[Fdo_commits] WFS: SelectAggregates command reports no geometry
	property
    Greg Boone
    greg.boone at autodesk.com
    Mon Jan  8 17:27:08 EST 2007
FDO WFS Provider Submission:
https://osgeo.org/svn/fdowfs/branches/3.2.x/Providers/WFS/Src/Provider
This submission fixes defect 875813: WFS SelectAggregates command
reports no geometry property
The problem with the http://webservices.ionicsoft.com/unData/wfs/UN
BND_ANNO class is that it contains 2 geometry properties. Due to this
fact, the FdoClassDefinition does not have it's Primary Geometry
Property value set. A solution to this defect will be to relax the check
on the geometry property name passed in to the SpatialExtents function
so that the provider only determines that the geometry property is
defined on the class.
Submitted revision 85
r85 | gregboone | 2007-01-08 18:19:49 -0500 (Mon, 08 Jan 2007) | 3 lines
Changed paths:
   M
/branches/3.2.x/Providers/WFS/Src/Provider/FdoWfsSelectAggregatesCommand
.cpp
   M
/branches/3.2.x/Providers/WFS/Src/Provider/FdoWfsSpatialExtentsAggregate
Reader.cpp
   M
Reader.h
URL: http://lists.osgeo.org/pipermail/fdo-commits/attachments/20070108/fc710850/attachment.html
More information about the Fdo-commits
