[fdo-commits] r666 - in trunk/Utilities: SchemaMgr/Src/Sm/Lp
TestCommon/Inc
svn_fdo at osgeo.org
Wed Jan 24 17:12:58 EST 2007
Author: danstoica
Date: 2007-01-24 17:12:58 -0500 (Wed, 24 Jan 2007)
New Revision: 666
trunk/Utilities/SchemaMgr/Src/Sm/Lp/SchemaCollection.cpp
trunk/Utilities/TestCommon/Inc/TestCommonConstraints.h
Date constraints described as strings fix
Modified: trunk/Utilities/SchemaMgr/Src/Sm/Lp/SchemaCollection.cpp
--- trunk/Utilities/SchemaMgr/Src/Sm/Lp/SchemaCollection.cpp 2007-01-24 21:58:41 UTC (rev 665)
+++ trunk/Utilities/SchemaMgr/Src/Sm/Lp/SchemaCollection.cpp 2007-01-24 22:12:58 UTC (rev 666)
@@ -925,7 +925,7 @@
FdoPtr<FdoDataValue> ret = val;
// Fast return if nothing to do
- if ( val == NULL || propType == FdoDataType_DateTime )
+ if ( val == NULL )
return ret;
FdoDataType constrType = val->GetDataType();
@@ -1023,6 +1023,39 @@
break;
+ case FdoDataType_String:
+ switch (propType) {
+ case FdoDataType_DateTime:
+ newData = val; // In case the conversion fail, return the same.
+ FdoStringP valString = ((FdoStringValue*)(FdoDataValue*)val)->GetString();
+ const char *timeStr = (const char *)valString;
+ if( timeStr != NULL && *timeStr != '\0' )
+ char *fmt = valString.Contains(L":") ? "%4d-%02d-%02d %02d:%02d:%02d" : "%4d-%02d-%02d-%02d-%02d-%02d";
+ int year, month, day, hour, minute, seconds;
+ year = month = day = hour = minute = seconds = 0;
+ int count = sscanf(timeStr, fmt, &year, &month, &day, &hour, &minute, &seconds);
+ // Check the number of successfully read items
+ if ( count >= 3 )
+ newData = FdoDateTimeValue::Create(FdoDateTime((FdoInt16)year, (FdoInt8)month, (FdoInt8)day,
+ (FdoInt8)hour, (FdoInt8)minute, (float)seconds));
+ break;
+ // Other cases...
+ default:
+ break;
ret = newData;
Modified: trunk/Utilities/TestCommon/Inc/TestCommonConstraints.h
--- trunk/Utilities/TestCommon/Inc/TestCommonConstraints.h 2007-01-24 21:58:41 UTC (rev 665)
+++ trunk/Utilities/TestCommon/Inc/TestCommonConstraints.h 2007-01-24 22:12:58 UTC (rev 666)
@@ -202,20 +202,18 @@
FdoPtr<FdoDataValue> val = pList->GetItem(j);
bool valMatched = false;
- // Some providers' DescribeSchema implementations set the constraint
- // values for date properties to string. Temporarily skip this check
- // for these providers until this bug is fixed.
- if ( val->GetDataType() == FdoDataType_DateTime ) {
- for ( int k = 0; k < masterCount && !valMatched; k++ ) {
- valMatched = ( wcscmp(val->ToString(), pMaster[k]) == 0 );
+ if ( val->GetDataType() != FdoDataType_DateTime )
+ CPPUNIT_ASSERT_MESSAGE( "Wrong type for datetime constraint returned", false);
- CPPUNIT_ASSERT_MESSAGE(
- (const char*) FdoStringP::Format( L"Wrong List Value %ls", pPropName ),
- valMatched
+ for ( int k = 0; k < masterCount && !valMatched; k++ ) {
+ valMatched = ( wcscmp(val->ToString(), pMaster[k]) == 0 );
+ (const char*) FdoStringP::Format( L"Wrong List Value %ls", pPropName ),
+ valMatched
DBG(printf("%ls,", val->ToString()));
DBG(printf("))\n"));
More information about the fdo-commits
