[fdo-commits] r811 - in branches/3.2.x/Utilities/Common: . Inc
svn_fdo at osgeo.org
Fri Feb 23 12:03:39 EST 2007
Author: romicadascalescu
Date: 2007-02-23 12:03:39 -0500 (Fri, 23 Feb 2007)
New Revision: 811
Added:
branches/3.2.x/Utilities/Common/Inc/FdoCommonExpressionExecutor.h
branches/3.2.x/Utilities/Common/FdoCommon.vcproj
Ticket #20 Generic RDBMS: fix various SelectAggregates defects
Modified: branches/3.2.x/Utilities/Common/FdoCommon.vcproj
--- branches/3.2.x/Utilities/Common/FdoCommon.vcproj 2007-02-22 23:10:09 UTC (rev 810)
+++ branches/3.2.x/Utilities/Common/FdoCommon.vcproj 2007-02-23 17:03:39 UTC (rev 811)
@@ -351,6 +351,10 @@
</File>
<File
+ RelativePath=".\Inc\FdoCommonExpressionExecutor.h"
+ </File>
+ <File
RelativePath="Inc\FdoCommonFeatureCommand.h"
</File>
Added: branches/3.2.x/Utilities/Common/Inc/FdoCommonExpressionExecutor.h
--- branches/3.2.x/Utilities/Common/Inc/FdoCommonExpressionExecutor.h (rev 0)
+++ branches/3.2.x/Utilities/Common/Inc/FdoCommonExpressionExecutor.h 2007-02-23 17:03:39 UTC (rev 811)
@@ -0,0 +1,281 @@
+ * Copyright (C) 2004-2006 Autodesk, Inc.
+* This library is free software; you can redistribute it and/or
+* modify it under the terms of version 2.1 of the GNU Lesser
+* General Public License as published by the Free Software Foundation.
+* This library is distributed in the hope that it will be useful,
+* but WITHOUT ANY WARRANTY; without even the implied warranty of
+* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+* Lesser General Public License for more details.
+* You should have received a copy of the GNU Lesser General Public
+* License along with this library; if not, write to the Free Software
+* Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
+#ifndef _FDOCOMMONEXPRESSIONEXECUTOR_H_
+#define _FDOCOMMONEXPRESSIONEXECUTOR_H_
+#ifdef _WIN32
+#pragma once
+#endif
+#include "FdoCommonOSUtil.h"
+/// \brief
+/// validate extended usage of functions
+class FdoCommonExpressionExecutor : public FdoDisposable
+protected:
+ FdoCommonExpressionExecutor() {};
+ FdoCommonExpressionExecutor(FdoFeatureSchemaCollection* schColl, FdoIdentifier* className)
+ m_UnknownTypeFound = false;
+ FdoInt32 cnt = 0;
+ FdoStringP Name;
+ FdoString** ptrNames = className->GetScope(cnt);
+ if (cnt == 0)
+ Name = className->GetName();
+ else
+ Name = *ptrNames;
+ FdoStringP schName = className->GetSchemaName();
+ if (schName.GetLength())
+ FdoPtr<FdoFeatureSchema> schema = schColl->GetItem(schName);
+ m_classes = schema->GetClasses();
+ m_actClass = m_classes->FindItem(Name);
+ else
+ for(int i = 0; i < schColl->GetCount(); i++)
+ FdoPtr<FdoFeatureSchema> schema = schColl->GetItem(i);
+ if (m_actClass == NULL)
+ m_classes = NULL;
+ else
+ break;
+ FdoDataType GetObjectType(FdoStringP objectName, FdoClassDefinition* classDef)
+ if (classDef != NULL)
+ FdoPtr<FdoPropertyDefinitionCollection> defColl = classDef->GetProperties();
+ if(!objectName.Contains(L"."))
+ FdoPtr<FdoPropertyDefinition> propDef = defColl->FindItem(objectName);
+ if (propDef == NULL)
+ FdoPtr<FdoClassDefinition> baseClassDef = classDef->GetBaseClass();
+ while(baseClassDef != NULL)
+ defColl = baseClassDef->GetProperties();
+ propDef = defColl->FindItem(objectName);
+ if (propDef != NULL)
+ break;
+ baseClassDef = baseClassDef->GetBaseClass();
+ if (propDef != NULL && propDef->GetPropertyType() == FdoPropertyType_DataProperty)
+ return ((FdoDataPropertyDefinition*)propDef.p)->GetDataType();
+ else
+ FdoStringP propName = objectName.Left(L".");
+ objectName = objectName.Right(L".");
+ FdoPtr<FdoPropertyDefinition> propDef = defColl->FindItem(propName);
+ propDef = defColl->FindItem(propName);
+ break;
+ if(propDef->GetPropertyType() == FdoPropertyType_ObjectProperty)
+ FdoPtr<FdoClassDefinition> classObjDef = ((FdoObjectPropertyDefinition*)propDef.p)->GetClass();
+ return GetObjectType(objectName, classObjDef);
+ else if(propDef->GetPropertyType() == FdoPropertyType_AssociationProperty)
+ FdoPtr<FdoClassDefinition> classObjDef = ((FdoAssociationPropertyDefinition*)propDef.p)->GetAssociatedClass();
+ m_UnknownTypeFound = true;
+ return (FdoDataType)(FdoDataType_Boolean-1);
+public:
+ static FdoCommonExpressionExecutor* Create(FdoFeatureSchemaCollection* schColl, FdoIdentifier* className)
+ return new FdoCommonExpressionExecutor(schColl, className);
+ void ValidateIdentifiers(FdoIdentifierCollection* idCol, FdoIExpressionCapabilities* expCap)
+ try
+ FdoPtr<FdoFunctionDefinitionCollection> functions = expCap->GetFunctions();
+ for (int i = 0; i < idCol->GetCount(); i++)
+ FdoPtr<FdoIdentifier> idf = idCol->GetItem(i);
+ if (dynamic_cast<FdoComputedIdentifier*>(idf.p) != NULL)
+ FdoPtr<FdoExpression> expr = ((FdoComputedIdentifier*)idf.p)->GetExpression();
+ ValidateExpresion(expr, functions);
+ catch(FdoException* e)
+ if(m_UnknownTypeFound)
+ e->Release();
+ else
+ throw e;
+private:
+ FdoDataType ValidateExpresion(FdoExpression* expr, FdoFunctionDefinitionCollection* functions)
+ if (dynamic_cast<FdoIdentifier*>(expr) != NULL){
+ return GetObjectType(((FdoIdentifier*)expr)->GetName(), m_actClass);
+ else if (dynamic_cast<FdoFunction*>(expr) != NULL)
+ FdoFunction* fct = (FdoFunction*)expr;
+ FdoString* fctName = fct->GetName();
+ FdoPtr<FdoExpressionCollection> argsExp = fct->GetArguments();
+ FdoPtr<FdoFunctionDefinition> function;
+ for(int i = 0; i < functions->GetCount(); i++)
+ function = functions->GetItem(i);
+ if (FdoCommonOSUtil::wcsicmp(function->GetName(), fctName) != 0)
+ function = NULL;
+ else
+ break;
+ if (function == NULL) // unknown function do the best...
+ // No argument provided, return the type
+ if (argsExp == NULL || !argsExp->GetCount())
+ return function->GetReturnType();
+ FdoPtr<FdoReadOnlySignatureDefinitionCollection> pSigs = function->GetSignatures();
+ for(int i = 0; i < pSigs->GetCount(); i++)
+ FdoPtr<FdoSignatureDefinition> pSig = pSigs->GetItem(i);
+ FdoPtr<FdoReadOnlyArgumentDefinitionCollection> args = pSig->GetArguments();
+ if (argsExp->GetCount() != args->GetCount())
+ continue;
+ bool argsFound = true;
+ for(int y = 0; y < args->GetCount(); y++)
+ FdoDataType dataTypeArg;
+ FdoPtr<FdoArgumentDefinition> arg = args->GetItem(y);
+ FdoPtr<FdoExpression> exp = argsExp->GetItem(y);
+ dataTypeArg = ValidateExpresion(exp, functions);
+ if (dataTypeArg == (FdoDataType)(FdoDataType_Boolean-1))
+ dataTypeArg = arg->GetDataType();
+ if (dataTypeArg != arg->GetDataType())
+ argsFound = false;
+ break;
+ if (argsFound)
+ return pSig->GetReturnType();
+ throw FdoException::Create (FdoException::NLSGetMessage(FDO_NLSID(FDO_80_INVALID_EXPRESSION)));
+ else if (dynamic_cast<FdoUnaryExpression*>(expr) != NULL)
+ // just validate the expression from inside
+ FdoPtr<FdoExpression> exp1 = ((FdoUnaryExpression*)expr)->GetExpression();
+ ValidateExpresion(exp1, functions);
+ return FdoDataType_Boolean;
+ else if (dynamic_cast<FdoBinaryExpression*>(expr) != NULL)
+ FdoPtr<FdoExpression> exp1 = ((FdoBinaryExpression*)expr)->GetLeftExpression();
+ FdoDataType left = ValidateExpresion(exp1, functions);
+ FdoPtr<FdoExpression> exp2 = ((FdoBinaryExpression*)expr)->GetRightExpression();
+ FdoDataType right = ValidateExpresion(exp2, functions);
+ if (left == FdoDataType_String || right == FdoDataType_String)
+ return FdoDataType_String;
+ if (left == FdoDataType_DateTime || right == FdoDataType_DateTime)
+ return FdoDataType_DateTime;
+ if (left == FdoDataType_Double || right == FdoDataType_Double)
+ return FdoDataType_Double;
+ if (left == FdoDataType_Decimal || right == FdoDataType_Decimal)
+ return FdoDataType_Decimal;
+ if (left == FdoDataType_Single || right == FdoDataType_Single)
+ if (left == FdoDataType_Int64 || right == FdoDataType_Int64)
+ return FdoDataType_Int64;
+ if (left == FdoDataType_Int32 || right == FdoDataType_Int32)
+ return FdoDataType_Int32;
+ if (left == FdoDataType_Int16 || right == FdoDataType_Int16)
+ return FdoDataType_Int16;
+ if (left == FdoDataType_Byte || right == FdoDataType_Byte)
+ return FdoDataType_Byte;
+ if (left == FdoDataType_Boolean || right == FdoDataType_Boolean)
+ // unknown type
+ else if (dynamic_cast<FdoStringValue*>(expr) != NULL)
+ else if (dynamic_cast<FdoDateTime*>(expr) != NULL)
+ else if (dynamic_cast<FdoInt16Value*>(expr) != NULL)
+ else if (dynamic_cast<FdoInt32Value*>(expr) != NULL)
+ else if (dynamic_cast<FdoInt64Value*>(expr) != NULL)
+ else if (dynamic_cast<FdoDoubleValue*>(expr) != NULL)
+ else if (dynamic_cast<FdoDecimalValue*>(expr) != NULL)
+ else if (dynamic_cast<FdoSingleValue*>(expr) != NULL)
+ return FdoDataType_Single;
+ else if (dynamic_cast<FdoByteValue*>(expr) != NULL)
+ else if (dynamic_cast<FdoBooleanValue*>(expr) != NULL)
+ else // unknown type
+private:
+ FdoPtr<FdoClassCollection> m_classes;
+ FdoPtr<FdoClassDefinition> m_actClass;
+ FdoBoolean m_UnknownTypeFound;
+#endif //_FDOCOMMONEXPRESSIONEXECUTOR_H_
More information about the fdo-commits
