[fdo-commits] r783 - in branches/3.2.1/Fdo: UnitTest
Unmanaged/Src/Fdo/Xml
svn_fdo at osgeo.org
Fri Feb 16 14:21:49 EST 2007
Author: brentrobinson
Date: 2007-02-16 14:21:49 -0500 (Fri, 16 Feb 2007)
New Revision: 783
branches/3.2.1/Fdo/UnitTest/SpatialContextTest.cpp
branches/3.2.1/Fdo/UnitTest/SpatialContextTest.h
branches/3.2.1/Fdo/Unmanaged/Src/Fdo/Xml/SCReadHandler.cpp
branches/3.2.1/Fdo/Unmanaged/Src/Fdo/Xml/SCReadHandler.h
branches/3.2.1/Fdo/Unmanaged/Src/Fdo/Xml/SpatialContextReader.cpp
FdoXmlSpatialContextReader: Prevent ':' encoding
Modified: branches/3.2.1/Fdo/UnitTest/SpatialContextTest.cpp
--- branches/3.2.1/Fdo/UnitTest/SpatialContextTest.cpp 2007-02-15 20:00:00 UTC (rev 782)
+++ branches/3.2.1/Fdo/UnitTest/SpatialContextTest.cpp 2007-02-16 19:21:49 UTC (rev 783)
@@ -103,7 +103,7 @@
bFailed = true;
if ( !bFailed )
- CPPUNIT_FAIL( "Writing nameless spatial context should have failed." );
+ CPPUNIT_FAIL( "Writing extentless spatial context should have failed." );
// now for the happy tests.
@@ -332,6 +332,59 @@
+void SpatialContextTest::testXmlDotColon()
+ try {
+ FdoInt32 pass;
+ // pass 0 writes SC without WKT, pass1 writes it with WKT.
+ for ( pass = 0; pass < 2; pass++ ) {
+ FdoIoMemoryStreamP stream = FdoIoMemoryStream::Create();
+ FdoIoMemoryStreamP stream2 = FdoIoMemoryStream::Create();
+ FdoXmlWriterP xmlWriter = FdoXmlWriter::Create(stream);
+ FdoXmlSpatialContextWriterP writer = FdoXmlSpatialContextWriter::Create(
+ xmlWriter
+ writer->SetName( L"EPSG:123.4" );
+ writer->SetDescription( L". and : test" );
+ writer->SetCoordinateSystem( L"EPSG:1234" );
+ if ( pass == 1 )
+ writer->SetCoordinateSystemWkt( L"LOCAL_CS [ \"Non-Earth (Meter)\", LOCAL_DATUM [\"Local Datum\", 0], UNIT [\"Meter\", 1.0], AXIS [\"X\", EAST], AXIS[\"Y\", NORTH]]" );
+ FdoPtr<FdoByteArray> extent = SerializeExtent( 0, 0, 15000, 10000 );
+ writer->SetExtent( extent );
+ writer->SetExtentType( FdoSpatialContextExtentType_Dynamic );
+ writer->SetXYTolerance( 0.1 );
+ writer->SetZTolerance( 0.01 );
+ writer->WriteSpatialContext();
+ writer = NULL;
+ xmlWriter = NULL;
+ stream->Reset();
+ FdoXmlSpatialContextReaderP reader =
+ FdoXmlSpatialContextReader::Create(
+ FdoXmlReaderP( FdoXmlReader::Create(stream) ),
+ FdoXmlSpatialContextFlagsP(
+ FdoXmlSpatialContextFlags::Create( NULL, FdoXmlFlags::ErrorLevel_High )
+ FDO_CPPUNIT_ASSERT( reader->ReadNext() );
+ FDO_CPPUNIT_ASSERT( wcscmp(reader->GetName(), L"EPSG:123.4") == 0 );
+ FDO_CPPUNIT_ASSERT( wcscmp(reader->GetCoordinateSystem(), L"EPSG:1234") == 0 );
+ FDO_CPPUNIT_ASSERT( wcscmp(reader->GetDescription(), L". and : test") == 0 );
+ FDO_CPPUNIT_ASSERT( !reader->ReadNext() );
+ catch ( FdoException* e ) {
+ UnitTestUtil::FailOnException( e );
FdoByteArray* SpatialContextTest::SerializeExtent( double minX, double minY, double maxX, double maxY )
// Create a byte array
Modified: branches/3.2.1/Fdo/UnitTest/SpatialContextTest.h
--- branches/3.2.1/Fdo/UnitTest/SpatialContextTest.h 2007-02-15 20:00:00 UTC (rev 782)
+++ branches/3.2.1/Fdo/UnitTest/SpatialContextTest.h 2007-02-16 19:21:49 UTC (rev 783)
@@ -27,6 +27,7 @@
FDO_CPPUNIT_DEFINE(testXmlV2);
FDO_CPPUNIT_DEFINE(testXmlError);
FDO_CPPUNIT_DEFINE(testXmlNesting);
+ FDO_CPPUNIT_DEFINE(testXmlDotColon);
CPPUNIT_TEST_SUITE(SpatialContextTest);
@@ -35,6 +36,7 @@
CPPUNIT_TEST(testXmlV2);
CPPUNIT_TEST(testXmlError);
CPPUNIT_TEST(testXmlNesting);
+ CPPUNIT_TEST(testXmlDotColon);
CPPUNIT_TEST_SUITE_END();
@@ -57,6 +59,9 @@
// root element.
void testXmlNesting();
+ // Test round-tripping spatial contexts with dots and/or colons in name and coordsys name,
+ void testXmlDotColon();
// Convert extents from doubles to byte array
FdoByteArray* SerializeExtent( double minX, double minY, double maxX, double maxY );
// Deserialize spatial contexts from inStream and serialize them to outStream
Modified: branches/3.2.1/Fdo/Unmanaged/Src/Fdo/Xml/SCReadHandler.cpp
--- branches/3.2.1/Fdo/Unmanaged/Src/Fdo/Xml/SCReadHandler.cpp 2007-02-15 20:00:00 UTC (rev 782)
+++ branches/3.2.1/Fdo/Unmanaged/Src/Fdo/Xml/SCReadHandler.cpp 2007-02-16 19:21:49 UTC (rev 783)
@@ -146,6 +146,22 @@
mElementPrefix = L"";
+FdoStringP FdoXmlSCReadHandler::DecodeName ( FdoStringP name, FdoXmlReader* reader )
+ FdoStringP outName = name;
+ if ( mXmlFlags->GetNameAdjust() ) {
+ //Workaround: '.' and ':' are not allowed in schema element names so DecodeName replaces
+ //them with '-dot-' and '-colon'. However '.' and ':' are allowed in spatial context names
+ //so change them back.
+ //The ideal fix is to move the '.' and ':' replacement up from FdoXmlReader to the
+ //Fdo/Schema level but this would be a bit riskier and should be done in a later version.
+ outName = reader->DecodeName(name).Replace( L"-colon-", L":" ).Replace( L"-dot-", L"." );
+ return outName;
FdoXmlSaxHandler* FdoXmlSCReadHandler::doTransition(
FdoBoolean isStart,
FdoXmlSaxContext* context,
@@ -337,9 +353,7 @@
attr = atts->FindItem( FdoXml::mGmlUri + L":id" );
if ( attr ) {
- mID = mXmlFlags->GetNameAdjust() ?
- (FdoString*) reader->DecodeName(attr->GetValue()) :
- attr->GetValue();
+ mID = DecodeName( attr->GetValue(), reader );
break;
@@ -479,7 +493,7 @@
else {
- mCoordSysName = tokens->GetString(1);
+ mCoordSysName = DecodeName( tokens->GetString(1), reader );
@@ -714,9 +728,7 @@
if ( attr ) {
- mCsysID = mXmlFlags->GetNameAdjust() ?
- attr->GetValue();
+ mCsysID = DecodeName( attr->GetValue(), reader );
break;
Modified: branches/3.2.1/Fdo/Unmanaged/Src/Fdo/Xml/SCReadHandler.h
--- branches/3.2.1/Fdo/Unmanaged/Src/Fdo/Xml/SCReadHandler.h 2007-02-15 20:00:00 UTC (rev 782)
+++ branches/3.2.1/Fdo/Unmanaged/Src/Fdo/Xml/SCReadHandler.h 2007-02-16 19:21:49 UTC (rev 783)
@@ -44,6 +44,8 @@
// Initializes the handler. Must be called before reading each spatial context.
void Setup( FdoXmlFlags* pXmlFlags );
+ // Decodes any escaped characters in Spatial Context and Coordinate System names.
+ FdoStringP DecodeName ( FdoStringP name, FdoXmlReader* reader );
protected:
FdoXmlSCReadHandler() {}
Modified: branches/3.2.1/Fdo/Unmanaged/Src/Fdo/Xml/SpatialContextReader.cpp
--- branches/3.2.1/Fdo/Unmanaged/Src/Fdo/Xml/SpatialContextReader.cpp 2007-02-15 20:00:00 UTC (rev 782)
+++ branches/3.2.1/Fdo/Unmanaged/Src/Fdo/Xml/SpatialContextReader.cpp 2007-02-16 19:21:49 UTC (rev 783)
@@ -160,10 +160,6 @@
mExtent = gf->GetFgf(geom);
mSCHandler->mFirst = false;
- // Decode the coordinate system name.
- if ( mXmlFlags->GetNameAdjust() ) {
- mSCHandler->mCoordSysName = mXmlReader->DecodeName( mSCHandler->mCoordSysName );
return true;
else {
More information about the fdo-commits
