[fdo-commits] r699 - in trunk/Providers/GenericRdbms/Src: Gdbi
ODBCDriver
svn_fdo at osgeo.org
Mon Jan 29 13:47:41 EST 2007
Author: danstoica
Date: 2007-01-29 13:47:41 -0500 (Mon, 29 Jan 2007)
New Revision: 699
trunk/Providers/GenericRdbms/Src/Gdbi/GdbiQueryResult.cpp
trunk/Providers/GenericRdbms/Src/Gdbi/GdbiQueryResult.h
trunk/Providers/GenericRdbms/Src/ODBCDriver/bind.c
trunk/Providers/GenericRdbms/Src/ODBCDriver/constants.h
trunk/Providers/GenericRdbms/Src/ODBCDriver/define.c
trunk/Providers/GenericRdbms/Src/ODBCDriver/desc_slct.c
trunk/Providers/GenericRdbms/Src/ODBCDriver/execute.c
trunk/Providers/GenericRdbms/Src/ODBCDriver/fetch.c
trunk/Providers/GenericRdbms/Src/ODBCDriver/vndr_info.c
Merge branch 3.2.x to Trunk
Modified: trunk/Providers/GenericRdbms/Src/Gdbi/GdbiQueryResult.cpp
--- trunk/Providers/GenericRdbms/Src/Gdbi/GdbiQueryResult.cpp 2007-01-29 18:08:55 UTC (rev 698)
+++ trunk/Providers/GenericRdbms/Src/Gdbi/GdbiQueryResult.cpp 2007-01-29 18:47:41 UTC (rev 699)
@@ -25,6 +25,9 @@
#endif
#include "FdoCommonOSUtil.h"
#include "GdbiQueryIdentifier.h"
+#ifdef HAVE_GEOM_INFO_TYPE
+#include <inc/geometry/fgf/AllGeometry_c.h>
+#endif
// Arbitrary size which should be more than enough for the
// the ASCII or UNICODE representation of any numeric value.
@@ -66,6 +69,7 @@
m_QueryId = new GdbiQueryIdentifier(command, qid);
define_exec();
+ m_missed=0;
GdbiQueryResult::GdbiQueryResult(GdbiCommands* command, GdbiQueryIdentifier *queryObj):
m_pGdbiCommands( command ),
@@ -79,29 +83,45 @@
m_QueryId = FDO_SAFE_ADDREF(queryObj);
define_exec();
+ m_missed=0;
void GdbiQueryResult::define_exec()
- GdbiColumnInfoType* colInfo = new GdbiColumnInfoType;
char buffer[16];
- int name_length = GDBI_COLUMN_SIZE;
- wchar_t colName[GDBI_COLUMN_SIZE];
- mColMap = new std::map<std::wstring,GdbiColumnInfoType*>();
+ int name_length = GDBI_COLUMN_SIZE;
+ wchar_t colName[GDBI_COLUMN_SIZE];
+ int colType;
+ int colSize;
+ int colNullAllowed;
+ mColList = new std::vector<GdbiColumnInfoType*>();
int idx = 1;
bool status = false;
- while( m_pGdbiCommands->desc_slct( m_QueryId->GetQueryId(), idx++, name_length, colName, &colInfo->type, &colInfo->size, &colInfo->null_allowed) == RDBI_SUCCESS )
+ while( m_pGdbiCommands->desc_slct( m_QueryId->GetQueryId(), idx++, name_length, colName, &colType, &colSize, &colNullAllowed) == RDBI_SUCCESS )
FdoStringP upperName = FdoStringP(colName).Upper();
const wchar_t* name = (const wchar_t*)upperName;
- if (mColMap->find (name) != mColMap->end())
- continue; // TODO: throw new GdbiException(FdoCommonNlsUtil::NLSGetMessage( FDORDBMS_495, "Duplicate columns of name '%1$ls' found in query result.", fdordbms_cat, name));
- mColMap->insert( std::pair<std::wstring,GdbiColumnInfoType*> ( name, colInfo ) );
+ GdbiColumnInfoType* colInfo = new GdbiColumnInfoType;
+ mColList->push_back( colInfo );
+ // Copy info
+ colInfo->name = new wchar_t[wcslen(name) + 1];
+ wcscpy(colInfo->name, name );
+ colInfo->type = colType;
+ colInfo->size = colSize;
+ colInfo->null_allowed = colNullAllowed;
colInfo->original_type = colInfo->type;
- colInfo->index = idx-1;
+ colInfo->index = idx - 1;
m_pGdbiCommands->alcnullind(m_pGdbiCommands->get_array_size(), &(colInfo->isNull));
@@ -110,7 +130,7 @@
colInfo->type = RDBI_STRING;
else
- if (colInfo->type == RDBI_FIXED_CHAR || colInfo->type == RDBI_STRING)
+ if (colInfo->type == RDBI_FIXED_CHAR || colInfo->type == RDBI_STRING || colInfo->type == RDBI_WSTRING)
// allocate space for null indicator
colInfo->size++;
@@ -151,11 +171,8 @@
m_pGdbiCommands->define( m_QueryId->GetQueryId(), FdoCommonOSUtil::itoa(colInfo->index, buffer), colInfo->type, colInfo->size, (colInfo->type == RDBI_BLOB_REF) ? (char *)&(colInfo->value) : (char*)colInfo->value, colInfo->isNull );
- colInfo = new GdbiColumnInfoType;
- delete colInfo;
m_pGdbiCommands->execute( m_QueryId->GetQueryId(), 0, 0 );
@@ -167,11 +184,12 @@
m_pGdbiCommands->end_select( m_QueryId->GetQueryId());
- if( mColMap )
+ if( mColList )
- for (std::map <std::wstring,GdbiColumnInfoType*>::iterator i = mColMap->begin(); i != mColMap->end(); ++i )
+ for (size_t i = 0; i < mColList->size(); i++ )
- GdbiColumnInfoType *colInfo = i->second;
+ GdbiColumnInfoType *colInfo = mColList->at(i);
if( colInfo->value && colInfo->type == RDBI_BLOB_REF )
if (m_QueryId)
@@ -189,9 +207,13 @@
if( colInfo->isNull )
free( (void*)colInfo->isNull );
+ if ( colInfo->name )
+ delete [] colInfo->name;
delete colInfo;
- delete mColMap;
+ delete mColList;
FDO_SAFE_RELEASE(m_QueryId);
@@ -248,25 +270,22 @@
int GdbiQueryResult::GetColumnCount( )
- if( mColMap )
- return (int)mColMap->size();
+ if( mColList )
+ return (int)mColList->size();
return 0;
int GdbiQueryResult::GetColumnDesc( int colIdx, GdbiColumnDesc &desc )
- int idx = colIdx;
- std::map <std::wstring,GdbiColumnInfoType*>::iterator iter = mColMap->begin();
- for( iter = mColMap->begin(); iter != mColMap->end(); iter++ )
- if( idx == iter->second->index )
- break;
+ int idx = colIdx; // 1 based
- if( iter == mColMap->end() ) // error
- return false;
+ if ( colIdx > (int)mColList->size() ) // error
+ return false;
- GdbiColumnInfoType *colInfo = iter->second;
- strncpy( desc.column, (const char*)FdoStringP(iter->first.c_str(),true), sizeof(desc.column) - 1);
+ GdbiColumnInfoType *colInfo = mColList->at(idx-1);
+ strncpy( desc.column, (const char*)FdoStringP(colInfo->name), sizeof(desc.column) - 1);
desc.column[sizeof(desc.column)-1]=0;
desc.datatype = colInfo->original_type;
desc.size = (colInfo->type == RDBI_CHAR || colInfo->type == RDBI_FIXED_CHAR || colInfo->type == RDBI_STRING) ? colInfo->size-1 : colInfo->size;
@@ -277,122 +296,104 @@
int GdbiQueryResult::GetBinaryValue( const wchar_t *colName, int length, char *address, bool *null_ind, int *ccode )
- std::map <std::wstring,GdbiColumnInfoType*>::iterator iter;
- bool isNull;
- FdoStringP upperName = FdoStringP(colName).Upper();
- const wchar_t* name = (const wchar_t*)upperName;
- iter = mColMap->find( StripTable(name) );
- if( iter != mColMap->end() )
- isNull = (m_pGdbiCommands->is_null(colInfo->isNull, mArrayPos) == 1);
- if (isNull == false)
+ GdbiColumnInfoType *colInfo = FindColumnCache(colName);
+ bool isNull = (m_pGdbiCommands->is_null(colInfo->isNull, mArrayPos) == 1);
+ if (isNull == false)
+ if (colInfo->type == RDBI_CHAR || colInfo->type == RDBI_BOOLEAN)
- if (colInfo->type == RDBI_CHAR || colInfo->type == RDBI_BOOLEAN)
- memcpy(address, (char*)(colInfo->value) + mArrayPos*colInfo->size, 1);
- if (length != 1)
- address[1] = '\0';
- else
- int size = ( length > colInfo->size )? colInfo->size : length;
- memcpy(address, ((char*)colInfo->value) + mArrayPos*colInfo->size, size );
+ memcpy(address, (char*)(colInfo->value) + mArrayPos*colInfo->size, 1);
+ if (length != 1)
+ address[1] = '\0';
- if( null_ind )
- *null_ind = isNull;
+ else
+ int size = ( length > colInfo->size )? colInfo->size : length;
+ memcpy(address, ((char*)colInfo->value) + mArrayPos*colInfo->size, size );
+ if( null_ind )
+ *null_ind = isNull;
- if( ccode )
- *ccode = RDBI_SUCCESS;
+ if( ccode )
+ *ccode = RDBI_SUCCESS;
- return RDBI_SUCCESS;
+ return RDBI_SUCCESS;
- throw new GdbiException(L"Column X not selected");
-int GdbiQueryResult::GetAsciiValue( const wchar_t *colName, int length, char *address, bool *null_ind, int *ccode )
+int GdbiQueryResult::GetAsciiValue( GdbiColumnInfoType *colInfo, int length, char *address, bool *null_ind, int *ccode )
char tmpDblBuffer[60];
char lascii[200];
int lccode = RDBI_SUCCESS;
- bool isNull;
+ switch (colInfo->type)
- switch (colInfo->type)
- case RDBI_SHORT:
- sprintf(lascii, "%d", (*(short *)((char*)colInfo->value + mArrayPos*colInfo->size)));
- do_copy(lascii, address, length, &lccode);
- break;
- case RDBI_INT:
- case RDBI_LONG:
- sprintf(lascii, "%ld", (*(long *)((char*)colInfo->value + mArrayPos*colInfo->size)));
- break;
- case RDBI_LONGLONG:
+ case RDBI_SHORT:
+ sprintf(lascii, "%d", (*(short *)((char*)colInfo->value + mArrayPos*colInfo->size)));
+ do_copy(lascii, address, length, &lccode);
+ break;
+ case RDBI_INT:
+ case RDBI_LONG:
+ sprintf(lascii, "%ld", (*(long *)((char*)colInfo->value + mArrayPos*colInfo->size)));
+ break;
+ case RDBI_LONGLONG:
#ifdef _WIN32
- sprintf(lascii, "%I64d", (*(FdoInt64 *)((char*)colInfo->value + mArrayPos*colInfo->size)));
+ sprintf(lascii, "%I64d", (*(FdoInt64 *)((char*)colInfo->value + mArrayPos*colInfo->size)));
#else
- sprintf(lascii, "%lld", (*(FdoInt64 *)((char*)colInfo->value + mArrayPos*colInfo->size)));
+ sprintf(lascii, "%lld", (*(FdoInt64 *)((char*)colInfo->value + mArrayPos*colInfo->size)));
#endif
- break;
- case RDBI_FLOAT:
- sprintf(lascii, "%s", ut_dtoa( (double) (*(float *)((char*)colInfo->value + mArrayPos*colInfo->size)), tmpDblBuffer) );
- break;
- case RDBI_DOUBLE:
- sprintf(lascii, "%s", ut_dtoa( (*(double *)((char*)colInfo->value + mArrayPos*colInfo->size)), tmpDblBuffer ) );
- break;
- default:
- if (colInfo->type == RDBI_CHAR)
- // Oracle and MySQL do not put null indicators
- memcpy(address, (char*)(colInfo->value) + mArrayPos*colInfo->size, colInfo->size);
- if (length != 1)
- else
- memcpy(address, (char*)(colInfo->value) + mArrayPos*colInfo->size, size);
- if (size < colInfo->size)
- address[size-1] = '\0';
- lccode = RDBI_DATA_TRUNCATED;
- break;
+ break;
+ case RDBI_FLOAT:
+ sprintf(lascii, "%s", ut_dtoa( (double) (*(float *)((char*)colInfo->value + mArrayPos*colInfo->size)), tmpDblBuffer) );
+ break;
+ case RDBI_DOUBLE:
+ sprintf(lascii, "%s", ut_dtoa( (*(double *)((char*)colInfo->value + mArrayPos*colInfo->size)), tmpDblBuffer ) );
+ break;
+ default:
+ if (colInfo->type == RDBI_CHAR)
+ // Oracle and MySQL do not put null indicators
+ memcpy(address, (char*)(colInfo->value) + mArrayPos*colInfo->size, colInfo->size);
+ if (length != 1)
+ else
+ memcpy(address, (char*)(colInfo->value) + mArrayPos*colInfo->size, size);
+ if (size < colInfo->size)
+ address[size-1] = '\0';
+ lccode = RDBI_DATA_TRUNCATED;
+ break;
- if( null_ind )
+ if( null_ind )
- if( ccode )
- *ccode = lccode;
+ if( ccode )
+ *ccode = lccode;
template<typename T> T GdbiQueryResult::GetNumber(
- const wchar_t *colName,
- bool *null_ind,
+ const wchar_t *colName,
+ bool *null_ind,
int *ccode
T val = 0;
short shortVal;
@@ -402,83 +403,75 @@
double doubleVal;
FdoInt64 int64Val;
- bool isNull;
- if( null_ind )
- if( ccode )
+ if( null_ind )
+ if( ccode )
- case RDBI_SHORT:
- memcpy(&shortVal, ((char*)colInfo->value) + mArrayPos*colInfo->size, sizeof(short) );
- val = (T)shortVal;
- break;
+ case RDBI_SHORT:
+ memcpy(&shortVal, ((char*)colInfo->value) + mArrayPos*colInfo->size, sizeof(short) );
+ val = (T)shortVal;
+ break;
- case RDBI_INT:
- memcpy(&intVal, ((char*)colInfo->value) + mArrayPos*colInfo->size, sizeof(int) );
- val = (T)intVal;
- break;
+ case RDBI_INT:
+ memcpy(&intVal, ((char*)colInfo->value) + mArrayPos*colInfo->size, sizeof(int) );
+ val = (T)intVal;
+ break;
- case RDBI_LONG:
- memcpy(&longVal, ((char*)colInfo->value) + mArrayPos*colInfo->size, sizeof(long) );
- val = (T)longVal;
- break;
+ case RDBI_LONG:
+ memcpy(&longVal, ((char*)colInfo->value) + mArrayPos*colInfo->size, sizeof(long) );
+ val = (T)longVal;
+ break;
- memcpy(&int64Val, ((char*)colInfo->value) + mArrayPos*colInfo->size, sizeof(FdoInt64) );
- val = (T)int64Val;
- break;
+ memcpy(&int64Val, ((char*)colInfo->value) + mArrayPos*colInfo->size, sizeof(FdoInt64) );
+ val = (T)int64Val;
+ break;
- case RDBI_FLOAT:
- memcpy(&floatVal, ((char*)colInfo->value) + mArrayPos*colInfo->size, sizeof(float) );
- val = (T)floatVal;
- break;
+ case RDBI_FLOAT:
+ memcpy(&floatVal, ((char*)colInfo->value) + mArrayPos*colInfo->size, sizeof(float) );
+ val = (T)floatVal;
+ break;
- case RDBI_DOUBLE:
- memcpy(&doubleVal, ((char*)colInfo->value) + mArrayPos*colInfo->size, sizeof(double) );
- val = (T)doubleVal;
+ case RDBI_DOUBLE:
+ memcpy(&doubleVal, ((char*)colInfo->value) + mArrayPos*colInfo->size, sizeof(double) );
+ val = (T)doubleVal;
+ break;
+ case RDBI_STRING:
+ if( sizeof(T) == sizeof(FdoInt64) )
+ // Sql server workaround
+ sscanf((char*)colInfo->value+ mArrayPos*colInfo->size,"%lld", &int64Val);
break;
- case RDBI_STRING:
- if( sizeof(T) == sizeof(FdoInt64) )
- // Sql server workaround
- sscanf((char*)colInfo->value+ mArrayPos*colInfo->size,"%lld", &int64Val);
- break;
- case RDBI_WSTRING:
- swscanf((wchar_t*)colInfo->value+ mArrayPos*colInfo->size/sizeof(wchar_t),L"%lld", &int64Val);
- break;
- default:
- (void)GetBinaryValue(colName, sizeof(T), (char*)&val, null_ind, ccode );
+ case RDBI_WSTRING:
+ swscanf((wchar_t*)colInfo->value+ mArrayPos*colInfo->size/sizeof(wchar_t),L"%lld", &int64Val);
break;
+ default:
+ (void)GetBinaryValue(colInfo->name, sizeof(T), (char*)&val, null_ind, NULL );
+ break;
- return val;
+ return val;
FdoDouble GdbiQueryResult::GetDouble( const wchar_t *ColName, bool *isnull, int *ccode )
@@ -506,92 +499,72 @@
return GetNumber<FdoInt64>(ColName, isnull, ccode);
-FdoFloat GdbiQueryResult::GetFloat( const wchar_t *ColName, bool *isnull, int *ccode )
+FdoFloat GdbiQueryResult::GetFloat( const wchar_t *ColName, bool *isnull, int *ccode)
return GetNumber<float>(ColName, isnull, ccode);
// Return a const wchar_t that must be copied ASP
-FdoString* GdbiQueryResult::GetString( const wchar_t *colName, bool *isnull, int *ccode )
+FdoString* GdbiQueryResult::GetString( const wchar_t *colName, bool *isnull, int *ccode)
+ if( isnull )
+ *isnull = (m_pGdbiCommands->is_null(colInfo->isNull, mArrayPos) == 1);
+ if( ( m_pGdbiCommands->SupportsUnicode() && colInfo->original_type == RDBI_STRING ) ||
+ colInfo->original_type == RDBI_WSTRING )
+ if( ccode )
+ return (const wchar_t*)(((char*)colInfo->value) + mArrayPos*colInfo->size);
- if( isnull )
- *isnull = (m_pGdbiCommands->is_null(colInfo->isNull, mArrayPos) == 1);
- bool isNull = (m_pGdbiCommands->is_null(colInfo->isNull, mArrayPos) == 1);
+ if ((mAsciiValBuffer != NULL) && (mAsciiValBufferSize <= colInfo->size))
- if( ( m_pGdbiCommands->SupportsUnicode() && colInfo->original_type == RDBI_STRING ) ||
- colInfo->original_type == RDBI_WSTRING )
- if( ccode )
- return (const wchar_t*)(((char*)colInfo->value) + mArrayPos*colInfo->size);
- if ((mAsciiValBuffer != NULL) && (mAsciiValBufferSize <= colInfo->size))
- delete [] mAsciiValBuffer;
- mAsciiValBuffer = NULL;
- if (mAsciiValBuffer == NULL)
- mAsciiValBufferSize = (colInfo->size < GDBI_MIN_STRING_BUFFER_SIZE) ? GDBI_MIN_STRING_BUFFER_SIZE : colInfo->size;
- mAsciiValBuffer = new char[mAsciiValBufferSize];
- if (GetAsciiValue( name, mAsciiValBufferSize, mAsciiValBuffer, NULL, NULL) != RDBI_SUCCESS)
- return NULL;
+ delete [] mAsciiValBuffer;
+ mAsciiValBuffer = NULL;
+ if (mAsciiValBuffer == NULL)
+ mAsciiValBufferSize = (colInfo->size < GDBI_MIN_STRING_BUFFER_SIZE) ? GDBI_MIN_STRING_BUFFER_SIZE : colInfo->size;
+ mAsciiValBuffer = new char[mAsciiValBufferSize];
- if ((mUnicodeBuffer != NULL) && (mUnicodeBufferSize < mAsciiValBufferSize))
- delete[] mUnicodeBuffer;
- mUnicodeBuffer = NULL;
- if( mUnicodeBuffer == NULL )
- mUnicodeBufferSize = mAsciiValBufferSize;
- mUnicodeBuffer = new wchar_t[mUnicodeBufferSize];
+ if (GetAsciiValue( colInfo, mAsciiValBufferSize, mAsciiValBuffer, NULL, NULL ) != RDBI_SUCCESS)
+ return NULL;
- if( mAsciiValBuffer[0] == '\0' )
- mUnicodeBuffer[0] = '\0';
- else if( ! ut_utf8_to_unicode( mAsciiValBuffer, mUnicodeBuffer, mUnicodeBufferSize ) )
- throw GdbiException::Create(NlsMsgGet(FDORDBMS_47, "UTF8 conversion failed"));
+ if ((mUnicodeBuffer != NULL) && (mUnicodeBufferSize < mAsciiValBufferSize))
+ delete[] mUnicodeBuffer;
+ mUnicodeBuffer = NULL;
+ if( mUnicodeBuffer == NULL )
+ mUnicodeBufferSize = mAsciiValBufferSize;
+ mUnicodeBuffer = new wchar_t[mUnicodeBufferSize];
- if( ccode )
- return mUnicodeBuffer;
+ if( mAsciiValBuffer[0] == '\0' )
+ mUnicodeBuffer[0] = '\0';
+ else if( ! ut_utf8_to_unicode( mAsciiValBuffer, mUnicodeBuffer, mUnicodeBufferSize ) )
+ throw GdbiException::Create(NlsMsgGet(FDORDBMS_47, "UTF8 conversion failed"));
+ if( ccode )
-FdoString* GdbiQueryResult::GetString( int index, bool *isnull, int *ccode )
+ return mUnicodeBuffer;
+FdoString* GdbiQueryResult::GetString(int index, bool *isnull, int *ccode)
- if( mColMap )
- if( colInfo->index == index )
- return GetString( i->first.c_str() , isnull, ccode );
+ FdoStringP colName = FdoStringP::Format(L"%ld", index );
+ return GetString( (const wchar_t *)colName, isnull, ccode);
FdoBoolean GdbiQueryResult::GetBoolean( const wchar_t *ColName, bool *isnull, int *ccode )
@@ -605,19 +578,11 @@
bool GdbiQueryResult::GetIsNull( const wchar_t *colName )
+ GdbiColumnInfoType *colInfo = FindColumnCache(colName );
+ return ( m_pGdbiCommands->is_null( colInfo->isNull, mArrayPos ) == 1 );
- return ( m_pGdbiCommands->is_null( colInfo->isNull, mArrayPos ) == 1 );
void GdbiQueryResult::do_copy(char *ascii_I, char *ascii_O, int len, int *ccode)
int llen = (int)strlen(ascii_I);
@@ -677,3 +642,55 @@
return GetIsNull( (const wchar_t*) FdoStringP( ColName ) );
+FdoByteArray * GdbiQueryResult::GetFgfFromGeomInfo( char * geomInfo )
+ FdoByteArray * byteArray = NULL;
+ (void) m_pGdbiCommands->geom_to_fgf( m_QueryId->GetQueryId(), geomInfo, (void **)(&byteArray) );
+ return byteArray;
+#else
+ return NULL;
+#endif
+int GdbiQueryResult::GetColumnIndex( const wchar_t *colName )
+ GdbiColumnInfoType *colInfoCached = FindColumnCache( colName );
+ return colInfoCached->index; // 1 - based
+GdbiColumnInfoType *GdbiQueryResult::FindColumnCache( const wchar_t *colName )
+ GdbiColumnInfoType *colInfo = NULL;
+ bool found = false;
+ int colIndex = FdoCommonOSUtil::wtoi( colName );
+ // Number ?
+ if ( colIndex > 0 )
+ if( mColList && colIndex <= (int)mColList->size())
+ colInfo = mColList->at( colIndex - 1);
+ found = true;
+ else
+ FdoStringP upperName = FdoStringP(colName).Upper();
+ const wchar_t* name = StripTable(upperName);
+ for ( size_t i = 0; !found && i < mColList->size(); i++ )
+ colInfo = mColList->at(i);
+ found = ( wcscmp( colInfo->name, name ) == 0 );
+ if ( !found )
+ throw FdoCommandException::Create(NlsMsgGet1(FDORDBMS_42, "Column %1$ls not found", colName));
+ return colInfo;
Modified: trunk/Providers/GenericRdbms/Src/Gdbi/GdbiQueryResult.h
--- trunk/Providers/GenericRdbms/Src/Gdbi/GdbiQueryResult.h 2007-01-29 18:08:55 UTC (rev 698)
+++ trunk/Providers/GenericRdbms/Src/Gdbi/GdbiQueryResult.h 2007-01-29 18:47:41 UTC (rev 699)
@@ -32,6 +32,7 @@
#define GDBI_COLUMN_SIZE 255
typedef struct _col_type_ {
+ wchar_t *name;
int original_type;
int type;
int size;
@@ -51,12 +52,13 @@
int mArrayTCount; // total number of fetched rows
int mArrayCCount; // number of fetched rows in a sngle fetch;
int mArrayPos; // position within array of fetched rows
- std::map<std::wstring,GdbiColumnInfoType*> *mColMap;
+ std::vector<GdbiColumnInfoType*> *mColList;
wchar_t *mUnicodeBuffer; // Used to return wchar string that should be copied
int mUnicodeBufferSize;
char *mAsciiValBuffer;
int mAsciiValBufferSize;
GdbiQueryIdentifier *m_QueryId;
+ int m_missed;
private:
GdbiQueryResult( GdbiCommands* command, int qid, bool ownsQid = true );
@@ -66,7 +68,7 @@
void define_exec();
int GetAsciiValue(
- const wchar_t *ColName,
+ GdbiColumnInfoType *colInfo,
int length,
char *ascii,
bool *isnull,
@@ -79,6 +81,8 @@
int *ccode
+ GdbiColumnInfoType *FindColumnCache(const wchar_t *colName );
public:
~GdbiQueryResult(void);
@@ -90,8 +94,7 @@
int *ccode
+ /// By char Name
FdoDouble GetDouble( const char *ColName, bool *isnull, int *ccode );
FdoInt32 GetInt32( const char *ColName, bool *isnull, int *ccode );
@@ -110,6 +113,7 @@
bool GetIsNull( const char *ColName );
+ /// By wchar Name
FdoDouble GetDouble( const wchar_t *ColName, bool *isnull, int *ccode );
FdoInt32 GetInt32( const wchar_t *ColName, bool *isnull, int *ccode );
@@ -126,10 +130,14 @@
FdoBoolean GetBoolean( const wchar_t *ColName, bool *isnull, int *ccode );
- FdoString* GetString( int index, bool *isnull, int *ccode );
bool GetIsNull( const wchar_t *ColName );
+ // Gets the column index (1 based) into the cached column list.
+ // Can be used in the getters as column position instead of column name.
+ int GetColumnIndex( const wchar_t *colName );
+ FdoString* GetString( int colIndex, bool *isnull, int *ccode );
int ReadNext();
void Close();
@@ -139,6 +147,8 @@
int GetColumnCount( );
int GetColumnDesc( int colIdx, GdbiColumnDesc &desc );
+ FdoByteArray * GetFgfFromGeomInfo( char * geomInfo );
#endif
Modified: trunk/Providers/GenericRdbms/Src/ODBCDriver/bind.c
--- trunk/Providers/GenericRdbms/Src/ODBCDriver/bind.c 2007-01-29 18:08:55 UTC (rev 698)
+++ trunk/Providers/GenericRdbms/Src/ODBCDriver/bind.c 2007-01-29 18:47:41 UTC (rev 699)
@@ -199,7 +199,7 @@
ODBCDR_RDBI_ERR( odbcdr_geom_bindColumn( context, c, bindnum, address ) );
- ODBCDR_RDBI_ERR( odbcdr_geom_setNumRows( context, c, ODBCDR_MAX_GEOM_ROWS ) );
+ ODBCDR_RDBI_ERR( odbcdr_geom_setNumRows( context, c, ODBCDR_MAX_ARRAY_SIZE) );
** For geometries, pass the parameter number in ParameterValuePtr
Modified: trunk/Providers/GenericRdbms/Src/ODBCDriver/constants.h
--- trunk/Providers/GenericRdbms/Src/ODBCDriver/constants.h 2007-01-29 18:08:55 UTC (rev 698)
+++ trunk/Providers/GenericRdbms/Src/ODBCDriver/constants.h 2007-01-29 18:47:41 UTC (rev 699)
@@ -49,19 +49,8 @@
** for the buffers. An estimate of array size is used because you do not know
** the actual array size until execute time.
-#define ODBCDR_MAX_ARRAY_SIZE 500
+#define ODBCDR_MAX_ARRAY_SIZE 150//500
-/* Limit on maximum number of rows with SqlServer geometries.
- * We buffer geometries for translation on-the-fly and won't
- * generally know the correct buffer size
- * until after the bind/define operations. Thus, the buffers are
- * always pre-allocated to the maximum size in order to avoid
- * studying the consequences of re-bind/define operations.
- * The maximum should be at least the maximum size given by the
- * client code expected to be using our geometries).
-#define ODBCDR_MAX_GEOM_ROWS (150)
/* SQLBindParameter requires the size of data, although data is inserted
* using SQLPutData() and teoretically this will be redundant.
Modified: trunk/Providers/GenericRdbms/Src/ODBCDriver/define.c
--- trunk/Providers/GenericRdbms/Src/ODBCDriver/define.c 2007-01-29 18:08:55 UTC (rev 698)
+++ trunk/Providers/GenericRdbms/Src/ODBCDriver/define.c 2007-01-29 18:47:41 UTC (rev 699)
@@ -142,7 +142,7 @@
ODBCDR_RDBI_ERR( odbcdr_geom_defineColumn(context, c, position, address));
- ODBCDR_RDBI_ERR( odbcdr_geom_setNumRows(context, c, ODBCDR_MAX_GEOM_ROWS));
+ ODBCDR_RDBI_ERR( odbcdr_geom_setNumRows(context, c, ODBCDR_MAX_ARRAY_SIZE));
ODBCDR_RDBI_ERR( odbcdr_geom_getSqlServerBuffAddr(
context,
Modified: trunk/Providers/GenericRdbms/Src/ODBCDriver/desc_slct.c
--- trunk/Providers/GenericRdbms/Src/ODBCDriver/desc_slct.c 2007-01-29 18:08:55 UTC (rev 698)
+++ trunk/Providers/GenericRdbms/Src/ODBCDriver/desc_slct.c 2007-01-29 18:47:41 UTC (rev 699)
@@ -170,6 +170,10 @@
break;
+ case SQL_WCHAR :
+ *rdbi_type = RDBI_WSTRING;
+ *binary_size = odbc_precision;
+ break;
case SQL_BIT:
/* Handle much like a CHAR. */
*rdbi_type = RDBI_BOOLEAN;
Modified: trunk/Providers/GenericRdbms/Src/ODBCDriver/execute.c
--- trunk/Providers/GenericRdbms/Src/ODBCDriver/execute.c 2007-01-29 18:08:55 UTC (rev 698)
+++ trunk/Providers/GenericRdbms/Src/ODBCDriver/execute.c 2007-01-29 18:47:41 UTC (rev 699)
@@ -185,7 +185,7 @@
if ( rc == SQL_NEED_DATA && c->bound_geometries != NULL )
- assert(count <= ODBCDR_MAX_GEOM_ROWS);
+ assert(count <= ODBCDR_MAX_ARRAY_SIZE);
/* Free any Oracle objects from previous executions/fetches. */
ODBCDR_RDBI_ERR( odbcdr_geom_freeSqlServerGeometries( context, c ) );
Modified: trunk/Providers/GenericRdbms/Src/ODBCDriver/fetch.c
--- trunk/Providers/GenericRdbms/Src/ODBCDriver/fetch.c 2007-01-29 18:08:55 UTC (rev 698)
+++ trunk/Providers/GenericRdbms/Src/ODBCDriver/fetch.c 2007-01-29 18:47:41 UTC (rev 699)
@@ -226,10 +226,10 @@
/* Translate geometry columns from SqlServer . */
if ( c->defined_geometries != NULL && rows_in_last_fetch > 0 )
- if ( rows_in_last_fetch > ODBCDR_MAX_GEOM_ROWS )
+ if ( rows_in_last_fetch > ODBCDR_MAX_ARRAY_SIZE )
// char buffer[256];
- // sprintf(buffer, "TOO MANY GEOMETRY ROWS: %d (max is %d)", rows_in_last_fetch, ODBCDR_MAX_GEOM_ROWS);
+ // sprintf(buffer, "TOO MANY GEOMETRY ROWS: %d (max is %d)", rows_in_last_fetch, ODBCDR_MAX_ARRAY_SIZE);
// msg_issue(buffer, 'e');
goto the_exit;
Modified: trunk/Providers/GenericRdbms/Src/ODBCDriver/vndr_info.c
--- trunk/Providers/GenericRdbms/Src/ODBCDriver/vndr_info.c 2007-01-29 18:08:55 UTC (rev 698)
+++ trunk/Providers/GenericRdbms/Src/ODBCDriver/vndr_info.c 2007-01-29 18:47:41 UTC (rev 699)
@@ -71,8 +71,7 @@
vndr_info->minStrLen = 1;
vndr_info->maxStrLen = 8000;
vndr_info->dbversion = ODBCVER;
- /* cannot fetch more than an array of 10 rows with Geometry */
- vndr_info->maxFetchSize = 10;
+ vndr_info->maxFetchSize = ODBCDR_MAX_ARRAY_SIZE;
// Initialize the dbversion with a more precise value
if( context->odbcdr_conns[0] != NULL )
More information about the fdo-commits
