[fdo-commits] r2513 - trunk/Fdo/Unmanaged/Src/Common
svn_fdo at osgeo.org
Wed Feb 14 03:10:12 EST 2007
Author: warmerdam
Date: 2007-02-14 03:10:12 -0500 (Wed, 14 Feb 2007)
New Revision: 2513
trunk/Fdo/Unmanaged/Src/Common/ConvertUTF.h
use unsigned int for UTF32, not long (64bit ticket #6)
Modified: trunk/Fdo/Unmanaged/Src/Common/ConvertUTF.h
--- trunk/Fdo/Unmanaged/Src/Common/ConvertUTF.h 2007-02-14 08:06:26 UTC (rev 2512)
+++ trunk/Fdo/Unmanaged/Src/Common/ConvertUTF.h 2007-02-14 08:10:12 UTC (rev 2513)
@@ -85,7 +85,7 @@
bit mask & shift operations.
-typedef unsigned long UTF32; /* at least 32 bits */
+typedef unsigned int UTF32; /* at least 32 bits */
typedef unsigned short UTF16; /* at least 16 bits */
typedef unsigned char UTF8; /* typically 8 bits */
typedef unsigned char Boolean; /* 0 or 1 */
More information about the fdo-commits
