[fdo-commits] r691 - trunk/Providers/GenericRdbms/Src/UnitTest/Odbc
svn_fdo at osgeo.org
Fri Jan 26 16:31:34 EST 2007
Author: gavincramer
Date: 2007-01-26 16:31:34 -0500 (Fri, 26 Jan 2007)
New Revision: 691
trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcBaseSetup.cpp
trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoConnectTest.cpp
trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoConnectTest.h
Port FDO345 from 3.2.x to trunk
Modified: trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcBaseSetup.cpp
--- trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcBaseSetup.cpp 2007-01-26 21:28:35 UTC (rev 690)
+++ trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcBaseSetup.cpp 2007-01-26 21:31:34 UTC (rev 691)
@@ -1,5 +1,5 @@
- * Copyright (C) 2004-2006 Autodesk, Inc.
+ * Copyright (C) 2004-2007 Autodesk, Inc.
* This library is free software; you can redistribute it and/or
* modify it under the terms of version 2.1 of the GNU Lesser
@@ -343,6 +343,42 @@
L"( FEATID1, NAME, X, Y )",
L" values ",
L"( 2, 'His''Name', 20, 25 );",
+#ifdef _WIN32
L"",
+ L"create table ALLDBTYPES (",
+ L"DBTYPE_VARCHAR2 VARCHAR2(10),",
+ L"DBTYPE_NUMBER NUMBER,",
+ L"DBTYPE_NUMBER_20_0 NUMBER(20,0),",
+ L"DBTYPE_NUMBER_27_5 NUMBER(27,5),",
+ L"DBTYPE_INTEGER INTEGER,",
+ L"DBTYPE_SMALLINT SMALLINT,",
+ L"DBTYPE_DECIMAL DECIMAL,",
+ L"DBTYPE_DECIMAL_26 DECIMAL(26),",
+ L"DBTYPE_NUMERIC NUMERIC,",
+ L"DBTYPE_NUMERIC_25_3 NUMERIC(25,3),",
+ L"DBTYPE_FLOAT FLOAT,",
+ L"DBTYPE_REAL REAL,",
+ L"DBTYPE_VARCHAR VARCHAR(10),",
+ L"DBTYPE_DATE DATE,",
+ L"DBTYPE_CHAR CHAR,",
+ L"DBTYPE_TIMESTAMP TIMESTAMP,",
+ L"DBTYPE_RAW10 RAW(10),",
+ L"DBTYPE_LONGRAW LONG RAW,",
+ L"DBTYPE_TIMESTAMP_TZ TIMESTAMP WITH TIME ZONE,",
+ L"DBTYPE_INTERVAL_YM INTERVAL YEAR TO MONTH,",
+ L"DBTYPE_INTERVAL_DS INTERVAL DAY TO SECOND,",
+ L"DBTYPE_TIMESTAMP_LTZ TIMESTAMP WITH LOCAL TIME ZONE",
+ L");",
+ L"",
+ L"create table ALLDBTYPES2 (",
+ L"DBTYPE_LONG LONG",
+ L");",
+ L"create table ALLDBTYPES3 (",
+ L"DBTYPE_LONGVARCHAR LONG VARCHAR",
+ L");",
+#endif
+ L"",
NULL
Modified: trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoConnectTest.cpp
--- trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoConnectTest.cpp 2007-01-26 21:28:35 UTC (rev 690)
+++ trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoConnectTest.cpp 2007-01-26 21:31:34 UTC (rev 691)
@@ -1,5 +1,5 @@
@@ -307,7 +307,258 @@
+void OdbcOracleFdoConnectTest::AllDatabaseTypesTest()
#ifdef _WIN32
+ OdbcBaseSetup pOdbcSetup(DataBaseType_Oracle);
+ try
+ FdoStringP userConnectString = UnitTestUtil::GetConnectionString(Connection_OraSetup);
+ // Create/open primary connection:
+ FdoPtr<FdoIConnection> connection = UnitTestUtil::GetProviderConnectionObject();
+ connection->SetConnectionString ( userConnectString);
+ connection->Open();
+ pOdbcSetup.CreateDataStore(connection.p, L"");
+ connection->Close();
+ catch (FdoException *ex)
+ ex->Release();
+ try
+ // call the static method
+ if (connection == NULL)
+ CPPUNIT_FAIL("FAILED - CreateConnection returned NULL\n");
+ connection->SetConnectionString(UnitTestUtil::GetConnectionString(Connection_WithDSN));
+ // Inspect tables that collectively contain has at least one column of all the database'
+ // built-in column types that a client can create. Multiple tables are used due to
+ // Oracle's restrictions on multiple LONG column types in one table.
+ // First, check incremental class loading by doing a Select on each one.
+ FdoPtr<FdoISelect> selectCmd = (FdoISelect*)connection->CreateCommand(FdoCommandType_Select);
+ selectCmd->SetFeatureClassName(L"ALLDBTYPES");
+ FdoPtr<FdoIFeatureReader> readerIncr = selectCmd->Execute();
+ FdoPtr<FdoClassDefinition> classDefIncr = readerIncr->GetClassDefinition();
+ AssertAllDatabaseTypes(classDefIncr);
+ selectCmd = (FdoISelect*)connection->CreateCommand(FdoCommandType_Select);
+ selectCmd->SetFeatureClassName(L"ALLDBTYPES2");
+ readerIncr = selectCmd->Execute();
+ classDefIncr = readerIncr->GetClassDefinition();
+ selectCmd->SetFeatureClassName(L"ALLDBTYPES3");
+ readerIncr->Close();
+ // Now re-open the database (to get rid of any partial schema loading)
+ // and get a full schema description.
+ FdoPtr<FdoIDescribeSchema> describeSchemaCmd =
+ (FdoIDescribeSchema*)connection->CreateCommand(FdoCommandType_DescribeSchema);
+ FdoPtr<FdoFeatureSchemaCollection> schemas = describeSchemaCmd->Execute();
+ if (schemas == NULL)
+ CPPUNIT_FAIL("FAILED - DescribeSchema returned NULL collection\n");
+ bool foundAllTypesClass = false;
+ bool foundAllTypesClass2 = false;
+ bool foundAllTypesClass3 = false;
+ FdoInt32 numSchemas = schemas->GetCount();
+ for (int i=0; i<numSchemas && !foundAllTypesClass; i++)
+ FdoPtr<FdoFeatureSchema> schema = schemas->GetItem(i);
+ FdoPtr<FdoClassCollection> classes = schema->GetClasses();
+ FdoInt32 numClasses = classes->GetCount();
+ for (int j=0; j<numClasses; j++)
+ FdoPtr<FdoClassDefinition> classDef = classes->GetItem(j);
+ // analyze the feature class
+ FdoString* className = classDef->GetName();
+ if (wcscmp(className, L"ALLDBTYPES")==0 ||
+ wcscmp(className, L"ALLDBTYPES2")==0 ||
+ wcscmp(className, L"ALLDBTYPES3")==0)
+ if (wcscmp(className, L"ALLDBTYPES")==0) foundAllTypesClass = true;
+ if (wcscmp(className, L"ALLDBTYPES2")==0) foundAllTypesClass2 = true;
+ if (wcscmp(className, L"ALLDBTYPES3")==0) foundAllTypesClass3 = true;
+ AssertAllDatabaseTypes(classDef);
+ // Select from the table and check the reader's class
+ // definition too.
+ selectCmd->SetFeatureClassName(className);
+ FdoPtr<FdoIFeatureReader> reader = selectCmd->Execute();
+ FdoPtr<FdoClassDefinition> classDef2 = reader->GetClassDefinition();
+ AssertAllDatabaseTypes(classDef2);
+ if (!foundAllTypesClass)
+ CPPUNIT_FAIL("FAILED - did not find class ALLDBTYPES\n");
+ if (!foundAllTypesClass2)
+ CPPUNIT_FAIL("FAILED - did not find class ALLDBTYPES2\n");
+ if (!foundAllTypesClass3)
+ CPPUNIT_FAIL("FAILED - did not find class ALLDBTYPES3\n");
+ TestCommonFail (ex);
+#else
+ CPPUNIT_FAIL("OdbcOracleFdoConnectTest::AllDatabaseTypesTest disable");
+#endif
+struct OdbcOracleAllDatabaseTypesMapEntry
+ FdoStringP propName;
+ FdoDataType dataType;
+ FdoInt32 length; // -1 == don't care
+ FdoInt32 precision; // -1 == don't care
+ FdoInt32 scale; // -1 == don't care
+// Any column types that are not in these lists will not appear in FDO
+// class definitions (schema manager skips unsupported types).
+// Multiple tables are used because Oracle has restrictions on how
+// many "long" columns may appear in one table.
+static OdbcOracleAllDatabaseTypesMapEntry OdbcOracleAllDatabaseTypesMap_S[] =
+ { L"DBTYPE_VARCHAR2", FdoDataType_String, 10, -1, -1 },
+ { L"DBTYPE_NUMBER", FdoDataType_Double, -1, 0, 0 },
+ { L"DBTYPE_NUMBER_20_0", FdoDataType_Decimal, -1, 20, 0 },
+ { L"DBTYPE_NUMBER_27_5", FdoDataType_Decimal, -1, 27, 5 },
+ { L"DBTYPE_INTEGER", FdoDataType_Decimal, -1, 38, 0 },
+ { L"DBTYPE_SMALLINT", FdoDataType_Decimal, -1, 38, 0 },
+ { L"DBTYPE_DECIMAL", FdoDataType_Decimal, -1, 38, 0 },
+ { L"DBTYPE_DECIMAL_26", FdoDataType_Decimal, -1, 26, 0 },
+ { L"DBTYPE_NUMERIC", FdoDataType_Decimal, -1, 38, 0 },
+ { L"DBTYPE_NUMERIC_25_3", FdoDataType_Decimal, -1, 25, 3 },
+ { L"DBTYPE_FLOAT", FdoDataType_Double, -1, 0, 0 },
+ { L"DBTYPE_REAL", FdoDataType_Double, -1, 0, 0 },
+ { L"DBTYPE_VARCHAR", FdoDataType_String, 10, 0, 0 },
+ { L"DBTYPE_DATE", FdoDataType_DateTime, 0, 0, 0 },
+ { L"DBTYPE_CHAR", FdoDataType_String, 1, 0, 0 },
+ { L"DBTYPE_TIMESTAMP", FdoDataType_String, 0, 0, 0 },
+static OdbcOracleAllDatabaseTypesMapEntry OdbcOracleAllDatabaseTypesMap2_S[] =
+ { L"DBTYPE_LONG", FdoDataType_String, 1073741824, 0, 0 }
+static OdbcOracleAllDatabaseTypesMapEntry OdbcOracleAllDatabaseTypesMap3_S[] =
+ { L"DBTYPE_LONGVARCHAR", FdoDataType_String, 1073741824, 0, 0 }
+static FdoInt32 OdbcOracleAllDatabaseTypesMapSize_S =
+ sizeof(OdbcOracleAllDatabaseTypesMap_S) / sizeof(OdbcOracleAllDatabaseTypesMap_S[0]);
+static FdoInt32 OdbcOracleAllDatabaseTypesMapSize2_S =
+ sizeof(OdbcOracleAllDatabaseTypesMap2_S) / sizeof(OdbcOracleAllDatabaseTypesMap2_S[0]);
+static FdoInt32 OdbcOracleAllDatabaseTypesMapSize3_S =
+ sizeof(OdbcOracleAllDatabaseTypesMap3_S) / sizeof(OdbcOracleAllDatabaseTypesMap3_S[0]);
+void OdbcOracleFdoConnectTest::AssertAllDatabaseTypes(FdoClassDefinition * classDef)
+ FdoInt32 numPropertiesMatchedToMap = 0;
+ FdoString * className = classDef->GetName();
+ OdbcOracleAllDatabaseTypesMapEntry * typeMap = NULL;
+ FdoInt32 typeMapSize = 0;
+ typeMap = OdbcOracleAllDatabaseTypesMap_S;
+ typeMapSize = OdbcOracleAllDatabaseTypesMapSize_S;
+ else if (wcscmp(className, L"ALLDBTYPES2")==0)
+ typeMap = OdbcOracleAllDatabaseTypesMap2_S;
+ typeMapSize = OdbcOracleAllDatabaseTypesMapSize2_S;
+ else if (wcscmp(className, L"ALLDBTYPES3")==0)
+ typeMap = OdbcOracleAllDatabaseTypesMap3_S;
+ typeMapSize = OdbcOracleAllDatabaseTypesMapSize3_S;
+ else
+ CPPUNIT_FAIL("FAILED - no type map found\n");
+ printf("Checking column type conversion for class '%ls'...\n", className);
+ FdoPtr<FdoPropertyDefinitionCollection> classProps = classDef->GetProperties();
+ FdoInt32 numProps = classProps->GetCount();
+ for (FdoInt32 i=0; i<numProps; i++)
+ FdoPtr<FdoPropertyDefinition> propDef = classProps->GetItem(i);
+ FdoString* propName = propDef->GetName();
+ FdoPropertyType propType = propDef->GetPropertyType();
+ if (FdoPropertyType_DataProperty != propType)
+ CPPUNIT_FAIL("FAILED - unexpectedly encountered a property of type other than Data\n");
+ FdoDataPropertyDefinition* dataPropDef = (FdoDataPropertyDefinition*)propDef.p;
+ FdoDataType dataDataType = dataPropDef->GetDataType();
+ FdoInt32 dataLength = dataPropDef->GetLength();
+ FdoInt32 dataPrecision = dataPropDef->GetPrecision();
+ FdoInt32 dataScale = dataPropDef->GetScale();
+ printf(" Property '%ls' length=%d precision=%d scale=%d\n",
+ propName, dataLength, dataPrecision, dataScale);
+ bool foundTypeMapEntry = false;
+ for (FdoInt32 j=0;
+ j < typeMapSize && !foundTypeMapEntry;
+ j++)
+ OdbcOracleAllDatabaseTypesMapEntry * mapEntry = &typeMap[j];
+ if (wcscmp(propName, mapEntry->propName)==0)
+ foundTypeMapEntry = true;
+ numPropertiesMatchedToMap++;
+ if (mapEntry->length != -1)
+ CPPUNIT_ASSERT( dataLength == mapEntry->length );
+ if (mapEntry->precision != -1)
+ CPPUNIT_ASSERT( dataPrecision == mapEntry->precision );
+ if (mapEntry->scale != -1)
+ CPPUNIT_ASSERT( dataScale == mapEntry->scale );
+ if (!foundTypeMapEntry)
+ CPPUNIT_FAIL("FAILED - mismatch while checking properties in class ALLDBTYPES\n");
+ if (numPropertiesMatchedToMap != typeMapSize)
+ CPPUNIT_FAIL("FAILED - mismatch while checking all properties in class ALLDBTYPES\n");
+#ifdef _WIN32
void OdbcAccessFdoConnectTest::set_provider()
UnitTestUtil::SetProvider( "OdbcAccess" );
Modified: trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoConnectTest.h
--- trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoConnectTest.h 2007-01-26 21:28:35 UTC (rev 690)
+++ trunk/Providers/GenericRdbms/Src/UnitTest/Odbc/OdbcFdoConnectTest.h 2007-01-26 21:31:34 UTC (rev 691)
@@ -1,5 +1,5 @@
@@ -38,6 +38,7 @@
CPPUNIT_TEST_SUB_SUITE (OdbcOracleFdoConnectTest, FdoConnectTest);
CPPUNIT_TEST (ConfigFileTest);
+ CPPUNIT_TEST (AllDatabaseTypesTest);
CPPUNIT_TEST_SUITE_END ();
void set_provider();
@@ -46,12 +47,15 @@
void query () {};
void ConfigFileTest();
+ void AllDatabaseTypesTest();
// Some values that can vary by target datastore...
FdoString * GetConfigFile() {return L"OracleTestConfig.xml";}
FdoString * GetConfigFile2() {return L"OracleTestConfig2.xml";}
FdoString * GetSchemaName() {return L"Acdb";}
FdoString * GetPhysicalSchemaName() {return L"";}
+ void AssertAllDatabaseTypes(FdoClassDefinition * classDef);
#ifdef _WIN32
More information about the fdo-commits
