[fdo-commits] r220 - branches/3.2.x/Providers/SDF/Src/UnitTest
svn_fdo at osgeo.org svn_fdo at osgeo.org
Fri Feb 23 11:47:37 EST 2007
Author: pierredalcourt
Date: 2007-02-23 11:47:37 -0500 (Fri, 23 Feb 2007)
New Revision: 220
Added:
   branches/3.2.x/Providers/SDF/Src/UnitTest/SchemaTest.cpp
   branches/3.2.x/Providers/SDF/Src/UnitTest/SchemaTest.h
TRAC Ticket #17 "SHP/SDF: fix various Select/SelectAggregates defects"
Added: branches/3.2.x/Providers/SDF/Src/UnitTest/SchemaTest.cpp
--- branches/3.2.x/Providers/SDF/Src/UnitTest/SchemaTest.cpp	                        (rev 0)
+++ branches/3.2.x/Providers/SDF/Src/UnitTest/SchemaTest.cpp	2007-02-23 16:47:37 UTC (rev 220)
@@ -0,0 +1,96 @@
+// Copyright (C) 2004-2006  Autodesk, Inc.
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of version 2.1 of the GNU Lesser
+// General Public License as published by the Free Software Foundation.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
+#include "SchemaTest.h"
+#include <ctime>
+#include <cppunit/extensions/HelperMacros.h>
+#include "SDF/SdfCommandType.h"
+#include "SDF/ICreateSDFFile.h"
+#define SDF_FILE_MG  L"../../TestData/HYDRANTSMULTIGEOM.sdf"
+CPPUNIT_TEST_SUITE_REGISTRATION( SchemaTest );
+CPPUNIT_TEST_SUITE_NAMED_REGISTRATION( SchemaTest, "SchemaTest");
+SchemaTest::SchemaTest(void)
+SchemaTest::~SchemaTest(void)
+void SchemaTest::setUp ()
+void SchemaTest::tearDown ()
+void SchemaTest::OpenConnection(FdoIConnection* conn, const wchar_t* path , bool placeDQ)
+#ifdef _WIN32
+    wchar_t fullpath[1024];
+    _wfullpath(fullpath, path, 1024);
+#else
+    char cpath[1024];
+    char cfullpath[1024];
+    wcstombs(cpath, path, 1024);
+    realpath(cpath, cfullpath);
+    mbstowcs(fullpath, cfullpath, 1024);
+#endif
+    std::wstring connStr;
+    if (placeDQ)
+        connStr = std::wstring(L"File=\"") + std::wstring(fullpath) + std::wstring(L"\"");
+    else
+        connStr = std::wstring(L"File=") + std::wstring(fullpath);
+    connStr += std::wstring(L";ReadOnly=TRUE");
+    conn->SetConnectionString(connStr.c_str());
+    conn->Open();
+void SchemaTest::TestMultipleGeom()
+    try
+        FdoPtr<IConnectionManager> manager = FdoFeatureAccessManager::GetConnectionManager ();
+        FdoPtr<FdoIConnection> conn = manager->CreateConnection (L"OSGeo.SDF.3.2");
+        OpenConnection(conn, SDF_FILE_MG);
+        FdoPtr<FdoIDescribeSchema>pDescSchemaCmd = (FdoIDescribeSchema*) conn->CreateCommand(FdoCommandType_DescribeSchema);
+        FdoPtr<FdoFeatureSchemaCollection> pfsc = pDescSchemaCmd->Execute();
+        FdoIoFileStreamP schemaFileStream = FdoIoFileStream::Create(L"SDFTestDescribeSchema.xml", L"w+");
+        pfsc->WriteXml(schemaFileStream);
+        schemaFileStream = NULL;
+        conn->Close();
+    catch (FdoException *ex )
+        printf("FDO error: %ls\n", ex->GetExceptionMessage());
+        ex->Release();
+        CPPUNIT_FAIL ("Failed to export schema!");
Property changes on: branches/3.2.x/Providers/SDF/Src/UnitTest/SchemaTest.cpp
___________________________________________________________________
   + native
Added: branches/3.2.x/Providers/SDF/Src/UnitTest/SchemaTest.h
--- branches/3.2.x/Providers/SDF/Src/UnitTest/SchemaTest.h	                        (rev 0)
+++ branches/3.2.x/Providers/SDF/Src/UnitTest/SchemaTest.h	2007-02-23 16:47:37 UTC (rev 220)
@@ -0,0 +1,52 @@
+#ifndef _SCHEMATEST_H_
+#define _SCHEMATEST_H_
+#ifdef _WIN32
+#pragma once
+#endif
+#include "Fdo.h"
+#include <cppunit/TestCase.h>
+#include <map>
+#include <TestCommonMiscUtil.h>
+ * The unit test for schema.
+class SchemaTest : public CppUnit::TestCase
+  CPPUNIT_TEST_SUITE( SchemaTest );
+  CPPUNIT_TEST( TestMultipleGeom );
+  CPPUNIT_TEST_SUITE_END();
+public:
+    SchemaTest(void);
+    virtual ~SchemaTest(void);
+    void setUp ();
+	void tearDown ();
+    void TestMultipleGeom();
+private:
+    void OpenConnection(FdoIConnection* conn, const wchar_t* path , bool placeDQ = false);
+#endif
Property changes on: branches/3.2.x/Providers/SDF/Src/UnitTest/SchemaTest.h
   + native
More information about the fdo-commits mailing list
