[fdo-commits] r2579 - trunk/Providers/GDAL/testwrk
svn_fdo at osgeo.org
Wed Feb 21 18:43:51 EST 2007
Author: warmerdam
Date: 2007-02-21 18:43:50 -0500 (Wed, 21 Feb 2007)
New Revision: 2579
Added:
trunk/Providers/GDAL/testwrk/fdorastutil.cpp
Removed:
trunk/Providers/GDAL/testwrk/rtest.cpp
trunk/Providers/GDAL/testwrk/GNUmakefile
trunk/Providers/GDAL/testwrk/RfpConfigExample.xml
preliminary effort to turn into a general fdo raster utility
Modified: trunk/Providers/GDAL/testwrk/GNUmakefile
--- trunk/Providers/GDAL/testwrk/GNUmakefile 2007-02-21 23:21:20 UTC (rev 2578)
+++ trunk/Providers/GDAL/testwrk/GNUmakefile 2007-02-21 23:43:50 UTC (rev 2579)
@@ -21,24 +21,21 @@
###### CONFIGURATION ######
# - fdocore top level sources directory
-FDOCORE = ${HOME}/dev/fdo/fdocore/_svn/fdocore
+FDOCORE = ${HOME}/fdobase
# - fdogdal top level sources directory
-FDOGDAL = ${HOME}/dev/fdo/fdogdal/_svn/fdogdal
+FDOGDAL = ${FDOCORE}/Providers/GDAL
# - fdocore installation prefix (default: /usr/local/fdo-3.3.0)
FDOCOREPREFIX = /usr/local/fdo-3.3.0
-# - fdogdal installation prefix
-FDOGDALPREFIX = ${HOME}/usr
# - GDAL installation prefix
-GDALPREFIX = ${HOME}/usr
+GDALPREFIX = ${FDOCORE}/Thirdparty/GDAL1.3/linux
###### END OF CONFIGURATION ######
CXX = g++
-CXXFLAGS = -g # -Wall -pedantic
+CXXFLAGS = -g # -Wall
FDO = ${FDOCORE}/Fdo
FDOUTILITIES = ${FDOCORE}/Utilities
@@ -67,12 +64,12 @@
-lxalan-c \
-lxalanMsg
-all : rtest
+all : fdorastutil
-rtest: rtest.cpp
- ${CXX} rtest.cpp -o $@ ${CXXFLAGS} ${INCLUDES} ${LIBDIRS} ${LIBS}
+fdorastutil: fdorastutil.cpp
+ ${CXX} fdorastutil.cpp -o $@ ${CXXFLAGS} ${INCLUDES} ${LIBDIRS} ${LIBS}
clean :
${RM} ~*
${RM} *.o
- ${RM} rtest
+ ${RM} fdorastutil
Modified: trunk/Providers/GDAL/testwrk/RfpConfigExample.xml
--- trunk/Providers/GDAL/testwrk/RfpConfigExample.xml 2007-02-21 23:21:20 UTC (rev 2578)
+++ trunk/Providers/GDAL/testwrk/RfpConfigExample.xml 2007-02-21 23:43:50 UTC (rev 2579)
@@ -71,7 +71,7 @@
<!-- Schema Overrides for Photo Feature Class -->
<complexType name="PhotoType">
<RasterDefinition name="photos">
- <Location name="/home/warmerda/openev">
+ <Location name="/home/warmerda">
<Feature name="Airport2">
<band name="RGB" number="1">
<Image name="utm.tif">
Copied: trunk/Providers/GDAL/testwrk/fdorastutil.cpp (from rev 2576, trunk/Providers/GDAL/testwrk/rtest.cpp)
--- trunk/Providers/GDAL/testwrk/fdorastutil.cpp (rev 0)
+++ trunk/Providers/GDAL/testwrk/fdorastutil.cpp 2007-02-21 23:43:50 UTC (rev 2579)
@@ -0,0 +1,731 @@
+ * Copyright (C) 2006 Frank Warmerdam
+ * This library is free software; you can redistribute it and/or
+ * modify it under the terms of version 2.1 of the GNU Lesser
+ * General Public License as published by the Free Software Foundation.
+ * This library is distributed in the hope that it will be useful,
+ * but WITHOUT ANY WARRANTY; without even the implied warranty of
+ * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+ * Lesser General Public License for more details.
+ * You should have received a copy of the GNU Lesser General Public
+ * License along with this library; if not, write to the Free Software
+ * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
+ * Purpose:
+ * This is a commandline utility to interogate information about a raster
+ * connection, and to dump read rasters to TIFF files.
+#include <Fdo.h>
+#include <FdoCommonOSUtil.h>
+#include <FdoCommonStringUtil.h>
+#include <FdoCommonMiscUtil.h>
+#include <FdoCommonFile.h>
+#include <Fdo/Raster/RasterDataModel.h>
+#include <gdal.h>
+#include <ogr_api.h>
+#include <cpl_conv.h>
+#include <cpl_string.h>
+static void TranslateTo( FdoPtr<FdoIRaster> raster,
+ const char *pszOutFilename );
+static void ReportSchemas( FdoPtr<FdoIConnection> conn, FdoStringP &FeatureClassName,
+ FdoStringP &FeatureIdName, FdoStringP &RasterName,
+ int bActuallyReport );
+/* Usage() */
+static void Usage()
+ printf( "\n"
+ "Usage: fdorastutil [-schema] [-sc] [-dump] [-nofeatures]\n"
+ " [-p <provider>] [-fc <featureclass>]\n"
+ " [-config <file>] [<target>]\n"
+ "\n"
+ " -schema: Report schema\n"
+ " -sc: Report spatial contexts.\n"
+ " -dump: Dump rasters to TIFF files.\n"
+ " -nofeatures: Don't report feature records.\n"
+ " -p <provider>: Provider. ie. OSGeo.Gdal.3.3\n"
+ " -fc <featureclass>: feature class to report/dump (default is first)\n"
+ " -config <file>: Use XML configuration file for connection.\n"
+ " <target>: Use file or directory as DefaultRasterFileLocation for\n"
+ " connection.\n" );
+ exit( 1 );
+/* main() */
+int main( int argc, char ** argv )
+ const char *targetConfig = NULL;
+ const char *targetFileDir = NULL;
+ int bReportSchema = FALSE;
+ int bReportSpatialContexts = FALSE;
+ int bReportFeatures = TRUE;
+ int bTranslateFeatures = FALSE;
+ int iArg;
+ FdoStringP provider = "OSGeo.Gdal.3.3";
+ FdoStringP FeatureClassName;
+/* Process arguments. */
+ for( iArg = 1; iArg < argc; iArg++ )
+ if( EQUAL(argv[iArg],"-schema") )
+ bReportSchema = TRUE;
+ else if( EQUAL(argv[iArg],"-sc") )
+ bReportSpatialContexts = TRUE;
+ else if( EQUAL(argv[iArg],"-dump") )
+ bTranslateFeatures = TRUE;
+ else if( EQUAL(argv[iArg],"-nofeatures") )
+ bReportFeatures = FALSE;
+ else if( iArg < argc-1 && EQUAL(argv[iArg],"-p") )
+ provider = argv[++iArg];
+ else if( iArg < argc-1 && EQUAL(argv[iArg],"-fc") )
+ FeatureClassName = argv[++iArg];
+ else if( iArg < argc-1 && EQUAL(argv[iArg],"-config") )
+ targetConfig = argv[++iArg];
+ else if( argv[iArg][0] == '-' )
+ Usage();
+ else if( targetFileDir == NULL )
+ targetFileDir = argv[iArg];
+ else
+ Usage();
+ if( targetConfig == NULL && targetFileDir == NULL )
+ Usage();
+/* Setup connection */
+ // Get instance of the connection manager
+ FdoPtr<IConnectionManager> manager;
+ manager = FdoFeatureAccessManager::GetConnectionManager();
+ if (0 == manager)
+ printf("GetConnectionManager returned nullptr.\n");
+ return 0;
+ // Call the manager’s CreateConnection() method using the provider
+ // internal name as an argument to obtain a connection object.
+ FdoPtr<FdoIConnection> conn;
+ conn = manager->CreateConnection (provider);
+ if (0 == conn)
+ printf("CreateConnection returned nullptr.\n");
+ return 0;
+/* Setup for a configuration file. */
+ if( targetConfig != NULL )
+ printf("Setting up connection config file: %s\n", targetConfig );
+ try
+ FdoStringP configFile(targetConfig);
+ FdoStringP configMode(L"rb");
+ FdoIoFileStreamP configStream =
+ FdoIoFileStream::Create( configFile, configMode );
+ conn->SetConfiguration( configStream );
+ catch (FdoException* ge)
+ printf( "Trapped exception: %ls\n", ge->GetExceptionMessage() );
+/* Setup for a file for directory. */
+ else
+ try
+ FdoStringP defaultLocation;
+ defaultLocation = L"DefaultRasterFileLocation=";
+ defaultLocation += targetFileDir;
+ conn->SetConnectionString (defaultLocation);
+ exit( 1 );
+/* Open the connection. */
+ try
+ FdoConnectionState state = conn->Open ();
+ if( state != FdoConnectionState_Open )
+ printf( "State = %d, not open.\n", (int) state );
+ conn->Close();
+ exit( 1 );
+ exit( 1 );
+/* Describe layer. */
+ FdoStringP FeatureIdName;
+ FdoStringP RasterName;
+ ReportSchemas( conn, FeatureClassName, FeatureIdName, RasterName,
+ bReportSchema );
+/* Actually scan raster records, reporting on them. */
+ try
+ FdoPtr<FdoISelect> select = (FdoISelect*)conn->CreateCommand (FdoCommandType_Select);
+ select->SetFeatureClassName (FeatureClassName);
+ FdoPtr<FdoIFeatureReader> reader = select->Execute ();
+ int iCounter = 0;
+ while (reader->ReadNext ())
+ FdoPtr<FdoIRaster> raster;
+ printf( "Feature:\n" );
+ printf( " Id = %ls\n", reader->GetString( FeatureIdName ) );
+ raster = reader->GetRaster( RasterName );
+ if( raster != NULL || !raster->IsNull() )
+ FdoPtr<FdoRasterDataModel> data_model;
+ printf( " Raster:\n" );
+ printf( " bands = %d, current = %d\n",
+ raster->GetNumberOfBands(),
+ raster->GetCurrentBand() );
+ printf( " size = %dx%d\n",
+ raster->GetImageXSize(),
+ raster->GetImageYSize() );
+ data_model = raster->GetDataModel();
+ if( data_model != NULL )
+ printf( " ModelType = %d\n",
+ (int) data_model->GetDataModelType() );
+ printf( " BitsPerPixel = %d\n",
+ data_model->GetBitsPerPixel() );
+ printf( " Organization = %d\n",
+ (int) data_model->GetOrganization() );
+ printf( " Data Type = %d\n",
+ (int) data_model->GetDataType() );
+ // Null (NODATA)
+ FdoDataValue* nullVal = raster->GetNullPixelValue();
+ if( nullVal != NULL && !nullVal->IsNull() )
+ if( nullVal->GetDataType() == FdoDataType_Byte )
+ FdoPtr<FdoByteValue> val = static_cast<FdoByteValue*>(nullVal);
+ printf( " NULL (Byte) = %d\n", val->GetByte() );
+ else if( nullVal->GetDataType() == FdoDataType_Int16 )
+ FdoPtr<FdoInt16Value> val = static_cast<FdoInt16Value*>(nullVal);
+ printf( " NULL (Int16) = %d\n", val->GetInt16() );
+ else if( nullVal->GetDataType() == FdoDataType_Int32 )
+ FdoPtr<FdoInt32Value> val = static_cast<FdoInt32Value*>(nullVal);
+ printf( " NULL (Int32) = %d\n", val->GetInt32() );
+ else if( nullVal->GetDataType() == FdoDataType_Single )
+ FdoPtr<FdoSingleValue> val = static_cast<FdoSingleValue*>(nullVal);
+ printf( " NULL (float) = %g\n", val->GetSingle() );
+ else if( nullVal->GetDataType() == FdoDataType_Double )
+ FdoPtr<FdoDoubleValue> val = static_cast<FdoDoubleValue*>(nullVal);
+ printf( " NULL (double) = %g\n", val->GetDouble() );
+ // Report boundary.
+ FdoPtr<FdoFgfGeometryFactory> geomFactory =
+ FdoFgfGeometryFactory::GetInstance();
+ FdoPtr<FdoByteArray> ba = raster->GetBounds();
+ FdoPtr<FdoIGeometry> geometry = geomFactory->CreateGeometryFromFgf(ba);
+ FdoStringP wkt = geometry->GetText();
+ printf( " Bounds = %s\n", (const char *) wkt );
+ try
+ FdoPtr<FdoIRasterPropertyDictionary> propDict = raster->GetAuxiliaryProperties();
+ FdoPtr<FdoDataValue> pal = propDict->GetProperty(L"Palette");
+ FdoLOBValue* palLOB = static_cast<FdoLOBValue*>(pal.p);
+ FdoByteArray *palArray = palLOB->GetData();
+ int iColor;
+ for( iColor = 0; iColor < palArray->GetCount(); iColor++ )
+ printf( " Palette[%d] = %d,%d,%d,%d\n",
+ iColor,
+ (*palArray)[ iColor*4 + 0 ],
+ (*palArray)[ iColor*4 + 1 ],
+ (*palArray)[ iColor*4 + 2 ],
+ (*palArray)[ iColor*4 + 3 ] );
+ catch(...)
+ // For now, only translate the first file.
+ if( iCounter == 0 && bTranslateFeatures )
+ TranslateTo( raster,
+ CPLString().Printf( "out_%d.tif", iCounter) );
+ iCounter++;
+ if( iCounter == 0 )
+ printf( "No features found for class %s.\n",
+ (const char *) FeatureClassName );
+ conn->Close();
+/* FdoStringToReadable() */
+/* This function is to support debugging. */
+const char *FdoStringToReadable( FdoString *pInput )
+ static FdoStringP oStringPerm;
+ FdoStringP oStringTemp( pInput );
+ oStringPerm = oStringTemp;
+ return (const char *) oStringPerm;
+/* TranslateTo() */
+/* Translate an IRaster to a GeoTIFF file. */
+ FdoPtr<FdoRasterDataModel> data_model = raster->GetDataModel();
+ GDALDriverH hOutDriver = GDALGetDriverByName( "GTiff" );
+ GDALDataType eOutType;
+ if( data_model == NULL )
+ return;
+ GDALAllRegister();
+/* Set alternate render size. */
+// raster->SetImageXSize(200);
+// raster->SetImageYSize(200);
+/* Set alternate bounds. */
+#ifdef notdef
+ FdoStringP wkt = L"POLYGON ((440720 3720600, 471440 3720600, 471440 3741320, 440720 3741320, 440720 3720600))";
+ FdoPtr<FdoAgfGeometryFactory> geomFactory =
+ FdoAgfGeometryFactory::GetInstance();
+ geomFactory->CreateGeometry(wkt);
+ FdoPtr<FdoByteArray> ba = geomFactory->GetAgf( geometry );
+ raster->SetBounds( ba );
+ ba = raster->GetBounds();
+ geometry = geomFactory->CreateGeometryFromAgf(ba);
+ wkt = geometry->GetText();
+#endif
+/* Determine number of bands. */
+ int nBandCount;
+ if( data_model->GetDataModelType() == FdoRasterDataModelType_Gray )
+ nBandCount = 1;
+ else if( data_model->GetDataModelType() == FdoRasterDataModelType_RGB )
+ nBandCount = 3;
+ else if( data_model->GetDataModelType() == FdoRasterDataModelType_RGBA )
+ nBandCount = 4;
+ else if( data_model->GetDataModelType() == FdoRasterDataModelType_Palette )
+ nBandCount = 1;
+ else if( data_model->GetDataModelType() == FdoRasterDataModelType_Bitonal )
+ fprintf( stderr,
+ "Bitonal RasterDataModelType not supported by rtest.\n" );
+ return;
+ else
+ fprintf( stderr, "Unrecognised RasterDataModelType\n" );
+ return;
+/* Determine target data type. */
+ if( data_model->GetBitsPerPixel() == 8 * nBandCount )
+ eOutType = GDT_Byte;
+ else if( data_model->GetBitsPerPixel() == 16 * nBandCount
+ && data_model->GetDataType() == FdoRasterDataType_Integer )
+ eOutType = GDT_Int16;
+ && data_model->GetDataType() == FdoRasterDataType_UnsignedInteger)
+ eOutType = GDT_UInt16;
+ else if( data_model->GetBitsPerPixel() == 32 * nBandCount
+ && data_model->GetDataType() == FdoRasterDataType_Integer)
+ eOutType = GDT_Int32;
+ eOutType = GDT_UInt32;
+ && data_model->GetDataType() == FdoRasterDataType_Float)
+ eOutType = GDT_Float32;
+ else if( data_model->GetBitsPerPixel() == 64 * nBandCount
+ eOutType = GDT_Float64;
+ else
+ fprintf( stderr,
+ "Unable to determine GDAL data type from data model.\n" );
+ return;
+/* Create the output file. */
+ GDALDatasetH hOutDS;
+ hOutDS = GDALCreate( hOutDriver, pszOutFilename,
+ raster->GetImageXSize(), raster->GetImageYSize(),
+ nBandCount, eOutType, NULL );
+ if( hOutDS == NULL )
+ return;
+/* Create the data stream to read from. */
+ FdoPtr<FdoIStreamReaderTmpl<FdoByte> > stream
+ = dynamic_cast<FdoIStreamReaderTmpl<FdoByte>*>(raster->GetStreamReader());
+/* Create buffer for one scanline of data. */
+ FdoByte *pabyLineData;
+ int nComponentSize = (GDALGetDataTypeSize(eOutType) / 8);
+ int nLineData = nBandCount * raster->GetImageXSize() * nComponentSize;
+ pabyLineData = (FdoByte *) CPLMalloc(nLineData);
+/* Process all scanlines. */
+ int iLine;
+ stream->Reset();
+ for( iLine = 0; iLine < raster->GetImageYSize(); iLine++ )
+ if( stream->ReadNext( pabyLineData, 0, nLineData )
+ != nLineData )
+ fprintf( stderr, "Got an error or short buffer in ReadNext()\n" );
+ break;
+ if( GDALDatasetRasterIO( hOutDS, GF_Write,
+ 0, iLine, raster->GetImageXSize(), 1,
+ pabyLineData, raster->GetImageXSize(), 1,
+ eOutType, nBandCount, NULL,
+ nComponentSize * nBandCount,
+ nLineData,
+ nComponentSize )
+ != CE_None )
+ break;
+/* Close and cleanup. */
+ GDALClose( hOutDS );
+/* ReportSchemas() */
+ FdoStringP &FeatureClassName,
+ FdoStringP &RasterName,
+ try
+ FdoPtr<FdoIDescribeSchema> describe =
+ (FdoIDescribeSchema*)conn->CreateCommand(
+ FdoCommandType_DescribeSchema);
+ FdoPtr<FdoFeatureSchemaCollection> schemas = describe->Execute ();
+ FdoFeatureSchema* schema = schemas->GetItem (0);
+ if( bActuallyReport )
+ printf ("Schema: %ls\n", schema->GetName());
+ if ((schema->GetDescription () != NULL)
+ && bActuallyReport
+ && (0 != wcscmp (schema->GetDescription (), L"")))
+ printf (" Description: %ls\n", schema->GetDescription ());
+ FdoClassCollection* classes = schema->GetClasses ();
+ for (int j = 0; j < classes->GetCount (); j++)
+ FdoClassDefinition* cls = classes->GetItem (j);
+ // Output basic class info:
+ if (FdoClassType_FeatureClass == cls->GetClassType ())
+ printf (" Feature Class: %ls\n", cls->GetName ());
+ else
+ printf (" Class: %ls\n", cls->GetName ());
+ // pick first feature class encountered.
+ if( wcscmp(FeatureClassName,L"") == 0 )
+ FeatureClassName = cls->GetName();
+ if ((cls->GetDescription () != NULL)
+ && (0 != wcscmp (cls->GetDescription (), L""))
+ && bActuallyReport )
+ printf (" Description: %ls\n", cls->GetDescription ());
+ FdoPtr<FdoClassCapabilities> classCapabilities = cls->GetCapabilities();
+ printf (" Class Capabilities:\n");
+ if (classCapabilities == NULL)
+ printf (" (Not available).\n");
+ else
+ printf (" Supports locking: %s\n", classCapabilities->SupportsLocking() ? "yes" : "no");
+ printf (" Supports long transactions: %s\n", classCapabilities->SupportsLongTransactions() ? "yes" : "no");
+ // Output identity properties:
+ FdoDataPropertyDefinitionCollection* identity = cls->GetIdentityProperties ();
+ for (int k = 0; k < identity->GetCount (); k++)
+ FdoDataPropertyDefinition* definition = identity->GetItem (k);
+ FeatureIdName = definition->GetName();
+ printf (" Id: %ls\n", definition->GetName ());
+ if ((definition->GetDescription () != NULL)
+ && (0 != wcscmp (definition->GetDescription (), L"")))
+ printf (" Description: %ls\n", definition->GetDescription ());
+ printf (" Type: %d Length: %d Precision: %d %ls\n",
+ (int) definition->GetDataType (),
+ definition->GetLength (),
+ definition->GetPrecision (),
+ definition->GetNullable () ? L"Nullable" : L"NotNull");
+ definition->Release ();
+ // Output regular properties:
+ FdoPropertyDefinitionCollection* properties = cls->GetProperties ();
+ for (int k = 0; k < properties->GetCount (); k++)
+ FdoPropertyDefinition* definition = properties->GetItem (k);
+ if (definition->GetPropertyType () == FdoPropertyType_RasterProperty)
+ FdoRasterPropertyDefinition *r_definition =
+ (FdoRasterPropertyDefinition*) definition;
+ RasterName = definition->GetName();
+ if( !bActuallyReport )
+ continue;
+ if (definition->GetPropertyType () == FdoPropertyType_DataProperty)
+ FdoDataPropertyDefinition* data_definition = (FdoDataPropertyDefinition*)definition;
+ printf (" Property: %ls\n", definition->GetName ());
+ if (!identity->Contains (data_definition))
+ if ((data_definition->GetDescription () != NULL) && (0 != wcscmp (data_definition->GetDescription (), L"")))
+ printf (" Description: %ls\n", data_definition->GetDescription ());
+ (int) data_definition->GetDataType (),
+ data_definition->GetLength (),
+ data_definition->GetPrecision (),
+ data_definition->GetNullable () ? L"Nullable" : L"NotNull");
+ else
+ printf( " (no data definition)\n" );
+ else if (definition->GetPropertyType () == FdoPropertyType_ObjectProperty)
+ printf (" Object Property: %ls\n", definition->GetName ());
+ if ((definition->GetDescription () != NULL) && (0 != wcscmp (definition->GetDescription (), L"")))
+ else if (definition->GetPropertyType () == FdoPropertyType_GeometricProperty)
+ FdoGeometricPropertyDefinition* geometry_definition = (FdoGeometricPropertyDefinition*)definition;
+ printf (" Geometric Property: %ls\n", geometry_definition->GetName ());
+ if ((geometry_definition->GetDescription () != NULL) && (0 != wcscmp (geometry_definition->GetDescription (), L"")))
+ printf (" Description: %ls\n", geometry_definition->GetDescription ());
+ int types = geometry_definition->GetGeometryTypes ();
+ if (0 != (types & FdoGeometricType_Point))
+ printf (" FdoGeometricType_Point types allowed\n");
+ if (0 != (types & FdoGeometricType_Curve))
+ printf (" FdoGeometricType_Curve types allowed\n");
+ if (0 != (types & FdoGeometricType_Surface))
+ printf (" FdoGeometricType_Surface types allowed\n");
+ if (0 != (types & FdoGeometricType_Solid))
+ printf (" FdoGeometricType_Solid types allowed\n");
+ else if (definition->GetPropertyType () == FdoPropertyType_RasterProperty)
+ FdoRasterPropertyDefinition *r_definition = (FdoRasterPropertyDefinition*) definition;
+ FdoStringP srs;
+ FdoRasterDataModel *data_model;
+ printf (" Raster: %ls\n", definition->GetName ());
+ srs = r_definition->GetSpatialContextAssociation();
+ if( srs != NULL )
+ printf( " SRS = %s\n", (const char *) srs );
+ else
+ printf( " SRS = NULL\n" );
+ data_model = r_definition->GetDefaultDataModel();
+ printf( " data_model = %p\n", data_model );
+ printf( " SRS = %ls\n",
+ r_definition->GetSpatialContextAssociation() );
+ else
+ printf (" Unsupported Property: %ls\n", definition->GetName ());
+ identity->Release ();
+ properties->Release ();
+ // Output schema attribute dictionary:
+ FdoSchemaAttributeDictionary* dictionary = cls->GetAttributes ();
+ int count;
+ const wchar_t **names = dictionary->GetAttributeNames (count);
+ if ((0 != count) && (NULL != names) && bActuallyReport )
+ printf (" MetaData:");
+ const wchar_t *name = *names;
+ for (int i = 0; i < count; i++)
+ if (0 != i)
+ printf (",");
+ const wchar_t* value = dictionary->GetAttributeValue (name);
+ printf (" %ls=%ls", name, value);
+ name++;
+ printf ("\n");
+ dictionary->Release ();
+ cls->Release ();
+ classes->Release ();
+ schema->Release ();
+ exit( 1 );
Deleted: trunk/Providers/GDAL/testwrk/rtest.cpp
--- trunk/Providers/GDAL/testwrk/rtest.cpp 2007-02-21 23:21:20 UTC (rev 2578)
+++ trunk/Providers/GDAL/testwrk/rtest.cpp 2007-02-21 23:43:50 UTC (rev 2579)
@@ -1,606 +0,0 @@
- * Copyright (C) 2004-2006 Autodesk, Inc.
- * This library is free software; you can redistribute it and/or
- * modify it under the terms of version 2.1 of the GNU Lesser
- * General Public License as published by the Free Software Foundation.
- * This library is distributed in the hope that it will be useful,
- * but WITHOUT ANY WARRANTY; without even the implied warranty of
- * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
- * Lesser General Public License for more details.
- * You should have received a copy of the GNU Lesser General Public
- * License along with this library; if not, write to the Free Software
- * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
-#include <malloc.h>
-#include <stdlib.h>
-#include <math.h>
-#include <time.h>
-#include <dlfcn.h>
-#include <Fdo.h>
-#include <FdoCommonOSUtil.h>
-#include <FdoCommonStringUtil.h>
-#include <FdoCommonMiscUtil.h>
-#include <FdoCommonFile.h>
-#include <Fdo/Raster/RasterDataModel.h>
-#include <gdal.h>
-#include <ogr_api.h>
-#include <cpl_conv.h>
-#include <cpl_string.h>
-static void TranslateTo( FdoPtr<FdoIRaster> raster,
- const char *pszOutFilename );
-/* main() */
-int main( int argc, char ** argv )
-/* Setup connection */
- // Get instance of the connection manager
- FdoPtr<IConnectionManager> manager;
- manager = FdoFeatureAccessManager::GetConnectionManager();
- if (0 == manager)
- printf("GetConnectionManager returned nullptr.\n");
- return 0;
- // Call the manager’s CreateConnection() method using the provider
- // internal name as an argument to obtain a connection object.
- FdoPtr<FdoIConnection> conn;
- conn = manager->CreateConnection (L"OSGeo.Gdal.3.3");
- if (0 == conn)
- printf("CreateConnection returned nullptr.\n");
- return 0;
- printf( "conn = %p\n", (void *) conn );
-/* Setup connection configuration if we don't have a filename */
-/* supplied on the commandline. */
- if( argc < 2 )
- printf("Setting up connection config file: RfpConfigExample.xml\n");
- try
- FdoStringP configFile(L"RfpConfigExample.xml");
- FdoStringP configMode(L"rb");
- FdoIoFileStreamP configStream =
- FdoIoFileStream::Create( configFile, configMode );
- conn->SetConfiguration( configStream );
- catch (FdoException* ge)
- printf( "Trapped exception: %ls\n", ge->GetExceptionMessage() );
-/* Open specific shapefile. */
- try
- if( argc == 2 )
- FdoStringP defaultLocation;
- defaultLocation = L"DefaultRasterFileLocation=";
- defaultLocation += argv[1];
- conn->SetConnectionString (defaultLocation);
- FdoConnectionState state = conn->Open ();
- if( state != FdoConnectionState_Open )
- printf( "State = %d, not open.\n", (int) state );
- conn->Close();
- exit( 1 );
-/* Describe layer. */
- FdoStringP FeatureClassName;
- FdoStringP FeatureIdName;
- FdoStringP RasterName;
- try
- FdoPtr<FdoIDescribeSchema> describe =
- (FdoIDescribeSchema*)conn->CreateCommand(
- FdoCommandType_DescribeSchema);
- FdoPtr<FdoFeatureSchemaCollection> schemas = describe->Execute ();
- FdoFeatureSchema* schema = schemas->GetItem (0);
- printf ("Schema: %ls\n", schema->GetName());
- if ((schema->GetDescription () != NULL)
- && (0 != wcscmp (schema->GetDescription (), L"")))
- printf (" Description: %ls\n", schema->GetDescription ());
- FdoClassCollection* classes = schema->GetClasses ();
- for (int j = 0; j < classes->GetCount (); j++)
- FdoClassDefinition* cls = classes->GetItem (j);
- // Output basic class info:
- if (FdoClassType_FeatureClass == cls->GetClassType ())
- printf (" Feature Class: %ls\n", cls->GetName ());
- else
- printf (" Class: %ls\n", cls->GetName ());
- FeatureClassName = cls->GetName();
- if ((cls->GetDescription () != NULL) && (0 != wcscmp (cls->GetDescription (), L"")))
- printf (" Description: %ls\n", cls->GetDescription ());
- FdoPtr<FdoClassCapabilities> classCapabilities = cls->GetCapabilities();
- printf (" Class Capabilities:\n");
- if (classCapabilities == NULL)
- printf (" (Not available).\n");
- else
- printf (" Supports locking: %s\n", classCapabilities->SupportsLocking() ? "yes" : "no");
- printf (" Supports long transactions: %s\n", classCapabilities->SupportsLongTransactions() ? "yes" : "no");
- // Output identity properties:
- FdoDataPropertyDefinitionCollection* identity = cls->GetIdentityProperties ();
- for (int k = 0; k < identity->GetCount (); k++)
- FdoDataPropertyDefinition* definition = identity->GetItem (k);
- printf (" Id: %ls\n", definition->GetName ());
- FeatureIdName = definition->GetName();
- if ((definition->GetDescription () != NULL) && (0 != wcscmp (definition->GetDescription (), L"")))
- printf (" Description: %ls\n", definition->GetDescription ());
- printf (" Type: %d Length: %d Precision: %d %ls\n",
- (int) definition->GetDataType (),
- definition->GetLength (),
- definition->GetPrecision (),
- definition->GetNullable () ? L"Nullable" : L"NotNull");
- definition->Release ();
- // Output regular properties:
- FdoPropertyDefinitionCollection* properties = cls->GetProperties ();
- for (int k = 0; k < properties->GetCount (); k++)
- FdoPropertyDefinition* definition = properties->GetItem (k);
- if (definition->GetPropertyType () == FdoPropertyType_DataProperty)
- FdoDataPropertyDefinition* data_definition = (FdoDataPropertyDefinition*)definition;
- printf (" Property: %ls\n", definition->GetName ());
- if (!identity->Contains (data_definition))
- if ((data_definition->GetDescription () != NULL) && (0 != wcscmp (data_definition->GetDescription (), L"")))
- printf (" Description: %ls\n", data_definition->GetDescription ());
- (int) data_definition->GetDataType (),
- data_definition->GetLength (),
- data_definition->GetPrecision (),
- data_definition->GetNullable () ? L"Nullable" : L"NotNull");
- else
- printf( " (no data definition)\n" );
- else if (definition->GetPropertyType () == FdoPropertyType_ObjectProperty)
- printf (" Object Property: %ls\n", definition->GetName ());
- else if (definition->GetPropertyType () == FdoPropertyType_GeometricProperty)
- FdoGeometricPropertyDefinition* geometry_definition = (FdoGeometricPropertyDefinition*)definition;
- printf (" Geometric Property: %ls\n", geometry_definition->GetName ());
- if ((geometry_definition->GetDescription () != NULL) && (0 != wcscmp (geometry_definition->GetDescription (), L"")))
- printf (" Description: %ls\n", geometry_definition->GetDescription ());
- int types = geometry_definition->GetGeometryTypes ();
- if (0 != (types & FdoGeometricType_Point))
- printf (" FdoGeometricType_Point types allowed\n");
- if (0 != (types & FdoGeometricType_Curve))
- printf (" FdoGeometricType_Curve types allowed\n");
- if (0 != (types & FdoGeometricType_Surface))
- printf (" FdoGeometricType_Surface types allowed\n");
- if (0 != (types & FdoGeometricType_Solid))
- printf (" FdoGeometricType_Solid types allowed\n");
- else if (definition->GetPropertyType () == FdoPropertyType_RasterProperty)
- FdoRasterPropertyDefinition *r_definition = (FdoRasterPropertyDefinition*) definition;
- FdoStringP srs;
- FdoRasterDataModel *data_model;
- printf (" Raster: %ls\n", definition->GetName ());
- RasterName = definition->GetName();
- srs = r_definition->GetSpatialContextAssociation();
- if( srs != NULL )
- printf( " SRS = %p\n", (const char *) srs );
- else
- printf( " SRS = NULL\n" );
- data_model = r_definition->GetDefaultDataModel();
- printf( " data_model = %p\n", data_model );
- if( data_model != NULL )
- printf( " ModelType = %d\n",
- (int) data_model->GetDataModelType() );
- printf( " BitsPerPixel = %d\n",
- data_model->GetBitsPerPixel() );
- printf( " Organization = %d\n",
- (int) data_model->GetOrganization() );
- printf( " Data Type = %d\n",
- (int) data_model->GetDataType() );
- printf( " SRS = %ls\n",
- r_definition->GetSpatialContextAssociation() );
- else
- printf (" Unsupported Property: %ls\n", definition->GetName ());
- identity->Release ();
- properties->Release ();
- // Output schema attribute dictionary:
- FdoSchemaAttributeDictionary* dictionary = cls->GetAttributes ();
- int count;
- const wchar_t **names = dictionary->GetAttributeNames (count);
- if ((0 != count) && (NULL != names))
- printf (" MetaData:");
- const wchar_t *name = *names;
- for (int i = 0; i < count; i++)
- if (0 != i)
- printf (",");
- const wchar_t* value = dictionary->GetAttributeValue (name);
- printf (" %ls=%ls", name, value);
- name++;
- printf ("\n");
- dictionary->Release ();
- cls->Release ();
- classes->Release ();
- schema->Release ();
-/* Setup query. */
- try
- FdoPtr<FdoISelect> select = (FdoISelect*)conn->CreateCommand (FdoCommandType_Select);
- select->SetFeatureClassName (FeatureClassName);
- FdoPtr<FdoIFeatureReader> reader = select->Execute ();
- int iCounter = 0;
- while (reader->ReadNext ())
- FdoPtr<FdoIRaster> raster;
- printf( "Feature:\n" );
- printf( " Id = %ls\n", reader->GetString( FeatureIdName ) );
- raster = reader->GetRaster( RasterName );
- if( raster != NULL || !raster->IsNull() )
- FdoPtr<FdoRasterDataModel> data_model;
- printf( " Raster:\n" );
- printf( " bands = %d, current = %d\n",
- raster->GetNumberOfBands(),
- raster->GetCurrentBand() );
- printf( " size = %dx%d\n",
- raster->GetImageXSize(),
- raster->GetImageYSize() );
- data_model = raster->GetDataModel();
- // Null (NODATA)
- FdoDataValue* nullVal = raster->GetNullPixelValue();
- if( nullVal != NULL && !nullVal->IsNull() )
- if( nullVal->GetDataType() == FdoDataType_Byte )
- FdoPtr<FdoByteValue> val = static_cast<FdoByteValue*>(nullVal);
- printf( " NULL (Byte) = %d\n", val->GetByte() );
- else if( nullVal->GetDataType() == FdoDataType_Int16 )
- FdoPtr<FdoInt16Value> val = static_cast<FdoInt16Value*>(nullVal);
- printf( " NULL (Int16) = %d\n", val->GetInt16() );
- else if( nullVal->GetDataType() == FdoDataType_Int32 )
- FdoPtr<FdoInt32Value> val = static_cast<FdoInt32Value*>(nullVal);
- printf( " NULL (Int32) = %d\n", val->GetInt32() );
- else if( nullVal->GetDataType() == FdoDataType_Single )
- FdoPtr<FdoSingleValue> val = static_cast<FdoSingleValue*>(nullVal);
- printf( " NULL (float) = %g\n", val->GetSingle() );
- else if( nullVal->GetDataType() == FdoDataType_Double )
- FdoPtr<FdoDoubleValue> val = static_cast<FdoDoubleValue*>(nullVal);
- printf( " NULL (double) = %g\n", val->GetDouble() );
- // Report boundary.
- FdoPtr<FdoFgfGeometryFactory> geomFactory =
- FdoFgfGeometryFactory::GetInstance();
- FdoPtr<FdoByteArray> ba = raster->GetBounds();
- FdoPtr<FdoIGeometry> geometry = geomFactory->CreateGeometryFromFgf(ba);
- FdoStringP wkt = geometry->GetText();
- printf( " Bounds = %s\n", (const char *) wkt );
- try
- FdoPtr<FdoIRasterPropertyDictionary> propDict = raster->GetAuxiliaryProperties();
- FdoPtr<FdoDataValue> pal = propDict->GetProperty(L"Palette");
- FdoLOBValue* palLOB = static_cast<FdoLOBValue*>(pal.p);
- FdoByteArray *palArray = palLOB->GetData();
- int iColor;
- for( iColor = 0; iColor < palArray->GetCount(); iColor++ )
- printf( " Palette[%d] = %d,%d,%d,%d\n",
- iColor,
- (*palArray)[ iColor*4 + 0 ],
- (*palArray)[ iColor*4 + 1 ],
- (*palArray)[ iColor*4 + 2 ],
- (*palArray)[ iColor*4 + 3 ] );
- catch(...)
- // For now, only translate the first file.
- if( iCounter == 0 )
- TranslateTo( raster,
- CPLString().Printf( "out_%d.tif", iCounter++) );
- conn->Close();
-/* FdoStringToReadable() */
-/* This function is to support debugging. */
-const char *FdoStringToReadable( FdoString *pInput )
- static FdoStringP oStringPerm;
- FdoStringP oStringTemp( pInput );
- oStringPerm = oStringTemp;
- return (const char *) oStringPerm;
-/* TranslateTo() */
-/* Translate an IRaster to a GeoTIFF file. */
- FdoPtr<FdoRasterDataModel> data_model = raster->GetDataModel();
- GDALDriverH hOutDriver = GDALGetDriverByName( "GTiff" );
- GDALDataType eOutType;
- if( data_model == NULL )
- return;
- GDALAllRegister();
-/* Set alternate render size. */
-// raster->SetImageXSize(200);
-// raster->SetImageYSize(200);
-/* Set alternate bounds. */
-#ifdef notdef
- FdoStringP wkt = L"POLYGON ((440720 3720600, 471440 3720600, 471440 3741320, 440720 3741320, 440720 3720600))";
- FdoPtr<FdoAgfGeometryFactory> geomFactory =
- FdoAgfGeometryFactory::GetInstance();
- geomFactory->CreateGeometry(wkt);
- FdoPtr<FdoByteArray> ba = geomFactory->GetAgf( geometry );
- raster->SetBounds( ba );
- ba = raster->GetBounds();
- geometry = geomFactory->CreateGeometryFromAgf(ba);
- wkt = geometry->GetText();
-#endif
-/* Determine number of bands. */
- int nBandCount;
- if( data_model->GetDataModelType() == FdoRasterDataModelType_Gray )
- nBandCount = 1;
- else if( data_model->GetDataModelType() == FdoRasterDataModelType_RGB )
- nBandCount = 3;
- else if( data_model->GetDataModelType() == FdoRasterDataModelType_RGBA )
- nBandCount = 4;
- else if( data_model->GetDataModelType() == FdoRasterDataModelType_Palette )
- nBandCount = 1;
- else if( data_model->GetDataModelType() == FdoRasterDataModelType_Bitonal )
- fprintf( stderr,
- "Bitonal RasterDataModelType not supported by rtest.\n" );
- return;
- else
- fprintf( stderr, "Unrecognised RasterDataModelType\n" );
- return;
-/* Determine target data type. */
- if( data_model->GetBitsPerPixel() == 8 * nBandCount )
- eOutType = GDT_Byte;
- else if( data_model->GetBitsPerPixel() == 16 * nBandCount
- && data_model->GetDataType() == FdoRasterDataType_Integer )
- eOutType = GDT_Int16;
- && data_model->GetDataType() == FdoRasterDataType_UnsignedInteger)
- eOutType = GDT_UInt16;
- else if( data_model->GetBitsPerPixel() == 32 * nBandCount
- && data_model->GetDataType() == FdoRasterDataType_Integer)
- eOutType = GDT_Int32;
- eOutType = GDT_UInt32;
- && data_model->GetDataType() == FdoRasterDataType_Float)
- eOutType = GDT_Float32;
- else if( data_model->GetBitsPerPixel() == 64 * nBandCount
- eOutType = GDT_Float64;
- else
- fprintf( stderr,
- "Unable to determine GDAL data type from data model.\n" );
- return;
-/* Create the output file. */
- GDALDatasetH hOutDS;
- hOutDS = GDALCreate( hOutDriver, pszOutFilename,
- raster->GetImageXSize(), raster->GetImageYSize(),
- nBandCount, eOutType, NULL );
- if( hOutDS == NULL )
- return;
-/* Create the data stream to read from. */
- FdoPtr<FdoIStreamReaderTmpl<FdoByte> > stream
- = dynamic_cast<FdoIStreamReaderTmpl<FdoByte>*>(raster->GetStreamReader());
-/* Create buffer for one scanline of data. */
- FdoByte *pabyLineData;
- int nComponentSize = (GDALGetDataTypeSize(eOutType) / 8);
- int nLineData = nBandCount * raster->GetImageXSize() * nComponentSize;
- pabyLineData = (FdoByte *) CPLMalloc(nLineData);
-/* Process all scanlines. */
- int iLine;
- stream->Reset();
- for( iLine = 0; iLine < raster->GetImageYSize(); iLine++ )
- if( stream->ReadNext( pabyLineData, 0, nLineData )
- != nLineData )
- fprintf( stderr, "Got an error or short buffer in ReadNext()\n" );
- break;
- if( GDALDatasetRasterIO( hOutDS, GF_Write,
- 0, iLine, raster->GetImageXSize(), 1,
- pabyLineData, raster->GetImageXSize(), 1,
- eOutType, nBandCount, NULL,
- nComponentSize * nBandCount,
- nLineData,
- nComponentSize )
- != CE_None )
- break;
-/* Close and cleanup. */
- GDALClose( hOutDS );
More information about the fdo-commits
