[fdo-commits] r667 - trunk/Providers/GenericRdbms/Src/Fdo/Lt
svn_fdo at osgeo.org svn_fdo at osgeo.org
Mon Jan 22 16:11:18 EST 2007
Author: thomasknoell
Date: 2007-01-22 16:11:17 -0500 (Mon, 22 Jan 2007)
New Revision: 667
   trunk/Providers/GenericRdbms/Src/Fdo/Lt/FdoRdbmsCommitLongTransaction.cpp
   trunk/Providers/GenericRdbms/Src/Fdo/Lt/FdoRdbmsGetLongTransactions.cpp
   trunk/Providers/GenericRdbms/Src/Fdo/Lt/FdoRdbmsRollbackLongTransaction.cpp
Modifications to the code to reflect the changed exception messages.
Modified: trunk/Providers/GenericRdbms/Src/Fdo/Lt/FdoRdbmsCommitLongTransaction.cpp
--- trunk/Providers/GenericRdbms/Src/Fdo/Lt/FdoRdbmsCommitLongTransaction.cpp	2007-01-22 21:10:33 UTC (rev 666)
+++ trunk/Providers/GenericRdbms/Src/Fdo/Lt/FdoRdbmsCommitLongTransaction.cpp	2007-01-22 21:11:17 UTC (rev 667)
@@ -1,5 +1,5 @@
- * Copyright (C) 2004-2006  Autodesk, Inc.
+ * Copyright (C) 2004-2007  Autodesk, Inc.
  * This library is free software; you can redistribute it and/or
  * modify it under the terms of version 2.1 of the GNU Lesser
@@ -156,9 +156,11 @@
                 FDORDBMSLONGTRANSACTIONCONSTANTS_LT_NAME_MAX_LENGTH) ||
         (wcslen(value) == 0                                        )    )
         throw FdoCommandException::Create(
-                      NlsMsgGet1(FDORDBMS_358,
-                                 "Invalid long transaction name '%1$ls'",
-                                 value));
+                NlsMsgGet2(
+                    FDORDBMS_358,
+                    "%1$ls: Long transaction name ('%2$ls') too long (0 < name <= 30)",
+                    L"FdoICommitLongTransaction",
+                    value));
     if (wcscmp(value, FDO_ROOTLONGTRANSACTION) == 0)
@@ -240,9 +242,9 @@
               NlsMsgGet2(
                 FDORDBMS_363,
-                "Invalid long transaction name ('%1$ls') for command '%2$ls'",
+                "%1$ls: Invalid long transaction name ('%2$ls')",
                 L"NULL",
-                L"FdoIRollbackLongTransaction"));
+                L"FdoICommitLongTransaction"));
       // Set a shortcut reference to the Long Transaction Manager.
Modified: trunk/Providers/GenericRdbms/Src/Fdo/Lt/FdoRdbmsGetLongTransactions.cpp
--- trunk/Providers/GenericRdbms/Src/Fdo/Lt/FdoRdbmsGetLongTransactions.cpp	2007-01-22 21:10:33 UTC (rev 666)
+++ trunk/Providers/GenericRdbms/Src/Fdo/Lt/FdoRdbmsGetLongTransactions.cpp	2007-01-22 21:11:17 UTC (rev 667)
@@ -1,5 +1,5 @@
@@ -113,9 +113,11 @@
         if ((wcslen(value) >  DBI_VERSION_NAME_LENGTH) ||
-                                 value));
+                      NlsMsgGet2(
+                        FDORDBMS_358,
+                        L"FdoIGetLongTransactions",
+                        value));
     // The basic tests to ensure the given long transaction name is valid have
     // been completed and the given name can be stored with the command.
Modified: trunk/Providers/GenericRdbms/Src/Fdo/Lt/FdoRdbmsRollbackLongTransaction.cpp
--- trunk/Providers/GenericRdbms/Src/Fdo/Lt/FdoRdbmsRollbackLongTransaction.cpp	2007-01-22 21:10:33 UTC (rev 666)
+++ trunk/Providers/GenericRdbms/Src/Fdo/Lt/FdoRdbmsRollbackLongTransaction.cpp	2007-01-22 21:11:17 UTC (rev 667)
@@ -1,5 +1,5 @@
@@ -155,9 +155,11 @@
-                                 value));
+                NlsMsgGet2(
+                    FDORDBMS_358,
+                    L"FdoIRollbackLongTransaction",
+                    value));
More information about the fdo-commits mailing list
