[fdo-commits] r2638 - trunk/Providers/WMS
svn_fdo at osgeo.org
Sun Mar 4 13:09:51 EST 2007
Author: gregboone
Date: 2007-03-04 13:09:51 -0500 (Sun, 04 Mar 2007)
New Revision: 2638
trunk/Providers/WMS/configure
trunk/Providers/WMS/configure.in
Ticket #5: Update to GDAL 1.4.0
Modified: trunk/Providers/WMS/configure
--- trunk/Providers/WMS/configure 2007-03-04 18:03:22 UTC (rev 2637)
+++ trunk/Providers/WMS/configure 2007-03-04 18:09:51 UTC (rev 2638)
@@ -1053,7 +1053,7 @@
default=DEFAULT
--with-fdo-thirdparty specifies directory for FDO API Thirdparty files
default=DEFAULT
- --with-fdo-gdal specifies directory for thirdparty GDAL files
+ --with-fdo-gdal specifies directory for the installed GDAL files
default=DEFAULT
Some influential environment variables:
@@ -18767,8 +18767,7 @@
fi;
if test $custom_fdo_gdal = "DEFAULT"; then
- FDOTHIRDPARTY="$PWD/Thirdparty/gdal"
- if test -d $FDOGDAL; then
+ if test -d $FDOGDAL && test ! $FDOGDAL = ""; then
{ echo "$as_me:$LINENO: Building with default location of thirdparty GDAL files at $FDOGDAL" >&5
echo "$as_me: Building with default location of thirdparty GDAL files at $FDOGDAL" >&6;}
else
@@ -18778,7 +18777,7 @@
fi
else
if test -d $custom_fdo_gdal; then
- FDOTHIRDPARTY="$custom_fdo_gdal"
+ FDOGDAL="$custom_fdo_gdal"
{ echo "$as_me:$LINENO: Building with custom location of thirdparty GDAL files at $FDOGDAL" >&5
echo "$as_me: Building with custom location of thirdparty GDAL files at $FDOGDAL" >&6;}
else
Modified: trunk/Providers/WMS/configure.in
--- trunk/Providers/WMS/configure.in 2007-03-04 18:03:22 UTC (rev 2637)
+++ trunk/Providers/WMS/configure.in 2007-03-04 18:09:51 UTC (rev 2638)
@@ -105,20 +105,19 @@
AC_ARG_WITH([fdo-gdal],
FDO_HELP_STRING([--with-fdo-gdal],
- [specifies directory for thirdparty GDAL files [[default=DEFAULT]]]),
+ [specifies directory for the installed GDAL files [[default=DEFAULT]]]),
[custom_fdo_gdal=$withval],
[custom_fdo_gdal=DEFAULT])
AC_MSG_NOTICE([Building with default location of thirdparty GDAL files at $FDOGDAL])
else
AC_MSG_ERROR([The default GDAL path $custom_fdo_gdal is not a valid directory. Please use the custom option])
fi
else
AC_MSG_NOTICE([Building with custom location of thirdparty GDAL files at $FDOGDAL])
else
AC_MSG_ERROR([The specified GDAL path $custom_fdo_gdal is not a valid directory])
More information about the fdo-commits
