[fdo-commits] r642 - branches/3.2.x/Providers/GenericRdbms/Src/UnitTest
svn_fdo at osgeo.org svn_fdo at osgeo.org
Wed Jan 17 15:01:57 EST 2007
Author: barbarazoladek
Date: 2007-01-17 15:01:57 -0500 (Wed, 17 Jan 2007)
New Revision: 642
   branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/apply_schema_err3S_master.txt
Updating master error file
Modified: branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/apply_schema_err3S_master.txt
--- branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/apply_schema_err3S_master.txt	2007-01-17 16:14:44 UTC (rev 641)
+++ branches/3.2.x/Providers/GenericRdbms/Src/UnitTest/apply_schema_err3S_master.txt	2007-01-17 20:01:57 UTC (rev 642)
@@ -26,6 +26,7 @@
  Error in Column {USER_DS}_apply_schema.dbo.base_missing.scale_too_high: scale 128 is greater than maximum allowed (38)
  Cannot change identity properties for class Error:Base Missing from () to (ID); identity property change is not supported
  Base class Acad:Ghost for class Error:Base Missing not found in current database
+ Identity Property 'Error:Base Conflict.FeatId' for new class must be autogenerated or non-readonly
  Cannot add/modify class Error:Base Conflict; identity properties inherited from base class are different in the Feature Schema (ID) and the Database (FeatId)
  Class 'Error:Base Conflict' and base class 'Acad:AcDbEntity' have different class types
  Class 'Error:Feature object property class', for object property 'Error:Error Op.featureClass', is not an FdoClass
More information about the fdo-commits mailing list
