[fdo-commits] r684 - trunk/Utilities/SchemaMgr/Src/Sm/Lp
svn_fdo at osgeo.org
Mon Jan 29 15:00:50 EST 2007
Author: gavincramer
Date: 2007-01-29 15:00:50 -0500 (Mon, 29 Jan 2007)
New Revision: 684
trunk/Utilities/SchemaMgr/Src/Sm/Lp/ClassDefinition.cpp
Port FDO335 from 3.2.x to trunk
Modified: trunk/Utilities/SchemaMgr/Src/Sm/Lp/ClassDefinition.cpp
--- trunk/Utilities/SchemaMgr/Src/Sm/Lp/ClassDefinition.cpp 2007-01-29 19:47:28 UTC (rev 683)
+++ trunk/Utilities/SchemaMgr/Src/Sm/Lp/ClassDefinition.cpp 2007-01-29 20:00:50 UTC (rev 684)
@@ -2261,7 +2261,7 @@
// don't create a new one.
mPhDbObject = dbObject;
- else if ( mbHasFdoIdentity ) {
+ else if ( mbHasFdoIdentity && FdoSmPhOwnerP(pPhysical->GetOwner())->GetHasMetaSchema() ) {
// No table is created if there are no id properties. Classes without id
// are only used as object property types.
@@ -2456,21 +2456,21 @@
if ( !pPathDbObject ) {
// No direct join , so check each dependency to see if it leads to a join path
- for ( int i = 0; i < pDeps->GetCount(); i++ ) {
- const FdoSmPhDependency* pDep = pDeps->RefItem(i);
+ for ( int i = 0; i < pDeps->GetCount(); i++ ) {
+ const FdoSmPhDependency* pDep = pDeps->RefItem(i);
- // Consider only cardinality 1 dependencies because collections of data
- // properties are not supported.
- if ( pDep->GetCardinality() == 1 ) {
- FdoSmLpDbObjectP pCurrDbObject;
+ // Consider only cardinality 1 dependencies because collections of data
+ // properties are not supported.
+ if ( pDep->GetCardinality() == 1 ) {
+ FdoSmLpDbObjectP pCurrDbObject;
- // Get the primary key table and Finalize it.
- FdoSmPhMgrP pPhysical = GetLogicalPhysicalSchema()->GetPhysicalSchema();
- FdoSmPhDbObjectP pDepDbObject;
- if (FdoSmPhOwnerP(pPhysical->GetOwner())->GetHasMetaSchema())
- pDepDbObject = pPhysical->FindDbObject( pDep->GetPkTableName() );
- else
- pDepDbObject = pPhysical->FindDbObject( pDep->GetPkTableName(), mOwner );
+ // Get the primary key table and Finalize it.
+ FdoSmPhMgrP pPhysical = GetLogicalPhysicalSchema()->GetPhysicalSchema();
+ FdoSmPhDbObjectP pDepDbObject;
+ if (FdoSmPhOwnerP(pPhysical->GetOwner())->GetHasMetaSchema())
+ pDepDbObject = pPhysical->FindDbObject( pDep->GetPkTableName() );
+ else
+ pDepDbObject = pPhysical->FindDbObject( pDep->GetPkTableName(), mOwner );
// Optimization: No need to follow the primary key table if it has no
// "Up" dependencies. This saves a lot of time when following dependencies
@@ -2478,19 +2478,19 @@
// to tables that do not have "up" dependencies. Skipping FinalizeDbObject for
// these tables saves a lot of time for datastores with many classes.
if ( pDepDbObject && (pDepDbObject->GetDependenciesUp()->GetCount() > 0) )
- pCurrDbObject = FinalizeDbObject( pDepDbObject, dbObjects, iLevel + 1, pProp );
- // If it was successfully finalized, check if it has a join path to the class table and
- // it's the shortest path encountered so far.
- if ( pCurrDbObject && (pCurrDbObject->GetPathDist() >= 0) && (pCurrDbObject->GetPathDist() < iMinDist) ) {
- // If so then it is the current candidate for the next table in the
- // join path.
- iMinDist = pCurrDbObject->GetPathDist();
- pPathDbObject = (pCurrDbObject->GetPathDist() == 0) ? mDbObject : pCurrDbObject;
- pPathDep = pDep;
+ pCurrDbObject = FinalizeDbObject( pDepDbObject, dbObjects, iLevel + 1, pProp );
+ // If it was successfully finalized, check if it has a join path to the class table and
+ // it's the shortest path encountered so far.
+ if ( pCurrDbObject && (pCurrDbObject->GetPathDist() >= 0) && (pCurrDbObject->GetPathDist() < iMinDist) ) {
+ // If so then it is the current candidate for the next table in the
+ // join path.
+ iMinDist = pCurrDbObject->GetPathDist();
+ pPathDbObject = (pCurrDbObject->GetPathDist() == 0) ? mDbObject : pCurrDbObject;
+ pPathDep = pDep;
if ( pPathDbObject ) {
More information about the fdo-commits
