[fdo-commits] r2525 - in trunk/Fdo/Unmanaged/Inc/Fdo/Connections: . Capabilities
svn_fdo at osgeo.org svn_fdo at osgeo.org
Thu Feb 15 14:45:13 EST 2007
Author: gregboone
Date: 2007-02-15 14:45:13 -0500 (Thu, 15 Feb 2007)
New Revision: 2525
   trunk/Fdo/Unmanaged/Inc/Fdo/Connections/Capabilities/ArgumentDefinition.h
   trunk/Fdo/Unmanaged/Inc/Fdo/Connections/Capabilities/FunctionDefinition.h
   trunk/Fdo/Unmanaged/Inc/Fdo/Connections/Capabilities/ISchemaCapabilities.h
   trunk/Fdo/Unmanaged/Inc/Fdo/Connections/Capabilities/SchemaElementNameType.h
   trunk/Fdo/Unmanaged/Inc/Fdo/Connections/Capabilities/SignatureDefinition.h
   trunk/Fdo/Unmanaged/Inc/Fdo/Connections/Capabilities/ThreadCapability.h
   trunk/Fdo/Unmanaged/Inc/Fdo/Connections/ConnectionException.h
   trunk/Fdo/Unmanaged/Inc/Fdo/Connections/ConnectionState.h
   trunk/Fdo/Unmanaged/Inc/Fdo/Connections/ProviderDatastoreType.h
FDO4: API - Update API documentation included in the FDO header files
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Connections/Capabilities/ArgumentDefinition.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Connections/Capabilities/ArgumentDefinition.h	2007-02-15 19:43:43 UTC (rev 2524)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Connections/Capabilities/ArgumentDefinition.h	2007-02-15 19:45:13 UTC (rev 2525)
@@ -31,8 +31,8 @@
 /// The FdoArgumentDefinition class contains metadata that describes an argument to a function.
 class FdoArgumentDefinition : public FdoIDisposable
+/// \cond DOXYGEN-IGNORE
 protected:
-/// \cond DOXYGEN-IGNORE
     /// Constructs an instance of an FdoArgumentDefinition using the specified arguments.
     FdoArgumentDefinition(FdoString* name, FdoString* description, FdoDataType dataType);
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Connections/Capabilities/FunctionDefinition.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Connections/Capabilities/FunctionDefinition.h	2007-02-15 19:43:43 UTC (rev 2524)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Connections/Capabilities/FunctionDefinition.h	2007-02-15 19:45:13 UTC (rev 2525)
@@ -33,8 +33,8 @@
 ///  The FdoFunctionDefinition class contains metadata that describes a function and its arguments.
 class FdoFunctionDefinition : public FdoIDisposable
-protected:
+protected:
     /// Constructs an instance of an FdoFunctionDefinition using the specified arguments.
     FdoFunctionDefinition (FdoString                       *name,
                            FdoString                       *description,
@@ -91,7 +91,7 @@
     /// Input the name of the function.
     /// \param description
     /// Input a brief description.
-    /// \param returnProperty Type
+    /// \param returnPropertyType
     /// Input the function return property type
     /// \param returnType
     /// Input the function return data type (ignore it property type is not data)
@@ -144,9 +144,6 @@
     /// \brief
     ///  Gets an array of FdoArgumentDefinition objects required for the function.
-    /// \param length
-    /// Output the number of argument definitions.
     /// \return
     /// Returns the list of argument definitions
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Connections/Capabilities/ISchemaCapabilities.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Connections/Capabilities/ISchemaCapabilities.h	2007-02-15 19:43:43 UTC (rev 2524)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Connections/Capabilities/ISchemaCapabilities.h	2007-02-15 19:45:13 UTC (rev 2525)
@@ -73,9 +73,6 @@
     /// \brief
     /// Returns the maximum supported precision for a decimal data property.
-    /// \param
-    /// None.
     /// \return
@@ -84,9 +81,6 @@
     /// \brief
     /// Returns the maximum supported scale for a decimal data property.
-    /// \param
-    /// None.
     /// \return
@@ -112,9 +106,6 @@
     /// Returns a string that includes all the reserved characters that cannot be
     /// used for the various schema element names for the provider.
-    /// \param
-    /// None
     /// \return
     /// Returns a string with the reserved characters for the identified schema element.
@@ -186,9 +177,6 @@
     /// Returns TRUE if default values can be specified for a data property
     /// definition, FALSE otherwise.
-    /// \param
-    /// None
     /// \return
@@ -212,6 +200,7 @@
 	FDO_API virtual bool SupportsInclusiveValueRangeConstraints() = 0;
     /// \brief
     /// DEPRECATED: Use SupportsInheritance() instead.
     ///          Determines if the feature provider supports inheritance.
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Connections/Capabilities/SchemaElementNameType.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Connections/Capabilities/SchemaElementNameType.h	2007-02-15 19:43:43 UTC (rev 2524)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Connections/Capabilities/SchemaElementNameType.h	2007-02-15 19:45:13 UTC (rev 2525)
@@ -22,24 +22,10 @@
 #pragma once
 #endif
+/// \ingroup (enums)
 /// \brief
 /// The FdoSchemaElementNameType enumeration lists all of the concrete schema name
 /// types defined to address schema limitation information.
-/// <param name="FdoSchemaElementNameType_Datastore">
-/// Represents the identifier to address a data store name
-/// </param>
-/// <param name="FdoSchemaElementNameType_Schema">
-/// Represents the identifier to address a schema
-/// </param>
-/// <param name="FdoSchemaElementNameType_Class">
-/// Represents the identifier to address a class
-/// </param>
-/// <param name="FdoSchemaElementNameType_Property">
-/// Represents the identifier to address a property
-/// </param>
-/// <param name="FdoSchemaElementNameType_Description">
-/// Represents the identifier to address a description
-/// </param>
 enum FdoSchemaElementNameType
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Connections/Capabilities/SignatureDefinition.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Connections/Capabilities/SignatureDefinition.h	2007-02-15 19:43:43 UTC (rev 2524)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Connections/Capabilities/SignatureDefinition.h	2007-02-15 19:45:13 UTC (rev 2525)
@@ -59,8 +59,8 @@
     FDO_API FdoDataType GetReturnType ();
 protected:
     /// Constructs an instance of a SignatureDefinition using the specified arguments.
     FdoSignatureDefinition (FdoDataType                     returnType,
                             FdoArgumentDefinitionCollection *arguments);
@@ -127,8 +127,8 @@
        FdoSignatureDefinitionCollection,
        FdoSchemaException>
 protected:
     FdoReadOnlySignatureDefinitionCollection ();
@@ -144,7 +144,7 @@
     /// \brief
     /// Constructs an instance of an FdoReadOnlySignatureDefinitionCollection by providing a non-readonly collection.
-    /// \param collection
+    /// \param col
     /// Input a signature collection
     /// \return
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Connections/Capabilities/ThreadCapability.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Connections/Capabilities/ThreadCapability.h	2007-02-15 19:43:43 UTC (rev 2524)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Connections/Capabilities/ThreadCapability.h	2007-02-15 19:45:13 UTC (rev 2525)
@@ -23,26 +23,9 @@
 #pragma once
 #endif
 /// \brief
 /// The FdoThreadCapability enumeration defines the threading capabilities of a feature provider.
-/// <param name="FdoThreadCapability_SingleThreaded">
-/// The feature provider is not thread safe.
-/// </param>
-/// <param name="FdoThreadCapability_PerConnectionThreaded">
-/// The feature provider supports a single thread per connection. Multiple concurrent threads
-/// cannot access the same connection object and only one command can be executing per
-/// connection. Multiple connections can be active concurrently as long as each is
-/// executing on its own thread.
-/// </param>
-/// <param name="FdoThreadCapability_PerCommandThreaded">
-/// The feature provider supports a single thread per command. Multiple concurrent threads
-/// cannot access the same command object, however multiple commands can be executing
-/// concurrently against a single connection.
-/// </param>
-/// <param name="FdoThreadCapability_MultiThreaded">
-/// The feature provider is fully multi-threaded. Concurrent thread access is safe
-/// for all objects.
-/// </param>
 enum FdoThreadCapability
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Connections/ConnectionException.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Connections/ConnectionException.h	2007-02-15 19:43:43 UTC (rev 2524)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Connections/ConnectionException.h	2007-02-15 19:45:13 UTC (rev 2525)
@@ -31,8 +31,8 @@
 /// specific.
 class FdoConnectionException : public FdoException
 protected:
     /// \brief
     /// Constructs a default instance of an FdoConnectionException.
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Connections/ConnectionState.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Connections/ConnectionState.h	2007-02-15 19:43:43 UTC (rev 2524)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Connections/ConnectionState.h	2007-02-15 19:45:13 UTC (rev 2525)
@@ -23,22 +23,9 @@
 #pragma once
 #endif
 /// \brief
 /// The FdoConnectionState enumeration indicates the current state of the connection
-/// <param name="FdoConnectionState_Busy">
-/// The connection is busy executing one or more commands. Executing another
-/// command while the connection is busy will result in an exception.
-/// </param>
-/// <param name="FdoConnectionState_Closed">
-/// The connection is closed.
-/// </param>
-/// <param name="FdoConnectionState_Open">
-/// The connection is open.
-/// </param>
-/// <param name="FdoConnectionState_Pending">
-/// The connection is pending. this is used to indicate that the application has
-/// issued an Open request, but the open is not completed because the application needs to include additional connection property values.
-/// </param>
 enum FdoConnectionState
@@ -51,7 +38,9 @@
     FdoConnectionState_Open,
-    /// The connection is open.
+    /// The connection is pending. this is used to indicate that the application has
+    /// issued an Open request, but the open is not completed because the application
+    /// needs to include additional connection property values.
 #endif
Modified: trunk/Fdo/Unmanaged/Inc/Fdo/Connections/ProviderDatastoreType.h
--- trunk/Fdo/Unmanaged/Inc/Fdo/Connections/ProviderDatastoreType.h	2007-02-15 19:43:43 UTC (rev 2524)
+++ trunk/Fdo/Unmanaged/Inc/Fdo/Connections/ProviderDatastoreType.h	2007-02-15 19:45:13 UTC (rev 2525)
@@ -22,21 +22,10 @@
 #pragma once
 #endif
 /// \brief
 /// The FdoProviderDatastoreType enumeration lists all of the concrete provider
 /// types supported by FDO.
-/// <param name="FdoProviderDatastoreType_DatabaseServer">
-/// Indicates that the provider is a database-based provider.
-/// </param>
-/// <param name="FdoProviderDatastoreType_File">
-/// Indicates that the provider is a file-based provider.
-/// </param>
-/// <param name="FdoProviderDatastoreType_WebServer">
-/// Indicates that the provider is a web-based provider.
-/// </param>
-/// <param name="FdoProviderDatastoreType_Unknown">
-/// Indicates that the provider is of an unknown provider type.
-/// </param>
 enum FdoProviderDatastoreType
More information about the fdo-commits mailing list
