[fdo-commits] r135 - branches/3.2.1/Providers/ArcSDE/Docs/doc_src/group_and_page_definitions
svn_fdo at osgeo.org svn_fdo at osgeo.org
Tue Feb 13 19:38:06 EST 2007
Author: gregboone
Date: 2007-02-13 19:38:06 -0500 (Tue, 13 Feb 2007)
New Revision: 135
   branches/3.2.1/Providers/ArcSDE/Docs/doc_src/group_and_page_definitions/define_pages.h
FDO4: Update API documentation generation process
Modified: branches/3.2.1/Providers/ArcSDE/Docs/doc_src/group_and_page_definitions/define_pages.h
--- branches/3.2.1/Providers/ArcSDE/Docs/doc_src/group_and_page_definitions/define_pages.h	2007-02-13 22:42:23 UTC (rev 134)
+++ branches/3.2.1/Providers/ArcSDE/Docs/doc_src/group_and_page_definitions/define_pages.h	2007-02-14 00:38:06 UTC (rev 135)
@@ -9,25 +9,35 @@
 (that is, with an underlying, supported Oracle or SQL Server
 database).
 </p>
-<p>The FDO Provider for ArcSDE has the following characteristics:
+<p>You can connect via ArcSDE to an underlying Oracle or SQL Server database.
+You can insert, select, update, and delete feature data in existing ArcSDE
+schemas. However, you cannot create or modify an ArcSDE schema.
 </p>
-<ul>
-<li>You can connect to the FDO Provider for ArcSDE in one step if
-    you already know the name of the data store that you want to
-    use. Otherwise, you must connect in two steps.</li>
-<li>With the FDO Provider for ArcSDE, you can either lock rows in a table or
-    version a table. You cannot do both at the
-    same time. To do either one, you must first alter the table’s
-    registration.</li>
-<li>The FDO Provider for ArcSDE does not support the creation or
-    destruction of feature schema (that is,it does not support the
-    FdoIApplySchema and FdoIDestroySchema commands.) However, it
-    does support the FdoIDescribeSchema command. The FDO Provider
-    for ArcSDE is intended to operate on already existing
-    feature schemas, and it supports inserting,
-    selecting, updating, and deleting data in existing schemas.</li>
-</ul>
+<p>To work with ArcSDE, you must install ArcSDE 9.1 and a supported data source,
+such as Oracle 9<i>i</i>, in the network. The host machine running AutoCAD Map
+3D, for example, must also have the required DLLs (three dynamically linked
+libraries, sde91.dll, sg91.dll, and pe91.dll) and the PATH environment variable
+must reference the local folder containing these DLLs. To accomplish this, you
+can install an ArcGIS 9.1 Desktop application or the ArcSDE SDK. For more
+information about ArcGIS 9.1 Desktop applications and the ArcSDE SDK, refer to
+the ESRI documentation.
+</p>
+<p>Furthermore, AutoCAD Map 3D uses facilities provided by ArcSDE for long
+transaction versioning and persistent locking. (ArcSDE supports one or the
+other, but not both, on the same class). ProductName uses the standard
+ArcSDE API and ArcSDE-supported storage on both the Oracle and SQL Server
+platforms. AutoCAD Map 3D does not use FDO metadata for ArcSDE schema—it uses
+existing metadata only.
+</p>
+<p>If ArcSDE encounters curved segments, it converts them to a series of line
+segments that approximate the original arc segment (an approximation of the
+original geometry).
+</p>
 <p>
 For more information, see <i>The Essential FDO</i> (FET_TheEssentialFDO.pdf)
 and the <i>FDO Developer's Guide</i> (FDG_FDODevGuide.pdf).
More information about the fdo-commits mailing list
