[fdo-commits] r133 - in branches/3.2.x/Providers/WMS/Docs/doc_src:
. headers_and_footers
svn_fdo at osgeo.org
Wed Feb 14 16:55:01 EST 2007
Author: gregboone
Date: 2007-02-14 16:55:01 -0500 (Wed, 14 Feb 2007)
New Revision: 133
Added:
branches/3.2.x/Providers/WMS/Docs/doc_src/Doxyfile_WMS_managed
branches/3.2.x/Providers/WMS/Docs/doc_src/headers_and_footers/footer_managed.html
branches/3.2.x/Providers/WMS/Docs/doc_src/headers_and_footers/header_managed.html
branches/3.2.x/Providers/WMS/Docs/doc_src/Makefile.am
branches/3.2.x/Providers/WMS/Docs/doc_src/headers_and_footers/Makefile.am
FDO4: Update API documentation generation process
Modified: branches/3.2.x/Providers/WMS/Docs/doc_src/Doxyfile_WMS
--- branches/3.2.x/Providers/WMS/Docs/doc_src/Doxyfile_WMS 2007-02-14 21:50:14 UTC (rev 132)
+++ branches/3.2.x/Providers/WMS/Docs/doc_src/Doxyfile_WMS 2007-02-14 21:55:01 UTC (rev 133)
@@ -101,7 +101,7 @@
ALPHABETICAL_INDEX = YES
COLS_IN_ALPHA_INDEX = 5
-IGNORE_PREFIX =
+IGNORE_PREFIX = Fdo
# configuration options related to the HTML output
Copied: branches/3.2.x/Providers/WMS/Docs/doc_src/Doxyfile_WMS_managed (from rev 130, branches/3.2.1/Providers/WMS/Docs/doc_src/Doxyfile_WMS_managed)
--- branches/3.2.x/Providers/WMS/Docs/doc_src/Doxyfile_WMS_managed (rev 0)
+++ branches/3.2.x/Providers/WMS/Docs/doc_src/Doxyfile_WMS_managed 2007-02-14 21:55:01 UTC (rev 133)
@@ -0,0 +1,227 @@
+# Doxyfile 1.5.1-p1
+# Project related configuration options
+PROJECT_NAME = "FDO Provider for WMS"
+PROJECT_NUMBER =
+OUTPUT_DIRECTORY =
+CREATE_SUBDIRS = NO
+OUTPUT_LANGUAGE = English
+USE_WINDOWS_ENCODING = NO
+BRIEF_MEMBER_DESC = YES
+REPEAT_BRIEF = YES
+ABBREVIATE_BRIEF =
+ALWAYS_DETAILED_SEC = NO
+INLINE_INHERITED_MEMB = NO
+FULL_PATH_NAMES = NO
+STRIP_FROM_PATH =
+STRIP_FROM_INC_PATH =
+SHORT_NAMES = NO
+JAVADOC_AUTOBRIEF = NO
+MULTILINE_CPP_IS_BRIEF = NO
+DETAILS_AT_TOP = YES
+INHERIT_DOCS = YES
+SEPARATE_MEMBER_PAGES = YES
+TAB_SIZE = 4
+ALIASES =
+OPTIMIZE_OUTPUT_FOR_C = NO
+OPTIMIZE_OUTPUT_JAVA = NO
+BUILTIN_STL_SUPPORT = NO
+DISTRIBUTE_GROUP_DOC = NO
+SUBGROUPING = YES
+# Build related configuration options
+EXTRACT_ALL = YES
+EXTRACT_PRIVATE = NO
+EXTRACT_STATIC = YES
+EXTRACT_LOCAL_CLASSES = YES
+EXTRACT_LOCAL_METHODS = NO
+HIDE_UNDOC_MEMBERS = NO
+HIDE_UNDOC_CLASSES = NO
+HIDE_FRIEND_COMPOUNDS = NO
+HIDE_IN_BODY_DOCS = NO
+INTERNAL_DOCS = NO
+CASE_SENSE_NAMES = NO
+HIDE_SCOPE_NAMES = NO
+SHOW_INCLUDE_FILES = YES
+INLINE_INFO = YES
+SORT_MEMBER_DOCS = YES
+SORT_BRIEF_DOCS = YES
+SORT_BY_SCOPE_NAME = NO
+GENERATE_TODOLIST = NO
+GENERATE_TESTLIST = NO
+GENERATE_BUGLIST = NO
+GENERATE_DEPRECATEDLIST= NO
+ENABLED_SECTIONS =
+MAX_INITIALIZER_LINES = 30
+SHOW_USED_FILES = YES
+SHOW_DIRECTORIES = NO
+FILE_VERSION_FILTER =
+# configuration options related to warning and progress messages
+QUIET = NO
+WARNINGS = YES
+WARN_IF_UNDOCUMENTED = YES
+WARN_IF_DOC_ERROR = YES
+WARN_NO_PARAMDOC = YES
+WARN_FORMAT = "$file:$line: $text"
+WARN_LOGFILE = warning_logfile_managed.txt
+# configuration options related to the input files
+INPUT = group_and_page_definitions \
+ ../../Managed/Src/OSGeo/FDO/Providers/WMS/Override
+FILE_PATTERNS = *.h
+RECURSIVE = YES
+EXCLUDE =
+EXCLUDE_SYMLINKS = NO
+EXCLUDE_PATTERNS =
+EXAMPLE_PATH = headers_and_footers
+EXAMPLE_PATTERNS = *
+EXAMPLE_RECURSIVE = YES
+IMAGE_PATH =
+INPUT_FILTER =
+FILTER_PATTERNS =
+FILTER_SOURCE_FILES = NO
+# configuration options related to source browsing
+SOURCE_BROWSER = YES
+INLINE_SOURCES = NO
+STRIP_CODE_COMMENTS = NO
+REFERENCED_BY_RELATION = YES
+REFERENCES_RELATION = YES
+REFERENCES_LINK_SOURCE = YES
+USE_HTAGS = NO
+VERBATIM_HEADERS = YES
+# configuration options related to the alphabetical class index
+ALPHABETICAL_INDEX = YES
+COLS_IN_ALPHA_INDEX = 5
+IGNORE_PREFIX = Fdo \
+ Mg
+# configuration options related to the HTML output
+GENERATE_HTML = YES
+HTML_OUTPUT = ../HTML/WMS_managed
+HTML_FILE_EXTENSION = .html
+HTML_HEADER = headers_and_footers/header_managed.html
+HTML_FOOTER = headers_and_footers/footer_managed.html
+HTML_STYLESHEET = headers_and_footers/custom.css
+HTML_ALIGN_MEMBERS = YES
+GENERATE_HTMLHELP = YES
+CHM_FILE = ../../WMS_Provider_API_managed.chm
+HHC_LOCATION = "C:/Program Files/HTML Help Workshop/hhc.exe"
+GENERATE_CHI = NO
+BINARY_TOC = YES
+TOC_EXPAND = YES
+DISABLE_INDEX = NO
+ENUM_VALUES_PER_LINE = 4
+GENERATE_TREEVIEW = YES
+TREEVIEW_WIDTH = 250
+# configuration options related to the LaTeX output
+GENERATE_LATEX = NO
+LATEX_OUTPUT = latex
+LATEX_CMD_NAME = latex
+MAKEINDEX_CMD_NAME = makeindex
+COMPACT_LATEX = NO
+PAPER_TYPE = a4wide
+EXTRA_PACKAGES =
+LATEX_HEADER =
+PDF_HYPERLINKS = NO
+USE_PDFLATEX = NO
+LATEX_BATCHMODE = NO
+LATEX_HIDE_INDICES = NO
+# configuration options related to the RTF output
+GENERATE_RTF = NO
+RTF_OUTPUT = rtf
+COMPACT_RTF = NO
+RTF_HYPERLINKS = NO
+RTF_STYLESHEET_FILE =
+RTF_EXTENSIONS_FILE =
+# configuration options related to the man page output
+GENERATE_MAN = NO
+MAN_OUTPUT = man
+MAN_EXTENSION = .3
+MAN_LINKS = NO
+# configuration options related to the XML output
+GENERATE_XML = NO
+XML_OUTPUT = xml
+XML_SCHEMA =
+XML_DTD =
+XML_PROGRAMLISTING = YES
+# configuration options for the AutoGen Definitions output
+GENERATE_AUTOGEN_DEF = NO
+# configuration options related to the Perl module output
+GENERATE_PERLMOD = NO
+PERLMOD_LATEX = NO
+PERLMOD_PRETTY = YES
+PERLMOD_MAKEVAR_PREFIX =
+# Configuration options related to the preprocessor
+ENABLE_PREPROCESSING = YES
+MACRO_EXPANSION = YES
+EXPAND_ONLY_PREDEF = NO
+SEARCH_INCLUDES = YES
+INCLUDE_PATH =
+INCLUDE_FILE_PATTERNS =
+PREDEFINED =
+EXPAND_AS_DEFINED =
+SKIP_FUNCTION_MACROS = YES
+# Configuration::additions related to external references
+TAGFILES =
+GENERATE_TAGFILE =
+ALLEXTERNALS = NO
+EXTERNAL_GROUPS = YES
+PERL_PATH = /usr/bin/perl
+# Configuration options related to the dot tool
+CLASS_DIAGRAMS = NO
+HIDE_UNDOC_RELATIONS = YES
+HAVE_DOT = YES
+CLASS_GRAPH = YES
+COLLABORATION_GRAPH = NO
+GROUP_GRAPHS = NO
+UML_LOOK = YES
+TEMPLATE_RELATIONS = NO
+INCLUDE_GRAPH = YES
+INCLUDED_BY_GRAPH = YES
+CALL_GRAPH = YES
+CALLER_GRAPH = NO
+GRAPHICAL_HIERARCHY = YES
+DIRECTORY_GRAPH = YES
+DOT_IMAGE_FORMAT = png
+DOT_PATH =
+DOTFILE_DIRS =
+MAX_DOT_GRAPH_WIDTH = 1024
+MAX_DOT_GRAPH_HEIGHT = 1024
+MAX_DOT_GRAPH_DEPTH = 1000
+DOT_TRANSPARENT = NO
+DOT_MULTI_TARGETS = NO
+GENERATE_LEGEND = YES
+DOT_CLEANUP = YES
+# Configuration::additions related to the search engine
+SEARCHENGINE = NO
Modified: branches/3.2.x/Providers/WMS/Docs/doc_src/Makefile.am
--- branches/3.2.x/Providers/WMS/Docs/doc_src/Makefile.am 2007-02-14 21:50:14 UTC (rev 132)
+++ branches/3.2.x/Providers/WMS/Docs/doc_src/Makefile.am 2007-02-14 21:55:01 UTC (rev 133)
@@ -21,4 +21,4 @@
DIST_SUBDIRS = group_and_page_definitions headers_and_footers
-EXTRA_DIST = Doxyfile_WMS
+EXTRA_DIST = Doxyfile_WMS Doxyfile_WMS_managed
Modified: branches/3.2.x/Providers/WMS/Docs/doc_src/headers_and_footers/Makefile.am
--- branches/3.2.x/Providers/WMS/Docs/doc_src/headers_and_footers/Makefile.am 2007-02-14 21:50:14 UTC (rev 132)
+++ branches/3.2.x/Providers/WMS/Docs/doc_src/headers_and_footers/Makefile.am 2007-02-14 21:55:01 UTC (rev 133)
@@ -17,4 +17,4 @@
AUTOMAKE_OPTIONS = foreign
-EXTRA_DIST = custom.css footer.html header.html
+EXTRA_DIST = custom.css footer.html header.html header_managed.html footer_managed.html
Copied: branches/3.2.x/Providers/WMS/Docs/doc_src/headers_and_footers/footer_managed.html (from rev 130, branches/3.2.1/Providers/WMS/Docs/doc_src/headers_and_footers/footer_managed.html)
--- branches/3.2.x/Providers/WMS/Docs/doc_src/headers_and_footers/footer_managed.html (rev 0)
+++ branches/3.2.x/Providers/WMS/Docs/doc_src/headers_and_footers/footer_managed.html 2007-02-14 21:55:01 UTC (rev 133)
@@ -0,0 +1,10 @@
+<!-- footer.html -->
+ <hr>
+ <table width="100%" border="0">
+ <tr>
+ <td align="right"><font size="-2"><a href="mailto:isd.docs at autodesk.com&subject=FDO%20Provider%20for%20WMS%20.NET%20API%20documentation">Comments?</a></font></td>
+ <!-- The logo can go in another cell, when we get one -->
+ </tr>
+ </table>
+ </body>
+</html>
\ No newline at end of file
Copied: branches/3.2.x/Providers/WMS/Docs/doc_src/headers_and_footers/header_managed.html (from rev 130, branches/3.2.1/Providers/WMS/Docs/doc_src/headers_and_footers/header_managed.html)
--- branches/3.2.x/Providers/WMS/Docs/doc_src/headers_and_footers/header_managed.html (rev 0)
+++ branches/3.2.x/Providers/WMS/Docs/doc_src/headers_and_footers/header_managed.html 2007-02-14 21:55:01 UTC (rev 133)
@@ -0,0 +1,17 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
+<html>
+ <head>
+ <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
+ <title>OSGeo FDO Provider for WMS .NET API Reference</title>
+ <link href="$relpath$custom.css" rel="stylesheet" type="text/css">
+ <link href="$relpath$tabs.css" rel="stylesheet" type="text/css">
+ </head>
+ <body bgcolor="#FFFFFF">
+ <tr>
+ <td><b>.NET API Reference<b></td>
+ <td align="right"><b>OSGeo FDO Provider for WMS<b></td>
+ </tr>
+ </table>
+<!-- End of: header.html -->
More information about the fdo-commits
