[fdo-commits] r2569 - in trunk/Utilities/Common: Inc Src
svn_fdo at osgeo.org svn_fdo at osgeo.org
Tue Feb 20 17:08:52 EST 2007
Author: badreddinekaroui
Date: 2007-02-20 17:08:51 -0500 (Tue, 20 Feb 2007)
New Revision: 2569
   trunk/Utilities/Common/Inc/FdoCommonFilterExecutor.h
   trunk/Utilities/Common/Src/FdoCommonFilterExecutor.cpp
Trac #13: Merging defect fixes from branch 3.2.x to the trunk
Merged the filter preprocessor that validate the properties reference by the filter against the class definition and validate the spatial operators against the Provider capabilities.
Modified: trunk/Utilities/Common/Inc/FdoCommonFilterExecutor.h
--- trunk/Utilities/Common/Inc/FdoCommonFilterExecutor.h	2007-02-20 22:04:39 UTC (rev 2568)
+++ trunk/Utilities/Common/Inc/FdoCommonFilterExecutor.h	2007-02-20 22:08:51 UTC (rev 2569)
@@ -72,6 +72,14 @@
     static FdoCommonFilterExecutor* Create (FdoIReader* featureReader, FdoIdentifierCollection* compIdents);
     /// \brief
+    /// Validate the properties mentioned in the filter against class properties and identifiers.
+    /// \return
+	/// Throws "The identifier 'IdName' was not recognized" exception.
+	static void ValidateFilter( FdoClassDefinition *cls, FdoFilter *filter, FdoIdentifierCollection *selIds = NULL, FdoIFilterCapabilities *filterCapabilities = NULL);
+    /// \brief
     /// Increase the reference count.
     /// \return
Modified: trunk/Utilities/Common/Src/FdoCommonFilterExecutor.cpp
--- trunk/Utilities/Common/Src/FdoCommonFilterExecutor.cpp	2007-02-20 22:04:39 UTC (rev 2568)
+++ trunk/Utilities/Common/Src/FdoCommonFilterExecutor.cpp	2007-02-20 22:08:51 UTC (rev 2569)
@@ -3797,3 +3797,182 @@
+void FdoCommonFilterExecutor::ValidateFilter( FdoClassDefinition *cls, FdoFilter *filter,
+											  FdoIdentifierCollection *selIds,
+											  FdoIFilterCapabilities *filterCapabilities )
+    class FdoCommonFilterValidator : public virtual FdoIExpressionProcessor, public virtual FdoIFilterProcessor
+    private:
+        FdoClassDefinition* m_class;
+		FdoIdentifierCollection *m_selectedIds;
+		FdoIFilterCapabilities	*m_filterCapabilities;
+    protected:
+        void HandleExpr( FdoExpression *exp )
+            exp->Process( this );
+        void HandleFilter( FdoFilter *filter )
+            filter->Process( this );
+    public:
+        FdoCommonFilterValidator( FdoClassDefinition *cls, FdoIdentifierCollection *selIds, FdoIFilterCapabilities *filterCapabilities )
+            m_class = cls;
+			m_selectedIds = selIds;
+			m_filterCapabilities = filterCapabilities;
+        virtual void Dispose() { delete this; }
+         /// <summary>Increase the reference count.</summary>
+        /// <returns>Returns the new reference count (value for debugging use only).</returns>
+        FdoInt32 AddRef()
+            // NOTE: due to multiple inheritance, there is an ambiguity in which AddRef() method to call.
+            //  Calling BOTH AddRef() methods leads to instances of this class being prematurely released.
+            return FdoIFilterProcessor::AddRef();
+        /// <summary>Decrease the reference count.</summary>
+        FdoInt32 Release ()
+            // NOTE: due to multiple inheritance, there is an ambiguity in which Release() method to call.
+            //  Calling BOTH Release() methods leads to instances of this class being prematurely released.
+            return FdoIFilterProcessor::Release();
+        virtual void ProcessBinaryExpression(FdoBinaryExpression& expr)
+            HandleExpr( FdoPtr<FdoExpression>(expr.GetLeftExpression()) );
+            HandleExpr( FdoPtr<FdoExpression>(expr.GetRightExpression()) );
+// Supress warnings C4100: 'expr' : unreferenced formal parameter
+#pragma warning( disable : 4100 )
+        virtual void ProcessBooleanValue(FdoBooleanValue& expr) {  }
+        virtual void ProcessByteValue(FdoByteValue& expr){   }
+        virtual void ProcessDateTimeValue(FdoDateTimeValue& expr){   }
+        virtual void ProcessDoubleValue(FdoDoubleValue& expr){   }
+        virtual void ProcessDecimalValue(FdoDecimalValue& expr){   }
+        virtual void ProcessInt16Value(FdoInt16Value& expr){  }
+        virtual void ProcessInt32Value(FdoInt32Value& expr){  }
+        virtual void ProcessInt64Value(FdoInt64Value& expr){  }
+        virtual void ProcessSingleValue(FdoSingleValue& expr){  }
+        virtual void ProcessStringValue(FdoStringValue& expr){  }
+        virtual void ProcessBLOBValue(FdoBLOBValue& expr){   }
+        virtual void ProcessCLOBValue(FdoCLOBValue& expr){  }
+        virtual void ProcessFunction(FdoFunction& expr)
+            FdoPtr<FdoExpressionCollection>col = expr.GetArguments();
+            for(int i=0; i<col->GetCount(); i++)
+                HandleExpr( FdoPtr<FdoExpression>(col->GetItem( i ) ) );
+        virtual void ProcessGeometryValue(FdoGeometryValue& expr){  }
+        virtual void ProcessParameter(FdoParameter& expr){  }
+        virtual void ProcessUnaryExpression(FdoUnaryExpression& expr)
+            HandleExpr( FdoPtr<FdoExpression>(expr.GetExpression()) );
+        virtual void ProcessBinaryLogicalOperator(FdoBinaryLogicalOperator& filter)
+            HandleFilter( FdoPtr<FdoFilter>(filter.GetLeftOperand()) );
+            HandleFilter( FdoPtr<FdoFilter>(filter.GetRightOperand()) );
+        virtual void ProcessComparisonCondition(FdoComparisonCondition& filter)
+            HandleExpr( FdoPtr<FdoExpression>(filter.GetLeftExpression()) );
+            HandleExpr( FdoPtr<FdoExpression>(filter.GetRightExpression()) );
+        virtual void ProcessDistanceCondition(FdoDistanceCondition& filter){  }
+        virtual void ProcessInCondition(FdoInCondition& filter)
+            ProcessIdentifier( *(FdoPtr<FdoIdentifier>(filter.GetPropertyName())) );
+        virtual void ProcessNullCondition(FdoNullCondition& filter)
+        virtual void ProcessSpatialCondition(FdoSpatialCondition& filter)
+			FdoSpatialOperations	op = filter.GetOperation();
+			bool					found = false;
+			int						numSpatialOps;
+			FdoSpatialOperations	*supportedSpatialOps = m_filterCapabilities->GetSpatialOperations( numSpatialOps );
+			for ( int i =0; i < numSpatialOps && !found; i++ )
+				found = ( op == supportedSpatialOps[i] );
+			if ( !found )
+				throw FdoException::Create(FdoException::NLSGetMessage(FDO_NLSID(FDO_105_UNSUPPORTED_SPATIAL_OPERATION)));
+        virtual void ProcessUnaryLogicalOperator(FdoUnaryLogicalOperator& filter)
+            HandleFilter( FdoPtr<FdoFilter>(filter.GetOperand()) );
+        virtual void ProcessIdentifier(FdoIdentifier& expr)
+			// Return in case ids validation not required.
+			if ( m_class == NULL )
+				return;
+             // This is used to validate the property names referenced in the filter.
+            FdoPtr<FdoPropertyDefinitionCollection> props = m_class->GetProperties();
+            FdoPtr<FdoReadOnlyPropertyDefinitionCollection> baseProps = m_class->GetBaseProperties();
+            FdoPtr<FdoPropertyDefinition> prop;
+            int length;
+            // If any of the identifiers is a decorated name of the form <obj proper>.<property>, then this is
+            // an association or object proeperty; assume it exist for now.
+            if( expr.GetScope( length ) && length > 0 )
+                return;
+			// Check properties
+            prop = props->FindItem( expr.GetName() );
+			bool	found = ( prop != NULL );
+            if( !found )
+				// Check base properties
+				try
+					prop = baseProps->GetItem( expr.GetName() );
+					found = true;
+				catch(FdoException *exp )
+					exp->Release();
+				// Check computed identifiers
+				if( !found && m_selectedIds )
+					FdoPtr<FdoIdentifier>	id = m_selectedIds->FindItem( expr.GetName() );
+					found = ( id != NULL );
+			if ( !found )
+				throw FdoException::Create(FdoException::NLSGetMessage(FDO_NLSID(FDO_81_IDENTIFIER_NOT_FOUND), expr.GetName()));
+        virtual void ProcessComputedIdentifier(FdoComputedIdentifier& expr)
+    FdoCommonFilterValidator  validator(cls, selIds, filterCapabilities);
+    filter->Process( &validator );
More information about the fdo-commits mailing list
