[fdo-commits] r697 -
	trunk/Providers/GenericRdbms/Src/Fdo/FeatureCommands
    svn_fdo at osgeo.org
    Mon Jan 29 13:03:05 EST 2007
Author: danstoica
Date: 2007-01-29 13:03:04 -0500 (Mon, 29 Jan 2007)
New Revision: 697
   trunk/Providers/GenericRdbms/Src/Fdo/FeatureCommands/FdoRdbmsFeatureReader.cpp
   trunk/Providers/GenericRdbms/Src/Fdo/FeatureCommands/FdoRdbmsFeatureReader.h
Merged FDO288 from branch 3.2.x to trunk
Modified: trunk/Providers/GenericRdbms/Src/Fdo/FeatureCommands/FdoRdbmsFeatureReader.cpp
--- trunk/Providers/GenericRdbms/Src/Fdo/FeatureCommands/FdoRdbmsFeatureReader.cpp	2007-01-27 21:06:04 UTC (rev 696)
+++ trunk/Providers/GenericRdbms/Src/Fdo/FeatureCommands/FdoRdbmsFeatureReader.cpp	2007-01-29 18:03:04 UTC (rev 697)
@@ -30,13 +30,17 @@
 #include "Inc/ut.h"
 #include "FdoCommonOSUtil.h"
+#include "FdoCommonFilterExecutor.h"
 #include <limits>       // For quiet_NaN()
 using namespace std;
-#define  PROPERTY2COLNAME( p1, p2 ) mConnection->GetUtility()->UnicodeToUtf8(Property2ColName( p1, p2 ))
-#define  PROPERTY2COLNAME_EXT( p1, p2, p3 ) mConnection->GetUtility()->UnicodeToUtf8(Property2ColName( p1, p2, p3 ))
+//#define FDORDBMS_SHOW_CACHE_PERF
+#define  PROPERTY2COLNAME( p1, p2 ) (Property2ColName( p1, p2))
+#define  PROPERTY2COLNAME_IDX( p1, p2, p3, p4 ) (Property2ColName( p1, p2, p3, p4))
+#define  PROPERTY2COLNAME_IDX_W( p1, p2, p3, p4 ) (Property2ColNameW( p1, p2, p3, p4))
 static  char  *strEndOfRecordExp = "End of feature data or NextFeature not called";
 static  char  *strObjPropetryExp = "Property '%1$ls' is an object property and cannot be returned through a basic type; use GetFeatureObject";
 static  char  *strNUllPropetryExp = "Property '%1$ls' value is NULL; use IsNull method before trying to access the property value";
@@ -60,6 +64,10 @@
         if (mFdoClassDefinition)
             mFdoClassDefinition->AddRef();
+        mPropertyInfoDefs = NULL;
+        mNumPropertyInfoDefs = 0;
+        mLastPropertyInfoDef = 0;
     virtual bool     ReadNext( )
@@ -96,19 +104,16 @@
     try \
         FdoPropertyType proptype; \
-        const char *colName = PROPERTY2COLNAME( propertyName, &proptype );\
-        if (colName == NULL) \
-             colName = GetDbAliasName( propertyName ); \
-            if( proptype != FdoPropertyType_DataProperty ) \
-                throw FdoCommandException::Create(NlsMsgGet1( FDORDBMS_67, strObjPropetryExp,  propertyName )); \
-            throw ""; \
+		int		cacheIndex; \
+        const wchar_t *colNameW = PROPERTY2COLNAME_IDX_W( propertyName, &proptype, NULL, &cacheIndex );\
+		if (colNameW == NULL) \
+			if( proptype != FdoPropertyType_DataProperty ) \
+				throw FdoCommandException::Create(NlsMsgGet1( FDORDBMS_67, strObjPropetryExp,  propertyName )); \
+			throw ""; \
         bool isNull = false; \
-        value = function( (char *) colName, &isNull, NULL); \
+		value = function( mPropertyInfoDefs[cacheIndex].columnPosition, &isNull, NULL ); \
         if( isNull ) \
             throw FdoCommandException::Create(NlsMsgGet1( FDORDBMS_385, strNUllPropetryExp,  propertyName )); \
@@ -177,16 +182,25 @@
     mUnskippedColCount = -1;
     mColList = NULL;
+	// Columns cache for fast property-column match retrieval
+	m_cacheHits	= 0;
+	m_cacheMissed1 = 0;
+	m_cacheMissed2 = 0;
     const FdoSmLpDataPropertyDefinition* featIdProp = classDef->RefFeatIdProperty();
     if ( featIdProp ) {
-        const FdoSmPhColumn* featIdCol = featIdProp->RefColumn();
-        if ( featIdCol )
-            mFeatIdColName = featIdCol->GetName();
+		// Cache the property in the 1st slot, followed by class id and revisionnumber.
+		// This is the order used by ReadNext()
+		mFeatIdColName = Property2ColName( featIdProp->GetName(), NULL );
     // TODO: push down to Schema Manager, rather than hard-code property names.
+    mClassIdColName = Property2ColName( L"ClassId", NULL );
     mRevNumColName = Property2ColName( L"RevisionNumber", NULL );
-    mClassIdColName = Property2ColName( L"ClassId", NULL );
     // Change the active SC if contains geometries
     ChangeActiveSpatialContext();
@@ -215,61 +229,210 @@
   if( mColList != NULL )
       delete[] mColList;
+  if ( mPropertyInfoDefs != NULL )
+      delete[] mPropertyInfoDefs;
   // Restore the active Spatial Context.
   RestoreActiveSpatialContext();
+#ifdef	FDORDBMS_SHOW_CACHE_PERF
+  printf("[Columns cache: Hits=%ld Missed1==%ld Missed2==%ld]\n", m_cacheHits, m_cacheMissed1, m_cacheMissed2);
+#endif
   if( mFdoConnection )
     mFdoConnection->Release();
-const wchar_t* FdoRdbmsFeatureReader::Property2ColName( const wchar_t *propName, FdoPropertyType *type, bool *found )
+const char* FdoRdbmsFeatureReader::Property2ColName( const wchar_t *propName, FdoPropertyType *type, bool *found, int *index )
-    wchar_t* string = NULL;
+	return Property2ColNameChar( propName, type, found, index );
+const wchar_t* FdoRdbmsFeatureReader::Property2ColNameW( const wchar_t *propName, FdoPropertyType *type, bool *found, int *index )
+	const char*  col = Property2ColNameChar( propName, type, found, index );
+	return ( col ? mPropertyInfoDefs[*index].columnNameW : (const wchar_t*)NULL );
+const char* FdoRdbmsFeatureReader::Property2ColNameChar( const wchar_t *propName, FdoPropertyType *type, bool *found, int *index )
+    const char*             string = NULL;
+	FdoStringP				colName;
+    FdoRdbmsPropertyInfoDef *cacheElem = NULL;
+    bool                    found2 = false;
+    int                     cacheIndex;
+	FdoPropertyType			propType;
+    if( mClassDefinition == NULL )
+        return NULL;
     if( found )
         *found = false;
+    if ( mPropertyInfoDefs == NULL )
+        const FdoSmLpPropertyDefinitionCollection *propertyDefinitions = mClassDefinition->RefProperties();
+        int numProps = propertyDefinitions->GetCount();
+        mPropertyInfoDefs = new FdoRdbmsPropertyInfoDef[ numProps ];
+    // Optimize the linear search in the cache:
+    // Chances are it's the A) next property (usually fetched in order)
+    // or B) the current property (after IsNull)
+    for ( int i = mLastPropertyInfoDef; !found2 && i < mNumPropertyInfoDefs; i++ )
+        cacheElem = &mPropertyInfoDefs[i];
+       found2 = ( FdoCommonOSUtil::wcsicmp( propName, cacheElem->propertyName ) == 0);
+       cacheIndex = i;
+    for ( int i = 0; !found2 && i < mLastPropertyInfoDef; i++ )
+        cacheIndex = i;
+    // Fast return if property found in the cache
+    if ( found2 )
+		m_cacheHits++;
+        if ( found )
+            *found = true;
+        if ( type )
+            *type = cacheElem->propertyType;
+        if ( index )
+            *index = cacheIndex;
+        mLastPropertyInfoDef = cacheIndex;
+		// Initialize Gdbi column position in case not initialize before.
+		if ( ( wcslen(cacheElem->columnPosition) == 0 ) && mQueryResult )
+			FdoStringP	colPos = FdoStringP::Format(L"%ld", mQueryResult->GetColumnIndex(cacheElem->columnNameW));
+			wcscpy( cacheElem->columnPosition, colPos );
+        return cacheElem->columnQName;
     if( type )
         *type = FdoPropertyType_DataProperty;
-    if( mClassDefinition == NULL )
-        return NULL;
-    for (int i=0; i<propertyDefinitions->GetCount(); i++)
-        const FdoSmLpPropertyDefinition *propertyDefinition = propertyDefinitions->RefItem(i);
+    const FdoSmLpPropertyDefinition *propertyDefinition = propertyDefinitions->RefItem(propName);
-        if (wcscmp(propertyDefinition->GetName(), propName) == 0)
-            if( found )
-                *found = true;
+    if ( propertyDefinition != NULL )
+		m_cacheMissed1++;
-            if( type != NULL )
-                *type = propertyDefinition->GetPropertyType();
-            if (propertyDefinition->GetPropertyType() == FdoPropertyType_DataProperty ||
-                propertyDefinition->GetPropertyType() == FdoPropertyType_GeometricProperty)
-                const FdoSmLpSimplePropertyDefinition* dataProp =
-                    static_cast<const FdoSmLpSimplePropertyDefinition*>(propertyDefinition);
-                const FdoSmPhColumn *column = dataProp->RefColumn();
-                if( column == NULL )
-                    return NULL;
-				string = mConnection->GetUtility()->newWcharP();
-				wcscpy( string, (const wchar_t*)FdoStringP::Format(L"%ls.%ls",(const wchar_t *)mClassDefinition->GetDbObjectName(), column->GetName() ) );
-                break;
-            break;
-    return string;
+        if( found )
+            *found = true;
+        propType = propertyDefinition->GetPropertyType();
+        if( type != NULL )
+            *type = propType;
+		if ( propType == FdoPropertyType_DataProperty ||
+             propType == FdoPropertyType_GeometricProperty)
+			const FdoSmLpSimplePropertyDefinition* dataProp =
+				static_cast<const FdoSmLpSimplePropertyDefinition*>(propertyDefinition);
+			const FdoSmPhColumn *column = dataProp->RefColumn();
+            if( column == NULL )
+                return NULL;
+			colName = FdoStringP(column->GetName()).Upper();
+            string = mConnection->GetUtility()->UnicodeToUtf8((const wchar_t *)colName);
+            // Cache
+            cacheElem = &mPropertyInfoDefs[mNumPropertyInfoDefs];
+            wcscpy( cacheElem->propertyName, propName );
+            strcpy( cacheElem->columnQName, string );
+			wcscpy( cacheElem->columnNameW, colName );
+            cacheElem->propertyType = propType;
+			wcscpy(cacheElem->columnPosition, L"");
+			cacheIndex = mNumPropertyInfoDefs;
+            if ( index )
+            // Remember this
+            mLastPropertyInfoDef = mNumPropertyInfoDefs;
+            mNumPropertyInfoDefs++;
+		else // Object, Association properties etc.
+			if ( index )
+				*index = -1;
+			return NULL;
+	else
+		m_cacheMissed2++;
+		// May be a computed identifier.
+		colName = GetDbAliasName( propName, &propType );
+		// Use the propName as col name.
+		if (colName == NULL )
+			return NULL;
+		colName = FdoStringP(colName).Upper();
+        // Cache
+        cacheElem->propertyType = FdoPropertyType_DataProperty;
+        if ( index )
+			*type = propType;
+        // Remember this
+	// Initialize Gdbi column index in case not initialize before.
+	// (Except for "classid" and "revisionumber" which may not be selected)
+	if ( (wcslen(cacheElem->columnPosition) == 0) && mQueryResult && type )
+	return mPropertyInfoDefs[cacheIndex].columnQName;
-const char* FdoRdbmsFeatureReader::GetDbAliasName( const wchar_t *propName )
+const char* FdoRdbmsFeatureReader::GetDbAliasName( const wchar_t *propName, FdoPropertyType *type )
     if( mProperties == NULL || mProperties->GetCount() == 0 )
         return NULL;
+	if ( type )
+		*type = FdoPropertyType_DataProperty;
     for (int i=0; i<mProperties->GetCount(); i++)
         FdoPtr<FdoIdentifier>ident = mProperties->GetItem( i );
@@ -282,6 +445,36 @@
     return NULL;
+void FdoRdbmsFeatureReader::GetExpressionType(FdoIConnection* connection, FdoClassDefinition* classDef, const char* colName, FdoExpression* expr, FdoPropertyType &propType, FdoDataType &dataType)
+    try
+        FdoCommonFilterExecutor::GetExpressionType(connection, classDef, expr, propType, dataType);
+    catch (FdoException *e)
+        e->Release();
+        // The expression was not recognized, use RDBI to determine types:
+        for ( int k=0; k<mColCount; k++ )
+            if( _stricmp(colName, mColList[k].c_alias) == 0 )
+                if (mColList[k].datatype == RDBI_GEOMETRY)
+                    propType = FdoPropertyType_GeometricProperty;
+                else
+                    propType = FdoPropertyType_DataProperty;
+                    dataType = FdoRdbmsUtil::DbiToFdoType( mColList[k].datatype );
+                break;
 // This is an internal method to support the DataReader
 FdoInt32 FdoRdbmsFeatureReader::GetPropertyCount()
@@ -505,7 +698,7 @@
             FdoPropertyType type;
             FdoPtr<FdoPropertyValue> FeatIdProp = mCurrentFeatId->GetItem(0);
             FdoPtr<FdoIdentifier> id = FeatIdProp->GetName();
-            const wchar_t *primKey = Property2ColName( id->GetText(), &type );
+            const char *primKey = Property2ColName( id->GetText(), &type );
             if( primKey == NULL || type != FdoPropertyType_DataProperty )
                 throw "";
@@ -1120,26 +1313,24 @@
     try
-        const char *colName = PROPERTY2COLNAME( propertyName, &type );
-            // May be an alias of a computed identifier
+		int				cacheIndex;
+        const	char	*colName = PROPERTY2COLNAME_IDX( propertyName, &type, NULL, &cacheIndex );
+        if (strlen(colName) == 0)
-            if( type != FdoPropertyType_DataProperty )
+			if( type != FdoPropertyType_DataProperty )
-            // The catch block will create the message string
-            throw "";
-        const wchar_t* value = mAttrQueryCache[mAttrsQidIdx].query->GetString( (char *) colName, &isNull, NULL );
+			// The catch block will create the message string
+			throw "";
+        const wchar_t* value = mAttrQueryCache[mAttrsQidIdx].query->GetString( mPropertyInfoDefs[cacheIndex].columnPosition, &isNull, NULL );
         if( isNull )
-        propertyValue = mStringMap.AddtoMap((char *) colName, value, mConnection->GetUtility() );
+		propertyValue = mStringMap.AddtoMap( (char *)colName, value, mConnection->GetUtility() );
     catch ( FdoCommandException* exc )
@@ -1296,28 +1487,24 @@
     try
+		int				cacheIndex;
+		const wchar_t *colNameW = PROPERTY2COLNAME_IDX_W( propertyName, &type, NULL, &cacheIndex );
         switch( type )
             case FdoPropertyType_DataProperty:
-                if (colName != NULL)
-                    return mAttrQueryCache[mAttrsQidIdx].query->GetIsNull( (char *) colName );
+                if (colNameW != NULL)
+                    return mAttrQueryCache[mAttrsQidIdx].query->GetIsNull( mPropertyInfoDefs[cacheIndex].columnPosition );
                 throw "";
             case FdoPropertyType_GeometricProperty:
                 try
-                    if( FdoPtr<FdoByteArray> (this->GetGeometry( propertyName, true )) != NULL )
-                        return false;
-                    else
-                        return true;
+					FdoPtr<FdoByteArray> ba = this->GetGeometry( propertyName, true);
+					return ( ba == NULL );
                 catch(FdoCommandException *exp )
@@ -1433,7 +1620,7 @@
     bool found;
-    const char *colName = PROPERTY2COLNAME_EXT( propertyName, &type, &found );
+    const char *colName = PROPERTY2COLNAME_IDX( propertyName, &type, &found, NULL );
     if( colName == NULL )
         if (exc)
@@ -1452,7 +1639,7 @@
 FdoByteArray* FdoRdbmsFeatureReader::GetGeometry(const wchar_t* propertyName, bool checkIsNullOnly)
-    return GetGeometry( propertyName, false, mAttrQueryCache[mAttrsQidIdx].query );
+    return GetGeometry( propertyName, checkIsNullOnly, mAttrQueryCache[mAttrsQidIdx].query );
 FdoByteArray* FdoRdbmsFeatureReader::GetGeometry(const wchar_t* propertyName, bool checkIsNullOnly, GdbiQueryResult *query)
@@ -1485,27 +1672,22 @@
         FdoSmOvGeometricColumnType columnType = pGeometricPropertyNonConst->GetGeometricColumnType();
         FdoSmOvGeometricContentType contentType = pGeometricPropertyNonConst->GetGeometricContentType();
         const char *    colName = NULL;
+		const wchar_t	*colNameW = NULL;
         const char *    colNameX = NULL;
         const char *    colNameY = NULL;
         const char *    colNameZ = NULL;
+		int		cacheIndex;
         if (FdoSmOvGeometricColumnType_Double != columnType)
-            colName = PROPERTY2COLNAME( propertyName, &type );
-                throw FdoRdbmsException::Create(NlsMsgGet1(
-                        FDORDBMS_468,
-                        "No column for geometric property '%1$ls'.",
-                        pPropertyDefinition->GetName()));
+            colNameW = PROPERTY2COLNAME_IDX_W( propertyName, &type, NULL, &cacheIndex );
+				throw "";
         else
             FdoString *colNameXW = pGeometricProperty->GetColumnNameX();
@@ -1534,8 +1716,9 @@
                FdoSmOvGeometricContentType_Default == contentType ) )
         	FdoIGeometry	*geom = NULL;
-            query->GetBinaryValue( (const wchar_t *) FdoStringP(colName), sizeof(FdoIGeometry *), (char*)&geom, &isNull,NULL);
-            pgeom = FDO_SAFE_ADDREF(geom);
+            query->GetBinaryValue( mPropertyInfoDefs[cacheIndex].columnPosition, sizeof(FdoIGeometry *), (char*)&geom, &isNull, NULL);
+			pgeom = FDO_SAFE_ADDREF(geom);
         else if ( FdoSmOvGeometricColumnType_Double == columnType &&
                   FdoSmOvGeometricContentType_Ordinates == contentType )
@@ -1574,8 +1757,8 @@
             if ( isSupportedType )
-                FdoPtr<FdoFgfGeometryFactory>  gf = FdoFgfGeometryFactory::GetInstance();
-                byteArray = gf->GetFgf( pgeom );
+				FdoPtr<FdoFgfGeometryFactory>  gf = FdoFgfGeometryFactory::GetInstance();
+				byteArray = gf->GetFgf( pgeom );
             else
@@ -1590,7 +1773,7 @@
-        else // isNull indicator is not set by dbi_get_val_b for geometry columns
+        else if (!checkIsNullOnly)// isNull indicator is not set by GDBI for geometry columns
@@ -1628,6 +1811,7 @@
         throw;
     return byteArray;
@@ -1811,24 +1995,40 @@
         mPropertiesFetched = false;
+		int cacheIndex;
+		// Reinitialize cache cursor
         if ( mFeatIdColName == L"" )
             dbiFeature.feat_num = 0;
         else
-            mQueryResult->GetBinaryValue( (const wchar_t*) mFeatIdColName, sizeof(long),
+			PROPERTY2COLNAME_IDX( mFeatIdColName, NULL, NULL, &cacheIndex );
+            mQueryResult->GetBinaryValue( mPropertyInfoDefs[cacheIndex].columnPosition, sizeof(long),
                         (char *)&dbiFeature.feat_num, NULL, NULL );
         if ( mClassIdColName == L"" )
             dbiFeature.classid = (long)mClassDefinition->GetId();
         else
-            mQueryResult->GetBinaryValue( (const wchar_t*) mClassIdColName, sizeof(long),
+			mLastPropertyInfoDef++;
+			PROPERTY2COLNAME_IDX( mClassIdColName, NULL, NULL, &cacheIndex );
                         (char *)&dbiFeature.classid, NULL, NULL );
         if ( mRevNumColName == L"" )
             dbiFeature.changeseq = 0;
         else
-            mQueryResult->GetBinaryValue( (const wchar_t*) mRevNumColName, sizeof(long),
+			PROPERTY2COLNAME_IDX( mRevNumColName, NULL, NULL, &cacheIndex );
                         (char *)&dbiFeature.changeseq, &isNull, NULL );
         // RevisionNumber could be null or RevisionColumn does not exist.
         if (isNull == false)
Modified: trunk/Providers/GenericRdbms/Src/Fdo/FeatureCommands/FdoRdbmsFeatureReader.h
--- trunk/Providers/GenericRdbms/Src/Fdo/FeatureCommands/FdoRdbmsFeatureReader.h	2007-01-27 21:06:04 UTC (rev 696)
+++ trunk/Providers/GenericRdbms/Src/Fdo/FeatureCommands/FdoRdbmsFeatureReader.h	2007-01-29 18:03:04 UTC (rev 697)
@@ -60,6 +60,14 @@
     size_t      len;
 } ValueDef;
+typedef struct {
+	wchar_t           propertyName[GDBI_SCHEMA_ELEMENT_NAME_SIZE];
+    char              columnQName[GDBI_SCHEMA_ELEMENT_NAME_SIZE*2 + 1];
+	wchar_t           columnNameW[GDBI_SCHEMA_ELEMENT_NAME_SIZE * sizeof(wchar_t) + 1]; // Not table qualified
+	wchar_t           columnPosition[3 * sizeof(wchar_t) + 1];  // 1- based
+    FdoPropertyType   propertyType;
+} FdoRdbmsPropertyInfoDef;
 typedef std::map<std::string, ValueDef *> StrMap;
 typedef std::pair<std::string, ValueDef *> ModulePair;
 typedef StrMap::iterator StringMapIterator;
@@ -134,9 +142,11 @@
       FdoRdbmsFeatureReader & operator=(const FdoRdbmsFeatureReader &right);
-      const wchar_t* Property2ColName( const wchar_t *propName, FdoPropertyType *type, bool *found = NULL );
+      const char*	 Property2ColName( const wchar_t *propName, FdoPropertyType *type, bool *found = NULL, int *index = NULL );
+      const wchar_t* Property2ColNameW( const wchar_t *propName, FdoPropertyType *type, bool *found = NULL, int *index = NULL );
+      const char*	 Property2ColNameChar( const wchar_t *propName, FdoPropertyType *type, bool *found = NULL, int *index = NULL );
-      const char* GetDbAliasName( const wchar_t *propName );
+      const char* GetDbAliasName( const wchar_t *propName, FdoPropertyType *type = NULL );
       int GetAttributeQuery( wchar_t* className );
@@ -150,6 +160,9 @@
       FdoIFeatureReader* GetAssociatedObject( const FdoSmLpAssociationPropertyDefinition *propertyDefinition );
+	  // Derive the given expression's property type and data type:
+	  void GetExpressionType(FdoIConnection* connection, FdoClassDefinition* classDef, const char* colName, FdoExpression* expr, FdoPropertyType &propType, FdoDataType &dataType);
 protected:
     virtual ~FdoRdbmsFeatureReader();
     virtual void Dispose();
@@ -262,7 +275,13 @@
     // secondary spatial filtering).
     FdoRdbmsSecondarySpatialFilters     mSecondarySpatialFilters;
+	// A cache of property definition names to avoid expensive string conversions
+	FdoRdbmsPropertyInfoDef   *mPropertyInfoDefs;
+	int                       mNumPropertyInfoDefs;
+	int                       mLastPropertyInfoDef;
+	int						  m_cacheHits;
+	int						  m_cacheMissed1;
+	int						  m_cacheMissed2;
 #endif // FDORDBMSFEATUREREADER_H
More information about the fdo-commits
