[fdo-commits] r661 - in branches/3.2.x/Utilities/Common: Inc Src
svn_fdo at osgeo.org
Wed Jan 24 15:49:10 EST 2007
Author: gregboone
Date: 2007-01-24 15:49:10 -0500 (Wed, 24 Jan 2007)
New Revision: 661
branches/3.2.x/Utilities/Common/Inc/FdoCommonFile.h
branches/3.2.x/Utilities/Common/Src/FdoCommonFile.cpp
Add new Method: FdoCommonFile::GetFileDirectoryAndName(const wchar_t *location, FdoStringP& directory, FdoStringP& filename)
Modified: branches/3.2.x/Utilities/Common/Inc/FdoCommonFile.h
--- branches/3.2.x/Utilities/Common/Inc/FdoCommonFile.h 2007-01-24 20:43:07 UTC (rev 660)
+++ branches/3.2.x/Utilities/Common/Inc/FdoCommonFile.h 2007-01-24 20:49:10 UTC (rev 661)
@@ -586,6 +586,16 @@
static bool IsAbsolutePath(const wchar_t *pFilename);
/// \brief
+ /// Determines the directory and filename parts from the specified path.
+ /// \param path
+ /// The path.
+ /// Returns nothing.
+ static bool GetFileDirectoryAndName(const wchar_t *location, FdoStringP& directory, FdoStringP& name);
+ /// \brief
/// Changes the read-write access mode of a file.
/// On Windows this sets/clears the read-only flag.
/// On Linux this only sets/clears the file's owner write flag.
Modified: branches/3.2.x/Utilities/Common/Src/FdoCommonFile.cpp
--- branches/3.2.x/Utilities/Common/Src/FdoCommonFile.cpp 2007-01-24 20:43:07 UTC (rev 660)
+++ branches/3.2.x/Utilities/Common/Src/FdoCommonFile.cpp 2007-01-24 20:49:10 UTC (rev 661)
@@ -1129,6 +1129,59 @@
#endif
+bool FdoCommonFile::GetFileDirectoryAndName(const wchar_t *location, FdoStringP& directory, FdoStringP& filename)
+#ifndef _WIN32
+ struct stat my_stat;
+ char* mbLocation = NULL;
+ wide_to_multibyte(mbLocation, location);
+ if (0 != stat (mbLocation, &my_stat))
+ return false;
+#else
+ DWORD attributes = GetFileAttributesW (location);
+ if ((INVALID_FILE_ATTRIBUTES == attributes))
+ return false;
+#endif
+ // Extract the file name and path from location. There are two kinds of delimiters,
+ // The last one appears would be selected to extract the file name.
+ // e.g. location1="c:\\path1/test.bmp", index would be set at "/".
+ const wchar_t* pdest = wcsrchr(location, FILE_PATH_DELIMITER); // L'\\'
+ const wchar_t* pdest2 = wcsrchr(location, FILE_PATH_DELIMITER2); // L'/'
+ int index = (int)(pdest - location);
+ int index2 = (int)(pdest2 - location);
+ if (index2 > index) {
+ index = index2;
+ pdest = pdest2;
+ // extract the filename
+ if (pdest) {
+ wchar_t lfilename[500];
+#ifdef _WIN32
+ wcscpy_s(lfilename, 500, pdest + 1);
+#else
+ lfilename = pdest+1;
+#endif
+ filename = lfilename;
+ // extract the directory name
+ if (index) {
+ wchar_t path[500];
+#ifdef _WIN32
+ wcsncpy_s(path, 500, location, index);
+#else
+ wcsncpy(path, location, index);
+#endif
+ directory = path;
+ return true;
void FdoCommonFile::Chmod(FdoString* filePath, bool bReadWrite)
#ifdef _WIN32
More information about the fdo-commits
