[fdo-commits] r2583 - in trunk/Utilities: Common/Inc Common/Src TestCommon TestCommon/Inc TestCommon/Src
svn_fdo at osgeo.org svn_fdo at osgeo.org
Thu Feb 22 09:28:04 EST 2007
Author: pierredalcourt
Date: 2007-02-22 09:28:04 -0500 (Thu, 22 Feb 2007)
New Revision: 2583
Added:
   trunk/Utilities/TestCommon/Inc/TestCommonFileUtil.h
   trunk/Utilities/TestCommon/Inc/TestCommonGeomUtil.h
   trunk/Utilities/TestCommon/Inc/TestCommonSchemaUtil.h
   trunk/Utilities/TestCommon/Src/TestCommonFileUtil.cpp
   trunk/Utilities/TestCommon/Src/TestCommonGeomUtil.cpp
   trunk/Utilities/TestCommon/Src/TestCommonSchemaUtil.cpp
   trunk/Utilities/Common/Inc/FdoCommonDataReader.h
   trunk/Utilities/Common/Inc/FdoCommonQueryAggregator.h
   trunk/Utilities/Common/Src/FdoCommonDataReader.cpp
   trunk/Utilities/Common/Src/FdoCommonFilterExecutor.cpp
   trunk/Utilities/Common/Src/FdoCommonQueryAggregator.cpp
   trunk/Utilities/TestCommon/Inc/TestCommonMiscUtil.h
   trunk/Utilities/TestCommon/Inc/stdafx.h
   trunk/Utilities/TestCommon/Makefile.am
   trunk/Utilities/TestCommon/Src/TestCommonMiscUtil.cpp
   trunk/Utilities/TestCommon/TestCommon.vcproj
TRAC Ticket #17 "SHP/SDF: fix various Select/SelectAggregates defects"
Modified: trunk/Utilities/Common/Inc/FdoCommonDataReader.h
--- trunk/Utilities/Common/Inc/FdoCommonDataReader.h	2007-02-22 14:26:12 UTC (rev 2582)
+++ trunk/Utilities/Common/Inc/FdoCommonDataReader.h	2007-02-22 14:28:04 UTC (rev 2583)
@@ -360,8 +360,8 @@
     virtual FdoCommonBinaryReader* GetBinaryReader();
     FdoCommonPropertyIndex* GetPropertyIndex();
-    FdoArray<FdoFunction*>* GetAggregateFunctions(FdoIdentifierCollection* selectedIds, FdoCommonExpressionType &exprType);
-    FdoArray<FdoFunction*>* GetAggregateFunctions(FdoExpression* expr, FdoCommonExpressionType &exprType);
+    static FdoArray<FdoFunction*>* GetAggregateFunctions(FdoIdentifierCollection* selectedIds, FdoCommonExpressionType &exprType);
+    static FdoArray<FdoFunction*>* GetAggregateFunctions(FdoExpression* expr, FdoCommonExpressionType &exprType);
     FdoClassDefinition* GetAggregateClassDef(FdoClassDefinition* originalClassDef, FdoIdentifierCollection* selectedIds);
     void RunAggregateQuery(FdoISelect* selectCmd, FdoClassDefinition* originalClassDef, FdoIdentifierCollection* selectedIds, FdoClassDefinition* aggrClassDef, FdoArray<FdoFunction*>* aggrFunctions);
Modified: trunk/Utilities/Common/Inc/FdoCommonQueryAggregator.h
--- trunk/Utilities/Common/Inc/FdoCommonQueryAggregator.h	2007-02-22 14:26:12 UTC (rev 2582)
+++ trunk/Utilities/Common/Inc/FdoCommonQueryAggregator.h	2007-02-22 14:28:04 UTC (rev 2583)
@@ -23,11 +23,13 @@
 struct AggregateStats
-    double   doubleVal;
-    double   doubleValAccumulator;
-    FdoInt64 int64Val;
+    double               doubleVal;
+    double               doubleValAccumulator;
+    FdoInt64             int64Val;
+    FdoStringP           stringVal;
+    FdoDateTime          dateTimeVal;
     FdoPtr<FdoIGeometry> geomVal;
-    bool     isNull;
+    bool                 isNull;
Modified: trunk/Utilities/Common/Src/FdoCommonDataReader.cpp
--- trunk/Utilities/Common/Src/FdoCommonDataReader.cpp	2007-02-22 14:26:12 UTC (rev 2582)
+++ trunk/Utilities/Common/Src/FdoCommonDataReader.cpp	2007-02-22 14:28:04 UTC (rev 2583)
@@ -411,10 +411,15 @@
 FdoArray<FdoFunction*>* FdoCommonDataReader::GetAggregateFunctions(FdoIdentifierCollection* selectedIds, FdoCommonExpressionType &exprType)
-    VALIDATE_ARGUMENT(selectedIds);
     FdoArray<FdoFunction*>* aggrIdents = NULL;
+    // If no identifiers have been explicitly selected, this implies a per-row expression type with no aggregate functions:
+    if (selectedIds == NULL)
+        exprType = FdoCommonExpressionType_PerRow;
+        return NULL;
     bool bContainsAggregateExpressions = false;
     bool bContainsPerRowExpressions = false;
     for (FdoInt32 i=0; i<selectedIds->GetCount(); i++)
Modified: trunk/Utilities/Common/Src/FdoCommonFilterExecutor.cpp
--- trunk/Utilities/Common/Src/FdoCommonFilterExecutor.cpp	2007-02-22 14:26:12 UTC (rev 2582)
+++ trunk/Utilities/Common/Src/FdoCommonFilterExecutor.cpp	2007-02-22 14:28:04 UTC (rev 2583)
@@ -3788,12 +3788,9 @@
-        // If no matching signature was found, revert to 'default' return property/data type:
-        if (!bFound)
-            retPropType = funcDef->GetReturnPropertyType();
-            retDataType = funcDef->GetReturnType();
+        // If no matching signature was found, throw an exception:
+        if (!bFound)
+            throw FdoException::Create(FdoException::NLSGetMessage(FDO_183_INVALID_FUNCTION_ARG, "One or more arguments for function '%1$ls' did not match the expected argument types.", function->GetName()));
Modified: trunk/Utilities/Common/Src/FdoCommonQueryAggregator.cpp
--- trunk/Utilities/Common/Src/FdoCommonQueryAggregator.cpp	2007-02-22 14:26:12 UTC (rev 2582)
+++ trunk/Utilities/Common/Src/FdoCommonQueryAggregator.cpp	2007-02-22 14:28:04 UTC (rev 2583)
@@ -219,6 +219,20 @@
                                 dv = FdoDoubleValue::Create(aggrStats.doubleVal);
                         break;
+                        case FdoDataType_String:
+                            if (aggrStats.isNull)
+                                dv = FdoStringValue::Create();  // defaults to NULL
+                            else
+                                dv = FdoStringValue::Create(aggrStats.stringVal);
+                        break;
+                        case FdoDataType_DateTime:
+                                dv = FdoDateTimeValue::Create();  // defaults to NULL
+                            else
+                                dv = FdoDateTimeValue::Create(aggrStats.dateTimeVal);
+                        break;
                         default:
                             throw FdoException::Create(FdoException::NLSGetMessage(FDO_NLSID(FDO_57_UNEXPECTEDERROR)));
@@ -260,34 +274,63 @@
             // If it is a number, get the result (cast to double); in the case of COUNT(),
             // this could be any type (e.g. geometry) so don't complain if not numeric:
             double d = 0.0;
+            FdoString* strResult = NULL;
+            FdoDateTime dateTimeResult;
             bool bValueIsNull = false;
+            FdoDataType resultDataType;
             if (GetResultPropertyType() == FdoPropertyType_DataProperty)
-                FdoDataType dataType = GetResultDataType();
-                if (dataType == FdoDataType_Double)
+                resultDataType = GetResultDataType();
+                if (resultDataType == FdoDataType_Double)
                     d = GetDoubleResult(bValueIsNull);
-                else if (dataType == FdoDataType_Single)
+                else if (resultDataType == FdoDataType_Single)
                     d = (double)GetSingleResult(bValueIsNull);
-                else if (dataType == FdoDataType_Decimal)
+                else if (resultDataType == FdoDataType_Decimal)
                     d = (double)GetDecimalResult(bValueIsNull);
-                else if (dataType == FdoDataType_Byte)
+                else if (resultDataType == FdoDataType_Byte)
                     d = (double)GetByteResult(bValueIsNull);
-                else if (dataType == FdoDataType_Int16)
+                else if (resultDataType == FdoDataType_Int16)
                     d = (double)GetInt16Result(bValueIsNull);
-                else if (dataType == FdoDataType_Int32)
+                else if (resultDataType == FdoDataType_Int32)
                     d = (double)GetInt32Result(bValueIsNull);
-                else if (dataType == FdoDataType_Int64)
+                else if (resultDataType == FdoDataType_Int64)
                     d = (double)GetInt64Result(bValueIsNull);
+                else if (resultDataType == FdoDataType_String)
+                    strResult = GetStringResult(bValueIsNull);
+                else if (resultDataType == FdoDataType_DateTime)
+                    dateTimeResult = GetDateTimeResult(bValueIsNull);
             // Handle the aggregate function logic:
             AggregateStats &aggrStats = m_aggrStats.at(m_aggrStatsIndex);
             if (0==wcscmp(expr.GetName(), FDO_FUNCTION_MIN))
-                if (!bValueIsNull && (aggrStats.isNull || (d < aggrStats.doubleVal)))
+                if (!bValueIsNull)
-                    aggrStats.doubleVal = d;
-                    aggrStats.isNull = false;
+                    if (resultDataType==FdoDataType_String)
+                        if (aggrStats.isNull || (0>wcscmp(strResult, aggrStats.stringVal)))
+                            aggrStats.stringVal = strResult;
+                            aggrStats.isNull = false;
+                    else if (resultDataType==FdoDataType_DateTime)
+                        if (aggrStats.isNull || (0>FdoCommonMiscUtil::CompareDateTimes(dateTimeResult, aggrStats.dateTimeVal)))
+                            aggrStats.dateTimeVal = dateTimeResult;
+                    else  // datatype is decimal, double, single, int16, int32, etc
+                        if (aggrStats.isNull || (d < aggrStats.doubleVal))
+                            aggrStats.doubleVal = d;
             else if (0==wcscmp(expr.GetName(), FDO_FUNCTION_AVG))
@@ -310,10 +353,32 @@
             else if (0==wcscmp(expr.GetName(), FDO_FUNCTION_MAX))
-                if (!bValueIsNull && (aggrStats.isNull || (d > aggrStats.doubleVal)))
+                        if (aggrStats.isNull || (0<wcscmp(strResult, aggrStats.stringVal)))
+                        if (aggrStats.isNull || (0<FdoCommonMiscUtil::CompareDateTimes(dateTimeResult, aggrStats.dateTimeVal)))
+                        if (aggrStats.isNull || (d > aggrStats.doubleVal))
             else if (0==wcscmp(expr.GetName(), FDO_FUNCTION_SUM))
Added: trunk/Utilities/TestCommon/Inc/TestCommonFileUtil.h
--- trunk/Utilities/TestCommon/Inc/TestCommonFileUtil.h	                        (rev 0)
+++ trunk/Utilities/TestCommon/Inc/TestCommonFileUtil.h	2007-02-22 14:28:04 UTC (rev 2583)
@@ -0,0 +1,49 @@
+ * Copyright (C) 2004-2006  Autodesk, Inc.
+* This library is free software; you can redistribute it and/or
+* modify it under the terms of version 2.1 of the GNU Lesser
+* General Public License as published by the Free Software Foundation.
+* This library is distributed in the hope that it will be useful,
+* but WITHOUT ANY WARRANTY; without even the implied warranty of
+* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
+* Lesser General Public License for more details.
+* You should have received a copy of the GNU Lesser General Public
+* License along with this library; if not, write to the Free Software
+* Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
+ * Revision Control Modification History
+ *         $Id:  $
+ *     $Author:  $
+ *   $DateTime:  $
+ *     $Change:  $
+#ifndef TESTCOMMONFILEUTIL___H
+#define TESTCOMMONFILEUTIL___H	1
+#ifdef _WIN32
+#pragma once
+#endif
+// File-based test utilities common to many providers
+class TestCommonFileUtil
+public:
+    // Compare the contents of 2 files, and return -1 if they don't match, 0 otherwise
+    static FdoInt32 CompareFiles( const char* file1Name, const char* file2Name );
+    // Compare the contents of 2 files, and throw a CPPUNIT exception if they do not match
+    static void CompareFilesAndThrow( const char* masterFileName, const char* outFileName );
+    // Compare the contents of 2 files, with a start byte offset and the number of bytes to compare (-1 to compare all bytes)
+    static void CompareFiles (const wchar_t* file1Name, const wchar_t* file2Name, unsigned long startByteOffset = 0L, unsigned long bytesToCompare = (unsigned long) -1L);
+#endif // TESTCOMMONFILEUTIL___H
Property changes on: trunk/Utilities/TestCommon/Inc/TestCommonFileUtil.h
___________________________________________________________________
   + native
Added: trunk/Utilities/TestCommon/Inc/TestCommonGeomUtil.h
--- trunk/Utilities/TestCommon/Inc/TestCommonGeomUtil.h	                        (rev 0)
+++ trunk/Utilities/TestCommon/Inc/TestCommonGeomUtil.h	2007-02-22 14:28:04 UTC (rev 2583)
@@ -0,0 +1,47 @@
+ *         $Id:  $
+ *     $Author:  $
+ *   $DateTime:  $
+ *     $Change:  $
+#ifndef TESTCOMMONGEOMUTIL___H
+#define TESTCOMMONGEOMUTIL___H	1
+#ifdef _WIN32
+#pragma once
+#endif
+// Geometry-based test utilities common to many providers
+class TestCommonGeomUtil
+public:
+    // Compare two geometries for equivalence:
+    static bool GeometriesEquivalent (FdoIGeometry *geom1, FdoIGeometry *geom2);
+    static bool LinearRingsEquivalent (FdoILinearRing* lr1, FdoILinearRing* lr2);
+    static bool PointsEquivalent (FdoIDirectPosition* pos1, FdoIDirectPosition* pos2);
+    // Print out info about the given geometry (type, length, area, etc):
+    static void PrintGeometryAnalysis( const wchar_t *class_name, int index, FdoByteArray * geom_fgf, double length, double area, bool verbose);
+#endif // TESTCOMMONGEOMUTIL___H
Property changes on: trunk/Utilities/TestCommon/Inc/TestCommonGeomUtil.h
   + native
Modified: trunk/Utilities/TestCommon/Inc/TestCommonMiscUtil.h
--- trunk/Utilities/TestCommon/Inc/TestCommonMiscUtil.h	2007-02-22 14:26:12 UTC (rev 2582)
+++ trunk/Utilities/TestCommon/Inc/TestCommonMiscUtil.h	2007-02-22 14:28:04 UTC (rev 2583)
@@ -33,15 +33,13 @@
 // Misc commonly-used utility functions:
 void TestCommonFail (FdoException* ge);
+void TestCommonFail (char* error);
-// Common select-related tests
+// Utilities common to many unit tests
 class TestCommonMiscUtil
 public:
-    void duplicateComputedIdTest (FdoIConnection* conn, FdoString* className, FdoString* propName);
     // Retrieve the named property value from a property value collection.
     // Create and add the property value to the collection if it is not already there.
     static FdoPropertyValue* AddNewProperty( FdoPropertyValueCollection* propertyValues, FdoString* name );
@@ -94,6 +92,13 @@
     static void SetupLeakReport();
 #endif
+    // Get time on system clock (in seconds) -- used for computing elapsed time.
+    static double GetTime_S(void);
+    // check that 2 doubles are roughly equal:
+    static bool FuzzyEqual (const double d1, const double d2);
 protected:
     static FdoPtr<FdoDataValue> ArgsToDataValue( va_list& arguments );
Added: trunk/Utilities/TestCommon/Inc/TestCommonSchemaUtil.h
--- trunk/Utilities/TestCommon/Inc/TestCommonSchemaUtil.h	                        (rev 0)
+++ trunk/Utilities/TestCommon/Inc/TestCommonSchemaUtil.h	2007-02-22 14:28:04 UTC (rev 2583)
@@ -0,0 +1,43 @@
+ *         $Id:  $
+ *     $Author:  $
+ *   $DateTime:  $
+ *     $Change:  $
+#ifndef TESTCOMMONSCHEMAUTIL___H
+#define TESTCOMMONSCHEMAUTIL___H	1
+#ifdef _WIN32
+#pragma once
+#endif
+// Schema-based test utilities common to many providers
+class TestCommonSchemaUtil
+public:
+    // Delete a class (if bDeleteRowsOnly==false) or delete the rows of a class (if bDeleteRowsOnly==true):
+    static void CleanUpClass(FdoIConnection *connection, const wchar_t* schema_name, const wchar_t* class_name, bool bDeleteRowsOnly=false);
+#endif // TESTCOMMONSCHEMAUTIL___H
Property changes on: trunk/Utilities/TestCommon/Inc/TestCommonSchemaUtil.h
   + native
Modified: trunk/Utilities/TestCommon/Inc/stdafx.h
--- trunk/Utilities/TestCommon/Inc/stdafx.h	2007-02-22 14:26:12 UTC (rev 2582)
+++ trunk/Utilities/TestCommon/Inc/stdafx.h	2007-02-22 14:28:04 UTC (rev 2583)
@@ -72,7 +72,15 @@
 using namespace std;
 #endif
+#ifdef _WIN32
+#include <io.h>
+#include <stddef.h>
+#else
+#include <sys/time.h>
+#endif
+#include <math.h>
 #include <FdoStd.h>
 #include <Fdo/Expression/DataValueCollection.h>
 #include <Fdo.h>
Modified: trunk/Utilities/TestCommon/Makefile.am
--- trunk/Utilities/TestCommon/Makefile.am	2007-02-22 14:26:12 UTC (rev 2582)
+++ trunk/Utilities/TestCommon/Makefile.am	2007-02-22 14:28:04 UTC (rev 2583)
@@ -27,12 +27,18 @@
   Src/TestCommonConstraints.cpp \
   Src/TestCommonFeatureCommands.cpp \
   Src/TestCommonMiscUtil.cpp \
+  Src/TestCommonFileUtil.cpp \
+  Src/TestCommonGeomUtil.cpp \
+  Src/TestCommonSchemaUtil.cpp \
   Src/stdafx.cpp
 noinst_HEADERS = $(libTestCommon_la_SOURCES) \
   Inc/TestCommonConstraints.h \
   Inc/TestCommonFeatureCommands.h \
   Inc/TestCommonMiscUtil.h \
+  Inc/TestCommonFileUtil.h \
+  Inc/TestCommonGeomUtil.h \
+  Inc/TestCommonSchemaUtil.h \
   Inc/TestCommon.h \
   Inc/stdafx.h
Added: trunk/Utilities/TestCommon/Src/TestCommonFileUtil.cpp
--- trunk/Utilities/TestCommon/Src/TestCommonFileUtil.cpp	                        (rev 0)
+++ trunk/Utilities/TestCommon/Src/TestCommonFileUtil.cpp	2007-02-22 14:28:04 UTC (rev 2583)
@@ -0,0 +1,136 @@
+* Copyright (C) 2004-2006  Autodesk, Inc.
+ *         $Id:  $
+ *     $Author:  $
+ *   $DateTime:  $
+ *     $Change:  $
+#include "stdafx.h"
+#include "TestCommonFileUtil.h"
+#include "FdoCommonFile.h"
+void TestCommonFileUtil::CompareFilesAndThrow( const char* masterFileName, const char* outFileName )
+	if ( CompareFiles( masterFileName, outFileName ) != 0 ) {
+		char buffer[5000];
+		sprintf( buffer, "Output file %s differs from expected output file %s", outFileName, masterFileName );
+        CPPUNIT_FAIL (buffer);
+FdoInt32 TestCommonFileUtil::CompareFiles( const char* file1Name, const char* file2Name )
+	char buffer[500];
+	char buffer1[5000];
+	char buffer2[5000];
+	FdoInt32 retcode = -1;
+	FILE* fp1 = fopen( file1Name, "r" );
+	FILE* fp2 = fopen( file2Name, "r" );
+	if ( fp1 == NULL ) {
+		sprintf( buffer, "TestCommonFileUtil::CompareFiles: failed to open file %s", file1Name );
+	if ( fp2 == NULL ) {
+    	fclose(fp1);
+		sprintf( buffer, "TestCommonFileUtil::CompareFiles: failed to open file %s", file2Name );
+	while ( fgets( buffer1, sizeof(buffer1-1), fp1 ) != NULL ) {
+		if ( !fgets( buffer2, sizeof(buffer2-1), fp2  ) )
+			// different: file2 has fewer lines.
+			goto the_exit;
+		if ( strcmp( buffer1, buffer2 ) )
+			// different: a line is different
+			goto the_exit;
+	if ( fgets( buffer2, sizeof(buffer2-1), fp2 ) )
+		// different: file2 has more lines.
+		goto the_exit;
+	retcode = 0;
+the_exit:
+	fclose(fp1);
+	fclose(fp2);
+	return( retcode );
+void TestCommonFileUtil::CompareFiles (const wchar_t* file1Name, const wchar_t* file2Name, unsigned long startByteOffset, unsigned long bytesToCompare)
+    FdoCommonFile file1;
+    FdoCommonFile file2;
+    FdoCommonFile::ErrorCode code;
+    unsigned char buffer1;
+    unsigned char buffer2;
+    unsigned long count;
+    if (file1.OpenFile (file1Name, FdoCommonFile::IDF_OPEN_READ, code))
+        if (file2.OpenFile (file2Name, FdoCommonFile::IDF_OPEN_READ, code))
+            file1.SetFilePointer (startByteOffset);
+            file2.SetFilePointer (startByteOffset);
+            if (-1L == bytesToCompare)
+                file2.GetFileSize (bytesToCompare);
+                file1.GetFileSize (count);
+                if (count > bytesToCompare)
+                    bytesToCompare = count;
+            count = 0;
+            while (file1.ReadFile (&buffer1, 1L))
+                if (file2.ReadFile (&buffer2, 1L))
+					// The 29th byte is LDID. The original file might not have it set but (i.e. is 0) but the
+					// copy file does (takes the locale into account).
+					bool isLDID = ((count + startByteOffset) == 29);
+                    if ((buffer1 != buffer2) && (buffer1 != 0 && isLDID))
+                        char message[1024];
+                        sprintf (message, "compare error at offset 0x%x, expected 0x%x, got 0x%x", count + startByteOffset, buffer2, buffer1);
+                        CPPUNIT_FAIL (message);
+                    count++;
+                        return;
+                else
+                    CPPUNIT_FAIL ("reference has fewer bytes");
+            // check the file2 file has been sucked dry too
+            CPPUNIT_ASSERT_MESSAGE ("reference has more bytes", !file2.ReadFile (&buffer2, 1L));
+        else
+            CPPUNIT_FAIL ("can't open reference file");
+    else
+        CPPUNIT_FAIL ("can't open target file");
Property changes on: trunk/Utilities/TestCommon/Src/TestCommonFileUtil.cpp
   + native
Added: trunk/Utilities/TestCommon/Src/TestCommonGeomUtil.cpp
--- trunk/Utilities/TestCommon/Src/TestCommonGeomUtil.cpp	                        (rev 0)
+++ trunk/Utilities/TestCommon/Src/TestCommonGeomUtil.cpp	2007-02-22 14:28:04 UTC (rev 2583)
@@ -0,0 +1,326 @@
+ *         $Id:  $
+ *     $Author:  $
+ *   $DateTime:  $
+ *     $Change:  $
+#include <FdoSpatial.h>
+#include "TestCommonGeomUtil.h"
+#include "TestCommonMiscUtil.h"
+bool TestCommonGeomUtil::GeometriesEquivalent(FdoIGeometry *geom1, FdoIGeometry *geom2)
+    bool bRet = true;
+    FdoGeometryType type1 = geom1->GetDerivedType();
+    FdoGeometryType type2 = geom2->GetDerivedType();
+    FdoDimensionality dim1 = (FdoDimensionality)geom1->GetDimensionality();
+    FdoDimensionality dim2 = (FdoDimensionality)geom1->GetDimensionality();
+    // Make sure types are the same:
+    if (type1 != type2)
+        return false;
+    // Make sure dimensionalities are the same:
+    if (dim1 != dim2)
+        return false;
+    // Make sure contents are the same:
+    FdoPtr<FdoIDirectPosition> pos1;
+    FdoPtr<FdoIDirectPosition> pos2;
+    bool bHasZ = (dim1 & FdoDimensionality_Z) > 0;
+    bool bHasM = (dim1 & FdoDimensionality_M) > 0;
+    switch (type1)
+        case FdoGeometryType_Point:
+            FdoIPoint* p1 = (FdoIPoint*)geom1;
+            FdoIPoint* p2 = (FdoIPoint*)geom2;
+            pos1 = p1->GetPosition();
+            pos2 = p2->GetPosition();
+            if (!PointsEquivalent(pos1, pos2))
+                return false;
+        break;
+        case FdoGeometryType_LineString:
+            FdoILineString* l1 = (FdoILineString*)geom1;
+            FdoILineString* l2 = (FdoILineString*)geom2;
+            FdoInt32 iCount1 = l1->GetCount();
+            FdoInt32 iCount2 = l2->GetCount();
+            if (iCount1 != iCount2)
+                return false;
+            for (FdoInt32 i=0; i<iCount1; i++)
+                pos1 = l1->GetItem(i);
+                pos2 = l2->GetItem(i);
+                    return false;
+        break;
+        case FdoGeometryType_Polygon:
+            FdoIPolygon* p1 = (FdoIPolygon*)geom1;
+            FdoIPolygon* p2 = (FdoIPolygon*)geom2;
+            FdoPtr<FdoILinearRing> ring1 = p1->GetExteriorRing();
+            FdoPtr<FdoILinearRing> ring2 = p2->GetExteriorRing();
+            if (!LinearRingsEquivalent(ring1, ring2))
+                return false;
+            FdoInt32 iIntRingCount1 = p1->GetInteriorRingCount();
+            FdoInt32 iIntRingCount2 = p2->GetInteriorRingCount();
+            if (iIntRingCount1 != iIntRingCount2)
+                return false;
+            for (FdoInt32 i=0; i<iIntRingCount1; i++)
+                ring1 = p1->GetInteriorRing(i);
+                ring2 = p2->GetInteriorRing(i);
+                    return false;
+        break;
+        case FdoGeometryType_MultiPoint:
+            FdoIMultiPoint* multi1 = (FdoIMultiPoint*)geom1;
+            FdoIMultiPoint* multi2 = (FdoIMultiPoint*)geom2;
+            FdoInt32 count1 = multi1->GetCount();
+            FdoInt32 count2 = multi2->GetCount();
+            if (count1 != count2)
+                return false;
+            for (FdoInt32 i=0; i<count1; i++)
+                FdoPtr<FdoIGeometry> item1 = multi1->GetItem(i);
+                FdoPtr<FdoIGeometry> item2 = multi2->GetItem(i);
+                if (!GeometriesEquivalent(item1,item2))
+                    return false;
+        break;
+        case FdoGeometryType_MultiLineString:
+            FdoIMultiLineString* multi1 = (FdoIMultiLineString*)geom1;
+            FdoIMultiLineString* multi2 = (FdoIMultiLineString*)geom2;
+                return false;
+                    return false;
+        break;
+        case FdoGeometryType_MultiPolygon:
+            FdoIMultiPolygon* multi1 = (FdoIMultiPolygon*)geom1;
+            FdoIMultiPolygon* multi2 = (FdoIMultiPolygon*)geom2;
+                return false;
+                    return false;
+        break;
+        case FdoGeometryType_MultiGeometry:
+        case FdoGeometryType_CurveString:
+        case FdoGeometryType_CurvePolygon:
+        case FdoGeometryType_MultiCurveString:
+        case FdoGeometryType_MultiCurvePolygon:
+        default:
+            throw FdoException::Create(L"Don't know how to compare these 2 geometries");
+        break;
+    return bRet;
+bool TestCommonGeomUtil::PointsEquivalent(FdoIDirectPosition* pos1, FdoIDirectPosition* pos2)
+    if (pos1->GetDimensionality() != pos2->GetDimensionality())
+        return false;
+    bool bHasZ = (pos1->GetDimensionality() & FdoDimensionality_Z) > 0;
+    bool bHasM = (pos1->GetDimensionality() & FdoDimensionality_M) > 0;
+    if (!TestCommonMiscUtil::FuzzyEqual(pos1->GetX(), pos2->GetX()))
+        return false;
+    if (!TestCommonMiscUtil::FuzzyEqual(pos1->GetY(), pos2->GetY()))
+        return false;
+    if (bHasZ && !TestCommonMiscUtil::FuzzyEqual(pos1->GetZ(),pos2->GetZ()))
+        return false;
+    if (bHasM && !TestCommonMiscUtil::FuzzyEqual(pos1->GetM(),pos2->GetM()))
+        return false;
+    return true;
+bool TestCommonGeomUtil::LinearRingsEquivalent(FdoILinearRing* lr1, FdoILinearRing* lr2)
+    FdoInt32 count1 = lr1->GetCount();
+    FdoInt32 count2 = lr2->GetCount();
+        return false;
+    // Compare all the points in the 2 linear rings:
+        FdoPtr<FdoIDirectPosition> pos1 = lr1->GetItem(i);
+        FdoPtr<FdoIDirectPosition> pos2 = lr2->GetItem(i);
+        if (!PointsEquivalent(pos1,pos2))
+            return false;
+    return true;
+void TestCommonGeomUtil::PrintGeometryAnalysis( const wchar_t *class_name, int index, FdoByteArray * geom_fgf, double length0, double area0, bool verbose)
+    FdoPtr<FdoFgfGeometryFactory> gf = FdoFgfGeometryFactory::GetInstance ();
+    FdoIGeometry    *geom = gf->CreateGeometryFromFgf( geom_fgf );
+    switch (geom->GetDerivedType())
+        if (verbose)
+            printf("%ls-%d. FdoGeometryType_LineString!\n", class_name, index);
+		break;
+        if (verbose)
+            printf("%ls-%d. FdoGeometryType_Point!\n", class_name, index);
+		break;
+            FdoIPolygon *poly = (FdoIPolygon *)geom;
+            FdoILinearRing *extRing = poly->GetExteriorRing();
+            double area = FdoSpatialUtility::ComputeLinearRingArea( extRing );
+            double length = FdoSpatialUtility::ComputeLinearRingLength( extRing );
+            if (verbose)
+                printf("%ls-%d. FdoGeometryType_Polygon  length=%lf (%lf) area=%lf (%lf)\n", class_name, index, length, length0, area, area0);
+            for ( int j = 0; j < poly->GetInteriorRingCount(); j++ )
+                FdoILinearRing *intRing = poly->GetInteriorRing(j);
+                area = FdoSpatialUtility::ComputeLinearRingArea( intRing );
+                if (verbose)
+                    printf("    %d. intPolygon  area=%lf\n", j, area);
+                FDO_SAFE_RELEASE(intRing);
+            FDO_SAFE_RELEASE(extRing);
+		break;
+        if (verbose)
+            printf("%ls-%d. FdoGeometryType_MultiPoint!\n", class_name, index);
+		break;
+        if (verbose)
+            printf("%ls-%d. FdoGeometryType_MultiGeometry!\n", class_name, index);
+		break;
+        if (verbose)
+            printf("%ls-%d. FdoGeometryType_MultiLineString!\n", class_name, index);
+		break;
+            if (verbose)
+                printf("%ls-%d. FdoGeometryType_MultiPolygon (%lf)\n", class_name, index, area0);
+            FdoIMultiPolygon *mpoly = (FdoIMultiPolygon *)geom;
+            for (int i = 0; i < mpoly->GetCount(); i++ )
+                FdoIPolygon *poly = mpoly->GetItem(i);
+                if (verbose)
+                    printf("    %d. extPolygon length=%lf (%lf) area=%lf (%lf) \n", i, length, length0, area, area0);
+                    if (verbose)
+                FDO_SAFE_RELEASE(poly);
+		break;
+        if (verbose)
+            printf("%ls-%d. FdoGeometryType_CurveString!\n", class_name, index);
+		break;
+        if (verbose)
+            printf("%ls-%d. FdoGeometryType_MultiCurveString!\n", class_name, index);
+		break;
+        if (verbose)
+            printf("%ls-%d. FdoGeometryType_CurvePolygon!\n", class_name, index);
+		break;
+        if (verbose)
+            printf("%ls-%d. FdoGeometryType_MultiCurvePolygon!\n", class_name, index);
+		break;
+    default:
+    FDO_SAFE_RELEASE(geom);
Property changes on: trunk/Utilities/TestCommon/Src/TestCommonGeomUtil.cpp
   + native
Modified: trunk/Utilities/TestCommon/Src/TestCommonMiscUtil.cpp
--- trunk/Utilities/TestCommon/Src/TestCommonMiscUtil.cpp	2007-02-22 14:26:12 UTC (rev 2582)
+++ trunk/Utilities/TestCommon/Src/TestCommonMiscUtil.cpp	2007-02-22 14:28:04 UTC (rev 2583)
@@ -50,6 +50,15 @@
     CPPUNIT_FAIL (multibyte);
+    char message[4096];
+    sprintf (message, "\nFAILURE: %s\n", error);
 FdoPropertyValue* TestCommonMiscUtil::AddNewProperty( FdoPropertyValueCollection* propertyValues, FdoString* name )
     FdoPropertyValue*  propertyValue = propertyValues->FindItem( name );
@@ -256,3 +265,43 @@
     return(0);
 #endif
+// Get time on system clock (in seconds) -- used for computing elapsed time.
+double TestCommonMiscUtil::GetTime_S(void)
+#ifdef _WIN32
+   double our_time;
+   our_time = GetTickCount() / 1000.0;
+   return our_time;
+#else
+	struct timeval			this_time;
+	static struct timezone	time_zone = { 0, 0 };
+	double					sec, micro, time;
+	if (gettimeofday(&this_time, &time_zone) == -1)
+		return (double) 0.0;
+	micro = (double) ((double) this_time.tv_usec / (double) 1000000.0);
+	sec = (double) this_time.tv_sec;
+	time = micro + sec;
+	return time;
+#endif
+bool TestCommonMiscUtil::FuzzyEqual (const double d1, const double d2)
+    if ((d1==0.0) || (d2==0.0))
+        return 1e-5 > fabs(d1 - d2);
+    else
+        return 1e-5 > fabs(1.0 - (d2 / d1));
Added: trunk/Utilities/TestCommon/Src/TestCommonSchemaUtil.cpp
--- trunk/Utilities/TestCommon/Src/TestCommonSchemaUtil.cpp	                        (rev 0)
+++ trunk/Utilities/TestCommon/Src/TestCommonSchemaUtil.cpp	2007-02-22 14:28:04 UTC (rev 2583)
@@ -0,0 +1,88 @@
+ *         $Id:  $
+ *     $Author:  $
+ *   $DateTime:  $
+ *     $Change:  $
+#include "TestCommonSchemaUtil.h"
+// Delete a class (if bDeleteRowsOnly==false) or delete the rows of a class (if bDeleteRowsOnly==true):
+void TestCommonSchemaUtil::CleanUpClass(FdoIConnection *connection, const wchar_t* schema_name, const wchar_t* class_name, bool bDeleteRowsOnly)
+    try
+        FdoPtr<FdoIdentifier> identifier = FdoIdentifier::Create (class_name);
+	    FdoPtr<FdoIDescribeSchema> descSchema = (FdoIDescribeSchema*)connection->CreateCommand(FdoCommandType_DescribeSchema);
+        // NOTE: in case the schema_name no longer exists, we dont specify it up front because it will cause an exception:
+	    //if (NULL!=schema_name)
+		//    descSchema->SetSchemaName(schema_name);
+	    FdoPtr<FdoFeatureSchemaCollection> schemas = descSchema->Execute();
+	    bool bFound = false;
+	    for (FdoInt32 iSchemaIndex = 0; iSchemaIndex<schemas->GetCount(); iSchemaIndex++)
+		    FdoPtr<FdoFeatureSchema> schema = schemas->GetItem(iSchemaIndex);
+		    if ((NULL==schema_name) || (0==wcscmp(schema->GetName(), schema_name)))
+			    FdoPtr<FdoClassCollection> classes = schema->GetClasses();
+			    for (FdoInt32 iClassIndex = 0; iClassIndex<classes->GetCount(); iClassIndex++)
+				    FdoPtr<FdoClassDefinition> classDef = classes->GetItem(iClassIndex);
+				    if (0==FdoCommonOSUtil::wcsicmp(classDef->GetName(), identifier->GetName ()))
+					    bFound = true;
+                        // delete the rows of this class, but not the class itself:
+                        FdoPtr<FdoIDelete> deleteCmd = (FdoIDelete*)connection->CreateCommand (FdoCommandType_Delete);
+                        deleteCmd->SetFeatureClassName(classDef->GetName());
+                        deleteCmd->Execute();
+                        if (!bDeleteRowsOnly)
+                             // delete the entire class:
+					        classDef->Delete();
+					        FdoPtr<FdoIApplySchema> applySchema = (FdoIApplySchema*)connection->CreateCommand(FdoCommandType_ApplySchema);
+					        applySchema->SetFeatureSchema(schema);
+					        applySchema->Execute();
+					    break;
+		    if (bFound)
+			    break;
+	    // recurse with default schema, if class not found:
+	    if (!bFound && (NULL!=schema_name) && (wcslen(schema_name)>0))
+		    CleanUpClass(connection, NULL, class_name);
+    catch (FdoException* ge)
+        TestCommonFail (ge);
Property changes on: trunk/Utilities/TestCommon/Src/TestCommonSchemaUtil.cpp
   + native
Modified: trunk/Utilities/TestCommon/TestCommon.vcproj
--- trunk/Utilities/TestCommon/TestCommon.vcproj	2007-02-22 14:26:12 UTC (rev 2582)
+++ trunk/Utilities/TestCommon/TestCommon.vcproj	2007-02-22 14:28:04 UTC (rev 2583)
@@ -195,9 +195,21 @@
 			</File>
 			<File
+				RelativePath=".\Src\TestCommonFileUtil.cpp"
+			</File>
+			<File
+				RelativePath=".\Src\TestCommonGeomUtil.cpp"
+			</File>
+			<File
 				RelativePath=".\Src\TestCommonMiscUtil.cpp"
 			</File>
+			<File
+				RelativePath=".\Src\TestCommonSchemaUtil.cpp"
+			</File>
 		</Filter>
 		<Filter
 			Name="Header Files"
@@ -216,9 +228,21 @@
 			</File>
 			<File
+				RelativePath=".\Inc\TestCommonFileUtil.h"
+			</File>
+			<File
+				RelativePath=".\Inc\TestCommonGeomUtil.h"
+			</File>
+			<File
 				RelativePath=".\Inc\TestCommonMiscUtil.h"
 			</File>
+			<File
+				RelativePath=".\Inc\TestCommonSchemaUtil.h"
+			</File>
 		</Filter>
 		<Filter
 			Name="Resource Files"
More information about the fdo-commits mailing list
