[fdo-commits] r685 - trunk/Providers/GenericRdbms/Src/SchemaMgr/Lp
svn_fdo at osgeo.org svn_fdo at osgeo.org
Wed Jan 24 12:50:07 EST 2007
Author: brentrobinson
Date: 2007-01-24 12:50:07 -0500 (Wed, 24 Jan 2007)
New Revision: 685
   trunk/Providers/GenericRdbms/Src/SchemaMgr/Lp/ClassDefinition.cpp
Merged from 3.2.x branch
Modified: trunk/Providers/GenericRdbms/Src/SchemaMgr/Lp/ClassDefinition.cpp
--- trunk/Providers/GenericRdbms/Src/SchemaMgr/Lp/ClassDefinition.cpp	2007-01-24 16:54:31 UTC (rev 684)
+++ trunk/Providers/GenericRdbms/Src/SchemaMgr/Lp/ClassDefinition.cpp	2007-01-24 17:50:07 UTC (rev 685)
@@ -136,20 +136,22 @@
     FdoSmLpSchemaP pSchema = GetLogicalPhysicalSchema();
+    FdoSmOvTableMappingType tableMappingType = FdoSmOvTableMappingType_Default;
-    // Extract any class overrides
-    if ( pClassOverrides  ) {
-        FdoRdbmsOvClassDefinition* pRdbmsOverrides = (FdoRdbmsOvClassDefinition*) pClassOverrides;
-        FdoRdbmsOvTableP tableOverrides = pRdbmsOverrides->GetTable();
+    if ( (GetElementState() == FdoSchemaElementState_Added) || GetIsFromFdo() ) {
+        // Extract any class overrides
+        if ( pClassOverrides  ) {
+            FdoRdbmsOvClassDefinition* pRdbmsOverrides = (FdoRdbmsOvClassDefinition*) pClassOverrides;
-        if ( (GetElementState() == FdoSchemaElementState_Added) || GetIsFromFdo() ) {
-            // TODO: the following is inconsistent with the way table name is handle
-            // In both cases should report modification errors or ignore on modification.
-            SetTableMapping( pRdbmsOverrides->GetTableMapping() );
+            tableMappingType = pRdbmsOverrides->GetTableMapping();
             // Save the table mapping specified by overrides, since mDbObjectMapping
             // may get defaulted.
-            SetOvTableMapping( FdoSmOvTableMappingTypeMapper::Type2String( pRdbmsOverrides->GetTableMapping() ) );
+            SetOvTableMapping( FdoSmOvTableMappingTypeMapper::Type2String( tableMappingType ) );
+        // TODO: the following is inconsistent with the way table name is handle
+        // In both cases should report modification errors or ignore on modification.
+        SetTableMapping( tableMappingType );
More information about the fdo-commits mailing list
