[fdo-commits] r121 - in branches/3.2.x/Providers/ArcSDE/Src:
Provider UnitTest
svn_fdo at osgeo.org
Mon Jan 29 17:02:11 EST 2007
Author: pierredalcourt
Date: 2007-01-29 17:02:11 -0500 (Mon, 29 Jan 2007)
New Revision: 121
branches/3.2.x/Providers/ArcSDE/Src/Provider/ArcSDEConnection.cpp
branches/3.2.x/Providers/ArcSDE/Src/Provider/ArcSDELongTransactionUtility.cpp
branches/3.2.x/Providers/ArcSDE/Src/UnitTest/LongTransactionTests.cpp
branches/3.2.x/Providers/ArcSDE/Src/UnitTest/LongTransactionTests.h
ArcSDE: fixed protected version defect (allow users to activate protected versions they do not own)
Modified: branches/3.2.x/Providers/ArcSDE/Src/Provider/ArcSDEConnection.cpp
--- branches/3.2.x/Providers/ArcSDE/Src/Provider/ArcSDEConnection.cpp 2007-01-26 17:08:01 UTC (rev 120)
+++ branches/3.2.x/Providers/ArcSDE/Src/Provider/ArcSDEConnection.cpp 2007-01-29 22:02:11 UTC (rev 121)
@@ -1107,13 +1107,6 @@
result = SE_version_get_info_by_id (mConnection, id, version);
handle_sde_err<FdoCommandException> (mConnection, result, __FILE__, __LINE__, ARCSDE_VERSION_INFO, "Version info for '%1$ls' could not be retrieved.", FdoCommonOSUtil::itow (id, buffer, ELEMENTS(buffer)));
- // check the access
- result = SE_versioninfo_get_access (version, &access);
- handle_sde_err<FdoCommandException> (mConnection, result, __FILE__, __LINE__, ARCSDE_VERSION_INFO_ITEM, "Version info item '%1$ls' could not be retrieved.", L"access");
- if (!(SE_VERSION_ACCESS_PUBLIC == access))
- if (!ArcSDELongTransactionUtility::IsOurVersion (mConnection, version))
- throw FdoException::Create (NlsMsgGet (ARCSDE_NOT_OWNER, "User is not the version owner."));
// lock the state
SetActiveState (ArcSDELongTransactionUtility::LockVersion (this, version));
Modified: branches/3.2.x/Providers/ArcSDE/Src/Provider/ArcSDELongTransactionUtility.cpp
--- branches/3.2.x/Providers/ArcSDE/Src/Provider/ArcSDELongTransactionUtility.cpp 2007-01-26 17:08:01 UTC (rev 120)
+++ branches/3.2.x/Providers/ArcSDE/Src/Provider/ArcSDELongTransactionUtility.cpp 2007-01-29 22:02:11 UTC (rev 121)
@@ -272,8 +272,12 @@
// NOTE: the state may be in use if this version's state matches its parent's version state, in which case the delete will fail
// (with one of a variety of errors, depending on the condition the state is in) and we should leave the state alone without throwing an exception.
result = SE_state_delete (conn, state);
- if ((result != SE_STATE_INUSE) && (result != SE_STATE_USED_BY_VERSION) && (result != SE_STATE_HAS_CHILDREN))
- handle_sde_err<FdoCommandException> (conn, result, __FILE__, __LINE__, ARCSDE_STATE_DELETE, "Cannot delete state.");
+ // NOTE: we purposefully ignore any errors returned from SE_state_delete() for two reasons:
+ // 1) This function's main purpose is to delete the version, not the state. If we get this far, te
+ // version has been deleted successfully.
+ // 2) SE_state_delete() may throw many different exceptions if the state still in use after the version is
+ // deleted, since states can be shared by multiple versions (e.g. SE_STATE_USED_BY_VERSION, SE_STATE_INUSE,
+ // SE_STATE_HAS_CHILDREN, SE_NO_PERMISSIONS, etc)
SE_versioninfo_free (version);
Modified: branches/3.2.x/Providers/ArcSDE/Src/UnitTest/LongTransactionTests.cpp
--- branches/3.2.x/Providers/ArcSDE/Src/UnitTest/LongTransactionTests.cpp 2007-01-26 17:08:01 UTC (rev 120)
+++ branches/3.2.x/Providers/ArcSDE/Src/UnitTest/LongTransactionTests.cpp 2007-01-29 22:02:11 UTC (rev 121)
@@ -1408,7 +1408,7 @@
try
// Create an ArcCatalog-like version:
- FdoStringP wNewVersionName = CreateArcCatalogLikeVersion();
+ FdoStringP wNewVersionName = CreateArcCatalogLikeVersion(SE_VERSION_ACCESS_PRIVATE);
// Rollback the new version using our ArcSDE Provider:
rollback = (FdoIRollbackLongTransaction*)mConnection->CreateCommand (FdoCommandType_RollbackLongTransaction);
@@ -1444,7 +1444,7 @@
try
// Activate this new version:
activate = (FdoIActivateLongTransaction*)mConnection->CreateCommand (FdoCommandType_ActivateLongTransaction);
@@ -1512,7 +1512,7 @@
try
// Commit the new version:
commit = (FdoICommitLongTransaction*)mConnection->CreateCommand (FdoCommandType_CommitLongTransaction);
@@ -1538,7 +1538,7 @@
-FdoStringP LongTransactionTests::CreateArcCatalogLikeVersion()
+FdoStringP LongTransactionTests::CreateArcCatalogLikeVersion(long accessLevel)
// Establish a low-level connection with ArcSDE server:
SE_ERROR error;
@@ -1580,7 +1580,7 @@
CPPUNIT_ASSERT(result == SE_SUCCESS);
result = SE_versioninfo_set_state_id (versioninfo, state_id);
- result = SE_versioninfo_set_access (versioninfo, SE_VERSION_ACCESS_PRIVATE);
+ result = SE_versioninfo_set_access (versioninfo, accessLevel);
result = SE_version_create(connection, versioninfo, TRUE, versioninfo);
@@ -1593,3 +1593,53 @@
FdoStringP wNewVersionName(newVersionName);
return wNewVersionName;
+void LongTransactionTests::read_protected_version()
+ if (CreateSchemaOnly()) return;
+ FdoStringP wNewVersionName;
+ FdoPtr <FdoIActivateLongTransaction> activate;
+ try
+ // Create an ArcCatalog-like *protected* version:
+ wNewVersionName = CreateArcCatalogLikeVersion(SE_VERSION_ACCESS_PROTECTED);
+ // Establish a second connection as a different user:
+ FdoPtr<FdoIConnection> conn2 = ArcSDETests::GetConnection ();
+ conn2->SetConnectionString (ArcSDETestConfig::ConnStringOzzie());
+ conn2->Open ();
+ // Activate this new version, as different user:
+ activate = (FdoIActivateLongTransaction*)conn2->CreateCommand (FdoCommandType_ActivateLongTransaction);
+ activate->SetName (wNewVersionName);
+ activate->Execute ();
+ // Try selecting data from versioned table, as different user:
+ FdoPtr<FdoISelect> select = (FdoISelect*)conn2->CreateCommand(FdoCommandType_Select);
+ select->SetFeatureClassName(ArcSDETestConfig::QClassNameTrees());
+ FdoPtr<FdoIFeatureReader> rdr = select->Execute();
+ while (rdr->ReadNext())
+ // do nothing
+ catch (FdoException* ge)
+ fail (ge);
+ // clean up this new version:
+ try
+ FdoPtr <FdoIRollbackLongTransaction> rollback = (FdoIRollbackLongTransaction*)mConnection->CreateCommand (FdoCommandType_RollbackLongTransaction);
+ rollback->SetName (wNewVersionName);
+ rollback->Execute ();
+ // ignore error here
Modified: branches/3.2.x/Providers/ArcSDE/Src/UnitTest/LongTransactionTests.h
--- branches/3.2.x/Providers/ArcSDE/Src/UnitTest/LongTransactionTests.h 2007-01-26 17:08:01 UTC (rev 120)
+++ branches/3.2.x/Providers/ArcSDE/Src/UnitTest/LongTransactionTests.h 2007-01-29 22:02:11 UTC (rev 121)
@@ -51,6 +51,7 @@
CPPUNIT_TEST (rollback_arccatalog_version);
CPPUNIT_TEST (activate_arccatalog_version);
CPPUNIT_TEST (commit_arccatalog_version);
+ CPPUNIT_TEST (read_protected_version);
CPPUNIT_TEST_SUITE_END ();
static FdoPtr<FdoIConnection> mConnection;
@@ -68,7 +69,7 @@
void MakeTwoObjectsInTwoVersions (int* item1, int* item2);
void MakeUpdateConflict (int* item1);
void CommitUpdateConflict (bool child);
- FdoStringP CreateArcCatalogLikeVersion();
+ FdoStringP CreateArcCatalogLikeVersion(long accessLevel);
// data:
static FdoString* NAME() { return L"My Long Transaction"; };
@@ -132,6 +133,7 @@
void rollback_arccatalog_version ();
void activate_arccatalog_version();
void commit_arccatalog_version();
+ void read_protected_version();
#endif // CPP_UNIT_LongTransactionTests_H
More information about the fdo-commits
