[fdo-commits] r209 - branches/3.2.1/Providers/SDF/Docs/doc_src/group_and_page_definitions
svn_fdo at osgeo.org svn_fdo at osgeo.org
Tue Feb 13 19:39:52 EST 2007
Author: gregboone
Date: 2007-02-13 19:39:51 -0500 (Tue, 13 Feb 2007)
New Revision: 209
   branches/3.2.1/Providers/SDF/Docs/doc_src/group_and_page_definitions/define_pages.h
FDO4: Update API documentation generation process
Modified: branches/3.2.1/Providers/SDF/Docs/doc_src/group_and_page_definitions/define_pages.h
--- branches/3.2.1/Providers/SDF/Docs/doc_src/group_and_page_definitions/define_pages.h	2007-02-12 15:23:48 UTC (rev 208)
+++ branches/3.2.1/Providers/SDF/Docs/doc_src/group_and_page_definitions/define_pages.h	2007-02-14 00:39:51 UTC (rev 209)
@@ -7,23 +7,34 @@
 that provides access to data in a particular data store. The FDO
 Provider for SDF provides FDO with access to an SDF-based data store.
-<p>The FDO Provider for SDF uses Autodesk's spatial database
-format, which is a file-based personal geodatabase that supports
-multiple features/attributes, spatial indexing,
-interoperability, file-locking, and high performance for
+<p>The Autodesk SDF file format is a standalone, file-based spatial database
+format that supports multiple features classes and properties in a single file,
+and provides spatial indexing, interoperability, and high performance for
 large data sets.
 </p>
 <p>The SDF file format has the following characteristics:
 </p>
+<ul>
+  <li>SDF files can be read on different platforms.
+  <li>One schema in a single SDF file supports multiple feature classes.
+  <li>The SDF file has its own spatial indexing.
+  <li>SDF files can store geometric and non-geometric data with minimum overhead.
+  <li>The SDF file format supports a single writer at any time, with multiple readers.
+</ul>
+<p>An SDF schema can support the following:
+</p>
 <ul>
-  <li> SDF files can be read on different platforms.
-  <li> The SDF file format has its own spatial indexing.
-  <li> SDF files can store geometric and non-geometric data with minimum
-overhead
-  <li>Although it does not support concurrency control (locking),
-   the SDF file format is a valid alternative to RDBMS.
+  <li>Auto ID generation
+  <li>Exclusive value range constraints
+  <li>Null value constraints
+  <li>Spatial contexts
+  <li>These geometry types: point, line string, polygon, multi-point, multi-line
+  string, multi-polygon, curve string, curve polygon, multi-curve string,
+  multi-curve polygon, linear ring, line string segment, circular arc segment, and ring.
 </ul>
 <p>
 For more information, see <i>The Essential FDO</i> (FET_TheEssentialFDO.pdf)
 and the <i>FDO Developer's Guide</i> (FDG_FDODevGuide.pdf).
More information about the fdo-commits mailing list
