[fdo-commits] r123 - in branches/3.2.x/Providers/ArcSDE:
Src/Provider Src/UnitTest TestData
svn_fdo at osgeo.org
Wed Jan 31 11:54:53 EST 2007
Author: pierredalcourt
Date: 2007-01-31 11:54:53 -0500 (Wed, 31 Jan 2007)
New Revision: 123
branches/3.2.x/Providers/ArcSDE/Src/Provider/ArcSDEDescribeSchemaCommand.cpp
branches/3.2.x/Providers/ArcSDE/Src/UnitTest/ArcSDETests.h
branches/3.2.x/Providers/ArcSDE/Src/UnitTest/SelectTests.cpp
branches/3.2.x/Providers/ArcSDE/Src/UnitTest/SelectTests.h
branches/3.2.x/Providers/ArcSDE/TestData/SetupTestData.perl
ArcSDE: fix defect introduced by recent performance enhancements; using unqualified names would fail if no describeschema operation had been previously performed
Modified: branches/3.2.x/Providers/ArcSDE/Src/Provider/ArcSDEDescribeSchemaCommand.cpp
--- branches/3.2.x/Providers/ArcSDE/Src/Provider/ArcSDEDescribeSchemaCommand.cpp 2007-01-29 22:22:21 UTC (rev 122)
+++ branches/3.2.x/Providers/ArcSDE/Src/Provider/ArcSDEDescribeSchemaCommand.cpp 2007-01-31 16:54:53 UTC (rev 123)
@@ -594,7 +594,8 @@
// optimization: only load information for a specific class if only that class is requested:
if ((preloadedClass==NULL)
&& ((mFdoClassIdToLoad==NULL)
- || ((0==wcscmp(mFdoClassIdToLoad->GetSchemaName(),fdoSchemaName)) && (0==wcscmp(mFdoClassIdToLoad->GetName(),fdoClassName)))))
+ || (((mFdoClassIdToLoad->GetSchemaName()==NULL) || (mFdoClassIdToLoad->GetSchemaName()[0]==NULL) || 0==wcscmp(mFdoClassIdToLoad->GetSchemaName(),fdoSchemaName))
+ && (0==wcscmp(mFdoClassIdToLoad->GetName(),fdoClassName)))))
// Store the overrides always:
FdoPtr<ArcSDEClassMapping> classMapping = mConnection->GetClassMapping(fdoSchemaName, fdoClassName, false);
Modified: branches/3.2.x/Providers/ArcSDE/Src/UnitTest/ArcSDETests.h
--- branches/3.2.x/Providers/ArcSDE/Src/UnitTest/ArcSDETests.h 2007-01-29 22:22:21 UTC (rev 122)
+++ branches/3.2.x/Providers/ArcSDE/Src/UnitTest/ArcSDETests.h 2007-01-31 16:54:53 UTC (rev 123)
@@ -577,6 +577,10 @@
DECLARE_CLASS(TestSingleDb, Metadcov, TestClassComplex, L"TESTB");
DECLARE_CLASS(TestMultiDb, Metadcov, TestClassSimpleMultiDb, L"TESTA");
DECLARE_CLASS(Sde, Australia, LargeWithGeom, L"LARGEWITHGEOM");
+ static FdoStringP ClassSchemaTreesUniqueName() { return FdoStringP::Format(L"%ls%ls", (FdoString*)FdoSchemaPrefixSde(), (FdoString*)UserNameMetadcov()); } \
+ static FdoStringP ClassNameTreesUniqueName() { return AdjustRdbmsName((FdoString*)FdoStringP::Format(L"TREES_%ls", (FdoString*)DatasetName())); } \
+ static FdoStringP QClassNameTreesUniqueName() { return FdoStringP::Format(L"%ls:%ls", (FdoString*)ClassSchemaTreesUniqueName(), (FdoString*)ClassNameTreesUniqueName()); }
#endif // CPP_UNIT_ArcSDETests_H
Modified: branches/3.2.x/Providers/ArcSDE/Src/UnitTest/SelectTests.cpp
--- branches/3.2.x/Providers/ArcSDE/Src/UnitTest/SelectTests.cpp 2007-01-29 22:22:21 UTC (rev 122)
+++ branches/3.2.x/Providers/ArcSDE/Src/UnitTest/SelectTests.cpp 2007-01-31 16:54:53 UTC (rev 123)
@@ -1704,3 +1704,29 @@
fail (ge);
+void SelectTests::simple_unique ()
+ if (CreateSchemaOnly()) return;
+ try
+ // Close/re-open the connection, to flush schema cache to make sure we are exercising the code in
+ // DescribeSchema that optimally fetches only the requested class even if its name is not qualified:
+ mConnection->Close ();
+ mConnection->Open ();
+ FdoPtr<FdoISelect> select = (FdoISelect*)mConnection->CreateCommand (FdoCommandType_Select);
+ select->SetFeatureClassName (ArcSDETestConfig::ClassNameTreesUniqueName());
+ FdoPtr<FdoIFeatureReader> reader = select->Execute ();
+ FdoPtr<FdoFeatureClass> classDef = (FdoFeatureClass*)reader->GetClassDefinition();
+ while (reader->ReadNext ())
+ ProcessFeature (reader, classDef);
+ reader->Close();
+ catch (FdoException *e)
+ fail(e);
Modified: branches/3.2.x/Providers/ArcSDE/Src/UnitTest/SelectTests.h
--- branches/3.2.x/Providers/ArcSDE/Src/UnitTest/SelectTests.h 2007-01-29 22:22:21 UTC (rev 122)
+++ branches/3.2.x/Providers/ArcSDE/Src/UnitTest/SelectTests.h 2007-01-31 16:54:53 UTC (rev 123)
@@ -46,6 +46,7 @@
CPPUNIT_TEST (spatial_query_outside_coordsys_extents);
CPPUNIT_TEST (multiple_databases);
CPPUNIT_TEST (spatial_filter_buffer_outside_extents);
+ CPPUNIT_TEST (simple_unique);
CPPUNIT_TEST_SUITE_END ();
static FdoPtr<FdoIConnection> mConnection;
@@ -81,6 +82,7 @@
void multiple_databases();
void spatial_filter_buffer_outside_extents();
void select_large_table_with_geom();
+ void simple_unique();
// helper methods:
void create_large_table_with_geom();
Modified: branches/3.2.x/Providers/ArcSDE/TestData/SetupTestData.perl
--- branches/3.2.x/Providers/ArcSDE/TestData/SetupTestData.perl 2007-01-29 22:22:21 UTC (rev 122)
+++ branches/3.2.x/Providers/ArcSDE/TestData/SetupTestData.perl 2007-01-31 16:54:53 UTC (rev 123)
@@ -325,7 +325,7 @@
# On both Oracle and SQL Server:
- print "\n" . $ACTION . " tables TREES, SOILS and PARCELS for " . $RDBMS . " ... \n";
+ print "\n" . $ACTION . " tables TREES, TREES_" . $DATASETNAME . ", SOILS and PARCELS for " . $RDBMS . " ... \n";
if ($INSTALLACTION ne "U") {
system "shp2sde -o create -l TREES,SHAPE -f " . $SHP_ROOT . "\\Metadcov\\Trees.shp -e p -a all -C OBJECTID,USER,0 -u " . $username_metadcov . " -p test " . $DB_INST;
@@ -334,10 +334,15 @@
system "echo y | sdetable -o alter_reg -t SOILS -V MULTI -c FID -C SDE -u " . $username_australia . " -p test " . $DB_INST;
system "shp2sde -o create -l PARCELS,SHAPE -f " . $SHP_ROOT . "\\Australia\\PARCELS.shp -e a -a all -C FID,USER,0 -u " . $username_australia . " -p test " . $DB_INST;
system "echo y | sdetable -o alter_reg -t PARCELS -c FID -C SDE -u " . $username_australia . " -p test " . $DB_INST;
+ # create a table with a unique name, to test code that deals with unqualified FDO class names:
+ system "shp2sde -o create -l TREES_" . $DATASETNAME . ",SHAPE -f " . $SHP_ROOT . "\\Metadcov\\Trees.shp -e p -a all -C OBJECTID,USER,0 -u " . $username_metadcov . " -p test " . $DB_INST;
+ system "echo y | sdetable -o alter_reg -t TREES_" . $DATASETNAME . " -V MULTI -c OBJECTID -C SDE -u " . $username_metadcov . " -p test " . $DB_INST;
} else {
system "echo y | sdetable -o delete -t TREES -u " . $username_metadcov . " -p test " . $DB_INST;
system "echo y | sdetable -o delete -t SOILS -u " . $username_australia . " -p test " . $DB_INST;
system "echo y | sdetable -o delete -t PARCELS -u " . $username_australia . " -p test " . $DB_INST;
+ system "echo y | sdetable -o delete -t TREES_" . $DATASETNAME . " -u " . $username_metadcov . " -p test " . $DB_INST;
More information about the fdo-commits
