[fdo-commits] r658 - in trunk/Providers/GenericRdbms/Src/UnitTest: . Common
svn_fdo at osgeo.org svn_fdo at osgeo.org
Mon Jan 22 12:45:43 EST 2007
Author: barbarazoladek
Date: 2007-01-22 12:45:43 -0500 (Mon, 22 Jan 2007)
New Revision: 658
   trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoInsertTest.cpp
   trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoInsertTest.h
   trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_err3S_master.txt
column not set to autoincrement in non-feature class
Modified: trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoInsertTest.cpp
--- trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoInsertTest.cpp	2007-01-20 14:20:11 UTC (rev 657)
+++ trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoInsertTest.cpp	2007-01-22 17:45:43 UTC (rev 658)
@@ -1529,4 +1529,63 @@
     return (FdoDouble) 2.225073858507202e-308;
+void FdoInsertTest::insertAutoGen()
+	FdoIConnection* connection = UnitTestUtil::GetConnection(mSuffix, true);
+        try
+			FdoPtr<FdoIDescribeSchema>  pDescCmd = (FdoIDescribeSchema*) connection->CreateCommand(FdoCommandType_DescribeSchema);
+			FdoFeatureSchemasP pSchemas = pDescCmd->Execute();
+			if (pSchemas)
+				FdoFeatureSchemaP pSchema = pSchemas->FindItem( L"TestEmpty" );
+				if (!pSchema)
+					FdoIApplySchema*  pCmd = (FdoIApplySchema*) connection->CreateCommand(FdoCommandType_ApplySchema);
+					//FdoPtr<FdoFeatureSchemaCollection> pSchemas = FdoFeatureSchemaCollection::Create(NULL);
+					FdoFeatureSchema* pNewSchema = FdoFeatureSchema::Create( L"TestEmpty", L"Test schema" );
+					//pSchemas->Add( pSchema );
+					FdoClass* pNewClass = FdoClass::Create( L"Empty", L"Test class" );
+					pNewClass->SetIsAbstract(false);
+					FdoDataPropertyDefinition* pProp = FdoDataPropertyDefinition::Create( L"AttrId", L"id" );
+					pProp->SetDataType( FdoDataType_Int64 );
+					pProp->SetNullable(false);
+					pProp->SetIsAutoGenerated(true);
+					pNewClass->GetProperties()->Add( pProp );
+					pNewClass->GetIdentityProperties()->Add( pProp );
+					pProp = FdoDataPropertyDefinition::Create( L"AttrName", L"Name" );
+					pProp->SetDataType( FdoDataType_String );
+					pProp->SetLength(64);
+					pProp->SetNullable(true);
+					FDO_SAFE_RELEASE(pProp);
+					pNewSchema->GetClasses()->Add( pNewClass );
+					pCmd->SetFeatureSchema( pNewSchema );
+					pCmd->Execute();
+			FdoIInsert *insertCommand = (FdoIInsert *) connection->CreateCommand(FdoCommandType_Insert);
+			insertCommand->SetFeatureClassName(L"TestEmpty:Empty");
+			FdoPtr<FdoPropertyValueCollection> propertyValues = insertCommand->GetPropertyValues();
+			FdoIFeatureReader *myReader = insertCommand->Execute();
+			CPPUNIT_ASSERT(myReader != NULL);
+			while (myReader->ReadNext())
+				CPPUNIT_ASSERT(!myReader->IsNull(L"AttrId"));
+			myReader->Release();
+			connection->Close();
+		catch (...)
+        connection->Close ();
+        throw;
Modified: trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoInsertTest.h
--- trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoInsertTest.h	2007-01-20 14:20:11 UTC (rev 657)
+++ trunk/Providers/GenericRdbms/Src/UnitTest/Common/FdoInsertTest.h	2007-01-22 17:45:43 UTC (rev 658)
@@ -35,6 +35,7 @@
   CPPUNIT_TEST( smartPointerInsert );
   CPPUNIT_TEST( insertFlushTest );
   //CPPUNIT_TEST( conditionalInsert );
+  CPPUNIT_TEST( insertAutoGen );
   CPPUNIT_TEST_SUITE_END();
 public:
@@ -55,6 +56,7 @@
     virtual void smartPointerInsert();
 	virtual void conditionalInsert();
     virtual void DisableFailures(){m_DisableFailures=true;};
+	virtual void insertAutoGen(); //Insert empty non-feature
 protected:
     virtual void  set_provider() {};
Modified: trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_err3S_master.txt
--- trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_err3S_master.txt	2007-01-20 14:20:11 UTC (rev 657)
+++ trunk/Providers/GenericRdbms/Src/UnitTest/apply_schema_err3S_master.txt	2007-01-22 17:45:43 UTC (rev 658)
@@ -26,6 +26,7 @@
  Error in Column {USER_DS}_apply_schema.dbo.base_missing.scale_too_high: scale 128 is greater than maximum allowed (38)
  Cannot change identity properties for class Error:Base Missing from () to (ID); identity property change is not supported
  Base class Acad:Ghost for class Error:Base Missing not found in current database
+ Identity Property 'Error:Base Conflict.FeatId' for new class must be autogenerated or non-readonly
  Cannot add/modify class Error:Base Conflict; identity properties inherited from base class are different in the Feature Schema (ID) and the Database (FeatId)
  Class 'Error:Base Conflict' and base class 'Acad:AcDbEntity' have different class types
  Class 'Error:Feature object property class', for object property 'Error:Error Op.featureClass', is not an FdoClass
More information about the fdo-commits mailing list
