[fdo-commits] r170 - trunk/Providers/SHP/Src/UnitTest
svn_fdo at osgeo.org svn_fdo at osgeo.org
Mon Jan 29 14:57:14 EST 2007
Author: danstoica
Date: 2007-01-29 14:57:14 -0500 (Mon, 29 Jan 2007)
New Revision: 170
   trunk/Providers/SHP/Src/UnitTest/ExtendedSelectTests.cpp
   trunk/Providers/SHP/Src/UnitTest/ExtendedSelectTests.h
   trunk/Providers/SHP/Src/UnitTest/FilterTests.cpp
Merged branch 3.2.x to Trunk
Modified: trunk/Providers/SHP/Src/UnitTest/ExtendedSelectTests.cpp
--- trunk/Providers/SHP/Src/UnitTest/ExtendedSelectTests.cpp	2007-01-29 18:46:29 UTC (rev 169)
+++ trunk/Providers/SHP/Src/UnitTest/ExtendedSelectTests.cpp	2007-01-29 19:57:14 UTC (rev 170)
@@ -165,33 +165,14 @@
                 const wchar_t *name = reader->GetString(L"NAME");
 				CPPUNIT_ASSERT_MESSAGE("Unexpected value", wcscmp(name,expected[count-1])==0 );
                 printf("%ls \t %d\n", name, reader->GetInt32( L"FeatId" ) );
         }while( reader->ReadNext() );
         finish = clock ();
         printf ("Read forward(%d)  time: %2.3f seconds\n\n\n",count, (double)(finish - start) / CLOCKS_PER_SEC);
         CPPUNIT_ASSERT_MESSAGE("Unexpected number of records", count==419 );
-		// IndexOf() on an ordered collection.
-	    if( reader->ReadFirst() )
-        do
-            if( count++ < 10 )
-  				FdoPtr<FdoPropertyValueCollection> key1 = FdoPropertyValueCollection::Create();
-                FdoPtr<FdoInt32Value> featid1 = FdoInt32Value::Create(count);
-                key1->Add( FdoPropertyValue::Create(L"FeatId", featid1) );
-                FdoInt32 index = reader->IndexOf(key1);
-				reader->ReadAtIndex(index); // this increments
-				const wchar_t *name = reader->GetString(L"NAME");
-				int featid = reader->GetInt32( L"FeatId");
-				CPPUNIT_ASSERT_MESSAGE("Unexpected value", featid1 = featid );
-        }while( count < 10 );
         // Iterate in the backward direction from last to first
         wchar_t*   expected2[] = {L"Zimbabwe",L"Zambia",L"Zaire",L"Western Sahara",L"Virgin Islands",L"Vietnam",L"Venezuela",L"Venezuela",L"Uzbekistan",L"Uruguay"};
         count = 0;
@@ -242,144 +223,3 @@
-#ifdef _WIN32
-#define LOCATION2 L"..\\..\\TestData\\Bike_Network"
-#else
-#define LOCATION2 L"../../TestData/Bike_Network"
-#endif
-#define	CLASS_NAME2	L"dpt_bike_network"
-void ExtendedSelectTests::WithNullValues()
-    int count = 0;
-    try
-		FdoPtr<FdoIConnection> connection = ShpTests::GetConnection ();
-        connection->SetConnectionString (L"DefaultFileLocation=" LOCATION2);
-        CPPUNIT_ASSERT_MESSAGE ("connection state not open", FdoConnectionState_Open == connection->Open ());
-        FdoPtr<ShpIExtendedSelect> select = (ShpIExtendedSelect*)connection->CreateCommand(ShpCommandType_ExtendedSelect);
-        select->SetFeatureClassName (CLASS_NAME2);
-		// List properties
-		// Use ordering properties
-        FdoPtr<FdoIdentifierCollection> orders = select->GetOrdering();
-        orders->Add( FdoPtr<FdoIdentifier>(FdoIdentifier::Create(L"STREETNAME")));
-        select->SetOrderingOption(L"STREETNAME", FdoOrderingOption_Ascending);
-		// execute
-		FdoPtr<ShpIScrollableFeatureReader>	reader = select->ExecuteScrollable();
-        // Iterate in the forward direction from first to last
-        wchar_t*   expected[] = {L"Afghanistan",L"Albania",L"Algeria",L"Andorra",L"Angola",L"Angola",L"Antigua and Barbuda",L"Argentina",L"Argentina",L"Argentina"};
-        count = 0;
-		int count_null = 0;
-        do
-			count++;
-			if ( reader->IsNull(L"STREETNAME") )
-				count_null++;
-				printf("null at %d\n", count);
-				continue;
-            const wchar_t *name = reader->GetString(L"STREETNAME");
-			//CPPUNIT_ASSERT_MESSAGE("Unexpected value", wcscmp(name,expected[count-1])==0 );
-            //printf("%ls \t %d\n", name, reader->GetInt32( L"FeatId" ) );
-        }while( reader->ReadNext() );
-		printf("count %ld (null %ld)\n", count, count_null);
-    catch (FdoException *ex )
-        printf("FDO error: %ls\n", ex->GetExceptionMessage());
-        return;
-#ifdef _WIN32
-#define LOCATION3 L"..\\..\\TestData\\Realtor_Neighborhoods"
-#else
-#define LOCATION3 L"../../TestData/Realtor_Neighborhoods"
-#endif
-#define	CLASS_NAME3	L"realtor_neighborhoods"
-#define	PROP_NAME3	L"SFAR_DISTR"
-void ExtendedSelectTests::WithFilter()
-    int count = 0;
-    try
-        connection->SetConnectionString (L"DefaultFileLocation=" LOCATION3);
-		// do DESCRIBE
-		FdoPtr<FdoIDescribeSchema> descSchema = (FdoIDescribeSchema*)connection->CreateCommand(FdoCommandType_DescribeSchema);
-		FdoPtr<FdoFeatureSchemaCollection> schemas = descSchema->Execute();
-		FdoPtr<FdoFeatureSchema> schema = schemas->GetItem(L"Default");
-		FdoPtr<FdoClassCollection> classes = schema->GetClasses();
-		FdoPtr<FdoClassDefinition> classDef = classes->GetItem(CLASS_NAME3);
-		FdoPtr<FdoPropertyDefinitionCollection> props = classDef->GetProperties();
-		for (int i=0; i<props->GetCount(); i++)
-			FdoPtr<FdoPropertyDefinition> prop = props->GetItem(i);
-			printf("name: %ls\n", prop->GetName());
-		// Do SELECT
-        select->SetFeatureClassName (CLASS_NAME3);
-		// Create a filter
-        select->SetFilter (FdoPtr<FdoFilter>(FdoFilter::Parse (L"SFAR_DISTR = 'District 5 - Central'")));
-        //orders->Add( FdoPtr<FdoIdentifier>(FdoIdentifier::Create(PROP_NAME3)));
-        //select->SetOrderingOption(PROP_NAME3, FdoOrderingOption_Ascending);
-		// execute
-    //    wchar_t*   expected[] = {L"Afghanistan",L"Albania",L"Algeria",L"Andorra",L"Angola",L"Angola",L"Antigua and Barbuda",L"Argentina",L"Argentina",L"Argentina"};
-        count = 0;
-        do
-			count++;
-			if ( reader->IsNull(PROP_NAME3) )
-				count_null++;
-				continue;
-            const wchar_t *name = reader->GetString(PROP_NAME3);
-            printf("%ld. %ls \n", reader->GetInt32( L"FeatId" ), (FdoString*) name );
-        return;
Modified: trunk/Providers/SHP/Src/UnitTest/ExtendedSelectTests.h
--- trunk/Providers/SHP/Src/UnitTest/ExtendedSelectTests.h	2007-01-29 18:46:29 UTC (rev 169)
+++ trunk/Providers/SHP/Src/UnitTest/ExtendedSelectTests.h	2007-01-29 19:57:14 UTC (rev 170)
@@ -13,8 +13,6 @@
   CPPUNIT_TEST_SUITE( ExtendedSelectTests );
   CPPUNIT_TEST( WorldTest );
-  CPPUNIT_TEST( WithNullValues );
-  CPPUNIT_TEST( WithFilter );
   CPPUNIT_TEST_SUITE_END();
 public:
@@ -24,9 +22,6 @@
 protected:
 	void WorldTest();
-	void WithNullValues();
-	void WithFilter();
Modified: trunk/Providers/SHP/Src/UnitTest/FilterTests.cpp
--- trunk/Providers/SHP/Src/UnitTest/FilterTests.cpp	2007-01-29 18:46:29 UTC (rev 169)
+++ trunk/Providers/SHP/Src/UnitTest/FilterTests.cpp	2007-01-29 19:57:14 UTC (rev 170)
@@ -603,6 +603,11 @@
 		long	 expected[100];
+        query = L"FeatId = 10 - 20";
+        count = featid_roads_query( query, 1, 0, NULL );
+		// Write more binary expressions...
         query = L"FeatId = 41";
 		expected[0] = 41;
         count = featid_roads_query( query, 1, 1, expected );
More information about the fdo-commits mailing list
