[fdo-commits] r808 -
branches/3.2.x/Fdo/Docs/doc_src/group_and_page_definitions
svn_fdo at osgeo.org
Thu Feb 22 15:11:06 EST 2007
Author: gregboone
Date: 2007-02-22 15:11:06 -0500 (Thu, 22 Feb 2007)
New Revision: 808
branches/3.2.x/Fdo/Docs/doc_src/group_and_page_definitions/define_pages_managed.h
FDO4: Update API documentation generation process - Remove enum/interface ingroups
Modified: branches/3.2.x/Fdo/Docs/doc_src/group_and_page_definitions/define_pages_managed.h
--- branches/3.2.x/Fdo/Docs/doc_src/group_and_page_definitions/define_pages_managed.h 2007-02-22 20:10:41 UTC (rev 807)
+++ branches/3.2.x/Fdo/Docs/doc_src/group_and_page_definitions/define_pages_managed.h 2007-02-22 20:11:06 UTC (rev 808)
@@ -1,61 +1,59 @@
/*! \mainpage Introduction
<div class="mainpage">
-<!-- This is the index.html page that the user first sees. -->
-<p>The Feature Data Objects (FDO) application
-programming interface (API) is a set of APIs used to
+<!-- This is the index.htm page that the user first sees. -->
+<p>The Feature Data Objects (FDO) application
+programming interface (API) is a set of APIs used to
manipulate, define, and analyze geospatial information.
</p>
-<p>FDO supports the retrieving and updating of spatial and non-spatial
-GIS feature data through a rich classification model that is
+<p>FDO supports the retrieving and updating of spatial and non-spatial
+GIS feature data through a rich classification model that is
based on OpenGIS and ISO standards.
</p>
<p>From the perspective of a client application user: the FDO API
-provides consistent access to feature data,
-whether it comes from a CAD-based data source, or from a
-relational data store that supports rich classification. To
-achieve this, FDO supports a model that can readily follow
-the capabilities of each data source, allowing for consumer
-applications functionality that is tailored to match that of
-the data source. For example, some data sources may support
-spatial queries, while others do not. Also, a flexible
-metadata model is required in FDO, allowing clients to adapt
+provides consistent access to feature data,
+whether it comes from a CAD-based data source, or from a
+relational data store that supports rich classification. To
+achieve this, FDO supports a model that can readily follow
+the capabilities of each data source, allowing for consumer
+applications functionality that is tailored to match that of
+the data source. For example, some data sources may support
+spatial queries, while others do not. Also, a flexible
+metadata model is required in FDO, allowing clients to adapt
to the underlying feature schema exposed by each data source.
</p>
-<p>From the perspective of a client application engineer: the
-FDO API provides a common, general purpose abstraction layer
-for accessing geospatial data from a variety of data sources.
-The API is, in part, an interface specification of the
-abstraction layer. A provider, such as FDO Provider for SDF, is
-an implementation of the interface for a specific type of
+<p>From the perspective of a client application engineer: the
+FDO API provides a common, general purpose abstraction layer
+for accessing geospatial data from a variety of data sources.
+The API is, in part, an interface specification of the
+abstraction layer. A provider, such as FDO Provider for SDF,
+is an implementation of the interface for a specific type of
data source, which in this example is an implementation for
-Autodesk's spatial database format
-(SDF). The API can support the standard data store
-manipulation operations, such as querying, updating, versioning,
-locking, and others, only when the underlying data store has
-the same capabilities for these operations.
+OSGeo's spatial database format (SDF). The API can support
+the standard data store manipulation operations, such as
+querying, updating, versioning, locking, and others, only
+when the underlying data store has the same capabilities
+for these operations.
</p>
<h2>
Architecture
</h2>
<p>
-The high-level architecture of FDO comprises feature
-providers that plug into an application to expose a
-consistent feature schema and a consistent interface for
-interacting with geospatial feature data, regardless of the
-underlying data store. The client applications interact
-through the various FDO interfaces, such as
-IConnection or ICommand, using an FDO interface layer, or feature
-access manager.
+The high-level architecture of FDO comprises feature providers
+that plug into an application to expose a consistent feature
+schema and a consistent interface for interacting with geospatial
+feature data, regardless of the underlying data store. The
+client applications interact through the various FDO interfaces,
+such as IConnection or ICommand, using an FDO interface layer,
+or feature access manager.
</p>
<p>
-FDO is assembled in or consists of conceptual packages of similar
-functionality. This packaging is reflected in the
-substructure of the FDO SDK 'includes' folder. FDO commands,
-provider-specific commands, and connections/capabilities
-provide access to native data stores through each specific
-FDO provider. Schema management (using XML), client services,
-and filters/expressions are all provider-independent packages
-that connect directly to the FDO API.
+FDO is assembled in or consists of conceptual packages of similar
+functionality. This packaging is reflected in the substructure of
+the FDO SDK 'includes' folder. FDO commands, provider-specific
+commands, and connections/capabilities provide access to native
+data stores through each specific FDO provider. Schema management
+(using XML), client services, and filters/expressions are all
+provider-independent packages that connect directly to the FDO API.
</p>
<p>
For more information, see <i>The Essential FDO</i> (FET_TheEssentialFDO.pdf)
@@ -65,8 +63,6 @@
<br>
</div>
-/// \defgroup enums
-/// \defgroup interfaces
/// \defgroup OSGeoFDO OSGeo::FDO
/// \defgroup OSGeoFDOClientServices OSGeo::FDO::ClientServices
/// \defgroup OSGeoFDOCommands OSGeo::FDO::Commands
@@ -92,4 +88,4 @@
/// \defgroup OSGeoFDOCommonXsl OSGeo::FDO::Common::Xsl
/// \defgroup OSGeoFDOGeometry OSGeo::FDO::Geometry
/// \defgroup OSGeoFDORuntime OSGeo::FDO::Runtime
-/// \defgroup OSGeoFDOSpatial OSGeo::FDO::Spatial
\ No newline at end of file
+/// \defgroup OSGeoFDOSpatial OSGeo::FDO::Spatial
More information about the fdo-commits
