 770)
@@ -185,6 +185,11 @@
/// Returns true if this column has any not null values.
virtual bool GetHasValues();
+ // Returns true if this column has the same definition (type,nullability)
+ // as the given column.
+ // Subclasses must extend this function if more definition attributes need to be checked.
+ virtual bool DefinitionEquals( FdoPtr<FdoSmPhColumn> otherColumn );
// TODO:
// void ChangeAssociatedSpatialContext();
Modified: branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/ColumnDecimal.h
--- branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/ColumnDecimal.h 2007-02-13 22:45:07 UTC (rev 769)
+++ branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/ColumnDecimal.h 2007-02-13 23:25:40 UTC (rev 770)
@@ -68,6 +68,10 @@
return FdoStringP::Format( L"%ls (%d, %d)", (FdoString*) GetTypeName(), GetLength(), GetScale() );
+ // Returns true if this column has the same definition (type,length,scale,nullability)
+ virtual bool DefinitionEquals( FdoSmPhColumnP otherColumn );
protected:
FdoSmPhColumnDecimal() {}
Modified: branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/ColumnGeom.h
--- branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/ColumnGeom.h 2007-02-13 22:45:07 UTC (rev 769)
+++ branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/ColumnGeom.h 2007-02-13 23:25:40 UTC (rev 770)
@@ -138,6 +138,11 @@
return 0;
+ // Returns true if this column has the same definition (type,dimensionality,srid,nullability)
protected:
Modified: branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/ColumnVarlen.h
--- branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/ColumnVarlen.h 2007-02-13 22:45:07 UTC (rev 769)
+++ branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/ColumnVarlen.h 2007-02-13 23:25:40 UTC (rev 770)
@@ -48,6 +48,10 @@
+ // Returns true if this column has the same definition (type,length,nullability)
protected:
FdoSmPhColumnVarlen() {}
@@ -66,6 +70,8 @@
int mLength;
+typedef FdoPtr<FdoSmPhColumnVarlen> FdoSmPhColumnVarlenP;
#endif
Modified: branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/Database.h
--- branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/Database.h 2007-02-13 22:45:07 UTC (rev 769)
+++ branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/Database.h 2007-02-13 23:25:40 UTC (rev 770)
@@ -69,6 +69,11 @@
/// Get a read-write smart pointer, throws FdoSchemaException if owner not in database
FdoSmPhOwnerP GetOwner(FdoStringP owner);
+ // Get a currently cached owner at the given 0-based index.
+ // Returns NULL if the index is out of range.
+ // This function does not add owners to the cache.
+ FdoSmPhOwnerP GetCachedOwner(FdoInt32 idx);
/// Create a new owner.
virtual FdoSmPhOwnerP CreateOwner(FdoStringP owner, bool hasMetaSchema = true );
Modified: branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/DbObject.h
--- branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/DbObject.h 2007-02-13 22:45:07 UTC (rev 769)
+++ branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/DbObject.h 2007-02-13 23:25:40 UTC (rev 770)
@@ -21,6 +21,8 @@
#include <Sm/Ph/DbObjType.h>
#include <Sm/Ph/ColumnCollection.h>
+#include <Sm/Ph/BaseObjectCollection.h>
+#include <Sm/Ph/FkeyCollection.h>
#include <Sm/Ph/ColumnBLOB.h>
#include <Sm/Ph/ColumnChar.h>
#include <Sm/Ph/ColumnDate.h>
@@ -37,6 +39,10 @@
class FdoSmPhReader;
class FdoSmPhTableColumnReader;
+class FdoSmPhRdBaseObjectReader;
+class FdoSmPhRdPkeyReader;
+class FdoSmPhRdFkeyReader;
+class FdoSmPhTableComponentReader;
class FdoSmPhTableDependencyReader;
// some constants
@@ -60,6 +66,14 @@
const FdoSmPhColumnCollection* RefColumns() const;
FdoSmPhColumnsP GetColumns();
+ /// Returns all the primary key columns in this database object.
+ const FdoSmPhColumnCollection* RefPkeyColumns() const;
+ FdoSmPhColumnsP GetPkeyColumns();
+ /// Returns all foreign keys for which this database object is the foreign "table"
+ const FdoSmPhFkeyCollection* RefFkeysUp() const;
+ FdoSmPhFkeysP GetFkeysUp();
/// Returns all the attribute dependencies (from F_AttributeDependencies)
/// where this database object is the primary key "table".
const FdoSmPhDependencyCollection* GetDependenciesDown() const;
@@ -68,16 +82,58 @@
/// where this databaseobject is the foreign key "table".
const FdoSmPhDependencyCollection* GetDependenciesUp() const;
- // Gets the lowest root object if this object is based on
- // a root object. Returns this if not based on a root object.
+ /// Returns the database object's best identity columns.
+ /// These are the primary key columns if the database object has a primary key.
+ /// If the object has no primary key but it has a root object then the best identity
+ /// for the root object (whose columns are all present in this object) is returned.
+ /// Typically, a view may have a table or another view as its root object.
+ /// NULL is returned if the database object has no identity and none can be derived
+ /// from its root object.
+ FdoSmPhColumnsP GetBestIdentity();
+ /// Supporting function for previous GetBestIdentity() function.
+ /// Returns the database object's best identity columns where all columns are in the
+ /// given database object. The given database object is usually one that has this
+ /// object as its base.
+ /// If there is no best identity on this database object, its root object is not checked.
+ /// NULL is returned if the database object has no identity suitable for the given object.
+ virtual FdoSmPhColumnsP GetBestIdentity( FdoPtr<FdoSmPhDbObject> dbObject );
+ /// Returns the name of this database object's primary key
+ FdoStringP GetPkeyName() const;
+ /// Get the root database object. A root object is a base object for which identity
+ /// can be derived. If this object has exactly one base object then the
+ /// base object is returned as the root object. If this object has multiple base objects then
+ /// the root object is considered ambiguous and NULL is returned. The reason for this is
+ /// that if we can't derive the best identity from the base objects when there are
+ /// more than one of them.
+ const FdoSmPhDbObject* RefRootObject() const;
+ FdoPtr<FdoSmPhDbObject> GetRootObject();
+ /// Get the lowest root object (The one at the top of the root object chain).
virtual FdoPtr<FdoSmPhDbObject> GetLowestRootObject();
+ /// Get the root object name. Returns L"" if this object has no root object.
+ FdoStringP GetRootObjectName() const;
+ /// Get the root object owner name. Returns L"" if this object has no root object.
+ FdoStringP GetRootOwner() const;
+ /// Get the root object's database name. Returns L"" if this object has no root object.
+ FdoStringP GetRootDatabase() const;
/// Returns the name of the containing database.
FdoStringP GetDatabase() const
return GetParent()->GetParent()->GetName();
+ /// Returns all base objects for this object. A base object is a object from which
+ /// this object is derived (e.g. a view can be based on one or more tables or other views)
+ const FdoSmPhBaseObjectCollection* RefBaseObjects() const;
+ FdoSmPhBaseObjectsP GetBaseObjects();
/// Returns the name of the containing owner (physical schema).
FdoStringP GetOwner() const
@@ -121,6 +177,13 @@
/// Returns NULL when size is 0.
virtual const FdoLockType* GetLockTypes(FdoInt32& size) const;
+ // Returns true if the given unique key has the same columns as the primary key.
+ FdoBoolean IsUkeyPkey( FdoSmPhColumnsP ukeyColumns );
+ // Returns true if this database object has all of the given columns. The columns
+ // must match by both name and definition.
+ FdoBoolean HasColumns( FdoSmPhColumnsP columns );
/// The following create various types of columns. See the constructor
/// declarations of these column types for parameter descriptions.
@@ -236,19 +299,55 @@
bool bAttach = true
+ /// Add a foreign key to this database object
+ FdoSmPhFkeyP CreateFkey(
+ FdoStringP name,
+ FdoStringP pkeyTableName,
+ FdoStringP pkeyTableOwner = L""
+ /// Commit modifications
+ /// Ensures that root object is commit before this object.
+ virtual void Commit( bool fromParent = false, bool isBeforeParent = false );
/// Get list of columns as references into a string collection
virtual FdoStringsP GetRefColsSql();
// Generate key column SQL clauses for the given columns.
virtual FdoStringsP GetKeyColsSql( FdoSmPhColumnCollection* columns );
+ /// Get SQL for creating primary key on new database object
+ FdoStringP GetAddPkeySql();
+ /// Sets the primary key name for this database object.
+ /// Can only be called for new database objects.
+ virtual void SetPkeyName( FdoStringP pkeyName );
+ /// Add a column to the primary key.
+ void AddPkeyCol(FdoStringP columnName );
// Load this object's columns from the given reader
virtual void CacheColumns( FdoPtr<FdoSmPhRdColumnReader> rdr );
+ // Load this object's columns from the given reader
+ virtual void CacheBaseObjects( FdoPtr<FdoSmPhRdBaseObjectReader> rdr );
+ // Load this object's primary key from the given reader
+ virtual void CachePkeys( FdoPtr<FdoSmPhRdPkeyReader> rdr );
+ // Load this objects's foreign keys from the given reader
+ virtual void CacheFkeys( FdoPtr<FdoSmPhRdFkeyReader> rdr );
// Load this object's "up" dependencies from the given reader.
// "Up" dependencies are the ones where this object is the FK table.
virtual void CacheDependenciesUp( FdoPtr<FdoSmPhDependencyReader> rdr );
+ /// Commit modifications to foreign keys.
+ virtual void CommitFkeys( bool isBeforeParent );
+ /// Drops this database object whether or not it has data.
+ void ForceDelete();
/// Gather all errors for this element and child elements into a chain of exceptions.
/// Adds each error as an exception, to the given exception chain and returns
/// the chain.
@@ -285,15 +384,52 @@
virtual void SetLockingMode( FdoLtLockModeType mode );
+ // Sets the root object for this database object.
+ // Pass in NULL to remove current root object relationship.
+ // Discards any previously set base objects.
+ void SetRootObject( FdoPtr<FdoSmPhDbObject> rootObject );
/// Loads column list for existing database object
void LoadColumns();
void LoadColumns( FdoPtr<FdoSmPhTableColumnReader> colRdr );
+ /// Loads objects that this object is based on, if not yet loaded.
+ void LoadBaseObjects();
+ void LoadBaseObjects( FdoPtr<FdoSmPhTableComponentReader> baseObjRdr );
+ /// Load Primary Key if not yet loaded
+ void LoadPkeys();
+ void LoadPkeys( FdoPtr<FdoSmPhReader> pkeyRdr, bool isSkipAdd = false );
+ /// Load Foreign Keys if not yet loaded
+ void LoadFkeys();
+ void LoadFkeys( FdoPtr<FdoSmPhReader> fkeyRdr, bool isSkipAdd );
+ // Create new base object group reader
+ virtual FdoPtr<FdoSmPhTableComponentReader> NewTableBaseReader( FdoPtr<FdoSmPhRdBaseObjectReader> rdr );
/// Create a column from a column reader and add it to this database object
virtual FdoSmPhColumnP NewColumn(
FdoPtr<FdoSmPhRdColumnReader> colRdr
+ /// Create a base object reference from a base object reader
+ virtual FdoSmPhBaseObjectP NewBaseObject(
+ FdoPtr<FdoSmPhTableComponentReader> baseObjRdr
+ // Create a base object reference specified by qualified name
+ FdoStringP name,
+ FdoStringP ownerName,
+ // Create a base object reference to the given database object.
/// Various functions that each provider must override to customize the
/// creation of various types of columns.
virtual FdoSmPhColumnP NewColumnBLOB(
@@ -420,9 +556,23 @@
FdoSmPhRdColumnReader* colRdr = NULL
) = 0;
- /// Create a reader to get the columns for this database object.
+ /// Foreign key object creator
+ virtual FdoSmPhFkeyP NewFkey(
+ FdoStringP name,
+ FdoStringP pkeyTableOwner,
+ FdoSchemaElementState elementState = FdoSchemaElementState_Added
+ /// Readers for Columns, Base Objects, Primary Key, and Foreign Keys
virtual FdoPtr<FdoSmPhRdColumnReader> CreateColumnReader() = 0;
+ virtual FdoPtr<FdoSmPhRdBaseObjectReader> CreateBaseObjectReader() const;
+ virtual FdoPtr<FdoSmPhRdPkeyReader> CreatePkeyReader() const;
+ virtual FdoPtr<FdoSmPhRdFkeyReader> CreateFkeyReader() const;
+ /// Autogenerate a unique primary key name for this database object.
+ virtual FdoStringP GenPkeyName();
/// Records this database object as having been updated so that modification
/// can be undone on rollback.
virtual void UpdRollbackCache();
@@ -430,9 +580,25 @@
/// Remove from parent Owner's collection.
virtual void Discard();
+ virtual void AddPkeyColumnError(FdoStringP columnName);
+ FdoSmPhColumnsP mPkeyColumns;
private:
void LoadDependencies( bool up );
void LoadDependenciesUp( FdoPtr<FdoSmPhTableDependencyReader> depRdr );
+ // Create new foreign key group reader
+ virtual FdoPtr<FdoSmPhTableComponentReader> NewTableFkeyReader( FdoPtr<FdoSmPhRdFkeyReader> rdr );
+ // Create new primary key group reader
+ virtual FdoPtr<FdoSmPhTableComponentReader> NewTablePkeyReader( FdoPtr<FdoSmPhRdPkeyReader> rdr );
+ // Check for loop when walking up root objects.
+ // Level is incremented each time this function is called.
+ // Caller is responsible for initializing level to 1 before the first call.
+ bool CheckRootObjectLoop( FdoInt32& level );
/* TODO:
virtual void Finalize();
@@ -442,10 +608,15 @@
void AddNotNullColError(FdoStringP columnName);
void AddColumnNoexistError( FdoStringP indexName, FdoStringP columnName );
+ void AddFkeyColumnError(FdoStringP columnName);
+ void AddCreateFkeyError(FdoStringP fkeyName);
/// Column list for this database object.
FdoSmPhColumnsP mColumns;
+ // Foreign key list.
+ FdoSmPhFkeysP mFkeysUp;
FdoPtr<FdoSmPhDependencyCollection> mDependenciesDown;
FdoPtr<FdoSmPhDependencyCollection> mDependenciesUp;
@@ -455,6 +626,10 @@
/// Supported Lock types.
FdoInt32 mLockTypeCount;
FdoLockType* mLockTypes;
+ FdoStringP mPkeyName;
+ FdoPtr<FdoSmPhBaseObjectCollection> mBaseObjects;
typedef FdoPtr<FdoSmPhDbObject> FdoSmPhDbObjectP;
Modified: branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/Mgr.h
--- branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/Mgr.h 2007-02-13 22:45:07 UTC (rev 769)
+++ branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/Mgr.h 2007-02-13 23:25:40 UTC (rev 770)
@@ -289,6 +289,10 @@
/// Get read-write pointer to database, Throws exception if database not found
FdoSmPhDatabaseP GetDatabase(FdoStringP database = L"");
+ // Get a currently cached database at the given 0-based index.
+ // This function does not add databases to the cache.
+ FdoSmPhDatabaseP GetCachedDatabase(FdoInt32 idx);
/// Get read-write pointer to an owner, NULL if owner not found
FdoSmPhOwnerP FindOwner(FdoStringP ownerName = L"", FdoStringP database = L"", bool caseSensitive = true);
Modified: branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/Owner.h
--- branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/Owner.h 2007-02-13 22:45:07 UTC (rev 769)
+++ branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/Owner.h 2007-02-13 23:25:40 UTC (rev 770)
@@ -36,6 +36,7 @@
class FdoSmPhRdCoordSysReader;
class FdoSmPhRdConstraintReader;
class FdoSmPhRdColumnReader;
class FdoSmPhRdTableJoin;
class FdoSmPhRdSpatialContextReader;
@@ -110,6 +111,11 @@
/// as a read-write smart pointer (exception thrown if not found)
FdoSmPhDbObjectP GetDbObject(FdoStringP dbObject);
+ // Get a currently cached database object at the given 0-based index.
+ // This function does not add database objects to the cache.
+ FdoSmPhDbObjectP GetCachedDbObject(FdoInt32 idx);
// Gets the physical spatial contexts for this owner.
// it contains the spatial contexts reverse-engineered from the RDBMS.
FdoSmPhSpatialContextsP GetSpatialContexts();
@@ -179,6 +185,9 @@
// Create a reader to get all columns for this owner and join
virtual FdoPtr<FdoSmPhRdColumnReader> CreateColumnReader( FdoPtr<FdoSmPhRdTableJoin> join ) const;
+ // Create a reader to get all base object references for this owner
/// Create a new table. Table is not posted to the datastore until its Commit() function
/// is called.
FdoSmPhTableP CreateTable(
Added: branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/Rd/BaseObjectReader.h
--- branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/Rd/BaseObjectReader.h (rev 0)
+++ branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/Rd/BaseObjectReader.h 2007-02-13 23:25:40 UTC (rev 770)
@@ -0,0 +1,67 @@
+#ifndef FDOSMPHRDBASEOBJECTREADER_H
+#define FDOSMPHRDBASEOBJECTREADER_H 1
+#include <Sm/Ph/Reader.h>
+#include <Sm/Ph/RowCollection.h>
+#include <Sm/Ph/DbObjType.h>
+#include <Sm/Ph/Mgr.h>
+// This abstract class reads base objects. Each provider must
+// provide its own implementing class.
+// A base object is a database object that another database object
+// depends on. Typically a view can be based on a table or another view.
+class FdoSmPhRdBaseObjectReader : public FdoSmPhReader
+public:
+protected:
+ //Unused constructor needed only to build on Linux
+ FdoSmPhRdBaseObjectReader() {}
+ // Creates a reader for all base object references in the given owner
+ FdoSmPhReaderP reader, // inner reader created by implementing class
+ FdoSmPhOwnerP owner // get the base objects for this owner
+ // Creates a reader for all base objects for a given database object
+ FdoSmPhDbObjectP dbObject // get the base objects for this database object
+ /// Deactivates the reader.
+ virtual ~FdoSmPhRdBaseObjectReader(void);
+ /// Creates a set of rows describing the fields for this
+ /// reader. There is one field per base object attribute.
+ virtual FdoSmPhRowsP MakeRows( FdoSmPhMgrP mgr );
+ FdoSmPhOwnerP mOwner;
+ FdoSmPhDbObjectP mDbObject;
+typedef FdoPtr<FdoSmPhRdBaseObjectReader> FdoSmPhRdBaseObjectReaderP;
+#endif
Modified: branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/Rd/ClassReader.h
--- branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/Rd/ClassReader.h 2007-02-13 22:45:07 UTC (rev 769)
+++ branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/Rd/ClassReader.h 2007-02-13 23:25:40 UTC (rev 770)
@@ -37,7 +37,8 @@
FdoStringP schemaName, // name of Feature Schema that will contain the classes
FdoStringP className, // name of Feature class
FdoSmPhMgrP mgr, // Physical Schema Manager
- FdoBoolean keyedOnly = true,// If true, skip tables without key.
+ FdoBoolean classifyDefaultTypes = true,// If true, classify only types of objects that are classified by default
+ // If false, classify all types of object than can be classified
FdoStringP database = L"", // Database where RDBMS schema resides (current connection by default)
FdoStringP owner = L"" // the RDBMS schema (defaults to current schema)
@@ -54,8 +55,24 @@
bool IsOrdinate(FdoSmPhColumnP column);
- virtual FdoStringP ClassifyObject( FdoStringP objectName, FdoSmPhDbObjType objectType );
+ // The following two functions control which database objects are reverse-engineered
+ // into FDO Class Definitions:
+ // Returns true if the type for the given object is one for which an FDO class definition
+ // can be generated.
+ // Returns true if the object is a table or view. Sub-classes can override this function
+ // to allow RDBMS-specific types to be classified.
+ // The classifyDefaultTypes parameter has no effect in this function. However, specific
+ // RDBMS's might have some types that can be classified but are not classified by default.
+ // When classifyDefaultTypes is true then this function must return true only for types
+ // that can be classified by default.
+ virtual bool ClassifyObjectType( FdoSmPhDbObjectP dbObject, FdoBoolean classifyDefaultTypes );
+ // Returns true if the given database object's corresponding class is in the Feature Schema
+ // for this class reader.
+ // No checking is done against the object's type. This is performed by ClassifyObjectType()
+ virtual FdoStringP ClassifyObject( FdoSmPhDbObjectP dbObject );
// Find the main geometric property for the class from the given column collection.
// Returns the main geometric property, L"" if none could be determined
// (non geometric properties, or there was a tie for best main geometry).
@@ -64,9 +81,12 @@
virtual FdoStringP FindGeometryProperty( FdoSmPhColumnsP cols, bool& hasGeom );
private:
+ // This function is now obsolete; override or extend ClassifyObject( FdoSmPhDbObjectP ) instead.
+ virtual FdoStringP ClassifyObject( FdoStringP objectName, FdoSmPhDbObjType objectType ) sealed;
FdoStringP mSchemaName;
- FdoBoolean mKeyedOnly;
+ FdoBoolean mClassifyDefaultTypes;
FdoSmPhDbObjectsP mDbObjects;
Modified: branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/Rd/PropertyReader.h
--- branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/Rd/PropertyReader.h 2007-02-13 22:45:07 UTC (rev 769)
+++ branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/Rd/PropertyReader.h 2007-02-13 23:25:40 UTC (rev 770)
@@ -107,7 +107,6 @@
void AddUsedName( FdoStringP propName );
- FdoSmPhTable* mpTable;
FdoSmPhColumnsP mIdCols;
FdoDictionaryP mUsedNames;
int mFkeyCount;
Modified: branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/Table.h
--- branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/Table.h 2007-02-13 22:45:07 UTC (rev 769)
+++ branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/Table.h 2007-02-13 23:25:40 UTC (rev 770)
@@ -23,7 +23,6 @@
#endif
#include <Sm/Ph/DbObject.h>
-#include <Sm/Ph/FkeyCollection.h>
#include <Sm/Ph/IndexCollection.h>
#include <Sm/Ph/ColumnBatchCollection.h>
#include <Sm/Ph/CheckConstraintCollection.h>
@@ -31,8 +30,6 @@
class FdoSmPhMgr;
class FdoSmPhOwner;
-class FdoSmPhRdPkeyReader;
-class FdoSmPhRdFkeyReader;
class FdoSmPhRdIndexReader;
@@ -48,10 +45,6 @@
/// support adding not-null columns.
virtual bool SupportsAddNotNullColumn() const;
- /// Returns all the primary key columns in this table.
- const FdoSmPhColumnCollection* RefPkeyColumns() const;
- FdoSmPhColumnsP GetPkeyColumns();
/// Returns all the unique columns in this table.
const FdoSmPhBatchColumnCollection* RefUkeyColumns() const;
FdoSmPhBatchColumnsP GetUkeyColumns();
@@ -70,27 +63,18 @@
const FdoSmPhIndexCollection* RefIndexes() const;
FdoSmPhIndexesP GetIndexes();
- /// Returns the table's best identity columns.
+ /// Returns the table's best identity columns, where all columns are in the given
+ /// database object (the given object is typically a view based on this table).
/// These are the primary key columns if the table has a primary key.
/// Otherwise, the columns for the table's lightest unique index are returned.
/// NULL is returned if the table has no identity.
- FdoSmPhColumnsP GetBestIdentity();
+ virtual FdoSmPhColumnsP GetBestIdentity( FdoSmPhDbObjectP dbObject );
- /// Returns all foreign keys for which this table is the foreign table
- const FdoSmPhFkeyCollection* RefFkeysUp() const;
- FdoSmPhFkeysP GetFkeysUp();
- /// Returns the name of this table's primary key
- FdoStringP GetPkeyName() const;
/// Returns an array of all types of locking supported on this Database Object.
/// size is set to the size of the array.
- // Returns true if the given unique key has the same columns as the primary key.
- FdoBoolean IsUkeyPkey( FdoSmPhColumnsP ukeyColumns );
/// Get SQL "create table" statement.
virtual FdoStringP GetAddSql();
@@ -115,9 +99,6 @@
/// Get SQL clause for adding a constraint
virtual FdoStringP GetAddConstraintSql(FdoStringP constraint);
- /// Get SQL for creating primary key on new table
- FdoStringP GetAddPkeySql();
/// Get SQL for creating UNIQUE constraints on new table
FdoStringP GetAddUkeysSql();
@@ -138,17 +119,10 @@
/// Can only be changed on new tables.
virtual void SetLtMode( FdoLtLockModeType mode );
- /// Sets the primary key name for this table.
- /// Can only be called for new tables.
- virtual void SetPkeyName( FdoStringP pkeyName );
/// Set the locking mode.
- /// Add a column to the primary key.
- void AddPkeyCol(FdoStringP columnName );
/// Add a column to a collection of unique keys
void AddUkeyCol(int uCollNum, FdoStringP columnName );
@@ -167,13 +141,6 @@
bool isUnique
- /// Add a foreign key to this table
- FdoSmPhFkeyP CreateFkey(
- FdoStringP name,
- FdoStringP pkeyTableName,
- FdoStringP pkeyTableOwner = L""
/// Return the list of constraints marked for drop
FdoStringsP GetDeletedConstraints();
@@ -181,33 +148,21 @@
/// deleting it from the datastore.
void DiscardIndex( FdoSmPhIndex* index );
- /// Commit modifications to foreign keys.
- virtual void CommitFkeys( bool isBeforeParent );
/// Deletes all rows from this table.
virtual void ClearRows() = 0;
/// Set the modification state of this table.
virtual void SetElementState(FdoSchemaElementState elementState);
- /// Drops the table whether or not it has data.
- void ForceDelete();
// Load this table's unique constraints from the given reader
virtual void CacheUkeys( FdoPtr<FdoSmPhRdConstraintReader> rdr );
// Load this table's check constraints from the given reader
virtual void CacheCkeys( FdoPtr<FdoSmPhRdConstraintReader> rdr );
- // Load this table's foreign keys from the given reader
- virtual void CacheFkeys( FdoPtr<FdoSmPhRdFkeyReader> rdr );
// Load this table's indexes from the given reader
virtual void CacheIndexes( FdoPtr<FdoSmPhRdIndexReader> rdr );
- // Load this table's primary key from the given reader
- virtual void CachePkeys( FdoPtr<FdoSmPhRdPkeyReader> rdr );
/// the chain.
@@ -246,10 +201,8 @@
FdoPtr<FdoSmPhTableIndexReader> rdr
- /// Readers for Primary Key, Constraints, Foreign Keys and Indexes.
+ /// Readers for Constraints and Indexes.
/// All have provider-specific implementations
- virtual FdoPtr<FdoSmPhRdPkeyReader> CreatePkeyReader() const = 0;
- virtual FdoPtr<FdoSmPhRdFkeyReader> CreateFkeyReader() const = 0;
virtual FdoPtr<FdoSmPhRdConstraintReader> CreateConstraintReader(FdoString* type) const = 0;
virtual FdoPtr<FdoSmPhRdIndexReader> CreateIndexReader() const = 0;
@@ -267,14 +220,6 @@
) = 0;
- /// Foreign key object creator
- virtual FdoSmPhFkeyP NewFkey(
- FdoStringP name,
- FdoStringP pkeyTableOwner,
- FdoSchemaElementState elementState = FdoSchemaElementState_Added
- ) = 0;
/// Commit modifications to child objects
virtual void CommitChildren( bool isBeforeParent );
@@ -287,9 +232,6 @@
/// Commit new added Check constraints
virtual void CommitCConstraints( bool isBeforeParent );
- /// Autogenerate a unique primary key name for this table.
- virtual FdoStringP GenPkeyName();
/// Column update functions, each provider must implement.
virtual bool AddColumn( FdoSmPhColumnP column ) = 0;
virtual bool ModifyColumn( FdoSmPhColumnP column ) = 0;
@@ -301,19 +243,9 @@
/// Add a constrait given the fully qualified string.
virtual bool AddConstraint( FdoStringP constraint ) = 0;
- void LoadPkeys( FdoPtr<FdoSmPhReader> pkeyRdr, bool isSkipAdd = false );
- virtual void AddPkeyColumnError(FdoStringP columnName);
virtual void AddIndexColumnError(FdoStringP columnName);
- FdoSmPhColumnsP mPkeyColumns;
private:
- /// Load Primary Key if not yet loaded
- void LoadPkeys();
- /// Load Foreign Keys if not yet loaded
- void LoadFkeys();
- void LoadFkeys( FdoPtr<FdoSmPhReader> fkeyRdr, bool isSkipAdd );
/// Load Unique Keys if not yet loaded
void LoadUkeys();
void LoadUkeys( FdoPtr<FdoSmPhReader> ukeyRdr, bool isSkipAdd );
@@ -331,16 +263,9 @@
// Create new check constraint group reader
virtual FdoPtr<FdoSmPhTableComponentReader> NewTableCkeyReader( FdoPtr<FdoSmPhRdConstraintReader> rdr );
- // Create new foreign key group reader
- virtual FdoPtr<FdoSmPhTableComponentReader> NewTableFkeyReader( FdoPtr<FdoSmPhRdFkeyReader> rdr );
// Create new index group reader
virtual FdoPtr<FdoSmPhTableIndexReader> NewTableIndexReader( FdoPtr<FdoSmPhRdIndexReader> rdr );
- // Create new primary key group reader
- virtual FdoPtr<FdoSmPhTableComponentReader> NewTablePkeyReader( FdoPtr<FdoSmPhRdPkeyReader> rdr );
- void AddFkeyColumnError(FdoStringP columnName);
void AddUkeyColumnError(FdoStringP columnName);
void AddUkeyError(FdoStringP columnNames);
void AddCkeyColumnError(FdoStringP columnName);
@@ -351,11 +276,8 @@
FdoSmPhCheckConstraintsP mCkeysCollection;
FdoStringsP mDeletedConstraints;
- FdoSmPhFkeysP mFkeysUp;
FdoSmPhIndexesP mIndexes;
- FdoStringP mPkeyName;
typedef FdoPtr<FdoSmPhTable> FdoSmPhTableP;
Modified: branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/View.h
--- branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/View.h 2007-02-13 22:45:07 UTC (rev 769)
+++ branches/3.2.x/Utilities/SchemaMgr/Inc/Sm/Ph/View.h 2007-02-13 23:25:40 UTC (rev 770)
@@ -32,30 +32,6 @@
class FdoSmPhView : virtual public FdoSmPhDbObject
public:
- /// Get the underlying table if this is a view over a foreign table
- const FdoSmPhDbObject* RefRootObject() const;
- FdoSmPhDbObjectP GetRootObject();
- virtual FdoSmPhDbObjectP GetLowestRootObject();
- /// Get the underlying table name if this is a view over a foreign table
- FdoStringP GetRootObjectName() const
- return mRootObjectName;
- /// Get the underlying table owner if this is a view over a foreign table
- FdoStringP GetRootOwner() const
- return mRootOwner;
- /// Get the underlying table database if this is a view over a foreign table
- FdoStringP GetRootDatabase() const
- return mRootDatabase;
void SetRootObject( FdoSmPhDbObjectP rootObject );
/// Serialize the table to an XML file.
@@ -104,12 +80,6 @@
virtual FdoStringP GetRootNameSql() = 0;
private:
- /// The following three are only set when this "table" is actually a view.
- FdoStringP mRootObjectName;
- FdoStringP mRootDatabase;
- FdoStringP mRootOwner;
- FdoSmPhDbObjectP mRootObject;
typedef FdoPtr<FdoSmPhView> FdoSmPhViewP;
Modified: branches/3.2.x/Utilities/SchemaMgr/LogicalPhysical.vcproj
--- branches/3.2.x/Utilities/SchemaMgr/LogicalPhysical.vcproj 2007-02-13 22:45:07 UTC (rev 769)
+++ branches/3.2.x/Utilities/SchemaMgr/LogicalPhysical.vcproj 2007-02-13 23:25:40 UTC (rev 770)
@@ -41,6 +41,7 @@
<Tool
Name="VCCLCompilerTool"
+ AdditionalOptions="-Zm110"
Optimization="0"
AdditionalIncludeDirectories=""$(FDO)\Unmanaged\Inc";"$(FDO)\Unmanaged";Inc;"$(FDOUTILITIES)\Common\Inc""
PreprocessorDefinitions="WIN32;_DEBUG;_LIB;_CRT_SECURE_NO_DEPRECATE;_AFXDLL"
Modified: branches/3.2.x/Utilities/SchemaMgr/Nls/SmMessage.mc
--- branches/3.2.x/Utilities/SchemaMgr/Nls/SmMessage.mc 2007-02-13 22:45:07 UTC (rev 769)
+++ branches/3.2.x/Utilities/SchemaMgr/Nls/SmMessage.mc 2007-02-13 23:25:40 UTC (rev 770)
@@ -161,6 +161,11 @@
Language=English
Class '%1$ls' uses Base table mapping; Cannot include base property '%2$ls' in unique constraint
+MessageId=2235
+SymbolicName=FDOSM_30
+Language=English
+Cannot add foreign key '%1$ls' to '%2$ls'; adding foreign key to this type of object is not supported
MessageId=2327
SymbolicName=FDOSM_122
Language=English
Modified: branches/3.2.x/Utilities/SchemaMgr/Physical.vcproj
--- branches/3.2.x/Utilities/SchemaMgr/Physical.vcproj 2007-02-13 22:45:07 UTC (rev 769)
+++ branches/3.2.x/Utilities/SchemaMgr/Physical.vcproj 2007-02-13 23:25:40 UTC (rev 770)
@@ -171,6 +171,10 @@
</File>
<File
+ RelativePath=".\Src\Sm\Ph\BaseObject.cpp"
+ </File>
+ <File
RelativePath=".\Src\Sm\Ph\CharacterSet.cpp"
</File>
@@ -219,11 +223,11 @@
</File>
<File
- RelativePath=".\src\Sm\Ph\ColumnList.cpp"
+ RelativePath=".\Src\Sm\Ph\ColumnList.cpp"
</File>
<File
- RelativePath=".\Src\Sm\Ph\ColumnList.cpp"
+ RelativePath=".\src\Sm\Ph\ColumnList.cpp"
</File>
<File
@@ -446,6 +450,10 @@
</FileConfiguration>
</File>
<File
+ RelativePath=".\Src\Sm\Ph\Rd\BaseObjectReader.cpp"
+ </File>
+ <File
RelativePath=".\Src\Sm\Ph\Rd\CharacterSetReader.cpp"
</File>
@@ -975,6 +983,14 @@
</File>
<File
+ RelativePath=".\Inc\Sm\Ph\BaseObject.h"
+ </File>
+ <File
+ RelativePath=".\Inc\Sm\Ph\BaseObjectCollection.h"
+ </File>
+ <File
RelativePath=".\Inc\Sm\Ph\CharacterSet.h"
</File>
@@ -1350,6 +1366,10 @@
</File>
<File
+ RelativePath=".\Inc\Sm\Ph\Rd\BaseObjectReader.h"
+ </File>
+ <File
RelativePath=".\Inc\Sm\Ph\Rd\CharacterSetReader.h"
</File>
Added: branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/BaseObject.cpp
--- branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/BaseObject.cpp (rev 0)
+++ branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/BaseObject.cpp 2007-02-13 23:25:40 UTC (rev 770)
@@ -0,0 +1,81 @@
+#include "stdafx.h"
+#include <Sm/Ph/DbObject.h>
+FdoSmPhBaseObject::FdoSmPhBaseObject(
+ FdoStringP name,
+ FdoSmPhDbElement(name, (FdoSmPhMgr*) NULL, parent, FdoSchemaElementState_Detached ),
+ mOwnerName(ownerName),
+ mDatabaseName(databaseName)
+ if ( ownerName == L"" )
+ mOwnerName = parent->GetParent()->GetName();
+ FdoSmPhDbElement(dbObject->GetName(), (FdoSmPhMgr*) NULL, parent, FdoSchemaElementState_Detached ),
+ mOwnerName(dbObject->GetParent()->GetName()),
+ mDatabaseName(dbObject->GetParent()->GetParent()->GetName()),
+ mDbObject(dbObject)
+FdoSmPhBaseObject::FdoSmPhBaseObject(void)
+FdoSmPhBaseObject::~FdoSmPhBaseObject(void)
+const FdoSmPhDbObject* FdoSmPhBaseObject::RefDbObject() const
+ FdoSmPhDbObjectP rootObject = ((FdoSmPhBaseObject*) this)->GetDbObject();
+ return (FdoSmPhDbObject*) rootObject;
+FdoSmPhDbObjectP FdoSmPhBaseObject::GetDbObject()
+ if ( (wcslen(GetName()) > 0) && (!mDbObject) )
+ mDbObject = GetManager()->FindDbObject( GetName(), GetOwnerName(), GetDatabaseName() );
+ return mDbObject;
+FdoStringP FdoSmPhBaseObject::GetOwnerName() const
+ return mOwnerName;
+FdoStringP FdoSmPhBaseObject::GetDatabaseName() const
+ return mDatabaseName;
Modified: branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Column.cpp
--- branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Column.cpp 2007-02-13 22:45:07 UTC (rev 769)
+++ branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Column.cpp 2007-02-13 23:25:40 UTC (rev 770)
@@ -262,6 +262,16 @@
return hasData;
+bool FdoSmPhColumn::DefinitionEquals( FdoSmPhColumnP otherColumn )
+ bool equals = false;
+ if ( (GetType() == otherColumn->GetType()) && (GetNullable() == otherColumn->GetNullable()) )
+ equals = true;
+ return equals;
void FdoSmPhColumn::SetElementState(FdoSchemaElementState elementState)
FdoSchemaElementState oldState = GetElementState();
Modified: branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/ColumnDecimal.cpp
--- branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/ColumnDecimal.cpp 2007-02-13 22:45:07 UTC (rev 769)
+++ branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/ColumnDecimal.cpp 2007-02-13 23:25:40 UTC (rev 770)
@@ -28,3 +28,20 @@
+bool FdoSmPhColumnDecimal::DefinitionEquals( FdoSmPhColumnP otherColumn )
+ bool equals = FdoSmPhColumnVarlen::DefinitionEquals( otherColumn );
+ if ( equals ) {
+ equals = false;
+ FdoSmPhColumnDecimalP otherDecimalColumn = otherColumn->SmartCast<FdoSmPhColumnDecimal>();
+ if ( otherDecimalColumn && (GetScale() == otherDecimalColumn->GetScale()) )
+ equals = true;
+ return equals;
Modified: branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/ColumnGeom.cpp
--- branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/ColumnGeom.cpp 2007-02-13 22:45:07 UTC (rev 769)
+++ branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/ColumnGeom.cpp 2007-02-13 23:25:40 UTC (rev 770)
@@ -101,6 +101,25 @@
mSpatialIndex = NULL;
+bool FdoSmPhColumnGeom::DefinitionEquals( FdoSmPhColumnP otherColumn )
+ bool equals = FdoSmPhColumn::DefinitionEquals( otherColumn );
+ if ( equals ) {
+ equals = false;
+ FdoSmPhColumnGeomP otherGeomColumn = otherColumn->SmartCast<FdoSmPhColumnGeom>();
+ if ( otherGeomColumn &&
+ (GetDimensionality() == otherGeomColumn->GetDimensionality()) &&
+ (GetSRID() == otherGeomColumn->GetSRID())
+ equals = true;
+ return equals;
void FdoSmPhColumnGeom::SetSpatialIndex( FdoSmPhSpatialIndexP spatialIndex )
FdoSmPhTableP table =
Modified: branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/ColumnVarlen.cpp
--- branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/ColumnVarlen.cpp 2007-02-13 22:45:07 UTC (rev 769)
+++ branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/ColumnVarlen.cpp 2007-02-13 23:25:40 UTC (rev 770)
@@ -40,3 +40,19 @@
return 1;
+bool FdoSmPhColumnVarlen::DefinitionEquals( FdoSmPhColumnP otherColumn )
+ if ( equals ) {
+ equals = false;
+ FdoSmPhColumnVarlenP otherVarColumn = otherColumn->SmartCast<FdoSmPhColumnVarlen>();
+ if ( otherVarColumn && (GetLength() == otherVarColumn->GetLength()) )
+ equals = true;
+ return equals;
Modified: branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Database.cpp
--- branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Database.cpp 2007-02-13 22:45:07 UTC (rev 769)
+++ branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Database.cpp 2007-02-13 23:25:40 UTC (rev 770)
@@ -85,6 +85,17 @@
return(pOwner);
+FdoSmPhOwnerP FdoSmPhDatabase::GetCachedOwner(FdoInt32 idx)
+ FdoSmPhOwnerP owner;
+ FdoSmPhOwnersP owners = GetOwners();
+ if ( (idx >= 0) && (idx < owners->GetCount()) )
+ owner = owners->GetItem( idx );
+ return owner;
const FdoSmPhCharacterSet* FdoSmPhDatabase::RefCharacterSet(FdoStringP characterSetName) const
return (FdoSmPhCharacterSet*) ((FdoSmPhDatabase*) this)->FindCharacterSet(characterSetName);
Modified: branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/DbObject.cpp
--- branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/DbObject.cpp 2007-02-13 22:45:07 UTC (rev 769)
+++ branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/DbObject.cpp 2007-02-13 23:25:40 UTC (rev 770)
@@ -23,8 +23,12 @@
#include <Sm/Ph/DependencyCollection.h>
#include <Sm/Ph/Rd/QueryReader.h>
#include <Sm/Ph/Rd/ColumnReader.h>
+#include <Sm/Ph/Rd/BaseObjectReader.h>
+#include <Sm/Ph/Rd/PkeyReader.h>
+#include <Sm/Ph/Rd/FkeyReader.h>
#include <Sm/Ph/DependencyReader.h>
#include <Sm/Ph/TableComponentReader.h>
+#include <Sm/Error.h>
FdoSmPhDbObject::FdoSmPhDbObject(
FdoStringP name,
@@ -59,7 +63,32 @@
return mColumns;
+const FdoSmPhColumnCollection* FdoSmPhDbObject::RefPkeyColumns() const
+ FdoSmPhColumnsP columns = ((FdoSmPhDbObject*) this)->GetPkeyColumns();
+ return (FdoSmPhColumnCollection*) columns;
+FdoSmPhColumnsP FdoSmPhDbObject::GetPkeyColumns()
+ LoadPkeys();
+ return mPkeyColumns;
+const FdoSmPhFkeyCollection* FdoSmPhDbObject::RefFkeysUp() const
+ return (FdoSmPhFkeyCollection*) ((FdoSmPhDbObject*) this)->GetFkeysUp();
+FdoSmPhFkeysP FdoSmPhDbObject::GetFkeysUp()
+ LoadFkeys();
+ return mFkeysUp;
const FdoSmPhDependencyCollection* FdoSmPhDbObject::GetDependenciesDown() const
((FdoSmPhDbObject*) this)->LoadDependencies(false);
@@ -74,11 +103,148 @@
return (FdoSmPhDependencyCollection*) mDependenciesUp;
+FdoSmPhColumnsP FdoSmPhDbObject::GetBestIdentity()
+ FdoSmPhColumnsP bestIdentity = GetBestIdentity( (FdoSmPhDbObject*) NULL );
+ // Choose primary key only if present
+ FdoSmPhDbObjectP rootObject = FDO_SAFE_ADDREF(this);
+ // If this database object does not have best identity of its own, look for a
+ // best identity from its root objects.
+ FdoInt32 level = 1;
+ while ( bestIdentity == NULL ) {
+ rootObject = rootObject->GetRootObject();
+ if ( rootObject )
+ bestIdentity = rootObject->GetBestIdentity( FDO_SAFE_ADDREF(this) );
+ else
+ break;
+ // Give up if this object has circular root object dependencies.
+ if ( !CheckRootObjectLoop(level) )
+ break;
+ return bestIdentity;
+FdoSmPhColumnsP FdoSmPhDbObject::GetBestIdentity( FdoSmPhDbObjectP dbObject )
+ FdoSmPhColumnsP bestIdentity = GetPkeyColumns();
+ if ( bestIdentity->GetCount() == 0 ) {
+ bestIdentity = NULL;
+ if ( bestIdentity ) {
+ if ( dbObject && !dbObject->HasColumns(bestIdentity) )
+FdoStringP FdoSmPhDbObject::GetPkeyName() const
+ // Trip a load of the primary key.
+ RefPkeyColumns();
+ return mPkeyName;
+const FdoSmPhDbObject* FdoSmPhDbObject::RefRootObject() const
+ FdoSmPhDbObjectP rootObject = ((FdoSmPhDbObject*) this)->GetRootObject();
+FdoSmPhDbObjectP FdoSmPhDbObject::GetRootObject()
+ FdoSmPhDbObjectP rootObject;
+ FdoSmPhBaseObjectsP baseObjects = GetBaseObjects();
+ if ( baseObjects->GetCount() == 1 ) {
+ FdoSmPhBaseObjectP baseObject = baseObjects->GetItem(0);
+ rootObject = baseObject->GetDbObject();
+ return rootObject;
FdoSmPhDbObjectP FdoSmPhDbObject::GetLowestRootObject()
- return FDO_SAFE_ADDREF(this);
+ FdoSmPhDbObjectP rootObject = GetRootObject();
+ if ( rootObject )
+ rootObject = rootObject->GetLowestRootObject();
+ else
+ rootObject = FDO_SAFE_ADDREF(this);
+FdoStringP FdoSmPhDbObject::GetRootObjectName() const
+ FdoStringP rootObjectName;
+ const FdoSmPhBaseObjectCollection* baseObjects = RefBaseObjects();
+ const FdoSmPhBaseObject* baseObject = baseObjects->RefItem(0);
+ rootObjectName = baseObject->GetName();
+ return rootObjectName;
+FdoStringP FdoSmPhDbObject::GetRootOwner() const
+ FdoStringP rootOwnerName;
+ rootOwnerName = baseObject->GetOwnerName();
+ return rootOwnerName;
+FdoStringP FdoSmPhDbObject::GetRootDatabase() const
+ FdoStringP rootDatabaseName;
+ rootDatabaseName = baseObject->GetDatabaseName();
+ return rootDatabaseName;
+const FdoSmPhBaseObjectCollection* FdoSmPhDbObject::RefBaseObjects() const
+ FdoSmPhBaseObjectsP baseObjects = ((FdoSmPhDbObject*) this)->GetBaseObjects();
+ return (FdoSmPhBaseObjectCollection*) baseObjects;
+FdoSmPhBaseObjectsP FdoSmPhDbObject::GetBaseObjects()
+ LoadBaseObjects();
+ return mBaseObjects;
FdoStringP FdoSmPhDbObject::GetDDLName() const
return GetDbName();
@@ -144,6 +310,45 @@
return NULL;
+FdoBoolean FdoSmPhDbObject::IsUkeyPkey( FdoSmPhColumnsP ukeyColumns )
+ FdoBoolean isUkeyPkey = false;
+ FdoInt32 idx;
+ FdoSmPhColumnsP pkeyColumns = GetPkeyColumns();
+ if ( (ukeyColumns->GetCount() > 0) && (ukeyColumns->GetCount() == pkeyColumns->GetCount()) ) {
+ isUkeyPkey = true;
+ for ( idx = 0; idx < ukeyColumns->GetCount(); idx++ ) {
+ FdoSmPhColumnP ukeyColumn = ukeyColumns->GetItem( idx );
+ if ( pkeyColumns->IndexOf(ukeyColumn->GetName()) < 0 ) {
+ isUkeyPkey = false;
+ break;
+ return isUkeyPkey;
+FdoBoolean FdoSmPhDbObject::HasColumns( FdoSmPhColumnsP columns )
+ FdoBoolean hasColumns = true;
+ FdoInt32 ix;
+ for ( ix = 0; ix < columns->GetCount(); ix++ ) {
+ FdoSmPhColumnP column = columns->GetItem( ix );
+ FdoSmPhColumnP thisColumn = GetColumns()->FindItem(column->GetName());
+ if ( (!thisColumn) || !column->DefinitionEquals(thisColumn) ) {
+ hasColumns = false;
+ break;
+ return hasColumns;
FdoStringsP FdoSmPhDbObject::GetRefColsSql()
FdoSmPhColumnsP columns = GetColumns();
@@ -157,6 +362,58 @@
return _getRefColsSql( columns );
+FdoStringP FdoSmPhDbObject::GetAddPkeySql()
+ FdoStringP pkeySql;
+ bool ansiQuotes = GetManager()->SupportsAnsiQuotes();
+ if ( pkeyColumns->GetCount() > 0 ) {
+ FdoStringsP pkColNames = GetKeyColsSql( pkeyColumns );
+ pkeySql = FdoStringP::Format(
+ L"constraint %ls%ls%ls primary key ( %ls )",
+ ansiQuotes ? L"\"" : L"",
+ (FdoString*) this->GenPkeyName(),
+ (FdoString*) pkColNames->ToString()
+ return pkeySql;
+void FdoSmPhDbObject::SetPkeyName( FdoStringP pkeyName )
+ if ( GetElementState() != FdoSchemaElementState_Added )
+ throw FdoSchemaException::Create(
+ FdoSmError::NLSGetMessage(
+ FDO_NLSID(FDOSM_20),
+ (FdoString*) GetQName()
+ mPkeyName = pkeyName;
+void FdoSmPhDbObject::AddPkeyCol(FdoStringP columnName )
+ LoadPkeys();
+ FdoSmPhColumnP column = GetColumns()->FindItem( columnName );
+ if ( column )
+ mPkeyColumns->Add( column );
+ else
+ FDO_NLSID(FDOSM_213),
+ (FdoString*) columnName,
+ GetName()
FdoStringP FdoSmPhDbObject::XMLSerializeProviderAtts() const
return FdoStringP::mEmptyString;
@@ -461,6 +718,38 @@
return column;
+FdoSmPhFkeyP FdoSmPhDbObject::CreateFkey(
+ FdoStringP name,
+ FdoStringP lTableOwner = pkeyTableOwner;
+ if ( lTableOwner == L"" )
+ lTableOwner = GetParent()->GetName();
+ FdoSmPhFkeyP fkey = NewFkey( name, pkeyTableName, lTableOwner );
+ if ( fkey == NULL )
+ AddCreateFkeyError( name );
+ FdoSmPhFkeysP fkeys = GetFkeysUp();
+ fkeys->Add( fkey );
+ return fkey;
+void FdoSmPhDbObject::Commit( bool fromParent, bool isBeforeParent )
+ FdoSmPhDbObjectP rootObject = this->GetRootObject();
+ if ( rootObject )
+ rootObject->Commit(fromParent, isBeforeParent);
+ FdoSmPhDbElement::Commit( fromParent, isBeforeParent );
void FdoSmPhDbObject::CheckNewColumn(
FdoStringP columnName,
@@ -533,6 +822,44 @@
+void FdoSmPhDbObject::CacheBaseObjects( FdoSmPhRdBaseObjectReaderP rdr )
+ // Do nothing if base objects already loaded
+ if ( !mBaseObjects ) {
+ mBaseObjects = new FdoSmPhBaseObjectCollection( this );
+ FdoSmPhTableComponentReaderP groupReader = NewTableBaseReader(
+ rdr
+ LoadBaseObjects( groupReader );
+void FdoSmPhDbObject::CachePkeys( FdoSmPhRdPkeyReaderP rdr )
+ // Do nothing if primary key already loaded
+ if ( !mPkeyColumns ) {
+ mPkeyColumns = new FdoSmPhColumnCollection();
+ LoadPkeys( NewTablePkeyReader(rdr)->SmartCast<FdoSmPhReader>(), false );
+ else
+ LoadPkeys( NewTablePkeyReader(rdr)->SmartCast<FdoSmPhReader>(), true );
+void FdoSmPhDbObject::CacheFkeys( FdoSmPhRdFkeyReaderP rdr )
+ // Do nothing if foreign keys already loaded.
+ if ( !mFkeysUp ) {
+ mFkeysUp = new FdoSmPhFkeyCollection();
+ LoadFkeys( NewTableFkeyReader(rdr)->SmartCast<FdoSmPhReader>(), false );
+ else
+ LoadFkeys( NewTableFkeyReader(rdr)->SmartCast<FdoSmPhReader>(), true );
void FdoSmPhDbObject::CacheDependenciesUp( FdoSmPhDependencyReaderP rdr )
// Do nothing if "up" dependencies already loaded
@@ -557,6 +884,30 @@
+void FdoSmPhDbObject::CommitFkeys( bool isBeforeParent )
+ FdoInt32 i;
+ FdoStringsP fkeyClauses = FdoStringCollection::Create();
+ for ( i = (fkeys->GetCount() - 1); i >= 0; i-- ) {
+ FdoSmPhFkeyP(fkeys->GetItem(i))->Commit(true, isBeforeParent);
+void FdoSmPhDbObject::ForceDelete()
+ FdoInt32 i;
+ FdoSmPhSchemaElement::SetElementState( FdoSchemaElementState_Deleted );
+ // Must explicitly delete any foreign keys when table is deleted.
+ for ( i = 0; i < fkeys->GetCount(); i++ ) {
+ FdoSmPhFkeyP(fkeys->GetItem(i))->SetElementState(FdoSchemaElementState_Deleted);
FdoSchemaExceptionP FdoSmPhDbObject::Errors2Exception(FdoSchemaException* pFirstException ) const
@@ -564,11 +915,19 @@
FdoSchemaExceptionP pException = FdoSmPhDbElement::Errors2Exception(pFirstException);
const FdoSmPhColumnCollection* pColumns = RefColumns();
+ int i;
// Add errors for the database object's columns.
- for ( int i = 0; i < pColumns->GetCount(); i++ )
+ for ( i = 0; i < pColumns->GetCount(); i++ )
pException = pColumns->RefItem(i)->Errors2Exception(pException);
+ if ( mFkeysUp ) {
+ // Add errors for the database object's foreign keys.
+ for ( i = 0; i < mFkeysUp->GetCount(); i++ )
+ pException = mFkeysUp->RefItem(i)->Errors2Exception(pException);
return pException;
@@ -630,13 +989,33 @@
+FdoPtr<FdoSmPhTableComponentReader> FdoSmPhDbObject::NewTablePkeyReader( FdoSmPhRdPkeyReaderP rdr )
+ return new FdoSmPhTableComponentReader(
+ GetName(),
+ L"",
+ L"table_name",
+ rdr->SmartCast<FdoSmPhReader>()
+FdoPtr<FdoSmPhTableComponentReader> FdoSmPhDbObject::NewTableFkeyReader( FdoSmPhRdFkeyReaderP rdr )
+ GetName(),
+ L"",
+ L"table_name",
FdoStringsP FdoSmPhDbObject::_getRefColsSql( FdoSmPhColumnCollection* columns )
FdoInt32 i;
FdoStringsP colClauses = FdoStringCollection::Create();
for ( i = 0; i < columns->GetCount(); i++ ) {
- colClauses->Add( columns->GetItem(i)->GetDbName() );
+ colClauses->Add( columns->RefItem(i)->GetDbName() );
return colClauses;
@@ -652,6 +1031,16 @@
mLockingMode = mode;
+void FdoSmPhDbObject::SetRootObject( FdoSmPhDbObjectP rootObject )
+ mBaseObjects->Clear();
+ if ( rootObject ) {
+ FdoSmPhBaseObjectP baseObject = NewBaseObject( rootObject );
+ mBaseObjects->Add( baseObject );
void FdoSmPhDbObject::LoadColumns()
if ( !mColumns ) {
@@ -680,10 +1069,145 @@
while ( colRdr->ReadNext() ) {
FdoSmPhColumnP newColumn = NewColumn( colRdr->GetColumnReader() );
- mColumns->Add( newColumn );
+ if ( newColumn )
+ mColumns->Add( newColumn );
+void FdoSmPhDbObject::LoadBaseObjects()
+ // Base objects not loaded so initialize the list.
+ // Skip database access when not necessary: object is new or has no name.
+ // Some temporary objects created by various readers have no name.
+ if ( (GetElementState() != FdoSchemaElementState_Added) && (wcslen(GetName()) > 0) ) {
+ FdoPtr<FdoSmPhRdBaseObjectReader> baseObjRdr = CreateBaseObjectReader();
+ // Read each column from the database and add it to this database object.
+ if ( baseObjRdr ) {
+ baseObjRdr
+void FdoSmPhDbObject::LoadBaseObjects( FdoPtr<FdoSmPhTableComponentReader> baseObjRdr )
+ while ( baseObjRdr->ReadNext() ) {
+ FdoSmPhBaseObjectP newBaseObject = NewBaseObject( baseObjRdr );
+ if ( newBaseObject )
+ mBaseObjects->Add( newBaseObject );
+void FdoSmPhDbObject::LoadPkeys(void)
+ // Skip load if new table.
+ if ( GetElementState() != FdoSchemaElementState_Added ) {
+ FdoPtr<FdoSmPhRdPkeyReader> pkeyRdr = CreatePkeyReader();
+ if ( pkeyRdr )
+ LoadPkeys( pkeyRdr->SmartCast<FdoSmPhReader>(), false );
+void FdoSmPhDbObject::LoadPkeys( FdoSmPhReaderP pkeyRdr, bool isSkipAdd )
+ // read each primary key column.
+ while (pkeyRdr->ReadNext() ) {
+ mPkeyName = pkeyRdr->GetString(L"", L"constraint_name");
+ FdoStringP columnName = pkeyRdr->GetString(L"",L"column_name");
+ FdoSmPhColumnP pkeyColumn = GetColumns()->FindItem( columnName );
+ if ( pkeyColumn == NULL ) {
+ // Primary Key column must be in this table.
+ if ( GetElementState() != FdoSchemaElementState_Deleted )
+ AddPkeyColumnError( columnName );
+ else if( ! isSkipAdd ) {
+ mPkeyColumns->Add(pkeyColumn);
+void FdoSmPhDbObject::LoadFkeys(void)
+ // Do nothing if already loaded
+ // Skip load for new tables
+ FdoPtr<FdoSmPhRdFkeyReader> fkeyRdr = CreateFkeyReader();
+ if ( fkeyRdr )
+ LoadFkeys( fkeyRdr->SmartCast<FdoSmPhReader>(), false );
+void FdoSmPhDbObject::LoadFkeys( FdoSmPhReaderP fkeyRdr, bool isSkipAdd )
+ FdoStringP nextFkey;
+ FdoSmPhFkeyP fkey;
+ // Read each foreign key and column
+ while ( fkeyRdr->ReadNext() ) {
+ nextFkey = fkeyRdr->GetString(L"",L"constraint_name");
+ if ( !fkey || (nextFkey != fkey->GetName()) ) {
+ // hit the next foreign key. Create an object for it
+ fkey = NewFkey(
+ nextFkey,
+ fkeyRdr->GetString(L"", "r_table_name"),
+ fkeyRdr->GetString(L"", "r_owner_name"),
+ FdoSchemaElementState_Unchanged
+ if( fkey && ! isSkipAdd )
+ mFkeysUp->Add(fkey);
+ // Add the column to the foreign key
+ FdoStringP columnName = fkeyRdr->GetString(L"",L"column_name");
+ FdoSmPhColumnP column = GetColumns()->FindItem(columnName);
+ if ( fkey && column ) {
+ fkey->AddFkeyColumn(
+ column,
+ fkeyRdr->GetString(L"", "r_column_name")
+ else {
+ // Foreign Key column must be in this table.
+ AddFkeyColumnError( columnName );
+FdoPtr<FdoSmPhTableComponentReader> FdoSmPhDbObject::NewTableBaseReader( FdoSmPhRdBaseObjectReaderP rdr )
+ GetName(),
+ L"",
+ L"name",
FdoSmPhColumnP FdoSmPhDbObject::NewColumn(
@@ -826,6 +1350,68 @@
+FdoSmPhBaseObjectP FdoSmPhDbObject::NewBaseObject(
+ return NewBaseObject(
+ baseObjRdr->GetString(L"",L"base_name"),
+ baseObjRdr->GetString(L"",L"base_owner"),
+ baseObjRdr->GetString(L"",L"base_database")
+ FdoStringP name,
+ return new FdoSmPhBaseObject( name, FDO_SAFE_ADDREF(this), ownerName, databaseName );
+ return new FdoSmPhBaseObject( dbObject, FDO_SAFE_ADDREF(this));
+FdoStringP FdoSmPhDbObject::GenPkeyName()
+ if ( mPkeyName == L"" ) {
+ FdoSmPhOwner* pOwner = dynamic_cast<FdoSmPhOwner*>((FdoSmPhSchemaElement*) GetParent());
+ mPkeyName = pOwner->UniqueDbObjectName( FdoStringP(L"PK_") + FdoStringP(GetName()) ).Replace(L".",L"_");
+ return mPkeyName;
+FdoSmPhFkeyP FdoSmPhDbObject::NewFkey(
+ FdoStringP name,
+ return (FdoSmPhFkey*) NULL;
+FdoPtr<FdoSmPhRdBaseObjectReader> FdoSmPhDbObject::CreateBaseObjectReader() const
+ return (FdoSmPhRdBaseObjectReader*) NULL;
+FdoPtr<FdoSmPhRdPkeyReader> FdoSmPhDbObject::CreatePkeyReader() const
+ return (FdoSmPhRdPkeyReader*) NULL;
+FdoPtr<FdoSmPhRdFkeyReader> FdoSmPhDbObject::CreateFkeyReader() const
+ return (FdoSmPhRdFkeyReader*) NULL;
void FdoSmPhDbObject::UpdRollbackCache()
GetManager()->AddRollbackTable( GetQName(), GetCommitState() );
@@ -836,45 +1422,104 @@
((FdoSmPhOwner*) GetParent())->DiscardDbObject( this );
-void FdoSmPhDbObject::AddReferenceLoopError(void)
+void FdoSmPhDbObject::AddPkeyColumnError(FdoStringP columnName)
- mpErrors->Add( FdoRdbmsSmErrorType_Other,
- FdoStringP(
- NlsMsgGet1(
- FDORDBMS_215,
- "Tried to finalize table %1$ls when already finalizing",
- GetName()
+ GetErrors()->Add( FdoSmErrorType_Other,
+ FdoSchemaException::Create(
+ FDO_NLSID(FDOSM_217),
+bool FdoSmPhDbObject::CheckRootObjectLoop( FdoInt32& level )
+ bool ok = true;
-void FdoSmPhDbObject::AddPkeyColumnError(FdoStringP columnName)
+ // When there are 100 or levels of object dependencies, there is likely something wrong.
+ // Check for a dependency loop in this case. This is done by counting the total number
+ // of DbObjects currently in the cache. If there are fewer objects than dependency levels
+ // we must have visited an object more than once, meaning that there is a dependency loop.
+ if ( (level % 100) == 0 ) {
+ FdoInt32 totalObjectCount = 0;
+ FdoInt32 ixD = 0;
+ // Count objects for each database
+ for ( ixD = 0; ; ixD++ ) {
+ FdoSmPhDatabaseP database = GetManager()->GetCachedDatabase( ixD );
+ if ( database == NULL )
+ break;
+ FdoInt32 ixO;
+ // Count objects for each owner within database
+ for ( ixO = 0; ; ixO++ ) {
+ FdoSmPhOwnerP owner = database->GetCachedOwner( ixO );
+ if ( owner == NULL )
+ break;
+ FdoInt32 ixB;
+ // Count each object for each owner.
+ for ( ixB = 0; ; ixB++ ) {
+ FdoSmPhDbObjectP dbObject = owner->GetCachedDbObject( ixB );
+ if ( dbObject == NULL )
+ break;
+ totalObjectCount++;
+ // Add 1 to be on the safe side.
+ if ( level > (totalObjectCount + 1) ) {
+ ok = false;
+ level++;
+ return ok;
+void FdoSmPhDbObject::AddFkeyColumnError(FdoStringP columnName)
- FdoStringP(
- NlsMsgGet2(
- FDORDBMS_217,
- "Primary Key column %1$ls is not a column in table %2$ls",
+ FDO_NLSID(FDOSM_2),
- GetName()
-void FdoSmPhDbObject::AddNotNullColError(FdoStringP columnName)
+void FdoSmPhDbObject::AddCreateFkeyError(FdoStringP fkeyName)
+ FDO_NLSID(FDOSM_30),
+ (FdoString*) fkeyName,
+void FdoSmPhDbObject::AddReferenceLoopError(void)
FdoStringP(
- NlsMsgGet2(
- FDORDBMS_218,
- "Table %1$ls has rows; cannot add non nullable column %2$ls to it",
- GetName(),
- (FdoString*) columnName
+ NlsMsgGet1(
+ FDORDBMS_215,
+ "Tried to finalize table %1$ls when already finalizing",
+ GetName()
Modified: branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Makefile.am
--- branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Makefile.am 2007-02-13 22:45:07 UTC (rev 769)
+++ branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Makefile.am 2007-02-13 23:25:40 UTC (rev 770)
@@ -24,6 +24,7 @@
libSmPhysical_la_SOURCES = \
AssociationReader.cpp \
AssociationWriter.cpp \
+ BaseObject.cpp \
CharacterSet.cpp \
ClassPropertyReader.cpp \
ClassPropertySADReader.cpp \
Modified: branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Mgr.cpp
--- branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Mgr.cpp 2007-02-13 22:45:07 UTC (rev 769)
+++ branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Mgr.cpp 2007-02-13 23:25:40 UTC (rev 770)
@@ -208,6 +208,16 @@
return(pDatabase);
+FdoSmPhDatabaseP FdoSmPhMgr::GetCachedDatabase(FdoInt32 idx)
+ FdoSmPhDatabaseP database;
+ if ( mDatabases && (idx >= 0) && (idx < mDatabases->GetCount()) )
+ database = mDatabases->GetItem( idx );
+ return database;
FdoSmPhOwnerP FdoSmPhMgr::FindOwner(FdoStringP ownerName, FdoStringP database, bool caseSensitive)
FdoSmPhDatabaseP pDatabase = FindDatabase(database, caseSensitive);
Modified: branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Owner.cpp
--- branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Owner.cpp 2007-02-13 22:45:07 UTC (rev 769)
+++ branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Owner.cpp 2007-02-13 23:25:40 UTC (rev 770)
@@ -23,6 +23,7 @@
#include <Sm/Ph/Rd/DbObjectReader.h>
#include <Sm/Ph/Rd/CoordSysReader.h>
#include <Sm/Ph/Rd/ConstraintReader.h>
@@ -235,6 +236,17 @@
return(pDbObject);
+FdoSmPhDbObjectP FdoSmPhOwner::GetCachedDbObject(FdoInt32 idx)
+ FdoSmPhDbObjectP dbObject;
+ FdoSmPhDbObjectsP dbObjects = GetDbObjects();
+ if ( (idx >= 0) && (idx < dbObjects->GetCount()) )
+ dbObject = dbObjects->GetItem( idx );
+ return dbObject;
FdoSmPhSpatialContextsP FdoSmPhOwner::GetSpatialContexts()
LoadSpatialContexts();
@@ -356,6 +368,11 @@
return (FdoSmPhRdColumnReader*) NULL;
+FdoPtr<FdoSmPhRdBaseObjectReader> FdoSmPhOwner::CreateBaseObjectReader() const
FdoPtr<FdoSmPhRdSpatialContextReader> FdoSmPhOwner::CreateRdSpatialContextReader()
return new FdoSmPhRdSpatialContextReader(FDO_SAFE_ADDREF(this) );
@@ -423,6 +440,7 @@
FdoSmPhRdDbObjectReaderP objReader;
FdoSmPhRdColumnReaderP columnReader;
+ FdoSmPhRdBaseObjectReaderP baseObjectReader;
FdoSmPhRdConstraintReaderP ukeyReader;
FdoSmPhRdConstraintReaderP ckeyReader;
FdoSmPhRdFkeyReaderP fkeyReader;
@@ -440,6 +458,7 @@
// Doing a single query per owner for each component is more efficient than
// a query per dbObject.
columnReader = CreateColumnReader();
+ baseObjectReader = CreateBaseObjectReader();
ukeyReader = CreateConstraintReader( L"", L"U" );
ckeyReader = CreateConstraintReader( L"", L"C" );
fkeyReader = CreateFkeyReader();
@@ -456,6 +475,15 @@
if ( columnReader )
dbObject->CacheColumns( columnReader );
+ if ( baseObjectReader )
+ dbObject->CacheBaseObjects( baseObjectReader );
+ if ( fkeyReader )
+ dbObject->CacheFkeys( fkeyReader );
+ if ( pkeyReader )
+ dbObject->CachePkeys( pkeyReader );
// Load the components into the db object.
FdoSmPhTableP table = dbObject->SmartCast<FdoSmPhTable>();
@@ -466,14 +494,8 @@
if ( ckeyReader )
table->CacheCkeys( ckeyReader );
- if ( fkeyReader )
- table->CacheFkeys( fkeyReader );
if ( indexReader )
table->CacheIndexes( indexReader );
- if ( pkeyReader )
- table->CachePkeys( pkeyReader );
@@ -642,10 +664,8 @@
if ( mDbObjects ) {
for ( i = (mDbObjects->GetCount() - 1); i >= 0; i-- ) {
- // Only tables have foreign keys.
- FdoSmPhTableP table = mDbObjects->GetItem(i)->SmartCast<FdoSmPhTable>(true);
- if ( table )
- table->CommitFkeys( isBeforeParent );
+ FdoSmPhDbObjectP dbObject = mDbObjects->GetItem(i);
+ dbObject->CommitFkeys( isBeforeParent );
Added: branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Rd/BaseObjectReader.cpp
--- branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Rd/BaseObjectReader.cpp (rev 0)
+++ branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Rd/BaseObjectReader.cpp 2007-02-13 23:25:40 UTC (rev 770)
@@ -0,0 +1,81 @@
+ * Copyright (C) 2004-2006 Autodesk, Inc.
+ * This library is free software; you can redistribute it and/or
+ * modify it under the terms of version 2.1 of the GNU Lesser
+ * General Public License as published by the Free Software Foundation.
+ * This library is distributed in the hope that it will be useful,
+ * but WITHOUT ANY WARRANTY; without even the implied warranty of
+ * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+ * Lesser General Public License for more details.
+ * You should have received a copy of the GNU Lesser General Public
+ * License along with this library; if not, write to the Free Software
+ * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
+FdoSmPhRdBaseObjectReader::FdoSmPhRdBaseObjectReader(
+ FdoSmPhReader(reader),
+ mOwner(owner)
+FdoSmPhRdBaseObjectReader::~FdoSmPhRdBaseObjectReader(void)
+FdoSmPhRowsP FdoSmPhRdBaseObjectReader::MakeRows( FdoSmPhMgrP mgr)
+ FdoSmPhRowsP rows = new FdoSmPhRowCollection();
+ // Single row, no joins
+ FdoSmPhRowP row = new FdoSmPhRow(mgr, L"BaseObjectFields");
+ rows->Add(row);
+ // Each field adds itself to the row.
+ FdoSmPhFieldP pField = new FdoSmPhField(
+ row,
+ L"name",
+ row->CreateColumnDbObject(L"name",false)
+ pField = new FdoSmPhField(
+ row,
+ L"base_name",
+ row->CreateColumnDbObject(L"base_name",false)
+ row,
+ L"base_owner",
+ row->CreateColumnDbObject(L"base_owner",false)
+ row,
+ L"base_database",
+ row->CreateColumnDbObject(L"base_database",true)
+ return( rows);
Modified: branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Rd/ClassReader.cpp
--- branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Rd/ClassReader.cpp 2007-02-13 22:45:07 UTC (rev 769)
+++ branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Rd/ClassReader.cpp 2007-02-13 23:25:40 UTC (rev 770)
@@ -44,13 +44,13 @@
FdoSmPhMgrP mgr,
- FdoBoolean keyedOnly,
+ FdoBoolean classifyDefaultTypes,
FdoStringP owner
FdoSmPhReader(mgr, froms),
- mKeyedOnly(keyedOnly),
+ mClassifyDefaultTypes(classifyDefaultTypes),
m_IsGeometryFromOrdinatesWanted(mgr->IsGeometryFromOrdinatesWanted()),
mSchemaName(schemaName),
mCurrDbObject(-1)
@@ -114,13 +114,11 @@
// Get the current object and determine whether table or view
FdoSmPhDbObjectP pObject = mDbObjects->GetItem( mCurrDbObject );
objectName = pObject->GetName();
- FdoSmPhTableP pTable = pObject->SmartCast<FdoSmPhTable>();
- FdoSmPhViewP pView = pObject->SmartCast<FdoSmPhView>();
// Only classification of tables or views is supported
- if ( pTable || pView ) {
+ if ( ClassifyObjectType(pObject, mClassifyDefaultTypes) ) {
// Check if class can be generated from this table or view.
- classifiedObjectName = ClassifyObject( objectName, pTable ? FdoSmPhDbObjType_Table : FdoSmPhDbObjType_View );
+ classifiedObjectName = ClassifyObject( pObject );
if ( classifiedObjectName.GetLength() > 0 ) {
found = true;
@@ -201,35 +199,26 @@
return(!IsEOF());
-FdoStringP FdoSmPhRdClassReader::ClassifyObject( FdoStringP objectName, FdoSmPhDbObjType objectType )
+bool FdoSmPhRdClassReader::ClassifyObjectType( FdoSmPhDbObjectP dbObject, FdoBoolean classifyDefaultTypes )
- FdoStringP classifiedObjectName = objectName;
- bool hasKey = false;
+ FdoSmPhTableP pTable = dbObject->SmartCast<FdoSmPhTable>();
+ FdoSmPhViewP pView = dbObject->SmartCast<FdoSmPhView>();
- if ( (classifiedObjectName.GetLength() > 0) &&
- (objectType == FdoSmPhDbObjType_Table)
- FdoSmPhDbObjectP dbObject;
+ return ( pTable || pView );
- dbObject = mOwner->FindDbObject( classifiedObjectName );
+FdoStringP FdoSmPhRdClassReader::ClassifyObject( FdoSmPhDbObjectP dbObject )
+ FdoStringP classifiedObjectName = dbObject->GetName();
+ bool hasKey = false;
- if ( dbObject ) {
- if ( (mSchemaName == L"") || (dbObject->GetBestSchemaName() == mSchemaName) ) {
- // Find out if the table has a key.
- FdoSmPhTable* pTable = dbObject ? dynamic_cast<FdoSmPhTable*>((FdoSmPhDbObject*) dbObject) : NULL;
- if ( pTable ) {
- hasKey = (pTable->GetBestIdentity() != NULL);
- else {
- // DbObject is for a different feature schema.
- classifiedObjectName = L"";
+ if ( classifiedObjectName.GetLength() > 0 ) {
+ if ( (mSchemaName == L"") || (dbObject->GetBestSchemaName() == mSchemaName) ) {
+ // Find out if the database object has a key.
+ hasKey = (dbObject->GetBestIdentity() != NULL);
else {
- // DbObject can't be found, skip it.
- // This can happen in the Oracle Provider for a number of
- // tables named 'bin$...'. These definitely need to be skipped.
+ // DbObject is for a different feature schema.
@@ -239,7 +228,7 @@
// Classify only if the object is a table or we were asked to
// include any objects.
// TODO: change the name of mKeyedOnly to reflect its new purpose.
- return ( (!mKeyedOnly) || (objectType == FdoSmPhDbObjType_Table)) ? classifiedObjectName : FdoStringP(L"");
+ return classifiedObjectName;
FdoStringP FdoSmPhRdClassReader::FindGeometryProperty( FdoSmPhColumnsP cols, bool& hasGeom )
@@ -304,3 +293,9 @@
return geomPropName;
+// This function is now obsolete; override or extend ClassifyObject( FdoSmPhDbObjectP ) instead.
+FdoStringP FdoSmPhRdClassReader::ClassifyObject( FdoStringP objectName, FdoSmPhDbObjType objectType )
+ throw FdoException::Create( L"Internal error, obsolete function FdoSmPhRdClassReader::ClassifyObject( FdoStringP , FdoSmPhDbObjType ) should never be called" );
Modified: branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Rd/Makefile.am
--- branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Rd/Makefile.am 2007-02-13 22:45:07 UTC (rev 769)
+++ branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Rd/Makefile.am 2007-02-13 23:25:40 UTC (rev 770)
@@ -21,6 +21,7 @@
libSmPhRd_la_SOURCES = \
+ BaseObjectReader.cpp \
CharacterSetReader.cpp \
ClassReader.cpp \
CollationReader.cpp \
Modified: branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Rd/PropertyReader.cpp
--- branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Rd/PropertyReader.cpp 2007-02-13 22:45:07 UTC (rev 769)
+++ branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Rd/PropertyReader.cpp 2007-02-13 23:25:40 UTC (rev 770)
@@ -43,7 +43,6 @@
mFieldIdx(-1),
mFkeyIdx(-1),
mDbObject(dbObject),
- mpTable(NULL),
mFkeyCount(0)
@@ -54,11 +53,8 @@
SetEOF(true);
else {
- // Count the number of foreign keys in the database object. Only
- // tables have foreign keys.
- mpTable = dynamic_cast<FdoSmPhTable*>((FdoSmPhDbObject*) mDbObject);
- if ( mpTable )
- mFkeyCount = mpTable->RefFkeysUp()->GetCount();
+ // Count the number of foreign keys in the database object.
+ mFkeyCount = mDbObject->RefFkeysUp()->GetCount();
// Determine the identity properties (columns)
ResolveIdentity();
@@ -165,7 +161,7 @@
// No more columns; get the next foreign key, and turn it into
// an association property.
- FdoSmPhFkeysP pFkeys = mpTable->GetFkeysUp();
+ FdoSmPhFkeysP pFkeys = mDbObject->GetFkeysUp();
FdoSmPhFkeyP pFkey = pFkeys->GetItem(mFkeyIdx);
const FdoSmPhTable* pPkeyTable = pFkey->RefPkeyTable();
@@ -252,10 +248,7 @@
void FdoSmPhRdPropertyReader::ResolveIdentity()
- mIdCols = NULL;
- if ( mpTable )
- mIdCols = mpTable->GetBestIdentity();
+ mIdCols = mDbObject->GetBestIdentity();
FdoStringP FdoSmPhRdPropertyReader::GetIdPosn( FdoStringP colName )
@@ -280,20 +273,18 @@
FdoStringP colName = column->GetName();
int idx;
- if ( mpTable ) {
- // Special case: do not weed out identity columns. Data properties need to
- // be generated for them.
- if ( FdoSmPhColumnP(FdoSmPhColumnsP(mpTable->GetPkeyColumns())->FindItem( colName )) )
- return false;
+ // Special case: do not weed out identity columns. Data properties need to
+ // be generated for them.
+ if ( FdoSmPhColumnP(FdoSmPhColumnsP(mDbObject->GetPkeyColumns())->FindItem( colName )) )
+ return false;
- // Check if the column is in a foreign key.
- for ( idx = 0; idx < pFkeys->GetCount(); idx++ ) {
- FdoSmPhFkeyP fkey = pFkeys->GetItem(idx);
- FdoSmPhColumnsP columns = fkey->GetFkeyColumns();
- if ( FdoSmPhColumnP(columns->FindItem(colName)) )
- return true;
+ // Check if the column is in a foreign key.
+ for ( idx = 0; idx < pFkeys->GetCount(); idx++ ) {
+ FdoSmPhFkeyP fkey = pFkeys->GetItem(idx);
+ FdoSmPhColumnsP columns = fkey->GetFkeyColumns();
+ if ( FdoSmPhColumnP(columns->FindItem(colName)) )
+ return true;
return false;
Modified: branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Table.cpp
--- branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Table.cpp 2007-02-13 22:45:07 UTC (rev 769)
+++ branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/Table.cpp 2007-02-13 23:25:40 UTC (rev 770)
@@ -20,8 +20,6 @@
#include <Sm/Ph/Table.h>
-#include <Sm/Ph/Rd/PkeyReader.h>
-#include <Sm/Ph/Rd/FkeyReader.h>
#include <Sm/Ph/Rd/IndexReader.h>
@@ -37,7 +35,7 @@
if ( !GetExists() )
// Use given primary key name for new tables.
- mPkeyName = pkeyName;
+ SetPkeyName(pkeyName);
mDeletedConstraints = FdoStringCollection::Create();
@@ -51,20 +49,6 @@
return true;
-const FdoSmPhColumnCollection* FdoSmPhTable::RefPkeyColumns() const
- FdoSmPhColumnsP columns = ((FdoSmPhTable*) this)->GetPkeyColumns();
- return (FdoSmPhColumnCollection*) columns;
-FdoSmPhColumnsP FdoSmPhTable::GetPkeyColumns()
- LoadPkeys();
- return mPkeyColumns;
const FdoSmPhBatchColumnCollection* FdoSmPhTable::RefUkeyColumns() const
FdoSmPhBatchColumnsP columnsColl = ((FdoSmPhTable*) this)->GetUkeyColumns();
@@ -105,81 +89,65 @@
return mIndexes;
-FdoSmPhColumnsP FdoSmPhTable::GetBestIdentity()
+FdoSmPhColumnsP FdoSmPhTable::GetBestIdentity( FdoSmPhDbObjectP dbObject )
int idx = 0;
long ixSize = (FdoSmPhIndex::mMaxWeight * 2);
long bestIxSize = (FdoSmPhIndex::mMaxWeight * 2);
- FdoSmPhColumnsP pkeyCols = GetPkeyColumns();
FdoSmPhIndexP bestIndex;
- // Choose primary key if present
- if ( pkeyCols->GetCount() > 0 ) {
- return pkeyCols;
+ FdoSmPhColumnsP bestIdentity = FdoSmPhDbObject::GetBestIdentity( dbObject );
- // No primary key, use best unique index.
- FdoSmPhIndexesP indexes = GetIndexes();
+ if ( bestIdentity == NULL ) {
- for ( idx = 0; idx < indexes->GetCount(); idx++ ) {
- FdoSmPhIndexP index = indexes->GetItem(idx);
+ // No primary key, use best unique index.
+ FdoSmPhIndexesP indexes = GetIndexes();
- // Calculate index compactness score.
- ixSize = index->GetWeight();
+ for ( idx = 0; idx < indexes->GetCount(); idx++ ) {
+ FdoSmPhIndexP index = indexes->GetItem(idx);
+ FdoSmPhColumnsP idxCols = index->GetColumns();
- // Weed out non-unique indexes or indexes whose columns are too big.
- if ( index->GetIsUnique() && (index->RefColumns()->GetCount() > 0) && (ixSize < FdoSmPhIndex::mMaxWeight) ) {
- if ( bestIndex ) {
- // Index already chosen, see if this one is better.
- FdoSmPhColumnsP idxCols = index->GetColumns();
- if (idxCols->GetCount() < bestIndex->RefColumns()->GetCount() ) {
- // This one has few columns, take it instead.
- bestIndex = index;
- bestIxSize = ixSize;
- else if ( idxCols->GetCount() == bestIndex->RefColumns()->GetCount() ) {
- // same number of columns, take this index only if it has a better
- // compactness score.
- if ( ixSize < bestIxSize ) {
+ // Weed out non-unique indexes or indexes with no columns
+ if ( index->GetIsUnique() && (index->RefColumns()->GetCount() > 0) ) {
+ // Calculate index compactness score.
+ ixSize = index->GetWeight();
+ // Weed out indexes whose columns are too big.
+ // If a database object was specified, skip indexes whose columns
+ // are not all present on the database object.
+ if ( (ixSize < FdoSmPhIndex::mMaxWeight) && ((!dbObject) || dbObject->HasColumns(idxCols)) ) {
+ if ( bestIndex ) {
+ // Index already chosen, see if this one is better.
+ if (idxCols->GetCount() < bestIndex->RefColumns()->GetCount() ) {
+ // This one has few columns, take it instead.
+ bestIndex = index;
+ bestIxSize = ixSize;
+ else if ( idxCols->GetCount() == bestIndex->RefColumns()->GetCount() ) {
+ // same number of columns, take this index only if it has a better
+ // compactness score.
+ if ( ixSize < bestIxSize ) {
+ else {
+ // No index chosen yet, chose this one initially.
bestIndex = index;
- else {
- // No index chosen yet, chose this one initially.
+ if ( bestIndex )
+ bestIdentity = bestIndex->GetColumns();
- if ( bestIndex )
- return bestIndex->GetColumns();
- return (FdoSmPhColumnCollection*) NULL;
-const FdoSmPhFkeyCollection* FdoSmPhTable::RefFkeysUp() const
- return (FdoSmPhFkeyCollection*) ((FdoSmPhTable*) this)->GetFkeysUp();
-FdoSmPhFkeysP FdoSmPhTable::GetFkeysUp()
- LoadFkeys();
- return mFkeysUp;
-FdoStringP FdoSmPhTable::GetPkeyName() const
- ((FdoSmPhTable*) this)->GetPkeyColumns();
- return mPkeyName;
const FdoLockType* FdoSmPhTable::GetLockTypes(FdoInt32& size) const
FdoSmPhOwner* pOwner = static_cast<FdoSmPhOwner*>((FdoSmPhSchemaElement*) GetParent());
@@ -188,41 +156,6 @@
return pOwner->GetLockTypes( GetLockingMode(), size );
-void FdoSmPhTable::SetPkeyName( FdoStringP pkeyName )
- if ( GetElementState() != FdoSchemaElementState_Added )
- throw FdoSchemaException::Create(
- FdoSmError::NLSGetMessage(
- FDO_NLSID(FDOSM_20),
- (FdoString*) GetQName()
-FdoBoolean FdoSmPhTable::IsUkeyPkey( FdoSmPhColumnsP ukeyColumns )
- FdoBoolean isUkeyPkey = false;
- FdoInt32 idx;
- FdoSmPhColumnsP pkeyColumns = GetPkeyColumns();
- if ( (ukeyColumns->GetCount() > 0) && (ukeyColumns->GetCount() == pkeyColumns->GetCount()) ) {
- isUkeyPkey = true;
- for ( idx = 0; idx < ukeyColumns->GetCount(); idx++ ) {
- FdoSmPhColumnP ukeyColumn = ukeyColumns->GetItem( idx );
- if ( pkeyColumns->IndexOf(ukeyColumn->GetName()) < 0 ) {
- isUkeyPkey = false;
- break;
- return isUkeyPkey;
void FdoSmPhTable::SetLtMode( FdoLtLockModeType mode )
if ( (mode != GetLtMode()) && (GetElementState() != FdoSchemaElementState_Added) ) {
@@ -251,24 +184,6 @@
FdoSmPhDbObject::SetLockingMode( mode );
-void FdoSmPhTable::AddPkeyCol(FdoStringP columnName )
- LoadPkeys();
- FdoSmPhColumnP column = GetColumns()->FindItem( columnName );
- if ( column )
- mPkeyColumns->Add( column );
- else
- FDO_NLSID(FDOSM_213),
- (FdoString*) columnName,
- GetName()
void FdoSmPhTable::AddUkeyCol(int uCollNum, FdoStringP columnName )
LoadUkeys();
@@ -309,42 +224,12 @@
return index;
-FdoSmPhFkeyP FdoSmPhTable::CreateFkey(
- FdoStringP name,
- FdoStringP lTableOwner = pkeyTableOwner;
- if ( lTableOwner == L"" )
- lTableOwner = GetParent()->GetName();
- FdoSmPhFkeyP fkey = NewFkey( name, pkeyTableName, lTableOwner );
- FdoSmPhFkeysP fkeys = GetFkeysUp();
- fkeys->Add( fkey );
- return fkey;
void FdoSmPhTable::DiscardIndex( FdoSmPhIndex* index )
indexes->Remove( index );
-void FdoSmPhTable::CommitFkeys( bool isBeforeParent )
- FdoInt32 i;
- FdoStringsP fkeyClauses = FdoStringCollection::Create();
- for ( i = (fkeys->GetCount() - 1); i >= 0; i-- ) {
- FdoSmPhFkeyP(fkeys->GetItem(i))->Commit(true, isBeforeParent);
void FdoSmPhTable::SetElementState(FdoSchemaElementState elementState)
// Error if try to drop a table that has rows.
@@ -362,19 +247,6 @@
-void FdoSmPhTable::ForceDelete()
- FdoInt32 i;
- FdoSmPhSchemaElement::SetElementState( FdoSchemaElementState_Deleted );
- // Must explicitly delete any foreign keys when table is deleted.
- for ( i = 0; i < fkeys->GetCount(); i++ ) {
- FdoSmPhFkeyP(fkeys->GetItem(i))->SetElementState(FdoSchemaElementState_Deleted);
void FdoSmPhTable::CacheUkeys( FdoSmPhRdConstraintReaderP rdr )
// Do nothing if unique constraints already loaded
@@ -399,18 +271,6 @@
LoadCkeys( NewTableCkeyReader(rdr)->SmartCast<FdoSmPhReader>(), true );
-void FdoSmPhTable::CacheFkeys( FdoSmPhRdFkeyReaderP rdr )
- // Do nothing if foreign keys already loaded.
- if ( !mFkeysUp ) {
- mFkeysUp = new FdoSmPhFkeyCollection();
- LoadFkeys( NewTableFkeyReader(rdr)->SmartCast<FdoSmPhReader>(), false );
- else
- LoadFkeys( NewTableFkeyReader(rdr)->SmartCast<FdoSmPhReader>(), true );
void FdoSmPhTable::CacheIndexes( FdoSmPhRdIndexReaderP rdr )
// Do nothing if indexes already loaded
@@ -423,18 +283,6 @@
LoadIndexes( NewTableIndexReader(rdr), true );
-void FdoSmPhTable::CachePkeys( FdoSmPhRdPkeyReaderP rdr )
- // Do nothing if primary key already loaded
- if ( !mPkeyColumns ) {
- mPkeyColumns = new FdoSmPhColumnCollection();
- LoadPkeys( NewTablePkeyReader(rdr)->SmartCast<FdoSmPhReader>(), false );
- else
- LoadPkeys( NewTablePkeyReader(rdr)->SmartCast<FdoSmPhReader>(), true );
FdoSchemaExceptionP FdoSmPhTable::Errors2Exception(FdoSchemaException* pFirstException ) const
FdoInt32 i;
@@ -458,13 +306,6 @@
pException = mIndexes->RefItem(i)->Errors2Exception(pException);
- if ( mFkeysUp ) {
- // Add errors for the table's columns.
- for ( i = 0; i < mFkeysUp->GetCount(); i++ )
- pException = mFkeysUp->RefItem(i)->Errors2Exception(pException);
if ( (GetElementState() == FdoSchemaElementState_Unchanged) ||
(GetElementState() == FdoSchemaElementState_Modified)
@@ -787,27 +628,6 @@
-FdoStringP FdoSmPhTable::GetAddPkeySql()
- FdoStringP pkeySql;
- bool ansiQuotes = GetManager()->SupportsAnsiQuotes();
- if ( pkeyColumns->GetCount() > 0 ) {
- FdoStringsP pkColNames = GetKeyColsSql( pkeyColumns );
- pkeySql = FdoStringP::Format(
- L"constraint %ls%ls%ls primary key ( %ls )",
- ansiQuotes ? L"\"" : L"",
- (FdoString*) this->GenPkeyName(),
- (FdoString*) pkColNames->ToString()
- return pkeySql;
FdoStringP FdoSmPhTable::GetAddUkeysSql()
FdoSmPhBatchColumnsP ukeyColumnsColl = GetUkeyColumns();
@@ -896,52 +716,6 @@
return constraintName;
-FdoStringP FdoSmPhTable::GenPkeyName()
- if ( mPkeyName == L"" ) {
- FdoSmPhOwner* pOwner = dynamic_cast<FdoSmPhOwner*>((FdoSmPhSchemaElement*) GetParent());
- mPkeyName = pOwner->UniqueDbObjectName( FdoStringP(L"PK_") + FdoStringP(GetName()) ).Replace(L".",L"_");
- return mPkeyName;
-void FdoSmPhTable::LoadPkeys(void)
- // Skip load if new table.
- if ( GetElementState() != FdoSchemaElementState_Added ) {
- FdoPtr<FdoSmPhRdPkeyReader> pkeyRdr = CreatePkeyReader();
- LoadPkeys( pkeyRdr->SmartCast<FdoSmPhReader>(), false );
-void FdoSmPhTable::LoadPkeys( FdoSmPhReaderP pkeyRdr, bool isSkipAdd )
- // read each primary key column.
- while (pkeyRdr->ReadNext() ) {
- mPkeyName = pkeyRdr->GetString(L"", L"constraint_name");
- FdoStringP columnName = pkeyRdr->GetString(L"",L"column_name");
- FdoSmPhColumnP pkeyColumn = GetColumns()->FindItem( columnName );
- if ( pkeyColumn == NULL ) {
- // Primary Key column must be in this table.
- if ( GetElementState() != FdoSchemaElementState_Deleted )
- AddPkeyColumnError( columnName );
- else if( ! isSkipAdd ) {
- mPkeyColumns->Add(pkeyColumn);
void FdoSmPhTable::LoadUkeys()
@@ -1074,61 +848,6 @@
-void FdoSmPhTable::LoadFkeys(void)
- // Do nothing if already loaded
- // Skip load for new tables
- FdoPtr<FdoSmPhRdFkeyReader> fkeyRdr = CreateFkeyReader();
- LoadFkeys( fkeyRdr->SmartCast<FdoSmPhReader>(), false );
-void FdoSmPhTable::LoadFkeys( FdoSmPhReaderP fkeyRdr, bool isSkipAdd )
- FdoStringP nextFkey;
- FdoSmPhFkeyP fkey;
- // Read each foreign key and column
- while ( fkeyRdr->ReadNext() ) {
- nextFkey = fkeyRdr->GetString(L"",L"constraint_name");
- if ( !fkey || (nextFkey != fkey->GetName()) ) {
- // hit the next foreign key. Create an object for it
- fkey = NewFkey(
- nextFkey,
- fkeyRdr->GetString(L"", "r_table_name"),
- fkeyRdr->GetString(L"", "r_owner_name"),
- FdoSchemaElementState_Unchanged
- if( ! isSkipAdd )
- mFkeysUp->Add(fkey);
- // Add the column to the foreign key
- FdoStringP columnName = fkeyRdr->GetString(L"",L"column_name");
- FdoSmPhColumnP column = GetColumns()->FindItem(columnName);
- if ( column ) {
- fkey->AddFkeyColumn(
- column,
- fkeyRdr->GetString(L"", "r_column_name")
- else {
- // Foreign Key column must be in this table.
- AddFkeyColumnError( columnName );
void FdoSmPhTable::LoadIndexes(void)
@@ -1196,16 +915,6 @@
-FdoPtr<FdoSmPhTableComponentReader> FdoSmPhTable::NewTableFkeyReader( FdoSmPhRdFkeyReaderP rdr )
- return new FdoSmPhTableComponentReader(
- GetName(),
- L"",
- L"table_name",
- rdr->SmartCast<FdoSmPhReader>()
FdoPtr<FdoSmPhTableIndexReader> FdoSmPhTable::NewTableIndexReader( FdoSmPhRdIndexReaderP rdr )
return new FdoSmPhTableIndexReader(
@@ -1214,16 +923,6 @@
-FdoPtr<FdoSmPhTableComponentReader> FdoSmPhTable::NewTablePkeyReader( FdoSmPhRdPkeyReaderP rdr )
- GetName(),
- L"",
- L"table_name",
FdoSmPhIndexP FdoSmPhTable::CreateIndex(
@@ -1251,19 +950,6 @@
return index;
-void FdoSmPhTable::AddPkeyColumnError(FdoStringP columnName)
- GetErrors()->Add( FdoSmErrorType_Other,
- FdoSchemaException::Create(
- FDO_NLSID(FDOSM_217),
void FdoSmPhTable::AddUkeyColumnError(FdoStringP columnName)
@@ -1290,18 +976,6 @@
-void FdoSmPhTable::AddFkeyColumnError(FdoStringP columnName)
- FDO_NLSID(FDOSM_2),
void FdoSmPhTable::AddIndexColumnError(FdoStringP columnName)
Modified: branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/View.cpp
--- branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/View.cpp 2007-02-13 22:45:07 UTC (rev 769)
+++ branches/3.2.x/Utilities/SchemaMgr/Src/Sm/Ph/View.cpp 2007-02-13 23:25:40 UTC (rev 770)
@@ -28,48 +28,21 @@
const FdoSmPhOwner* pOwner,
- FdoSmPhDbObject(viewName, pOwner, elementState ),
- mRootDatabase(rootDatabase),
- mRootOwner(rootOwner),
- mRootObjectName(rootObjectName)
+ FdoSmPhDbObject(viewName, pOwner, elementState )
+ if ( rootObjectName != L"" ) {
+ FdoSmPhBaseObjectP baseObject = NewBaseObject( rootObjectName, rootOwner, rootDatabase );
+ GetBaseObjects()->Add( baseObject );
FdoSmPhView::~FdoSmPhView(void)
-const FdoSmPhDbObject* FdoSmPhView::RefRootObject() const
- FdoSmPhDbObjectP rootObject = ((FdoSmPhView*) this)->GetRootObject();
- return (FdoSmPhDbObject*) rootObject;
-FdoSmPhDbObjectP FdoSmPhView::GetRootObject()
- if ( (mRootObjectName.GetLength() > 0) && (!mRootObject) )
- mRootObject = GetManager()->FindDbObject( mRootObjectName, mRootDatabase, mRootOwner );
- return mRootObject;
-FdoSmPhDbObjectP FdoSmPhView::GetLowestRootObject()
- FdoSmPhDbObjectP rootObject = GetRootObject();
- if ( rootObject )
- rootObject = rootObject->GetLowestRootObject();
- return rootObject;
void FdoSmPhView::SetRootObject( FdoSmPhDbObjectP rootObject )
- mRootObject = rootObject;
- mRootObjectName = rootObject ? rootObject->GetName() : L"";
- mRootOwner = rootObject ? rootObject->GetParent()->GetName() : L"";
- mRootDatabase = rootObject ? rootObject->GetParent()->GetParent()->GetName() : L"";
+ FdoSmPhDbObject::SetRootObject( rootObject );
void FdoSmPhView::XMLSerialize( FILE* xmlFp, int ref ) const
@@ -118,6 +91,17 @@
+ // After view commit, just commit the columns to update their element states.
+ if ( !isBeforeParent ) {
+ FdoSmPhColumnsP columns = GetColumns();
+ for ( i = (columns->GetCount() - 1); i >= 0; i-- ) {
+ FdoSmPhColumnP column = columns->GetItem(i);
+ column->Commit( true, isBeforeParent );
FdoStringP FdoSmPhView::GetAddSql()
More information about the fdo-commits
