[fdo-commits] r2650 - trunk/www/docs
svn_fdo at osgeo.org svn_fdo at osgeo.org
Tue Mar 6 19:30:33 EST 2007
Author: gregboone
Date: 2007-03-06 19:30:33 -0500 (Tue, 06 Mar 2007)
New Revision: 2650
   trunk/www/docs/OpenSourceBuild__README.html
Ticket #26: Update FDO web documentation
Modified: trunk/www/docs/OpenSourceBuild__README.html
--- trunk/www/docs/OpenSourceBuild__README.html	2007-03-06 05:17:36 UTC (rev 2649)
+++ trunk/www/docs/OpenSourceBuild__README.html	2007-03-07 00:30:33 UTC (rev 2650)
@@ -33,7 +33,7 @@
   1. cd [FDO OpenSource]
   2. Open and modify setenvironment.bat to specify the locations of the Thirdparty SDK
-     components and build tools. (Refer to Build notes below)
+     components and build tools. (Refer to the Build Notes below)
   3. call setenvironment.bat
@@ -407,19 +407,24 @@
-  2. Open and modify setenvironment.sh to specify the locations of the Thirdparty SDK
+  2. Open and modify setenvironment.sh to specify the locations of the
+     Thirdparty SDK components and build tools. (Refer to the Build Notes
+     below)
-  3. source ./setenvironment.sh
+  3.  Source set environment script (bash or bourne compatible shells)
+      source ./setenvironment.sh
   4. ./build_thirdparty.sh
   5. ./build_linux.sh
-  NOTE: build_linux.sh is a simple helper script that assists developers to build the FDO
-        components. These scripts supplement standard support of configure and make.
+  NOTE: build_linux.sh is a simple helper script that assists developers to
+        build the FDO components. These scripts supplement standard support of
+        configure and make.
-        The implementation of the above build_linux.sh script in essence calls ...
+        The implementation of the above build_linux.sh script in essence
+        calls ...
         aclocal
         libtoolize --force
@@ -429,9 +434,10 @@
         make
         make install
-        for the fdo core API components as well as the set of FDO providers that are
-        currently supported in the automated build process. Users are free to call configure
-        and make without using the build_linux.sh helper script.
+        for the fdo core API components as well as the set of FDO providers
+        that are currently supported in the automated build process. Users are
+        free to call configure and make without using the build_linux.sh helper
+        script.
 II. Build Notes
@@ -441,7 +447,7 @@
      directory must be set as writeable by the user, otherwise the user
      will have to log in and build FDO as the ROOT user. This requirement
      is due to the fact that the FDO Libraries will be built and installed
-     in /usr/local/fdo-3.2.0/lib
+     in /usr/local/fdo-3.3.0/lib
   2. Ensure that the following FDO Environment Variables are set as follows:
@@ -450,23 +456,24 @@
        FDOTHIRDPARTY = [FDO OpenSource]/ThirdParty
   3. In order to build the ArcSDE Provider, you will need to have the
-     ArcSDE 9.1 Client SDK installed and the following environment variable set that
-     points to the installation location:
+     ArcSDE 9.1 Client SDK installed and the following environment variable set
+     that points to the installation location:
        SDEHOME=[ArcSDE developer components path]
-     Note that ArcSDE is licensed software and must be obtained from an ESRI vendor.
+     Note that ArcSDE is licensed software and must be obtained from an ESRI
+     vendor.
-  4. In order to build the MySQL Provider, you will need to download and extract
-     the MySQL client and MySQL 5.0 devloper components from MySQL. These
-     components are located at:
+  4. In order to build the MySQL Provider, you will need to download and
+     extract the MySQL client and MySQL 5.0 devloper components from MySQL.
+     These components are located at:
        http://dev.mysql.com/downloads/mysql/5.0.html
      For example, for Red Hat Enterprise Linux 3 RPM (x86)
-       Client:                      MySQL-client-standard-5.0.22-0.rhel3.i386.rpm
-       Headers and Libraries:       MySQL-devel-standard-5.0.22-0.rhel3.i386.rpm
+       Client:                   MySQL-client-standard-5.0.22-0.rhel3.i386.rpm
+       Headers and Libraries:    MySQL-devel-standard-5.0.22-0.rhel3.i386.rpm
      NOTE: Choosing the RPM install of the MySQL components is *strongly*
      recommended. However, if a non-RPM installation of MySQL is chosen,
@@ -476,8 +483,8 @@
   5. In order to build the ODBC Provider, you will need to either
-     a) download and install the Linux ODBC driver Manager, specifically
-        the unixODBC-CORE and unixODBC-devel packages relased by www.unixodbc.org
+     a) download and install the Linux ODBC driver Manager, specifically the
+        unixODBC-CORE and unixODBC-devel packages relased by www.unixodbc.org
            Home Page:
            http://www.unixodbc.org/
@@ -494,72 +501,98 @@
            usr/lib and usr/include
-           The FDO ODBC provider build will automatically locate thee files in this liocation.
+           The FDO ODBC provider build will automatically locate thee files in
+           this liocation.
-     b) install an unixODBC driver such as the EasySofy Oracle ODBC driver. This installation
-        will include the driver libraries as well as the unixODBC manager libraries.
-        If such an installation occurs the manager libraries and headers will not be
-        installed under /usr/lib or usr/include but will be installed in a custom location
-        as specified by the driver RPM package. If this is the case, you will need to set
-        the following FDO environment variable to point to the location of the unixODBC
-        components:
+     b) install an unixODBC driver such as the EasySofy Oracle ODBC driver.
+        This installation will include the driver libraries as well as the
+        unixODBC manager libraries.
+        If such an installation occurs the manager libraries and headers will
+        not be installed under /usr/lib or usr/include but will be installed
+        in a custom location as specified by the driver RPM package. If this
+        is the case, you will need to set the following FDO environment
+        variable to point to the location of the unixODBC components:
            FDOODBC=[unixODBC developer components path]
-  6. OPTIONAL: The FDO build process allows it's documentation to be regenerated.
-     If this is required, install the OpenSource Doxygen documentation generation
-     software.  Doxygen is a documentation system for C++, C, Java, Objective-C,
-     Python, IDL (Corba and Microsoft flavors) and to some extent PHP, C#, and D.
-     Doxygen is often automataically installed on Fedora Core and RedHat systems.
+  6. OPTIONAL: The FDO build process allows it's documentation to be
+     regenerated.  If this is required, install the OpenSource Doxygen
+     documentation generation software.  Doxygen is a documentation system for
+     C++, C, Java, Objective-C, Python, IDL (Corba and Microsoft flavors) and
+     to some extent PHP, C#, and D.  Doxygen is often automataically installed
+     on Fedora Core and RedHat systems.
      To install Doxygen, refer to: http://www.stack.nl/~dimitri/doxygen/
-     The FDO Doxygen documentation generation process will also use the "dot" tool
-     from graphviz 1.5 to generate more advanced diagrams and graphs. Graphviz is an
-     "open-sourced", cross-platform graph drawing toolkit from AT&T and Lucent
-     Bell Labs.
+     The FDO Doxygen documentation generation process will also use the "dot"
+     tool from graphviz 1.5 to generate more advanced diagrams and graphs.
+     Graphviz is an "open-sourced", cross-platform graph drawing toolkit from
+     AT&T and Lucent Bell Labs.
      To install graphviz, refer to: http://www.graphviz.org/
   7. NOTE: To run the unit test, you must set LD_LIBRARY_PATH as follows:
-       export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/fdo-3.2.0/lib
+       export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/fdo-3.3.0/lib
        export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$SDEHOME/lib:$FDOTHIRDPARTY/ESRI/ArcSDEClient91/Linux/lib
-  8. NOTE: Several known problems exist if auto-mounted drives are used as locations
-     for the FDO Linux builds. It is recommended that users not use auto-mounted drives
-     when building FDO.
+  8. NOTE: Several known problems exist if auto-mounted drives are used as
+     locations for the FDO Linux builds. It is recommended that users not use
+     auto-mounted drives when building FDO.
-  9. NOTE: The FDO expression scripts (.y) are not automatially recompiled as a part of the
-     FDO build process. In order to recompile the .y files into their .cpp and .h
-     counterparts, execute the build_parse.sh script.
+  9. NOTE: The FDO expression scripts (.y) are not automatially recompiled as a
+     part of the FDO build process. In order to recompile the .y files into
+     their .cpp and .h counterparts, execute the build_parse.sh script.
- 10. NOTE: Use the [FDO OpenSource]\setenvironment.sh script to assist in setting and
-     maintaing the correct environment settings for the FDO build process.
-     This script can be modifed and used to set the correct environment variables
-     and PATH settings.
+ 10. NOTE: Use the [FDO OpenSource]\setenvironment.sh script to assist in
+     setting and maintaing the correct environment settings for the FDO build
+     process.  This script can be modifed and used to set the correct
+     environment variables and PATH settings.
- 11. The build_thirdparty.sh script is used to build the FDO Thirdparty binaries.
-     The following is a general guideline on how to use the build_thirdparty.bat build script.
-           build_thirdparty.sh [--h] [--a Action] [--m ConfigMakefiles]
+ 11. The build_thirdparty.sh script is used to build the FDO Thirdparty
+     open source components used by the FDO API and the FDO providers.
+     The following is a general guideline on how to use the
+     build_thirdparty.bat build script.
-           Help:            --h[elp]
-           Action:          --a[ction] buildinstall(default),
-                                       build,
-                                       install,
-                                       uninstall,
-                                       clean
-           ConfigMakefiles: --m[akefile] configure(default), noconfigure
+            build_thirdparty.sh [--h]
+                                [--a Action]
+                                [--w WithModule]
+                                [--m ConfigMakefiles]
+            Help:            --h[elp]
+            Action:          --a[ction] buildinstall(default),
+                                        build,
+                                        install,
+                                        uninstall,
+                                        clean
+            WithModule:      --w[ith] all(default),
+                                      fdo,
+                                      sdf,
+                                      wms,
+                                      wfs,
+                                      gdal
+            ConfigMakefiles: --m[akefile] configure(default),
+                                          noconfigure
-           e.g.
+            e.g.
             **** Display help for build_thirdparty.sh
             build_thirdparty --h
             **** Configure, Build and Install all Thirdparty components
             build_thirdparty
+            **** Configure, Build and Install Thirdparty components
+            **** related to the FDO API
+            build_thirdparty --w fdo
+            **** Build and Install Thirdparty components related to
+            **** the FDO API without running the configure script
+            build_thirdparty --w fdo --m noconfigure
+            **** related to the SDF and gdal providers
+            build_thirdparty --w sdf --w gdal --m noconfigure
             **** Uninstall all Thirdparty components
             build_thirdparty --a uninstall
             **** Clean up all Thirdparty components
@@ -567,7 +600,8 @@
  12. The build_linux.sh script is used to build and install the FDO OpenSource
-     libraries. The following is a general guideline on how to use build_linux.sh
+     libraries. The following is a general guideline on how to use
+     build_linux.sh
            build_linux.sh [--h]
@@ -586,7 +620,8 @@
                                        clean
            BuildDocs:       --d[ocs] skip(default), build
-           WithModule:      --w[ith] fdocore(default),
+                                     fdocore,
                                      fdo,
                                      thirdparty,
                                      providers,
More information about the fdo-commits mailing list
