[fdo-commits] r760 -
	branches/3.2.x/Providers/GenericRdbms/Src/Fdo/Filter
    svn_fdo at osgeo.org
    Mon Feb 19 18:24:46 EST 2007
Author: thomasknoell
Date: 2007-02-19 18:24:36 -0500 (Mon, 19 Feb 2007)
New Revision: 760
   branches/3.2.x/Providers/GenericRdbms/Src/Fdo/Filter/FdoRdbmsFilterProcessor.cpp
   branches/3.2.x/Providers/GenericRdbms/Src/Fdo/Filter/FdoRdbmsFilterProcessor.h
Required changes in the context of removing additional identity columns as part of the reader returned by the SelectAggregates command.
Modified: branches/3.2.x/Providers/GenericRdbms/Src/Fdo/Filter/FdoRdbmsFilterProcessor.cpp
--- branches/3.2.x/Providers/GenericRdbms/Src/Fdo/Filter/FdoRdbmsFilterProcessor.cpp	2007-02-19 23:23:44 UTC (rev 759)
+++ branches/3.2.x/Providers/GenericRdbms/Src/Fdo/Filter/FdoRdbmsFilterProcessor.cpp	2007-02-19 23:24:36 UTC (rev 760)
@@ -992,7 +992,6 @@
 bool FdoRdbmsFilterProcessor::ContainsAggregateFunctions( FdoIdentifierCollection *identifiers )
     class FindAggregate : public FdoRdbmsBaseFilterProcessor
@@ -1043,7 +1042,6 @@
     return false;
 void FdoRdbmsFilterProcessor::PrependTables()
     // Prepend the from clause as: table1,table2,table3 And make sure a given table will only appear once
@@ -1191,8 +1189,13 @@
 // The implementation of the public method that converts FDO filter to dbi SQL strings.
-const wchar_t* FdoRdbmsFilterProcessor::FilterToSql( FdoFilter  *filter, const wchar_t *className, SqlCommandType cmdType, FdoCommandType callerFdoCommand, FdoRdbmsFilterUtilConstrainDef *inFilterConstrain,
-                                             bool forUpdate )
+const wchar_t* FdoRdbmsFilterProcessor::FilterToSql( FdoFilter                      *filter,
+                                                     const wchar_t                  *className,
+                                                     SqlCommandType                 cmdType,
+                                                     FdoCommandType                 callerFdoCommand,
+                                                     FdoRdbmsFilterUtilConstrainDef *inFilterConstrain,
+                                                     bool                           forUpdate,
+                                                     FdoInt16                       callerId )
     int j;
@@ -1533,7 +1536,9 @@
             // the featid column.
             // Also if the we have a distinct clause, we should not be adding any columns as that will
             // change the returned result.
-            if( (! isFeatIdOnlyQuery && ! filterConstraint->distinct) && !( useAggregateFunctions && !mRequiresDistinct  ))
+            if( (! isFeatIdOnlyQuery && ! filterConstraint->distinct) &&
+                !( useAggregateFunctions && !mRequiresDistinct  ) &&
+                !( callerId == FdoCommandType_SelectAggregates && !mRequiresDistinct ) )
                 FdoStringP sqlTableName = mDbiConnection->GetSchemaUtil()->GetDbObjectSqlName(mDbiConnection->GetSchemaUtil()->GetClass(mCurrentClassName));
                 const  wchar_t* table = GetTableAlias(sqlTableName);
Modified: branches/3.2.x/Providers/GenericRdbms/Src/Fdo/Filter/FdoRdbmsFilterProcessor.h
--- branches/3.2.x/Providers/GenericRdbms/Src/Fdo/Filter/FdoRdbmsFilterProcessor.h	2007-02-19 23:23:44 UTC (rev 759)
+++ branches/3.2.x/Providers/GenericRdbms/Src/Fdo/Filter/FdoRdbmsFilterProcessor.h	2007-02-19 23:24:36 UTC (rev 760)
@@ -288,7 +288,7 @@
     bool CanOptimizeRelationQuery( const FdoSmLpClassDefinition* pClass, const FdoSmLpPropertyDefinition* propertyDefinition );
-    virtual const wchar_t* FilterToSql( FdoFilter  *filter, const wchar_t *className, SqlCommandType cmdType, FdoCommandType callerFdoCommand, FdoRdbmsFilterUtilConstrainDef *filterConstrain = NULL, bool forUpdate = false );
+    virtual const wchar_t* FilterToSql( FdoFilter  *filter, const wchar_t *className, SqlCommandType cmdType, FdoCommandType callerFdoCommand, FdoRdbmsFilterUtilConstrainDef *filterConstrain = NULL, bool forUpdate = false, FdoInt16 callerId = FdoCommandType_Select );
     FdoRdbmsSecondarySpatialFilterCollection * GetGeometricConditions() { return FDO_SAFE_ADDREF(mSecondarySpatialFilters.p); }
More information about the fdo-commits
