[fdo-commits] r2542 - in trunk/Providers/WMS/Docs/doc_src: . headers_and_footers
svn_fdo at osgeo.org svn_fdo at osgeo.org
Thu Feb 15 15:48:02 EST 2007
Author: gregboone
Date: 2007-02-15 15:48:02 -0500 (Thu, 15 Feb 2007)
New Revision: 2542
Added:
   trunk/Providers/WMS/Docs/doc_src/Doxyfile_WMS_managed
   trunk/Providers/WMS/Docs/doc_src/headers_and_footers/footer_managed.html
   trunk/Providers/WMS/Docs/doc_src/headers_and_footers/header_managed.html
   trunk/Providers/WMS/Docs/doc_src/Makefile.am
   trunk/Providers/WMS/Docs/doc_src/headers_and_footers/Makefile.am
FDO4: API - Update API documentation included in the FDO header files
Modified: trunk/Providers/WMS/Docs/doc_src/Doxyfile_WMS
--- trunk/Providers/WMS/Docs/doc_src/Doxyfile_WMS	2007-02-15 20:46:09 UTC (rev 2541)
+++ trunk/Providers/WMS/Docs/doc_src/Doxyfile_WMS	2007-02-15 20:48:02 UTC (rev 2542)
@@ -101,7 +101,7 @@
 ALPHABETICAL_INDEX     = YES
 COLS_IN_ALPHA_INDEX    = 5
-IGNORE_PREFIX          =
+IGNORE_PREFIX          = Fdo
 # configuration options related to the HTML output
Added: trunk/Providers/WMS/Docs/doc_src/Doxyfile_WMS_managed
--- trunk/Providers/WMS/Docs/doc_src/Doxyfile_WMS_managed	                        (rev 0)
+++ trunk/Providers/WMS/Docs/doc_src/Doxyfile_WMS_managed	2007-02-15 20:48:02 UTC (rev 2542)
@@ -0,0 +1,227 @@
+# Doxyfile 1.5.1-p1
+# Project related configuration options
+PROJECT_NAME           = "FDO Provider for WMS"
+PROJECT_NUMBER         =
+OUTPUT_DIRECTORY       =
+CREATE_SUBDIRS         = NO
+OUTPUT_LANGUAGE        = English
+USE_WINDOWS_ENCODING   = NO
+BRIEF_MEMBER_DESC      = YES
+REPEAT_BRIEF           = YES
+ABBREVIATE_BRIEF       =
+ALWAYS_DETAILED_SEC    = NO
+INLINE_INHERITED_MEMB  = NO
+FULL_PATH_NAMES        = NO
+STRIP_FROM_PATH        =
+STRIP_FROM_INC_PATH    =
+SHORT_NAMES            = NO
+JAVADOC_AUTOBRIEF      = NO
+MULTILINE_CPP_IS_BRIEF = NO
+DETAILS_AT_TOP         = YES
+INHERIT_DOCS           = YES
+SEPARATE_MEMBER_PAGES  = YES
+TAB_SIZE               = 4
+ALIASES                =
+OPTIMIZE_OUTPUT_FOR_C  = NO
+OPTIMIZE_OUTPUT_JAVA   = NO
+BUILTIN_STL_SUPPORT    = NO
+DISTRIBUTE_GROUP_DOC   = NO
+SUBGROUPING            = YES
+# Build related configuration options
+EXTRACT_ALL            = YES
+EXTRACT_PRIVATE        = NO
+EXTRACT_STATIC         = YES
+EXTRACT_LOCAL_CLASSES  = YES
+EXTRACT_LOCAL_METHODS  = NO
+HIDE_UNDOC_MEMBERS     = NO
+HIDE_UNDOC_CLASSES     = NO
+HIDE_FRIEND_COMPOUNDS  = NO
+HIDE_IN_BODY_DOCS      = NO
+INTERNAL_DOCS          = NO
+CASE_SENSE_NAMES       = NO
+HIDE_SCOPE_NAMES       = NO
+SHOW_INCLUDE_FILES     = YES
+INLINE_INFO            = YES
+SORT_MEMBER_DOCS       = YES
+SORT_BRIEF_DOCS        = YES
+SORT_BY_SCOPE_NAME     = NO
+GENERATE_TODOLIST      = NO
+GENERATE_TESTLIST      = NO
+GENERATE_BUGLIST       = NO
+GENERATE_DEPRECATEDLIST= NO
+ENABLED_SECTIONS       =
+MAX_INITIALIZER_LINES  = 30
+SHOW_USED_FILES        = YES
+SHOW_DIRECTORIES       = NO
+FILE_VERSION_FILTER    =
+# configuration options related to warning and progress messages
+QUIET                  = NO
+WARNINGS               = YES
+WARN_IF_UNDOCUMENTED   = YES
+WARN_IF_DOC_ERROR      = YES
+WARN_NO_PARAMDOC       = YES
+WARN_FORMAT            = "$file:$line: $text"
+WARN_LOGFILE           = warning_logfile_managed.txt
+# configuration options related to the input files
+INPUT                  = group_and_page_definitions \
+                         ../../Managed/Src/OSGeo/FDO/Providers/WMS/Override
+FILE_PATTERNS          = *.h
+RECURSIVE              = YES
+EXCLUDE                =
+EXCLUDE_SYMLINKS       = NO
+EXCLUDE_PATTERNS       =
+EXAMPLE_PATH           = headers_and_footers
+EXAMPLE_PATTERNS       = *
+EXAMPLE_RECURSIVE      = YES
+IMAGE_PATH             =
+INPUT_FILTER           =
+FILTER_PATTERNS        =
+FILTER_SOURCE_FILES    = NO
+# configuration options related to source browsing
+SOURCE_BROWSER         = YES
+INLINE_SOURCES         = NO
+STRIP_CODE_COMMENTS    = NO
+REFERENCED_BY_RELATION = YES
+REFERENCES_RELATION    = YES
+REFERENCES_LINK_SOURCE = YES
+USE_HTAGS              = NO
+VERBATIM_HEADERS       = YES
+# configuration options related to the alphabetical class index
+ALPHABETICAL_INDEX     = YES
+COLS_IN_ALPHA_INDEX    = 5
+IGNORE_PREFIX          = Fdo \
+                         Mg
+# configuration options related to the HTML output
+GENERATE_HTML          = YES
+HTML_OUTPUT            = ../HTML/WMS_managed
+HTML_FILE_EXTENSION    = .html
+HTML_HEADER            = headers_and_footers/header_managed.html
+HTML_FOOTER            = headers_and_footers/footer_managed.html
+HTML_STYLESHEET        = headers_and_footers/custom.css
+HTML_ALIGN_MEMBERS     = YES
+GENERATE_HTMLHELP      = YES
+CHM_FILE               = ../../WMS_Provider_API_managed.chm
+HHC_LOCATION           = "C:/Program Files/HTML Help Workshop/hhc.exe"
+GENERATE_CHI           = NO
+BINARY_TOC             = YES
+TOC_EXPAND             = YES
+DISABLE_INDEX          = NO
+ENUM_VALUES_PER_LINE   = 4
+GENERATE_TREEVIEW      = YES
+TREEVIEW_WIDTH         = 250
+# configuration options related to the LaTeX output
+GENERATE_LATEX         = NO
+LATEX_OUTPUT           = latex
+LATEX_CMD_NAME         = latex
+MAKEINDEX_CMD_NAME     = makeindex
+COMPACT_LATEX          = NO
+PAPER_TYPE             = a4wide
+EXTRA_PACKAGES         =
+LATEX_HEADER           =
+PDF_HYPERLINKS         = NO
+USE_PDFLATEX           = NO
+LATEX_BATCHMODE        = NO
+LATEX_HIDE_INDICES     = NO
+# configuration options related to the RTF output
+GENERATE_RTF           = NO
+RTF_OUTPUT             = rtf
+COMPACT_RTF            = NO
+RTF_HYPERLINKS         = NO
+RTF_STYLESHEET_FILE    =
+RTF_EXTENSIONS_FILE    =
+# configuration options related to the man page output
+GENERATE_MAN           = NO
+MAN_OUTPUT             = man
+MAN_EXTENSION          = .3
+MAN_LINKS              = NO
+# configuration options related to the XML output
+GENERATE_XML           = NO
+XML_OUTPUT             = xml
+XML_SCHEMA             =
+XML_DTD                =
+XML_PROGRAMLISTING     = YES
+# configuration options for the AutoGen Definitions output
+GENERATE_AUTOGEN_DEF   = NO
+# configuration options related to the Perl module output
+GENERATE_PERLMOD       = NO
+PERLMOD_LATEX          = NO
+PERLMOD_PRETTY         = YES
+PERLMOD_MAKEVAR_PREFIX =
+# Configuration options related to the preprocessor
+ENABLE_PREPROCESSING   = YES
+MACRO_EXPANSION        = YES
+EXPAND_ONLY_PREDEF     = NO
+SEARCH_INCLUDES        = YES
+INCLUDE_PATH           =
+INCLUDE_FILE_PATTERNS  =
+PREDEFINED             =
+EXPAND_AS_DEFINED      =
+SKIP_FUNCTION_MACROS   = YES
+# Configuration::additions related to external references
+TAGFILES               =
+GENERATE_TAGFILE       =
+ALLEXTERNALS           = NO
+EXTERNAL_GROUPS        = YES
+PERL_PATH              = /usr/bin/perl
+# Configuration options related to the dot tool
+CLASS_DIAGRAMS         = NO
+HIDE_UNDOC_RELATIONS   = YES
+HAVE_DOT               = YES
+CLASS_GRAPH            = YES
+COLLABORATION_GRAPH    = NO
+GROUP_GRAPHS           = NO
+UML_LOOK               = YES
+TEMPLATE_RELATIONS     = NO
+INCLUDE_GRAPH          = YES
+INCLUDED_BY_GRAPH      = YES
+CALL_GRAPH             = YES
+CALLER_GRAPH           = NO
+GRAPHICAL_HIERARCHY    = YES
+DIRECTORY_GRAPH        = YES
+DOT_IMAGE_FORMAT       = png
+DOT_PATH               =
+DOTFILE_DIRS           =
+MAX_DOT_GRAPH_WIDTH    = 1024
+MAX_DOT_GRAPH_HEIGHT   = 1024
+MAX_DOT_GRAPH_DEPTH    = 1000
+DOT_TRANSPARENT        = NO
+DOT_MULTI_TARGETS      = NO
+GENERATE_LEGEND        = YES
+DOT_CLEANUP            = YES
+# Configuration::additions related to the search engine
+SEARCHENGINE           = NO
Property changes on: trunk/Providers/WMS/Docs/doc_src/Doxyfile_WMS_managed
___________________________________________________________________
   + native
Modified: trunk/Providers/WMS/Docs/doc_src/Makefile.am
--- trunk/Providers/WMS/Docs/doc_src/Makefile.am	2007-02-15 20:46:09 UTC (rev 2541)
+++ trunk/Providers/WMS/Docs/doc_src/Makefile.am	2007-02-15 20:48:02 UTC (rev 2542)
@@ -21,4 +21,4 @@
 DIST_SUBDIRS = group_and_page_definitions headers_and_footers
-EXTRA_DIST = Doxyfile_WMS
+EXTRA_DIST = Doxyfile_WMS Doxyfile_WMS_managed
Modified: trunk/Providers/WMS/Docs/doc_src/headers_and_footers/Makefile.am
--- trunk/Providers/WMS/Docs/doc_src/headers_and_footers/Makefile.am	2007-02-15 20:46:09 UTC (rev 2541)
+++ trunk/Providers/WMS/Docs/doc_src/headers_and_footers/Makefile.am	2007-02-15 20:48:02 UTC (rev 2542)
@@ -17,4 +17,4 @@
 AUTOMAKE_OPTIONS = foreign
-EXTRA_DIST = custom.css footer.html header.html
+EXTRA_DIST = custom.css footer.html header.html header_managed.html footer_managed.html
Added: trunk/Providers/WMS/Docs/doc_src/headers_and_footers/footer_managed.html
--- trunk/Providers/WMS/Docs/doc_src/headers_and_footers/footer_managed.html	                        (rev 0)
+++ trunk/Providers/WMS/Docs/doc_src/headers_and_footers/footer_managed.html	2007-02-15 20:48:02 UTC (rev 2542)
@@ -0,0 +1,10 @@
+<!-- footer.html -->
+		<hr>
+		<table width="100%"  border="0">
+			<tr>
+				<td align="right"><font size="-2"><a href="mailto:isd.docs at autodesk.com&subject=FDO%20Provider%20for%20WMS%20.NET%20API%20documentation">Comments?</a></font></td>
+				<!-- The logo can go in another cell, when we get one -->
+			</tr>
+		</table>
+	</body>
+</html>
\ No newline at end of file
Property changes on: trunk/Providers/WMS/Docs/doc_src/headers_and_footers/footer_managed.html
   + native
Added: trunk/Providers/WMS/Docs/doc_src/headers_and_footers/header_managed.html
--- trunk/Providers/WMS/Docs/doc_src/headers_and_footers/header_managed.html	                        (rev 0)
+++ trunk/Providers/WMS/Docs/doc_src/headers_and_footers/header_managed.html	2007-02-15 20:48:02 UTC (rev 2542)
@@ -0,0 +1,17 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN"	"http://www.w3.org/TR/html4/loose.dtd">
+<html>
+	<head>
+		<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
+		<title>OSGeo FDO Provider for WMS .NET API Reference</title>
+		<link href="$relpath$custom.css" rel="stylesheet" type="text/css">
+		<link href="$relpath$tabs.css" rel="stylesheet" type="text/css">
+	</head>
+	<body bgcolor="#FFFFFF">
+			<tr>
+				<td><b>.NET API Reference<b></td>
+				<td align="right"><b>OSGeo FDO Provider for WMS<b></td>
+			</tr>
+		</table>
+<!-- End of: header.html -->
Property changes on: trunk/Providers/WMS/Docs/doc_src/headers_and_footers/header_managed.html
   + native
More information about the fdo-commits mailing list
